2024 Skoda Octavia NX - request for exception (module 5F unreachable after repeated jump-starts)
Amedeo
Romania - Rm.Valcea
C?ID=14228
I've been using VCDS/VAG-COM for over 15 years, currently working on a client's vehicle affected by what appears to be an SFD-related communication issue.
Vehicle: Skoda Octavia NX, VIN TMBAJ7NXXNY096941, 143,433 km
Software: VCDS Beta 26.5.2.1 (x64), Data version 20260506 DS377.0
Interface: HEX-NET, serial HN2-006304
Context: The vehicle's battery went completely dead 4-5 times, and was jump-started each time. After the last jump-start, the fault codes below appeared, and the infotainment/navigation system entered a reboot loop.
Full auto-scan attached (before any unlock attempt). 8 modules show SFD protection (03, 09, 15, 17, 19, 23, 75, and 5F). Module 5F (Information Electronics 1) is completely unreachable ("Cannot be reached"), and this cascades into communication/databus/ethernet errors across modules 01, 08, 10, 13, 17, 19, 23, 75, and A5.
I'd like to request consideration for an exception to place a paid SFD Service order (Professional/unlimited VIN), so I can properly diagnose whether this is an SFD lock or an actual hardware/communication fault caused by the voltage drops during jump-starting. I'm happy to post before/after scans and the SFD session log as required.
Amedeo
Romania - Rm.Valcea
C?ID=14228
Friday,03,July,2026,11:47:22:12012
VCDS Version: 26.5.2.1 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260506 DS377.0
Dealer/Shop Name: AMEDEO 076.074.575
Workshop Code: 599 10203 012134
VIN: TMBAJ7NXXNY096941   License Plate: VL42DNA
Mileage: 143433km-89125mi   Repair Order: Madalin - 0743888459
Chassis Type: NX-SK38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6C 75 A5
          BB BC 811E 811F 8120 8121 C002 C003
VIN: TMBAJ7NXXNY096941   Mileage: 143433km-89125miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DTTC)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 022 KT    HW: 05L 907 309 AA
   Component: R4 2.0l TDI   H80 1998
   Revision: ECH80---    Dataset Number: V03935358XK 0001 CVN: 48D95515914A6D2022E7CED8914A6D2043FB2DAA
   Coding: 012508320364050970080000000000000000000000000000
   Shop #: WSC 31000 790 00270
   ASAM Dataset: EV_ECM20TDI01105L906022KT 007001
   ROD: EV_ECM20TDI01105L906022DE_007_VW38.rod
   VCID: 835865DD9B9776D24B0-80D6
   VINID: 91D4916877A8A1EA4024624404DE3158BC
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1       H13 0110
   Serial number: 20220224060604070152
23765 - Control unit for information electronics 1
          U1054 00 [00101111] - No Communication
          [Information electronics control module 1No Communication]
                    Fault Frequency: 204
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:15:17
                    Engine speed: 813.50 /min
                    Normed load value: 34.1 %
                    Coolant temperature: 94 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.160 V
                    selected gear-Bits 0-7: 0
   Part No SW: 0GC 906 555 K    HW: 0GC 300 047
   Component: GSG DQ381     H06 5080
   CVN: 8FC55133
   ASAM Dataset: EV_TCMDQ381062 001020
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: C3D8A5DDDB17B6D20B0-8096
   Subsystem 1 - Part No SW: 5WA 713 033 BB    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20220309000080744319
   Subsystem 2 - Part No SW: 5E4 713 203     HW: 5E4 713 203
   Component: ZSB_SB_mono    H02 0025
   Serial number: 22 020 0630 L 1 U1B9
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810600003922689
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BL    HW: 5WA 614 517 N
   Component: ESC           H13 0133
   Serial number: 60482000000667  Dataset Number: V03935351BG 0001 CVN: 01B7675E
   Coding: 34072CA422294472528050040AC461866DB658F55AC8670821BCA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 9378559DEBF7E652FB0-80C6 SFD [x]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 J    HW: 5WA 959 436 J
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935347FV 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: DBE87DBD43A7EE12630-808E
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 AC    HW: 5WA 907 727 AC
   Component: Climatronic   H02 0440
   Serial number: --------------- Dataset Number: V03935336HW 0001
   Coding: 101010010211120000100010101011110000112100100000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005069
   ROD: EV_ACClimaBHBVW38X_SK38.rod
   VCID: 91745F95D1EB1442C9C-80C4
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000000960495
   Interior temperature sensor:
   Subsystem 2 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002140322122123512
459025 - Databus
          U1121 00 [00101111] - Missing Message
          [Databus missing message radio]
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [01100101] - -
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 20:49:17
                    Voltage terminal 30: 12.60 V
                    Compressor shut-off condition: Engine running time too short: engine start not detected by CAN
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 AE    HW: 5WA 937 086 L
   Component: BCM37w_M028 0175
   Serial number: BXJ53F100422940 Dataset Number: V03935372UU 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_SK38.rod
   VCID: 947A5681EEF9E16AE2A-80C0 SFD [x]
   Subsystem 1 - Part No SW: 5E4 955 119 A    HW: 5E4 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: J400FRWISCH    067 0084
   Serial number: 907453F0402206400688
   Component: G397_RLFSS     H06 0004
   Serial number: 43287277X81A955555B0
   Subsystem 3 - Part No SW: 5E4 941 501 A    HW: 5E4 941 501
   Component: E1-LTM         H30 0550
   Serial number: 00000000000000000241
   Subsystem 4 - Part No SW: 5E3 925 200 F    HW: 5E3 925 200 F
   Component: DiETa          H04 0002
   Serial number: 01557VD2000CS
   Subsystem 5 - Part No SW: 5E3 959 569 A    HW: 5E3 959 569 A
   Component: DACHKONSOLE    101 0104
   Serial number: 000000092413VKG00300
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 EP    HW: 5Q1 953 549 F
   Serial number: 00000024022204400507
   Left taillight 1:
   Subsystem 7 - Part No SW: 5E3 945 207 A    HW: 5E3 945 207 A
   Component: SHL_li1        005 1214
   Serial number: ABMRO128012200041511
   Left taillight 2:
   Subsystem 8 - Part No SW: 5E6 945 307 A    HW: 5E6 945 307 A
   Component: SHL_li2        005 1214
   Serial number: ABMRO111032200041118
   Right taillight 1:
   Subsystem 9 - Part No SW: 5E3 945 208 A    HW: 5E3 945 208 A
   Component: SHL_re1        005 1214
   Serial number: ABMRO121022200042469
   Right taillight 2:
   Subsystem 10 - Part No SW: 5E6 945 308 A    HW: 5E6 945 308 A
   Component: SHL_re2        005 1214
   Serial number: ABMRO110022200051672
   Part No SW: 5WA 919 294 C    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0577
   Serial number: 000006042294560 Dataset Number: V03935348FY 0001
   Coding: 0040010011
   ASAM Dataset: EV_EPHBO18VW3800000 002029
   ROD: EV_EPHBO18VW3800000_AU38.rod
   VCID: D2F69099146D2F5AB06-8086
1114113 - Driver Assistance Systems Audio Output
          B1AE2 F0 [00101111] - Infotainment System; Implausible Signal
          [sound_ouput_MIB_totally_disturbed]
                    Mileage: 143433 km
                    Date: 2026.06.30
                    Time: 18:20:36
13638928 - Databus
          [MIB - MainUnit_01 - kein Signal/keine Kommunikation]
                    Mileage: 143433 km
                    Date: 2026.06.30
                    Time: 18:20:36
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Dataset Number: V03935354QE 0001
   Coding: 0903007D0077404512474000004040C54E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: CDCC83E50D5370A2ED4-8098
1230 - Databus
          [FAULT_TIMEOUT_MAINUNIT_01]
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:58
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 DL    HW: 1EA 959 655 DL
   Component: VW40Airbag    010 0176
   Serial number: W100SkE02D4     Dataset Number: V03935354YD 0001
   Coding: 98CC000000C0C000000000000000000050540000205400004000F68000120065
   Shop #: WSC 31000 074 00352
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_VW41.rod
   VCID: 8E4E44E9C0D50BBAD4E-80DA SFD [x]
   Subsystem 1 - Part No SW: -----------    HW: 440 002 202 22
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ0000002A851BD5F
   Subsystem 2 - Part No SW: -----------    HW: 440 002 202 22
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000F5951BD5P
   Subsystem 3 - Part No SW: -----------    HW: 440 000 104 22
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJAB07487D683500-
   Subsystem 4 - Part No SW: -----------    HW: 440 000 104 22
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJAB081A9E417D000
   Subsystem 5 - Part No SW: -----------    HW: 440 002 707 21
   Component: FrontSensor_D  00A 014A
   Serial number: 355CJ9900ABA0153D00T
   Part No SW: 5E3 920 770 B    HW: 5E3 920 770 B
   Component: KOMBI         201 5370
   Dataset Number: V03935369QW 0001
   Coding: 04A4004063840008018462032000080800301400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003033
   ROD: EV_DashBoardVDDMQB37W_003_SK38.rod
   VCID: A80212714271758A3E2-80FC SFD [x]
16777018 - Control unit for information electronics 1
          U1054 00 [00001001] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
   Part No SW: 5WA 907 530 Q    HW: 5WA 907 530 G
   Component: GW2020 High   756 7300
   Revision: --------    Serial number: 260160902151243 Dataset Number: V03935355TE 0001
   Coding: 0000838D0700000000000000010303325301600902000300030100000001010100000000000000000000000000000000
   GVL: 3D0000000208408C80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 005011
   ROD: EV_GatewMQB2020_004_SK38.rod
   VCID: D6FE6C893885337A5CE-8082 SFD [x]
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 1368879305
   Subsystem 3 - Part No SW: 5E3 919 719 Q    HW: 5E3 919 719 Q
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440061091223099
7 Faults Found:
2175091 - Control unit for information electronics 1
          [Information_electronics_control_module_1_no_communication]
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:14:52
1049253 - Ethernet Databus Branch 5
          U1230 00 [00101111] - No Communication
          [Ethernet_databus_no_communication_branch_5_/_port_6]
                    Fault Frequency: 18
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:15:30
2498675 - Ethernet Module for Information Electronics 1
          U1645 00 [00101000] - No Communication
          [Information_electronics_control_module_1_no_communication_vlan]
                    Reset counter: 27
                    Mileage: 143181 km
                    Date: 2026.06.07
                    Time: 17:32:18
8397571 - LV Energy Management
          B1802 F1 [00101000] - Warning Triggered
                    Fault Frequency: 39
                    Reset counter: 37
                    Mileage: 143314 km
                    Date: 2026.06.25
                    Time: 18:07:46
                    23
8471553 - Function Restricted due to Missing Message(s)
          U1111 00 [00101000] - -
          [error_communication_Headunit_PaCo]
                    Fault Frequency: 25
                    Mileage: 143145 km
                    Date: 2026.06.06
                    Time: 15:35:41
          B184C 00 [00100000] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Fault Frequency: 0
                    Reset counter: 0
8482819 - Activatable Functions
          B18D3 F3 [01101101] - Faulty Vehicle Configuration
          [Fs_id_configuration_error]
                    Mileage: 143153 km
                    Date: 2026.06.06
                    Time: 19:07:31
   Part No SW: 5WA 909 059 Q    HW: 3Q0 909 059 C
   Component: EBKV          H09 0309
   Serial number: BPA085180222013 Dataset Number: V03935354NE 0001
   Coding: 1002C100230000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: DEEE74A950B5FB3A04E-808A SFD [x]
172400 - System Voltage
          P0562 00 [00100000] - Too Low
          [PSCUnderVoltageLevel1]
1024368 - Brake Booster
          C1187 F6 [00100000] - Function Limitation due to External Brake Pressure Build-Up
          [ActiveRestrictionDetected]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000098149011 Dataset Number: V03935308NF 0001
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: B236F01974AD0F5A906-80E6
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000459589293  Dataset Number: V03935365VU 0001
   Coding: 001C0120D000020000001120
   Shop #: WSC 31000 790 00352
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000058878969
   Coding: 110200
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1040
   Serial number: 01037468 Dataset Number: V03935362VR 0001
   Coding: 0000000000000000000002010100010000000101000101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000461357778  Dataset Number: V03935365VZ 0001
   VCID: D1F49F95116B544289C-8084
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000058998964
   Coding: 090200
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20050322010 Dataset Number: V03935343SU 0001
   Coding: 03033260843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   Part No SW: 5WA 035 284 J    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H12 0311
   Serial number: 0000000203VITD6 Dataset Number: V03935361QW 0001
   Coding: 033810109069A8A09005460061052607
   ASAM Dataset: EV_OCU3HMQB37W 002029
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: CDCC83E50D5370A2ED4-8098 SFD [x]
7248 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:59
                    Voltage terminal 30: 12.7 V
9455892 - Mute switch radio
          B1049 14 [00001001] - Open or Short to Ground
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:56
   Part No SW: 5WA 980 653 C    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3302
   Serial number: E82645704221110 Dataset Number: V03935360CJ 0001
   Coding: 0002088821484040509E00001020002001018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_SK38.rod
   VCID: CFF099ED075F42B29F8-809A
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
1122626 - Databus
          [Timeout_Mainunit_01]
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: C7C0B1CDEF2F9AF2D78-8092
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:33, VBatt start/end: 12.8V/12.8V)-----------
------------------------------22 Faults Found------------------------------
Amedeo
Romania - Rm.Valcea
C?ID=14228
I also tried placing the SFD Service order directly through the store form, using the Beta license serial for this interface (HN2-xxxxxx), and received this message:
"SFD Service is currently not available for this Interface - Serial Number [Redacted]."
Could you please advise how I can proceed?
Amedeo
Romania - Rm.Valcea
C?ID=14228
Here are the Control Module Maps (Measuring Values) for this vehicle, generated with Alligator. These were captured without SFD unlocked (locked state), since I don't have SFD service active on this interface yet. Posting in 3 parts due to size.
If needed for comparison, I'm happy to post the unlocked version as well once I have SFD access on this interface.AutoScan: TMBAJ7NXXNY096941
   Radiator shutter:
          U1054 00 {00101111} - No Communication
          {Information electronics control module 1No Communication}
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:15:17
   CVN: 8FC55133
   VCID: 9378559DEBF7E652FB0-80C6 SFD {x}
   Air quality sensor:
459025 - Databus
          U1121 00 {00101111} - Missing Message
          {Databus missing message radio}
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
          B10F0 00 {01100101} - -
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 20:49:17
   VCID: 947A5681EEF9E16AE2A-80C0 SFD {x}
   Left taillight 1:
   Left taillight 2:
   Right taillight 1:
   Right taillight 2:
   Coding: 0040010011
          B1AE2 F0 {00101111} - Infotainment System; Implausible Signal
          {sound_ouput_MIB_totally_disturbed}
                    Mileage: 143433 km
                    Date: 2026.06.30
                    Time: 18:20:36
13638928 - Databus
          {MIB - MainUnit_01 - kein Signal/keine Kommunikation}
                    Mileage: 143433 km
                    Date: 2026.06.30
                    Time: 18:20:36
1230 - Databus
          {FAULT_TIMEOUT_MAINUNIT_01}
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:58
   VCID: 8E4E44E9C0D50BBAD4E-80DA SFD {x}
   VCID: A80212714271758A3E2-80FC SFD {x}
          U1054 00 {00001001} - No Communication
          {Audio_0x31 communication error bap_error_timeout heartbeat}
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
          {TEL_0x28 communication error bap_error_timeout heartbeat}
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
          {NAV_SD_0x32 communication error bap_error_timeout heartbeat}
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
   VCID: D6FE6C893885337A5CE-8082 SFD {x}
   Generator:
7 Faults Found:
          {Information_electronics_control_module_1_no_communication}
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:14:52
          U1230 00 {00101111} - No Communication
          {Ethernet_databus_no_communication_branch_5_/_port_6}
                    Fault Frequency: 18
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:15:30
          U1645 00 {00101000} - No Communication
          {Information_electronics_control_module_1_no_communication_vlan}
                    Reset counter: 27
                    Mileage: 143181 km
                    Date: 2026.06.07
                    Time: 17:32:18
          B1802 F1 {00101000} - Warning Triggered
                    Fault Frequency: 39
                    Reset counter: 37
                    Mileage: 143314 km
                    Date: 2026.06.25
                    Time: 18:07:46
                    23
          U1111 00 {00101000} - -
          {error_communication_Headunit_PaCo}
                    Fault Frequency: 25
                    Mileage: 143145 km
                    Date: 2026.06.06
                    Time: 15:35:41
          B184C 00 {00100000} - -
          {Unlock_protection_of_vehicle_diagnosis_active}
                    Fault Frequency: 0
                    Reset counter: 0
          B18D3 F3 {01101101} - Faulty Vehicle Configuration
          {Fs_id_configuration_error}
                    Mileage: 143153 km
                    Date: 2026.06.06
                    Time: 19:07:31
   VCID: DEEE74A950B5FB3A04E-808A SFD {x}
          P0562 00 {00100000} - Too Low
          {PSCUnderVoltageLevel1}
          C1187 F6 {00100000} - Function Limitation due to External Brake Pressure Build-Up
          {ActiveRestrictionDetected}
   Coding: 110200
   Coding: 090200
   VCID: CDCC83E50D5370A2ED4-8098 SFD {x}
          U1111 00 {00001001} - -
          {InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful}
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:59
          B1049 14 {00001001} - Open or Short to Ground
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:56
1122664 - Databus
          U1121 00 {00001001} - Missing Message
          {TIMEOUT_PSD_04}
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
1122626 - Databus
          {Timeout_Mainunit_01}
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
VCDS Beta 26.5.2:  SRI Reset-SRI2.CLB
Control Module Part Number: 5E3 920 770 B       Labels:  *None-SRI2
Component:KOMBI         201 5370, Coding:04A4004063840008018462032000080800301400
Channel        Description                                                 	Current val.                                                	New val.
IDE12960-Resetting oil service        ESI: Service Status                                         	no warning                                                  	---
IDE12964-Oil: driven distance since last oil service                                                	ESI: Distance SINCE last Oil Service                        	5800 km                                                     	---
IDE12965-Oil: time since last oil service                                                           	ESI: Time SINCE last Oil Service                            	154 d                                                       	---
IDE12966-Oil: min distance until next oil service (flexible interval)                               	ESI: Minimum Distance to Oil Service(s)                     	15000 km                                                    	---
IDE12967-Oil: max. distance until next oil service (flexible interval)                              	ESI: Maximum Distance to Oil Service(s)                     	30000 km                                                    	---
IDE12968-Oil: min time until next oil service (flexible interval)                                   	ESI: Minimum Time to Oil Service(s)                         	365 d                                                       	---
IDE12969-Oil: max time until next oil service (flexible interval)                                   	ESI: Maximum Time to Oil Service(s)                         	730 d                                                       	---
IDE12980-Inspection: distance driven since the last inspection                                      	FIX: Distance SINCE last mileage-dependent Inspection       	5800 km                                                     	---
IDE12981-Inspection: time since the last inspection                                                 	FIX: Time SINCE last time-dependent Inspection              	154 d                                                       	---
IDE12978-Inspection: distance until next inspection                                                 	FIX: Max. Distance to mileage-dependent Inspection(s)       	1500000 km                                                  	---
IDE12979-Inspection: time until next inspection                                                     	FIX: Max. Time to time-dependent Inspection(s)              	365 d                                                       	---
IDE12970-Oil: distance until next oil service (fixed interval)                                      	SIA/SID: Maximum Distance to Service/Inspection             	15000 km                                                    	---
IDE12971-Oil: time until next oil service (fixed interval)                                          	SIA/SID: Maximum Time to Service/Inspection                 	365 d                                                       	---
*IDE12972-Oil: theoretical service interval                                                         	ESI/INFO: Theoretical Oil Service Interval                  	12500.00 km                                                 	---
*IDE12975-Oil: remaining driving distance                                                           	ESI/INFO: Remaining Distance to Oil Service                 	9170 km                                                     	---
*IDE12976-Oil: remaining running time        ESI/INFO: Remaining Time to Oil Service                     	211 d                                                       	---
*IDE12973-Oil: service interval exceeded in km                                                      	ESI/INFO: Oil Service Exceedance                            	0 km                                                        	---
*IDE12974-Oil service interval exceeded in days                                                     	ESI/INFO: Oil Service Exceedance                            	0 d                                                         	---
IDE00819-Day counter        INFO: Day Counter (since Delivery Inspection)               	1517 d                                                      	---
IDE00301-Distance        INFO: Vehicle/Odomoter Mileage                              	143433 km                                                   	---
IDE11086-Service notification        Service Notification (Early Warning/Prediction)             	30 d                                                        	---
IDE12962-Oil: soot entry        ESI/INFO: Soot Entry                                        	23100 km                                                    	---
IDE12963-Oil: thermal loading        ESI/INFO: Thermal Load                                      	4300 km                                                     	---
IDE12961-Oil quality        ESI/INFO: Oil Quality                                       	poor oil quality                                            	---
blockmap-01-05L-906-022-KT_TMBAJ7NXXNY096941-20260703-1348.CSV
;SW:05L-906-022-KT   HW:05L-907-309-AA ---  01: Engine
;Component:R4 2.0l TDI   H80 1998, Coding:012508320364050970080000000000000000000000000000
;EV_ECM20TDI01105L906022KT,007001,EV_ECM20TDI01105L906022DE_007_VW38.rod
;Friday,03,July,2026,13:48:01:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: 835865DD9B9776D24B0-80D6
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),TMBAJ7NXXNY096941,
IDE00019,Voltage terminal 30,12.360, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,0, /min
IDE00022,Transmission input speed,16383.5, /min
IDE00025,Coolant temperature,28, °C
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),13.7, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator pedal position,14.1, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,-500.0, Nm
IDE00102,Control Module temperature,34.5, °C
IDE00151,Oil fill level,77.844, mm
IDE00172,A/C compressor torque,0.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00190,Charge air pressure: specified value,674, hPa
IDE00194,Coolant temperature at radiator output: specified value,88.0, °C
IDE00196,Engine oil temperature,28.4, °C
IDE00202,Low fuel pressure: specified value,5.000, bar
IDE00304,Fuel level,29.00, l
IDE00347,Air mass: actual value:,0.00, g/s
IDE00348,Intake air temperature,30, °C
IDE00349,Throttle valve position: normed,0.0, %
IDE00351,Main injection: start of activation,0.00, °
IDE00352,Main injection: duration of activation,0.0, µs
IDE00353,Engine start: start quantity,0.00, mg/stroke
IDE00354,Engine start: start synchronization,EPM_MODE_WAIT,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00358,Limitation: torque,185.0, Nm
IDE00359,Limitation: smoke,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00363-ENG188621,Glow status-Bits 0-7,80,
IDE00363-ENG188621,Glow status-Bits 0-7,0,
IDE00364,Pre-glow time,0, ms
IDE00365,Injection quantity deviation cylinder 1,0.00, mg/stroke
IDE00366,Injection quantity deviation cylinder 2,0.00, mg/stroke
IDE00367,Injection quantity deviation cylinder 3,0.00, mg/stroke
IDE00368,Injection quantity deviation cylinder 4,0.00, mg/stroke
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.02, %
IDE00383,Pre-injection 1: activation start,0.00, °
IDE00384,Pre-injection 1: activation duration,0.0, µs
IDE00385,Pre-injection 2: activation start,0.00, °
IDE00386,Pre-injection 2: activation duration,0.0, µs
IDE00387,Post-injection 1: activation start,0.00, °
IDE00388,Post-injection 1: activation duration,0.0, µs
IDE00389,Post-injection 2: activation start,0.00, °
IDE00390,Post-injection 2: activation duration,0.0, µs
IDE00394,Camshaft position: start of phase window,123.02, °
IDE00395,Camshaft position: end of phase window,304.01, °
IDE00399,Regulation factor: total,1.000,
IDE00405,Crankshaft speed (RPM),0.0, /min
IDE00406,Camshaft RPM,0.0, /min
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413,Starter control: Interlock- or P/N-signal,Correct result,
IDE00413-ENG127289,Starter control: Interlock- or P/N-signal-Test_Program_B TRUE UBYTE,1,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,0,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00420,Service regeneration: current duration,0.0, s
IDE00430-ENG188621,Particle filter: field regeneration request status-Bits 0-7,0,
IDE00432,Particle filter: time since last regeneration,7.295, H
IDE00434,Particle filter: soot mass calculated,21.49, g
IDE00435,Particle filter: soot mass measured,2.89, g
IDE00436,Particle filter: kilometers since last regeneration,134.2, km
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00451,Currently running routine,Unknown (0)
IDE00472,Mean injection quantity,0.00, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,28, °C
IDE00583,Throttle valve specified value,0.0, %
IDE00584,Distance driven since erasing DTC memory,302, km
IDE00588,Fuel tank fill level,63.9, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00603,Number of driving cycles since erasing DTC memory,18,
IDE00608,Fuel type,Diesel,
IDE00773,Terminal 15 status via CAN,1,
IDE00784,Current test step,0,
IDE01076,Time since ignition off,2676, s
IDE01260,Generator performance,0, W
IDE01378,Fuel high pressure: control deviation,389100, hPa
IDE01381,Pre-injection 3: activation duration,0.0, µs
IDE01382,Post-injection 3: activation start,0.00, °
IDE01383,Post-injection 3: activation duration,0.0, µs
IDE01387,Injector 1: rail pressure calibration point 1,0.00, µs
IDE01388,Injector 1: rail pressure calibration point 2,0.00, µs
IDE01389,Injector 1: rail pressure calibration point 3,0.00, µs
IDE01390,Injector 2: rail pressure calibration point 1,0.00, µs
IDE01391,Injector 2: rail pressure calibration point 2,0.00, µs
IDE01392,Injector 2: rail pressure calibration point 3,0.00, µs
IDE01393,Injector 3: rail pressure calibration point 1,0.00, µs
IDE01394,Injector 3: rail pressure calibration point 2,0.00, µs
IDE01395,Injector 3: rail pressure calibration point 3,0.00, µs
IDE01396,Injector 4: rail pressure calibration point 1,0.00, µs
IDE01397,Injector 4: rail pressure calibration point 2,0.00, µs
IDE01398,Injector 4: rail pressure calibration point 3,0.00, µs
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01407,Particle filter: fuel consumption since last regeneration,9.85, l
IDE01410,Charge limit over-charge,50.00, g
IDE01834,Battery voltage,12360, mV
IDE01880,Accelerator pedal position 2,14.5, %
IDE01922,Vehicle distance driven,143433, km
IDE02211,Brake pressure,0.12, MPa
IDE02228,Fuel pressure regulator valve: specified value rail pressure,0, hPa
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02558-ENG100471,High pressure test: cancel condition-Param 1 Tst Abort Fid,-,
IDE02558-ENG100389,High pressure test: cancel condition-Param 10 Tst Abort Inj Quant,-,
IDE02558-ENG103668,High pressure test: cancel condition-Param 11 Tst Abort Eng Speed,-,
IDE02558-ENG102582,High pressure test: cancel condition-Param 12 Tst Abort Rail Pres High,-,
IDE02558-ENG104255,High pressure test: cancel condition-Param 13 Tst Abort Rail Pres Low,-,
IDE02558-ENG163334,High pressure test: cancel condition-Param 14 Tst Abort Acctlst Nez,-,
IDE02558-ENG163335,High pressure test: cancel condition-Param 15 Tst Abort Covehtrqacs High,-,
IDE02558-ENG100876,High pressure test: cancel condition-Param 16 Undefined Abort Reason,Undefined Abort Reason,
IDE02558-ENG101560,High pressure test: cancel condition-Param 2 Tst Abort Clutch,-,
IDE02558-ENG102266,High pressure test: cancel condition-Param 3 Tst Abort Speed Nez,-,
IDE02558-ENG100337,High pressure test: cancel condition-Param 4 Tst Abort Brake Press,-,
IDE02558-ENG101825,High pressure test: cancel condition-Param 5 Tst Abort Thrpedal Press,-,
IDE02558-ENG103033,High pressure test: cancel condition-Param 6 Tst Abort Loop Ctl,-,
IDE02558-ENG103871,High pressure test: cancel condition-Param 7 Tst Abort Eng Idle Speed,-,
IDE02558-ENG102719,High pressure test: cancel condition-Param 8 Tst Abort Eng Cold,-,
IDE02558-ENG99486,High pressure test: cancel condition-Param 9 Tst Abort Pf Regen,-,
IDE02559-ENG104262,High pressure test result-Param 1 Rail st Up Hp Tst{0},0,
IDE02559-ENG104127,High pressure test result-Param 10 Rail ti Up Hp Tst{2},0, ms
IDE02559-ENG100303,High pressure test result-Param 11 Rail st Dwn Hp Tst{2},0,
IDE02559-ENG102830,High pressure test result-Param 12 Rail ti Dwn Hp Tst{2},0, ms
IDE02559-ENG100056,High pressure test result-Param 13 Rail st Up Hp Tst{3},0,
IDE02559-ENG102683,High pressure test result-Param 14 Rail ti Up Hp Tst{3},0, ms
IDE02559-ENG104012,High pressure test result-Param 15 Rail st Dwn Hp Tst{3},0,
IDE02559-ENG100728,High pressure test result-Param 16 Rail ti Dwn Hp Tst{3},0, ms
IDE02559-ENG103970,High pressure test result-Param 17 Rail ti Dwn Hp Tst{4},0, ms
IDE02559-ENG101422,High pressure test result-Param 18 Rail ti Dwn Hp Tst{5},0, ms
IDE02559-ENG103957,High pressure test result-Param 19 Rail st Dwn Hp Tst{4},0,
IDE02559-ENG100031,High pressure test result-Param 2 Rail ti Up Hp Tst{0},0, ms
IDE02559-ENG101860,High pressure test result-Param 20 Rail ti Dwn Hp Tst{6},0, ms
IDE02559-ENG101478,High pressure test result-Param 21 Rail ti Drop5 Stp Hp Tst{0},0, ms
IDE02559-ENG101370,High pressure test result-Param 22 Rail ti Drop5 Stp Hp Tst{1},0, ms
IDE02559-ENG99268,High pressure test result-Param 23 Rail ti Drop5 Stp Hp Tst{2},0, ms
IDE02559-ENG99112,High pressure test result-Param 24 Rail ti Drop5 Stp Hp Tst{3},0, ms
IDE02559-ENG102406,High pressure test result-Param 25 Rail ti Drop5 Stp Hp Tst{4},0, ms
IDE02559-ENG102422,High pressure test result-Param 26 Rail ti Drop5 Stp Hp Tst{5},0, ms
IDE02559-ENG100074,High pressure test result-Param 27 Rail ti Drop5 Stp Hp Tst{6},0, ms
IDE02559-ENG104167,High pressure test result-Param 28 Rail ti Drop5 Stp Hp Tst{7},0, ms
IDE02559-ENG100629,High pressure test result-Param 29 Rail ti Drop5 Stp Hp Tst{8},0, ms
IDE02559-ENG103601,High pressure test result-Param 3 Rail st Dwn Hp Tst{0},0,
IDE02559-ENG99302,High pressure test result-Param 30 Rail ti Drop5 Stp Hp Tst{9},0, ms
IDE02559-ENG103151,High pressure test result-Param 31 Rail ti Drop5 Stp Hp Tst{10},0, ms
IDE02559-ENG100429,High pressure test result-Param 32 Rail ti Drop5 Stp Hp Tst{11},0, ms
IDE02559-ENG101212,High pressure test result-Param 33 Rail ti Drop5 Stp Hp Tst{12},0, ms
IDE02559-ENG103534,High pressure test result-Param 34 Rail ti Drop5 Stp Hp Tst{13},0, ms
IDE02559-ENG103173,High pressure test result-Param 35 Rail ti Drop5 Stp Hp Tst{14},0, ms
IDE02559-ENG99461,High pressure test result-Param 36 Rail ti Drop5 Stp Hp Tst{15},0, ms
IDE02559-ENG163336,High pressure test result-Param 37 Rail p Std Dvt Rpl6k{0},0, hPa
IDE02559-ENG163337,High pressure test result-Param 38 Rail p Mean Val Rpl6k{0},0, hPa
IDE02559-ENG163338,High pressure test result-Param 39 Rail p Std Dvt Rpl6k{1},0, hPa
IDE02559-ENG102202,High pressure test result-Param 4 Rail ti Dwn Hp Tst{0},0, ms
IDE02559-ENG163339,High pressure test result-Param 40 Rail p Mean Val Rpl6k{1},0, hPa
IDE02559-ENG163340,High pressure test result-Param 41 Rail p Std Dvt Rpl6k{2},0, hPa
IDE02559-ENG163341,High pressure test result-Param 42 Rail p Mean Val Rpl6k{2},0, hPa
IDE02559-ENG163342,High pressure test result-Param 43 Rail p Std Dvt Rpl6k{3},0, hPa
IDE02559-ENG163343,High pressure test result-Param 44 Rail p Mean Val Rpl6k{3},0, hPa
IDE02559-ENG102632,High pressure test result-Param 5 Rail st Up Hp Tst{1},0,
IDE02559-ENG103992,High pressure test result-Param 6 Rail ti Up Hp Tst{1},0, ms
IDE02559-ENG101023,High pressure test result-Param 7 Rail st Dwn Hp Tst{1},0,
IDE02559-ENG100114,High pressure test result-Param 8 Rail ti Dwn Hp Tst{1},0, ms
IDE02559-ENG101094,High pressure test result-Param 9 Rail st Up Hp Tst{2},0,
IDE02742,Oil pressure actual value,100.5, kPa
IDE02756,Number of manual engine starts,7036,
IDE02757,Number of automatic engine starts,14880,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,1839,
IDE03010-MAS01627,Number of prevented stop processes-Steering,2930,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,2971,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,563,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,440,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,17,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,5,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,198,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,863,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03015,Compression test cylinder 1,0.0, /min
IDE03016,Compression test cylinder 2,0.0, /min
IDE03017,Compression test cylinder 3,0.0, /min
IDE03018,Compression test cylinder 4,0.0, /min
IDE03133,Heating circuit 1 for reducing agent metering system: actual current,0, mA
IDE03134,Heating circuit 2 for reducing agent metering system: actual current,378, mA
IDE03135,Sensor for reducing agent tank temperature: temperature,26.8, °C
IDE03137,Heating circuit 1 for reducing agent metering system: actual voltage,0.0, mV
IDE03138,Heating circuit 2 for reducing agent metering system: actual voltage,119.6, mV
IDE03139,Reducing agent injector: resistance,0, mOhm
IDE03140,NOx sensor 1: NOx concentration,0, ppm
IDE03141,NOx sensor 2: NOx concentration,0, ppm
IDE03142,Remaining vehicle distance until reducing agent deficiency,12614.00, km
IDE03145,NOx sensor 2: offset for correction factor,0, ppm
IDE03149,NOx sensor 1: offset for correction factor,0, ppm
IDE03187,Checksum of flash,C6D7,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03242,Injector for reduction agent: current holding phase,0, mA
IDE03243,Reducing agent injector: current saturation phase,0, mA
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03248,Pressure control valve adaptation factor,0.9739,
IDE03288-ENG188621,Heating circuit 1 for reducing agent metering system: activation-Bits 0-7,0,
IDE03289-ENG188621,Heating circuit 2 for reducing agent metering system: activation-Bits 0-7,0,
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03383,Exhaust mass flow of EGR,0.0, kg/h
IDE03387,Duration of overtemperature at the reduction agent injector,6948, s
IDE03393-ENG188621,Selector lever position-Bits 0-7,8,
IDE03405-ENG188621,Particle filter field regeneration: cancel conditions-Bits 0-7,0,
IDE03582,Temperature sensor for engine temperature management,222.0, °C
IDE03583-ENG188621,Engine shut-down overrides-Bits 0-7,8,
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,All releases are present,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping prohibitions for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping prohibitions for active participants-A/C system,not active,
IDE03587-MAS00127,Stopping prohibitions for active participants-Brake,not active,
IDE03587-MAS00506,Stopping prohibitions for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping prohibitions for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping prohibitions for active participants-Gearbox,not active,
IDE03587-MAS01106,Stopping prohibitions for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping prohibitions for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping prohibitions for active participants-Steering,not active,
IDE03587-MAS02237,Stopping prohibitions for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping prohibitions for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping prohibitions for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping prohibitions for active participants-Motor,active,
IDE03587-MAS06709,Stopping prohibitions for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping prohibitions for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping prohibitions for active participants-Front sensor for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C system,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-Brake,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Gearbox,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication errors,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,not active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.030, m/s²
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,128,
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,56,
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,129,
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,224,
IDE03767,Engine status,COENG_READY,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03998,Clutch Position Sensor,0.0, %
IDE04002,Charge air pressure control,BP_A cmd/act:67.4/98.5, kPa
IDE04003,Charge air temperature sensor,B1S1/B1S2:28/28, °C
IDE04008,Fuel consumption per hour,0.00, L/h
IDE04009,Driver's desired torque,0.0, %
IDE04010,Engine torque: normalized,0.0, %
IDE04011,Nominal torque,360, Nm
IDE04015,Exhaust gas recirculation,EGR A:0/0/0 % / EGR B:0/0/0 %,
IDE04016,Fuel Pressure Regulation,FRP CMD:40000/--- kPa / FRP ACT:1090/--- kPa,
IDE04035,exh.gas recirc. temperature,EGRTemp 11/12:---/28 °C / EGRTemp 21/22:---/--- °C,
IDE04083,Coolant temperatures,ECT 1:28, °C
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:100.0/12.2 % / VGT_B cmd/act:---/--- %,
IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4:  / 33/33/34/31 °C,
IDE04092,Particulate filter bank 1,0.19/---/---, kPa
IDE04095,Engine running time,Total:2382H987s  / Idle:272H140s ,
IDE04098,NOX Sensor,NOx11:65535 ppm / NOx21:65535 ppm,
IDE04099,Reduction agent dosing,ReAg Rate/Demand:0.0/0.00 L/h / Reag Tnk Lvl:62.7 %,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04260-ENG188621,Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7,0,
IDE04261-ENG188621,Learning cycle counter of zero quant calib: middle press pt-Bits 0-7,0,
IDE04262-ENG188621,Learning cycle counter of zero quant calib: top press pt-Bits 0-7,0,
IDE04272,Counter for regeneration time of particulate filter,0.0, s
IDE04468,Air mass at air mass meter 1,-0.1, kg/h
IDE04623,Kick-down threshold,4125.2, mV
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04652,Exhaust gas jet volume in particle filter,0.0, m³/h
IDE04653,Simulated particle filter surface temperature,28.0, °C
IDE04666,Heat delivery temperature in cooling system,-273.1, °C
IDE04670,Crankshaft signal evaluation: status,WAITSIG,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,1,
IDE04679-ENG188621,O2 sensor 1: bank 1: status O2 signal: validity-Bits 0-7,0,
IDE04682-ENG188621,Allowed number of injections-Bits 0-7,5,
IDE04683-ENG188621,Injection release status-Bits 0-7,0,
IDE04684-ENG188621,Desired injection characteristic-Bits 0-7,124,
IDE04685,Setpoint generation interior torque,0.0, Nm
IDE04686,Calculated clutch limit torque,-61.0, Nm
IDE04687,Mean temperature of SCR catalyst,28.0, °C
IDE04688-ENG188621,Engine control module reset status-Bits 0-7,0,
IDE04688-ENG188621,Engine control module reset status-Bits 0-7,16,
IDE04690-ENG188621,Transmission torque intervention status-Bits 0-7,0,
IDE04693,Increasing desired torque intervention of ESP,-48824.3, Nm
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,255,
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,110,
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,140,
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,33,
IDE04695-ENG137752,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG137752,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04866,Charging of press sensor betw ND and HD turbocharger: adapt,985, hPa
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,0,
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,1,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,0,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,1,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,0,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,1,
IDE04887,Powertrain target torque,-461.0, Nm
IDE05132-ENG188621,Charge pressure control activity-Bits 0-7,0,
IDE05135,Status of compressor release,Correct result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,1,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,16,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,128,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,1,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,0,
IDE05137-ENG188621,Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7,0,
IDE05138,Shut-off timer: last engine shut-off time,86051, s
IDE05139,Shut-off timer: last ECM after-run time,123, s
IDE05260-ENG188621,Gear position sensor: current value-Bits 0-7,0,
IDE05348,NOx-Sensor 2: O2-Concentration,0.21069,
IDE05352-ENG188621,Status of trailing throttle detec in trailing throttle coord-Bits 0-7,0,
IDE05356,Calculated NOx concentration behind turbocharger,0.00, ppm
IDE05386,Exhaust gas model temperature 0,124.3, °C
IDE05387,Exhaust gas model temperature 1,29.3, °C
IDE05388,Exhaust gas model temperature 2,18.6, °C
IDE05389,Exhaust gas model temperature 3,18.6, °C
IDE05390,Exhaust gas model temperature 4,-0.0, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0028, rad
IDE05625,Speed regulation requested torque,-461.0, Nm
IDE05626,Calculated temperature at reduction agent injection valve,-0.0, °C
IDE05781,Engine temperature management actuator: specified value,0.00, %
IDE05846,DPF statistics: current average speed,15.4, km/h
IDE05853,DPF statistics: current avg temperature after part filter,0.0, K
IDE05855,DPF statistics: current regeneration time slice not possible,0.000, H
IDE05861-ENG188621,DPF statistics: number of interrupted regenerations-Bits 0-7,0,
IDE05877,DPF statistics: regen time slice not poss in charge cycle,0.000,
IDE05883,DPF statistics: regeneration time,0, s
IDE05901,DPF statistics: route in charge cycle,128, km
IDE05903,DPF statistics: avg driv cycle time during charge cycle,0, s
IDE05908-ENG188621,DPF statistics: regeneration request-Bits 0-7,0,
IDE05910,DPF statistics: exhaust temperature regulation average value,0.44,
IDE05918-ENG188621,DPF statistics: regeneration blocked status-Bits 0-7,0,
IDE05922-ENG188621,DPF statistics: error status-Bits 0-7,0,
IDE06013,Engine start: start synchronization 2,EPM_NO_SYNC,
IDE06013-ENG127375,Engine start: start synchronization 2-Test_Program_Epm st Sync State t UBYTE,0,
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,0,
IDE06058-ENG188621,Engine control module reset status info-Bits 0-7,0,
IDE06059,Particulate filter: oil ash mass,30.8334328, g
IDE06060,Particulate filter ash load limit,80.000, g
IDE06216,DPF Statistics: average val.: exhaust temp. ctrl before DPF,2.0,
IDE06255,Vehicle lateral acceleration,-0.04, g
IDE06256,Vehicle lateral acceleration: raw value,-0.04, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06258,Charge air temperature at the turbocharger outlet: calculated,28.7, °C
IDE06298-ENG188621,Status of engine during start-Bits 0-7,2,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.0, mV
IDE06405,Engine oil temperature_SAE,28, °C
IDE06433,Standardized airflow ratio: filtered,3.9999,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,-0.031, m/s²
IDE06446-ENG188621,Status: incline angle-Bits 0-7,0,
IDE06552,Time since terminal 15 ON,269480, ms
IDE06567,Frequency counter deactivate start/stop function,2094,
IDE06568,Stop prevention by driver frequency counter,14116,
IDE06569,Frequency counter vehicle standstill,40477,
IDE06607,Distance at last active oil overfill warning,2.1, km
IDE06608,Total distance with active oil overfill warnings,231.4, km
IDE06610,Frequency counter vehicle standstill with stop,14257,
IDE06647-ENG188621,Start-stop switch status-Bits 0-7,1,
IDE06703,Drivetrain coordinator: ACC fault status,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,32,
IDE06706-ENG188621,ACC variants-Bits 0-7,2,
IDE06707,CCS Switch,2,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06866-ENG188621,Range limit cancellation due to red. agent metering sys. fault-Bits 0-7,0,
IDE06946-ENG188621,Brake actuated status-Bits 0-7,0,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,85.9, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE06993-MAS05410,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 1,Available,
IDE06993-MAS05410,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 1,0.000000, %
IDE06993-MAS05411,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 2,20.974870, %
IDE06993-MAS05411,Oxygen sensors (broadband)-Oxygen concentration bank 1: sensor 2,Available,
IDE06993-MAS05412,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 1,0.000000, %
IDE06993-MAS05412,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 1,Not available,
IDE06993-MAS05413,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 2,0.000000, %
IDE06993-MAS05413,Oxygen sensors (broadband)-Oxygen concentration bank 2: sensor 2,Not available,
IDE06993-MAS05414,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 1,Available,
IDE06993-MAS05414,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 1,1.001, lambda
IDE06993-MAS05415,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 2,Available,
IDE06993-MAS05415,Oxygen sensors (broadband)-Oxygen value bank 1: sensor 2,8.000, lambda
IDE06993-MAS05416,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 1,Not available,
IDE06993-MAS05416,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 1,0.000, lambda
IDE06993-MAS05417,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 2,0.000, lambda
IDE06993-MAS05417,Oxygen sensors (broadband)-Oxygen value bank 2: sensor 2,Not available,
IDE07001,Piston-cooling jets: activation,1,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,4,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,212,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,0,
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,0,
IDE07084,Differential pressure ratio: low-pressure EGR,2.475,
IDE07086,Exhaust mass flow of low-pressure EGR: calculated,0.0, kg/h
IDE07088,NOx sensor 1: oxygen concentration,0.21077,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,0,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,4,
IDE07374,Cylinder mass flow: act. value calculated,0.0, kg/h
IDE07375,Charge pressure before throttle valve: calculated actual value,985.0, hPa
IDE07377,EGR valve 1: B1: mass current - specified value,0.0, kg/h
IDE07378,Exhaust flap actuator 1: B1: inlet pressure - specified value,985.5, hPa
IDE07379,Cylinder charge: spec. value,358.2, mg/stroke
IDE07380,NOx storage catalytic converter: sulfur load: actual value calculated,0.000, g
IDE07381,Cylinder charge: act. value calculated,0.0, mg/stroke
IDE07382,EGR valve 2: B1: mass current - specified value,0.0, kg/h
IDE07383,NOx storage catalytic converter: aging factor: actual value calculated,0, s
IDE07384,Throttle valve actuator 1: B1: outlet pressure - specified value,675.5, hPa
IDE07385,Exhaust flap actuator 1: B1: inlet pressure - actual value calculated,986.0, hPa
IDE07386,Total HFM air mass flow: calculated,0.0, kg/h
IDE07528-ENG122685,Coordinator releases for particulate filter regeneration-SwSVW st Ctl Cdn Eng,11111111 11111111 11111111 11111111 ,
IDE07528-ENG122684,Coordinator releases for particulate filter regeneration-SwSVW st Ctl Cdn Veh,11111111 11111111 11111111 11110111 ,
IDE07529-ENG122685,Coordinator releases: standard-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07529-ENG122684,Coordinator releases: standard-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07530-ENG122685,Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07530-ENG122684,Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07531-ENG122685,Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07531-ENG122684,Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07532-ENG122685,Coordinator releases for short trip-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
IDE07532-ENG122684,Coordinator releases for short trip-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,3,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,16,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,177,
IDE07534-ENG188621,Target operating mode for engine-Bits 0-7,1,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,177,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,3,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,1,
IDE07535-ENG188621,Current operating mode of engine-Bits 0-7,16,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,1,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,177,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,3,
IDE07536-ENG188621,Next requested operating mode for engine-Bits 0-7,16,
IDE07538,Intake manifold press. sensor: act. value calculated,985, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,38.79, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,0.00, %
IDE07550,Engine temp. management actuator: raw value,0.0, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07598,Cruise control switch actuation,8192,
IDE07605,Cruise control system: temporary deactivation,0,
IDE07706,Outside temperature sensor 1: B1: raw value,28.0, °C
IDE07707,Mass airflow sensor 1 bank 1 temperature: raw value,30.5, °C
IDE07708,Turbocharger 1 charger output: temp. sensor 1: B1: raw value,28.7, °C
IDE07709,Turbocharger 1 charger output: temp. sensor 1: B1: raw voltage,4266.0, mV
IDE07710,Charge air cooler output: temp. sensor 1: B1: raw value,28.4, °C
IDE07711,Charge air cooler output: temp. sensor 1: B1: raw voltage,4272.0, mV
IDE07712,Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value,32.1, °C
IDE07713,Turbocharger 1 turbine input: temp. sensor 1: B1: raw voltage,915.6, mV
IDE07714,Turbocharger 1 turbine output: temp. sensor 1: B1: raw value,32.6, °C
IDE07715,Turbocharger 1 turbine output: temp. sensor 1: B1: raw voltage,916.8, mV
IDE07716,Particulate filter input: temp. sensor 1: bank 1: raw value,33.5, °C
IDE07717,Particulate filter input: temp. sensor 1: B1: raw voltage,919.2, mV
IDE07718,Particulate filter output: temp. sensor 1: bank 1: raw value,31.6, °C
IDE07719,Particulate filter output: temp. sensor 1: bank 1: raw voltage,913.2, mV
IDE07722,Coolant temp. sens.1 bank 1 before charge air cooler: raw value,28.6, °C
IDE07723,Coolant temp.sens.1 bank 1 before ch.air cool.:uncnd.voltage,3175.8, mV
IDE07724,Coolant temperature at engine outlet: calculated,28.3, °C
IDE07725,Coolant temperature sensor 1: B1: on cylinder head: raw value,28.3, °C
IDE07726,Coolant temperature sensor 1: B1: on cylinder head: raw voltage,3192.8, mV
IDE07731,EGR temp. sensor 2: B1: raw value,30.3, °C
IDE07732,EGR temp. sensor 2 B1: raw voltage,4489.4, mV
IDE07733,Ambient air pressure sensor 1 bank 1: raw value,986, hPa
IDE07738,Charge air cooler inlet: pressure sensor 1 bank 1: raw value,985.4, hPa
IDE07739,Charge air cooler inlet: press.sensor 1 bank 1: uncnd. voltage,1033.8, mV
IDE07742,Cylinder head: pressure sensor 3 bank 1: maximum value,0.000, bar
IDE07744,Particle filter: air pressure sensor 1 bank 1: raw value,2, hPa
IDE07745,Particl.filt.: different.press.sensor 1 bank 1: adaptat. value,0, hPa
IDE07747,Par.fil: diff.pr.sens.1 bank 1: offset,-1, hPa
IDE07748,Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset,2, hPa
IDE07750,Exhaust recirculat.2: different.press.sens.1 bank 1: raw value,-2.0, hPa
IDE07751,Exhaust gas recirculation 2: differential pressure sensor 1 bank 1: additional value,-0.8, hPa
IDE07752,Exh.recirculat.2: different.press.sensor 1 bank 1: uncnd.volt.,0.0, mV
IDE07754,Exhaust recirculation valve 1 bank 1: activation,0.00, %
IDE07755,Exhaust recirculation valve 1 bank 1: position feedback  uncnd. voltage,675.2, mV
IDE07756,Exhaust recirculation valve 1 bank 1: position feedback  specified value,0.00, %
IDE07757,Exhaust recirculation valve 1 bank 1: position feedback  actual value,0.20, %
IDE07758,Exhaust recirculation valve 1 bank 1: position feedback  offset closed,1.01, %
IDE07759-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  mechanical stops-Bits 0-7,98,
IDE07759-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  mechanical stops-Bits 0-7,93,
IDE07759-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07759-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  mechanical stops-Bits 0-7,8,
IDE07760-ENG188621,Exhaust recirculation valve 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07761,Exhaust recirculation valve 2 bank 1: activation,0.00, %
IDE07762,Exhaust recirculation valve 2 bank 1: position feedback  uncnd. voltage,699.6, mV
IDE07763,Exhaust recirculation valve 2 bank 1: position feedback  specified value,0.00, %
IDE07764,Exhaust recirculation valve 2 bank 1: position feedback  actual value,0.00, %
IDE07765,Exhaust recirculation valve 2 bank 1: position feedback  offset closed,0.00, %
IDE07766-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07766-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  mechanical stops-Bits 0-7,89,
IDE07766-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  mechanical stops-Bits 0-7,220,
IDE07766-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  mechanical stops-Bits 0-7,2,
IDE07767-ENG188621,Exhaust recirculation valve 2 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07768,Throttle valve adapter 1 bank 1: activation,28.31, %
IDE07769,Throttle valve adapter 1 bank 1: position feedback  uncnd. voltage,703.2, mV
IDE07770,Throttle valve adapter 1 bank 1: position feedback  specified value,100.00, %
IDE07771,Throttle valve adapter 1 bank 1: position feedback  actual value,100.00, %
IDE07772,Throttle valve adapter 1 bank 1: position feedback  offset closed,-0.06, %
IDE07773-ENG188621,Throttle valve adapter 1 bank 1: position feedback  mechanical stops-Bits 0-7,14,
IDE07773-ENG188621,Throttle valve adapter 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07773-ENG188621,Throttle valve adapter 1 bank 1: position feedback  mechanical stops-Bits 0-7,122,
IDE07774-ENG188621,Throttle valve adapter 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07775,Exhaust recirculation valve 1 bank 1: activation,0.00, %
IDE07776,Exhaust flap actuator 1 bank 1: position feedback  uncnd. voltage,4327.4, mV
IDE07777,Exhaust flap actuator 1 bank 1: position feedback  specified value,0.00, %
IDE07778,Exhaust flap actuator 1 bank 1: position feedback  actual value,0.00, %
IDE07779,Exhaust flap actuator 1 bank 1: position feedback  offset closed,2.19, %
IDE07780-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,229,
IDE07780-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,61,
IDE07780-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07781-ENG188621,Exhaust flap actuator 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07783,Turbine actuator 1 bank 1: position feedback  uncnd. voltage,3891.2, mV
IDE07784,Turbine actuator 1 bank 1: position feedback  specified value,100.00, %
IDE07785,Turbine actuator 1 bank 1: position feedback  actual value,12.52, %
IDE07786,Turbine actuator 1 bank 1: position feedback  offset closed,22.45, %
IDE07787-ENG188621,Turbine actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,137,
IDE07787-ENG188621,Turbine actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,0,
IDE07787-ENG188621,Turbine actuator 1 bank 1: position feedback  mechanical stops-Bits 0-7,40,
IDE07788-ENG188621,Turbine actuator 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07789,Turbine actuator 1 bank 1: activation,0.00, %
IDE07797,Injector 1 bank 1 for reducing agent before SCR cat: activation,0.00, %
IDE07798,Heater support pump 1 bank 1 second.circuit: activat.,10.00, %
IDE07799,Heater support pump 1 bank 1 primary circuit: activation,35.00, %
IDE07800,Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.,10.00, %
IDE07801,Mass airflow sensor 1 bank 1 airflow: raw value,0.0, mg/stroke
IDE07807,Fuel temperature sensor 1: B1: raw value,30.4, °C
IDE07808,Fuel temperature sensor 1: B1: before CR pump: raw voltage,3793.6, mV
IDE07812,Transmission neutral position sensor 1: raw value,0.00, %
IDE07815-ENG188621,Transmission neutral position sensor: adaptation status-Bits 0-7,0,
IDE07818,Fuel high pressure sensor: actual value,10900, hPa
IDE07819,Fuel high pressure sensor: unconditioned voltage,516.2, mV
IDE07820,Fuel high pressure sensor: nominal value,400000, hPa
IDE07821,Fuel metering valve: activation,15.69, %
IDE07822,Fuel pressure regulator valve: activation,6.44, %
IDE07823-ENG188621,Tank-internal presupply pump 1 bank 1: status-Bits 0-7,3,
IDE07824,Tank-internal presupply pump 1 bank 1: activation,10.00, %
IDE07825,Tank-internal presupply pump 1 bank 1: nominal value,0.0, l/h
IDE07826,Accelerator pedal travel: raw value,0.00, %
IDE07827,Accelerator pedal: sensor voltage 1,722.8, mV
IDE07828,Accelerator pedal: sensor voltage 2,363.6, mV
IDE07832,Coolant fan 1: activation,10.15, %
IDE07834-ENG188621,Status of starter activation relay-Bits 0-7,0,
IDE07841,Precontrol value of map,0.000, µs
IDE07842-ENG188621,Precontrol map value index-Bits 0-7,40,
IDE07904-ENG188621,Brake test switch status-Bits 0-7,0,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,0,
IDE07906-ENG188621,Upper clutch switch: status-Bits 0-7,0,
IDE07928,Oxygen sensor bank 1 before oxi cat: exhaust temper. calculated,27.0, °C
IDE07935,Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation,1.0623,
IDE07936,Oxyg.sens.bank 1 before oxi cat:act.-integr.pump curr.adapt.,0.00, g
IDE07984,Particle sensor: cleaning deviation reaction time,0.000,
IDE07986,Particle sensor: soot volume in exhaust,0.00, mg/m³
IDE07987,Particle sensor: exhaust temperature,27.0, °C
IDE07988,Particle sensor: exhust speed,0.00, m/s
IDE07989,Particle sensor: heat voltage,0.00, V
IDE07990,Particle sensor: surface temperature,49.85, °C
IDE08065,Mass airflow sensor 1 bank 1 temperature sensor: raw value,334.8, mV
IDE08069-ENG188621,Fuel filter: water level sensor 1-Bits 0-7,0,
IDE08076,Fuel filter: water level sensor 1 raw voltage,0.0, mV
IDE08132-ENG122793,SCR error notification reset status-SCR Inducement Group,0,
IDE08132-ENG122794,SCR error notification reset status-SCR Inducement State DFCC,0,
IDE08132-ENG176596,SCR error notification reset status-SCR Inducement Tester DFCC Five,0,
IDE08132-ENG176595,SCR error notification reset status-SCR Inducement Tester DFCC Four,0,
IDE08132-ENG176592,SCR error notification reset status-SCR Inducement Tester DFCC One,0,
IDE08132-ENG176594,SCR error notification reset status-SCR Inducement Tester DFCC Three,0,
IDE08132-ENG176593,SCR error notification reset status-SCR Inducement Tester DFCC Two,0,
IDE08212,Standardized air flow ratio,3.9999,
IDE08213,Standardised airflow ratio plausibility,0,
IDE08285-ENG188621,Filling reducing agent metering system status-Bits 0-7,0,
IDE08721,Particle sensor: time in op. mode measurement,0.0, s
IDE09163,Exhaust recircul.2: different.press.sens.1 bank 1: dyn. offset,-2.0, hPa
IDE09164,Efficiency of the SCR catalytic converter,0.00000,
IDE09165,Low-pres.exhaust gas recirc.filt.diagn.:release condit.,35865,
IDE09327,Cylinder 1 bank 1 internal moment,0.0, Nm
IDE09328,Cylinder 2 bank 1 internal moment,0.0, Nm
IDE09329,Cylinder 3 bank 1 internal moment,0.0, Nm
IDE09330,Cylinder 4 bank 1 internal moment,0.0, Nm
IDE09331,Cylinder 1 bank 1 primary combustion position,0.00, °
IDE09332,Cylinder 2 bank 1 primary combustion position,0.00, °
IDE09333,Cylinder 3 bank 1 primary combustion position,0.00, °
IDE09334,Cylinder 4 bank 1 primary combustion position,0.00, °
IDE09339,Charge limit for service regeneration while driving,40.00, g
IDE09490,Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value,-1.0, hPa
IDE09673-ENG188621,Cylinder head: main combustion position controller 3 bank 1: limit status-Bits 0-7,0,
IDE09677,Cyl. head: press. sens 3 bank 1: press. correct. intern. moment,0.0, Nm
IDE09681-ENG188621,Cyl. head: press. sen 3 bank 1: error status combustion chamber pressure-Bits 0-7,0,
IDE09685-ENG188621,Cylinder head: controller internal moment 3 bank 1: limit status-Bits 0-7,0,
IDE09842-ENG188621,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,255,
IDE09843-ENG188621,Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7,255,
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,15.9998,
IDE09884,Oxygen sensor bank 1 upstream oxi cat: pump current adaptation successful,Correct result,
IDE09884-ENG127289,Oxygen sensor bank 1 upstream oxi cat: pump current adaptation successful-Test_Program_B TRUE UBYTE,1,
IDE09885,O2 sensor bank 1 upstrm oxi cat: status of signal quality,14,
IDE09886,Exhaust gas recirc. valve 2 bank 1: mass flow - calculated,0.0, kg/h
IDE09962,Cylinder head: pressure sensor 3 bank 1: primary combustion position,0.00, °
IDE09966,Cylinder head: pressure sensor 3 bank 1: primary combustion standard deviation,0.00, °
IDE09970,Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode,0.00, °
IDE09974-ENG188621,Cylinder head: pressure sensor 3 bank 1: group run time-Bits 0-7,255,
IDE09976,Coolant fan 1: activation,10.15, %
IDE09977,Control module temp.: max. value,80.6, °C
IDE10022,Heating circuit 3 for reducing agent metering: voltage,0.00, V
IDE10029,Heating circuit 3 for reducing agent: current,0.00, A
IDE10032,Reducing agent quality sensor: urea concentration,33.9, %
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,107.9, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,4294967, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,142949, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
IDE10063-ENG137751,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,5,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,124.0, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,4294967, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,142038, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
IDE10064-ENG137751,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,6,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,144.0, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,140796, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,140742, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,7,
IDE10065-ENG137751,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,3,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,135.7, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,4294967, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,140289, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
IDE10066-ENG137751,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,3,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,117.4, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,4294967, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,138967, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,7,
IDE10067-ENG137751,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,3,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,128.1, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,4294967, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,136368, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,7,
IDE10068-ENG137751,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,3,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,116.1, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,4294967, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,135261, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,7,
IDE10069-ENG137751,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,3,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,110.3, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,4294967, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,134271, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,7,
IDE10070-ENG137751,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,3,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,125.3, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,133258, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,133201, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,7,
IDE10071-ENG137751,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,3,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,121.7, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,4294967, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,131060, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,7,
IDE10072-ENG137751,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,3,
IDE10241,Reducing agent pump module relative press.: calculated,0, hPa
IDE10246,Reducing agent tank volume: act. value filtered,9.0352, kg
IDE10248,Reducing agent supply pump: offset factor calculated,0.999,
IDE10249,Reducing agent fill level sensor: act. value,88.8, mm
IDE10251,Reducing agent supply pump: measured resistance,4567, mOhm
IDE10253,Exh. gas recirc. valve 1 bank 1: pos. contr. spec. value,-25.00, %
IDE10254,Turbine actuator 1 bank 1: pos. contr. spec. value,100.00, %
IDE10255,Throttle valve adapter 1 bank 1: pos. contr. spec. value,125.00, %
IDE10313-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,7,
IDE10313-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,0,
IDE10313-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,16,
IDE10314-ENG188621,Exhaust recirculation valve 2 bank 1: monitoring  status-Bits 0-7,0,
IDE10314-ENG188621,Exhaust recirculation valve 2 bank 1: monitoring  status-Bits 0-7,7,
IDE10314-ENG188621,Exhaust recirculation valve 2 bank 1: monitoring  status-Bits 0-7,16,
IDE10315-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,16,
IDE10315-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,0,
IDE10315-ENG188621,Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7,7,
IDE10316-ENG188621,Turbine actuator 1 bank 1: monitoring - status-Bits 0-7,0,
IDE10316-ENG188621,Turbine actuator 1 bank 1: monitoring - status-Bits 0-7,16,
IDE10316-ENG188621,Turbine actuator 1 bank 1: monitoring - status-Bits 0-7,7,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,0,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,18,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,7,
IDE10402-ENG188621,Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7,64,
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,1,
IDE10569-ENG188621,Turbo charger 1 Turbine inp.: Temp. sensor 1 Bank 1: raw data-Bits 0-7,0,
IDE10570,Turbo charger.1 turbine inp.: temp.sensor 1 bank 1: comp. temp.,-273.1, °C
IDE10571,Turbo charger.1 turbine inp.: temp.sens. 1 bank 1: ins.resist.,0, kOhm
IDE10576-ENG188621,Reducing agent system and actuator: condition-Bits 0-7,1,
IDE10576-ENG188621,Reducing agent system and actuator: condition-Bits 0-7,0,
IDE10578-ENG188621,Reducing agent system release: cancel conditions quick start-Bits 0-7,0,
IDE10579-ENG188621,Reducing agent system pressurization release conditions-Bits 0-7,2,
IDE10579-ENG188621,Reducing agent system pressurization release conditions-Bits 0-7,199,
IDE10580,Engine oil level: test method 1,103.4, %
IDE10581,Engine oil level: test method 2,131.9, %
IDE10582,Engine oil level: test method 3,104.5, %
IDE10633,Clutch protection function: reduced torque,3267.7, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0.0, 1/min/s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,55, ml/mm
IDE10811-ENG188621,Release requirement for DPF regeneration-Bits 0-7,0,
IDE10812-ENG188621,Particulate filter regeneration: status-Bits 0-7,0,
IDE10813,Temp. dwnstrm. of oxi-cat without fuel combustion: calculated,18.7, °C
IDE10814,Exhaust recirculation cooler 2 Bank 1: efficiency calculated,0.0000,
IDE10815,Post injection 2: quantity spec. value,0.00, mg/stroke
IDE10816-ENG188621,Particulate filter regeneration level: current-Bits 0-7,0,
IDE10817,Lambda value at inlet of particulate filter,32.767,
IDE10818,Temp. spec. value for exhaust gas temp.con.dwnstrm. of oxi-cat,-0.0, °C
IDE10819,Exh. gas temp.control dwnstrm. of oxi-cat: filtered model error,-0.0, °C
IDE10820,Exh. gas temp. ctrl. upstrm. of turbine: spec. value,420.0, °C
IDE10823,Exhaust gas model temperature 5,31.1, °C
IDE10824,Exhaust gas model temperature 6,-0.0, °C
IDE10825,Exhaust gas model temperature 7,-0.0, °C
IDE10826,Exh. gas temp. controller upstrm. of turbine: I-part,0.000,
IDE10827,Exh.gas temp.contr. dwnstrm.of oxi-cat:post inject.qty.spec.val,0.00, mg/stroke
IDE10828,Exh. gas temp.contr. upstrm. of turbine: post inject.qty.corr.,0.00, mg/injection
IDE10829,Post injection 1: quantity spec. value,0.00, mg/stroke
IDE10830,Post injection 3: quantity spec. value,0.00, mg/stroke
IDE10831,Exhaust recirculat.2: different.press.sens.1 bank 1: calculated,985, hPa
IDE10878,Remaining veh distance until reducing agent deficiency:display,12614.25, km
IDE10879,Sensor for reducing agent fill level: calibrated,59.31, %
IDE10917,Reducing agent delivery pump: coil temperature,29.5, °C
IDE10920,Temp. upstrm. of reducing agent cat.: calculated,33.5, °C
IDE10921-ENG188621,Reducing agent delivery pump: number of strokes-Bits 0-7,0,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11074,Fuel pres.sen. 1 bank 1 upstream from HD pump: press. dev.,0.0, kPa
IDE11111,Fuel pres.sen 1 bank 1 upstr from HD pump: act.value averaged,96.1, kPa
IDE11112,Fuel pres.sens.1 bank 1 upstr from HD pump: act.val. filtered,96.1, kPa
IDE11113,Fuel pres.sen. 1 bank 1 upstream from HD pump: raw volt.,0.782, V
IDE11114,Fuel press. sensor 1 bank 1 upstr. from HD pump: adapt. value,0.0, kPa
IDE11115,Start/stop driver request: counter restart by starter,2331,
IDE11116,Start/stop driver request: counter internal-motor restart,564,
IDE11117,Charge press. ctrl deviation after throttle valve bank 1,985.0, hPa
IDE11118,Pressure after throttle valve: calculated,-311.0, hPa
IDE11119,Pressure corr. value after low pressure EGR valve: calculated,0.0, hPa
IDE11203,Oil pressure setpoint,238.5, kPa
IDE11219,Reducing agent inj. quantity: spec. value,0.0, mg/s
IDE11220,Reducing agent system: current status,COSCR_NOPRESSURECTL,
IDE11220-ENG127431,Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE,2,
IDE11221,Reducing agent system: last status,COSCR_STANDBY,
IDE11221-ENG127431,Reducing agent system: last status-Test_Program_SCR Con State 01 UBYTE,1,
IDE11222,Reducing agent system: current substatus,COSCR_INVALID,
IDE11222-ENG127432,Reducing agent system: current substatus-Test_Program_SCR Con State 02 UBYTE,255,
IDE11223,Reducing agent system: last substatus,COSCR_INVALID,
IDE11223-ENG127432,Reducing agent system: last substatus-Test_Program_SCR Con State 02 UBYTE,255,
IDE11224,Charge air cooler water mixing valve: position feedback  specified value,100.00, %
IDE11225-ENG188621,Charge air cooler water mixing valve: position feedback  mechanical stops-Bits 0-7,0,
IDE11226-ENG188621,Charge air cooler water mixing valve: position feedback  breakaway attempts-Bits 0-7,0,
IDE11227,Charge air cooler water mixing valve: position feedback  closed: offset,0.00, %
IDE11228,Charge air cooler water mixing valve: position feedback  raw voltage,0.0, mV
IDE11229,Charge air cooler water mix. valve: activation,0.00, %
IDE11230,Charge air cooler water mixing valve: position feedback  actual value,0.00, %
IDE11233,Charge air cooler water mix. valve: pos. control setpoint,0.00, %
IDE11250,Reducing agent quality sensor: raw temperature value,26.8, °C
IDE11267,Oil level: max. value: relative,167.0, %
IDE11268,Oil level: min. value: relative,77.0, %
IDE11302-ENG188621,Engine oil level: test method 1 qualification-Bits 0-7,2,
IDE11303-ENG188621,Engine oil level: test method 3 qualification-Bits 0-7,8,
IDE11321-ENG188621,Rail press. regulation: operating condition-Bits 0-7,0,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,0,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,195,
IDE11330,Oil press. control valve: activation pulse duty factor,100.00, %
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometres,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometres,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometres,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometres,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometres,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometres,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometres,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometres,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometres,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometres,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11392,Activation of radiator shutter 2,0.00, %
IDE11448,Reducing agent over-pressure: diagnosis progress,0.0, %
IDE11449,Reducing agent under-pressure: diagnosis progress,0.0, %
IDE11574,Status max. oil level dynamically exceeded,False result,
IDE11574-ENG127289,Status max. oil level dynamically exceeded-Test_Program_B TRUE UBYTE,0,
IDE11575,Status max. oil level permanently exceeded,False result,
IDE11575-ENG127289,Status max. oil level permanently exceeded-Test_Program_B TRUE UBYTE,0,
IDE11576,Oil level: last valid dynamic value overfilling,0.000, mm
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,not active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11635-ENG188621,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG188621,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11895-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-7,2,
IDE11895-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-7,151,
IDE11896,Particle filter: differential press. sens.1 bank 1: raw value 1,2, hPa
IDE11897,Particle filter: differential press. sens.1 bank 1: raw value 2,-3, hPa
IDE11898-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-7,135,
IDE11898-ENG188621,Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-7,2,
IDE11899,Par.fil: diff.pr.sens.1 bank 1: sensor temperature,30.64, °C
IDE11900,Par.fil: diff.pr.sens.1 bank 1: data quality,100.00, %
IDE11901-ENG188621,Par.fil: diff.pr.sens.1 bank 1: sensor configuration-Bits 0-7,0,
IDE11902-ENG188621,Par.fil: diff.pr.sens.1 bank 1: manufacturer ID-Bits 0-7,0,
IDE11903-ENG188621,Par.fil: diff.pr.sens.1 bank 1: internal error code-Bits 0-7,0,
IDE11904-ENG188621,Par.fil: diff.pr.sens.1 bank 1: sensor type-Bits 0-7,0,
IDE11905-ENG188621,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,14,
IDE11905-ENG188621,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,0,
IDE11906-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,14,
IDE11906-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
IDE11907-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,15,
IDE11907-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
IDE11908-ENG188621,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,0,
IDE11908-ENG188621,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,143,
IDE11910-ENG188621,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,0,
IDE11910-ENG188621,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,15,
IDE11981,Turbocharg. 1 turb: input temp.sensor 1 bank 1: data quality,0.00, %
IDE12044-ENG188621,Crankshaft Position adapt.: write attempt counter-Bits 0-7,1,
IDE12074-ENG188621,Position adapt. of intake camshaft bank 1: counter-Bits 0-7,1,
IDE12078-ENG188621,Position adapt. of camshafts cyl: individual bank 1: counter-Bits 0-7,0,
IDE12105,Temperature sensor for cylinder block: uncond. voltage value,3194.0, mV
IDE12106,Temperature sensor for cylinder block,28.2, °C
IDE12392,Turbocharger: pin separation from min. throughput position,100.0, mV
IDE12457-ENG188621,Turbocharger 1 bypass valve 1 bank 1: position feedback  adaption value-Bits 0-7,7,
IDE12458,Turbocharger 1 bypass valve 1 bank 1: position feedback  initial teach-in,961.0, mV
IDE12468-ENG188621,Login counter of the simulation interface-Bits 0-7,0,
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2155872256,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13387,Turbocharger: current averaged minimum throughput position,861.0, mV
IDE13597,NOx sensor 3: NOx concentration,0, ppm
IDE14135,Cylinder pressure sensor 3: angle correction value,-0.31, °
IDE14153,Oil level: minimum value: compensated,50.140, mm
IDE14207,Fuel pressure sensor for high-pressure pump: regulation status,False result,
IDE14207-ENG127289,Fuel pressure sensor for high-pressure pump: regulation status-Test_Program_B TRUE UBYTE,0,
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
IDE14502-ENG188621,Fuel system output test status-Bits 0-7,0,
IDE14503-ENG188621,High-pressure fuel system: leak test status-Bits 0-7,0,
IDE14505-ENG188621,High Pressure test: status-Bits 0-7,0,
IDE14507,Fuel high-pressure system: residual current pressure regulation valve,0, mA
IDE14508,Fuel high-pressure system: pressure regulation valve control limit,0, mm³/s
IDE14509,Fuel high pressure system: lowest fuel low-pressure value,0, hPa
IDE14510,High-pressure fuel system: metering unit first throttle effect,0, mm³/s
IDE14511,Fuel high-pressure system: leak test maximum value,0, hPa
IDE14512,High-pressure fuel system: leak test final result,0, hPa
IDE14513,High pressure system: leak test starter deactivated,0, hPa
IDE14518,High Pressure test: standard deviation phase 4,0, hPa
IDE14519,High Pressure test: standard deviation phase 3,0, hPa
IDE14520,High Pressure test: standard deviation phase 2,0, hPa
IDE14521,High Pressure test: standard deviation phase 1,0, hPa
IDE14522,High Pressure test: pressure build-up time phase 4,0, ms
IDE14523,High Pressure test: pressure build-up time phase 3,0, ms
IDE14524,High Pressure test: pressure build-up time phase 2,0, ms
IDE14525,High Pressure test: pressure build-up time phase 1,0, ms
IDE14526,High Pressure test: pressure reduction time phase 4,0, ms
IDE14527,High Pressure test: pressure reduction time phase 3,0, ms
IDE14528,High Pressure test: pressure reduction time phase 2,0, ms
IDE14529,High Pressure test: pressure reduction time phase 1,0, ms
IDE14536,High Pressure test: high pressure average value phase 1,0, hPa
IDE14537,High Pressure test: high pressure average value phase 2,0, hPa
IDE14538,High Pressure test: high pressure average value phase 3,0, hPa
IDE14539,High Pressure test: high pressure average value phase 4,0, hPa
IDE14540,High Pressure test: pressure build-up time: final value 1,0, ms
IDE14541,High Pressure test: pressure build-up time: final value 2,0, ms
IDE14542,High Pressure test: pressure build-up time: final value 3,0, ms
IDE14607-ENG188621,Coolant distributor module: position feedback  breakaway attempts-Bits 0-7,0,
IDE14608-ENG188621,Coolant distributor module: position feedback  mechanical stops-Bits 0-7,0,
IDE14610,Charge air cooler water bypass valve: position feedback target value,0.00, %
IDE14611,Charge air cooler water bypass valve: position control target value,0.00, %
IDE14612,Charge air cooler water bypass valve: activation,0.00, %
IDE14903,Fuel Injector 2 for reducing agent before SCR cat: activation,0.00, %
IDE14904,Crankcase ventilation heater 1: control,100.00, %
IDE14965,AGR total ground current: deviation from specified value,0.0, kg/h
IDE14966,High Pressure AGR ground current: threshold value deviation from specified value,0.0, kg/h
IDE14967,Low pressure AGR ground current threshold value discrepancy from specified value,2.5, kg/h
IDE14968,High Pressure AGR ground current: deviation from specified value,0.0, kg/h
IDE14969,Low pressure AGR ground current: deviation from specified value,0.0, kg/h
IDE14971,AGR overall ground current: threshold value deviation from specified value,500.0, kg/h
IDE14985,Reducing agent system: AdBlue distribution dosing,0,
IDE15033,Oxidation catalytic converter diagnostic: distance since last intervention,143120612, m
IDE15034,Oxidation catalytic converter diagnostic: frequency counter mode,0,
IDE15184,Duration of overtemperature at the reduction agent fuel injector 2,42079, s
IDE15186,NOx sensor 3: offset for correction factor,0, ppm
IDE15187,NOx-Sensor 3: O2-Concentration,0.21069,
IDE15271-ENG188621,Crankcase ventilation disk separator: actual speed-Bits 0-7,255,
IDE15272,Crankcase ventilation disk separator: supply voltage,25.5, V
IDE15273,Crankcase ventilation disk separator: current consumption,51.0, A
IDE15317,Reducing agent injector 2: current holding phase,0, mA
IDE15318,Calculated temperature at reduction agent injection valve 2,-0.0, °C
IDE15319,Reducing agent injector 2: current saturation phase,0, mA
IDE15320,Reducing agent injector 2: resistance,0, mOhm
IDE15321,Efficiency of SCR catalytic converter 2,0.00000,
IDE15322,Temperature of SCR catalytic converter 2 calculated,28.0, °C
IDE15330-ENG188621,Initial fuel filling with toggle activation: status-Bits 0-7,0,
IDE15516,Engine temperature control actuator: thermostat control,0.00, %
IDE15565,High-pressure fuel system: low-pressure pump duty cycle,0.00, %
IDE15592-ENG188621,Fuel high-pressure system: flow rate test operating point-Bits 0-7,0,
IDE15593,Fuel high-pressure system: fuel temperature during test,-273.1, °C
IDE15707,Reducing agent: dosing quantity test: actual quantity,0.000, g
IDE15712-ENG188621,NOx sensor 1: release status-Bits 0-7,0,
IDE15713-ENG188621,NOx sensor 2: release status-Bits 0-7,0,
IDE15714-ENG188621,NOx sensor 3: release status-Bits 0-7,0,
IDE15715,NOx efficiency SCR diagnostic: progress,0.000,
IDE15716,NOx efficiency SCR 2 diagnostic: progress,0.000,
IDE15717,NOx efficiency SCR diagnostic: release status,1139571947,
IDE15718,NOx efficiency SCR 2 diagnostic: release status,809500672,
IDE15719,NOx efficiency SCR diagnostic: quick-start release status,1139043563,
IDE15720,NOx efficiency SCR 2 diagnostic: quick-start release status,809500672,
IDE15785,Reducing agent sensor quality: adaptation status,False result,
IDE15785-ENG127289,Reducing agent sensor quality: adaptation status-Test_Program_B TRUE UBYTE,0,
IDE15881-ENG188621,Heated Oxygen sensor: status signal validity-Bits 0-7,0,
IDE15885-ENG188621,Heated oxygen sensor: diagnostic status-Bits 0-7,0,
IDE15889-ENG188621,Heated oxygen sensor: communication status ASIC-Bits 0-7,0,
IDE15893-ENG188621,Heated Oxygen Sensor: ECM communication status-Bits 0-7,0,
IDE15922,NOx sensor: oxygen adaptation factor,0.9951,
IDE15923,NOx sensor 2: oxygen adaptation factor,0.9895,
IDE15924,NOx sensor 3: oxygen adaptation factor,0.9856,
IDE15926,Heated Oxygen Sensor: oxygen adaptation factor,1.0623,
IDE16005,Drive train coordinator: acceleration request target value,0.000, m/s²
IDE16006,Drive train coordinator current status,0,
IDE16007,Drive train coordinator: Acceleration Requester Status,0,
IDE16008,Drive Train Coordinator: Embassies Status,0,
IDE16009,Drivetrain coordinator: proximity control type,2,
IDE16010,Driver assistance systems: control panel actuations,1342177280,
IDE16011,Drive train coordinator: blocking reasons of CCS and limiter,0,
IDE16022,Urea concentration: temperature & offset corrected,32.8, %
IDE16023,urea concentration: temperature corrected,33.7, %
IDE16115,Consumed reducing agent,72493.677, g
IDE16127-ENG188621,Particulate sensor: status-Bits 0-7,0,
IDE16131,Initial calibration: individual progresses,0.000, µA
IDE16144,Heating circuit 1 for Reducing Agent Metering System: PWM activation,0.00, %
IDE16145,Heating circuit 2 for Reducing Agent Metering System: PWM activation,0.00, %
IDE16146,Heating circuit 3 for Reducing Agent Metering System: PWM activation,0.00, %
IDE16240-ENG188621,Counter write attempts: adaptation to aging SCR coating-Bits 0-7,0,
IDE16313-ENG188621,Crankshaft sensor wheel adaptation values: status after reset-Bits 0-7,0,
IDE16608,Engine protection torque limitation: depending on temperature,0,
MAS12413-ENG188621,Charge air cooler water mix. valve: monitoring status-Bits 0-7,0,
MAS16371-ENG188621,Low pressure EGR cooler efficiency diagnostic: status-Bits 0-7,136,
MAS16371-ENG188621,Low pressure EGR cooler efficiency diagnostic: status-Bits 0-7,15,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,1,
MAS16535,Exhaust gas recirculation 2: filter pressure loss at bank 1: modeled,0.1, hPa
MAS16536,Exhaust gas recirculation 2: filter pressure loss at bank 1: simulated,0.0, hPa
MAS16542,NOx catalytic converter of Bank 1: NH3 reducing agent fill level,0.3286, g/l
MAS17031,Radiator shutter 1: actual position,0, %
MAS17032,Radiator shutter 2: actual position,255, %
MAS17236-ENG188621,Adaptation of radiator shutter 2: status-Bits 0-7,1,
MAS17359-ENG188621,Mass airflow sensor: temperatures: raw data-Bits 0-7,1,
MAS17359-ENG188621,Mass airflow sensor: temperatures: raw data-Bits 0-7,79,
MAS17360-ENG188621,Mass airflow sensor including temperature sensor: sensor type-Bits 0-7,0,
MAS17360-ENG188621,Mass airflow sensor including temperature sensor: sensor type-Bits 0-7,26,
MAS17361-ENG188621,Mass airflow sensor including temperature sensor: sensor design-Bits 0-7,0,
MAS17362-ENG188621,Mass airflow sensor including temperature sensor: internal fault code-Bits 0-7,0,
MAS17363-ENG188621,Mass airflow sensor: airflow: raw data-Bits 0-7,15,
MAS17363-ENG188621,Mass airflow sensor: airflow: raw data-Bits 0-7,159,
MAS17364-ENG188621,Mass airflow sensor including temperature sensor: manufacturer ID-Bits 0-7,0,
MAS17364-ENG188621,Mass airflow sensor including temperature sensor: manufacturer ID-Bits 0-7,3,
MAS17365,Mass airflow sensor including temperature sensor: data quality,100.00, %
MAS17366-ENG188621,Charge air cooler inlet: pressure sender: sensor design-Bits 0-7,0,
MAS17366-ENG188621,Charge air cooler inlet: pressure sender: sensor design-Bits 0-7,1,
MAS17367-ENG188621,Charge air cooler inlet: pressure sender: raw data-Bits 0-7,4,
MAS17367-ENG188621,Charge air cooler inlet: pressure sender: raw data-Bits 0-7,9,
MAS17368,Charge air cooler inlet: pressure sender: data quality,100.00, %
MAS17369-ENG188621,Charge air cooler inlet: pressure sender: internal error code-Bits 0-7,0,
MAS17370-ENG188621,Charge air cooler inlet: pressure sender: manufacturer ID-Bits 0-7,0,
MAS17370-ENG188621,Charge air cooler inlet: pressure sender: manufacturer ID-Bits 0-7,86,
MAS17371-ENG188621,Charge air cooler inlet: pressure sender: sensor type-Bits 0-7,4,
MAS17371-ENG188621,Charge air cooler inlet: pressure sender: sensor type-Bits 0-7,0,
MAS20408,NOx catalytic converter 2: NH3 reducing agent loading,0.6897, g/l
MAS21928,Drive train coordinator: longitudinal dynamics control: functionalities,9,
MAS22113,SCR initial filling,1,
ENG119898,Actual_section_of_standard_test,0,
ENG122655,Air_flow_adaption_engine_revolutions_datapoint,2500.0, /min
ENG122656,Air_flow_adaption_map_number_datapoint,1,
ENG122654,Air_flow_adaption_mass_flow_value,0, mg/stroke
ENG122657,Air_flow_adaption_moment_datapoint,150.0, Nm
ENG128810-ENG188621,Boost_pressure_adaption_index_value-Bits 0-7,1,
ENG128811,Boost_pressure_adaption_learning_value,0.00, hPa
ENG101413,Calibration Identifications,05L022KT1998GFAJ,
ENG99697,Calibration Verification Numbers,48 D9 55 15,
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,3,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG274020,Cylinder Fuel Rate,0.00, mg/stroke
ENG105735,Cylinder_pressure_offset_cylinder_3,0.000, bar
ENG254612-ENG255535,Diesel Exhaust Fluid Dosing-Commanded DEF Dosing,0.0, %
ENG254612-ENG255536,Diesel Exhaust Fluid Dosing-Commanded DEF Dosing Supported,Available,
ENG254612-ENG255583,Diesel Exhaust Fluid Dosing-DEF Usage for the Current Driving Cycle,0.0005, l
ENG254612-ENG255584,Diesel Exhaust Fluid Dosing-DEF Usage for the Current Driving Cycle Supported,Available,
ENG274021-ENG274330,Diesel Exhaust Fluid Sensor Output-DEF Concentration,32.75, %
ENG274021-ENG274331,Diesel Exhaust Fluid Sensor Output-DEF Concentration supported,Available,
ENG274021-ENG274332,Diesel Exhaust Fluid Sensor Output-DEF Level supported,Available,
ENG274021-ENG274333,Diesel Exhaust Fluid Sensor Output-DEF Tank Level,62.7, %
ENG274021-ENG274334,Diesel Exhaust Fluid Sensor Output-DEF Tank Temperature,26, °C
ENG274021-ENG274335,Diesel Exhaust Fluid Sensor Output-DEF Temperature supported,Available,
ENG274021-ENG274336,Diesel Exhaust Fluid Sensor Output-DEF Type,DEF is proper mixture,
ENG274021-ENG274337,Diesel Exhaust Fluid Sensor Output-DEF Type supported,Available,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG106086-ENG188621,EGR_governor_deviation_monitoring_enabling-Bits 0-7,0,
ENG247045,Engine Exhaust Flow Rate,0.0, kg/h
ENG151174,Engine Friction - Percent Torque,16.0, %
ENG289267-ENG188621,Exh st N Ox Sens Vld Bits Cat2 Ds-Bits 0-7,0,
ENG137923-ENG188621,Exh st N Ox Sens Vld Bits Ds-Bits 0-7,0,
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.00, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.00, g/s
ENG111022,Glow_period_control_unit_calculated_glow_voltage,0, mV
ENG111025,Glow_period_control_unit_energy_integrator_calculated_value,0.0, V²s
ENG111024,Glow_period_control_unit_energy_integrator_input_voltage,0, mV
ENG111026,Glow_period_control_unit_engine_temperature,28.3, °C
ENG103875-ENG99452,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Completion Condition Counts,6824, counts
ENG103875-ENG103994,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Conditions Encountered Counts,1893, counts
ENG103875-ENG125935,In-use Performance Tracking: 16 counters-Counters 17-18,|Fuel Monitor Completion Condition Counts,Fuel Monitor Conditions Encountered Counts|3840
ENG103875-ENG100817,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Completion Condition Counts,0, counts
ENG103875-ENG101113,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG104133,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts,0, counts
ENG103875-ENG104165,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG102823,In-use Performance Tracking: 16 counters-Ignition Cycle Counter,25856, counts
ENG103875-ENG99234,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG99167,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG101363,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Completion Condition Counts,0, counts
ENG103875-ENG103522,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG125933,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG125934,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG99988,In-use Performance Tracking: 16 counters-OBD Monitoring Conditions Encountered Counts,7, counts
ENG103875-ENG100240,In-use Performance Tracking: 16 counters-PM Filter Monitor Completion Condition Counts,0, counts
ENG103875-ENG103730,In-use Performance Tracking: 16 counters-PM Filter Monitor Conditions Encountered Counts,0, counts
ENG110883,IUMPR_minimum_ratio_group_0,2.8651,
ENG110884,IUMPR_minimum_ratio_group_1,1.1832,
ENG110885,IUMPR_minimum_ratio_group_2,0.0000,
ENG110886,IUMPR_minimum_ratio_group_3,7.9999,
ENG110887,IUMPR_minimum_ratio_group_4,0.8789,
ENG110888,IUMPR_minimum_ratio_group_5,1.5076,
ENG110889,IUMPR_minimum_ratio_group_6,3.6049,
ENG110890,IUMPR_minimum_ratio_group_7,2.0284,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG107569,Main_injection_quantity,0.00, mg/stroke
ENG274010-ENG274696,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 3,65535, ppm
ENG274010-ENG274697,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 3 data availability,No Sensor fault: no results available,
ENG274010-ENG274698,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 3 supported,installed,
ENG274010-ENG274699,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 4,0, ppm
ENG274010-ENG274700,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 4 data availability,Results available OR MAX value because of Sensor fault,
ENG274010-ENG274701,NOx Sensor 2-NOx Sensor Concentration Bank 1 Sensor 4 supported,not installed,
ENG274010-ENG274702,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 3,0, ppm
ENG274010-ENG274703,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 3 data availability,Results available OR MAX value because of Sensor fault,
ENG274010-ENG274704,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 3 supported,not installed,
ENG274010-ENG274705,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 4,0, ppm
ENG274010-ENG274706,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 4 data availability,Results available OR MAX value because of Sensor fault,
ENG274010-ENG274707,NOx Sensor 2-NOx Sensor Concentration Bank 2 Sensor 4 supported,not installed,
ENG151177-ENG151947,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 3,20.848212, %
ENG151177-ENG151955,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 3 supported,Available,
ENG151177-ENG151948,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 4,20.765808, %
ENG151177-ENG151956,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 1 Sensor 4 supported,Available,
ENG151177-ENG151949,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 3,0.000000, %
ENG151177-ENG151957,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 3 supported,Not available,
ENG151177-ENG151950,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 4,0.000000, %
ENG151177-ENG151958,O2 Sensor (Wide Range) 2-O2 Sensor Concentration Bank 2 Sensor 4 supported,Not available,
ENG151177-ENG151951,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 3,8.000, lambda
ENG151177-ENG151959,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 3 supported,Available,
ENG151177-ENG151952,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 4,8.000, lambda
ENG151177-ENG151960,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 1 Sensor 4 supported,Available,
ENG151177-ENG151953,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 3,0.000, lambda
ENG151177-ENG151961,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 3 supported,Not available,
ENG151177-ENG151954,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 4,0.000, lambda
ENG151177-ENG151962,O2 Sensor (Wide Range) 2-O2 Sensor Lambda Bank 2 Sensor 4 supported,Not available,
ENG168870,Oxicat_diagnose_active_status,3206,
ENG127252-ENG151857,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 1 Sensor 1,not active,
ENG127252-ENG151859,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 2 Sensor 1,not active,
ENG127252-ENG151855,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 1 Sensor 1,0.00, %
ENG127252-ENG151856,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 2 Sensor 1,0.00, %
ENG127252-ENG151861,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 1 Sensor 1 supported,Available,
ENG127252-ENG151863,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 2 Sensor 1 supported,Not available,
ENG127252-ENG151858,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 1 Sensor 1,not active,
ENG127252-ENG151860,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 2 Sensor 1,not active,
ENG127252-ENG151862,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 1 Sensor 1 supported,Available,
ENG127252-ENG151864,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 2 Sensor 1 supported,Not available,
ENG119902-ENG188621,Prioritize_exceptional_case_control-Bits 0-7,10,
ENG127401,Reductant_inducement_system_error,False result,
ENG127401-ENG127289,Reductant_inducement_system_error-Test_Program_B TRUE UBYTE,0,
ENG110382-ENG151591,SCR inducem system status-deviation of reagent consumption,Unknown (0)
ENG110382-ENG151584,SCR inducem system status-Distance traveled in current 10K block,9983, km
ENG110382-ENG151585,SCR inducem system status-Distance traveled while inducement system active in 20K block,0, km
ENG110382-ENG151586,SCR inducem system status-Distance traveled while inducement system active in 30K block,0, km
ENG110382-ENG151587,SCR inducem system status-Distance traveled while inducement system active in 40K block,0, km
ENG110382-ENG151583,SCR inducem system status-Distance traveled while inducement system active in current 10K block,0, km
ENG110382-ENG151590,SCR inducem system status-incorrect reagent,Unknown (0)
ENG110382-ENG151588,SCR inducem system status-inducement system active,not_active,
ENG110382-ENG151592,SCR inducem system status-NOx emissions too high,Unknown (0)
ENG110382-ENG151589,SCR inducem system status-reagent level too low,Unknown (0)
ENG121093-ENG188621,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG132858-ENG188621,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,0,
ENG109106-ENG188621,Status_of_adaption_of_toothed_speed-Bits 0-7,0,
ENG132847,Top_speed_limitation,250.000, km/h
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG247048,Vehicle Odometer,143433.2, km
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG132846,Velocity_limiter_setpoint,511.000, km/h
Elapsed Time: 01:31
blockmap-02-0GC-906-555-K_TMBAJ7NXXNY096941-20260703-1349.CSV
;SW:0GC-906-555-K   HW:0GC-300-047 ---  02: Auto Trans
;Component:GSG DQ381     H06 5080, Coding:0014
;EV_TCMDQ381062,001020,EV_TCMDQ381062_VW38.rod
;Friday,03,July,2026,13:49:43:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: C3D8A5DDDB17B6D20B0-8096
Group,Description,Actual
IDE00018,Voltage terminal 15,12.2, V
IDE00019,Voltage terminal 30,12.1, V
IDE00021,Engine speed,0, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,0, /min
IDE00023,Transmission output speed,0, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,32, °C
IDE00025,Coolant temperature,28, °C
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activate,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1083.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,32, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG140165,Security Access: Number of invalid keys-Counter Value,0,
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,1198.0, mA
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Direction of travel-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,-0.30, bar
IDE02221,Engine torque: qualification,valid,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,Not operated,
IDE02714,Brake test switch,Not operated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,E-Pump: power supply-Voltage Supply Electric Motor,12.2, V
IDE02727-ENG99192,Shift Lock Solenoid Specified Status-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,31, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,31, °C
IDE02742,Oil pressure actual value,0.25, bar
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,2.50, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,0.25, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,2.50, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,0.25, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,384.8, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,384.0, mA
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,397.7, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,398.0, mA
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.00, bar
IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,0.03, bar
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,50.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,50.0, mA
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,0.02, bar
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,50.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,48.0, mA
IDE02820,Transmission mileage,142934.9, km
IDE02821-ENG101653,Pressure Supply Specified Pressure/Threshold 1-Pressure Supply Commanded Value Threshold 1,0.25, bar
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02827-ENG103491,Installation information steering wheel paddles-Application Info Steering Paddels,59,
IDE02828-ENG103640,Installation information brakes-Application Info Breaksystem,59,
IDE02829-ENG103127,Installation information steering column module-Application Info Steering Modul,59,
IDE02830-ENG100103,Installation information gateway-Application Info Gateway,59,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid EOL,
IDE02861-ENG103083,Mechatronic identification-Baudatum,220412,
IDE02861-ENG98675,Mechatronic identification-Construction version,N5,
IDE02861-ENG99175,Mechatronic identification-Kassel,K,
IDE02861-ENG104192,Mechatronic identification-Kennung der Mechatronik-Montagelinie,D15,
IDE02861-ENG103830,Mechatronic identification-Lfd.-Nr,6326,
IDE02861-ENG103525,Mechatronic identification-Teilenummer (3 letzten + Index),0GCH_,
IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
IDE02862-ENG103083,Production data transmission-Baudatum,220412,
IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,UVJ,
IDE02862-ENG99175,Production data transmission-Kassel,K,
IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,D08,
IDE02862-ENG103830,Production data transmission-Lfd.-Nr,1185,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,-10.17, mm
IDE02865-ENG104121,AD value 1 of actual position of gear actuator A-Gearpositioner A Actual Position AD Value 1,3008,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,0.0, mA
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,0.00, mm
IDE02873-ENG101728,AD value 1 of actual position of gear actuator B-Gearpositioner B Actual Position AD Value 1,2045,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,0.0, mA
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.25, mm
IDE02881-ENG99453,AD value 1 of actual position of gear actuator C-Gearpositioner C Actual Position AD Value 1,2042,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,0.0, mA
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-9.44, mm
IDE02889-ENG100525,AD value 1 of actual position of gear actuator D-Gearpositioner D Actual Position AD Value 1,1216,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,0.0, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,0.0, mA
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03107-ENG126246,Kilometers at last basic setting-Kilometer At Last Basic Adjustment,0, km
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,14,
IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,Test stand data valid,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
IDE03160-ENG100046,Remaining Clutch Quick Adaptations Kiss Point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03172,Driving Strategy Percentage Driving in D or S w/Cruise,0, %
IDE03173,Driving Strategy Percentage Driving in S w/o cruise,0, %
IDE03174,Driving strategy driving portions in Tiptronic,0, %
IDE03180-ENG103176,Number of standard trips-General Denominator,457,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,61,
IDE03397-ENG252486,Status of selector lever lock-Selector_lever_shiftlock_status,Selector lever lock not installed,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,0, °C
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG159578,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG159577,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG159579,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG159710,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG159576,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,0.02, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.03, bar
IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,0.0, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,0, km
IDE06425,Dynamometer mode: functional,not activated,
IDE10300-ENG252451,OBD Driving Cycle detected-OBD_Driving_Cycle_set_once,not active,
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,145,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,117,
IDE12712-ENG167245,Mileage at last initialization clutch friction coefficient model-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG167207,Clutch friction coefficient model mileage-Gearbox mileage,142934.9, km
IDE13738-ENG167870,Function test auxiliary hydraulic pump for transmission oil status-Hauptdruck,0.00, bar
IDE13738-ENG167750,Function test auxiliary hydraulic pump for transmission oil status-Reason for abort,Do not cancel,
IDE13738-ENG101241,Function test auxiliary hydraulic pump for transmission oil status-Speed,0, /min
IDE13947-ENG167877,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,655340, km
IDE14615-MAS18568,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 1,-10.35, mm
IDE14615-MAS18569,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 2,-10.94, mm
IDE14615-MAS18570,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 3,10.99, mm
IDE14615-MAS18571,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 4,9.55, mm
IDE14615-MAS18572,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 5,8.70, mm
IDE14615-MAS18573,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 6,9.01, mm
IDE14615-MAS18574,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 7,-9.36, mm
IDE14615-MAS18575,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear R,-9.62, mm
IDE14616-MAS18576,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 1,-3.03, mm
IDE14616-MAS18577,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 2,-2.59, mm
IDE14616-MAS18578,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 3,2.29, mm
IDE14616-MAS18579,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 4,2.12, mm
IDE14616-MAS18580,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 5,1.45, mm
IDE14616-MAS18581,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 6,1.77, mm
IDE14616-MAS18582,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 7,-1.73, mm
IDE14616-MAS18583,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear R,-2.02, mm
IDE14617-MAS18584,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator A,-0.43, mm
IDE14617-MAS18585,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator B,-0.16, mm
IDE14617-MAS18586,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator C,-0.09, mm
IDE14617-MAS18587,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator D,-0.05, mm
IDE14962-MAS00966,Selector lever data-Manufacturer index location,KM7-MK1,
IDE14962-MAS00968,Selector lever data-Day of manufacture,08.03.22,
IDE14962-MAS00969,Selector lever data-Manufacturer- test stand number,2446,
IDE14962-MAS00970,Selector lever data-Running manufacturer number,323I,
IDE14962-MAS12659,Selector lever data-VW/Audi part numbers of sub-bus users,5WA713041K ,
IDE14962-MAS12660,Selector lever data-Hardware version number of sub-bus users,H04,
IDE14962-MAS12661,Selector lever data-Software version number of sub-bus users,0016,
IDE14962-MAS12662,Selector lever data-Hardware part number of sub-bus users,5WA713041  ,
IDE14962-MAS12663,Selector lever data-Series number of sub-bus users,YB075VC80323I       ,
IDE14962-MAS13422,Selector lever data-System description of sub bus participant,SB_mono      ,
IDE15365-ENG252483,Selector lever: driver's intended gear selection-Selector_lever_driver_command_of_driving_position,Not operated,
IDE15366-ENG252485,Selector lever P button status-Selector_lever_P_button_status,Not operated,
IDE15368-ENG252487,Selector lever unlock button status-Selector_lever_unlock_key_status,not installed,
IDE15370-ENG252481,Electrical parking lock raw value position-Parking_lock_actuator_raw_position,3, %
IDE15371-ENG252477,Electrical parking lock: current power consumption-Parking_lock_actuator_actual_current_consumption,0.7, A
IDE15372-ENG252479,Electrical parking lock position-Parking_lock_actuator_position,P selected,
IDE15408-ENG252484,Selector lever holding magnet status-Selector_lever_holding_magnet_status,does not stop,
IDE15409-ENG252478,Electrical parking lock output stage temperature-Parking_lock_actuator_output_stage_temperature,42, °C
IDE15410-ENG252480,Q-bit electrical parking lock-Parking_lock_actuator_qualification_bit,valid value,
IDE15411-ENG252488,Selector lever variant-Selector_lever_variant,Monostable 2x2 roller segment,
IDE15412-ENG252482,Electrical parking lock voltage-Parking_lock_actuator_voltage,13, V
IDE15789-ENG255239,Seed allocation-Provided_seed_value,15 30 E6 87,
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,6,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,109380, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,0.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,SIGNALE,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG_7,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG_6,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG264658,Analysis 13-Snapshot 1 Gearpositioner A Actual Position,-10.24, mm
IDE80014-ENG264659,Analysis 14-Snapshot 1 Gearpositioner B Actual Position,0.00, mm
IDE80015-ENG264660,Analysis 15-Snapshot 1 Gearpositioner C Actual Position,-0.16, mm
IDE80016-ENG264661,Analysis 16-Snapshot 1 Gearpositioner D Actual Position,-9.44, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.0, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,20.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,200, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,14.5, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,14.4, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,59, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,0, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,211,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,119760, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,1,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,0.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,Shutdown,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,Neutral,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG_R,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG_1,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-10.24, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,0.00, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-0.16, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-9.60, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.1, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,12.4, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,71, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,72, °C
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,65535,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,65535,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,65535,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,65535,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,65535,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,65535,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,65535,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,65535,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,65535,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,65535,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,65535,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,65535,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,382.2, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,3878613.7, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,5276639.8, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,1995.7, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,102, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,4794599.8, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,4346558.1, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,15354.0, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,776.2, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,195, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,5980023.3, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,3169790.1, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,7118.7, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,361.3, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,181, °C
IDE80101-ENG102219,Analysis 101-Betriebszeit Motor (Drehzahlbereich 1),2012.5, H
IDE80101-ENG103682,Analysis 101-Betriebszeit Motor (Drehzahlbereich 2),71.5, H
IDE80101-ENG101200,Analysis 101-Betriebszeit Motor (Drehzahlbereich 3),0.0, H
IDE80101-ENG100226,Analysis 101-Betriebszeit Motor (Drehzahlbereich 4),0.0, H
IDE80101-ENG102223,Analysis 101-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,35496,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,70014,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,116615,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,103660,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,86489,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,83929,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,46492,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,9393,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,1,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,1,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,0,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,5,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,0,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,0,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,32,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80105-ENG100707,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 1),1331.8, H
IDE80105-ENG101697,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 2),1207.4, H
IDE80105-ENG100556,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 3),4.3, H
IDE80105-ENG100205,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.2, H
IDE80106-ENG103428,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 1),1661.1, H
IDE80106-ENG101321,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 2),880.5, H
IDE80106-ENG100639,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 3),2.0, H
IDE80106-ENG103433,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.1, H
IDE80107-ENG101291,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 1),431.6, H
IDE80107-ENG104169,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 2),361.6, H
IDE80107-ENG100021,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 3),41.4, H
IDE80107-ENG101292,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 4),4.4, H
IDE80107-ENG99418,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
IDE80108-ENG99240,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 1),277.9, H
IDE80108-ENG99973,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 2),151.4, H
IDE80108-ENG103238,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 3),20.3, H
IDE80108-ENG101007,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 4),3.4, H
IDE80108-ENG101190,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
IDE80117-MAS02330,Analysis 117-SPECIFIED condition,OFF,
IDE80117-MAS02331,Analysis 117-ACTUAL condition,OFF,
IDE80118-ENG167269,Analysis 118-Snapshot 1 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80119-ENG167272,Analysis 119-Snapshot 1 auxiliary transmission fluid pump motor electronics temperature,20, °C
IDE80120-ENG167271,Analysis 120-Snapshot 1 auxiliary transmission fluid pump motor current,0, mA
IDE80121-ENG161275,Analysis 121-GOP current limitation failure status,OFF,
IDE80121-ENG161276,Analysis 121-GOP rotor position sensor failure status,OFF,
IDE80122-ENG167275,Analysis 122-Snapshot 1 auxiliary transmission fluid pump motor voltage terminal 30,0.0, V
IDE80123-ENG167270,Analysis 123-Snapshot 1 auxiliary transmission fluid pump motor commanded speed demand estimation,0, /min
IDE80124-ENG167273,Analysis 124-Snapshot 1 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80125-MAS02330,Analysis 125-SPECIFIED condition,OFF,
IDE80125-MAS02331,Analysis 125-ACTUAL condition,OFF,
IDE80126-ENG167276,Analysis 126-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80127-ENG167278,Analysis 127-Snapshot 2 auxiliary transmission fluid pump motor electronics temperature,63, °C
IDE80128-ENG167277,Analysis 128-Snapshot 2 auxiliary transmission fluid pump motor current,0, mA
IDE80129-ENG161275,Analysis 129-GOP current limitation failure status,OFF,
IDE80129-ENG161276,Analysis 129-GOP rotor position sensor failure status,OFF,
IDE80130-ENG167280,Analysis 130-Snapshot 2 auxiliary transmission fluid pump motor voltage terminal 30,12.5, V
IDE80131-ENG167276,Analysis 131-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80132-ENG167279,Analysis 132-Snapshot 2 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80133-ENG167274,Analysis 133-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80134-ENG167274,Analysis 134-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80137-ENG167891,Analysis 137-Mode A FID event memory entry 1,65535,
IDE80137-ENG167892,Analysis 137-Mode A FID event memory entry 2,65535,
IDE80137-ENG167893,Analysis 137-Mode A FID event memory entry 3,65535,
IDE80137-ENG167894,Analysis 137-Mode A FID event memory entry 4,65535,
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,143433, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,142920, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,1,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,100.0, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,420.0, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,500.0, Nm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.0, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,100.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,420.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,500.0, Nm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.0, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,1140,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,143410, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1: success counter-Clutch 2 adaption part 1 positive case counter,1619,
IDE80299-ENG127884,Clutch 2 adaption kiss point part 1: vehicle mileage-Clutch 2 adaption part 1 vehicle mileage,143250, km
IDE80303-ENG127833,Overall software description-Software full name,L50,
IDE80305-ENG125922,Parameter set description-Data set name,FL_0GC906555K_5080_PO1UVJ,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
ENG102069,Accelerator Pedal Position D,14.1, %
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,28, °C
ENG157549,Anzahl Launch Control Anfahrt,0,
ENG157501-ENG130284,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 0,88 16 04 00,
ENG157501-ENG130285,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 1,88 16 04 00,
ENG157501-ENG130286,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157501-ENG130287,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 3,78 56 34 12,
ENG157501-ENG161272,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 1,F3 02 02 00,
ENG157501-ENG167224,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 2,0,
ENG157501-ENG167225,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 3,0,
ENG157501-ENG161273,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 4,0,
ENG157501-ENG161274,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 5,0,
ENG157501-ENG167226,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 6,243,
ENG157501-ENG130283,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Gesamt-Software-Version,L50,
ENG157501-ENG160009,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Häufigkeit,23,
ENG157501-ENG98689,Ausgabe der Abschalt- und Resetdaten 1 DKSW-kilometer reading,579110, km
ENG157501-ENG130295,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 15-Spannung,11.6, V
ENG157501-ENG130296,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 30-Spannung,11.6, V
ENG157501-ENG130297,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Mechatroniktemperatur,34, °C
ENG157501-ENG130291,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Quelle,7,
ENG157501-ENG112343,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Status,1,
ENG157501-ENG130293,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Typ,1,
ENG157501-ENG130300,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Status des Eintrags,BB,
ENG157501-ENG130299,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Uds-Lesestatus des Eintrages,0,
ENG157502-ENG130284,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157502-ENG130285,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157502-ENG130286,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157502-ENG130287,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157502-ENG161272,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 1,00 00 00 00,
ENG157502-ENG167224,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 2,0,
ENG157502-ENG167225,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 3,0,
ENG157502-ENG161273,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 4,0,
ENG157502-ENG161274,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 5,0,
ENG157502-ENG167226,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 6,0,
ENG157502-ENG130283,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Gesamt-Software-Version,
ENG157502-ENG160009,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Häufigkeit,0,
ENG157502-ENG98689,Ausgabe der Abschalt- und Resetdaten 2 DKSW-kilometer reading,655350, km
ENG157502-ENG130295,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 15-Spannung,51.0, V
ENG157502-ENG130296,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 30-Spannung,51.0, V
ENG157502-ENG130297,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Mechatroniktemperatur,215, °C
ENG157502-ENG130291,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Quelle,0,
ENG157502-ENG112343,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Status,0,
ENG157502-ENG130293,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Typ,0,
ENG157502-ENG130300,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Status des Eintrags,FF,
ENG157502-ENG130299,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157503-ENG130284,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157503-ENG130285,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157503-ENG130286,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157503-ENG130287,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157503-ENG161272,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 1,00 00 00 00,
ENG157503-ENG167224,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 2,0,
ENG157503-ENG167225,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 3,0,
ENG157503-ENG161273,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 4,0,
ENG157503-ENG161274,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 5,0,
ENG157503-ENG167226,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 6,0,
ENG157503-ENG130283,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Gesamt-Software-Version,
ENG157503-ENG160009,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Häufigkeit,0,
ENG157503-ENG98689,Ausgabe der Abschalt- und Resetdaten 3 DKSW-kilometer reading,655350, km
ENG157503-ENG130295,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 15-Spannung,51.0, V
ENG157503-ENG130296,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 30-Spannung,51.0, V
ENG157503-ENG130297,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Mechatroniktemperatur,215, °C
ENG157503-ENG130291,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Quelle,0,
ENG157503-ENG112343,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Status,0,
ENG157503-ENG130293,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Typ,0,
ENG157503-ENG130300,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Status des Eintrags,FF,
ENG157503-ENG130299,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157504-ENG130284,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157504-ENG130285,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157504-ENG130286,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157504-ENG130287,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157504-ENG161272,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 1,00 00 00 00,
ENG157504-ENG167224,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 2,0,
ENG157504-ENG167225,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 3,0,
ENG157504-ENG161273,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 4,0,
ENG157504-ENG161274,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 5,0,
ENG157504-ENG167226,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 6,0,
ENG157504-ENG130283,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Gesamt-Software-Version,
ENG157504-ENG160009,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Häufigkeit,0,
ENG157504-ENG98689,Ausgabe der Abschalt- und Resetdaten 4 DKSW-kilometer reading,655350, km
ENG157504-ENG130295,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 15-Spannung,51.0, V
ENG157504-ENG130296,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 30-Spannung,51.0, V
ENG157504-ENG130297,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Mechatroniktemperatur,215, °C
ENG157504-ENG130291,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Quelle,0,
ENG157504-ENG112343,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Status,0,
ENG157504-ENG130293,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Typ,0,
ENG157504-ENG130300,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Status des Eintrags,FF,
ENG157504-ENG130299,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157505-ENG130284,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157505-ENG130285,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157505-ENG130286,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157505-ENG130287,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157505-ENG161272,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 1,00 00 00 00,
ENG157505-ENG167224,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 2,0,
ENG157505-ENG167225,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 3,0,
ENG157505-ENG161273,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 4,0,
ENG157505-ENG161274,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 5,0,
ENG157505-ENG167226,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 6,0,
ENG157505-ENG130283,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Gesamt-Software-Version,
ENG157505-ENG160009,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Häufigkeit,0,
ENG157505-ENG98689,Ausgabe der Abschalt- und Resetdaten 5 DKSW-kilometer reading,655350, km
ENG157505-ENG130295,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 15-Spannung,51.0, V
ENG157505-ENG130296,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 30-Spannung,51.0, V
ENG157505-ENG130297,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Mechatroniktemperatur,215, °C
ENG157505-ENG130291,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Quelle,0,
ENG157505-ENG112343,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Status,0,
ENG157505-ENG130293,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Typ,0,
ENG157505-ENG130300,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Status des Eintrags,FF,
ENG157505-ENG130299,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Uds-Lesestatus des Eintrages,1,
ENG101413,Calibration Identifications,0GC906555K++5080,
ENG103147,Calibration Verification Numbers (checksum),8F C5 51 33,
ENG99187,CAN version,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,73 88 B4 B1,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,31 4F 7D 3D,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,8F C5 51 33,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,1C 3C 9C 82,
ENG101012,Clutch 1 adaption basic characteristic point 0 position,2.58, bar
ENG102187,Clutch 1 adaption basic characteristic point 1 position,4.45, bar
ENG99501,Clutch 1 adaption basic characteristic point 2 position,10.24, bar
ENG99792,Clutch 1 adaption basic characteristic point 3 position,14.00, bar
ENG103827,Clutch 1 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG99333,Clutch 1 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG102537,Clutch 1 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG104250,Clutch 2 adaption basic characteristic point 0 position,2.29, bar
ENG100941,Clutch 2 adaption basic characteristic point 1 position,4.00, bar
ENG99957,Clutch 2 adaption basic characteristic point 2 position,9.41, bar
ENG99481,Clutch 2 adaption basic characteristic point 3 position,14.00, bar
ENG102732,Clutch 2 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG101931,Clutch 2 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG100136,Clutch 2 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,0, km
ENG103186,Clutch center central plate temperature,31, °C
ENG107241-ENG103334,Coefficient vmd_k_Clutch_1C0-Koeffizient,60.034,
ENG107242-ENG103334,Coefficient vmd_k_Clutch_1C1-Koeffizient,68.489,
ENG107243-ENG103334,Coefficient vmd_k_Clutch_1C2-Koeffizient,-67.470,
ENG107244-ENG103334,Coefficient vmd_k_Clutch_1C3-Koeffizient,44.227,
ENG107245-ENG103334,Coefficient vmd_k_Clutch_2C0-Koeffizient,68.556,
ENG107246-ENG103334,Coefficient vmd_k_Clutch_2C1-Koeffizient,69.909,
ENG107247-ENG103334,Coefficient vmd_k_Clutch_2C2-Koeffizient,-82.268,
ENG107248-ENG103334,Coefficient vmd_k_Clutch_2C3-Koeffizient,32.870,
ENG107249-ENG103334,Coefficient vmd_k_Cool_C0-Koeffizient,762.133,
ENG107250-ENG103334,Coefficient vmd_k_Cool_C1-Koeffizient,296.882,
ENG107251-ENG103334,Coefficient vmd_k_Cool_C2-Koeffizient,0.454,
ENG107252-ENG103334,Coefficient vmd_k_Cool_C3-Koeffizient,-23.454,
ENG107253-ENG103334,Coefficient vmd_k_Cool_C4-Koeffizient,-1.790,
ENG107254-ENG103334,Coefficient vmd_k_Cool_Qmax-Koeffizient,24.544,
ENG107255-ENG103334,Coefficient vmd_k_CutOff_ OddC0-Koeffizient,134.139,
ENG107256-ENG103334,Coefficient vmd_k_CutOff_ OddC1-Koeffizient,-0.079,
ENG107257-ENG103334,Coefficient vmd_k_CutOff_ OddC2-Koeffizient,19.158,
ENG107258-ENG103334,Coefficient vmd_k_CutOff_Even_C0-Koeffizient,164.772,
ENG107259-ENG103334,Coefficient vmd_k_CutOff_Even_C1-Koeffizient,-0.089,
ENG107260-ENG103334,Coefficient vmd_k_CutOff_Even_C2-Koeffizient,25.815,
ENG107261-ENG103334,Coefficient vmd_k_CutOff_Even_C3-Koeffizient,0.308,
ENG107262-ENG103334,Coefficient vmd_k_CutOff_Even_C4-Koeffizient,63.957,
ENG107263-ENG103334,Coefficient vmd_k_CutOff_OddC3-Koeffizient,0.399,
ENG107264-ENG103334,Coefficient vmd_k_CutOff_OddC4-Koeffizient,85.408,
ENG107265-ENG103334,Coefficient vmd_k_FlwC0_Even_ABw-Koeffizient,721.688,
ENG107266-ENG103334,Coefficient vmd_k_FlwC0_Even_AFw-Koeffizient,912.136,
ENG107267-ENG103334,Coefficient vmd_k_FlwC0_Even_BBw-Koeffizient,690.013,
ENG107268-ENG103334,Coefficient vmd_k_FlwC0_Even_BFw-Koeffizient,920.348,
ENG107269-ENG103334,Coefficient vmd_k_FlwC0_OddABw-Koeffizient,706.807,
ENG107270-ENG103334,Coefficient vmd_k_FlwC0_OddAFw-Koeffizient,907.601,
ENG107271-ENG103334,Coefficient vmd_k_FlwC0_OddBBw-Koeffizient,705.513,
ENG107272-ENG103334,Coefficient vmd_k_FlwC0_OddBFw-Koeffizient,885.832,
ENG107273-ENG103334,Coefficient vmd_k_FlwC1_Even_ABw-Koeffizient,26.040,
ENG107274-ENG103334,Coefficient vmd_k_FlwC1_Even_AFw-Koeffizient,65.644,
ENG107275-ENG103334,Coefficient vmd_k_FlwC1_Even_BBw-Koeffizient,41.570,
ENG107276-ENG103334,Coefficient vmd_k_FlwC1_Even_BFw-Koeffizient,69.211,
ENG107277-ENG103334,Coefficient vmd_k_FlwC1_OddABw-Koeffizient,30.975,
ENG107278-ENG103334,Coefficient vmd_k_FlwC1_OddAFw-Koeffizient,68.241,
ENG107279-ENG103334,Coefficient vmd_k_FlwC1_OddBBw-Koeffizient,26.540,
ENG107280-ENG103334,Coefficient vmd_k_FlwC1_OddBFw-Koeffizient,59.633,
ENG107281-ENG103334,Coefficient vmd_k_FlwC2_Even_ABw-Koeffizient,6.765,
ENG107282-ENG103334,Coefficient vmd_k_FlwC2_Even_AFw-Koeffizient,10.667,
ENG107283-ENG103334,Coefficient vmd_k_FlwC2_Even_BBw-Koeffizient,12.224,
ENG107284-ENG103334,Coefficient vmd_k_FlwC2_Even_BFw-Koeffizient,14.695,
ENG107285-ENG103334,Coefficient vmd_k_FlwC2_OddABw-Koeffizient,9.532,
ENG107286-ENG103334,Coefficient vmd_k_FlwC2_OddAFw-Koeffizient,13.975,
ENG107287-ENG103334,Coefficient vmd_k_FlwC2_OddBBw-Koeffizient,5.857,
ENG107288-ENG103334,Coefficient vmd_k_FlwC2_OddBFw-Koeffizient,9.231,
ENG107289-ENG103334,Coefficient vmd_k_FlwC3_Even_ABw-Koeffizient,-44.681,
ENG107290-ENG103334,Coefficient vmd_k_FlwC3_Even_AFw-Koeffizient,-13.251,
ENG107291-ENG103334,Coefficient vmd_k_FlwC3_Even_BBw-Koeffizient,-5.655,
ENG107292-ENG103334,Coefficient vmd_k_FlwC3_Even_BFw-Koeffizient,-27.736,
ENG107293-ENG103334,Coefficient vmd_k_FlwC3_OddABw-Koeffizient,-39.064,
ENG107294-ENG103334,Coefficient vmd_k_FlwC3_OddAFw-Koeffizient,-21.781,
ENG107295-ENG103334,Coefficient vmd_k_FlwC3_OddBBw-Koeffizient,-46.303,
ENG107296-ENG103334,Coefficient vmd_k_FlwC3_OddBFw-Koeffizient,7.640,
ENG107297-ENG103334,Coefficient vmd_k_Line_C0-Koeffizient,-5.648,
ENG107298-ENG103334,Coefficient vmd_k_Line_C1-Koeffizient,1174.500,
ENG107299-ENG103334,Coefficient vmd_k_Line_C2-Koeffizient,-40.852,
ENG107300-ENG103334,Coefficient vmd_k_Line_C3-Koeffizient,-0.010,
ENG107301-ENG103334,Coefficient vmd_k_Line_C4-Koeffizient,1.000,
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG102274,Control Module Voltage,12.200, V
ENG103403,Converter Loss Torque,2.9, Nm
ENG100625,Coolant temperature,27, °C
ENG157510-ENG167264,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,1754.5, mJ
ENG157510-ENG167265,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,489397.2, J
ENG157510-ENG167266,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,1754.5, mJ
ENG157510-ENG167267,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,489397.2, J
ENG157510-ENG161282,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG157511-ENG167264,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,1353.0, mJ
ENG157511-ENG167265,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,448496.9, J
ENG157511-ENG167266,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,1353.0, mJ
ENG157511-ENG167267,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,448496.9, J
ENG157511-ENG161282,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG104016,Designation VWDQ-Lib,L44G01,
ENG98602,Driver intention torque,-31.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG100152-ENG104003,ECUNAME-ECU,TCM,
ENG100152,ECUNAME,TransmisCtrl,
ENG98756,Engine torque,-448.0, Nm
ENG104230,Engine torque loss,61.0, Nm
ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,195, °C
ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,181, °C
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG100414,Gangsteller A Adaption Neutralposition,-0.5, mm
ENG100089,Gangsteller B Adaption Neutralposition,0.0, mm
ENG103055,Gangsteller C Adaption Neutralposition,0.1, mm
ENG101354,Gangsteller D Adaption Neutralposition,0.1, mm
ENG110510,Gear actuator adaption engaged position G1,-9.0, mm
ENG110511,Gear actuator adaption engaged position G2,-9.7, mm
ENG110512,Gear actuator adaption engaged position G3,9.7, mm
ENG99484,Gear actuator adaption engaged position G4,9.2, mm
ENG110513,Gear actuator adaption engaged position G5,8.8, mm
ENG110514,Gear actuator adaption engaged position G6,9.6, mm
ENG110515,Gear actuator adaption engaged position G7,-9.4, mm
ENG110516,Gear actuator adaption engaged position GR,-8.6, mm
ENG110517,Gear actuator adaption synchro position G1,-2.8, mm
ENG110518,Gear actuator adaption synchro position G2,-2.2, mm
ENG110519,Gear actuator adaption synchro position G3,2.1, mm
ENG99198,Gear actuator adaption synchro position G4,2.2, mm
ENG110520,Gear actuator adaption synchro position G5,1.3, mm
ENG110521,Gear actuator adaption synchro position G6,2.0, mm
ENG110522,Gear actuator adaption synchro position G7,-1.6, mm
ENG110523,Gear actuator adaption synchro position GR,-1.7, mm
ENG157514-ENG161285,Gear_ratio_control-Status 1-Gang,Übersetzung i.O.,
ENG157514-ENG161286,Gear_ratio_control-Status 2-Gang,Übersetzung i.O.,
ENG157514-ENG161287,Gear_ratio_control-Status 3-Gang,Übersetzung i.O.,
ENG157514-ENG161288,Gear_ratio_control-Status 4-Gang,Übersetzung i.O.,
ENG157514-ENG161289,Gear_ratio_control-Status 5-Gang,Übersetzung i.O.,
ENG157514-ENG161290,Gear_ratio_control-Status 6-Gang,Übersetzung i.O.,
ENG157514-ENG161291,Gear_ratio_control-Status 7-Gang,Übersetzung i.O.,
ENG157514-ENG161292,Gear_ratio_control-Status R-Gang,Übersetzung i.O.,
ENG157514-ENG167281,Gear_ratio_control-Übersetzung 1-Gang,15.145,
ENG157514-ENG167282,Gear_ratio_control-Übersetzung 2-Gang,8.634,
ENG157514-ENG167283,Gear_ratio_control-Übersetzung 3-Gang,5.239,
ENG157514-ENG167284,Gear_ratio_control-Übersetzung 4-Gang,3.708,
ENG157514-ENG167285,Gear_ratio_control-Übersetzung 5-Gang,2.820,
ENG157514-ENG167286,Gear_ratio_control-Übersetzung 6-Gang,2.255,
ENG157514-ENG167287,Gear_ratio_control-Übersetzung 7-Gang,1.750,
ENG157514-ENG167288,Gear_ratio_control-Übersetzung R-Gang,12.243,
ENG157515-ENG167227,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_A,7.7, mm
ENG157515-ENG167228,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_B,-76.8, mm
ENG157515-ENG167229,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167230,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167231,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_A,7.7, mm
ENG157515-ENG167232,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_B,-76.8, mm
ENG157515-ENG167233,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167234,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167235,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_A,7.7, mm
ENG157515-ENG167236,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_B,-76.8, mm
ENG157515-ENG167237,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167238,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167239,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_A,7.7, mm
ENG157515-ENG167240,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_B,-76.8, mm
ENG157515-ENG167241,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167242,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167246,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_A,79.3, mm
ENG157515-ENG167247,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_B,-5.1, mm
ENG157515-ENG167248,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167249,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167250,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_A,79.3, mm
ENG157515-ENG167251,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_B,-5.1, mm
ENG157515-ENG167252,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167253,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167254,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_A,79.3, mm
ENG157515-ENG167255,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_B,-5.1, mm
ENG157515-ENG167256,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167257,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167258,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_A,79.3, mm
ENG157515-ENG167259,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_B,-5.1, mm
ENG157515-ENG167260,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167261,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_B,51.2, mm
ENG157516-ENG167243,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_1,240.6, bar
ENG157516-ENG167244,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_2,240.6, bar
ENG157516-ENG167262,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_1,307.2, bar
ENG157516-ENG167263,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_2,281.6, bar
ENG99720,Height info,984, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,30.0, Nm
ENG99582,Intake air temperature,30, °C
ENG252350,Kupplung 1 Adaption Kupplungsendlage (KEL) geschlossen,15.00, bar
ENG252349,Kupplung 1 Adaption Kupplungsendlage (KEL) offen,0.00, bar
ENG110538,Kupplung 2 Adaption Kupplungsendlage (KEL) geschlossen,15.00, bar
ENG110539,Kupplung 2 Adaption Kupplungsendlage (KEL) offen,0.00, bar
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,21,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,15338,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,7914,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,90,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,1431,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,20023,
ENG101251,Leergas,Leergas,
ENG107605-ENG103083,Mechatronics-ID_Dev.-Baudatum,220412,
ENG107605-ENG98675,Mechatronics-ID_Dev.-Construction version,N5,
ENG107605-ENG99175,Mechatronics-ID_Dev.-Kassel,K,
ENG107605-ENG104192,Mechatronics-ID_Dev.-Kennung der Mechatronik-Montagelinie,D15,
ENG107605-ENG103830,Mechatronics-ID_Dev.-Lfd.-Nr,6326,
ENG107605-ENG103525,Mechatronics-ID_Dev.-Teilenummer (3 letzten + Index),0GCH_,
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,124.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,4294967295, km
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.1, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),1077.4, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),1465.7, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.6, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG100188,Reached maximum temperature control module,102, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,0.0, %
ENG103000,Run time complete system,2543.9960, H
ENG100909,Snapshot 1 Info current ECM3 error 0,0,
ENG100722,Snapshot 1 Info current ECM3 error 1,0,
ENG103157,Snapshot 1 Info old ECM3 error 0,0,
ENG99098,Snapshot 1 Info old ECM3 error 1,0,
ENG102200,Snapshot 2 Info current ECM3 error 0,0,
ENG101765,Snapshot 2 Info current ECM3 error 1,0,
ENG101738,Snapshot 2 Info old ECM3 error 0,0,
ENG101881,Snapshot 2 Info old ECM3 error 1,0,
ENG263113-ENG263203,Snapshot_1_TCM_DQ381-Accelerator_Pedal_Position,20.0, %
ENG263113-ENG263225,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263113-ENG263226,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263113-ENG263227,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263113-ENG263228,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,20, °C
ENG263113-ENG263787,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263113-ENG263788,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263113-ENG263230,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263113-ENG263789,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263113-ENG263790,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263113-ENG263233,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,0.0, V
ENG263113-ENG263236,Snapshot_1_TCM_DQ381-Clutch_1/2_maximum_temperature,0, °C
ENG263113-ENG129747,Snapshot_1_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263113-ENG263237,Snapshot_1_TCM_DQ381-Clutch_1_current_valve_actual_value,0, mA
ENG263113-ENG129748,Snapshot_1_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263113-ENG263238,Snapshot_1_TCM_DQ381-Clutch_2_current_valve_actual_value,0, mA
ENG263113-ENG263792,Snapshot_1_TCM_DQ381-Clutch_cooling_current_valve,1195, mA
ENG263113-ENG263239,Snapshot_1_TCM_DQ381-Clutch_main_condition,New,
ENG263113-ENG263240,Snapshot_1_TCM_DQ381-Commanded_gear,GANG_7,
ENG263113-ENG98516,Snapshot_1_TCM_DQ381-Counter,0,
ENG263113-ENG263805,Snapshot_1_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263113-ENG263218,Snapshot_1_TCM_DQ381-Engine_torque,200, Nm
ENG263113-ENG263254,Snapshot_1_TCM_DQ381-Failure_ID,6,
ENG263113-ENG263257,Snapshot_1_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263113-ENG263206,Snapshot_1_TCM_DQ381-Gearpositioner_A_Actual_Position,-10.24, mm
ENG263113-ENG263207,Snapshot_1_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263113-ENG263208,Snapshot_1_TCM_DQ381-Gearpositioner_B_Actual_Position,0.00, mm
ENG263113-ENG263209,Snapshot_1_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263113-ENG263210,Snapshot_1_TCM_DQ381-Gearpositioner_C_Actual_Position,-0.16, mm
ENG263113-ENG263211,Snapshot_1_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263113-ENG263212,Snapshot_1_TCM_DQ381-Gearpositioner_D_Actual_Position,-9.44, mm
ENG263113-ENG263213,Snapshot_1_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263113-ENG263260,Snapshot_1_TCM_DQ381-Information_actual_ECM3_error_0,0,
ENG263113-ENG263261,Snapshot_1_TCM_DQ381-Information_actual_ECM3_error_1,0,
ENG263113-ENG263262,Snapshot_1_TCM_DQ381-Information_old_ECM3_error_0,0,
ENG263113-ENG263263,Snapshot_1_TCM_DQ381-Information_old_ECM3_error_1,0,
ENG263113-ENG263836,Snapshot_1_TCM_DQ381-Main_pressure_/_accumulator_current_valve,1205, mA
ENG263113-ENG103063,Snapshot_1_TCM_DQ381-Mileage,109380, km
ENG263113-ENG263217,Snapshot_1_TCM_DQ381-Oil_Pressure_Actual_Value,0.0, bar
ENG263113-ENG263286,Snapshot_1_TCM_DQ381-Preselection_gear,GANG_6,
ENG263113-ENG263214,Snapshot_1_TCM_DQ381-Shift_Position_Plausible,P,
ENG263113-ENG263309,Snapshot_1_TCM_DQ381-Transmission_fluid_temperature,59, °C
ENG263113-ENG263310,Snapshot_1_TCM_DQ381-Transmission_input_speed,0, /min
ENG263113-ENG263215,Snapshot_1_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263113-ENG263311,Snapshot_1_TCM_DQ381-Transmission_part_1_current_valve_actual_value,0, mA
ENG263113-ENG263312,Snapshot_1_TCM_DQ381-Transmission_part_2_current_valve_actual_value,0, mA
ENG263113-ENG263313,Snapshot_1_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263113-ENG263314,Snapshot_1_TCM_DQ381-Transmission_speed_shaft_2,0, /min
ENG263113-ENG263315,Snapshot_1_TCM_DQ381-Vehicle_condition,SIGNALE,
ENG263113-ENG263216,Snapshot_1_TCM_DQ381-Voltage_Supply_Electric_Motor,14.4, V
ENG263113-ENG263202,Snapshot_1_TCM_DQ381-Voltage_Terminal_15,14.5, V
ENG263116-ENG263203,Snapshot_2_TCM_DQ381-Accelerator_Pedal_Position,0.0, %
ENG263116-ENG263225,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263116-ENG263226,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263116-ENG263227,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263116-ENG263228,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,63, °C
ENG263116-ENG263787,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263116-ENG263788,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263116-ENG263230,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263116-ENG263789,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263116-ENG263790,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263116-ENG263233,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,12.5, V
ENG263116-ENG263236,Snapshot_2_TCM_DQ381-Clutch_1/2_maximum_temperature,72, °C
ENG263116-ENG129747,Snapshot_2_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263116-ENG263237,Snapshot_2_TCM_DQ381-Clutch_1_current_valve_actual_value,0, mA
ENG263116-ENG129748,Snapshot_2_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263116-ENG263238,Snapshot_2_TCM_DQ381-Clutch_2_current_valve_actual_value,0, mA
ENG263116-ENG263792,Snapshot_2_TCM_DQ381-Clutch_cooling_current_valve,0, mA
ENG263116-ENG263239,Snapshot_2_TCM_DQ381-Clutch_main_condition,Neutral,
ENG263116-ENG263240,Snapshot_2_TCM_DQ381-Commanded_gear,GANG_R,
ENG263116-ENG98516,Snapshot_2_TCM_DQ381-Counter,1,
ENG263116-ENG263805,Snapshot_2_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263116-ENG263218,Snapshot_2_TCM_DQ381-Engine_torque,-50, Nm
ENG263116-ENG263254,Snapshot_2_TCM_DQ381-Failure_ID,211,
ENG263116-ENG263257,Snapshot_2_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263116-ENG263206,Snapshot_2_TCM_DQ381-Gearpositioner_A_Actual_Position,-10.24, mm
ENG263116-ENG263207,Snapshot_2_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263116-ENG263208,Snapshot_2_TCM_DQ381-Gearpositioner_B_Actual_Position,0.00, mm
ENG263116-ENG263209,Snapshot_2_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263116-ENG263210,Snapshot_2_TCM_DQ381-Gearpositioner_C_Actual_Position,-0.16, mm
ENG263116-ENG263211,Snapshot_2_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263116-ENG263212,Snapshot_2_TCM_DQ381-Gearpositioner_D_Actual_Position,-9.60, mm
ENG263116-ENG263213,Snapshot_2_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263116-ENG263260,Snapshot_2_TCM_DQ381-Information_actual_ECM3_error_0,0,
ENG263116-ENG263261,Snapshot_2_TCM_DQ381-Information_actual_ECM3_error_1,0,
ENG263116-ENG263262,Snapshot_2_TCM_DQ381-Information_old_ECM3_error_0,0,
ENG263116-ENG263263,Snapshot_2_TCM_DQ381-Information_old_ECM3_error_1,0,
ENG263116-ENG263836,Snapshot_2_TCM_DQ381-Main_pressure_/_accumulator_current_valve,0, mA
ENG263116-ENG103063,Snapshot_2_TCM_DQ381-Mileage,119760, km
ENG263116-ENG263217,Snapshot_2_TCM_DQ381-Oil_Pressure_Actual_Value,0.0, bar
ENG263116-ENG263286,Snapshot_2_TCM_DQ381-Preselection_gear,GANG_1,
ENG263116-ENG263214,Snapshot_2_TCM_DQ381-Shift_Position_Plausible,P,
ENG263116-ENG263309,Snapshot_2_TCM_DQ381-Transmission_fluid_temperature,71, °C
ENG263116-ENG263310,Snapshot_2_TCM_DQ381-Transmission_input_speed,0, /min
ENG263116-ENG263215,Snapshot_2_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263116-ENG263311,Snapshot_2_TCM_DQ381-Transmission_part_1_current_valve_actual_value,0, mA
ENG263116-ENG263312,Snapshot_2_TCM_DQ381-Transmission_part_2_current_valve_actual_value,0, mA
ENG263116-ENG263313,Snapshot_2_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263116-ENG263314,Snapshot_2_TCM_DQ381-Transmission_speed_shaft_2,0, /min
ENG263116-ENG263315,Snapshot_2_TCM_DQ381-Vehicle_condition,Shutdown,
ENG263116-ENG263216,Snapshot_2_TCM_DQ381-Voltage_Supply_Electric_Motor,12.4, V
ENG263116-ENG263202,Snapshot_2_TCM_DQ381-Voltage_Terminal_15,0.1, V
ENG263119-ENG263203,Snapshot_3_TCM_DQ381-Accelerator_Pedal_Position,0.0, %
ENG263119-ENG263225,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263119-ENG263226,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263119-ENG263227,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263119-ENG263228,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,22, °C
ENG263119-ENG263787,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263119-ENG263788,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263119-ENG263230,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263119-ENG263789,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263119-ENG263790,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263119-ENG263233,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,9.4, V
ENG263119-ENG263236,Snapshot_3_TCM_DQ381-Clutch_1/2_maximum_temperature,24, °C
ENG263119-ENG129747,Snapshot_3_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263119-ENG263237,Snapshot_3_TCM_DQ381-Clutch_1_current_valve_actual_value,50, mA
ENG263119-ENG129748,Snapshot_3_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263119-ENG263238,Snapshot_3_TCM_DQ381-Clutch_2_current_valve_actual_value,50, mA
ENG263119-ENG263792,Snapshot_3_TCM_DQ381-Clutch_cooling_current_valve,1200, mA
ENG263119-ENG263239,Snapshot_3_TCM_DQ381-Clutch_main_condition,Neutral,
ENG263119-ENG263240,Snapshot_3_TCM_DQ381-Commanded_gear,GANG_R,
ENG263119-ENG98516,Snapshot_3_TCM_DQ381-Counter,2,
ENG263119-ENG263805,Snapshot_3_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263119-ENG263218,Snapshot_3_TCM_DQ381-Engine_torque,-18, Nm
ENG263119-ENG263254,Snapshot_3_TCM_DQ381-Failure_ID,172,
ENG263119-ENG263257,Snapshot_3_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263119-ENG263206,Snapshot_3_TCM_DQ381-Gearpositioner_A_Actual_Position,-10.08, mm
ENG263119-ENG263207,Snapshot_3_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263119-ENG263208,Snapshot_3_TCM_DQ381-Gearpositioner_B_Actual_Position,0.00, mm
ENG263119-ENG263209,Snapshot_3_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263119-ENG263210,Snapshot_3_TCM_DQ381-Gearpositioner_C_Actual_Position,-0.16, mm
ENG263119-ENG263211,Snapshot_3_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263119-ENG263212,Snapshot_3_TCM_DQ381-Gearpositioner_D_Actual_Position,-9.28, mm
ENG263119-ENG263213,Snapshot_3_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263119-ENG263260,Snapshot_3_TCM_DQ381-Information_actual_ECM3_error_0,243,
ENG263119-ENG263261,Snapshot_3_TCM_DQ381-Information_actual_ECM3_error_1,2,
ENG263119-ENG263262,Snapshot_3_TCM_DQ381-Information_old_ECM3_error_0,243,
ENG263119-ENG263263,Snapshot_3_TCM_DQ381-Information_old_ECM3_error_1,2,
ENG263119-ENG263836,Snapshot_3_TCM_DQ381-Main_pressure_/_accumulator_current_valve,1070, mA
ENG263119-ENG103063,Snapshot_3_TCM_DQ381-Mileage,142920, km
ENG263119-ENG263217,Snapshot_3_TCM_DQ381-Oil_Pressure_Actual_Value,1.0, bar
ENG263119-ENG263286,Snapshot_3_TCM_DQ381-Preselection_gear,GANG_1,
ENG263119-ENG263214,Snapshot_3_TCM_DQ381-Shift_Position_Plausible,P,
ENG263119-ENG263309,Snapshot_3_TCM_DQ381-Transmission_fluid_temperature,24, °C
ENG263119-ENG263310,Snapshot_3_TCM_DQ381-Transmission_input_speed,992, /min
ENG263119-ENG263215,Snapshot_3_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263119-ENG263311,Snapshot_3_TCM_DQ381-Transmission_part_1_current_valve_actual_value,50, mA
ENG263119-ENG263312,Snapshot_3_TCM_DQ381-Transmission_part_2_current_valve_actual_value,395, mA
ENG263119-ENG263313,Snapshot_3_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263119-ENG263314,Snapshot_3_TCM_DQ381-Transmission_speed_shaft_2,0, /min
ENG263119-ENG263315,Snapshot_3_TCM_DQ381-Vehicle_condition,FAP,
ENG263119-ENG263216,Snapshot_3_TCM_DQ381-Voltage_Supply_Electric_Motor,9.3, V
ENG263119-ENG263202,Snapshot_3_TCM_DQ381-Voltage_Terminal_15,9.3, V
ENG263122-ENG263203,Snapshot_4_TCM_DQ381-Accelerator_Pedal_Position,0.0, %
ENG263122-ENG263225,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263122-ENG263226,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263122-ENG263227,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263122-ENG263228,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,-40, °C
ENG263122-ENG263787,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263122-ENG263788,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263122-ENG263230,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263122-ENG263789,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263122-ENG263790,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263122-ENG263233,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,0.0, V
ENG263122-ENG263236,Snapshot_4_TCM_DQ381-Clutch_1/2_maximum_temperature,-60, °C
ENG263122-ENG129747,Snapshot_4_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263122-ENG263237,Snapshot_4_TCM_DQ381-Clutch_1_current_valve_actual_value,0, mA
ENG263122-ENG129748,Snapshot_4_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263122-ENG263238,Snapshot_4_TCM_DQ381-Clutch_2_current_valve_actual_value,0, mA
ENG263122-ENG263792,Snapshot_4_TCM_DQ381-Clutch_cooling_current_valve,0, mA
ENG263122-ENG263239,Snapshot_4_TCM_DQ381-Clutch_main_condition,New,
ENG263122-ENG263240,Snapshot_4_TCM_DQ381-Commanded_gear,GANG N,
ENG263122-ENG98516,Snapshot_4_TCM_DQ381-Counter,0,
ENG263122-ENG263805,Snapshot_4_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263122-ENG263218,Snapshot_4_TCM_DQ381-Engine_torque,-50, Nm
ENG263122-ENG263254,Snapshot_4_TCM_DQ381-Failure_ID,65535,
ENG263122-ENG263257,Snapshot_4_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263122-ENG263206,Snapshot_4_TCM_DQ381-Gearpositioner_A_Actual_Position,-20.48, mm
ENG263122-ENG263207,Snapshot_4_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263122-ENG263208,Snapshot_4_TCM_DQ381-Gearpositioner_B_Actual_Position,-20.48, mm
ENG263122-ENG263209,Snapshot_4_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263122-ENG263210,Snapshot_4_TCM_DQ381-Gearpositioner_C_Actual_Position,-20.48, mm
ENG263122-ENG263211,Snapshot_4_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263122-ENG263212,Snapshot_4_TCM_DQ381-Gearpositioner_D_Actual_Position,-20.48, mm
ENG263122-ENG263213,Snapshot_4_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263122-ENG263260,Snapshot_4_TCM_DQ381-Information_actual_ECM3_error_0,0,
ENG263122-ENG263261,Snapshot_4_TCM_DQ381-Information_actual_ECM3_error_1,0,
ENG263122-ENG263262,Snapshot_4_TCM_DQ381-Information_old_ECM3_error_0,0,
ENG263122-ENG263263,Snapshot_4_TCM_DQ381-Information_old_ECM3_error_1,0,
ENG263122-ENG263836,Snapshot_4_TCM_DQ381-Main_pressure_/_accumulator_current_valve,0, mA
ENG263122-ENG103063,Snapshot_4_TCM_DQ381-Mileage,0, km
ENG263122-ENG263217,Snapshot_4_TCM_DQ381-Oil_Pressure_Actual_Value,-10.0, bar
ENG263122-ENG263286,Snapshot_4_TCM_DQ381-Preselection_gear,GANG N,
ENG263122-ENG263214,Snapshot_4_TCM_DQ381-Shift_Position_Plausible,P,
ENG263122-ENG263309,Snapshot_4_TCM_DQ381-Transmission_fluid_temperature,-60, °C
ENG263122-ENG263310,Snapshot_4_TCM_DQ381-Transmission_input_speed,0, /min
ENG263122-ENG263215,Snapshot_4_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263122-ENG263311,Snapshot_4_TCM_DQ381-Transmission_part_1_current_valve_actual_value,0, mA
ENG263122-ENG263312,Snapshot_4_TCM_DQ381-Transmission_part_2_current_valve_actual_value,0, mA
ENG263122-ENG263313,Snapshot_4_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263122-ENG263314,Snapshot_4_TCM_DQ381-Transmission_speed_shaft_2,0, /min
ENG263122-ENG263315,Snapshot_4_TCM_DQ381-Vehicle_condition,New,
ENG263122-ENG263216,Snapshot_4_TCM_DQ381-Voltage_Supply_Electric_Motor,0.0, V
ENG263122-ENG263202,Snapshot_4_TCM_DQ381-Voltage_Terminal_15,0.0, V
ENG101057,Specified idle speed,1060, /min
ENG100803,Speed: output,0, /min
ENG106780-ENG103213,Transmission-ID_Dev.-Aggregatekennzeichnung (Getriebe),006,
ENG106780-ENG103083,Transmission-ID_Dev.-Baudatum,220412,
ENG106780-ENG104019,Transmission-ID_Dev.-Getriebekennbuchstabe,UVJ,
ENG106780-ENG99175,Transmission-ID_Dev.-Kassel,K,
ENG106780-ENG101707,Transmission-ID_Dev.-Kennung der Montagelinie,D08,
ENG106780-ENG103830,Transmission-ID_Dev.-Lfd.-Nr,1185,
ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
ENG109959-ENG101914,vmd_i_FlwVlvCurMin_mA_EvenA-vmd i FlwVlvCurMin mA EvenA,443,
ENG109960-ENG104144,vmd_i_FlwVlvCurMin_mA_EvenB-vmd i FlwVlvCurMin mA EvenB,454,
ENG109961-ENG101870,vmd_i_FlwVlvCurMin_mA_OddA-vmd i FlwVlvCurMin mA OddA,443,
ENG109962-ENG102688,vmd_i_FlwVlvCurMin_mA_OddB-vmd i FlwVlvCurMin mA OddB,442,
ENG109963-ENG103264,vmd_i_NulFlw_mA_Even_ABw-vmd i NulFlw mA Even ABw,724,
ENG109964-ENG100102,vmd_i_NulFlw_mA_Even_AFw-vmd i NulFlw mA Even AFw,879,
ENG109965-ENG103659,vmd_i_NulFlw_mA_Even_BBw-vmd i NulFlw mA Even BBw,724,
ENG109966-ENG100519,vmd_i_NulFlw_mA_Even_BFw-vmd i NulFlw mA Even BFw,868,
ENG109967-ENG99410,vmd_i_NulFlw_mA_OddABw-vmd i NulFlw mA OddABw,717,
ENG109968-ENG99443,vmd_i_NulFlw_mA_OddAFw-vmd i NulFlw mA OddAFw,858,
ENG109969-ENG100167,vmd_i_NulFlw_mA_OddBBw-vmd i NulFlw mA OddBBw,705,
ENG109970-ENG99387,vmd_i_NulFlw_mA_OddBFw-vmd i NulFlw mA OddBFw,865,
ENG109971-ENG103334,vmd_k_Line_PmaxKoeffizient vmd_k_Line_Pmax-Koeffizient,24.545,
ENG109005,Voltage Common Highside 1,12.2, V
ENG99955,Voltage Common Highside 2,12.2, V
Elapsed Time: 00:46
blockmap-03-5WA-614-517-BL_TMBAJ7NXXNY096941-20260703-1350.CSV
;SW:5WA-614-517-BL   HW:5WA-614-517-N ---  03: ABS Brakes
;Component:ESC           H13 0133, Coding:34072CA422294472528050040AC461866DB658F55AC8670821BCA231018FF100002814
;EV_Brake1ESCEPBMQB37W,013056,EV_Brake1ESCEPBMQB37W_013_AU38.rod
;Friday,03,July,2026,13:50:36:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: 9378559DEBF7E652FB0-80C6 SFD {x}
Group,Description,Actual
IDE00019,Voltage terminal 30,12.265, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,28.0, °C
IDE00085,Normed load value,0, %
IDE00086,Accelerator pedal position,14.1, %
IDE00097,OBD - requirements for which this vehicle is designed,EOBD,
IDE00601-ENG161107,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG161129,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG161142,Monitoring status since erasing DTC memory-Readiness_State,00000000 ,
IDE00601-ENG161227,Monitoring status since erasing DTC memory-Supported_Info,00000000 ,
IDE00601-ENG161228,Monitoring status since erasing DTC memory-Supported_Info_Readiness,00000100 ,
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,NXXNY096941,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,On,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.braking,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,197,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.braking,1,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,11,
IDE03010-MAS01299,Number of prevented stop processes-Offroad,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,73,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,38,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,80,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,64561,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,11,
IDE03011-MAS02515,Number of requested start processes-System malfunction,37,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,38,
IDE03310,Brake lamp,OFF,
IDE03310-MAS01167,Brake lamp-Actuation time,0 s,
IDE03310-ENG170421,Brake lamp-IoReached Status,Output diagnostic test not active,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.0, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,12.3, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.3, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,12.3, V
IDE03680-MAS01468,Supply voltages-Terminal 15,On,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,-327.51, bar
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,forward,
IDE04425-MAS09580,Left front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,forward,
IDE04426-MAS09580,Right front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-MAS09580,Left rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-MAS09580,Right rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.13734, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,-0.16677, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.39240, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,0.166, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,0.481, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,1.575, °
IDE04446-IDE14988,Hill descent control-Incline,0, %
IDE04446-MAS01299,Hill descent control-Offroad,Off-road deactivated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04446-MAS05585,Hill descent control-Standby,not active,
IDE04446-MAS12601,Hill descent control-HDC intervention,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not available due to specific system,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,143401, km
IDE04461-MAS01481,Internal measured values-Temperature in control module,36.3, °C
IDE04461-MAS10973,Internal measured values-Hardware reset,120,
IDE04461-MAS10974,Internal measured values-Software reset,5797,
IDE04461-MAS15830,Internal measured values-Data block description,Block 2,
IDE04461-MAS17870,Internal measured values-Number of resets,0,
IDE04461-ENG264503,Internal measured values-C1 Idle Task,42, %
IDE04461-ENG264509,Internal measured values-Ct mainloop,51, %
IDE04461-ENG264510,Internal measured values-Ct prc task,53, %
IDE04461-ENG264511,Internal measured values-Ct valve task,53, %
IDE04461-ENG126445,Internal measured values-Idle Task,29, %
IDE04461-ENG264549,Internal measured values-Idp Task,33, %
IDE04461-ENG264551,Internal measured values-Ipb main task,15, %
IDE04461-ENG264552,Internal measured values-Ipb safety task,42, %
IDE04461-ENG264663,Internal measured values-Task BAP 10ms,44, %
IDE04461-ENG264664,Internal measured values-Task C0 Com task 5ms AsilD,0, %
IDE04461-ENG264665,Internal measured values-Task C1 10ms AsilB,39, %
IDE04461-ENG264666,Internal measured values-Task C1 1ms AsilB,36, %
IDE04461-ENG264667,Internal measured values-Task Com task1 5ms AsilD,41, %
IDE04461-ENG264668,Internal measured values-Task Com task1 5ms Qm,47, %
IDE04461-ENG264669,Internal measured values-Task Com task2 5ms Qm,68, %
IDE04461-ENG264670,Internal measured values-Task mFDR 5ms_AsilD,59, %
IDE04461-ENG264671,Internal measured values-Task mFDR 5ms_Qm,64, %
IDE04461-ENG264672,Internal measured values-Task TPI 20ms,50, %
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,139691, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,not activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,0, m/s²
IDE04765-IDE02955,Counter steer support-System status,Not available due to specific system,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,0, km
IDE04772,Indicator light in the button for electromech. parking brake,On,
IDE04772-MAS01167,Indicator light in the button for electromech. parking brake-Actuation time,Without time limit,
IDE04772-ENG170421,Indicator light in the button for electromech. parking brake-IoReached Status,Output diagnostic test not active,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04939-IDE02763,Tire Pressure Monitoring System (TPMS)-System malfunction lamp: status,OFF,
IDE04939-IDE02765,Tire Pressure Monitoring System (TPMS)-Pressure warning lamp: status,OFF,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,143055, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,143314, km
IDE04939-IDE09286,Tire Pressure Monitoring System (TPMS)-Software version of tire monitoring display,R1906A26,
IDE04939-IDE09287,Tire Pressure Monitoring System (TPMS)-Param. set version tire press monitoring display,0,
IDE04939-IDE09288,Tire Pressure Monitoring System (TPMS)-Param. set tire press monitor display: checksum,48,
IDE04939-IDE09289,Tire Pressure Monitoring System (TPMS)-Tire press monitor.display: diagnosis status,00 00 04 05 00 00 00 00 A8 22,
IDE04939-IDE11039,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: le. frt,241,
IDE04939-IDE11040,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,241,
IDE04939-IDE11041,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.:counter for fast press. loss: le. rr.,241,
IDE04939-IDE11042,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,241,
IDE04939-IDE11043,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. frt,221,
IDE04939-IDE11044,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,221,
IDE04939-IDE11045,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. rr.,221,
IDE04939-IDE11046,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,221,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2025,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2026,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,8,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,7,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,6,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,4,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,4,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,17,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,24,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,6,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,27,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,3,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,25,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,18,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,0,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,20,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,2,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,11,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,15,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,41,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,10,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,6,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,7,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,40,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,8,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,53,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,42,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,56,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,32,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,17,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,27,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,7,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,48,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,34,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,35,
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,141061, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,119761, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,118244, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,4294967295, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,143129, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,143129, km
IDE04939-MAS14292,Tire Pressure Monitoring System (TPMS)-Analysis data of latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14293,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14294,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14295,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14296,Tire Pressure Monitoring System (TPMS)-Analysis data of the latest warning,01 21 00 00 00 00 00 00 00 10,
IDE04939-MAS14297,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest warning,01 21 00 00 00 00 00 00 00 10,
IDE04939-MAS14298,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest warning,02 25 A4 02 00 28 00 00 A8 22,
IDE04939-MAS14299,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest warning,02 25 A4 02 00 28 00 00 A8 22,
IDE04939-MAS18039,Tire Pressure Monitoring System (TPMS)-Odometer reading at fifth most recent configuration,118244, km
IDE04939-MAS18041,Tire Pressure Monitoring System (TPMS)-Analysis data from fifth most recent configuration,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS18042,Tire Pressure Monitoring System (TPMS)-Temperature at time of most recent warning,32, °C
IDE04939-MAS18066,Tire Pressure Monitoring System (TPMS)-Temperature at time of second to last warning,25, °C
IDE04939-MAS18067,Tire Pressure Monitoring System (TPMS)-Temperature at time of third most recent warning,24, °C
IDE04939-MAS18069,Tire Pressure Monitoring System (TPMS)-Temperature at time of fourth most recent warning,24, °C
IDE04939-MAS18070,Tire Pressure Monitoring System (TPMS)-Odometer reading of fifth most recent warning,143129, km
IDE04939-MAS18072,Tire Pressure Monitoring System (TPMS)-Temperature at time of fifth most recent warning,25, °C
IDE04939-MAS18073,Tire Pressure Monitoring System (TPMS)-Analysis data of fifth most recent warning,02 25 A4 02 00 28 00 00 A8 22,
IDE04939-MAS18074,Tire Pressure Monitoring System (TPMS)-Tire control display parameter set info,195,
IDE04939-MAS18076,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during most recent warning,19, °C
IDE04939-MAS18077,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during second most recent warning,19, °C
IDE04939-MAS18078,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during third most recent warning,19, °C
IDE04939-MAS18079,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fourth most recent warning,19, °C
IDE04939-MAS18080,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fifth most recent warning,19, °C
IDE04939-ENG135557,Tire Pressure Monitoring System (TPMS)-RKA_Config_Info,0,
IDE05053,Right parking brake motor: close gradually,Open,
IDE05053-MAS01167,Right parking brake motor: close gradually-Actuation time,Without time limit,
IDE05053-ENG170421,Right parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05054,Left parking brake motor: close gradually,Open,
IDE05054-MAS01167,Left parking brake motor: close gradually-Actuation time,Without time limit,
IDE05054-ENG170421,Left parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05333,Indicator light in AUTO HOLD button,OFF,
IDE05333-MAS01167,Indicator light in AUTO HOLD button-Actuation time,Without time limit,
IDE05333-ENG170421,Indicator light in AUTO HOLD button-IoReached Status,Output diagnostic test not active,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06422-ENG103176,IUMPR_1-General Denominator,1893,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,6835,
IDE06422-ENG100120,IUMPR_1-Milage,139310,
IDE06422-ENG101622,IUMPR_1-Record Number,41,
IDE06423-ENG101817,IUMPR_2-Denominator,1893,
IDE06423-ENG103772,IUMPR_2-DFCC Value,00 8B,
IDE06423-ENG99150,IUMPR_2-Numerator,6136,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06424-ENG101817,IUMPR_3-Denominator,1893,
IDE06424-ENG103772,IUMPR_3-DFCC Value,10 BD,
IDE06424-ENG99150,IUMPR_3-Numerator,6136,
IDE06424-ENG101622,IUMPR_3-Record Number,2,
IDE07183,Parking brake motors: close incrementally,Open,
IDE07183-MAS01167,Parking brake motors: close incrementally-Actuation time,Without time limit,
IDE07183-ENG170421,Parking brake motors: close incrementally-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,not active,
IDE13239-IDE04947,Loose wheel warning system-Odometer reading of last warning,0, km
IDE13239-MAS00106,Loose wheel warning system-Year,2000,
IDE13239-MAS00107,Loose wheel warning system-Month,0,
IDE13239-MAS00108,Loose wheel warning system-Day,0,
IDE13239-MAS00109,Loose wheel warning system-Hours,0,
IDE13239-MAS00110,Loose wheel warning system-Minutes,0,
IDE13239-MAS00111,Loose wheel warning system-Seconds,0,
IDE13239-MAS04541,Loose wheel warning system-Odometer reading of next-to-last warning,0, km
IDE13239-MAS04542,Loose wheel warning system-Odometer reading of third-to-last warning,0, km
IDE13239-MAS16487,Loose wheel warning system-Wheels affected by the latest warning,no warning,
IDE13239-MAS16489,Loose wheel warning system-Wheels affected by the penultimate warning,no warning,
IDE13239-MAS16491,Loose wheel warning system-Wheels affected by the third last warning,no warning,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,Available,
IDE14227-MAS18085,modular vehicle dynamic controller-Electronic Stability Program function status,mFDR_not_active_by_failure,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_active_DCC_controlled,
IDE14227-MAS18087,modular vehicle dynamic controller-Haldex function status,mFDR_active_haldex_not_configured,
IDE14227-MAS18088,modular vehicle dynamic controller-Min Haldex target locking rate,0.0, %
IDE14227-MAS18089,modular vehicle dynamic controller-Max Haldex target locking rate,50.0, %
IDE14227-ENG264561,modular vehicle dynamic controller-mFDR Sollfaktor DCC HL,100, %
IDE14227-ENG264562,modular vehicle dynamic controller-mFDR Sollfaktor DCC HR,100, %
IDE14227-ENG264563,modular vehicle dynamic controller-mFDR Sollfaktor DCC VL,100, %
IDE14227-ENG264564,modular vehicle dynamic controller-mFDR Sollfaktor DCC VR,100, %
IDE14479-IDE02657,Parking brake system status-Cut-off current: left: reached,0.00, A
IDE14479-IDE02658,Parking brake system status-Cut-off current: right: reached,0.00, A
IDE14479-IDE04496,Parking brake system status-Left parking brake motor: status,closed,
IDE14479-IDE04497,Parking brake system status-Right parking brake motor: status,closed,
IDE14479-IDE04506,Parking brake system status-Calculated left rear brake temperature,27.0, °C
IDE14479-IDE04507,Parking brake system status-Calculated right rear brake temperature,27.0, °C
IDE14479-IDE04647,Parking brake system status-Left parking brake motor: current,0.00, A
IDE14479-IDE04648,Parking brake system status-Right parking brake motor: current,0.00, A
IDE14479-IDE05048,Parking brake system status-Left parking brake motor: actuation counter,6547,
IDE14479-IDE05049,Parking brake system status-Right parking brake motor: actuation counter,6547,
IDE14623,Commutation test status,not active,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,28.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,28.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,28.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,28.0, °C
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Not available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Not available,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,27,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,143433, km
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Not open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,connected,
MAS02138-MAS00218,Hill-start assistant-Driver´s door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02286-MAS01167,Hydraulic pump-Actuation time,0 s,
MAS02286-MAS06857,Hydraulic pump-Speed,0, /min
MAS02286-ENG170421,Hydraulic pump-IoReached Status,Output diagnostic test not active,
MAS02426-MAS01167,Text display in instrument cluster-Actuation time,Without time limit,
MAS02426,Text display in instrument cluster,0,
MAS02426-ENG170421,Text display in instrument cluster-IoReached Status,Output diagnostic test not active,
MAS04012-IDE03297,Intake valves-Left front ABS inlet valve,OFF,
MAS04012-IDE03299,Intake valves-Right front ABS inlet valve,OFF,
MAS04012-IDE03301,Intake valves-left rear ABS intake valve,OFF,
MAS04012-IDE03303,Intake valves-right rear ABS intake valve,OFF,
MAS04012-MAS01167,Intake valves-Actuation time,0 s,
MAS04012-ENG170421,Intake valves-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG101413,Calibration Identifications,5WA517BL01330210,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,01 B7 67 5E,
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG264445,Entwicklermesswert_08,|VZM_function_request,VZM_Participant
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,6547,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,6547,
ENG264448,Entwicklermesswert_12,40081D,
ENG264449-ENG135765,Entwicklermesswert_13-Input_Signal_A_Belt_Error,No malfunction,
ENG264449-ENG135764,Entwicklermesswert_13-Input_Signal_A_Belt_Status,engaged,
ENG264449-ENG135767,Entwicklermesswert_13-Input_Signal_B_Door_Error,No malfunction,
ENG264449-ENG135766,Entwicklermesswert_13-Input_Signal_B_Door_Status,Open,
ENG264450-MAS01167,Entwicklerstellglied_01_status-Actuation time,0 s,
ENG264450-MAS11641,Entwicklerstellglied_01_status-OBD lamp,OFF,
ENG264450-ENG170421,Entwicklerstellglied_01_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 00:15
blockmap-05-5WA-959-436-J_TMBAJ7NXXNY096941-20260703-1351.CSV
;SW:5WA-959-436-J   HW:5WA-959-436-J ---  05: Acc/Start Auth.
;Component:Kessy IOBOX   100 0725, Coding:
;EV_Kessy37w,004024,EV_Kessy37w_004.rod
;Friday,03,July,2026,13:51:13:12012
;VCID: DBE87DBD43A7EE12630-808E
IDE00019,Voltage terminal 30,12.329, V
IDE02413,Door handle touch sensor: last operation,Driver´s door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,133,
IDE02419,Proximity sensor frt.pass. door: number of triggers,68,
IDE02420,Proximity sensor left rear door: number of triggers,51,
IDE02421,Proximity sensor right rear door: number of triggers,45,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,0,
IDE02422-MAS01483,Driver door handle: version information-Software version,0,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,0,
IDE02422,Driver door handle: version information,00 00 00 00 00,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,0,
IDE02423-MAS01483,ass. door handle: version information-Software version,0,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,0,
IDE02423,ass. door handle: version information,00 00 00 00 00,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,0,
IDE02424-MAS01483,Left rear door handle: version information-Software version,0,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,0,
IDE02424,Left rear door handle: version information,00 00 00 00 00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,0,
IDE02425-MAS01483,Right rear door handle: version information-Software version,0,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,0,
IDE02425,Right rear door handle: version information,00 00 00 00 00,
IDE02466,Play protection activation counter driver door,0,
IDE02466,Play protection activation counter driver door,not active,
IDE02467,Play protection activation counter frt.pass. door,not active,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,not active,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02469,Play protection activation counter right rear door,not active,
IDE02482,72h-Signaling counter driver door,20,
IDE02483,72-hour signaling counter frt.pass. door,56,
IDE02486,Data logger triggering,not initialized,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.3, V
IDE07359,Dimming of starter button lighting,10000,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19612,Outer door handle switch: status-Rear Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19613,Outer door handle switch: status-Tank Exterior Door Handle Switch: status,Not operated,
IDE14924-MAS00218,Status of release conditions Passive Entry-Driver´s door,not enabled,
IDE14924-MAS00219,Status of release conditions Passive Entry-Passenger´s door,not enabled,
IDE14924-MAS00220,Status of release conditions Passive Entry-Rear left door,not enabled,
IDE14924-MAS00221,Status of release conditions Passive Entry-Rear right door,not enabled,
IDE14924-MAS19581,Status of release conditions Passive Entry-Rear,not enabled,
IDE14924-MAS19611,Status of release conditions Passive Entry-Tank,not enabled,
IDE14925-MAS00218,Status of release conditions Passive Exit-Driver´s door,not enabled,
IDE14925-MAS00219,Status of release conditions Passive Exit-Passenger´s door,Enabled,
IDE14925-MAS00220,Status of release conditions Passive Exit-Rear left door,Enabled,
IDE14925-MAS00221,Status of release conditions Passive Exit-Rear right door,Enabled,
IDE14925-MAS19581,Status of release conditions Passive Exit-Rear,not enabled,
IDE14925-MAS19611,Status of release conditions Passive Exit-Tank,not enabled,
IDE14926,Status of release conditions for key search,Key search: release activated,
IDE14927-MAS19605,History of range limiter for automatic functions-Reduction level,|Level_of_reduction,Year
IDE14928-MAS00080,Sensor for control section-Coding information,Not coded,
IDE14928-MAS02176,Sensor for control section-Approach to the inside,not active,
IDE14928-MAS02177,Sensor for control section-Actuation to the inside,not active,
IDE14928-MAS02178,Sensor for control section-Approach to the outside,not active,
IDE14928-MAS02179,Sensor for control section-Actuation to the outside,not active,
IDE14928-MAS02451,Sensor for control section-Pulling actuation: outside door handle,not active,
IDE14929-MAS00080,Sensor for fuel filler flap control section-Coding information,Not coded,
IDE14929-MAS02176,Sensor for fuel filler flap control section-Approach to the inside,not active,
IDE14929-MAS02177,Sensor for fuel filler flap control section-Actuation to the inside,not active,
IDE14929-MAS02178,Sensor for fuel filler flap control section-Approach to the outside,not active,
IDE14929-MAS02179,Sensor for fuel filler flap control section-Actuation to the outside,not active,
IDE14929-MAS02451,Sensor for fuel filler flap control section-Pulling actuation: outside door handle,not active,
IDE14930,Sensor fuel filler flap control section: number of triggers,0,
IDE14931,Sensor control section trunk: number of triggers,0,
IDE14932,Fuel filler flap control section: play protection,0,
IDE14932,Fuel filler flap control section: play protection,not active,
IDE14933,Trunk control section: play protection counter,not active,
IDE14933,Trunk control section: play protection counter,0,
IDE14934-MAS01482,Trunk control section: version information-Hardware version,0,
IDE14934-MAS01483,Trunk control section: version information-Software version,0,
IDE14934-MAS04065,Trunk control section: version information-EEPROM,0,
IDE14934,Trunk control section: version information,00 00 00 00 00,
IDE14935-MAS01482,Fuel filler cap control section: version information-Hardware version,0,
IDE14935-MAS01483,Fuel filler cap control section: version information-Software version,0,
IDE14935-MAS04065,Fuel filler cap control section: version information-EEPROM,0,
IDE14935,Fuel filler cap control section: version information,00 00 00 00 00,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Power_On_Reset,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Power_On_Reset,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Power_On_Reset,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Power_On_Reset,
ENG254757-MAS00106,Lf_antenna_eight_detune_counter-Year,2000,
ENG254757-MAS00107,Lf_antenna_eight_detune_counter-Month,0,
ENG254757-MAS00108,Lf_antenna_eight_detune_counter-Day,0,
ENG254757-MAS00109,Lf_antenna_eight_detune_counter-Hours,0,
ENG254757-MAS00110,Lf_antenna_eight_detune_counter-Minutes,0,
ENG254757-MAS00111,Lf_antenna_eight_detune_counter-Seconds,0,
ENG254757-ENG255615,Lf_antenna_eight_detune_counter-Detune_counter,0,
ENG254758-MAS00106,Lf_antenna_five_detune_counter-Year,2000,
ENG254758-MAS00107,Lf_antenna_five_detune_counter-Month,0,
ENG254758-MAS00108,Lf_antenna_five_detune_counter-Day,0,
ENG254758-MAS00109,Lf_antenna_five_detune_counter-Hours,0,
ENG254758-MAS00110,Lf_antenna_five_detune_counter-Minutes,0,
ENG254758-MAS00111,Lf_antenna_five_detune_counter-Seconds,0,
ENG254758-ENG255615,Lf_antenna_five_detune_counter-Detune_counter,0,
ENG254759-MAS00106,Lf_antenna_four_detune_counter-Year,2000,
ENG254759-MAS00107,Lf_antenna_four_detune_counter-Month,0,
ENG254759-MAS00108,Lf_antenna_four_detune_counter-Day,0,
ENG254759-MAS00109,Lf_antenna_four_detune_counter-Hours,0,
ENG254759-MAS00110,Lf_antenna_four_detune_counter-Minutes,0,
ENG254759-MAS00111,Lf_antenna_four_detune_counter-Seconds,0,
ENG254759-ENG255615,Lf_antenna_four_detune_counter-Detune_counter,0,
ENG254760-MAS00106,Lf_antenna_one_detune_counter-Year,2000,
ENG254760-MAS00107,Lf_antenna_one_detune_counter-Month,0,
ENG254760-MAS00108,Lf_antenna_one_detune_counter-Day,0,
ENG254760-MAS00109,Lf_antenna_one_detune_counter-Hours,0,
ENG254760-MAS00110,Lf_antenna_one_detune_counter-Minutes,0,
ENG254760-MAS00111,Lf_antenna_one_detune_counter-Seconds,0,
ENG254760-ENG255615,Lf_antenna_one_detune_counter-Detune_counter,0,
ENG254761-MAS00106,Lf_antenna_seven_detune_counter-Year,2000,
ENG254761-MAS00107,Lf_antenna_seven_detune_counter-Month,0,
ENG254761-MAS00108,Lf_antenna_seven_detune_counter-Day,0,
ENG254761-MAS00109,Lf_antenna_seven_detune_counter-Hours,0,
ENG254761-MAS00110,Lf_antenna_seven_detune_counter-Minutes,0,
ENG254761-MAS00111,Lf_antenna_seven_detune_counter-Seconds,0,
ENG254761-ENG255615,Lf_antenna_seven_detune_counter-Detune_counter,0,
ENG254762-MAS00106,Lf_antenna_six_detune_counter-Year,2000,
ENG254762-MAS00107,Lf_antenna_six_detune_counter-Month,0,
ENG254762-MAS00108,Lf_antenna_six_detune_counter-Day,0,
ENG254762-MAS00109,Lf_antenna_six_detune_counter-Hours,0,
ENG254762-MAS00110,Lf_antenna_six_detune_counter-Minutes,0,
ENG254762-MAS00111,Lf_antenna_six_detune_counter-Seconds,0,
ENG254762-ENG255615,Lf_antenna_six_detune_counter-Detune_counter,0,
ENG254763-MAS00106,Lf_antenna_three_detune_counter-Year,2000,
ENG254763-MAS00107,Lf_antenna_three_detune_counter-Month,0,
ENG254763-MAS00108,Lf_antenna_three_detune_counter-Day,0,
ENG254763-MAS00109,Lf_antenna_three_detune_counter-Hours,0,
ENG254763-MAS00110,Lf_antenna_three_detune_counter-Minutes,0,
ENG254763-MAS00111,Lf_antenna_three_detune_counter-Seconds,0,
ENG254763-ENG255615,Lf_antenna_three_detune_counter-Detune_counter,0,
ENG254764-MAS00106,Lf_antenna_two_detune_counter-Year,2000,
ENG254764-MAS00107,Lf_antenna_two_detune_counter-Month,0,
ENG254764-MAS00108,Lf_antenna_two_detune_counter-Day,0,
ENG254764-MAS00109,Lf_antenna_two_detune_counter-Hours,0,
ENG254764-MAS00110,Lf_antenna_two_detune_counter-Minutes,0,
ENG254764-MAS00111,Lf_antenna_two_detune_counter-Seconds,0,
ENG254764-ENG255615,Lf_antenna_two_detune_counter-Detune_counter,0,
ENG254789-MAS00106,Over_temperature_counter_lf_driver-Year,2000,
ENG254789-MAS00107,Over_temperature_counter_lf_driver-Month,0,
ENG254789-MAS00108,Over_temperature_counter_lf_driver-Day,0,
ENG254789-MAS00109,Over_temperature_counter_lf_driver-Hours,0,
ENG254789-MAS00110,Over_temperature_counter_lf_driver-Minutes,0,
ENG254789-MAS00111,Over_temperature_counter_lf_driver-Seconds,0,
ENG254789-ENG256116,Over_temperature_counter_lf_driver-Over_temperature_counter,0, counts
ENG108452,Reset_counter,35,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,0,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,2006232112,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,235338551,
ENG254855-ENG103063,WUP_measurement_historie-Mileage,0, km
ENG254855-ENG103063,WUP_measurement_historie-Mileage,16777215, km
Elapsed Time: 00:07
blockmap-08-5WA-907-727-AC_TMBAJ7NXXNY096941-20260703-1351.CSV
;SW:5WA-907-727-AC   HW:5WA-907-727-AC ---  08: Auto HVAC
;Component:Climatronic   H02 0440, Coding:101010010211120000100010101011110000112100100000000000000000
;EV_ACClimaBHBVW38X,005069,EV_ACClimaBHBVW38X_SK38.rod
;Friday,03,July,2026,13:51:32:12012
;VCID: 91745F95D1EB1442C9C-80C4
IDE00019,Voltage terminal 30,12.10, V
IDE00021,Engine speed,0.0, /min
IDE00025,Coolant temperature,27.00, °C
IDE00085,Normed load value,0.000, %
IDE00097,OBD - requirements for which this vehicle is designed,0,
IDE00198,Refrigerant pressure,7.80, bar
IDE00323-ENG127697,Security Access: Number of invalid keys-Counter_2,0,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not active,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not active,
IDE00445,Unlearning counter according OBD,0,
IDE00601,Monitoring status since erasing DTC memory,65281,
IDE00602,Monitoring status in current driving cycle,65281,
IDE00965,Compressor shut-off condition,Engine running time too short: engine start not detected by CAN,
IDE00966,Compressor current: actual value,0.0, A
IDE00967,Compressor current: specified value,0.0, A
IDE00968,Compressor speed,0.0, /min
IDE00969,Compressor load,0.0, Nm
IDE00970,Coolant fan activation: actual value,10.00, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,28.00, °C
IDE00974,Outside air temperature internally calculated,27.00, °C
IDE00976,Left front vent temperature,30.00, °C
IDE00977,Right front vent temperature,30.00, °C
IDE00981,Footwell vent temperature,31.0, °C
IDE00982,Temperature downstream of evaporator,30.00, °C
IDE00983,Inside temperature,29.00, °C
IDE00984,Sun intensity left,0.00, W/m²
IDE00985,Sun intensity right,0.00, W/m²
IDE00987,Blower voltage: specified value,7.00, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,66.5, %
IDE00994,Actual value for fresh air/recirculation air flow flap,156,
IDE00995,Fresh air/recirculating air/back pressure door specified value,157,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,46,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,211,
IDE00998,Left temperature flap - actual value,28,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00999,Temperature door left - Specified value,27,
IDE01040,Left Temperature Control Door - cold stop,32,
IDE01041,Left temperature flap: warm stop,227,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01042,Right temperature flap: actual value,24,
IDE01043,Temperature door right - Specified value,23,
IDE01044,Right temperature flap: cold stop,28,
IDE01045,Right temperature flap: warm stop,225,
IDE01050,Front air distribution flap: actual value,23.5, %
IDE01050,Front air distribution flap: actual value,74,
IDE01051,Air distribution door front - Specified value,78,
IDE01052,Front air distribution flap: air outlet stop,26,
IDE01053,Front air distribution flap: footwell air outlet stop,230,
IDE01054,Defroster flap: actual value,123,
IDE01054,Defroster flap: actual value,50.0, %
IDE01055,Defrost door - Specified value,122,
IDE01056,Defroster flap: stop open,16,
IDE01057,Defroster flap: stop closed,229,
IDE01063,Status of recirculation air,recirc. due to back pressure portion,
IDE01065,Rear vent temperature,0.00, °C
IDE01069,Rear blower voltage: specified value,0.0, V
IDE01076,Time since ignition off,240, min
IDE01226,Blower voltage: actual value,6.90, V
IDE01227,Blower current,7.75, A
IDE01232,Supply voltage for external components,4.9, V
IDE01264,Remaining time of parking heater/ventilation operation,10, s
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,0,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,2,
IDE01419,Compressor shut-off condition: last,Outside temperature too low,
IDE01420,Compressor shut-off requirement: penultimate,Outside temperature too low,
IDE01421,Compressor shut-off requirement: antepenultimate,Outside temperature too low,
IDE01433,Air quality status,Clean air,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01564,Pressing a button-Windshield defogger,Not operated,
IDE01442-MAS01577,Pressing a button-Auxiliary heating,operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01448,Actual value of heated front window,not coded / not installed,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,not coded / not installed,
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,not coded / not installed,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded / not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,29.20, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,6.52, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded / not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0.00, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,not coded / not installed,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,not coded / not installed,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not coded / not installed,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded / not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,not coded / not installed,
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,not coded / not installed,
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,not coded / not installed,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded / not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,29.00, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,6.57, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded / not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0.00, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,not coded / not installed,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,not coded / not installed,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not coded / not installed,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded / not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,not coded / not installed,
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.10, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,OFF,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,OFF,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,Unknown (210)
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),0, mA
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),0, mA
IDE01694-MAS01767,Left rear seat heater-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear seat heater-Left rear seat heater specified temperature,-50.0, °C
IDE01694-MAS01769,Left rear seat heater-Left rear seat heater actual temperature,-50.0, °C
IDE01694-MAS01770,Left rear seat heater-Left rear seat heater current,0.00, A
IDE01695-MAS01771,Right rear seat heater-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear seat heater-Right rear seat heater specified temperature,-50.0, °C
IDE01695-MAS01773,Right rear seat heater-Right rear seat heater actual temperature,-50.0, °C
IDE01695-MAS01774,Right rear seat heater-Right rear seat heater current,0.00, A
IDE02270-IDE01268,CAN input signal(s) status-Front windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management: shut-off stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,Not available,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE03008-IDE80251,Stop process prevented-Neck heating,not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxiliary heat mode,not active,
IDE03008-MAS05046,Stop process prevented-Evaporator temperature difference from setting,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03010-IDE80251,Number of prevented stop processes-Neck heating,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxiliary heat mode,0,
IDE03010-MAS05046,Number of prevented stop processes-Evaporator temperature difference from setting,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-IDE80251,Number of requested start processes-Neck heating,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxiliary heat mode,0,
IDE03011-MAS05046,Number of requested start processes-Evaporator temperature difference from setting,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,0, s
IDE04312-MAS00084,System run time-Terminal 15 on,253, s
IDE05533,Heater for nozzles,not coded / not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,31.60, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,31.00, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,42.00, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,17.60, °C
IDE06233-MAS01632,Auxiliary heater: controlled-Status,Unknown (210)
IDE06233-MAS03746,Auxiliary heater: controlled-Current: actual value,10,
IDE06233-MAS04625,Auxiliary heater: controlled-Power: actual value,2420.00,
IDE06233-MAS04626,Auxiliary heater: controlled-Power: target value,0.00,
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,No enabling,
IDE06234-MAS01447,Auxiliary heater: in stages-Actual value,0,
IDE06234-MAS01448,Auxiliary heater: in stages-Specified value,0,
IDE06234-MAS04992,Auxiliary heater: in stages-Specified value for control,0,
IDE06235,Potentiometer for rear vent temperature,0.0, Nm
IDE06307-MAS00106,Stop prevention history data-Year,2000, yr
IDE06307-MAS00107,Stop prevention history data-Month,0, Months
IDE06307-MAS00108,Stop prevention history data-Day,0, d
IDE06307-MAS00109,Stop prevention history data-Hours,0, H
IDE06307-MAS00110,Stop prevention history data-Minutes,0, min
IDE06307-MAS00111,Stop prevention history data-Seconds,0, s
IDE06307-MAS01517,Stop prevention history data-Defrost active,not active,
IDE06307-MAS01564,Stop prevention history data-Windshield defogger,not active,
IDE06307-MAS02802,Stop prevention history data-Interior temperature difference to specifications,not active,
IDE06307-MAS02803,Stop prevention history data-Interior vent difference to setting,not active,
IDE06307-MAS02804,Stop prevention history data-Manual fan speed increase,not active,
IDE06307-MAS04353,Stop prevention history data-Fogging hazard (humidity sensor),not active,
IDE06307-MAS04354,Stop prevention history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06307-MAS05009,Stop prevention history data-A/C request: auxiliary heat mode,not active,
IDE06307-MAS05046,Stop prevention history data-Evaporator temperature difference from setting,not active,
IDE06307-MAS05047,Stop prevention history data-Maximum cooling and heating set,not active,
IDE06307-MAS06551,Stop prevention history data-Seat ventilation,not active,
IDE06307-MAS09538,Stop prevention history data-max A/C,not active,
IDE06308-MAS00106,Start request history data-Year,2000, yr
IDE06308-MAS00107,Start request history data-Month,0, Months
IDE06308-MAS00108,Start request history data-Day,0, d
IDE06308-MAS00109,Start request history data-Hours,0, H
IDE06308-MAS00110,Start request history data-Minutes,0, min
IDE06308-MAS00111,Start request history data-Seconds,0, s
IDE06308-MAS01517,Start request history data-Defrost active,not active,
IDE06308-MAS01564,Start request history data-Windshield defogger,not active,
IDE06308-MAS02802,Start request history data-Interior temperature difference to specifications,not active,
IDE06308-MAS02803,Start request history data-Interior vent difference to setting,not active,
IDE06308-MAS02804,Start request history data-Manual fan speed increase,not active,
IDE06308-MAS03904,Start request history data-Maximum permissible stop duration reached,not active,
IDE06308-MAS04353,Start request history data-Fogging hazard (humidity sensor),not active,
IDE06308-MAS04354,Start request history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06308-MAS05009,Start request history data-A/C request: auxiliary heat mode,not active,
IDE06308-MAS05046,Start request history data-Evaporator temperature difference from setting,not active,
IDE06308-MAS05047,Start request history data-Maximum cooling and heating set,not active,
IDE06308-MAS06551,Start request history data-Seat ventilation,not active,
IDE06308-MAS09538,Start request history data-max A/C,not active,
IDE06545,Blower voltage for production routines,11.0, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,No effect,
IDE06593,Air recirculation for production routines,No effect,
IDE07991-MAS04446,A/C clutch-Relay activation status,not active,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Parallel activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Parallel activation of backrest and seat cushion,
IDE09189-IDE09201,HV heater temperature-Intake temperature,Malfunction,
IDE09189-IDE09202,HV heater temperature-Exhaust Temperature,Malfunction,
IDE10300,OBD Driving Cycle detected,Unknown (255)
IDE11383-IDE01233,Compressor: system monitor-Compressor motor current,Initialization,
IDE11383-MAS05976,Compressor: system monitor-A/C compressor: inverter temperature,128.00, °C
IDE11383-MAS05978,Compressor: system monitor-High voltage supply voltage,Initialization,
IDE11383-MAS05979,Compressor: system monitor-A/C compressor: start-up monitor,Malfunction,
IDE11383-MAS12656,Compressor: system monitor-A/C compressor: Inverter temperature status,Sensor test running,
IDE11455-MAS11114,Range consumption forecast-Time to transition from dynamic to steady-state operation,240, min
IDE11455-MAS11115,Range consumption forecast-Change in the prediction initiated by customer action,202,
IDE11455-MAS11116,Range consumption forecast-Dynamic power for heating/cooling,650020.00, W
IDE11455-MAS11117,Range consumption forecast-Steady-state power for heating/cooling,650020.00, W
IDE11455-MAS11118,Range consumption forecast-Consumption for heating and cooling of the components,65002, Ws
IDE11455-MAS11119,Range consumption forecast-Overflow-bit component consumption,Unknown (202)
IDE11455-MAS11120,Range consumption forecast-Consumption for heating and cooling of the interior,65002, Ws
IDE11455-MAS13274,Range consumption forecast-Overflow-bit interior consumption,Unknown (202)
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,0.00, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded / not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,29.000, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,not coded / not installed,
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,not coded / not installed,
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,not coded / not installed,
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,not coded / not installed,
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,not coded / not installed,
IDE11789-MAS11878,Air quality in the interior-Degree of contamination,Clean air,
IDE11795,Supply voltage 2 for external components,4.9, V
IDE11836,Query of the supported PIDs (0x01 - 0x20),2551709713,
IDE11837,Query of the supported PIDs (0x21 - 0x40),1,
IDE11838,Query of the supported PIDs (0x41 - 0x60),3296722944,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),339738624,
IDE12141-MAS00106,History memory: parking heater-Year,2000, yr
IDE12141-MAS00107,History memory: parking heater-Month,0, Months
IDE12141-MAS00108,History memory: parking heater-Day,0, d
IDE12141-MAS00109,History memory: parking heater-Hours,0, H
IDE12141-MAS00110,History memory: parking heater-Minutes,0, min
IDE12141-MAS00111,History memory: parking heater-Seconds,0, s
IDE12141-MAS02526,History memory: parking heater-Activation,Unknown (0)
IDE12141-MAS04390,History memory: parking heater-Active source,Unknown (0)
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine is running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13845,Production mode status,not active,
IDE14095,Wiper park position heater,not coded / not installed,
IDE14804-MAS19258,A/C Compressor compatibility monitor-Activated numbers of error screen in climate control module,Malfunction,
IDE14804-MAS19259,A/C Compressor compatibility monitor-Number of A/C Compressor error display from last routine,255,
IDE14804-MAS19260,A/C Compressor compatibility monitor-Number of error display for A/C Compressor: actual value,255,
IDE14804-MAS19261,A/C Compressor compatibility monitor-Activated error display in climate control module: status,Not qualified,
IDE14804-MAS19262,A/C Compressor compatibility monitor-Number of disrupted standard comparisons,0,
IDE80001,Analysis 1,Malfunction,
IDE80001,Analysis 1,0,
IDE80001,Analysis 1,65280,
IDE80002,Analysis 2,0,
IDE80002,Analysis 2,Malfunction,
IDE80002,Analysis 2,65280,
IDE80003,Analysis 3,0,
IDE80003,Analysis 3,65280,
IDE80003,Analysis 3,Malfunction,
IDE80101-IDE80001,Analysis 101-Analysis 1,FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80002,Analysis 101-Analysis 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80003,Analysis 101-Analysis 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80004,Analysis 101-Analysis 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80005,Analysis 101-Analysis 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00194,---,Initialization,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,28,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,59,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,241,
MAS11295,Refrigerant temperature,3200.2, °C
MAS11297-MAS01379,Standstilll A/C: customer setting-Operating time,10, min
MAS11298,Standstilll A/C remaining run time,0, s
Elapsed Time: 00:19
Amedeo
Romania - Rm.Valcea
C?ID=14228
blockmap-09-5WA-937-086-AE_TMBAJ7NXXNY096941-20260703-1352.CSV
;SW:5WA-937-086-AE   HW:5WA-937-086-L ---  09: Cent. Elect.
;Component:BCM37w_M028 0175, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_SK38.rod
;Friday,03,July,2026,13:52:27:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: 947A5681EEF9E16AE2A-80C0 SFD {x}
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00301,Distance,143372, km
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Adaptive Cruise Control,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,6 Position operating unit,
IDE00973,Outside temperature,28.0, °C
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,not active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,not active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,not active,
IDE01992-SFT33054,Installation list: current installations-Burglary protection control module 1 VL,active,
IDE01992-SFT33055,Installation list: current installations-Burglary protection control module 2 VR,active,
IDE01992-SFT33056,Installation list: current installations-Burglary protection control module 3 HL,active,
IDE01992-SFT33057,Installation list: current installations-Burglary protection control module 4 HR,active,
IDE01992-SFT33058,Installation list: current installations-Burglary protection control module 5 vehicle interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,not active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,not active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,not active,
IDE01996-SFT33054,Installation list: specified installations-Burglary protection control module 1 VL,active,
IDE01996-SFT33055,Installation list: specified installations-Burglary protection control module 2 VR,active,
IDE01996-SFT33056,Installation list: specified installations-Burglary protection control module 3 HL,active,
IDE01996-SFT33057,Installation list: specified installations-Burglary protection control module 4 HR,active,
IDE01996-SFT33058,Installation list: specified installations-Burglary protection control module 5 vehicle interior,not active,
IDE02711-IDE05228,Rear wiper-Operating hour counter,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE02711-MAS01632,Rear wiper-Status,not coded / not installed,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not installed,
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Selector lever in position P,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,41, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02857-ENG126436,Activation current-signal_horn,Measuring value not available,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,not ready for sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Ready For Sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Ready For Sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Ready For Sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary protection control module 1 VL,not ready for sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary protection control module 2 VR,not ready for sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary protection control module 3 HL,not ready for sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary protection control module 4 HR,not ready for sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary protection control module 5 vehicle interior,Ready For Sleep,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,28.0, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.4, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,OFF,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Terminal 15 ignition button: signal 2,
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,0.0, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,362000,
IDE05045-MAS05878,Front wiper module-level,not coded / not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not coded / not installed,
IDE05834-MAS00212,Driver info-Washer fluid low,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded / not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,0, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,31.8, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,31.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,42.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,17.7, °C
IDE06507-MAS13127,Button in center console-Status of button 1,not coded / not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded / not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded / not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded / not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded / not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded / not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE08211-MAS03129,History data control module reset-Reset counter,28,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,BC 71 F0 B0,
IDE08240,Transponder ID Key 2,47 68 F0 B0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,06 9F 4D 35,
IDE08343,Immobilizer Challenge,1D 1F 72 57,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,1, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,1, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,183, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,178, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,1083, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,1004, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,1, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,305, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,119, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,121, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,13, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,0, mA
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,0, mA
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,0, mA
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,0, mA
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,74, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,72, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,307, mA
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m²
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,10,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,11,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded / not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded / not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded / not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,0,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,4B 72 41 C4,
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,Intermittent operation,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 4,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded / not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded / not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded / not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded / not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG255221,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,TMBAJ7NXXNY096941,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device not installed,
IDE13956-MAS01493,Key position replication: input signals-Engine is running,not active,
IDE13956-MAS02248,Key position replication: input signals-Signal status,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG256242,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG256551,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14238-MAS02282,Wiper arm position-Position,0.0, °
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 2F 4E 2C 42 49 7B 07,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not recognised,
IDE14958-SFT00008,Recognized actual fitting list: adapt-HVAC electronics,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not recognised,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,not recognised,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not recognised,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not recognised,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not recognised,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not recognised,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not recognised,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not recognised,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for driver assistance systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not recognised,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,not recognised,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,not recognised,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not recognised,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary protection control module 1 VL,detected,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary protection control module 2 VR,detected,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary protection control module 3 HL,detected,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary protection control module 4 HR,detected,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary protection control module 5 vehicle interior,not recognised,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Left rear door control module,detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Right rear door control module,detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not recognised,
IDE14958-SFT272139,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not recognised,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 41,
IDE14993,Software composition list identification data,|Software Composition ID,System designation
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,active,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,Terminal 15: discrete and CAN,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,unrestricted,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,none,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,none,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,Initialization,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,12.30, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,12.35, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,12.30, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,12.30, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,11.55, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,A3,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,15 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,30,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,19,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,143433, km
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-Left taillight 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Power rear lid opening control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left neck heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right neck heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272139,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-Left taillight 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right taillight 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right taillight 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver's side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger's side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,Available,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,Available,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-Left taillight 1,Available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,Available,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271950,Specified installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left neck heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right neck heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272139,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-Left taillight 2,Available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right taillight 1,Available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right taillight 2,Available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,Available,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,Available,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-Left taillight 1,Available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,Available,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT271950,Actual installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left neck heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right neck heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272139,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-Left taillight 2,Available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right taillight 1,Available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right taillight 2,Available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-Left taillight 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271950,Bus identification of sub-bus users-Power rear lid opening control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left neck heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right neck heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272139,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT272142,Bus identification of sub-bus users-Left taillight 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right taillight 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right taillight 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver's side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger's side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,active,
MAS25323,Ambient lighting: error locations,not installed,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,41,
ENG277599,ASIL_relevante_RDIDs,|Adapted values/adaptation,Status of adaptation|0A 72
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,Pin A38 ZAT 2,
ENG263729,Dataset_download_written_rdids,|ID data set,Number
ENG254610-ENG161480,Datensatz Historienspeicher-Betriebsstundenzaehler_1,0.000000, s
ENG254610-ENG161481,Datensatz Historienspeicher-Betriebsstundenzaehler_2,0.000000, s
ENG254610-ENG161482,Datensatz Historienspeicher-Betriebsstundenzaehler_3,0.000000, s
ENG254610-ENG161483,Datensatz Historienspeicher-Betriebsstundenzaehler_4,0.000000, s
ENG254610-ENG161484,Datensatz Historienspeicher-Betriebsstundenzaehler_5,0.000000, s
ENG254610-ENG289718,Datensatz Historienspeicher-Datensatz_Version_1,0,
ENG254610-ENG289711,Datensatz Historienspeicher-Datensatz_Version_2,0,
ENG254610-ENG289716,Datensatz Historienspeicher-Datensatz_Version_3,0,
ENG254610-ENG289719,Datensatz Historienspeicher-Datensatz_Version_4,0,
ENG254610-ENG289720,Datensatz Historienspeicher-Datensatz_Version_5,0,
ENG254610-ENG164431,Datensatz Historienspeicher-Wischzyklenzaehler_1,0,
ENG254610-ENG164432,Datensatz Historienspeicher-Wischzyklenzaehler_2,0,
ENG254610-ENG164433,Datensatz Historienspeicher-Wischzyklenzaehler_3,0,
ENG254610-ENG164434,Datensatz Historienspeicher-Wischzyklenzaehler_4,0,
ENG254610-ENG164435,Datensatz Historienspeicher-Wischzyklenzaehler_5,0,
ENG286564,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG286565,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,347, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,966, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,146.6960, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,362000,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|ID number,Authentication
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 00 00 00 00 00 00,
ENG121906,Last_LIN_Message_Kessy,00 00 03 00 FE 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 00 00 00 00,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 00 00 00 00,
ENG116804-ENG122179,Light sensor parameter-1_rb_E2_Sensor_Error1_g,0,
ENG116804-ENG122180,Light sensor parameter-2_rb_E2_Sensor_Error2_g,0,
ENG116804-ENG122181,Light sensor parameter-3_rb_E2_Sensor_Error3_g,0,
ENG116804-ENG122182,Light sensor parameter-4_rb_E2_Sensor_Error4_g,0,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,active,
ENG116804-ENG121664,Light sensor parameter-night_mode,NotActive,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,NotActive,
ENG116804-ENG121666,Light sensor parameter-rain_mode,NotActive,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,90,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG121677,Light sensor parameter-rb_LIN_CHECKSUMERROR_COUNTER_g,0,
ENG116804-ENG122178,Light sensor parameter-rb_LIN_FRAMING_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG122177,Light sensor parameter-rb_LIN_OVER_TFRAMEMAX_COUNTER_g,0,
ENG116804-ENG122176,Light sensor parameter-rb_LIN_OVER_THEADERMAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,186,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,0,
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,180,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,0,
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,0,
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,NotActive,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,not coded / not installed,
ENG116909-ENG256024,LIN activity-LIN 11,not coded / not installed,
ENG116909-ENG256025,LIN activity-LIN 12,not coded / not installed,
ENG116909-ENG256026,LIN activity-LIN 13,not coded / not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded / not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded / not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,not coded / not installed,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Communication,
ENG116909-ENG256030,LIN activity-LIN 7,not coded / not installed,
ENG116909-ENG256031,LIN activity-LIN 8,Communication,
ENG116909-ENG256032,LIN activity-LIN 9,not coded / not installed,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,1,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,362000,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,2937.5875, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,42, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,0.06, °
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,0.06, °
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,0.06, °
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,12.26, V
ENG254795,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command
ENG116792,Power up history,|Funktionsanforderung|2|1|1|2|13|0|0|0|0|0|,
ENG116805-ENG121648,Rain sensor parameter-rb_CloseTypeStandby_g,0,
ENG116805-ENG121657,Rain sensor parameter-rb_Errorflags_g,0,
ENG116805-ENG121651,Rain sensor parameter-rb_HumTemp_ErrorCode_g,0,
ENG116805-ENG121656,Rain sensor parameter-rb_Max_WDGFastTaskCounter_g,141,
ENG116805-ENG121655,Rain sensor parameter-rb_Min_WDGFastTaskCounter_g,139,
ENG116805-ENG121653,Rain sensor parameter-rb_NoCommunicationCounter,0,
ENG116805-ENG121641,Rain sensor parameter-rb_PotiStageFromBox_g,5,
ENG116805-ENG121642,Rain sensor parameter-rb_PWM_Voltage_g,127,
ENG116805-ENG121652,Rain sensor parameter-rb_StaticNoCommunicationCounter,0,
ENG116805-ENG121654,Rain sensor parameter-rb_SupplyVoltage_mg,155,
ENG116805-ENG121640,Rain sensor parameter-rub_Empf_Faktor,22,
ENG116805-ENG121639,Rain sensor parameter-rub_Int_Speicher,0,
ENG116805-ENG121645,Rain sensor parameter-rub_LengthCounter,187,
ENG116805-ENG121643,Rain sensor parameter-rub_Nachwisch_Count,0,
ENG116805-ENG121638,Rain sensor parameter-rub_Ovr_Speicher,0,
ENG116805-ENG121646,Rain sensor parameter-rub_PulseCounter,1,
ENG116805-ENG121647,Rain sensor parameter-rub_SignalIntegral_g,0,
ENG116805-ENG121644,Rain sensor parameter-ruw_StX_Speicher,0,
ENG116805-ENG121650,Rain sensor parameter-rw_HumiTicks_g,25504,
ENG116805-ENG121649,Rain sensor parameter-rw_TempTicks_g,-32.86, °C
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,6, s
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0, s
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,-0.01, km/(hs)
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,29,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,255,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,208,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,5,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,9.8, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,20, °C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,2933.6595, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,0, °C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,51,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,9,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,254,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,0,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,9.6, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,11, °C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,2895.5081, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,50,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,2,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,64,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,255,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,14.0, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,25, °C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,2894.6751, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,17,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,15,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,2,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,74,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,12.7, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,49, °C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,1560.0424, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,35,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,24,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,65,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,66,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,13.1, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,27, °C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,2648.4403, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,16,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,1,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,2,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,14.2, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,48, °C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,1559.8758, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,0,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,0,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,0,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,0,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,0.0, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,0, °C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,0.0000, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,0, °C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,0, °C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG254816,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254825,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-kilometer reading,137400, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.6, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,13.0, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.3, V
ENG122921-ENG121628,values_motorloads-mod_temp_fast,24, °C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,32, °C
ENG122921-ENG121629,values_motorloads-temp_pcb,25, °C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG254854-ENG161480,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG254854-ENG161481,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG254854-ENG161482,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG254854-ENG161483,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG254854-ENG161484,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG254854-ENG162659,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG254854-ENG162660,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG254854-ENG162661,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG254854-ENG162662,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG254854-ENG162663,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG254854-ENG163410,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG254854-ENG163411,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG254854-ENG163412,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG254854-ENG163413,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG254854-ENG163414,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG254854-ENG163415,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG254854-ENG163416,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG254854-ENG163417,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG254854-ENG163418,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG254854-ENG163419,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG254854-ENG163420,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG254854-ENG163421,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG254854-ENG163422,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG254854-ENG163423,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG254854-ENG163424,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG254854-ENG164205,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG254854-ENG164206,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG254854-ENG164207,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG254854-ENG164208,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG254854-ENG164209,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG254854-ENG164431,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG254854-ENG164432,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG254854-ENG164433,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG254854-ENG164434,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG254854-ENG164435,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG133751-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG133751-ENG161419,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),362028,
ENG133751-ENG98439,Wischermesswerte 1-Battery voltage,12.2730, V
ENG133751-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG133751-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG133751-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG133751-ENG98786,Wischermesswerte 1-Engine angle,0.0, °
ENG133751-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG133751-ENG115795,Wischermesswerte 1-Operating Hours,10563074.896, s
ENG133751-ENG115650,Wischermesswerte 1-PCB-Temperatur,58112.088, °C
ENG133751-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1600087150,
ENG133751-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG133751-ENG147706,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG133751-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG133752-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,0.0, °
ENG133752-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210, °
ENG133752-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.5260, °
ENG133752-ENG255292,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,0.0, °
ENG133752-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,29,
ENG133752-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0, °
ENG133752-ENG147708,Wischermesswerte 2-Blockzaehler (Ueberlast),1,
ENG133752-ENG147709,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG133752-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG133752-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG133752-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG133752-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG133752-ENG98396,Wischermesswerte 2-Operating time,10554893.087, s
ENG133752-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,147.9, °
ENG133752-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG133752-ENG99020,Wischermesswerte 2-Supply voltage,9.7898, V
ENG133752-ENG98969,Wischermesswerte 2-Temperature,20.036, °C
ENG133752-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,12.0, °
ENG133743-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG133743-ENG255531,Wischermesswerte 3-Chip number Infineon,BE FD DB 5F 7C 63 47 39 E7 EA 04 39,
ENG133743-ENG125000,Wischermesswerte 3-EOL number,40,
ENG133743-ENG125001,Wischermesswerte 3-Error state,0,
ENG133743-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG133743-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG133743-ENG98897,Wischermesswerte 3-Serial number,39 30 37 34 35 33 46 30 34 30 32 32 30 36 34 30 30 36 38 38,
ENG254856-ENG255353,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,18,
ENG254856-ENG255354,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,48388,
ENG254856-ENG255356,WWS Historie-Anzahl Wischzyklen max. UBatt,1370,
ENG254856-ENG263779,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,3078,
ENG254856-ENG263780,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,249995,
ENG254856-ENG263781,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,13935,
ENG254856-ENG263782,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,11611,
ENG254856-ENG263783,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,5475,
ENG254856-ENG263784,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,5303,
ENG254856-ENG263785,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,3999,
ENG254856-ENG263786,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,68636,
ENG254856-ENG255393,WWS Historie-Betriebsstunden max MCU Temperatur,774.008228, s
ENG254856-ENG255394,WWS Historie-Betriebsstunden max. LIN Temperatur,22918.409295, s
ENG254856-ENG255396,WWS Historie-Betriebsstunden max. UBatt,3983.581564, s
ENG254856-ENG289707,WWS Historie-extern_Temp,0, °C
ENG254856-ENG255812,WWS Historie-Kl_15_Zyklenzaehler,7114,
ENG254856-ENG255813,WWS Historie-Kl_X_Zyklenzaehler,22106,
ENG254856-ENG289722,WWS Historie-LIN_Signal_max_Exterior_Temp,-70, °C
ENG254856-ENG289704,WWS Historie-max_Intern_Temp,118, °C
ENG254856-ENG256046,WWS Historie-max_power_supply,15.3, V
ENG254856-ENG256320,WWS Historie-Sleep_Counter,10548,
ENG254856-ENG256640,WWS Historie-Wakeup_Counter,10530,
Elapsed Time: 01:25
blockmap-10-5WA-919-294-C_TMBAJ7NXXNY096941-20260703-1357.CSV
;SW:5WA-919-294-C   HW:5WA-919-294 ---  10: Park/Steer Assist
;Component:PDC 08 Kanal  H04 0577, Coding:0040010011
;EV_EPHBO18VW3800000,002029,EV_EPHBO18VW3800000_AU38.rod
;Friday,03,July,2026,13:57:36:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: D2F69099146D2F5AB06-8086
Group,Description,Actual
IDE00018,Voltage terminal 15,12.3, V
IDE00957-MAS01632,Resulting distance of front sensors-Status,Malfunction,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,Malfunction,
IDE00973,Outside temperature,28.00, °
IDE00974,Outside air temperature internally calculated,28.00, °
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,Malfunction,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,Malfunction,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,Malfunction,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,Malfunction,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,Malfunction,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,Malfunction,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,Malfunction,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,Malfunction,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,0.560, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.512, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,0.512, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.512, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.512, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,0.512, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.512, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,0.512, ms
IDE01165,Park assist activation tone,OFF,
IDE01166,Supply voltage for park assist sensor,12.3, V
IDE01167,Convertible offset for volume level 1,1,
IDE01169,Audio lowering request,No,
IDE01588,Direction of travel,not recognised,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03011-IDE03726,Number of requested start processes-Parallel Parking Assistance,0,
IDE03011-MAS00825,Number of requested start processes-Parking Aid Control Module,0,
IDE03684,Vehicle stopped,Yes,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE10300,OBD Driving Cycle detected,not active,
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,1013, mm
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,0, mm
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,273, mm
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,0, mm
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,0, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,37, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,33, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,38, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,31, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,41, bar
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2026,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,1,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,2,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,5,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,4,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,17,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,15,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,26,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,21,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,8,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,17,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,22,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,8,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,20,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,14,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,29,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,52,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,46,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,7,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,12,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,31,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,12,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,27,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,29,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,4.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,6.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,3.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-5.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-2.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,not active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
Elapsed Time: 00:05
blockmap-13-5WA-907-572-B_TMBAJ7NXXNY096941-20260703-1357.CSV
;SW:5WA-907-572-B   HW:5WA-907-572 ---  13: Auto Dist. Reg
;Component:ACC Bosch MQB H20 0395, Coding:0903007D0077404512474000004040C54E4020000000000000000000000000
;EV_FRONTRADARBOSCHVW380,004017,EV_FRONTRADARBOSCHVW380_004_VW38.rod
;Friday,03,July,2026,13:57:50:12012
;VCID: CDCC83E50D5370A2ED4-8098
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,12.1, V
IDE00102,Control Module temperature,57, °C
IDE00310,Outside temperature,28.0, °C
IDE00391,Adaptive distance regulation: status,ACC_Off_MainSwitch_Off,
IDE00924,Steering angle,1.600, °
IDE00925,Yaw rate,0.000, rad/s
IDE01268-MAS02506,Front windshield wiper-Wiper active,not active,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,6C 76 58 80,
IDE02057-MAS02356,Dynamic calibration: status-Type of calibration,static,
IDE02057-MAS05634,Dynamic calibration: status-Progress,0, %
IDE02057-ENG279299,Dynamic calibration: status-Absolute_driving_distance,0, m
IDE02057-ENG279303,Dynamic calibration: status-Acceleration_out_of_range,Framework conditions currently not met,
IDE02057-ENG98465,Dynamic calibration: status-Calibration status,not started,
IDE02057-ENG279396,Dynamic calibration: status-Effective_driving_distance,0, m
IDE02057-ENG279410,Dynamic calibration: status-Fault_signal_active,Framework conditions currently not met,
IDE02057-ENG279411,Dynamic calibration: status-Few_locations,Framework conditions currently not met,
IDE02057-ENG279533,Dynamic calibration: status-Speed_out_of_range,Framework conditions currently not met,
IDE02057-ENG279572,Dynamic calibration: status-Yaw_rate_out_of_range,Framework conditions currently not met,
IDE02068-MAS00106,Time stamp-Year,2026,
IDE02068-MAS00107,Time stamp-Month,6,
IDE02068-MAS00108,Time stamp-Day,30,
IDE02068-MAS00109,Time stamp-Hours,20,
IDE02068-MAS00110,Time stamp-Minutes,35,
IDE02068-MAS00111,Time stamp-Seconds,0,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead approaching: ACC passive,3610,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead approaching: ACC OFF,2787,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,1,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead approaching: ACC passive,1066,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead approaching: ACC OFF,1059,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Actual value,4,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE08343,Immobilizer Challenge,E2 2D 1B 8A,
IDE08936,Misalignment angle: horiz,0.376, °
IDE09906,Vertical deadjustment,0.708, °
IDE10902-IDE00018,Expanded ambient data 1-Voltage terminal 15,12.0, V
IDE10902-IDE00102,Expanded ambient data 1-Control Module temperature,57, °C
IDE10902-IDE00310,Expanded ambient data 1-Outside temperature,28.0, °C
IDE10902-IDE03660,Expanded ambient data 1-Longitudinal acceleration,0.00, m/s²
IDE10902-MAS00370,Expanded ambient data 1-Vehicle speed,0.00, m/s
IDE10902-MAS01632,Expanded ambient data 1-Status,ACC_Off_MainSwitch_Off,
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,1.600, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.000, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Front windshield wiper,not active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,0.376, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,0.708, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2026,
IDE10903-MAS00107,Expanded ambient data 2-Month,6,
IDE10903-MAS00108,Expanded ambient data 2-Day,30,
IDE10903-MAS00109,Expanded ambient data 2-Hours,20,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,35,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,3,
IDE10903-MAS00711,Expanded ambient data 2-kilometer reading,143433, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,0.280, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,0.000, °
IDE10903-ENG255471,Expanded ambient data 2-Blindness_combined,0, %
IDE10903-ENG255476,Expanded ambient data 2-Blindness_indicator_1,0, %
IDE10903-ENG255477,Expanded ambient data 2-Blindness_indicator_2,100, %
IDE10903-ENG255478,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG255479,Expanded ambient data 2-Blindness_indicator_4,99, %
IDE10903-ENG255480,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG255481,Expanded ambient data 2-Blindness_indicator_6,0, %
IDE10903-ENG255628,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG256311,Expanded ambient data 2-Sensor_FRKL,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|2|2|2|2|2|2|2|2|2|,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|,
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.280, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,0.000, °
IDE12062,Counter for terminal 15 reset,7183,
IDE12238,I network: discarded messages counter,0,
IDE13845,Production mode status,not active,
IDE14997,Number of events: sensor blind,0,
IDE14998,Number of events: misalignment,0,
IDE15000-IDE08936,History data sensor calibration-Misalignment angle: horiz,0.000, °
IDE15000-IDE09906,History data sensor calibration-Vertical deadjustment,-0.500, °
IDE15000-IDE14999,History data sensor calibration-Duration of calibration,0.20, s
IDE15000-IDE15022,History data sensor calibration-Result of calibration,OK,
IDE15000-MAS00106,History data sensor calibration-Year,2022,
IDE15000-MAS00107,History data sensor calibration-Month,5,
IDE15000-MAS00108,History data sensor calibration-Day,3,
IDE15000-MAS00109,History data sensor calibration-Hours,6,
IDE15000-MAS00110,History data sensor calibration-Minutes,19,
IDE15000-MAS00111,History data sensor calibration-Seconds,48,
IDE15000-MAS00711,History data sensor calibration-kilometer reading,4, km
IDE15000-MAS02356,History data sensor calibration-Type of calibration,static,
IDE15000-MAS13429,History data sensor calibration-Horizontal correction angle: currently,0.000, °
IDE15000-MAS13430,History data sensor calibration-Vertical correction angle: currently,-0.490, °
IDE15006,History data sensor 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15007,History data sensor 02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15008,History data sensor 03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15009,History data sensor 04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15010,History data sensor 05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15011,History data sensor 06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15012,History data sensor 07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15013,History data sensor 08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15014,History data sensor 09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15015,History data sensor 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15016,History data sensor 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15017,History data sensor 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15018,History data sensor 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15019,History data sensor 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15020,History data sensor 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00370,Vehicle speed,0.00, m/s
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 01 01 00,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,10,
ENG254718-MAS17521,Function_On_Demand_Unlock_ID_Status_Dev-Unlockable functions: activation status,|ID number,Release code for a SWaP function
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,10,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG139832,Sw_version_supplier,EV_FRONTRADARBOSCHVW38000401700¥Ø=03955WA907572B SysC_VWMQB37w_0395_RC1000,
Elapsed Time: 00:18
blockmap-15-1EA-959-655-DL_TMBAJ7NXXNY096941-20260703-1358.CSV
;SW:1EA-959-655-DL   HW:1EA-959-655-DL ---  15: Airbags
;Component:VW40Airbag    010 0176, Coding:98CC000000C0C000000000000000000050540000205400004000F68000120065
;EV_AirbaVW40ALVVW38X,001012,EV_AirbaVW40ALVVW38X_VW41.rod
;Friday,03,July,2026,13:58:20:12012
;VCID: 8E4E44E9C0D50BBAD4E-80DA SFD {x}
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,connected,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,too large,
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,connected,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,too large,
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,connected,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,too large,
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,not installed,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,no measured value present,
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,not installed,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,no measured value present,
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Rear driver head curtain airbag igniter-Status,not installed,
IDE00947-MAS05030,Rear driver head curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Rear passenger head curtain airbag igniter-Status,not installed,
IDE00948-MAS05030,Rear passenger head curtain airbag igniter-Resistance,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,not installed,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,not installed,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01359-MAS01632,Front pedestrian protection trigger-Status,not installed,
IDE01359-MAS05030,Front pedestrian protection trigger-Resistance,no measured value present,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE01560,Number of activations of active head restraint,0,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,not installed,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,no measured value present,
IDE03800-MAS01632,Driver airbag release valve igniter-Status,not installed,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,not installed,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Actual value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,not calculated,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,0.0, %
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,0.0, %
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,0.0, %
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,not installed,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,not installed,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,1,
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,not installed,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,not installed,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Front driver side third row seat belt tensioner igniter-Status,not installed,
IDE08436-MAS05030,Front driver side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,not installed,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,not installed,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,not installed,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,not installed,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,0,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,0,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,0,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,1,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,0,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,not installed,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,connected,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,not active,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,not installed,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,not installed,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,no measured value present,
IDE14662-IDE13284,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row driver side,0,
IDE14662-IDE13586,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,0,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,0,
IDE14662-IDE14846,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: center,0,
IDE14662-IDE14847,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row driver side,0,
IDE14662-IDE14848,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,0,
IDE14662-IDE14849,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row center,0,
IDE14662-MAS00038,Expanded diagnosis of seat occupancy detection-Seat occupied recognition rear  driver side,0,
IDE14662-MAS00039,Expanded diagnosis of seat occupancy detection-Seat occupied recognition rear  passenger side,0,
IDE14662-MAS00040,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: center: rear,0,
IDE14662-MAS00231,Expanded diagnosis of seat occupancy detection-Seat occupant detection passenger side,0,
IDE14662-MAS00478,Expanded diagnosis of seat occupancy detection-Reserved,0,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,not installed,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,not active,
IDE14662-MAS18987,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: 3rd row center,0,
IDE14740-IDE13284,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row driver side,not installed,
IDE14740-IDE13586,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,not installed,
IDE14740-IDE14240,Wireless seat occupancy detection-Driver side seat occupancy detection,not installed,
IDE14740-IDE14846,Wireless seat occupancy detection-Seat occupancy detection: center,not installed,
IDE14740-IDE14847,Wireless seat occupancy detection-Seat-occupied recognition: 4th row driver side,not installed,
IDE14740-IDE14848,Wireless seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,not installed,
IDE14740-IDE14849,Wireless seat occupancy detection-Seat-occupied recognition: 4th row center,not installed,
IDE14740-MAS00038,Wireless seat occupancy detection-Seat occupied recognition rear  driver side,not installed,
IDE14740-MAS00039,Wireless seat occupancy detection-Seat occupied recognition rear  passenger side,not installed,
IDE14740-MAS00040,Wireless seat occupancy detection-Seat occupied recognition: center: rear,not installed,
IDE14740-MAS00231,Wireless seat occupancy detection-Seat occupant detection passenger side,not installed,
IDE14740-MAS18987,Wireless seat occupancy detection-Seat occupancy detection: 3rd row center,not installed,
IDE14741-IDE00821,Wireless belt buckle query-Seat belt switch 2nd row driver's side,not installed,
IDE14741-IDE00822,Wireless belt buckle query-Safety belt switch 2nd row frt.passenger side,not installed,
IDE14741-IDE00823,Wireless belt buckle query-Seat belt switch 2nd row center,not installed,
IDE14741-IDE00824,Wireless belt buckle query-Seat belt switch 3rd row driver's side,not installed,
IDE14741-IDE00825,Wireless belt buckle query-Passenger side 3rd row seat belt switch,not installed,
IDE14741-IDE00826,Wireless belt buckle query-Seat belt switch 3rd row center,not installed,
IDE14741-IDE14842,Wireless belt buckle query-Center seat belt switch,not installed,
IDE14741-IDE14843,Wireless belt buckle query-Seat belt switch: 4th row driver side,not installed,
IDE14741-IDE14844,Wireless belt buckle query-Seat belt switch: 4th row passenger side,not installed,
IDE14741-IDE14845,Wireless belt buckle query-Seat belt switch: 4th row center,not installed,
IDE14741-MAS00025,Wireless belt buckle query-Driver seat belt switch,not installed,
IDE14741-MAS00026,Wireless belt buckle query-Front passenger side safety belt switch,not installed,
IDE14841-MAS01632,Seat Belt Tensioner Igniter: center 3rd row-Status,not installed,
IDE14841-MAS05030,Seat Belt Tensioner Igniter: center 3rd row-Resistance,no measured value present,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
IDE15772-MAS14174,Wireless belt request/seat occupancy detection status-2nd Row Center,not configured,
IDE15772-MAS20984,Wireless belt request/seat occupancy detection status-1st Row Driver Side,not configured,
IDE15772-MAS20985,Wireless belt request/seat occupancy detection status-1st Row Passenger Side,not configured,
IDE15772-MAS20986,Wireless belt request/seat occupancy detection status-1st Row Center,not configured,
IDE15772-MAS20987,Wireless belt request/seat occupancy detection status-3rd Row Center,not configured,
IDE15772-MAS20988,Wireless belt request/seat occupancy detection status-4th Row Center,not configured,
IDE15772-MAS20989,Wireless belt request/seat occupancy detection status-4th Row Passenger Side,not configured,
IDE15772-MAS20990,Wireless belt request/seat occupancy detection status-3rd Row Passenger Side,not configured,
IDE15772-MAS20991,Wireless belt request/seat occupancy detection status-2nd Row Passenger Side,not configured,
IDE15772-MAS20992,Wireless belt request/seat occupancy detection status-2nd Row Driver Side,not configured,
IDE15772-MAS20993,Wireless belt request/seat occupancy detection status-3rd Row Driver Side,not configured,
IDE15772-MAS20994,Wireless belt request/seat occupancy detection status-4th Row Driver Side,not configured,
IDE16064-MAS01632,Driver Head Curtain Airbag Igniter 2-Status,not installed,
IDE16064-MAS05030,Driver Head Curtain Airbag Igniter 2-Resistance,no measured value present,
IDE16065-MAS01632,Front Passenger Head Curtain Airbag Igniter 2-Status,not installed,
IDE16065-MAS05030,Front Passenger Head Curtain Airbag Igniter 2-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,3.4, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,not installed,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger front airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger front airbag igniter-Resistance,2.6, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,not installed,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,no measured value present,
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.7, Ohm
MAS00006-MAS01632,Front passenger thorax airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger thorax airbag igniter-Resistance,2.6, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,not installed,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,not installed,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.8, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,3.0, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,correct,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,2.6, Ohm
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,not installed,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver seat belt tension igniter-Resistance,2.8, Ohm
MAS00014-MAS01632,Front passenger seat belt tensioner igniter-Status,correct,
MAS00014-MAS05030,Front passenger seat belt tensioner igniter-Resistance,2.8, Ohm
MAS00015-MAS01632,Driver seat belt tensioner igniter 2-Status,not installed,
MAS00015-MAS05030,Driver seat belt tensioner igniter 2-Resistance,no measured value present,
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,not installed,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,no measured value present,
MAS00017-MAS01632,Igniter for Driver Belt Force Limiter-Status,not installed,
MAS00017-MAS05030,Igniter for Driver Belt Force Limiter-Resistance,no measured value present,
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,not installed,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,no measured value present,
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,3.1, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,3.1, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,not installed,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,not installed,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver active head restraint igniter/trigger-Status,not installed,
MAS00023-MAS05030,Driver active head restraint igniter/trigger-Resistance,no measured value present,
MAS00024-MAS01632,Front passenger active head restraint igniter/trigger-Status,not installed,
MAS00024-MAS05030,Front passenger active head restraint igniter/trigger-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,connected,
MAS00025-MAS05030,Driver seat belt switch-Resistance,too large,
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,0.0, Ohm
MAS00030-MAS01632,Seat occupant detection-Status,Not assigned,
MAS00030-MAS05030,Seat occupant detection-Resistance,404.0, Ohm
MAS00031,Airbag deactivation status,OFF,
MAS00032-MAS01632,Key switch terminal 1-Status,OFF,
MAS00032-MAS05030,Key switch terminal 1-Resistance,3900.0, Ohm
MAS00033-MAS01632,Key switch terminal 2-Status,OFF,
MAS00033-MAS05030,Key switch terminal 2-Resistance,240.0, Ohm
MAS00035-MAS01632,Seat position sensor: driver side-Status,not installed,
MAS00035-MAS04136,Seat position sensor: driver side-Current,no measured value present,
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,not installed,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,no measured value present,
MAS00038-MAS01632,Seat occupied recognition rear  driver side-Status,assigned,
MAS00038-MAS05030,Seat occupied recognition rear  driver side-Resistance,too large,
MAS00039-MAS01632,Seat occupied recognition rear  passenger side-Status,assigned,
MAS00039-MAS05030,Seat occupied recognition rear  passenger side-Resistance,too large,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,assigned,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,too large,
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,11.5, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,12.4, V
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
Elapsed Time: 00:18
blockmap-17-5E3-920-770-B_TMBAJ7NXXNY096941-20260703-1345.CSV
;SW:5E3-920-770-B   HW:5E3-920-770-B ---  17: Instruments
;Component:KOMBI         201 5370, Coding:04A4004063840008018462032000080800301400
;EV_DashBoardVDDMQB37W,003033,EV_DashBoardVDDMQB37W_003_SK38.rod
;Friday,03,July,2026,13:45:26:12012
;VCID: A80212714271758A3E2-80FC SFD {x}
IDE00019,Voltage terminal 30,12.4, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,27.00, °C
IDE00196,Engine oil temperature,28, °C
IDE00316-IDE00500,Time-Hour,20, H
IDE00316-IDE00501,Time-Minute,22, min
IDE00316-MAS00111,Time-Seconds,36, s
IDE00317-IDE00502,Date-Year,2026, yr
IDE00317-IDE00503,Date-Month,6, Months
IDE00317-IDE00504,Date-Day,30, d
IDE00706,Fuel level gasoline,101.6, %
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2005, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2065, mm
IDE01076,Time since ignition off,84817, s
IDE01985-MAS06855,FAZIT identification test sum-Test sum,E8 D0 7B 6F,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,28.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,107,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,100,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,100,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,13,
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane departure warning,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03471-ENG164384,Vehicle configuration-virtual_side_mirror,Correct coding,
IDE03471-ENG174709,Vehicle configuration-zFAS,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,9.1, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,45.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,47.5, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,9.0, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,43.9, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,45.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,47.5, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,43.2, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,30.1, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,45.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,47.5, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,30.2, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,14.1, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,45.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,47.5, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,14.4, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,14310.0, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,14230.0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,14200.0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,14150.0, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,167, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,4, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,32767, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,32767, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,32767, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,1890,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,171,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,1963,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,184,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,29.1, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,163, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,29.4, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-IDE00802,Calculated volume-Full volume,45.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,29.4, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,3276.7, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,3276.7, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,3276.7, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,29.4, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,3276.7, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,3276.7, l
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,3276.7, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,29.4, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,29.4, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,29.4, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.03125, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-12.15625, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,29.2, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000,
IDE03474-ENG99683,Calculated volume-version_of_application,120,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03477-IDE00500,GPS time-Hour,23, H
IDE03477-IDE00500,GPS time-Hour,21, H
IDE03477-IDE00501,GPS time-Minute,52, min
IDE03477-IDE00501,GPS time-Minute,45, min
IDE03477-IDE00502,GPS time-Year,2026, yr
IDE03477-IDE00503,GPS time-Month,7, Months
IDE03477-IDE00504,GPS time-Day,1, d
IDE03477-IDE00504,GPS time-Day,2, d
IDE03477-MAS00111,GPS time-Seconds,55, s
IDE03477-MAS00111,GPS time-Seconds,29, s
IDE03477-MAS03493,GPS time-last synchronization year,2026, yr
IDE03506,Distance: high resolution,08 8C 9E 29,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,8F F0 00 08,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,CF F0 00 55,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,4F F0 00 55,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,0F F0 00 08,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,3F F0 6A 83,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,8F F0 70 87,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,CF F0 01 79,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 70 87,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,4F F0 01 79,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,BF F0 E5 B7,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,3F F0 E5 B7,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,0F F1 19 DB,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,4F F0 03 09,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,8F F1 19 DB,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,CF F0 03 09,
IDE03911-ENG263219,Service -interval- display: history 1-Block_16,3F F1 88 52,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,BF F1 8F 0B,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,8F F1 AB 45,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,CF F0 04 65,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,0F F1 AB 45,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,4F F0 04 65,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,0F F2 18 8C,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,4F F0 05 54,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,8F F2 19 7A,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,CF F0 05 54,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,4F F0 05 54,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,0F F2 19 7A,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,8F F2 19 7A,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,CF F0 05 54,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,4F F0 05 54,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,0F F2 19 7A,
IDE03912-ENG263219,Service -interval- display: history 2-Block_16,8F F2 19 7A,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,CF F0 05 54,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-ENG263219,Service -interval- display: history 3-Block_16,FF FF FF FF,
IDE03914-ENG263219,Service -interval- display: history 4-Block_16,FF FF FF FF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06924,Performance display,4093,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08343,Immobilizer Challenge,1C 9A A5 3E,
IDE09635,Reason for configuration error,BAP Timeout,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10803,Suspicious Logical addressee BAP,50,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,231,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12972,Oil: theoretical service interval,12500.00, km
IDE12973,Oil: service interval exceeded in km,0, km
IDE12974,Oil service interval exceeded in days,0, d
IDE12975,Oil: remaining driving distance,9170, km
IDE12976,Oil: remaining running time,211, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,Kilometres,
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,9200,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Service in,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Service in,
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Service in,
IDE12977-MAS07271,Oil status-Inspection: unit of distance traveled,Kilometres,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,204700,
IDE12977-MAS07273,Oil status-Inspection: time,211,
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,211,
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,37,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,TMBAJ7NXXNY096941,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,11,
IDE14124-IDE03840,Gong status-Volume of actuator test,0, %
IDE14124-MAS01167,Gong status-Actuation time,Unknown (0)
IDE14124-MAS05781,Gong status-Acoustics,all_acoustics,
IDE14124-ENG261531,Gong status-IO Reached Status,Output diagnostic test not active,
IDE14126-MAS01167,Other function lights status-Actuation time,Unknown (0)
IDE14126-MAS01168,Other function lights status-Start parameter,00 00 00,
IDE14126-ENG261531,Other function lights status-IO Reached Status,Output diagnostic test not active,
IDE14127-MAS01167,Lights status-Actuation time,Unknown (0)
IDE14127-MAS01168,Lights status-Start parameter,00 00 00,
IDE14127-ENG261531,Lights status-IO Reached Status,Output diagnostic test not active,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,Unknown (0)
IDE14129-ENG261531,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,Unknown (0)
IDE14130-MAS01168,Test image in center display status-Start parameter,Unknown (0)
IDE14130-ENG261531,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,Unknown (0)
IDE14132-MAS01168,Indicator lamp status-Start parameter,00 00 00,
IDE14132-ENG261531,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE14185-IDE00301,Gas systems test-Distance,0, km
IDE14185-IDE00502,Gas systems test-Year,2001, yr
IDE14185-IDE00503,Gas systems test-Month,1, Months
IDE14185-IDE00504,Gas systems test-Day,1, d
IDE14185-MAS17869,Gas systems test-Time since last reset,0, d
IDE14185-MAS17870,Gas systems test-Number of resets,0,
IDE14212-ENG103300,Service Key Master daily data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14213-ENG103300,Service Key Master current data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14214-ENG263244,Service Key Master write counter-Counter_current_clamp_15,0,
IDE14214-ENG263245,Service Key Master write counter-Counter_current_total,11664,
IDE14214-ENG263246,Service Key Master write counter-Counter_daily_clamp_15,0,
IDE14214-ENG263247,Service Key Master write counter-Counter_daily_total,8764,
IDE14214-ENG119822,Service Key Master write counter-Error_Counter,0,
IDE14214-ENG263298,Service Key Master write counter-state_current,Engine_off,
IDE14214-ENG263299,Service Key Master write counter-State_daily,Engine_off,
IDE14214-ENG263221,Service Key Master write counter-transponder_id,00 00 00 00,
IDE14214-ENG263220,Service Key Master write counter-Transponder_type,00 00,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,2026, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,7, Months
IDE14236-MAS00108,Authentic time: last confirmed time-Day,3, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,8, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,52, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,21, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,0, H
IDE14237-MAS00106,Authentic time: actual time-Year,2026, yr
IDE14237-MAS00107,Authentic time: actual time-Month,7, Months
IDE14237-MAS00108,Authentic time: actual time-Day,3, d
IDE14237-MAS00109,Authentic time: actual time-Hours,10, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,45, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,36, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,0, H
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,00,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,|Verification failed|00 00|,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,|failed signature creation|00 00|,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,00,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,00,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,00,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 2F 4E 2C 42 49 69 B4,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,00,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-ENG103935,Secure Onboard Communication: Freshness Values information-Parameter,|SOC PDU ID to which this freshness information is assigned,Freshness Value query status
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,|Missing key|00 00|,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,00,
IDE15081,Authentic time: status of distribution signal trigger,0,
MAS00902-ENG99140,Extended Service Intervals (ESI)-advance_warning_fixed_days,not active,
MAS00902-ENG100265,Extended Service Intervals (ESI)-advance_warning_fixed_km,not active,
MAS00902-ENG101600,Extended Service Intervals (ESI)-advance_warning_WIV_days,not active,
MAS00902-ENG102887,Extended Service Intervals (ESI)-advance_warning_WIV_km,not active,
MAS00902-ENG99971,Extended Service Intervals (ESI)-in_calculation,active,
MAS00902-ENG101015,Extended Service Intervals (ESI)-no_calculation_available,not active,
MAS00902-ENG101477,Extended Service Intervals (ESI)-service_warning_fixed_days,not active,
MAS00902-ENG101550,Extended Service Intervals (ESI)-service_warning_fixed_km,not active,
MAS00902-ENG101709,Extended Service Intervals (ESI)-service_warning_WIV_days,not active,
MAS00902-ENG102993,Extended Service Intervals (ESI)-service_warning_WIV_km,not active,
MAS10768,Daily mileage,37, km
ENG186121,Authentic_time_current_counter_kl15_since_last_sync,0,
ENG262946,Authentic_time_last_backend_response,|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||,
ENG186123,Authentic_time_last_client_response,0,
ENG186123,Authentic_time_last_client_response,2026-07-03T10:43:59Z,
ENG186123,Authentic_time_last_client_response,2026-07-03T08:52:21Z,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0.9,
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,26, %
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0.0,
ENG105830-ENG263248,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_night,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG263249,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_blue,0.0,
ENG105830-ENG263250,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_green,0.0,
ENG105830-ENG263251,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_red,0.0,
ENG105830-ENG263252,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_yellow,0.0,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,9, %
ENG105830-ENG261530,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,3981,
ENG99439,Instrument_recorder,07 23 60 00 4D 51 42 32 30 32 30 32 31 53 31 46 41 43 47 32 62 35 32 30 31 34 5F 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 05 06 05 09 05 06 05 09 06 00 00 1F 00 CA 00 B1 03 00 00 00 00 00 00 76 53 06 00 F8 48 92 57 20 00 C4 00 97 02 00 00 01 00 00 00 A7 4E 06 00 F0 CF C4 65 1F 00 D6 00 8A 02 00 00 02 00 00 00 A7 4E 06 00 F0 CF C4 65 07 00 28 00 03 C1 00 00 1B 00 00 00 B8 48 06 00 D0 A9 F8 E9 07 00 28 00 03 C1 00 00 17 00 00 00 B8 48 06 00 D0 A9 F8 E9 07 00 28 00 03 C1 00 00 13 00 00 00 B8 48 06 00 D0 A9 F8 E9 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 2C 00 03 00 00 00 04 00 04 00 02 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 02 00 8C FF B7 00 00 10 3B 00 8C FF FF FF 00 00 35 12 C8 35 12 12 06 17 00 00 00 01 86 EE FF B7 00 00 00 00 00 00 54 41 A8 48 80 00 40 00 32 16 14 00 00 00 A8,
ENG128745,Instrument_recorder_graphic,05 23 60 00 4D 51 42 32 30 32 30 32 31 53 31 46 47 43 5F 53 4B B8 48 06 00 A6 93 24 E8 AB 01 00 00 13 00 00 00 02 C1 00 00 10 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 DA 93 24 E8 AB 01 00 00 13 00 00 00 02 C1 00 00 11 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 25 94 24 E8 AB 01 00 00 13 00 00 00 02 C1 00 00 12 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 5A 94 24 E8 AB 01 00 00 13 00 00 00 02 C1 00 00 13 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 95 94 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 04 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 FF 94 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 06 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 71 95 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 0A 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 D7 95 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 0E 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 11 96 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 0F 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 4E 96 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 10 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 A5 96 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 23 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 EB 96 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 24 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 B8 48 06 00 52 97 24 E8 AB 01 00 00 13 00 00 00 03 C1 00 00 25 00 00 00 3E 20 00 00 02 00 00 00 01 00 00 00 69 55 06 00 A2 29 F3 51 2C 00 00 00 01 00 00 00 73 00 01 00 00 00 00 00 3D 27 00 00 2F 06 00 00 02 00 00 00 69 55 06 00 DF EF F3 51 2C 00 00 00 01 00 00 00 73 00 01 00 00 00 00 00 3D 27 00 00 2F 06 00 80 02 00 00 00 68 55 06 00 9B 8D A6 A6 B2 02 00 00 3E 00 00 00 7B 00 00 00 00 00 00 00 3C 27 00 00 F8 0B 00 00 02 00 00 00 68 55 06 00 59 8F A6 A6 F0 00 00 00 0F 00 00 00 88 01 00 00 00 00 00 00 3C 27 00 00 F8 0B 00 00 02 00 00 00 58 55 06 00 BB F1 E4 AC 7C 00 00 00 06 00 00 00 00 01 0F 00 00 00 00 00 37 27 00 00 70 04 00 00 02 00 00 00 96 53 06 00 3B A4 A4 F5 83 02 00 00 37 00 00 00 E8 00 00 00 00 00 00 00 01 25 00 00 03 00 00 00 02 00 00 00 C9 54 06 00 25 BC B1 03 61 02 00 00 2F 00 00 00 E8 00 00 00 00 00 00 00 36 26 00 00 6F 02 00 00 04 00 00 00 96 52 06 00 50 90 04 CE A5 03 00 00 4D 00 00 00 12 06 00 00 02 04 00 00 3F 24 00 00 13 00 00 00 02 00 00 00 8D 52 06 00 49 8D FE 2C 7C 00 00 00 06 00 00 00 00 01 0F 00 00 00 00 00 39 24 00 00 06 00 00 00 02 00 00 00 32 55 06 00 FF B8 36 E6 9A 04 00 00 66 00 00 00 55 01 01 00 00 00 00 00 03 27 00 00 09 00 00 00 02 00 00 00 B1 51 06 00 D1 C3 D6 7D 8C 02 00 00 37 00 00 00 BB 04 00 00 00 00 00 00 86 23 00 00 73 01 00 00 02 00 00 00 B7 52 06 00 68 9E 78 B6 8C 02 00 00 37 00 00 00 BB 04 00 00 00 00 00 00 4C 24 00 00 7D 00 00 00 02 00 00 00 5D 4C 06 00 CF C2 59 CD A3 02 00 00 3C 00 00 00 4D 00 00 00 00 00 00 00 3C 21 00 00 1D 00 00 00 02 00 00 00 5D 4C 06 00 5A C5 59 CD ED 00 00 00 0F 00 00 00 75 01 00 00 00 00 00 00 3C 21 00 00 0A 00 00 00 02 00 00 00 C6 4D 06 00 6A 6F B4 FA 8A 04 00 00 64 00 00 00 CF 01 0A 00 00 00 00 00 D6 21 00 00 00 00 00 00 7E 00 00 00 9D 01 00 00 62 11 13 00 00 04 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 04 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 64 30 39 39 62 38 38 78 02 00 00 00 42 27 00 00 02 00 00 00 69 D6 FF FF 00 00 00 00 57 C6 FF FF 00 00 00 00 6F C1 36 13 01 FF FF FF,
ENG264452,Instrument_recorder_graphic_3,||05|23|60|00|4D|51|42|32|30|32|30|32|31|53|31|46|47|43|5F|53|4B|B8|48|06|00|A6|93|24|E8|AB|01|00|00|13|00|00|00|02|C1|00|00|10|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|DA|93|24|E8|AB|01|00|00|13|00|00|00|02|C1|00|00|11|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|25|94|24|E8|AB|01|00|00|13|00|00|00|02|C1|00|00|12|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|5A|94|24|E8|AB|01|00|00|13|00|00|00|02|C1|00|00|13|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|95|94|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|04|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|FF|94|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|06|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|71|95|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|0A|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|D7|95|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|0E|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|11|96|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|0F|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|4E|96|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|10|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|A5|96|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|23|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|EB|96|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|24|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|B8|48|06|00|52|97|24|E8|AB|01|00|00|13|00|00|00|03|C1|00|00|25|00|00|00|3E|20|00|00|02|00|00|00|01|00|00|00|69|55|06|00|A2|29|F3|51|2C|00|00|00|01|00|00|00|73|00|01|00|00|00|00|00|3D|27|00|00|2F|06|00|00|02|00|00|00|69|55|06|00|DF|EF|F3|51|2C|00|00|00|01|00|00|00|73|00|01|00|00|00|00|00|3D|27|00|00|2F|06|00|80|02|00|00|00|68|55|06|00|9B|8D|A6|A6|B2|02|00|00|3E|00|00|00|7B|00|00|00|00|00|00|00|3C|27|00|00|F8|0B|00|00|02|00|00|00|68|55|06|00|59|8F|A6|A6|F0|00|00|00|0F|00|00|00|88|01|00|00|00|00|00|00|3C|27|00|00|F8|0B|00|00|02|00|00|00|58|55|06|00|BB|F1|E4|AC|7C|00|00|00|06|00|00|00|00|01|0F|00|00|00|00|00|37|27|00|00|70|04|00|00|02|00|00|00|96|53|06|00|3B|A4|A4|F5|83|02|00|00|37|00|00|00|E8|00|00|00|00|00|00|00|01|25|00|00|03|00|00|00|02|00|00|00|C9|54|06|00|25|BC|B1|03|61|02|00|00|2F|00|00|00|E8|00|00|00|00|00|00|00|36|26|00|00|6F|02|00|00|04|00|00|00|96|52|06|00|50|90|04|CE|A5|03|00|00|4D|00|00|00|12|06|00|00|02|04|00|00|3F|24|00|00|13|00|00|00|02|00|00|00|8D|52|06|00|49|8D|FE|2C|7C|00|00|00|06|00|00|00|00|01|0F|00|00|00|00|00|39|24|00|00|06|00|00|00|02|00|00|00|32|55|06|00|FF|B8|36|E6|9A|04|00|00|66|00|00|00|55|01|01|00|00|00|00|00|03|27|00|00|09|00|00|00|02|00|00|00|B1|51|06|00|D1|C3|D6|7D|8C|02|00|00|37|00|00|00|BB|04|00|00|00|00|00|00|86|23|00|00|73|01|00|00|02|00|00|00|B7|52|06|00|68|9E|78|B6|8C|02|00|00|37|00|00|00|BB|04|00|00|00|00|00|00|4C|24|00|00|7D|00|00|00|02|00|00|00|5D|4C|06|00|CF|C2|59|CD|A3|02|00|00|3C|00|00|00|4D|00|00|00|00|00|00|00|3C|21|00|00|1D|00|00|00|02|00|00|00|5D|4C|06|00|5A|C5|59|CD|ED|00|00|00|0F|00|00|00|75|01|00|00|00|00|00|00|3C|21|00|00|0A|00|00|00|02|00|00|00|C6|4D|06|00|6A|6F|B4|FA|8A|04|00|00|64|00|00|00|CF|01|0A|00|00|00|00|00|D6|21|00|00|00|00|00|00|7E|00|00|00|9D|01|00|00|62|11|16|00|00|04|00|00|00|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|00|00|04|00|00|00|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|64|30|39|39|62|38|38|78|02|00|00|00|41|27|00|00|02|00|00|00|6A|D6|FF|FF|00|00|00|00|57|C6|FF|FF|00|00|00|00|6F|C1|36|13|02|FF|FF|FF|,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,156,
Elapsed Time: 00:17
blockmap-19-5WA-907-530-Q_TMBAJ7NXXNY096941-20260703-1346.CSV
;SW:5WA-907-530-Q   HW:5WA-907-530-G ---  19: CAN Gateway
;Component:GW2020 High   756 7300, Coding:0000838D0700000000000000010303325301600902000300030100000001010100000000000000000000000000000000
;EV_GatewMQB2020,005011,EV_GatewMQB2020_004_SK38.rod
;Friday,03,July,2026,13:46:29:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: D6FE6C893885337A5CE-8082 SFD {x}
Group,Description,Actual
IDE00019,Voltage terminal 30,12.3, V
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,none,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
IDE00634,Vehicle electric system current,21.971, A
IDE00767-ENG280618,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 00 00 80,
IDE00767-ENG280619,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG280620,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG280621,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG136152,No. of unscheduled ECU resets-KL30_Reset_Counter,25,
IDE00767-ENG280656,No. of unscheduled ECU resets-Muc_Reset_Counter,2,
IDE00767-ENG280678,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG280679,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG280680,No. of unscheduled ECU resets-Reason_of_4th_last_reset,2,
IDE00767-ENG280681,No. of unscheduled ECU resets-Reason_of_5th_last_reset,0,
IDE00767-ENG280682,No. of unscheduled ECU resets-Reason_of_latest_reset,2,
IDE00767-ENG280768,No. of unscheduled ECU resets-Watchdog_Reset_Counter,1,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.6, H
IDE01807-MAS00106,History data 21-Year,2026,
IDE01807-MAS00107,History data 21-Month,6,
IDE01807-MAS00108,History data 21-Day,4,
IDE01807-MAS00109,History data 21-Hours,18, H
IDE01807-MAS00110,History data 21-Minutes,27, min
IDE01807-MAS14375,History data 21-Cycle counter,7055,
IDE01807-MAS14376,History data 21-ECU 1,00 73,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.6, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 00,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG159905,History data 21-Bus_ECU_1,Infotainment data bus,
IDE01807-ENG159908,History data 21-Bus_ECU_2,Unknown,
IDE01807-ENG159911,History data 21-Bus_ECU_3,Unknown,
IDE01807-ENG159914,History data 21-Bus_ECU_4,Unknown,
IDE01807-ENG159917,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.1, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.1, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2025,
IDE01809-MAS00107,History data 23-Month,8,
IDE01809-MAS00108,History data 23-Day,24,
IDE01809-MAS00109,History data 23-Hours,19, H
IDE01809-MAS00110,History data 23-Minutes,37, min
IDE01809-MAS14375,History data 23-Cycle counter,5515,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Infotainment data bus,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 46,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,23,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG255497,History data 23-Bus_Waking_ECU_1,Comfort data bus,
IDE01809-ENG255498,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG255499,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG255500,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG255501,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,1.7, H
IDE01810-MAS00106,History data 24-Year,2026,
IDE01810-MAS00107,History data 24-Month,6,
IDE01810-MAS00108,History data 24-Day,28,
IDE01810-MAS00109,History data 24-Hours,4, H
IDE01810-MAS00110,History data 24-Minutes,54, min
IDE01810-MAS14375,History data 24-Cycle counter,7154,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,17 33 0E 00,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Infotainment data bus,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,28,
IDE01810-MAS20473,History data 24-Alerting message counter,2,
IDE01812-MAS01468,History data 26-Terminal 15,7165,
IDE01812-MAS03173,History data 26-Powertrain data bus,55,
IDE01812-MAS03174,History data 26-Comfort data bus,9610,
IDE01812-MAS03177,History data 26-Infotainment data bus,14,
IDE01812-MAS03178,History data 26-Suspension data bus,1,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,17,
IDE01812-MAS14374,History data 26-Totals,10623,
IDE01812-MAS16910,History data 26-Migration data bus,836,
IDE01813-MAS03173,History data 27-Powertrain data bus,25,
IDE01813-MAS03174,History data 27-Comfort data bus,1037,
IDE01813-MAS03177,History data 27-Infotainment data bus,1,
IDE01813-MAS03178,History data 27-Suspension data bus,0,
IDE01813-MAS12185,History data 27-Hybrid data bus,9824,
IDE01813-MAS14374,History data 27-Totals,10887,
IDE01814-MAS03173,History data 28-Powertrain data bus,54,
IDE01814-MAS03174,History data 28-Comfort data bus,5009,
IDE01814-MAS03177,History data 28-Infotainment data bus,6912,
IDE01814-MAS03178,History data 28-Suspension data bus,13120,
IDE01814-MAS14374,History data 28-Totals,13054,
IDE01814-MAS16910,History data 28-Migration data bus,6123,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.1, H
IDE01816-MAS00106,History data 30-Year,2024,
IDE01816-MAS00107,History data 30-Month,9,
IDE01816-MAS00108,History data 30-Day,10,
IDE01816-MAS00109,History data 30-Hours,2, H
IDE01816-MAS00110,History data 30-Minutes,31, min
IDE01816-MAS14375,History data 30-Cycle counter,2923,
IDE01816-ENG151642,History data 30-Bus_1,Infotainment data bus,
IDE01816-ENG151644,History data 30-Bus_2,Comfort data bus,
IDE01816-ENG151646,History data 30-Bus_3,Migration data bus,
IDE01816-ENG151648,History data 30-Bus_4,Suspension data bus,
IDE01816-ENG151650,History data 30-Bus_5,Powertrain data bus,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,21.1, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,10.7, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.6, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.1, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.1, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.6, H
IDE01817-MAS00106,History data 31-Year,2026,
IDE01817-MAS00107,History data 31-Month,6,
IDE01817-MAS00108,History data 31-Day,4,
IDE01817-MAS00109,History data 31-Hours,18, H
IDE01817-MAS00110,History data 31-Minutes,27, min
IDE01817-MAS14375,History data 31-Cycle counter,7055,
IDE01817-MAS14376,History data 31-ECU 1,00 73,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.6, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 00,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG159905,History data 31-Bus_ECU_1,Infotainment data bus,
IDE01817-ENG159908,History data 31-Bus_ECU_2,Unknown,
IDE01817-ENG159911,History data 31-Bus_ECU_3,Unknown,
IDE01817-ENG159914,History data 31-Bus_ECU_4,Unknown,
IDE01817-ENG159917,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2025,
IDE01818-MAS00107,History data 32-Month,8,
IDE01818-MAS00108,History data 32-Day,24,
IDE01818-MAS00109,History data 32-Hours,19, H
IDE01818-MAS00110,History data 32-Minutes,37, min
IDE01818-MAS14375,History data 32-Cycle counter,5515,
IDE01818-MAS14391,History data 32-Alerting ECU,00 46,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,1.7, H
IDE01819-MAS00106,History data 33-Year,2026,
IDE01819-MAS00107,History data 33-Month,6,
IDE01819-MAS00108,History data 33-Day,28,
IDE01819-MAS00109,History data 33-Hours,4, H
IDE01819-MAS00110,History data 33-Minutes,54, min
IDE01819-MAS14375,History data 33-Cycle counter,7154,
IDE01819-MAS14393,History data 33-ID of the alerting message,17 33 0E 00,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Infotainment data bus,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2022,
IDE01820-MAS00107,History data 34-Month,5,
IDE01820-MAS00108,History data 34-Day,2,
IDE01820-MAS00109,History data 34-Hours,19, H
IDE01820-MAS00110,History data 34-Minutes,17, min
IDE01820-MAS14375,History data 34-Cycle counter,15,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 0E,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,7168,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82A - 140A,
IDE01831-MAS06311,Generator variant-ASIC manufacturer,1,
IDE01831-MAS06312,Generator variant-ASIC variant,4,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Duration of last driving cycle,0.0, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,8A D1 D6 F8,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-request idle speed increase,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Extractable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG299090,Readiness for bus sleep mode-ECU_Sleepindication,|Sleep-Bit 0,Sleep-Bit 1
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,not active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,not engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,not engaged,
IDE05814,Individualization characteristic,62 BB E8 79 52,
IDE05960-IDE01827,Generator-Specified generator voltage,10.6, V
IDE05960-IDE01828,Generator-Generator DF Signal,0.025, %
IDE05960-IDE01829,Generator-Generator exciter current,0.000, A
IDE05960-IDE01830,Generator-Generator Status,OFF,
IDE05960-IDE01855,Generator-Generator current,0.0, A
IDE05960-MAS06306,Generator-Status generator release by engine,no request,
IDE05960-MAS06307,Generator-Status of battery charging function,not active,
IDE05960-MAS11758,Generator-Identification,Yes,
IDE05960-MAS14589,Generator-mechanical power,0, W
IDE05960-MAS21174,Generator-Generator reserve current,0.0, A
IDE05960-MAS21325,Generator-Ramp time,6, s
IDE06011-ENG118665,Selected driving profile-driving_profile,without_function,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0)
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,0, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.90,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognised,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognised,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.30, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.30, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,952, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,976, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,DE 67 46 CA,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.4, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,32, °C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,100, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Neck heating,not enabled,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,not enabled,
IDE09058-MAS01564,Energy management: consumer releases-Windshield defogger,not enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,not enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,not enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heating,not enabled,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,not enabled,
IDE09058-MAS06552,Energy management: consumer releases-Seat heating: front,not enabled,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,327400, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),14.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,5.2, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,13.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,33.8, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,509, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,509, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,509, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,0, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,500,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,500,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,2045,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,Kilometres,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,13.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,13.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,13.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,13.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,13.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,13.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,26.6, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery:  RWB-internal deduction,0, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS23872,Extended battery diagnosis-Available extractable charge,11, Ah
IDE10674-ENG98590,Extended battery diagnosis-ERROR,---,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,0,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Actual value,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initialization,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No error recognized,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11740,Ethernet counter connection interruptions: branch 5,0,
IDE11741,Ethernet counter connection interruptions: branch 6,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 19|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|4|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,4,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,94,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|9C 28 BF E0 AA B2|,
IDE11762-IDE02766,Information break recommendation-Malfunction status,Switched off: not installed,
IDE11762-MAS03095,Information break recommendation-Function status,not installed,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,Yes,
IDE11869,IP network: NDP cache,Write only channel,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|44 3C 88 1A E4 25|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,Write only channel,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|F8 38 69 44 FC 6B|,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,No enabling,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Activation,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Activation,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|3|5|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|5|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|3|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,98,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12625,IP network: current link deceleration: branch 1,65535, µs
IDE12626,IP network: current link deceleration: branch 2,65535, µs
IDE12627,IP network: current link deceleration: branch 3,65535, µs
IDE12628,IP network: current link deceleration: branch 4,65535, µs
IDE12629,IP network: current link deceleration: branch 5,65535, µs
IDE12630,IP network: current link deceleration: branch 6,65535, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1, µs
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG255704,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnostic filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnostic filter: status-Mileage recorder,20, km
IDE13754-MAS16867,Diagnostic filter: status-Reason for deactivation,hood open,
IDE13754-MAS16875,Diagnostic filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00143433*2026-06-30-20:21:10*1*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00143433*2026-06-30-20:21:10*1*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00143433*2026-06-30-18:20:12*1*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00143433*2026-06-30-00:54:59*1*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00143433*2026-06-29-20:46:47*1*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,TMBAJ7NXXNY096941,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.0, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.5, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,20.0, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.0, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,65532,
IDE14151-MAS17930,Route-based range calculation-Range from destination,65532,
IDE14151-MAS17931,Route-based range calculation-Route-based range,65532,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,Malfunction,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,124,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,150,
IDE14260-ENG255502,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,3,
IDE14260-ENG255503,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 2F 4E 2C 42 49 6D 2B,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,not active,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
MAS00464-MAS00106,Standard - ambient data 1-Year,2099,
MAS00464-MAS00107,Standard - ambient data 1-Month,5,
MAS00464-MAS00108,Standard - ambient data 1-Day,28,
MAS00464-MAS00109,Standard - ambient data 1-Hours,24,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,41,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,5,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,241,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,143433, km
MAS00769-IDE02717,Multi-function steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multi-function steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multi-function steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multi-function steering wheel control module-Brand,Skoda,
MAS00769-MAS01288,Multi-function steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multi-function steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multi-function steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multi-function steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multi-function steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multi-function steering wheel control module-MFL message counter,4,
MAS00769-MAS06030,Multi-function steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multi-function steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multi-function steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,All releases are present,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,25, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS05129,Engine running status-Motor,Engine off,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,not active,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 1D
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|81|0|0|0|0|0|82|82|0|0|0|0|0|0|83|83|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
MAS16744-IDE01836,12-volt battery-Battery current,-21.956, A
MAS16744-IDE01837,12-volt battery-Temperature of battery sensor,30, °C
MAS16744-IDE01838,12-volt battery-Battery temperature,30, °C
MAS16744-IDE01839,12-volt battery-Battery charge status,96, %
MAS16744-IDE01841,12-volt battery-Battery internal resistance,3.8, mOhm
MAS16744-IDE01842,12-volt battery-Usable battery charge,78, Ah
MAS16744-IDE01948,12-volt battery-Battery internal resistance not normed,3.8, mOhm
MAS16744-IDE04186,12-volt battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12-volt battery-adapted battery capacity,116, Ah
MAS16744-MAS00362,12-volt battery-Battery voltage,12.463, V
MAS16744-MAS06086,12-volt battery-Total re-charge,12357.7, Ah
MAS16744-MAS06087,12-volt battery-Entire energy throughput,12044.6, Ah
MAS16744-MAS22232,12-volt battery-Battery aging: charge-related,89, %
MAS16744-MAS22233,12-volt battery-Battery aging: performance-related,93, %
MAS16744,12-volt battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge status,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.7, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-0.123, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Not available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,invalid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 01 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,Available,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition not met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition not met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,24,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,00,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,Available,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,00 00 00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,69 9B 22 45,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Incomplete transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,2026-07-03T10:43:59Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2026-07-03T08:52:21Z,
ENG254617-ENG299125,DoIP_Status-DoIP_Status_ECU,|Node_address,number_tcp_connections_ecu
ENG254617-ENG280661,DoIP_Status-number_of_total_ecu,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognised,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognised,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,12,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,not active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG137077-ENG255696,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG254621-ENG255502,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,3,
ENG254621-ENG255503,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG254621-ENG255504,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG254621-ENG255545,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG254621-ENG255551,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,150,
ENG254621-ENG255553,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,124,
ENG254621-ENG255557,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,-21.959, A
ENG254621-ENG255558,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG254621-ENG255559,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG254621-ENG256044,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,952, A
ENG254621-ENG256064,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,9.90,
ENG254621-ENG256101,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG254621-ENG256097,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG254621-ENG256098,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG254621-ENG256099,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG254621-ENG256100,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG254621-ENG256270,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG254621-ENG256620,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,12.461, V
ENG254622-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG254622-MAS21179,Energy_management_dashboard_display-Energy generator reports,1,
ENG254622-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG254622-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG299130,Gateway app. software identification-Gateway_applikation_software_identifikation,|nf_name,SW_VERSION|routing_gateway
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG254725-ENG256045,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG254725-ENG152043,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG254725-ENG255205,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG254727-ENG152029,HV-EM_energy_specification-High_voltage_battery_energy_information,102350,
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,102300, Wh
ENG254727-ENG152039,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG254728-ENG152030,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG254728-ENG152033,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG152037,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,12700, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,0, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,OFF,
ENG254730-ENG152028,HV-EM_operation_limitation-High_voltage_battery_current_limitation,0, A
ENG254730-ENG255206,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,127.0, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,No enabling,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,0, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG254777,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0)
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG151186,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG151187-ENG256301,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188,MV-EM_48V_overvoltage_check,---,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,0.0, A
ENG151192,MV-EM_dc_power_desired,0, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,0, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
ENG254783-ENG246261,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG254783-ENG274259,NVEM_12V_Rekuperation-Batterie_Ladezustand,0,
ENG254783-ENG274260,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG254783-ENG274261,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG254783-ENG274262,NVEM_12V_Rekuperation-Batterie_Temperatur,1,
ENG254783-ENG255379,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG254783-ENG255380,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG254783-ENG255700,NVEM_12V_Rekuperation-Energienetz,1,
ENG254783-ENG255703,NVEM_12V_Rekuperation-Entnehmbare_Ladung,1,
ENG254783-ENG255737,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG254783-ENG255738,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG254783-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG254783-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG254783-ENG252593,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG254783-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,1,
ENG254783-ENG256076,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,Neutral,
ENG254783-ENG256106,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG254783-ENG255165,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG254783-ENG256273,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG254783-ENG256306,NVEM_12V_Rekuperation-Saeureschichtung,1,
ENG254783-ENG101873,NVEM_12V_Rekuperation-Sonderveto,1,
ENG254783-ENG256364,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG254783-ENG256365,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG254783-ENG256366,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG254783-ENG256367,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG254783-ENG256368,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG254783-ENG256369,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG254783-ENG256399,NVEM_12V_Rekuperation-Status_Rekuperation,not active,
ENG254783-ENG256400,NVEM_12V_Rekuperation-Status_Stromregelung,not active,
ENG254784-ENG255286,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG254784-ENG255298,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG254784-ENG255179,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG254784-ENG255754,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG254784-ENG256398,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG254784-ENG256720,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG250370,NVEM_Grund_BEM_falsch_codiert,0,
ENG254786-ENG255308,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG254786-ENG255209,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,1,
ENG254787-ENG255299,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG254787-ENG255300,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG254787-ENG255779,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG254787-ENG255780,NVEM_HLR_Master-Heizleistungskontingent_Stufe,not active,
ENG254788-ENG255369,NVEM_Zustand_HLR-BA2_ZuendungEin,1,
ENG254788-ENG255370,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG254788-ENG256423,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG254788-ENG256424,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG254788-ENG256425,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG254788-ENG256426,NVEM_Zustand_HLR-TabE_Crash,0,
ENG254788-ENG256427,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG254788-ENG256428,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG254788-ENG256429,NVEM_Zustand_HLR-TabNQ,0,
ENG280376,Reason_nvem_vehicle_electrical_system_state_diagnosis,0,
ENG280381-ENG280515,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_emergency_strategy,0,
ENG280381-ENG280516,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_failure_warning,not active,
ENG280381-ENG280517,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operating_quadrant,Standard mode,
ENG280381-ENG280518,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operational_restriction,not active,
ENG280381-ENG280519,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_service_information,OK,
Elapsed Time: 00:53
Amedeo
Romania - Rm.Valcea
C?ID=14228
blockmap-23-5WA-909-059-Q_TMBAJ7NXXNY096941-20260703-1358.CSV
;SW:5WA-909-059-Q   HW:3Q0-909-059-C ---  23: Brake Booster
;Component:EBKV          H09 0309, Coding:1002C100230000CE39E79C73000049922449922400
;EV_BrakeBoostG2BoschVW37W,016028,EV_BrakeBoostG2BoschVW37W_016_VW38.rod
;Friday,03,July,2026,13:58:52:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: DEEE74A950B5FB3A04E-808A SFD {x}
Group,Description,Actual
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,28.000, km/h
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.90000, bar
IDE05816-IDE09696,Input signals from data bus-Charisma driving program: CAN output value,No program,
IDE05816-MAS01078,Input signals from data bus-Vehicle model,Combustion engine,
IDE05816-MAS02357,Input signals from data bus-Vehicle identification,00 39 36 39 34 31,
IDE05816-MAS08111,Input signals from data bus-OBD std.,EOBD,
IDE05816-MAS19863,Input signals from data bus-Status of parking brake: electromechanical,Bremse_geschl_(Spannkraft_voll/reduziert),
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08588-IDE00020,Sensor signals for electromechanical power brake-Terminal 15 status,Terminal 15 on,
IDE08588-IDE00102,Sensor signals for electromechanical power brake-Control Module temperature,32.0, °C
IDE08588-IDE02222,Sensor signals for electromechanical power brake-Driver brakes: qualification,OFF,
IDE08588-IDE02713,Sensor signals for electromechanical power brake-Brake lamp switch,OFF,
IDE08588-IDE02714,Sensor signals for electromechanical power brake-Brake test switch,On,
IDE08588-IDE11037,Sensor signals for electromechanical power brake-Brake light switch: qualification,On,
IDE08588-MAS00043,Sensor signals for electromechanical power brake-Terminal 30 power supply,12.2, V
IDE08588-MAS05192,Sensor signals for electromechanical power brake-Driver braking,OFF,
IDE08588-MAS06928,Sensor signals for electromechanical power brake-Supply voltage pedal travel sensor,4.9, V
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,0.0449218750, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.00000, Nm
IDE08588-MAS11639,Sensor signals for electromechanical power brake-Input rod travel,0.000000, mm
IDE08588-MAS18095,Sensor signals for electromechanical power brake-Output rod,0.000000, mm
IDE08588-MAS18096,Sensor signals for electromechanical power brake-Brake pedal travel,Initialization,
IDE08588-MAS18097,Sensor signals for electromechanical power brake-Brake test switch: qualification,On,
IDE08588-MAS18098,Sensor signals for electromechanical power brake-Driver brakes clearly,OFF,
IDE08623-MAS02163,OBD configuration-coded,EOBD,
IDE08623-MAS08097,OBD configuration-Status: OBD lamp,OFF,
IDE08623-MAS14472,OBD configuration-calculated,EOBD,
IDE08623-MAS19862,OBD configuration-Status of generic scan tool,OFF,
IDE10300,OBD Driving Cycle detected,not active,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00000, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00000000000, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,Open,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.0000000, mm
IDE14229-MAS18099,Brake booster control status-Control mode,No activation,
IDE14229-MAS18101,Brake booster control status-Actuator Position,0.03905, mm
IDE14229-MAS18102,Brake booster control status-Actuator torque,0.00000, Nm
IDE14229-MAS18103,Brake booster control status-Actuator speed,0.00781, mm/s
IDE14229-MAS18104,Brake booster control status-Remaining hold time,0, s
IDE14696-MAS03458,Leak test-Differential pressure,0.0000, bar
IDE14696-MAS19863,Leak test-Status of parking brake: electromechanical,Open,
IDE14696-MAS19864,Leak test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leak test-Brake pressure 2,0, bar
IDE80221-ENG252453,Analysis 221-Driver On Pedal,false,
IDE80221-ENG252454,Analysis 221-iBooster Ready for Actuation,OFF,
IDE80221-ENG252457,Analysis 221-iBooster System Mode,ready,
IDE80221-ENG252455,Analysis 221-Pedal Apply Recognition HW Output,false,
IDE80221-ENG252458,Analysis 221-Thermal Limitation,not_active,
IDE80221-ENG252452,Analysis 221-Wakeup Information HW,On,
IDE80221-ENG252456,Analysis 221-Wakeup Information NET,On,
IDE80222,Analysis 222,01 EF 5F,
IDE80223,Analysis 223,1.7578125, mm/s
IDE80223,Analysis 223,0.0000000, mm
IDE80223,Analysis 223,102.8750000, mm/s
IDE80223,Analysis 223,0.00000000000, Nm
IDE80223,Analysis 223,40.7421875, mm
IDE80223,Analysis 223,1.78027343750, Nm
IDE80225,Analysis 225,12,
IDE80225,Analysis 225,1,
IDE80225,Analysis 225,not active,
IDE80226-ENG249302,Analysis 226-Umgesetztes Charisma-Fahrprogramm_Wert,0,
MAS10409-MAS00106,Time stamp-Year,2026,
MAS10409-MAS00107,Time stamp-Month,6,
MAS10409-MAS00108,Time stamp-Day,30,
MAS10409-MAS00109,Time stamp-Hours,20,
MAS10409-MAS00110,Time stamp-Minutes,36,
MAS10409-MAS00111,Time stamp-Seconds,3,
Elapsed Time: 00:02
blockmap-2B-2Q0-905-861-B_TMBAJ7NXXNY096941-20260703-1359.CSV
;SW:2Q0-905-861-B   HW:2Q0-905-861-B ---  2B: Steer. Col. Lock
;Component:ELV-MQBB      H09 0040, Coding:8800000000000000
;EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW38.rod
;Friday,03,July,2026,13:59:06:12012
;VCID: B236F01974AD0F5A906-80E6
IDE00019,Voltage terminal 30,12.1,
IDE00021,Engine speed,0.00, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-outdated,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,6816,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,17,
MAS00464-ENG279797,Standard - ambient data 1-time indication,00,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
ENG128822-ENG255750,functional_check-Functional_Check_VW_EOL,Confirmed,
Elapsed Time: 00:04
blockmap-42-5Q4-959-593-P_TMBAJ7NXXNY096941-20260703-1359.CSV
;SW:5Q4-959-593-P   HW:5Q4-959-593-P ---  42: Door Elect, Driver
;Component:TSG FS        011 0912, Coding:001C0120D000020000001120
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW27.rod
;Friday,03,July,2026,13:59:19:12012
;VCID: D2F69099146D2F5AB06-8086
IDE00310,Outside temperature,28.00, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,reachable,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,not reachable,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Left rear door control module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,12.10, V
IDE02262,synchronous mirror adjustment,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,12.20, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating State,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-installed,not installed,
IDE04540,Mirror adjustment (X/Y direction),Center position,
IDE04580,Dimming of inside door handle lighting,0, %
IDE04581,Dimming for interior ambient lighting,Not available,
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator lamp in button,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,not installed,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,16, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator lamp in button,not coded / not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded / not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,11.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle state,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,not active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Idle state,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,7A22,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,21.00, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,50.00, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,16.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,11.00, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,14.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,10.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,0.00, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07405-MAS02447,Enable driver front window regulator relay-Activation,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Activation,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,38, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,Not available,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatic dimming outside mirror-Status,not installed,
IDE10164-MAS03691,Automatic dimming outside mirror-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE15336,Light output 1 pin D8 target brightness on front driver side,Not available,
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,Not available,
IDE15339,Light output 4 pin D16 target brightness on front driver side,0, %
IDE15636,Light output 2 pin D3 target brightness on front driver side,100, %
IDE16389-MAS25781,Front ambient Lighting configuration - light output 1-Malfunction location,Unknown (255)
IDE16390-MAS25781,Front ambient Lighting configuration - light output 2-Malfunction location,Unknown (255)
IDE16391-MAS25781,Front ambient Lighting configuration - light output 3-Malfunction location,Unknown (255)
IDE16392-MAS25781,Front ambient Lighting configuration - light output 4-Malfunction location,Unknown (255)
MAS01872,Rear lid remote release button,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,Not available,
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:09
blockmap-44-5WA-907-144-G_TMBAJ7NXXNY096941-20260703-1359.CSV
;SW:5WA-907-144-G   HW:5WA-907-144-C ---  44: Steering Assist
;Component:BASGEN1MQB37  102 1040, Coding:0000000000000000000002010100010000000101000101
;EV_SteerAssisBASGEN1MQB37,007046,EV_SteerAssisBASGEN1MQB37_007.rod
;Friday,03,July,2026,13:59:42:12012
;VCID: CDCC83E50D5370A2ED4-8098
IDE00019,Voltage terminal 30,12.25, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,0,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Not blocked,
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,0,
IDE02202,End stage temperature,30, °C
IDE02955,System status,Ready for busstat,
IDE03682-IDE04457,motor position sensor-Speed of electric drive motor,-18000.1, /min
IDE03682-MAS02961,motor position sensor-Engine angle,1, °
IDE03735,Steering torque,0.0, Nm
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,0, %
IDE04448,Steering angle sensor: angle,1.00001, °
IDE04454,Steering angle sensor: angle speed,0, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,161.2, mm
IDE04459,Steering angle sensor: offset index mark mechanical middle,235, mm
IDE04460,Steering angle sensor: offset straight line running,1.3, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not recognised,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not recognised,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not recognised,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognised,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,not recognised,
IDE05155,Power steering current consumption,6253.5, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,80.86, mm
IDE05162-MAS11514,Software end stop-End stop right,-80.34, mm
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,not performed,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,not performed,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,No,
IDE05713-MAS06528,Network diagnosis-Release status,No,
IDE07543,Vehicle speed,0, km/h
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,no restriction,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11602-IDE11629,Result of steering angle sensor: initialization-Status of the active routine,Finish routine: routine OK,
IDE11602-MAS05584,Result of steering angle sensor: initialization-Result,Preconditions met,
IDE11602-MAS14036,Result of steering angle sensor: initialization-Number of iterations,2,
IDE11602-MAS14037,Result of steering angle sensor: initialization-RESTRICTION,no restriction,
IDE11602-MAS14038,Result of steering angle sensor: initialization-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,no restriction,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Preconditions met,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,no restriction,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Preconditions met,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,2,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,no restriction,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,0.0, %
IDE11865-IDE00021,Reason for engagement steering support-Engine speed,not met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,Met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08112,Reason for engagement steering support-Drive readiness,not met,
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,invalid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
MAS08112,Drive readiness,not active,
ENG157712,Current_gradient_limiting,11.9, %
ENG157713,Current_limiting,6553.5, %
Elapsed Time: 00:07
blockmap-52-5Q4-959-592-P_TMBAJ7NXXNY096941-20260703-1400.CSV
;SW:5Q4-959-592-P   HW:5Q4-959-592-P ---  52: Door Elect, Pass.
;Component:TSG BFS       011 0912, Coding:001C0120D000020000001120
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW27.rod
;Friday,03,July,2026,14:00:00:12012
;VCID: D1F49F95116B544289C-8084
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Right rear door control module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,12.10, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,12.10, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05726,Dimmer terminal 58xd,17, %
IDE05727-IDE04213,Front passenger side door status-Central locking button,not installed,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Top position,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Top position,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,7A22,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,19.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,22.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,40.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,70.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,73.00, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Activation,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Activation,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,38, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,Not available,
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,0.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE15340,Light output 1 pin D8 target brightness on front passenger side,Not available,
IDE15341,Light output 2 pin D3 target brightness on front passenger side,100, %
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,Not available,
IDE15343,Light output 4 pin D16 target brightness on front passenger side,0, %
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:08
blockmap-6C-5WA-980-556-D_TMBAJ7NXXNY096941-20260703-1400.CSV
;SW:5WA-980-556-D   HW:5WA-980-556-B ---  6C: Back-up Cam.
;Component:RV eCompact   H30 0344, Coding:03033260843000
;EV_CamSysRVCCompaFicos,010024,EV_CamSysRVCCompaFicos_010_VW38.rod
;Friday,03,July,2026,14:00:24:12012
IDE00019,Voltage terminal 30,12.21, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,not recognised,
IDE00924-IDE08941,Steering angle-Rack position,0.00,
IDE00924-MAS02471,Steering angle-Sign,Positive,
IDE00924-MAS02983,Steering angle-Steering wheel angle,1.6,
IDE00924,Steering angle,0.0625,
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.00,
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE06449-MAS05746,Camera system calibration-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Camera system calibration-Rearview camera calibration progress,0, %
IDE06449-MAS05750,Camera system calibration-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Camera system calibration-Cause of rearview camera calibration error,calibrated,
IDE06449-MAS05803,Camera system calibration-Rearview camera calibration resumption,No resumption,
IDE07402-MAS10858,External activation-Rear camera,not active,
IDE10589-MAS10858,Temperature of the camera-Rear camera,54, °C
IDE10740-IDE03619,System state area view-System condition,active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780-MAS11932,Ethernet counter connection interruptions-Counter open circuit,0, dB
IDE10781-MAS11933,Ethernet counter checksum malfunction-Counter CRC error,0, dB
IDE11010-MAS00106,Rear camera: calibration time-Year,2000, yr
IDE11010-MAS00107,Rear camera: calibration time-Month,0, Months
IDE11010-MAS00108,Rear camera: calibration time-Day,0, d
IDE11010-MAS00109,Rear camera: calibration time-Hours,0, H
IDE11010-MAS00110,Rear camera: calibration time-Minutes,0, min
IDE11010-MAS00111,Rear camera: calibration time-Seconds,0, s
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1e+007,
IDE13845,Production mode status,No function restriction,
MAS02356-MAS10858,Type of calibration-Rear camera,TopView: calibration with calibration panel,
Elapsed Time: 00:05
blockmap-75-5WA-035-284-J_TMBAJ7NXXNY096941-20260703-1400.CSV
;SW:5WA-035-284-J   HW:5WA-035-284-C ---  75: Telematics
;Component:OCU3HMQB37W   H12 0311, Coding:033810109069A8A09005460061052607
;EV_OCU3HMQB37W,002029,EV_OCU3HMQB37W_002_VW38.rod
;Friday,03,July,2026,14:00:37:12012
;VCID: CDCC83E50D5370A2ED4-8098 SFD {x}
IDE00019,Voltage terminal 30,12.2, V
IDE00102,Control Module temperature,43, °C
IDE00608,Fuel type,Diesel,
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE00767,No. of unscheduled ECU resets,2,
IDE01215,Dimmer terminal 58d,44.86, %
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Direction of travel,128, °
IDE01588-MAS01632,Direction of travel-Status,Available,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS02230,GPS Position-Height,226, m
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: altitude of position unknown,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,3,
IDE01718,Crash signal,Not available,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01971,Lowest recorded control module temperature,-9, °C
IDE01972,Highest recorded control module temperature,73, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,10, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,28,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,32,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,30, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,34, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE03477-MAS00106,GPS time-Year,2026,
IDE03477-MAS00107,GPS time-Month,7,
IDE03477-MAS00108,GPS time-Day,3,
IDE03477-MAS00109,GPS time-Hours,11,
IDE03477-MAS00110,GPS time-Minutes,0,
IDE03477-MAS00111,GPS time-Seconds,41,
IDE03477-MAS01632,GPS time-Status,valid,
IDE04293,Operating state for emer call module,registerstate_roaming,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,901280066684571,
IDE04750-MAS04226,SIM card-Telephone number,               ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89882390000375295113,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000007695717237,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,356991929527901,
IDE05431-MAS01167,Lock for high-voltage charging connector-Actuation time,0 s,
IDE05431-ENG170421,Lock for high-voltage charging connector-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,Air conditioning/heating function via remote control-Actuation time,0 s,
IDE07007-ENG170421,Air conditioning/heating function via remote control-IoReached Status,Output diagnostic test not active,
IDE07589-IDE07590,Update programming: status-Currently processed module,1,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2000,
IDE07589-MAS00107,Update programming: status-Month,0,
IDE07589-MAS00108,Update programming: status-Day,0,
IDE07589-MAS00109,Update programming: status-Hours,0,
IDE07589-MAS00110,Update programming: status-Minutes,0,
IDE07589-MAS00111,Update programming: status-Seconds,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Others,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charging function of high-voltage battery-Actuation time,0 s,
IDE07975-ENG170421,Remote control for charging function of high-voltage battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG170421,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 A3 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,B0 CD F2 D4,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,8, %
IDE09602-MAS01167,Locale hazard warning-Actuation time,0 s,
IDE09602-ENG170421,Locale hazard warning-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge status,96, %
IDE11307-MAS08415,eCall battery status-Battery condition,normal,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|7|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,65535,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|F8 38 69 44 FC 6B|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|9C 28 BF E0 AA B2|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|4|7|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,65535,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Speaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Speaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,TMBAJ7NXXNY096941,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 02,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,17,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2026, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,6, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,6, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,0, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,3, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,58, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,3,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2026, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),6, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),8, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),14, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),25, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),49, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,activated,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2032, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,7, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,29, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
IDE14344-MAS18506,Automotive audio bus (A2B): status-Node name,Microphone module in roof,
IDE14344-MAS18507,Automotive audio bus (A2B): status-Node number,0,
IDE14344-MAS18509,Automotive audio bus (A2B): status-Node status,electrically OK,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 00 00 00 00 00 00 00,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,1,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2F,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15695,Front radar-based localization,not active,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,A3,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,38,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,6,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,241,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,143433, km
MAS01490-MAS08403,Energy management-Remaining short term energy budget,921, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,2345,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,226,
MAS04394-IDE07699,Connection status-Mobile network operator,1,
MAS04394-MAS03991,Connection status-Reception level antenna 1,8, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,236362499,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG170421,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS10430,Indicator light for emerg. call,Faulty function,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,Support from metadata version 0x10,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 19,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,Group attribute set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18223-ENG299118,History of sent driver assistance data-beginn array,|ID,Number|0
MAS18223-ENG104031,History of sent driver assistance data-Number,0,
MAS18224-ENG299118,History of causes for sent driver assistance data-beginn array,|ID,Number|0
MAS18224-ENG104031,History of causes for sent driver assistance data-Number,0,
MAS18225-ENG98987,Transmission delay for driver assistance data-Time,0, ms
MAS18226-MAS01167,Sending the driver assistance data-Actuation time,0 s,
MAS18226-ENG170421,Sending the driver assistance data-IoReached Status,Output diagnostic test not active,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,navigation_v1,
MAS18461-MAS18465,FoD product list-Import regulation,New function,
MAS18461-MAS18471,FoD product list-Product regulation,Individual purchase,
MAS18461-MAS18474,FoD product list-Change information regulation,No change in meta info,
MAS18461-MAS18477,FoD product list-Notification control,No user notification,
MAS18461-MAS18481,FoD product list-Activate regulation,Immediate activation,
MAS18461-MAS18484,FoD product list-Deactivate regulation,not safety-related,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 07 1C 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,6003,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest#              ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
MAS19270,Parameter list,|Parameter ID,Data description
MAS19273,Shadow drive metadata,|User ID,Year
MAS19295,Historical memory for synchronization,|Year,Month
MAS19313,BAP historical memory,|Year,Month
MAS19326,CAN signals for OCU customization,|Year,Month
ENG123206,Antenna_Switch,LTE antenna 1,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG187669,Authentic_time_last_client_response-Current_time_used,2026-07-03T10:43:59Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2026-07-03T08:52:21Z,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,79.620,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,2655, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,80,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,81,
ENG247784-ENG118139,Hazard_Information-function_state,State_0,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,10.158.1.131I,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,11568,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,12854,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,Malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4100, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,12848,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,Malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,14898,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,Malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,73,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,12592,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,13114,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,14900,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,13625,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,11568,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,13105,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,13140,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,37938,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,12634,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,23040, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,Malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,774975025, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,0,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,774976824, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,Malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,36, m
ENG247810-ENG248070,REM_Available_Transmission_Buffer-Buffer,0, KByte
ENG247811-ENG98502,REM_Development_Interface-Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 18 03 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247822-ENG159329,Third_Last_Position-Latitude, 45° 1'47.5"N,
ENG247822-ENG159328,Third_Last_Position-Longitude, 24°17'38.2"E ,
ENG254851-MAS01779,VTT_First_GPS_fix-Length,---           ,
ENG254851-MAS01780,VTT_First_GPS_fix-Width,---           ,
ENG254851-MAS02230,VTT_First_GPS_fix-Height,65034, m
Elapsed Time: 01:26
blockmap-A5-5WA-980-653-C_TMBAJ7NXXNY096941-20260703-1402.CSV
;SW:5WA-980-653-C   HW:5WA-980-653 ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H09 3302, Coding:0002088821484040509E00001020002001018000000000000000000000000000
;EV_MFK3ValeoMQB,005050,EV_MFK3ValeoMQB_005_SK38.rod
;Friday,03,July,2026,14:02:44:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: CFF099ED075F42B29F8-809A
Group,Description,Actual
IDE00018,Voltage terminal 15,12.3, V
IDE00767,No. of unscheduled ECU resets,1,
IDE00973,Outside temperature,28.0, °C
IDE01968,Dynamic calibration: yaw angle offset,-0.079, °
IDE01969,Dynamic calibration: pitch angle offset,-0.316, °
IDE01970,Dynamic calibration: roll angle offset,0.515, °
IDE01971,Lowest recorded control module temperature,-11, °C
IDE01972,Highest recorded control module temperature,82, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,0 s,
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Output diagnostic test not active,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,0 s,
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Output diagnostic test not active,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02486,Data logger triggering,not initialized,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,0 s,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Output diagnostic test not active,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,52874, km
IDE03948-MAS01167,High beam recommendation-Actuation time,0 s,
IDE03948-MAS08863,High beam recommendation-Status of actuator test,Output diagnostic test not active,
IDE04036-MAS01632,High beam assistant: status-Status,not active,
IDE04036-MAS17492,High beam assistant: status-Switching state,OFF,
IDE04036-MAS17493,High beam assistant: status-Sensor view,Not assigned,
IDE04036-MAS17494,High beam assistant: status-Higher sensitivity active,No,
IDE04123-MAS01480,High beam: reason for shut-off-excessive temperature,No,
IDE04123-MAS06833,High beam: reason for shut-off-Ambient brightness too high,No,
IDE04123-MAS06846,High beam: reason for shut-off-Location detected,No,
IDE04123-MAS14875,High beam: reason for shut-off-Fog detected,No,
IDE04123-MAS17489,High beam: reason for shut-off-Oncoming vehicle detected,No,
IDE04123-MAS17490,High beam: reason for shut-off-Vehicle ahead detected,No,
IDE04123-MAS17491,High beam: reason for shut-off-Speed not achieved,Yes,
IDE04123,High beam: reason for shut-off,4,
IDE04123,High beam: reason for shut-off,0,
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,Lane assist deactivated in steering,
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.00, Nm
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,0 s,
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Output diagnostic test not active,
IDE06592-MAS00478,Status: special functions-Reserved,00,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,used,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07214,Dynamic calibration: camera height offset,-19, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,1023, m
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,1023, m
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,25.650001, °
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,25.650001, °
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,35.150001, °
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,35.150001, °
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,51.15, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,51.15, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Right hand driv.,
IDE09492-MAS11790,Temperatures-Control Module temperature,48, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,52, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,51, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0,
IDE10406-MAS00106,Last initial calibrations: details-Year,2022,
IDE10406-MAS00107,Last initial calibrations: details-Month,5,
IDE10406-MAS00108,Last initial calibrations: details-Day,3,
IDE10406-MAS00109,Last initial calibrations: details-Hours,6,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,19,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,56,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2022,
IDE10664-MAS00107,Current initial calibration: details-Month,5,
IDE10664-MAS00108,Current initial calibration: details-Day,3,
IDE10664-MAS00109,Current initial calibration: details-Hours,6,
IDE10664-MAS00110,Current initial calibration: details-Minutes,19,
IDE10664-MAS00111,Current initial calibration: details-Seconds,56,
IDE10664-MAS00711,Current initial calibration: details-kilometer reading,4,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,TMBAJ7NXXNY096941,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE10780,Ethernet counter connection interruptions,2,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,1.013, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,-0.570, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,0.051, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1339, mm
IDE11752-ENG277500,IP network: IPv6-addresses-Ip_ipv6_addresses_list,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|, hex
IDE11753-ENG277501,IP network: IPv6-multicast-addresses-Ip_ipv6_multicast_addresses_list,|IPv6 Multicast address|FF 14 00 00 00 0B|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11755-ENG277505,IP network: VLANs-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,256,
IDE11761-ENG277502,IP network: MAC addresses-Ip_mac_addresses_list,|MAC address|74 90 50 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11869-ENG277503,IP network: NDP cache-Ip_ndp_cache_list,|MAC address,IPv6 address
IDE11988-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 1-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|74 90 50 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11989-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 2-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11990-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 3-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11991-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 4-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11992-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 5-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11993-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 6-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11994-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 7-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11995-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 8-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE12230-ENG277505,IP network: VLANs of Ethernet switch ports branch 1-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE12231-ENG277505,IP network: VLANs of Ethernet switch ports branch 2-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-ENG277505,IP network: VLANs of Ethernet switch ports branch 3-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12233-ENG277505,IP network: VLANs of Ethernet switch ports branch 4-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12234-ENG277505,IP network: VLANs of Ethernet switch ports branch 5-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12235-ENG277505,IP network: VLANs of Ethernet switch ports branch 6-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12236-ENG277505,IP network: VLANs of Ethernet switch ports branch 7-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12237-ENG277505,IP network: VLANs of Ethernet switch ports branch 8-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12239-ENG277504,IP network: test feedback value of communications relationships-Ip_return_value_test_communication_connection,|IPv6 address,Result|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12626,IP network: current link deceleration: branch 2,0, µs
IDE12627,IP network: current link deceleration: branch 3,0, µs
IDE12628,IP network: current link deceleration: branch 4,0, µs
IDE12629,IP network: current link deceleration: branch 5,0, µs
IDE12630,IP network: current link deceleration: branch 6,0, µs
IDE12631,IP network: current link deceleration: branch 7,0, µs
IDE12632,IP network: current link deceleration: branch 8,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,Not available,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,643.08, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,538.11, px
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1453.57, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1453.57, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.000468891,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.000363679,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.000638848,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.00,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2400.00, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,742.50, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1697.00, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2400.00, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-742.50, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1697.00, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2400.00, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,742.50, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,1103.00, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2400.00, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-742.50, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,1103.00, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,2.6, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,3.9, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,716.50, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,715.75, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,722.75, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,719.50, mm
IDE13998,Distance to calibration field: stored values,1500.00, mm
IDE14000,Windshield defogger camera: activation status,OFF,
MAS01634-MAS09193,Supply voltage-PLA,12.3, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,1.0, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.0, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.7, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,3.2, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,4.1, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17473,Functional state and lane boundary information,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 0E 0F 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS19593-MAS01167,Upload for expanded static navigation data activation-Actuation time,0 s,
MAS19593-MAS08863,Upload for expanded static navigation data activation-Status of actuator test,Output diagnostic test not active,
MAS19594-MAS01167,Upload for expanded dynamic navigation data activation-Actuation time,0 s,
MAS19594-MAS08863,Upload for expanded dynamic navigation data activation-Status of actuator test,Output diagnostic test not active,
ENG152732-MAS06854,CRC32 Checksum of FAZIT Identification String-Version,81,
ENG152732-MAS06855,CRC32 Checksum of FAZIT Identification String-Test sum,5E 57 00 13,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,2,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902-ENG247044,Function_On_Demand_Freischalt_ID_Status_Dev-Function_On_Demand_Freischalt_ID_Status,|Authentication,Functions
ENG106922,Immobilizer - Challenge,6A 68 7C F7,
ENG185847-MAS01167,Light_assist_blockage_detection-Actuation time,0 s,
ENG185847-MAS08863,Light_assist_blockage_detection-Status of actuator test,Output diagnostic test not active,
ENG185858-MAS01167,Light_assist_self_glare_detection-Actuation time,0 s,
ENG185858-MAS08863,Light_assist_self_glare_detection-Status of actuator test,Output diagnostic test not active,
ENG185848-MAS01167,Main_beam_defect_message-Actuation time,0 s,
ENG185848-MAS08863,Main_beam_defect_message-Status of actuator test,Output diagnostic test not active,
ENG251654-MAS01167,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251654-MAS08863,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Status of actuator test,Output diagnostic test not active,
ENG251655-MAS01167,REM_Static_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251655-MAS08863,REM_Static_EyeQ_Data_Test_Trigger_status-Status of actuator test,Output diagnostic test not active,
ENG185865-MAS01167,SAE_mode_activation-Actuation time,0 s,
ENG185865-MAS08863,SAE_mode_activation-Status of actuator test,Output diagnostic test not active,
Elapsed Time: 00:47
blockmap-811E-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1403.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  811E: Burglary Protection FL
;Component:Kessy RSAD    070 0636, Coding:
;EV_RSADVL37w,002013,EV_RSADVL37w_002_VW38.rod
;Friday,03,July,2026,14:03:45:12012
;VCID: C7C0B1CDEF2F9AF2D78-8092
IDE00019,Voltage terminal 30,12215, mV
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.2, V
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,2,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Power_On_Reset,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Power_On_Reset,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Unexpected_Watchdog_Reset,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Power_On_Reset,
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_front_driver_side,
ENG108452,Reset_counter,38,
Elapsed Time: 00:01
blockmap-811F-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1403.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  811F: Burglary Protection FR
;EV_RSADVR37w,002013,EV_RSADHL37w_002_VW38.rod
;Friday,03,July,2026,14:03:52:12012
IDE00019,Voltage terminal 30,12178, mV
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.1, V
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Power_On_Reset,
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_front_codriver_side,
ENG108452,Reset_counter,37,
Elapsed Time: 00:01
blockmap-8120-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1404.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  8120: Burglary Protection RL
;EV_RSADHL37w,002013,EV_RSADHL37w_002_VW38.rod
;Friday,03,July,2026,14:04:00:12012
IDE00019,Voltage terminal 30,12180, mV
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_rear_driver_side,
Elapsed Time: 00:01
blockmap-8121-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1404.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  8121: Burglary Protection RR
;EV_RSADHR37w,002013,EV_RSADHL37w_002_VW38.rod
;Friday,03,July,2026,14:04:07:12012
IDE00019,Voltage terminal 30,12159, mV
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_rear_codriver_side,
Elapsed Time: 00:01
blockmap-OBD_TMBAJ7NXXNY096941-20260703-1404.CSV
;33-OBD2
;Friday,03,July,2026,14:04:21:12012
;VCID: D5FC6B852C033862554-8080
04,Calculated load value,0.0 %,0.0 %
05,Engine coolant temperature,28 °C,28 °C
0C,Engine RPM,0 /min,0 /min
0D,Vehicle speed,0 km/h,0 km/h
0F,Intake air temperature,30 °C
10,Mass Air Flow,0.00 g/s
11,Absolute Throttle Position,13.7 %
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,0 s
21,Distance travelled with MIL on,0 km
2F,Fuel Level Input,63.9 %
30,Warm-ups since DTC cleared,18
31,Distance since DTC cleared,302 km
33,Barometric pressure,98 kPa abs
42,Control module voltage,12.100 V,12.000 V
45,Relative Throttle Position,0.0 %
46,Ambient Air Temp,28 °C
49,Accelerator Pedal Position D,14.1 %,14.1 %
4A,Accelerator Pedal Position E,14.5 %
4C,Commanded Throttle Actuator Control,0.0 %
51,Fuel type,Diesel
5C,Engine Oil Temp,28 °C
5E,Engine Fuel Rate,0.00 L/h
61,Torque Driver's Request,0.0 %
62,Torque actual,0.0 %
63,Torque Reference,360 Nm
65,Auxiliary Input/Output,GEAR_RCMD: N
67,Engine Coolant Temp,ECT 1:28 °C
69,EGR Command/Actual/Error,EGR A:0/0/0 %,EGR B:0/0/0 %
6B,EGR Temperature,EGRTemp 11/12:---/28 °C,EGRTemp 21/22:---/--- °C
6D,Fuel Press. Control A/B,FRP CMD:40000/--- kPa,FRP ACT:1000/--- kPa
70,Boost Press Ctrl A/B,BP_A cmd/act:67.4/98.5 kPa
71,Var. Geom. Turb. Ctrl A/B,VGT_A cmd/act:100.0/12.2 %,VGT_B cmd/act:---/--- %
77,Charge Air Temp.,B1S1/B1S2:29/28 °C
78,EGT B1-S1-4,S1/S2/S3/S4:,33/36/34/33 °C
7A,DPF Bank 1 Delta/In/Out,0.19/---/--- kPa
7F,Engine Run Time,Total:2382H987s,Idle:272H140s
83,NOx Sensor Bank 1/2,NOx11:65535 ppm,NOx21:65535 ppm
85,NOx Control System,ReAg Rate/Demand:0.0/0.00 L/h,Reag Tnk Lvl:62.7 %
8B,Aftertreatment status,PF_Regen:Status:N,Typ:Pass.
8C,O2 sensor wide range,1.001 lbd,7.995 lbd
8E,Eng. friction %torque,16.0 %
8F,PM sensor output,B1S1:ACT:NO;REGN:NO,B1S1:0.00 %
9B,DEF sensor,conc. proper,DEF_CON:  %
9C,O2 sensor wide range,7.995 lbd,7.995 lbd
9D,Fuel rate,Engine: 0.00 g/s,Vehicle: 0.00 g/s
9E,Exhaust flow rate,0.0 kg/h
A2,Cyl. fuel rate,0.00 mg/str
A4,Transm gear,N
A6,Odometer,143433.2 km
Type 02 - VIN : TMBAJ7NXXNY096941 (Address E8)
Type 04 - Calibration ID : 05L022KT1998GFAJNOX00907807 0010NOX00907807 0010NOX00907807 0010PMS00906261 1000 (Address E8)
Type 04 - Calibration ID : 0GC906555K++5080 (Address E9)
Type 06 - Calibration Verification Number : 48D95515 (Address E8)
Type 06 - Calibration Verification Number : 914A6D20 (Address E8)
Type 06 - Calibration Verification Number : 22E7CED8 (Address E8)
Type 06 - Calibration Verification Number : 43FB2DAA (Address E8)
Type 06 - Calibration Verification Number : 8FC55133 (Address E9)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 0B - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 1893
    Ignition cycle count : 6832
         NMHC Catalyst : 510 / 178
         NOx/SCR Catalyst : 2240 / 1893
         NOx Adsorber : 0 / 0
         PM Filter : 1621 / 178
         Exhaust Gas Sensor : 1664 / 1893
         EGR and/or VVT : 2854 / 1893
         Boost Pressure : 6824 / 1893
         Fuel : 3840 / 1893
Type 17 - Vehicle Operation Data - Distance-Fuel Used, Recent/Lifetime:
         Total Distance Traveled : -0.1 km / 143437.0 km
         Total Fuel Consumed : -0.01 L / 6906.11 L
Amedeo
Romania - Rm.Valcea
C?ID=14228
And here are the Adaptation maps for the same vehicle, also captured without SFD unlocked. Posting in 2 parts.
AutoScan: TMBAJ7NXXNY096941
Friday,03,July,2026,11:47:22:12012
VCDS Version: 26.5.2.1 (x64)  HEX-NET2 CB: 0.4713.5
Dealer/Shop Name: AMEDEO 076.074.575
Workshop Code: 599 10203 012134
VIN: TMBAJ7NXXNY096941   License Plate: VL42DNA
Mileage: 143433km-89125mi   Repair Order: Madalin - 0743888459
Chassis Type: NX-SK38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6C 75 A5
          BB BC 811E 811F 8120 8121 C002 C003
VIN: TMBAJ7NXXNY096941   Mileage: 143433km-89125miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DTTC)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 022 KT    HW: 05L 907 309 AA
   Component: R4 2.0l TDI   H80 1998
   Revision: ECH80---    Dataset Number: V03935358XK 0001 CVN: 48D95515914A6D2022E7CED8914A6D2043FB2DAA
   Coding: 012508320364050970080000000000000000000000000000
   Shop #: WSC 31000 790 00270
   ASAM Dataset: EV_ECM20TDI01105L906022KT 007001
   ROD: EV_ECM20TDI01105L906022DE_007_VW38.rod
   VCID: 835865DD9B9776D24B0-80D6
   VINID: 91D4916877A8A1EA4024624404DE3158BC
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1       H13 0110
   Serial number: 20220224060604070152
23765 - Control unit for information electronics 1
          U1054 00 {00101111} - No Communication
          {Information electronics control module 1No Communication}
                    Fault Frequency: 204
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:15:17
                    Engine speed: 813.50 /min
                    Normed load value: 34.1 %
                    Coolant temperature: 94 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.160 V
                    selected gear-Bits 0-7: 0
   Part No SW: 0GC 906 555 K    HW: 0GC 300 047
   Component: GSG DQ381     H06 5080
   CVN: 8FC55133
   ASAM Dataset: EV_TCMDQ381062 001020
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: C3D8A5DDDB17B6D20B0-8096
   Subsystem 1 - Part No SW: 5WA 713 033 BB    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20220309000080744319
   Subsystem 2 - Part No SW: 5E4 713 203     HW: 5E4 713 203
   Component: ZSB_SB_mono    H02 0025
   Serial number: 22 020 0630 L 1 U1B9
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810600003922689
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BL    HW: 5WA 614 517 N
   Component: ESC           H13 0133
   Serial number: 60482000000667  Dataset Number: V03935351BG 0001 CVN: 01B7675E
   Coding: 34072CA422294472528050040AC461866DB658F55AC8670821BCA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 9378559DEBF7E652FB0-80C6 SFD {x}
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 J    HW: 5WA 959 436 J
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935347FV 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: DBE87DBD43A7EE12630-808E
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 AC    HW: 5WA 907 727 AC
   Component: Climatronic   H02 0440
   Serial number: --------------- Dataset Number: V03935336HW 0001
   Coding: 101010010211120000100010101011110000112100100000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005069
   ROD: EV_ACClimaBHBVW38X_SK38.rod
   VCID: 91745F95D1EB1442C9C-80C4
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000000960495
   Interior temperature sensor:
   Subsystem 2 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002140322122123512
459025 - Databus
          U1121 00 {00101111} - Missing Message
          {Databus missing message radio}
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 {01100101} - -
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 20:49:17
                    Voltage terminal 30: 12.60 V
                    Compressor shut-off condition: Engine running time too short: engine start not detected by CAN
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 AE    HW: 5WA 937 086 L
   Component: BCM37w_M028 0175
   Serial number: BXJ53F100422940 Dataset Number: V03935372UU 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_SK38.rod
   VCID: 947A5681EEF9E16AE2A-80C0 SFD {x}
   Subsystem 1 - Part No SW: 5E4 955 119 A    HW: 5E4 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: J400FRWISCH    067 0084
   Serial number: 907453F0402206400688
   Component: G397_RLFSS     H06 0004
   Serial number: 43287277X81A955555B0
   Subsystem 3 - Part No SW: 5E4 941 501 A    HW: 5E4 941 501
   Component: E1-LTM         H30 0550
   Serial number: 00000000000000000241
   Subsystem 4 - Part No SW: 5E3 925 200 F    HW: 5E3 925 200 F
   Component: DiETa          H04 0002
   Serial number: 01557VD2000CS
   Subsystem 5 - Part No SW: 5E3 959 569 A    HW: 5E3 959 569 A
   Component: DACHKONSOLE    101 0104
   Serial number: 000000092413VKG00300
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 EP    HW: 5Q1 953 549 F
   Serial number: 00000024022204400507
   Left taillight 1:
   Subsystem 7 - Part No SW: 5E3 945 207 A    HW: 5E3 945 207 A
   Component: SHL_li1        005 1214
   Serial number: ABMRO128012200041511
   Left taillight 2:
   Subsystem 8 - Part No SW: 5E6 945 307 A    HW: 5E6 945 307 A
   Component: SHL_li2        005 1214
   Serial number: ABMRO111032200041118
   Right taillight 1:
   Subsystem 9 - Part No SW: 5E3 945 208 A    HW: 5E3 945 208 A
   Component: SHL_re1        005 1214
   Serial number: ABMRO121022200042469
   Right taillight 2:
   Subsystem 10 - Part No SW: 5E6 945 308 A    HW: 5E6 945 308 A
   Component: SHL_re2        005 1214
   Serial number: ABMRO110022200051672
   Part No SW: 5WA 919 294 C    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0577
   Serial number: 000006042294560 Dataset Number: V03935348FY 0001
   Coding: 0040010011
   ASAM Dataset: EV_EPHBO18VW3800000 002029
   ROD: EV_EPHBO18VW3800000_AU38.rod
   VCID: D2F69099146D2F5AB06-8086
1114113 - Driver Assistance Systems Audio Output
          B1AE2 F0 {00101111} - Infotainment System; Implausible Signal
          {sound_ouput_MIB_totally_disturbed}
                    Mileage: 143433 km
                    Date: 2026.06.30
                    Time: 18:20:36
13638928 - Databus
          {MIB - MainUnit_01 - kein Signal/keine Kommunikation}
                    Mileage: 143433 km
                    Date: 2026.06.30
                    Time: 18:20:36
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Dataset Number: V03935354QE 0001
   Coding: 0903007D0077404512474000004040C54E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: CDCC83E50D5370A2ED4-8098
1230 - Databus
          {FAULT_TIMEOUT_MAINUNIT_01}
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:58
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 DL    HW: 1EA 959 655 DL
   Component: VW40Airbag    010 0176
   Serial number: W100SkE02D4     Dataset Number: V03935354YD 0001
   Coding: 98CC000000C0C000000000000000000050540000205400004000F68000120065
   Shop #: WSC 31000 074 00352
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_VW41.rod
   VCID: 8E4E44E9C0D50BBAD4E-80DA SFD {x}
   Subsystem 1 - Part No SW: -----------    HW: 440 002 202 22
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ0000002A851BD5F
   Subsystem 2 - Part No SW: -----------    HW: 440 002 202 22
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000F5951BD5P
   Subsystem 3 - Part No SW: -----------    HW: 440 000 104 22
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJAB07487D683500-
   Subsystem 4 - Part No SW: -----------    HW: 440 000 104 22
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJAB081A9E417D000
   Subsystem 5 - Part No SW: -----------    HW: 440 002 707 21
   Component: FrontSensor_D  00A 014A
   Serial number: 355CJ9900ABA0153D00T
   Part No SW: 5E3 920 770 B    HW: 5E3 920 770 B
   Component: KOMBI         201 5370
   Dataset Number: V03935369QW 0001
   Coding: 04A4004063840008018462032000080800301400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003033
   ROD: EV_DashBoardVDDMQB37W_003_SK38.rod
   VCID: A80212714271758A3E2-80FC SFD {x}
16777018 - Control unit for information electronics 1
          U1054 00 {00001001} - No Communication
          {Audio_0x31 communication error bap_error_timeout heartbeat}
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
16777020 - Control unit for information electronics 1
          {TEL_0x28 communication error bap_error_timeout heartbeat}
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
16777022 - Control unit for information electronics 1
          {NAV_SD_0x32 communication error bap_error_timeout heartbeat}
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
   Part No SW: 5WA 907 530 Q    HW: 5WA 907 530 G
   Component: GW2020 High   756 7300
   Revision: --------    Serial number: 260160902151243 Dataset Number: V03935355TE 0001
   Coding: 0000838D0700000000000000010303325301600902000300030100000001010100000000000000000000000000000000
   GVL: 3D0000000208408C80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 005011
   ROD: EV_GatewMQB2020_004_SK38.rod
   VCID: D6FE6C893885337A5CE-8082 SFD {x}
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 1368879305
   Subsystem 3 - Part No SW: 5E3 919 719 Q    HW: 5E3 919 719 Q
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440061091223099
7 Faults Found:
2175091 - Control unit for information electronics 1
          {Information_electronics_control_module_1_no_communication}
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:14:52
1049253 - Ethernet Databus Branch 5
          U1230 00 {00101111} - No Communication
          {Ethernet_databus_no_communication_branch_5_/_port_6}
                    Fault Frequency: 18
                    Mileage: 143129 km
                    Date: 2026.06.06
                    Time: 00:15:30
2498675 - Ethernet Module for Information Electronics 1
          U1645 00 {00101000} - No Communication
          {Information_electronics_control_module_1_no_communication_vlan}
                    Reset counter: 27
                    Mileage: 143181 km
                    Date: 2026.06.07
                    Time: 17:32:18
8397571 - LV Energy Management
          B1802 F1 {00101000} - Warning Triggered
                    Fault Frequency: 39
                    Reset counter: 37
                    Mileage: 143314 km
                    Date: 2026.06.25
                    Time: 18:07:46
                    23
8471553 - Function Restricted due to Missing Message(s)
          U1111 00 {00101000} - -
          {error_communication_Headunit_PaCo}
                    Fault Frequency: 25
                    Mileage: 143145 km
                    Date: 2026.06.06
                    Time: 15:35:41
          B184C 00 {00100000} - -
          {Unlock_protection_of_vehicle_diagnosis_active}
                    Fault Frequency: 0
                    Reset counter: 0
8482819 - Activatable Functions
          B18D3 F3 {01101101} - Faulty Vehicle Configuration
          {Fs_id_configuration_error}
                    Mileage: 143153 km
                    Date: 2026.06.06
                    Time: 19:07:31
   Part No SW: 5WA 909 059 Q    HW: 3Q0 909 059 C
   Component: EBKV          H09 0309
   Serial number: BPA085180222013 Dataset Number: V03935354NE 0001
   Coding: 1002C100230000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: DEEE74A950B5FB3A04E-808A SFD {x}
172400 - System Voltage
          P0562 00 {00100000} - Too Low
          {PSCUnderVoltageLevel1}
1024368 - Brake Booster
          C1187 F6 {00100000} - Function Limitation due to External Brake Pressure Build-Up
          {ActiveRestrictionDetected}
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000098149011 Dataset Number: V03935308NF 0001
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: B236F01974AD0F5A906-80E6
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000459589293  Dataset Number: V03935365VU 0001
   Coding: 001C0120D000020000001120
   Shop #: WSC 31000 790 00352
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000058878969
   Coding: 110200
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1040
   Serial number: 01037468 Dataset Number: V03935362VR 0001
   Coding: 0000000000000000000002010100010000000101000101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000461357778  Dataset Number: V03935365VZ 0001
   VCID: D1F49F95116B544289C-8084
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000058998964
   Coding: 090200
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20050322010 Dataset Number: V03935343SU 0001
   Coding: 03033260843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   Part No SW: 5WA 035 284 J    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H12 0311
   Serial number: 0000000203VITD6 Dataset Number: V03935361QW 0001
   Coding: 033810109069A8A09005460061052607
   ASAM Dataset: EV_OCU3HMQB37W 002029
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: CDCC83E50D5370A2ED4-8098 SFD {x}
7248 - Function Restricted due to Missing Message(s)
          U1111 00 {00001001} - -
          {InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful}
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:59
                    Voltage terminal 30: 12.7 V
9455892 - Mute switch radio
          B1049 14 {00001001} - Open or Short to Ground
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:56
   Part No SW: 5WA 980 653 C    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3302
   Serial number: E82645704221110 Dataset Number: V03935360CJ 0001
   Coding: 0002088821484040509E00001020002001018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_SK38.rod
1122664 - Databus
          U1121 00 {00001001} - Missing Message
          {TIMEOUT_PSD_04}
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
1122626 - Databus
          {Timeout_Mainunit_01}
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.06.29
                    Time: 19:32:53
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:33, VBatt start/end: 12.8V/12.8V)-----------
------------------------------22 Faults Found------------------------------
VCDS Beta 26.5.2:  SRI Reset-SRI2.CLB
Control Module Part Number: 5E3 920 770 B       Labels:  *None-SRI2
Component:KOMBI         201 5370, Coding:04A4004063840008018462032000080800301400
Channel        Description                                                 	Current val.                                                	New val.
IDE12960-Resetting oil service        ESI: Service Status                                         	no warning                                                  	---
IDE12964-Oil: driven distance since last oil service                                                	ESI: Distance SINCE last Oil Service                        	5800 km                                                     	---
IDE12965-Oil: time since last oil service                                                           	ESI: Time SINCE last Oil Service                            	154 d                                                       	---
IDE12966-Oil: min distance until next oil service (flexible interval)                               	ESI: Minimum Distance to Oil Service(s)                     	15000 km                                                    	---
IDE12967-Oil: max. distance until next oil service (flexible interval)                              	ESI: Maximum Distance to Oil Service(s)                     	30000 km                                                    	---
IDE12968-Oil: min time until next oil service (flexible interval)                                   	ESI: Minimum Time to Oil Service(s)                         	365 d                                                       	---
IDE12969-Oil: max time until next oil service (flexible interval)                                   	ESI: Maximum Time to Oil Service(s)                         	730 d                                                       	---
IDE12980-Inspection: distance driven since the last inspection                                      	FIX: Distance SINCE last mileage-dependent Inspection       	5800 km                                                     	---
IDE12981-Inspection: time since the last inspection                                                 	FIX: Time SINCE last time-dependent Inspection              	154 d                                                       	---
IDE12978-Inspection: distance until next inspection                                                 	FIX: Max. Distance to mileage-dependent Inspection(s)       	1500000 km                                                  	---
IDE12979-Inspection: time until next inspection                                                     	FIX: Max. Time to time-dependent Inspection(s)              	365 d                                                       	---
IDE12970-Oil: distance until next oil service (fixed interval)                                      	SIA/SID: Maximum Distance to Service/Inspection             	15000 km                                                    	---
IDE12971-Oil: time until next oil service (fixed interval)                                          	SIA/SID: Maximum Time to Service/Inspection                 	365 d                                                       	---
*IDE12972-Oil: theoretical service interval                                                         	ESI/INFO: Theoretical Oil Service Interval                  	12500.00 km                                                 	---
*IDE12975-Oil: remaining driving distance                                                           	ESI/INFO: Remaining Distance to Oil Service                 	9170 km                                                     	---
*IDE12976-Oil: remaining running time        ESI/INFO: Remaining Time to Oil Service                     	211 d                                                       	---
*IDE12973-Oil: service interval exceeded in km                                                      	ESI/INFO: Oil Service Exceedance                            	0 km                                                        	---
*IDE12974-Oil service interval exceeded in days                                                     	ESI/INFO: Oil Service Exceedance                            	0 d                                                         	---
IDE00819-Day counter        INFO: Day Counter (since Delivery Inspection)               	1517 d                                                      	---
IDE00301-Distance        INFO: Vehicle/Odomoter Mileage                              	143433 km                                                   	---
IDE11086-Service notification        Service Notification (Early Warning/Prediction)             	30 d                                                        	---
IDE12962-Oil: soot entry        ESI/INFO: Soot Entry                                        	23100 km                                                    	---
IDE12963-Oil: thermal loading        ESI/INFO: Thermal Load                                      	4300 km                                                     	---
IDE12961-Oil quality        ESI/INFO: Oil Quality                                       	poor oil quality                                            	---
adpmap-01-05L-906-022-KT_TMBAJ7NXXNY096941-20260703-1349.CSV
;SW:05L-906-022-KT   HW:05L-907-309-AA ---  01: Engine
;Component:R4 2.0l TDI   H80 1998, Coding:012508320364050970080000000000000000000000000000
;EV_ECM20TDI01105L906022KT,007001,EV_ECM20TDI01105L906022DE_007_VW38.rod
;Friday,03,July,2026,13:49:32:12012
;VCID: 835865DD9B9776D24B0-80D6
IDE00263-Injector 1 correction value,8ZH442K ,7
IDE00264-Injector 2 correction value,AZIGBBE ,7
IDE00265-Injector 3 correction value,88ACB6C ,7
IDE00266-Injector 4 correction value,AG1CATG ,7
IDE01096-Particulate Filter Statistics,0 ,1
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE01945-Engine run-in oil pressure,not active ,1
IDE02637-Adaptation for metering quantity measurement,4 ,1
IDE04158-Activation of start/stop function,active ,1
IDE07903-Adaptation of ash mass,30.83 g,2
IDE10309-Adaptation of oxidation catalytic converter aging,4.64435e+006 s,2
IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,-150.00 °,4
IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,0.00 °,4
IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,17.97 °,4
IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4
IDE15783-Adaptation for aging coated particulate filter,16086527.5000 s,4
IDE15794-ENG264196-Radiator shutter: target value-Setpoint radiator shutter 1,0 %,4
IDE15794-ENG264197-Radiator shutter: target value-Setpoint radiator shutter 1 - no reaction,no reaction ,4
IDE15794-ENG264198-Radiator shutter: target value-Setpoint radiator shutter 2,0 %,4
IDE15794-ENG264199-Radiator shutter: target value-Setpoint radiator shutter 2 - no reaction,no reaction ,4
IDE15794-ENG264200-Radiator shutter: target value-Setpoint radiator shutter 3,0 %,4
IDE15794-ENG264201-Radiator shutter: target value-Setpoint radiator shutter 3 - no reaction,no reaction ,4
IDE15794-ENG264202-Radiator shutter: target value-Setpoint radiator shutter 4,0 %,4
IDE15794-ENG264203-Radiator shutter: target value-Setpoint radiator shutter 4 - no reaction,no reaction ,4
Elapsed Time: 00:04
adpmap-02-0GC-906-555-K_TMBAJ7NXXNY096941-20260703-1350.CSV
;SW:0GC-906-555-K   HW:0GC-300-047 ---  02: Auto Trans
;Component:GSG DQ381     H06 5080, Coding:0014
;EV_TCMDQ381062,001020,EV_TCMDQ381062_VW38.rod
;Friday,03,July,2026,13:50:30:12012
;VCID: C3D8A5DDDB17B6D20B0-8096
IDE00001-ENG252054-Production mode-Deactivate P button,not activated ,3
IDE00001-ENG252070-Production mode-Haltemagnet ausschalten,not activated ,3
IDE00001-ENG252086-Production mode-Longpush,not activated ,3
IDE00001-ENG252078-Production mode-NER aktiv halten,not activated ,3
IDE00001-ENG252050-Production mode-N-Haltephase deaktivieren,not activated ,3
IDE00001-ENG98860-Production mode-Production mode,not activated ,3
Elapsed Time: 00:01
adpmap-03-5WA-614-517-BL_TMBAJ7NXXNY096941-20260703-1350.CSV
;SW:5WA-614-517-BL   HW:5WA-614-517-N ---  03: ABS Brakes
;Component:ESC           H13 0133, Coding:34072CA422294472528050040AC461866DB658F55AC8670821BCA231018FF100002814
;EV_Brake1ESCEPBMQB37W,013056,EV_Brake1ESCEPBMQB37W_013_AU38.rod
;Friday,03,July,2026,13:50:53:12012
;VCID: 9378559DEBF7E652FB0-80C6 SFD {x}
IDE00820-ENG264053-Activating and deactivating all development messages-Activation of Development Message EPB00,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264054-Activating and deactivating all development messages-Activation of Development Message EPB01,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264055-Activating and deactivating all development messages-Activation of Development Message EPB02,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264056-Activating and deactivating all development messages-Activation of Development Message ESC00,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264057-Activating and deactivating all development messages-Activation of Development Message ESC01,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264058-Activating and deactivating all development messages-Activation of Development Message ESC02,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264059-Activating and deactivating all development messages-Activation of Development Message ESC03,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264060-Activating and deactivating all development messages-Activation of Development Message ESC04,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264061-Activating and deactivating all development messages-Activation of Development Message ESC05,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264062-Activating and deactivating all development messages-Activation of Development Message ESC06,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264063-Activating and deactivating all development messages-Activation of Development Message ESC07,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264064-Activating and deactivating all development messages-Activation of Development Message ESC08,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264065-Activating and deactivating all development messages-Activation of Development Message ESC10,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264066-Activating and deactivating all development messages-Activation of Development Message FDR01,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE03659-Roller test bench mode,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE04456-Brake disk drying,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE04765-Counter steer support,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE05055-Hydraulic brake assistant,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE05057-Brake prefill,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE05161-Straight ahead brake stabilization,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE07292-Brake pre-filling,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE07565-ABS in lower speed range,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE11985-Expected OBD requirements,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE12030-Rough road optimization,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-IDE07280-Delay and hold management-Multiple collision brake,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS00919-Delay and hold management-Pedestrian protection,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS05087-Delay and hold management-ACC,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS05506-Delay and hold management-Stopping distance reduction,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS10858-Delay and hold management-Rear camera,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS12321-Delay and hold management-Trailer maneuvering system,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS15696-Delay and hold management-Rear cross traffic assistant,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS15806-Delay and hold management-Parking assist,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS18082-Delay and hold management-Emergency assistant,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14226-Electronic engine braking torque reduction,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE15332-MAS17834-Vehicle curb weight-Curb weight of rear axle,563.0 kg,4
IDE15332-MAS17837-Vehicle curb weight-Curb weight of front axle,924.0 kg,4
MAS03691-Dimming,Security access required;You should unlock SFD before attempting advanced functions.,4
MAS09595-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
MAS09595-IDE02939-Production mode-Activate/lock control,Deactivating ,3
MAS09595-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
MAS09595-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
MAS09595-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3
MAS09595-Production mode-,not active ,3
MAS14035-Precondition,Security access required;You should unlock SFD before attempting advanced functions.,3
MAS16144-Wheel loose detection: warning threshold,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264022-Developer_Function_01,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264037-Developer_Function_02,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264035-ENG264163-Developer_Function_03-Developer_Function_03_Bremsdrucksensor,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264035-ENG264164-Developer_Function_03-Developer_Function_03_PYA,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264021-Developer_Function_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG264130-dimming_characteristic_1-Daempfung_Abdimmen_KL_58xD_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG154584-dimming_characteristic_1-Daempfung_Aufdimmen_KL_58xd_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG101574-dimming_characteristic_1-X1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG99557-dimming_characteristic_1-X2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG102140-dimming_characteristic_1-X3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG102936-dimming_characteristic_1-X4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG103548-dimming_characteristic_1-X5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG113992-dimming_characteristic_1-X6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG99777-dimming_characteristic_1-Y1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG100480-dimming_characteristic_1-Y2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG100773-dimming_characteristic_1-Y3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG100631-dimming_characteristic_1-Y4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG102174-dimming_characteristic_1-Y5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG113993-dimming_characteristic_1-Y6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG264130-dimming_characteristic_2-Daempfung_Abdimmen_KL_58xD_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG154584-dimming_characteristic_2-Daempfung_Aufdimmen_KL_58xd_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG101574-dimming_characteristic_2-X1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG99557-dimming_characteristic_2-X2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG102140-dimming_characteristic_2-X3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG102936-dimming_characteristic_2-X4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG103548-dimming_characteristic_2-X5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG113992-dimming_characteristic_2-X6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG99777-dimming_characteristic_2-Y1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG100480-dimming_characteristic_2-Y2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG100773-dimming_characteristic_2-Y3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG100631-dimming_characteristic_2-Y4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG102174-dimming_characteristic_2-Y5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG113993-dimming_characteristic_2-Y6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264073-Dynamic_Developer_Function_01-ASAP_Address_0,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264074-Dynamic_Developer_Function_01-ASAP_Address_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264075-Dynamic_Developer_Function_01-ASAP_Address_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264076-Dynamic_Developer_Function_01-ASAP_Address_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264077-Dynamic_Developer_Function_01-ASAP_Address_11,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264078-Dynamic_Developer_Function_01-ASAP_Address_12,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264079-Dynamic_Developer_Function_01-ASAP_Address_13,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264080-Dynamic_Developer_Function_01-ASAP_Address_14,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264081-Dynamic_Developer_Function_01-ASAP_Address_15,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264082-Dynamic_Developer_Function_01-ASAP_Address_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264083-Dynamic_Developer_Function_01-ASAP_Address_3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264084-Dynamic_Developer_Function_01-ASAP_Address_4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264085-Dynamic_Developer_Function_01-ASAP_Address_5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264086-Dynamic_Developer_Function_01-ASAP_Address_6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264087-Dynamic_Developer_Function_01-ASAP_Address_7,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264088-Dynamic_Developer_Function_01-ASAP_Address_8,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264089-Dynamic_Developer_Function_01-ASAP_Address_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264090-Dynamic_Developer_Function_01-ASAP_Address_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264091-Dynamic_Developer_Function_01-ASAP_Address_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264092-Dynamic_Developer_Function_01-ASAP_Address_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264093-Dynamic_Developer_Function_01-ASAP_Address_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264094-Dynamic_Developer_Function_01-ASAP_Address_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264095-Dynamic_Developer_Function_01-ASAP_Address_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264096-Dynamic_Developer_Function_01-ASAP_Address_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264097-Dynamic_Developer_Function_01-ASAP_Address_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264098-Dynamic_Developer_Function_01-ASAP_Address_9,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264099-Dynamic_Developer_Function_01-ASAP_Address_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264100-Dynamic_Developer_Function_01-ASAP_Address_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264101-Dynamic_Developer_Function_01-ASAP_Address_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264102-Dynamic_Developer_Function_01-ASAP_Address_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264103-Dynamic_Developer_Function_01-ASAP_Address_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264104-Dynamic_Developer_Function_01-ASAP_Address_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264105-Dynamic_Developer_Function_01-ASAP_Address_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264106-Dynamic_Developer_Function_01-ASAP_Address_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264107-Dynamic_Developer_Function_01-ASAP_Address_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264108-Dynamic_Developer_Function_01-ASAP_Address_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264109-Dynamic_Developer_Function_01-ASAP_Data_Type_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264110-Dynamic_Developer_Function_01-ASAP_Data_Type_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264111-Dynamic_Developer_Function_01-ASAP_Data_Type_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264112-Dynamic_Developer_Function_01-ASAP_Data_Type_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264113-Dynamic_Developer_Function_01-ASAP_Data_Type_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264114-Dynamic_Developer_Function_01-ASAP_Data_Type_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264115-Dynamic_Developer_Function_01-ASAP_Data_Type_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264116-Dynamic_Developer_Function_01-ASAP_Data_Type_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264117-Dynamic_Developer_Function_01-ASAP_Data_Type_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264118-Dynamic_Developer_Function_01-ASAP_Data_Type_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264119-Dynamic_Developer_Function_01-ASAP_Data_Type_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264120-Dynamic_Developer_Function_01-ASAP_Data_Type_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264121-Dynamic_Developer_Function_01-ASAP_Data_Type_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264122-Dynamic_Developer_Function_01-ASAP_Data_Type_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264123-Dynamic_Developer_Function_01-ASAP_Data_Type_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264124-Dynamic_Developer_Function_01-ASAP_Data_Type_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264125-Dynamic_Developer_Function_01-ASAP_Data_Type_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264126-Dynamic_Developer_Function_01-ASAP_Data_Type_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264127-Dynamic_Developer_Function_01-ASAP_Data_Type_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264128-Dynamic_Developer_Function_01-ASAP_Data_Type_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264131-Dynamic_Developer_Function_01-Data_position_0_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264132-Dynamic_Developer_Function_01-Data_position_0_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264133-Dynamic_Developer_Function_01-Data_position_1_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264134-Dynamic_Developer_Function_01-Data_position_1_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264135-Dynamic_Developer_Function_01-Data_position_10_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264136-Dynamic_Developer_Function_01-Data_position_10_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264137-Dynamic_Developer_Function_01-Data_position_11_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264138-Dynamic_Developer_Function_01-Data_position_11_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264139-Dynamic_Developer_Function_01-Data_position_12_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264140-Dynamic_Developer_Function_01-Data_position_12_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264141-Dynamic_Developer_Function_01-Data_position_13_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264142-Dynamic_Developer_Function_01-Data_position_13_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264143-Dynamic_Developer_Function_01-Data_position_14_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264144-Dynamic_Developer_Function_01-Data_position_14_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264145-Dynamic_Developer_Function_01-Data_position_15_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264146-Dynamic_Developer_Function_01-Data_position_15_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264147-Dynamic_Developer_Function_01-Data_position_2_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264148-Dynamic_Developer_Function_01-Data_position_2_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264149-Dynamic_Developer_Function_01-Data_position_3_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264150-Dynamic_Developer_Function_01-Data_position_3_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264151-Dynamic_Developer_Function_01-Data_position_4_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264152-Dynamic_Developer_Function_01-Data_position_4_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264153-Dynamic_Developer_Function_01-Data_position_5_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264154-Dynamic_Developer_Function_01-Data_position_5_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264155-Dynamic_Developer_Function_01-Data_position_6_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264156-Dynamic_Developer_Function_01-Data_position_6_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264157-Dynamic_Developer_Function_01-Data_position_7_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264158-Dynamic_Developer_Function_01-Data_position_7_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264159-Dynamic_Developer_Function_01-Data_position_8_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264160-Dynamic_Developer_Function_01-Data_position_8_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264161-Dynamic_Developer_Function_01-Data_position_9_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264162-Dynamic_Developer_Function_01-Data_position_9_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264166-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264167-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264073-Dynamic_Developer_Function_02-ASAP_Address_0,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264074-Dynamic_Developer_Function_02-ASAP_Address_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264075-Dynamic_Developer_Function_02-ASAP_Address_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264076-Dynamic_Developer_Function_02-ASAP_Address_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264077-Dynamic_Developer_Function_02-ASAP_Address_11,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264078-Dynamic_Developer_Function_02-ASAP_Address_12,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264079-Dynamic_Developer_Function_02-ASAP_Address_13,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264080-Dynamic_Developer_Function_02-ASAP_Address_14,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264081-Dynamic_Developer_Function_02-ASAP_Address_15,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264082-Dynamic_Developer_Function_02-ASAP_Address_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264083-Dynamic_Developer_Function_02-ASAP_Address_3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264084-Dynamic_Developer_Function_02-ASAP_Address_4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264085-Dynamic_Developer_Function_02-ASAP_Address_5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264086-Dynamic_Developer_Function_02-ASAP_Address_6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264087-Dynamic_Developer_Function_02-ASAP_Address_7,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264088-Dynamic_Developer_Function_02-ASAP_Address_8,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264089-Dynamic_Developer_Function_02-ASAP_Address_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264090-Dynamic_Developer_Function_02-ASAP_Address_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264091-Dynamic_Developer_Function_02-ASAP_Address_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264092-Dynamic_Developer_Function_02-ASAP_Address_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264093-Dynamic_Developer_Function_02-ASAP_Address_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264094-Dynamic_Developer_Function_02-ASAP_Address_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264095-Dynamic_Developer_Function_02-ASAP_Address_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264096-Dynamic_Developer_Function_02-ASAP_Address_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264097-Dynamic_Developer_Function_02-ASAP_Address_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264098-Dynamic_Developer_Function_02-ASAP_Address_9,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264099-Dynamic_Developer_Function_02-ASAP_Address_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264100-Dynamic_Developer_Function_02-ASAP_Address_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264101-Dynamic_Developer_Function_02-ASAP_Address_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264102-Dynamic_Developer_Function_02-ASAP_Address_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264103-Dynamic_Developer_Function_02-ASAP_Address_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264104-Dynamic_Developer_Function_02-ASAP_Address_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264105-Dynamic_Developer_Function_02-ASAP_Address_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264106-Dynamic_Developer_Function_02-ASAP_Address_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264107-Dynamic_Developer_Function_02-ASAP_Address_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264108-Dynamic_Developer_Function_02-ASAP_Address_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264109-Dynamic_Developer_Function_02-ASAP_Data_Type_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264110-Dynamic_Developer_Function_02-ASAP_Data_Type_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264111-Dynamic_Developer_Function_02-ASAP_Data_Type_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264112-Dynamic_Developer_Function_02-ASAP_Data_Type_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264113-Dynamic_Developer_Function_02-ASAP_Data_Type_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264114-Dynamic_Developer_Function_02-ASAP_Data_Type_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264115-Dynamic_Developer_Function_02-ASAP_Data_Type_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264116-Dynamic_Developer_Function_02-ASAP_Data_Type_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264117-Dynamic_Developer_Function_02-ASAP_Data_Type_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264118-Dynamic_Developer_Function_02-ASAP_Data_Type_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264119-Dynamic_Developer_Function_02-ASAP_Data_Type_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264120-Dynamic_Developer_Function_02-ASAP_Data_Type_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264121-Dynamic_Developer_Function_02-ASAP_Data_Type_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264122-Dynamic_Developer_Function_02-ASAP_Data_Type_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264123-Dynamic_Developer_Function_02-ASAP_Data_Type_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264124-Dynamic_Developer_Function_02-ASAP_Data_Type_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264125-Dynamic_Developer_Function_02-ASAP_Data_Type_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264126-Dynamic_Developer_Function_02-ASAP_Data_Type_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264127-Dynamic_Developer_Function_02-ASAP_Data_Type_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264128-Dynamic_Developer_Function_02-ASAP_Data_Type_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264131-Dynamic_Developer_Function_02-Data_position_0_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264132-Dynamic_Developer_Function_02-Data_position_0_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264133-Dynamic_Developer_Function_02-Data_position_1_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264134-Dynamic_Developer_Function_02-Data_position_1_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264135-Dynamic_Developer_Function_02-Data_position_10_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264136-Dynamic_Developer_Function_02-Data_position_10_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264137-Dynamic_Developer_Function_02-Data_position_11_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264138-Dynamic_Developer_Function_02-Data_position_11_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264139-Dynamic_Developer_Function_02-Data_position_12_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264140-Dynamic_Developer_Function_02-Data_position_12_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264141-Dynamic_Developer_Function_02-Data_position_13_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264142-Dynamic_Developer_Function_02-Data_position_13_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264143-Dynamic_Developer_Function_02-Data_position_14_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264144-Dynamic_Developer_Function_02-Data_position_14_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264145-Dynamic_Developer_Function_02-Data_position_15_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264146-Dynamic_Developer_Function_02-Data_position_15_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264147-Dynamic_Developer_Function_02-Data_position_2_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264148-Dynamic_Developer_Function_02-Data_position_2_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264149-Dynamic_Developer_Function_02-Data_position_3_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264150-Dynamic_Developer_Function_02-Data_position_3_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264151-Dynamic_Developer_Function_02-Data_position_4_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264152-Dynamic_Developer_Function_02-Data_position_4_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264153-Dynamic_Developer_Function_02-Data_position_5_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264154-Dynamic_Developer_Function_02-Data_position_5_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264155-Dynamic_Developer_Function_02-Data_position_6_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264156-Dynamic_Developer_Function_02-Data_position_6_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264157-Dynamic_Developer_Function_02-Data_position_7_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264158-Dynamic_Developer_Function_02-Data_position_7_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264159-Dynamic_Developer_Function_02-Data_position_8_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264160-Dynamic_Developer_Function_02-Data_position_8_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264161-Dynamic_Developer_Function_02-Data_position_9_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264162-Dynamic_Developer_Function_02-Data_position_9_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264166-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264167-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264073-Dynamic_Developer_Function_03-ASAP_Address_0,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264074-Dynamic_Developer_Function_03-ASAP_Address_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264075-Dynamic_Developer_Function_03-ASAP_Address_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264076-Dynamic_Developer_Function_03-ASAP_Address_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264077-Dynamic_Developer_Function_03-ASAP_Address_11,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264078-Dynamic_Developer_Function_03-ASAP_Address_12,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264079-Dynamic_Developer_Function_03-ASAP_Address_13,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264080-Dynamic_Developer_Function_03-ASAP_Address_14,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264081-Dynamic_Developer_Function_03-ASAP_Address_15,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264082-Dynamic_Developer_Function_03-ASAP_Address_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264083-Dynamic_Developer_Function_03-ASAP_Address_3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264084-Dynamic_Developer_Function_03-ASAP_Address_4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264085-Dynamic_Developer_Function_03-ASAP_Address_5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264086-Dynamic_Developer_Function_03-ASAP_Address_6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264087-Dynamic_Developer_Function_03-ASAP_Address_7,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264088-Dynamic_Developer_Function_03-ASAP_Address_8,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264089-Dynamic_Developer_Function_03-ASAP_Address_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264090-Dynamic_Developer_Function_03-ASAP_Address_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264091-Dynamic_Developer_Function_03-ASAP_Address_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264092-Dynamic_Developer_Function_03-ASAP_Address_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264093-Dynamic_Developer_Function_03-ASAP_Address_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264094-Dynamic_Developer_Function_03-ASAP_Address_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264095-Dynamic_Developer_Function_03-ASAP_Address_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264096-Dynamic_Developer_Function_03-ASAP_Address_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264097-Dynamic_Developer_Function_03-ASAP_Address_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264098-Dynamic_Developer_Function_03-ASAP_Address_9,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264099-Dynamic_Developer_Function_03-ASAP_Address_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264100-Dynamic_Developer_Function_03-ASAP_Address_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264101-Dynamic_Developer_Function_03-ASAP_Address_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264102-Dynamic_Developer_Function_03-ASAP_Address_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264103-Dynamic_Developer_Function_03-ASAP_Address_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264104-Dynamic_Developer_Function_03-ASAP_Address_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264105-Dynamic_Developer_Function_03-ASAP_Address_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264106-Dynamic_Developer_Function_03-ASAP_Address_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264107-Dynamic_Developer_Function_03-ASAP_Address_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264108-Dynamic_Developer_Function_03-ASAP_Address_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264109-Dynamic_Developer_Function_03-ASAP_Data_Type_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264110-Dynamic_Developer_Function_03-ASAP_Data_Type_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264111-Dynamic_Developer_Function_03-ASAP_Data_Type_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264112-Dynamic_Developer_Function_03-ASAP_Data_Type_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264113-Dynamic_Developer_Function_03-ASAP_Data_Type_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264114-Dynamic_Developer_Function_03-ASAP_Data_Type_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264115-Dynamic_Developer_Function_03-ASAP_Data_Type_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264116-Dynamic_Developer_Function_03-ASAP_Data_Type_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264117-Dynamic_Developer_Function_03-ASAP_Data_Type_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264118-Dynamic_Developer_Function_03-ASAP_Data_Type_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264119-Dynamic_Developer_Function_03-ASAP_Data_Type_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264120-Dynamic_Developer_Function_03-ASAP_Data_Type_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264121-Dynamic_Developer_Function_03-ASAP_Data_Type_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264122-Dynamic_Developer_Function_03-ASAP_Data_Type_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264123-Dynamic_Developer_Function_03-ASAP_Data_Type_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264124-Dynamic_Developer_Function_03-ASAP_Data_Type_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264125-Dynamic_Developer_Function_03-ASAP_Data_Type_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264126-Dynamic_Developer_Function_03-ASAP_Data_Type_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264127-Dynamic_Developer_Function_03-ASAP_Data_Type_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264128-Dynamic_Developer_Function_03-ASAP_Data_Type_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264131-Dynamic_Developer_Function_03-Data_position_0_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264132-Dynamic_Developer_Function_03-Data_position_0_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264133-Dynamic_Developer_Function_03-Data_position_1_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264134-Dynamic_Developer_Function_03-Data_position_1_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264135-Dynamic_Developer_Function_03-Data_position_10_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264136-Dynamic_Developer_Function_03-Data_position_10_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264137-Dynamic_Developer_Function_03-Data_position_11_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264138-Dynamic_Developer_Function_03-Data_position_11_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264139-Dynamic_Developer_Function_03-Data_position_12_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264140-Dynamic_Developer_Function_03-Data_position_12_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264141-Dynamic_Developer_Function_03-Data_position_13_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264142-Dynamic_Developer_Function_03-Data_position_13_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264143-Dynamic_Developer_Function_03-Data_position_14_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264144-Dynamic_Developer_Function_03-Data_position_14_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264145-Dynamic_Developer_Function_03-Data_position_15_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264146-Dynamic_Developer_Function_03-Data_position_15_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264147-Dynamic_Developer_Function_03-Data_position_2_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264148-Dynamic_Developer_Function_03-Data_position_2_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264149-Dynamic_Developer_Function_03-Data_position_3_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264150-Dynamic_Developer_Function_03-Data_position_3_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264151-Dynamic_Developer_Function_03-Data_position_4_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264152-Dynamic_Developer_Function_03-Data_position_4_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264153-Dynamic_Developer_Function_03-Data_position_5_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264154-Dynamic_Developer_Function_03-Data_position_5_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264155-Dynamic_Developer_Function_03-Data_position_6_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264156-Dynamic_Developer_Function_03-Data_position_6_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264157-Dynamic_Developer_Function_03-Data_position_7_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264158-Dynamic_Developer_Function_03-Data_position_7_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264159-Dynamic_Developer_Function_03-Data_position_8_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264160-Dynamic_Developer_Function_03-Data_position_8_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264161-Dynamic_Developer_Function_03-Data_position_9_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264162-Dynamic_Developer_Function_03-Data_position_9_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264166-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264167-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_2,Security access required;You should unlock SFD before attempting advanced functions.,3
Elapsed Time: 00:14
adpmap-05-5WA-959-436-J_TMBAJ7NXXNY096941-20260703-1351.CSV
;SW:5WA-959-436-J   HW:5WA-959-436-J ---  05: Acc/Start Auth.
;Component:Kessy IOBOX   100 0725, Coding:
;EV_Kessy37w,004024,EV_Kessy37w_004.rod
;Friday,03,July,2026,13:51:21:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: DBE87DBD43A7EE12630-808E
ENG253038-ENG258893-DevCod_ Search lights-Suchbeleuchtung_ZAT_bei_KL58_aktiv,activated ,5
ENG253038-ENG258265-DevCod_ Search lights-Suchbeleuchtung_ZAT_Beleuchtung_SES_Variante_aktiv,not activated ,5
ENG253038-ENG260629-DevCod_ Search lights-Suchbeleuchtung_ZAT_Normierung_aktiv,activated ,5
ENG253038-ENG259779-DevCod_ Search lights-Suchbeleuchtung_ZAT_OpenLoadErkennung_aktiv,not activated ,5
ENG253038-ENG260681-DevCod_ Search lights-Suchbeleuchtung_ZAT_SES_Mode,not activated ,5
ENG253096-DevCod_AutomatischeFunktionen,not activated ,6
ENG253395-ENG141964-DevCod_Fahrzeugkonfiguration-Steering assignment,Left ,5
ENG253395-ENG273785-DevCod_Fahrzeugkonfiguration-Transponding_Antennen_Strom_reduziert_aktiv,not active ,5
ENG253143-ENG258965-DevCod_Passive_EntryExit-Toggle-Datalogging_LFDebug_aktiv,not activated ,5
ENG253143-ENG258844-DevCod_Passive_EntryExit-Toggle-Gleichzeitiges_Senden_Innenraumantennen_aktiv,activated ,5
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,6
ENG129029-ENG259793-Easy_close_alignment-VIT_AktivTasteB_Zyklus,1.0 s,6
ENG253331-ENG258816-Par_Automatische_Funktionen-AutomatikFunktionen_Timeout,4320 min,10
ENG253331-ENG260182-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeber_Anwesenheit,300 ms,10
ENG253220-IDE15282-Par_Bedienstellen-Door: driver control section: installation variant,1 ,36
ENG253220-IDE15283-Par_Bedienstellen-Door: front passenger control section: installation variant,1 ,36
ENG253220-IDE15284-Par_Bedienstellen-5th control section: installation variant,5 ,36
ENG253220-IDE15285-Par_Bedienstellen-Fuel filler cap control section: installation variant,5 ,36
ENG253220-IDE15286-Par_Bedienstellen-Rear driver side control section: installation variant,1 ,36
ENG253220-IDE15287-Par_Bedienstellen-Rear passenger side control section: installation variant,1 ,36
ENG253220-ENG259190-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_5teT,4320 min,36
ENG253220-ENG259838-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_BT,4320 min,36
ENG253220-ENG260574-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_FT,0 min,36
ENG253220-ENG261264-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HBFS,4320 min,36
ENG253220-ENG258369-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HFS,4320 min,36
ENG253220-ENG258148-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_Tank,3600 min,36
ENG253220-ENG261229-Par_Bedienstellen-Bedienstelle_Aktivierungsschwelle_Spielschutzzaehler,80 ,36
ENG253220-ENG259917-Par_Bedienstellen-Bedienstelle_Ausschaltzeit_Spielschutz_aktiv,1800 s,36
ENG253220-ENG261227-Par_Bedienstellen-Bedienstelle_Deaktivierung_SchwelleFahrendesFzg,20 km/h,36
ENG253220-ENG261134-Par_Bedienstellen-Bedienstelle_Deaktivierungsschwelle_Spielschutzzaehler,60 ,36
ENG253220-ENG258448-Par_Bedienstellen-Bedienstelle_MaxBetaetigung,120 s,36
ENG253220-ENG259922-Par_Bedienstellen-Bedienstelle_MaxKomfortUnterbrechung,10 ms,36
ENG253220-ENG261271-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_5teT,500 ms,36
ENG253220-ENG259320-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_BT,500 ms,36
ENG253220-ENG259918-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_FT,1500 ms,36
ENG253220-ENG260179-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HBFS,500 ms,36
ENG253220-ENG260090-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HFS,500 ms,36
ENG253220-ENG260565-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_Tank,500 ms,36
ENG253220-ENG261322-Par_Bedienstellen-Bedienstelle_MinBetaetigung_ToggleTaster,140 ms,36
ENG253220-ENG259707-Par_Bedienstellen-Bedienstelle_MinBetaetigung_Verriegelungssensor,140 ms,36
ENG253220-ENG258814-Par_Bedienstellen-Bedienstelle_Reaktivierung_SchwelleStehendesFzg,10 km/h,36
ENG253220-ENG258395-Par_Bedienstellen-Bedienstelle_Reduzierung_Zaehlerstand_Spielschutzzaehler,60 s,36
ENG253190-ENG258772-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Diagnose,71 ms,35
ENG253190-ENG258701-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Entry,10400 µs,35
ENG253190-ENG261026-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Exit,40400 µs,35
ENG253190-ENG258968-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Naeherung,20400 µs,35
ENG253190-ENG259906-Par_Näherungssensoren-Naeherungssensor_MaxPausenlaenge,10 ms,35
ENG253190-ENG260803-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Diagnose,42 ms,35
ENG253190-ENG259643-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Entry,6200 µs,35
ENG253190-ENG259840-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Exit,24200 µs,35
ENG253190-ENG259205-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Naeherung,12200 µs,35
ENG253190-ENG260098-Par_Näherungssensoren-Verzoegerung_PowerOn_Reset,1960 ms,35
ENG253285-ENG260495-Par_PassiveKomfort-Delay_Reichweitenbegrenzung_Start,0 ms,10
ENG253285-ENG260385-Par_PassiveKomfort-KomfortReichweitenbegr_Timout,75 s,10
ENG253285-ENG261013-Par_PassiveKomfort-PassiveKomfortFunktionen_MaxSignalisierungsdauer,60 s,10
ENG253285-ENG263587-Par_PassiveKomfort-PassiveKomfortFunktionen_Zeitfenster_fuer_Bedienhandlung,800 ms,10
ENG253285-ENG261279-Par_PassiveKomfort-Reichweitenbegrenzung_Zyklus,90 ms,10
ENG253106-ENG258919-Par_ScanStrategie_RetryHandling-anz_RetriesRegistering,1 Num,22
ENG253106-ENG259329-Par_ScanStrategie_RetryHandling-Erste_Warnschwelle_thermische_Überlast,45 °C,22
ENG253106-ENG259473-Par_ScanStrategie_RetryHandling-P2_Pause_zwischen_Transponding_Telegrammen,200 ms,22
ENG253106-ENG259392-Par_ScanStrategie_RetryHandling-Sperrzeit_LFTreiber_nach_thermischer_Ueberlast,5.0 s,22
ENG253106-ENG263515-Par_ScanStrategie_RetryHandling-t_CANSignalDelayAfterSleep,30 ms,22
ENG253106-ENG258479-Par_ScanStrategie_RetryHandling-t_LFDebug_Nachsignaslisierung,100 ms,22
ENG253106-ENG263591-Par_ScanStrategie_RetryHandling-Temperaturschaltschwelle_LF_Wavetable,100 °C,22
ENG253106-ENG276176-Par_ScanStrategie_RetryHandling-Timeout_Grundwert_RetryRegistering,52 ms,22
ENG253106-ENG276194-Par_ScanStrategie_RetryHandling-Timeout_Inkrementwert_RetryRegistering,7 ms,22
ENG253106-ENG261110-Par_ScanStrategie_RetryHandling-Verzoegerung_LFSenden_nach_Weckleitungziehen,0 ms,22
ENG253106-ENG260133-Par_ScanStrategie_RetryHandling-Zweite_Warnschwelle_thermische_Überlast,65 °C,22
ENG253086-MAS18911-Passive_Komfort-Convenience closing by locking using door handle active,activated ,5
ENG253086-ENG280093-Passive_Komfort-Noise_filter_aktiv,activated ,5
ENG253086-ENG261176-Passive_Komfort-Passive_Komfort_Oeffnen_aktiv,not activated ,5
ENG253086-ENG259864-Passive_Komfort-Passive_Komfort_Togglen_aktiv,not activated ,5
ENG253352-ENG259594-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Abdimmen,0.0 ,30
ENG253352-ENG259617-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Aufdimmen,0.0 ,30
ENG253352-ENG261228-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ausschalten_KL15,10 min,30
ENG253352-ENG258605-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_0Prozent_Dimmkurve,0.0 %,30
ENG253352-ENG258785-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Deltawert_50Prozent_Dimmkurve,50.0 %,30
ENG253352-ENG263542-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Fehlerdimmwert,80 %,30
ENG253352-ENG260556-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Nennspannung,13.0 V,30
ENG253352-ENG258781-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_OffsetDimmwert,1.0 ,30
ENG253352-ENG259791-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Deltawert_100Prozent_Dimmkurve,100.0 %,30
ENG253287-ENG261242-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES1,2.0 %,32
ENG253287-ENG260274-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES2,2.0 %,32
ENG253287-ENG258981-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES1,1.0 %,32
ENG253287-ENG260137-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES2,1.0 %,32
ENG253287-ENG259846-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES1,15.0 %,32
ENG253287-ENG261362-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES2,15.0 %,32
ENG253287-ENG258809-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_1,5 %,32
ENG253287-ENG258501-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_2,10 %,32
ENG253287-ENG260497-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_1,90 %,32
ENG253287-ENG258157-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_2,100 %,32
ENG253287-ENG261138-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES1,25.0 %,32
ENG253287-ENG258211-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES2,25.0 %,32
ENG253287-ENG261183-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_faktor,0.2 ,32
ENG253287-ENG259175-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_Offset,3.0 Num,32
ENG253287-ENG261051-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Fall_OFF,900 ms,32
ENG253287-ENG260479-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_OFF,0 ms,32
ENG253287-ENG258704-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_ON,0 ms,32
ENG253287-ENG260922-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Rise_ON,100 ms,32
ENG253287-ENG260304-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Fall_OFF,2000 ms,32
ENG253287-ENG258413-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_OFF,0 ms,32
ENG253287-ENG260729-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_ON,0 ms,32
ENG253287-ENG258296-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Rise_ON,100 ms,32
ENG253287-ENG258477-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES1,3.0 %,32
ENG253287-ENG259506-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES2,3.0 %,32
ENG253287-ENG258902-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES1,1.0 %,32
ENG253287-ENG260830-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES2,1.0 %,32
Elapsed Time: 00:05
adpmap-08-5WA-907-727-AC_TMBAJ7NXXNY096941-20260703-1351.CSV
;SW:5WA-907-727-AC   HW:5WA-907-727-AC ---  08: Auto HVAC
;Component:Climatronic   H02 0440, Coding:101010010211120000100010101011110000112100100000000000000000
;EV_ACClimaBHBVW38X,005069,EV_ACClimaBHBVW38X_SK38.rod
;Friday,03,July,2026,13:51:52:12012
;VCID: 91745F95D1EB1442C9C-80C4
IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,Service life-dependent store ,1
IDE01479-Gear ratio of engine - A/C compressor,1.3 ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,0 min,1
IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1
IDE02744-Steering wheel heating,long_push ,1
IDE03176-Duration of compressor run in,60 s,1
IDE04074-Driving program,not installed ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,10
IDE04927-MAS12610-Window heater-Activation of wiper arm heater,4.00 °C,10
IDE04927-ENG263527-Window heater-Config_heating_voltage_request,No_set_point_voltage ,10
IDE04927-ENG263525-Window heater-Heating_rear_window_activation_time,320 s,10
IDE04927-ENG263512-Window heater-Heating_rear_window_cutoff_temperature,35.00 °C,10
IDE04927-ENG263556-Window heater-Heating_rear_window_temperature_activation_time,active ,10
IDE04927-ENG263570-Window heater-Window_heating_front_activation_time_pause,320 s,10
IDE04927-ENG263505-Window heater-Window_heating_front_cutoff_temperature,35.00 °C,10
IDE04927-ENG263589-Window heater-Window_heating_front_maximum_temperature_activation_time,1200 s,10
IDE04927-ENG263529-Window heater-Window_heating_front_temperature_activation_time,active ,10
IDE06089-ENG263584-Seat heater level current consumption allocation-Config_seat_heating_high_voltage_request,Sollspannungsanforderung 14.7 ,17
IDE06089-ENG263533-Seat heater level current consumption allocation-Config_seat_heating_low_voltage_request,Keine Spannungsanforderung ,17
IDE06089-ENG263526-Seat heater level current consumption allocation-Seat_heating_correction_of_temperature_regulation_on_heat_flow,0.0 °C,17
IDE06089-ENG263552-Seat heater level current consumption allocation-Seat_heating_filter_constant_for_heat_flow,1 s,17
IDE06089-ENG263578-Seat heater level current consumption allocation-Seat_heating_offset_voltage,15.0 V,17
IDE06089-ENG263544-Seat heater level current consumption allocation-Seat_heating_stage_1_lower_threshold,24.0 °C,17
IDE06089-ENG263507-Seat heater level current consumption allocation-Seat_heating_stage_1_upper_threshold,25.0 °C,17
IDE06089-ENG263592-Seat heater level current consumption allocation-Seat_heating_stage_2_lower_threshold,24.0 °C,17
IDE06089-ENG263559-Seat heater level current consumption allocation-Seat_heating_stage_2_upper_threshold,25.0 °C,17
IDE06089-ENG263539-Seat heater level current consumption allocation-Seat_heating_stage_3_lower_threshold,31.0 °C,17
IDE06089-ENG263554-Seat heater level current consumption allocation-Seat_heating_stage_3_upper_threshold,32.0 °C,17
IDE06089-ENG263536-Seat heater level current consumption allocation-Seat_heating_stage_4_lower_threshold,31.0 °C,17
IDE06089-ENG263549-Seat heater level current consumption allocation-Seat_heating_stage_4_upper_threshold,32.0 °C,17
IDE06089-ENG263566-Seat heater level current consumption allocation-Seat_heating_stage_5_lower_threshold,47.0 °C,17
IDE06089-ENG263597-Seat heater level current consumption allocation-Seat_heating_stage_5_upper_threshold,48.0 °C,17
IDE06089-ENG263562-Seat heater level current consumption allocation-Seat_heating_stage_6_lower_threshold,47.0 °C,17
IDE06089-ENG263524-Seat heater level current consumption allocation-Seat_heating_stage_6_upper_threshold,48.0 °C,17
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 l/min,1
IDE06545-Blower voltage for production routines,11.0 V,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE07108-A/C styles,Display ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,70 s,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,41 s,2
IDE07301-Remote start function: activation of seat heating,Seat heater request driver side ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,25.0 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,32.0 °C,1
IDE07307-Remote start function: activation stage of seat heating,4 ,1
IDE07308-Remote start function: activation stage of seat ventilation,4 ,1
IDE07398-Blower logic with manual adjustment,Fan setting: absolute ,1
IDE07418-Additional filter,not installed ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE07951-Time until head area heater performance is reduced from stage 3 to stage 2,0 min,1
IDE07952-Time until head area heater performance is reduced from stage 2 to stage 1,0 min,1
IDE08356-ENG125698-Left seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08356-ENG125700-Left seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08356-ENG125697-Left seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08356-ENG125699-Left seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08356-ENG125701-Left seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08356-ENG134731-Left seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08356-ENG125695-Left seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08356-ENG125696-Left seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08357-ENG125698-Left seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08357-ENG125700-Left seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08357-ENG125697-Left seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08357-ENG125699-Left seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08357-ENG125701-Left seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08357-ENG134731-Left seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08357-ENG125695-Left seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08357-ENG125696-Left seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08358-ENG125698-Left seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08358-ENG125700-Left seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08358-ENG125697-Left seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08358-ENG125699-Left seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08358-ENG125701-Left seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08358-ENG134731-Left seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08358-ENG125695-Left seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08358-ENG125696-Left seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08359-ENG125698-Left seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08359-ENG125700-Left seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08359-ENG125697-Left seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08359-ENG125699-Left seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08359-ENG125701-Left seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08359-ENG134731-Left seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08359-ENG125695-Left seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08359-ENG125696-Left seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE08360-ENG125698-Right seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08360-ENG125700-Right seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08360-ENG125697-Right seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08360-ENG125699-Right seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08360-ENG125701-Right seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08360-ENG134731-Right seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08360-ENG125695-Right seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08360-ENG125696-Right seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08361-ENG125698-Right seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08361-ENG125700-Right seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08361-ENG125697-Right seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08361-ENG125699-Right seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08361-ENG125701-Right seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08361-ENG134731-Right seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08361-ENG125695-Right seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08361-ENG125696-Right seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08362-ENG125698-Right seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08362-ENG125700-Right seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08362-ENG125697-Right seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08362-ENG125699-Right seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08362-ENG125701-Right seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08362-ENG134731-Right seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08362-ENG125695-Right seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08362-ENG125696-Right seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08363-ENG125698-Right seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08363-ENG125700-Right seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08363-ENG125697-Right seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08363-ENG125699-Right seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08363-ENG125701-Right seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08363-ENG134731-Right seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08363-ENG125695-Right seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08363-ENG125696-Right seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE10118-Fan speed reduction for telephony,activated ,1
IDE10278-Behavior of compressor during moderate outside temperatures,inactive ,1
IDE11935-Personalization,activated ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13371-Interior humidity sensor: sensitivity,Medium ,1
IDE13676-Remote start function: rear window defogger,activated ,1
IDE13677-Remote start function: seat climate control takeover,activated ,1
IDE14087-Time until seat heat recovery within the maximum level,120 min,1
IDE15635-Number of interruptions permitted during compressor run-in,0 ,1
IDE80009-Analysis 9,not activated ,1
IDE80010-Analysis 10,not activated ,1
IDE80011-Analysis 11,not activated ,1
IDE80251-MAS09644-Neck heating-Vent temperature,0 ,1
IDE80251-MAS10293-Neck heating-Fan speed,0 ,1
MAS01651-Display and control unit: rear,not installed ,1
MAS06414-Temperature tuning,normal tuning ,1
MAS06415-Blower adjustment,normal tuning ,1
MAS06416-Blower display in auto operation,not activated ,1
MAS06417-Amplified overshoots heater operation,not activated ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
MAS19885-Remote start function: rear windshield heater transfer,activated ,1
MAS19886-Interior temperature sensor: after-run time,180 s,2
ENG263483-AC_evaporator_temperature_offset,0.00 K,1
ENG276128-air_recirculation_deactivate_at_open_sunroof,not activated ,1
ENG263479-Auto-Toggle,not activated ,1
ENG263474-ENG263585-Development_Messages_Mode_Activation-General_Messages,0 ,18
ENG263474-ENG263519-Development_Messages_Mode_Activation-LIN_1_Messages,0 ,18
ENG263474-ENG263517-Development_Messages_Mode_Activation-LIN_2_Messages,0 ,18
ENG263474-ENG263537-Development_Messages_Mode_Activation-LIN_3_Messages,0 ,18
ENG263474-ENG263573-Development_Messages_Mode_Activation-LIN_4_Messages,0 ,18
ENG263474-ENG263548-Development_Messages_Mode_Activation-LIN_5_Messages,0 ,18
ENG263474-ENG263518-Development_Messages_Mode_Activation-LIN_6_Messages,0 ,18
ENG263474-ENG263550-Development_Messages_Mode_Activation-LIN_7_Messages,0 ,18
ENG263474-ENG263508-Development_Messages_Mode_Activation-LIN_8_Messages,0 ,18
ENG263440-Entwicklungs-ID für Entwicklungszwecke freischalten,0 ,2
ENG153885-Knockout_test_mode,0 ,1
ENG263490-manuel_air_recirculation_deacivate_AUTO_mode,activated ,1
ENG263452-OnBoardDiagnose für Entwicklungszwecke freischalten,inactive ,1
ENG125614-Reset_Blower_1_Backrest_Left,inactive ,1
ENG125615-Reset_Blower_1_Backrest_Right,inactive ,1
ENG125613-Reset_Blower_1_Cushion_Left,inactive ,1
ENG125616-Reset_Blower_1_Cushion_Right,inactive ,1
ENG125623-Reset_Blower_2_Backrest_Left,inactive ,1
ENG125624-Reset_Blower_2_Backrest_Right,inactive ,1
ENG125621-Reset_Blower_2_Cushion_Left,inactive ,1
ENG125622-Reset_Blower_2_Cushion_Right,inactive ,1
ENG263461-Schedule-Link_Switsh,according_coding_brand ,1
ENG263450-seat_dependent_climatisation,not activated ,1
ENG263443-seatheatin_function_switch,AUTO_seatheating_function ,1
ENG263458-winterfunction,not installed ,1
Elapsed Time: 00:28
adpmap-09-5WA-937-086-AE_TMBAJ7NXXNY096941-20260703-1353.CSV
;SW:5WA-937-086-AE   HW:5WA-937-086-L ---  09: Cent. Elect.
;Component:BCM37w_M028 0175, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_SK38.rod
;Friday,03,July,2026,13:53:53:12012
;VCID: 947A5681EEF9E16AE2A-80C0 SFD {x}
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE00001-ENG281100-Production mode-Remotestart_Pmode,not active ,3
IDE00301-Distance,0 km,4
IDE01550-Service position,148.010842 °,2
IDE02455-ENG116601-Light function "Coming/Leaving Home"-Coming Home Verbaustatus,automatic ,2
IDE02455-ENG260981-Light function "Coming/Leaving Home"-Darstellung Coming-home Verlauf,not active ,2
IDE02455-ENG261352-Light function "Coming/Leaving Home"-Darstellung Leaving-home Verlauf,not active ,2
IDE02455-ENG115657-Light function "Coming/Leaving Home"-Leaving-Home Verbausstatus,Enabled ,2
IDE02455-ENG115863-Light function "Coming/Leaving Home"-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,2
IDE02455-ENG116602-Light function "Coming/Leaving Home"-Menuesteuerung Coming Home Werkseinstellung,active ,2
IDE02455-ENG116606-Light function "Coming/Leaving Home"-Menuesteuerung Leaving-home Freischaltung per BAP,active ,2
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,2
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0 s,8
IDE02711-ENG112304-Rear wiper-Heckwischer,not installed ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,kein Heckwischerstopp ,8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck,not active ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,7 s,8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,not active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,1500 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,1200 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,0 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,1000 ms,7
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,7
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,7
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beams ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,Main beam ,4
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,255 min,2
IDE07161-temporary VIN,Conditions not correct or request sequence error,2
IDE07356-Position during interval mode,11.505483 °,2
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,present ,9
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,9
IDE08786-ENG259537-Assistance light functions-Maskierung_Regenlichtmenü,not active ,9
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,9
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,9
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,9
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,9
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,9
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,9
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,40 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,40 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,40 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,40 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,40 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,40 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,70 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,70 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,40 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,40 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,100 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,100 %,12
IDE09767-ENG133381-Position lamps-Bedingungen zur Parklichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG133380-Position lamps-Bedingungen zur Standlichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG137034-Position lamps-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,7
IDE09767-ENG115862-Position lamps-Lichtwarnungsverhalten,klemmenabhaengig ,7
IDE09767-ENG115859-Position lamps-Parklicht ueber LSS aktiviert,One-sided ,7
IDE09767-ENG126816-Position lamps-Standlicht aus,active ,7
IDE09767-ENG115829-Position lamps-Standlichtreduzierung mit beidseitigem Parklicht,active ,7
IDE09767-ENG133383-Position lamps-Standlicht-Verfügbarkeit,24 s,7
IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,7
IDE10298-Alternating park position 1,0.010989 °,2
IDE10299-Alternating park position 2,5.010984 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,2
IDE10845-Control module rear lid opening: vehicle type-,FE ,12
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,0 s,12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,0 ms,12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schlüsselsuche,0 s,12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,0 ms,12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,0 km/h,12
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,12
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,12
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,12
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,12
IDE12302-SFT00022-Identification of sub-bus participant-Steering Column Electronics,old ,6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-Left taillight 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Power rear lid opening control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-Left taillight 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right taillight 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right taillight 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver's side,old ,6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger's side,old ,6
IDE12488-Antenna 1 for short-range communication,No Response From Subnet Component,6
IDE12489-Antenna 2 for short-range communication,No Response From Subnet Component,6
IDE13064-Wiper motor control module: dataset,5A 00 05 C8 00 78 00 73 00 00 00 32 05 C8 00 00 00 32 05 C8 01 00 0A 2A 3E 0A 0A 00 32 1E 23 2D 30 34 38 3B 00 6E 01 CC 05 0B 00 0B 0E 14 19 00 00 00 00 00 00 F6 F3 E7 CE 00 EC 1E BA B0 4C 56 78 96 00 19 00 00 00 00 00 00 F6 F1 DD C4 00 00 00 00 00 00 00 00 16 54 AC D9 ,90
IDE13354-Wiper motor control module: dataset 2,5A 00 04 04 B4 00 0A 0A 00 05 05 0A 05 0A 02 32 32 3E 14 00 15 16 16 16 14 14 14 14 00 7F 05 01 02 01 02 05 01 02 01 03 25 00 04 04 0C 78 04 04 0C 01 04 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C C8 B6 9D ,70
IDE13355-Wiper motor control module: dataset 3,5A 00 08 00 0A 19 00 00 0A 04 64 96 C8 FA 4E 50 55 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F8 6B 1F 8D ,50
IDE13356-Wiper motor control module: dataset 4,5A 00 35 45 34 39 35 35 31 31 39 41 20 35 45 34 39 35 35 31 31 39 41 20 30 36 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2C FC A9 70 ,70
IDE13391-ENG246968-BAP function status-CHo_LHo_Nachlauf,0 ms,16
IDE13391-ENG115656-BAP function status-Coming Home Leuchten,Low beams ,16
IDE13391-ENG116604-BAP function status-Coming-home Einschaltereignis,Driver's door open ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,696 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,800 lx,16
IDE13391-ENG116603-BAP function status-Menueeinstellung Cominghome,10 seconds ,16
IDE13391-ENG258918-BAP function status-Menueeinstellung Cominghome bei Tag,10 seconds ,16
IDE13391-ENG259258-BAP function status-Menueeinstellung Leaving-home bei Tag,10 seconds ,16
IDE13391-ENG116607-BAP function status-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,16
IDE13391-ENG258405-BAP function status-Tagfahrlicht mit CHO bei Tag in Stellung AUTO,not active ,16
IDE13391-ENG259717-BAP function status-Tagfahrlicht mit LHO bei Tag in Stellung AUTO,not active ,16
IDE15901-Direct entry keys,installed ,2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,Yes ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,4
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,4
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,4
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,4
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,4
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,4
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,4
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,4
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,4
IDE80016-Analysis 16,No Response From Subnet Component,4
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,4
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,4
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,4
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,4
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,4
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,4
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,4
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,4
IDE80017-ENG289601-Analysis 17-Offset_PP1,No Response From Subnet Component,4
IDE80017-ENG289602-Analysis 17-Offset_PP2,No Response From Subnet Component,4
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,4
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,4
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,4
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,4
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,4
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,4
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,4
IDE80017-ENG289603-Analysis 17-Offset_T1,No Response From Subnet Component,4
IDE80017-ENG289604-Analysis 17-Offset_T2,No Response From Subnet Component,4
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,4
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,4
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,4
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,4
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,4
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,4
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,4
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,4
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,4
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,4
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,4
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,4
IDE80018-ENG289601-Analysis 18-Offset_PP1,No Response From Subnet Component,4
IDE80018-ENG289602-Analysis 18-Offset_PP2,No Response From Subnet Component,4
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,4
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,4
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,4
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,4
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,4
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,4
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,4
IDE80018-ENG289603-Analysis 18-Offset_T1,No Response From Subnet Component,4
IDE80018-ENG289604-Analysis 18-Offset_T2,No Response From Subnet Component,4
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,4
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,4
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,4
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,4
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,4
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,4
MAS05055-lower turn position,12.010977 °,2
MAS05056-upper turn position,148.010842 °,2
MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),On ,3
MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),On ,3
MAS05807-ENG264069-Coding-APS bei Abparken (1bit),OFF ,3
MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),OFF ,3
MAS05807-ENG264071-Coding-APS für 100 Zyklen deaktiv (1bit),OFF ,3
MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),OFF ,3
MAS05807-ENG264178-Coding-geräusch optimierte Wischkennlinie (1bit),OFF ,3
MAS05807-ENG264181-Coding-langsames Abparken (1bit),OFF ,3
MAS05807-ENG264190-Coding-Produktionsmodus möglich (1bit),OFF ,3
MAS05807-ENG264192-Coding-Regensensoraktivierung über Fahrfreigabe (1bit),On ,3
MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),On ,3
MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),On ,3
MAS05807-ENG264271-Coding-softe Geschwindigkeitsrückschaltung (1bit),On ,3
MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),OFF ,3
MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),OFF ,3
MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),On ,3
MAS05807-ENG264276-Coding-Tränenwischen (1bit),On ,3
MAS05807-ENG264279-Coding-v-abhängige Wischstufenrückschaltung (1bit),On ,3
MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),OFF ,3
MAS05894-IDE13022-Engine run on-Function activation,not active ,4
MAS05894-MAS13391-Engine run on-Delay time timer,400 ms,4
MAS07146-MAS13125-Button 1-Function of button 1,not coded / not installed ,1
MAS07146-MAS13128-Button 1-Indicator lamp button 1,installed ,1
MAS07147-MAS13129-Button 2-Function of button 2,not coded / not installed ,1
MAS07147-MAS13131-Button 2-Indicator lamp button 2,installed ,1
MAS07148-MAS13132-Button 3-Function of button 3,not coded / not installed ,1
MAS07148-MAS13134-Button 3-Indicator lamp button 3,installed ,1
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,0 lx,24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,0 lx,24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO,0 lx,24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten,0 lx,24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,0 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung,00 ,24
MAS09325-IDE13878-Daytime running lights-Activation: daytime running lights,Daytime running lights ,8
MAS09325-MAS09335-Daytime running lights-Daytime running lights/parking light,not active ,8
MAS09325-MAS16273-Daytime running lights-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lights-Daytime running indicator lamp,not active ,8
MAS09325-ENG142193-Daytime running lights-Geschwindigkeitsabhaengiges TFL,5 km/h,8
MAS09325-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,8
MAS09325-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,8
MAS09325-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,active ,8
MAS09325-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,8
MAS09325-ENG142192-Daytime running lights-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,8
MAS09325-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,not active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,not active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,not active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,50 ms,8
MAS12382-ENG261058-Dynamic turn signal control-IPA_RPA_Blinkbestätugung,active ,8
MAS12382-ENG260850-Dynamic turn signal control-IPA_RPA_blinken_links,active ,8
MAS12382-ENG258687-Dynamic turn signal control-IPA_RPA_blinken_rechts,active ,8
MAS12382-ENG260708-Dynamic turn signal control-Multikollisions_blinken,not active ,8
MAS12382-ENG122209-Dynamic turn signal control-Notwarn_blinken_NBA_Phase_2,active ,8
MAS12382-ENG122211-Dynamic turn signal control-Richtungs_blinken_links,active ,8
MAS12382-ENG122210-Dynamic turn signal control-Richtungs_blinken_rechts,active ,8
MAS12382-ENG260812-Dynamic turn signal control-SWA_blinken_links,active ,8
MAS12382-ENG260466-Dynamic turn signal control-SWA_blinken_rechts,active ,8
MAS12382-ENG122214-Dynamic turn signal control-Warnblinken_Zuendung_AUS,active ,8
MAS12382-ENG122213-Dynamic turn signal control-Warnblinken_Zuendung_EIN,active ,8
MAS13139-MAS13135-Button 4-Function of button 4,not coded / not installed ,1
MAS13139-MAS13136-Button 4-Indicator lamp button 4,installed ,1
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,No Response From Subnet Component,1
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,No Response From Subnet Component,1
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,No Response From Subnet Component,1
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,No Response From Subnet Component,1
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,No Response From Subnet Component,1
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,No Response From Subnet Component,1
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,No Response From Subnet Component,1
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,No Response From Subnet Component,1
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,No Response From Subnet Component,1
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,No Response From Subnet Component,1
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,No Response From Subnet Component,1
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,No Response From Subnet Component,1
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,No Response From Subnet Component,1
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,No Response From Subnet Component,1
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,No Response From Subnet Component,1
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,No Response From Subnet Component,1
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,No Response From Subnet Component,1
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,No Response From Subnet Component,1
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,No Response From Subnet Component,1
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,No Response From Subnet Component,1
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,No Response From Subnet Component,1
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,No Response From Subnet Component,1
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,No Response From Subnet Component,1
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,No Response From Subnet Component,1
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,No Response From Subnet Component,1
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,No Response From Subnet Component,1
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,No Response From Subnet Component,1
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,No Response From Subnet Component,1
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,No Response From Subnet Component,1
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,No Response From Subnet Component,1
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,No Response From Subnet Component,1
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,No Response From Subnet Component,1
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,No Response From Subnet Component,1
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,No Response From Subnet Component,1
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,No Response From Subnet Component,1
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,No Response From Subnet Component,1
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,No Response From Subnet Component,1
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,No Response From Subnet Component,1
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,No Response From Subnet Component,1
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,No Response From Subnet Component,1
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,No Response From Subnet Component,1
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,No Response From Subnet Component,1
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,No Response From Subnet Component,1
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,No Response From Subnet Component,1
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,No Response From Subnet Component,1
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,No Response From Subnet Component,1
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,No Response From Subnet Component,1
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,No Response From Subnet Component,1
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,No Response From Subnet Component,1
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,No Response From Subnet Component,1
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,No Response From Subnet Component,1
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,No Response From Subnet Component,1
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,No Response From Subnet Component,1
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,No Response From Subnet Component,1
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,No Response From Subnet Component,1
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,No Response From Subnet Component,1
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,No Response From Subnet Component,1
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,No Response From Subnet Component,1
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,No Response From Subnet Component,1
MAS14140-IDE15905-Flashing function-Travel Assist,not active ,4
MAS14140-ENG154601-Flashing function-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,4
MAS14140-ENG259090-Flashing function-Hupen_durch_Fahrerassistenz,active ,4
MAS14140-ENG142029-Flashing function-Warnblinken_durch_Fahrerassistenz,not active ,4
MAS18831-IDE80001-Control module for optical rear lid opening: dataset-Analysis 1,No Response From Subnet Component,4
MAS18831-IDE80002-Control module for optical rear lid opening: dataset-Analysis 2,No Response From Subnet Component,4
MAS18831-IDE80003-Control module for optical rear lid opening: dataset-Analysis 3,No Response From Subnet Component,4
MAS18831-IDE80004-Control module for optical rear lid opening: dataset-Analysis 4,No Response From Subnet Component,4
MAS18831-IDE80005-Control module for optical rear lid opening: dataset-Analysis 5,No Response From Subnet Component,4
MAS18831-IDE80006-Control module for optical rear lid opening: dataset-Analysis 6,No Response From Subnet Component,4
MAS18831-IDE80007-Control module for optical rear lid opening: dataset-Analysis 7,No Response From Subnet Component,4
MAS18831-IDE80008-Control module for optical rear lid opening: dataset-Analysis 8,No Response From Subnet Component,4
MAS18831-IDE80009-Control module for optical rear lid opening: dataset-Analysis 9,No Response From Subnet Component,4
MAS18831-IDE80010-Control module for optical rear lid opening: dataset-Analysis 10,No Response From Subnet Component,4
MAS18831-IDE80011-Control module for optical rear lid opening: dataset-Analysis 11,No Response From Subnet Component,4
MAS18831-IDE80012-Control module for optical rear lid opening: dataset-Analysis 12,No Response From Subnet Component,4
MAS18831-IDE80013-Control module for optical rear lid opening: dataset-Analysis 13,No Response From Subnet Component,4
MAS18831-IDE80014-Control module for optical rear lid opening: dataset-Analysis 14,No Response From Subnet Component,4
MAS18831-IDE80015-Control module for optical rear lid opening: dataset-Analysis 15,No Response From Subnet Component,4
MAS18831-IDE80016-Control module for optical rear lid opening: dataset-Analysis 16,No Response From Subnet Component,4
MAS18831-IDE80017-Control module for optical rear lid opening: dataset-Analysis 17,No Response From Subnet Component,4
MAS18831-IDE80018-Control module for optical rear lid opening: dataset-Analysis 18,No Response From Subnet Component,4
MAS18831-IDE80019-Control module for optical rear lid opening: dataset-Analysis 19,No Response From Subnet Component,4
MAS18831-IDE80020-Control module for optical rear lid opening: dataset-Analysis 20,No Response From Subnet Component,4
MAS18831-IDE80021-Control module for optical rear lid opening: dataset-Analysis 21,No Response From Subnet Component,4
MAS18831-IDE80022-Control module for optical rear lid opening: dataset-Analysis 22,No Response From Subnet Component,4
MAS18831-IDE80023-Control module for optical rear lid opening: dataset-Analysis 23,No Response From Subnet Component,4
MAS18831-IDE80024-Control module for optical rear lid opening: dataset-Analysis 24,No Response From Subnet Component,4
MAS18831-IDE80025-Control module for optical rear lid opening: dataset-Analysis 25,No Response From Subnet Component,4
MAS18831-IDE80026-Control module for optical rear lid opening: dataset-Analysis 26,No Response From Subnet Component,4
MAS18831-IDE80027-Control module for optical rear lid opening: dataset-Analysis 27,No Response From Subnet Component,4
MAS18831-IDE80028-Control module for optical rear lid opening: dataset-Analysis 28,No Response From Subnet Component,4
MAS18831-IDE80029-Control module for optical rear lid opening: dataset-Analysis 29,No Response From Subnet Component,4
MAS18831-IDE80030-Control module for optical rear lid opening: dataset-Analysis 30,No Response From Subnet Component,4
MAS18831-IDE80031-Control module for optical rear lid opening: dataset-Analysis 31,No Response From Subnet Component,4
MAS18831-IDE80032-Control module for optical rear lid opening: dataset-Analysis 32,No Response From Subnet Component,4
MAS18831-IDE80033-Control module for optical rear lid opening: dataset-Analysis 33,No Response From Subnet Component,4
MAS18831-IDE80034-Control module for optical rear lid opening: dataset-Analysis 34,No Response From Subnet Component,4
MAS18831-IDE80035-Control module for optical rear lid opening: dataset-Analysis 35,No Response From Subnet Component,4
MAS18831-IDE80036-Control module for optical rear lid opening: dataset-Analysis 36,No Response From Subnet Component,4
MAS18831-IDE80037-Control module for optical rear lid opening: dataset-Analysis 37,No Response From Subnet Component,4
MAS18831-IDE80038-Control module for optical rear lid opening: dataset-Analysis 38,No Response From Subnet Component,4
MAS18831-IDE80039-Control module for optical rear lid opening: dataset-Analysis 39,No Response From Subnet Component,4
MAS18831-IDE80040-Control module for optical rear lid opening: dataset-Analysis 40,No Response From Subnet Component,4
MAS18831-IDE80041-Control module for optical rear lid opening: dataset-Analysis 41,No Response From Subnet Component,4
MAS18831-IDE80042-Control module for optical rear lid opening: dataset-Analysis 42,No Response From Subnet Component,4
MAS18831-IDE80043-Control module for optical rear lid opening: dataset-Analysis 43,No Response From Subnet Component,4
MAS18831-IDE80044-Control module for optical rear lid opening: dataset-Analysis 44,No Response From Subnet Component,4
MAS18831-IDE80045-Control module for optical rear lid opening: dataset-Analysis 45,No Response From Subnet Component,4
MAS18831-IDE80046-Control module for optical rear lid opening: dataset-Analysis 46,No Response From Subnet Component,4
MAS18831-IDE80047-Control module for optical rear lid opening: dataset-Analysis 47,No Response From Subnet Component,4
MAS18831-IDE80048-Control module for optical rear lid opening: dataset-Analysis 48,No Response From Subnet Component,4
MAS18831-IDE80049-Control module for optical rear lid opening: dataset-Analysis 49,No Response From Subnet Component,4
MAS18831-IDE80050-Control module for optical rear lid opening: dataset-Analysis 50,No Response From Subnet Component,4
MAS18831-IDE80051-Control module for optical rear lid opening: dataset-Analysis 51,No Response From Subnet Component,4
MAS18831-IDE80052-Control module for optical rear lid opening: dataset-Analysis 52,No Response From Subnet Component,4
MAS18831-IDE80053-Control module for optical rear lid opening: dataset-Analysis 53,No Response From Subnet Component,4
MAS18831-IDE80054-Control module for optical rear lid opening: dataset-Analysis 54,No Response From Subnet Component,4
MAS18831-IDE80055-Control module for optical rear lid opening: dataset-Analysis 55,No Response From Subnet Component,4
MAS18831-IDE80056-Control module for optical rear lid opening: dataset-Analysis 56,No Response From Subnet Component,4
MAS18831-IDE80057-Control module for optical rear lid opening: dataset-Analysis 57,No Response From Subnet Component,4
MAS18831-IDE80058-Control module for optical rear lid opening: dataset-Analysis 58,No Response From Subnet Component,4
MAS18831-IDE80059-Control module for optical rear lid opening: dataset-Analysis 59,No Response From Subnet Component,4
MAS18831-IDE80060-Control module for optical rear lid opening: dataset-Analysis 60,No Response From Subnet Component,4
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
SFT00061-MAS10520-Special Function-Special function 1,not installed ,4
SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,4
ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,4
ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,4
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,0 ,9
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,0 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,17476 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,17476 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,0.0 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,not active ,270
ENG253358-ENG289605-Anpassungen_Exterior_Light-p_vip30_Dimmung_SalR,00 ,270
ENG253358-ENG289606-Anpassungen_Exterior_Light-p_vip30_Dimmung_TSG,3C ,270
ENG253358-ENG289607-Anpassungen_Exterior_Light-p_vip30_Dimmzeit,100 ms,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,not active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,not active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,1310.70 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,not active ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,not active ,270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung,not active ,8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,No ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,00 ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,00 ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,00 ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,00 ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,00 ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,00 ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,not active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,not active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,not activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,not activated ,4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,not activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,not activated ,4
ENG253240-ENG263541-Automatisierte Abschaltungen-Abschalt_verzögerungs_zeit,60 s,8
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8
ENG253240-ENG259987-Automatisierte Abschaltungen-Abschaltung nur in P,Alle Fahrstufen ,8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer für Ausführung des Abschaltwunsch an SPN,2.0 s,8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verfügbarkeit Komfortabschaltung,Available ,8
ENG253240-ENG258110-Automatisierte Abschaltungen-Zündungsabschaltung über Energiemanagement,Available ,8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG253018-Clamp_Control,Driver´s door ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,100 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,200 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,100 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,100 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG253350-ENG258402-Coding_seat_pneumatics_driver_side-Function_easy_entry,No Response From Subnet Component,40
ENG253350-ENG260372-Coding_seat_pneumatics_driver_side-Function_massage,No Response From Subnet Component,40
ENG253350-ENG260893-Coding_seat_pneumatics_driver_side-Function_memory,No Response From Subnet Component,40
ENG253350-ENG261225-Coding_seat_pneumatics_driver_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253350-ENG259055-Coding_seat_pneumatics_driver_side-Function_off_delay,No Response From Subnet Component,40
ENG253350-ENG259290-Coding_seat_pneumatics_driver_side-Function_personalisation,No Response From Subnet Component,40
ENG253350-ENG259372-Coding_seat_pneumatics_driver_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253350-ENG259654-Coding_seat_pneumatics_driver_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253350-ENG259159-Coding_seat_pneumatics_driver_side-Function_race_mode,No Response From Subnet Component,40
ENG253350-ENG261329-Coding_seat_pneumatics_driver_side-Function_side_support,No Response From Subnet Component,40
ENG253350-ENG258695-Coding_seat_pneumatics_driver_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253175-ENG258402-Coding_seat_pneumatics_passenger_side-Function_easy_entry,No Response From Subnet Component,40
ENG253175-ENG260372-Coding_seat_pneumatics_passenger_side-Function_massage,No Response From Subnet Component,40
ENG253175-ENG260893-Coding_seat_pneumatics_passenger_side-Function_memory,No Response From Subnet Component,40
ENG253175-ENG261225-Coding_seat_pneumatics_passenger_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253175-ENG259055-Coding_seat_pneumatics_passenger_side-Function_off_delay,No Response From Subnet Component,40
ENG253175-ENG259290-Coding_seat_pneumatics_passenger_side-Function_personalisation,No Response From Subnet Component,40
ENG253175-ENG259372-Coding_seat_pneumatics_passenger_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253175-ENG259654-Coding_seat_pneumatics_passenger_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253175-ENG259159-Coding_seat_pneumatics_passenger_side-Function_race_mode,No Response From Subnet Component,40
ENG253175-ENG261329-Coding_seat_pneumatics_passenger_side-Function_side_support,No Response From Subnet Component,40
ENG253175-ENG258695-Coding_seat_pneumatics_passenger_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253229-ENG258467-Define_Const-Dimm2Bin,50 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,not_activated ,6
ENG253216-ENG277085-DevCod_Automatische_Verriegelung-Automatische_FunktionBeiAnnaeherung_Entfernung_aktiv,activated ,6
ENG253028-DevCod_Bedienstellen,not activated ,1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,not activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,not activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,not activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,not activated ,6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering assignment,Left ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schließverhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,activated ,6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,activated ,6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,not activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv,not activated ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetür,activated ,6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,not installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-Diebstahlschutz.Modulsoftware-,not active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,not active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,10_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,not activated ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,21
ENG179017-ENG125667-Driver_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125666-Driver_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125668-Driver_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125673-Driver_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125672-Driver_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125674-Driver_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125670-Driver_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125669-Driver_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125671-Driver_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125676-Driver_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125675-Driver_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125677-Driver_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125664-Driver_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125663-Driver_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125665-Driver_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125667-Driver_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125666-Driver_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125668-Driver_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125673-Driver_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125672-Driver_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125674-Driver_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125670-Driver_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125669-Driver_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125671-Driver_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125676-Driver_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125675-Driver_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125677-Driver_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125664-Driver_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125663-Driver_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125665-Driver_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125667-Driver_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125666-Driver_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125668-Driver_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125673-Driver_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125672-Driver_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125674-Driver_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125670-Driver_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125669-Driver_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125671-Driver_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125676-Driver_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125675-Driver_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125677-Driver_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125664-Driver_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125663-Driver_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125665-Driver_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,21
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,21
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,21
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,21
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,21
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,21
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,21
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,21
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,21
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,21
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,21
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,21
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,21
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,21
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,21
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,21
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,21
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,21
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,21
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,21
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,21
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,21
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,21
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,21
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,21
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,21
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,21
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,21
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,21
ENG286142-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,21
ENG286142-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,21
ENG286142-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,21
ENG286142-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,21
ENG286142-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,21
ENG286142-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,21
ENG286142-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,21
ENG286142-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,21
ENG286142-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,21
ENG286142-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,21
ENG286142-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,21
ENG286142-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,21
ENG286142-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,21
ENG286142-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,21
ENG286142-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,21
ENG286142-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,21
ENG286142-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,21
ENG286142-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,21
ENG286142-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,21
ENG286142-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,21
ENG286142-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,21
ENG286142-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,21
ENG286142-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,21
ENG286142-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,21
ENG286142-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,21
ENG286142-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,21
ENG286142-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,21
ENG286142-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,21
ENG286142-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,21
ENG286142-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,21
ENG286142-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,21
ENG286142-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,21
ENG286142-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,21
ENG286142-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,21
ENG286142-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,21
ENG286142-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,21
ENG286142-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,21
ENG286142-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,21
ENG286142-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,21
ENG286142-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,21
ENG286142-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,21
ENG286142-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,21
ENG286142-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,21
ENG286142-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,21
ENG286142-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,21
ENG286142-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,21
ENG286142-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,21
ENG286142-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,21
ENG286142-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,21
ENG286142-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,21
ENG286142-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,21
ENG286142-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,21
ENG286142-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,21
ENG286142-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,21
ENG286142-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,21
ENG286142-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,21
ENG286142-IDE80057-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,21
ENG286142-IDE80058-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,21
ENG286142-IDE80059-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,21
ENG286142-IDE80060-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,21
ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,21
ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,21
ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,21
ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,21
ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,21
ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,21
ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,21
ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,21
ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,21
ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,21
ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,21
ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,21
ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,21
ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,21
ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,21
ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,21
ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,21
ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,21
ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,21
ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,21
ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,21
ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,21
ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,21
ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,21
ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,21
ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,21
ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,21
ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,21
ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,21
ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,21
ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,21
ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,21
ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,21
ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,21
ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,21
ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,21
ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,21
ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,21
ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,21
ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,21
ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,21
ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,21
ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,21
ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,21
ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,21
ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,21
ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,21
ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,21
ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,21
ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,21
ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,21
ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,21
ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,21
ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,21
ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,21
ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,21
ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,21
ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,21
ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,21
ENG253243-ENG286261-Easy Open-p_a_Schiebetürentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,not active ,4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,not active ,4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_15,not active ,4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_S,not active ,4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Motorlauf,not active ,4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,15 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,50 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,10 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,not activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,not activated ,4
ENG122934-erase_error_table,00 00 00 ,3
ENG122933-error_mask,00 00 ,2
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach,active ,4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ,LIN ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,not active ,6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Keine_Spannungsanforderung ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,0 ms,6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,immer Wischerstopp ,6
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
ENG117283-ENG263535-Frontwaschfunktion-Waschfrequenz_bei_LSS_aus,35 ,2
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4
ENG171911-ENG141957-Funk-Radio freq.,MQB37w: 434 MHz RdW + NAR (2-kanalig) ,4
ENG253288-Grundparameter SPN-,10000 ms,30
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30
ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung,Always ,8
ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden,Always ,8
ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit,not installed ,8
ENG141645-MAS00212-HW_Verbau-Washer fluid low,installed ,8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8
ENG141645-ENG152427-HW_Verbau-Rear window defogger,not installed ,8
ENG253080-IAA Nutzermanagement,installed ,1
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,not activated ,4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4
ENG253070-MAS14172-Intelligente Heckleuchte-Parametierung-Brake light larger area,active ,23
ENG253070-MAS14173-Intelligente Heckleuchte-Parametierung-Brake light smaller area,active ,23
ENG253070-ENG259403-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Aktivierung,0.00 m,23
ENG253070-ENG260952-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Deaktivierung,0.00 m,23
ENG253070-ENG259366-Intelligente Heckleuchte-Parametierung-p_adaptive_helligkeitsanpassung,active ,23
ENG253070-ENG260454-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_dauer,10 ms,23
ENG253070-ENG260199-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_schwelle,-16.00000 m/s²,23
ENG253070-ENG260962-Intelligente Heckleuchte-Parametierung-p_CHO_LHO_statisch,not active ,23
ENG253070-ENG259731-Intelligente Heckleuchte-Parametierung-p_LH_Diag_LED_def_inaktiv,not active ,23
ENG253070-ENG259241-Intelligente Heckleuchte-Parametierung-p_LH_Diag_Status_def_inaktiv,not active ,23
ENG253070-ENG260043-Intelligente Heckleuchte-Parametierung-p_LH_zusatzschlussl_def_deaktiv,not active ,23
ENG253070-ENG260406-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_dunkel,4000 lx,23
ENG253070-ENG260839-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_hoch,50000 lx,23
ENG253070-ENG258451-Intelligente Heckleuchte-Parametierung-p_SHL_Anim_LTM_Auto,not active ,23
ENG253070-ENG259407-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15aus,0 ,23
ENG253070-ENG260457-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15ein,0 ,23
ENG253070-ENG259766-Intelligente Heckleuchte-Parametierung-p_SHL_dynamisch,not active ,23
ENG253070-ENG258437-Intelligente Heckleuchte-Parametierung-p_v_BRL_Aktivierung,20 km/h,23
ENG253070-ENG258439-Intelligente Heckleuchte-Parametierung-p_v_BRL_Deaktivierung,10 km/h,23
ENG253070-ENG261315-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_aus,60 km/h,23
ENG253070-ENG259510-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_ein,75 km/h,23
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,0 ,4
ENG253039-MAS21321-Intelligente Heckleuchte-Verbau-Audi parking system installed,not installed ,4
ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-Left taillight 1,installed ,4
ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-Left taillight 2,installed ,4
ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right taillight 1,installed ,4
ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right taillight 2,installed ,4
ENG253039-ENG261019-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_KZL_iSBBR,not active ,4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,not active ,4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,01 ,96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,01 ,96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,01 ,96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,100 %,96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,100 %,96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,100 %,96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,100 %,96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,100 %,96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,100 %,96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,100 %,96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,100 %,96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,100 %,96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,100 %,96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,100 %,96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,100 %,96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,100 %,96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,100 %,96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,100 %,96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,01 ,96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,01 ,96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,not active ,96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,02 ,96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,01 ,96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,01 ,96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,00 ,96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,00 ,96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,00 ,96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,00 ,96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,00 ,96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,00 ,96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,00 ,96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,00 ,96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,00 ,96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,00 ,96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,01 ,96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,00 ,96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,00 ,96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,00 ,96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,00 ,96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,00 ,96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,00 ,96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,00 ,96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,00 ,96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,00 ,96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,00 ,96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,01 ,96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,00 ,96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,00 ,96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,00 ,96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,00 ,96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,00 ,96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,00 ,96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,00 ,96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,00 ,96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,00 ,96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,00 ,96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,00 ,96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,00 ,96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,00 ,96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,00 ,96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,00 ,96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,00 ,96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,00 ,96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,00 ,96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,00 ,96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,00 ,96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,00 ,96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,01 ,96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,00 ,96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,00 ,96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,00 ,96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,00 ,96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,00 ,96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,00 ,96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,00 ,96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,00 ,96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,00 ,96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,00 ,96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,00 ,96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,00 ,96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,00 ,96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,00 ,96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,00 ,96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,00 ,96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,00 ,96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,00 ,96
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,active ,16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,active ,9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,not active ,9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,not active ,9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,active ,9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,active ,9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,active ,9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,not active ,9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,not active ,9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,not active ,9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,not active ,9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,not active ,9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,active ,9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,not active ,9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,not active ,9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,not active ,9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,not active ,9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,not active ,9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,not active ,9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,not active ,9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,not active ,9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,not active ,9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,not active ,9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,active ,9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,not active ,9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,not active ,9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,not active ,9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,not active ,9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,not active ,9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,not active ,9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,not active ,9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,not active ,9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,not active ,9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,not active ,9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,active ,9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,not active ,9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,not active ,9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,not active ,9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,not active ,9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,not active ,9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,not active ,9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,not active ,9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,not active ,9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,not active ,9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,not active ,9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,active ,9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,not active ,9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,not active ,9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,not active ,9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,not active ,9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,not active ,9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,not active ,9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,not active ,9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,not active ,9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,not active ,9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,not active ,9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,active ,9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,not active ,9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,not active ,9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,not active ,9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,not active ,9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,not active ,9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,not active ,9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,not active ,9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,not active ,9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,not active ,9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,not active ,9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,active ,9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,not active ,9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,not active ,9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,not active ,9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,not active ,14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,active ,14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,not active ,14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,not active ,14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,03 ,14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,active ,14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,active ,14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 10 00 00 00 04 00 00 00 20 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 1C 70 00 ,100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,46 ,100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,46 ,100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,46 ,100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,46 ,100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,46 ,100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,46 ,100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,46 ,100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,46 ,100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,active ,100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,08 92 0C 69 ,100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,active ,100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,not active ,100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,active ,100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,active ,100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,active ,100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,active ,100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,active ,100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,active ,100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,01 ,100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,not active ,100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,00 ,100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,00 ,100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,00 ,100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,00 ,100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,00 ,100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,00 ,100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,00 ,100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,00 ,100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,03 ,100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,02 ,100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,00 ,100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,03 ,100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,00 ,100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,00 ,100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,00 ,100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,03 ,100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,02 ,100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,00 ,100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,03 ,100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,00 ,100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,00 ,100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,00 ,100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,03 ,100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,03 ,100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,00 ,100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,02 ,100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,00 ,100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,00 ,100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,00 ,100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,00 ,100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,03 ,100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,00 ,100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,02 ,100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,00 ,100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,00 ,100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,00 ,100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,00 ,100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,00 ,100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,00 ,100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,00 ,100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,00 ,100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,0 s,100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,active ,100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,08 92 0C 69 ,100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,01 ,100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,not active ,100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,active ,100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,active ,100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,active ,100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,active ,100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,13 ,100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,07 ,100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,15 ,100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,05 ,100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,FF ,100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100
ENG253355-Interior_light_interface_function,No_voltage_requirement ,1
ENG253312-ENG297177-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_1,00 ,51
ENG253312-ENG297178-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_10,00 ,51
ENG253312-ENG297179-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_11,00 ,51
ENG253312-ENG297180-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_12,00 ,51
ENG253312-ENG297181-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_13,00 ,51
ENG253312-ENG297182-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_14,00 ,51
ENG253312-ENG297183-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_15,00 ,51
ENG253312-ENG297184-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_2,00 ,51
ENG253312-ENG297185-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_3,00 ,51
ENG253312-ENG297186-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_4,00 ,51
ENG253312-ENG297187-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_5,00 ,51
ENG253312-ENG297188-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_6,00 ,51
ENG253312-ENG297189-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_7,00 ,51
ENG253312-ENG297190-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_8,00 ,51
ENG253312-ENG297191-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_9,00 ,51
ENG253312-ENG297192-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_1,00 ,51
ENG253312-ENG297193-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_10,A1 ,51
ENG253312-ENG297194-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_11,A2 ,51
ENG253312-ENG297195-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_12,A3 ,51
ENG253312-ENG297196-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_13,00 ,51
ENG253312-ENG297197-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_14,00 ,51
ENG253312-ENG297198-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_15,00 ,51
ENG253312-ENG297199-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_2,00 ,51
ENG253312-ENG297200-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_3,04 ,51
ENG253312-ENG297201-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_4,00 ,51
ENG253312-ENG297202-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_5,1C ,51
ENG253312-ENG297203-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_6,61 ,51
ENG253312-ENG297204-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_7,6F ,51
ENG253312-ENG297205-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_8,70 ,51
ENG253312-ENG297206-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_9,A0 ,51
ENG253312-ENG297207-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_1,00 ,51
ENG253312-ENG297208-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_10,00 ,51
ENG253312-ENG297209-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_11,00 ,51
ENG253312-ENG297210-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_12,00 ,51
ENG253312-ENG297211-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_13,00 ,51
ENG253312-ENG297212-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_14,00 ,51
ENG253312-ENG297213-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_15,00 ,51
ENG253312-ENG297214-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_2,00 ,51
ENG253312-ENG297215-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_3,00 ,51
ENG253312-ENG297216-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_4,00 ,51
ENG253312-ENG297217-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_5,00 ,51
ENG253312-ENG297218-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_6,00 ,51
ENG253312-ENG297219-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_7,00 ,51
ENG253312-ENG297220-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_8,00 ,51
ENG253312-ENG297221-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_9,00 ,51
ENG253312-ENG297222-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_1,Offset_0 ,51
ENG253312-ENG297223-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_10,Offset_0 ,51
ENG253312-ENG297224-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_11,Offset_0 ,51
ENG253312-ENG297225-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_12,Offset_0 ,51
ENG253312-ENG297226-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_13,Offset_0 ,51
ENG253312-ENG297227-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_14,Offset_0 ,51
ENG253312-ENG297228-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_15,Offset_0 ,51
ENG253312-ENG297229-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_2,Offset_0 ,51
ENG253312-ENG297230-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_3,Offset_0 ,51
ENG253312-ENG297231-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_4,Offset_0 ,51
ENG253312-ENG297232-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_5,Offset_0 ,51
ENG253312-ENG297233-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_6,Offset_0 ,51
ENG253312-ENG297234-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_7,Offset_0 ,51
ENG253312-ENG297235-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_8,Offset_0 ,51
ENG253312-ENG297236-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_9,Offset_0 ,51
ENG253312-ENG297237-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_1,Offset_0 ,51
ENG253312-ENG297238-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_10,Offset_0 ,51
ENG253312-ENG297239-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_11,Offset_0 ,51
ENG253312-ENG297240-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_12,Offset_0 ,51
ENG253312-ENG297241-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_13,Offset_0 ,51
ENG253312-ENG297242-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_14,Offset_0 ,51
ENG253312-ENG297243-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_15,Offset_0 ,51
ENG253312-ENG297244-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_2,Offset_0 ,51
ENG253312-ENG297245-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_3,Offset_0 ,51
ENG253312-ENG297246-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_4,Offset_0 ,51
ENG253312-ENG297247-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_5,Offset_0 ,51
ENG253312-ENG297248-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_6,Offset_0 ,51
ENG253312-ENG297249-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_7,Offset_0 ,51
ENG253312-ENG297250-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_8,Offset_0 ,51
ENG253312-ENG297251-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_9,Offset_0 ,51
ENG253312-ENG297252-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_1,Offset_0 ,51
ENG253312-ENG297253-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_10,Offset_0 ,51
ENG253312-ENG297254-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_11,Offset_0 ,51
ENG253312-ENG297255-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_12,Offset_0 ,51
ENG253312-ENG297256-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_13,Offset_0 ,51
ENG253312-ENG297257-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_14,Offset_0 ,51
ENG253312-ENG297258-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_15,Offset_0 ,51
ENG253312-ENG297259-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_2,Offset_0 ,51
ENG253312-ENG297260-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_3,Offset_0 ,51
ENG253312-ENG297261-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_4,Offset_0 ,51
ENG253312-ENG297262-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_5,Offset_0 ,51
ENG253312-ENG297263-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_6,Offset_0 ,51
ENG253312-ENG297264-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_7,Offset_0 ,51
ENG253312-ENG297265-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_8,Offset_0 ,51
ENG253312-ENG297266-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_9,Offset_0 ,51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,0E ,93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,00 ,93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,FF ,93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,00 ,93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,66 ,93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,67 ,93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,00 ,93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,00 ,93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,00 ,93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,00 ,93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,00 ,93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,00 ,93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,00 ,93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,00 ,93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,00 ,93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,00 ,93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,00 ,93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,00 ,93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,00 ,93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,02 ,93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,00 ,93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,03 ,93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,05 ,93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,06 ,93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,07 ,93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,04 ,93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,00 ,93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,00 ,93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,00 ,93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,00 ,93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,00 ,93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,00 ,93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,00 ,93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,00 ,93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,00 ,93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,00 ,93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,0D ,93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,0D ,93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,0C ,93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,0C ,93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,65 ,93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,FF ,93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,67 ,93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,65 ,93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,00 ,93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,65 ,93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,FF ,93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,66 ,93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,65 ,93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,00 ,93
ENG276127-Interior_Monitoring_Data_Set2,No Response From Subnet Component,93
ENG253388-ENG247388-Kessyfunktion-beeptime_reunlock,5_ms ,4
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,not active ,4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4
ENG253388-ENG248300-Kessyfunktion-reunlock_beep,not active ,4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4
ENG172886-MAS10514-lcm-Expanded high beam control,High beam assistant ,4
ENG172886-ENG142185-lcm-LCM_blinker,true ,4
ENG172886-ENG142034-lcm-Light_Control_Module,not installed ,4
ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0,maximize ,20
ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0,maximize ,20
ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0,maximize ,20
ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0,100 ,20
ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0,0 ,20
ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0,0 ,20
ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0,0 ,20
ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0,14 ,20
ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0,34 ,20
ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0,Blinkleuchten ,20
ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0,Always ,20
ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0,Blinken links Hellphase ,20
ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0,not active ,20
ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0,not active ,20
ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0,not active ,20
ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0,not active ,20
ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0,not active ,20
ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0,not active ,20
ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0,not active ,20
ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0,not active ,20
ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0,not active ,20
ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0,not active ,20
ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0,not active ,20
ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1,maximize ,20
ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1,maximize ,20
ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1,maximize ,20
ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1,100 ,20
ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1,0 ,20
ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1,0 ,20
ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1,0 ,20
ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1,15 ,20
ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1,3E ,20
ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1,Blinkleuchten ,20
ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1,Always ,20
ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1,Blinken rechts Hellphase ,20
ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1,not active ,20
ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1,not active ,20
ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1,not active ,20
ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1,not active ,20
ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1,not active ,20
ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1,not active ,20
ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1,not active ,20
ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1,not active ,20
ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1,not active ,20
ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1,not active ,20
ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1,not active ,20
ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10,maximize ,20
ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10,maximize ,20
ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10,maximize ,20
ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10,0 ,20
ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10,0 ,20
ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10,0 ,20
ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10,0 ,20
ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,20
ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10,00 ,20
ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10,not_active ,20
ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10,Always ,20
ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10,not active ,20
ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10,not active ,20
ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10,not active ,20
ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10,not active ,20
ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10,not active ,20
ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10,not active ,20
ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10,not active ,20
ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10,not active ,20
ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10,not active ,20
ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10,not active ,20
ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10,not active ,20
ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10,not active ,20
ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11,maximize ,20
ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11,maximize ,20
ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11,maximize ,20
ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11,0 ,20
ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11,0 ,20
ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11,0 ,20
ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11,0 ,20
ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,20
ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11,00 ,20
ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11,not_active ,20
ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11,Always ,20
ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11,not active ,20
ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11,not active ,20
ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11,not active ,20
ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11,not active ,20
ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11,not active ,20
ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11,not active ,20
ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11,not active ,20
ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11,not active ,20
ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11,not active ,20
ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11,not active ,20
ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11,not active ,20
ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11,not active ,20
ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12,maximize ,20
ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12,maximize ,20
ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12,maximize ,20
ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12,100 ,20
ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12,0 ,20
ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12,0 ,20
ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12,0 ,20
ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12,24 ,20
ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12,38 ,20
ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12,LED_Tagfahrlicht_modul_Signal ,20
ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12,Always ,20
ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12,Nebellicht links ,20
ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,Abbiegelicht links ,20
ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12,not active ,20
ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12,not active ,20
ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12,not active ,20
ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12,not active ,20
ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12,not active ,20
ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12,not active ,20
ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12,not active ,20
ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12,not active ,20
ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12,not active ,20
ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12,not active ,20
ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13,maximize ,20
ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13,maximize ,20
ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13,maximize ,20
ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13,100 ,20
ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13,0 ,20
ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13,0 ,20
ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13,0 ,20
ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13,25 ,20
ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13,42 ,20
ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13,LED_Tagfahrlicht_modul_Signal ,20
ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13,Always ,20
ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13,Nebellicht rechts ,20
ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,Abbiegelicht rechts ,20
ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13,not active ,20
ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13,not active ,20
ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13,not active ,20
ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13,not active ,20
ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13,not active ,20
ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13,not active ,20
ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13,not active ,20
ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13,not active ,20
ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13,not active ,20
ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13,not active ,20
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,127 ,20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,22 ,20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,38 ,20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,LED_Tagfahrlicht_modul_Versorgung ,20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,Nebellicht links ,20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,Abbiegelicht links ,20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,127 ,20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,23 ,20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,42 ,20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,LED_Tagfahrlicht_modul_Versorgung ,20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,Nebellicht rechts ,20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,Abbiegelicht rechts ,20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,maximize ,20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,127 ,20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,0 ,20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,08 ,20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,Blinken links Hellphase ,20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,Quittierungsfunktion1 ,20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,not active ,20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,not active ,20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,maximize ,20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,127 ,20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,0 ,20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,18 ,20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,18 ,20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,Blinken rechts Hellphase ,20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,Quittierungsfunktion1 ,20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,not active ,20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,not active ,20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20
ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2,maximize ,20
ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2,maximize ,20
ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2,maximize ,20
ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2,28 ,20
ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2,100 ,20
ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2,0 ,20
ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2,0 ,20
ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2,4A ,20
ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2,48 ,20
ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2,LED_Tagfahrlicht_modul_Signal ,20
ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2,Always ,20
ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2,Position lamps ,20
ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2,Parking light left ,20
ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2,not active ,20
ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2,Daytime running lights ,20
ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2,not active ,20
ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2,not active ,20
ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2,not active ,20
ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2,not active ,20
ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2,not active ,20
ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2,not active ,20
ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2,not active ,20
ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2,not active ,20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,maximize ,20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,maximize ,20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,maximize ,20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,127 ,20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,0 ,20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,0 ,20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,09 ,20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,LED_Bremsleuchten ,20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,Brake lamp ,20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,not active ,20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,not active ,20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,not active ,20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,not active ,20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,maximize ,20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,maximize ,20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,maximize ,20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,127 ,20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,0 ,20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,0 ,20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,19 ,20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,LED_Bremsleuchten ,20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,Brake lamp ,20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,not active ,20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,not active ,20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,not active ,20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,not active ,20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,29 ,20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20
ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32,maximize ,20
ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32,maximize ,20
ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32,maximize ,20
ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32,127 ,20
ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32,0 ,20
ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32,0 ,20
ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32,0 ,20
ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32,29 ,20
ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32,11 ,20
ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32,LIN_SBBR_Versorgung_OL_Appl_55 ,20
ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32,Always ,20
ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32,LED-Heckleuchte Versorgung ,20
ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32,not active ,20
ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32,not active ,20
ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32,not active ,20
ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32,not active ,20
ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32,not active ,20
ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32,not active ,20
ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32,not active ,20
ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32,not active ,20
ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32,not active ,20
ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32,not active ,20
ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32,not active ,20
ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24,maximize ,20
ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24,maximize ,20
ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24,maximize ,20
ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24,127 ,20
ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24,0 ,20
ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24,0 ,20
ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24,0 ,20
ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,20
ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24,21 ,20
ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24,LIN_SBBR_Versorgung_OL_Appl_55 ,20
ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24,Always ,20
ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24,LED-Heckleuchte Versorgung ,20
ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24,not active ,20
ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24,not active ,20
ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24,not active ,20
ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24,not active ,20
ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24,not active ,20
ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24,not active ,20
ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24,not active ,20
ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24,not active ,20
ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24,not active ,20
ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24,not active ,20
ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24,not active ,20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,127 ,20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,0 ,20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,28 ,20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allg_LED_mit_Open_Load_Diagnose_ohne_PWM ,20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Position lamps ,20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,not active ,20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20
ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26,maximize ,20
ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26,maximize ,20
ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26,maximize ,20
ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26,0 ,20
ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26,0 ,20
ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26,0 ,20
ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26,0 ,20
ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,20
ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26,00 ,20
ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26,not_active ,20
ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26,Always ,20
ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26,not active ,20
ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26,not active ,20
ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26,not active ,20
ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26,not active ,20
ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26,not active ,20
ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26,not active ,20
ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26,not active ,20
ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26,not active ,20
ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26,not active ,20
ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26,not active ,20
ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26,not active ,20
ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26,not active ,20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,0 ,20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,00 ,20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,not_active ,20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,not active ,20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20
ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28,maximize ,20
ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28,maximize ,20
ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28,maximize ,20
ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28,0 ,20
ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28,0 ,20
ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28,0 ,20
ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28,0 ,20
ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28,00 ,20
ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28,00 ,20
ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28,not_active ,20
ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28,Always ,20
ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28,not active ,20
ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28,not active ,20
ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28,not active ,20
ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28,not active ,20
ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28,not active ,20
ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28,not active ,20
ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28,not active ,20
ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28,not active ,20
ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28,not active ,20
ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28,not active ,20
ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28,not active ,20
ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28,not active ,20
ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29,maximize ,20
ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29,maximize ,20
ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29,maximize ,20
ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29,127 ,20
ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29,0 ,20
ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29,0 ,20
ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29,0 ,20
ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29,31 ,20
ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29,00 ,20
ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29,LED_Tagfahrlicht_modul_Signal ,20
ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29,Always ,20
ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29,Rueckfahrlicht ,20
ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29,not active ,20
ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29,not active ,20
ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29,not active ,20
ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29,not active ,20
ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29,not active ,20
ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29,not active ,20
ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29,not active ,20
ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29,not active ,20
ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29,not active ,20
ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29,not active ,20
ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29,not active ,20
ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3,maximize ,20
ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3,maximize ,20
ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3,maximize ,20
ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3,28 ,20
ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3,100 ,20
ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3,0 ,20
ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3,0 ,20
ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3,4C ,20
ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3,4C ,20
ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3,LED_Tagfahrlicht_modul_Signal ,20
ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3,Always ,20
ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3,Position lamps ,20
ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3,Parking light right ,20
ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3,not active ,20
ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3,Daytime running lights ,20
ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3,not active ,20
ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3,not active ,20
ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3,not active ,20
ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3,not active ,20
ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3,not active ,20
ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3,not active ,20
ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3,not active ,20
ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3,not active ,20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,0 ,20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,00 ,20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,not_active ,20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,not active ,20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,100 ,20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,66 ,20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,00 ,20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,Ambientelicht 1 ,20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,00 ,20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,00 ,20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,00 ,20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20
ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35,maximize ,20
ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35,maximize ,20
ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35,maximize ,20
ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35,0 ,20
ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35,0 ,20
ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35,0 ,20
ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35,0 ,20
ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35,00 ,20
ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35,00 ,20
ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35,not_active ,20
ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35,Always ,20
ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35,not active ,20
ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35,not active ,20
ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35,not active ,20
ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35,not active ,20
ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35,not active ,20
ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35,not active ,20
ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35,not active ,20
ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35,not active ,20
ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35,not active ,20
ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35,not active ,20
ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35,not active ,20
ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35,not active ,20
ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36,maximize ,20
ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36,maximize ,20
ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36,maximize ,20
ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36,0 ,20
ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36,0 ,20
ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36,0 ,20
ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36,0 ,20
ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36,00 ,20
ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36,00 ,20
ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36,not_active ,20
ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36,Always ,20
ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36,not active ,20
ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36,not active ,20
ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36,not active ,20
ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36,not active ,20
ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36,not active ,20
ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36,not active ,20
ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36,not active ,20
ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36,not active ,20
ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36,not active ,20
ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36,not active ,20
ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36,not active ,20
ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36,not active ,20
ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37,maximize ,20
ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37,maximize ,20
ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37,maximize ,20
ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37,0 ,20
ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37,0 ,20
ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37,0 ,20
ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37,0 ,20
ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37,00 ,20
ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37,00 ,20
ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37,not_active ,20
ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37,Always ,20
ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37,not active ,20
ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37,not active ,20
ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37,not active ,20
ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37,not active ,20
ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37,not active ,20
ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37,not active ,20
ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37,not active ,20
ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37,not active ,20
ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37,not active ,20
ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37,not active ,20
ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37,not active ,20
ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37,not active ,20
ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38,maximize ,20
ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38,maximize ,20
ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38,maximize ,20
ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38,0 ,20
ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38,0 ,20
ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38,0 ,20
ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38,0 ,20
ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38,00 ,20
ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38,00 ,20
ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38,not_active ,20
ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38,Always ,20
ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38,not active ,20
ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38,not active ,20
ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38,not active ,20
ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38,not active ,20
ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38,not active ,20
ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38,not active ,20
ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38,not active ,20
ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38,not active ,20
ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38,not active ,20
ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38,not active ,20
ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38,not active ,20
ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38,not active ,20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,00 ,20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,00 ,20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20
ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4,maximize ,20
ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4,maximize ,20
ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4,maximize ,20
ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4,127 ,20
ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4,0 ,20
ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4,0 ,20
ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4,0 ,20
ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4,49 ,20
ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4,48 ,20
ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4,LED_Tagfahrlicht_modul_Versorgung ,20
ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4,Always ,20
ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4,Position lamps ,20
ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4,Parking light left ,20
ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4,Daytime running lights ,20
ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4,not active ,20
ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4,not active ,20
ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4,not active ,20
ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4,not active ,20
ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4,not active ,20
ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4,not active ,20
ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4,not active ,20
ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4,not active ,20
ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4,not active ,20
ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40,maximize ,20
ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v,maximize ,20
ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40,maximize ,20
ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40,0 ,20
ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40,0 ,20
ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40,0 ,20
ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40,0 ,20
ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40,00 ,20
ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40,00 ,20
ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40,not_active ,20
ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40,Always ,20
ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40,not active ,20
ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40,not active ,20
ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40,not active ,20
ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40,not active ,20
ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40,not active ,20
ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40,not active ,20
ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40,not active ,20
ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40,not active ,20
ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40,not active ,20
ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40,not active ,20
ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40,not active ,20
ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40,not active ,20
ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41,maximize ,20
ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41,maximize ,20
ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41,maximize ,20
ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41,0 ,20
ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41,0 ,20
ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41,0 ,20
ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41,0 ,20
ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41,00 ,20
ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41,00 ,20
ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41,not_active ,20
ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41,Always ,20
ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41,not active ,20
ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41,not active ,20
ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41,not active ,20
ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41,not active ,20
ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41,not active ,20
ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41,not active ,20
ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41,not active ,20
ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41,not active ,20
ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41,not active ,20
ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41,not active ,20
ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41,not active ,20
ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41,not active ,20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,127 ,20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,55 ,20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,52 ,20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,allgemeine_LED_bis_6W ,20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,Abblendlicht links ,20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,Main beam left ,20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,Headlamp flasher ,20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,127 ,20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,56 ,20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,53 ,20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,allgemeine_LED_bis_6W ,20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,Abblendlicht rechts ,20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,Main beam right ,20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,Headlamp flasher ,20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,85 ,20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,00 ,20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED Lichtmodul ohne Open Load Diagnose ,20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,aktiv100prozent ,20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20
ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45,maximize ,20
ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45,maximize ,20
ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45,maximize ,20
ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45,100 ,20
ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45,0 ,20
ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45,0 ,20
ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45,0 ,20
ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45,00 ,20
ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45,00 ,20
ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20
ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45,Always ,20
ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45,Luggage compartment light ,20
ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45,not active ,20
ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45,not active ,20
ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45,not active ,20
ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45,not active ,20
ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45,not active ,20
ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45,not active ,20
ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45,not active ,20
ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45,not active ,20
ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45,not active ,20
ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45,not active ,20
ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45,not active ,20
ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5,maximize ,20
ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5,maximize ,20
ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5,maximize ,20
ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5,127 ,20
ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5,0 ,20
ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5,0 ,20
ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5,0 ,20
ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5,4B ,20
ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5,4C ,20
ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5,LED_Tagfahrlicht_modul_Versorgung ,20
ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5,Always ,20
ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5,Position lamps ,20
ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5,Parking light right ,20
ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5,Daytime running lights ,20
ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5,not active ,20
ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5,not active ,20
ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5,not active ,20
ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5,not active ,20
ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5,not active ,20
ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5,not active ,20
ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5,not active ,20
ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5,not active ,20
ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5,not active ,20
ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6,maximize ,20
ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6,maximize ,20
ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6,maximize ,20
ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6,127 ,20
ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6,0 ,20
ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6,0 ,20
ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6,0 ,20
ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,20
ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6,36 ,20
ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6,LED Abblendlicht ohne Open Load Diagnose ,20
ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6,Always ,20
ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6,Abblendlicht links ,20
ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6,Main beam left ,20
ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6,Headlamp flasher ,20
ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6,not active ,20
ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6,not active ,20
ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6,not active ,20
ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6,not active ,20
ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6,not active ,20
ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6,not active ,20
ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6,not active ,20
ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6,not active ,20
ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6,not active ,20
ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7,maximize ,20
ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7,maximize ,20
ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7,maximize ,20
ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7,127 ,20
ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7,0 ,20
ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7,0 ,20
ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7,0 ,20
ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,20
ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7,40 ,20
ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7,LED Abblendlicht ohne Open Load Diagnose ,20
ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7,Always ,20
ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7,Abblendlicht rechts ,20
ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7,Main beam right ,20
ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7,Headlamp flasher ,20
ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7,not active ,20
ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7,not active ,20
ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7,not active ,20
ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7,not active ,20
ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7,not active ,20
ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7,not active ,20
ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7,not active ,20
ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7,not active ,20
ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7,not active ,20
ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8,maximize ,20
ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8,maximize ,20
ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8,maximize ,20
ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8,127 ,20
ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8,0 ,20
ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8,0 ,20
ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8,0 ,20
ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,20
ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8,37 ,20
ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8,LED_Tagfahrlicht_modul_Signal ,20
ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8,Always ,20
ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8,Main beam left ,20
ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8,Headlamp flasher ,20
ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8,not active ,20
ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8,not active ,20
ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8,not active ,20
ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8,not active ,20
ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8,not active ,20
ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8,not active ,20
ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8,not active ,20
ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8,not active ,20
ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8,not active ,20
ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8,not active ,20
ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9,maximize ,20
ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9,maximize ,20
ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9,maximize ,20
ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9,127 ,20
ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9,0 ,20
ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9,0 ,20
ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9,0 ,20
ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,20
ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9,41 ,20
ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9,LED_Tagfahrlicht_modul_Signal ,20
ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9,Always ,20
ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9,Main beam right ,20
ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9,Headlamp flasher ,20
ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9,not active ,20
ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9,not active ,20
ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9,not active ,20
ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9,not active ,20
ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9,not active ,20
ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9,not active ,20
ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9,not active ,20
ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9,not active ,20
ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9,not active ,20
ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9,not active ,20
ENG253237-IDE03311-Licht Konfig-Abhängig-Emergency braking display,active ,4
ENG253237-IDE07470-Licht Konfig-Abhängig-After-run for park light,No_sidelights_delay ,4
ENG253237-ENG142020-Licht Konfig-Abhängig-All-weather light,not installed ,4
ENG253237-ENG258575-Licht Konfig-Abhängig-Diskrete_SBBR_links,not installed ,4
ENG253237-ENG259588-Licht Konfig-Abhängig-Diskrete_SBBR_rechts,not installed ,4
ENG253237-ENG142191-Licht Konfig-Abhängig-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,4
ENG253237-ENG142190-Licht Konfig-Abhängig-Signaturlicht_verbaut,not installed ,4
ENG253374-ENG246963-Licht_bedienung-Anzeigezeit_LTM_PopUp1,6.0 s,12
ENG253374-ENG246964-Licht_bedienung-Anzeigezeit_LTM_PopUp1_lang,10 s,12
ENG253374-ENG246965-Licht_bedienung-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12
ENG253374-ENG246966-Licht_bedienung-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12
ENG253374-ENG246978-Licht_bedienung-Licht_anforderung_FAS,not installed ,12
ENG253374-ENG246979-Licht_bedienung-Licht_anforderung_Pilopark,not active ,12
ENG253374-ENG246980-Licht_bedienung-Licht_Reaktivierungs_grenze,100 m,12
ENG253374-ENG246981-Licht_bedienung-Lichttastermodul,LTM_Zentraltaste ,12
ENG253374-ENG246982-Licht_bedienung-LTM_Anzeige_Config,02 ,12
ENG253374-ENG246983-Licht_bedienung-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12
ENG253374-ENG246984-Licht_bedienung-LTM_BGL_Geschwindigkeitsabhängig,active ,12
ENG253374-ENG246985-Licht_bedienung-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,12
ENG253374-ENG246986-Licht_bedienung-LTM_BGL_Wegabhängig,active ,12
ENG253374-ENG246987-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabhängig,active ,12
ENG253374-ENG246988-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,12
ENG253374-ENG246989-Licht_bedienung-LTM_GlobalOFF_Wegabhängig,active ,12
ENG253374-ENG246990-Licht_bedienung-LTM_GlobalOFF_Zündungsabhängig,not active ,12
ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A,00 ,28
ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B,00 ,28
ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C,00 ,28
ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D,00 ,28
ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1,00 ,28
ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2,00 ,28
ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A,00 ,28
ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B,00 ,28
ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C,00 ,28
ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D,00 ,28
ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1,00 ,28
ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2,00 ,28
ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A,00 ,28
ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B,00 ,28
ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C,00 ,28
ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D,00 ,28
ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1,00 ,28
ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2,00 ,28
ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A,00 ,28
ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B,00 ,28
ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C,00 ,28
ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D,00 ,28
ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1,00 ,28
ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2,00 ,28
ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp,INDIVIDUAL ,4
ENG174381-MAS07990-light_control-Comfort flasher,active ,4
ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4
ENG174381-MAS10538-light_control-Light rotary sw. connection,Data bus LIN 1 ,4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp,integriert in Suchbeleuchtung ,4
ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4
ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4
ENG174381-ENG154711-light_control-PreCrash_RECAS,active ,4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4
ENG174381-ENG142004-light_control-Umgreifende_Heckklappe,not installed ,4
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2
ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2
ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2
ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2
ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2
ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2
ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2
ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2
ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.04 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,4 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,40 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,60 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,not installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,not active ,2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Toggletaster ,2
ENG253158-LWR Basissoftware,15 %,16
ENG253042-IDE03638-LWR Konfiguration-Static cornering light,ECE R119 ,8
ENG253042-IDE03644-LWR Konfiguration-Highway light,not activated ,8
ENG253042-MAS02922-LWR Konfiguration-City light,not activated ,8
ENG253042-MAS07013-LWR Konfiguration-All-weather light,not activated ,8
ENG253042-MAS07933-LWR Konfiguration-Eco mode,not activated ,8
ENG253042-ENG172238-LWR Konfiguration-chassis_unit,Verbundlenkerhinterachse ,8
ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR,activated ,8
ENG253042-ENG174374-LWR Konfiguration-LED_Headlight,activated ,8
ENG253042-ENG259430-LWR Konfiguration-LWR_konfig,DC HMI ,8
ENG253042-ENG172241-LWR Konfiguration-lwr_sensors,1_sensor ,8
ENG253042-ENG171501-LWR Konfiguration-Market,ECE ,8
ENG253042-ENG173009-LWR Konfiguration-offroad_light,not activated ,8
ENG253042-ENG172245-LWR Konfiguration-rain_light,not activated ,8
ENG253042-ENG174637-LWR Konfiguration-Source_height_value,BCM ,8
ENG253042-ENG172240-LWR Konfiguration-steering_curve,normal ,8
ENG253084-MDK,00 ,4
ENG249798-MDK_coding-,00 ,8
ENG249798-ENG253476-MDK_coding-MDK_bBtle_COV,00 ,8
ENG249798-ENG253477-MDK_coding-MDK_bExtendedScActivation_COV,00 ,8
ENG253387-mdk_locking_coding,not installed ,3
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG122979-ENG141953-Networking-Getriebesteuergeraet,Monostable selector lever ,8
ENG153902-NFC_FS_debug_switch,No Response From Subnet Component,8
ENG153904-NFC_MiKo_debug_switch,No Response From Subnet Component,8
ENG253222-NFC_MiKo_WLC_Functions-,No Response From Subnet Component,8
ENG253222-ENG253104-NFC_MiKo_WLC_Functions-NFC_MiKo_Attenuation_internal_BTLE_antenna,No Response From Subnet Component,8
ENG124714-ENG142044-OCU-DWA_push,active ,10
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,10
ENG124714-OCU-,installed ,10
ENG124714-ENG259569-OCU-Remote HuF,active ,10
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,10
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,10
ENG124714-ENG260662-OCU-Remote HuF maximale Ausführungsdauer,30 s,10
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,10
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,10
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,10
ENG253051-ENG258966-Par_AutomatikFKT-AutomatikFunktion_Entfernungsschwelle_Wechsel_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry,50 dB,27
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,60 ,27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,2 s,27
ENG253220-Par_Bedienstellen,2 ,7
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,255 %,26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschließen,3200 ms,26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,800 ms,26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26
ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung,5000 ms,6
ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer,0.0 s,6
ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer,2.0 s,6
ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL,3 ,20
ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR,3 ,20
ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN,1 ,20
ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL,1 ,20
ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR,1 ,20
ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox,600 cm,20
ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts,345 cm,20
ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten,600 cm,20
ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox,210 cm,20
ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts,105 cm,20
ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten,210 cm,20
ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung,600 cm,20
ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung,0 cm,20
ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung,45 ,20
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,80 ms,18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,18
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,18
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125667-Passenger_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125666-Passenger_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125668-Passenger_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125673-Passenger_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125672-Passenger_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125674-Passenger_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125670-Passenger_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125669-Passenger_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125671-Passenger_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125676-Passenger_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125675-Passenger_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125677-Passenger_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125664-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125663-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125665-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125667-Passenger_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125666-Passenger_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125668-Passenger_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125673-Passenger_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125672-Passenger_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125674-Passenger_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125670-Passenger_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125669-Passenger_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125671-Passenger_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125676-Passenger_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125675-Passenger_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125677-Passenger_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125664-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125663-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125665-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125667-Passenger_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125666-Passenger_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125668-Passenger_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125673-Passenger_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125672-Passenger_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125674-Passenger_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125670-Passenger_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125669-Passenger_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125671-Passenger_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125676-Passenger_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125675-Passenger_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125677-Passenger_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125664-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125663-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125665-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,18
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,18
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,18
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,18
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,18
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,18
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,18
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,18
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,18
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,18
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,18
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,18
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,18
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,18
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,18
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,18
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,18
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,18
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,18
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,18
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,18
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,18
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,18
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,18
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,18
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,18
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,18
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,18
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,18
ENG286146-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,18
ENG286146-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,18
ENG286146-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,18
ENG286146-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,18
ENG286146-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,18
ENG286146-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,18
ENG286146-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,18
ENG286146-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,18
ENG286146-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,18
ENG286146-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,18
ENG286146-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,18
ENG286146-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,18
ENG286146-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,18
ENG286146-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,18
ENG286146-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,18
ENG286146-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,18
ENG286146-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,18
ENG286146-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,18
ENG286146-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,18
ENG286146-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,18
ENG286146-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,18
ENG286146-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,18
ENG286146-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,18
ENG286146-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,18
ENG286146-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,18
ENG286146-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,18
ENG286146-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,18
ENG286146-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,18
ENG286146-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,18
ENG286146-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,18
ENG286146-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,18
ENG286146-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,18
ENG286146-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,18
ENG286146-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,18
ENG286146-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,18
ENG286146-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,18
ENG286146-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,18
ENG286146-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,18
ENG286146-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,18
ENG286146-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,18
ENG286146-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,18
ENG286146-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,18
ENG286146-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,18
ENG286146-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,18
ENG286146-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,18
ENG286146-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,18
ENG286146-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,18
ENG286146-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,18
ENG286146-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,18
ENG286146-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,18
ENG286146-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,18
ENG286146-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,18
ENG286146-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,18
ENG286146-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,18
ENG286146-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,18
ENG286146-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,18
ENG286146-IDE80057-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,18
ENG286146-IDE80058-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,18
ENG286146-IDE80059-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,18
ENG286146-IDE80060-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,18
ENG286147-IDE00047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,18
ENG286147-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,18
ENG286147-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,18
ENG286147-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,18
ENG286147-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,18
ENG286147-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,18
ENG286147-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,18
ENG286147-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,18
ENG286147-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,18
ENG286147-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,18
ENG286147-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,18
ENG286147-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,18
ENG286147-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,18
ENG286147-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,18
ENG286147-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,18
ENG286147-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,18
ENG286147-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,18
ENG286147-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,18
ENG286147-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,18
ENG286147-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,18
ENG286147-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,18
ENG286147-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,18
ENG286147-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,18
ENG286147-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,18
ENG286147-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,18
ENG286147-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,18
ENG286147-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,18
ENG286147-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,18
ENG286147-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,18
ENG286147-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,18
ENG286147-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,18
ENG286147-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,18
ENG286147-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,18
ENG286147-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,18
ENG286147-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,18
ENG286147-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,18
ENG286147-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,18
ENG286147-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,18
ENG286147-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,18
ENG286147-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,18
ENG286147-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,18
ENG286147-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,18
ENG286147-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,18
ENG286147-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,18
ENG286147-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,18
ENG286147-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,18
ENG286147-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,18
ENG286147-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,18
ENG286147-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,18
ENG286147-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,18
ENG286147-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,18
ENG286147-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,18
ENG286147-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,18
ENG286147-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,18
ENG286147-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,18
ENG286147-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,18
ENG286147-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,18
ENG286147-MAS01078-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,18
ENG286147-MAS14087-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,18
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,activated ,8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,activated ,8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,activated ,8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,activated ,8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,activated ,8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,activated ,8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,activated ,8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,activated ,8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,not activated ,8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,not activated ,8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,activated ,8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8
ENG129043-PASSIVE_GO,activated ,4
ENG253210-ENG260453-Personalisierung_2_0-Active_Participant_Doorlocking_Enabled,Deactivated ,12
ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12
ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12
ENG253210-ENG259660-Personalisierung_2_0-Active_Participant_Mirror_Enabled,activated ,12
ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12
ENG253210-ENG258609-Personalisierung_2_0-PSO_Setup_1,not_active ,12
ENG253210-ENG260679-Personalisierung_2_0-PSO_Setup_2,not_active ,12
ENG253210-ENG259992-Personalisierung_2_0-PSO_Setup_Bereich_1,0 ms,12
ENG253210-ENG260317-Personalisierung_2_0-PSO_Setup_Bereich_2,0 ms,12
ENG253210-ENG260178-Personalisierung_2_0-Version_ Personalisierung,Customization coded 2.x ,12
ENG253210-ENG247653-Personalisierung_2_0-Wait_for_IAA_Slot_Info,150 ms,12
ENG253109-PSI5 Konfiguration,02 ,16
ENG253310-PSI5 Sensoren,not installed ,1
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Skoda ,8
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,8
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,not active ,8
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,8
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,8
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Left ,8
ENG141646-ENG281077-Querschnitts_funktionen-SubCAN weckt nur den BusMaster,not active ,8
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8
ENG244881-ENG286173-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286174-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286175-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286176-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286177-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286178-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286179-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286180-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange{0},No Response From Subnet Component,8
ENG244881-ENG286181-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange{1},No Response From Subnet Component,8
ENG244881-ENG286182-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange{0},No Response From Subnet Component,8
ENG244881-ENG286183-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange{1},No Response From Subnet Component,8
ENG244881-ENG286184-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation{0},No Response From Subnet Component,8
ENG244881-ENG286185-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation{1},No Response From Subnet Component,8
ENG244881-ENG289577-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289578-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286188-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289579-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289580-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289581-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289582-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289583-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289584-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286195-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286196-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286197-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange{0},No Response From Subnet Component,8
ENG244881-ENG286198-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange{1},No Response From Subnet Component,8
ENG244881-ENG286199-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286200-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286201-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange{0},No Response From Subnet Component,8
ENG244881-ENG286202-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange{1},No Response From Subnet Component,8
ENG244881-ENG286203-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange{0},No Response From Subnet Component,8
ENG244881-ENG286204-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange{1},No Response From Subnet Component,8
ENG244881-ENG286205-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange{0},No Response From Subnet Component,8
ENG244881-ENG286206-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange{1},No Response From Subnet Component,8
ENG244881-ENG286207-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange{0},No Response From Subnet Component,8
ENG244881-ENG286208-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange{1},No Response From Subnet Component,8
ENG244881-ENG286209-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usCRC,No Response From Subnet Component,8
ENG244881-ENG289585-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289586-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286212-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286213-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286214-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286215-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286216-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286217-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286218-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286219-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286220-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286221-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange{0},No Response From Subnet Component,8
ENG244881-ENG286222-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange{1},No Response From Subnet Component,8
ENG244881-ENG286223-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange{0},No Response From Subnet Component,8
ENG244881-ENG286224-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange{1},No Response From Subnet Component,8
ENG244881-ENG286225-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation{0},No Response From Subnet Component,8
ENG244881-ENG286226-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation{1},No Response From Subnet Component,8
ENG244881-ENG289587-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289588-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286229-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289589-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289590-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289591-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289592-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289593-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289594-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286236-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286237-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286238-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange{0},No Response From Subnet Component,8
ENG244881-ENG286239-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange{1},No Response From Subnet Component,8
ENG244881-ENG286240-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286241-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286242-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange{0},No Response From Subnet Component,8
ENG244881-ENG286243-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange{1},No Response From Subnet Component,8
ENG244881-ENG286244-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange{0},No Response From Subnet Component,8
ENG244881-ENG286245-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange{1},No Response From Subnet Component,8
ENG244881-ENG286246-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange{0},No Response From Subnet Component,8
ENG244881-ENG286247-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange{1},No Response From Subnet Component,8
ENG244881-ENG286248-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange{0},No Response From Subnet Component,8
ENG244881-ENG286249-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange{1},No Response From Subnet Component,8
ENG244881-ENG286250-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usCRC,No Response From Subnet Component,8
ENG244881-ENG289595-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289596-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286253-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286254-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286262-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-padding,No Response From Subnet Component,8
ENG244881-ENG286271-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286272-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286273-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286274-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_{1},No Response From Subnet Component,8
ENG244881-ENG289612-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_High,No Response From Subnet Component,8
ENG244881-ENG289613-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_Low,No Response From Subnet Component,8
ENG244881-ENG286278-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_1_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286279-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286280-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286281-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio1_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286282-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286283-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286284-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{0},No Response From Subnet Component,8
ENG244881-ENG286285-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{1},No Response From Subnet Component,8
ENG244881-ENG286286-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{10},No Response From Subnet Component,8
ENG244881-ENG286287-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{11},No Response From Subnet Component,8
ENG244881-ENG286288-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{12},No Response From Subnet Component,8
ENG244881-ENG286289-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{13},No Response From Subnet Component,8
ENG244881-ENG286290-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{14},No Response From Subnet Component,8
ENG244881-ENG286291-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{15},No Response From Subnet Component,8
ENG244881-ENG286292-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{16},No Response From Subnet Component,8
ENG244881-ENG286293-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{17},No Response From Subnet Component,8
ENG244881-ENG286294-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{18},No Response From Subnet Component,8
ENG244881-ENG286295-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{19},No Response From Subnet Component,8
ENG244881-ENG286296-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{2},No Response From Subnet Component,8
ENG244881-ENG286297-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{20},No Response From Subnet Component,8
ENG244881-ENG286298-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{21},No Response From Subnet Component,8
ENG244881-ENG286299-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{22},No Response From Subnet Component,8
ENG244881-ENG286300-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{23},No Response From Subnet Component,8
ENG244881-ENG286301-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{24},No Response From Subnet Component,8
ENG244881-ENG286302-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{25},No Response From Subnet Component,8
ENG244881-ENG286303-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{26},No Response From Subnet Component,8
ENG244881-ENG286304-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{27},No Response From Subnet Component,8
ENG244881-ENG286305-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{28},No Response From Subnet Component,8
ENG244881-ENG286306-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{29},No Response From Subnet Component,8
ENG244881-ENG286307-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{3},No Response From Subnet Component,8
ENG244881-ENG286308-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{30},No Response From Subnet Component,8
ENG244881-ENG286309-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{31},No Response From Subnet Component,8
ENG244881-ENG286310-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{32},No Response From Subnet Component,8
ENG244881-ENG286311-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{33},No Response From Subnet Component,8
ENG244881-ENG286312-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{34},No Response From Subnet Component,8
ENG244881-ENG286313-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{35},No Response From Subnet Component,8
ENG244881-ENG286314-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{36},No Response From Subnet Component,8
ENG244881-ENG286315-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{37},No Response From Subnet Component,8
ENG244881-ENG286316-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{38},No Response From Subnet Component,8
ENG244881-ENG286317-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{39},No Response From Subnet Component,8
ENG244881-ENG286318-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{4},No Response From Subnet Component,8
ENG244881-ENG286319-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{40},No Response From Subnet Component,8
ENG244881-ENG286320-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{41},No Response From Subnet Component,8
ENG244881-ENG286321-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{42},No Response From Subnet Component,8
ENG244881-ENG286322-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{43},No Response From Subnet Component,8
ENG244881-ENG286323-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{44},No Response From Subnet Component,8
ENG244881-ENG286324-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{45},No Response From Subnet Component,8
ENG244881-ENG286325-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{46},No Response From Subnet Component,8
ENG244881-ENG286326-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{47},No Response From Subnet Component,8
ENG244881-ENG286327-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{48},No Response From Subnet Component,8
ENG244881-ENG286328-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{49},No Response From Subnet Component,8
ENG244881-ENG286329-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{5},No Response From Subnet Component,8
ENG244881-ENG286330-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{50},No Response From Subnet Component,8
ENG244881-ENG286331-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{51},No Response From Subnet Component,8
ENG244881-ENG286332-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{52},No Response From Subnet Component,8
ENG244881-ENG286333-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{53},No Response From Subnet Component,8
ENG244881-ENG286334-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{54},No Response From Subnet Component,8
ENG244881-ENG286335-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{55},No Response From Subnet Component,8
ENG244881-ENG286336-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{56},No Response From Subnet Component,8
ENG244881-ENG286337-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{57},No Response From Subnet Component,8
ENG244881-ENG286338-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{58},No Response From Subnet Component,8
ENG244881-ENG286339-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{59},No Response From Subnet Component,8
ENG244881-ENG286340-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{6},No Response From Subnet Component,8
ENG244881-ENG286341-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{60},No Response From Subnet Component,8
ENG244881-ENG286342-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{61},No Response From Subnet Component,8
ENG244881-ENG286343-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{62},No Response From Subnet Component,8
ENG244881-ENG286344-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{63},No Response From Subnet Component,8
ENG244881-ENG286345-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{64},No Response From Subnet Component,8
ENG244881-ENG286346-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{65},No Response From Subnet Component,8
ENG244881-ENG286347-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{7},No Response From Subnet Component,8
ENG244881-ENG286348-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{8},No Response From Subnet Component,8
ENG244881-ENG286349-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{9},No Response From Subnet Component,8
ENG244881-ENG289614-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Retry_Timeout,No Response From Subnet Component,8
ENG244881-ENG289615-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Sent_Time,No Response From Subnet Component,8
ENG244881-ENG286353-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Algo_Time_Out,No Response From Subnet Component,8
ENG244881-ENG286354-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_1,No Response From Subnet Component,8
ENG244881-ENG289616-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_2,No Response From Subnet Component,8
ENG244881-ENG286355-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_1,No Response From Subnet Component,8
ENG244881-ENG286356-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_2,No Response From Subnet Component,8
ENG244881-ENG286357-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_3,No Response From Subnet Component,8
ENG244881-ENG286358-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_4,No Response From Subnet Component,8
ENG244881-ENG286359-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Fahrzeugtyp,No Response From Subnet Component,8
ENG244881-ENG286360-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Padding,No Response From Subnet Component,8
ENG244881-ENG286361-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{0},No Response From Subnet Component,8
ENG244881-ENG286362-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{01},No Response From Subnet Component,8
ENG244881-ENG286363-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{2},No Response From Subnet Component,8
ENG244881-ENG286364-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{3},No Response From Subnet Component,8
ENG244881-ENG286365-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{4},No Response From Subnet Component,8
ENG244881-ENG286366-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{5},No Response From Subnet Component,8
ENG244881-ENG286367-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{6},No Response From Subnet Component,8
ENG244881-ENG286368-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{7},No Response From Subnet Component,8
ENG244881-ENG286369-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{8},No Response From Subnet Component,8
ENG244881-ENG286370-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{9},No Response From Subnet Component,8
ENG244881-ENG286371-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286372-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286373-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286374-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286375-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286376-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286377-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ucPoly_FeatureNumber,No Response From Subnet Component,8
ENG244881-ENG286378-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ul_CRC,No Response From Subnet Component,8
ENG244881-ENG286380-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_0,No Response From Subnet Component,8
ENG244881-ENG286381-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_1,No Response From Subnet Component,8
ENG244881-ENG286382-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa Time_Diff_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286383-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa_Time_Diff_Range_{0},No Response From Subnet Component,8
ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3
ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,installedLIN1 ,3
ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,installed ,3
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,3
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,3
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,3
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,3
ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,OFF ,3
ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3
ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an über Geschwindigkeit,Master steuert ,3
ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3
ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz I ,3
ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3
ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,On ,3
ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,OFF ,3
ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,80% Transmission ,3
ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,35% Transmission ,3
ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,LIN ,3
ENG122927-RLS_close_glazing,2.5 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,5
ENG253157-roof_module,installed ,1
ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,not installed ,6
ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6
ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,not installed ,6
ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6
ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6
ENG253336-ENG116647-Schiebedach_ZV-SAD Komfort oeffnen,not active ,6
ENG253336-ENG289611-Schiebedach_ZV-SAD Komfort_oeffnungs_modus,Open ,6
ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,not active ,6
ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6
ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6
ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6
ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,not activated ,1
ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1
ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1
ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1
ENG253118-IDE02851-Schlüsselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31
ENG253118-ENG126943-Schlüsselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31
ENG253118-ENG126944-Schlüsselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG277093-Schlüsselpositionsnachbildung (SPN)-Evaluation_Klemmenkoordinator,Yes ,31
ENG253118-ENG126945-Schlüsselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,300 ms,31
ENG253118-ENG129003-Schlüsselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG253448-Schlüsselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31
ENG253118-ENG126939-Schlüsselpositionsnachbildung (SPN)-rpm_threshold_engine_runnning,100 /min,31
ENG253118-ENG126946-Schlüsselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31
ENG253118-ENG258251-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31
ENG253118-ENG126947-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31
ENG253264-Seat_cushion_fan,not installed ,1
ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8
ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,not installed ,8
ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,installed ,8
ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,3 ,8
ENG253224-ENG259581-Seat_pneumatics-Massage_programs,3 ,8
ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8
ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8
ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8
ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8
ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8
ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6
ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6
ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6
ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6
ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6
ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6
ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,0 ms,4
ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4
ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,5000 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,5000 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,400 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,50 ms,48
ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,60 s,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,100 ms,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,250 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,200 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,200 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,2000 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,1000 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,30 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,5.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,300 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,active ,3
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,not active ,3
ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,active ,3
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,not active ,3
ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,active ,3
ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,active ,3
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,60 °C,8
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,140 km/h,8
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,0 ms,8
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,36 °C,8
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-11 °C,8
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG253353-ENG260527-Störungsmeldungen Licht/Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15
ENG253353-ENG260368-Störungsmeldungen Licht/Wischwasch-p_t_LDS_defekt_meldung,10 s,15
ENG253353-ENG260726-Störungsmeldungen Licht/Wischwasch-p_t_RLS_Meldung,2000 ms,15
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21
ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,0 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21
ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10
ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8
ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8
ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8
ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8
ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8
ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8
ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8
ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8
ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8
ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8
ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8
ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8
ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8
ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8
ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,100.0 ,8
ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,100.0 ,8
ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6
ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6
ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6
ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6
ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6
ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10
ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8
ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8
ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8
ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8
ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8
ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8
ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,100.0 ,8
ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,100.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,12800 lx,24
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,51200 lx,24
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,50 ,24
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,200 ,24
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,400 ,24
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,450 ,24
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,100 ,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,150 ,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,200 ,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,255 ,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 %,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 %,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 %,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 %,10
ENG249751-Two_keys,active ,3
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG252991-Vehicle configuration,activated ,1
ENG253245-ENG261297-verbauliste_subcan-Digitale Dachantenne,not installed ,4
ENG253245-ENG260575-verbauliste_subcan-nfc_miko,not installed ,4
ENG253245-ENG260904-verbauliste_subcan-nfc_tgs,not installed ,4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,6
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,6
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,6
ENG141634-ENG116655-Verdecksteuergeraet-Kessy Komfortbedienung Reichweitenbegrenzung,active ,6
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,6
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,6
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,6
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,6
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,6
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,6
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,6
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,6
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,6
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,6
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,6
ENG253327-ENG277083-Verlassenswarnung und Standlichtnachlauf-Ausgabedauer Wegrollwarnung,10 s,8
ENG253327-ENG261189-Verlassenswarnung und Standlichtnachlauf-Ausgabeverhalten Verlassenswarnung,VLW mit VLK2.2 Kriterien ,8
ENG253327-ENG261016-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Verlassenswarnung,1.4 s,8
ENG253327-ENG277084-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Wegrollwarnung,1.0 s,8
ENG253327-ENG261326-Verlassenswarnung und Standlichtnachlauf-Entprellung Degradierte Verlassenswarnung,1.6 s,8
ENG253327-ENG259356-Verlassenswarnung und Standlichtnachlauf-Entprellung Verlassenswarnung,5 min,8
ENG253327-ENG258196-Verlassenswarnung und Standlichtnachlauf-Fahrzeuggeschwindigkeit zur Stillstandserkennung,3 km/h,8
ENG253327-ENG116720-Verlassenswarnung und Standlichtnachlauf-Standlicht-Nachlaufzeit,30 min,8
ENG253327-ENG277124-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Standlichtnachlauf,active ,8
ENG253327-ENG277125-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Verlassenswarnung,equippt ,8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28
ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8
ENG159625-ENG286258-Virtual pedal-Kick_and_close_HBFS,not installed ,8
ENG159625-ENG286259-Virtual pedal-Kick_and_close_HFS,not installed ,8
ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,not active ,8
ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,not active ,8
ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,not active ,8
ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4
ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4
ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,0 ms,4
ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,0 ms,4
ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,not installed ,4
ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,not installed ,4
ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,not installed ,4
ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8
ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8
ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8
ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8
ENG154424-ENG260022-Waschen-RVC_Waschen,installed ,8
ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8
ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8
ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8
ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8
ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4
ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,0 ms,4
ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4
ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4
ENG253279-ENG126852-Wisch_geschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
ENG253279-ENG126853-Wisch_geschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
ENG253279-ENG116699-Wisch_geschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,00 00 00 00 ,4
ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 ,11
ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11
ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11
ENG281049-ENG263583-Zündungswarnung und Antrieb-Aktiv-Warnung-Ausgabe MoLaWa_AAW,active ,8
ENG281049-ENG263581-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellung_MoLaWa,1.5 ,8
ENG281049-ENG263504-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswechsel Belegt zu nicht Belegt,0.8 s,8
ENG281049-ENG281097-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswecsel nicht Belegt zu Belegt,0.0 s,8
ENG281049-ENG263576-Zündungswarnung und Antrieb-Aktiv-Warnung-Freigabeentprellung Abschaltung nach EM,60 s,8
ENG281049-ENG263531-Zündungswarnung und Antrieb-Aktiv-Warnung-Unterdrückung der Zündungswarnung,active ,8
ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6
ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6
ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_not_active ,6
ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,not active ,6
ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,not active ,6
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,6
ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6
ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,not active ,6
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale_Entriegelung ,6
ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6
ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,active ,6
ENG141653-ENG258544-ZV Heck-eingeschränkte_Freigabe_HD_Innentaste,not active ,6
ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6
ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6
ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6
ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,not installed ,6
ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6
ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6
ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,No ,6
ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,puls_contact_control ,6
ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,6
ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6
ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6
ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6
ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8
ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschließen_brasilien,not active ,8
ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,installed ,8
ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8
ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8
ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8
ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,active ,8
ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schließen,active ,8
ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8
ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8
ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,not active ,8
ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,active ,8
ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,active ,8
ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8
ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8
ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8
ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8
ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,not active ,7
ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7
ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7
ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7
ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,7
ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,not active ,7
ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7
ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,7
ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.0 s,7
ENG263451-ENG281092-ZV NFZ - Elektronische Rueckwandklappe-pa_eRWK_KST_Sonderzustand_Anf,not active ,7
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,none ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,No ,2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,No ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,none ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,No ,2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,No ,2
ENG253123-ENG259042-ZV Nutzfahrzeuge-SBT_Schloss_direkt,not installed ,5
ENG253123-ENG142041-ZV Nutzfahrzeuge-Schiebetueren_Crafter,not installed ,5
ENG253123-ENG260914-ZV Nutzfahrzeuge-TKM_BFS_verbaut,not installed ,5
ENG253123-ENG258445-ZV Nutzfahrzeuge-TKM_FS_verbaut,not installed ,5
ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6
ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6
ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,not active ,6
ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,not active ,6
ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6
ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6
ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,not active ,6
ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,not active ,6
ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,not active ,6
ENG141652-ENG258598-ZV Türkonfiguration-Fzg_mit_Vier_Tueren,Yes ,2
ENG141652-ENG260173-ZV Türkonfiguration-Schloesser_direkt_gesteuert,vordere via CAN angeschlossen: hinten diskre ,2
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,2
ENG141652-ENG258913-ZV Türkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2
ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,not active ,2
ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2
ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2
ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG263484-ENG263546-ZV_HW_Router-PIN_A11,Tür HL verriegeln oder Laderaumabdeckung links ,5
ENG263484-ENG263569-ZV_HW_Router-PIN_A31,LuT zentral oder Tankklappenrückmeldung ,5
ENG263484-ENG263532-ZV_HW_Router-PIN_A32,Softtouch Heckdeckel ,5
ENG263484-ENG263567-ZV_HW_Router-PIN_A33,Tür HR Verriegelung/Safe oder Verdeck zu ,5
ENG263484-ENG263596-ZV_HW_Router-PIN_A35,Tür HL Verriegelung/Safe ,5
ENG263484-ENG263575-ZV_HW_Router-PIN_A48,Tür HR TK-Signal ,5
ENG263484-ENG263528-ZV_HW_Router-PIN_A49,Taste Heckdeckelentriegelung ,5
ENG263484-ENG263547-ZV_HW_Router-PIN_A50,Tür HL TK-Signal ,5
ENG263484-ENG263598-ZV_HW_Router-PIN_A51,IRUE/NGS aus oder Heckscheibenbruch ,5
ENG263484-ENG263545-ZV_HW_Router-PIN_A7,Tür HR verriegeln oder Laderaumabdeckung rechts ,5
ENG263484-ENG263590-ZV_HW_Router-PIN_C21,Funktions-LED Taste3 ,5
ENG263484-ENG263523-ZV_HW_Router-PIN_C22,Funktions-LED Taste4 ,5
ENG263484-ENG263565-ZV_HW_Router-PIN_C34,Cockpit-Taste 3 ,5
ENG263484-ENG263571-ZV_HW_Router-PIN_C59,Cockpit-Taste 4 ,5
ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,No ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,not active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,not active ,5
ENG263427-ENG259542-zv_router_global-Schiebetuer_verriegeln_bei_offenem_tank,not active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
Elapsed Time: 03:34
Amedeo
Romania - Rm.Valcea
C?ID=14228
adpmap-10-5WA-919-294-C_TMBAJ7NXXNY096941-20260703-1357.CSV
;SW:5WA-919-294-C   HW:5WA-919-294 ---  10: Park/Steer Assist
;Component:PDC 08 Kanal  H04 0577, Coding:0040010011
;EV_EPHBO18VW3800000,002029,EV_EPHBO18VW3800000_AU38.rod
;Friday,03,July,2026,13:57:41:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: D2F69099146D2F5AB06-8086
IDE00845-Wheel circumference,1950 mm,2
IDE01165-Park assist activation tone,OFF ,1
IDE01167-Convertible offset for volume level 1,1 ,1
IDE02329-Allowance for vehicle fittings (width),0 cm,1
IDE02333-Allowance for vehicle fittings (length),0 cm,1
IDE14666-Parking aid: personalization,activated ,1
IDE17582-Park assist mute for emergency call,Security access required,1
MAS05448-Vehicle path display,not activated ,1
MAS12843-Maneuvering brake function,Security access required,1
MAS15621-Restart information,not activated ,1
MAS21139-MAS21140-Manually determined wheel sizes-Manually determined tire size front left,0 mm,8
MAS21139-MAS21141-Manually determined wheel sizes-Manually determined tire size front right,0 mm,8
MAS21139-MAS21142-Manually determined wheel sizes-Manually determined tire size rear left,0 mm,8
MAS21139-MAS21143-Manually determined wheel sizes-Manually determined tire size rear right,0 mm,8
Elapsed Time: 00:03
adpmap-13-5WA-907-572-B_TMBAJ7NXXNY096941-20260703-1358.CSV
;SW:5WA-907-572-B   HW:5WA-907-572 ---  13: Auto Dist. Reg
;Component:ACC Bosch MQB H20 0395, Coding:0903007D0077404512474000004040C54E4020000000000000000000000000
;EV_FRONTRADARBOSCHVW380,004017,EV_FRONTRADARBOSCHVW380_004_VW38.rod
;Friday,03,July,2026,13:58:09:12012
;VCID: CDCC83E50D5370A2ED4-8098
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,Security access required,3
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,Security access required,3
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,Security access required,3
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,Security access required,3
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,Security access required,3
IDE01949-Distance basic setting option,On ,1
IDE05815-Sail function,Activate ,1
IDE08935-Expanded restart function,On ,1
IDE09564-Distance change via speed adjustment,OFF ,1
IDE09565-Prioritized target object display,OFF ,1
IDE12516-Predictive speed limit regulation,activated ,1
IDE15695-Front radar-based localization,activated ,1
MAS19336-Active participant function activated,Deactivated ,1
ENG253321-Monitoring_and_FRKL_masking,General reject,1
Elapsed Time: 00:04
adpmap-15-1EA-959-655-DL_TMBAJ7NXXNY096941-20260703-1358.CSV
;SW:1EA-959-655-DL   HW:1EA-959-655-DL ---  15: Airbags
;Component:VW40Airbag    010 0176, Coding:98CC000000C0C000000000000000000050540000205400004000F68000120065
;EV_AirbaVW40ALVVW38X,001012,EV_AirbaVW40ALVVW38X_VW41.rod
;Friday,03,July,2026,13:58:39:12012
;VCID: 8E4E44E9C0D50BBAD4E-80DA SFD {x}
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,Conditions not correct or request sequence error,2
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,Conditions not correct or request sequence error,2
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,Conditions not correct or request sequence error,2
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,Conditions not correct or request sequence error,2
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,Conditions not correct or request sequence error,2
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,Conditions not correct or request sequence error,2
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,Conditions not correct or request sequence error,2
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,Conditions not correct or request sequence error,2
IDE05178-Conclude start of operation,locked ,1
IDE06314-Calibration data: pre-crash,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,not defined ,4
IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,not defined ,4
IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner second row right,not defined ,4
IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner second row left,not defined ,4
IDE06527-IDE12159-Adaptation pre-crash-Control module for belt feed: second row left,not defined ,4
IDE06527-IDE12160-Adaptation pre-crash-Control module for belt feed: second row right,not defined ,4
IDE06528-Programming: left belt tensioner,Conditions not correct or request sequence error,4
IDE06529-Programming: right belt tensioner,Conditions not correct or request sequence error,4
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,3
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,3
IDE07160-ENG258305-Control module switch-off: switch-off time-BusKnockOut_Tmr_NVEM,0 min,3
IDE07277-Programming of belt tensioner 2nd row: left,Conditions not correct or request sequence error,3
IDE07278-Programming of belt tensioner 2nd row: right,Conditions not correct or request sequence error,3
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,not defined ,8
IDE12055-IDE14841-Adaptation airbag 2-Seat Belt Tensioner Igniter: center 3rd row,not defined ,8
IDE12055-IDE15776-Adaptation airbag 2-Deactivation igniter: DC/DC converter,not defined ,8
IDE12055-IDE16063-Adaptation airbag 2-Igniter for high-voltage battery 3 open circuit,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
IDE15773-MAS05774-Wireless belt request/seat occupancy detection-2nd Row Left,Conditions not correct or request sequence error,8
IDE15773-MAS05775-Wireless belt request/seat occupancy detection-2nd Row Right,Conditions not correct or request sequence error,8
IDE15773-MAS14174-Wireless belt request/seat occupancy detection-2nd Row Center,Conditions not correct or request sequence error,8
IDE15773-MAS20986-Wireless belt request/seat occupancy detection-1st Row Center,Conditions not correct or request sequence error,8
IDE15773-MAS20987-Wireless belt request/seat occupancy detection-3rd Row Center,Conditions not correct or request sequence error,8
IDE15773-MAS20988-Wireless belt request/seat occupancy detection-4th Row Center,Conditions not correct or request sequence error,8
IDE15773-MAS25344-Wireless belt request/seat occupancy detection-3rd Row Left,Conditions not correct or request sequence error,8
IDE15773-MAS25345-Wireless belt request/seat occupancy detection-4th Row Left,Conditions not correct or request sequence error,8
IDE15773-MAS25346-Wireless belt request/seat occupancy detection-4th Row Right,Conditions not correct or request sequence error,8
IDE15773-MAS25347-Wireless belt request/seat occupancy detection-3rd Row Right,Conditions not correct or request sequence error,8
IDE15773-MAS25348-Wireless belt request/seat occupancy detection-1st Row Right,Conditions not correct or request sequence error,8
IDE15773-MAS25349-Wireless belt request/seat occupancy detection-1st Row Left,Conditions not correct or request sequence error,8
MAS00975-IDE00947-Airbag adaptations-Rear driver head curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Rear passenger head curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Front driver side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger front airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00013-Airbag adaptations-Driver seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger seat belt tensioner igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00023-Airbag adaptations-Driver active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Front passenger active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key-operated switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection passenger side,activated ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter hood,not defined ,8
Elapsed Time: 00:07
adpmap-17-5E3-920-770-B_TMBAJ7NXXNY096941-20260703-1345.CSV
;SW:5E3-920-770-B   HW:5E3-920-770-B ---  17: Instruments
;Component:KOMBI         201 5370, Coding:04A4004063840008018462032000080800301400
;EV_DashBoardVDDMQB37W,003033,EV_DashBoardVDDMQB37W_003_SK38.rod
;Friday,03,July,2026,13:45:43:12012
;VCID: A80212714271758A3E2-80FC SFD {x}
IDE00301-Distance,143433 km,3
IDE00343-Language variant,romanian ,1
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,1517 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE02489-Display depiction,Variant 1 ,1
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,150 ,2
IDE03348-Speed warning-,active ,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG262858-Service-key settings-p_deactivate_SK-Sub_Function_Current_Data,On ,5
IDE03568-ENG262855-Service-key settings-p_deactivate_SK-Sub_Function_Daily_Data,On ,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,OFF ,5
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-IDE12722-Configuration of displayable contents-Driving profile display,Display ,4
IDE11472-MAS01833-Configuration of displayable contents-Charge air pressure,not active ,4
IDE11472-MAS03555-Configuration of displayable contents-Lap counter,not active ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS05757-Configuration of displayable contents-Engine torque,not active ,4
IDE11472-MAS14767-Configuration of displayable contents-Convenience tire pressure warning display,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE11472-MAS19327-Configuration of displayable contents-Engine performance,not active ,4
IDE11472-MAS19328-Configuration of displayable contents-Transmission temperature,not active ,4
IDE11472-MAS19329-Configuration of displayable contents-G-meter,not active ,4
IDE11472-MAS19330-Configuration of displayable contents-Torque distribution,not active ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12792-IDE00301-Personalization of user account 1-Distance,Kilometres ,70
IDE12792-MAS01230-Personalization of user account 1-Date,dd_mm_yy ,70
IDE12792-MAS01456-Personalization of user account 1-Speed,Kilometers per hour ,70
IDE12792-MAS02201-Personalization of user account 1-Temperature,°C ,70
IDE12792-MAS02957-Personalization of user account 1-Time,24h ,70
IDE12792-MAS03032-Personalization of user account 1-Volume,litre ,70
IDE12792-MAS03034-Personalization of user account 1-Pressure,bar ,70
IDE12792-MAS05637-Personalization of user account 1-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12792-MAS05638-Personalization of user account 1-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12792-MAS05875-Personalization of user account 1-Average consumption: electric drive,kWh per 100 km ,70
IDE12792-Personalization of user account 1-,active ,70
IDE12792-ENG154881-Personalization of user account 1-Active_design,0 ,70
IDE12792-ENG154882-Personalization of user account 1-Active_view,0 ,70
IDE12792-ENG155000-Personalization of user account 1-DC_aktiverSpeicherplatz,0 ,70
IDE12792-ENG155001-Personalization of user account 1-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12792-ENG155002-Personalization of user account 1-DC_linkeTubeninformation,00 ,70
IDE12792-ENG155003-Personalization of user account 1-DC_rechteTubeninformation,00 ,70
IDE12792-ENG155004-Personalization of user account 1-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155005-Personalization of user account 1-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155006-Personalization of user account 1-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155007-Personalization of user account 1-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155008-Personalization of user account 1-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155009-Personalization of user account 1-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155051-Personalization of user account 1-Display_Average_Consumption,active ,70
IDE12792-ENG155052-Personalization of user account 1-Display_Average_Speed,active ,70
IDE12792-ENG155053-Personalization of user account 1-Display_ComfortPowerConsumption,not active ,70
IDE12792-ENG155054-Personalization of user account 1-Display_ConsumerList,not active ,70
IDE12792-ENG155055-Personalization of user account 1-Display_CoolantTemperature,not active ,70
IDE12792-ENG155056-Personalization of user account 1-Display_CurrentConsumption,active ,70
IDE12792-ENG155057-Personalization of user account 1-Display_DigitalSpeedometer,active ,70
IDE12792-ENG155058-Personalization of user account 1-Display_Distance,active ,70
IDE12792-ENG155059-Personalization of user account 1-Display_DrivingTime,active ,70
IDE12792-ENG155060-Personalization of user account 1-Display_DualSpeedometer,not active ,70
IDE12792-ENG155061-Personalization of user account 1-Display_Laptimer,not active ,70
IDE12792-ENG155062-Personalization of user account 1-Display_LiveTips,not active ,70
IDE12792-ENG155063-Personalization of user account 1-Display_Nachtankmenge,not active ,70
IDE12792-ENG155064-Personalization of user account 1-Display_OilTemperature,active ,70
IDE12792-ENG155065-Personalization of user account 1-Display_Range,active ,70
IDE12792-ENG155066-Personalization of user account 1-Display_ResetTime,not active ,70
IDE12792-ENG155067-Personalization of user account 1-Display_SpeedWarning,not active ,70
IDE12792-ENG155068-Personalization of user account 1-Display_VZA,active ,70
IDE12792-ENG155069-Personalization of user account 1-Display_ZeroEmission_Distance,not active ,70
IDE12792-ENG155070-Personalization of user account 1-Display_ZeroEmission_Time,not active ,70
IDE12792-ENG155246-Personalization of user account 1-LastMode_HMI_global_active_layout,0 ,70
IDE12792-ENG155247-Personalization of user account 1-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12792-ENG155248-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12792-ENG155249-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12792-ENG155250-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12792-ENG155251-Personalization of user account 1-LastMode_HMI_HistoryState_main,0 ,70
IDE12792-ENG155252-Personalization of user account 1-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12792-ENG155253-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12792-ENG155254-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12792-ENG155255-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12792-ENG155256-Personalization of user account 1-LastMode_HMI_HistoryState_sport,0 ,70
IDE12792-ENG155257-Personalization of user account 1-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12792-ENG155258-Personalization of user account 1-LastMode_HMI_MFA_store,0 ,70
IDE12792-ENG155259-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12792-ENG155260-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12792-ENG155261-Personalization of user account 1-LastMode_v_Kunde_aktiv,not active ,70
IDE12792-ENG155262-Personalization of user account 1-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12792-ENG155263-Personalization of user account 1-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12792-ENG262859-Personalization of user account 1-speed_value,0 ,70
IDE12792-ENG263509-Personalization of user account 1-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12794-IDE00301-Personalization of user account 2-Distance,Kilometres ,70
IDE12794-MAS01230-Personalization of user account 2-Date,dd_mm_yy ,70
IDE12794-MAS01456-Personalization of user account 2-Speed,Kilometers per hour ,70
IDE12794-MAS02201-Personalization of user account 2-Temperature,°C ,70
IDE12794-MAS02957-Personalization of user account 2-Time,24h ,70
IDE12794-MAS03032-Personalization of user account 2-Volume,litre ,70
IDE12794-MAS03034-Personalization of user account 2-Pressure,bar ,70
IDE12794-MAS05637-Personalization of user account 2-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12794-MAS05638-Personalization of user account 2-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12794-MAS05875-Personalization of user account 2-Average consumption: electric drive,kWh per 100 km ,70
IDE12794-Personalization of user account 2-,not active ,70
IDE12794-ENG154881-Personalization of user account 2-Active_design,0 ,70
IDE12794-ENG154882-Personalization of user account 2-Active_view,0 ,70
IDE12794-ENG155000-Personalization of user account 2-DC_aktiverSpeicherplatz,0 ,70
IDE12794-ENG155001-Personalization of user account 2-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12794-ENG155002-Personalization of user account 2-DC_linkeTubeninformation,00 ,70
IDE12794-ENG155003-Personalization of user account 2-DC_rechteTubeninformation,00 ,70
IDE12794-ENG155004-Personalization of user account 2-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155005-Personalization of user account 2-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155006-Personalization of user account 2-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155007-Personalization of user account 2-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155008-Personalization of user account 2-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155009-Personalization of user account 2-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155051-Personalization of user account 2-Display_Average_Consumption,active ,70
IDE12794-ENG155052-Personalization of user account 2-Display_Average_Speed,active ,70
IDE12794-ENG155053-Personalization of user account 2-Display_ComfortPowerConsumption,not active ,70
IDE12794-ENG155054-Personalization of user account 2-Display_ConsumerList,not active ,70
IDE12794-ENG155055-Personalization of user account 2-Display_CoolantTemperature,not active ,70
IDE12794-ENG155056-Personalization of user account 2-Display_CurrentConsumption,active ,70
IDE12794-ENG155057-Personalization of user account 2-Display_DigitalSpeedometer,active ,70
IDE12794-ENG155058-Personalization of user account 2-Display_Distance,active ,70
IDE12794-ENG155059-Personalization of user account 2-Display_DrivingTime,active ,70
IDE12794-ENG155060-Personalization of user account 2-Display_DualSpeedometer,not active ,70
IDE12794-ENG155061-Personalization of user account 2-Display_Laptimer,not active ,70
IDE12794-ENG155062-Personalization of user account 2-Display_LiveTips,not active ,70
IDE12794-ENG155063-Personalization of user account 2-Display_Nachtankmenge,not active ,70
IDE12794-ENG155064-Personalization of user account 2-Display_OilTemperature,active ,70
IDE12794-ENG155065-Personalization of user account 2-Display_Range,active ,70
IDE12794-ENG155066-Personalization of user account 2-Display_ResetTime,not active ,70
IDE12794-ENG155067-Personalization of user account 2-Display_SpeedWarning,not active ,70
IDE12794-ENG155068-Personalization of user account 2-Display_VZA,active ,70
IDE12794-ENG155069-Personalization of user account 2-Display_ZeroEmission_Distance,not active ,70
IDE12794-ENG155070-Personalization of user account 2-Display_ZeroEmission_Time,not active ,70
IDE12794-ENG155246-Personalization of user account 2-LastMode_HMI_global_active_layout,0 ,70
IDE12794-ENG155247-Personalization of user account 2-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12794-ENG155248-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12794-ENG155249-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12794-ENG155250-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12794-ENG155251-Personalization of user account 2-LastMode_HMI_HistoryState_main,0 ,70
IDE12794-ENG155252-Personalization of user account 2-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12794-ENG155253-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12794-ENG155254-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12794-ENG155255-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12794-ENG155256-Personalization of user account 2-LastMode_HMI_HistoryState_sport,0 ,70
IDE12794-ENG155257-Personalization of user account 2-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12794-ENG155258-Personalization of user account 2-LastMode_HMI_MFA_store,0 ,70
IDE12794-ENG155259-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12794-ENG155260-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12794-ENG155261-Personalization of user account 2-LastMode_v_Kunde_aktiv,not active ,70
IDE12794-ENG155262-Personalization of user account 2-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12794-ENG155263-Personalization of user account 2-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12794-ENG262859-Personalization of user account 2-speed_value,0 ,70
IDE12794-ENG263509-Personalization of user account 2-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12796-IDE00301-Personalization of user account 3-Distance,Kilometres ,70
IDE12796-MAS01230-Personalization of user account 3-Date,dd_mm_yy ,70
IDE12796-MAS01456-Personalization of user account 3-Speed,Kilometers per hour ,70
IDE12796-MAS02201-Personalization of user account 3-Temperature,°C ,70
IDE12796-MAS02957-Personalization of user account 3-Time,24h ,70
IDE12796-MAS03032-Personalization of user account 3-Volume,litre ,70
IDE12796-MAS03034-Personalization of user account 3-Pressure,bar ,70
IDE12796-MAS05637-Personalization of user account 3-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12796-MAS05638-Personalization of user account 3-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12796-MAS05875-Personalization of user account 3-Average consumption: electric drive,kWh per 100 km ,70
IDE12796-Personalization of user account 3-,not active ,70
IDE12796-ENG154881-Personalization of user account 3-Active_design,0 ,70
IDE12796-ENG154882-Personalization of user account 3-Active_view,0 ,70
IDE12796-ENG155000-Personalization of user account 3-DC_aktiverSpeicherplatz,0 ,70
IDE12796-ENG155001-Personalization of user account 3-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12796-ENG155002-Personalization of user account 3-DC_linkeTubeninformation,00 ,70
IDE12796-ENG155003-Personalization of user account 3-DC_rechteTubeninformation,00 ,70
IDE12796-ENG155004-Personalization of user account 3-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155005-Personalization of user account 3-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155006-Personalization of user account 3-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155007-Personalization of user account 3-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155008-Personalization of user account 3-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155009-Personalization of user account 3-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155051-Personalization of user account 3-Display_Average_Consumption,active ,70
IDE12796-ENG155052-Personalization of user account 3-Display_Average_Speed,active ,70
IDE12796-ENG155053-Personalization of user account 3-Display_ComfortPowerConsumption,not active ,70
IDE12796-ENG155054-Personalization of user account 3-Display_ConsumerList,not active ,70
IDE12796-ENG155055-Personalization of user account 3-Display_CoolantTemperature,not active ,70
IDE12796-ENG155056-Personalization of user account 3-Display_CurrentConsumption,active ,70
IDE12796-ENG155057-Personalization of user account 3-Display_DigitalSpeedometer,active ,70
IDE12796-ENG155058-Personalization of user account 3-Display_Distance,active ,70
IDE12796-ENG155059-Personalization of user account 3-Display_DrivingTime,active ,70
IDE12796-ENG155060-Personalization of user account 3-Display_DualSpeedometer,not active ,70
IDE12796-ENG155061-Personalization of user account 3-Display_Laptimer,not active ,70
IDE12796-ENG155062-Personalization of user account 3-Display_LiveTips,not active ,70
IDE12796-ENG155063-Personalization of user account 3-Display_Nachtankmenge,not active ,70
IDE12796-ENG155064-Personalization of user account 3-Display_OilTemperature,active ,70
IDE12796-ENG155065-Personalization of user account 3-Display_Range,active ,70
IDE12796-ENG155066-Personalization of user account 3-Display_ResetTime,not active ,70
IDE12796-ENG155067-Personalization of user account 3-Display_SpeedWarning,not active ,70
IDE12796-ENG155068-Personalization of user account 3-Display_VZA,active ,70
IDE12796-ENG155069-Personalization of user account 3-Display_ZeroEmission_Distance,not active ,70
IDE12796-ENG155070-Personalization of user account 3-Display_ZeroEmission_Time,not active ,70
IDE12796-ENG155246-Personalization of user account 3-LastMode_HMI_global_active_layout,0 ,70
IDE12796-ENG155247-Personalization of user account 3-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12796-ENG155248-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12796-ENG155249-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12796-ENG155250-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12796-ENG155251-Personalization of user account 3-LastMode_HMI_HistoryState_main,0 ,70
IDE12796-ENG155252-Personalization of user account 3-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12796-ENG155253-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12796-ENG155254-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12796-ENG155255-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12796-ENG155256-Personalization of user account 3-LastMode_HMI_HistoryState_sport,0 ,70
IDE12796-ENG155257-Personalization of user account 3-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12796-ENG155258-Personalization of user account 3-LastMode_HMI_MFA_store,0 ,70
IDE12796-ENG155259-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12796-ENG155260-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12796-ENG155261-Personalization of user account 3-LastMode_v_Kunde_aktiv,not active ,70
IDE12796-ENG155262-Personalization of user account 3-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12796-ENG155263-Personalization of user account 3-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12796-ENG262859-Personalization of user account 3-speed_value,0 ,70
IDE12796-ENG263509-Personalization of user account 3-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12798-IDE00301-Personalization of user account 4-Distance,Kilometres ,70
IDE12798-MAS01230-Personalization of user account 4-Date,dd_mm_yy ,70
IDE12798-MAS01456-Personalization of user account 4-Speed,Kilometers per hour ,70
IDE12798-MAS02201-Personalization of user account 4-Temperature,°C ,70
IDE12798-MAS02957-Personalization of user account 4-Time,24h ,70
IDE12798-MAS03032-Personalization of user account 4-Volume,litre ,70
IDE12798-MAS03034-Personalization of user account 4-Pressure,bar ,70
IDE12798-MAS05637-Personalization of user account 4-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12798-MAS05638-Personalization of user account 4-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12798-MAS05875-Personalization of user account 4-Average consumption: electric drive,kWh per 100 km ,70
IDE12798-Personalization of user account 4-,not active ,70
IDE12798-ENG154881-Personalization of user account 4-Active_design,0 ,70
IDE12798-ENG154882-Personalization of user account 4-Active_view,0 ,70
IDE12798-ENG155000-Personalization of user account 4-DC_aktiverSpeicherplatz,0 ,70
IDE12798-ENG155001-Personalization of user account 4-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12798-ENG155002-Personalization of user account 4-DC_linkeTubeninformation,00 ,70
IDE12798-ENG155003-Personalization of user account 4-DC_rechteTubeninformation,00 ,70
IDE12798-ENG155004-Personalization of user account 4-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155005-Personalization of user account 4-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155006-Personalization of user account 4-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155007-Personalization of user account 4-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155008-Personalization of user account 4-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155009-Personalization of user account 4-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155051-Personalization of user account 4-Display_Average_Consumption,active ,70
IDE12798-ENG155052-Personalization of user account 4-Display_Average_Speed,active ,70
IDE12798-ENG155053-Personalization of user account 4-Display_ComfortPowerConsumption,not active ,70
IDE12798-ENG155054-Personalization of user account 4-Display_ConsumerList,not active ,70
IDE12798-ENG155055-Personalization of user account 4-Display_CoolantTemperature,not active ,70
IDE12798-ENG155056-Personalization of user account 4-Display_CurrentConsumption,active ,70
IDE12798-ENG155057-Personalization of user account 4-Display_DigitalSpeedometer,active ,70
IDE12798-ENG155058-Personalization of user account 4-Display_Distance,active ,70
IDE12798-ENG155059-Personalization of user account 4-Display_DrivingTime,active ,70
IDE12798-ENG155060-Personalization of user account 4-Display_DualSpeedometer,not active ,70
IDE12798-ENG155061-Personalization of user account 4-Display_Laptimer,not active ,70
IDE12798-ENG155062-Personalization of user account 4-Display_LiveTips,not active ,70
IDE12798-ENG155063-Personalization of user account 4-Display_Nachtankmenge,not active ,70
IDE12798-ENG155064-Personalization of user account 4-Display_OilTemperature,active ,70
IDE12798-ENG155065-Personalization of user account 4-Display_Range,active ,70
IDE12798-ENG155066-Personalization of user account 4-Display_ResetTime,not active ,70
IDE12798-ENG155067-Personalization of user account 4-Display_SpeedWarning,not active ,70
IDE12798-ENG155068-Personalization of user account 4-Display_VZA,active ,70
IDE12798-ENG155069-Personalization of user account 4-Display_ZeroEmission_Distance,not active ,70
IDE12798-ENG155070-Personalization of user account 4-Display_ZeroEmission_Time,not active ,70
IDE12798-ENG155246-Personalization of user account 4-LastMode_HMI_global_active_layout,0 ,70
IDE12798-ENG155247-Personalization of user account 4-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12798-ENG155248-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12798-ENG155249-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12798-ENG155250-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12798-ENG155251-Personalization of user account 4-LastMode_HMI_HistoryState_main,0 ,70
IDE12798-ENG155252-Personalization of user account 4-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12798-ENG155253-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12798-ENG155254-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12798-ENG155255-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12798-ENG155256-Personalization of user account 4-LastMode_HMI_HistoryState_sport,0 ,70
IDE12798-ENG155257-Personalization of user account 4-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12798-ENG155258-Personalization of user account 4-LastMode_HMI_MFA_store,0 ,70
IDE12798-ENG155259-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12798-ENG155260-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12798-ENG155261-Personalization of user account 4-LastMode_v_Kunde_aktiv,not active ,70
IDE12798-ENG155262-Personalization of user account 4-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12798-ENG155263-Personalization of user account 4-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12798-ENG262859-Personalization of user account 4-speed_value,0 ,70
IDE12798-ENG263509-Personalization of user account 4-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12800-IDE00301-Personalization of user account 5-Distance,Kilometres ,70
IDE12800-MAS01230-Personalization of user account 5-Date,dd_mm_yy ,70
IDE12800-MAS01456-Personalization of user account 5-Speed,Kilometers per hour ,70
IDE12800-MAS02201-Personalization of user account 5-Temperature,°C ,70
IDE12800-MAS02957-Personalization of user account 5-Time,24h ,70
IDE12800-MAS03032-Personalization of user account 5-Volume,litre ,70
IDE12800-MAS03034-Personalization of user account 5-Pressure,bar ,70
IDE12800-MAS05637-Personalization of user account 5-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12800-MAS05638-Personalization of user account 5-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12800-MAS05875-Personalization of user account 5-Average consumption: electric drive,kWh per 100 km ,70
IDE12800-Personalization of user account 5-,not active ,70
IDE12800-ENG154881-Personalization of user account 5-Active_design,0 ,70
IDE12800-ENG154882-Personalization of user account 5-Active_view,0 ,70
IDE12800-ENG155000-Personalization of user account 5-DC_aktiverSpeicherplatz,0 ,70
IDE12800-ENG155001-Personalization of user account 5-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12800-ENG155002-Personalization of user account 5-DC_linkeTubeninformation,00 ,70
IDE12800-ENG155003-Personalization of user account 5-DC_rechteTubeninformation,00 ,70
IDE12800-ENG155004-Personalization of user account 5-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155005-Personalization of user account 5-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155006-Personalization of user account 5-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155007-Personalization of user account 5-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155008-Personalization of user account 5-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155009-Personalization of user account 5-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155051-Personalization of user account 5-Display_Average_Consumption,active ,70
IDE12800-ENG155052-Personalization of user account 5-Display_Average_Speed,active ,70
IDE12800-ENG155053-Personalization of user account 5-Display_ComfortPowerConsumption,not active ,70
IDE12800-ENG155054-Personalization of user account 5-Display_ConsumerList,not active ,70
IDE12800-ENG155055-Personalization of user account 5-Display_CoolantTemperature,not active ,70
IDE12800-ENG155056-Personalization of user account 5-Display_CurrentConsumption,active ,70
IDE12800-ENG155057-Personalization of user account 5-Display_DigitalSpeedometer,active ,70
IDE12800-ENG155058-Personalization of user account 5-Display_Distance,active ,70
IDE12800-ENG155059-Personalization of user account 5-Display_DrivingTime,active ,70
IDE12800-ENG155060-Personalization of user account 5-Display_DualSpeedometer,not active ,70
IDE12800-ENG155061-Personalization of user account 5-Display_Laptimer,not active ,70
IDE12800-ENG155062-Personalization of user account 5-Display_LiveTips,not active ,70
IDE12800-ENG155063-Personalization of user account 5-Display_Nachtankmenge,not active ,70
IDE12800-ENG155064-Personalization of user account 5-Display_OilTemperature,active ,70
IDE12800-ENG155065-Personalization of user account 5-Display_Range,active ,70
IDE12800-ENG155066-Personalization of user account 5-Display_ResetTime,not active ,70
IDE12800-ENG155067-Personalization of user account 5-Display_SpeedWarning,not active ,70
IDE12800-ENG155068-Personalization of user account 5-Display_VZA,active ,70
IDE12800-ENG155069-Personalization of user account 5-Display_ZeroEmission_Distance,not active ,70
IDE12800-ENG155070-Personalization of user account 5-Display_ZeroEmission_Time,not active ,70
IDE12800-ENG155246-Personalization of user account 5-LastMode_HMI_global_active_layout,0 ,70
IDE12800-ENG155247-Personalization of user account 5-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12800-ENG155248-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12800-ENG155249-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12800-ENG155250-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12800-ENG155251-Personalization of user account 5-LastMode_HMI_HistoryState_main,0 ,70
IDE12800-ENG155252-Personalization of user account 5-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12800-ENG155253-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12800-ENG155254-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12800-ENG155255-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12800-ENG155256-Personalization of user account 5-LastMode_HMI_HistoryState_sport,0 ,70
IDE12800-ENG155257-Personalization of user account 5-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12800-ENG155258-Personalization of user account 5-LastMode_HMI_MFA_store,0 ,70
IDE12800-ENG155259-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12800-ENG155260-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12800-ENG155261-Personalization of user account 5-LastMode_v_Kunde_aktiv,not active ,70
IDE12800-ENG155262-Personalization of user account 5-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12800-ENG155263-Personalization of user account 5-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12800-ENG262859-Personalization of user account 5-speed_value,0 ,70
IDE12800-ENG263509-Personalization of user account 5-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12802-IDE00301-Personalization of user account 6-Distance,Kilometres ,70
IDE12802-MAS01230-Personalization of user account 6-Date,dd_mm_yy ,70
IDE12802-MAS01456-Personalization of user account 6-Speed,Kilometers per hour ,70
IDE12802-MAS02201-Personalization of user account 6-Temperature,°C ,70
IDE12802-MAS02957-Personalization of user account 6-Time,24h ,70
IDE12802-MAS03032-Personalization of user account 6-Volume,litre ,70
IDE12802-MAS03034-Personalization of user account 6-Pressure,bar ,70
IDE12802-MAS05637-Personalization of user account 6-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12802-MAS05638-Personalization of user account 6-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12802-MAS05875-Personalization of user account 6-Average consumption: electric drive,kWh per 100 km ,70
IDE12802-Personalization of user account 6-,not active ,70
IDE12802-ENG154881-Personalization of user account 6-Active_design,0 ,70
IDE12802-ENG154882-Personalization of user account 6-Active_view,0 ,70
IDE12802-ENG155000-Personalization of user account 6-DC_aktiverSpeicherplatz,0 ,70
IDE12802-ENG155001-Personalization of user account 6-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12802-ENG155002-Personalization of user account 6-DC_linkeTubeninformation,00 ,70
IDE12802-ENG155003-Personalization of user account 6-DC_rechteTubeninformation,00 ,70
IDE12802-ENG155004-Personalization of user account 6-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155005-Personalization of user account 6-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155006-Personalization of user account 6-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155007-Personalization of user account 6-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155008-Personalization of user account 6-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155009-Personalization of user account 6-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155051-Personalization of user account 6-Display_Average_Consumption,active ,70
IDE12802-ENG155052-Personalization of user account 6-Display_Average_Speed,active ,70
IDE12802-ENG155053-Personalization of user account 6-Display_ComfortPowerConsumption,not active ,70
IDE12802-ENG155054-Personalization of user account 6-Display_ConsumerList,not active ,70
IDE12802-ENG155055-Personalization of user account 6-Display_CoolantTemperature,not active ,70
IDE12802-ENG155056-Personalization of user account 6-Display_CurrentConsumption,active ,70
IDE12802-ENG155057-Personalization of user account 6-Display_DigitalSpeedometer,active ,70
IDE12802-ENG155058-Personalization of user account 6-Display_Distance,active ,70
IDE12802-ENG155059-Personalization of user account 6-Display_DrivingTime,active ,70
IDE12802-ENG155060-Personalization of user account 6-Display_DualSpeedometer,not active ,70
IDE12802-ENG155061-Personalization of user account 6-Display_Laptimer,not active ,70
IDE12802-ENG155062-Personalization of user account 6-Display_LiveTips,not active ,70
IDE12802-ENG155063-Personalization of user account 6-Display_Nachtankmenge,not active ,70
IDE12802-ENG155064-Personalization of user account 6-Display_OilTemperature,active ,70
IDE12802-ENG155065-Personalization of user account 6-Display_Range,active ,70
IDE12802-ENG155066-Personalization of user account 6-Display_ResetTime,not active ,70
IDE12802-ENG155067-Personalization of user account 6-Display_SpeedWarning,not active ,70
IDE12802-ENG155068-Personalization of user account 6-Display_VZA,active ,70
IDE12802-ENG155069-Personalization of user account 6-Display_ZeroEmission_Distance,not active ,70
IDE12802-ENG155070-Personalization of user account 6-Display_ZeroEmission_Time,not active ,70
IDE12802-ENG155246-Personalization of user account 6-LastMode_HMI_global_active_layout,0 ,70
IDE12802-ENG155247-Personalization of user account 6-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12802-ENG155248-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12802-ENG155249-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12802-ENG155250-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12802-ENG155251-Personalization of user account 6-LastMode_HMI_HistoryState_main,0 ,70
IDE12802-ENG155252-Personalization of user account 6-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12802-ENG155253-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12802-ENG155254-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12802-ENG155255-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12802-ENG155256-Personalization of user account 6-LastMode_HMI_HistoryState_sport,0 ,70
IDE12802-ENG155257-Personalization of user account 6-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12802-ENG155258-Personalization of user account 6-LastMode_HMI_MFA_store,0 ,70
IDE12802-ENG155259-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12802-ENG155260-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12802-ENG155261-Personalization of user account 6-LastMode_v_Kunde_aktiv,not active ,70
IDE12802-ENG155262-Personalization of user account 6-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12802-ENG155263-Personalization of user account 6-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12802-ENG262859-Personalization of user account 6-speed_value,0 ,70
IDE12802-ENG263509-Personalization of user account 6-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12804-IDE00301-Personalization of user account 7-Distance,Kilometres ,70
IDE12804-MAS01230-Personalization of user account 7-Date,dd_mm_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Kilometers per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature,°C ,70
IDE12804-MAS02957-Personalization of user account 7-Time,24h ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,litre ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,bar ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,kWh per 100 km ,70
IDE12804-Personalization of user account 7-,not active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,0 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG262859-Personalization of user account 7-speed_value,0 ,70
IDE12804-ENG263509-Personalization of user account 7-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,23100 km,2
IDE12963-Oil: thermal loading,4300 km,2
IDE12964-Oil: driven distance since last oil service,5800 km,3
IDE12965-Oil: time since last oil service,154 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),30000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,1500000 km,3
IDE12979-Inspection: time until next inspection,365 d,2
IDE12980-Inspection: distance driven since the last inspection,5800 km,3
IDE12981-Inspection: time since the last inspection,154 d,2
IDE12982-Inspection: distance reset value,30000 km,2
IDE12983-Inspection: time reset value,730 d,2
IDE13031-MAS03935-Long-term store-Driving time,0 min,44
IDE13031-MAS15517-Long-term store-Travel distance,0 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,0 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,0 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,0 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,0 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.000 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.000 kWh,44
IDE13094-Tachometer end value,Variant 0 ,1
IDE13275-IDE00301-Personalization default value-Distance,Kilometres ,70
IDE13275-MAS01230-Personalization default value-Date,dd_mm_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Kilometers per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature,°C ,70
IDE13275-MAS02957-Personalization default value-Time,24h ,70
IDE13275-MAS03032-Personalization default value-Volume,litre ,70
IDE13275-MAS03034-Personalization default value-Pressure,bar ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,kWh per 100 km ,70
IDE13275-Personalization default value-,active ,70
IDE13275-ENG154881-Personalization default value-Active_design,0 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,not active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,not active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,not active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,not active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,not active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,not active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,not active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,not active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,not active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,not active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,not active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,0 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,5 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG262859-Personalization default value-speed_value,150 ,70
IDE13275-ENG263509-Personalization default value-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE13441-Secondary speed in case of unit replacement,No display ,1
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14112-Gas system test - warning reset,No ,1
IDE14116-Gas system test - warning time,1443 d,2
IDE14123-MAS01129-Design variant activation-Variant 1,active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,Yes ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,0 s,1
IDE14222-Test number length: authentic time,16 B,1
IDE14875-MAS19483-Activation of views-View 1,active ,2
IDE14875-MAS19484-Activation of views-View 2,active ,2
IDE14875-MAS19485-Activation of views-View 3,active ,2
IDE14875-MAS19486-Activation of views-View 4,active ,2
IDE14875-MAS19487-Activation of views-View 5,active ,2
IDE14875-MAS19488-Activation of views-View 6,active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,not active ,2
IDE14875-MAS19491-Activation of views-View 9,not active ,2
IDE14875-MAS19492-Activation of views-View 10,not active ,2
IDE14875-MAS19493-Activation of views-View 12,not active ,2
IDE14875-MAS19494-Activation of views-View 11,not active ,2
IDE14875-MAS19495-Activation of views-View 13,not active ,2
IDE14875-MAS19496-Activation of views-View 14,not active ,2
IDE14875-MAS19497-Activation of views-View 15,not active ,2
IDE14875-MAS19498-Activation of views-View 16,not active ,2
IDE15080-Logo,kein_logo ,1
IDE15909-Removable seats,Layout normal ,1
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,No ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
MAS01758-IDE00500-Date / time-Hour,20 H,6
MAS01758-IDE00501-Date / time-Minute,23 min,6
MAS01758-IDE00502-Date / time-Year,2026 yr,6
MAS01758-IDE00503-Date / time-Month,6 Months,6
MAS01758-IDE00504-Date / time-Day,30 d,6
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG262830-Correction_factor_consumption_and_operating_range_electric,100 %,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,05 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,25 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,96 ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,12 ,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,12 ,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,20 ,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,70 ,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,500 ,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,1000 ,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.0 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.0 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.0 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.0 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.0 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.0 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.0 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.0 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.0 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.0 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.0 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.0 %,24
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4.0 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6.0 °C,16
ENG135292-phev_stat_intervall-,1.0 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.0 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.0 s,7
ENG135292-phev_stat_intervall-,00000000 00010000  ,7
ENG262832-Switching_Networking,Ethernet ,1
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.50 ,18
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:36
adpmap-19-5WA-907-530-Q_TMBAJ7NXXNY096941-20260703-1347.CSV
;SW:5WA-907-530-Q   HW:5WA-907-530-G ---  19: CAN Gateway
;Component:GW2020 High   756 7300, Coding:0000838D0700000000000000010303325301600902000300030100000001010100000000000000000000000000000000
;EV_GatewMQB2020,005011,EV_GatewMQB2020_004_SK38.rod
;Friday,03,July,2026,13:47:23:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: D6FE6C893885337A5CE-8082 SFD {x}
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,not active ,5
IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,not active ,5
IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,not active ,5
IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,not active ,5
IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,not active ,5
IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,not active ,5
IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,not active ,5
IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,not active ,5
IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,not active ,5
IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,not active ,5
IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,not active ,5
IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,not active ,5
IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,not active ,5
IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,not active ,5
IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,not active ,5
IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,not active ,5
IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,not active ,5
IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,not active ,5
IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,not active ,5
IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,not active ,5
IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,not active ,5
IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,not active ,5
IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,not active ,5
IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,not active ,5
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,70 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Wet ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111112 ,15
IDE03903-Production process data 1,40 00 ,2
IDE04330-Transfer of release code for a SWaP function,12 10 FF FF FF FF 03 62 BB E8 79 52 54 4D 42 41 4A 37 4E 58 58 4E 59 30 39 36 39 34 31 00 69 9B 22 45 10 10 01 01 00 00 00 00 00 00 00 00 00 00 10 0E 16 00 00 00 00 00 00 00 00 00 00 10 01 02 00 00 00 00 00 00 00 00 00 00 10 01 0A 00 00 00 00 00 00 00 00 00 00 00 07 0A 00 00 00 00 00 00 00 00 00 00 00 07 0B 00 00 00 00 00 00 00 00 00 00 00 04 01 00 00 00 00 00 00 00 00 00 00 10 02 08 00 10 69 9B 21 F2 69 C0 0B F2 00 07 05 00 00 00 00 00 00 00 00 00 00 00 07 09 00 00 00 00 00 00 00 00 00 00 00 06 03 00 00 00 00 00 00 00 00 00 00 10 01 05 00 00 00 00 00 00 00 00 00 00 00 07 1C 00 00 00 00 00 00 00 00 00 00 10 01 06 00 00 00 00 00 00 00 00 00 00 10 01 04 00 00 00 00 00 00 00 00 00 00 10 02 0E 00 10 69 9B 22 44 69 C0 0C 44 56 90 C1 AA 27 3C 7D B1 11 06 72 C3 7A 3C F2 B1 F0 3B 9C 4B D1 2D 55 B5 D7 11 DA C4 A8 02 40 B6 65 07 C7 E4 B6 AE CE B8 0D 02 CE E1 4B E7 9D 8A 2B A7 99 D8 FA 33 B6 03 32 85 39 CB 31 0D 2C BF CE F7 6B 33 C4 02 47 53 00 9D 30 27 2D CA 00 55 89 C4 D3 0F 48 E5 36 31 36 BB C2 E4 3E CA DA 65 0F 09 9B C4 36 0F BB 96 B0 EA 84 9A 5D E3 F2 D3 90 AE 70 22 47 F9 96 06 75 11 EE 42 EA 50 52 29 6E 08 75 14 F7 76 D1 4F 12 81 BA 21 9A 5C 9D 24 CF 9E 7E 3E 56 FA 5A 58 0F 0A 25 F5 EC C6 6A B3 F8 2A 77 13 8A F3 17 E7 7F A5 ED D4 E8 E4 3D B9 79 66 11 49 3D C7 D8 7B DD 72 0A 66 11 8A 52 51 74 EF 6B 46 DB AE DC A6 AA 54 C9 CD 49 DF FC 2D 14 68 48 98 12 8B B0 9D EB 42 3A 37 32 03 A5 F3 37 F9 38 E8 B7 F1 F6 65 D9 14 77 9A 59 D6 71 C8 15 F0 76 B4 0F 72 CB 95 52 C2 DD CA 1C CF 74 80 B0 32 A2 63 22 63 01 98 38 55 74 01 5A E0 76 64 F7 79 3E 9D 3E 6D E4 A6 4D 1A 47 6A 39 20 1A 83 C1 7B 6E DE 7E 20 D2 5A C0 A3 8B 48 54 1D 4A 93 B3 F9 12 71 99 5D C3 CD E4 1D 13 60 85 1B 88 C9 1B 5E 52 CF FF 98 94 5E 06 95 AE A0 08 07 D2 CD D9 73 C8 8D 25 34 EF 56 24 D8 FB 45 51 EB 3C 09 C4 E4 80 2B D4 92 74 D4 5C 42 F7 05 80 13 B2 9F 50 A4 90 4A 65 42 34 D6 7A 31 B2 16 FF D2 53 30 ,627
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE07160-Control module switch-off: switch-off time,20 min,2
IDE08220-Vehicle production mode,not active ,1
IDE08624-MKE Check box,not activated ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,1.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,0 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,-15000 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,150 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,150 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,10 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,1.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,1.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,1.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,1.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,1.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,1.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),1.5 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,1.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,4.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,1.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,1.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,1.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,1.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,1.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,1.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,1.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,1.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,0.0 l/100km,48
IDE10351-MAS10460-Message mirroring-Target bus,not active ,2
IDE10351-MAS21167-Message mirroring-Source bus,Powertrain data bus ,2
IDE10735-Number requests autonomous recharging,9 ,1
IDE11689-48V-System: locking,regular operation ,1
IDE13844-Distance left for deactivation of production mode,200 km,1
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,0.0 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,0.0 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,0.0 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,0.0 kWh/100 km,40
IDE14750-Deactivate all development messages,0 ,5
IDE15316-FoD Partner,Available ,1
IDE15331-Multifunction steering wheel extended adaptation,Configuration 1 ,3
IDE15756-Ethernet port 3 VLAN configuration,VLAN_Comfort and VLAN_Infotainment ,1
IDE15853-Report system for deviations: coding,0 ,3
MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,active ,5
MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,active ,5
MAS08072-ENG172201-Driving profile selection-FPA_Funktion,not active ,5
MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,active ,5
MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,not active ,5
MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,not active ,5
MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,active ,5
MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,not active ,5
MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,active ,5
MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,active ,5
MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,not active ,5
MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,not active ,5
MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,not active ,5
MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,active ,5
MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,not active ,5
MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,active ,5
MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,active ,5
MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,active ,5
MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,not active ,5
MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,active ,5
MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,not active ,5
MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,not active ,5
MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,not active ,5
MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,not active ,5
MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,not active ,5
MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,not active ,5
MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,active ,5
MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Dropping slope on curve ,5
MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Yes ,4
MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Yes ,4
MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Yes ,4
MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,No ,4
MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,No ,4
MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,No ,4
MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,No ,4
MAS16743-Alternator gear ratio,73 ,1
SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,installed ,3
SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,active with terminal 58 ,3
SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multi-function steering wheel control module-Variant,Low (audio/instrument cluster) ,3
SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,installed ,3
SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,not active ,3
SFT271921-MAS13892-Multi-function steering wheel control module-Platform,MQB ,3
SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,not active ,3
SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),automatic ,3
SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),automatic ,3
SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,invalid ,3
SFT272190-Steering Wheel Touch Recognition Control Module,No Response From Subnet Component,3
ENG253073-Diagnostic_filter_permanent_deactivation,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG253088-EM_function_variant_EM-HLR,0 ,1
ENG279934-ENG280094-Engress_filter-packet_based_/_port_shaper_burst_size_configuration,2000 ,10
ENG279934-ENG280095-Engress_filter-packet_based_/_port_shaper_shaping_rate_configuration,2000 packets/s,10
ENG279934-ENG280098-Engress_filter-port_shaper_bucket_count_select,packet_based ,10
ENG279934-ENG280099-Engress_filter-port_shaper_enabling,enable_shaper ,10
ENG253271-ENG259280-GW_Content_list-Bus_ID,00 ,48
ENG253271-ENG253458-GW_Content_list-Node_address,00 00 ,48
ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,On ,8
ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,On ,8
ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,On ,8
ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,On ,8
ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,On ,8
ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,On ,8
ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,On ,8
ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,On ,8
ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,On ,8
ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,On ,8
ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,On ,8
ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,On ,8
ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,On ,8
ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,On ,8
ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,On ,8
ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,On ,8
ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,On ,8
ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,On ,8
ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,On ,8
ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,On ,8
ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,On ,8
ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,On ,8
ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,On ,8
ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,On ,8
ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,On ,8
ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,On ,8
ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,On ,8
ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,On ,8
ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,On ,8
ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,On ,8
ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,On ,8
ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,On ,8
ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,On ,8
ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,On ,8
ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,On ,8
ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,On ,8
ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,On ,8
ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,On ,8
ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,On ,8
ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,On ,8
ENG253192-MAS01898-IDS_white_list_features-Drive train,On ,1
ENG253192-MAS16574-IDS_white_list_features-Infotainment,On ,1
ENG253396-Mirroring_LIN3_to_LIN4,No ,1
ENG137850-MVK_Warning,regular operation ,1
ENG253252-ENG260330-Node_to_cluster_list-NCL_element_1,00 00 00 00 00 ,160
ENG253252-ENG260846-Node_to_cluster_list-NCL_element_10,00 00 00 00 00 ,160
ENG253252-ENG258686-Node_to_cluster_list-NCL_element_11,00 00 00 00 00 ,160
ENG253252-ENG259563-Node_to_cluster_list-NCL_element_12,00 00 00 00 00 ,160
ENG253252-ENG259135-Node_to_cluster_list-NCL_element_13,00 00 00 00 00 ,160
ENG253252-ENG261302-Node_to_cluster_list-NCL_element_14,00 00 00 00 00 ,160
ENG253252-ENG259590-Node_to_cluster_list-NCL_element_15,00 00 00 00 00 ,160
ENG253252-ENG261163-Node_to_cluster_list-NCL_element_16,00 00 00 00 00 ,160
ENG253252-ENG258229-Node_to_cluster_list-NCL_element_17,00 00 00 00 00 ,160
ENG253252-ENG259389-Node_to_cluster_list-NCL_element_18,00 00 00 00 00 ,160
ENG253252-ENG260540-Node_to_cluster_list-NCL_element_19,00 00 00 00 00 ,160
ENG253252-ENG259624-Node_to_cluster_list-NCL_element_2,00 00 00 00 00 ,160
ENG253252-ENG258136-Node_to_cluster_list-NCL_element_20,00 00 00 00 00 ,160
ENG253252-ENG261360-Node_to_cluster_list-NCL_element_21,00 00 00 00 00 ,160
ENG253252-ENG260775-Node_to_cluster_list-NCL_element_22,00 00 00 00 00 ,160
ENG253252-ENG259077-Node_to_cluster_list-NCL_element_23,00 00 00 00 00 ,160
ENG253252-ENG259062-Node_to_cluster_list-NCL_element_24,00 00 00 00 00 ,160
ENG253252-ENG260421-Node_to_cluster_list-NCL_element_25,00 00 00 00 00 ,160
ENG253252-ENG261354-Node_to_cluster_list-NCL_element_26,00 00 00 00 00 ,160
ENG253252-ENG258201-Node_to_cluster_list-NCL_element_27,00 00 00 00 00 ,160
ENG253252-ENG260110-Node_to_cluster_list-NCL_element_28,00 00 00 00 00 ,160
ENG253252-ENG258645-Node_to_cluster_list-NCL_element_29,00 00 00 00 00 ,160
ENG253252-ENG261260-Node_to_cluster_list-NCL_element_3,00 00 00 00 00 ,160
ENG253252-ENG259078-Node_to_cluster_list-NCL_element_30,00 00 00 00 00 ,160
ENG253252-ENG260192-Node_to_cluster_list-NCL_element_31,00 00 00 00 00 ,160
ENG253252-ENG259747-Node_to_cluster_list-NCL_element_32,00 00 00 00 00 ,160
ENG253252-ENG259375-Node_to_cluster_list-NCL_element_4,00 00 00 00 00 ,160
ENG253252-ENG259916-Node_to_cluster_list-NCL_element_5,00 00 00 00 00 ,160
ENG253252-ENG260559-Node_to_cluster_list-NCL_element_6,00 00 00 00 00 ,160
ENG253252-ENG259415-Node_to_cluster_list-NCL_element_7,00 00 00 00 00 ,160
ENG253252-ENG260302-Node_to_cluster_list-NCL_element_8,00 00 00 00 00 ,160
ENG253252-ENG259224-Node_to_cluster_list-NCL_element_9,00 00 00 00 00 ,160
ENG253340-SFD_Testmode,not active ,1
ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,00 00 01 ,24
ENG253268-MAS03174-TCR_bus_can-Comfort data bus,00 00 30 ,24
ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,00 01 C0 ,24
ENG253268-MAS03178-TCR_bus_can-Suspension data bus,00 00 04 ,24
ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,00 00 00 ,24
ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,00 00 02 ,24
ENG253268-MAS16909-TCR_bus_can-Data bus driver assistance systems,00 00 08 ,24
ENG253268-MAS16910-TCR_bus_can-Migration data bus,00 00 01 ,24
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,00 01 C0 ,12
ENG253184-MAS03180-TCR_bus_lin-Local data bus,00 00 00 ,12
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,00 00 00 ,12
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,00 00 00 ,12
ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,00 04 00 ,24
ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,00 20 00 ,24
ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,00 08 00 ,24
ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,00 02 00 ,24
ENG253199-MAS18934-TCR_bus_vlan-VLAN Connect,00 10 00 ,24
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,10
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,10
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,10
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,10
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,10
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,10
ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,1800 s,10
Elapsed Time: 00:22
adpmap-23-5WA-909-059-Q_TMBAJ7NXXNY096941-20260703-1358.CSV
;SW:5WA-909-059-Q   HW:3Q0-909-059-C ---  23: Brake Booster
;Component:EBKV          H09 0309, Coding:1002C100230000CE39E79C73000049922449922400
;EV_BrakeBoostG2BoschVW37W,016028,EV_BrakeBoostG2BoschVW37W_016_VW38.rod
;Friday,03,July,2026,13:58:55:12012
;VCID: DEEE74A950B5FB3A04E-808A SFD {x}
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,20 min,2
IDE11447-electro-mechanical brake booster,active ,1
IDE11985-Expected OBD requirements-,EOBD ,2
IDE11985-Expected OBD requirements-,Combustion engine ,2
IDE14698-Parameters of leak test-,17.0000000 mm,20
IDE14698-Parameters of leak test-,30.0000000 mm/s,20
IDE14698-Parameters of leak test-,5 ,20
IDE14698-Parameters of leak test-,0.5 s,20
IDE14698-Parameters of leak test-,0.0 s,20
IDE14698-Parameters of leak test-,15.0000000 mm,20
IDE14698-Parameters of leak test-,10.0000000 mm/s,20
IDE14698-Parameters of leak test-,12.0 s,20
IDE14698-Parameters of leak test-,10.0 s,20
IDE14698-Parameters of leak test-,50 bar,20
IDE14698-Parameters of leak test-,6.0000000 mm,20
IDE14698-Parameters of leak test-,12.0000000 mm,20
IDE14699-Parameters of heaviness test-,12.0000000 mm,13
IDE14699-Parameters of heaviness test-,30.0000000 mm/s,13
IDE14699-Parameters of heaviness test-,5 ,13
IDE14699-Parameters of heaviness test-,0.5 s,13
IDE14699-Parameters of heaviness test-,0.0 s,13
IDE14699-Parameters of heaviness test-,1.29980468750 Nm,13
IDE14699-Parameters of heaviness test-,50.0000000 mm/s,13
IDE14700-Parameters of ventilation routine-,21.0000000 mm,18
IDE14700-Parameters of ventilation routine-,180.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,25 ,18
IDE14700-Parameters of ventilation routine-,50.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,0.0 s,18
IDE14700-Parameters of ventilation routine-,30.0000000 mm,18
IDE14700-Parameters of ventilation routine-,5.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,5 ,18
IDE14700-Parameters of ventilation routine-,1.7968750 mm/s,18
IDE14700-Parameters of ventilation routine-,1.0 s,18
IDE80111-Analysis 111,active ,1
IDE80121-Analysis 121-,80 s,2
IDE80121-Analysis 121-,0 ,2
IDE80122-Analysis 122-,10 s,2
IDE80122-Analysis 122-,0 ,2
IDE80123-Analysis 123,OFF ,1
IDE80124-Analysis 124-,00 ,2
IDE80124-Analysis 124-,0 ,2
IDE80125-Analysis 125-,0 ,2
IDE80126-Analysis 126,0 ,2
IDE80131-MAS05513-Analysis 131-Bit 0,OFF ,1
IDE80131-MAS05514-Analysis 131-Bit 1,OFF ,1
IDE80131-MAS05515-Analysis 131-Bit 2,OFF ,1
IDE80131-MAS05516-Analysis 131-Bit 3,OFF ,1
IDE80131-MAS05517-Analysis 131-Bit 4,OFF ,1
IDE80131-MAS05518-Analysis 131-Bit 5,OFF ,1
IDE80131-MAS05519-Analysis 131-Bit 6,OFF ,1
IDE80131-MAS05520-Analysis 131-Bit 7,OFF ,1
IDE80134-Analysis 134-,00 00 00 00 ,40
IDE80134-Analysis 134-,00 ,40
IDE80135-Analysis 135-,00 00 00 00 ,40
IDE80135-Analysis 135-,00 ,40
IDE80136-Analysis 136-,00 00 00 00 ,40
IDE80136-Analysis 136-,00 ,40
IDE80137-Analysis 137-,00 00 00 00 ,40
IDE80137-Analysis 137-,00 ,40
MAS00194----,00 00 ,2
Elapsed Time: 00:07
adpmap-2B-2Q0-905-861-B_TMBAJ7NXXNY096941-20260703-1359.CSV
;SW:2Q0-905-861-B   HW:2Q0-905-861-B ---  2B: Steer. Col. Lock
;Component:ELV-MQBB      H09 0040, Coding:8800000000000000
;EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW38.rod
;Friday,03,July,2026,13:59:11:12012
;VCID: B236F01974AD0F5A906-80E6
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,not tested ,1
Elapsed Time: 00:01
adpmap-42-5Q4-959-593-P_TMBAJ7NXXNY096941-20260703-1359.CSV
;SW:5Q4-959-593-P   HW:5Q4-959-593-P ---  42: Door Elect, Driver
;Component:TSG FS        011 0912, Coding:001C0120D000020000001120
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW27.rod
;Friday,03,July,2026,13:59:28:12012
;VCID: D2F69099146D2F5AB06-8086
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,00 00 ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 09 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 C0 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF BF FF 00 00 00 0A 01 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,54 6B ,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,02 EE 02 8A 14 EC 02 02 02 0A 00 00 00 00 05 3C 02 12 19 0A 00 05 F1 1E 1E 14 00 05 FB 0A 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 01 19 1E 20 1E FA D8 C4 F6 FB 28 1E 32 0A 1E 00 00 32 02 20 0E 12 10 FA F6 F1 F6 FB 19 14 28 00 09 1E 00 FA 02 20 0E 12 10 FA EC E2 F6 FB 1E 14 28 00 0A 1E 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,CD 0F ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 5E 01 72 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 8C 00 C3 32 3C C8 00 4E 00 4D 79 64 64 32 60 CD 6D C7 64 14 32 0A 0A 60 E6 6D D9 64 14 32 0A 0A 14 00 00 37 41 32 32 01 00 00 00 00 00 00 00 00 00 F3 AB ,88
Elapsed Time: 00:08
adpmap-44-5WA-907-144-G_TMBAJ7NXXNY096941-20260703-1359.CSV
;SW:5WA-907-144-G   HW:5WA-907-144-C ---  44: Steering Assist
;Component:BASGEN1MQB37  102 1040, Coding:0000000000000000000002010100010000000101000101
;EV_SteerAssisBASGEN1MQB37,007046,EV_SteerAssisBASGEN1MQB37_007.rod
;Friday,03,July,2026,13:59:49:12012
;VCID: CDCC83E50D5370A2ED4-8098
IDE03724-Straight line running,Active: with learned value ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Direct: controlled over threshold value ,1
IDE06657-Steering angle: calculated,not active ,1
IDE06678-Pull compensation,Active: without learned value ,1
IDE09571-RPM monitoring,active ,1
IDE14345-Lateral assistant coordinator: parking assist,not active ,1
IDE14346-Lateral assistant coordinator: reduced stopping distance,active ,1
IDE14347-Lateral assistance coordinator: lane assist,active ,1
IDE14348-Lateral assistant coordination: counter-steering assist,active ,1
IDE15619-Maneuvering assistant lateral control coordinator,not active ,1
MAS09008-Plausibility check,not active ,1
Elapsed Time: 00:04
adpmap-52-5Q4-959-592-P_TMBAJ7NXXNY096941-20260703-1400.CSV
;SW:5Q4-959-592-P   HW:5Q4-959-592-P ---  52: Door Elect, Pass.
;Component:TSG BFS       011 0912, Coding:001C0120D000020000001120
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW27.rod
;Friday,03,July,2026,14:00:09:12012
;VCID: D1F49F95116B544289C-8084
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,00 00 ,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 09 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 C0 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF BF FF 00 00 00 0A 01 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,07 E3 ,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,02 EE 02 8A 14 EC 02 02 02 0A 00 00 00 00 05 3C 02 12 19 0A 00 05 F1 1E 1E 14 00 05 FB 0A 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 01 19 1E 20 1E FA D8 C4 F6 FB 28 1E 32 0A 1E 00 00 32 02 20 0E 12 10 FA F6 F1 F6 FB 19 14 28 00 09 1E 00 FA 02 20 0E 12 10 FA EC E2 F6 FB 1E 14 28 00 0A 1E 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,CD 0F ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 5E 01 72 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 8C 00 C3 32 3C C8 00 4E 00 4D 79 00 00 32 60 CD 6D C7 64 14 32 0A 0A 60 E6 6D D9 64 14 32 0A 0A 14 00 00 37 41 32 32 01 00 00 00 00 00 00 00 00 00 FE 2D ,88
Elapsed Time: 00:08
adpmap-6C-5WA-980-556-D_TMBAJ7NXXNY096941-20260703-1400.CSV
;SW:5WA-980-556-D   HW:5WA-980-556-B ---  6C: Back-up Cam.
;Component:RV eCompact   H30 0344, Coding:03033260843000
;EV_CamSysRVCCompaFicos,010024,EV_CamSysRVCCompaFicos_010_VW38.rod
;Friday,03,July,2026,14:00:29:12012
IDE00001-IDE15846-Production mode-Camera cleaning,not active ,3
IDE00001-MAS03384-Production mode-Blindness detection,not active ,3
IDE00001-MAS21952-Production mode-online calibration,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,63 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,71 min,2
ENG153885-Knockout_test_mode,0 ,1
Elapsed Time: 00:03
adpmap-75-5WA-035-284-J_TMBAJ7NXXNY096941-20260703-1402.CSV
;SW:5WA-035-284-J   HW:5WA-035-284-C ---  75: Telematics
;Component:OCU3HMQB37W   H12 0311, Coding:033810109069A8A09005460061052607
;EV_OCU3HMQB37W,002029,EV_OCU3HMQB37W_002_VW38.rod
;Friday,03,July,2026,14:02:04:12012
;VCID: CDCC83E50D5370A2ED4-8098 SFD {x}
IDE00608-MAS00713-Fuel type-Petrol,not installed ,1
IDE00608-MAS00716-Fuel type-Diesel,installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,not installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,1000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE02330-Call number 2 for info call,+33364119982    ,15
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG252092-Vehicle function list CAN-Dash_Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,not activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,not activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior lighting,activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multi-function display,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Air Conditioning,activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane departure warning,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,not activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up-Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Road sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Auxiliary heating,activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,not activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,not activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,11
IDE04307-MAS07249-Vehicle function list BAP-Main beam,activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,not activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,activated ,11
IDE04307-MAS20539-Vehicle function list BAP-BAP distance PaCo_0x55,activated ,11
IDE04307-MAS20545-Vehicle function list BAP-BAP distance doors2_0x63,not activated ,11
IDE04307-MAS20550-Vehicle function list BAP-BAP distance infotainment_settings_0x50,activated ,11
IDE04307-MAS20553-Vehicle function list BAP-BAP distance mirror_0x0E,activated ,11
IDE04307-MAS20556-Vehicle function list BAP-BAP distance unit_master_0x13,activated ,11
IDE04307-MAS22226-Vehicle function list BAP-BAP distance REM_0x5B,activated ,11
IDE04307-MAS22227-Vehicle function list BAP-BAP distance REM2_0x67,activated ,11
IDE04307-MAS22228-Vehicle function list BAP-BAP distance remote_services_0x4E,not activated ,11
IDE04307-MAS22229-Vehicle function list BAP-BAP distance info_settings_0x50_Buszuordnung,Ethernet ,11
IDE04307-MAS23125-Vehicle function list BAP-BAP distance RemonteStartOnline_0x70,not activated ,11
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,255 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,60 min,2
IDE07699-Mobile network operator,info.m2mcubic.com ,17
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE09244-Fuel tank volume,66 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,not activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,not activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,40 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,10 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14170-Timeout for service key query,10 ,1
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Tracking Data group selected ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic settings not detected guest: services,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with balancing of interests,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with consent,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Maximum private sphere in shape 2 ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,not activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE15695-Front radar-based localization-,activated ,1
IDE15695-ENG263520-Front radar-based localization-Front_radar_rem_data_output,activated ,1
MAS01078-Vehicle model,Passenger car (category M1) ,1
MAS07110-Muting of audio sources,Muting not active ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://mod3vkmsmbbreg-0.prd.eu.dp.vwg-connect.com/mbb/vehicles/v2/registration/        ,513
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,513
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,MBB ,513
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Normal/Hybrid ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,2 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-Transmission interval below threshold,5 %,3
MAS13840-Gnss data transmission rate,10 Hz ,2
MAS13841-Gnss min height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Rear left door,installed ,1
MAS17427-MAS00221-Door configuration-Rear right door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,not installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,not installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17554-Digital key: backend notification,not activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,OFF ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Accident,OFF ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,OFF ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,OFF ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,OFF ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,OFF ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_30 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,02 01 02 01 6B 6D 32 6D 63 75 62 69 63 2E 63 6F 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 64 70 2E 76 77 67 2D 63 6F 6E 6E 65 63 74 2E 63 6F 6D 2F 6D 62 62 2F 76 65 68 69 63 6C 65 73 2F 76 32 2F 72 65 67 69 73 74 72 61 74 69 6F 6E 2F 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,400 ms,1
MAS19213-Operation during severe BAP errors while storing data,Continue operation ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,installed ,1
MAS19239-Time window for key recognition,5 min,1
MAS19240-Authorization level after-run time,0 min,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG113413-a2b_data_streams-reserved_01,0 ,10
ENG253242-ENG261390-a2b_data_streams-reserved_02,0 ,10
ENG253242-ENG261450-a2b_data_streams-reserved_03,0 ,10
ENG253242-ENG261451-a2b_data_streams-reserved_04,0 ,10
ENG253242-ENG261386-a2b_data_streams-Reserved_05,0 ,10
ENG253242-ENG261387-a2b_data_streams-Reserved_06,0 ,10
ENG253242-ENG261388-a2b_data_streams-Reserved_07,0 ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG261370-Airbag_Signal_Setting,10 ms ,1
ENG275595-IDE01762-BAP_Connection_Control-Doors,OFF ,25
ENG275595-IDE03031-BAP_Connection_Control-Seat adjustment,OFF ,25
ENG275595-IDE03111-BAP_Connection_Control-Interior lighting,automatic ,25
ENG275595-MAS00688-BAP_Connection_Control-Multi-function display,automatic ,25
ENG275595-MAS01118-BAP_Connection_Control-Air Conditioning,automatic ,25
ENG275595-MAS01282-BAP_Connection_Control-Wiper,automatic ,25
ENG275595-MAS01891-BAP_Connection_Control-Lane departure warning,OFF ,25
ENG275595-MAS02444-BAP_Connection_Control-Central locking,OFF ,25
ENG275595-MAS03385-BAP_Connection_Control-Lane change assistance,OFF ,25
ENG275595-MAS03420-BAP_Connection_Control-Head-Up-Display,OFF ,25
ENG275595-MAS03853-BAP_Connection_Control-Road sign detection,OFF ,25
ENG275595-MAS05087-BAP_Connection_Control-ACC,OFF ,25
ENG275595-MAS05506-BAP_Connection_Control-Stopping distance reduction,OFF ,25
ENG275595-MAS07249-BAP_Connection_Control-Main beam,automatic ,25
ENG275595-MAS08072-BAP_Connection_Control-Driving profile selection,OFF ,25
ENG275595-MAS08785-BAP_Connection_Control-Parking aid,automatic ,25
ENG275595-MAS20539-BAP_Connection_Control-BAP distance PaCo_0x55,automatic ,25
ENG275595-MAS20545-BAP_Connection_Control-BAP distance doors2_0x63,OFF ,25
ENG275595-MAS20550-BAP_Connection_Control-BAP distance infotainment_settings_0x50,automatic ,25
ENG275595-MAS20553-BAP_Connection_Control-BAP distance mirror_0x0E,automatic ,25
ENG275595-MAS20556-BAP_Connection_Control-BAP distance unit_master_0x13,automatic ,25
ENG275595-ENG98891-BAP_Connection_Control-Reserved,OFF ,25
ENG275595-ENG113413-BAP_Connection_Control-reserved_01,OFF ,25
ENG275595-ENG261390-BAP_Connection_Control-reserved_02,OFF ,25
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG253218-ENG113413-function_configuration_a2b_topology-reserved_01,0 ,5
ENG253218-ENG261390-function_configuration_a2b_topology-reserved_02,0 ,5
ENG253218-ENG261450-function_configuration_a2b_topology-reserved_03,0 ,5
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 °,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 °,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 °,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 °,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Direction of travel,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,not activated ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:33
adpmap-A5-5WA-980-653-C_TMBAJ7NXXNY096941-20260703-1403.CSV
;SW:5WA-980-653-C   HW:5WA-980-653 ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H09 3302, Coding:0002088821484040509E00001020002001018000000000000000000000000000
;EV_MFK3ValeoMQB,005050,EV_MFK3ValeoMQB_005_SK38.rod
;Friday,03,July,2026,14:03:32:12012
;VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
;VCID: CFF099ED075F42B29F8-809A
IDE04733-Road sign detection fusion mode-,Security access required,3
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE07358-Distance to calibration field,Security access required,1
IDE09375-IDE05717-Axle offset-Front axle transverse position,Security access required,1
IDE09375-IDE05718-Axle offset-Rear axle transverse position,Security access required,1
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,Security access required,1
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,Security access required,1
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,Security access required,1
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,Security access required,1
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,Security access required,1
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,Security access required,1
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,Security access required,1
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,Security access required,1
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,Security access required,1
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,Security access required,1
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,Security access required,1
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,Security access required,1
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,Security access required,1
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,Security access required,1
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,Security access required,1
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,Security access required,1
IDE10407-Personalization of intervention moment at T. 15 on,Security access required,1
IDE10870-Switch-on condition: lane depart. warn.,Security access required,1
IDE10873-BAP personalization,Security access required,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.000 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.000 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.000 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,0 mm,8
IDE12097-Menu for roadside fusion persistency,Security access required,8
Elapsed Time: 00:08
adpmap-811E-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1403.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  811E: Burglary Protection FL
;Component:Kessy RSAD    070 0636, Coding:
;EV_RSADVL37w,002013,EV_RSADVL37w_002_VW38.rod
;Friday,03,July,2026,14:03:46:12012
;VCID: C7C0B1CDEF2F9AF2D78-8092
ENG253318-Par_Fahrzeugkonfiguration,255 dBµA/m,5
Elapsed Time: 00:01
adpmap-811F-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1403.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  811F: Burglary Protection FR
;EV_RSADVR37w,002013,EV_RSADHL37w_002_VW38.rod
;Friday,03,July,2026,14:03:54:12012
Elapsed Time: 00:01
adpmap-8120-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1404.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  8120: Burglary Protection RL
;EV_RSADHL37w,002013,EV_RSADHL37w_002_VW38.rod
;Friday,03,July,2026,14:04:01:12012
Elapsed Time: 00:01
adpmap-8121-5WA-962-133-B_TMBAJ7NXXNY096941-20260703-1404.CSV
;SW:5WA-962-133-B   HW:5WA-962-133-B ---  8121: Burglary Protection RR
;EV_RSADHR37w,002013,EV_RSADHL37w_002_VW38.rod
;Friday,03,July,2026,14:04:09:12012
Elapsed Time: 00:01
TTT
C?ID=547002
No amount of sfd service will bring a dead alive.
  • Agree
Amedeo
Romania - Rm.Valcea
C?ID=14228
Thank you for the reply. First, I need to rewrite the data for the new battery, which is why I need SFD. After that, I'll see, once I check the causes.
TTT
C?ID=547002
The root cause is electronics weakness against slow drop of input voltage plus voltage spikes when alternator does not have a place to dump energy. For long term storage, beter disconnect the battery, that won't hurt a thing.
5F you can already start your diagnostic, wiring diagrams, test lamp, oscilloscope for checking comms.
Amedeo
Romania - Rm.Valcea
C?ID=14228
Update: I disconnected and reconnected the infotainment/navigation unit (5E3 035 816 H, address 5F, MIB3). I noticed the cooling fan is not spinning. I gently blew some compressed air on it, and managed to get a full auto-scan with almost no faults. Shortly after, it started cutting out again and stopped communicating.
It looks like the fan on this unit has failed, causing it to overheat and enter a repeated shutdown/reboot cycle. I'll likely need to replace the unit with a used one (same part family, 5E3 035 816).
Since this module is SFD-protected, I assume the replacement unit will also need to go through the SFD process to be properly coded/matched to this VIN. Could you confirm if that's the case, and whether this changes anything about my request for an exception?
Friday,03,July,2026,17:42:10:12012
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4713.5
Dealer/Shop Name:  Amedeo  --->>>  tel: 0767.074.575
Workshop Code: 599 10101 012131
VIN: TMBAJ7NXXNY096941   License Plate: VL42DNA
Mileage: 143433km-89125mi   Repair Order: 1
Chassis Type: NX-SK38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6C 75 A5
          BB BC 811E 811F 8120 8121 C002 C003
VIN: TMBAJ7NXXNY096941   Mileage: 143433km-89125miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DTTC)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 022 KT    HW: 05L 907 309 AA
   Component: R4 2.0l TDI   H80 1998
   Revision: ECH80---    Dataset Number: V03935358XK 0001 CVN: 48D95515914A6D2022E7CED8914A6D2043FB2DAA
   Coding: 012508320364050970080000000000000000000000000000
   Shop #: WSC 31000 790 00270
   ASAM Dataset: EV_ECM20TDI01105L906022KT 007001
   ROD: EV_ECM20TDI01105L906022KT.rod
   VCID: 0358E5DD1B97F6D2D21-8056
   VINID: 91D4916877A8A1EA4024624404DE3158BC
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1       H13 0110
   Serial number: 20220224060604070152
Readiness: 0 0 0 1 1
   Part No SW: 0GC 906 555 K    HW: 0GC 300 047
   Component: GSG DQ381     H06 5080
   CVN: 8FC55133
   ASAM Dataset: EV_TCMDQ381062 001020
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 43D825DD5B1736D2921-8016
   Subsystem 1 - Part No SW: 5WA 713 033 BB    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20220309000080744319
   Subsystem 2 - Part No SW: 5E4 713 203     HW: 5E4 713 203
   Component: ZSB_SB_mono    H02 0025
   Serial number: 22 020 0630 L 1 U1B9
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810600003922689
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BL    HW: 5WA 614 517 N
   Component: ESC           H13 0133
   Serial number: 60482000000667  Dataset Number: V03935351BG 0001 CVN: 01B7675E
   Coding: 34072CA422294472528050040AC461866DB658F55AC8670821BCA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 1378D59D6BF76652621-8046 SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 J    HW: 5WA 959 436 J
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935347FV 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 5BE8FDBDC3A76E12FA1-800E
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 AC    HW: 5WA 907 727 AC
   Component: Climatronic   H02 0440
   Serial number: --------------- Dataset Number: V03935336HW 0001
   Coding: 101010010211120000100010101011110000112100100000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005069
   ROD: EV_ACClimaBHBVW38X_VW38.rod
   VCID: 1174DF9551EB944250D-8044
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000000960495
   Interior temperature sensor:
   Subsystem 2 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002140322122123512
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 AE    HW: 5WA 937 086 L
   Component: BCM37w_M028 0175
   Serial number: BXJ53F100422940 Dataset Number: V03935372UU 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_AU38.rod
   VCID: 147AD6816EF9616A7BB-8040 SFD
   Subsystem 1 - Part No SW: 5E4 955 119 A    HW: 5E4 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: J400FRWISCH    067 0084
   Serial number: 907453F0402206400688
   Component: G397_RLFSS     H06 0004
   Serial number: 43287277X81A955555B0
   Subsystem 3 - Part No SW: 5E4 941 501 A    HW: 5E4 941 501
   Component: E1-LTM         H30 0550
   Serial number: 00000000000000000241
   Subsystem 4 - Part No SW: 5E3 925 200 F    HW: 5E3 925 200 F
   Component: DiETa          H04 0002
   Serial number: 01557VD2000CS
   Subsystem 5 - Part No SW: 5E3 959 569 A    HW: 5E3 959 569 A
   Component: DACHKONSOLE    101 0104
   Serial number: 000000092413VKG00300
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 EP    HW: 5Q1 953 549 F
   Serial number: 00000024022204400507
   Left taillight 1:
   Subsystem 7 - Part No SW: 5E3 945 207 A    HW: 5E3 945 207 A
   Component: SHL_li1        005 1214
   Serial number: ABMRO128012200041511
   Left taillight 2:
   Subsystem 8 - Part No SW: 5E6 945 307 A    HW: 5E6 945 307 A
   Component: SHL_li2        005 1214
   Serial number: ABMRO111032200041118
   Right taillight 1:
   Subsystem 9 - Part No SW: 5E3 945 208 A    HW: 5E3 945 208 A
   Component: SHL_re1        005 1214
   Serial number: ABMRO121022200042469
   Right taillight 2:
   Subsystem 10 - Part No SW: 5E6 945 308 A    HW: 5E6 945 308 A
   Component: SHL_re2        005 1214
   Serial number: ABMRO110022200051672
   Part No SW: 5WA 919 294 C    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0577
   Serial number: 000006042294560 Dataset Number: V03935348FY 0001
   Coding: 0040010011
   ASAM Dataset: EV_EPHBO18VW3800000 002029
   ROD: EV_EPHBO18VW3800000_AU38.rod
   VCID: 52F61099946DAF5A297-8006
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Dataset Number: V03935354QE 0001
   Coding: 0903007D0077404512474000004040C54E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4DCC03E58D53F0A2745-8018
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 DL    HW: 1EA 959 655 DL
   Component: VW40Airbag    010 0176
   Serial number: W100SkE02D4     Dataset Number: V03935354YD 0001
   Coding: 98CC000000C0C000000000000000000050540000205400004000F68000120065
   Shop #: WSC 31000 074 00352
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_VWE3.rod
   VCID: 0E4EC4E940D58BBA4DF-805A SFD
   Subsystem 1 - Part No SW: -----------    HW: 440 002 202 22
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ0000002A851BD5F
   Subsystem 2 - Part No SW: -----------    HW: 440 002 202 22
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000F5951BD5P
   Subsystem 3 - Part No SW: -----------    HW: 440 000 104 22
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJAB07487D683500-
   Subsystem 4 - Part No SW: -----------    HW: 440 000 104 22
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJAB081A9E417D000
   Subsystem 5 - Part No SW: -----------    HW: 440 002 707 21
   Component: FrontSensor_D  00A 014A
   Serial number: 355CJ9900ABA0153D00T
   Part No SW: 5E3 920 770 B    HW: 5E3 920 770 B
   Component: KOMBI         201 5370
   Dataset Number: V03935369QW 0001
   Coding: 04A4004063840008018462032000080800301400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003033
   ROD: EV_DashBoardVDDMQB37W_003_SK38.rod
   VCID: 28029271C271F58AA73-807C SFD
16777018 - Control unit for information electronics 1
          U1054 00 [00001001] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.07.01
                    Time: 00:17:01
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 241
                    Mileage: 143433 km
                    Date: 2026.07.01
                    Time: 00:17:01
   Part No SW: 5WA 907 530 Q    HW: 5WA 907 530 G
   Component: GW2020 High   756 7300
   Revision: --------    Serial number: 260160902151243 Dataset Number: V03935355TE 0001
   Coding: 0000838D0700000000000000010303325301600902000300030100000001010100000000000000000000000000000000
   GVL: 3D0000000208408C80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 005011
   ROD: EV_GatewMQB2020_004_VW41.rod
   VCID: 56FEEC89B885B37AC5F-8002 SFD
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 1368879305
   Subsystem 3 - Part No SW: 5E3 919 719 Q    HW: 5E3 919 719 Q
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440061091223099
   Part No SW: 5WA 909 059 Q    HW: 3Q0 909 059 C
   Component: EBKV          H09 0309
   Serial number: BPA085180222013 Dataset Number: V03935354NE 0001
   Coding: 1002C100230000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 5EEEF4A9D0B57B3A9DF-800A SFD
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000098149011 Dataset Number: V03935308NF 0001
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 32367019F4AD8F5A097-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000459589293  Dataset Number: V03935365VU 0001
   Coding: 001C0120D000020000001120
   Shop #: WSC 31000 790 00352
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000058878969
   Coding: 110200
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1040
   Serial number: 01037468 Dataset Number: V03935362VR 0001
   Coding: 0000000000000000000002010100010000000101000101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000461357778  Dataset Number: V03935365VZ 0001
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   VCID: 51F41F95916BD44210D-8004
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000058998964
   Coding: 090200
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5E3 035 816 H    HW: 5E3 035 816
   Component: MU-O-ND-EU    H58 1989
   Serial number: WG8LGM200422000 Dataset Number: V03935369QR 0001
   Coding: 33810000008000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_SK38.rod
   VCID: 2C0A6E61D689D9AA43B-8078-R SFD
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20050322010 Dataset Number: V03935343SU 0001
   Coding: 03033260843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   Part No SW: 5WA 035 284 J    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H12 0311
   Serial number: 0000000203VITD6 Dataset Number: V03935361QW 0001
   Coding: 033810109069A8A09005460061052607
   ASAM Dataset: EV_OCU3HMQB37W 002029
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 4DCC03E58D53F0A2745-8018 SFD
   Part No SW: 5WA 980 653 C    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3302
   Serial number: E82645704221110 Dataset Number: V03935360CJ 0001
   Coding: 0002088821484040509E00001020002001018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_SK38.rod
   VCID: 4FF019ED875FC2B2069-801A
1122626 - Databus
          [Timeout_Mainunit_01]
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.07.01
                    Time: 00:18:24
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 0
                    Mileage: 143433 km
                    Date: 2026.07.01
                    Time: 00:18:21
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 47C031CD6F2F1AF24E9-8012
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:35, VBatt start/end: 12.9V/12.9V)-----------
------------------------------4 Faults Found-------------------------------
"SFD Service is currently not available for this Interface - Serial Number [Redacted]."
Could you please advise how I can proceed?
Your HEX-NET is from 2021 and doesn't qualify for a free year of SFD Service. However, you've posted enough data that I've given it an exception for temporary service, so try again.
That said, I don't believe SFD Service will solve your problems.
I believe that replacing this module is more complicated than that. SFD replaces Security Access, but I do not think it replaces Component Protection.
NEtech
Denmark
C?ID=56995
[Information electronics control module 1No Communication]
Extra DTC information in Engine.
@Eric is this a bug?
Or is the "No Communication" text correct there.
Eric
HC800000
What would you consider a bug? Sometimes the DTC tip is unfortunately just a rephrase of the main DTC :(
NEtech
Denmark
C?ID=56995
This is on the line above: U1054 00 [00101111] - No Communication
And there is no space after "1"
Amedeo
Romania - Rm.Valcea
C?ID=14228
Thank you respectfully for the exception, Uwe.
Regarding your comment about Component Protection: for a few days, the client took the unit to a local electronics repair technician, who promised he could fix it. If the repair turns out not to be possible, I've found a used unit in Lithuania, though shipping takes about three weeks.
For now, the car is with me, with the unit removed. If I end up replacing it with a used unit, I'm hoping Component Protection can be resolved at the dealership.
Amedeo
Romania - Rm.Valcea
C?ID=14228
Thank you all for your time and advice in this thread.
Update: the 5F unit works perfectly for a few minutes, while it's still cold, right after I connect power to it. The fan isn't working, so it heats up fairly quickly and then loses communication — exactly as shown in the last scan I posted.
For now I'm waiting for the unit to come back from repair. I'll keep you posted.
