MK3 MY16 Škoda Superb steering wheel with flappy paddles
Gizmo
S.E.Kent UK
C?ID=49193
Yesterday I tried (without success) to code a 2015 MK3 Superb with a retrofitted MFSW c/w flappy paddles.
The steering wheel came out of my new 2015 Superb with just 4 miles on the clock, however I did not drive my car before removal so cannot say 100% that it works, I did however do a scan before I removed it and there were no DTC’s.
The multi function buttons however are out of a Octavia vRS these are slightly different to the Superb, the Superb has a ‘Driver Assist’ button whereas the vRS has a ‘Voice control’ button, despite this ALL of the buttons work perfectly as Škoda intended.
The issue was I could find nowhere to activate the flappy paddles with VCDS, one forum search said the Octavia didn’t require any coding to a retro fit DSG steering wheel???
The 09 - Cent. Elect. / 16 - steering wheel / 19 - CAN Gateway long coding and admaps were identical (apart from spec differences between cars) from my factory fitted DSG wheel Superb.
Saturday,05,March,2016,10:14:27:28571VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: TMBKJ7NP1G7015385   License Plate: EX65 ***
Mileage: 1984km-1232mi   Repair Order: 1
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
          5F 6D A5
VIN: TMBKJ7NP1G7015385   Mileage: 1984km-1232miles
Address 01: Engine (J623-DFCA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2,0L EDC   H22 1195
   Revision: B4H22---
   Coding: 011D0032036501083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
   ROD: EV_ECM20TDI01104L906026FN_SK48.rod
   VCID: 7BB63EAEF28AFBE62B-802E
   Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4803
   Revision: 06253104    Serial number: TFK01507241139
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 177E021EEEE23F86AF-8042
   Revision: 00000000    Serial number: 62125000000177
   Coding: 1E07929C34210B71077A060841C84978492CD0E0608292F53861F0F8C2A9
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 7AB83BAAFDB0C2EE30-802E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0709
   Revision: 00036000    Serial number: 0374536391
   Coding: 030C0C0703
   ROD: EV_KessyHellaMQBAB_SK48.rod
   VCID: 3A38FBAABD3002EE70-806E
   Subsystem 2 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65025501
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 3V0 907 044 AJ    HW: 3V0 907 044 AJ
   Component: AC Automat    H32 3601
   Revision: 20K04000    Serial number: 00000B00015601
   Coding: 12110104000400011005100100101100
   ASAM Dataset: EV_ACClimaPrehVW37X 002009
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 7CB43DB2F784FCDE22-8028
   Slave 1:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061521601102
   Coding: 0FD11A66C2C72AFB17844086B10C572C0800000000000000000000000000
   ROD: EV_BCMBOSCH_SK48.rod
   VCID: 095A5466A856D97629-805C
   Slave 1:
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 150122  032 0121
   Serial number: 00000001501200606211
   Coding: 165DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S2Y15M08D06H22M27S43
   Coding: 0088DF
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY151180TJ2
   Serial number: 00000000000033001403
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615197
   Coding: 0371067851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_SK48.rod
   VCID: 0D526076DC3EC55605-8058
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 320067C355FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3424D5929F54F49EAA-8060
1538 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Reset counter: 110
                    Mileage: 1784 km
                    Date: 2016.03.05
                    Time: 08:02:24
1542 - Sensor for Automatic Distance Control
                    Reset counter: 110
                    Mileage: 1784 km
                    Date: 2016.03.05
                    Time: 08:02:24
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 30071541350533
   ROD: EV_DRCONTITEMIC.rod
   VCID: 373EE29E8E221F868F-8062
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R10MPBY
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   Subsystem 1 - Part No SW: -----------    HW: 480 000 708 15
   Serial number: 35700000000CD520C51M
   Subsystem 2 - Part No SW: -----------    HW: 480 001 507 15
   Serial number: 358000000009A450851F
   Subsystem 3 - Part No SW: -----------    HW: 480 401 407 15
   Serial number: 3510002A91B7E8F0F35N
   Subsystem 4 - Part No SW: -----------    HW: 480 401 407 15
   Serial number: 3520002A91B7E8F2920E
   Subsystem 5 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3550002BD1B7E8F3E08Y
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 BD    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150806501099
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73A6168EDADAB3A673-8026
   Part No SW: 3V0 920 911     HW: 3V0 920 911
   Component: KOMBI         305 6421
   Coding: 27A5091A7F80A600018B6A0B5001000000000000
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 6FAE1AFEB6F2974697-803A
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 27071510801692
   Coding: 030100044F087300EB00025A9C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00063
   ROD: EV_GatewConti.rod
   VCID: 75A22896D4AEAD965D-8020
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D0445300715
   Serial number: 1795207503
   Serial number: 15000058410007
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA1C86A0C681B681-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OGD13122
   Coding: 001400000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B36FEAEB20A3BE66B-806E
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0373935154
   Coding: 02011203
   ROD: EV_HREntryHella_SK37.rod
   VCID: 3C34FDB2B7043CDE62-8068
   Lane Change Assistant 2:
   Serial number: 300615BFU05993
   Coding: 001D0820DE01040000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 43C6864ECAFA432623-8016
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 9303
   ROD: EV_SteerAssisMQB.rod
   Serial number: 100715BGA04028
   Coding: 001D0220DE01040000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 42C8834AD5E04A2E28-8016
   Coding: 06D602003F010000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40CC8942DBEC583E3E-8014
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 A    HW: 3V0 035 020
   Component: MU-H-ND-EU    H42 0318
   Serial number: A435G0F7511515
   Coding: 038402010000000011111202008808002F0003E601200100DE
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 240425D22FB4641E3A-8070
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H44 1028
   Serial number: SKZ8Z9RAM0065L
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 801 JJ    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Door Electronics Rear Left:
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: -----------    HW: -----------
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1011
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Component: HDSG-Modul    H12 0250
   Revision: --------    Serial number: 30158191000000
   Coding: 0D08
   ASAM Dataset: EV_DeckLidCONTIAU736 001011
   ROD: EV_DeckLidCONTIAU736_SK48.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 3Q0 980 654     HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0010
   Serial number: 11081511P10851
   Coding: 020408020000040100062346C040A00088000E100000
   ROD: EV_MFKBoschMQBB_SK48.rod
   VCID: 74A41592DFD4B49E6A-8020
End-------------------------(Elapsed Time: 03:01)--------------------------
(The two DTC’s showing above were due to snow covering the sensor on the way to me)
philb24
uk, hythe
C?ID=212219
You should be able to get it working if you have the correct SWCM, there is a list on this site of SWCM modules & there functions
Gizmo
S.E.Kent UK
C?ID=49193
