Friday,30,October,2015,14:20:34:45928
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUF1GFF7G1015138 License Plate: JXS3338
Mileage: 368km-228mi Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
5F 6C A5 A9
VIN: WAUF1GFF7G1015138 Mileage: 368km-228miles
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00122466000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H_AU37.rod
VCID: 45AF892BC4128E162E-8010
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4903
Revision: 06253104 Serial number: TFK01506020163
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_AU37.rod
VCID: 538BA7733A4620A6B0-8006
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 3Q0 907 379 L HW: 3Q0 907 379 G
Component: ESC H42 0722
Revision: 00000000 Serial number: 61395000001866
Coding: 31FF6B9254210A710178030341CB698CD62A5080C08296B6184150D48208
VCID: 43AB9733CA26B02600-8016
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0371681725
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A55EAD7BDECF1EE53-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000664399
Coding: 03000014010000000000000000001400
VCID: 334BC7F39A8600A690-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0173
Serial number: 01061516600656
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 01275D3B90BA623652-8054
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150617 042 0585
Serial number: 150620021115
Coding: 0A47F7
Slave 2:
Component: G397_RLFS H06 0002
Serial number: 24025928
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 10 04 2015 00001536
Serial number: 00000000000032759641
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000CML9S00000
Coding: 101F00
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391516203685
Coding: 0070150011
ROD: EV_EPHVA18AU3700000_AU37.rod
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-567.clb
Part No SW: 5Q0 907 567 N HW: 5Q0 907 567 N
Component: ACC3 H10 0400
Serial number: 10061503090567
Coding: 01261701FE0309
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 46AD8E27F914850E27-8012
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 100615010
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide_AU37.rod
Address 15: Airbags
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 GR HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 18061504220381
Coding: E818
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 1001687FCBD01BBECD-8044
Part No SW: 8V0 920 972 B HW: 8V0 920 972 B
Component: KOMBI H03 6420
Coding: 0BCD181B7F88D7050281E8001800000000000000
VCID: 3D5FE1CBACC2C6D676-8068
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 16061510800725
Coding: 0101000830085A005B00023C980B00000001010000000000000000000000
ROD: EV_GatewConti.rod
VCID: 75CF39EBD4725E967E-8020
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 27 05 2015 C0064291
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00029.04.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000162994002
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449C4EF9F88079E89-8060
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0080
Serial number: 0368287311
Coding: 030211
ROD: EV_LaneChangAssis_AU37.rod
VCID: 3851F0DF83E0E3FEA5-806C
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 250515BEO10839
Coding: 005D1B205C00048000000003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9102
ROD: EV_SteerAssisMQB.rod
VCID: 3753F3E38EFEEC86AC-8062
Component: TSG BFS 020 0041
Serial number: 280515BER07519
Coding: 005D13205E00048000000003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42A59237D53CB92E0B-8016
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 0122000123200400
VCID: 3FA39BC3A6CED4C664-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7050
Coding: E00100
Part No SW: 8V0 035 038 B HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302F0FB014885
Coding: 017301020000000021220002041A00102F000225010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY2039FF
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000013041500020152
Door Electronics Rear Left:
Component: Gracenote --- 3006
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_CamSysRearPANAAU914.rod
VCID: 3041C8FF6B903BBEED-8064
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000373865
Coding: 0100000000010303000500010100000100
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3C59ECCFB7D8CFDE41-8068
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 060101201082
VCID: 7DDF21CBEC4206D636-8028
End-------------------------(Elapsed Time: 04:04)--------------------------
