2010 S5 convertible top switches
   #21
Mike T
Valrico, FL, USA
C?ID=601016
I reset the 2 side latches but the problem at this point is that I can't get my hands in there to pull the cylinder/arms down to get the switches to read them.
   #23
Mike T
Valrico, FL, USA
C?ID=601016
So far I have cleared several other codes from the initial scan report posted. Will post shortly. It's difficult here since I'm disabled and my legs don't really work anymore, but thanks to members help on here...I'm getting there!
   #25
Jef
HQ
The F290 and F407 look to be a single part with 3 wires where as the F291 looks to be a more normal simple single sensor with just 2 wires.
Along with those 3 sensors, there are two other sensors wired to a common ground, the F411 and F412. Said common grounds all go to T16u/8 of the J256.
Did F411 and F412 ever have errors?
Vdub
C?ID=57533
its one of the most problematic reachable sensors which often fails at an A5
   #27
Ziddywerks
Northern NJ USA
C?ID=208579
   #28
Mike T
Valrico, FL, USA
C?ID=601016
Sorry for the delay. Cleaned up the other codes I had going. Those cleared out when I put the original seat modules back in. Todays readout attached.
Thursday,02,July,2026,23:49:16:60431
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.5
VIN: WAUVGAFH8AN013634   License Plate:
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 22 26 36 3C 42 46 47 52
          53 55 56 5F 62 6C 72
VIN: WAUVGAFH8AN013634   Mileage: 70050km-43527miles
26-Auto Roof -- Status: Malfunction 0010
Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H06 0003
   Revision: --H06---    CVN: BC966676
   Coding: 011C000A240F0128
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 323AC21BA4A1A16A097-8066
   VINID: 9D19665D159821178004318310A0C14052
Readiness: 1110 1101
   Part No SW: 8K0 927 156 M    HW: 0B5 927 156 E
   Component: 0B5 30TFSINAR H03 0007
   Revision: --H03---    Serial number: 0000000978 CVN: 00005EB1
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 3E22E62B60F9750AFDF-806A
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 290D1A
   Shop #: WSC 02391 823 56573
   VCID: 7AAA2A3B3CD1992A817-802E
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0326
   Coding: 0D0300
   Shop #: WSC 02399 823 56573
   VCID: 045654C34E15DFDAEBB-8050
   Subsystem 1 - Part No SW: 8T0 959 754 S    HW: 8T0 959 754 S
   Component: FBSAUDIB8 IDG  H38 0060
   Serial number: 0509000057050008
   Serial number: 0209000074474007
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001001360111
   Coding: 00017025002C00000000
   VCID: 43D497DF0B9B18E2921-8016
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01211020090080
   Coding: 66132000
   VCID: 005E58D35A0DC3FACF3-8054
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000484197
   Coding: 26001091063CAF212700080300003D3D0F9CD2C800010161000000
   VCID: 3C26EC237665671AD3B-8068
   Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 121009  H06 0021
   Serial number: SWF09100125109
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10071865
   Coding: 025523
   Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001310090399
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940928801787
   Coding: 200102
   VCID: 3E22E62B6079750AFDF-806A
Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
   Part No SW: 8F0 959 655 A    HW: 8F0 959 655 A
   Component: AirbagVW-AU10 H10 0430
   Serial number: 003A5D060M4K   Dataset Number: 8F0909602B0020
   Coding: 303737353631303030304A55304C38463053
   Shop #: WSC 02135 785 00200
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 3632FE0B48C9BD4A25F-8062
   Seat occupant detection:
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0900003RRG
   Serial number: 6334MSME4C451465E
   Serial number: 6344MSME4C331867I
   Serial number: 6352QSME2E3B5634P
   Serial number: 6362QSME573D0822I
   Serial number: 63732SME26424C20V
   Serial number: 63832SME503E261C0
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90319IJE000BY
   Coding: 000036
   Part No SW: 8T0 920 981 N    HW: 8T0 920 981 N
   Component: KOMBIINSTR.   H34 0255
   Revision: 00000000    Serial number: CI523G7A9
   Coding: 8B1719008300D705020000
   VCID: 47CC83CF3FA334C24E9-8012
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09A090027
   Coding: 00C303
   Component: J367-BDM  H06 0170
   Serial number: 190945D7061009
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163     HW: 8K0 907 163
   Component: 4 Wheel Drive H09 0004
   Serial number: 001609090001034 Dataset Number: 8F0909104B0012
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
   VCID: 6D8011677D1F3E92145-8038
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H09 0170
   Coding: 030000
   ASAM Dataset: EV_ElectRoofContr 001007
   ROD: EV_ElectRoofContr.rod
   VCID: 71B80D176127DA7230D-8024
0043 - Supply Voltage 1 for Switches
          B119F 01 [10001001] - Electrical Failure
                    Reset counter: 47
                    Mileage: 70052 km
                    Date: 2009.07.15
                    Time: 02:53:47
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001001359199
   Coding: 00197B25002C00000000
Address 3C: Lane Change        Labels: 8K0-907-566.clb
   Part No SW: 8K0 907 566 F    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0010
   Revision: 00H01000    Serial number: 6PZ 009 014-19
   Coding: 0000005
   VCID: 3A2AEA3B7051592AC17-806E
   Subsystem 1 - Part No: 8K0 907 568 F
   Component: J0770_SWA_Slave_H01 0010
   Subsystem 2 - Serial number: 6PZ 009 014-39
   Subsystem 3 - Serial number: 5F15.10.0900H010003CR10559ÿ
   Subsystem 4 - Serial number: R10559ÿ
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009446815
   Coding: 011C53724E08332C03
   VCID: 45D089C705AF26D2BC5-8010
   Revision: 00002001    Serial number: 0122046366
   Coding: 010602BA007A442100B0030000000000
   Subsystem 1 - Part No SW: 8F0 959 719     HW: 8F0 959 719
   Component: GTO BF  H06 0050
   Serial number: 00000000000000171889
Address 47: Sound System
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009477277
   Coding: 011C53324E08332C03
   VCID: 44D694C30E951FDAABB-8010
   Revision: 00000003    Serial number: 10000000330307
   VCID: 3436C4035E35AF5A1BB-8060
   Part No: 8K5 907 357
   Coding: 0000002
   VCID: 77AC330F03C38442FE9-8022
   Part No SW: 4G0 035 080 G    HW: 4G0 035 080
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 158E20N7540416
   Coding: 020007010000000101
   Shop #: WSC 28450 005 1048576
   VCID: 221A325BF4C131EAF97-8076
   Part No SW: 8T1 035 664 F    HW: 8T1 035 664 B
   Component: H-BN-NA       H45 0189
   Revision: --------    Serial number: 490JX097530119
   Coding: 010200030206A1EF55000B0E000000010100
   VCID: 3B24EF3F736B6022DA1-806E
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356J/091087808
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000380497
   Component: CD-Database  1293
00822 - Connection DSP to Radio
                    Reset counter: 47
                    Mileage: 70052 km
                    Date: 2009.07.15
                    Time: 16:19:23
                    Voltage: 12.70 V
   Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
   Revision:             Serial number: 0000102119674
   Coding: 010C13324008372C03
   Part No SW: 8F0 907 441     HW: 4L0 907 441 B
   Coding: 8388607
   VCID: 678C634F536314C26E9-8032
00001 - Brake Control Unit
   Revision:             Serial number: 0000102119701
End----------(Elapsed Time: 01:55, VBatt start/end: 12.5V/12.5V)-----------
------------------------------3 Faults Found-------------------------------
   #29
Mike T
Valrico, FL, USA
C?ID=601016
Maybe a dumb question, but could this have anything to do with the radio amplifier being removed? It has a fiber test loop in it currently for comm. The amp was removed when I got it. Came with a B&O amp.
   #30
Mike T
Valrico, FL, USA
C?ID=601016
Friday,03,July,2026,08:02:49:60431
Mileage: Repair Order: 4
Address 26: Auto Roof (8F0 959 255 )
08:02:43
IDE02664-MAS02263 Switch for folding top-Convertible top open position switch Not operated
IDE02664-MAS02264 Switch for folding top-Convertible top front closed position switch operated
IDE02664-MAS02265 Switch for folding top-Convertible top latch -open- switch Not operated
IDE02664-MAS02266 Switch for folding top-Convertible top left lock switch operated
IDE02664-MAS02268 Switch for folding top-Switch for folding top closed: left Malfunction
IDE02664-MAS02269 Switch for folding top-Switch for folding top closed: right Malfunction
IDE02664-MAS02270 Switch for folding top-Upper tensioning bow switch Not operated
IDE02664-MAS02271 Switch for folding top-Left tensioning bow switch Not operated
IDE02664-MAS02272 Switch for folding top-Right tensioning bow switch Not operated
IDE02664-MAS02273 Switch for folding top-Convertible top compartment -open- switch Malfunction
IDE02664-MAS02274 Switch for folding top-Left convertible top compartment cover switch Malfunction
IDE02664-MAS02275 Switch for folding top-Right convertible top compartment cover switch Malfunction
Friday,03,July,2026,08:07:21:60431
Mileage: Repair Order: 5
08:07:15
IDE02664-MAS02276 Switch for folding top-Switch for convertible top compartment cover lock unlocked Not operated
IDE02664-MAS02277 Switch for folding top-Switch for convertible top compartment cover lock locked operated
IDE02664-MAS02278 Switch for folding top-Left convertible top compartment enclosure switch operated
IDE02664-MAS02279 Switch for folding top-Right convertible top compartment enclosure switch operated
IDE02664-MAS02280 Switch for folding top-Left wind deflector switch Not operated
IDE02664-MAS02281 Switch for folding top-Right wind deflector switch Not operated
IDE02665 Power top operation switch Not operated
IDE02666-MAS00538 Convertible top status-Convertible top operation indicator lamp OFF
IDE02666-MAS01535 Convertible top status-Rear window defogger OFF
IDE02666-MAS01911 Convertible top status-Tone sensor OFF
IDE02666-MAS02282 Convertible top status-Position Implausible
IDE02666-MAS02283 Convertible top status-Condition Malfunction
   #31
Mike T
Valrico, FL, USA
C?ID=601016
Update. When I try to manually activate the top compartment latch motor V222, I can hear the J256 module clicking, but nothing happens. Also, I'm reading a ground on both side of F291 and all 3 wires on F290. I'm having to use a different scan tool since VCDS doesn't let you cycle the top components. Pump and all relays do activate for tests.
   #32
Zenerdiode
Newcastle, England
C?ID=24330
