VW Transporter T5 2008 2.5L ABS Coding
GBrewAFC
C?ID=652741
Hi all,
Recently purchsaed a T5 which had an ABS fault, we replaced the pump and bled the brakes. It cleared the other symptoms (bouncing fuel gauge, no speed on speedo etc). Understand we need to 're-code' the pump as it is a replacement. Below is an auto-scan from the van. Is anyone able to help with the coding required to resolve this? I preume / hope fixing this will clear up a few of the other codes relating to sensors etc. I had been doing some searching on the other posts in the forum, they suggested changing the coding to 0000557 or 0000559 both of which were rejected. Part number number for the previous was 10092603103.
Thanks in advance.
George
Saturday,04,July,2026,14:13:22:57739
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.5
VIN: WV1ZZZ7HZ8H046742   License Plate:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H046742   Mileage: 193330km-120129miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DS    HW: 070 906 016 DS
   Component: R5 2,5L EDC  000SG  1585
   Revision: --H05---    Serial number: VWZ7Z0G5754152
   Coding: 0000072
   Shop #: WSC 80093 222 69422
   VCID: 64964E550245A79A4BB-5160
   VINID: 9E606AAAA1D8A886001061C408615A802D
005716 - Please check DTC Memory of Instrument Cluster
               P1654 - 000 -
                    Mileage: 193337 km
                    Voltage: 12.39 V
                    Temperature: 28.8 C
                    Temperature: 42.3 C
                    Temperature: 20.7 C
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Component: (M)ABS MK25E        0103
   Revision: 00H21001
   Coding: 0000092
   Shop #: WSC 02736 790 00000
   VCID: 45D0B3D1A9BFFE92BC5-5140
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 154
                    Mileage: 191427 km
                    Count: 128
                    Count: 4097
                    Count: 199
01324 - Control Module for All Wheel Drive (J492)
                    Fault Frequency: 151
                    Reset counter: 15
                    Mileage: 191427 km
                    Count: 128
                    Count: 4097
                    Count: 8202
Address 08: Auto HVAC        Labels: 7Hx-820-045.clb
   Part No: 7H0 820 045 AM
   Component: CLIMA/AC            0303
   VCID: 70BE3205C6BD0B3A3F3-5140
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000100
   VCID: 74B63E15B2A5371ADBB-5140
00991 - Interior Lights
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0010
   Coding: 13122
   Shop #: WSC 02736
   VCID: 221A084D5DD1E9AAF97-5140
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 T
   Coding: 00413
   Shop #: WSC 00050
   VCID: 3D20DB31C46FB652E45-5140
   WV1ZZZ7HZ8H046742     VWZ7Z0G5754152
00771 - Fuel Level Sensor (G)
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02736
   VCID: 70BE3205C3BD0B3A3F3-5140
02065 - Control Module for Speech Amplifier (J656)
            49-00 - No Communications
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C11 Komfortger t     0004
   Coding: 00021
   Shop #: WSC 02736
   VCID: 323AF80D0D31792A097-4B1E
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 7H0 035 152 H    HW: 7H0 035 152 H
   Component: Radio DE2           0007
   Revision: 00005000    Serial number: VWZ4Z4G4240486
   Coding: 0010200
   VCID: 270C195933F30C82AE9-5140
End----------(Elapsed Time: 06:04, VBatt start/end: 12.5V/12.5V)-----------
------------------------------13 Faults Found------------------------------
Did you read the coding value from the original? If we had done this, we would have insisted on fitting a new genuine full unit 7H0 614 117 but that is that is £2458.
GBrewAFC
C?ID=652741
No we did not. We sent the old pump off to ECU testing for refurbishment but they said they couldn't communicate with the original pump. Supposedly tested from the provider of the pump and to be fair once fitted cleared the other issues so presume to be functional.
Ohh God, not them again.
I come up with 0000552, but my confidence in this is not very high.
That's:
- Diesel engine
- Carvan/Multivan FWD
- No differential lock.
GBrewAFC
C?ID=652741
Thanks Uwe, this worked!
One question, i have been following the YouTube guide from RossTech. When I run through the basic settings the first step, input code 060 just bring up an error message (after entering the security code) any ideas?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Post a fresh Auto-Scan with the proper coding in it and let us see what's up...
GBrewAFC
C?ID=652741
Thanks Sebastian, see below
Monday,06,July,2026,14:08:06:57739
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H046742   Mileage: 193350km-120142miles
   Coding: 0000072
               P1654 - 000 -
                    Mileage: 193358 km
                    Voltage: 12.31 V
                    Temperature: 34.2°C
                    Temperature: 55.8°C
                    Temperature: 28.8°C
   Revision: 00H21001
   Coding: 0000552
   Coding: 0000100
   Coding: 13122
   Shop #: WSC 02736
   Coding: 00413
   Shop #: WSC 00050
   Coding: 00006
   Shop #: WSC 02736
   Component: C11 Komfortgerát     0004
   Coding: 00021
   Shop #: WSC 02736
   Coding: 0010200
End----------(Elapsed Time: 06:01, VBatt start/end: 12.5V/12.5V)-----------
------------------------------3 Faults Found-------------------------------
This is the message I am getting when on basic settings.
What is it you're trying to do in Group 060?
And on what basis did you conclude that 060 is a valid Basic Settings Group in this ABS module?
NEtech
Denmark
C?ID=56995
Have you used [Coding II - 11] or [Security access - 16] > 40168 ?
GBrewAFC
C?ID=652741
I see, thanks for confirming!
First time using these kind of things and certainly more used to working on cars that you definitely can't plug in!
Had been following the guide for MK60 which I presume is a newer version etc and therefore not relevant, thanks again!
Sebastian
Magdeburg, Germany
HN0-nnnnnn
No, it's not because it's newer but because you have an ABS and not an ESP.
  • Agree
