Audi Q7 Etron air suspension problem
Tbjorstad
Norway
C?ID=651221
Hi,
I'm hoping someone can point me in the right direction.
I've been troubleshooting the air suspension on my Audi for a while. I recently replaced one of the ride height sensors and successfully completed the suspension calibration using the guides on this forum. The suspension now appears to be working normally, and the vehicle raises and lowers as expected.
However, I still have one fault that I can't clear:
"Basic setting of deflected position not performed."
I've tried running the basic setting multiple times and have followed several forum threads describing the procedure, but every attempt ends with the same message:
"ERROR: Conditions not correct or request sequence error."
I'm obviously missing something, but I can't figure out what. Is there a specific prerequisite or sequence that needs to be followed before performing the deflected position basic setting?
Any advice would be greatly appreciated.
Thanks!
Thursday,02,July,2026,22:02:15:43336
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: WAUZZZ4M7JD014628   License Plate:
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 18 19 23 29 36 39 3C 42 44 46
          47 51 52 5F 65 69 6C 6D 74 81 82 84 8B 8C A5 AC BA BB BC C5
          C6 CA CF D6 D7
VIN: WAUZZZ4M7JD014628   Mileage: 172381km-107112miles
74-Chassis Control -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CVZA)       Labels:. 059-907-401-V3.clb
   Part No SW: 4M0 907 401 A    HW: 059 907 309 F
   Component: 3.0TDI MD1    H24 0010
   Revision: C7H24---    CVN: 67C2796F5C4C9900755A2113755A2113
   Coding: 2A2A403A057E050335382B00000000000000000000000000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM30TDI0114M0907401A 001018
   ROD: EV_ECM30TDI0114M0907401A.rod
   VCID: 270C190E7F6780B2AE9-8072
   VINID: 9D196AAAA11D1DA50004418220F799516F
   Active accelerator pedal:
   Subsystem 1 - Part No SW: 4M1 723 523     HW: 4M1 723 523
   Component: J1115 - FFP  H18 0008
   Serial number: 123456789ABCDEFGHIJK
   Clutch electronics 1:
   Subsystem 2 - Part No SW: 0D7 142 057 D    HW: 0D7 142 057 D
   Component: J1128 CCU  H04 0033
   Part No SW: 4M0 927 158 M    HW: 0D7 927 156 B
   Component: 0D7 30TDIRdW  H05 1012
   Revision: --H05---    CVN: 74BB8865
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002011
   ROD: EV_TCMALX52011.rod
   VCID: 3E22DC6A80FD217AFDF-806A
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component:     V552 ATFP  D.4 0000
   Serial number:             00009250
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 P    HW: 4M0 907 379 P
   Component: ESP9 Premium  H09 0649
   CVN: 9E814F6B
   Coding: 2C9830B232A30A9AD1A41893188512AEF6A6DA340C4C508B181848756F655B
   ASAM Dataset: EV_ESP9BOSCHAU536P 011013
   ROD: EV_ESP9BOSCHAU536P_AU73.rod
   VCID: 44D6AE82EE114BAAABB-8010
   Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
   Component: MEM-BFS       008 0031
   Serial number: 00000270227644 Dataset Number: 4M0909866C  0016
   Coding: 001010000000B0410000010101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3B24D57E93EF3452DA1-806E
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 3  H52 0100
   Coding: 661A48094549410D06220280820000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 678C590EBFE740B26E9-8032
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001866255
   Humidity sensor: exterior:
   Serial number: C95093C800PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: E265 Kli Fond  H40 0080
263425 - Temperature Sensor for Rear Right Seat
          B1114 01 [00001001] - Electrical Failure
                    Reset counter: 174
                    Mileage: 172381 km
                    Date: 2026.07.02
                    Time: 21:38:39
                    Voltage terminal 30: 12.23 V
                    Outside temperature: 18.50 °C
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514AA 0054
   Coding: 07501943C13900CD4501571958BF8CF9130331019000000000000000E00016810A4502AB32B71A
   VCID: 025A689AB485859AD97-8056
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 170708  044 0893
   Serial number: 90115300401718900479
   Coding: 1BC7F7
   Serial number: 20387838X81A955547A0
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 AD    HW: 4M0 941 531 AD
   Component: E1 - LDS  H06 0008
   Serial number: 04 07 2017  01013226
   Serial number: GX1CE112051723510536
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00475630
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA128783000037025605
   Coding: 0A0100
   Subsystem 7 - Part No SW: 4M0 925 301 S    HW: 4M0 925 301 S
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000007168
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 D    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Dataset Number: 4M0909863L  0031
   Coding: 5477FFFB58FFEC0A949C80E0
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3138F75641A3CE0270D-8064
Address 15: Airbags (J234)       Labels:| 8W0-959-655-V1.clb
   Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
   Component: Airbag10.44   H01 0106
   Serial number: 003UL001B9MB Dataset Number: 4M0909602AH 0003
   Coding: AAFCF0C00CA0000098F600F3D04C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 3D20DB668DFB3A62E45-8068
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705L0242R01819
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706M0238R00063
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 062 807 17
   Serial number: 3577Y00BB2474D50E0DB
   Subsystem 4 - Part No SW: -----------    HW: 442 062 807 17
   Serial number: 3587Y00BD2474D52B077
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 906 17
   Serial number: 35177009D26ED1B371FW
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 906 17
   Serial number: 3527700BF2694C94D0CZ
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 807 17
   Serial number: 3557500C12757C03F37D
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 807 17
   Serial number: 3567500C12757C0312B3
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 407 17
   Serial number: 23075009B277227101E.
   Subsystem 10 - Part No SW: -----------    HW: 442 420 708 17
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00C3249F6C1022H
   Subsystem 11 - Part No SW: -----------    HW: 442 420 708 17
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00BB249F6C1518Z
   Part No SW: 4M0 907 129 JE    HW: 4M0 907 129 JE
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7CA61662D661F36A93B-8028
   Part No SW: 4M0 920 794 C    HW: 4M0 920 794 C
   Component: FHybRDW       H18 0370
   Coding: 050401C07C98000800A669703204600000000000
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 3334FD5EBBBFFC12021-8066
Address 18: Aux. Heat (J364)       Labels:| 4M0-265-105.clb
   Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
   Component: HSG           H11 0090
   Dataset Number: 4M0909858E  0017
   Coding: 0D0803
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: 29081F366973B6C2B8D-807C
   Part No SW: 8W7 907 468 E    HW: 8W7 907 468 E
   Component: Gateway       H42 0118
   Revision: 6C020003    Serial number: 0386C759217824 Dataset Number: 4M0909515L  0080
   Coding: 02010101008206C07382010000590032DCDA0007180000000175079E10000000
   GVL: 09583C0888440008D4FCC8000006C818110C0000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: 4DC08BA63D5B8AE2745-8018
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20170823144838 01440
   Serial number: 0926055104
   Part No SW: 4M0 909 059 C    HW: 4M0 909 059
   Component: J539 EBKV H11 0194
   Serial number:   085460013153 Dataset Number: 4M0909524G  0001
   ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
   ROD: EV_BrakeBoostBOSCHAU736.rod
   VCID: 3436FE42BEB1FB2A1BB-8060
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 4M0 909 057 A    HW: 4M0 909 057
   Component: VX70BrakeAssi  H04 0153
   Serial number: 05802861240817190203
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Component: LCM_MLBevoH05 0024
   Dataset Number: 4M0909519C  0009
   ROD: EV_LCMLeftHELLAAU736_AU37.rod
   VCID: 79A80F76D953C64288D-802C
   Component: MEM-FS        008 0031
   Serial number: 00000270214763 Dataset Number: 4M0909856C  0018
   Coding: 00181B000000B0410000010101010000110000313100000000000000000000
   Dataset Number: 4M0909520C  0009
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 4M0909535L  0015
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 3632C44AA8CDE93A25F-8062
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0131
   Serial number: 0000275453653  Dataset Number: 4M0909872J  0036
   Coding: 005D8A015E00008000013032
   Shop #: WSC 00089 218 00000
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 43D4AD9EEB1F4C92921-8016
Address 44: Steering Assist (J500)       Labels:* 4N0-909-144-V1.clb
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000058897 Dataset Number: 4M0909852P  0002
   Coding: B0150101010001
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   Part No SW: 8W0 907 064 DD    HW: 8W0 907 064 DD
   Component: BCM2 MLBevo   019 0366
   Dataset Number: 4M0909501H  0064
   Coding: 01741E000FB100606309A0006E00580203004004804F06502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 013013
   ROD: EV_BCM2HellaAU736_013_AU49.rod
   VCID: 01586796B1839E82C0D-8054
   ID - sensor:
   Subsystem 1 - Part No SW: 4M0 959 754 AM    HW: 4M0 959 754 AM
   Component: ID-Geber  H40 0105
   Serial number: 3617000146548013
   Serial number: 000000000ZY1721504R8
   Subsystem 3 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223972004713
   Heated Windshield Control Module:
   Subsystem 4 - Part No SW: 4N0 907 133     HW: 4N0 907 133
   Component: J505-FSH  H08 0040
   Serial number: 17231000314011120081
65758 - Voltage Supply for Control Module for Rear Lid Opening
          B1690 11 [00001001] - Short to Ground
                    Reset counter: 174
                    Mileage: 172381 km
                    Date: 2026.07.02
                    Time: 21:39:05
                    Supply voltages-Terminal 30 power supply: 12.636 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.663 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.622 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 11 04 E0
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000048155 Dataset Number: 4M1909510E  0012
   Coding: 0135960B008AF53AAF0000010001
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 23140D1E0B5F6C92F21-8076
Address 51: Electric Drive (J841)       Labels:. 4MX-907-INV-V1.clb
   Part No SW: 4M1 907 080 C    HW: 4M1 907 080 C
   Component: A73P7828T1000 H10 0022
   Revision: --H10---    CVN: 68E52997
   Coding: 01000000000000000000
   ASAM Dataset: EV_DMCM08530214M1907080C 001001
   ROD: EV_DMCM08530214M1907080C.rod
   VCID: 2D00EB265D9BAAE2545-8078
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0131
   Serial number: 0000275010046  Dataset Number: 4M0909873J  0036
   Coding: 005D8A015E00008000013030
   ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
   VCID: 42DAA89AF405459A997-8016
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035 A    HW: 4M1 035 035
   Component: MU-P-LND-EU   034 1117
   Serial number: A641H0HB017567 Dataset Number: 4M0909545K  0042
   Coding: 013796010000000053111102000A00332F001DE5017001009E
   Subsystem 1 - Part No SW: V03 959 802 TH    HW: -----------
   Component: ECE 2020  --- 0184
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4M1 919 605     HW: 4M1 919 605
   Component: AU536_DU_HIGH  H44 0008
   Serial number: AUZ8Z9HJM00FLR
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H13 0161
   Serial number: 01091400000000000039
   Compact disc data bank:
   Component: Gracenote2  --- 1016
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0010
   Serial number: 40000000012607 Dataset Number: 4M0909850B  0005
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 2F3CF12E5797D8F2669-807A
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0451371139 Dataset Number: 4M0909527C  0024
   Coding: 0110000202010000
   VCID: 3530C346B5CBE2222C5-8060
428804 - Pitch Angle Sensor
          U115A 00 [00001000] - No Communications
          [Pivot angle sensor - no signal/communication]
                    Reset counter: 214
                    Mileage: 172381 km
                    Date: 2026.07.02
                    Time: 21:39:22
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG020818 Dataset Number: 4M1909460H  0022
   Coding: 02350601BF0FA10008404500
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31491696900000 Dataset Number: 4M0909541G  0025
   Coding: 00F0
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 323AF85A44A5F51A097-8066
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M0 907 777 J    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H35 1214
   Serial number: 2708170241  Dataset Number: 4M0909576M  0044
   Coding: 98586880F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 40DEA292FA09578A8F3-8014
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130163750
   Coding: 303030
196609 - Basic Setting of Deflected Position not Performed
          C10C5 00 [10001001] - -
                    Reset counter: 174
                    Mileage: 172381 km
                    Date: 2026.07.02
                    Time: 21:39:28
   Part No SW: 4M1 713 041 E    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 17081143710812
   ROD: EV_GSMWaehlZFAU736.rod
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 4M0 919 617 B    HW: 4M0 919 617 B
   Component: HeadUpDisplay H29 1640
   Coding: 5F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU73.rod
Address 84: Night Vision (J853)       Labels:| 4M0-907-547.clb
   Part No SW: 4M0 907 547 B    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H11 0037
   Serial number: 635868600201722
   Coding: 200111
   ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
   ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H06 0007
   Serial number: 639589400B1721400007
4107 - No Basic Setting
          B2010 00 [00001001] - -
          [NightVision ECU: basic settings are missing or not correct]
                    Reset counter: 174
                    Mileage: 172381 km
                    Date: 2026.07.02
                    Time: 21:39:45
                    Image processor: error number-Image processor: error number 2: 00 00 00 00
                    Image processor: error number-Image processor: error number 1: 52 60 00 01
                    Voltage terminal 15: 12.40 V
                    Dynamic calibration-Dynamic calibration: yaw angle offset: 0.20 °
                    Dynamic calibration-Dynamic calibration: pitch angle offset: 1.10 °
                    Dynamic calibration: status-Dynamic calibration: pitch angle offset: 0.00 °
                    Dynamic calibration: status-Dynamic calibration: OFF
                    Dynamic calibration: status-Distance traveled with active dynamic calibration: 5265 km
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 D    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0023
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 4M0 915 233 E    HW: 4M0 915 233 E
   Component: BMC_PHEV_PL73 H08 0195
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU49.rod
   High-Voltage Battery Switch Box:
   Subsystem 1 - Part No SW: 4M0 915 253 E    HW: 4M0 915 253 E
   Component: J990  H17 0200
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J991  H08 0105
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J992  H08 0105
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J993  H08 0105
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J994  H08 0105
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J995  H08 0105
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J996  H08 0105
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J997  H08 0105
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J998  H08 0105
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J999  H08 0105
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1000  H08 0105
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1001  H08 0105
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1002  H08 0105
   Cell module control module 13:
   Subsystem 14 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1045  H08 0105
   Cell module control module 14:
   Subsystem 15 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1046  H08 0105
   Part No SW: 4M0 907 217 E    HW: 4M0 907 217 E
   Component: BVS           H16 0050
   Dataset Number: 4M0909466M  0044
   Coding: 040703060000040202202397CD0000B4B0F0C020F280
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 303EF2524AA9C70A7F3-8064
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   Dataset Number: 4M0909571J  0002
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736.rod
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 D    HW: 4M0 907 145 B
   Component: AEMevo        H09 0111
   Dataset Number: 4M0909578G  0015
   ASAM Dataset: EV_AEMZFAU736 006012
   ROD: EV_AEMZFAU736_006.rod
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0131
   Serial number: 0000274438511  Dataset Number: 4M0909897J  0036
   Coding: 004D88000000008000003020
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   VCID: 45D0B386E52B72A2BC5-8010
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS      005 0131
   Serial number: 0000274441318  Dataset Number: 4M0909896J  0036
   ROD: EV_DCU2RearPasseMAXHCONT_VW41.rod
Address C5: Therm. mgt. (J1024)       Labels:* 5GE-907-458.clb
   Part No SW: 4M0 965 429 E    HW: 4M0 965 429 B
   Component: TME-Max       H06 0020
   Serial number: 0046330 Dataset Number: 4M0909476G  0017
   Coding: 01
   ASAM Dataset: EV_ThermContrVISAU49X 001030
   ROD: EV_ThermContrVISAU49X_001_AU73.rod
   VCID: 3928CF7699D30642C8D-806C
   Subsystem 1 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
   Component: G395 pT-Sens1  H10 0009
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR172433003810000200
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4M0 816 797 A    HW: 4M0 816 797 A
   Component: J842 EKK es33  H02 0013
   Serial number: 00000000017040500315
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 1 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N636 EV1_KaMi  H12 0102
   Serial number: 00000000000150213255
   Refrigerant Shut-Off Valve 2:
   Subsystem 6 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130213869
   Refrigerant Shut-Off Valve 3:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130213837
   Refrigerant Shut-Off Valve 4:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130213841
   Refrigerant Shut-Off Valve 5:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130213871
60016 - Interior Pre-Conditioning
          P13F1 00 [00101111] - Not Started
                    Mileage: 172381 km
                    Date: 2026.07.02
                    Time: 21:55:35
                    Expanded ambient data 1-Voltage terminal 30: 0.000 V
                    Expanded ambient data 1-Vehicle speed: 0 km/h
                    Expanded ambient data 1-System status: Control operation: ignition on
                    Expanded ambient data 1-Power quota setting by energy management: 00
                    Expanded ambient data 1-Status of drive readiness hybrid: Engine start
                    Expanded ambient data 1-Ambient temperature: 18.50 °C
                    Expanded ambient data 1-current state of low temp.circ.: 00
                    Expanded ambient data 1-previous state low-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                    Expanded ambient data 1-current state of high-temp.circ.: 00
                    Expanded ambient data 1-previous state of high-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                    Expanded ambient data 1-current state of battery low temp.circ.: 02
                    Expanded ambient data 1-previous state of battery low temp.circ.: 00
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: FF
                    Expanded ambient data 1-current state of battery cold circuit: 00
                    Expanded ambient data 1-previous state of battery cold circuit: 00
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: FF
                    Switch-off conditions for pre-conditioning of interior-High-voltage energy management: active
                    Switch-off conditions for pre-conditioning of interior-Function canceled: entry in DTC memory: not active
                    Switch-off conditions for pre-conditioning of interior-Communication errors: not active
                    Switch-off conditions for pre-conditioning of interior-Switch-off due to energy management: not active
                    Switch-off conditions for pre-conditioning of interior-No release by coordinator: active
                    Switch-off conditions for pre-conditioning of interior-Fuel supply low: not active
                    Switch-off conditions for pre-conditioning of interior-Parking heater error value received: not active
                    Switch-off conditions for pre-conditioning of interior-High-voltage energy management: charging capacity too low: not active
Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
   Part No SW: 5QE 915 681 AA    HW: 5QE 915 681 AA
   Component: OBC Delta-ES  H57 0721
   Dataset Number: 4M0909811E  0012
   Coding: 11508B207004
   ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
   ROD: EV_OBCTwoPhaseDT2AU736.rod
   VCID: 0B4445BE83CFC4D2AA1-805E
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 4M0909469G  0015
   Coding: 6A8000053602
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
   VCID: 3A2AD07A9CD50D5AC17-806E
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1A6A30FA3C152D5A217-804E
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
   Dataset Number: 4M0909472D  0012
End----(Elapsed Time: 03:24, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
------------------------------6 Faults Found-------------------------------
Have you tried these steps yet (with the car raised)?
The key points should be in posts 3 and the Wheel Change Mode in 9 may be needed.
Tbjorstad
Norway
C?ID=651221
Yes, i tried to follow this tread, but still got the same fault code.
I have also 0% on the height raw values, and get the "security access needed" fault when trying to change. I did not find any code wich gives me the correct access yet.
I havent had a battery charger available when trying before, but I will try with a battey charger connected tomorrow. (I guess this should be connected to the battery in the footwell at the passenger side?
OK, ERROR: Conditions not correct or request sequence error sounds more like a prerequisite that's not met rather than an error caused by needing a SA code. Try to clear ALL DTCs with the hood open before the next attempt. I don't know if it (in addition to all door latches) needs to be closed prior to the actual procedure but opening it initially should disable the diagnostic firewall.
Make sure the 12V battery charger is connected to the dedicated charging/jump start ports rather than the 12V battery directly. This is critical so the battery manager sees the current flow. Those are usually under the hood (engine bay). The one on my 2022 e-tron 55 is on the right front strut tower area but my battery is in the cowl so the Q7 may not be setup the same.
NEtech
Denmark
C?ID=56995
Height values probably out of specification, when raised.
Search for IDE13061 and IDE09271
Tbjorstad
Norway
C?ID=651221
Hi,
these are my data when the car is lifted to the lift/offroad position.
Do you know what they should be, and how to adjust if they are wrong?
Tbjorstad
Norway
C?ID=651221
I will for sure try this on sunday, when my lift are available again.
NEtech
Denmark
C?ID=56995
I would guess the 486 mm is to low.
Move it, or whatever is possible, before going further on that step.
Tbjorstad
Norway
C?ID=651221
Hi, I followed your guide step by step with the charger connected, but unfortunately the same error code appeared again. I have also tried with the hood both open and closed.
I also tried running the full suspension calibration once more, guided by DrPeter. Everything was successful until I reached the deflected calibration stage, where the issue occurred again.
What would you recommend as the next step?
If this isn't sorted already I agree with NEtech. The left front value looks too low. Here's the low mile/nearly new car condition data from my mine:
There a lot of useful Adv MVBs in there but these were my Absolute numbers from that map:
IDE09271-IDE02951,Absolute vehicle height-Absolute left front vehicle height,453, mm​
IDE09271-IDE02952,Absolute vehicle height-Absolute right front vehicle height,455, mm​
IDE09271-IDE02953,Absolute vehicle height-Absolute left rear vehicle height,462, mm​
IDE09271-IDE02954,Absolute vehicle height-Absolute right rear vehicle height,457, mm​
It may not have been on perfectly level ground at that time but they are pretty close.
IDE13061-MAS15232,Learned height deviations fully extended-Maximum suspension travel front left,106, mm​
IDE13061-MAS15233,Learned height deviations fully extended-Height deviation of empty position: left front,-127, mm​
IDE13061-MAS15234,Learned height deviations fully extended-Maximum suspension travel front right,106, mm​
IDE13061-MAS15235,Learned height deviations fully extended-Height deviation of empty position: right front,-127, mm​
IDE13061-MAS15236,Learned height deviations fully extended-Maximum suspension travel rear left,103, mm​
IDE13061-MAS15237,Learned height deviations fully extended-Height deviation of empty position: left rear,-127, mm​
IDE13061-MAS15238,Learned height deviations fully extended-Maximum suspension travel rear right,99, mm​
IDE13061-MAS15239,Learned height deviations fully extended-Height deviation of empty position: right rear,-127, mm​
The next time you have access to a lift I would:
1) Make a Measuring Value function map on address 74 before you lift it.
2) Lift it until the wheels can hang and then repeat another map.
Mapping is explained here:
You can open each of those CSV files with Notepad, select and copy the contents and then paste them in-between CODE tags (like the Auto-Scan) so they look like my baseline thread. That should show us all of the groups with the suspension loaded and then again unloaded.
Also, let us know which sensor was replaced, if the old one failed due to damage versus electrical errors and try to get us the part number that they sold you.
Tbjorstad
Norway
C?ID=651221
Hi,
I'm not sure if I did this correctly, but I've given it a try. The sensor I replaced was the front right sensor.
Please let me know if you need any additional information.
When the car is in Automode:
Adpmap:
;SW:4M0-907-777-J   HW:4M0-907-777-B ---  74: Chassis Control
;Component:Fahrwerk-SG   H35 1214, Coding:98586880F8
;EV_ChassContrContiAU426,001003,EV_ChassContrContiAU426.rod
;Monday,13,July,2026,10:59:38:43336
;VCDS Version: 26.3.0.0 (x64)  Data version: 20260320 DS375.1
;VCID: 40DEA292FA09578A8F3-8014
IDE00001-Production mode,active ,3
IDE00820-IDE00106-Activating and deactivating all development messages-Internal DTC,0 ,3
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,OFF ,3
IDE00820-ENG146557-Activating and deactivating all development messages-development_message_ECU_specific_01_02,OFF ,3
IDE00820-ENG100523-Activating and deactivating all development messages-development_message_ECU_specific_03_to_10,OFF ,3
IDE00820-ENG103002-Activating and deactivating all development messages-development_message_S100,OFF ,3
IDE00820-ENG102128-Activating and deactivating all development messages-development_message_S101,OFF ,3
IDE00820-ENG103295-Activating and deactivating all development messages-development_message_S102,OFF ,3
IDE02001-Body height left front wheel house edge,416.00 mm,2
IDE02002-Body height right front wheel house edge,423.00 mm,2
IDE02003-Body height left rear wheel house edge,428.00 mm,2
IDE02004-Body height right rear wheel house edge,433.00 mm,2
IDE04330-Transfer of release code for a SWaP function,Conditions not correct or request sequence error,3
IDE04331-Selection of release codes for a SWaP function,Conditions not correct or request sequence error,3
IDE08539-Constant pwr supply to all dampers,OFF ,1
IDE08997-IDE04195-Raw values: height sensors when deflected-Left front level ctrl sys sensor: adaptation value (deflected),0.00 %,8
IDE08997-IDE04198-Raw values: height sensors when deflected-Right front level ctrl sys sensor: adaptation value (deflected),0.00 %,8
IDE08997-IDE04201-Raw values: height sensors when deflected-Left rear level ctrl sys sensor: adaptation value (deflected),0.00 %,8
IDE08997-IDE04204-Raw values: height sensors when deflected-Right rear level ctrl sys sensor: adaptation value (deflected),0.00 %,8
IDE09244-Fuel tank volume,85 l,1
IDE09245-Deviation from empty weight in full state,8.00 kg,2
IDE09246-MAS08451-Height offset for prelim. stage: calibrat. produc.-Front axle,0 mm,2
IDE09246-MAS08452-Height offset for prelim. stage: calibrat. produc.-Rear axle,0 mm,2
IDE09247-MAS01853-Calibrated raw values of height sensor syst.-Left front,-29 mm,4
IDE09247-MAS01854-Calibrated raw values of height sensor syst.-Right front,-19 mm,4
IDE09247-MAS01855-Calibrated raw values of height sensor syst.-Left rear,-27 mm,4
IDE09247-MAS01856-Calibrated raw values of height sensor syst.-Right rear,-24 mm,4
IDE09260-MAS10785-Tight level control tolerance-Axle ctr. position: activation threshold,0 mm,4
IDE09260-MAS10786-Tight level control tolerance-Axke ctr. position: setpoint level limit,0 mm,4
IDE09260-MAS10787-Tight level control tolerance-Axle askew pos.: activation threshold,0 mm,4
IDE09260-MAS10788-Tight level control tolerance-Axle slanted position: tol. threshold,0 mm,4
ENG105619-Constant_damper_current_front_left,0.00 mA,2
ENG105620-Constant_damper_current_front_right,0.00 mA,2
ENG105621-Constant_damper_current_rear_left,0.00 mA,2
ENG105622-Constant_damper_current_rear_right,0.00 mA,2
ENG109010-speed_value_for_testing_mode,0.00 km/h,2
Elapsed Time: 00:06
And
Blockmap:
;Monday,13,July,2026,11:00:10:43336
Group,Description,Actual
IDE00018,Voltage terminal 15,12.00, V
IDE00019,Voltage terminal 30,12.30, V
IDE00030,Status of actuator test,cancelled,
IDE00106,Internal DTC,641,
IDE00303-IDE08198,Status: doors/lids 1-Activation status anti-theft warning system,not active,
IDE00303-MAS00218,Status: doors/lids 1-Driver´s door,closed,
IDE00303-MAS00219,Status: doors/lids 1-Passenger´s door,closed,
IDE00303-MAS00220,Status: doors/lids 1-Rear left door,closed,
IDE00303-MAS00221,Status: doors/lids 1-Rear right door,closed,
IDE00303-MAS06522,Status: doors/lids 1-Rear lid: Status,closed,
IDE00303-MAS08523,Status: doors/lids 1-All doors and rear lid closed,Condition met,
IDE00541-IDE02543,Acceleration-Body acceleration sensor,9.80, m/s²
IDE00541-IDE02545,Acceleration-Body acceleration sensor: status,valid,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,41 F0 F0 98,
IDE02542,Transverse acceleration sensor 2: temperature,-327.68, °C
IDE02544,Body acceleration sensor: temperature,19.73, °C
IDE02547,Roll rate sensor: temperature,20.35, °C
IDE02550,Pitch rate sensor: temperature,19.66, °C
IDE02556,Yaw rate sensor 2: temperature,-327.68, °C
IDE02940-MAS03034,System pressure-Pressure,1.30, bar
IDE02940-MAS10469,System pressure-Raw value,0.56, V
IDE02941,Compressor temperature,16, °C
IDE02946-MAS01374,Status MMI operation-Trailer,not active,
IDE02946-MAS03024,Status MMI operation-Car jack mode,not active,
IDE02946-MAS08486,Status MMI operation-Lift mode,not active,
IDE03038,Control position: specified value,Normal level,
IDE03050,Voltage supply for Solen.val. block,0.21, V
IDE03051,Voltage supply for right sensor for level control system,4.98, V
IDE03052,Voltage supply for left sensor for level control system,4.98, V
IDE03053,Voltage supply of sensor for system pressure,4.98, V
IDE03064,Accumulator pressure,17.10, bar
IDE03208-MAS01390,Software version for suppliers-Block 1,71091214,
IDE03208-MAS01391,Software version for suppliers-Block 2,71091214,
IDE03208-MAS01392,Software version for suppliers-Block 3,71049901,
IDE03208-MAS01393,Software version for suppliers-Block 4,71014002,
IDE03208-MAS01394,Software version for suppliers-Block 5,71089123,
IDE03208-MAS01395,Software version for suppliers-Block 6,71009502,
IDE03208-MAS01396,Software version for suppliers-Block 7,710795G0,
IDE03208-MAS01397,Software version for suppliers-Block 8,71059619,
IDE03208-MAS01398,Software version for suppliers-Block 9,71069600,
IDE03208-MAS01399,Software version for suppliers-Block 10,--------,
IDE03208-MAS01400,Software version for suppliers-Block 11,71029F00,
IDE03208-MAS01401,Software version for suppliers-Block 12,71039800,
IDE03208-MAS01402,Software version for suppliers-Block 13,--------,
IDE03208-MAS01403,Software version for suppliers-Block 14,--------,
IDE03208-MAS01404,Software version for suppliers-Block 15,--------,
IDE03661-IDE02546,Rotation rate-Roll rate sensor,-0.01, rad/s
IDE03661-IDE02548,Rotation rate-Roll rate sensor: status,valid,
IDE03661-IDE02549,Rotation rate-Pitch rate sensor,0.00, rad/s
IDE03661-IDE02551,Rotation rate-Pitch rate sensor: status,valid,
IDE04018-MAS00106,Pressure test time stamp: current-Year,2026,
IDE04018-MAS00107,Pressure test time stamp: current-Month,7,
IDE04018-MAS00108,Pressure test time stamp: current-Day,13,
IDE04018-MAS00109,Pressure test time stamp: current-Hours,11,
IDE04018-MAS00110,Pressure test time stamp: current-Minutes,0,
IDE04018-MAS00111,Pressure test time stamp: current-Seconds,35,
IDE04781-MAS11602,Microprocessor malfunction type-Group,00,
IDE04781-MAS11758,Microprocessor malfunction type-Identification,00,
IDE04781-MAS11759,Microprocessor malfunction type-Saving,00 00 00 00,
IDE05163-MAS01221,Air Suspension Compressor-Compressor main status,OFF,
IDE05163-MAS01442,Air Suspension Compressor-Compressor speed,0, /min
IDE05163-MAS02194,Air Suspension Compressor-Temperature 1,24, °C
IDE05163-MAS02195,Air Suspension Compressor-Temperature 2,16, °C
IDE05163-MAS02196,Air Suspension Compressor-Temperature 3,-40, °C
IDE05163-MAS02832,Air Suspension Compressor-Malfunction status,No malfunction,
IDE05163-MAS04121,Air Suspension Compressor-Voltage,12.40, V
IDE05163-MAS04136,Air Suspension Compressor-Current,0.00, A
IDE05163-ENG145284,Air Suspension Compressor-compressor_temperature_2_Textual,numerical value: no text,
IDE05163-ENG145285,Air Suspension Compressor-compressor_temperature_3_Textual,numerical value: no text,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,No,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06487-MAS04887,Run-time of the level-level 1,13, km
IDE06487-MAS05353,Run-time of the level-level 2,2055, km
IDE06487-MAS05490,Run-time of the level-level 3,0, km
IDE06487-MAS05491,Run-time of the level-Level 4,16495, km
IDE06487-MAS05760,Run-time of the level-Level 5,17067, km
IDE06487-MAS05761,Run-time of the level-Level 6,5769, km
IDE06487-MAS05762,Run-time of the level-level 7,0, km
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,05,
IDE07151-IDE03849,Vehicle level sensor: raw value-Left front level control system sensor: raw value,55.75, %
IDE07151-IDE03857,Vehicle level sensor: raw value-Right front level control system sensor: raw value,45.23, %
IDE07151-IDE03865,Vehicle level sensor: raw value-Left rear level control system sensor: raw value,55.23, %
IDE07151-IDE04147,Vehicle level sensor: raw value-Right rear level control system sensor: raw value,45.20, %
IDE08343,Immobilizer Challenge,94 70 3E 14,
IDE08605-IDE02955,Status drive profile for level control system-System status,Available,
IDE08605-IDE06419,Status drive profile for level control system-Driving profile switchover,will be performed.,
IDE08605-MAS01447,Status drive profile for level control system-Actual value,1,
IDE08605-MAS01448,Status drive profile for level control system-Specified value,1,
IDE08605-MAS05058,Status drive profile for level control system-Compatibility,Yes,
IDE08667-IDE02955,Drive profile selec. for damper adjustment-System status,Available,
IDE08667-IDE06419,Drive profile selec. for damper adjustment-Driving profile switchover,will be performed.,
IDE08667-MAS01447,Drive profile selec. for damper adjustment-Actual value,1,
IDE08667-MAS01448,Drive profile selec. for damper adjustment-Specified value,1,
IDE08667-MAS05058,Drive profile selec. for damper adjustment-Compatibility,Yes,
IDE09236,Replacement strategy damper,0, bit
IDE09237-MAS03002,Damper control status-Driving program,Profile 1,
IDE09237-MAS04188,Damper control status-Transport mode,not active,
IDE09237-MAS06797,Damper control status-Status configuration,Damper control,
IDE09237-MAS08446,Damper control status-Control position adapted,Yes,
IDE09237-MAS08447,Damper control status-Loading mode,not active,
IDE09238-IDE03056,Damper valve: actual current-Damper valve current: left front,0.38, A
IDE09238-IDE03058,Damper valve: actual current-Damper valve current: right front,0.32, A
IDE09238-IDE03060,Damper valve: actual current-Left rear shock absorber valve current,0.32, A
IDE09238-IDE03062,Damper valve: actual current-Right rear shock absorber valve current,0.32, A
IDE09239-IDE03057,Damper valve: PWM value-Left front damper: PWM signal value,3.19, %
IDE09239-IDE03059,Damper valve: PWM value-Right front damper: PWM signal value,14.17, %
IDE09239-IDE03061,Damper valve: PWM value-Left rear damper: PWM signal value,14.07, %
IDE09239-IDE03063,Damper valve: PWM value-Right rear damper: PWM signal value,14.54, %
IDE09240-IDE03056,Damper valve: target current-Damper valve current: left front,0.40, A
IDE09240-IDE03058,Damper valve: target current-Damper valve current: right front,0.40, A
IDE09240-IDE03060,Damper valve: target current-Left rear shock absorber valve current,0.40, A
IDE09240-IDE03062,Damper valve: target current-Right rear shock absorber valve current,0.40, A
IDE09241-MAS01853,Calculated damper temperature-Left front,14, °C
IDE09241-MAS01854,Calculated damper temperature-Right front,12, °C
IDE09241-MAS01855,Calculated damper temperature-Left rear,16, °C
IDE09241-MAS01856,Calculated damper temperature-Right rear,16, °C
IDE09242-MAS08451,Damper output stage temperature-Front axle,24, °C
IDE09242-MAS08452,Damper output stage temperature-Rear axle,23, °C
IDE09248-MAS03024,Control prevention detection-Car jack mode,not active,
IDE09248-MAS04501,Control prevention detection-Lift,not active,
IDE09248-MAS08454,Control prevention detection-Locked position diagnosis,not active,
IDE09248-MAS08455,Control prevention detection-Locked position snow wedge,not active,
IDE09248-MAS08456,Control prevention detection-Locked position wheel change,not active,
IDE09248-MAS08457,Control prevention detection-Limited due to doors/flaps,not active,
IDE09249-IDE03451,Control limitation detection-Transverse acceleration,not active,
IDE09249-IDE03660,Control limitation detection-Longitudinal acceleration,not active,
IDE09249-IDE04928,Control limitation detection-Anti-theft protection,not active,
IDE09249-MAS05179,Control limitation detection-ABS intervention,not active,
IDE09249-MAS05180,Control limitation detection-ESP intervention,not active,
IDE09249-MAS08458,Control limitation detection-Limited due to vehicle entanglement,not active,
IDE09249-MAS08459,Control limitation detection-Limited due to system error reaction,not active,
IDE09261-IDE03037,Level control: internal status-Level controller conditions,Stand mode 1: engine off and door closed,
IDE09261-IDE03065,Level control: internal status-Control from accumulator possible,Yes,
IDE09261-MAS01106,Level control: internal status-Level control system,active,
IDE09261-MAS08446,Level control: internal status-Control position adapted,Yes,
IDE09261-MAS08486,Level control: internal status-Lift mode,not active,
IDE09261-MAS08490,Level control: internal status-Control demand,not recognised,
IDE09261-MAS08491,Level control: internal status-Extreme level,not recognised,
IDE09261-MAS08492,Level control: internal status-Control possible with compressor,No,
IDE09262-MAS03002,Level control: external status-Driving program,1,
IDE09262-MAS03024,Level control: external status-Car jack mode,not active,
IDE09262-MAS04188,Level control: external status-Transport mode,not active,
IDE09262-MAS08447,Level control: external status-Loading mode,not active,
IDE09262-MAS08493,Level control: external status-Locked position,not active,
IDE09263,Level control system error reaction,00 00 00 00 00 04 00 00 00,
IDE09264-MAS01299,Driving program running times-Offroad,4703, km
IDE09264-MAS02014,Driving program running times-Comfort,16845, km
IDE09264-MAS02015,Driving program running times-AUTO,16385, km
IDE09264-MAS02016,Driving program running times-Dynamic,16727, km
IDE09264-MAS05471,Driving program running times-Efficiency,0, km
IDE09264-MAS08486,Driving program running times-Lift mode,13, km
IDE09265-IDE05164,No. activations of Solen.val. block-Air suspension valve: left front,145999, counts
IDE09265-IDE05165,No. activations of Solen.val. block-Air suspension valve: right front,142738, counts
IDE09265-IDE05166,No. activations of Solen.val. block-Air suspension valve: left rear,118352, counts
IDE09265-IDE05167,No. activations of Solen.val. block-Air suspension valve: right rear,113998, counts
IDE09265-MAS05733,No. activations of Solen.val. block-Level control accumulator valve,98368, counts
IDE09266-IDE03219,No. activations of level control valves-Relief valve,255713, counts
IDE09266-IDE03667,No. activations of level control valves-Electrical switching valve 1,276, counts
IDE09266-IDE03668,No. activations of level control valves-Electrical switching valve 2,0, counts
IDE09266-MAS10770,No. activations of level control valves-Valve 1 for aux. vol. of air suspensions,0, counts
IDE09266-MAS10771,No. activations of level control valves-Valve 2 for aux. vol. of air suspensions,0, counts
IDE09266-MAS10772,No. activations of level control valves-Valve 3 for aux. vol. of air suspensions,0, counts
IDE09266-MAS10773,No. activations of level control valves-Valve 4 for aux. vol. of air suspensions,0, counts
IDE09267-MAS08494,Number of control cycles-Number of automatic target level changes,25340, counts
IDE09267-MAS08495,Number of control cycles-Number of correction controls,72760, counts
IDE09267-MAS08496,Number of control cycles-Number of manual target level changes when standing,661, counts
IDE09267-MAS08497,Number of control cycles-Number of manual target level changes when driving,1148, counts
IDE09268-MAS08498,Switch on occurrences of compressor-shorter as time duration 1,1214, counts
IDE09268-MAS08499,Switch on occurrences of compressor-between time duration 1 and 2,6822, counts
IDE09268-MAS08500,Switch on occurrences of compressor-between time duration 2 and 3,6993, counts
IDE09268-MAS08506,Switch on occurrences of compressor-between time duration 3 and 4,4263, counts
IDE09268-MAS08507,Switch on occurrences of compressor-between time duration 4 and 5,245, counts
IDE09268-MAS08508,Switch on occurrences of compressor-longer as time duration 5,67, counts
IDE09269-MAS08509,Running times of compressor-counter pressure less than pressure value 1,22065, s
IDE09269-MAS08510,Running times of compressor-counter pressure between pressure value 1 and 2,48589, s
IDE09269-MAS08511,Running times of compressor-counter pressure between pressure value 2 and 3,25788, s
IDE09269-MAS08512,Running times of compressor-counter pressure larger than pressure value 3,32472, s
IDE09270-MAS08514,No. of compressor activations-for control process,8003, counts
IDE09270-MAS08515,No. of compressor activations-for accumulator filling,11190, counts
IDE09270-MAS08972,No. of compressor activations-at temperature small temperature value 1,1054, counts
IDE09270-MAS08973,No. of compressor activations-at temperature between temperature value 1 and 2,18286, counts
IDE09270-MAS08974,No. of compressor activations-at temperature between temperature value 2 and 3,263, counts
IDE09270-MAS08975,No. of compressor activations-at temp. higher than temperature value 3,1, counts
IDE09271-IDE02951,Absolute vehicle height-Absolute left front vehicle height,440, mm
IDE09271-IDE02952,Absolute vehicle height-Absolute right front vehicle height,446, mm
IDE09271-IDE02953,Absolute vehicle height-Absolute left rear vehicle height,456, mm
IDE09271-ENG145283,Absolute vehicle height-vehicle_level_absolute_front_left_Textual,numerical value: no text,
IDE09272-IDE03123,Last measd pressur in air spring bellows-Last measured pressure in left front pneumatic spring bellows,7.90, bar
IDE09272-IDE03124,Last measd pressur in air spring bellows-Last measured pressure in right front pneumatic spring bellows,8.90, bar
IDE09272-IDE03125,Last measd pressur in air spring bellows-Last measured pressure in left rear pneumatic spring bellows,7.60, bar
IDE09272-IDE03126,Last measd pressur in air spring bellows-Last measured pressure in right rear pneumatic spring bellows,7.10, bar
IDE09273-IDE02947,Height deviation from adapted vehicle height-Left front height deviation from adapted vehicle height,-2, mm
IDE09273-IDE02948,Height deviation from adapted vehicle height-Right front height deviation from adapted vehicle height,4, mm
IDE09273-IDE02949,Height deviation from adapted vehicle height-Left rear height deviation from adapted vehicle height,1, mm
IDE09273-IDE02950,Height deviation from adapted vehicle height-Right rear height deviation from adapted vehicle height,2, mm
IDE09274-IDE03042,Height deviation from control pos-Height deviation of control position: left front,-2, mm
IDE09274-IDE03043,Height deviation from control pos-Height deviation of control position: right front,4, mm
IDE09274-IDE03044,Height deviation from control pos-Height deviation of control position: left rear,1, mm
IDE09274-IDE03045,Height deviation from control pos-Height deviation of control position: right rear,2, mm
IDE09275-IDE04447,Loading function operating condition-Function status,not active,
IDE09275-IDE05288,Loading function operating condition-Load level button: raise,not active,
IDE09275-IDE05289,Loading function operating condition-Load level button: lower,not active,
IDE09275-IDE05290,Loading function operating condition-Load level button: redundant signal path,not active,
IDE09275-IDE05291,Loading function operating condition-Indicator light in button for load level,OFF,
IDE09275-MAS07052,Loading function operating condition-Setting,automatic,
IDE09275-MAS08526,Loading function operating condition-Button position neutral,active,
IDE09275-MAS08976,Loading function operating condition-Precondition:doors closed,Condition met,
IDE09275-MAS08977,Loading function operating condition-Precondition:Tailgate open,Condition not met,
IDE09275-MAS08978,Loading function operating condition-Precondition:no ctrl. process active,Condition met,
IDE09275-MAS08979,Loading function operating condition-Precondition:level control active,Condition met,
IDE09275-MAS08980,Loading function operating condition-Precondition:no relevant error on the rear axle components,Condition met,
IDE09455,Number of wake-up processes via level ctrl.,61106, counts
IDE09457-MAS00106,Time of stored pressure test 1-Year,2000,
IDE09457-MAS00107,Time of stored pressure test 1-Month,1,
IDE09457-MAS00108,Time of stored pressure test 1-Day,1,
IDE09457-MAS00109,Time of stored pressure test 1-Hours,0,
IDE09457-MAS00110,Time of stored pressure test 1-Minutes,0,
IDE09457-MAS00111,Time of stored pressure test 1-Seconds,0,
IDE09458-MAS00106,Time of stored pressure test 2-Year,2000,
IDE09458-MAS00107,Time of stored pressure test 2-Month,1,
IDE09458-MAS00108,Time of stored pressure test 2-Day,1,
IDE09458-MAS00109,Time of stored pressure test 2-Hours,0,
IDE09458-MAS00110,Time of stored pressure test 2-Minutes,0,
IDE09458-MAS00111,Time of stored pressure test 2-Seconds,0,
IDE09459-IDE04024,Result of stored pressure test 1-Pressure test: saved front left strut pressure,0.00, bar
IDE09459-IDE04025,Result of stored pressure test 1-Pressure test: saved front right strut pressure,0.00, bar
IDE09459-IDE04026,Result of stored pressure test 1-Pressure test: saved rear left strut pressure,0.00, bar
IDE09459-IDE04027,Result of stored pressure test 1-Pressure test: saved rear right strut pressure,0.00, bar
IDE09459-IDE04028,Result of stored pressure test 1-Pressure test: saved accumulator pressure,0.00, bar
IDE09460-IDE04024,Result of stored pressure test 2-Pressure test: saved front left strut pressure,0.00, bar
IDE09460-IDE04025,Result of stored pressure test 2-Pressure test: saved front right strut pressure,0.00, bar
IDE09460-IDE04026,Result of stored pressure test 2-Pressure test: saved rear left strut pressure,0.00, bar
IDE09460-IDE04027,Result of stored pressure test 2-Pressure test: saved rear right strut pressure,0.00, bar
IDE09460-IDE04028,Result of stored pressure test 2-Pressure test: saved accumulator pressure,0.00, bar
IDE09461-IDE02942,Vehicle trim position-Left front vehicle height: PWM signal value,48.38, %
IDE09461-IDE02943,Vehicle trim position-Right front vehicle height: PWM signal value,51.62, %
IDE09461-IDE02944,Vehicle trim position-Left rear vehicle height: PWM signal value,48.10, %
IDE09461-IDE02945,Vehicle trim position-Right rear vehicle height: PWM signal value,51.90, %
IDE09461-MAS01853,Vehicle trim position-Left front,442, mm
IDE09461-MAS01854,Vehicle trim position-Right front,442, mm
IDE09461-MAS01855,Vehicle trim position-Left rear,455, mm
IDE09461-MAS01856,Vehicle trim position-Right rear,455, mm
IDE09464-IDE03219,Valve status air suspension-Relief valve,OFF,
IDE09464-IDE03667,Valve status air suspension-Electrical switching valve 1,OFF,
IDE09464-IDE05164,Valve status air suspension-Air suspension valve: left front,OFF,
IDE09464-IDE05165,Valve status air suspension-Air suspension valve: right front,OFF,
IDE09464-IDE05166,Valve status air suspension-Air suspension valve: left rear,OFF,
IDE09464-IDE05167,Valve status air suspension-Air suspension valve: right rear,OFF,
IDE09464-MAS05733,Valve status air suspension-Level control accumulator valve,OFF,
IDE10557-MAS05790,Inclination display: calculated wrong alignment-Estimated installation error in direction of roll angle,00 00 00 00,
IDE10557-MAS05791,Inclination display: calculated wrong alignment-Estimated installation error in direction of pitch angle,00 00 00 00,
IDE10558-MAS05292,Inclination display: input signals inertial sensors-Estimated offset fault of rotation rate sensor,BB 7C 62 7F,
IDE10558-MAS05293,Inclination display: input signals inertial sensors-Estimated offset fault of longitudinal acceleration sensor,BD C1 F6 30,
IDE10558-MAS11832,Inclination display: input signals inertial sensors-Sensor system status: current,00,
IDE10558-MAS11833,Inclination display: input signals inertial sensors-Sensor system status: previous,00,
IDE10559-MAS02465,Inclination display: input signals GPS-Speed in y-direction,3B 81 A4 B0,
IDE10559-MAS02469,Inclination display: input signals GPS-Speed in x-direction,BE 3E 6C D2,
IDE10598-MAS09214,Compressor for air suspension: number of shut-offs-due to excessive temp. during ctrl. process,2, counts
IDE10598-MAS09215,Compressor for air suspension: number of shut-offs-due to excessive temp. during accumulator filling,3, counts
IDE10599-IDE04561,Actuator test: release status-Switch-on and shut-off conditions,Boundary conditions met,
IDE10599-MAS06528,Actuator test: release status-Release status,At least one release missing,
IDE10611-IDE02923,Actuator test: release status 2-Lower vehicle at left front,Enabled,
IDE10611-IDE02924,Actuator test: release status 2-Lower vehicle at right front,Enabled,
IDE10611-IDE02925,Actuator test: release status 2-Lower vehicle at left rear,Enabled,
IDE10611-IDE02926,Actuator test: release status 2-Lower vehicle at right rear,Enabled,
IDE10611-IDE08716,Actuator test: release status 2-System check for boost function,Enabled,
IDE10611-IDE09462,Actuator test: release status 2-Checking pressure reservoir and compressor,Enabled,
IDE10611-MAS10770,Actuator test: release status 2-Valve 1 for aux. vol. of air suspensions,not enabled,
IDE10611-MAS10771,Actuator test: release status 2-Valve 2 for aux. vol. of air suspensions,not enabled,
IDE10611-MAS10772,Actuator test: release status 2-Valve 3 for aux. vol. of air suspensions,not enabled,
IDE10611-MAS10773,Actuator test: release status 2-Valve 4 for aux. vol. of air suspensions,not enabled,
IDE10801-MAS03095,Calibration of level control for determining axle load: status-Function status,calibrated,
IDE10801-MAS08451,Calibration of level control for determining axle load: status-Front axle,-68, kg
IDE10801-MAS08452,Calibration of level control for determining axle load: status-Rear axle,-100, kg
IDE10805-MAS01853,Valves for add. volume of air suspension: status-Left front,OFF,
IDE10805-MAS01854,Valves for add. volume of air suspension: status-Right front,OFF,
IDE10805-MAS01855,Valves for add. volume of air suspension: status-Left rear,OFF,
IDE10805-MAS01856,Valves for add. volume of air suspension: status-Right rear,OFF,
IDE10807-IDE00123,Signal processing adapted values-Travel reinforcement of disc set regulation,5000, m
IDE10807-MAS02453,Signal processing adapted values-Steering wheel angle offset,0.00, rad
IDE10807-MAS11340,Signal processing adapted values-Correction factor for left front wheel,1.00,
IDE10807-MAS11341,Signal processing adapted values-Correction factor for right front wheel,1.00,
IDE10807-MAS11342,Signal processing adapted values-Correction factor for left rear wheel,1.00,
IDE10807-MAS11343,Signal processing adapted values-Correction factor for right rear wheel,1.00,
IDE10807-MAS11344,Signal processing adapted values-Permissible steering angle offset deviation,0.00, rad
IDE10941-MAS05290,Inclination display: input signals inertial sensors 2-Estimated offset fault of roll rate sensor,B9 7A B6 32,
IDE10941-MAS05295,Inclination display: input signals inertial sensors 2-Estimated offset fault of vertical acceleration sensor,3C 80 86 CF,
IDE10941-MAS11832,Inclination display: input signals inertial sensors 2-Sensor system status: current,00,
IDE10941-MAS11833,Inclination display: input signals inertial sensors 2-Sensor system status: previous,00,
IDE10971-MAS02465,Inclination display: calculated values-Speed in y-direction,3B 87 F0 4C,
IDE10971-MAS02469,Inclination display: calculated values-Speed in x-direction,BE 3D 7A FC,
IDE10971-MAS05282,Inclination display: calculated values-Status: longitudinal speed: input,00,
IDE10971-MAS05758,Inclination display: calculated values-Driving situation,01,
IDE10971-MAS11840,Inclination display: calculated values-Status of incline angles and speeds,0F,
IDE10971-MAS11841,Inclination display: calculated values-Status of calculation algorithm,00,
IDE10971-MAS11842,Inclination display: calculated values-Calculation algorithm initialized,00,
IDE10971-MAS11843,Inclination display: calculated values-Status of rotation rate filter,00,
IDE10972-MAS05282,Inclination display: input signals: signal processing-Status: longitudinal speed: input,00,
IDE10972-MAS05298,Inclination display: input signals: signal processing-Longitudinal acceleration: input,00 00 00 00,
IDE10972-MAS11838,Inclination display: input signals: signal processing-Status of tire radius scale factor,00,
IDE10972-MAS11839,Inclination display: input signals: signal processing-Tire radius scale factor,3F 80 00 00,
IDE12885-IDE00326,Damper control: input signal from steering-Steering wheel angle,35.80, °
IDE12885-IDE02219,Damper control: input signal from steering-Steering wheel angle: sign,Positive,
IDE12885-MAS02981,Damper control: input signal from steering-Overlay angle,0.00, °
IDE12885-MAS04455,Damper control: input signal from steering-Active steering internal status,operational,
IDE12885-MAS13750,Damper control: input signal from steering-Overlay angle: sign,Positive,
IDE12885-ENG145287,Damper control: input signal from steering-SCU_superpositon_angle_ADS_Textual,numerical value: no text,
ENG144274,Current_Fuel_Volume,10190, kg
ENG144274,Current_Fuel_Volume,8, kg
ENG144274,Current_Fuel_Volume,10180, kg
ENG144274,Current_Fuel_Volume,13, l
ENG101549,FIBEX_implementation,MLBevo_FlexRay_KMatrix_V8.09.00F_20141106_BP.xml,
ENG144011-IDE03602,initialisation_status-Left front level control system sensor,1,
ENG144011-IDE03603,initialisation_status-Right front level control sensor,1,
ENG144011-IDE03604,initialisation_status-Left rear level control system sensor,1,
ENG144011-IDE03605,initialisation_status-Right rear level control system sensor,1,
ENG144011-MAS18050,initialisation_status-Left front level control system sensor value range: deflected,0,
ENG144011-MAS18051,initialisation_status-Right front level control system sensor value range: deflected,0,
ENG144011-MAS18052,initialisation_status-Left rear level control system sensor value range: deflected,0,
ENG144011-MAS18053,initialisation_status-Right rear level control system sensor value range: deflected,0,
ENG144011-MAS18056,initialisation_status-Left front level control system sensor value range: decompressed,0,
ENG144011-MAS18058,initialisation_status-Right front level control system sensor value range: decompressed,0,
ENG144011-MAS18061,initialisation_status-Left rear level control system sensor value range: decompressed,0,
ENG144011-MAS18064,initialisation_status-Right rear level control system sensor value range: decompressed,0,
ENG144011-MAS18065,initialisation_status-Function activation: deflected,0,
ENG144010-IDE00556,Input_signals-Outside temperature,19.50, °C
ENG144009-ENG102896,Input_signals_engine-engine_moment_driver_command,0, Nm
ENG144009-ENG145288,Input_signals_engine-engine_moment_driver_command_Textual,numerical value: no text,
ENG144009-ENG144703,Input_signals_engine-Engine_RPM,0.00, /min
ENG144009-ENG100233,Input_signals_engine-MO_brake_light_switch,Not braking,
ENG144009-ENG99648,Input_signals_engine-MO_driver_brakes,Not braking,
ENG144009-ENG145177,Input_signals_engine-momentum_factor,Factor 1,
ENG144007-IDE02211,Input_signals_ESP-Brake pressure,0.30, bar
ENG144007-ENG99480,Input_signals_ESP-ESP_coding_ADS,Initial value,
ENG144007-ENG102099,Input_signals_ESP-ESP_HBA_active,not active,
ENG144007-ENG101918,Input_signals_ESP-ESP_prefill_triggered,No,
ENG144007-ENG101915,Input_signals_ESP-ESP_request_distribution_of_rolling_moment,-1.00,
ENG144007-ENG101844,Input_signals_ESP-ESP_standstill_flag,standstill detected,
ENG144007-ENG103106,Input_signals_ESP-ESP_system_state,No malfunction,
When the car is lifted of ground:
adpmap:
;Monday,13,July,2026,11:07:52:43336
Blockmap
;Monday,13,July,2026,11:07:14:43336
IDE00019,Voltage terminal 30,11.60, V
IDE00106,Internal DTC,0,
IDE00541-IDE02543,Acceleration-Body acceleration sensor,9.76, m/s²
IDE02544,Body acceleration sensor: temperature,19.18, °C
IDE02547,Roll rate sensor: temperature,19.80, °C
IDE02550,Pitch rate sensor: temperature,19.18, °C
IDE02941,Compressor temperature,17, °C
IDE03050,Voltage supply for Solen.val. block,0.14, V
IDE03064,Accumulator pressure,16.70, bar
IDE03661-IDE02546,Rotation rate-Roll rate sensor,0.00, rad/s
IDE04018-MAS00110,Pressure test time stamp: current-Minutes,7,
IDE04018-MAS00111,Pressure test time stamp: current-Seconds,40,
IDE05163-MAS02194,Air Suspension Compressor-Temperature 1,21, °C
IDE05163-MAS04121,Air Suspension Compressor-Voltage,12.20, V
IDE07151-IDE03849,Vehicle level sensor: raw value-Left front level control system sensor: raw value,88.81, %
IDE07151-IDE03857,Vehicle level sensor: raw value-Right front level control system sensor: raw value,12.32, %
IDE07151-IDE03865,Vehicle level sensor: raw value-Left rear level control system sensor: raw value,87.95, %
IDE07151-IDE04147,Vehicle level sensor: raw value-Right rear level control system sensor: raw value,13.32, %
IDE08343,Immobilizer Challenge,2A 5A 48 75,
IDE08605-IDE02955,Status drive profile for level control system-System status,Not available,
IDE09238-IDE03058,Damper valve: actual current-Damper valve current: right front,0.38, A
IDE09238-IDE03060,Damper valve: actual current-Left rear shock absorber valve current,0.38, A
IDE09239-IDE03057,Damper valve: PWM value-Left front damper: PWM signal value,3.41, %
IDE09239-IDE03059,Damper valve: PWM value-Right front damper: PWM signal value,3.72, %
IDE09239-IDE03061,Damper valve: PWM value-Left rear damper: PWM signal value,3.72, %
IDE09239-IDE03063,Damper valve: PWM value-Right rear damper: PWM signal value,0.00, %
IDE09241-MAS01854,Calculated damper temperature-Right front,13, °C
IDE09242-MAS08451,Damper output stage temperature-Front axle,23, °C
IDE09248-MAS03024,Control prevention detection-Car jack mode,active,
IDE09248-MAS04501,Control prevention detection-Lift,active,
IDE09248-MAS08456,Control prevention detection-Locked position wheel change,active,
IDE09261-MAS01106,Level control: internal status-Level control system,not active,
IDE09262-MAS03024,Level control: external status-Car jack mode,active,
IDE09262-MAS08493,Level control: external status-Locked position,active,
IDE09265-IDE05164,No. activations of Solen.val. block-Air suspension valve: left front,146002, counts
IDE09265-IDE05165,No. activations of Solen.val. block-Air suspension valve: right front,142741, counts
IDE09265-MAS05733,No. activations of Solen.val. block-Level control accumulator valve,98370, counts
IDE09266-IDE03219,No. activations of level control valves-Relief valve,255716, counts
IDE09267-MAS08496,Number of control cycles-Number of manual target level changes when standing,663, counts
IDE09271-IDE02951,Absolute vehicle height-Absolute left front vehicle height,549, mm
IDE09271-IDE02952,Absolute vehicle height-Absolute right front vehicle height,556, mm
IDE09271-IDE02953,Absolute vehicle height-Absolute left rear vehicle height,560, mm
IDE09271-IDE02954,Absolute vehicle height-Absolute right rear vehicle height,560, mm
IDE09272-IDE03123,Last measd pressur in air spring bellows-Last measured pressure in left front pneumatic spring bellows,8.10, bar
IDE09272-IDE03124,Last measd pressur in air spring bellows-Last measured pressure in right front pneumatic spring bellows,8.80, bar
IDE09273-IDE02947,Height deviation from adapted vehicle height-Left front height deviation from adapted vehicle height,107, mm
IDE09273-IDE02948,Height deviation from adapted vehicle height-Right front height deviation from adapted vehicle height,114, mm
IDE09273-IDE02949,Height deviation from adapted vehicle height-Left rear height deviation from adapted vehicle height,105, mm
IDE09273-IDE02950,Height deviation from adapted vehicle height-Right rear height deviation from adapted vehicle height,105, mm
IDE09274-IDE03042,Height deviation from control pos-Height deviation of control position: left front,107, mm
IDE09274-IDE03043,Height deviation from control pos-Height deviation of control position: right front,114, mm
IDE09274-IDE03044,Height deviation from control pos-Height deviation of control position: left rear,105, mm
IDE09274-IDE03045,Height deviation from control pos-Height deviation of control position: right rear,105, mm
IDE09275-MAS08978,Loading function operating condition-Precondition:no ctrl. process active,Condition not met,
IDE09275-MAS08979,Loading function operating condition-Precondition:level control active,Condition not met,
IDE09455,Number of wake-up processes via level ctrl.,61107, counts
IDE10558-MAS05292,Inclination display: input signals inertial sensors-Estimated offset fault of rotation rate sensor,BB 7B 4C C5,
IDE10559-MAS02465,Inclination display: input signals GPS-Speed in y-direction,BA 3A 78 66,
IDE10559-MAS02469,Inclination display: input signals GPS-Speed in x-direction,3C 61 9B EE,
IDE10611-IDE02923,Actuator test: release status 2-Lower vehicle at left front,not enabled,
IDE10611-IDE02924,Actuator test: release status 2-Lower vehicle at right front,not enabled,
IDE10611-IDE02925,Actuator test: release status 2-Lower vehicle at left rear,not enabled,
IDE10611-IDE02926,Actuator test: release status 2-Lower vehicle at right rear,not enabled,
IDE10801-MAS03095,Calibration of level control for determining axle load: status-Function status,not calibrated,
IDE10801-MAS08451,Calibration of level control for determining axle load: status-Front axle,-54, kg
IDE10801-MAS08452,Calibration of level control for determining axle load: status-Rear axle,-99, kg
IDE10941-MAS05290,Inclination display: input signals inertial sensors 2-Estimated offset fault of roll rate sensor,B9 92 A1 14,
IDE10971-MAS02465,Inclination display: calculated values-Speed in y-direction,38 92 72 D9,
IDE10971-MAS02469,Inclination display: calculated values-Speed in x-direction,3C 7E 40 05,
IDE12885-IDE00326,Damper control: input signal from steering-Steering wheel angle,35.30, °
ENG144011-MAS18064,initialisation_status-Right rear level control system sensor value range: decompressed,1,
ENG144007-IDE02211,Input_signals_ESP-Brake pressure,0.00, bar
Thanks!
Sorry for the delay. If this is not fixed I see that your Absolute (meaning live readings) are fairly reasonable but the right front is 6 to 7 mm greater than the left front in both positions:
On the ground and in Auto mode:
IDE09271-IDE02951,Absolute vehicle height-Absolute left front vehicle height,440, mm​
IDE09271-IDE02952,Absolute vehicle height-Absolute right front vehicle height,446, mm​
IDE09271-IDE02953,Absolute vehicle height-Absolute left rear vehicle height,456, mm​
Lifted off the ground:
IDE09271-IDE02951,Absolute vehicle height-Absolute left front vehicle height,549, mm​
IDE09271-IDE02952,Absolute vehicle height-Absolute right front vehicle height,556, mm​
IDE09271-IDE02953,Absolute vehicle height-Absolute left rear vehicle height,560, mm​
IDE09271-IDE02954,Absolute vehicle height-Absolute right rear vehicle height,560, mm​
Yours does not have the "fully extended" groups like my e-tron 55 but that right front discrepancy carries over to the "deviation" groups:
IDE09273-IDE02947,Height deviation from adapted vehicle height-Left front height deviation from adapted vehicle height,107, mm​
IDE09273-IDE02948,Height deviation from adapted vehicle height-Right front height deviation from adapted vehicle height,114, mm​
IDE09273-IDE02949,Height deviation from adapted vehicle height-Left rear height deviation from adapted vehicle height,105, mm​
IDE09273-IDE02950,Height deviation from adapted vehicle height-Right rear height deviation from adapted vehicle height,105, mm​
IDE09274-IDE03042,Height deviation from control pos-Height deviation of control position: left front,107, mm​
IDE09274-IDE03043,Height deviation from control pos-Height deviation of control position: right front,114, mm​
IDE09274-IDE03044,Height deviation from control pos-Height deviation of control position: left rear,105, mm​
IDE09274-IDE03045,Height deviation from control pos-Height deviation of control position: right rear,105, mm​
If this is not fixed I would try to do the standard calibration once more. After doing so see if the right front "deviation" values look better before attempting the deflected calibration again.
Repeating the standard calibration does not help then make sure the new sensor they sold you was: 4M0 941 286 D
Vdub
C?ID=57533
Where is the part from? I've had some aftermarket level sensors that werent quit good as the OEM, so often you buy twice...
