2025 VW Polo - SFD Scan
SMull
Dublin, Ireland
C?ID=413685
Hi Team - scans attached from a 2025 VW Polo using the latest VCDS Beta. Appreciate if this could be reviewed for access to SFD purchase please? Happy to provide additional scans on an ongoing basis.
Friday,03,July,2026,19:11:47:22234
VCDS Version: 26.5.2.1 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260506 DS377.0
VIN: WVWZZZAW6SU061370   License Plate: 212D
Mileage: 3461km-2150mi   Repair Order:
Chassis Type: AW-VW27 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 75 A5
VIN: WVWZZZAW6SU061370   Mileage: 3461km-2150miles
Address 01: Engine (J623-DUSB)       Labels: Redir Fail!
   Part No SW: 05C 906 012 B    HW: 05C 907 309 F
   Component: R3 1.0l TFS   H80 3589
   Revision: KKH80000    CVN: BF3913FB
   Coding: 0111003623040D0800000000000000000000000000000000
   Shop #: WSC 00000 648 00255
   ASAM Dataset: EV_ECM10TFS01105C906012B 001003
   ROD: EV_ECM10TFS01105C906012B_VW27.rod
   VCID: 1C61D048C62EAA4A2AA-8048-R SFD+SFD2 [x]
   VINID: 9E69EAAAA4671A39401810C700E5F2A491
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 DB    HW: 2Q0 614 517 CB
   Component: ESC_Base_vFGS H20 0140
   Serial number: BPA085120325015 Dataset Number: V03935441NA 0001
   Coding: 090A0152B9FE9B
   ASAM Dataset: EV_BrakeBoschMQBA0UNECE 013017
   ROD: EV_BrakeBoschMQBA0UNECE_VW27.rod
   VCID: 71BFD1FC712C772229C-8024-R SFD+SFD2 [x]
0631 - TPMS Warning
          C102D F5 [00100000] - Tire Pressure too Low
          [RKA library detected Pressure Warning Error]
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G2 820 045 S    HW: 2G2 820 045 S
   Component: SG_AC_Manuell H70 0701
   Coding: 012100000800010001000800020000000010000000000000000000000000
   Shop #: WSC 31414 790 00200
   ASAM Dataset: EV_ACManuePrehMQBA0 001013
   ROD: EV_ACManuePrehMQBA0.rod
   VCID: 313F11FCB1AC372269C-8064-R
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V1.clb
   Part No SW: 2Q0 937 090 G    HW: 2Q0 937 090 G
   Component: BCM A0 Std+   H16 0995
   Serial number: 00202502703876 Dataset Number: V03935443UX 0001
   ASAM Dataset: EV_BCMA0 210001
   ROD: EV_BCMA0_209_VW27.rod
   VCID: 363522E058C2101A3CE-8062-R SFD+SFD2 [x]
   Driver door control module:
   Subsystem 1 - Part No SW: 2Q2 959 405 G    HW: 2Q2 959 163 F
   Component: FHSG_DRV  003 0004
   Serial number: 00000000000088603798
   Coding: 1F0007
   Front passenger door control module:
   Subsystem 2 - Part No SW: 2Q2 959 406 G    HW: 2Q2 959 164 F
   Component: FHSG_PSG  003 0004
   Serial number: 00000000000088946749
   Coding: 058007
   Subsystem 3 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000089283748
   Coding: 1F0000
   Subsystem 4 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000088976290
   Coding: 070000
   Part No SW: 5QA 919 294 L    HW: 5QA 919 294
   Component: PDC 8 Kanal   H12 0083
   Serial number: 000150058625069 Dataset Number: V03935440VF 0001
   Coding: 8451151001
   ASAM Dataset: EV_EPHVA18AU3700000 010058
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 55F7856CE5843B02D54-8000-R
   Part No SW: 2Q0 907 567 C    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H04 0541
   Dataset Number: V03935443EK 0001
   Coding: 2802600208FF8748949C812500508700000000000000008004
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_VW27.rod
   VCID: 38292CD852D6E66A2E2-806C-R SFD+SFD2 [x]
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 BL    HW: 2Q0 959 655 BL
   Component: VW23Airbag    040 0719
   Revision: --------    Dataset Number: V03935435UG 0001
   Coding: 88CCCCC0800000035C5400CF008C40FC0065
   ASAM Dataset: EV_AirbaVW23BPAVW27X 001012
   ROD: EV_AirbaVW23BPAVW27X.rod
   VCID: 08499C1862B656EA9E2-805C-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: -----------    HW: 442 060 903 25
   Serial number: 3577Y53B116DF26502B8
   Subsystem 2 - Part No SW: -----------    HW: 442 060 903 25
   Serial number: 3587Y53B116DF2640140
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 703 25
   Serial number: 3517732C718B8C5322AN
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 502 25
   Serial number: 3527739029F52A46865M
   Subsystem 5 - Part No SW: -----------    HW: 442 131 612 24
   Component: FrontSensor_D  290 118A
   Serial number: 355AG33D03E56A43887/
   Part No SW: 2GP 920 310 C    HW: 2GP 920 310 C
   Component: KOMBI         090 6856
   Coding: 2424000061840008018822031000000000200420
   ASAM Dataset: EV_DashBoardJCIMQBAB 013002
   ROD: EV_DashBoardJCIMQBAB_013.rod
   VCID: 3B2333D463E0CD72C30-806E-R SFD+SFD2 [x]
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 12
                    Mileage: 3352 km
                    Date: 2026.06.22
                    Time: 17:26:49
8667137 - Mileage
          U1679 00 [00001000] - Calculation Faulty
          [Berechnungsgrundlage Wegstrecke fehlerhaft]
                    Reset counter: 31
                    Mileage: 12 km
                    Date: 2025.08.01
                    Time: 12:45:48
   Part No SW: 3Q0 907 530 BF    HW: 3Q0 907 530 BB
   Component: GW 2023 CLA   550 5585
   Revision: --------    Serial number: CU5SIB190325009 Dataset Number: V03935444AK 0001
   Coding: 0000808D0F00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
   GVL: 3D00000000004080800000004800000000000000000000000000000000000044
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW27.rod
   VCID: 74B1D8E80E3E420AC2A-8020 SFD+SFD2 [x]
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 105D9566
   Subsystem 3 - Part No SW: 3G0 959 442 AA    HW: 3G0 959 442 AA
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440036264249130
2170900 - No Communication with Instrument Cluster
          U0155 00 [00100000] - -
                    Fault Frequency: 0
                    Reset counter: 0
8417280 - Diagnostic Filter
          U17A0 00 [00100000] - Not Activated
          [Filter_is_not_active]
                    Fault Frequency: 0
                    Reset counter: 0
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 AM    HW: 2Q2 909 144 AD
   Component: TRW_G4L_MQBA0 623 6064
   Serial number: 04867662CB4S044 Dataset Number: V03935465XK 0001
   Coding: 010000000100000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LClass 016018
   ROD: EV_SteerAssisTRWG4LClass.rod
   VCID: 7EA5FAC03072185AA4E-802A-R SFD+SFD2 [x]
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 2G7 035 869 A    HW: 2G7 035 869 A
   Component: MU-E-D-EU     072 0161
   Serial number: VWZAZ2D0625864  Dataset Number: V03935450YY 0001
   Coding: 22700008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIGPMQB 001001
   ROD: EV_MUEIGPMQB_VW27.rod
   VCID: 303914F8BAA63E2A662-8064-R SFD+SFD2 [x]
   Part No SW: 2GA 035 284 A    HW: 2GA 035 284
   Component: OCUClas2023_H H11 0619
   Serial number: 0000000501VIKE4 Dataset Number: V03935454PE 0001
   Coding: 02010500000100210000010013000607111112111012100010
   ASAM Dataset: EV_OCUClass2023 001060
   ROD: EV_OCUClass2023.rod
   VCID: 313F11FCB1AC372269C-8064-R SFD+SFD2 [x]
   Part No SW: 2Q0 980 653 H    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1602
   Serial number: EF1689304250770 Dataset Number: V03935442FK 0001
   Coding: 0000081001404020409E08001020000000018048600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007058
   VCID: 3A2D36D06CDAF47AD86-806E-R
End----------(Elapsed Time: 01:12, VBatt start/end: 12.1V/12.0V)-----------
------------------------------5 Faults Found-------------------------------
SMull
Dublin, Ireland
C?ID=413685
Disregard
