VW Crafter 2025
RTS
C?ID=492458
Pre Scan
Wednesday,24,June,2026,21:53:50:50062
VCDS Version: 26.5.2.1 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260506 DS377.0
VIN: WV3ZZZSZ7T90*****   License Plate:
Chassis Type: SZ-VN54P PA* (5QS)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 52 5F 65 75 A5
          8109 810A 811E 811F 8120 8121 C002 C003
VIN: WV3ZZZSZ7T9004430   Mileage: 23238km-14439miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
8109-Close Rge Radar 1 -- Status: Cannot be reached 0100
810A-Close Rge Radar 2 -- Status: Cannot be reached 0100
811E-Burglary Protection FL -- Status: Cannot be reached 0100
811F-Burglary Protection FR -- Status: Cannot be reached 0100
8120-Burglary Protection RL -- Status: Cannot be reached 0100
8121-Burglary Protection RR -- Status: Cannot be reached 0100
Address 01: Engine (J623-DNAE)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 023 RL    HW: 05L 907 309 AH
   Component: R4 2.0l TDI   H80 4282
   Revision: NEH80---    Dataset Number: V03935465RM 0001 CVN: 250819F7991E9EBCA3C795CF64CF85E9A3C795CF43FB2DAA
   Coding: 011900340304010830000000000000000000000000000000
   Shop #: WSC 69101 377 00163
   ASAM Dataset: EV_ECM20TDI01105L906023RL 010007
   ROD: EV_ECM20TDI01105L906023RL_010.rod
   VCID: 0358E7173B9920F2CB0-8056 SFD+SFD2 [x]
   VINID: 9E60EAAAA8EA1E42400041030064820006
8 Faults Found:
45423 - Crash Shut-Down Activated
          P1609 00 [10101111] - -
          [Crash shut-off was triggered]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
                    Engine speed: 0.00 /min
                    Coolant temperature: 31  C
                    Intake air temperature: 29  C
                    Voltage terminal 30: 11.800 V
                    Engine status: COENG_READY
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
                    Acceleration: 0.000 m/s
                    Drivetrain coordinator: ACC fault status: 0
                    Drive train coordinator irreversible switch off conditions: 0
                    Drivetrain coordinator: brake fault status: 517
4875 - Coolant Pump 2
          P261A 00 [00100111] - Open circuit
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:11
                    Voltage terminal 30: 11.780 V
                    Coolant temperature sensor 1: B1: on cylinder head: raw value: 31.5  C
                    exh.gas recirc. (EGR) cooler pump: specified value: 10.00 %
                    EGR temp. sensor 2: B1: raw value: 30.4  C
                    Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value: 30.8  C
21605 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [10100111] - Malfunction
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:11
                    Turbocharger 1 charger output: temp. sensor 1: B1: raw value: 28.8  C
                    Fuel temperature sensor 1: B1: raw value: 29.6  C
                    Outside temperature sensor 1: B1: raw value: 3003.6  C
                    Control Module temperature: 34.9  C
                    Shut-off timer: last engine shut-off time: 732 s
                    Charge air cooler output: temp. sensor 1: B1: raw value: 28.1  C
23725 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [00100111] - -
          [Invalid Data Received FromInstrument Panel Cluster Control Module]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    selected gear-Bits 0-7: 1
44047 - Front Camera for Driver Assist Systems
          U1229 00 [00100111] - Implausible Message
          [Front camera for driver assistance systems implausible]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
23731 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [00100111] - -
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
38372 - Coolant Pump 2
          P2B62 00 [00100111] - Supply Voltage Malfunction
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
                    exh.gas recirc. (EGR) cooler pump: specified value: 21.24 %
                    EGR temp. sensor 2: B1: raw value: 30.5  C
                    Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value: 31.2  C
Readiness: 1 1 0 1 1
Address 03: ABS Brakes (J104)       Labels: 2N0-614-517-V1.clb
   Part No SW: 2N0 614 517 L    HW: 2N0 614 517 J
   Component: ESP10CB       H04 0740
   Serial number: BPA085210625015 Dataset Number: V03935474NE 0001
   Coding: 68244A48FE6340B052F57D
   ASAM Dataset: EV_Brake1BOSCHESP10VN54T 008016
   ROD: EV_Brake1BOSCHESP10VN54T_008.rod
   VCID: 343A74CB2EB7574A02A-8060 SFD+SFD2 [x]
0307 - Steering angle sensor
          C0528 00 [10100011] - Implausible signal
          [SAS failure when center is not yet found and vehicle speed or time exceeded. Failure is set with lamp activation.]
0433 - Steering angle sensor
          C0528 00 [10100111] - Implausible signal
          [Scl: LWI_Lenkradwinkel Error]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:08
0527 - Implausible Data Received from Instrument Panel Control Module
          [Scl: KBI_Standzeit_02 Invalid Value]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:13
0528 - Databus
          U1123 00 [00100111] - Received Error Message
          [Scl: KBI_Aussen_Temp_gef Error Value]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:13
0529 - Databus
          U1122 00 [00100011] - Implausible Message
          [Scl: KBI_Aussen_Temp_gef Invalid Value]
0612 - Control Module for ACC
          U164C 00 [00100111] - No Communications
          [ComScl: PDU AWV_03 - Timeout error]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 AC    HW: 5WA 959 436 M
   Component: Kessy IOBOX   122 0771
   Serial number: --------------- Dataset Number: V03935392HP 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 157CA94F450DAE42154-8040
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 BK    HW: 5WA 907 727 AF
   Component: AC Manuell    H01 5088
   Serial number: 211072520440550 Dataset Number: V03935472EA 0001
   Coding: 203110010011000000000000000001010000030000000000000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002062
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
   VCID: 1A66BA73AC13813A386-804E SFD+SFD2 [x]
523552 - BCM
          U15BA 00 [00100111] - Received Malfunction Value
          [Body computer 1/vehicle electrical system control module/el.ZE Received malfunction value 5]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
523532 - BCM
          [Body computer 1/vehicle electrical system control module/el.ZE Received malfunction value 2]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:11
523590 - Instrument Cluster
          U12DD 00 [00100111] - Received Malfunction Message
          [Instrumenten Panel Cluster (IPC) Control Module Received malfunction value]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
1048839 - Function limitation due to crash signal
          B1397 00 [00100111] - -
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:30
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 CE    HW: 5WA 937 086 BK
   Component: BCM37w_M1238 0517
   Serial number: BXJ53F050725940 Dataset Number: V03935477GJ 0001
   ASAM Dataset: EV_BCMwBL 005001
   ROD: EV_BCMwBL_005_VW41.rod
   VCID: 167EAE43580BA55A1CE-8042 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53524102400027178
   Subsystem 2 - Part No SW: 571 941 633     HW: 571 941 633
   Component: E1 - LiAM      H05 0070
   Serial number:  09S20.06.2526792673
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000006733867
   Subsystem 4 - Part No SW: 5Q0 951 172 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA    006 0501
   Serial number: 0000000000000Q3EH99Q
   Subsystem 5 - Part No SW: 5H0 959 561 CG    HW: 5H0 959 561 CG
   Component: -VW----LINDA-  505 0835
   Serial number: MW3LND06072500011623
   Steering Column Switch:
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [00101111] - Open or Short to Plus
                    Fault Frequency: 118
                    Reset counter: 2
                    Mileage: 257 km
                    Date: 2010.00.00
                    Time: 05:43:06
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [00101111] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 257 km
                    Date: 2010.00.00
                    Time: 05:43:06
9738 - Bulb for Left Parking Lamp
          B12E8 15 [00101111] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 258 km
                    Date: 2010.00.00
                    Time: 05:43:06
9994 - Bulb for Right Parking Lamp
          B12E9 15 [00101111] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 258 km
                    Date: 2010.00.00
                    Time: 05:43:06
137217 - Outside temperature sensor
          B103F 1B [00101111] - Resistance Too High
                    Reset counter: 2
                    Mileage: 258 km
                    Date: 2010.00.00
                    Time: 05:43:06
338440 - Databus
          U1123 00 [00101111] - Received Error Message
          [Kombi  Datenbus empfangener Fehlerwert]
                    Reset counter: 2
                    Mileage: 262 km
                    Date: 2010.00.00
                    Time: 05:43:06
   Part No SW: 5QS 919 294 B    HW: 5QS 919 294
   Component: PDC 08ch low  H01 0191
   Serial number: 000024072595570 Dataset Number: V03935465HH 0001
   Coding: 0040010001
   ASAM Dataset: EV_EPHBO18VW3360000 001010
   ROD: EV_EPHBO18VW3360000_VW42.rod
   VCID: 5DECF16FFDBDB6029D4-8008
9 Faults Found:
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [00100011] - Open or Short to Ground
1112084 - Front Left Center Parking Aid Sensor
          B10F8 14 [00100011] - Open or Short to Ground
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [00100011] - Open or Short to Ground
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [00100011] - Open or Short to Ground
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [00101111] - Open Circuit
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
12587032 - Databus
          [BCM - Klima_Sensor_02.BCM1_Aussen_Temp_ungef - Fehlerspeicher auslesen]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
12587097 - Databus
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
12587130 - Databus
          [Steuerger t f r Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:14
12587196 - Databus
          [Bremsensteuerger t - VMM_02_Auth.VZM_Systemstatus - Fehlerspeicher auslesen]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 P    HW: 5QS 959 655 P
   Component: AirbagVW50    010 0250
   Serial number: 000000003C0TNRD Dataset Number: V03935460WQ 0001
   Coding: 8800000000C00000000000000000000095000000A9000000E000F68000AB00A7
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001062
   ROD: EV_AirbaVW50SMEVW49X.rod
   VCID: 70B2B8DB1A2F2B6A262-8024 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: -----------    HW: 480 051 006 19
   Component: FrontSensor_D  000 010A
   Serial number: 35500009CE19DC066770
   Subsystem 2 - Part No SW: -----------    HW: 480 051 006 19
   Component: FrontSensor_P  000 010A
   Serial number: 35600009AE19DC0888D0
          B1000 1B [10101111] - Resistance Too High
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
          B1006 1B [10101111] - Resistance Too High
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10101111] - Resistance Too High
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
9437723 - Igniter for Passenger's Airbag
          B1002 1B [10101111] - Resistance Too High
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
1075977 - Databus
          [NWD: 0x102 ESC_50 error value ESP_v_ref]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
1061381 - Databus
          [NWD: 0x5E1 Klima_Sensor_02 error value BCM1_Aussen_Temp_ungef]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 BB    HW: 1EE 953 507 BB
   Component: GSMMEB        005 0066
   Serial number: 000000070725260
   ASAM Dataset: EV_SMLSKLOGEN2 009005
   ROD: EV_SMLSKLOGEN2_009_VWE3.rod
   VCID: 7CAA9CEB46675F0A8AA-8028 SFD [x]
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 F    HW: 5H0 920 340 F
   Component: KOMBI         501 3365
   Dataset Number: V03935473LD 0001
   Coding: 24240F8E6284064001802207200003080030680800
   ASAM Dataset: EV_DashBoardVDDMQB37W 006052
   ROD: EV_DashBoardVDDMQB37W_006_VN47.rod
   VCID: 251C998F956D3EC2854-8070 SFD [x]
16777028 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00001001] - -
          [AWV_0x18 communication error bap_error_timeout heartbeat]
                    Reset counter: 95
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
13639936 - Databus
          [ECU for body control modul error error value recieved]
                    Reset counter: 95
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:07
16776976 - Databus
          [AWV_02 communication error can_error_timeout]
                    Reset counter: 95
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:07
16711695 - Low Coolant Level
          B1B07 00 [00001001] - -
          [warning_insufficient_coolant]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:07
   Part No SW: 5QS 907 530 F    HW: 5QS 907 530
   Component: GW MQB 23     005 2095
   Serial number: SMERBG160725009 Dataset Number: V03935469ZM 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   GVL: 3D0000000208408C80408040480000400000400000580000000000000000005C
   ASAM Dataset: EV_GatewMQBwBL 001027
   ROD: EV_GatewMQBwBL_VW41.rod
   VCID: 57E0E3479F815C52C78-8002 SFD+SFD2 [ ]
   Generator:
   Component: 5-00-17-01-03
   Subsystem 2 - Part No SW: 2N0 915 181 G    HW: 2N0 915 181 G
   Component: J367-BDMHella  H01 2362
   Serial number: 0033476606
   Subsystem 3 - Part No SW: 3G0 959 442 T    HW: 3G0 959 442 T
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440036153252745
7 Faults Found:
8397826 - Crash Shut-Down
          B189C F0 [00101111] - Active
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:11
2232508 - Short-Range Radar Control Module 2
          U16E7 00 [00101111] - No Communication
          [Close_range_radar_2_no_communication]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:13
2232507 - Short-Range Radar Control Module
          U16E4 00 [00101111] - No Communication
          [Close_range_radar_1_no_communication]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:13
2494551 - Ethernet Module for ACC
          U163C 00 [00101111] - No Communication
          [Cruise_control_front_distance_range_sensor_no_communication_vlan]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:26
2232407 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00101111] - -
          [Cruise_control_front_distance_range_sensor_no_communication]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:13
1048997 - Ethernet Databus Branch 5
          U11BF 00 [00101111] - Electrical Malfunction
          [Ethernet_databus_electric_fault_branch_5_/_port_6]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:11
                    Version number: 01
                    Number of status electrical error: 9
                    Ethernet interface: 2
                    No malfunction
                    Specified voltage: 10.600 V
                    Target current: -249 A
                    Voltage limit boost mode: 0.0
1049253 - Ethernet Databus Branch 5
          U1230 00 [00101111] - No Communication
          [Ethernet_databus_no_communication_branch_5_/_port_6]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:26
   Part No SW: 2N0 909 059 C    HW: 2N0 909 059
   Component: EBKV          H10 0310
   Serial number: BPA085260625018 Dataset Number: V03935440F  0001
   Coding: A904A240000000EF1C000000000000000000000000
   ASAM Dataset: EV_BrakeBoostG2BoschVN54X 003003
   ROD: EV_BrakeBoostG2BoschVN54X.rod
   VCID: 333877D72BB950721B0-8066 SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861 A    HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0071
   Serial number: 25000162599007- Dataset Number: V03935458YU 0001
   Coding: 0020000000000000
   Shop #: WSC 69101 377 00172
   ASAM Dataset: EV_ELVMarqUNECE 004001
   ROD: EV_ELVMarqUNECE_004_VW27.rod
   VCID: 49C4353F59353AA241C-801C SFD+SFD2 [x]
   Part No SW: 3WA 959 393 A    HW: 3WA 959 393
   Component: TSG FS        001 0222
   Serial number: Y2007YFK0030A   Dataset Number: V03935441ZS 0001
   Coding: 00303B208101000900003020
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
   VCID: 52F61253B463797A306-8006 SFD+SFD2 [x]
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 2N0 909 145 G    HW: 2N0 909 145 C
   Component: BASGEN1MQB37  705 7082
   Serial number: 02521930 Dataset Number: V03935464A  0001
   Coding: 00000001000000000001020100000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017079
   ROD: EV_SteerAssisBASGEN1MQB37.rod
5423 - Steering Angle Sensor
          B1168 F2 [10100111] - Not Initialized
          [DTC_RACKPOS_NOINIT]
                    Reset counter: 0
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:08
                    MonitorId: 00 00
                    HybridDriveReady: 00000000
                    IgnitionEnabled: 00000001
                    Communication control: 00000000
                    Diagnostic session: 00000001
                    ComM_ModeType: 00000000
                    NM_Signal_Fahrbereit: 00000000
                    NM Signal V gr 7: 00000000
                    System status: 3
                    ECU Status: 0
                    HWLib Status: 1
                    Support power reduction: 0.0 %
                    Voltage terminal 30: 11.891 V
                    Temperature circuit board: 37  C
                    Output stage temperature: 32  C
                    Rackposition: 0.00 mm
                    Rackspeed: 0.28 mm/s
                    pinion angle dependent amplitude factor: 0
                    Steering wheel angle: 0.5  /s
                    SupplierFreezeFrameData: 00 00 00 00 D8 36 0E 00 5B 0E 17 6B C8 B4 BF FE D0 B4 BF FE
   Part No SW: 3WA 959 392 A    HW: 3WA 959 392
   Component: TSG BFS       001 0222
   Serial number: Y2007YF700Z59   Dataset Number: V03935443YY 0001
   Coding: 001131208101000900003020
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
   VCID: 51F41D5FB165026209C-8004 SFD+SFD2 [x]
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 2K7 035 869 C    HW: 2K7 035 869 C
   Component: MU-E-D-EU     065 0226
   Serial number: VWZAZ2D0903480  Dataset Number: V03935469BL 0001
   Coding: 65493008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIGPMQB37w 001001
   ROD: EV_MUEIGPMQB37w_VN54P.rod
   VCID: 363E4EC338CB455A3CE-8062 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 14A 919 603 B    HW: 14A 919 603
   Component: ABT-E3_10      H50 1046
   Serial number: TPO00106042510310693
7173 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:11
                    BAP: 02
                    Voltage terminal 30: 11.8 V
7195 - Function Restricted due to Interrupted Communications
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:11
                    BAP: 02
Address 65: Tire Pressure (J502)       Labels:* None
   Part No SW: 3WA 907 273 H    HW: 976 907 273 B
   Component: RDKHUFVWMQBW  H54 0012
   Serial number: 0000000PA256030 Dataset Number: V03935464TM 0001
   Coding: 0100
   ASAM Dataset: EV_RDKHUFVWMQBWBasel 002016
   ROD: EV_RDKHUFVWMQBWBasel.rod
   VCID: 4FF01B27A75114921F8-801A SFD+SFD2 [x]
   Part No SW: 571 035 284 D    HW: 571 035 284
   Component: OCUMQBW2023_H H09 0668
   Serial number: 0000000504VIVRF Dataset Number: V03935465GD 0001
   Coding: 06010601000000100000000013002607101112111012000010
   ASAM Dataset: EV_OCUMWB2023 001072
   ROD: EV_OCUMWB2023_VW42.rod
   VCID: 1760A3475F019C52078-8042 SFD+SFD2 [x]
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [00100111] - -
          [ACC (0x05) - Funktionseinschr nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:12
                    Voltage terminal 30: 11.7 V
12866049 - Databus
          [Airbag: Error value received]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
   Part No SW: 3WA 907 217 D    HW: 3WA 907 217
   Component: MFK120_MQB    H18 1543
   Dataset Number: V03935477VL 0001
   Coding: 0106000000000000000000822840000500000000204600000000FE00000038EE43F24074C000000040000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK120MAGNAMQBWB 005004
   ROD: EV_MFK120MAGNAMQBWB_005_VW41.rod
7 Faults Found:
221210 - Internal Fault
          B200F FE [00100111] - -
          [Calibration_internal_fault]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:08
1049428 - Internal Fault
          B200F F2 [00100111] - -
          [SWC_HCA_Init_Values_Received]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:08
3145750 - Databus
          [ESP_Systemstatus_ERROR]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
1048851 - Databus
          U1121 00 [00100111] - Missing Message
          [TIMEOUT_AWV_02]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:10
3145822 - Databus
          [LV_Blk_re_Seite_def_ERROR]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:13
1049218 - Internal Fault
          B200F F3 [00100111] - -
          [LDA_FC1_Status_ERROR]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
1049857 - Internal Fault
          [BHE_FC1_Status_ERROR]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:12:09
Address 8109: Close Rge Radar 1
Address 810A: Close Rge Radar 2
Address 811E: Burglary Protection FL
Address 811F: Burglary Protection FR
Address 8120: Burglary Protection RL
Address 8121: Burglary Protection RR
End----(Elapsed Time: 01:33, VBatt start/end: 12.0V/11.8V. VIgn 11.9V)-----
------------------------------62 Faults Found------------------------------
Post Scan
Wednesday,24,June,2026,22:00:18:50062
   VCID: 0358E7173B9920F2CB0-8056 SFD+SFD2 [ ]
10 Faults Found:
5462 - Output for Starter Relay
          P0615 00 [11100101] - Open Circuit
          [Starter Relay Circuit]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:31
                    Engine speed: 147.00 /min
                    Voltage terminal 30: 10.440 V
                    Starter control: terminal 50 feedback-Bits 0-7: 0
                    Status of starter activation relay-Bits 0-7: 3
                    Starter control: shut-off conditions 1-Bits 0-7: 0
                    Number of manual engine starts: 482
                    Number of automatic engine starts: 26
          U0416 00 [00100100] - -
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:03
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:04
                    Coolant temperature sensor 1: B1: on cylinder head: raw value: 31.4  C
                    EGR temp. sensor 2: B1: raw value: 30.3  C
                    Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value: 30.2  C
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:04
                    Voltage terminal 30: 11.760 V
                    Turbocharger 1 charger output: temp. sensor 1: B1: raw value: 28.7  C
                    Control Module temperature: 35.5  C
                    Shut-off timer: last engine shut-off time: 965 s
                    Charge air cooler output: temp. sensor 1: B1: raw value: 28.0  C
28252 - Coolant Pump 3
          P26FA 00 [00100111] - Air in System
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:18:48
                    Coolant temperature: 46  C
                    Intake air temperature: 28  C
                    Voltage terminal 30: 12.160 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 95.00 %
                    Shut-off timer: last engine shut-off time: 23 s
                    Temperature sensor for cylinder block: 29.0  C
                    Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value: 123.8  C
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:04
          U1229 00 [00100100] - Implausible Message
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:04
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:04
43768 - Release / Enable Active
          B184C 00 [00100111] - -
          [Activation active]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:18:27
                    Vehicle speed: 255 km/h
                    Voltage terminal 30: 12.180 V
          P2B62 00 [01100101] - Supply Voltage Malfunction
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:04
Readiness: 0 0 0 1 1
          U0423 00 [00100100] - -
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:58
0528 - Databus
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:58
0529 - Databus
          U164C 00 [00101111] - No Communications
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:54
523552 - BCM
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
523532 - BCM
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:18:15
                    Fault Frequency: 133
                    Reset counter: 2
                    Mileage: 257 km
                    Date: 2010.00.00
                    Time: 05:43:06
                    Reset counter: 2
                    Mileage: 257 km
                    Date: 2010.00.00
                    Time: 05:43:06
                    Fault Frequency: 132
                    Reset counter: 2
                    Mileage: 258 km
                    Date: 2010.00.00
                    Time: 05:43:06
                    Reset counter: 2
                    Mileage: 258 km
                    Date: 2010.00.00
                    Time: 05:43:06
                    Reset counter: 2
                    Mileage: 258 km
                    Date: 2010.00.00
                    Time: 05:43:06
338440 - Databus
                    Reset counter: 2
                    Mileage: 262 km
                    Date: 2010.00.00
                    Time: 05:43:06
   Coding: 0040010001
7 Faults Found:
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:54
12587032 - Databus
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
12587130 - Databus
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:59
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
1061381 - Databus
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:54
                    Reset counter: 95
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
13639936 - Databus
                    Reset counter: 95
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:52
16776976 - Databus
                    Reset counter: 95
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:52
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:52
   Generator:
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:07
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:07
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:20
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:07
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:05
                    Version number: 02
                    No malfunction
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:16:20
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:56
                    BAP: 02
                    Voltage terminal 30: 13.2 V
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:56
                    BAP: 02
   Coding: 0100
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
                    Voltage terminal 30: 13.1 V
12866049 - Databus
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:55
1048851 - Databus
          [TIMEOUT_AWV_02]
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:56
3145822 - Databus
                    Mileage: 23238 km
                    Date: 2026.04.06
                    Time: 00:17:59
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.1V)-----------
------------------------------52 Faults Found---------------------
RTS
C?ID=492458
SFD Log
WV3ZZZSZ7T900****,Address 0x19,5QS 907 530 F,Online SFD,Wednesday,24,June,2026,21    51    39,HN2-011522,SFD challenge retrieval success, 583 bytes
WV3ZZZSZ7T900****,Address 0x19,5QS 907 530 F,Online SFD,Wednesday,24,June,2026,21    51    41,HN2-011522,SFD unlock token retrieval success, 852 bytes
WV3ZZZSZ7T900****,Address 0x19,5QS 907 530 F,Online SFD,Wednesday,24,June,2026,21    51    41,HN2-011522,SFD unlock token transmitted to controller
WV3ZZZSZ7T900****,Address 0x19,5QS 907 530 F,Online SFD,Wednesday,24,June,2026,21    51    43,HN2-011522,Unlock_successful
WV3ZZZSZ7T900****,Address 0x01,05L 906 023 RL,Online SFD,Wednesday,24,June,2026,21    54    00,HN2-011522,SFD challenge retrieval success, 583 bytes
WV3ZZZSZ7T900****,Address 0x01,05L 906 023 RL,Online SFD,Wednesday,24,June,2026,21    54    03,HN2-011522,SFD unlock token retrieval success, 532 bytes
WV3ZZZSZ7T900****,Address 0x01,05L 906 023 RL,Online SFD,Wednesday,24,June,2026,21    54    03,HN2-011522,SFD unlock token transmitted to controller
WV3ZZZSZ7T900****,Address 0x01,05L 906 023 RL,Online SFD,Wednesday,24,June,2026,21    54    04,HN2-011522,Unlock_successful
RTS
C?ID=492458
forgot to screenshot all sfd unlock
RTS
C?ID=492458
ADP LOG
Address 19    5QS 907 530 F    channel [SFD ] IDE16611-Diagnosis filter     temporary deactivation    adapted from    not active     to    not active     Wednesday    24    June    2026    21    51    50    50062    WV3ZZZSZ7T900****
GES Log
Address 0x01    05L 906 023 RL    UDS Basic Settings    [SFD ] IDE17266-Unlocking the fuel system after a crash    Wednesday    24    June    2026    21    54    31    50062    WV3ZZZSZ7T900****
Address 0x19    5QS 907 530 F    UDS Basic Settings    IDE06504-ENG254041-Reset of reversible crash shut-off    Wednesday    24    June    2026    21    55    43    50062    WV3ZZZSZ7T900****
