;SW:5Q0-959-435-C HW:5Q0-959-435 --- 05: Acc/Start Auth.
;Component:VWKESSYMQB 021 0803, Coding:032C0C
;EV_KessyHellaMQBAB,002020,EV_KessyHellaMQBAB_002_AU37.rod
;Thursday,02,July,2026,19:45:52:31403
;VCDS Version: 26.3.0.0 (x64) Data version: 20260320 DS375.1
;VCID: 3C26D64F76EC0D5AD3B-8068
Group,Description,Actual
IDE00019,Voltage terminal 30,12.224, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00030,Status of actuator test,canceled for safety reasons,
IDE02406,Key number of last identified ID sensor,Not available,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver´s door,Open,
IDE02408-MAS00219,Individual door locking: status-Passenger´s door,closed,
IDE02408-MAS00220,Individual door locking: status-Rear left door,closed,
IDE02408-MAS00221,Individual door locking: status-Rear right door,closed,
IDE02409,ID-sensor 1 authentication: status,No response,
IDE02410,ID-sensor 2 authentication: status,No response,
IDE02411,ID-sensor 3 authentication: status,No response,
IDE02412,ID-sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver´s door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,115,
IDE02419,Proximity sensor frt.pass. door: number of triggers,193,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,70,
IDE02422-MAS01483,Driver door handle: version information-Software version,2F,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,6A,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,FF,
IDE02423-MAS01483,ass. door handle: version information-Software version,FF,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,FF,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,00,
IDE02424-MAS01483,Left rear door handle: version information-Software version,00,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,00,
IDE02425-MAS01483,Right rear door handle: version information-Software version,00,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,00,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,No,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,No,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,No,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,No,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,||0|,
IDE02483,72-hour signaling counter frt.pass. door,||0|,
IDE02484,72h-Signaling counter left rear door,||0|,
IDE02485,72h-Signaling counter right rear door,||0|,
IDE02486,Data logger triggering,not activated,
IDE02495-MAS00976,Service-Key: Number of activations-Counter,0,
IDE02496-MAS00976,Service-Key: Number of Timeouts-Counter,0,
IDE02497-MAS00976,Service-Key: Number of incomplete messages-Counter,0,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,0,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,0,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,0,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,0,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,1,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,332,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,4,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2026,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,6,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,7,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,30,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,16,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,8,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,15,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,50,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,45,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,36,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,23,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,55,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,59,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,36,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,44,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,9,
IDE03127,Prevented stop processes (ring memory),3,
IDE03127,Prevented stop processes (ring memory),2,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,All releases are present,
IDE04042-ENG151577,ID sensor history data-Scan 1 Origin,Passive Go,
IDE04042-ENG104152,ID sensor history data-Scan 1 Single Scan,Interior with trunk,
IDE04042-ENG151484,ID sensor history data-Scan 1 Trigger,Go authentication request,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG151507,ID sensor history data-Scan 2 Origin,Passive Go,
IDE04042-ENG99359,ID sensor history data-Scan 2 Single Scan,Interior with trunk,
IDE04042-ENG151474,ID sensor history data-Scan 2 Trigger,Go ID request,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,52,
IDE04042-ENG151555,ID sensor history data-Scan 3 Origin,Passive Go,
IDE04042-ENG102354,ID sensor history data-Scan 3 Single Scan,Interior with trunk,
IDE04042-ENG151486,ID sensor history data-Scan 3 Trigger,Go authentication request,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,62,
IDE05204,Manufacturer production data door handle drivers door,11 70 86 17 46,
IDE05205,Manufacturer production data door handle front pass.door,FF FF FF FF FF,
IDE05206,Manufacturer production data door handle left rear,00 00 00 00 00,
IDE05207,Manufacturer production data door handle right rear,00 00 00 00 00,
IDE07359,Dimming of starter button lighting,64 0B,
ENG157998-MAS00106,lf_shutdowns-Year,2026,
ENG157998-MAS00107,lf_shutdowns-Month,7,
ENG157998-MAS00108,lf_shutdowns-Day,1,
ENG157998-MAS00108,lf_shutdowns-Day,2,
ENG157998-MAS00109,lf_shutdowns-Hours,19,
ENG157998-MAS00109,lf_shutdowns-Hours,15,
ENG157998-MAS00110,lf_shutdowns-Minutes,57,
ENG157998-MAS00110,lf_shutdowns-Minutes,33,
ENG157998-MAS00110,lf_shutdowns-Minutes,56,
ENG157998-MAS00111,lf_shutdowns-Seconds,44,
ENG157998-MAS00111,lf_shutdowns-Seconds,54,
ENG157998-MAS00111,lf_shutdowns-Seconds,28,
ENG157998-MAS00111,lf_shutdowns-Seconds,18,
ENG157998-ENG163142,lf_shutdowns-Mileage_lf_shutdown_n,35962, km
ENG157998-ENG163143,lf_shutdowns-Mileage_lf_shutdown_n-1,35962, km
ENG157998-ENG163144,lf_shutdowns-Mileage_lf_shutdown_n-2,35962, km
ENG157998-ENG163145,lf_shutdowns-Mileage_lf_shutdown_n-3,35962, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,00000000 ,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,00000001 ,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,00000000 ,
ENG157420-ENG129142,Scan_cycle_data-Car_key_3,00000000 ,
ENG157420-ENG129143,Scan_cycle_data-Car_key_4,00000000 ,
ENG157420-ENG161108,Scan_cycle_data-Mileage_n,35962, km
ENG157420-ENG161109,Scan_cycle_data-Mileage_n-1,35962, km
ENG157420-ENG161110,Scan_cycle_data-Mileage_n-10,35952, km
ENG157420-ENG161111,Scan_cycle_data-Mileage_n-11,35595, km
ENG157420-ENG161112,Scan_cycle_data-Mileage_n-12,35595, km
ENG157420-ENG161113,Scan_cycle_data-Mileage_n-13,35140, km
ENG157420-ENG161114,Scan_cycle_data-Mileage_n-14,35140, km
ENG157420-ENG161115,Scan_cycle_data-Mileage_n-15,35065, km
ENG157420-ENG161116,Scan_cycle_data-Mileage_n-16,35065, km
ENG157420-ENG161117,Scan_cycle_data-Mileage_n-17,35062, km
ENG157420-ENG161118,Scan_cycle_data-Mileage_n-18,35062, km
ENG157420-ENG161119,Scan_cycle_data-Mileage_n-19,35033, km
ENG157420-ENG161120,Scan_cycle_data-Mileage_n-2,35962, km
ENG157420-ENG161121,Scan_cycle_data-Mileage_n-3,35962, km
ENG157420-ENG161122,Scan_cycle_data-Mileage_n-4,35962, km
ENG157420-ENG161123,Scan_cycle_data-Mileage_n-5,35962, km
ENG157420-ENG161124,Scan_cycle_data-Mileage_n-6,35963, km
ENG157420-ENG161125,Scan_cycle_data-Mileage_n-7,35960, km
ENG157420-ENG161126,Scan_cycle_data-Mileage_n-8,35957, km
ENG157420-ENG161127,Scan_cycle_data-Mileage_n-9,35954, km
ENG157420-ENG161148,Scan_cycle_data-Retry_count_n,1,
ENG157420-ENG161150,Scan_cycle_data-Retry_count_n-1,1,
ENG157420-ENG161151,Scan_cycle_data-Retry_count_n-10,1,
ENG157420-ENG161152,Scan_cycle_data-Retry_count_n-11,8,
ENG157420-ENG161153,Scan_cycle_data-Retry_count_n-12,6,
ENG157420-ENG161154,Scan_cycle_data-Retry_count_n-13,8,
ENG157420-ENG161155,Scan_cycle_data-Retry_count_n-14,6,
ENG157420-ENG161156,Scan_cycle_data-Retry_count_n-15,38,
ENG157420-ENG161157,Scan_cycle_data-Retry_count_n-16,6,
ENG157420-ENG161158,Scan_cycle_data-Retry_count_n-17,39,
ENG157420-ENG161159,Scan_cycle_data-Retry_count_n-18,6,
ENG157420-ENG161160,Scan_cycle_data-Retry_count_n-19,8,
ENG157420-ENG161161,Scan_cycle_data-Retry_count_n-2,1,
ENG157420-ENG161162,Scan_cycle_data-Retry_count_n-3,1,
ENG157420-ENG161163,Scan_cycle_data-Retry_count_n-4,1,
ENG157420-ENG161164,Scan_cycle_data-Retry_count_n-5,1,
ENG157420-ENG163537,Scan_cycle_data-Retry_count_n-6,1,
ENG157420-ENG161165,Scan_cycle_data-Retry_count_n-7,1,
ENG157420-ENG161166,Scan_cycle_data-Retry_count_n-8,1,
ENG157420-ENG161167,Scan_cycle_data-Retry_count_n-9,1,
ENG157420-ENG161186,Scan_cycle_data-Scan_reason_n,driver_window,
ENG157420-ENG161187,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG157420-ENG161188,Scan_cycle_data-Scan_reason_n-10,driver_window,
ENG157420-ENG161189,Scan_cycle_data-Scan_reason_n-11,Passenger_door,
ENG157420-ENG161190,Scan_cycle_data-Scan_reason_n-12,Driver_door,
ENG157420-ENG161191,Scan_cycle_data-Scan_reason_n-13,Driver_door,
ENG157420-ENG161192,Scan_cycle_data-Scan_reason_n-14,Driver_door,
ENG157420-ENG161193,Scan_cycle_data-Scan_reason_n-15,Passenger_door,
ENG157420-ENG161194,Scan_cycle_data-Scan_reason_n-16,Driver_door,
ENG157420-ENG161195,Scan_cycle_data-Scan_reason_n-17,Driver_door,
ENG157420-ENG161196,Scan_cycle_data-Scan_reason_n-18,Driver_door,
ENG157420-ENG161197,Scan_cycle_data-Scan_reason_n-19,Driver_door,
ENG157420-ENG161198,Scan_cycle_data-Scan_reason_n-2,driver_window,
ENG157420-ENG161199,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG157420-ENG161200,Scan_cycle_data-Scan_reason_n-4,Driver_door,
ENG157420-ENG161201,Scan_cycle_data-Scan_reason_n-5,Driver_door,
ENG157420-ENG161202,Scan_cycle_data-Scan_reason_n-6,Passenger_door,
ENG157420-ENG161203,Scan_cycle_data-Scan_reason_n-7,Passenger_door,
ENG157420-ENG161204,Scan_cycle_data-Scan_reason_n-8,Passenger_door,
ENG157420-ENG161205,Scan_cycle_data-Scan_reason_n-9,Driver_door,
ENG157420-ENG161206,Scan_cycle_data-Scan_trigger_n,Set_stop_car,
ENG157420-ENG161207,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG157420-ENG161208,Scan_cycle_data-Scan_trigger_n-10,Set_drive_car,
ENG157420-ENG161209,Scan_cycle_data-Scan_trigger_n-11,Reset_stop_car,
ENG157420-ENG161210,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG157420-ENG161211,Scan_cycle_data-Scan_trigger_n-13,Reset_stop_car,
ENG157420-ENG161212,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG157420-ENG161213,Scan_cycle_data-Scan_trigger_n-15,Reset_stop_car,
ENG157420-ENG161214,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG157420-ENG161215,Scan_cycle_data-Scan_trigger_n-17,Reset_stop_car,
ENG157420-ENG161216,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG157420-ENG161217,Scan_cycle_data-Scan_trigger_n-19,Reset_stop_car,
ENG157420-ENG161218,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG157420-ENG161219,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG157420-ENG161220,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG157420-ENG161221,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG157420-ENG161222,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG157420-ENG161223,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG157420-ENG161224,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG157420-ENG161225,Scan_cycle_data-Scan_trigger_n-9,Set_drive_car,
Elapsed Time: 00:09
