Disable DSR in Q5 with 1B-Active Steering
Mrclopec
Nipomo, CA
C?ID=149231
I noticed on just about every Q5 from the factory with the standard electromechanical power steering, 44-Steering Assist Byte 0 is listed as 10 (DSR enabled), however mine came from the factory as 01 (DSR Disabled and Steering aid control module J500 coded/locked). Does this mean that J792 is acting as a master to J500? Does that mean that DSR would have to be disabled through coding J792 instead?
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CPNB)       Labels: 059-907-401-V2.clb
   Part No SW: 8K5 907 401 S    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0001
   Revision: 58H14---
   Coding: 2A2A4012057603050000
   Shop #: WSC 55440 001 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401S 001003
   ROD: EV_ECM30TDI0118K5907401S.rod
   VCID: 408F6B65DB83AB3E1D-8015
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1003
   Revision: --H19---
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 4B954C49E2C57866F8-801F
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 23AD1C03
   VCID: 11299E21C86912B6C2-8045
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0DA54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 081FB345BB33537E15-805D
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01190920141164
   Coding: 3621228080
   VCID: 77FDC0B9C6CD2C866C-8023
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000893404802
   Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000
   VCID: 7AFBD98DF5DF31EE13-802F
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140827  H12 0050
   Coding: 01DD13
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 008157
   VCID: 377D00B9864DEC86AC-8063
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12HYXB
   Coding: 303334313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4C974F55E7CB7F5EF1-8019
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000GX4R
   Serial number: 6334MSME480E2C00D
   Serial number: 6344MSME4879646DV
   Serial number: 6352QSME5C460456J
   Serial number: 6362QSME4747316EO
   Serial number: 63732SME40443466U
   Serial number: 63832SME64424D44+
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NIG000A4
   Coding: 0000FF
   VCID: 44876775C79BB71E39-8011
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 B    HW: 8R0 920 982 B
   Component: KOMBIINSTR.   H35 0564
   Revision: 00400000    Serial number: ZDC27399F
   Coding: 8BBF22006F01D705020000
   VCID: 3A7B198DB55FF1EE53-806F
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z149050B6E
   Coding: 80CF07FF00
   VCID: 4C974F55EFCB7F5EF1-8019
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 020100
   VCID: 39790681B059FAF65A-806D
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019164747464545425363E00
   Shop #: WSC 06325 000 00000
   VCID: 7CF7DF95FFEB0FDE01-8029
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000114744385
   Coding: 01581B00000000000000
   VCID: 428B616DDD8FB92E0B-8017
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0346139735
   Coding: 010221
   VCID: 3F8D6899A67DD4C664-806B
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000116313843
   Coding: 011D13215E00440004
   VCID: 4FAD58591EDD444694-801B
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0030925634
   Coding: 010001010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X.rod
   Revision: 00002001    Serial number: 0347056755
   Coding: 0126063A20FA709584A0053600040047
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813034061406
   VCID: 2D5122D174115656C6-8079
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000117929946
   VCID: 4E93455D19D74D4E9F-801B
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000264223
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B198DBD5FF1EE53-806F
   Revision: AB001007    Serial number: 156I20E8065591
   Coding: 020007010000000001
   VCID: 2447C7F527DB971E19-8071
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600213910000FA
   Coding: 0132104
   VCID: 377D00B9464DEC86AC-8063
   Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0812
   Revision: --------    Serial number: 204I10E7679622
   Coding: 160200060005E9EF7D02AF5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000117821679
   Coding: 010C13204000240004
   VCID: 46837D7DF1A7850E27-8013
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00008200724693
   Coding: 0200000000000000
   VCID: 36630DBD8147158EB7-8063
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J47A2YG
   Coding: 1031010
   VCID: 346737B5573B079E89-8061
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D711291A471C6D676-8069
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 142460205
   ROD: EV_RDCMA00100.rod
   VCID: 2D5122D17C115656C6-8079
