Passat B9 2024 Auto-Scan
Paskal
Czech Republic
C?ID=508876
Auto-Scan
Friday,19,June,2026,13:34:34:15875
VCDS Version: 26.5.2.1 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260506 DS377.0
Chassis Type: CJ-VW49 (5QS)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 23 2B 42 44 4B 52
          5F 69 6C 6D 75 82 A5 BB BC CA D6 D7 DE 8107 8109 810A 810B 810C 8117 811E
          811F 8120 8121 C002 C003
VIN: WVWZZZCJxxxxxxxxx   Mileage: 22586km-14034miles
CA-Sunroof -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8109-Close Rge Radar 1 -- Status: OK 0000
810A-Close Rge Radar 2 -- Status: OK 0000
810B-Close Rge Radar 3 -- Status: OK 0000
810C-Close Rge Radar 4 -- Status: OK 0000
8117-Rear surroundings cam -- Status: OK 0000
Address 01: Engine (J623-DXPA)       Labels: None
   Part No SW: 05L 906 022 DL    HW: 05L 907 309 AG
   Component: R4 2.0l TDI   H80 4618
   Revision: NEH80---    Dataset Number: V03935407XE 0001 CVN: EC2033D610A70AD22DB0E9639EAA3CA82DB0E96345690194
   Coding: 0125003A03741D0870080000001000000000000000000000
   Shop #: WSC 19062 004 1048576
   ASAM Dataset: EV_ECM20TDI01105L906022DL 010012
   ROD: EV_ECM20TDI01105L906022DL.rod
   VCID: 74B0DECB4E38CF9AC2A-8020 SFD+SFD2 [x]
   VINID: 9E69EAAAA4DAA22500089148086D605579
   Radiator shutter:
   Subsystem 1 - Part No SW: 5QS 965 501 E    HW: 5QS 965 501 E
   Component: V544_SAB_XS_1  H03 0003
   Serial number: 20240504060506052152
   Radiator louver 2:
   Heater for exhaust gas catalytic converter:
   Flush-air pump:
   Active oil separating system:
   Part No SW: 0GC 906 555 GA    HW: 0GC 300 058 K
   Component: GSG DQ381     H06 0661
   CVN: C03E69A6
   ASAM Dataset: EV_TCMDQ381064 001011
   ROD: EV_TCMDQ381064.rod
   VCID: 0058821B0A80E33AD62-8054 SFD [x]
   Parking lock:
   Subsystem 1 - Part No SW: 5QS 907 483 A    HW: 5QS 907 483
   Component: SB_Auto        H02 0060
   Serial number: 9244762000668005
   MTF pump:
   Subsystem 2 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700006589953
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 3WA 614 517 AM    HW: 3WA 614 517 D
   Component: EBC470IESCH09 0390
   Serial number: 0000000         Dataset Number: V03935469WZ 0001 CVN: CE1340
   Coding: 2C285124A48B399C410799AC9EB701040583952149A8
   ASAM Dataset: EV_Brake1ZFESCEPBMQB48W 002068
   ROD: EV_Brake1ZFESCEPBMQB48W_002.rod
   VCID: 117EB75F51EA9AB249C-8044 SFD+SFD2 [x]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 AD    HW: 5WA 959 436 N
   Component: Kessy IOBOX   122 0771
   Serial number: --------------- Dataset Number: V03935407SN 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 1674C44378047D8A1CE-8042
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 3WA 907 007 F    HW: 3WA 907 007
   Component: Climatronic   H01 5089
   Serial number: 218052419584550 Dataset Number: V03935469TY 0001
   Coding: 212010244111120010201010111011110000132110200000000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002062
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
   VCID: 48C85A3B62301B7A5E2-801C SFD+SFD2 [x]
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002110524003547505
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000010000373347
   Subsystem 3 - Part No SW: 11A 907 049 B    HW: 11A 907 049 B
   Component: E265 KPH SH    H02 0184
   Serial number: G07S10.04.2400970512
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 084 AG    HW: 5WA 937 084 R
   Component: BCM37w_H      H26 0326
   Serial number: 051024139040210 Dataset Number: V03935462SS 0001
   ASAM Dataset: EV_BCMwBL 004001
   ROD: EV_BCMwBL_004.rod
   VCID: 1470BE4B6EF86F9A62A-8040 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 3J1 955 119     HW: 3J1 955 119
   Component: WISCHER_MYJTL  006 0093
   Serial number: VZ1SKA25052441008924
   Subsystem 2 - Part No SW: 89A 955 555 B    HW: 89A 955 555 B
   Component: G397_RLFSS     004 0007
   Serial number: MRO71305062400013271
   Subsystem 3 - Part No SW: 571 941 633 A    HW: 571 941 633 A
   Component: E1 - LiAM      H05 0070
   Serial number:  07S03.05.2426791333
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000004531212
   Subsystem 5 - Part No SW: 5Q0 951 172 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA    006 0501
   Serial number: 0000000000000Q3DEP39
   Subsystem 6 - Part No SW: 3J0 959 561 B    HW: 3J0 959 561 B
   Component: -VW----LINDA-  550 0851
   Serial number: SYLLND02052400021477
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 14A 881 643 B    HW: 14A 881 643 B
   Component: J873 MKS_FSv   H02 0152
   Serial number: 7009362240C242003554
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 14A 881 643 B    HW: 14A 881 643 B
   Component: J872 MKS_BFSv  H02 0152
   Serial number: 7009362240C241801454
   Power rear lid opening control module:
   Subsystem 9 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 45146716
   Left taillight 1:
   Subsystem 10 - Part No SW: 3J0 945 207     HW: 3J0 945 207
   Component: SHL_li1        H03 0107
   Serial number: 21005305b004bf40A000
   Left taillight 2:
   Subsystem 11 - Part No SW: 3J0 945 307     HW: 3J0 945 307
   Component: SHL_li2        H03 0107
   Serial number: 21005306E004E5C0B000
   Right taillight 1:
   Subsystem 12 - Part No SW: 3J0 945 208     HW: 3J0 945 208
   Component: SHL_re1        H03 0107
   Serial number: 21005305E004ABB0B000
   Right taillight 2:
   Subsystem 13 - Part No SW: 3J0 945 307     HW: 3J0 945 307
   Component: SHL_re2        H03 0107
   Serial number: 21005306e004b7b0A000
   Part No SW: 5QS 919 300 B    HW: 5QS 919 300
   Component: IPA 12ch high H01 0179
   Serial number: 000025052495580 Dataset Number: V03935448GJ 0001
   Coding: 8A30126111
   ASAM Dataset: EV_EPHBO3CVW3360000 001014
   ROD: EV_EPHBO3CVW3360000_VW49.rod
   VCID: 51FE775F916ADAB209C-8004
   Part No SW: 1N3 907 567 D    HW: 1N3 907 819
   Component: ACC Bosch MQB H02 0436
   Dataset Number: V03935485SC 0001
   Coding: 0E8930EF4071404040020008000040C0010020008004000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW412 002016
   ROD: EV_FRONTRADARBOSCHVW412_002_VW41.rod
   VCID: 38282AFB12D06BFA2E2-806C SFD+SFD2 [x]
Address 14: Susp. Elect. (J250)       Labels: 5QS-907-376.clb
   Part No SW: 5QS 907 376 G    HW: 5QS 907 376 F
   Component: DAEMPFUNGS-SG H08 0607
   Serial number: AAA214500081705 Dataset Number: V03935471DP 0001
   ASAM Dataset: EV_DCC4CONTITEMIC 005012
   ROD: EV_DCC4CONTITEMIC.rod
   VCID: 6098A29BEAC0433AB62-8034
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 S    HW: 5QS 959 655
   Component: AirbagVW50    004 0131
   Serial number: 000000003C0MYRB Dataset Number: V03935459GJ 0001
   Coding: 98CC008000F0C000000000000000000051540000A1540000C000F680002B40A7
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001014
   ROD: EV_AirbaVW50SMEVW49X.rod
   VCID: 73B2DDD74B36C8A2DB0-8026 SFD+SFD2 [x]
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 85E 980 945 D    HW: 85E 980 945 D
   Component: BeltPretRevFL  002 3040
   Serial number: 3J0857705C0137Y00272
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 85E 980 946 D    HW: 85E 980 946 D
   Component: BeltPretRevFR  002 3040
   Serial number: 3J0857706C0148Y00132
   Subsystem 3 - Part No SW: -----------    HW: 480 000 40B 17
   Serial number: 35700003C4894B874A60
   Subsystem 4 - Part No SW: -----------    HW: 480 000 504 18
   Serial number: 35800007D48D46A67E40
   Subsystem 5 - Part No SW: -----------    HW: 480 051 105 18
   Component: SideSensor_Dr  000 0149
   Serial number: 3510000B2D12C148A430
   Subsystem 6 - Part No SW: -----------    HW: 480 051 105 18
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000C6D12C14B2A20
   Subsystem 7 - Part No SW: -----------    HW: 480 051 E04 18
   Component: FrontSensor_D  000 014A
   Serial number: 3550000A8D0C630B89F0
   Subsystem 8 - Part No SW: -----------    HW: 480 051 E04 18
   Component: FrontSensor_P  000 014A
   Serial number: 3560000A8D0C630B6850
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 9 - Part No SW: -----------    HW: 480 051 105 18
   Component: Side_Sens_B_D  000 0149
   Serial number: I0P0000BAD12C14B0980
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 10 - Part No SW: -----------    HW: 480 051 105 18
   Component: Side_Sens_B_P  000 0149
   Serial number: I0Q0000AED12C14D4A40
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 M    HW: 1EE 953 507 M
   Component: GSMMEB        005 0066
   Serial number: 000000030624477
   ASAM Dataset: EV_SMLSKLOGEN2 009005
   ROD: EV_SMLSKLOGEN2_009_VW49.rod
   VCID: 45D6530F55220612A54-8010 SFD [x]
   Part No SW: 571 920 340 A    HW: 571 920 340
   Component: KOMBI         304 9460
   Dataset Number: V03935440WZ 0001
   Coding: 042402457B9C00080880720B2000080810387C0000
   ASAM Dataset: EV_DashBoardVDDMQB37W 005050
   ROD: EV_DashBoardVDDMQB37W_005_VW42.rod
   VCID: 1078B25B5AE093BA462-8044 SFD [x]
Address 18: Aux. Heat (J364)       Labels:| 5WA-963-27x-V1.clb
   Part No SW: 3J0 963 272 A    HW: 3J0 963 272 A
   Component: STH-VW37x     006 0002
   Serial number: 000000000000416 Dataset Number: V03935403YG 0001
   Coding: 2D1B155A5C25162CE46D19
   ASAM Dataset: EV_AuxilHeateWOSVW38X 003004
   ROD: EV_AuxilHeateWOSVW38X.rod
   VCID: 2B0205B7D386D062530-807E
   Part No SW: 5QS 907 530 B    HW: 5QS 907 530
   Component: GW MQB 23     005 3093
   Serial number: SMERBG230524007 Dataset Number: V03935467YA 0001
   Coding: 000000000000000000000000000000000000000000000300030000000000000000000000000000000000000000000000
   GVL: 3D08080002E8C08C80408046CC00104004006002007C00020200000000000054
   ASAM Dataset: EV_GatewMQBwBL 001018
   ROD: EV_GatewMQBwBL_VW41.rod
   VCID: 53F27D57AB76A8A23B0-8006 SFD+SFD2 [x]
   Generator:
   Component: 5-01-18-01-03
   Subsystem 2 - Part No SW: 5QS 915 181     HW: 5QS 915 181
   Component: J367-BDMHella  H01 2362
   Serial number: 8056154406
   Inverter for socket:
   Subsystem 3 - Part No SW: 5H0 907 155     HW: 5H0 907 155
   Component: Inverter       H06 0060
   Serial number: 5ZJSHFT1701240001071
   Subsystem 4 - Part No SW: 571 959 442 C    HW: 571 959 442 C
   Component: E221__MFL-PR6  H07 0130
   Serial number: PR6-0440079142242361
   Subsystem 5 - Part No SW: 5H0 959 542 N    HW: 5H0 959 542 N
   Component: KLR_JSS_1Zone  089 0023
   Serial number: 3136188AA25212158301
   Part No SW: 3WA 909 059 R    HW: 3WA 909 059 B
   Component: EBB-ZF-Gen1   H06 0486
   Serial number: 5100164         Dataset Number: V03935476RN 0001
   Coding: 201010200040E8
   ASAM Dataset: EV_BrakeBoostZFMQB48W 001072
   ROD: EV_BrakeBoostZFMQB48W_001.rod
   VCID: 5DE69B6FDDB26ED29D4-8008 SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000099768010 Dataset Number: V03935398ZW 0001
   Coding: 8820000000000000
   Shop #: WSC 31414 790 00369
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 08489A3B22B0DB7A9E2-805C SFD+SFD2 [x]
   Part No SW: 3WA 959 593 A    HW: 3WA 959 593
   Component: TSG FS        001 0222
   Serial number: YG007XDO01629   Dataset Number: V03935449QB 0001
   Coding: 003D9A20DC00008102003030
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
   VCID: 54F07E4BAE78AF9A22A-8000 SFD+SFD2 [x]
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 3WA 907 145 E    HW: 3WA 907 145
   Component: BASGEN1MQB37  504 1122
   Serial number: 03752048 Dataset Number: V03935437JB 0001
   Coding: 00000000000000010001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 4ACC60337C3CE96A486-801E SFD+SFD2 [x]
   Part No SW: 5QS 907 338 C    HW: 5QS 907 338 B
   Component: FCM Baseline  019 3093
   Serial number: 780542040024136 Dataset Number: V03935450AZ 0001
   Coding: 00000000090001D206002F11020003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiWBL 001008
   ROD: EV_MultiModulContiWBL.rod
   VCID: 5AEC9073CC9C99EAF86-800E SFD [x]
   Part No SW: 3WA 959 592 A    HW: 3WA 959 592
   Component: TSG BFS       001 0222
   Serial number: YG007XDL08897   Dataset Number: V03935449QC 0001
   Coding: 003D1820DC00008102003030
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 571 035 816 C    HW: 571 035 816
   Component: MU-O-ND-EU    H10 2650
   Serial number: WG8LGM060424000 Dataset Number: V03935462QT 0001
   Coding: 24920006000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 002001
   ROD: EV_MUOIMQB37w_002_VW49.rod
   VCID: 176AC9477F0E4482078-8042 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 14A 919 606     HW: 14A 919 606
   Component: ABT-E3_15      H52 7046
   Serial number: TPO00125112315010329
   Subsystem 2 - Part No: V03 959 820 GG
   Component: EUR 2024       0095
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H2 907 383 D    HW: 5H2 907 383
   Component: Anhaenger     H12 0204
   Serial number: 000000000006455 Dataset Number: V03935378DR 0001
   Coding: 0100000202001200
   ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
   ROD: EV_TrailFunctG3MPFMHella_VW49.rod
   VCID: 313E17DFF1AABAB269C-8064 SFD+SFD2 [x]
   Part No SW: 5QS 907 556 A    HW: 5WA 907 556 D
   Component: TV eEntry     H32 0675
   Serial number: FZ6ESP170424000 Dataset Number: V03935441BR 0001
   Coding: 020380003F142080
   ASAM Dataset: EV_CamSysTVFicosBL 001004
   ROD: EV_CamSysTVFicosBL_VW41.rod
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R243 UmfKamSV  H23 0070
   Serial number: FCLMAR11052401062216
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R244 UmfKamSL  H23 0070
   Serial number: FCLMAR20052401023345
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R245 UmfKamSR  H23 0070
   Serial number: FCLMAR260324010706A5
   Part No SW: 3J0 959 107 A    HW: 3J0 959 107
   Component: HDSG-Modul    H02 0444
   Revision: --------    Serial number: A2-C786-5400-3 Dataset Number: V03935441SD 0001
   Coding: 56C8
   ASAM Dataset: EV_DeckLidCONTIAU536 001009
   ROD: EV_DeckLidCONTIAU536_001_VW42.rod
   VCID: 2D060BAFED92DE524D4-8078
   Part No SW: 571 035 284 B    HW: 571 035 284
   Component: OCUMQBW2023_H H07 0626
   Serial number: 0000000404VIFWA Dataset Number: V03935423VF 0001
   Coding: 02010601000000211000010113002607101112111012111110
   ASAM Dataset: EV_OCUMWB2023 001066
   ROD: EV_OCUMWB2023_VW42.rod
   VCID: 1576C34F65027692154-8040 SFD+SFD2 [x]
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 3J1 919 608 A    HW: 3J1 919 608
   Component: HeadupDisplay H09 2417
   Dataset Number: V03935431WK 0001
   Coding: 5700E000
   ASAM Dataset: EV_HUDMQBwBL 002013
   ROD: EV_HUDMQBwBL_002.rod
   VCID: 303812DBFAA0B3BA662-8064 SFD+SFD2 [x]
16777040 - Function Restricted due to Interrupted Communications
          U1110 00 [00101110] - -
          [Navigation_0x32_timing_error_bap_timeout_heartbeat]
                    Mileage: 22586 km
                    Date: 2026.06.19
                    Time: 13:25:51
   Part No SW: 3WA 907 217 C    HW: 3WA 907 217
   Component: MFK120        H18 1423
   Dataset Number: V03935484GV 0001
   Coding: 0005000000000000000000BAF940C00400000000806580000000FC00000038FE43F040004000000000800000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK120MAGNAMQBWB 001024
   ROD: EV_MFK120MAGNAMQBWB_001.rod
3146032 - Databus
          U1123 00 [00100111] - Received Error Message
          [NR_RL_Blindness_ERROR]
                    Mileage: 22586 km
                    Date: 2026.06.19
                    Time: 13:25:46
3146033 - Databus
          [NR_RS_Blindness_ERROR]
                    Mileage: 22586 km
                    Date: 2026.06.19
                    Time: 13:25:46
Address BB: Door Rear Drv (J388)       Labels:* Redir Fail!
   Part No SW: 3WA 959 595 A    HW: 3WA 959 595
   Component: TSG HFS       001 0222
   Serial number: YG007XDU1141D   Dataset Number: V03935449QE 0001
   Coding: 000C90200100008100003020
   ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001016
   ROD: EV_DCU4RearDriveMAXHBRO_VW42.rod
   VCID: 56F48443B884BD8ADCE-8002 SFD+SFD2 [x]
Address BC: Door Rear Pass (J389)       Labels:* Redir Fail!
   Part No SW: 3WA 959 594 A    HW: 3WA 959 594
   Component: TSG HBFS      001 0222
   Serial number: YG007XE402687   Dataset Number: V03935449QD 0001
   ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001016
   ROD: EV_DCU4RearPasseMAXHBRO_VW42.rod
   VCID: 55F6834FA582B692D54-8000 SFD+SFD2 [x]
   Part No SW: 8Y1 907 594 AC    HW: 4K1 907 594
   Component: SAD_STG_1     010 0010
   Dataset Number: V03935432NF 0001
   Coding: 608040749202
   Part No SW: 992 941 572 AH    HW: 992 941 572 A
   Component: LED1L         H25 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 698EBFBF19FA027261C-803C
   Component: LED1R         H25 9204
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address DE: Charger 1 for mobile dev (J0000)       Labels:* None
   Part No SW: 3P0 035 502 B    HW: 3P0 035 502
   Component: COUPLING BOX  004 0170
   Serial number: 324000000000024 Dataset Number: V03935425HL 0001
   Coding: 800000
   ASAM Dataset: EV_DualCouplBoxSK336 001006
   ROD: EV_DualCouplBoxSK336_VW42.rod
   VCID: 2410EE8BBE581F1A92A-8070 SFD+SFD2 [x]
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5QS 035 741 A    HW: 5QS 035 741
   Component: TrxModulHigh  H04 0610
   Dataset Number: V03935433LH 0001
   Coding: 02492000010101010000010000010100000001
   ASAM Dataset: EV_TrxMLGEMQBWBL 001026
   ROD: EV_TrxMLGEMQBWBL_VW49.rod
   VCID: 4EC46C238054C54A14E-801A SFD+SFD2 [x]
Address 8109: Close Rge Radar 1 (J1088)       Labels:* None
   Part No SW: 3WA 907 541 J    HW: 95C 907 541
   Component: Nanoradar 1   H08 0138
   Serial number: 14520046557347  Dataset Number: V03935467NK 0001
   Coding: 59955A1529C405000000
   ASAM Dataset: EV_NR1HELLAVW38X 001112
   ROD: EV_NR1HELLAVW38X_001_VW38.rod
   VCID: 4FFA7127875ECC421F8-801A SFD+SFD2 [x]
Address 810A: Close Rge Radar 2 (J1089)       Labels:* None
   Component: Nanoradar 2   H08 0138
   Serial number: 14520046560628  Dataset Number: V03935467NM 0001
   ASAM Dataset: EV_NR2HELLAVW38X 001112
   ROD: EV_NR2HELLAVW38X_001_VW38.rod
Address 810B: Close Rge Radar 3 (J770)       Labels:* None
   Component: Nanoradar 3   H08 0138
   Serial number: 14520046346156  Dataset Number: V03935467NN 0001
   Coding: 59565A1529C405000000
   ASAM Dataset: EV_NR3HELLAVW38X 001112
   ROD: EV_NR3HELLAVW38X_001_VW38.rod
Address 810C: Close Rge Radar 4 (J769)       Labels:* None
   Component: Nanoradar 4   H08 0138
   Serial number: 14520046346181  Dataset Number: V03935467NQ 0001
   Coding: 99696A1631C40F000000
   ASAM Dataset: EV_NR4HELLAVW38X 001112
   ROD: EV_NR4HELLAVW38X_001_VW38.rod
Address 8117: Rear surroundings cam (J772)       Labels:* None
   Part No SW: 5R3 980 568 F    HW: 1EA 980 568 B
   Component: RV eSmart     H20 0445
   Serial number: FCLK20250424000 Dataset Number: V03935440SB 0001
   Coding: 0203800027152080
   ASAM Dataset: EV_AVCamerRearFicosBL 004029
   ROD: EV_AVCamerRearFicosBL_004_VW49.rod
   VCID: 44D04E0B5E183F1AB2A-8010 SFD+SFD2 [x]
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 G    HW: 5WA 962 133 E
   Component: Kessy RSAD    122 0770
   ASAM Dataset: EV_RSADVL37w 004018
   ROD: EV_RSADHR37w_004_VW38.rod
   VCID: 4CC0662B7648F75A7AA-8018
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 004018
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 004018
   ROD: EV_RSADHL37w_004_VW38.rod
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 004018
End-----(Elapsed Time: 02:22, VBatt start/end: 13.7V/13.7V, Deb=1024)------
------------------------------3 Faults Found-------------------------------
adpmap 19
    SW:5QS-907-530-B   HW:5QS-907-530 ---  19: CAN Gateway
    Component:GW MQB 23     005 3093, Coding:000000000000000000000000000000000000000000000300030000000000000000000000000000000000000000000000
    EV_GatewMQBwBL,001018,EV_GatewMQBwBL_VW41.rod
    Friday,19,June,2026,13:18:43:15875
    VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
    VCID: 53F27D57AB76A8A23B0-8006 SFD+SFD2 [ ]
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
[SFD ] IDE00002-Transport mode,not active ,1
[SFD2] IDE00003-Coding,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,48
[EXTD] IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,Write only channel ,0
[EXTD] IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,Write only channel ,18
[EXTD] IDE00820-ENG447862-Activating and deactivating all development messages-ELF_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,Write only channel ,26
[EXTD] IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG447864-Activating and deactivating all development messages-HVLM_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG447863-Activating and deactivating all development messages-HVL-SF_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,Write only channel ,10
[EXTD] IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,Write only channel ,16
[SFD ] IDE01211-Static current measuring mode,Write only channel ,2
[SFD2] IDE01996-ENG151565-Installation list: specified installations-ECU coded Bit 0,Write only channel ,0
[SFD2] IDE01996-ENG176508-Installation list: specified installations-ECU coded Bit 1,Write only channel ,0
[SFD2] IDE01996-ENG176493-Installation list: specified installations-ECU coded Bit 2,Write only channel ,0
[SFD2] IDE01996-ENG176430-Installation list: specified installations-ECU coded Bit 3,Write only channel ,0
[SFD2] IDE01996-ENG176439-Installation list: specified installations-ECU coded Bit 4,Write only channel ,0
[SFD2] IDE01996-ENG176505-Installation list: specified installations-ECU coded Bit 5,Write only channel ,0
[SFD2] IDE01996-ENG176473-Installation list: specified installations-ECU coded Bit 6,Write only channel ,0
[SFD2] IDE01996-ENG176498-Installation list: specified installations-ECU coded Bit 7,Write only channel ,2
IDE02185-IKA key,Write only channel ,35
IDE02332-Deactivate production mode,Write only channel ,4
[SFD ] IDE03256-MAS06105-Battery adaptation-Rated battery capacity,Write only channel Ah,2
[SFD ] IDE03256-MAS06106-Battery adaptation-Battery technology,Write only channel ,10
[SFD ] IDE03256-MAS06107-Battery adaptation-Battery manufacturer,Write only channel ,20
[SFD ] IDE03256-MAS06108-Battery adaptation-Battery Serial Number,Write only channel ,51
IDE03903-Production process data 1,Write only channel ,3
IDE04330-Transfer of release code for a SWaP function,Write only channel ,0
IDE04331-Selection of release codes for a SWaP function,Write only channel ,5
[SFD ] IDE06425-Dynamometer mode: functional-,Write only channel ,0
[SFD ] IDE06425-ENG98891-Dynamometer mode: functional-Reserved,Write only channel ,2
[SFD ] IDE06530-Distance left for deactivation of static current measuring mode,Write only channel km,2
[SFD ] IDE06541-Distance left for deactivation of transport mode,Write only channel km,2
IDE06833-Component protection SHE key,Write only channel ,0
IDE07139-Normal bus behavior during diagnosis,Write only channel ,2
[PROD] IDE07160-Control module switch-off: switch-off time,Write only channel min,2
IDE07838-Counter for inconsistent states,Write only channel ,3
IDE08220-Vehicle production mode,Write only channel ,0
[SFD2] IDE08623-MAS02672-OBD configuration-Start-stop,Write only channel ,8
[SFD2] IDE08623-MAS08039-OBD configuration-HV charging,Write only channel ,8
[SFD2] IDE08623-MAS14468-OBD configuration-OBD type,Write only channel ,10
[SFD2] IDE08623-MAS26199-OBD configuration-MHEV,Write only channel ,8
[SFD2] IDE08623-MAS26725-OBD configuration-Internal combustion engine information,Write only channel ,8
[SFD2] IDE08623-MAS26826-OBD configuration-HEV,Write only channel ,8
[SFD2] IDE08623-MAS27147-OBD configuration-OBD on event data recorder (EDR),Write only channel ,0
[SFD2] IDE08623-MAS28789-OBD configuration-Starter battery: type,Write only channel ,0
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,Write only channel l/100km,259
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,Write only channel km/h,51
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,Write only channel W,67
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,Write only channel W,83
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,Write only channel W,99
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,Write only channel A,115
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,Write only channel kWh/100 km,131
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,Write only channel kWh/100 km,147
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,Write only channel kWh/100 km,163
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,Write only channel kWh/100 km,179
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,Write only channel kWh/100 km,195
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,Write only channel kWh/100 km,211
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),Write only channel kWh/100 km,3
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,Write only channel l/100km,19
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,Write only channel kWh/100 km,35
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,Write only channel kWh/100 km,227
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,Write only channel kg/100 km,243
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,Write only channel l/100km,275
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,Write only channel l/100km,291
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,Write only channel l/100km,307
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,Write only channel l/100km,323
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,Write only channel l/100km,339
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,Write only channel l/100km,355
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,Write only channel l/100km,371
[EXTD] IDE10351-MAS10460-Message mirroring-Target bus,Write only channel ,2
[EXTD] IDE10351-MAS21167-Message mirroring-Source bus,Write only channel ,10
[SFD ] IDE11689-48V-System: locking,Write only channel ,2
IDE12153-MAS11025-Start component protection authentication-Status,Write only channel ,18
IDE12153-MAS13795-Start component protection authentication-Node address,Write only channel ,3
[SFD2] IDE13748-IDE17293-Coding low voltage energy management-Autonomous inverter for socket,Write only channel ,16
[SFD2] IDE13748-IDE17294-Coding low voltage energy management-Battery architecture,Write only channel ,0
[SFD2] IDE13748-MAS23870-Coding low voltage energy management-Battery installation point,Write only channel ,2
[SFD2] IDE13748-MAS23871-Coding low voltage energy management-Additional memory control,Write only channel ,8
[SFD2] IDE13748-SFT271977-Coding low voltage energy management-Inverter for socket,Write only channel ,16
IDE13756-Diagnosis filter: activation,Write only channel ,2
IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,Write only channel km,2
IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,Write only channel km,10
IDE13844-Distance left for deactivation of production mode,Write only channel km,2
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,Write only channel kWh/100 km,3
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,Write only channel kWh/100 km,19
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,Write only channel kWh/100 km,35
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,Write only channel kWh/100 km,51
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,Write only channel kWh/100 km,67
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,Write only channel kWh/100 km,83
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,Write only channel kWh/100 km,99
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,Write only channel kWh/100 km,115
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,Write only channel kWh/100 km,131
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,Write only channel kWh/100 km,147
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,Write only channel kWh/100 km,163
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,Write only channel kWh/100 km,179
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,Write only channel kWh/100 km,195
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,Write only channel kWh/100 km,211
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,Write only channel kWh/100 km,227
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,Write only channel kWh/100 km,243
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,Write only channel kWh/100 km,259
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,Write only channel kWh/100 km,275
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,Write only channel kWh/100 km,291
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,Write only channel kWh/100 km,307
[SFD2] IDE14423-IDE01058-High-voltage charging management coding-Country coding,Write only channel ,8
[SFD2] IDE14423-MAS01065-High-voltage charging management coding-Brand,Write only channel ,10
[SFD2] IDE14423-MAS08226-High-voltage charging management coding-Max charging current,Write only channel ,8
[SFD2] IDE14423-ENG172426-High-voltage charging management coding-AC_charging_socket_A,Write only channel ,0
[SFD2] IDE14423-ENG172427-High-voltage charging management coding-AC_charging_socket_B,Write only channel ,0
[SFD2] IDE14423-ENG174048-High-voltage charging management coding-Automatic_wireless_charging,Write only channel ,0
[SFD2] IDE14423-ENG259912-High-voltage charging management coding-charge_flap_lock_detection,Write only channel ,16
[SFD2] IDE14423-ENG260779-High-voltage charging management coding-Charge_flap_locking,Write only channel ,8
[SFD2] IDE14423-ENG172423-High-voltage charging management coding-DC_charging_Chademo,Write only channel ,0
[SFD2] IDE14423-ENG258832-High-voltage charging management coding-DC_charging_china,Write only channel ,0
[SFD2] IDE14423-ENG174370-High-voltage charging management coding-kind_of_plug_interlock_detection,Write only channel ,16
[SFD2] IDE14423-ENG172503-High-voltage charging management coding-PLC_charging_socket_A,Write only channel ,0
[SFD2] IDE14423-ENG172504-High-voltage charging management coding-PLC_charging_socket_B,Write only channel ,0
[SFD2] IDE14423-ENG251485-High-voltage charging management coding-plug_and_charge,Write only channel ,16
[SFD2] IDE14423-ENG251486-High-voltage charging management coding-plug_interlock,Write only channel ,16
[SFD2] IDE14423-ENG174643-High-voltage charging management coding-stimulation_wire,Write only channel ,16
[SFD ] IDE14750-Deactivate all development messages,Write only channel ,6
[SFD2] IDE15100-IDE02321-Parking coordinator coding-Activation of park assist,Write only channel ,16
[SFD2] IDE15100-IDE17041-Parking coordinator coding-Reversing mode bumper protection,Write only channel ,40
[SFD2] IDE15100-IDE17042-Parking coordinator coding-Reversing mode parking space,Write only channel ,40
[SFD2] IDE15100-IDE17043-Parking coordinator coding-Reversing mode parallel to road,Write only channel ,40
[SFD2] IDE15100-IDE17044-Parking coordinator coding-Reversing mode crossing traffic,Write only channel ,40
[SFD2] IDE15100-IDE17045-Parking coordinator coding-Reversing mode trailer hitch,Write only channel ,40
[SFD2] IDE15100-IDE17046-Parking coordinator coding-Rear Assist,Write only channel ,24
[SFD2] IDE15100-IDE17047-Parking coordinator coding-Automatic rear pedestrian brake,Write only channel ,40
[SFD2] IDE15100-IDE17048-Parking coordinator coding-Video Parking System,Write only channel ,48
[SFD2] IDE15100-IDE21181-Parking coordinator coding-Cross traffic alert (RCTA): mode,Write only channel ,48
[SFD2] IDE15100-IDE21185-Parking coordinator coding-TopView camera (design variant),Write only channel ,48
[SFD2] IDE15100-IDE21225-Parking coordinator coding-Main switch parking message manager,Write only channel ,0
[SFD2] IDE15100-MAS01083-Parking coordinator coding-Country Variant,Write only channel ,24
[SFD2] IDE15100-MAS01090-Parking coordinator coding-Gearbox,Write only channel ,8
[SFD2] IDE15100-MAS09095-Parking coordinator coding-Optical parking system,Write only channel ,18
[SFD2] IDE15100-MAS12061-Parking coordinator coding-Sensor with rotation direction detection,Write only channel ,8
[SFD2] IDE15100-MAS12321-Parking coordinator coding-Trailer maneuvering system,Write only channel ,16
[SFD2] IDE15100-MAS15696-Parking coordinator coding-Rear cross traffic assistant,Write only channel ,16
[SFD2] IDE15100-MAS23011-Parking coordinator coding-trailer hitch,Write only channel ,10
[SFD2] IDE15100-MAS23012-Parking coordinator coding-Intersection assistant,Write only channel ,24
[SFD2] IDE15100-MAS23014-Parking coordinator coding-Acoustic parking system,Write only channel ,32
[SFD2] IDE15100-MAS23015-Parking coordinator coding-Collision assistant,Write only channel ,34
[SFD2] IDE15100-MAS23016-Parking coordinator coding-Remote controlled functions,Write only channel ,42
[SFD2] IDE15100-MAS23019-Parking coordinator coding-Electric parking brake,Write only channel ,16
[SFD2] IDE15100-MAS23063-Parking coordinator coding-PDC front and rear or front: rear and side,Write only channel ,32
[SFD2] IDE15100-MAS25259-Parking coordinator coding-Trained parking,Write only channel ,24
[SFD2] IDE15100-SFT33108-Parking coordinator coding-Rush Hour Pilot,Write only channel ,50
[SFD2] IDE15100-ENG364596-Parking coordinator coding-HMI Concept,Write only channel ,0
[SFD2] IDE15100-ENG257808-Parking coordinator coding-PaCo_Car_HardKeyFAS,Write only channel ,8
[SFD2] IDE15100-ENG258080-Parking coordinator coding-PaCo_Drive_type,Write only channel ,8
[SFD2] IDE15100-ENG257781-Parking coordinator coding-PaCo_Parking_Hardkey,Write only channel ,16
[SFD2] IDE15100-ENG257858-Parking coordinator coding-PaCo_Personalisation,Write only channel ,0
[SFD2] IDE15100-ENG258079-Parking coordinator coding-PaCo_Traffic_side,Write only channel ,8
IDE15316-FoD Partner,Write only channel ,0
[SFD2] IDE15331-Multifunction steering wheel extended adaptation,Write only channel ,0
[SFD2] IDE15413-IDE18871-Anomaly detection configuration-Report system for deviations: activation status,Write only channel ,0
[SFD2] IDE15413-MAS26275-Anomaly detection configuration-GBT China compliant,Write only channel ,0
[SFD2] IDE15756-Ethernet port 3 VLAN configuration,Write only channel ,2
IDE15838-MAS01065-Expanded charging function coding profile options-Brand,Write only channel ,2
IDE15838-MAS21134-Expanded charging function coding profile options-expanded charging functions,Write only channel ,8
IDE15838-MAS21791-Expanded charging function coding profile options-Coordinated charging,Write only channel ,0
IDE15838-MAS21792-Expanded charging function coding profile options-Preferred charging times,Write only channel ,0
IDE15838-MAS21793-Expanded charging function coding profile options-Excess charging,Write only channel ,0
IDE15838-MAS21794-Expanded charging function coding profile options-Minimum charging,Write only channel ,0
IDE15838-MAS21795-Expanded charging function coding profile options-Charging with price threshold,Write only channel ,0
IDE15838-MAS21796-Expanded charging function coding profile options-Charging statistics,Write only channel ,0
IDE15839-IDE01058-Expanded charging function coding-Country coding,Write only channel ,2
IDE15839-MAS01065-Expanded charging function coding-Brand,Write only channel ,8
IDE15839-MAS21134-Expanded charging function coding-expanded charging functions,Write only channel ,0
IDE15839-MAS21789-Expanded charging function coding-Coordinated charging with energy management system,Write only channel ,0
IDE15839-MAS21790-Expanded charging function coding-Coordinated charging with tariff data service,Write only channel ,0
[SFD2] IDE16058-FoD Set assignment of work clearance ID,Write only channel ,0
[SFD2] IDE16455-Configuration of unlockable functions,Write only channel ,0
[SFD2] IDE16462-Unlockable functions: communication configuration,Write only channel ,0
[SFD ] IDE16611-Diagnosis filter: temporary deactivation,Write only channel ,0
[EXTD] IDE17298-MAS00128-Trustworthy time synchronization in the master performance-Adaptive Cruise Control,Write only channel ,16
[EXTD] IDE17298-MAS13018-Trustworthy time synchronization in the master performance-Front sensor for driver assistance systems,Write only channel ,16
[EXTD] IDE17298-MAS23893-Trustworthy time synchronization in the master performance-Round counter for redeterminations,Write only channel ,2
[EXTD] IDE17298-MAS23894-Trustworthy time synchronization in the master performance-Round counter for memory attempts,Write only channel ,10
[EXTD] IDE17298-SFT33033-Trustworthy time synchronization in the master performance-Short-range radar 1,Write only channel ,16
[EXTD] IDE17298-SFT33034-Trustworthy time synchronization in the master performance-Short-range radar 2,Write only channel ,16
[EXTD] IDE17298-SFT33035-Trustworthy time synchronization in the master performance-Short-range radar 3,Write only channel ,16
[EXTD] IDE17298-SFT33036-Trustworthy time synchronization in the master performance-Short-range radar 4,Write only channel ,16
[SFD2] IDE18363-Electronic architecture,Write only channel ,4
[SFD2] IDE19530-Ethernet port 4 VLAN configuration,Write only channel ,2
[SFD2] MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,Write only channel ,0
[SFD2] MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,Write only channel ,2
[SFD2] MAS08072-ENG172201-Driving profile selection-FPA_Funktion,Write only channel ,0
[SFD2] MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,Write only channel ,24
[SFD2] MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,Write only channel ,24
[SFD2] MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,Write only channel ,16
[SFD2] MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,Write only channel ,34
[SFD2] MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,Write only channel ,16
[SFD2] MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,Write only channel ,26
[SFD2] MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,Write only channel ,18
[SFD2] MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,Write only channel ,32
[SFD2] MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,Write only channel ,8
[SFD2] MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,Write only channel ,24
[SFD2] MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,Write only channel ,8
[SFD2] MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,Write only channel ,16
[SFD2] MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,Write only channel ,8
[SFD2] MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,Write only channel ,16
[SFD2] MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,Write only channel ,8
[SFD2] MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,Write only channel ,16
[SFD2] MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,Write only channel ,32
[SFD2] MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,Write only channel ,8
[SFD2] MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,Write only channel ,32
[SFD2] MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,Write only channel ,32
[SFD2] MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,Write only channel ,32
[SFD2] MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,Write only channel ,8
[SFD2] MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,Write only channel ,16
[SFD2] MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,Write only channel ,16
[SFD2] MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,Write only channel ,24
[SFD2] MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,Write only channel ,8
[SFD2] MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,Write only channel ,24
[SFD2] MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,Write only channel ,32
[SFD2] MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,Write only channel ,24
[SFD2] MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,Write only channel ,10
[SFD2] MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,Write only channel ,32
[SFD2] MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,Write only channel ,24
[SFD2] MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,Write only channel ,0
[SFD2] MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,Write only channel ,0
[SFD2] MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,Write only channel ,0
[SFD2] MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Write only channel ,0
[SFD2] MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Write only channel ,0
[SFD2] MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Write only channel ,8
[SFD2] MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Write only channel ,0
[SFD2] MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,Write only channel ,0
[SFD2] MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,Write only channel ,16
[SFD2] MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,Write only channel ,16
[SFD2] MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,Write only channel ,8
[SFD2] MAS16743-Alternator gear ratio,Write only channel ,2
[SFD2] MAS23693-MAS18081-Drowsiness and attention detection-Test Mode,Write only channel ,130
[SFD2] MAS23693-MAS20954-Drowsiness and attention detection-Function coding,Write only channel ,138
[SFD2] MAS23693-ENG101808-Drowsiness and attention detection-Bytes 1-16,Write only channel ,17
[SFD2] MAS26807-Engine start with belt-driven starter-alternator,Write only channel ,2
[SFD2] MAS28749-MAS28939-DoIP ECU configuration-Node address: DoIP-only control module 1,Write only channel ,2
[SFD2] MAS28749-MAS28939-DoIP ECU configuration-Node address: DoIP-only control module 1,Write only channel ,10
[SFD2] MAS28749-MAS28940-DoIP ECU configuration-Node address: DoIP-only control module 2,Write only channel ,18
[SFD2] MAS28749-MAS28940-DoIP ECU configuration-Node address: DoIP-only control module 2,Write only channel ,26
[SFD2] MAS28749-MAS28941-DoIP ECU configuration-Node address: DoIP-only control module 3,Write only channel ,34
[SFD2] MAS28749-MAS28941-DoIP ECU configuration-Node address: DoIP-only control module 3,Write only channel ,42
[SFD2] MAS28749-MAS28942-DoIP ECU configuration-Node address: DoIP-only control module 4,Write only channel ,50
[SFD2] MAS28749-MAS28942-DoIP ECU configuration-Node address: DoIP-only control module 4,Write only channel ,58
[SFD2] MAS28749-MAS28943-DoIP ECU configuration-Node address: DoIP-only control module 5,Write only channel ,66
[SFD2] MAS28749-MAS28943-DoIP ECU configuration-Node address: DoIP-only control module 5,Write only channel ,74
[SFD2] MAS28749-MAS28944-DoIP ECU configuration-Node address: DoIP-only control module 6,Write only channel ,82
[SFD2] MAS28749-MAS28944-DoIP ECU configuration-Node address: DoIP-only control module 6,Write only channel ,90
[SFD2] MAS28749-MAS28945-DoIP ECU configuration-Node address: DoIP-only control module 7,Write only channel ,98
[SFD2] MAS28749-MAS28945-DoIP ECU configuration-Node address: DoIP-only control module 7,Write only channel ,106
[SFD2] MAS28749-MAS28946-DoIP ECU configuration-Node address: DoIP-only control module 8,Write only channel ,114
[SFD2] MAS28749-MAS28946-DoIP ECU configuration-Node address: DoIP-only control module 8,Write only channel ,122
[SFD2] SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,Write only channel ,0
[SFD2] SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,Write only channel ,0
[SFD2] SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,Write only channel ,2
[SFD2] SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,Write only channel ,10
[SFD2] SFT271921-MAS06614-Multi-function steering wheel control module-Variant,Write only channel ,0
[SFD2] SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,Write only channel ,0
[SFD2] SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,Write only channel ,8
[SFD2] SFT271921-MAS13892-Multi-function steering wheel control module-Platform,Write only channel ,16
[SFD2] SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,Write only channel ,8
[SFD2] SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),Write only channel ,8
[SFD2] SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),Write only channel ,8
[SFD2] SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,Write only channel ,8
SFT272190-Steering Wheel Touch Recognition Control Module,Write only channel ,2
TXT01205-MAS10460-Message mirroring development-Target bus,Write only channel ,2
TXT01205-MAS21167-Message mirroring development-Source bus,Write only channel ,10
[EXTD] ENG253073-Diagnostic_filter_permanent_deactivation,Write only channel ,0
[SFD2] ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,Write only channel ,72
[SFD2] ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,Write only channel ,58
[SFD2] ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,Write only channel ms,66
[SFD2] ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,Write only channel ms,50
[SFD2] ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,Write only channel ms,18
[SFD2] ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,Write only channel ms,26
[SFD2] ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,Write only channel ms,42
[SFD2] ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,Write only channel ms,34
[SFD2] ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,Write only channel ms,2
[SFD2] ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,Write only channel ms,10
[EXTD] ENG331085-ENG280094-Egress_filter-packet_based_/_port_shaper_burst_size_configuration,Write only channel ,53
[EXTD] ENG331085-ENG280095-Egress_filter-packet_based_/_port_shaper_shaping_rate_configuration,Write only channel packets/s,21
[EXTD] ENG331085-ENG280098-Egress_filter-port_shaper_bucket_count_select,Write only channel ,10
[EXTD] ENG331085-ENG280099-Egress_filter-port_shaper_enabling,Write only channel ,2
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,2
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,26
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,50
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,74
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,98
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,122
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,146
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,170
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,194
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,218
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,242
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,266
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,290
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,314
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,338
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,362
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,11
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,35
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,59
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,83
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,107
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,131
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,155
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,179
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,203
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,227
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,251
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,275
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,299
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,323
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,347
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,371
[EXTD] ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,Write only channel ,0
[EXTD] ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,Write only channel ,0
[EXTD] ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,Write only channel ,0
[EXTD] ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,Write only channel ,0
[EXTD] ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,Write only channel ,0
[EXTD] ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,Write only channel ,0
[EXTD] ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,Write only channel ,0
[EXTD] ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,Write only channel ,2
[EXTD] ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,Write only channel ,8
[EXTD] ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,Write only channel ,8
[EXTD] ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,Write only channel ,8
[EXTD] ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,Write only channel ,8
[EXTD] ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,Write only channel ,8
[EXTD] ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,Write only channel ,8
[EXTD] ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,Write only channel ,8
[EXTD] ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,Write only channel ,10
[EXTD] ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,Write only channel ,16
[EXTD] ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,Write only channel ,16
[EXTD] ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,Write only channel ,16
[EXTD] ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,Write only channel ,16
[EXTD] ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,Write only channel ,16
[EXTD] ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,Write only channel ,16
[EXTD] ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,Write only channel ,16
[EXTD] ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,Write only channel ,18
[EXTD] ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,Write only channel ,24
[EXTD] ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,Write only channel ,24
[EXTD] ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,Write only channel ,24
[EXTD] ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,Write only channel ,24
[EXTD] ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,Write only channel ,24
[EXTD] ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,Write only channel ,24
[EXTD] ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,Write only channel ,24
[EXTD] ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,Write only channel ,26
[EXTD] ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,Write only channel ,32
[EXTD] ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,Write only channel ,32
[EXTD] ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,Write only channel ,32
[EXTD] ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,Write only channel ,32
[EXTD] ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,Write only channel ,32
[EXTD] ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,Write only channel ,32
[EXTD] ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,Write only channel ,32
[EXTD] ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,Write only channel ,34
[EXTD] ENG376354-ENG376439-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ACC_18_can-id_0x14D,Write only channel ,0
[EXTD] ENG376354-ENG258827-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_01_can-id_0x040,Write only channel ,0
[EXTD] ENG376354-ENG259901-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_02_can-id_0x520,Write only channel ,0
[EXTD] ENG376354-ENG259106-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_03_can-id_0x041,Write only channel ,0
[EXTD] ENG376354-ENG376486-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_04_can-id_0x545,Write only channel ,0
[EXTD] ENG376354-ENG376503-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-AWV_03_can-id_0x0DB,Write only channel ,0
[EXTD] ENG376354-ENG376508-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Blinkmodi_02_can-id_0x366,Write only channel ,0
[EXTD] ENG376354-ENG258357-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-BMS_07_can-id_0x5CA,Write only channel ,2
[EXTD] ENG376354-ENG376567-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_02_can-id_0x3F4,Write only channel ,8
[EXTD] ENG376354-ENG376569-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_04_can-id_0x0F7,Write only channel ,8
[EXTD] ENG376354-ENG376581-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DiETa_01_can-id_0x353,Write only channel ,8
[EXTD] ENG376354-ENG258444-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_01_can-id_0x1A4,Write only channel ,8
[EXTD] ENG376354-ENG259736-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_02_can-id_0x1F0,Write only channel ,8
[EXTD] ENG376354-ENG376591-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EBKV_03_can-id_0x176,Write only channel ,8
[EXTD] ENG376354-ENG376634-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ELV_01_can-id_0x656,Write only channel ,8
[EXTD] ENG376354-ENG376635-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM1_01_can-id_0x0C0,Write only channel ,10
[EXTD] ENG376354-ENG376636-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM2_01_can-id_0x0C1,Write only channel ,16
[EXTD] ENG376354-ENG258228-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EPB_03_can-id_0x1F7,Write only channel ,16
[EXTD] ENG376354-ENG376650-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_50_can-id_0x102,Write only channel ,16
[EXTD] ENG376354-ENG376651-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_51_Auth_can-id_0x0FC,Write only channel ,16
[EXTD] ENG376354-ENG376652-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_52_can-id_0x12DD5497,Write only channel ,16
[EXTD] ENG376354-ENG258443-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_10_can-id_0x116,Write only channel ,16
[EXTD] ENG376354-ENG258752-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_21_can-id_0x0FD,Write only channel ,16
[EXTD] ENG376354-ENG258803-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_24_can-id_0x31B,Write only channel ,18
[EXTD] ENG376354-ENG376653-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_30_can-id_0x1A555521,Write only channel ,24
[EXTD] ENG376354-ENG376705-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_11_can-id_0x0AD,Write only channel ,24
[EXTD] ENG376354-ENG376706-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_16_can-id_0x144,Write only channel ,24
[EXTD] ENG376354-ENG376748-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-HVK_01_can-id_0x503,Write only channel ,24
[EXTD] ENG376354-ENG376756-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-IPA_02_can-id_0x16A9545F,Write only channel ,24
[EXTD] ENG376354-ENG259431-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Status_01_can-id_0x3C0,Write only channel ,24
[EXTD] ENG376354-ENG258280-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Steuerung_01_can-id_0x58C,Write only channel ,24
[EXTD] ENG376354-ENG260883-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_01_can-id_0x32A,Write only channel ,26
[EXTD] ENG376354-ENG261199-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_02_can-id_0x11D,Write only channel ,32
[EXTD] ENG376354-ENG259434-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_03_can-id_0x09F,Write only channel ,32
[EXTD] ENG376354-ENG376764-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_05_can-id_0x06E,Write only channel ,32
[EXTD] ENG376354-ENG258969-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Licht_Anf_01_can-id_0x3D5,Write only channel ,32
[EXTD] ENG376354-ENG259107-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LWI_01_can-id_0x086,Write only channel ,32
[EXTD] ENG376354-ENG376780-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_BT_01_can-id_0x49C,Write only channel ,32
[EXTD] ENG376354-ENG376781-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_FT_01_can-id_0x492,Write only channel ,32
[EXTD] ENG376354-ENG260730-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_14_can-id_0x3BE,Write only channel ,34
[EXTD] ENG376354-ENG376786-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_51_Auth_can-id_0x10B,Write only channel ,40
[EXTD] ENG376354-ENG376787-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_54_can-id_0x14C,Write only channel ,40
[EXTD] ENG376354-ENG376788-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_55_Auth_can-id_0x0F6,Write only channel ,40
[EXTD] ENG376354-ENG376789-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_56_can-id_0x0BE,Write only channel ,40
[EXTD] ENG376354-ENG376790-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_57_can-id_0x12DD54AA,Write only channel ,40
[EXTD] ENG376354-ENG258115-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_Code_01_can-id_0x641,Write only channel ,40
[EXTD] ENG376354-ENG376814-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PAO_Status_01_can-id_0x16A954FD,Write only channel ,40
[EXTD] ENG376354-ENG376817-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Parken_01_can-id_0x206,Write only channel ,42
[EXTD] ENG376354-ENG376824-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PLA_04_can-id_0x407,Write only channel ,48
[EXTD] ENG376354-ENG376834-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-QFK_01_Auth_can-id_0x13D,Write only channel ,48
[EXTD] ENG376354-ENG260760-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-RCTA_01_can-id_0x2B7,Write only channel ,48
[EXTD] ENG376354-ENG376908-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TA_01_can-id_0x26B,Write only channel ,48
[EXTD] ENG376354-ENG259993-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_FT_02_can-id_0x3E5,Write only channel ,48
[EXTD] ENG376354-ENG376959-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_HFS_02_can-id_0x341,Write only channel ,48
[EXTD] ENG376354-ENG376988-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-VMM_02_can-id_0x139,Write only channel ,48
[EXTD] ENG376354-ENG376990-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Waehlhebel_04_can-id_0x0B5,Write only channel ,50
[EXTD] ENG253192-MAS01898-IDS_white_list_features-Drive train,Write only channel ,0
[EXTD] ENG253192-MAS03178-IDS_white_list_features-Suspension data bus,Write only channel ,0
[EXTD] ENG253192-MAS12183-IDS_white_list_features-Comfort CAN bus 2,Write only channel ,0
[EXTD] ENG253192-MAS16574-IDS_white_list_features-Infotainment,Write only channel ,0
[EXTD] ENG376363-Max_number_of_TCP-Sockets,Write only channel ,2
ENG253396-Mirroring_LIN3_to_LIN4,Write only channel ,0
ENG253252-ENG260330-Node_to_cluster_list-NCL_element_1,Write only channel ,6
ENG253252-ENG260846-Node_to_cluster_list-NCL_element_10,Write only channel ,366
ENG253252-ENG258686-Node_to_cluster_list-NCL_element_11,Write only channel ,406
ENG253252-ENG259563-Node_to_cluster_list-NCL_element_12,Write only channel ,446
ENG253252-ENG259135-Node_to_cluster_list-NCL_element_13,Write only channel ,486
ENG253252-ENG261302-Node_to_cluster_list-NCL_element_14,Write only channel ,526
ENG253252-ENG259590-Node_to_cluster_list-NCL_element_15,Write only channel ,566
ENG253252-ENG261163-Node_to_cluster_list-NCL_element_16,Write only channel ,606
ENG253252-ENG258229-Node_to_cluster_list-NCL_element_17,Write only channel ,646
ENG253252-ENG259389-Node_to_cluster_list-NCL_element_18,Write only channel ,686
ENG253252-ENG260540-Node_to_cluster_list-NCL_element_19,Write only channel ,726
ENG253252-ENG259624-Node_to_cluster_list-NCL_element_2,Write only channel ,46
ENG253252-ENG258136-Node_to_cluster_list-NCL_element_20,Write only channel ,766
ENG253252-ENG261360-Node_to_cluster_list-NCL_element_21,Write only channel ,806
ENG253252-ENG260775-Node_to_cluster_list-NCL_element_22,Write only channel ,846
ENG253252-ENG259077-Node_to_cluster_list-NCL_element_23,Write only channel ,886
ENG253252-ENG259062-Node_to_cluster_list-NCL_element_24,Write only channel ,926
ENG253252-ENG260421-Node_to_cluster_list-NCL_element_25,Write only channel ,966
ENG253252-ENG261354-Node_to_cluster_list-NCL_element_26,Write only channel ,1006
ENG253252-ENG258201-Node_to_cluster_list-NCL_element_27,Write only channel ,1046
ENG253252-ENG260110-Node_to_cluster_list-NCL_element_28,Write only channel ,1086
ENG253252-ENG258645-Node_to_cluster_list-NCL_element_29,Write only channel ,1126
ENG253252-ENG261260-Node_to_cluster_list-NCL_element_3,Write only channel ,86
ENG253252-ENG259078-Node_to_cluster_list-NCL_element_30,Write only channel ,1166
ENG253252-ENG260192-Node_to_cluster_list-NCL_element_31,Write only channel ,1206
ENG253252-ENG259747-Node_to_cluster_list-NCL_element_32,Write only channel ,1246
ENG253252-ENG259375-Node_to_cluster_list-NCL_element_4,Write only channel ,126
ENG253252-ENG259916-Node_to_cluster_list-NCL_element_5,Write only channel ,166
ENG253252-ENG260559-Node_to_cluster_list-NCL_element_6,Write only channel ,206
ENG253252-ENG259415-Node_to_cluster_list-NCL_element_7,Write only channel ,246
ENG253252-ENG260302-Node_to_cluster_list-NCL_element_8,Write only channel ,286
ENG253252-ENG259224-Node_to_cluster_list-NCL_element_9,Write only channel ,326
[SFD ] ENG309781-NVEM_function_variant,Write only channel ,2
ENG253340-SFD_Testmode,Write only channel ,0
[EXTD] ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,Write only channel ,28
[EXTD] ENG253268-MAS03174-TCR_bus_can-Comfort data bus,Write only channel ,52
[EXTD] ENG253268-MAS03175-TCR_bus_can-Extended data bus,Write only channel ,124
[EXTD] ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,Write only channel ,76
[EXTD] ENG253268-MAS03178-TCR_bus_can-Suspension data bus,Write only channel ,100
[EXTD] ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,Write only channel ,4
[EXTD] ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,Write only channel ,148
[EXTD] ENG253268-MAS16910-TCR_bus_can-Migration data bus,Write only channel ,172
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,Write only channel ,28
ENG253184-MAS03180-TCR_bus_lin-Local data bus,Write only channel ,4
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,Write only channel ,52
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,Write only channel ,76
[EXTD] ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,Write only channel ,4
[EXTD] ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,Write only channel ,28
[EXTD] ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,Write only channel ,76
[EXTD] ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,Write only channel ,100
[EXTD] ENG253199-MAS18934-TCR_bus_vlan-VLAN Connect,Write only channel ,52
ENG376375-ENG376911-Test_Block_1-Test_Parameter_1,Write only channel ,5
ENG376375-ENG376919-Test_Block_1-Test_Parameter_1 (2),Write only channel ,37
ENG376375-ENG376920-Test_Block_1-Test_Parameter_1 (3),Write only channel ,69
ENG376375-ENG376921-Test_Block_1-Test_Parameter_1 (4),Write only channel ,101
ENG376375-ENG376922-Test_Block_1-Test_Parameter_1 (5),Write only channel ,133
ENG376375-ENG376923-Test_Block_1-Test_Parameter_1 (6),Write only channel ,165
ENG376375-ENG376924-Test_Block_1-Test_Parameter_1 (7),Write only channel ,197
ENG376375-ENG376925-Test_Block_1-Test_Parameter_1 (8),Write only channel ,229
ENG376376-ENG376911-Test_Block_2-Test_Parameter_1,Write only channel ,5
ENG376376-ENG376912-Test_Block_2-Test_Parameter_1 (10),Write only channel ,293
ENG376376-ENG376913-Test_Block_2-Test_Parameter_1 (11),Write only channel ,325
ENG376376-ENG376914-Test_Block_2-Test_Parameter_1 (12),Write only channel ,357
ENG376376-ENG376915-Test_Block_2-Test_Parameter_1 (13),Write only channel ,389
ENG376376-ENG376916-Test_Block_2-Test_Parameter_1 (14),Write only channel ,421
ENG376376-ENG376917-Test_Block_2-Test_Parameter_1 (15),Write only channel ,453
ENG376376-ENG376918-Test_Block_2-Test_Parameter_1 (16),Write only channel ,485
ENG376376-ENG376919-Test_Block_2-Test_Parameter_1 (2),Write only channel ,37
ENG376376-ENG376920-Test_Block_2-Test_Parameter_1 (3),Write only channel ,69
ENG376376-ENG376921-Test_Block_2-Test_Parameter_1 (4),Write only channel ,101
ENG376376-ENG376922-Test_Block_2-Test_Parameter_1 (5),Write only channel ,133
ENG376376-ENG376923-Test_Block_2-Test_Parameter_1 (6),Write only channel ,165
ENG376376-ENG376924-Test_Block_2-Test_Parameter_1 (7),Write only channel ,197
ENG376376-ENG376925-Test_Block_2-Test_Parameter_1 (8),Write only channel ,229
ENG376376-ENG376926-Test_Block_2-Test_Parameter_1 (9),Write only channel ,261
ENG376377-Test_Block_3,Write only channel ,2
ENG376378-Test_Block_4,Write only channel ,3
ENG376379-Test_Block_5,Write only channel ,4
ENG376380-Test_Block_6,Write only channel ,5
ENG376381-Test_Block_7,Write only channel ,4
ENG376382-Test_Block_8,Write only channel ,5
[EXTD] ENG376385-Traffic_Limit_on_ext_ETH-Ports,Write only channel %,2
[SFD ] ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,Write only channel ,11
[SFD ] ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,Write only channel ,58
[SFD ] ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,Write only channel ,66
[SFD ] ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,Write only channel min,74
[SFD ] ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,Write only channel s,2
[SFD ] ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,Write only channel s,27
[SFD ] ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,Write only channel s,43
Elapsed Time: 00:34
    SW:5QS-907-530-B   HW:5QS-907-530 ---  19: CAN Gateway
    Component:GW MQB 23     005 3093, Coding:000000000000000000000000000000000000000000000300030000000000000000000000000000000000000000000000
    EV_GatewMQBwBL,001018,EV_GatewMQBwBL_VW41.rod
    Friday,19,June,2026,13:18:43:15875
    VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
    VCID: 53F27D57AB76A8A23B0-8006 SFD+SFD2 [ ]
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
[SFD ] IDE00002-Transport mode,not active ,1
[SFD2] IDE00003-Coding,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,48
[EXTD] IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,Write only channel ,0
[EXTD] IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,Write only channel ,18
[EXTD] IDE00820-ENG447862-Activating and deactivating all development messages-ELF_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,Write only channel ,26
[EXTD] IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG447864-Activating and deactivating all development messages-HVLM_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG447863-Activating and deactivating all development messages-HVL-SF_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,Write only channel ,8
[EXTD] IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,Write only channel ,10
[EXTD] IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,Write only channel ,32
[EXTD] IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,Write only channel ,16
[EXTD] IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,Write only channel ,24
[EXTD] IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,Write only channel ,16
[SFD ] IDE01211-Static current measuring mode,Write only channel ,2
[SFD2] IDE01996-ENG151565-Installation list: specified installations-ECU coded Bit 0,Write only channel ,0
[SFD2] IDE01996-ENG176508-Installation list: specified installations-ECU coded Bit 1,Write only channel ,0
[SFD2] IDE01996-ENG176493-Installation list: specified installations-ECU coded Bit 2,Write only channel ,0
[SFD2] IDE01996-ENG176430-Installation list: specified installations-ECU coded Bit 3,Write only channel ,0
[SFD2] IDE01996-ENG176439-Installation list: specified installations-ECU coded Bit 4,Write only channel ,0
[SFD2] IDE01996-ENG176505-Installation list: specified installations-ECU coded Bit 5,Write only channel ,0
[SFD2] IDE01996-ENG176473-Installation list: specified installations-ECU coded Bit 6,Write only channel ,0
[SFD2] IDE01996-ENG176498-Installation list: specified installations-ECU coded Bit 7,Write only channel ,2
IDE02185-IKA key,Write only channel ,35
IDE02332-Deactivate production mode,Write only channel ,4
[SFD ] IDE03256-MAS06105-Battery adaptation-Rated battery capacity,Write only channel Ah,2
[SFD ] IDE03256-MAS06106-Battery adaptation-Battery technology,Write only channel ,10
[SFD ] IDE03256-MAS06107-Battery adaptation-Battery manufacturer,Write only channel ,20
[SFD ] IDE03256-MAS06108-Battery adaptation-Battery Serial Number,Write only channel ,51
IDE03903-Production process data 1,Write only channel ,3
IDE04330-Transfer of release code for a SWaP function,Write only channel ,0
IDE04331-Selection of release codes for a SWaP function,Write only channel ,5
[SFD ] IDE06425-Dynamometer mode: functional-,Write only channel ,0
[SFD ] IDE06425-ENG98891-Dynamometer mode: functional-Reserved,Write only channel ,2
[SFD ] IDE06530-Distance left for deactivation of static current measuring mode,Write only channel km,2
[SFD ] IDE06541-Distance left for deactivation of transport mode,Write only channel km,2
IDE06833-Component protection SHE key,Write only channel ,0
IDE07139-Normal bus behavior during diagnosis,Write only channel ,2
[PROD] IDE07160-Control module switch-off: switch-off time,Write only channel min,2
IDE07838-Counter for inconsistent states,Write only channel ,3
IDE08220-Vehicle production mode,Write only channel ,0
[SFD2] IDE08623-MAS02672-OBD configuration-Start-stop,Write only channel ,8
[SFD2] IDE08623-MAS08039-OBD configuration-HV charging,Write only channel ,8
[SFD2] IDE08623-MAS14468-OBD configuration-OBD type,Write only channel ,10
[SFD2] IDE08623-MAS26199-OBD configuration-MHEV,Write only channel ,8
[SFD2] IDE08623-MAS26725-OBD configuration-Internal combustion engine information,Write only channel ,8
[SFD2] IDE08623-MAS26826-OBD configuration-HEV,Write only channel ,8
[SFD2] IDE08623-MAS27147-OBD configuration-OBD on event data recorder (EDR),Write only channel ,0
[SFD2] IDE08623-MAS28789-OBD configuration-Starter battery: type,Write only channel ,0
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,Write only channel l/100km,259
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,Write only channel km/h,51
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,Write only channel W,67
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,Write only channel W,83
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,Write only channel W,99
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,Write only channel A,115
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,Write only channel kWh/100 km,131
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,Write only channel kWh/100 km,147
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,Write only channel kWh/100 km,163
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,Write only channel kWh/100 km,179
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,Write only channel kWh/100 km,195
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,Write only channel kWh/100 km,211
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),Write only channel kWh/100 km,3
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,Write only channel l/100km,19
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,Write only channel kWh/100 km,35
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,Write only channel kWh/100 km,227
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,Write only channel kg/100 km,243
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,Write only channel l/100km,275
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,Write only channel l/100km,291
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,Write only channel l/100km,307
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,Write only channel l/100km,323
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,Write only channel l/100km,339
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,Write only channel l/100km,355
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,Write only channel l/100km,371
[EXTD] IDE10351-MAS10460-Message mirroring-Target bus,Write only channel ,2
[EXTD] IDE10351-MAS21167-Message mirroring-Source bus,Write only channel ,10
[SFD ] IDE11689-48V-System: locking,Write only channel ,2
IDE12153-MAS11025-Start component protection authentication-Status,Write only channel ,18
IDE12153-MAS13795-Start component protection authentication-Node address,Write only channel ,3
[SFD2] IDE13748-IDE17293-Coding low voltage energy management-Autonomous inverter for socket,Write only channel ,16
[SFD2] IDE13748-IDE17294-Coding low voltage energy management-Battery architecture,Write only channel ,0
[SFD2] IDE13748-MAS23870-Coding low voltage energy management-Battery installation point,Write only channel ,2
[SFD2] IDE13748-MAS23871-Coding low voltage energy management-Additional memory control,Write only channel ,8
[SFD2] IDE13748-SFT271977-Coding low voltage energy management-Inverter for socket,Write only channel ,16
IDE13756-Diagnosis filter: activation,Write only channel ,2
IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,Write only channel km,2
IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,Write only channel km,10
IDE13844-Distance left for deactivation of production mode,Write only channel km,2
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,Write only channel kWh/100 km,3
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,Write only channel kWh/100 km,19
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,Write only channel kWh/100 km,35
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,Write only channel kWh/100 km,51
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,Write only channel kWh/100 km,67
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,Write only channel kWh/100 km,83
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,Write only channel kWh/100 km,99
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,Write only channel kWh/100 km,115
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,Write only channel kWh/100 km,131
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,Write only channel kWh/100 km,147
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,Write only channel kWh/100 km,163
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,Write only channel kWh/100 km,179
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,Write only channel kWh/100 km,195
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,Write only channel kWh/100 km,211
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,Write only channel kWh/100 km,227
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,Write only channel kWh/100 km,243
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,Write only channel kWh/100 km,259
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,Write only channel kWh/100 km,275
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,Write only channel kWh/100 km,291
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,Write only channel kWh/100 km,307
[SFD2] IDE14423-IDE01058-High-voltage charging management coding-Country coding,Write only channel ,8
[SFD2] IDE14423-MAS01065-High-voltage charging management coding-Brand,Write only channel ,10
[SFD2] IDE14423-MAS08226-High-voltage charging management coding-Max charging current,Write only channel ,8
[SFD2] IDE14423-ENG172426-High-voltage charging management coding-AC_charging_socket_A,Write only channel ,0
[SFD2] IDE14423-ENG172427-High-voltage charging management coding-AC_charging_socket_B,Write only channel ,0
[SFD2] IDE14423-ENG174048-High-voltage charging management coding-Automatic_wireless_charging,Write only channel ,0
[SFD2] IDE14423-ENG259912-High-voltage charging management coding-charge_flap_lock_detection,Write only channel ,16
[SFD2] IDE14423-ENG260779-High-voltage charging management coding-Charge_flap_locking,Write only channel ,8
[SFD2] IDE14423-ENG172423-High-voltage charging management coding-DC_charging_Chademo,Write only channel ,0
[SFD2] IDE14423-ENG258832-High-voltage charging management coding-DC_charging_china,Write only channel ,0
[SFD2] IDE14423-ENG174370-High-voltage charging management coding-kind_of_plug_interlock_detection,Write only channel ,16
[SFD2] IDE14423-ENG172503-High-voltage charging management coding-PLC_charging_socket_A,Write only channel ,0
[SFD2] IDE14423-ENG172504-High-voltage charging management coding-PLC_charging_socket_B,Write only channel ,0
[SFD2] IDE14423-ENG251485-High-voltage charging management coding-plug_and_charge,Write only channel ,16
[SFD2] IDE14423-ENG251486-High-voltage charging management coding-plug_interlock,Write only channel ,16
[SFD2] IDE14423-ENG174643-High-voltage charging management coding-stimulation_wire,Write only channel ,16
[SFD ] IDE14750-Deactivate all development messages,Write only channel ,6
[SFD2] IDE15100-IDE02321-Parking coordinator coding-Activation of park assist,Write only channel ,16
[SFD2] IDE15100-IDE17041-Parking coordinator coding-Reversing mode bumper protection,Write only channel ,40
[SFD2] IDE15100-IDE17042-Parking coordinator coding-Reversing mode parking space,Write only channel ,40
[SFD2] IDE15100-IDE17043-Parking coordinator coding-Reversing mode parallel to road,Write only channel ,40
[SFD2] IDE15100-IDE17044-Parking coordinator coding-Reversing mode crossing traffic,Write only channel ,40
[SFD2] IDE15100-IDE17045-Parking coordinator coding-Reversing mode trailer hitch,Write only channel ,40
[SFD2] IDE15100-IDE17046-Parking coordinator coding-Rear Assist,Write only channel ,24
[SFD2] IDE15100-IDE17047-Parking coordinator coding-Automatic rear pedestrian brake,Write only channel ,40
[SFD2] IDE15100-IDE17048-Parking coordinator coding-Video Parking System,Write only channel ,48
[SFD2] IDE15100-IDE21181-Parking coordinator coding-Cross traffic alert (RCTA): mode,Write only channel ,48
[SFD2] IDE15100-IDE21185-Parking coordinator coding-TopView camera (design variant),Write only channel ,48
[SFD2] IDE15100-IDE21225-Parking coordinator coding-Main switch parking message manager,Write only channel ,0
[SFD2] IDE15100-MAS01083-Parking coordinator coding-Country Variant,Write only channel ,24
[SFD2] IDE15100-MAS01090-Parking coordinator coding-Gearbox,Write only channel ,8
[SFD2] IDE15100-MAS09095-Parking coordinator coding-Optical parking system,Write only channel ,18
[SFD2] IDE15100-MAS12061-Parking coordinator coding-Sensor with rotation direction detection,Write only channel ,8
[SFD2] IDE15100-MAS12321-Parking coordinator coding-Trailer maneuvering system,Write only channel ,16
[SFD2] IDE15100-MAS15696-Parking coordinator coding-Rear cross traffic assistant,Write only channel ,16
[SFD2] IDE15100-MAS23011-Parking coordinator coding-trailer hitch,Write only channel ,10
[SFD2] IDE15100-MAS23012-Parking coordinator coding-Intersection assistant,Write only channel ,24
[SFD2] IDE15100-MAS23014-Parking coordinator coding-Acoustic parking system,Write only channel ,32
[SFD2] IDE15100-MAS23015-Parking coordinator coding-Collision assistant,Write only channel ,34
[SFD2] IDE15100-MAS23016-Parking coordinator coding-Remote controlled functions,Write only channel ,42
[SFD2] IDE15100-MAS23019-Parking coordinator coding-Electric parking brake,Write only channel ,16
[SFD2] IDE15100-MAS23063-Parking coordinator coding-PDC front and rear or front: rear and side,Write only channel ,32
[SFD2] IDE15100-MAS25259-Parking coordinator coding-Trained parking,Write only channel ,24
[SFD2] IDE15100-SFT33108-Parking coordinator coding-Rush Hour Pilot,Write only channel ,50
[SFD2] IDE15100-ENG364596-Parking coordinator coding-HMI Concept,Write only channel ,0
[SFD2] IDE15100-ENG257808-Parking coordinator coding-PaCo_Car_HardKeyFAS,Write only channel ,8
[SFD2] IDE15100-ENG258080-Parking coordinator coding-PaCo_Drive_type,Write only channel ,8
[SFD2] IDE15100-ENG257781-Parking coordinator coding-PaCo_Parking_Hardkey,Write only channel ,16
[SFD2] IDE15100-ENG257858-Parking coordinator coding-PaCo_Personalisation,Write only channel ,0
[SFD2] IDE15100-ENG258079-Parking coordinator coding-PaCo_Traffic_side,Write only channel ,8
IDE15316-FoD Partner,Write only channel ,0
[SFD2] IDE15331-Multifunction steering wheel extended adaptation,Write only channel ,0
[SFD2] IDE15413-IDE18871-Anomaly detection configuration-Report system for deviations: activation status,Write only channel ,0
[SFD2] IDE15413-MAS26275-Anomaly detection configuration-GBT China compliant,Write only channel ,0
[SFD2] IDE15756-Ethernet port 3 VLAN configuration,Write only channel ,2
IDE15838-MAS01065-Expanded charging function coding profile options-Brand,Write only channel ,2
IDE15838-MAS21134-Expanded charging function coding profile options-expanded charging functions,Write only channel ,8
IDE15838-MAS21791-Expanded charging function coding profile options-Coordinated charging,Write only channel ,0
IDE15838-MAS21792-Expanded charging function coding profile options-Preferred charging times,Write only channel ,0
IDE15838-MAS21793-Expanded charging function coding profile options-Excess charging,Write only channel ,0
IDE15838-MAS21794-Expanded charging function coding profile options-Minimum charging,Write only channel ,0
IDE15838-MAS21795-Expanded charging function coding profile options-Charging with price threshold,Write only channel ,0
IDE15838-MAS21796-Expanded charging function coding profile options-Charging statistics,Write only channel ,0
IDE15839-IDE01058-Expanded charging function coding-Country coding,Write only channel ,2
IDE15839-MAS01065-Expanded charging function coding-Brand,Write only channel ,8
IDE15839-MAS21134-Expanded charging function coding-expanded charging functions,Write only channel ,0
IDE15839-MAS21789-Expanded charging function coding-Coordinated charging with energy management system,Write only channel ,0
IDE15839-MAS21790-Expanded charging function coding-Coordinated charging with tariff data service,Write only channel ,0
[SFD2] IDE16058-FoD Set assignment of work clearance ID,Write only channel ,0
[SFD2] IDE16455-Configuration of unlockable functions,Write only channel ,0
[SFD2] IDE16462-Unlockable functions: communication configuration,Write only channel ,0
[SFD ] IDE16611-Diagnosis filter: temporary deactivation,Write only channel ,0
[EXTD] IDE17298-MAS00128-Trustworthy time synchronization in the master performance-Adaptive Cruise Control,Write only channel ,16
[EXTD] IDE17298-MAS13018-Trustworthy time synchronization in the master performance-Front sensor for driver assistance systems,Write only channel ,16
[EXTD] IDE17298-MAS23893-Trustworthy time synchronization in the master performance-Round counter for redeterminations,Write only channel ,2
[EXTD] IDE17298-MAS23894-Trustworthy time synchronization in the master performance-Round counter for memory attempts,Write only channel ,10
[EXTD] IDE17298-SFT33033-Trustworthy time synchronization in the master performance-Short-range radar 1,Write only channel ,16
[EXTD] IDE17298-SFT33034-Trustworthy time synchronization in the master performance-Short-range radar 2,Write only channel ,16
[EXTD] IDE17298-SFT33035-Trustworthy time synchronization in the master performance-Short-range radar 3,Write only channel ,16
[EXTD] IDE17298-SFT33036-Trustworthy time synchronization in the master performance-Short-range radar 4,Write only channel ,16
[SFD2] IDE18363-Electronic architecture,Write only channel ,4
[SFD2] IDE19530-Ethernet port 4 VLAN configuration,Write only channel ,2
[SFD2] MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,Write only channel ,0
[SFD2] MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,Write only channel ,2
[SFD2] MAS08072-ENG172201-Driving profile selection-FPA_Funktion,Write only channel ,0
[SFD2] MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,Write only channel ,24
[SFD2] MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,Write only channel ,24
[SFD2] MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,Write only channel ,16
[SFD2] MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,Write only channel ,34
[SFD2] MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,Write only channel ,16
[SFD2] MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,Write only channel ,26
[SFD2] MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,Write only channel ,18
[SFD2] MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,Write only channel ,32
[SFD2] MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,Write only channel ,8
[SFD2] MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,Write only channel ,24
[SFD2] MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,Write only channel ,8
[SFD2] MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,Write only channel ,16
[SFD2] MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,Write only channel ,8
[SFD2] MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,Write only channel ,16
[SFD2] MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,Write only channel ,8
[SFD2] MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,Write only channel ,16
[SFD2] MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,Write only channel ,32
[SFD2] MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,Write only channel ,8
[SFD2] MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,Write only channel ,32
[SFD2] MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,Write only channel ,32
[SFD2] MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,Write only channel ,32
[SFD2] MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,Write only channel ,8
[SFD2] MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,Write only channel ,16
[SFD2] MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,Write only channel ,16
[SFD2] MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,Write only channel ,24
[SFD2] MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,Write only channel ,8
[SFD2] MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,Write only channel ,24
[SFD2] MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,Write only channel ,32
[SFD2] MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,Write only channel ,24
[SFD2] MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,Write only channel ,10
[SFD2] MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,Write only channel ,32
[SFD2] MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,Write only channel ,24
[SFD2] MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,Write only channel ,0
[SFD2] MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,Write only channel ,0
[SFD2] MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,Write only channel ,0
[SFD2] MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Write only channel ,0
[SFD2] MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Write only channel ,0
[SFD2] MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Write only channel ,8
[SFD2] MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Write only channel ,0
[SFD2] MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,Write only channel ,0
[SFD2] MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,Write only channel ,16
[SFD2] MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,Write only channel ,16
[SFD2] MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,Write only channel ,8
[SFD2] MAS16743-Alternator gear ratio,Write only channel ,2
[SFD2] MAS23693-MAS18081-Drowsiness and attention detection-Test Mode,Write only channel ,130
[SFD2] MAS23693-MAS20954-Drowsiness and attention detection-Function coding,Write only channel ,138
[SFD2] MAS23693-ENG101808-Drowsiness and attention detection-Bytes 1-16,Write only channel ,17
[SFD2] MAS26807-Engine start with belt-driven starter-alternator,Write only channel ,2
[SFD2] MAS28749-MAS28939-DoIP ECU configuration-Node address: DoIP-only control module 1,Write only channel ,2
[SFD2] MAS28749-MAS28939-DoIP ECU configuration-Node address: DoIP-only control module 1,Write only channel ,10
[SFD2] MAS28749-MAS28940-DoIP ECU configuration-Node address: DoIP-only control module 2,Write only channel ,18
[SFD2] MAS28749-MAS28940-DoIP ECU configuration-Node address: DoIP-only control module 2,Write only channel ,26
[SFD2] MAS28749-MAS28941-DoIP ECU configuration-Node address: DoIP-only control module 3,Write only channel ,34
[SFD2] MAS28749-MAS28941-DoIP ECU configuration-Node address: DoIP-only control module 3,Write only channel ,42
[SFD2] MAS28749-MAS28942-DoIP ECU configuration-Node address: DoIP-only control module 4,Write only channel ,50
[SFD2] MAS28749-MAS28942-DoIP ECU configuration-Node address: DoIP-only control module 4,Write only channel ,58
[SFD2] MAS28749-MAS28943-DoIP ECU configuration-Node address: DoIP-only control module 5,Write only channel ,66
[SFD2] MAS28749-MAS28943-DoIP ECU configuration-Node address: DoIP-only control module 5,Write only channel ,74
[SFD2] MAS28749-MAS28944-DoIP ECU configuration-Node address: DoIP-only control module 6,Write only channel ,82
[SFD2] MAS28749-MAS28944-DoIP ECU configuration-Node address: DoIP-only control module 6,Write only channel ,90
[SFD2] MAS28749-MAS28945-DoIP ECU configuration-Node address: DoIP-only control module 7,Write only channel ,98
[SFD2] MAS28749-MAS28945-DoIP ECU configuration-Node address: DoIP-only control module 7,Write only channel ,106
[SFD2] MAS28749-MAS28946-DoIP ECU configuration-Node address: DoIP-only control module 8,Write only channel ,114
[SFD2] MAS28749-MAS28946-DoIP ECU configuration-Node address: DoIP-only control module 8,Write only channel ,122
[SFD2] SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,Write only channel ,0
[SFD2] SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,Write only channel ,0
[SFD2] SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,Write only channel ,2
[SFD2] SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,Write only channel ,10
[SFD2] SFT271921-MAS06614-Multi-function steering wheel control module-Variant,Write only channel ,0
[SFD2] SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,Write only channel ,0
[SFD2] SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,Write only channel ,8
[SFD2] SFT271921-MAS13892-Multi-function steering wheel control module-Platform,Write only channel ,16
[SFD2] SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,Write only channel ,8
[SFD2] SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),Write only channel ,8
[SFD2] SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),Write only channel ,8
[SFD2] SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,Write only channel ,8
SFT272190-Steering Wheel Touch Recognition Control Module,Write only channel ,2
TXT01205-MAS10460-Message mirroring development-Target bus,Write only channel ,2
TXT01205-MAS21167-Message mirroring development-Source bus,Write only channel ,10
[EXTD] ENG253073-Diagnostic_filter_permanent_deactivation,Write only channel ,0
[SFD2] ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,Write only channel ,72
[SFD2] ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,Write only channel ,58
[SFD2] ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,Write only channel ms,66
[SFD2] ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,Write only channel ms,50
[SFD2] ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,Write only channel ms,18
[SFD2] ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,Write only channel ms,26
[SFD2] ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,Write only channel ms,42
[SFD2] ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,Write only channel ms,34
[SFD2] ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,Write only channel ms,2
[SFD2] ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,Write only channel ms,10
[EXTD] ENG331085-ENG280094-Egress_filter-packet_based_/_port_shaper_burst_size_configuration,Write only channel ,53
[EXTD] ENG331085-ENG280095-Egress_filter-packet_based_/_port_shaper_shaping_rate_configuration,Write only channel packets/s,21
[EXTD] ENG331085-ENG280098-Egress_filter-port_shaper_bucket_count_select,Write only channel ,10
[EXTD] ENG331085-ENG280099-Egress_filter-port_shaper_enabling,Write only channel ,2
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,2
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,26
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,50
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,74
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,98
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,122
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,146
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,170
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,194
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,218
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,242
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,266
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,290
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,314
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,338
[EXTD] ENG253271-ENG259280-GW_Content_list-Bus_ID,Write only channel ,362
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,11
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,35
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,59
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,83
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,107
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,131
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,155
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,179
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,203
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,227
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,251
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,275
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,299
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,323
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,347
[EXTD] ENG253271-ENG253458-GW_Content_list-Node_address,Write only channel ,371
[EXTD] ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,Write only channel ,0
[EXTD] ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,Write only channel ,0
[EXTD] ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,Write only channel ,0
[EXTD] ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,Write only channel ,0
[EXTD] ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,Write only channel ,0
[EXTD] ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,Write only channel ,0
[EXTD] ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,Write only channel ,0
[EXTD] ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,Write only channel ,2
[EXTD] ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,Write only channel ,8
[EXTD] ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,Write only channel ,8
[EXTD] ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,Write only channel ,8
[EXTD] ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,Write only channel ,8
[EXTD] ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,Write only channel ,8
[EXTD] ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,Write only channel ,8
[EXTD] ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,Write only channel ,8
[EXTD] ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,Write only channel ,10
[EXTD] ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,Write only channel ,16
[EXTD] ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,Write only channel ,16
[EXTD] ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,Write only channel ,16
[EXTD] ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,Write only channel ,16
[EXTD] ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,Write only channel ,16
[EXTD] ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,Write only channel ,16
[EXTD] ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,Write only channel ,16
[EXTD] ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,Write only channel ,18
[EXTD] ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,Write only channel ,24
[EXTD] ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,Write only channel ,24
[EXTD] ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,Write only channel ,24
[EXTD] ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,Write only channel ,24
[EXTD] ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,Write only channel ,24
[EXTD] ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,Write only channel ,24
[EXTD] ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,Write only channel ,24
[EXTD] ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,Write only channel ,26
[EXTD] ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,Write only channel ,32
[EXTD] ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,Write only channel ,32
[EXTD] ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,Write only channel ,32
[EXTD] ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,Write only channel ,32
[EXTD] ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,Write only channel ,32
[EXTD] ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,Write only channel ,32
[EXTD] ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,Write only channel ,32
[EXTD] ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,Write only channel ,34
[EXTD] ENG376354-ENG376439-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ACC_18_can-id_0x14D,Write only channel ,0
[EXTD] ENG376354-ENG258827-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_01_can-id_0x040,Write only channel ,0
[EXTD] ENG376354-ENG259901-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_02_can-id_0x520,Write only channel ,0
[EXTD] ENG376354-ENG259106-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_03_can-id_0x041,Write only channel ,0
[EXTD] ENG376354-ENG376486-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_04_can-id_0x545,Write only channel ,0
[EXTD] ENG376354-ENG376503-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-AWV_03_can-id_0x0DB,Write only channel ,0
[EXTD] ENG376354-ENG376508-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Blinkmodi_02_can-id_0x366,Write only channel ,0
[EXTD] ENG376354-ENG258357-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-BMS_07_can-id_0x5CA,Write only channel ,2
[EXTD] ENG376354-ENG376567-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_02_can-id_0x3F4,Write only channel ,8
[EXTD] ENG376354-ENG376569-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_04_can-id_0x0F7,Write only channel ,8
[EXTD] ENG376354-ENG376581-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DiETa_01_can-id_0x353,Write only channel ,8
[EXTD] ENG376354-ENG258444-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_01_can-id_0x1A4,Write only channel ,8
[EXTD] ENG376354-ENG259736-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_02_can-id_0x1F0,Write only channel ,8
[EXTD] ENG376354-ENG376591-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EBKV_03_can-id_0x176,Write only channel ,8
[EXTD] ENG376354-ENG376634-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ELV_01_can-id_0x656,Write only channel ,8
[EXTD] ENG376354-ENG376635-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM1_01_can-id_0x0C0,Write only channel ,10
[EXTD] ENG376354-ENG376636-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM2_01_can-id_0x0C1,Write only channel ,16
[EXTD] ENG376354-ENG258228-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EPB_03_can-id_0x1F7,Write only channel ,16
[EXTD] ENG376354-ENG376650-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_50_can-id_0x102,Write only channel ,16
[EXTD] ENG376354-ENG376651-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_51_Auth_can-id_0x0FC,Write only channel ,16
[EXTD] ENG376354-ENG376652-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_52_can-id_0x12DD5497,Write only channel ,16
[EXTD] ENG376354-ENG258443-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_10_can-id_0x116,Write only channel ,16
[EXTD] ENG376354-ENG258752-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_21_can-id_0x0FD,Write only channel ,16
[EXTD] ENG376354-ENG258803-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_24_can-id_0x31B,Write only channel ,18
[EXTD] ENG376354-ENG376653-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_30_can-id_0x1A555521,Write only channel ,24
[EXTD] ENG376354-ENG376705-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_11_can-id_0x0AD,Write only channel ,24
[EXTD] ENG376354-ENG376706-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_16_can-id_0x144,Write only channel ,24
[EXTD] ENG376354-ENG376748-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-HVK_01_can-id_0x503,Write only channel ,24
[EXTD] ENG376354-ENG376756-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-IPA_02_can-id_0x16A9545F,Write only channel ,24
[EXTD] ENG376354-ENG259431-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Status_01_can-id_0x3C0,Write only channel ,24
[EXTD] ENG376354-ENG258280-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Steuerung_01_can-id_0x58C,Write only channel ,24
[EXTD] ENG376354-ENG260883-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_01_can-id_0x32A,Write only channel ,26
[EXTD] ENG376354-ENG261199-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_02_can-id_0x11D,Write only channel ,32
[EXTD] ENG376354-ENG259434-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_03_can-id_0x09F,Write only channel ,32
[EXTD] ENG376354-ENG376764-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_05_can-id_0x06E,Write only channel ,32
[EXTD] ENG376354-ENG258969-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Licht_Anf_01_can-id_0x3D5,Write only channel ,32
[EXTD] ENG376354-ENG259107-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LWI_01_can-id_0x086,Write only channel ,32
[EXTD] ENG376354-ENG376780-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_BT_01_can-id_0x49C,Write only channel ,32
[EXTD] ENG376354-ENG376781-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_FT_01_can-id_0x492,Write only channel ,32
[EXTD] ENG376354-ENG260730-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_14_can-id_0x3BE,Write only channel ,34
[EXTD] ENG376354-ENG376786-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_51_Auth_can-id_0x10B,Write only channel ,40
[EXTD] ENG376354-ENG376787-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_54_can-id_0x14C,Write only channel ,40
[EXTD] ENG376354-ENG376788-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_55_Auth_can-id_0x0F6,Write only channel ,40
[EXTD] ENG376354-ENG376789-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_56_can-id_0x0BE,Write only channel ,40
[EXTD] ENG376354-ENG376790-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_57_can-id_0x12DD54AA,Write only channel ,40
[EXTD] ENG376354-ENG258115-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_Code_01_can-id_0x641,Write only channel ,40
[EXTD] ENG376354-ENG376814-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PAO_Status_01_can-id_0x16A954FD,Write only channel ,40
[EXTD] ENG376354-ENG376817-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Parken_01_can-id_0x206,Write only channel ,42
[EXTD] ENG376354-ENG376824-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PLA_04_can-id_0x407,Write only channel ,48
[EXTD] ENG376354-ENG376834-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-QFK_01_Auth_can-id_0x13D,Write only channel ,48
[EXTD] ENG376354-ENG260760-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-RCTA_01_can-id_0x2B7,Write only channel ,48
[EXTD] ENG376354-ENG376908-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TA_01_can-id_0x26B,Write only channel ,48
[EXTD] ENG376354-ENG259993-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_FT_02_can-id_0x3E5,Write only channel ,48
[EXTD] ENG376354-ENG376959-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_HFS_02_can-id_0x341,Write only channel ,48
[EXTD] ENG376354-ENG376988-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-VMM_02_can-id_0x139,Write only channel ,48
[EXTD] ENG376354-ENG376990-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Waehlhebel_04_can-id_0x0B5,Write only channel ,50
[EXTD] ENG253192-MAS01898-IDS_white_list_features-Drive train,Write only channel ,0
[EXTD] ENG253192-MAS03178-IDS_white_list_features-Suspension data bus,Write only channel ,0
[EXTD] ENG253192-MAS12183-IDS_white_list_features-Comfort CAN bus 2,Write only channel ,0
[EXTD] ENG253192-MAS16574-IDS_white_list_features-Infotainment,Write only channel ,0
[EXTD] ENG376363-Max_number_of_TCP-Sockets,Write only channel ,2
ENG253396-Mirroring_LIN3_to_LIN4,Write only channel ,0
ENG253252-ENG260330-Node_to_cluster_list-NCL_element_1,Write only channel ,6
ENG253252-ENG260846-Node_to_cluster_list-NCL_element_10,Write only channel ,366
ENG253252-ENG258686-Node_to_cluster_list-NCL_element_11,Write only channel ,406
ENG253252-ENG259563-Node_to_cluster_list-NCL_element_12,Write only channel ,446
ENG253252-ENG259135-Node_to_cluster_list-NCL_element_13,Write only channel ,486
ENG253252-ENG261302-Node_to_cluster_list-NCL_element_14,Write only channel ,526
ENG253252-ENG259590-Node_to_cluster_list-NCL_element_15,Write only channel ,566
ENG253252-ENG261163-Node_to_cluster_list-NCL_element_16,Write only channel ,606
ENG253252-ENG258229-Node_to_cluster_list-NCL_element_17,Write only channel ,646
ENG253252-ENG259389-Node_to_cluster_list-NCL_element_18,Write only channel ,686
ENG253252-ENG260540-Node_to_cluster_list-NCL_element_19,Write only channel ,726
ENG253252-ENG259624-Node_to_cluster_list-NCL_element_2,Write only channel ,46
ENG253252-ENG258136-Node_to_cluster_list-NCL_element_20,Write only channel ,766
ENG253252-ENG261360-Node_to_cluster_list-NCL_element_21,Write only channel ,806
ENG253252-ENG260775-Node_to_cluster_list-NCL_element_22,Write only channel ,846
ENG253252-ENG259077-Node_to_cluster_list-NCL_element_23,Write only channel ,886
ENG253252-ENG259062-Node_to_cluster_list-NCL_element_24,Write only channel ,926
ENG253252-ENG260421-Node_to_cluster_list-NCL_element_25,Write only channel ,966
ENG253252-ENG261354-Node_to_cluster_list-NCL_element_26,Write only channel ,1006
ENG253252-ENG258201-Node_to_cluster_list-NCL_element_27,Write only channel ,1046
ENG253252-ENG260110-Node_to_cluster_list-NCL_element_28,Write only channel ,1086
ENG253252-ENG258645-Node_to_cluster_list-NCL_element_29,Write only channel ,1126
ENG253252-ENG261260-Node_to_cluster_list-NCL_element_3,Write only channel ,86
ENG253252-ENG259078-Node_to_cluster_list-NCL_element_30,Write only channel ,1166
ENG253252-ENG260192-Node_to_cluster_list-NCL_element_31,Write only channel ,1206
ENG253252-ENG259747-Node_to_cluster_list-NCL_element_32,Write only channel ,1246
ENG253252-ENG259375-Node_to_cluster_list-NCL_element_4,Write only channel ,126
ENG253252-ENG259916-Node_to_cluster_list-NCL_element_5,Write only channel ,166
ENG253252-ENG260559-Node_to_cluster_list-NCL_element_6,Write only channel ,206
ENG253252-ENG259415-Node_to_cluster_list-NCL_element_7,Write only channel ,246
ENG253252-ENG260302-Node_to_cluster_list-NCL_element_8,Write only channel ,286
ENG253252-ENG259224-Node_to_cluster_list-NCL_element_9,Write only channel ,326
[SFD ] ENG309781-NVEM_function_variant,Write only channel ,2
ENG253340-SFD_Testmode,Write only channel ,0
[EXTD] ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,Write only channel ,28
[EXTD] ENG253268-MAS03174-TCR_bus_can-Comfort data bus,Write only channel ,52
[EXTD] ENG253268-MAS03175-TCR_bus_can-Extended data bus,Write only channel ,124
[EXTD] ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,Write only channel ,76
[EXTD] ENG253268-MAS03178-TCR_bus_can-Suspension data bus,Write only channel ,100
[EXTD] ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,Write only channel ,4
[EXTD] ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,Write only channel ,148
[EXTD] ENG253268-MAS16910-TCR_bus_can-Migration data bus,Write only channel ,172
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,Write only channel ,28
ENG253184-MAS03180-TCR_bus_lin-Local data bus,Write only channel ,4
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,Write only channel ,52
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,Write only channel ,76
[EXTD] ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,Write only channel ,4
[EXTD] ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,Write only channel ,28
[EXTD] ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,Write only channel ,76
[EXTD] ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,Write only channel ,100
[EXTD] ENG253199-MAS18934-TCR_bus_vlan-VLAN Connect,Write only channel ,52
ENG376375-ENG376911-Test_Block_1-Test_Parameter_1,Write only channel ,5
ENG376375-ENG376919-Test_Block_1-Test_Parameter_1 (2),Write only channel ,37
ENG376375-ENG376920-Test_Block_1-Test_Parameter_1 (3),Write only channel ,69
ENG376375-ENG376921-Test_Block_1-Test_Parameter_1 (4),Write only channel ,101
ENG376375-ENG376922-Test_Block_1-Test_Parameter_1 (5),Write only channel ,133
ENG376375-ENG376923-Test_Block_1-Test_Parameter_1 (6),Write only channel ,165
ENG376375-ENG376924-Test_Block_1-Test_Parameter_1 (7),Write only channel ,197
ENG376375-ENG376925-Test_Block_1-Test_Parameter_1 (8),Write only channel ,229
ENG376376-ENG376911-Test_Block_2-Test_Parameter_1,Write only channel ,5
ENG376376-ENG376912-Test_Block_2-Test_Parameter_1 (10),Write only channel ,293
ENG376376-ENG376913-Test_Block_2-Test_Parameter_1 (11),Write only channel ,325
ENG376376-ENG376914-Test_Block_2-Test_Parameter_1 (12),Write only channel ,357
ENG376376-ENG376915-Test_Block_2-Test_Parameter_1 (13),Write only channel ,389
ENG376376-ENG376916-Test_Block_2-Test_Parameter_1 (14),Write only channel ,421
ENG376376-ENG376917-Test_Block_2-Test_Parameter_1 (15),Write only channel ,453
ENG376376-ENG376918-Test_Block_2-Test_Parameter_1 (16),Write only channel ,485
ENG376376-ENG376919-Test_Block_2-Test_Parameter_1 (2),Write only channel ,37
ENG376376-ENG376920-Test_Block_2-Test_Parameter_1 (3),Write only channel ,69
ENG376376-ENG376921-Test_Block_2-Test_Parameter_1 (4),Write only channel ,101
ENG376376-ENG376922-Test_Block_2-Test_Parameter_1 (5),Write only channel ,133
ENG376376-ENG376923-Test_Block_2-Test_Parameter_1 (6),Write only channel ,165
ENG376376-ENG376924-Test_Block_2-Test_Parameter_1 (7),Write only channel ,197
ENG376376-ENG376925-Test_Block_2-Test_Parameter_1 (8),Write only channel ,229
ENG376376-ENG376926-Test_Block_2-Test_Parameter_1 (9),Write only channel ,261
ENG376377-Test_Block_3,Write only channel ,2
ENG376378-Test_Block_4,Write only channel ,3
ENG376379-Test_Block_5,Write only channel ,4
ENG376380-Test_Block_6,Write only channel ,5
ENG376381-Test_Block_7,Write only channel ,4
ENG376382-Test_Block_8,Write only channel ,5
[EXTD] ENG376385-Traffic_Limit_on_ext_ETH-Ports,Write only channel %,2
[SFD ] ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,Write only channel ,11
[SFD ] ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,Write only channel ,58
[SFD ] ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,Write only channel ,66
[SFD ] ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,Write only channel min,74
[SFD ] ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,Write only channel s,2
[SFD ] ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,Write only channel s,27
[SFD ] ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,Write only channel s,43
Elapsed Time: 00:34
adpmap 17
    SW:571-920-340-A   HW:571-920-340 ---  17: Instruments
    Component:KOMBI         304 9460, Coding:042402457B9C00080880720B2000080810387C0000
    EV_DashBoardVDDMQB37W,005050,EV_DashBoardVDDMQB37W_005_VW42.rod
    Friday,19,June,2026,13:16:23:15875
    VCDS Version: 26.5.2.1 (x64)  Data version: 20260506 DS377.0
    VCID: 1078B25B5AE093BA462-8044 SFD [ ]
IDE00301-Distance,22657 km,3
IDE00343-Language variant,Czech ,1
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,733 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE02489-Display depiction,Variant 1 ,1
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03568-ENG262858-Service-key settings-p_deactivate_SK-Sub_Function_Current_Data,On ,5
IDE03568-ENG262855-Service-key settings-p_deactivate_SK-Sub_Function_Daily_Data,On ,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,OFF ,5
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-IDE12722-Configuration of displayable contents-Driving profile display,No display ,4
IDE11472-MAS01833-Configuration of displayable contents-Charge air pressure,not active ,4
IDE11472-MAS03555-Configuration of displayable contents-Lap counter,not active ,4
IDE11472-MAS03688-Configuration of displayable contents-Navigation information,not active ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS05757-Configuration of displayable contents-Engine torque,not active ,4
IDE11472-MAS14767-Configuration of displayable contents-Convenience tire pressure warning display,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,not active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE11472-MAS19327-Configuration of displayable contents-Engine performance,not active ,4
IDE11472-MAS19328-Configuration of displayable contents-Transmission temperature,not active ,4
IDE11472-MAS19329-Configuration of displayable contents-G-meter,not active ,4
IDE11472-MAS19330-Configuration of displayable contents-Torque distribution,not active ,4
IDE11472-MAS23291-Configuration of displayable contents-Color switch-over,not active ,4
IDE11472-MAS29813-Configuration of displayable contents-Warning rear seats display,not active ,4
IDE11472-MAS30856-Configuration of displayable contents-Driver assistance systems: environment graphics,Variant 1 ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12792-IDE00301-Personalization of user account 1-Distance,Kilometres ,70
IDE12792-MAS01230-Personalization of user account 1-Date,dd_mm_yy ,70
IDE12792-MAS01456-Personalization of user account 1-Speed,Kilometers per hour ,70
IDE12792-MAS02201-Personalization of user account 1-Temperature,°C ,70
IDE12792-MAS02957-Personalization of user account 1-Time,24h ,70
IDE12792-MAS03032-Personalization of user account 1-Volume,litre ,70
IDE12792-MAS03034-Personalization of user account 1-Pressure,bar ,70
IDE12792-MAS05637-Personalization of user account 1-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12792-MAS05638-Personalization of user account 1-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12792-MAS05875-Personalization of user account 1-Average consumption: electric drive,kWh per 100 km ,70
IDE12792-Personalization of user account 1-,not active ,70
IDE12792-ENG154881-Personalization of user account 1-Active_design,0 ,70
IDE12792-ENG154882-Personalization of user account 1-Active_view,0 ,70
IDE12792-ENG155000-Personalization of user account 1-DC_aktiverSpeicherplatz,0 ,70
IDE12792-ENG155001-Personalization of user account 1-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12792-ENG155002-Personalization of user account 1-DC_linkeTubeninformation,00 ,70
IDE12792-ENG155003-Personalization of user account 1-DC_rechteTubeninformation,00 ,70
IDE12792-ENG155004-Personalization of user account 1-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155005-Personalization of user account 1-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155006-Personalization of user account 1-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155007-Personalization of user account 1-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155008-Personalization of user account 1-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155009-Personalization of user account 1-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155051-Personalization of user account 1-Display_Average_Consumption,active ,70
IDE12792-ENG155052-Personalization of user account 1-Display_Average_Speed,active ,70
IDE12792-ENG155053-Personalization of user account 1-Display_ComfortPowerConsumption,not active ,70
IDE12792-ENG155054-Personalization of user account 1-Display_ConsumerList,not active ,70
IDE12792-ENG155055-Personalization of user account 1-Display_CoolantTemperature,not active ,70
IDE12792-ENG155056-Personalization of user account 1-Display_CurrentConsumption,active ,70
IDE12792-ENG155057-Personalization of user account 1-Display_DigitalSpeedometer,active ,70
IDE12792-ENG155058-Personalization of user account 1-Display_Distance,active ,70
IDE12792-ENG155059-Personalization of user account 1-Display_DrivingTime,active ,70
IDE12792-ENG155060-Personalization of user account 1-Display_DualSpeedometer,not active ,70
IDE12792-ENG155061-Personalization of user account 1-Display_Laptimer,not active ,70
IDE12792-ENG155062-Personalization of user account 1-Display_LiveTips,not active ,70
IDE12792-ENG155063-Personalization of user account 1-Display_Nachtankmenge,not active ,70
IDE12792-ENG155064-Personalization of user account 1-Display_OilTemperature,active ,70
IDE12792-ENG155065-Personalization of user account 1-Display_Range,active ,70
IDE12792-ENG155066-Personalization of user account 1-Display_ResetTime,not active ,70
IDE12792-ENG155067-Personalization of user account 1-Display_SpeedWarning,not active ,70
IDE12792-ENG155068-Personalization of user account 1-Display_VZA,active ,70
IDE12792-ENG155069-Personalization of user account 1-Display_ZeroEmission_Distance,not active ,70
IDE12792-ENG155070-Personalization of user account 1-Display_ZeroEmission_Time,not active ,70
IDE12792-ENG155246-Personalization of user account 1-LastMode_HMI_global_active_layout,0 ,70
IDE12792-ENG155247-Personalization of user account 1-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12792-ENG155248-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12792-ENG155249-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12792-ENG155250-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12792-ENG155251-Personalization of user account 1-LastMode_HMI_HistoryState_main,0 ,70
IDE12792-ENG155252-Personalization of user account 1-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12792-ENG155253-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12792-ENG155254-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12792-ENG155255-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12792-ENG155256-Personalization of user account 1-LastMode_HMI_HistoryState_sport,0 ,70
IDE12792-ENG155257-Personalization of user account 1-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12792-ENG155258-Personalization of user account 1-LastMode_HMI_MFA_store,0 ,70
IDE12792-ENG155259-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12792-ENG155260-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12792-ENG155261-Personalization of user account 1-LastMode_v_Kunde_aktiv,not active ,70
IDE12792-ENG155262-Personalization of user account 1-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12792-ENG155263-Personalization of user account 1-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12792-ENG262859-Personalization of user account 1-speed_value,0 ,70
IDE12792-ENG263509-Personalization of user account 1-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12794-IDE00301-Personalization of user account 2-Distance,Kilometres ,70
IDE12794-MAS01230-Personalization of user account 2-Date,dd_mm_yy ,70
IDE12794-MAS01456-Personalization of user account 2-Speed,Kilometers per hour ,70
IDE12794-MAS02201-Personalization of user account 2-Temperature,°C ,70
IDE12794-MAS02957-Personalization of user account 2-Time,24h ,70
IDE12794-MAS03032-Personalization of user account 2-Volume,litre ,70
IDE12794-MAS03034-Personalization of user account 2-Pressure,bar ,70
IDE12794-MAS05637-Personalization of user account 2-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12794-MAS05638-Personalization of user account 2-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12794-MAS05875-Personalization of user account 2-Average consumption: electric drive,kWh per 100 km ,70
IDE12794-Personalization of user account 2-,not active ,70
IDE12794-ENG154881-Personalization of user account 2-Active_design,0 ,70
IDE12794-ENG154882-Personalization of user account 2-Active_view,0 ,70
IDE12794-ENG155000-Personalization of user account 2-DC_aktiverSpeicherplatz,0 ,70
IDE12794-ENG155001-Personalization of user account 2-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12794-ENG155002-Personalization of user account 2-DC_linkeTubeninformation,00 ,70
IDE12794-ENG155003-Personalization of user account 2-DC_rechteTubeninformation,00 ,70
IDE12794-ENG155004-Personalization of user account 2-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155005-Personalization of user account 2-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155006-Personalization of user account 2-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155007-Personalization of user account 2-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155008-Personalization of user account 2-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155009-Personalization of user account 2-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155051-Personalization of user account 2-Display_Average_Consumption,active ,70
IDE12794-ENG155052-Personalization of user account 2-Display_Average_Speed,active ,70
IDE12794-ENG155053-Personalization of user account 2-Display_ComfortPowerConsumption,not active ,70
IDE12794-ENG155054-Personalization of user account 2-Display_ConsumerList,not active ,70
IDE12794-ENG155055-Personalization of user account 2-Display_CoolantTemperature,not active ,70
IDE12794-ENG155056-Personalization of user account 2-Display_CurrentConsumption,active ,70
IDE12794-ENG155057-Personalization of user account 2-Display_DigitalSpeedometer,active ,70
IDE12794-ENG155058-Personalization of user account 2-Display_Distance,active ,70
IDE12794-ENG155059-Personalization of user account 2-Display_DrivingTime,active ,70
IDE12794-ENG155060-Personalization of user account 2-Display_DualSpeedometer,not active ,70
IDE12794-ENG155061-Personalization of user account 2-Display_Laptimer,not active ,70
IDE12794-ENG155062-Personalization of user account 2-Display_LiveTips,not active ,70
IDE12794-ENG155063-Personalization of user account 2-Display_Nachtankmenge,not active ,70
IDE12794-ENG155064-Personalization of user account 2-Display_OilTemperature,active ,70
IDE12794-ENG155065-Personalization of user account 2-Display_Range,active ,70
IDE12794-ENG155066-Personalization of user account 2-Display_ResetTime,not active ,70
IDE12794-ENG155067-Personalization of user account 2-Display_SpeedWarning,not active ,70
IDE12794-ENG155068-Personalization of user account 2-Display_VZA,active ,70
IDE12794-ENG155069-Personalization of user account 2-Display_ZeroEmission_Distance,not active ,70
IDE12794-ENG155070-Personalization of user account 2-Display_ZeroEmission_Time,not active ,70
IDE12794-ENG155246-Personalization of user account 2-LastMode_HMI_global_active_layout,0 ,70
IDE12794-ENG155247-Personalization of user account 2-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12794-ENG155248-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12794-ENG155249-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12794-ENG155250-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12794-ENG155251-Personalization of user account 2-LastMode_HMI_HistoryState_main,0 ,70
IDE12794-ENG155252-Personalization of user account 2-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12794-ENG155253-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12794-ENG155254-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12794-ENG155255-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12794-ENG155256-Personalization of user account 2-LastMode_HMI_HistoryState_sport,0 ,70
IDE12794-ENG155257-Personalization of user account 2-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12794-ENG155258-Personalization of user account 2-LastMode_HMI_MFA_store,0 ,70
IDE12794-ENG155259-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12794-ENG155260-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12794-ENG155261-Personalization of user account 2-LastMode_v_Kunde_aktiv,not active ,70
IDE12794-ENG155262-Personalization of user account 2-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12794-ENG155263-Personalization of user account 2-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12794-ENG262859-Personalization of user account 2-speed_value,0 ,70
IDE12794-ENG263509-Personalization of user account 2-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12796-IDE00301-Personalization of user account 3-Distance,Kilometres ,70
IDE12796-MAS01230-Personalization of user account 3-Date,dd_mm_yy ,70
IDE12796-MAS01456-Personalization of user account 3-Speed,Kilometers per hour ,70
IDE12796-MAS02201-Personalization of user account 3-Temperature,°C ,70
IDE12796-MAS02957-Personalization of user account 3-Time,24h ,70
IDE12796-MAS03032-Personalization of user account 3-Volume,litre ,70
IDE12796-MAS03034-Personalization of user account 3-Pressure,bar ,70
IDE12796-MAS05637-Personalization of user account 3-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12796-MAS05638-Personalization of user account 3-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12796-MAS05875-Personalization of user account 3-Average consumption: electric drive,kWh per 100 km ,70
IDE12796-Personalization of user account 3-,not active ,70
IDE12796-ENG154881-Personalization of user account 3-Active_design,0 ,70
IDE12796-ENG154882-Personalization of user account 3-Active_view,0 ,70
IDE12796-ENG155000-Personalization of user account 3-DC_aktiverSpeicherplatz,0 ,70
IDE12796-ENG155001-Personalization of user account 3-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12796-ENG155002-Personalization of user account 3-DC_linkeTubeninformation,00 ,70
IDE12796-ENG155003-Personalization of user account 3-DC_rechteTubeninformation,00 ,70
IDE12796-ENG155004-Personalization of user account 3-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155005-Personalization of user account 3-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155006-Personalization of user account 3-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155007-Personalization of user account 3-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155008-Personalization of user account 3-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155009-Personalization of user account 3-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155051-Personalization of user account 3-Display_Average_Consumption,active ,70
IDE12796-ENG155052-Personalization of user account 3-Display_Average_Speed,active ,70
IDE12796-ENG155053-Personalization of user account 3-Display_ComfortPowerConsumption,not active ,70
IDE12796-ENG155054-Personalization of user account 3-Display_ConsumerList,not active ,70
IDE12796-ENG155055-Personalization of user account 3-Display_CoolantTemperature,not active ,70
IDE12796-ENG155056-Personalization of user account 3-Display_CurrentConsumption,active ,70
IDE12796-ENG155057-Personalization of user account 3-Display_DigitalSpeedometer,active ,70
IDE12796-ENG155058-Personalization of user account 3-Display_Distance,active ,70
IDE12796-ENG155059-Personalization of user account 3-Display_DrivingTime,active ,70
IDE12796-ENG155060-Personalization of user account 3-Display_DualSpeedometer,not active ,70
IDE12796-ENG155061-Personalization of user account 3-Display_Laptimer,not active ,70
IDE12796-ENG155062-Personalization of user account 3-Display_LiveTips,not active ,70
IDE12796-ENG155063-Personalization of user account 3-Display_Nachtankmenge,not active ,70
IDE12796-ENG155064-Personalization of user account 3-Display_OilTemperature,active ,70
IDE12796-ENG155065-Personalization of user account 3-Display_Range,active ,70
IDE12796-ENG155066-Personalization of user account 3-Display_ResetTime,not active ,70
IDE12796-ENG155067-Personalization of user account 3-Display_SpeedWarning,not active ,70
IDE12796-ENG155068-Personalization of user account 3-Display_VZA,active ,70
IDE12796-ENG155069-Personalization of user account 3-Display_ZeroEmission_Distance,not active ,70
IDE12796-ENG155070-Personalization of user account 3-Display_ZeroEmission_Time,not active ,70
IDE12796-ENG155246-Personalization of user account 3-LastMode_HMI_global_active_layout,0 ,70
IDE12796-ENG155247-Personalization of user account 3-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12796-ENG155248-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12796-ENG155249-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12796-ENG155250-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12796-ENG155251-Personalization of user account 3-LastMode_HMI_HistoryState_main,0 ,70
IDE12796-ENG155252-Personalization of user account 3-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12796-ENG155253-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12796-ENG155254-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12796-ENG155255-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12796-ENG155256-Personalization of user account 3-LastMode_HMI_HistoryState_sport,0 ,70
IDE12796-ENG155257-Personalization of user account 3-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12796-ENG155258-Personalization of user account 3-LastMode_HMI_MFA_store,0 ,70
IDE12796-ENG155259-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12796-ENG155260-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12796-ENG155261-Personalization of user account 3-LastMode_v_Kunde_aktiv,not active ,70
IDE12796-ENG155262-Personalization of user account 3-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12796-ENG155263-Personalization of user account 3-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12796-ENG262859-Personalization of user account 3-speed_value,0 ,70
IDE12796-ENG263509-Personalization of user account 3-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12798-IDE00301-Personalization of user account 4-Distance,Kilometres ,70
IDE12798-MAS01230-Personalization of user account 4-Date,dd_mm_yy ,70
IDE12798-MAS01456-Personalization of user account 4-Speed,Kilometers per hour ,70
IDE12798-MAS02201-Personalization of user account 4-Temperature,°C ,70
IDE12798-MAS02957-Personalization of user account 4-Time,24h ,70
IDE12798-MAS03032-Personalization of user account 4-Volume,litre ,70
IDE12798-MAS03034-Personalization of user account 4-Pressure,bar ,70
IDE12798-MAS05637-Personalization of user account 4-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12798-MAS05638-Personalization of user account 4-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12798-MAS05875-Personalization of user account 4-Average consumption: electric drive,kWh per 100 km ,70
IDE12798-Personalization of user account 4-,not active ,70
IDE12798-ENG154881-Personalization of user account 4-Active_design,0 ,70
IDE12798-ENG154882-Personalization of user account 4-Active_view,0 ,70
IDE12798-ENG155000-Personalization of user account 4-DC_aktiverSpeicherplatz,0 ,70
IDE12798-ENG155001-Personalization of user account 4-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12798-ENG155002-Personalization of user account 4-DC_linkeTubeninformation,00 ,70
IDE12798-ENG155003-Personalization of user account 4-DC_rechteTubeninformation,00 ,70
IDE12798-ENG155004-Personalization of user account 4-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155005-Personalization of user account 4-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155006-Personalization of user account 4-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155007-Personalization of user account 4-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155008-Personalization of user account 4-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155009-Personalization of user account 4-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155051-Personalization of user account 4-Display_Average_Consumption,active ,70
IDE12798-ENG155052-Personalization of user account 4-Display_Average_Speed,active ,70
IDE12798-ENG155053-Personalization of user account 4-Display_ComfortPowerConsumption,not active ,70
IDE12798-ENG155054-Personalization of user account 4-Display_ConsumerList,not active ,70
IDE12798-ENG155055-Personalization of user account 4-Display_CoolantTemperature,not active ,70
IDE12798-ENG155056-Personalization of user account 4-Display_CurrentConsumption,active ,70
IDE12798-ENG155057-Personalization of user account 4-Display_DigitalSpeedometer,active ,70
IDE12798-ENG155058-Personalization of user account 4-Display_Distance,active ,70
IDE12798-ENG155059-Personalization of user account 4-Display_DrivingTime,active ,70
IDE12798-ENG155060-Personalization of user account 4-Display_DualSpeedometer,not active ,70
IDE12798-ENG155061-Personalization of user account 4-Display_Laptimer,not active ,70
IDE12798-ENG155062-Personalization of user account 4-Display_LiveTips,not active ,70
IDE12798-ENG155063-Personalization of user account 4-Display_Nachtankmenge,not active ,70
IDE12798-ENG155064-Personalization of user account 4-Display_OilTemperature,active ,70
IDE12798-ENG155065-Personalization of user account 4-Display_Range,active ,70
IDE12798-ENG155066-Personalization of user account 4-Display_ResetTime,not active ,70
IDE12798-ENG155067-Personalization of user account 4-Display_SpeedWarning,not active ,70
IDE12798-ENG155068-Personalization of user account 4-Display_VZA,active ,70
IDE12798-ENG155069-Personalization of user account 4-Display_ZeroEmission_Distance,not active ,70
IDE12798-ENG155070-Personalization of user account 4-Display_ZeroEmission_Time,not active ,70
IDE12798-ENG155246-Personalization of user account 4-LastMode_HMI_global_active_layout,0 ,70
IDE12798-ENG155247-Personalization of user account 4-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12798-ENG155248-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12798-ENG155249-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12798-ENG155250-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12798-ENG155251-Personalization of user account 4-LastMode_HMI_HistoryState_main,0 ,70
IDE12798-ENG155252-Personalization of user account 4-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12798-ENG155253-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12798-ENG155254-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12798-ENG155255-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12798-ENG155256-Personalization of user account 4-LastMode_HMI_HistoryState_sport,0 ,70
IDE12798-ENG155257-Personalization of user account 4-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12798-ENG155258-Personalization of user account 4-LastMode_HMI_MFA_store,0 ,70
IDE12798-ENG155259-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12798-ENG155260-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12798-ENG155261-Personalization of user account 4-LastMode_v_Kunde_aktiv,not active ,70
IDE12798-ENG155262-Personalization of user account 4-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12798-ENG155263-Personalization of user account 4-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12798-ENG262859-Personalization of user account 4-speed_value,0 ,70
IDE12798-ENG263509-Personalization of user account 4-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12800-IDE00301-Personalization of user account 5-Distance,Kilometres ,70
IDE12800-MAS01230-Personalization of user account 5-Date,dd_mm_yy ,70
IDE12800-MAS01456-Personalization of user account 5-Speed,Kilometers per hour ,70
IDE12800-MAS02201-Personalization of user account 5-Temperature,°C ,70
IDE12800-MAS02957-Personalization of user account 5-Time,24h ,70
IDE12800-MAS03032-Personalization of user account 5-Volume,litre ,70
IDE12800-MAS03034-Personalization of user account 5-Pressure,bar ,70
IDE12800-MAS05637-Personalization of user account 5-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12800-MAS05638-Personalization of user account 5-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12800-MAS05875-Personalization of user account 5-Average consumption: electric drive,kWh per 100 km ,70
IDE12800-Personalization of user account 5-,not active ,70
IDE12800-ENG154881-Personalization of user account 5-Active_design,0 ,70
IDE12800-ENG154882-Personalization of user account 5-Active_view,0 ,70
IDE12800-ENG155000-Personalization of user account 5-DC_aktiverSpeicherplatz,0 ,70
IDE12800-ENG155001-Personalization of user account 5-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12800-ENG155002-Personalization of user account 5-DC_linkeTubeninformation,00 ,70
IDE12800-ENG155003-Personalization of user account 5-DC_rechteTubeninformation,00 ,70
IDE12800-ENG155004-Personalization of user account 5-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155005-Personalization of user account 5-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155006-Personalization of user account 5-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155007-Personalization of user account 5-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155008-Personalization of user account 5-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155009-Personalization of user account 5-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155051-Personalization of user account 5-Display_Average_Consumption,active ,70
IDE12800-ENG155052-Personalization of user account 5-Display_Average_Speed,active ,70
IDE12800-ENG155053-Personalization of user account 5-Display_ComfortPowerConsumption,not active ,70
IDE12800-ENG155054-Personalization of user account 5-Display_ConsumerList,not active ,70
IDE12800-ENG155055-Personalization of user account 5-Display_CoolantTemperature,not active ,70
IDE12800-ENG155056-Personalization of user account 5-Display_CurrentConsumption,active ,70
IDE12800-ENG155057-Personalization of user account 5-Display_DigitalSpeedometer,active ,70
IDE12800-ENG155058-Personalization of user account 5-Display_Distance,active ,70
IDE12800-ENG155059-Personalization of user account 5-Display_DrivingTime,active ,70
IDE12800-ENG155060-Personalization of user account 5-Display_DualSpeedometer,not active ,70
IDE12800-ENG155061-Personalization of user account 5-Display_Laptimer,not active ,70
IDE12800-ENG155062-Personalization of user account 5-Display_LiveTips,not active ,70
IDE12800-ENG155063-Personalization of user account 5-Display_Nachtankmenge,not active ,70
IDE12800-ENG155064-Personalization of user account 5-Display_OilTemperature,active ,70
IDE12800-ENG155065-Personalization of user account 5-Display_Range,active ,70
IDE12800-ENG155066-Personalization of user account 5-Display_ResetTime,not active ,70
IDE12800-ENG155067-Personalization of user account 5-Display_SpeedWarning,not active ,70
IDE12800-ENG155068-Personalization of user account 5-Display_VZA,active ,70
IDE12800-ENG155069-Personalization of user account 5-Display_ZeroEmission_Distance,not active ,70
IDE12800-ENG155070-Personalization of user account 5-Display_ZeroEmission_Time,not active ,70
IDE12800-ENG155246-Personalization of user account 5-LastMode_HMI_global_active_layout,0 ,70
IDE12800-ENG155247-Personalization of user account 5-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12800-ENG155248-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12800-ENG155249-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12800-ENG155250-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12800-ENG155251-Personalization of user account 5-LastMode_HMI_HistoryState_main,0 ,70
IDE12800-ENG155252-Personalization of user account 5-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12800-ENG155253-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12800-ENG155254-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12800-ENG155255-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12800-ENG155256-Personalization of user account 5-LastMode_HMI_HistoryState_sport,0 ,70
IDE12800-ENG155257-Personalization of user account 5-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12800-ENG155258-Personalization of user account 5-LastMode_HMI_MFA_store,0 ,70
IDE12800-ENG155259-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12800-ENG155260-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12800-ENG155261-Personalization of user account 5-LastMode_v_Kunde_aktiv,not active ,70
IDE12800-ENG155262-Personalization of user account 5-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12800-ENG155263-Personalization of user account 5-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12800-ENG262859-Personalization of user account 5-speed_value,0 ,70
IDE12800-ENG263509-Personalization of user account 5-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12802-IDE00301-Personalization of user account 6-Distance,Kilometres ,70
IDE12802-MAS01230-Personalization of user account 6-Date,dd_mm_yy ,70
IDE12802-MAS01456-Personalization of user account 6-Speed,Kilometers per hour ,70
IDE12802-MAS02201-Personalization of user account 6-Temperature,°C ,70
IDE12802-MAS02957-Personalization of user account 6-Time,24h ,70
IDE12802-MAS03032-Personalization of user account 6-Volume,litre ,70
IDE12802-MAS03034-Personalization of user account 6-Pressure,bar ,70
IDE12802-MAS05637-Personalization of user account 6-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12802-MAS05638-Personalization of user account 6-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12802-MAS05875-Personalization of user account 6-Average consumption: electric drive,kWh per 100 km ,70
IDE12802-Personalization of user account 6-,not active ,70
IDE12802-ENG154881-Personalization of user account 6-Active_design,0 ,70
IDE12802-ENG154882-Personalization of user account 6-Active_view,0 ,70
IDE12802-ENG155000-Personalization of user account 6-DC_aktiverSpeicherplatz,0 ,70
IDE12802-ENG155001-Personalization of user account 6-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12802-ENG155002-Personalization of user account 6-DC_linkeTubeninformation,00 ,70
IDE12802-ENG155003-Personalization of user account 6-DC_rechteTubeninformation,00 ,70
IDE12802-ENG155004-Personalization of user account 6-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155005-Personalization of user account 6-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155006-Personalization of user account 6-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155007-Personalization of user account 6-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155008-Personalization of user account 6-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155009-Personalization of user account 6-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155051-Personalization of user account 6-Display_Average_Consumption,active ,70
IDE12802-ENG155052-Personalization of user account 6-Display_Average_Speed,active ,70
IDE12802-ENG155053-Personalization of user account 6-Display_ComfortPowerConsumption,not active ,70
IDE12802-ENG155054-Personalization of user account 6-Display_ConsumerList,not active ,70
IDE12802-ENG155055-Personalization of user account 6-Display_CoolantTemperature,not active ,70
IDE12802-ENG155056-Personalization of user account 6-Display_CurrentConsumption,active ,70
IDE12802-ENG155057-Personalization of user account 6-Display_DigitalSpeedometer,active ,70
IDE12802-ENG155058-Personalization of user account 6-Display_Distance,active ,70
IDE12802-ENG155059-Personalization of user account 6-Display_DrivingTime,active ,70
IDE12802-ENG155060-Personalization of user account 6-Display_DualSpeedometer,not active ,70
IDE12802-ENG155061-Personalization of user account 6-Display_Laptimer,not active ,70
IDE12802-ENG155062-Personalization of user account 6-Display_LiveTips,not active ,70
IDE12802-ENG155063-Personalization of user account 6-Display_Nachtankmenge,not active ,70
IDE12802-ENG155064-Personalization of user account 6-Display_OilTemperature,active ,70
IDE12802-ENG155065-Personalization of user account 6-Display_Range,active ,70
IDE12802-ENG155066-Personalization of user account 6-Display_ResetTime,not active ,70
IDE12802-ENG155067-Personalization of user account 6-Display_SpeedWarning,not active ,70
IDE12802-ENG155068-Personalization of user account 6-Display_VZA,active ,70
IDE12802-ENG155069-Personalization of user account 6-Display_ZeroEmission_Distance,not active ,70
IDE12802-ENG155070-Personalization of user account 6-Display_ZeroEmission_Time,not active ,70
IDE12802-ENG155246-Personalization of user account 6-LastMode_HMI_global_active_layout,0 ,70
IDE12802-ENG155247-Personalization of user account 6-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12802-ENG155248-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12802-ENG155249-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12802-ENG155250-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12802-ENG155251-Personalization of user account 6-LastMode_HMI_HistoryState_main,0 ,70
IDE12802-ENG155252-Personalization of user account 6-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12802-ENG155253-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12802-ENG155254-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12802-ENG155255-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12802-ENG155256-Personalization of user account 6-LastMode_HMI_HistoryState_sport,0 ,70
IDE12802-ENG155257-Personalization of user account 6-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12802-ENG155258-Personalization of user account 6-LastMode_HMI_MFA_store,0 ,70
IDE12802-ENG155259-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12802-ENG155260-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12802-ENG155261-Personalization of user account 6-LastMode_v_Kunde_aktiv,not active ,70
IDE12802-ENG155262-Personalization of user account 6-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12802-ENG155263-Personalization of user account 6-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12802-ENG262859-Personalization of user account 6-speed_value,0 ,70
IDE12802-ENG263509-Personalization of user account 6-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12804-IDE00301-Personalization of user account 7-Distance,Kilometres ,70
IDE12804-MAS01230-Personalization of user account 7-Date,dd_mm_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Kilometers per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature,°C ,70
IDE12804-MAS02957-Personalization of user account 7-Time,24h ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,litre ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,bar ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,kWh per 100 km ,70
IDE12804-Personalization of user account 7-,not active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,0 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG262859-Personalization of user account 7-speed_value,0 ,70
IDE12804-ENG263509-Personalization of user account 7-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,4300 km,2
IDE12963-Oil: thermal loading,20000 km,2
IDE12964-Oil: driven distance since last oil service,3800 km,3
IDE12965-Oil: time since last oil service,217 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),30000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,30000 km,3
IDE12979-Inspection: time until next inspection,730 d,2
IDE12980-Inspection: distance driven since the last inspection,3800 km,3
IDE12981-Inspection: time since the last inspection,217 d,2
IDE12982-Inspection: distance reset value,30000 km,2
IDE12983-Inspection: time reset value,365 d,2
IDE13031-MAS03935-Long-term store-Driving time,0 min,44
IDE13031-MAS15517-Long-term store-Travel distance,0 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,0 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,0 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,0 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,0 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.000 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.000 kWh,44
IDE13094-Tachometer end value,Variant 4 ,1
IDE13275-IDE00301-Personalization default value-Distance,Kilometres ,70
IDE13275-MAS01230-Personalization default value-Date,dd_mm_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Kilometers per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature,°C ,70
IDE13275-MAS02957-Personalization default value-Time,24h ,70
IDE13275-MAS03032-Personalization default value-Volume,litre ,70
IDE13275-MAS03034-Personalization default value-Pressure,bar ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,kWh per 100 km ,70
IDE13275-Personalization default value-,not active ,70
IDE13275-ENG154881-Personalization default value-Active_design,0 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,not active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,not active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,0 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,5 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG262859-Personalization default value-speed_value,0 ,70
IDE13275-ENG263509-Personalization default value-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE13441-Secondary speed in case of unit replacement,Display ,1
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14112-Gas system test - warning reset,No ,1
IDE14116-Gas system test - warning time,1443 d,2
IDE14123-MAS01129-Design variant activation-Variant 1,not active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,Yes ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,0 s,1
IDE14222-Test number length: authentic time,16 B,1
IDE14875-MAS19483-Activation of views-View 1,active ,2
IDE14875-MAS19484-Activation of views-View 2,not active ,2
IDE14875-MAS19485-Activation of views-View 3,active ,2
IDE14875-MAS19486-Activation of views-View 4,active ,2
IDE14875-MAS19487-Activation of views-View 5,not active ,2
IDE14875-MAS19488-Activation of views-View 6,active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,active ,2
IDE14875-MAS19491-Activation of views-View 9,not active ,2
IDE14875-MAS19492-Activation of views-View 10,not active ,2
IDE14875-MAS19493-Activation of views-View 12,not active ,2
IDE14875-MAS19494-Activation of views-View 11,not active ,2
IDE14875-MAS19495-Activation of views-View 13,active ,2
IDE14875-MAS19496-Activation of views-View 14,not active ,2
IDE14875-MAS19497-Activation of views-View 15,not active ,2
IDE14875-MAS19498-Activation of views-View 16,not active ,2
IDE15080-Logo,logo_2 ,1
IDE15909-Removable seats,Layout normal ,1
IDE17327-MAS01877-Tachometer color setting-Red,0 ,3
IDE17327-MAS01878-Tachometer color setting-Green,0 ,3
IDE17327-MAS01879-Tachometer color setting-Blue,0 ,3
IDE18473-WLTP concept,Default WLTP ,1
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,No ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
MAS01083-IDE18009-Country Variant-Canada variant,No ,2
MAS01758-IDE00500-Date / time-Hour,13 H,6
MAS01758-IDE00501-Date / time-Minute,16 min,6
MAS01758-IDE00502-Date / time-Year,2026 yr,6
MAS01758-IDE00503-Date / time-Month,6 Months,6
MAS01758-IDE00504-Date / time-Day,19 d,6
ENG309777-Aktivierung IPA,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG262830-Correction_factor_consumption_and_operating_range_electric,100 %,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,96 ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,9 ‰,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,9 ‰,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,16 ‰,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,56 ‰,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,400 ‰,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,1000 ‰,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.0 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.0 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.0 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.0 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.0 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.0 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.0 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.0 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.0 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.0 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.0 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.0 %,24
ENG316729-ESI_Maximum_mileage_to_next_service_ZDC,30000 km,2
ENG316730-ESI_Maximum_time_to_next_service_ZDC,730 d,2
ENG316731-ESI_Minimum_mileage_to_next_service_ZDC,15000 km,2
ENG316732-ESI_Minimum_time_to_next_service_ZDC,365 d,2
ENG316733-ESI_Oil_quality_ZDC,poor oil quality ,1
ENG316701-FIX_Maximum_distance_to_next_mileage_based_service_event_zdc,30000 km,3
ENG316702-FIX_Maximum_time_to_next_time_based_service_event_zdc,1095 d,2
ENG316734-FIX_resetvalue_distance_to_next_mileage_based_service_events_ZDC,30000 km,2
ENG316735-FIX_resetvalue_time_to_next_mileage_based_service_events_ZDC,365 d,2
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4.0 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6.0 °C,16
ENG135292-phev_stat_intervall-,1.0 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.0 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.0 s,7
ENG135292-phev_stat_intervall-,00000000 00010000  ,7
ENG316738-SID_Maximum_mileage_to_next_oil_service_ZDC,15000 km,2
ENG316739-SID_Maximum_time_to_next_oil_service_ZDC,365 d,2
ENG262832-Switching_Networking,Ethernet ,1
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.50 ,18
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:47
Paskal
Czech Republic
C?ID=508876
What does an error in the A5 control unit mean - bad coding or adaptation?
The service said that they did not see any error in the A5 - but that seems like nonsense to me.
Because the position storage stopped working. The service said that they were waiting for a software update because of this.
I think it's from the close-range radars. Occasional sensor blindness can have various external causes.
ODIS is probably programmed to ignore those faults.
PS: I just noticed how your interface is registered, with your initials only. We should not have approved SFD service like that and have better controls for this now, but I would appreciate it if you would fix that by registering you interface with your real name.
Eric
HC800000
Weird, the 17 AdpMap was made with SFD unlocked and therefore not R-mode, but we didn't get SFD protection information like we did in 19. Maybe that SFD1 module doesn't support that function.
zoyichka
Australia
C?ID=638642
By the look of the scan, your Passat and my Superb started their motoring careers on the same production line in Bratislava.
You’d have the 15” infotainment display featuring “Ida” and capacitive-touch HVAC, whereas I have the more modest 13” unit with “Laura” living rent-free inside the dashboard, physical LCD rotary/push “Smart Dials” for drive modes and HVAC. Very cool to see two differently packaged vehicles with mostly identical DNA. I’ll post my scan in a new before I head to work.
Paskal
Czech Republic
C?ID=508876
Hello UWE
I've fixed it.
I received the email and am waiting for the review.
I also think it will be the rear radars.
Because they behave strangely. Example: I'm standing at an intersection at traffic lights and the Dashboard shows me that I can park, even though there are other cars behind me.
I also think that this is why (blindness) the memory parking position and parking plus don't work. It says "This function is currently unavailable"
In 2 weeks I'm going to update it, because of this they called me from the service (that I'm not the only one who doesn't have it working) that they were advised by support. That they should try it and test if it will work after the update.
Paskal
Czech Republic
C?ID=508876
Weird, the 17 AdpMap was made with SFD unlocked and therefore not R-mode. Maybe that SFD1 module doesn't support that function.
It is possible that it is not supported by this module 17
Paskal
Czech Republic
C?ID=508876
So I went to VW service on Wednesday for a software repair (support recommended them to try uploading some software there) - for Park Assist Plus. The car stayed there for 1 day, but unfortunately it didn't help (I don't know what they uploaded there)
So I have to wait again for Vivino to update the software for Park Assist Plus. They've been working on that update since April. They told me I'm not the only one with such a problem.
Hold on, I'm disappointed, VW is no longer what it used to be. VW goes from 10 to 5 :banghead:
Eric
HC800000
It's too late now, but before anyone goes to get a reflash, I would advise getting a vehicle map of the Advanced ID, and then get another one after the reflash. This way you can compare which modules and which datasets got updated.
Paskal
Czech Republic
C?ID=508876
@Eric
Sorry, I forgot to write in the post that I made a backup of the coding and customization before taking the car to the service.
I was at a colleague's place and he made a backup for me with Odis.
When I have time on the weekend (I'll go to my colleague's place) I'll check what they tried to change.
Paskal
Czech Republic
C?ID=508876
Odis backup - then I'll check it.
I had Odis make that backup so I could compare it to the same data that VW service uses.
Contents
Installation overview
0001 - Engine electronics
001 Identification 006 Load coding 007 Load adaptation
0002 - Transmission electronics
001 Identification 007 Load adaptation
0003 - Brake electronics
0008 - Air conditioning/heating electronics
0009 - Central electronic unit
0013 - Distance control
0014 - Wheel damping electronics
0015 - Airbag
0016 - Steering column electronics
0017 - Instrument cluster
0018 - Auxiliary/auxiliary heater
0019 - Diagnostic data bus interface
0023 - Brake servo
002B - Steering column lock
001 Identification 006 Load coding 007 Load customization
0042 - Driver's door electronics
0044 - Power steering
004B - Multifunction module
0052 - Passenger door electronics
005F - Information electronics 1
0069 - Trailer function
006C - Reverse system cameras
006D - Tailgate electronics
0076 - Parking assistance
0082 - Head-up display
00A5 - Driver assistance system front sensors
00B7 - Access and start system interface
00BB - Driver side rear door electronics
00BC - Rear door electronics on passenger side
00C4 - Voltage converter
001 Identification
00CA - Sliding roof control unit
00D6 - Left light control 2
00D7 - Right light control 2
00DE - Mobile terminal charger 1
8107 - Antenna module
8109 - Short range radar 1
810A - Short range radar 2
810B - Short range radar 3
810C - Short range radar 4
8117 - Rear view camera
811E - Intrusion protection control unit 1 PL
811F - Intrusion protection control unit 2 PP
8120 - Intrusion protection control unit 3 ZL
8121 - Intrusion protection control unit 4 ZP
Paskal
Czech Republic
C?ID=508876
New AutoScan Beta version 26.7.0.1
Sunday,26,July,2026,16:50:50:15875
VCDS Version: 26.7.0.1 (x64) HEX-V2 CB: 0.4713.4
Data version: 20260708 DS378.0
VIN: WVWZZZCJXRD029582 License Plate:
Chassis Type: CJ-VW49 (5QS)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 23 2B 42 44 4B 52
5F 69 6C 6D 75 82 A5 BB BC CA D6 D7 DE 8107 8109 810A 810B 810C 8117 811E
811F 8120 8121 C002 C003
VIN: WVWZZZCJXRD029582 Mileage: 22841km-14192miles
CA-Sunroof -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8109-Close Rge Radar 1 -- Status: OK 0000
810A-Close Rge Radar 2 -- Status: OK 0000
810B-Close Rge Radar 3 -- Status: OK 0000
810C-Close Rge Radar 4 -- Status: OK 0000
8117-Rear surroundings cam -- Status: OK 0000
Address 01: Engine (J623-DXPA) Labels: Redir Fail!
Part No SW: 05L 906 022 DL HW: 05L 907 309 AG
Component: R4 2.0l TDI H80 4618
Revision: NEH80--- Dataset Number: V03935407XE 0001 CVN: EC2033D610A70AD22DB0E9639EAA3CA82DB0E96345690194
Coding: 0125003A03741D0870080000001000000000000000000000
Shop #: WSC 19062 004 1048576
ASAM Dataset: EV_ECM20TDI01105L906022DL 010012
ROD: EV_ECM20TDI01105L906022DL.rod
VCID: 74B0DECB4E38CF9ACBA-8020-R SFD+SFD2 [x]
VINID: 9E69EAAAA4DAA22500089148086D605579
Radiator shutter:
Subsystem 1 - Part No SW: 5QS 965 501 E HW: 5QS 965 501 E
Component: V544_SAB_XS_1 H03 0003
Serial number: 20240504060506052152
Radiator louver 2:
Heater for exhaust gas catalytic converter:
Flush-air pump:
Active oil separating system:
Part No SW: 0GC 906 555 GA HW: 0GC 300 058 K
Component: GSG DQ381 H06 0661
CVN: C03E69A6
ASAM Dataset: EV_TCMDQ381064 001011
ROD: EV_TCMDQ381064.rod
VCID: 0058821B0A80E33ADF2-8054-R SFD [x]
Parking lock:
Subsystem 1 - Part No SW: 5QS 907 483 A HW: 5QS 907 483
Component: SB_Auto H02 0060
Serial number: 9244762000668005
MTF pump:
Subsystem 2 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810700006589953
Address 03: ABS Brakes (J104) Labels: 3WA-614-517-V1.clb
Part No SW: 3WA 614 517 AM HW: 3WA 614 517 D
Component: EBC470IESCH09 0390
Serial number: 0000000 Dataset Number: V03935469WZ 0001 CVN: CE1340
Coding: 2C285124A48B399C410799AC9EB701040583952149A8
ASAM Dataset: EV_Brake1ZFESCEPBMQB48W 002068
ROD: EV_Brake1ZFESCEPBMQB48W_002.rod
VCID: 117EB75F51EA9AB240C-8044-R SFD+SFD2 [x]
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 AD HW: 5WA 959 436 N
Component: Kessy IOBOX 122 0771
Serial number: --------------- Dataset Number: V03935407SN 0001
ASAM Dataset: EV_Kessy37w 005030
ROD: EV_Kessy37w_005_VW38.rod
VCID: 1674C44378047D8A15E-8042-R
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 3WA 907 007 F HW: 3WA 907 007
Component: Climatronic H01 5089
Serial number: 218052419584550 Dataset Number: V03935469TY 0001
Coding: 212010244111120010201010111011110000132110200000000000000000
ASAM Dataset: EV_ACClimaBHBE3ADV 002062
ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
VCID: 48C85A3B62301B7A572-801C-R SFD+SFD2 [x]
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00002110524003547505
Air quality sensor:
Subsystem 2 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 00000000010000373347
Subsystem 3 - Part No SW: 11A 907 049 B HW: 11A 907 049 B
Component: E265 KPH SH H02 0184
Serial number: G07S10.04.2400970512
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 084 AG HW: 5WA 937 084 R
Component: BCM37w_H H26 0326
Serial number: 051024139040210 Dataset Number: V03935462SS 0001
ASAM Dataset: EV_BCMwBL 004001
ROD: EV_BCMwBL_004.rod
VCID: 1470BE4B6EF86F9A6BA-8040-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 3J1 955 119 HW: 3J1 955 119
Component: WISCHER_MYJTL 006 0093
Serial number: VZ1SKA25052441008924
Subsystem 2 - Part No SW: 89A 955 555 B HW: 89A 955 555 B
Component: G397_RLFSS 004 0007
Serial number: MRO71305062400013271
Subsystem 3 - Part No SW: 571 941 633 A HW: 571 941 633 A
Component: E1 - LiAM H05 0070
Serial number: 07S03.05.2426791333
Subsystem 4 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000004531212
Subsystem 5 - Part No SW: 5Q0 951 172 C HW: 5Q0 951 172 C
Component: Sensor, DWA 006 0501
Serial number: 0000000000000Q3DEP39
Subsystem 6 - Part No SW: 3J0 959 561 B HW: 3J0 959 561 B
Component: -VW----LINDA- 550 0851
Serial number: SYLLND02052400021477
Valve block 1 in front seat driver side:
Subsystem 7 - Part No SW: 14A 881 643 B HW: 14A 881 643 B
Component: J873 MKS_FSv H02 0152
Serial number: 7009362240C242003554
Valve block 1 in front seat passenger side:
Subsystem 8 - Part No SW: 14A 881 643 B HW: 14A 881 643 B
Component: J872 MKS_BFSv H02 0152
Serial number: 7009362240C241801454
Power rear lid opening control module:
Subsystem 9 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 45146716
Left taillight 1:
Subsystem 10 - Part No SW: 3J0 945 207 HW: 3J0 945 207
Component: SHL_li1 H03 0107
Serial number: 21005305b004bf40A000
Left taillight 2:
Subsystem 11 - Part No SW: 3J0 945 307 HW: 3J0 945 307
Component: SHL_li2 H03 0107
Serial number: 21005306E004E5C0B000
Right taillight 1:
Subsystem 12 - Part No SW: 3J0 945 208 HW: 3J0 945 208
Component: SHL_re1 H03 0107
Serial number: 21005305E004ABB0B000
Right taillight 2:
Subsystem 13 - Part No SW: 3J0 945 307 HW: 3J0 945 307
Component: SHL_re2 H03 0107
Serial number: 21005306e004b7b0A000
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5QS 919 300 B HW: 5QS 919 300
Component: IPA 12ch high H01 0179
Serial number: 000025052495580 Dataset Number: V03935448GJ 0001
Coding: 8A30126111
ASAM Dataset: EV_EPHBO3CVW3360000 001014
ROD: EV_EPHBO3CVW3360000_VW42.rod
VCID: 51FE775F916ADAB200C-8004-R
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 1N3 907 567 D HW: 1N3 907 819
Component: ACC Bosch MQB H02 0436
Dataset Number: V03935485SC 0001
Coding: 0E8930EF4071404040020008000040C0010020008004000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW412 002016
ROD: EV_FRONTRADARBOSCHVW412_002_VW41.rod
VCID: 38282AFB12D06BFA272-806C-R SFD+SFD2 [x]
Address 14: Susp. Elect. (J250) Labels: 5QS-907-376.clb
Part No SW: 5QS 907 376 G HW: 5QS 907 376 F
Component: DAEMPFUNGS-SG H08 0607
Serial number: AAA214500081705 Dataset Number: V03935471DP 0001
ASAM Dataset: EV_DCC4CONTITEMIC 005012
ROD: EV_DCC4CONTITEMIC.rod
VCID: 6098A29BEAC0433ABF2-8034-R
Address 15: Airbags (J234) Labels:| 5QS-959-655.clb
Part No SW: 5QS 959 655 S HW: 5QS 959 655
Component: AirbagVW50 004 0131
Serial number: 000000003C0MYRB Dataset Number: V03935459GJ 0001
Coding: 98CC008000F0C000000000000000000051540000A1540000C000F680002B40A7
ASAM Dataset: EV_AirbaVW50SMEVW49X 001014
ROD: EV_AirbaVW50SMEVW49X.rod
VCID: 73B2DDD74B36C8A2D20-8026-R SFD+SFD2 [x]
Left seat belt tensioner:
Subsystem 1 - Part No SW: 85E 980 945 D HW: 85E 980 945 D
Component: BeltPretRevFL 002 3040
Serial number: 3J0857705C0137Y00272
Right seat belt tensioner:
Subsystem 2 - Part No SW: 85E 980 946 D HW: 85E 980 946 D
Component: BeltPretRevFR 002 3040
Serial number: 3J0857706C0148Y00132
Subsystem 3 - Part No SW: ----------- HW: 480 000 40B 17
Serial number: 35700003C4894B874A60
Subsystem 4 - Part No SW: ----------- HW: 480 000 504 18
Serial number: 35800007D48D46A67E40
Subsystem 5 - Part No SW: ----------- HW: 480 051 105 18
Component: SideSensor_Dr 000 0149
Serial number: 3510000B2D12C148A430
Subsystem 6 - Part No SW: ----------- HW: 480 051 105 18
Component: SideSensor_Pr 000 0149
Serial number: 3520000C6D12C14B2A20
Subsystem 7 - Part No SW: ----------- HW: 480 051 E04 18
Component: FrontSensor_D 000 014A
Serial number: 3550000A8D0C630B89F0
Subsystem 8 - Part No SW: ----------- HW: 480 051 E04 18
Component: FrontSensor_P 000 014A
Serial number: 3560000A8D0C630B6850
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 9 - Part No SW: ----------- HW: 480 051 105 18
Component: Side_Sens_B_D 000 0149
Serial number: I0P0000BAD12C14B0980
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 10 - Part No SW: ----------- HW: 480 051 105 18
Component: Side_Sens_B_P 000 0149
Serial number: I0Q0000AED12C14D4A40
Address 16: Steering wheel (J527) Labels: 1EE-953-507.clb
Part No SW: 1EE 953 507 M HW: 1EE 953 507 M
Component: GSMMEB 005 0066
Serial number: 000000030624477
ASAM Dataset: EV_SMLSKLOGEN2 009005
ROD: EV_SMLSKLOGEN2_009_VW49.rod
VCID: 45D6530F55220612AC4-8010-R SFD [x]
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 571 920 340 A HW: 571 920 340
Component: KOMBI 304 9460
Dataset Number: V03935440WZ 0001
Coding: 042402457B9C00080880720B2000080810387C0000
ASAM Dataset: EV_DashBoardVDDMQB37W 005050
ROD: EV_DashBoardVDDMQB37W_005_VW42.rod
VCID: 1078B25B5AE093BA4F2-8044-R SFD [x]
Address 18: Aux. Heat (J364) Labels:| 5WA-963-27x-V1.clb
Part No SW: 3J0 963 272 A HW: 3J0 963 272 A
Component: STH-VW37x 006 0002
Serial number: 000000000000416 Dataset Number: V03935403YG 0001
Coding: 2D1B155A5C25162CE46D19
ASAM Dataset: EV_AuxilHeateWOSVW38X 003004
ROD: EV_AuxilHeateWOSVW38X.rod
VCID: 2B0205B7D386D0625A0-807E-R
Address 19: CAN Gateway (J533-----) Labels:* None
Part No SW: 5QS 907 530 B HW: 5QS 907 530
Component: GW MQB 23 005 3093
Serial number: SMERBG230524007 Dataset Number: V03935467YA 0001
Coding: 000000000000000000000000000000000000000000000300030000000000000000000000000000000000000000000000
GVL: 3D08080002E8C08C80408046CC00104004006002007C00020200000000000054
ASAM Dataset: EV_GatewMQBwBL 001018
ROD: EV_GatewMQBwBL_VW41.rod
VCID: 53F27D57AB76A8A2320-8006 SFD+SFD2 [x]
Generator:
Component: 5-01-18-01-03
Subsystem 2 - Part No SW: 5QS 915 181 HW: 5QS 915 181
Component: J367-BDMHella H01 2362
Serial number: 8056154406
Inverter for socket:
Subsystem 3 - Part No SW: 5H0 907 155 HW: 5H0 907 155
Component: Inverter H06 0060
Serial number: 5ZJSHFT1701240001071
Subsystem 4 - Part No SW: 571 959 442 C HW: 571 959 442 C
Component: E221__MFL-PR6 H07 0130
Serial number: PR6-0440079142242361
Subsystem 5 - Part No SW: 5H0 959 542 N HW: 5H0 959 542 N
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA25212158301
Address 23: Brake Booster (J539) Labels: None
Part No SW: 3WA 909 059 R HW: 3WA 909 059 B
Component: EBB-ZF-Gen1 H06 0486
Serial number: 5100164 Dataset Number: V03935476RN 0001
Coding: 201010200040E8
ASAM Dataset: EV_BrakeBoostZFMQB48W 001072
ROD: EV_BrakeBoostZFMQB48W_001.rod
VCID: 5DE69B6FDDB26ED2944-8008-R SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764) Labels:. 3WA-905-861.clb
Part No SW: 3WA 905 861 HW: 3WA 905 861
Component: ELV-MQB_UNECE H05 0063
Serial number: 24000099768010 Dataset Number: V03935398ZW 0001
Coding: 8820000000000000
Shop #: WSC 31414 790 00369
ASAM Dataset: EV_ELVMarqUNECE 003006
ROD: EV_ELVMarqUNECE_003_VW27.rod
VCID: 08489A3B22B0DB7A972-805C-R SFD+SFD2 [x]
Part No SW: 3WA 959 593 A HW: 3WA 959 593
Component: TSG FS 001 0222
Serial number: YG007XDO01629 Dataset Number: V03935449QB 0001
Coding: 003D9A20DC00008102003030
ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
VCID: 54F07E4BAE78AF9A2BA-8000-R SFD+SFD2 [x]
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V2.clb
Part No SW: 3WA 907 145 E HW: 3WA 907 145
Component: BASGEN1MQB37 504 1122
Serial number: 03752048 Dataset Number: V03935437JB 0001
Coding: 00000000000000010001020101000100000001010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssisBASGEN1MQB37_017.rod
VCID: 4ACC60337C3CE96A416-801E-R SFD+SFD2 [x]
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5QS 907 338 C HW: 5QS 907 338 B
Component: FCM Baseline 019 3093
Serial number: 780542040024136 Dataset Number: V03935450AZ 0001
Coding: 00000000090001D206002F11020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiWBL 001008
ROD: EV_MultiModulContiWBL.rod
VCID: 5AEC9073CC9C99EAF16-800E-R SFD [x]
Part No SW: 3WA 959 592 A HW: 3WA 959 592
Component: TSG BFS 001 0222
Serial number: YG007XDL08897 Dataset Number: V03935449QC 0001
Coding: 003D1820DC00008102003030
ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
VCID: 53F27D57AB76A8A2320-8006-R SFD+SFD2 [x]
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 571 035 816 C HW: 571 035 816
Component: MU-O-ND-EU H10 2650
Serial number: WG8LGM060424000 Dataset Number: V03935462QT 0001
Coding: 24920006000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 002001
ROD: EV_MUOIMQB37w_002_VW49.rod
VCID: 176AC9477F0E44820E8-8042-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 14A 919 606 HW: 14A 919 606
Component: ABT-E3_15 H52 7046
Serial number: TPO00125112315010329
Subsystem 2 - Part No: V03 959 820 GG
Component: EUR 2024 0095
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 D HW: 5H2 907 383
Component: Anhaenger H12 0204
Serial number: 000000000006455 Dataset Number: V03935378DR 0001
Coding: 0100000202001200
ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
ROD: EV_TrailFunctG3MPFMHella_VW49.rod
VCID: 313E17DFF1AABAB260C-8064-R SFD+SFD2 [x]
Address 6C: Back-up Cam. (J928---------) Labels:* None
Part No SW: 5QS 907 556 A HW: 5WA 907 556 D
Component: TV eEntry H32 0675
Serial number: FZ6ESP170424000 Dataset Number: V03935441BR 0001
Coding: 020380003F142080
ASAM Dataset: EV_CamSysTVFicosBL 001004
ROD: EV_CamSysTVFicosBL_VW41.rod
Front peripheral camera slave:
Subsystem 1 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R243 UmfKamSV H23 0070
Serial number: FCLMAR11052401062216
Peripheral camera slave: left:
Subsystem 2 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R244 UmfKamSL H23 0070
Serial number: FCLMAR20052401023345
Right peripheral camera slave:
Subsystem 3 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R245 UmfKamSR H23 0070
Serial number: FCLMAR260324010706A5
Part No SW: 3J0 959 107 A HW: 3J0 959 107
Component: HDSG-Modul H02 0444
Revision: -------- Serial number: A2-C786-5400-3 Dataset Number: V03935441SD 0001
Coding: 56C8
ASAM Dataset: EV_DeckLidCONTIAU536 001009
ROD: EV_DeckLidCONTIAU536_001_VW42.rod
VCID: 2D060BAFED92DE52444-8078-R
Part No SW: 571 035 284 B HW: 571 035 284
Component: OCUMQBW2023_H H07 0626
Serial number: 0000000404VIFWA Dataset Number: V03935423VF 0001
Coding: 02010601000000211000010113002607101112111012111110
ASAM Dataset: EV_OCUMWB2023 001066
ROD: EV_OCUMWB2023_VW42.rod
VCID: 1576C34F650276921C4-8040-R SFD+SFD2 [x]
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 3J1 919 608 A HW: 3J1 919 608
Component: HeadupDisplay H09 2417
Dataset Number: V03935431WK 0001
Coding: 5700E000
ASAM Dataset: EV_HUDMQBwBL 002013
ROD: EV_HUDMQBwBL_002.rod
VCID: 303812DBFAA0B3BA6F2-8064-R SFD+SFD2 [x]
16777040 - Function Restricted due to Interrupted Communications
U1110 00 [00101111] - -
[Navigation_0x32_timing_error_bap_timeout_heartbeat]
Mileage: 22841 km
Date: 2026.07.26
Time: 16:09:49
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 3WA 907 217 C HW: 3WA 907 217
Component: MFK120 H18 1423
Dataset Number: V03935484GV 0001
Coding: 0005000000000000000000BAF940C00400000000806580000000FC00000038FE43F040004000000000800000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK120MAGNAMQBWB 001024
ROD: EV_MFK120MAGNAMQBWB_001.rod
3146032 - Databus
U1123 00 [00100111] - Received Error Message
[NR_RL_Blindness_ERROR]
Mileage: 22841 km
Date: 2026.07.26
Time: 16:09:44
3146033 - Databus
[NR_RS_Blindness_ERROR]
Mileage: 22841 km
Date: 2026.07.26
Time: 16:09:44
Address BB: Door Rear Drv (J388) Labels:* Redir Fail!
Part No SW: 3WA 959 595 A HW: 3WA 959 595
Component: TSG HFS 001 0222
Serial number: YG007XDU1141D Dataset Number: V03935449QE 0001
Coding: 000C90200100008100003020
ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001016
ROD: EV_DCU4RearDriveMAXHBRO_VW42.rod
VCID: 56F48443B884BD8AD5E-8002-R SFD+SFD2 [x]
Address BC: Door Rear Pass (J389) Labels:* Redir Fail!
Part No SW: 3WA 959 594 A HW: 3WA 959 594
Component: TSG HBFS 001 0222
Serial number: YG007XE402687 Dataset Number: V03935449QD 0001
ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001016
ROD: EV_DCU4RearPasseMAXHBRO_VW42.rod
VCID: 55F6834FA582B692DC4-8000-R SFD+SFD2 [x]
Part No SW: 8Y1 907 594 AC HW: 4K1 907 594
Component: SAD_STG_1 010 0010
Dataset Number: V03935432NF 0001
Coding: 608040749202
Part No SW: 992 941 572 AH HW: 992 941 572 A
Component: LED1L H25 9204
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
VCID: 698EBFBF19FA027268C-803C-R
Component: LED1R H25 9204
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address DE: Charger 1 for mobile dev (J0000) Labels:* None
Part No SW: 3P0 035 502 B HW: 3P0 035 502
Component: COUPLING BOX 004 0170
Serial number: 324000000000024 Dataset Number: V03935425HL 0001
Coding: 800000
ASAM Dataset: EV_DualCouplBoxSK336 001006
ROD: EV_DualCouplBoxSK336.rod
VCID: 2410EE8BBE581F1A9BA-8070-R SFD+SFD2 [x]
Address 8107: Antenna (J666) Labels:* None
Part No SW: 5QS 035 741 A HW: 5QS 035 741
Component: TrxModulHigh H04 0610
Dataset Number: V03935433LH 0001
Coding: 02492000010101010000010000010100000001
ASAM Dataset: EV_TrxMLGEMQBWBL 001026
ROD: EV_TrxMLGEMQBWBL_VW49.rod
VCID: 4EC46C238054C54A1DE-801A-R SFD+SFD2 [x]
Address 8109: Close Rge Radar 1 (J1088) Labels:* None
Part No SW: 3WA 907 541 J HW: 95C 907 541
Component: Nanoradar 1 H08 0138
Serial number: 14520046557347 Dataset Number: V03935467NK 0001
Coding: 59955A1529C405000000
ASAM Dataset: EV_NR1HELLAVW38X 001112
ROD: EV_NR1HELLAVW38X_001_VW38.rod
VCID: 4FFA7127875ECC42168-801A-R SFD+SFD2 [x]
Address 810A: Close Rge Radar 2 (J1089) Labels:* None
Component: Nanoradar 2 H08 0138
Serial number: 14520046560628 Dataset Number: V03935467NM 0001
ASAM Dataset: EV_NR2HELLAVW38X 001112
ROD: EV_NR2HELLAVW38X_001_VW38.rod
Address 810B: Close Rge Radar 3 (J770) Labels:* None
Component: Nanoradar 3 H08 0138
Serial number: 14520046346156 Dataset Number: V03935467NN 0001
Coding: 59565A1529C405000000
ASAM Dataset: EV_NR3HELLAVW38X 001112
ROD: EV_NR3HELLAVW38X_001_VW38.rod
Address 810C: Close Rge Radar 4 (J769) Labels:* None
Component: Nanoradar 4 H08 0138
Serial number: 14520046346181 Dataset Number: V03935467NQ 0001
Coding: 99696A1631C40F000000
ASAM Dataset: EV_NR4HELLAVW38X 001112
ROD: EV_NR4HELLAVW38X_001_VW38.rod
Address 8117: Rear surroundings cam (J772) Labels:* None
Part No SW: 5R3 980 568 F HW: 1EA 980 568 B
Component: RV eSmart H20 0445
Serial number: FCLK20250424000 Dataset Number: V03935440SB 0001
Coding: 0203800027152080
ASAM Dataset: EV_AVCamerRearFicosBL 004029
ROD: EV_AVCamerRearFicosBL_004_VW49.rod
VCID: 44D04E0B5E183F1ABBA-8010-R SFD+SFD2 [x]
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 G HW: 5WA 962 133 E
Component: Kessy RSAD 122 0770
ASAM Dataset: EV_RSADVL37w 004018
ROD: EV_RSADHR37w_004_VW38.rod
VCID: 4CC0662B7648F75A73A-8018-R
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 004018
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 004018
ROD: EV_RSADHL37w_004_VW38.rod
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 004018
End----------(Elapsed Time: 34:45, VBatt start/end: 13.8V/13.8V)-----------
------------------------------3 Faults Found-------------------------------
adpmap - 01
SW:05L-906-022-DL HW:05L-907-309-AG --- 01: Engine
Component:R4 2.0l TDI H80 4618, Coding:0125003A03741D0870080000001000000000000000000000
EV_ECM20TDI01105L906022DL,010012,EV_ECM20TDI01105L906022DL.rod
Sunday,26,July,2026,16:21:09:15875
VCDS Version: 26.7.0.1 (x64) Data version: 20260708 DS378.0
IDE00263-Injector 1 correction value,81H3C6I ,7
IDE00264-Injector 2 correction value,8RZV8OH ,7
IDE00265-Injector 3 correction value,8IHX62I ,7
IDE00266-Injector 4 correction value,AHZ85KF ,7
IDE01096-Particulate Filter Statistics,0 ,1
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE01945-Engine run-in oil pressure,not active ,1
IDE07903-Adaptation of ash mass,7.55 g,2
IDE10309-Adaptation of oxidation catalytic converter aging,2.81126e+006 s,2
IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,-129.69 °,4
IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,0.00 °,4
IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,3.91 °,4
IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4
IDE15783-Adaptation for aging coated particulate filter,3863591.3125 s,4
IDE15794-ENG264196-Radiator shutter: target value-Setpoint radiator shutter 1,0 %,4
IDE15794-ENG264197-Radiator shutter: target value-Setpoint radiator shutter 1 - no reaction,no reaction ,4
IDE15794-ENG264198-Radiator shutter: target value-Setpoint radiator shutter 2,0 %,4
IDE15794-ENG264199-Radiator shutter: target value-Setpoint radiator shutter 2 - no reaction,no reaction ,4
IDE15794-ENG264200-Radiator shutter: target value-Setpoint radiator shutter 3,0 %,4
IDE15794-ENG264201-Radiator shutter: target value-Setpoint radiator shutter 3 - no reaction,no reaction ,4
IDE15794-ENG264202-Radiator shutter: target value-Setpoint radiator shutter 4,0 %,4
IDE15794-ENG264203-Radiator shutter: target value-Setpoint radiator shutter 4 - no reaction,no reaction ,4
Elapsed Time: 00:04
adpmap - 02
SW:0GC-906-555-GA HW:0GC-300-058-K --- 02: Auto Trans
Component:GSG DQ381 H06 0661, Coding:
EV_TCMDQ381064,001011,EV_TCMDQ381064.rod
Sunday,26,July,2026,16:22:13:15875
IDE00001-ENG252054-Production mode-Deactivate P button,not activated ,3
IDE00001-ENG252070-Production mode-Haltemagnet ausschalten,not activated ,3
IDE00001-ENG324914-Production mode-kein Kriechen in Rückwärts-Fahrstufen,not activated ,3
IDE00001-ENG324915-Production mode-kein Kriechen in Vorwärts-Fahrstufen,not activated ,3
IDE00001-ENG252086-Production mode-Longpush,not activated ,3
IDE00001-ENG252078-Production mode-NER aktiv halten,not activated ,3
IDE00001-ENG252050-Production mode-N-Haltephase deaktivieren,not activated ,3
IDE00001-ENG98860-Production mode-Production mode,not activated ,3
ENG376279-Betriebsumgebung,Unknown (2),1
ENG125931-ECU_W,Conditions not correct or request sequence error,1
ENG364523-Freigabe Kraftschluss Fzgbau,Conditions not correct or request sequence error,1
Elapsed Time: 00:03
adpmap - 2B
SW:3WA-905-861 HW:3WA-905-861 --- 2B: Steer. Col. Lock
Component:ELV-MQB_UNECE H05 0063, Coding:8820000000000000
EV_ELVMarqUNECE,003006,EV_ELVMarqUNECE_003_VW27.rod
Sunday,26,July,2026,16:35:09:15875
IDE00820-Activating and deactivating all development messages,operated ,1
IDE07566-Steering column lock unlocked,unlock ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,6
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,2 ,6
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,not tested ,1
Elapsed Time: 00:01
adpmap - 03
SW:3WA-614-517-AM HW:3WA-614-517-D --- 03: ABS Brakes
Component:EBC470IESCH09 0390, Coding:2C285124A48B399C410799AC9EB701040583952149A8
EV_Brake1ZFESCEPBMQB48W,002068,EV_Brake1ZFESCEPBMQB48W_002.rod
Sunday,26,July,2026,16:22:39:15875
IDE00001-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
IDE00001-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
IDE00001-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3
IDE00001-MAS24092-Production mode-Electromechanical parking brake button: long push,Deactivating ,3
IDE00001-MAS24093-Production mode-Switching off the control and sensor plausibility,Deactivating ,3
IDE00001-Production mode-,not active ,3
IDE00820-ENG376450-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_1,not activated ,3
IDE00820-ENG376451-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_2,not activated ,3
IDE00820-ENG376452-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_3,not activated ,3
IDE00820-ENG376426-Activating and deactivating all development messages-Activation of Development Message EB_Basisdienste_01,not activated ,3
IDE00820-ENG376453-Activating and deactivating all development messages-Activation of Development Message EPB_00,not activated ,3
IDE00820-ENG376454-Activating and deactivating all development messages-Activation of Development Message EPB_01,not activated ,3
IDE00820-ENG376455-Activating and deactivating all development messages-Activation of Development Message EPB_02,not activated ,3
IDE00820-ENG376456-Activating and deactivating all development messages-Activation of Development Message ESC_00,not activated ,3
IDE00820-ENG376457-Activating and deactivating all development messages-Activation of Development Message ESC_01,not activated ,3
IDE00820-ENG376458-Activating and deactivating all development messages-Activation of Development Message ESC_02,not activated ,3
IDE00820-ENG376459-Activating and deactivating all development messages-Activation of Development Message ESC_03,not activated ,3
IDE00820-ENG376460-Activating and deactivating all development messages-Activation of Development Message ESC_04,not activated ,3
IDE00820-ENG376461-Activating and deactivating all development messages-Activation of Development Message ESC_05,not activated ,3
IDE00820-ENG376462-Activating and deactivating all development messages-Activation of Development Message FDR_01,not activated ,3
IDE00820-ENG376463-Activating and deactivating all development messages-Activation of Development Message PBC_VDA_01,not activated ,3
IDE00820-ENG376464-Activating and deactivating all development messages-Activation of Development Message RKA_01,not activated ,3
IDE03493-Driver's door status,activated ,1
IDE04456-Brake disk drying,Medium ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05337-Starting vibration reduction,Strong ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE07292-Brake pre-filling,ended ,1
IDE11985-Expected OBD requirements,EOBD ,1
IDE14225-IDE07280-Delay and hold management-Multiple collision brake,activated ,2
IDE14225-IDE08968-Delay and hold management-High-voltage charging management,not activated ,2
IDE14225-IDE11421-Delay and hold management-Leaving concept,activated ,2
IDE14225-IDE11447-Delay and hold management-electro-mechanical brake booster,activated ,2
IDE14225-IDE18029-Delay and hold management-Rush Hour Pilot,not activated ,2
IDE14225-MAS00919-Delay and hold management-Pedestrian protection,activated ,2
IDE14225-MAS01090-Delay and hold management-Gearbox,activated ,2
IDE14225-MAS05087-Delay and hold management-ACC,activated ,2
IDE14225-MAS05129-Delay and hold management-Motor,not activated ,2
IDE14225-MAS05506-Delay and hold management-Stopping distance reduction,activated ,2
IDE14225-MAS15696-Delay and hold management-Rear cross traffic assistant,activated ,2
IDE14225-MAS15806-Delay and hold management-Parking assist,activated ,2
IDE14225-MAS18082-Delay and hold management-Emergency assistant,activated ,2
IDE14225-MAS18083-Delay and hold management-Developer function imaginary participant 1,not activated ,2
IDE14225-MAS18084-Delay and hold management-Developer function imaginary participant 2,not activated ,2
IDE14226-Electronic engine braking torque reduction,activated ,1
IDE15332-MAS17834-Vehicle curb weight-Curb weight of rear axle,763 kg,4
IDE15332-MAS17837-Vehicle curb weight-Curb weight of front axle,1025 kg,4
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,30
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,14 ,30
MAS02080-XCP calibration protocol,not activated ,1
MAS03691-Dimming,activated ,1
MAS14035-Precondition,Security access required You should unlock SFD before attempting advanced functions.,1
ENG264022-Developer_Function_01,00 00 ,2
ENG264025-Developer_Function_04,5 ,1
ENG264021-Developer_Function_10,activated ,1
ENG281048-ENG309827-Developer_Function_114-Autohold_dimming_nominal_voltage,Security access required You should unlock SFD before attempting advanced functions.,1
ENG281048-ENG309828-Developer_Function_114-Autohold_dimming_normalization_status,Security access required You should unlock SFD before attempting advanced functions.,1
ENG281048-ENG309829-Developer_Function_114-Electronic_park_brake_dimming_nominal_voltage,Security access required You should unlock SFD before attempting advanced functions.,1
ENG281048-ENG309830-Developer_Function_114-Electronic_park_brake_dimming_normalization_status,Security access required You should unlock SFD before attempting advanced functions.,1
ENG364521-Developer_Function_115,Security access required You should unlock SFD before attempting advanced functions.,1
ENG122844-ENG264130-dimming_characteristic_1-Daempfung_Abdimmen_KL_58xD_PWM,0.10 s,23
ENG122844-ENG154584-dimming_characteristic_1-Daempfung_Aufdimmen_KL_58xd_PWM,0.20 s,23
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,23
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,23
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,23
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,23
ENG122844-ENG103548-dimming_characteristic_1-X5,150 ,23
ENG122844-ENG113992-dimming_characteristic_1-X6,220 ,23
ENG122844-ENG115661-dimming_characteristic_1-x7,253 ,23
ENG122844-ENG99777-dimming_characteristic_1-Y1,1.00 %,23
ENG122844-ENG100480-dimming_characteristic_1-Y2,1.00 %,23
ENG122844-ENG100773-dimming_characteristic_1-Y3,6.00 %,23
ENG122844-ENG100631-dimming_characteristic_1-Y4,10.00 %,23
ENG122844-ENG102174-dimming_characteristic_1-Y5,20.00 %,23
ENG122844-ENG113993-dimming_characteristic_1-Y6,60.00 %,23
ENG122844-ENG115665-dimming_characteristic_1-y7,100.00 %,23
ENG122845-ENG264130-dimming_characteristic_2-Daempfung_Abdimmen_KL_58xD_PWM,0.10 s,23
ENG122845-ENG154584-dimming_characteristic_2-Daempfung_Aufdimmen_KL_58xd_PWM,0.20 s,23
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,23
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,23
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,23
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,23
ENG122845-ENG103548-dimming_characteristic_2-X5,150 ,23
ENG122845-ENG113992-dimming_characteristic_2-X6,220 ,23
ENG122845-ENG115661-dimming_characteristic_2-x7,253 ,23
ENG122845-ENG99777-dimming_characteristic_2-Y1,1.00 %,23
ENG122845-ENG100480-dimming_characteristic_2-Y2,1.00 %,23
ENG122845-ENG100773-dimming_characteristic_2-Y3,6.00 %,23
ENG122845-ENG100631-dimming_characteristic_2-Y4,10.00 %,23
ENG122845-ENG102174-dimming_characteristic_2-Y5,20.00 %,23
ENG122845-ENG113993-dimming_characteristic_2-Y6,60.00 %,23
ENG122845-ENG115665-dimming_characteristic_2-y7,100.00 %,23
ENG264029-Dynamic_Developer_Function_01,General reject,23
ENG264027-Dynamic_Developer_Function_02,General reject,23
ENG264028-Dynamic_Developer_Function_03,General reject,23
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
Elapsed Time: 00:11
adpmap - 4B
SW:5QS-907-338-C HW:5QS-907-338-B --- 4B: Multifunc. Module
Component:FCM Baseline 019 3093, Coding:00000000090001D206002F11020003000000000000000000000000000000
EV_MultiModulContiWBL,001008,EV_MultiModulContiWBL.rod
Sunday,26,July,2026,16:36:17:15875
IDE01996-MAS24761-Installation list: specified installations-Central control for digital matrix light,No ,1
IDE01996-MAS24762-Installation list: specified installations-Projection module for left matrix headlamp,No ,1
IDE01996-MAS24763-Installation list: specified installations-Projection module for right matrix headlamp,No ,1
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03679-Adaptive light functions,Security access required You should unlock SFD before attempting advanced functions.,1
MAS25262-MAS25263-GPS stopwatch (racing function)-GPS corridor: width,10 m,5
MAS25262-MAS25264-GPS stopwatch (racing function)-GPS corridor: height,7 m,5
MAS25262-MAS25265-GPS stopwatch (racing function)-Results of round: display time,10 s,5
MAS25262-MAS25266-GPS stopwatch (racing function)-GPS Position: tolerance,10 cm,5
MAS25262-MAS25267-GPS stopwatch (racing function)-GPS Position: deviation,3 ,5
MAS25268-MAS25269-Acceleration gauge (racing function)-Traffic light: display time,1000 ms,3
MAS25268-MAS25270-Acceleration gauge (racing function)-Traffic light: breakdown duration,5 s,3
MAS25268-ENG456412-Acceleration gauge (racing function)-a_adapt_r_func_p_speed_max,0 km/h,3
MAS25268-ENG456413-Acceleration gauge (racing function)-a_adapt_r_func_p_speed_min,0 km/h,3
Elapsed Time: 00:09
adpmap - 05
SW:5WA-959-436-AD HW:5WA-959-436-N --- 05: Acc/Start Auth.
Component:Kessy IOBOX 122 0771, Coding:
EV_Kessy37w,005030,EV_Kessy37w_005_VW38.rod
Sunday,26,July,2026,16:23:05:15875
ENG253038-ENG258893-DevCod_ Search lights-Suchbeleuchtung_ZAT_bei_KL58_aktiv,activated ,5
ENG253038-ENG258265-DevCod_ Search lights-Suchbeleuchtung_ZAT_Beleuchtung_SES_Variante_aktiv,activated ,5
ENG253038-ENG260629-DevCod_ Search lights-Suchbeleuchtung_ZAT_Normierung_aktiv,activated ,5
ENG253038-ENG259779-DevCod_ Search lights-Suchbeleuchtung_ZAT_OpenLoadErkennung_aktiv,not activated ,5
ENG253038-ENG260681-DevCod_ Search lights-Suchbeleuchtung_ZAT_SES_Mode,activated ,5
ENG253096-DevCod_AutomatischeFunktionen,activated ,6
ENG253395-ENG141964-DevCod_Fahrzeugkonfiguration-Steering assignment,Left ,5
ENG253395-ENG273785-DevCod_Fahrzeugkonfiguration-Transponding_Antennen_Strom_reduziert_aktiv,not active ,5
ENG253143-ENG258965-DevCod_Passive_EntryExit-Toggle-Datalogging_LFDebug_aktiv,not activated ,5
ENG253143-ENG258844-DevCod_Passive_EntryExit-Toggle-Gleichzeitiges_Senden_Innenraumantennen_aktiv,activated ,5
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,6
ENG129029-ENG259793-Easy_close_alignment-VIT_AktivTasteB_Zyklus,1.0 s,6
ENG253331-ENG258816-Par_Automatische_Funktionen-AutomatikFunktionen_Timeout,4320 min,10
ENG253331-ENG260182-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeber_Anwesenheit,300 ms,10
ENG253220-IDE15282-Par_Bedienstellen-Door: driver control section: installation variant,0 ,36
ENG253220-IDE15283-Par_Bedienstellen-Door: front passenger control section: installation variant,0 ,36
ENG253220-IDE15284-Par_Bedienstellen-5th control section: installation variant,5 ,36
ENG253220-IDE15285-Par_Bedienstellen-Fuel filler cap control section: installation variant,5 ,36
ENG253220-IDE15286-Par_Bedienstellen-Rear driver side control section: installation variant,0 ,36
ENG253220-IDE15287-Par_Bedienstellen-Rear passenger side control section: installation variant,0 ,36
ENG253220-ENG259190-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_5teT,4320 min,36
ENG253220-ENG259838-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_BT,4320 min,36
ENG253220-ENG260574-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_FT,0 min,36
ENG253220-ENG261264-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HBFS,4320 min,36
ENG253220-ENG258369-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HFS,4320 min,36
ENG253220-ENG258148-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_Tank,3600 min,36
ENG253220-ENG261229-Par_Bedienstellen-Bedienstelle_Aktivierungsschwelle_Spielschutzzaehler,80 ,36
ENG253220-ENG259917-Par_Bedienstellen-Bedienstelle_Ausschaltzeit_Spielschutz_aktiv,1800 s,36
ENG253220-ENG261227-Par_Bedienstellen-Bedienstelle_Deaktivierung_SchwelleFahrendesFzg,20 km/h,36
ENG253220-ENG261134-Par_Bedienstellen-Bedienstelle_Deaktivierungsschwelle_Spielschutzzaehler,60 ,36
ENG253220-ENG258448-Par_Bedienstellen-Bedienstelle_MaxBetaetigung,120 s,36
ENG253220-ENG259922-Par_Bedienstellen-Bedienstelle_MaxKomfortUnterbrechung,10 ms,36
ENG253220-ENG261271-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_5teT,500 ms,36
ENG253220-ENG259320-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_BT,500 ms,36
ENG253220-ENG259918-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_FT,1500 ms,36
ENG253220-ENG260179-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HBFS,500 ms,36
ENG253220-ENG260090-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HFS,500 ms,36
ENG253220-ENG260565-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_Tank,500 ms,36
ENG253220-ENG261322-Par_Bedienstellen-Bedienstelle_MinBetaetigung_ToggleTaster,140 ms,36
ENG253220-ENG259707-Par_Bedienstellen-Bedienstelle_MinBetaetigung_Verriegelungssensor,140 ms,36
ENG253220-ENG258814-Par_Bedienstellen-Bedienstelle_Reaktivierung_SchwelleStehendesFzg,10 km/h,36
ENG253220-ENG258395-Par_Bedienstellen-Bedienstelle_Reduzierung_Zaehlerstand_Spielschutzzaehler,60 s,36
ENG253220-ENG445320-Par_Bedienstellen-Spielschutz_Anzahl_Bereich_Pings,0 ,36
ENG253220-ENG445321-Par_Bedienstellen-Spielschutz_IOBox_aktiv,not activated ,36
ENG253220-ENG445322-Par_Bedienstellen-Spielschutz_Stufe_1_Ping_Timer,0 min,36
ENG253220-ENG445323-Par_Bedienstellen-Spielschutz_Stufe_2_Ping_Timer,0 min,36
ENG253190-ENG258772-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Diagnose,70 ms,35
ENG253190-ENG258701-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Entry,10000 µs,35
ENG253190-ENG261026-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Exit,40000 µs,35
ENG253190-ENG258968-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Naeherung,20000 µs,35
ENG253190-ENG259906-Par_Näherungssensoren-Naeherungssensor_MaxPausenlaenge,10 ms,35
ENG253190-ENG260803-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Diagnose,42 ms,35
ENG253190-ENG259643-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Entry,6000 µs,35
ENG253190-ENG259840-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Exit,24000 µs,35
ENG253190-ENG259205-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Naeherung,12000 µs,35
ENG253190-ENG260098-Par_Näherungssensoren-Verzoegerung_PowerOn_Reset,1960 ms,35
ENG253285-ENG260495-Par_PassiveKomfort-Delay_Reichweitenbegrenzung_Start,0 ms,10
ENG253285-ENG260385-Par_PassiveKomfort-KomfortReichweitenbegr_Timout,75 s,10
ENG253285-ENG261013-Par_PassiveKomfort-PassiveKomfortFunktionen_MaxSignalisierungsdauer,60 s,10
ENG253285-ENG263587-Par_PassiveKomfort-PassiveKomfortFunktionen_Zeitfenster_fuer_Bedienhandlung,800 ms,10
ENG253285-ENG261279-Par_PassiveKomfort-Reichweitenbegrenzung_Zyklus,90 ms,10
ENG253106-ENG258919-Par_ScanStrategie_RetryHandling-anz_RetriesRegistering,1 Num,22
ENG253106-ENG259329-Par_ScanStrategie_RetryHandling-Erste_Warnschwelle_thermische_Überlast,45 °C,22
ENG253106-ENG259473-Par_ScanStrategie_RetryHandling-P2_Pause_zwischen_Transponding_Telegrammen,200 ms,22
ENG253106-ENG259392-Par_ScanStrategie_RetryHandling-Sperrzeit_LFTreiber_nach_thermischer_Ueberlast,5.0 s,22
ENG253106-ENG263515-Par_ScanStrategie_RetryHandling-t_CANSignalDelayAfterSleep,30 ms,22
ENG253106-ENG258479-Par_ScanStrategie_RetryHandling-t_LFDebug_Nachsignaslisierung,100 ms,22
ENG253106-ENG263591-Par_ScanStrategie_RetryHandling-Temperaturschaltschwelle_LF_Wavetable,100 °C,22
ENG253106-ENG276176-Par_ScanStrategie_RetryHandling-Timeout_Grundwert_RetryRegistering,52 ms,22
ENG253106-ENG276194-Par_ScanStrategie_RetryHandling-Timeout_Inkrementwert_RetryRegistering,7 ms,22
ENG253106-ENG261110-Par_ScanStrategie_RetryHandling-Verzoegerung_LFSenden_nach_Weckleitungziehen,0 ms,22
ENG253106-ENG260133-Par_ScanStrategie_RetryHandling-Zweite_Warnschwelle_thermische_Überlast,65 °C,22
ENG253086-MAS18911-Passive_Komfort-Convenience closing by locking using door handle active,activated ,5
ENG253086-ENG280093-Passive_Komfort-Noise_filter_aktiv,activated ,5
ENG253086-ENG261176-Passive_Komfort-Passive_Komfort_Oeffnen_aktiv,not activated ,5
ENG253086-ENG259864-Passive_Komfort-Passive_Komfort_Togglen_aktiv,not activated ,5
ENG253352-ENG259594-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Abdimmen,1.0 ,30
ENG253352-ENG259617-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Aufdimmen,2.0 ,30
ENG253352-ENG261228-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ausschalten_KL15,10 min,30
ENG253352-ENG258605-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_0Prozent_Dimmkurve,0.0 %,30
ENG253352-ENG258785-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Deltawert_50Prozent_Dimmkurve,50.0 %,30
ENG253352-ENG263542-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Fehlerdimmwert,80 %,30
ENG253352-ENG260556-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Nennspannung,13.0 V,30
ENG253352-ENG258781-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_OffsetDimmwert,1.0 ,30
ENG253352-ENG259791-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Deltawert_100Prozent_Dimmkurve,100.0 %,30
ENG253287-ENG261242-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES1,10.0 %,32
ENG253287-ENG260274-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES2,3.0 %,32
ENG253287-ENG258981-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260137-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES2,2.0 %,32
ENG253287-ENG259846-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES1,80.0 %,32
ENG253287-ENG261362-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES2,20.0 %,32
ENG253287-ENG258809-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_1,0 %,32
ENG253287-ENG258501-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_2,0 %,32
ENG253287-ENG260497-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_1,80 %,32
ENG253287-ENG258157-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_2,100 %,32
ENG253287-ENG261138-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES1,100.0 %,32
ENG253287-ENG258211-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES2,30.0 %,32
ENG253287-ENG261183-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_faktor,0.1 ,32
ENG253287-ENG259175-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_Offset,2.0 Num,32
ENG253287-ENG261051-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Fall_OFF,740 ms,32
ENG253287-ENG260479-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_OFF,0 ms,32
ENG253287-ENG258704-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_ON,0 ms,32
ENG253287-ENG260922-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Rise_ON,100 ms,32
ENG253287-ENG260304-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Fall_OFF,1600 ms,32
ENG253287-ENG258413-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_OFF,0 ms,32
ENG253287-ENG260729-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_ON,0 ms,32
ENG253287-ENG258296-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Rise_ON,100 ms,32
ENG253287-ENG258477-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES1,15.0 %,32
ENG253287-ENG259506-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES2,4.0 %,32
ENG253287-ENG258902-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260830-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES2,2.0 %,32
Elapsed Time: 00:06
adpmap - F5
SW:571-035-816-C HW:571-035-816 --- 5F: Information Electr.
Component:MU-O-ND-EU H10 2650, Coding:24920006000000000000000000000000000000000000000000
EV_MUOIMQB37w,002001,EV_MUOIMQB37w_002_VW49.rod
Sunday,26,July,2026,16:37:33:15875
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,automatic ,1
IDE00768-Country identification: country of sale,CZ ,2
IDE00769-Call number 1 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02330-Call number 2 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,15 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,25 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,15 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,25 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,15 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,25 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,15 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,25 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,15 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,25 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,15 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,25 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,15 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,25 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,15 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,25 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,15 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,25 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,15 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,25 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,15 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,25 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,15 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,25 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,15 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,25 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,15 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,25 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,15 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,25 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,15 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,25 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,15 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,25 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,15 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,25 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,15 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,25 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,15 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,25 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,15 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,25 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,15 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,25 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,15 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,25 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,15 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,25 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,27 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,27 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,27 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,27 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,27 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,27 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,27 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,27 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,121
IDE02502-Confirmation of installation change,CA 5B ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,not activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,not activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,not activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,not activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,CAN_FAS ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,CAB_5 ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,not activated ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,not activated ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,Terminal 15 ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,CAB_5 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Infotainment data bus ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,CAB_2 ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,CAB_2 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,CAB_2 ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,CAN_Comfort_3 ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,not activated ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,not activated ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Infotainment data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,Powertrain data bus ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,Powertrain data bus ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Infotainment data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,CAB_5 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,CAN_Comfort_3 ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,not activated ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Infotainment data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,Ethernet ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,CAN_FAS ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,CAN_Comfort_3 ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,Infotainment data bus ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,can_fas_2 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,not activated ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,Suspension data bus ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,CAN_Comfort_3 ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,can_fas_2 ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,CAN_FAS ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,CAN_FAS ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,CAN_Comfort_3 ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,can_fas_2 ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,CAB_5 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,0 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-GNSS: refresh rate,10 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10604-Menu entries for mobile online services,activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,36 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,40 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11122-Country identification: country of sale HMI,CZ ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,01 ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,slave ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Deactivated ,2
IDE15489-Port mirroring,00 00 ,2
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,170
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,84 ,170
IDE16969-Reset fault memory for production process,No ,1
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG248413-alphabetic_scrollbar,On ,1
ENG298045-ENG298074-atmospheres_features-atm_function,Not available ,2
ENG298045-ENG298082-atmospheres_features-fes_available,Not available ,2
ENG298045-ENG298161-atmospheres_features-startup_last_profile,Not available ,2
ENG298046-ENG345909-atmospheres_functional_parameters-playlist_environment,0 ,8
ENG298046-ENG298148-atmospheres_functional_parameters-playlist_stop_request_time,20 s,8
ENG298046-ENG298149-atmospheres_functional_parameters-playlist_update_interval,60 min,8
ENG298047-ENG298070-atmospheres_participant_coding-ambientlight,Not available ,2
ENG298047-ENG298075-atmospheres_participant_coding-audio_eq_preset,Not available ,2
ENG298047-ENG298076-atmospheres_participant_coding-audio_volume,Not available ,2
ENG298047-ENG298084-atmospheres_participant_coding-fpk_view,Not available ,2
ENG298047-ENG298111-atmospheres_participant_coding-homescreen,Not available ,2
ENG298047-ENG298147-atmospheres_participant_coding-playlist,Not available ,2
ENG298048-ENG298069-atmospheres_participant_control_delay-amb_delay,0 ms,16
ENG298048-ENG345288-atmospheres_participant_control_delay-aup_delay,0 ms,16
ENG298048-ENG298077-atmospheres_participant_control_delay-auv_delay,0 ms,16
ENG298048-ENG298083-atmospheres_participant_control_delay-fpk_delay,0 ms,16
ENG298048-ENG298110-atmospheres_participant_control_delay-hhs_delay,0 ms,16
ENG298048-ENG298146-atmospheres_participant_control_delay-pla_delay,0 ms,16
ENG298049-ENG298150-atmospheres_profile_coding-profile_slot_1,Not available ,2
ENG298049-ENG298151-atmospheres_profile_coding-profile_slot_10,Not available ,2
ENG298049-ENG298152-atmospheres_profile_coding-profile_slot_2,Not available ,2
ENG298049-ENG298153-atmospheres_profile_coding-profile_slot_3,Not available ,2
ENG298049-ENG298154-atmospheres_profile_coding-profile_slot_4,Not available ,2
ENG298049-ENG298155-atmospheres_profile_coding-profile_slot_5,Not available ,2
ENG298049-ENG298156-atmospheres_profile_coding-profile_slot_6,Not available ,2
ENG298049-ENG298157-atmospheres_profile_coding-profile_slot_7,Not available ,2
ENG298049-ENG298158-atmospheres_profile_coding-profile_slot_8,Not available ,2
ENG298049-ENG298159-atmospheres_profile_coding-profile_slot_9,Not available ,2
ENG298050-ENG331833-atmospheres_profile_property_configuration_individual-amb_no_change_available,Not available ,16
ENG298050-ENG331836-atmospheres_profile_property_configuration_individual-audio_volume_offset_max,2 ,16
ENG298050-ENG331837-atmospheres_profile_property_configuration_individual-audio_volume_offset_min,-48 ,16
ENG298050-ENG331838-atmospheres_profile_property_configuration_individual-audio_volume_offset_step,2 ,16
ENG298050-ENG331839-atmospheres_profile_property_configuration_individual-aup_no_change_available,Not available ,16
ENG298050-ENG331840-atmospheres_profile_property_configuration_individual-auv_no_change_available,Not available ,16
ENG298050-ENG331882-atmospheres_profile_property_configuration_individual-fpk_no_change_available,Not available ,16
ENG298050-ENG298085-atmospheres_profile_property_configuration_individual-FPK_view_1,Not available ,16
ENG298050-ENG298086-atmospheres_profile_property_configuration_individual-FPK_view_10,Not available ,16
ENG298050-ENG298087-atmospheres_profile_property_configuration_individual-FPK_view_11,Not available ,16
ENG298050-ENG298088-atmospheres_profile_property_configuration_individual-FPK_view_12,Not available ,16
ENG298050-ENG298089-atmospheres_profile_property_configuration_individual-FPK_view_13,Not available ,16
ENG298050-ENG298090-atmospheres_profile_property_configuration_individual-FPK_view_14,Not available ,16
ENG298050-ENG298091-atmospheres_profile_property_configuration_individual-FPK_view_15,Not available ,16
ENG298050-ENG298092-atmospheres_profile_property_configuration_individual-FPK_view_16,Not available ,16
ENG298050-ENG298093-atmospheres_profile_property_configuration_individual-FPK_view_17,Not available ,16
ENG298050-ENG298094-atmospheres_profile_property_configuration_individual-FPK_view_18,Not available ,16
ENG298050-ENG298095-atmospheres_profile_property_configuration_individual-FPK_view_19,Not available ,16
ENG298050-ENG298096-atmospheres_profile_property_configuration_individual-FPK_view_2,Not available ,16
ENG298050-ENG298097-atmospheres_profile_property_configuration_individual-FPK_view_20,Not available ,16
ENG298050-ENG298098-atmospheres_profile_property_configuration_individual-FPK_view_21,Not available ,16
ENG298050-ENG298099-atmospheres_profile_property_configuration_individual-FPK_view_22,Not available ,16
ENG298050-ENG298100-atmospheres_profile_property_configuration_individual-FPK_view_23,Not available ,16
ENG298050-ENG298101-atmospheres_profile_property_configuration_individual-FPK_view_24,Not available ,16
ENG298050-ENG298102-atmospheres_profile_property_configuration_individual-FPK_view_3,Not available ,16
ENG298050-ENG298103-atmospheres_profile_property_configuration_individual-FPK_view_4,Not available ,16
ENG298050-ENG298104-atmospheres_profile_property_configuration_individual-FPK_view_5,Not available ,16
ENG298050-ENG298105-atmospheres_profile_property_configuration_individual-FPK_view_6,Not available ,16
ENG298050-ENG298106-atmospheres_profile_property_configuration_individual-FPK_view_7,Not available ,16
ENG298050-ENG298107-atmospheres_profile_property_configuration_individual-FPK_view_8,Not available ,16
ENG298050-ENG298108-atmospheres_profile_property_configuration_individual-FPK_view_9,Not available ,16
ENG298050-ENG331899-atmospheres_profile_property_configuration_individual-hhs_no_change_available,Not available ,16
ENG298050-ENG332342-atmospheres_profile_property_configuration_individual-pla_no_change_available,Not available ,16
ENG253302-ENG260724-audio_zone_configuration-zone_1_direction,none ,6
ENG253302-ENG259844-audio_zone_configuration-zone_1_position,none ,6
ENG253302-ENG260273-audio_zone_configuration-zone_2_direction,none ,6
ENG253302-ENG259809-audio_zone_configuration-zone_2_position,none ,6
ENG253302-ENG261136-audio_zone_configuration-zone_3_direction,none ,6
ENG253302-ENG260623-audio_zone_configuration-zone_3_position,none ,6
ENG253302-ENG259382-audio_zone_configuration-zone_4_direction,none ,6
ENG253302-ENG259681-audio_zone_configuration-zone_4_position,none ,6
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG252010-Car_net,we_connect ,1
ENG248423-channel_band_width_802_11ac,80MHz ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,BAP ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,0 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,IP_streaming ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,BAP ,8
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,18
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,18
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,18
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,18
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,18
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,18
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1.0 %,18
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1.0 %,18
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3.0 %,18
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6.0 %,18
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44.0 %,18
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100.0 %,18
ENG253228-ENG101574-Dimming_Illumination_for_Display_Unit_day_design-X1,0 ,18
ENG253228-ENG99557-Dimming_Illumination_for_Display_Unit_day_design-X2,10 ,18
ENG253228-ENG102140-Dimming_Illumination_for_Display_Unit_day_design-X3,50 ,18
ENG253228-ENG102936-Dimming_Illumination_for_Display_Unit_day_design-X4,100 ,18
ENG253228-ENG103548-Dimming_Illumination_for_Display_Unit_day_design-X5,150 ,18
ENG253228-ENG113992-Dimming_Illumination_for_Display_Unit_day_design-X6,253 ,18
ENG253228-ENG99777-Dimming_Illumination_for_Display_Unit_day_design-Y1,0.6 %,18
ENG253228-ENG100480-Dimming_Illumination_for_Display_Unit_day_design-Y2,0.6 %,18
ENG253228-ENG100773-Dimming_Illumination_for_Display_Unit_day_design-Y3,1.0 %,18
ENG253228-ENG100631-Dimming_Illumination_for_Display_Unit_day_design-Y4,3.0 %,18
ENG253228-ENG102174-Dimming_Illumination_for_Display_Unit_day_design-Y5,30.0 %,18
ENG253228-ENG113993-Dimming_Illumination_for_Display_Unit_day_design-Y6,100.0 %,18
ENG253188-ENG258678-display_manager_configuration-abt_display_type,4 ,4
ENG253188-ENG259576-display_manager_configuration-driver_display_type,1 ,4
ENG253188-ENG260129-display_manager_configuration-hud_display_type,1 ,4
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,0 ms,2
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG331821-function_configuration_a2b_topology-External_sound_system,Not_present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG302728-function_configuration_a2b_topology-InnenSound_Unit,Not_present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,not installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,25 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP_over_IP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,OFF ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,On ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,On ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,OFF ,6
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,6 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,OFF ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,EU ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,On ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,On ,4
ENG248433-ENG248828-function_configuration_navigation-vza,not activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,activated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG331901-function_configuration_phone-Kopplebox_Fast_Charger,Deactivated ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,activated ,2
ENG248435-ENG297696-function_configuration_pso-iaa_function_new,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,activated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,activated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,EU_Band_III-N ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,1 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,not_active ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,not activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,Default ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,no_country ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,no_region ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,On ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,OFF ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG244879-ENG297725-function_configuration_sw_update-UOTA_T_Box,Not available ,1
ENG248440-function_configuration_swap_fod,swap_not_active_fod_slave_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,IVI_partition_only ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,FBAS ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,Deactivated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248442-geocoordinate_create,do_not_create ,1
ENG248443-geocoordinate_show,do_not show ,1
ENG297656-ENG297687-HMI_Display_Of_Online_Functionality-HMI_ID_0_OutOfData_Notification,activated ,5
ENG297656-ENG297688-HMI_Display_Of_Online_Functionality-HMI_ID_1_SoonOutOfData_Notifcation,activated ,5
ENG297656-ENG297689-HMI_Display_Of_Online_Functionality-HMI_ID_2_ModemStandby_Notification,activated ,5
ENG297656-ENG297690-HMI_Display_Of_Online_Functionality-HMI_ID_3_OCU_NoConnection_Notification,activated ,5
ENG297656-ENG297691-HMI_Display_Of_Online_Functionality-HMI_ID_4_OCU_Searching_Notification,activated ,5
ENG297656-ENG297692-HMI_Display_Of_Online_Functionality-HMI_ID_5_NoApn2Config_Notification,activated ,5
ENG297656-ENG297693-HMI_Display_Of_Online_Functionality-HMI_ID_6_NoConnection2WLANAP_Notification,activated ,5
ENG297656-ENG297694-HMI_Display_Of_Online_Functionality-HMI_ID_7_NoInternetViaWLAN_Notification,activated ,5
ENG297656-ENG297695-HMI_Display_Of_Online_Functionality-HMI_ID_81_OutOfRegion_Notification,activated ,5
ENG297656-ENG297718-HMI_Display_Of_Online_Functionality-Menu_System_Setup_Online_Service,activated ,5
ENG297656-ENG297720-HMI_Display_Of_Online_Functionality-Popup_Confirm_B2C_Switch,activated ,5
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248454-ENG248814-ipv4_address_of_subnet_4_on_ccu-segment_1,10 ,4
ENG248454-ENG248815-ipv4_address_of_subnet_4_on_ccu-segment_2,173 ,4
ENG248454-ENG248816-ipv4_address_of_subnet_4_on_ccu-segment_3,202 ,4
ENG248454-ENG248817-ipv4_address_of_subnet_4_on_ccu-segment_4,2 ,4
ENG248455-ENG248814-ipv4_address_of_subnet_4_on_mib-segment_1,10 ,4
ENG248455-ENG248815-ipv4_address_of_subnet_4_on_mib-segment_2,173 ,4
ENG248455-ENG248816-ipv4_address_of_subnet_4_on_mib-segment_3,202 ,4
ENG248455-ENG248817-ipv4_address_of_subnet_4_on_mib-segment_4,2 ,4
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG248463-ENG248814-ipv6_address_of_subnet_4_on_ccu-segment_1,64816 ,8
ENG248463-ENG248815-ipv6_address_of_subnet_4_on_ccu-segment_2,57486 ,8
ENG248463-ENG248816-ipv6_address_of_subnet_4_on_ccu-segment_3,49201 ,8
ENG248463-ENG248817-ipv6_address_of_subnet_4_on_ccu-segment_4,2 ,8
ENG248464-ENG248814-ipv6_address_of_subnet_4_on_mib-segment_1,64816 ,8
ENG248464-ENG248815-ipv6_address_of_subnet_4_on_mib-segment_2,57486 ,8
ENG248464-ENG248816-ipv6_address_of_subnet_4_on_mib-segment_3,49201 ,8
ENG248464-ENG248817-ipv6_address_of_subnet_4_on_mib-segment_4,2 ,8
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG278389-Market_and_brand_specific_preInstSet_of_webapps,preinstallation_set_0 ,1
ENG309780-Minimal_headless_Nav_Ready4ISA,Deactivated ,2
ENG253300-nearby_detection_room,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,60
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG273498-parkingsystem_video_input,1920x1080 ,3
ENG252007-ENG297686-Privacy_mode-globe_icon,activated ,2
ENG252007-ENG252075-Privacy_mode-supress_privacy_mode,not activated ,2
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG117912-ENG117775-Select_Remote_Test_DAB_Service-Parameter_Adaption_Service_ID,Conditions not correct or request sequence error,1
ENG117912-ENG117776-Select_Remote_Test_DAB_Service-Parameter_Adaption_Subservice_ID,Conditions not correct or request sequence error,1
ENG253230-slider_parameter,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,20
ENG248470-sortorder,sortorder_1 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG298059-view_control_default_values,1 ,6
ENG298060-ENG298113-view_control_features-layer_atm_available,Available ,2
ENG298060-ENG298114-view_control_features-layer_fpa_available,Available ,2
ENG298060-ENG298160-view_control_features-startup_last_layer,Not available ,2
ENG298060-ENG298163-view_control_features-view_control_function,Not available ,2
ENG248475-wlan_ap_local_net_dhcp_lease_time,72 H,1
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,12 ,1
Elapsed Time: 01:27
adpmap - 6C
SW:5QS-907-556-A HW:5WA-907-556-D --- 6C: Back-up Cam.
Component:TV eEntry H32 0675, Coding:020380003F142080
EV_CamSysTVFicosBL,001004,EV_CamSysTVFicosBL_VW41.rod
Sunday,26,July,2026,16:39:56:15875
VCDS Version: 26.7.0.1 (x64) Data version: 20260708 DS378.0
VCID: 5AEC9073CC9C99EAF16-800E-R
IDE00001-IDE15846-Production mode-Camera cleaning,not active ,3
IDE00001-MAS03384-Production mode-Blindness detection,not active ,3
IDE00001-MAS21952-Production mode-online calibration,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,3 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,32 min ,2
ENG153885-MAS00478-Knockout_test_mode-Reserved,0 ,1
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
Elapsed Time: 00:02
adpmap - 6D
SW:3J0-959-107-A HW:3J0-959-107 --- 6D: Trunk Elect.
Component:HDSG-Modul H02 0444, Coding:56C8
EV_DeckLidCONTIAU536,001009,EV_DeckLidCONTIAU536_001_VW42.rod
Sunday,26,July,2026,16:40:12:15875
VCID: 2D060BAFED92DE52444-8078-R
IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
IDE00001-MAS10735-Production mode-Calibration,not active ,3
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
IDE02158-Program opening stop,3569 ,2
IDE03435-Detection area upper,80 ,2
IDE03776-Offset for maximum programmable opening stop,60 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,400 ,4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,0 ,4
IDE09511-Minimum opening height of tailgate,1200 ,2
IDE09512-Deactivation of tailgate,active ,1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
IDE09514-MAS27006-Deactivation of tailgate while in trailer operation-Actuations for the rear lid opener in the virtual remote control vehicle key,not active ,2
IDE09514-MAS27007-Deactivation of tailgate while in trailer operation-Actuations for the rear lid closure in the virtual remote control vehicle key,not active ,2
IDE09520-Offset for opening height after basic setting,0 ,2
IDE10408-Opening height in production mode,0 %,2
IDE10695-Dectivation of the luggage compartment cover,active ,1
IDE10703-Luggage compartment cover: tolerance of the block counter,50 ,2
IDE10704-Luggage compartment cover: maximum no. of block drives,3 ,2
IDE10705-Luggage compartment cover: number bloom drives,100 ,2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,50 ,4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,150 ,4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,300 ,4
IDE10708-Luggage compartment cover: adjust. track tolerance,100 ,2
IDE10709-Luggage compartment cover: excess limitation in exclusion area,active ,1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,active ,2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,not active ,2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,not active ,2
ENG131232-MAS08212-Ausstattungen aktivieren-Motor 2,not active ,2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,not active ,2
Elapsed Time: 00:06
adpmap - 08
SW:3WA-907-007-F HW:3WA-907-007 --- 08: Auto HVAC
Component:Climatronic H01 5089, Coding:212010244111120010201010111011110000132110200000000000000000
EV_ACClimaBHBE3ADV,002062,EV_ACClimaBHBE3ADV_002_VW41.rod
Sunday,26,July,2026,16:23:53:15875
VCID: 48C85A3B62301B7A572-801C-R SFD+SFD2 [x]
IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
IDE00001-ENG369640-Production mode-ProductionByte_0,0 ,3
IDE00001-ENG369641-Production mode-ProductionByte_2,0 ,3
IDE00036-Vehicle equipment code,Variant 1 ,1
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,Service life-dependent store ,1
IDE01479-Gear ratio of engine - A/C compressor,1.26 ,1
IDE01482-After-run of parking heater or parking ventilation,not activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01536-Post heating of auxiliary heating,0 ,1
IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,0 min,1
IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1
IDE02744-IDE15865-Steering wheel heating-NTC target temperature stage 1 (Steering Wheel: Heated),34 °C,10
IDE02744-IDE15866-Steering wheel heating-NTC target temperature stage 2 (Steering Wheel: Heated),39 °C,10
IDE02744-IDE15867-Steering wheel heating-NTC target temperature stage 3 (Steering Wheel: Heated),44 °C,10
IDE02744-IDE15868-Steering wheel heating-PI controller I factor (Steering Wheel: Heated),0.40 ,10
IDE02744-IDE15869-Steering wheel heating-PI controller P factor (Steering Wheel: Heated),18 ,10
IDE02744-IDE15870-Steering wheel heating-Offset I controller target temperature (Steering Wheel: Heated),5 °C,10
IDE02744-IDE15871-Steering wheel heating-Maximum temperature (Steering Wheel: Heated),50 °C,10
IDE02744-IDE15872-Steering wheel heating-NTC static timeout (Steering Wheel: Heated),10 min,10
IDE02744-IDE15873-Steering wheel heating-Load mode timeout (Steering Wheel: Heated),10 min,10
IDE02744-IDE15874-Steering wheel heating-Automatic heating pad configuration (Steering Wheel: Heated),1 ms,10
IDE02744-IDE20215-Steering wheel heating-LIN SCSM installed,not activated ,10
IDE03176-Duration of compressor run in,40 s,1
IDE04074-Driving program,not installed ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,10
IDE04927-MAS12610-Window heater-Activation of wiper arm heater,4.0 °C,10
IDE04927-ENG263527-Window heater-Config_heating_voltage_request,No_set_point_voltage ,10
IDE04927-ENG263525-Window heater-Heating_rear_window_activation_time,320 s,10
IDE04927-ENG263512-Window heater-Heating_rear_window_cutoff_temperature,35.00 °C,10
IDE04927-ENG263556-Window heater-Heating_rear_window_temperature_activation_time,active ,10
IDE04927-ENG263570-Window heater-Window_heating_front_activation_time_pause,320 s,10
IDE04927-ENG263505-Window heater-Window_heating_front_cutoff_temperature,35.00 °C,10
IDE04927-ENG263589-Window heater-Window_heating_front_maximum_temperature_activation_time,1800 s,10
IDE04927-ENG263529-Window heater-Window_heating_front_temperature_activation_time,active ,10
IDE06089-ENG263584-Seat heater level current consumption allocation-Config_seat_heating_high_voltage_request,Sollspannungsanforderung 14.7 ,17
IDE06089-ENG263533-Seat heater level current consumption allocation-Config_seat_heating_low_voltage_request,Keine Spannungsanforderung ,17
IDE06089-ENG263526-Seat heater level current consumption allocation-Seat_heating_correction_of_temperature_regulation_on_heat_flow,0.0 °C,17
IDE06089-ENG263552-Seat heater level current consumption allocation-Seat_heating_filter_constant_for_heat_flow,1 s,17
IDE06089-ENG263578-Seat heater level current consumption allocation-Seat_heating_offset_voltage,15.7 V,17
IDE06089-ENG263544-Seat heater level current consumption allocation-Seat_heating_stage_1_lower_threshold,22.0 °C,17
IDE06089-ENG263507-Seat heater level current consumption allocation-Seat_heating_stage_1_upper_threshold,23.00 °C,17
IDE06089-ENG263592-Seat heater level current consumption allocation-Seat_heating_stage_2_lower_threshold,22.00 °C,17
IDE06089-ENG263559-Seat heater level current consumption allocation-Seat_heating_stage_2_upper_threshold,23.00 °C,17
IDE06089-ENG263539-Seat heater level current consumption allocation-Seat_heating_stage_3_lower_threshold,35.50 °C,17
IDE06089-ENG263554-Seat heater level current consumption allocation-Seat_heating_stage_3_upper_threshold,36.00 °C,17
IDE06089-ENG263536-Seat heater level current consumption allocation-Seat_heating_stage_4_lower_threshold,35.50 °C,17
IDE06089-ENG263549-Seat heater level current consumption allocation-Seat_heating_stage_4_upper_threshold,36.00 ,17
IDE06089-ENG263566-Seat heater level current consumption allocation-Seat_heating_stage_5_lower_threshold,52.50 ,17
IDE06089-ENG263597-Seat heater level current consumption allocation-Seat_heating_stage_5_upper_threshold,53.00 ,17
IDE06089-ENG263562-Seat heater level current consumption allocation-Seat_heating_stage_6_lower_threshold,52.50 °C,17
IDE06089-ENG263524-Seat heater level current consumption allocation-Seat_heating_stage_6_upper_threshold,53.00 ,17
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 l/min,1
IDE06545-Blower voltage for production routines,6.00 V,1
IDE06547-Air distribution for production routines,Air distribution top and footwell ,1
IDE06593-Air recirculation for production routines,Fresh air ,1
IDE07108-A/C styles,Display ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 s,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 s,2
IDE07301-Remote start function: activation of seat heating,Seat heating: front ,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07398-Blower logic with manual adjustment,Fan setting: absolute ,1
IDE07418-Additional filter,not installed ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,active for 10 minutes ,1
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,0 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,0 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,0 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,0 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,0 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,0 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,0 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,0 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,0 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,0 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,0 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,0 %,12
IDE10118-Fan speed reduction for telephony,not activated ,1
IDE10278-Behavior of compressor during moderate outside temperatures,inactive ,1
IDE11425-Rear blower logic: for manual adjustment,Matching coding ,1
IDE11426-Rear blower voltage: for voice activation,not activated ,1
IDE11427-Rear blower voltage: for production routines,6.00 V,1
IDE11428-Rear air distribution: for production routines,No effect ,1
IDE11631-MAS13043-Remaining run-time of the cooling circuit deaeration-Circuit 1,1200.0 s,2
IDE11631-MAS13044-Remaining run-time of the cooling circuit deaeration-Circuit 2,1200.0 s,2
IDE11935-Personalization,activated ,1
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,0 %,12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,0 %,12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,0 %,12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,0 %,12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,0 %,12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,0 %,12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,0 %,12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,0 %,12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,0 %,12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,0 %,12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,0 %,12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,0 %,12
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13371-Interior humidity sensor: sensitivity,Medium ,1
IDE14087-Time until seat heat recovery within the maximum level,0 min,1
IDE15635-Number of interruptions permitted during compressor run-in,10 ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,592 ,106
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,52 ,106
IDE16800-Pre-ventilation: coding override,not active ,1
IDE17680-IDE16487-Coolant: fill level detection-CO2 overfill detection,not active ,1
IDE17680-MAS14106-Coolant: fill level detection-CO2: low fill level detection,active when stationary ,1
IDE18112-Auxiliary heater: runtime,short ,1
IDE18376-MAS03179-Adjustment of the schedule table-Local data bus 2,1 s,4
IDE18376-MAS03180-Adjustment of the schedule table-Local data bus,1 s,4
IDE18376-MAS05972-Adjustment of the schedule table-Local data bus 3,0 s,4
IDE18376-MAS06525-Adjustment of the schedule table-Local data bus 4,1 s,4
IDE18376-MAS06526-Adjustment of the schedule table-Local data bus 5,0 ,4
IDE18376-MAS06527-Adjustment of the schedule table-Local data bus 6,0 s,4
IDE18376-MAS14771-Adjustment of the schedule table-Local data bus 7,0 s,4
IDE18376-MAS19909-Adjustment of the schedule table-Local data bus 8,0 s,4
IDE19964-ENG387656-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_1_lower_threshold,0.00 °C,17
IDE19964-ENG387657-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_1_upper_threshold,0.00 °C,17
IDE19964-ENG387658-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_2_lower_threshold,0.00 °C,17
IDE19964-ENG387659-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_2_upper_threshold,0.00 °C,17
IDE19964-ENG387660-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_3_lower_threshold,0.00 °C,17
IDE19964-ENG387661-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_3_upper_threshold,0.00 °C,17
IDE19964-ENG387662-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_4_lower_threshold,0.00 °C,17
IDE19964-ENG387663-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_4_upper_threshold,0.00 °C,17
IDE19964-ENG387664-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_5_lower_threshold,0.00 °C,17
IDE19964-ENG387665-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_5_upper_threshold,0.00 °C,17
IDE19964-ENG387666-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_6_lower_threshold,0.00 °C,17
IDE19964-ENG387667-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_6_upper_threshold,0.00 °C,17
IDE80009-Analysis 9,not activated ,1
IDE80010-Analysis 10,not activated ,1
IDE80011-Analysis 11,not activated ,1
MAS01651-Display and control unit: rear,Temperature ,1
MAS05214-Steering wheel heating,long_push ,1
MAS06414-Temperature tuning,normal tuning ,1
MAS06415-Blower adjustment,normal tuning ,1
MAS06416-Blower display in auto operation,not activated ,1
MAS06417-Amplified overshoots heater operation,not activated ,1
MAS19886-Interior temperature sensor: after-run time,180 s,2
SFT00117-Emergency call module and communication unit,installed ,1
ENG263483-AC_evaporator_temperature_offset,-0.70 K,1
ENG276128-air_recirculation_deactivate_at_open_sunroof,activated ,1
ENG316722-AP_Clima_Master_FL_Setup,87 09 20 00 A7 19 A4 00 01 00 42 00 00 00 00 00 07 00 42 00 00 00 00 00 ,24
ENG316723-AP_Clima_Zone1_FL_Setup,15 04 20 09 17 0D 20 0B 07 00 00 C0 74 D6 07 07 00 00 C0 74 56 07 00 00 00 00 00 00 7A 01 00 00 00 00 00 00 00 00 00 00 ,40
ENG316724-AP_Clima_Zone2_FL_Setup,00 00 00 00 01 04 00 00 00 00 00 00 00 00 00 06 06 00 00 00 04 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,40
ENG316725-AP_SIH_FL_Setup,05 00 03 00 03 00 00 00 00 43 03 00 00 00 00 00 00 01 01 00 00 00 00 00 00 ,25
ENG316726-AP_Steering_wheel_heating,03 25 25 00 00 00 00 00 00 00 ,10
ENG316727-AP_Windowheater,3F 00 00 00 00 00 00 00 00 00 00 00 00 ,13
ENG263479-Auto-Toggle,not activated ,1
ENG263474-ENG263585-Development_Messages_Mode_Activation-General_Messages,0 ,18
ENG263474-ENG263519-Development_Messages_Mode_Activation-LIN_1_Messages,0 ,18
ENG263474-ENG263517-Development_Messages_Mode_Activation-LIN_2_Messages,0 ,18
ENG263474-ENG263537-Development_Messages_Mode_Activation-LIN_3_Messages,0 ,18
ENG263474-ENG263573-Development_Messages_Mode_Activation-LIN_4_Messages,0 ,18
ENG263474-ENG263548-Development_Messages_Mode_Activation-LIN_5_Messages,0 ,18
ENG263474-ENG263518-Development_Messages_Mode_Activation-LIN_6_Messages,0 ,18
ENG263474-ENG263550-Development_Messages_Mode_Activation-LIN_7_Messages,0 ,18
ENG263474-ENG263508-Development_Messages_Mode_Activation-LIN_8_Messages,0 ,18
ENG263440-Entwicklungs-ID für Entwicklungszwecke freischalten,0 ,2
ENG153885-Knockout_test_mode,0 ,1
ENG263490-manuel_air_recirculation_deacivate_AUTO_mode,activated ,1
ENG263452-OnBoardDiagnose für Entwicklungszwecke freischalten,not activated ,1
ENG279929-ENG280096-pms_data_to_hmi-papam_pms_inside,No display ,2
ENG279929-ENG280097-pms_data_to_hmi-papam_pms_outside,No display ,2
ENG263450-seat_dependent_climatisation,not activated ,1
ENG263443-seatheatin_function_switch,AUTO_seatheating_function ,1
ENG263458-winterfunction,not installed ,1
Elapsed Time: 00:24
adpmap - 09
SW:5WA-937-084-AG HW:5WA-937-084-R --- 09: Cent. Elect.
Component:BCM37w_H H26 0326, Coding:
EV_BCMwBL,004001,EV_BCMwBL_004.rod
Sunday,26,July,2026,16:26:10:15875
VCID: 1470BE4B6EF86F9A6BA-8040-R SFD+SFD2 [x]
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE00001-ENG260220-Production mode-Remotestart Pmode,not active ,3
IDE00301-Distance,22841 km,4
IDE01550-Service position,172.834993 °,2
IDE02455-MAS28776-Light function "Coming/Leaving Home"-Coming Home light: installation status,Enabled ,2
IDE02455-MAS28799-Light function "Coming/Leaving Home"-Leaving Home light: default value for activation via BAP,active ,2
IDE02455-MAS28801-Light function "Coming/Leaving Home"-Leaving Home light: installation status,automatic ,2
IDE02455-MAS28805-Light function "Coming/Leaving Home"-Display of Leaving Home light history,active ,2
IDE02455-MAS28890-Light function "Coming/Leaving Home"-Leaving Home and Coming Home light menu settings,Changing the Leaving Home and Coming Home light time via BAP ,2
IDE02455-MAS28898-Light function "Coming/Leaving Home"-Display of Coming Home light history,active ,2
IDE02455-MAS28918-Light function "Coming/Leaving Home"-Coming Home light: default value for activation via BAP,active ,2
IDE02488-Anti-theft system interior monitoring,Security access required You should unlock SFD before attempting advanced functions.,2
IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE03471-ENG369552-Vehicle configuration-Fahrzeugplattform,MQB ,16
IDE03471-ENG369585-Vehicle configuration-Innenraumsuche_SmartDevices_Freigeben_bei_Remotestart,not activated ,16
IDE03471-ENG369594-Vehicle configuration-Ladetankklappe_bereich,Entry_bereich_gesamt ,16
IDE03471-ENG369608-Vehicle configuration-MDK_System_aktiv,not activated ,16
IDE03471-ENG369637-Vehicle configuration-PassiveEntry_FK_aktiv,not activated ,16
IDE03471-ENG369638-Vehicle configuration-PassiveGo_Startberechtigter_Innenraum,ohne Kofferraum ,16
IDE03471-ENG259357-Vehicle configuration-PassiveKomfortTogglen_aktiv,not activated ,16
IDE03471-ENG369646-Vehicle configuration-Reichweitenueberpruefung_fuer_RPA_aktiv,not activated ,16
IDE03471-ENG369649-Vehicle configuration-Rke_fenster_sad_komfortlauf,not activated ,16
IDE03471-ENG369650-Vehicle configuration-Rke_frontdeckel_entriegeln,not activated ,16
IDE03471-ENG369651-Vehicle configuration-Rke_fzg_entriegeln_aktiv,not activated ,16
IDE03471-ENG369652-Vehicle configuration-Rke_heckdeckel_entriegeln,not activated ,16
IDE03471-ENG369653-Vehicle configuration-Rke_heckdeckel_komfortlauf,not activated ,16
IDE03471-ENG369654-Vehicle configuration-Rke_panic_alarm,not activated ,16
IDE03471-ENG369655-Vehicle configuration-Rke_verdeck_komfortlauf,not activated ,16
IDE03471-ENG369657-Vehicle configuration-RSAD_Kanal_A_aktiv,not activated ,16
IDE03471-ENG369658-Vehicle configuration-RSAD_Kanal_B_aktiv,not activated ,16
IDE03471-ENG369686-Vehicle configuration-UWB_BT_HR_verbaut,not activated ,16
IDE03471-ENG369687-Vehicle configuration-UWB_BT_IN_H_KR_verbaut,not activated ,16
IDE03471-ENG369688-Vehicle configuration-UWB_BT_IN_H_verbaut,not activated ,16
IDE03471-ENG369689-Vehicle configuration-UWB_BT_VL verbaut,not activated ,16
IDE03471-ENG369690-Vehicle configuration-UWB_HL_verbaut,not activated ,16
IDE03471-ENG369691-Vehicle configuration-UWB_IN_V_KR_verbaut,not activated ,16
IDE03471-ENG369692-Vehicle configuration-UWB_IN_V_verbaut,not activated ,16
IDE03471-ENG369693-Vehicle configuration-UWB_Kanal_5_aktiv,not activated ,16
IDE03471-ENG369694-Vehicle configuration-UWB_Kanal_6_aktiv,not activated ,16
IDE03471-ENG369695-Vehicle configuration-UWB_Kanal_8_aktiv,not activated ,16
IDE03471-ENG369696-Vehicle configuration-UWB_Kanal_9_aktiv,not activated ,16
IDE03471-ENG369697-Vehicle configuration-UWB_VR_verbaut,not activated ,16
IDE03471-ENG369746-Vehicle configuration-WAL_beim_Timeout_aktiv,not activated ,16
IDE03471-ENG369747-Vehicle configuration-WAL_beim_Verschwinden_aktiv,not activated ,16
IDE03471-ENG369748-Vehicle configuration-WAL_mit _Schluessel_im_Innenraum_aktiv,not activated ,16
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,not active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,1000 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,1000 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,0 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,800 ms,7
IDE05822-Anti-theft alarm system vehicle inclination sensor,Security access required You should unlock SFD before attempting advanced functions.,7
IDE05823-DWA Interior monitoring parameter set,01 08 08 00 43 53 0A 78 02 14 0A 33 81 33 0C FF 00 00 01 55 97 04 0F 0E 73 00 F4 0B 32 87 6B 23 75 5B 57 DB 28 46 3F 3A 69 58 85 2E 0A A3 02 CA 06 53 00 0E 19 00 88 0A 30 F7 66 0F E3 4A 87 1B 08 36 3F 3A 69 58 83 08 0A A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 4A 77 1B 08 26 3F 3A 69 47 83 08 0A A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 28 57 1B 08 26 3F 3A 69 58 82 05 0A A3 05 3C 26 09 15 0C 16 18 86 09 26 34 67 23 55 5B 57 9B 28 26 0C FA 0A 44 85 2E 0A A3 21 03 00 35 4C 0F 0F 0F 38 B7 13 45 2B DA ,172
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beams ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,Main beam ,4
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG331134-Air conditioning/heating function via remote control-pa_RSt_MOD_CAPTCHA_aktiv,active ,8
IDE07007-ENG331135-Air conditioning/heating function via remote control-pa_t_Motorstartanforderung_RSt,not active ,8
IDE07007-ENG331136-Air conditioning/heating function via remote control-pa_t_S2_Timer_RSt_MOD,15 s,8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG331137-Air conditioning/heating function via remote control-Remotestart_MOD_verbaut,not installed ,8
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,70 min,2
IDE07161-temporary VIN,Conditions not correct or request sequence error,2
IDE07356-Position during interval mode,29.890080 °,2
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,present ,9
IDE08786-MAS28772-Assistance light functions-Automatic headlight control: delay,500 ms,9
IDE08786-MAS28775-Assistance light functions-Light sensor sensitivity,normal ,9
IDE08786-MAS28910-Assistance light functions-Masking of rain light menu,not active ,9
IDE08786-MAS28926-Assistance light functions-Rain-activated automatic headlight control,active ,9
IDE08786-MAS28927-Assistance light functions-Rotary light switch: fault output,active ,9
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,600 s,5
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,0 s,5
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,Driver side ,5
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,Open circuit ,5
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,Open circuit ,5
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,600 s,5
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,0 s,5
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,Front passenger side ,5
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,Open circuit ,5
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,Open circuit ,5
IDE09546-Multicontour seat on driver's side: reset compressor counter,Activate ,1
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,Activate ,1
IDE09548-Multicontour seat on driver's side: reset adaptation,Activate ,1
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,Exhaust Malfunction Indicator Lamp (MIL) (OBD) ,1
IDE09767-MAS28778-Position lamps-Two-sided parking light availability,24 s,7
IDE09767-MAS28828-Position lamps-Two-sided parking light reduction,active ,7
IDE09767-MAS28897-Position lamps-Parking light activated via steering-column switch,One-sided ,7
IDE09767-MAS28901-Position lamps-Distinction between light warning for campers and passenger cars,Terminal-dependent ,7
IDE09767-MAS28902-Position lamps-Condition for two-sided parking light limitation/deactivation,Switch-off due to energy management ,7
IDE09767-MAS28903-Position lamps-Conditions for parking light limitation,Switch-off due to energy management ,7
IDE09767-MAS28904-Position lamps-Factor for availability timer,Availability up to 24 hours of operation – five minutes ,7
IDE09767-MAS28931-Position lamps-Two-sided parking light OFF with dipped beam switch: S contact OFF,active ,7
IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,7
IDE10298-Alternating park position 1,9.846144 °,2
IDE10299-Alternating park position 2,25.846128 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,2
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,1 s,12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,900 ms,12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schlüsselsuche,0 s,12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,800 ms,12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,2 km/h,12
IDE10845-ENG121904-Control module rear lid opening: vehicle type-Rear_Lid_Opening_Sender_vehicle_type,00 ,12
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,12
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,12
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,12
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,12
IDE12302-SFT00022-Identification of sub-bus participant-Steering Column Electronics,old ,6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-Left taillight 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271948-Identification of sub-bus participant-Left rear door control module,old ,6
IDE12302-SFT271949-Identification of sub-bus participant-Right rear door control module,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Power rear lid opening control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-Left taillight 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right taillight 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right taillight 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver's side,old ,6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger's side,old ,6
IDE12488-Antenna 1 for short-range communication,No Response From Subnet Component,6
IDE12986-IDE18243-BAP configuration-Switch-on and off effect 1,15 ,8
IDE12986-IDE18244-BAP configuration-Switch-on and off effect 2,3 ,8
IDE12986-IDE20547-BAP configuration-Available HD projections in the HMI menu,0 ,8
IDE12986-IDE20548-BAP configuration-Default value for HD projection in the HMI menu,0 ,8
IDE13391-IDE17779-BAP function status-Exit/entry lighting: brightness detection,New ,16
IDE13391-IDE17826-BAP function status-Switchable light signature: front added,not installed ,16
IDE13391-IDE17827-BAP function status-Light signature: front,not installed ,16
IDE13391-IDE17828-BAP function status-Light signature: rear,not installed ,16
IDE13391-IDE17848-BAP function status-Switchable light signature: rear added,not installed ,16
IDE13391-IDE18239-BAP function status-Daytime running light timer: delay,0 ms,16
IDE13391-IDE18240-BAP function status-Low beam headlight timer: delay,0 ms,16
IDE13391-IDE18241-BAP function status-Default value for operating and display log for taillight animation,1 ,16
IDE13391-IDE18242-BAP function status-Default value for operating and display log for turn signal animation,1 ,16
IDE13391-IDE20512-BAP function status-Operating and display log: taillight signature standard value,0 ,16
IDE13391-IDE20515-BAP function status-Installation coding: troubleshooting switchable light signatures,not installed ,16
IDE13391-MAS28779-BAP function status-Leaving Home lights,Low beams ,16
IDE13391-MAS28797-BAP function status-Leaving Home light: default value for time setting via BAP,10 seconds ,16
IDE13391-MAS28798-BAP function status-Leaving Home light: default value for time setting during the day,10 seconds ,16
IDE13391-MAS28800-BAP function status-Leaving Home light: switch-on event,Ignition On ,16
IDE13391-MAS28803-BAP function status-Leaving Home and Coming Home light: run-on,0 ms,16
IDE13391-MAS28804-BAP function status-Daytime running light with Leaving Home light during the day in AUTO position,not active ,16
IDE13391-MAS28816-BAP function status-Daytime running light with Coming Home light during the day in AUTO position,not active ,16
IDE13391-MAS28833-BAP function status-Switchable signatures,not installed ,16
IDE13391-MAS28891-BAP function status-Coming Home light: default value for time setting during the day,10 seconds ,16
IDE13391-MAS28892-BAP function status-Coming Home light: default value for time setting via BAP,10 seconds ,16
IDE13391-MAS28915-BAP function status-Switchable signatures: selection of light functions for switching,00 ,16
IDE13391-MAS28916-BAP function status-Switchable signatures: operating mode (ECE: NAR: RoW),0 ,16
IDE13391-MAS28920-BAP function status-Default value for operating and display log headlight signature,0 ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,600 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,1200 lx,16
IDE15050-ENG258767-Occupant Detection-central locking system deactivation_ComfortReadyStatus,true ,20
IDE15050-ENG261091-Occupant Detection-ComfortReadyStatus_Klemme_S,false ,20
IDE15050-ENG260007-Occupant Detection-deactivation_ComfortReadyStatus,door ,20
IDE15050-ENG258901-Occupant Detection-DriverSBE_Out,true ,20
IDE15050-ENG260692-Occupant Detection-HV_Fahreranwesenheit_aktiv,false ,20
IDE15050-ENG259960-Occupant Detection-HV_Fahreranwesenheit_deactivation_via_Kl15,false ,20
IDE15050-ENG259613-Occupant Detection-nm_cluster_ComfortReadyStatus,not_active ,20
IDE15050-ENG261255-Occupant Detection-nm_cluster_tuer,not_active ,20
IDE15050-ENG259794-Occupant Detection-nm_timeout_tuer,90 s,20
IDE15050-ENG260195-Occupant Detection-OccupantSBE_Out,true ,20
IDE15050-ENG258604-Occupant Detection-timeout_ComfortReadyStatus,30 s,20
IDE15050-ENG260437-Occupant Detection-timeout_DriverExitIntent,30 s,20
IDE15901-Direct entry keys,not installed ,2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,Yes ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
IDE15906-ENG395123-Light control module-High_Beam_Architecture,6_DLA_FCM_AFS_and_HB ,4
IDE15906-ENG430598-Light control module-LCM_Mounting,FCM_connected ,4
IDE15906-ENG430599-Light control module-LCM_Turn_Indicator,false ,4
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,388
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,00 C1 ,388
IDE19299-MAS14172-Smart rear combination lamp: configuration-Brake light larger area,not active ,23
IDE19299-MAS14173-Smart rear combination lamp: configuration-Brake light smaller area,not active ,23
IDE19299-MAS28752-Smart rear combination lamp: configuration-Dynamic taillight,not active ,23
IDE19299-MAS28753-Smart rear combination lamp: configuration-Adaptive brightness adjustment: rear,not active ,23
IDE19299-MAS28754-Smart rear combination lamp: configuration-Activation status: additional taillight faulty,not active ,23
IDE19299-MAS28755-Smart rear combination lamp: configuration-Activation status: diagnostics LED faulty,not active ,23
IDE19299-MAS28756-Smart rear combination lamp: configuration-Activation status: diagnostics status faulty,not active ,23
IDE19299-MAS28757-Smart rear combination lamp: configuration-Upper speed threshold: dynamic taillight ON,75 km/h,23
IDE19299-MAS28758-Smart rear combination lamp: configuration-Lower speed threshold: dynamic taillight OFF,60 km/h,23
IDE19299-MAS28759-Smart rear combination lamp: configuration-Lower speed threshold: braking surface reduced ON,10 km/h,23
IDE19299-MAS28760-Smart rear combination lamp: configuration-Upper speed threshold: braking surface reduced OFF,20 km/h,23
IDE19299-MAS28765-Smart rear combination lamp: configuration-Taillight animation: when light button module is set to AUTO,not active ,23
IDE19299-MAS28766-Smart rear combination lamp: configuration-Taillight animation: dimming activation when terminal 15 OFF,0 ,23
IDE19299-MAS28767-Smart rear combination lamp: configuration-Taillight animation: dimming activation when terminal 15 ON,0 ,23
IDE19299-MAS28771-Smart rear combination lamp: configuration-Delay time until braking surface must be engaged,10 ms,23
IDE19299-MAS28773-Smart rear combination lamp: configuration-Upper distance threshold: increase braking surface,0.00 m,23
IDE19299-MAS28774-Smart rear combination lamp: configuration-Lower distance threshold: reduce braking surface,0.00 m,23
IDE19299-MAS28780-Smart rear combination lamp: configuration-Lower ambient brightness threshold: decrease brightness of rear combination lamp,4000 lx,23
IDE19299-MAS28781-Smart rear combination lamp: configuration-Upper ambient brightness threshold: increase brightness of rear combination lamp,50000 lx,23
IDE19299-MAS28793-Smart rear combination lamp: configuration-Acceleration threshold: brake light area enlargement,-16.00000 m/s˛,23
IDE19299-ENG260962-Smart rear combination lamp: configuration-p_CHO_LHO_statisch,not active ,23
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,255 s,5
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,60 s,5
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,255 ,5
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,16 V,5
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,9 V,5
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,3 hPa,30
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,65535 hPa,30
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,300 hPa,30
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,270 hPa,30
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,65535 hPa,30
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,400 hPa,30
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,10 hPa,30
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,65535 hPa,30
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,0 hPa,30
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,0 hPa,30
IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,65535 hPa,30
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,2 hPa,30
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,65535 hPa,30
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,65535 hPa,30
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,255 s,5
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,60 s,5
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,255 ,5
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,16 V,5
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,9 V,5
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,3 hPa,30
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,65535 hPa,30
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,300 hPa,30
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,270 hPa,30
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,65535 hPa,30
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,400 hPa,30
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,10 hPa,30
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,65535 hPa,30
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,0 hPa,30
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,0 hPa,30
IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,65535 hPa,30
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,2 hPa,30
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,65535 hPa,30
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,65535 hPa,30
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,100 %,6
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,255 %,6
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,80 %,6
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,255 %,6
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,65535 ms,6
IDE80016-Analysis 16,10 s,1
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,0 hPa,64
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,0 hPa,64
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,0 hPa,64
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,0 hPa,64
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,0 hPa,64
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,0 hPa,64
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,0 hPa,64
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,0 hPa,64
IDE80017-ENG289601-Analysis 17-Offset_PP1,0 %,64
IDE80017-ENG289602-Analysis 17-Offset_PP2,0 %,64
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,0 ms,64
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,0 ms,64
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,0 ms,64
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,0 ms,64
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,0 ms,64
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,0 ms,64
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,0 ms,64
IDE80017-ENG289603-Analysis 17-Offset_T1,0 °C,64
IDE80017-ENG289604-Analysis 17-Offset_T2,0 °C,64
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,0 ms,64
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,0 ms,64
IDE80017-ENG133491-Analysis 17-p_longpush_time,0 ms,64
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,255 %,64
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,255 %,64
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,45 %,64
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,66 %,64
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,20 %,64
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,24 %,64
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,46 %,64
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,65535 ms,64
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,65535 ms,64
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,65535 ms,64
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,255 ,64
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,255 min,64
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,255 min,64
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,255 ms,64
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,255 min,64
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,255 min,64
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,variant_2 ,64
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,255 s,64
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,255 s,64
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,60 %,64
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,60 %,64
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,0 hPa,64
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,0 hPa,64
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,0 hPa,64
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,0 hPa,64
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,0 hPa,64
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,0 hPa,64
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,0 hPa,64
IDE80018-ENG289601-Analysis 18-Offset_PP1,0 %,64
IDE80018-ENG289602-Analysis 18-Offset_PP2,0 %,64
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,0 ms,64
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,0 ms,64
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,0 ms,64
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,0 ms,64
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,0 ms,64
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,0 ms,64
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,0 ms,64
IDE80018-ENG289603-Analysis 18-Offset_T1,0 °C,64
IDE80018-ENG289604-Analysis 18-Offset_T2,0 °C,64
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,0 hPa,64
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,0 ms,64
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,0 ms,64
IDE80018-ENG133491-Analysis 18-p_longpush_time,0 ms,64
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,255 %,64
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,255 %,64
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,45 %,64
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,66 %,64
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,20 %,64
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,24 %,64
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,46 %,64
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,65535 ms,64
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,65535 ms,64
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,65535 ms,64
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,255 ,64
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,255 min,64
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,255 min,64
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,255 ms,64
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,255 min,64
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,255 min,64
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,variant_2 ,64
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,255 s,64
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,255 s,64
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,60 %,64
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,60 %,64
IDE80025-ENG126865-Analysis 25-s_Kompressorleistung_Manuelle_Befuellung_LRD,100 %,6
IDE80025-ENG126867-Analysis 25-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,255 %,6
IDE80025-ENG126866-Analysis 25-s_Kompressorleistung_Memorisierte_Befuellung_LRD,80 %,6
IDE80025-ENG126868-Analysis 25-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,255 %,6
IDE80025-ENG125690-Analysis 25-s_VerzoegerungszeitKompressoranlauf,65535 ms,6
MAS05055-lower turn position,29.890080 °,2
MAS05056-upper turn position,172.834993 °,2
MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),On ,3
MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),OFF ,3
MAS05807-ENG264069-Coding-APS bei Abparken (1bit),On ,3
MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),OFF ,3
MAS05807-ENG264071-Coding-APS für 100 Zyklen deaktiv (1bit),OFF ,3
MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),On ,3
MAS05807-ENG264178-Coding-geräusch optimierte Wischkennlinie (1bit),OFF ,3
MAS05807-ENG264181-Coding-langsames Abparken (1bit),OFF ,3
MAS05807-ENG264190-Coding-Produktionsmodus möglich (1bit),On ,3
MAS05807-ENG264192-Coding-Regensensoraktivierung über Fahrfreigabe (1bit),On ,3
MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),On ,3
MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),On ,3
MAS05807-ENG264271-Coding-softe Geschwindigkeitsrückschaltung (1bit),OFF ,3
MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),OFF ,3
MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),OFF ,3
MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),On ,3
MAS05807-ENG264276-Coding-Tränenwischen (1bit),On ,3
MAS05807-ENG264279-Coding-v-abhängige Wischstufenrückschaltung (1bit),On ,3
MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),OFF ,3
MAS05894-IDE13022-Engine run on-Function activation,not active ,4
MAS05894-MAS13391-Engine run on-Delay time timer,400 ms,4
MAS07146-MAS13125-Button 1-Function of button 1,not coded / not installed ,1
MAS07146-MAS13128-Button 1-Indicator lamp button 1,installed ,1
MAS07147-MAS13129-Button 2-Function of button 2,not coded / not installed ,1
MAS07147-MAS13131-Button 2-Indicator lamp button 2,installed ,1
MAS07148-MAS13132-Button 3-Function of button 3,not coded / not installed ,1
MAS07148-MAS13134-Button 3-Indicator lamp button 3,installed ,1
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 1E ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,3500 lx,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Medium ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,3800 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,3500 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS09325-IDE13878-Daytime running lights-Activation: daytime running lights,Daytime running lights ,8
MAS09325-MAS09335-Daytime running lights-Daytime running lights/parking light,not active ,8
MAS09325-MAS16273-Daytime running lights-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lights-Daytime running indicator lamp,not active ,8
MAS09325-MAS28806-Daytime running lights-Daytime running light: speed-dependent,0 km/h,8
MAS09325-MAS28807-Daytime running lights-Daytime running light: deactivation via speed,not active ,8
MAS09325-MAS28808-Daytime running lights-Daytime running light: switchover of standard output value,active ,8
MAS09325-MAS28812-Daytime running lights-Deactivate daytime/continuous running light with handbrake active,not active ,8
MAS09325-MAS28813-Daytime running lights-Daytime/continuous running light also activates two-sided parking light,not active ,8
MAS09325-MAS28814-Daytime running lights-Daytime running light activation possible via BAP or operating sequence,not active ,8
MAS09325-MAS28815-Daytime running lights-Daytime running light only in AUTO switch position,active ,8
MAS09325-ENG387560-Daytime running lights-DRL_activates_tail_light,not active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,active ,8
MAS12382-MAS28788-Dynamic turn signal control-Multi-collision indication,not active ,8
MAS12382-MAS28820-Dynamic turn signal control-Side Assist: left turn signal,active ,8
MAS12382-MAS28821-Dynamic turn signal control-Side Assist: right turn signal,active ,8
MAS12382-MAS28825-Dynamic turn signal control-Hazard warning lights with ignition off,active ,8
MAS12382-MAS28826-Dynamic turn signal control-Hazard warning lights with ignition on,active ,8
MAS12382-MAS28829-Dynamic turn signal control-Emergency warning signal: emergency brake display: phase 2,active ,8
MAS12382-MAS28831-Dynamic turn signal control-Turn signal: left,active ,8
MAS12382-MAS28832-Dynamic turn signal control-Turn signal: right,active ,8
MAS12382-MAS28912-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal confirmation,active ,8
MAS12382-MAS28913-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal left,active ,8
MAS12382-MAS28914-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal right,active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,50 ms,8
MAS13139-MAS13135-Button 4-Function of button 4,not coded / not installed ,1
MAS13139-MAS13136-Button 4-Indicator lamp button 4,installed ,1
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,0 ,37
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,1 ,37
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,1 ,37
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,3 ,37
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,0 ,37
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,16 ,37
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,16 ,37
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,32 ,37
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,32 ,37
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,2 ,37
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,31 ,37
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,2 ,37
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,31 ,37
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,0 ,37
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,10 ,37
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,10 ,37
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,0 ,37
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,0 ,37
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,0 ,37
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,0 ,37
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,active ,37
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,not active ,37
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,not active ,37
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,Bottom ,37
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,Dynamic ,37
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,3 ,37
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,not active ,37
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,Dynamic ,37
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,10 ,37
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,not active ,37
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,active ,37
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,50 ,37
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,2 ,37
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,12 ,37
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,4 ,37
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,Do not reset ,37
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,16 ,37
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,16 ,37
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,16 ,37
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,16 ,37
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,2 ,37
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,31 ,37
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,2 ,37
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,31 ,37
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,224 ,37
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,10 ,37
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,10 ,37
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,0 ,37
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,0 ,37
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,0 ,37
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,0 ,37
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,6 ,37
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,25 ,37
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,255 ,37
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,5 ,37
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,60 ,37
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,224 ,37
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,0 ,37
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,not active ,37
MAS14140-IDE15905-Flashing function-Travel Assist,active ,4
MAS14140-IDE18029-Flashing function-Rush Hour Pilot,not active ,4
MAS14140-IDE20494-Flashing function-Installation coding: flashing request for rush hour pilot,not active ,4
MAS14140-IDE21298-Flashing function-Travel Assist Handsfree,not active ,4
MAS14140-MAS28783-Flashing function-Driving assistance system: flashing function,Lane change alert flashing: hazard warning signals and brake light signals ,4
MAS14140-MAS28895-Flashing function-Hazard warning lights by means of driver assist system,active ,4
MAS14140-MAS28928-Flashing function-Horn via driver assist system,active ,4
MAS18824-IDE15903-Light button module-Light button module,LTM_Zentraltaste ,12
MAS18824-MAS21301-Light button module-Reactivation limit light,95 m,12
MAS18824-ENG246963-Light button module-Anzeigezeit_LTM_PopUp1,4.0 s,12
MAS18824-ENG246964-Light button module-Anzeigezeit_LTM_PopUp1_lang,4 s,12
MAS18824-ENG246965-Light button module-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12
MAS18824-ENG246966-Light button module-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12
MAS18824-ENG246978-Light button module-Licht_anforderung_FAS,not installed ,12
MAS18824-ENG246979-Light button module-Licht_anforderung_Pilopark,active ,12
MAS18824-ENG246982-Light button module-LTM_Anzeige_Config,02 ,12
MAS18824-ENG246983-Light button module-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12
MAS18824-ENG246984-Light button module-LTM_BGL_Geschwindigkeitsabhängig,active ,12
MAS18824-ENG246985-Light button module-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,12
MAS18824-ENG246986-Light button module-LTM_BGL_Wegabhängig,active ,12
MAS18824-ENG246987-Light button module-LTM_GlobalOFF_Geschwindigkeitsabhängig,active ,12
MAS18824-ENG246988-Light button module-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,12
MAS18824-ENG246989-Light button module-LTM_GlobalOFF_Wegabhängig,active ,12
MAS18824-ENG246990-Light button module-LTM_GlobalOFF_Zündungsabhängig,not active ,12
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
SFT00061-MAS10520-Special Function-Special function 1,not installed ,4
SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,4
ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,4
ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,4
ENG344785-ENG345280-Alco_lock_coding-Alco_lock_installed,No ,2
ENG344785-ENG422578-Alco_lock_coding-Comfort_ready_debounce,No ,2
ENG344785-ENG422661-Alco_lock_coding-Eval_comfort_ready,No ,2
ENG344785-ENG422662-Alco_lock_coding-Eval_driver_presence,No ,2
ENG344785-ENG422663-Alco_lock_coding-Eval_external_LIN_activity_by_LIN_busmaster,No ,2
ENG344785-ENG422664-Alco_lock_coding-Eval_unplausible_values_from_Alco_lock,No ,2
ENG344785-ENG422700-Alco_lock_coding-LIN_send_delay,No ,2
ENG344785-ENG422701-Alco_lock_coding-LIN_send_delay_msg_counter,No ,2
ENG344785-ENG422736-Alco_lock_coding-Permanent_terminal_15_release_in_unset_mode,No ,2
ENG344785-ENG422761-Alco_lock_coding-USS_debounce,No ,2
ENG344785-ENG422762-Alco_lock_coding-Vehicle_state_change_mode_set_mode_to_shut_down_via_timeout,Yes ,2
ENG344786-ENG422579-Alco_lock_parameter-Counter_unplausible_data_received,0 s,21
ENG344786-ENG422581-Alco_lock_parameter-Debounce_Comfort_ready_signal,0.0 s,21
ENG344786-ENG422582-Alco_lock_parameter-Debounce_USS_signals,0.0 s,21
ENG344786-ENG422699-Alco_lock_parameter-LIN_data_send_delay,0.0 s,21
ENG344786-ENG413992-Alco_lock_parameter-Qual_time_delay_DTC_104,0.0 s,21
ENG344786-ENG422745-Alco_lock_parameter-Rpm_threshold_engine_running,100 /min,21
ENG344786-ENG422750-Alco_lock_parameter-Speed_threshold_vehicle_stopped,7.0 km/h,21
ENG344786-ENG422751-Alco_lock_parameter-State_change_set_mode_to_unset_mode_via_terminal_15,Condition_terminal_15_active ,21
ENG344786-ENG414014-Alco_lock_parameter-Time_delay_switchoff_LIN_activity_bit,0.0 s,21
ENG344786-ENG422754-Alco_lock_parameter-Timeout_automatic_transition_set_mode_to_shut_down,5 min,21
ENG344786-ENG422755-Alco_lock_parameter-Timeout_automatic_transition_unset_mode_to_set_mode,1 s,21
ENG344786-ENG422756-Alco_lock_parameter-Timeout_protocol_validation,5 s,21
ENG344786-ENG422757-Alco_lock_parameter-Timeout_switchoff_alco_lock_after_idle_followup_time,0.0 min,21
ENG344786-ENG346064-Alco_lock_parameter-Used_LIN_version,LIN_2_0 ,21
ENG344786-ENG422760-Alco_lock_parameter-Used_protocol_version,Norm_version_2022 ,21
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,100 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,00 01 FF FF 02 03 FF FF ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,FF FF FF FF 0E 0F FF FF ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,0E 0F FF FF 10 11 FF FF ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,0E 0F FF FF FF FF FF FF ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,00 01 FF FF FF FF FF FF ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,FF FF FF FF 06 07 FF FF ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,0A 0B FF FF 0A 0B FF FF ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,0C 0D FF FF 0A 0B FF FF ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,04 05 FF FF FF FF FF FF ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,08 09 FF FF FF FF FF FF ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,8806 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,0 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,25.5 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,active ,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,600.00 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,active ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,active ,270
ENG253358-ENG403619-Anpassungen_Exterior_Light-VIP30_Dimmzeit,0 ms,270
ENG253358-ENG403620-Anpassungen_Exterior_Light-VIP30_Umfeld-SALR,00 ,270
ENG253358-ENG403621-Anpassungen_Exterior_Light-VIP30_Umfeld-TSG,00 ,270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung,not active ,8
ENG253146-ENG345149-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung Bremslicht,not active ,8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,No ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,00 ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,00 ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,00 ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,00 ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,00 ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,00 ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,not active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,not active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,activated ,4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,activated ,4
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer für Ausführung des Abschaltwunsch an SPN,2.0 s,8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8
ENG253240-ENG346089-Automatisierte Abschaltungen-Verfügbarkeit Hinweis Komfortabschaltung,active ,8
ENG253240-ENG346090-Automatisierte Abschaltungen-Verfügbarkeit Hinweis Komfortabschaltung bevorstehend,active ,8
ENG253240-ENG346091-Automatisierte Abschaltungen-Verfügbarkeit Hinweis Standlichtnachlauf,active ,8
ENG253240-ENG346092-Automatisierte Abschaltungen-Verfügbarkeit Hinweis zur Weiterfahrt,not active ,8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verfügbarkeit Komfortabschaltung,Available ,8
ENG253240-ENG258110-Automatisierte Abschaltungen-Zündungsabschaltung über Energiemanagement,Available ,8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG307652-ENG331129-Child Presence Detection-p_CPD_warnton_aktiv,not active ,2
ENG307652-ENG331130-Child Presence Detection-p_t_Delta_Timer,10 ,2
ENG307652-ENG331133-Child Presence Detection-p_ZV_child_presence_detection,active ,2
ENG253018-Clamp_Control,Driver´s door ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,10 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,10 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,10 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,10 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG344797-ENG345093-Config A2L_Monitor-Address 1,00 00 00 00 ,16
ENG344797-ENG345094-Config A2L_Monitor-Address 2,00 00 00 00 ,16
ENG344797-ENG345095-Config A2L_Monitor-Address 3,00 00 00 00 ,16
ENG344797-ENG345096-Config A2L_Monitor-Address 4,00 00 00 00 ,16
ENG344801-Datensatz PrDet (SC 790),30 33 30 39 30 37 39 30 50 52 44 45 54 32 30 36 01 00 01 00 01 00 01 01 01 01 01 01 01 01 00 01 0A 01 0E 00 C8 01 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 D4 03 D4 03 D4 03 D4 00 00 00 00 00 00 00 00 03 D1 03 D1 03 D1 03 D1 00 00 00 00 00 00 00 00 03 C5 03 C5 03 C5 03 C5 00 00 00 00 00 00 00 00 03 95 03 95 03 95 03 95 03 55 03 55 03 55 03 55 02 D5 02 D5 02 D5 02 D5 01 D5 01 D5 01 D5 01 D5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7E 0A 88 FA ,512
ENG344802-Datensatz USS,30 34 30 31 30 30 36 31 55 53 53 30 30 30 30 34 00 32 00 64 07 D0 01 F4 00 0A 03 E8 00 00 00 1E 00 32 00 32 00 32 00 32 02 58 05 07 D0 01 01 01 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 E0 D6 DD ,128
ENG253229-ENG258467-Define_Const-Dimm2Bin,1 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 on or off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,activated ,6
ENG253216-ENG345291-DevCod_Automatische_Verriegelung-AutomatischeFunktionenDurchExterneTrigger_aktiv,activated ,6
ENG253028-DevCod_Bedienstellen,not activated ,1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,not activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,not activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,not activated ,6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering assignment,Left ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schließverhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,not activated ,6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,activated ,6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetür,activated ,6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,sounder_installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-MAS31160-Diebstahlschutz.Modulsoftware-OBD monitoring,active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,not active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,60_ms ,6
ENG253244-ENG278531-Diebstahlschutz.Modulsoftware-dwa_alarm_delay_quelle,immidiat_driver_door_contact_thatcham ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,not active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,not activated ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,00000000 00000000 ,66
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,11111111 11111111 ,66
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,11111101 00011110 ,66
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,00000000 00000000 ,66
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,00000000 00000000 ,66
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,00000000 00000000 ,66
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,00000000 00000000 ,66
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,00000000 00000000 ,66
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,00000000 00000000 ,66
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,11111101 00011110 ,66
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,11111101 00011110 ,66
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,11111101 00011110 ,66
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,11111101 00011110 ,66
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,11111101 00011110 ,66
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,11111101 00011110 ,66
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,00000000 00000000 ,66
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,00000000 00000000 ,66
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,00000000 00000000 ,66
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,00000000 00000000 ,66
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,00000000 00000000 ,66
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,00000000 00000000 ,66
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,00000000 00000000 ,66
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,00000000 00000000 ,66
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,00000000 00000000 ,66
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,00000000 00000000 ,66
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,00000000 00000000 ,66
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,00000000 00000000 ,66
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,00000000 00000000 ,66
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,00000000 00000000 ,66
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,00000000 00000000 ,66
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,11111111 11111111 ,66
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,11111111 11111111 ,66
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,11111111 11111111 ,66
ENG286142-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,66
ENG286142-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,66
ENG286142-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,66
ENG286142-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,66
ENG286142-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,66
ENG286142-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,66
ENG286142-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,66
ENG286142-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,66
ENG286142-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,66
ENG286142-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,66
ENG286142-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,66
ENG286142-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,66
ENG286142-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,66
ENG286142-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,66
ENG286142-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,66
ENG286142-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,66
ENG286142-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,66
ENG286142-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,66
ENG286142-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,66
ENG286142-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,66
ENG286142-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,66
ENG286142-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,66
ENG286142-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,66
ENG286142-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,66
ENG286142-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,66
ENG286142-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,66
ENG286142-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,66
ENG286142-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,66
ENG286142-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,66
ENG286142-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,66
ENG286142-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,66
ENG286142-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,66
ENG286142-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,66
ENG286142-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,66
ENG286142-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,66
ENG286142-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,66
ENG286142-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,66
ENG286142-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,66
ENG286142-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,66
ENG286142-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,66
ENG286142-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,66
ENG286142-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,66
ENG286142-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,66
ENG286142-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,66
ENG286142-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,66
ENG286142-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,66
ENG286142-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,66
ENG286142-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,66
ENG286142-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,66
ENG286142-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,66
ENG286142-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,66
ENG286142-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,66
ENG286142-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,66
ENG286142-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,66
ENG286142-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,66
ENG286142-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,66
ENG286142-IDE80057-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,66
ENG286142-IDE80058-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,66
ENG286142-IDE80059-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,66
ENG286142-IDE80060-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,66
ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,66
ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,66
ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,66
ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,66
ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,66
ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,66
ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,66
ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,66
ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,66
ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,66
ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,66
ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,66
ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,66
ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,66
ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,66
ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,66
ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,66
ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,66
ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,66
ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,66
ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,66
ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,66
ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,66
ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,66
ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,66
ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,66
ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,66
ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,66
ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,66
ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,66
ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,66
ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,66
ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,66
ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,66
ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,66
ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,66
ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,66
ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,66
ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,66
ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,66
ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,66
ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,66
ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,66
ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,66
ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,66
ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,66
ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,66
ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,66
ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,66
ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,66
ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,66
ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,66
ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,66
ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,66
ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,66
ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,66
ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,66
ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,66
ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,66
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,B1 35 91 0F 08 21 84 66 9A 3F D1 F8 02 5C 17 5C 0C 94 2F B6 52 BB 9F DA 6F FE 10 97 E8 0B 75 3E 33 F1 93 E6 7A 60 DA 1F AF E8 8F 3F 41 EB 9D 5C 3A C0 BD D8 AB BD 7A FC 52 5A 15 3C 04 CA 6F 2A E6 95 91 C9 D8 4C DC BD 91 AF 88 94 B3 B4 86 34 C9 3A 31 A5 EE BA 2B BF E2 6B C0 BE 4F 8B 4F A6 E6 E1 17 BD 90 B4 EB D0 36 E5 80 F8 93 5E 34 6E 95 0E 32 39 76 F0 6C 6A CA DE 80 95 8E 06 0E B7 C6 10 C7 97 EC F9 7C FE 29 ED 02 2C 9C E3 E5 71 81 B3 ED 7D F3 BD ,150
ENG253243-ENG286261-Easy Open-p_a_Schiebetürentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,active ,4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,active ,4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_15,not active ,4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_S,not active ,4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Motorlauf,not active ,4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,5 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,50 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,10 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,activated ,4
ENG253250-MAS28923-Fahrlichthinweis-Multiple warnings when driving in the dark without lights,active ,4
ENG253250-MAS28924-Fahrlichthinweis-Warning when driving in the dark without lights: configuration,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG141650-MAS28896-Fernlicht_assistent-Resetting high-beam control Light Assist,not active ,6
ENG141650-MAS28925-Fernlicht_assistent-Factory setting for high-beam control Light Assist – information electronics menu,present ,6
ENG141650-MAS28929-Fernlicht_assistent-Activation of high-beam control Light Assist: menu in information electronics,present ,6
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ,LIN ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,not active ,6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Keine_Spannungsanforderung ,6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant,active ,6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,kein Wischerstopp ,6
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
ENG117283-ENG263535-Frontwaschfunktion-Waschfrequenz_bei_LSS_aus,0 ,2
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4
ENG171911-ENG141957-Funk-Radio freq.,MQB37w: 434 MHz RdW + NAR (2-kanalig) ,4
ENG253288-Grundparameter SPN-,10000 ms,30
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30
ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen,active ,8
ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,8
ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden,Always ,8
ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit,installed ,8
ENG141645-MAS00212-HW_Verbau-Washer fluid low,installed ,8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8
ENG141645-ENG152427-HW_Verbau-Rear window defogger,installed ,8
ENG253080-IAA Nutzermanagement,installed ,1
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,not activated ,4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,1 ,4
ENG253039-MAS21321-Intelligente Heckleuchte-Verbau-Audi parking system installed,not installed ,4
ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-Left taillight 1,installed ,4
ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-Left taillight 2,installed ,4
ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right taillight 1,installed ,4
ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right taillight 2,installed ,4
ENG253039-ENG345762-Intelligente Heckleuchte-Verbau-LIN_SBBR_full_e2e,active ,4
ENG253039-ENG261019-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_KZL_iSBBR,active ,4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,not active ,4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,01 ,96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,11 ,96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,11 ,96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,100 %,96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,50 %,96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,50 %,96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,50 %,96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,50 %,96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,50 %,96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,50 %,96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,50 %,96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,50 %,96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,50 %,96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,50 %,96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,50 %,96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,50 %,96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,50 %,96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,50 %,96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,01 ,96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,01 ,96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,active ,96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,00 ,96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,01 ,96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,01 ,96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,00 ,96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,01 ,96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,01 ,96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,01 ,96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,01 ,96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,01 ,96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,01 ,96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,01 ,96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,01 ,96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,01 ,96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,01 ,96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,01 ,96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,01 ,96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,01 ,96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,01 ,96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,01 ,96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,01 ,96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,01 ,96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,01 ,96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,01 ,96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,01 ,96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,01 ,96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,01 ,96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,01 ,96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,01 ,96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,01 ,96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,01 ,96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,01 ,96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,01 ,96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,01 ,96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,01 ,96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,01 ,96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,01 ,96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,01 ,96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,01 ,96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,01 ,96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,01 ,96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,01 ,96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,01 ,96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,01 ,96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,01 ,96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,01 ,96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,01 ,96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,01 ,96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,01 ,96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,01 ,96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,01 ,96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,01 ,96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,01 ,96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,01 ,96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,01 ,96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,01 ,96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,01 ,96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,01 ,96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,01 ,96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,01 ,96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,01 ,96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,01 ,96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,01 ,96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,01 ,96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,00 ,96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,01 ,96
ENG253069-ENG436052-Interior_light_external_events-Display_ORU_on_TK,not active ,16
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,active ,16
ENG253069-ENG403530-Interior_light_external_events-External_event_activation_atmospheres,not active ,16
ENG253069-ENG403531-Interior_light_external_events-External_event_activation_door_scenario,not active ,16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16
ENG253069-ENG403532-Interior_light_external_events-External_event_activation_wellbeing,not active ,16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,active ,9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,active ,9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,active ,9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,active ,9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,active ,9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,active ,9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,active ,9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,active ,9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,active ,9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,active ,9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,active ,9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,active ,9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,active ,9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,active ,9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,active ,9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,active ,9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,active ,9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,active ,9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,active ,9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,active ,9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,active ,9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,active ,9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,active ,9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,active ,9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,active ,9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,active ,9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,active ,9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,active ,9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,active ,9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,active ,9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,active ,9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,active ,9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,active ,9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,active ,9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,active ,9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,active ,9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,active ,9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,active ,9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,active ,9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,active ,9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,active ,9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,active ,9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,active ,9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,active ,9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,active ,9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,active ,9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,active ,9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,active ,9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,active ,9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,active ,9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,active ,9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,active ,9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,active ,9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,active ,9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,active ,9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,active ,9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,active ,9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,active ,9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,active ,9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,active ,9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,active ,9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,active ,9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,active ,9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,active ,9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,active ,9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,active ,9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,active ,9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,active ,9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,active ,9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,active ,9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,active ,14
ENG253391-ENG403484-Interior_light_general_settings-Automatic_intensity_adjustment,not active ,14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,active ,14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,active ,14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,not active ,14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,02 ,14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,not active ,14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,not active ,14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14
ENG253391-ENG403552-Interior_light_general_settings-Overvoltage_deactivation,not active ,14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14
ENG253391-ENG403611-Interior_light_general_settings-Undervoltage_deactivation,not active ,14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 10 08 00 00 00 60 00 00 00 00 00 0C 00 00 00 31 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,64 ,100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,64 ,100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,64 ,100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,64 ,100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,64 ,100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,64 ,100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,64 ,100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,64 ,100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,active ,100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,active ,100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,active ,100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,active ,100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,active ,100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,active ,100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,active ,100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,active ,100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,active ,100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,00 ,100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,active ,100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,0F ,100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,0F ,100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,0F ,100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,0F ,100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,0F ,100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,0F ,100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,0F ,100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,0F ,100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,03 ,100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,03 ,100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,02 ,100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,00 ,100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,00 ,100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,03 ,100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,00 ,100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,03 ,100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,02 ,100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,02 ,100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,00 ,100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,00 ,100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,02 ,100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,00 ,100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,00 ,100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,00 ,100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,00 ,100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,00 ,100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,00 ,100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,00 ,100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,00 ,100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,03 ,100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,03 ,100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,03 ,100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,00 ,100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,00 ,100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,03 ,100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,03 ,100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,03 ,100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,02 ,100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,00 ,100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,00 ,100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,02 ,100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,5 s,100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,active ,100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,01 ,100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,active ,100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,not active ,100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,active ,100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,active ,100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,active ,100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,13 ,100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,07 ,100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,FF ,100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,05 ,100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,17 ,100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100
ENG253355-Interior_light_interface_function,No_voltage_requirement ,1
ENG253312-ENG297177-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_1,21 ,51
ENG253312-ENG297178-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_10,47 ,51
ENG253312-ENG297179-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_11,8A ,51
ENG253312-ENG297180-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_12,8C ,51
ENG253312-ENG297181-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_13,00 ,51
ENG253312-ENG297182-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_14,00 ,51
ENG253312-ENG297183-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_15,00 ,51
ENG253312-ENG297184-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_2,00 ,51
ENG253312-ENG297185-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_3,00 ,51
ENG253312-ENG297186-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_4,29 ,51
ENG253312-ENG297187-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_5,19 ,51
ENG253312-ENG297188-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_6,00 ,51
ENG253312-ENG297189-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_7,00 ,51
ENG253312-ENG297190-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_8,00 ,51
ENG253312-ENG297191-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_9,57 ,51
ENG253312-ENG297192-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_1,0A ,51
ENG253312-ENG297193-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_10,30 ,51
ENG253312-ENG297194-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_11,89 ,51
ENG253312-ENG297195-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_12,8B ,51
ENG253312-ENG297196-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_13,00 ,51
ENG253312-ENG297197-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_14,00 ,51
ENG253312-ENG297198-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_15,00 ,51
ENG253312-ENG297199-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_2,00 ,51
ENG253312-ENG297200-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_3,00 ,51
ENG253312-ENG297201-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_4,12 ,51
ENG253312-ENG297202-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_5,02 ,51
ENG253312-ENG297203-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_6,00 ,51
ENG253312-ENG297204-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_7,00 ,51
ENG253312-ENG297205-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_8,00 ,51
ENG253312-ENG297206-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_9,40 ,51
ENG253312-ENG297207-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_1,61 ,51
ENG253312-ENG297208-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_10,A8 ,51
ENG253312-ENG297209-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_11,00 ,51
ENG253312-ENG297210-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_12,00 ,51
ENG253312-ENG297211-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_13,00 ,51
ENG253312-ENG297212-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_14,00 ,51
ENG253312-ENG297213-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_15,00 ,51
ENG253312-ENG297214-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_2,73 ,51
ENG253312-ENG297215-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_3,74 ,51
ENG253312-ENG297216-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_4,63 ,51
ENG253312-ENG297217-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_5,00 ,51
ENG253312-ENG297218-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_6,00 ,51
ENG253312-ENG297219-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_7,00 ,51
ENG253312-ENG297220-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_8,7F ,51
ENG253312-ENG297221-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_9,80 ,51
ENG253312-ENG297222-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_1,Offset_0 ,51
ENG253312-ENG297223-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_10,Offset_0 ,51
ENG253312-ENG297224-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_11,Offset_0 ,51
ENG253312-ENG297225-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_12,Offset_0 ,51
ENG253312-ENG297226-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_13,Offset_0 ,51
ENG253312-ENG297227-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_14,Offset_0 ,51
ENG253312-ENG297228-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_15,Offset_0 ,51
ENG253312-ENG297229-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_2,Offset_0 ,51
ENG253312-ENG297230-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_3,Offset_0 ,51
ENG253312-ENG297231-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_4,Offset_0 ,51
ENG253312-ENG297232-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_5,Offset_0 ,51
ENG253312-ENG297233-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_6,Offset_0 ,51
ENG253312-ENG297234-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_7,Offset_0 ,51
ENG253312-ENG297235-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_8,Offset_0 ,51
ENG253312-ENG297236-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_9,Offset_0 ,51
ENG253312-ENG297237-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_1,Offset_0 ,51
ENG253312-ENG297238-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_10,Offset_0 ,51
ENG253312-ENG297239-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_11,Offset_0 ,51
ENG253312-ENG297240-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_12,Offset_0 ,51
ENG253312-ENG297241-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_13,Offset_0 ,51
ENG253312-ENG297242-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_14,Offset_0 ,51
ENG253312-ENG297243-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_15,Offset_0 ,51
ENG253312-ENG297244-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_2,Offset_0 ,51
ENG253312-ENG297245-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_3,Offset_0 ,51
ENG253312-ENG297246-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_4,Offset_0 ,51
ENG253312-ENG297247-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_5,Offset_0 ,51
ENG253312-ENG297248-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_6,Offset_0 ,51
ENG253312-ENG297249-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_7,Offset_0 ,51
ENG253312-ENG297250-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_8,Offset_0 ,51
ENG253312-ENG297251-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_9,Offset_0 ,51
ENG253312-ENG297252-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_1,Offset_0 ,51
ENG253312-ENG297253-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_10,Offset_0 ,51
ENG253312-ENG297254-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_11,Offset_0 ,51
ENG253312-ENG297255-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_12,Offset_0 ,51
ENG253312-ENG297256-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_13,Offset_0 ,51
ENG253312-ENG297257-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_14,Offset_0 ,51
ENG253312-ENG297258-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_15,Offset_0 ,51
ENG253312-ENG297259-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_2,Offset_0 ,51
ENG253312-ENG297260-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_3,Offset_0 ,51
ENG253312-ENG297261-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_4,Offset_0 ,51
ENG253312-ENG297262-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_5,Offset_0 ,51
ENG253312-ENG297263-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_6,Offset_0 ,51
ENG253312-ENG297264-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_7,Offset_0 ,51
ENG253312-ENG297265-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_8,Offset_0 ,51
ENG253312-ENG297266-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_9,Offset_0 ,51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,12 ,93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,00 ,93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,00 ,93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,FE ,93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,00 ,93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,00 ,93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,14 ,93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,22 ,93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,04 ,93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,05 ,93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,00 ,93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,0A ,93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,20 ,93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,00 ,93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,1A ,93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,14 ,93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,21 ,93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,04 ,93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,05 ,93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,00 ,93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,08 ,93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,1F ,93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,00 ,93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,00 ,93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,00 ,93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,18 ,93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,0C ,93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,10 ,93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,0D ,93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,0E ,93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,38 ,93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,00 ,93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,23 ,93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,24 ,93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,FF ,93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,FF ,93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,FF ,93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,FF ,93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,FF ,93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,FF ,93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,00 ,93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,00 ,93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,67 ,93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,00 ,93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,69 ,93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,00 ,93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,00 ,93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,66 ,93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,00 ,93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,68 ,93
ENG253388-ENG247388-Kessyfunktion-beeptime_reunlock,60_ms ,4
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,active ,4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4
ENG253388-ENG248300-Kessyfunktion-reunlock_beep,active ,4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4
ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0,maximize ,20
ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0,maximize ,20
ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0,maximize ,20
ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0,0 ,20
ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0,0 ,20
ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0,0 ,20
ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0,0 ,20
ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0,00 ,20
ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0,00 ,20
ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0,not_active ,20
ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0,Always ,20
ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0,not active ,20
ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0,not active ,20
ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0,not active ,20
ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0,not active ,20
ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0,not active ,20
ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0,not active ,20
ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0,not active ,20
ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0,not active ,20
ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0,not active ,20
ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0,not active ,20
ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0,not active ,20
ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0,not active ,20
ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1,maximize ,20
ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1,maximize ,20
ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1,maximize ,20
ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1,0 ,20
ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1,0 ,20
ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1,0 ,20
ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1,0 ,20
ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1,0 ,20
ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1,0 ,20
ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1,not_active ,20
ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1,Always ,20
ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1,not active ,20
ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1,not active ,20
ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1,not active ,20
ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1,not active ,20
ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1,not active ,20
ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1,not active ,20
ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1,not active ,20
ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1,not active ,20
ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1,not active ,20
ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1,not active ,20
ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1,not active ,20
ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1,not active ,20
ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10,maximize ,20
ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10,maximize ,20
ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10,maximize ,20
ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10,0 ,20
ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10,0 ,20
ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10,0 ,20
ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10,0 ,20
ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10,0 ,20
ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10,0 ,20
ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10,not_active ,20
ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10,Always ,20
ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10,not active ,20
ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10,not active ,20
ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10,not active ,20
ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10,not active ,20
ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10,not active ,20
ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10,not active ,20
ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10,not active ,20
ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10,not active ,20
ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10,not active ,20
ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10,not active ,20
ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10,not active ,20
ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10,not active ,20
ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11,maximize ,20
ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11,maximize ,20
ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11,maximize ,20
ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11,0 ,20
ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11,0 ,20
ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11,0 ,20
ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11,0 ,20
ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11,0 ,20
ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11,0 ,20
ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11,not_active ,20
ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11,Always ,20
ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11,not active ,20
ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11,not active ,20
ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11,not active ,20
ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11,not active ,20
ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11,not active ,20
ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11,not active ,20
ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11,not active ,20
ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11,not active ,20
ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11,not active ,20
ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11,not active ,20
ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11,not active ,20
ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11,not active ,20
ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12,maximize ,20
ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12,maximize ,20
ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12,maximize ,20
ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12,0 ,20
ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12,0 ,20
ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12,0 ,20
ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12,0 ,20
ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12,0 ,20
ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12,0 ,20
ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12,not_active ,20
ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12,Always ,20
ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12,not active ,20
ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,not active ,20
ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12,not active ,20
ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12,not active ,20
ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12,not active ,20
ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12,not active ,20
ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12,not active ,20
ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12,not active ,20
ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12,not active ,20
ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12,not active ,20
ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12,not active ,20
ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12,not active ,20
ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13,maximize ,20
ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13,maximize ,20
ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13,maximize ,20
ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13,0 ,20
ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13,0 ,20
ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13,0 ,20
ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13,0 ,20
ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13,0 ,20
ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13,0 ,20
ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13,not_active ,20
ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13,Always ,20
ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13,not active ,20
ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,not active ,20
ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13,not active ,20
ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13,not active ,20
ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13,not active ,20
ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13,not active ,20
ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13,not active ,20
ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13,not active ,20
ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13,not active ,20
ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13,not active ,20
ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13,not active ,20
ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13,not active ,20
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,0 ,20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,0 ,20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,0 ,20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,not_active ,20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,not active ,20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,not active ,20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,0 ,20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,0 ,20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,0 ,20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,not_active ,20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,not active ,20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,not active ,20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,maximize ,20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,0 ,20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,0 ,20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,0 ,20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,0 ,20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,not_active ,20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,not active ,20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,not active ,20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,not active ,20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,not active ,20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,maximize ,20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,0 ,20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,0 ,20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,0 ,20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,0 ,20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,not_active ,20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,not active ,20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,not active ,20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,not active ,20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,not active ,20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20
ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2,maximize ,20
ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2,maximize ,20
ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2,maximize ,20
ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2,0 ,20
ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2,0 ,20
ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2,0 ,20
ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2,0 ,20
ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2,0 ,20
ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2,0 ,20
ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2,not_active ,20
ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2,Always ,20
ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2,not active ,20
ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2,not active ,20
ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2,not active ,20
ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2,not active ,20
ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2,not active ,20
ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2,not active ,20
ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2,not active ,20
ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2,not active ,20
ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2,not active ,20
ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2,not active ,20
ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2,not active ,20
ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2,not active ,20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,maximize ,20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,maximize ,20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,maximize ,20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,0 ,20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,0 ,20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,0 ,20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,0 ,20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,0 ,20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,not_active ,20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,not active ,20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,not active ,20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,not active ,20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,not active ,20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,not active ,20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,maximize ,20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,maximize ,20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,maximize ,20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,0 ,20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,0 ,20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,0 ,20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,0 ,20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,0 ,20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,not_active ,20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,not active ,20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,not active ,20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,not active ,20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,not active ,20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,not active ,20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,44 ,20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,41 ,20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20
ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32,maximize ,20
ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32,maximize ,20
ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32,maximize ,20
ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32,0 ,20
ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32,0 ,20
ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32,0 ,20
ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32,0 ,20
ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32,0 ,20
ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32,0 ,20
ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32,not_active ,20
ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32,Always ,20
ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32,not active ,20
ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32,not active ,20
ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32,not active ,20
ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32,not active ,20
ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32,not active ,20
ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32,not active ,20
ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32,not active ,20
ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32,not active ,20
ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32,not active ,20
ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32,not active ,20
ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32,not active ,20
ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32,not active ,20
ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24,maximize ,20
ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24,maximize ,20
ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24,maximize ,20
ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24,0 ,20
ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24,0 ,20
ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24,0 ,20
ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24,0 ,20
ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24,0 ,20
ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24,0 ,20
ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24,not_active ,20
ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24,Always ,20
ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24,not active ,20
ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24,not active ,20
ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24,not active ,20
ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24,not active ,20
ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24,not active ,20
ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24,not active ,20
ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24,not active ,20
ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24,not active ,20
ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24,not active ,20
ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24,not active ,20
ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24,not active ,20
ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24,not active ,20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,100 ,20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,100 ,20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,48 ,20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,40 ,20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allgemeine_LED_bis_6W ,20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Position lamps ,20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,Ambiente Exterior 4 ,20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20
ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26,maximize ,20
ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26,maximize ,20
ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26,maximize ,20
ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26,0 ,20
ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26,0 ,20
ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26,0 ,20
ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26,0 ,20
ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26,0 ,20
ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26,0 ,20
ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26,not_active ,20
ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26,Always ,20
ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26,not active ,20
ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26,not active ,20
ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26,not active ,20
ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26,not active ,20
ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26,not active ,20
ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26,not active ,20
ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26,not active ,20
ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26,not active ,20
ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26,not active ,20
ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26,not active ,20
ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26,not active ,20
ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26,not active ,20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,0 ,20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,0 ,20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,0 ,20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,not_active ,20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,not active ,20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20
ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28,maximize ,20
ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28,maximize ,20
ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28,maximize ,20
ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28,0 ,20
ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28,0 ,20
ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28,0 ,20
ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28,0 ,20
ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28,0 ,20
ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28,0 ,20
ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28,not_active ,20
ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28,Always ,20
ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28,not active ,20
ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28,not active ,20
ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28,not active ,20
ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28,not active ,20
ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28,not active ,20
ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28,not active ,20
ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28,not active ,20
ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28,not active ,20
ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28,not active ,20
ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28,not active ,20
ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28,not active ,20
ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28,not active ,20
ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29,maximize ,20
ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29,maximize ,20
ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29,maximize ,20
ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29,127 ,20
ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29,0 ,20
ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29,0 ,20
ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29,0 ,20
ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29,50 ,20
ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29,0 ,20
ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29,LED_Tagfahrlicht_modul_Signal ,20
ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29,Always ,20
ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29,Rueckfahrlicht ,20
ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29,not active ,20
ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29,not active ,20
ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29,not active ,20
ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29,not active ,20
ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29,not active ,20
ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29,not active ,20
ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29,not active ,20
ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29,not active ,20
ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29,not active ,20
ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29,not active ,20
ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29,not active ,20
ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3,maximize ,20
ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3,maximize ,20
ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3,maximize ,20
ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3,0 ,20
ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3,0 ,20
ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3,0 ,20
ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3,0 ,20
ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3,0 ,20
ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3,0 ,20
ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3,not_active ,20
ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3,Always ,20
ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3,not active ,20
ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3,not active ,20
ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3,not active ,20
ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3,not active ,20
ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3,not active ,20
ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3,not active ,20
ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3,not active ,20
ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3,not active ,20
ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3,not active ,20
ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3,not active ,20
ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3,not active ,20
ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3,not active ,20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,0 ,20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,0 ,20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,0 ,20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,not_active ,20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,not active ,20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,100 ,20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,102 ,20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,0 ,20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,Ambientelicht 1 ,20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,0 ,20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,0 ,20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,0 ,20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,0 ,20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,0 ,20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,0 ,20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20
ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35,maximize ,20
ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35,maximize ,20
ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35,maximize ,20
ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35,100 ,20
ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35,0 ,20
ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35,0 ,20
ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35,0 ,20
ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35,99 ,20
ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35,0 ,20
ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35,Always ,20
ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35,Warnblink Taster Suchbeleuchtung ,20
ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35,not active ,20
ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35,not active ,20
ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35,not active ,20
ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35,not active ,20
ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35,not active ,20
ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35,not active ,20
ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35,not active ,20
ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35,not active ,20
ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35,not active ,20
ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35,not active ,20
ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35,not active ,20
ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36,maximize ,20
ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36,maximize ,20
ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36,maximize ,20
ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36,0 ,20
ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36,0 ,20
ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36,0 ,20
ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36,0 ,20
ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36,0 ,20
ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36,0 ,20
ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36,not_active ,20
ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36,Always ,20
ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36,not active ,20
ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36,not active ,20
ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36,not active ,20
ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36,not active ,20
ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36,not active ,20
ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36,not active ,20
ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36,not active ,20
ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36,not active ,20
ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36,not active ,20
ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36,not active ,20
ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36,not active ,20
ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36,not active ,20
ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37,maximize ,20
ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37,maximize ,20
ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37,maximize ,20
ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37,0 ,20
ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37,0 ,20
ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37,0 ,20
ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37,0 ,20
ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37,0 ,20
ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37,0 ,20
ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37,not_active ,20
ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37,Always ,20
ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37,not active ,20
ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37,not active ,20
ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37,not active ,20
ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37,not active ,20
ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37,not active ,20
ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37,not active ,20
ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37,not active ,20
ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37,not active ,20
ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37,not active ,20
ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37,not active ,20
ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37,not active ,20
ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37,not active ,20
ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38,maximize ,20
ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38,maximize ,20
ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38,maximize ,20
ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38,0 ,20
ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38,0 ,20
ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38,0 ,20
ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38,0 ,20
ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38,0 ,20
ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38,0 ,20
ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38,not_active ,20
ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38,Always ,20
ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38,not active ,20
ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38,not active ,20
ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38,not active ,20
ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38,not active ,20
ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38,not active ,20
ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38,not active ,20
ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38,not active ,20
ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38,not active ,20
ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38,not active ,20
ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38,not active ,20
ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38,not active ,20
ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38,not active ,20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,0 ,20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,0 ,20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20
ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4,maximize ,20
ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4,maximize ,20
ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4,maximize ,20
ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4,0 ,20
ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4,0 ,20
ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4,0 ,20
ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4,0 ,20
ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4,0 ,20
ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4,0 ,20
ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4,not_active ,20
ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4,Always ,20
ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4,not active ,20
ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4,not active ,20
ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4,not active ,20
ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4,not active ,20
ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4,not active ,20
ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4,not active ,20
ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4,not active ,20
ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4,not active ,20
ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4,not active ,20
ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4,not active ,20
ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4,not active ,20
ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4,not active ,20
ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40,maximize ,20
ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v,maximize ,20
ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40,maximize ,20
ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40,0 ,20
ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40,0 ,20
ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40,0 ,20
ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40,0 ,20
ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40,0 ,20
ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40,0 ,20
ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40,not_active ,20
ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40,Always ,20
ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40,not active ,20
ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40,not active ,20
ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40,not active ,20
ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40,not active ,20
ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40,not active ,20
ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40,not active ,20
ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40,not active ,20
ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40,not active ,20
ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40,not active ,20
ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40,not active ,20
ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40,not active ,20
ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40,not active ,20
ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41,maximize ,20
ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41,maximize ,20
ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41,maximize ,20
ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41,0 ,20
ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41,0 ,20
ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41,0 ,20
ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41,0 ,20
ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41,0 ,20
ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41,0 ,20
ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41,not_active ,20
ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41,Always ,20
ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41,not active ,20
ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41,not active ,20
ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41,not active ,20
ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41,not active ,20
ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41,not active ,20
ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41,not active ,20
ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41,not active ,20
ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41,not active ,20
ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41,not active ,20
ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41,not active ,20
ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41,not active ,20
ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41,not active ,20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,0 ,20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,0 ,20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,0 ,20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,not_active ,20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,not active ,20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,not active ,20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,not active ,20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,0 ,20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,0 ,20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,0 ,20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,not_active ,20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,not active ,20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,not active ,20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,not active ,20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,133 ,20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,0 ,20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED Lichtmodul ohne Open Load Diagnose ,20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,aktiv100prozent ,20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20
ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45,maximize ,20
ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45,maximize ,20
ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45,maximize ,20
ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45,100 ,20
ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45,0 ,20
ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45,0 ,20
ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45,0 ,20
ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45,137 ,20
ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45,0 ,20
ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45,Always ,20
ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45,Luggage compartment light ,20
ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45,not active ,20
ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45,not active ,20
ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45,not active ,20
ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45,not active ,20
ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45,not active ,20
ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45,not active ,20
ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45,not active ,20
ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45,not active ,20
ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45,not active ,20
ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45,not active ,20
ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45,not active ,20
ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5,maximize ,20
ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5,maximize ,20
ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5,maximize ,20
ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5,0 ,20
ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5,0 ,20
ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5,0 ,20
ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5,0 ,20
ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5,0 ,20
ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5,0 ,20
ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5,not_active ,20
ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5,Always ,20
ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5,not active ,20
ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5,not active ,20
ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5,not active ,20
ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5,not active ,20
ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5,not active ,20
ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5,not active ,20
ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5,not active ,20
ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5,not active ,20
ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5,not active ,20
ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5,not active ,20
ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5,not active ,20
ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5,not active ,20
ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6,maximize ,20
ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6,maximize ,20
ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6,maximize ,20
ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6,127 ,20
ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6,0 ,20
ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6,0 ,20
ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6,0 ,20
ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6,61 ,20
ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6,18 ,20
ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6,LIN_SBBR_Versorgung_OL_Appl_55 ,20
ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6,Always ,20
ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6,LED-Heckleuchte Versorgung ,20
ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6,not active ,20
ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6,not active ,20
ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6,not active ,20
ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6,not active ,20
ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6,not active ,20
ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6,not active ,20
ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6,not active ,20
ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6,not active ,20
ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6,not active ,20
ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6,not active ,20
ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6,not active ,20
ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7,maximize ,20
ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7,maximize ,20
ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7,maximize ,20
ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7,127 ,20
ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7,0 ,20
ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7,0 ,20
ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7,0 ,20
ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7,62 ,20
ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7,34 ,20
ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7,LIN_SBBR_Versorgung_OL_Appl_55 ,20
ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7,Always ,20
ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7,LED-Heckleuchte Versorgung ,20
ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7,not active ,20
ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7,not active ,20
ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7,not active ,20
ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7,not active ,20
ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7,not active ,20
ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7,not active ,20
ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7,not active ,20
ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7,not active ,20
ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7,not active ,20
ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7,not active ,20
ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7,not active ,20
ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8,maximize ,20
ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8,maximize ,20
ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8,maximize ,20
ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8,0 ,20
ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8,0 ,20
ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8,0 ,20
ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8,0 ,20
ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8,0 ,20
ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8,0 ,20
ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8,not_active ,20
ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8,Always ,20
ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8,not active ,20
ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8,not active ,20
ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8,not active ,20
ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8,not active ,20
ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8,not active ,20
ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8,not active ,20
ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8,not active ,20
ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8,not active ,20
ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8,not active ,20
ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8,not active ,20
ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8,not active ,20
ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8,not active ,20
ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9,maximize ,20
ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9,maximize ,20
ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9,maximize ,20
ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9,0 ,20
ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9,0 ,20
ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9,0 ,20
ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9,0 ,20
ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9,0 ,20
ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9,0 ,20
ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9,not_active ,20
ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9,Always ,20
ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9,not active ,20
ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9,not active ,20
ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9,not active ,20
ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9,not active ,20
ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9,not active ,20
ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9,not active ,20
ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9,not active ,20
ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9,not active ,20
ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9,not active ,20
ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9,not active ,20
ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9,not active ,20
ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9,not active ,20
ENG253237-IDE03311-Licht Konfig-Abhängig-Emergency braking display,active ,4
ENG253237-IDE07470-Licht Konfig-Abhängig-After-run for park light,No run-on of two-sided parking light ,4
ENG253237-MAS28761-Licht Konfig-Abhängig-All-weather light: installation status,installed ,4
ENG253237-MAS28762-Licht Konfig-Abhängig-Signature light: installation status,not installed ,4
ENG253237-MAS28763-Licht Konfig-Abhängig-Discreet right taillight: installation status,not installed ,4
ENG253237-MAS28764-Licht Konfig-Abhängig-Discreet left taillight: installation status,not installed ,4
ENG253237-MAS28782-Licht Konfig-Abhängig-Instrument cluster display: signature light user interface specifications,not active ,4
ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A,00 ,28
ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B,00 ,28
ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C,00 ,28
ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D,00 ,28
ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1,00 ,28
ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2,00 ,28
ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A,00 ,28
ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B,00 ,28
ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C,00 ,28
ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D,00 ,28
ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1,00 ,28
ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2,00 ,28
ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A,00 ,28
ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B,00 ,28
ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C,00 ,28
ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D,00 ,28
ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1,00 ,28
ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2,00 ,28
ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A,00 ,28
ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B,00 ,28
ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C,00 ,28
ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D,00 ,28
ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1,00 ,28
ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2,00 ,28
ENG174381-IDE17998-light_control-(De)activating the taillight animation,active ,4
ENG174381-IDE18362-light_control-Park Assist plus / with remote control – activating the turn signal: status,active ,4
ENG174381-IDE20495-light_control-Installation coding: hazard warning lights for child presence detection,not active ,4
ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp,INDIVIDUAL ,4
ENG174381-MAS07990-light_control-Comfort flasher,active ,4
ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4
ENG174381-MAS10538-light_control-Light rotary sw. connection,Data bus LIN 1 ,4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp,INDIVIDUAL ,4
ENG174381-MAS21313-light_control-Blinker signature,not active ,4
ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4
ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4
ENG174381-ENG154711-light_control-PreCrash_RECAS,active ,4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4
ENG174381-ENG142004-light_control-Umgreifende_Heckklappe,not installed ,4
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2
ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2
ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2
ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2
ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2
ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2
ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2
ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2
ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,No Response From Subnet Component,2
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,No Response From Subnet Component,2
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,No Response From Subnet Component,2
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,No Response From Subnet Component,2
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,No Response From Subnet Component,2
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,No Response From Subnet Component,2
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,No Response From Subnet Component,2
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,No Response From Subnet Component,2
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,No Response From Subnet Component,2
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,No Response From Subnet Component,2
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,No Response From Subnet Component,2
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,No Response From Subnet Component,2
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,No Response From Subnet Component,2
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,No Response From Subnet Component,2
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,No Response From Subnet Component,2
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,No Response From Subnet Component,2
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,No Response From Subnet Component,2
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,No Response From Subnet Component,2
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,No Response From Subnet Component,2
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,No Response From Subnet Component,2
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,No Response From Subnet Component,2
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,No Response From Subnet Component,2
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,No Response From Subnet Component,2
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,No Response From Subnet Component,2
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,No Response From Subnet Component,2
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,No Response From Subnet Component,2
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,No Response From Subnet Component,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,No Response From Subnet Component,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,No Response From Subnet Component,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,No Response From Subnet Component,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,No Response From Subnet Component,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,No Response From Subnet Component,2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,No Response From Subnet Component,2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,No Response From Subnet Component,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,No Response From Subnet Component,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,No Response From Subnet Component,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,No Response From Subnet Component,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,No Response From Subnet Component,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,No Response From Subnet Component,2
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Rocker sw. ,2
ENG253158-LWR Basissoftware,15 %,16
ENG253042-IDE03638-LWR Konfiguration-Static cornering light,ECE R48 ,8
ENG253042-IDE03644-LWR Konfiguration-Highway light,not activated ,8
ENG253042-MAS02922-LWR Konfiguration-City light,not activated ,8
ENG253042-MAS07013-LWR Konfiguration-All-weather light,activated ,8
ENG253042-MAS07933-LWR Konfiguration-Eco mode,not activated ,8
ENG253042-ENG172238-LWR Konfiguration-chassis_unit,Verbundlenkerhinterachse ,8
ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR,not activated ,8
ENG253042-ENG174374-LWR Konfiguration-LED_Headlight,not activated ,8
ENG253042-ENG259430-LWR Konfiguration-LWR_konfig,not installed ,8
ENG253042-ENG172241-LWR Konfiguration-lwr_sensors,2_sensors ,8
ENG253042-ENG171501-LWR Konfiguration-Market,ECE ,8
ENG253042-ENG173009-LWR Konfiguration-offroad_light,not activated ,8
ENG253042-ENG172245-LWR Konfiguration-rain_light,not activated ,8
ENG253042-ENG174637-LWR Konfiguration-Source_height_value,DCC ,8
ENG253042-ENG172240-LWR Konfiguration-steering_curve,normal ,8
ENG369156-ENG369620-MDK Automatikfunktionen-p_auto_ZV_Reak_nicht_in_Front_Heck_Zone,not active ,1
ENG369156-ENG369621-MDK Automatikfunktionen-p_auto_ZV_Reak_nicht_nur_in_personalisierter_Zone,not active ,1
ENG369156-ENG369622-MDK Automatikfunktionen-p_auto_ZV_Reak_Tueren_nicht_bei_Front_Heck_Zone,not active ,1
ENG369156-ENG369623-MDK Automatikfunktionen-p_auto_ZV_Reak_ver_mit_SAFE,not active ,1
ENG369156-ENG369624-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_entr_quittierung,not active ,1
ENG369156-ENG369625-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_ver_Abbruchquittierung,active ,1
ENG369156-ENG369626-MDK Automatikfunktionen-p_FBS_kessy_MDK_auto_ver_ohne_SAFE_quittierung,active ,1
ENG369156-ENG369627-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_ver_quittierung,not active ,1
ENG344856-ENG345887-MDK Funktion-p_komfortbedienung_fh_oeffnen_ueber_MDK,not active ,4
ENG344856-ENG345888-MDK Funktion-p_komfortbedienung_fh_schliessen_ueber_MDK,not active ,4
ENG344856-ENG345889-MDK Funktion-p_komfortbedienung_MDK_aktiv,not active ,4
ENG344856-ENG345890-MDK Funktion-p_komfortbedienung_verdeck_oeffnen_ueber_MDK,not active ,4
ENG344856-ENG345891-MDK Funktion-p_komfortbedienung_verdeck_schliessen_ueber_MDK,not active ,4
ENG344856-ENG345892-MDK Funktion-p_MDK_verbaut,not installed ,4
ENG344857-mdk_funktionaktivierung,not activated ,1
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,65535 hPa,12
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,65535 hPa,12
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,255 s,12
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,60 s,12
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,60 s,12
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,255 s,12
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,255 %,12
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,255 %,12
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,255 %,12
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,255 °C,12
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,65535 hPa,12
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,65535 hPa,12
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,255 s,12
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,60 s,12
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,60 s,12
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,255 s,12
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,255 %,12
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,255 %,12
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,255 %,12
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,255 °C,12
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,Monostable selector lever ,8
ENG153902-NFC_FS_debug_switch,No Response From Subnet Component,8
ENG124714-ENG395072-OCU-cp_remote_fenster_komfort,not active ,10
ENG124714-ENG142044-OCU-DWA_push,active ,10
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,10
ENG124714-OCU-,installed ,10
ENG124714-ENG395178-OCU-p_t_rlu_komfortbedienungsdauer,10.00 s,10
ENG124714-ENG395179-OCU-p_t_rlu_komfortschliessen_pausenzeit,2.00 s,10
ENG124714-ENG395180-OCU-p_t_rlu_komfortschliessen_startphase,10.00 s,10
ENG124714-ENG259569-OCU-Remote HuF,active ,10
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,10
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,10
ENG124714-ENG260662-OCU-Remote HuF maximale Ausführungsdauer,30 s,10
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,30 s,10
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,1000 ms,10
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,10
ENG298054-ENG260528-OpenByWire_RBox_Schloss-p_t_ZV_ansteuerzeit_motor,0 ms,9
ENG298054-ENG298139-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_Crash_ansteuerzeit_motor,250 ms,9
ENG298054-ENG298140-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor,70 ms,9
ENG298054-ENG298141-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_max,90 ms,9
ENG298054-ENG298142-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_min,60 ms,9
ENG298054-ENG298143-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_bremsen_motor,20 ms,9
ENG298054-ENG298144-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_verzoegerte_ansteuerung,0 ms,9
ENG298054-ENG298145-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_warten_motor,500 ms,9
ENG298055-ENG298136-OpenByWire_Schloss-p_t_ZV_OBW_EOE_ansteuerzeit_motor,250 ms,2
ENG298055-ENG298137-OpenByWire_Schloss-p_t_ZV_OBW_EOE_bremsen_motor,0 ms,2
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27
ENG253051-ENG345290-Par_AutomatikFKT-AutomatikFunktion_RSSI_Bewertungsschwelle_IDGeber,45 dB,27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,60 ,27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,0 s,27
ENG253220-Par_Bedienstellen,2 ,7
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18
ENG253386-ENG345660-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_AutoEntry (2),4 ,26
ENG253386-ENG345661-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_AutoExit,4 ,26
ENG253386-ENG345662-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_EasyClose,1 ,26
ENG253386-ENG345663-Par_IDGeberSuche-Entprellzyklen_Signalisierung_IDGeber_FastEntry,1 ,26
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,1 %,26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschließen,3200 ms,26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,500 ms,26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26
ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung,5000 ms,6
ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer,0.0 s,6
ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer,2.0 s,6
ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL,3 ,20
ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR,3 ,20
ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN,1 ,20
ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL,1 ,20
ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR,1 ,20
ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox,600 cm,20
ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts,420 cm,20
ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten,600 cm,20
ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox,210 cm,20
ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts,105 cm,20
ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten,210 cm,20
ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung,600 cm,20
ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung,0 cm,20
ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung,45 cm,20
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,80 ms,18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,00000000 00000000 ,66
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,11111111 11111111 ,66
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,11111101 00011110 ,66
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,00000000 00000000 ,66
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,00000000 00000000 ,66
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,00000000 00000000 ,66
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,00000000 00000000 ,66
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,00000000 00000000 ,66
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,00000000 00000000 ,66
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,11111101 00011110 ,66
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,11111101 00011110 ,66
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,11111101 00011110 ,66
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,11111101 00011110 ,66
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,11111101 00011110 ,66
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,11111101 00011110 ,66
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,00000000 00000000 ,66
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,00000000 00000000 ,66
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,00000000 00000000 ,66
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,00000000 00000000 ,66
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,00000000 00000000 ,66
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,00000000 00000000 ,66
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,00000000 00000000 ,66
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,00000000 00000000 ,66
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,00000000 00000000 ,66
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,00000000 00000000 ,66
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,00000000 00000000 ,66
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,00000000 00000000 ,66
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,00000000 00000000 ,66
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,00000000 00000000 ,66
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,00000000 00000000 ,66
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,11111111 11111111 ,66
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,11111111 11111111 ,66
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,11111111 11111111 ,66
ENG286146-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,66
ENG286146-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,66
ENG286146-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,66
ENG286146-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,66
ENG286146-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,66
ENG286146-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,66
ENG286146-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,66
ENG286146-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,66
ENG286146-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,66
ENG286146-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,66
ENG286146-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,66
ENG286146-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,66
ENG286146-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,66
ENG286146-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,66
ENG286146-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,66
ENG286146-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,66
ENG286146-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,66
ENG286146-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,66
ENG286146-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,66
ENG286146-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,66
ENG286146-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,66
ENG286146-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,66
ENG286146-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,66
ENG286146-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,66
ENG286146-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,66
ENG286146-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,66
ENG286146-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,66
ENG286146-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,66
ENG286146-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,66
ENG286146-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,66
ENG286146-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,66
ENG286146-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,66
ENG286146-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,66
ENG286146-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,66
ENG286146-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,66
ENG286146-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,66
ENG286146-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,66
ENG286146-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,66
ENG286146-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,66
ENG286146-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,66
ENG286146-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,66
ENG286146-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,66
ENG286146-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,66
ENG286146-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,66
ENG286146-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,66
ENG286146-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,66
ENG286146-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,66
ENG286146-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,66
ENG286146-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,66
ENG286146-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,66
ENG286146-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,66
ENG286146-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,66
ENG286146-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,66
ENG286146-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,66
ENG286146-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,66
ENG286146-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,66
ENG286146-IDE80057-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,66
ENG286146-IDE80058-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,66
ENG286146-IDE80059-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,66
ENG286146-IDE80060-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,66
ENG286147-IDE00047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,66
ENG286147-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,66
ENG286147-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,66
ENG286147-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,66
ENG286147-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,66
ENG286147-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,66
ENG286147-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,66
ENG286147-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,66
ENG286147-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,66
ENG286147-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,66
ENG286147-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,66
ENG286147-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,66
ENG286147-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,66
ENG286147-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,66
ENG286147-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,66
ENG286147-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,66
ENG286147-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,66
ENG286147-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,66
ENG286147-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,66
ENG286147-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,66
ENG286147-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,66
ENG286147-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,66
ENG286147-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,66
ENG286147-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,66
ENG286147-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,66
ENG286147-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,66
ENG286147-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,66
ENG286147-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,66
ENG286147-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,66
ENG286147-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,66
ENG286147-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,66
ENG286147-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,66
ENG286147-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,66
ENG286147-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,66
ENG286147-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,66
ENG286147-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,66
ENG286147-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,66
ENG286147-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,66
ENG286147-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,66
ENG286147-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,66
ENG286147-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,66
ENG286147-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,66
ENG286147-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,66
ENG286147-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,66
ENG286147-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,66
ENG286147-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,66
ENG286147-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,66
ENG286147-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,66
ENG286147-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,66
ENG286147-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,66
ENG286147-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,66
ENG286147-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,66
ENG286147-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,66
ENG286147-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,66
ENG286147-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,66
ENG286147-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,66
ENG286147-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,66
ENG286147-MAS01078-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,66
ENG286147-MAS14087-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,66
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,activated ,8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,activated ,8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,activated ,8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,activated ,8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,activated ,8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,activated ,8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,activated ,8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,activated ,8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,not activated ,8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,not activated ,8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,activated ,8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8
ENG129043-PASSIVE_GO,activated ,4
ENG253210-ENG260453-Personalisierung_2_0-Active_Participant_Doorlocking_Enabled,Deactivated ,12
ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12
ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12
ENG253210-ENG259660-Personalisierung_2_0-Active_Participant_Mirror_Enabled,activated ,12
ENG253210-ENG298068-Personalisierung_2_0-Active_Participant_SeatPneumatic_Enabled,activated ,12
ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12
ENG253210-ENG258609-Personalisierung_2_0-PSO_Setup_1,not_active ,12
ENG253210-ENG260679-Personalisierung_2_0-PSO_Setup_2,not_active ,12
ENG253210-ENG259992-Personalisierung_2_0-PSO_Setup_Bereich_1,0 ms,12
ENG253210-ENG260317-Personalisierung_2_0-PSO_Setup_Bereich_2,0 ms,12
ENG253210-ENG260178-Personalisierung_2_0-Version_ Personalisierung,Customization coded 2.x ,12
ENG253210-ENG247653-Personalisierung_2_0-Wait_for_IAA_Slot_Info,150 ms,12
ENG344862-ENG146414-Pilotiertes_Parken_ZV-ffb_kessy_active_for_piloted_parking,Kessy_and_ffb_at_kl15_on_and_piloted_parking_event_active ,5
ENG344862-ENG260469-Pilotiertes_Parken_ZV-KFT_Pilopar_aktiv,active ,5
ENG344862-ENG258878-Pilotiertes_Parken_ZV-ZV_Pilopar_aktiv,active ,5
ENG253109-PSI5 Konfiguration,02 ,16
ENG253310-PSI5 Sensoren,not installed ,1
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,8
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,8
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A58 ,8
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,8
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Left ,8
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8
ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3
ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,installedLIN1 ,3
ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,installed ,3
ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,On ,3
ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3
ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an über Geschwindigkeit,Ein / Slave steuert ,3
ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3
ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz I ,3
ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3
ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,On ,3
ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,OFF ,3
ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,80% Transmission ,3
ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,85% Transmission ,3
ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,LIN ,3
ENG253157-roof_module,installed ,1
ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,installed ,6
ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6
ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,installed ,6
ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6
ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6
ENG253336-ENG149217-Schiebedach_ZV-SAD_Komfort_oeffnen,active ,6
ENG253336-ENG369659-Schiebedach_ZV-SAD_Komfort_oeffnungs_modus,tilting ,6
ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,active ,6
ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6
ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6
ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6
ENG253012-ENG298118-Schiebetür-p_n_eRWK_Abbruchblinken_Blinkzyklen,3 ,14
ENG253012-ENG298119-Schiebetür-p_n_eRWK_Mindestanzahl_Oeffnungsblinken,2 ,14
ENG253012-ENG298120-Schiebetür-p_n_Sbt_Crashred_Wdh,10 ,14
ENG253012-ENG298121-Schiebetür-p_t_Abbruchblinken_eRWK_Hellphase,50 %,14
ENG253012-ENG298122-Schiebetür-p_t_Abbruchblinken_eRWK_Periodendauer,1000 ms,14
ENG253012-ENG298123-Schiebetür-p_t_Anf_Entr_Sbt_Timeout,10.00 s,14
ENG253012-ENG298125-Schiebetür-p_t_eRWK_Oeffnungsblinken_Hellphase,50 %,14
ENG253012-ENG298126-Schiebetür-p_t_eRWK_Oeffnungsblinken_max,10 s,14
ENG253012-ENG298127-Schiebetür-p_t_eRWK_Oeffnungsblinken_Periodendauer,1000 ms,14
ENG253012-ENG298128-Schiebetür-p_t_KiSi_Fkt_Bel_Timeout,600 s,14
ENG253012-ENG298130-Schiebetür-p_t_Sbt_Verzoegerung_Nachverriegelung,0 ms,14
ENG253012-ENG298132-Schiebetür-p_t_ZV_eKiSi_gesperrt,300 ms,14
ENG253012-ENG298133-Schiebetür-p_t_ZV_eRWK_Oeffnungsblinken_Mindest_Dauer,1.00 s,14
ENG253012-ENG298134-Schiebetür-p_t_ZV_FFB_Schiebetuer_Verzoegerung,800 ms,14
ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,not activated ,1
ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1
ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1
ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1
ENG253118-IDE02851-Schlüsselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31
ENG253118-ENG126943-Schlüsselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31
ENG253118-ENG126944-Schlüsselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG277093-Schlüsselpositionsnachbildung (SPN)-Evaluation_Klemmenkoordinator,Yes ,31
ENG253118-ENG126945-Schlüsselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,300 ms,31
ENG253118-ENG129003-Schlüsselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG253448-Schlüsselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31
ENG253118-ENG126939-Schlüsselpositionsnachbildung (SPN)-rpm_threshold_engine_runnning,100 /min,31
ENG253118-ENG126946-Schlüsselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31
ENG253118-ENG258251-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31
ENG253118-ENG126947-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31
ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8
ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,installed ,8
ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,installed ,8
ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,3 ,8
ENG253224-ENG259581-Seat_pneumatics-Massage_programs,2 ,8
ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8
ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8
ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8
ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8
ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8
ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6
ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6
ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6
ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6
ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6
ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6
ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,100 ms,4
ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4
ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,No Response From Subnet Component,4
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,No Response From Subnet Component,4
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,No Response From Subnet Component,4
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,No Response From Subnet Component,4
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,No Response From Subnet Component,4
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,No Response From Subnet Component,4
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,No Response From Subnet Component,4
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,No Response From Subnet Component,4
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,No Response From Subnet Component,4
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,No Response From Subnet Component,4
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,No Response From Subnet Component,4
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,No Response From Subnet Component,4
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,No Response From Subnet Component,4
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,No Response From Subnet Component,4
ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,No Response From Subnet Component,4
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,No Response From Subnet Component,4
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,No Response From Subnet Component,4
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,No Response From Subnet Component,4
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,No Response From Subnet Component,4
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,No Response From Subnet Component,4
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,No Response From Subnet Component,4
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,No Response From Subnet Component,4
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,No Response From Subnet Component,4
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,No Response From Subnet Component,4
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,No Response From Subnet Component,4
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,No Response From Subnet Component,4
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,No Response From Subnet Component,4
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,No Response From Subnet Component,4
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,No Response From Subnet Component,4
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,No Response From Subnet Component,4
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,No Response From Subnet Component,4
ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,active ,3
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,active ,3
ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,active ,3
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,active ,3
ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,active ,3
ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,active ,3
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,60 °C,8
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,140 km/h,8
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,25500 ms,8
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,35 °C,8
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-10 °C,8
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG302681-ENG260527-Störungsmeldungen_Licht_Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15
ENG302681-ENG260368-Störungsmeldungen_Licht_Wischwasch-p_t_LDS_defekt_meldung,10 s,15
ENG302681-ENG260726-Störungsmeldungen_Licht_Wischwasch-p_t_RLS_Meldung,2000 ms,15
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21
ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,6.9 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,1.8 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21
ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,50.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,50.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10
ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8
ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8
ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8
ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8
ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8
ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8
ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8
ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8
ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8
ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8
ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8
ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8
ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8
ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8
ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,50.0 ,8
ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,50.0 ,8
ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6
ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6
ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6
ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6
ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6
ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10
ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8
ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8
ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8
ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8
ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8
ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8
ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,50.0 ,8
ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,50.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,24
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,24
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,160 ,24
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,300 ,24
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,380 ,24
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,440 ,24
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,100 ,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,150 ,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,200 ,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,255 ,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 %,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 %,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 %,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 %,10
ENG286149-ENG286256-Switch Panel-Drive Select,No Response From Subnet Component,10
ENG286149-ENG286257-Switch Panel-ESC_Off-Taster,No Response From Subnet Component,10
ENG286149-ENG286389-Switch Panel-WBT,No Response From Subnet Component,10
ENG344887-total_distance_pass_jump,activated ,1
ENG249751-Two_keys,active ,3
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG252991-Vehicle configuration,activated ,1
ENG253245-verbauliste_subcan,installed ,4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,6
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,6
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,6
ENG141634-ENG116655-Verdecksteuergeraet-Kessy Komfortbedienung Reichweitenbegrenzung,active ,6
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,6
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,6
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,6
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,6
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,6
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,6
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,6
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,6
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,6
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,6
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,6
ENG253327-ENG261016-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Verlassenswarnung,1.4 s,8
ENG253327-ENG261326-Verlassenswarnung und Standlichtnachlauf-Entprellung Degradierte Verlassenswarnung,1.6 s,8
ENG253327-ENG259356-Verlassenswarnung und Standlichtnachlauf-Entprellung Verlassenswarnung,5 min,8
ENG253327-ENG258196-Verlassenswarnung und Standlichtnachlauf-Fahrzeuggeschwindigkeit zur Stillstandserkennung,3 km/h,8
ENG253327-ENG116720-Verlassenswarnung und Standlichtnachlauf-Standlicht-Nachlaufzeit,30 min,8
ENG253327-ENG346085-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit degradierte VLW,not active ,8
ENG253327-ENG346086-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Fehlermeldung Gurt,active ,8
ENG253327-ENG346087-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Fehlermeldung Sitz,active ,8
ENG253327-ENG346088-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Fehlermeldung Tür,active ,8
ENG253327-ENG277124-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Standlichtnachlauf,active ,8
ENG253327-ENG277125-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Verlassenswarnung,active ,8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28
ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8
ENG159625-ENG286258-Virtual pedal-Kick_and_close_HBFS,not installed ,8
ENG159625-ENG286259-Virtual pedal-Kick_and_close_HFS,not installed ,8
ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,active ,8
ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,active ,8
ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,active ,8
ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4
ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4
ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,0 ms,4
ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,0 ms,4
ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,not installed ,4
ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,not installed ,4
ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,installed ,4
ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8
ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8
ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8
ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8
ENG154424-ENG260022-Waschen-RVC_Waschen,installed ,8
ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8
ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8
ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8
ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8
ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4
ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,1500 ms,4
ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4
ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4
ENG253279-ENG126852-Wisch_geschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG253279-ENG126853-Wisch_geschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG253279-ENG116699-Wisch_geschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,35 ,3
ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 ,11
ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11
ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11
ENG281049-ENG395058-Zündungswarnung und Antrieb-Aktiv-Warnung-Ausgabe erweiterte AAW,active ,8
ENG281049-ENG263583-Zündungswarnung und Antrieb-Aktiv-Warnung-Ausgabe MoLaWa_AAW,active ,8
ENG281049-ENG345659-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellung VLW in N,1.4 s,8
ENG281049-ENG263581-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellung_MoLaWa,0.8 ,8
ENG281049-ENG263504-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswechsel Belegt zu nicht Belegt,0.0 s,8
ENG281049-ENG281097-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswecsel nicht Belegt zu Belegt,0.0 s,8
ENG281049-ENG395232-Zündungswarnung und Antrieb-Aktiv-Warnung-Timer erweiterte AAW,600 s,8
ENG281049-ENG395233-Zündungswarnung und Antrieb-Aktiv-Warnung-Timer erweiterte AAW Standzeit,7200 s,8
ENG281049-ENG395234-Zündungswarnung und Antrieb-Aktiv-Warnung-Timer erweiterte AAW Zykluszeit,600 s,8
ENG281049-ENG263531-Zündungswarnung und Antrieb-Aktiv-Warnung-Unterdrückung der Zündungswarnung,active ,8
ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6
ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6
ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_active ,6
ENG141651-ENG345672-ZV allgemein-FFB_kessy_verr_sperren_bei_nicht_eingelegter_p_stellung,active ,6
ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,not active ,6
ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,active ,6
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,6
ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6
ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,not active ,6
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,6
ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6
ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,active ,6
ENG141653-ENG442356-ZV Heck-eingeschraenkte_Freigabe_HD_Innentaste,not active ,6
ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6
ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6
ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6
ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,via_CAN ,6
ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6
ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6
ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,Yes ,6
ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,contact_control_with_least_active_time ,6
ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.00 s,6
ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6
ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6
ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6
ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8
ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschließen_brasilien,not active ,8
ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,installed ,8
ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8
ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8
ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8
ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,not active ,8
ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schließen,active ,8
ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8
ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8
ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,not active ,8
ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,active ,8
ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,active ,8
ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8
ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8
ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8
ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8
ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,not active ,7
ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7
ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7
ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7
ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,7
ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,not active ,7
ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7
ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.60 s,7
ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.00 s,7
ENG263451-ENG281092-ZV NFZ - Elektronische Rueckwandklappe-pa_eRWK_KST_Sonderzustand_Anf,not active ,7
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,none ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,No ,2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,No ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,none ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,No ,2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,No ,2
ENG253123-ENG259042-ZV Nutzfahrzeuge-SBT_Schloss_direkt,not installed ,5
ENG253123-ENG142041-ZV Nutzfahrzeuge-Schiebetueren_Crafter,not installed ,5
ENG253123-ENG260914-ZV Nutzfahrzeuge-TKM_BFS_verbaut,not installed ,5
ENG253123-ENG258445-ZV Nutzfahrzeuge-TKM_FS_verbaut,not installed ,5
ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6
ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6
ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,active ,6
ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,not active ,6
ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6
ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6
ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,not active ,6
ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,not active ,6
ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,not active ,6
ENG141652-ENG258598-ZV Türkonfiguration-Fzg_mit_Vier_Tueren,Yes ,2
ENG141652-ENG345897-ZV Türkonfiguration-pa_ZV_erweiterte_Synchronisation,not active ,2
ENG141652-ENG260173-ZV Türkonfiguration-Schloesser_direkt_gesteuert,Alle Tueren via CAN vernetzt ,2
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,2
ENG141652-ENG258913-ZV Türkonfiguration-ZV Schlosstyp,Zweimotorenschloss ,2
ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,not active ,2
ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2
ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2
ENG253276-ENG345632-ZV_Autolock-disable_unlock_over_15kmh,active ,2
ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG263484-ENG263546-ZV_HW_Router-PIN_A11,Tuer HL verriegeln oder Laderaumabdeckung links ,5
ENG263484-ENG263569-ZV_HW_Router-PIN_A31,LuT zentral oder Tankklappenrueckmeldung ,5
ENG263484-ENG263532-ZV_HW_Router-PIN_A32,Softtouch Heckdeckel ,5
ENG263484-ENG263567-ZV_HW_Router-PIN_A33,Tuer HR Verriegelung/Safe oder Verdeck zu ,5
ENG263484-ENG263596-ZV_HW_Router-PIN_A35,Tuer HL Verriegelung/Safe ,5
ENG263484-ENG263575-ZV_HW_Router-PIN_A48,Tuer HR TK-Signal ,5
ENG263484-ENG263528-ZV_HW_Router-PIN_A49,Taste Heckdeckelentriegelung ,5
ENG263484-ENG263547-ZV_HW_Router-PIN_A50,Tuer HL TK-Signal ,5
ENG263484-ENG263598-ZV_HW_Router-PIN_A51,IRUE/NGS aus oder Heckscheibenbruch ,5
ENG263484-ENG263545-ZV_HW_Router-PIN_A7,Tuer HR verriegeln oder Laderaumabdeckung rechts ,5
ENG263484-ENG263590-ZV_HW_Router-PIN_C21,Funktions-LED Taste3 ,5
ENG263484-ENG263523-ZV_HW_Router-PIN_C22,Funktions-LED Taste4 ,5
ENG263484-ENG263565-ZV_HW_Router-PIN_C34,Cockpit-Taste 3 ,5
ENG263484-ENG263571-ZV_HW_Router-PIN_C59,Cockpit-Taste 4 ,5
ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,No ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,not active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,not active ,5
ENG263427-ENG259542-zv_router_global-Schiebetuer_verriegeln_bei_offenem_tank,not active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
Elapsed Time: 05:30
adpmap - 10
SW:5QS-919-300-B HW:5QS-919-300 --- 10: Park/Steer Assist
Component:IPA 12ch high H01 0179, Coding:8A30126111
EV_EPHBO3CVW3360000,001014,EV_EPHBO3CVW3360000_VW42.rod
Sunday,26,July,2026,16:31:58:15875
VCDS Version: 26.7.0.1 (x64) Data version: 20260708 DS378.0
VCID: 51FE775F916ADAB200C-8004-R
IDE01165-Park assist activation tone,OFF ,1
IDE01167-Convertible offset for volume level 1,1 ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,2
ENG413791-HMI_Version,HMI_1.X ,1
Elapsed Time: 00:05
adpmap - 13
SW:1N3-907-567-D HW:1N3-907-819 --- 13: Auto Dist. Reg
Component:ACC Bosch MQB H02 0436, Coding:0E8930EF4071404040020008000040C0010020008004000000000000000000
EV_FRONTRADARBOSCHVW412,002016,EV_FRONTRADARBOSCHVW412_002_VW41.rod
Sunday,26,July,2026,16:32:46:15875
VCID: 38282AFB12D06BFA272-806C-R SFD+SFD2 [x]
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,OFF ,1
IDE00820-MAS24969-Activating and deactivating all development messages-S100 developer messages,OFF ,1
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE01949-Distance basic setting option,OFF ,1
IDE07159-MAS05583-Control module switch-off: counter-Data bus,34 ,2
IDE11924-MAS13429-Correction angle-Horizontal correction angle: currently,-10.000 °,4
IDE11924-MAS13430-Correction angle-Vertical correction angle: currently,-10.000 °,4
IDE11926-MAS04910-Static calibration: preparation-Driving axis angle,0 ',7
IDE11926-MAS13433-Static calibration: preparation-Lateral displacement of front axle,0.00 mm,7
IDE11926-MAS13434-Static calibration: preparation-Lateral displacement of rear axle,0.00 mm,7
IDE11926-MAS13435-Static calibration: preparation-Vertical lead angle,-0.00 °,7
IDE14161-MAS04910-Static calibration: follow-up-Driving axis angle,0 ',7
IDE14161-MAS13433-Static calibration: follow-up-Lateral displacement of front axle,0.00 mm,7
IDE14161-MAS13434-Static calibration: follow-up-Lateral displacement of rear axle,0.00 mm,7
IDE14161-MAS13435-Static calibration: follow-up-Vertical lead angle,-0.00 °,7
IDE15695-Front radar-based localization,activated ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,18
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,8 ,18
IDE16782-Maximum route length of short-track calibration,1 m,1
IDE17401-Triggering documentation,Activate ,1
IDE17405-IDE06260-Trustworthy time synchronization in slave performance-ID number,0 ms,5
IDE17405-MAS24094-Trustworthy time synchronization in slave performance-Lap time,500 ms,5
IDE17405-MAS24095-Trustworthy time synchronization in slave performance-Response time,100 ms,5
IDE17781-Warn-brake-evade: complete switch,Activate ,1
IDE18351-SFD developer mode,General reject,1
MAS18081-MAS00478-Test Mode-Reserved,0 ,1
MAS18081-MAS21993-Test Mode-Return value idle bus,not active ,1
MAS18081-MAS21994-Test Mode-Veto,not active ,1
MAS18081-MAS21995-Test Mode-Suppress veto,not active ,1
MAS19336-Active participant function activated,activated ,1
MAS23686-Image data storage,Deactivating ,1
Elapsed Time: 00:07
adpmap - 14
SW:5QS-907-376-G HW:5QS-907-376-F --- 14: Susp. Elect.
Component:DAEMPFUNGS-SG H08 0607, Coding:
EV_DCC4CONTITEMIC,005012,EV_DCC4CONTITEMIC.rod
Sunday,26,July,2026,16:33:06:15875
VCID: 6098A29BEAC0433ABF2-8034-R
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,12
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,5 ,12
Elapsed Time: 00:00
adpmap - 15
SW:5QS-959-655-S HW:5QS-959-655 --- 15: Airbags
Component:AirbagVW50 004 0131, Coding:98CC008000F0C000000000000000000051540000A1540000C000F680002B40A7
EV_AirbaVW50SMEVW49X,001014,EV_AirbaVW50SMEVW49X.rod
Sunday,26,July,2026,16:33:37:15875
VCID: 73B2DDD74B36C8A2D20-8026-R SFD+SFD2 [x]
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE06314-Calibration data: pre-crash,01 07 00 06 02 00 7F 0D 1F 7F 2C 00 00 3F 00 6C 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 A0 C0 00 00 00 00 00 00 00 00 00 00 ,42
IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,activated ,4
IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,activated ,4
IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner second row right,not defined ,4
IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner second row left,not defined ,4
IDE06527-IDE12159-Adaptation pre-crash-Control module for belt feed: second row left,not defined ,4
IDE06527-IDE12160-Adaptation pre-crash-Control module for belt feed: second row right,not defined ,4
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,3
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,0 min,3
IDE07160-ENG258305-Control module switch-off: switch-off time-BusKnockOut_Tmr_NVEM,0 min,3
IDE09601-IDE03311-Adaptation PreCrash functions-Emergency braking display,not defined ,16
IDE09601-IDE03633-Adaptation PreCrash functions-Close sunroof,not defined ,16
IDE09601-IDE03634-Adaptation PreCrash functions-Close windows,not defined ,16
IDE09601-IDE09602-Adaptation PreCrash functions-Locale hazard warning,not defined ,16
IDE09601-IDE09603-Adaptation PreCrash functions-RECAS,not defined ,16
IDE09601-IDE09604-Adaptation PreCrash functions-Seat adjustment - backrest,not defined ,16
IDE09601-IDE09605-Adaptation PreCrash functions-Seat adjust. - side bolster,not defined ,16
IDE09601-IDE09606-Adaptation PreCrash functions-Seat adjustment - headrests,not defined ,16
IDE09601-IDE09607-Adaptation PreCrash functions-PreCrash Front,not defined ,16
IDE09601-IDE09608-Adaptation PreCrash functions-Seat belt slack reduction: left,activated ,16
IDE09601-IDE09609-Adaptation PreCrash functions-Seat belt slack reduction: right,activated ,16
IDE09601-IDE09610-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row left,not defined ,16
IDE09601-IDE09611-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row right,not defined ,16
IDE09601-IDE09612-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row ctr.,not defined ,16
IDE09601-IDE09613-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row left,not defined ,16
IDE09601-IDE09614-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row right,not defined ,16
IDE09601-IDE09615-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row ctr.,not defined ,16
IDE09601-IDE09616-Adaptation PreCrash functions-Reversible belt tensioning left,activated ,16
IDE09601-IDE09617-Adaptation PreCrash functions-Reversible belt tensioning right,activated ,16
IDE09601-IDE09618-Adaptation PreCrash functions-Reversible belt tensioning: act. code of seat belt tightenert,not defined ,16
IDE09601-IDE09619-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row right,not defined ,16
IDE09601-IDE09620-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row ctr.,not defined ,16
IDE09601-IDE09621-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row left,not defined ,16
IDE09601-IDE09622-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row right,not defined ,16
IDE09601-IDE09623-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row ctr.,not defined ,16
IDE09601-IDE16527-Adaptation PreCrash functions-PreCrash door locking,not defined ,16
IDE09601-IDE16528-Adaptation PreCrash functions-PreCrash seat adjustment: driver's seat,not defined ,16
IDE09601-IDE16529-Adaptation PreCrash functions-PreCrash seat adjustment: passenger seat,not defined ,16
IDE09601-IDE16530-Adaptation PreCrash functions-PreCrash seat adjustment: 2nd seat row,not defined ,16
IDE09601-MAS00478-Adaptation PreCrash functions-Reserved,2 ,16
IDE09601-MAS03834-Adaptation PreCrash functions-Emergency signal flashing,not defined ,16
IDE09601-MAS09950-Adaptation PreCrash functions-LED bar activation,not defined ,16
IDE09601-MAS15067-Adaptation PreCrash functions-Belt parking 1st row,not defined ,16
IDE09601-MAS15068-Adaptation PreCrash functions-Belt parking 2nd row,not defined ,16
IDE09601-MAS15069-Adaptation PreCrash functions-Measurement recording,not defined ,16
IDE09601-MAS15070-Adaptation PreCrash functions-BAP resistance PreSense system,not defined ,16
IDE09601-MAS15071-Adaptation PreCrash functions-BAP resistance PreSense warning,not defined ,16
IDE09601-MAS15072-Adaptation PreCrash functions-BAP resistance: distance warning,not defined ,16
IDE09601-MAS15073-Adaptation PreCrash functions-BAP resistance: turning assistance,not defined ,16
IDE09601-MAS15074-Adaptation PreCrash functions-BAP resistance proactive passenger cover,not defined ,16
IDE09601-MAS15107-Adaptation PreCrash functions-Drivetrain actuation,not defined ,16
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,activated ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,activated ,8
IDE12055-IDE14841-Adaptation airbag 2-Seat Belt Tensioner Igniter: center 3rd row,not defined ,8
IDE12055-IDE15776-Adaptation airbag 2-Deactivation igniter: DC/DC converter,not defined ,8
IDE12055-IDE16063-Adaptation airbag 2-Igniter for high-voltage battery 3 open circuit,not defined ,8
IDE12055-IDE17275-Adaptation airbag 2-Igniter for deactivation of A/C system 3,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
IDE12055-MAS29851-Adaptation airbag 2-Igniter for seat ramp airbag 2nd row: passenger's side,not defined ,8
IDE12055-MAS29852-Adaptation airbag 2-Igniter for seat ramp airbag 2nd row: driver's side,not defined ,8
IDE18988-Type-version-variant data for accident data recorder,------------------------------------------------------------------------------------- ,100
MAS00975-IDE00947-Airbag adaptations-Rear driver head curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Rear passenger head curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Front driver side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger front airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00013-Airbag adaptations-Driver seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger seat belt tensioner igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00023-Airbag adaptations-Driver active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Front passenger active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key-operated switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection passenger side,activated ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter hood,not defined ,8
Elapsed Time: 00:15
adpmap - 16
SW:1EE-953-507-M HW:1EE-953-507-M --- 16: Steering wheel
Component:GSMMEB 005 0066, Coding:
EV_SMLSKLOGEN2,009005,EV_SMLSKLOGEN2_009_VW49.rod
Sunday,26,July,2026,16:34:02:15875
VCID: 45D6530F55220612AC4-8010-R SFD [x]
IDE02694-Signal horn activation,Always ,1
IDE07159-ENG273891-Control module switch-off: counter-Bus KnockOut_Ctr,02 ,2
IDE07159-ENG273843-Control module switch-off: counter-ECU KnockOut_Ctr,00 ,2
IDE07160-ENG273602-Control module switch-off: switch-off time-Bus KnockOut_Tmr,15 min,3
IDE07160-ENG302713-Control module switch-off: switch-off time-Bus KnockOut_Tmr NVEM,not active ,3
IDE07160-ENG273618-Control module switch-off: switch-off time-ECU KnockOut_Tmr,30 min,3
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
IDE17782-ENG302794-Fault voltages and fault times-P_t_overvoltage_debounce_time,90000 ms,4
IDE17782-ENG302820-Fault voltages and fault times-P_t_undervoltage_debounce_time,90000 ms,4
IDE17782-ENG302827-Fault voltages and fault times-P_v_overvoltage_limit_value,16.5 V,4
IDE17782-ENG302828-Fault voltages and fault times-P_v_undervoltage_limit_value,8.5 V,4
IDE17784-ENG302756-Gear change actuator: debounce times-P_t_gearshifter_clockwise_1_debounce_time,40 ms,7
IDE17784-ENG302757-Gear change actuator: debounce times-P_t_gearshifter_clockwise_2_debounce_time,40 ms,7
IDE17784-ENG302758-Gear change actuator: debounce times-P_t_gearshifter_counter_clockwise_1_debounce_time,40 ms,7
IDE17784-ENG302759-Gear change actuator: debounce times-P_t_gearshifter_counter_clockwise_2_debounce_time,40 ms,7
IDE17784-ENG302760-Gear change actuator: debounce times-P_t_gearshifter_error_debounce_time,40 ms,7
IDE17784-ENG302761-Gear change actuator: debounce times-P_t_gearshifter_init_debounce_time,40 ms,7
IDE17784-ENG302762-Gear change actuator: debounce times-P_t_gearshifter_steady_debounce_time,40 ms,7
IDE17785-Selector mechanism: selector lever storage time parameters,1000 ms,1
IDE17788-ENG302785-Selector mechanism: holding phase time parameters-P_t_illumination_after_n_holding_phase,500 ms,2
IDE17788-ENG302793-Selector mechanism: holding phase time parameters-P_t_n_hold_duration,30 min,2
IDE17789-ENG302749-Selector mechanism: parking button time parameters-P_n_p_button_one_open,50 units,6
IDE17789-ENG302795-Selector mechanism: parking button time parameters-P_t_p_button_debounce,40 ms,6
IDE17789-ENG302797-Selector mechanism: parking button time parameters-P_t_p_button_event_short,20 ms,6
IDE17789-ENG302798-Selector mechanism: parking button time parameters-P_t_p_button_open_circuit,1000 ms,6
IDE17789-ENG302799-Selector mechanism: parking button time parameters-P_t_p_button_short_circuit,200 ms,6
IDE17789-ENG302801-Selector mechanism: parking button time parameters-P_t_p_button_stuck,60 s,6
IDE17790-Gear change actuator: switch request limit,100 ms,1
IDE17791-ENG302719-Selector mechanism: output of driver request time parameters-Cp_display_drivelevel,installed ,4
IDE17791-ENG302720-Selector mechanism: output of driver request time parameters-Cp_wh_variant,variant_8 ,4
IDE17791-ENG302791-Selector mechanism: output of driver request time parameters-P_t_min_display,100 ms,4
IDE17791-ENG302792-Selector mechanism: output of driver request time parameters-P_t_min_display_p,1000 ms,4
IDE17793-ENG302763-Gear change actuator: fault times-P_t_gearshifter_stuck_debounce_time,300 s,2
IDE17793-ENG302764-Gear change actuator: fault times-P_t_gearshifter_unstuck_debounce_time,5000 ms,2
IDE17794-Selector mechanism: CAN protocol counter,03 ,1
IDE17795-Windshield wiper: interval 1,Intervall_2 ,1
IDE17796-Selector mechanism: CAN protocol time parameters,5000 ms,1
IDE17797-Selector mechanism: CAN protocol,Classic CAN ,1
IDE17798-Windshield wiper: interval 2,Intervall_4 ,1
IDE17799-ENG302782-Horn: fault times-P_t_horn_notification_time,2000 ms,3
IDE17799-ENG302783-Horn: fault times-P_t_horn_stuck_debounce_time,60 s,3
IDE17799-ENG302784-Horn: fault times-P_t_horn_unstuck_debounce_time,5000 ms,3
IDE17800-ENG302780-Horn: debounce times-P_t_horn_debounce_activation_value,30 ms,2
IDE17800-ENG302781-Horn: debounce times-P_t_horn_debounce_deactivation_value,50 ms,2
IDE17801-Windshield wiper: winter settings time,60 s,1
IDE17802-Read in horn,SMLS ,1
IDE17803-Turn signal switch: lockout time,100 ms,1
IDE17804-ENG302775-Turn signal switch: debounce times-P_t_highbeam_debounce_time,40 ms,3
IDE17804-ENG302786-Turn signal switch: debounce times-P_t_lighthorn_debounce_time,40 ms,3
IDE17804-ENG302814-Turn signal switch: debounce times-P_t_turnindicator_debounce_time,40 ms,3
IDE17805-ENG302754-Windshield wiper rotary knob: debounce times-P_t_frontwiper_debounce_time,40 ms,2
IDE17805-ENG302804-Windshield wiper rotary knob: debounce times-P_t_rearwiper_debounce_time,200 ms,2
IDE17806-ENG324788-Windshield wiper button: debounce times-Cp_wiper_button_prio,Prio_off ,3
IDE17806-ENG325089-Windshield wiper button: debounce times-P_t_wiper_button_debounce_time_position_1,40 ms,3
IDE17806-ENG325090-Windshield wiper button: debounce times-P_t_wiper_button_debounce_time_position_2,40 ms,3
IDE17807-ENG302776-Turn signal switch: fault times-P_t_highbeam_invalid_dequalification_time,100 ms,13
IDE17807-ENG302777-Turn signal switch: fault times-P_t_highbeam_invalid_qualification_time,100 ms,13
IDE17807-ENG302778-Turn signal switch: fault times-P_t_highbeam_stuck_debounce_time,300 s,13
IDE17807-ENG302779-Turn signal switch: fault times-P_t_highbeam_unstuck_debounce_time,5000 ms,13
IDE17807-ENG302787-Turn signal switch: fault times-P_t_lighthorn_invalid_dequalification_time,100 ms,13
IDE17807-ENG302788-Turn signal switch: fault times-P_t_lighthorn_invalid_qualification_time,100 ms,13
IDE17807-ENG302789-Turn signal switch: fault times-P_t_lighthorn_stuck_debounce_time,300 s,13
IDE17807-ENG302790-Turn signal switch: fault times-P_t_lighthorn_unstuck_debounce_time,5000 ms,13
IDE17807-ENG302815-Turn signal switch: fault times-P_t_turnindicator_invalid_dequalification_time,100 ms,13
IDE17807-ENG302816-Turn signal switch: fault times-P_t_turnindicator_invalid_qualification_time,100 ms,13
IDE17807-ENG302817-Turn signal switch: fault times-P_t_turnindicator_stuck_debounce_time,300 s,13
IDE17807-ENG302818-Turn signal switch: fault times-P_t_turnindicator_unplausible_debounce_time,100 ms,13
IDE17807-ENG302819-Turn signal switch: fault times-P_t_turnindicator_unstuck_debounce_time,5000 ms,13
IDE17808-ENG302823-Windshield wiper rotary knob: fault times-P_t_wiper_thumbwheel_implausible,200 ms,3
IDE17808-ENG302824-Windshield wiper rotary knob: fault times-P_t_wiper_thumbwheel_open_circuit,1000 ms,3
IDE17808-ENG302825-Windshield wiper rotary knob: fault times-P_t_wiper_thumbwheel_short_circuit,200 ms,3
IDE17809-ENG302809-Windshield wiper button: fault times-P_t_tipwipewash_open_circuit,1000 ms,4
IDE17809-ENG302810-Windshield wiper button: fault times-P_t_tipwipewash_short_circuit,200 ms,4
IDE17809-ENG302811-Windshield wiper button: fault times-P_t_tipwipewash_stuck,60 s,4
IDE17809-ENG302812-Windshield wiper button: fault times-P_t_tipwipewash_unstuck,5000 ms,4
IDE17810-Steering wheel heating installed,installed ,1
IDE17811-Steering wheel heating: output,110 W,1
IDE17812-Steering wheel heating: pulse width modulation frequency,25 Hz,1
IDE17813-ENG302807-Steering wheel heating: fault times-P_t_swh_open_load_debounce_time,1000 ms,2
IDE17813-ENG302808-Steering wheel heating: fault times-P_t_swh_short_circuit_debounce_time,200 ms,2
IDE17815-ENG302752-Electronic parking brake: lighting fault times-P_t_epb_search_illumination_open_circuit_debounce_time,1000 ms,2
IDE17815-ENG302753-Electronic parking brake: lighting fault times-P_t_epb_search_illumination_short_circuit_debounce_time,200 ms,2
IDE17816-Attenuation dimming down,1 units,1
IDE17817-ENG302765-CCS lever: debounce times and fault times-P_t_gra_err_gra_stuck,300 s,9
IDE17817-ENG302766-CCS lever: debounce times and fault times-P_t_gra_err_gra_unstuck,5000 ms,9
IDE17817-ENG302768-CCS lever: debounce times and fault times-P_t_gra_err_open_circuit,1000 ms,9
IDE17817-ENG302769-CCS lever: debounce times and fault times-P_t_gra_err_short_circuit,200 ms,9
IDE17817-ENG302770-CCS lever: debounce times and fault times-P_t_gralever_adr_set_debounce,40 ms,9
IDE17817-ENG302771-CCS lever: debounce times and fault times-P_t_gralever_err_gra_stuck,300 s,9
IDE17817-ENG302772-CCS lever: debounce times and fault times-P_t_gralever_err_gra_unstuck,5000 ms,9
IDE17817-ENG302773-CCS lever: debounce times and fault times-P_t_gralever_invalid_dequalification_time,100 ms,9
IDE17817-ENG302774-CCS lever: debounce times and fault times-P_t_gralever_invalid_qualification_time,100 ms,9
IDE17818-Attenuation dimming up,2 units,1
IDE17819-ENG101574-Parking symbol function lighting: dimming curve-X1,0 units,21
IDE17819-ENG99557-Parking symbol function lighting: dimming curve-X2,10 units,21
IDE17819-ENG102140-Parking symbol function lighting: dimming curve-X3,50 units,21
IDE17819-ENG102936-Parking symbol function lighting: dimming curve-X4,100 units,21
IDE17819-ENG103548-Parking symbol function lighting: dimming curve-X5,150 units,21
IDE17819-ENG113992-Parking symbol function lighting: dimming curve-X6,220 units,21
IDE17819-ENG115661-Parking symbol function lighting: dimming curve-x7,253 units,21
IDE17819-ENG99777-Parking symbol function lighting: dimming curve-Y1,22 units,21
IDE17819-ENG100480-Parking symbol function lighting: dimming curve-Y2,22 units,21
IDE17819-ENG100773-Parking symbol function lighting: dimming curve-Y3,50 units,21
IDE17819-ENG100631-Parking symbol function lighting: dimming curve-Y4,111 units,21
IDE17819-ENG102174-Parking symbol function lighting: dimming curve-Y5,200 units,21
IDE17819-ENG113993-Parking symbol function lighting: dimming curve-Y6,700 units,21
IDE17819-ENG115665-Parking symbol function lighting: dimming curve-y7,1000 units,21
IDE17820-ENG101574-Function lighting: dimming curve-X1,0 units,21
IDE17820-ENG99557-Function lighting: dimming curve-X2,10 units,21
IDE17820-ENG102140-Function lighting: dimming curve-X3,50 units,21
IDE17820-ENG102936-Function lighting: dimming curve-X4,100 units,21
IDE17820-ENG103548-Function lighting: dimming curve-X5,150 units,21
IDE17820-ENG113992-Function lighting: dimming curve-X6,220 units,21
IDE17820-ENG115661-Function lighting: dimming curve-x7,253 units,21
IDE17820-ENG99777-Function lighting: dimming curve-Y1,10 units,21
IDE17820-ENG100480-Function lighting: dimming curve-Y2,10 units,21
IDE17820-ENG100773-Function lighting: dimming curve-Y3,25 units,21
IDE17820-ENG100631-Function lighting: dimming curve-Y4,50 units,21
IDE17820-ENG102174-Function lighting: dimming curve-Y5,500 units,21
IDE17820-ENG113993-Function lighting: dimming curve-Y6,850 units,21
IDE17820-ENG115665-Function lighting: dimming curve-y7,1000 units,21
IDE17821-ENG101574-Search lighting: dimming curve-X1,0 units,21
IDE17821-ENG99557-Search lighting: dimming curve-X2,6 units,21
IDE17821-ENG102140-Search lighting: dimming curve-X3,20 units,21
IDE17821-ENG102936-Search lighting: dimming curve-X4,50 units,21
IDE17821-ENG103548-Search lighting: dimming curve-X5,70 units,21
IDE17821-ENG113992-Search lighting: dimming curve-X6,85 units,21
IDE17821-ENG115661-Search lighting: dimming curve-x7,100 units,21
IDE17821-ENG99777-Search lighting: dimming curve-Y1,0 units,21
IDE17821-ENG100480-Search lighting: dimming curve-Y2,60 units,21
IDE17821-ENG100773-Search lighting: dimming curve-Y3,200 units,21
IDE17821-ENG100631-Search lighting: dimming curve-Y4,500 units,21
IDE17821-ENG102174-Search lighting: dimming curve-Y5,700 units,21
IDE17821-ENG113993-Search lighting: dimming curve-Y6,850 units,21
IDE17821-ENG115665-Search lighting: dimming curve-y7,1000 units,21
IDE17823-Terminal 58xd: error value,80 %,1
IDE17824-Network run-on timer,12 min,1
IDE20117-P display shut-down delay,4 s,1
IDE20118-ENG395174-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_open_circuit,1000 ms,4
IDE20118-ENG395175-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_short_circuit,200 ms,4
IDE20118-ENG395176-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_stuck,300 s,4
IDE20118-ENG395177-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_unstuck,5000 ms,4
IDE20119-ENG395170-Rear window wiper button: fault times-P_t_rearwiper_button_open_circuit,1000 ms,4
IDE20119-ENG395171-Rear window wiper button: fault times-P_t_rearwiper_button_short_circuit,200 ms,4
IDE20119-ENG395172-Rear window wiper button: fault times-P_t_rearwiper_button_stuck,60 s,4
IDE20119-ENG395173-Rear window wiper button: fault times-P_t_rearwiper_button_unstuck,1000 ms,4
IDE20120-ENG395168-Rear window wiper button: debounce times-P_t_rear_wiper_button_debounce_time_position_1,40 ms,2
IDE20120-ENG395169-Rear window wiper button: debounce times-P_t_rear_wiper_button_debounce_time_position_2,40 ms,2
IDE20121-Windshield wiper: interval 3,Unknown (0),1
ENG153885-Knockout_test_mode,00 ,1
Elapsed Time: 00:13
adpmap - 17
SW:571-920-340-A HW:571-920-340 --- 17: Instruments
Component:KOMBI 304 9460, Coding:042402457B9C00080880720B2000080810387C0000
EV_DashBoardVDDMQB37W,005050,EV_DashBoardVDDMQB37W_005_VW42.rod
Sunday,26,July,2026,16:16:28:15875
VCID: 1078B25B5AE093BA4F2-8044-R SFD [x]
IDE00301-Distance,22913 km,3
IDE00343-Language variant,Czech ,1
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,771 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE02489-Display depiction,Variant 1 ,1
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03568-ENG262858-Service-key settings-p_deactivate_SK-Sub_Function_Current_Data,On ,5
IDE03568-ENG262855-Service-key settings-p_deactivate_SK-Sub_Function_Daily_Data,On ,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,OFF ,5
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-IDE12722-Configuration of displayable contents-Driving profile display,No display ,4
IDE11472-MAS01833-Configuration of displayable contents-Charge air pressure,not active ,4
IDE11472-MAS03555-Configuration of displayable contents-Lap counter,not active ,4
IDE11472-MAS03688-Configuration of displayable contents-Navigation information,not active ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS05757-Configuration of displayable contents-Engine torque,not active ,4
IDE11472-MAS14767-Configuration of displayable contents-Convenience tire pressure warning display,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,not active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE11472-MAS19327-Configuration of displayable contents-Engine performance,not active ,4
IDE11472-MAS19328-Configuration of displayable contents-Transmission temperature,not active ,4
IDE11472-MAS19329-Configuration of displayable contents-G-meter,not active ,4
IDE11472-MAS19330-Configuration of displayable contents-Torque distribution,not active ,4
IDE11472-MAS23291-Configuration of displayable contents-Color switch-over,not active ,4
IDE11472-MAS29813-Configuration of displayable contents-Warning rear seats display,not active ,4
IDE11472-MAS30856-Configuration of displayable contents-Driver assistance systems: environment graphics,Variant 1 ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12792-IDE00301-Personalization of user account 1-Distance,Kilometres ,70
IDE12792-MAS01230-Personalization of user account 1-Date,dd_mm_yy ,70
IDE12792-MAS01456-Personalization of user account 1-Speed,Kilometers per hour ,70
IDE12792-MAS02201-Personalization of user account 1-Temperature,°C ,70
IDE12792-MAS02957-Personalization of user account 1-Time,24h ,70
IDE12792-MAS03032-Personalization of user account 1-Volume,litre ,70
IDE12792-MAS03034-Personalization of user account 1-Pressure,bar ,70
IDE12792-MAS05637-Personalization of user account 1-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12792-MAS05638-Personalization of user account 1-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12792-MAS05875-Personalization of user account 1-Average consumption: electric drive,kWh per 100 km ,70
IDE12792-Personalization of user account 1-,not active ,70
IDE12792-ENG154881-Personalization of user account 1-Active_design,0 ,70
IDE12792-ENG154882-Personalization of user account 1-Active_view,0 ,70
IDE12792-ENG155000-Personalization of user account 1-DC_aktiverSpeicherplatz,0 ,70
IDE12792-ENG155001-Personalization of user account 1-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12792-ENG155002-Personalization of user account 1-DC_linkeTubeninformation,00 ,70
IDE12792-ENG155003-Personalization of user account 1-DC_rechteTubeninformation,00 ,70
IDE12792-ENG155004-Personalization of user account 1-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155005-Personalization of user account 1-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155006-Personalization of user account 1-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155007-Personalization of user account 1-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155008-Personalization of user account 1-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155009-Personalization of user account 1-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155051-Personalization of user account 1-Display_Average_Consumption,active ,70
IDE12792-ENG155052-Personalization of user account 1-Display_Average_Speed,active ,70
IDE12792-ENG155053-Personalization of user account 1-Display_ComfortPowerConsumption,not active ,70
IDE12792-ENG155054-Personalization of user account 1-Display_ConsumerList,not active ,70
IDE12792-ENG155055-Personalization of user account 1-Display_CoolantTemperature,not active ,70
IDE12792-ENG155056-Personalization of user account 1-Display_CurrentConsumption,active ,70
IDE12792-ENG155057-Personalization of user account 1-Display_DigitalSpeedometer,active ,70
IDE12792-ENG155058-Personalization of user account 1-Display_Distance,active ,70
IDE12792-ENG155059-Personalization of user account 1-Display_DrivingTime,active ,70
IDE12792-ENG155060-Personalization of user account 1-Display_DualSpeedometer,not active ,70
IDE12792-ENG155061-Personalization of user account 1-Display_Laptimer,not active ,70
IDE12792-ENG155062-Personalization of user account 1-Display_LiveTips,not active ,70
IDE12792-ENG155063-Personalization of user account 1-Display_Nachtankmenge,not active ,70
IDE12792-ENG155064-Personalization of user account 1-Display_OilTemperature,active ,70
IDE12792-ENG155065-Personalization of user account 1-Display_Range,active ,70
IDE12792-ENG155066-Personalization of user account 1-Display_ResetTime,not active ,70
IDE12792-ENG155067-Personalization of user account 1-Display_SpeedWarning,not active ,70
IDE12792-ENG155068-Personalization of user account 1-Display_VZA,active ,70
IDE12792-ENG155069-Personalization of user account 1-Display_ZeroEmission_Distance,not active ,70
IDE12792-ENG155070-Personalization of user account 1-Display_ZeroEmission_Time,not active ,70
IDE12792-ENG155246-Personalization of user account 1-LastMode_HMI_global_active_layout,0 ,70
IDE12792-ENG155247-Personalization of user account 1-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12792-ENG155248-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12792-ENG155249-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12792-ENG155250-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12792-ENG155251-Personalization of user account 1-LastMode_HMI_HistoryState_main,0 ,70
IDE12792-ENG155252-Personalization of user account 1-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12792-ENG155253-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12792-ENG155254-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12792-ENG155255-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12792-ENG155256-Personalization of user account 1-LastMode_HMI_HistoryState_sport,0 ,70
IDE12792-ENG155257-Personalization of user account 1-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12792-ENG155258-Personalization of user account 1-LastMode_HMI_MFA_store,0 ,70
IDE12792-ENG155259-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12792-ENG155260-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12792-ENG155261-Personalization of user account 1-LastMode_v_Kunde_aktiv,not active ,70
IDE12792-ENG155262-Personalization of user account 1-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12792-ENG155263-Personalization of user account 1-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12792-ENG262859-Personalization of user account 1-speed_value,0 ,70
IDE12792-ENG263509-Personalization of user account 1-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12794-IDE00301-Personalization of user account 2-Distance,Kilometres ,70
IDE12794-MAS01230-Personalization of user account 2-Date,dd_mm_yy ,70
IDE12794-MAS01456-Personalization of user account 2-Speed,Kilometers per hour ,70
IDE12794-MAS02201-Personalization of user account 2-Temperature,°C ,70
IDE12794-MAS02957-Personalization of user account 2-Time,24h ,70
IDE12794-MAS03032-Personalization of user account 2-Volume,litre ,70
IDE12794-MAS03034-Personalization of user account 2-Pressure,bar ,70
IDE12794-MAS05637-Personalization of user account 2-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12794-MAS05638-Personalization of user account 2-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12794-MAS05875-Personalization of user account 2-Average consumption: electric drive,kWh per 100 km ,70
IDE12794-Personalization of user account 2-,not active ,70
IDE12794-ENG154881-Personalization of user account 2-Active_design,0 ,70
IDE12794-ENG154882-Personalization of user account 2-Active_view,0 ,70
IDE12794-ENG155000-Personalization of user account 2-DC_aktiverSpeicherplatz,0 ,70
IDE12794-ENG155001-Personalization of user account 2-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12794-ENG155002-Personalization of user account 2-DC_linkeTubeninformation,00 ,70
IDE12794-ENG155003-Personalization of user account 2-DC_rechteTubeninformation,00 ,70
IDE12794-ENG155004-Personalization of user account 2-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155005-Personalization of user account 2-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155006-Personalization of user account 2-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155007-Personalization of user account 2-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155008-Personalization of user account 2-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155009-Personalization of user account 2-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155051-Personalization of user account 2-Display_Average_Consumption,active ,70
IDE12794-ENG155052-Personalization of user account 2-Display_Average_Speed,active ,70
IDE12794-ENG155053-Personalization of user account 2-Display_ComfortPowerConsumption,not active ,70
IDE12794-ENG155054-Personalization of user account 2-Display_ConsumerList,not active ,70
IDE12794-ENG155055-Personalization of user account 2-Display_CoolantTemperature,not active ,70
IDE12794-ENG155056-Personalization of user account 2-Display_CurrentConsumption,active ,70
IDE12794-ENG155057-Personalization of user account 2-Display_DigitalSpeedometer,active ,70
IDE12794-ENG155058-Personalization of user account 2-Display_Distance,active ,70
IDE12794-ENG155059-Personalization of user account 2-Display_DrivingTime,active ,70
IDE12794-ENG155060-Personalization of user account 2-Display_DualSpeedometer,not active ,70
IDE12794-ENG155061-Personalization of user account 2-Display_Laptimer,not active ,70
IDE12794-ENG155062-Personalization of user account 2-Display_LiveTips,not active ,70
IDE12794-ENG155063-Personalization of user account 2-Display_Nachtankmenge,not active ,70
IDE12794-ENG155064-Personalization of user account 2-Display_OilTemperature,active ,70
IDE12794-ENG155065-Personalization of user account 2-Display_Range,active ,70
IDE12794-ENG155066-Personalization of user account 2-Display_ResetTime,not active ,70
IDE12794-ENG155067-Personalization of user account 2-Display_SpeedWarning,not active ,70
IDE12794-ENG155068-Personalization of user account 2-Display_VZA,active ,70
IDE12794-ENG155069-Personalization of user account 2-Display_ZeroEmission_Distance,not active ,70
IDE12794-ENG155070-Personalization of user account 2-Display_ZeroEmission_Time,not active ,70
IDE12794-ENG155246-Personalization of user account 2-LastMode_HMI_global_active_layout,0 ,70
IDE12794-ENG155247-Personalization of user account 2-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12794-ENG155248-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12794-ENG155249-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12794-ENG155250-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12794-ENG155251-Personalization of user account 2-LastMode_HMI_HistoryState_main,0 ,70
IDE12794-ENG155252-Personalization of user account 2-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12794-ENG155253-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12794-ENG155254-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12794-ENG155255-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12794-ENG155256-Personalization of user account 2-LastMode_HMI_HistoryState_sport,0 ,70
IDE12794-ENG155257-Personalization of user account 2-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12794-ENG155258-Personalization of user account 2-LastMode_HMI_MFA_store,0 ,70
IDE12794-ENG155259-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12794-ENG155260-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12794-ENG155261-Personalization of user account 2-LastMode_v_Kunde_aktiv,not active ,70
IDE12794-ENG155262-Personalization of user account 2-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12794-ENG155263-Personalization of user account 2-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12794-ENG262859-Personalization of user account 2-speed_value,0 ,70
IDE12794-ENG263509-Personalization of user account 2-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12796-IDE00301-Personalization of user account 3-Distance,Kilometres ,70
IDE12796-MAS01230-Personalization of user account 3-Date,dd_mm_yy ,70
IDE12796-MAS01456-Personalization of user account 3-Speed,Kilometers per hour ,70
IDE12796-MAS02201-Personalization of user account 3-Temperature,°C ,70
IDE12796-MAS02957-Personalization of user account 3-Time,24h ,70
IDE12796-MAS03032-Personalization of user account 3-Volume,litre ,70
IDE12796-MAS03034-Personalization of user account 3-Pressure,bar ,70
IDE12796-MAS05637-Personalization of user account 3-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12796-MAS05638-Personalization of user account 3-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12796-MAS05875-Personalization of user account 3-Average consumption: electric drive,kWh per 100 km ,70
IDE12796-Personalization of user account 3-,not active ,70
IDE12796-ENG154881-Personalization of user account 3-Active_design,0 ,70
IDE12796-ENG154882-Personalization of user account 3-Active_view,0 ,70
IDE12796-ENG155000-Personalization of user account 3-DC_aktiverSpeicherplatz,0 ,70
IDE12796-ENG155001-Personalization of user account 3-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12796-ENG155002-Personalization of user account 3-DC_linkeTubeninformation,00 ,70
IDE12796-ENG155003-Personalization of user account 3-DC_rechteTubeninformation,00 ,70
IDE12796-ENG155004-Personalization of user account 3-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155005-Personalization of user account 3-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155006-Personalization of user account 3-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155007-Personalization of user account 3-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155008-Personalization of user account 3-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155009-Personalization of user account 3-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155051-Personalization of user account 3-Display_Average_Consumption,active ,70
IDE12796-ENG155052-Personalization of user account 3-Display_Average_Speed,active ,70
IDE12796-ENG155053-Personalization of user account 3-Display_ComfortPowerConsumption,not active ,70
IDE12796-ENG155054-Personalization of user account 3-Display_ConsumerList,not active ,70
IDE12796-ENG155055-Personalization of user account 3-Display_CoolantTemperature,not active ,70
IDE12796-ENG155056-Personalization of user account 3-Display_CurrentConsumption,active ,70
IDE12796-ENG155057-Personalization of user account 3-Display_DigitalSpeedometer,active ,70
IDE12796-ENG155058-Personalization of user account 3-Display_Distance,active ,70
IDE12796-ENG155059-Personalization of user account 3-Display_DrivingTime,active ,70
IDE12796-ENG155060-Personalization of user account 3-Display_DualSpeedometer,not active ,70
IDE12796-ENG155061-Personalization of user account 3-Display_Laptimer,not active ,70
IDE12796-ENG155062-Personalization of user account 3-Display_LiveTips,not active ,70
IDE12796-ENG155063-Personalization of user account 3-Display_Nachtankmenge,not active ,70
IDE12796-ENG155064-Personalization of user account 3-Display_OilTemperature,active ,70
IDE12796-ENG155065-Personalization of user account 3-Display_Range,active ,70
IDE12796-ENG155066-Personalization of user account 3-Display_ResetTime,not active ,70
IDE12796-ENG155067-Personalization of user account 3-Display_SpeedWarning,not active ,70
IDE12796-ENG155068-Personalization of user account 3-Display_VZA,active ,70
IDE12796-ENG155069-Personalization of user account 3-Display_ZeroEmission_Distance,not active ,70
IDE12796-ENG155070-Personalization of user account 3-Display_ZeroEmission_Time,not active ,70
IDE12796-ENG155246-Personalization of user account 3-LastMode_HMI_global_active_layout,0 ,70
IDE12796-ENG155247-Personalization of user account 3-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12796-ENG155248-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12796-ENG155249-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12796-ENG155250-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12796-ENG155251-Personalization of user account 3-LastMode_HMI_HistoryState_main,0 ,70
IDE12796-ENG155252-Personalization of user account 3-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12796-ENG155253-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12796-ENG155254-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12796-ENG155255-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12796-ENG155256-Personalization of user account 3-LastMode_HMI_HistoryState_sport,0 ,70
IDE12796-ENG155257-Personalization of user account 3-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12796-ENG155258-Personalization of user account 3-LastMode_HMI_MFA_store,0 ,70
IDE12796-ENG155259-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12796-ENG155260-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12796-ENG155261-Personalization of user account 3-LastMode_v_Kunde_aktiv,not active ,70
IDE12796-ENG155262-Personalization of user account 3-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12796-ENG155263-Personalization of user account 3-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12796-ENG262859-Personalization of user account 3-speed_value,0 ,70
IDE12796-ENG263509-Personalization of user account 3-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12798-IDE00301-Personalization of user account 4-Distance,Kilometres ,70
IDE12798-MAS01230-Personalization of user account 4-Date,dd_mm_yy ,70
IDE12798-MAS01456-Personalization of user account 4-Speed,Kilometers per hour ,70
IDE12798-MAS02201-Personalization of user account 4-Temperature,°C ,70
IDE12798-MAS02957-Personalization of user account 4-Time,24h ,70
IDE12798-MAS03032-Personalization of user account 4-Volume,litre ,70
IDE12798-MAS03034-Personalization of user account 4-Pressure,bar ,70
IDE12798-MAS05637-Personalization of user account 4-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12798-MAS05638-Personalization of user account 4-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12798-MAS05875-Personalization of user account 4-Average consumption: electric drive,kWh per 100 km ,70
IDE12798-Personalization of user account 4-,not active ,70
IDE12798-ENG154881-Personalization of user account 4-Active_design,0 ,70
IDE12798-ENG154882-Personalization of user account 4-Active_view,0 ,70
IDE12798-ENG155000-Personalization of user account 4-DC_aktiverSpeicherplatz,0 ,70
IDE12798-ENG155001-Personalization of user account 4-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12798-ENG155002-Personalization of user account 4-DC_linkeTubeninformation,00 ,70
IDE12798-ENG155003-Personalization of user account 4-DC_rechteTubeninformation,00 ,70
IDE12798-ENG155004-Personalization of user account 4-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155005-Personalization of user account 4-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155006-Personalization of user account 4-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155007-Personalization of user account 4-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155008-Personalization of user account 4-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155009-Personalization of user account 4-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155051-Personalization of user account 4-Display_Average_Consumption,active ,70
IDE12798-ENG155052-Personalization of user account 4-Display_Average_Speed,active ,70
IDE12798-ENG155053-Personalization of user account 4-Display_ComfortPowerConsumption,not active ,70
IDE12798-ENG155054-Personalization of user account 4-Display_ConsumerList,not active ,70
IDE12798-ENG155055-Personalization of user account 4-Display_CoolantTemperature,not active ,70
IDE12798-ENG155056-Personalization of user account 4-Display_CurrentConsumption,active ,70
IDE12798-ENG155057-Personalization of user account 4-Display_DigitalSpeedometer,active ,70
IDE12798-ENG155058-Personalization of user account 4-Display_Distance,active ,70
IDE12798-ENG155059-Personalization of user account 4-Display_DrivingTime,active ,70
IDE12798-ENG155060-Personalization of user account 4-Display_DualSpeedometer,not active ,70
IDE12798-ENG155061-Personalization of user account 4-Display_Laptimer,not active ,70
IDE12798-ENG155062-Personalization of user account 4-Display_LiveTips,not active ,70
IDE12798-ENG155063-Personalization of user account 4-Display_Nachtankmenge,not active ,70
IDE12798-ENG155064-Personalization of user account 4-Display_OilTemperature,active ,70
IDE12798-ENG155065-Personalization of user account 4-Display_Range,active ,70
IDE12798-ENG155066-Personalization of user account 4-Display_ResetTime,not active ,70
IDE12798-ENG155067-Personalization of user account 4-Display_SpeedWarning,not active ,70
IDE12798-ENG155068-Personalization of user account 4-Display_VZA,active ,70
IDE12798-ENG155069-Personalization of user account 4-Display_ZeroEmission_Distance,not active ,70
IDE12798-ENG155070-Personalization of user account 4-Display_ZeroEmission_Time,not active ,70
IDE12798-ENG155246-Personalization of user account 4-LastMode_HMI_global_active_layout,0 ,70
IDE12798-ENG155247-Personalization of user account 4-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12798-ENG155248-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12798-ENG155249-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12798-ENG155250-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12798-ENG155251-Personalization of user account 4-LastMode_HMI_HistoryState_main,0 ,70
IDE12798-ENG155252-Personalization of user account 4-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12798-ENG155253-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12798-ENG155254-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12798-ENG155255-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12798-ENG155256-Personalization of user account 4-LastMode_HMI_HistoryState_sport,0 ,70
IDE12798-ENG155257-Personalization of user account 4-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12798-ENG155258-Personalization of user account 4-LastMode_HMI_MFA_store,0 ,70
IDE12798-ENG155259-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12798-ENG155260-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12798-ENG155261-Personalization of user account 4-LastMode_v_Kunde_aktiv,not active ,70
IDE12798-ENG155262-Personalization of user account 4-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12798-ENG155263-Personalization of user account 4-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12798-ENG262859-Personalization of user account 4-speed_value,0 ,70
IDE12798-ENG263509-Personalization of user account 4-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12800-IDE00301-Personalization of user account 5-Distance,Kilometres ,70
IDE12800-MAS01230-Personalization of user account 5-Date,dd_mm_yy ,70
IDE12800-MAS01456-Personalization of user account 5-Speed,Kilometers per hour ,70
IDE12800-MAS02201-Personalization of user account 5-Temperature,°C ,70
IDE12800-MAS02957-Personalization of user account 5-Time,24h ,70
IDE12800-MAS03032-Personalization of user account 5-Volume,litre ,70
IDE12800-MAS03034-Personalization of user account 5-Pressure,bar ,70
IDE12800-MAS05637-Personalization of user account 5-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12800-MAS05638-Personalization of user account 5-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12800-MAS05875-Personalization of user account 5-Average consumption: electric drive,kWh per 100 km ,70
IDE12800-Personalization of user account 5-,not active ,70
IDE12800-ENG154881-Personalization of user account 5-Active_design,0 ,70
IDE12800-ENG154882-Personalization of user account 5-Active_view,0 ,70
IDE12800-ENG155000-Personalization of user account 5-DC_aktiverSpeicherplatz,0 ,70
IDE12800-ENG155001-Personalization of user account 5-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12800-ENG155002-Personalization of user account 5-DC_linkeTubeninformation,00 ,70
IDE12800-ENG155003-Personalization of user account 5-DC_rechteTubeninformation,00 ,70
IDE12800-ENG155004-Personalization of user account 5-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155005-Personalization of user account 5-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155006-Personalization of user account 5-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155007-Personalization of user account 5-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155008-Personalization of user account 5-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155009-Personalization of user account 5-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155051-Personalization of user account 5-Display_Average_Consumption,active ,70
IDE12800-ENG155052-Personalization of user account 5-Display_Average_Speed,active ,70
IDE12800-ENG155053-Personalization of user account 5-Display_ComfortPowerConsumption,not active ,70
IDE12800-ENG155054-Personalization of user account 5-Display_ConsumerList,not active ,70
IDE12800-ENG155055-Personalization of user account 5-Display_CoolantTemperature,not active ,70
IDE12800-ENG155056-Personalization of user account 5-Display_CurrentConsumption,active ,70
IDE12800-ENG155057-Personalization of user account 5-Display_DigitalSpeedometer,active ,70
IDE12800-ENG155058-Personalization of user account 5-Display_Distance,active ,70
IDE12800-ENG155059-Personalization of user account 5-Display_DrivingTime,active ,70
IDE12800-ENG155060-Personalization of user account 5-Display_DualSpeedometer,not active ,70
IDE12800-ENG155061-Personalization of user account 5-Display_Laptimer,not active ,70
IDE12800-ENG155062-Personalization of user account 5-Display_LiveTips,not active ,70
IDE12800-ENG155063-Personalization of user account 5-Display_Nachtankmenge,not active ,70
IDE12800-ENG155064-Personalization of user account 5-Display_OilTemperature,active ,70
IDE12800-ENG155065-Personalization of user account 5-Display_Range,active ,70
IDE12800-ENG155066-Personalization of user account 5-Display_ResetTime,not active ,70
IDE12800-ENG155067-Personalization of user account 5-Display_SpeedWarning,not active ,70
IDE12800-ENG155068-Personalization of user account 5-Display_VZA,active ,70
IDE12800-ENG155069-Personalization of user account 5-Display_ZeroEmission_Distance,not active ,70
IDE12800-ENG155070-Personalization of user account 5-Display_ZeroEmission_Time,not active ,70
IDE12800-ENG155246-Personalization of user account 5-LastMode_HMI_global_active_layout,0 ,70
IDE12800-ENG155247-Personalization of user account 5-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12800-ENG155248-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12800-ENG155249-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12800-ENG155250-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12800-ENG155251-Personalization of user account 5-LastMode_HMI_HistoryState_main,0 ,70
IDE12800-ENG155252-Personalization of user account 5-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12800-ENG155253-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12800-ENG155254-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12800-ENG155255-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12800-ENG155256-Personalization of user account 5-LastMode_HMI_HistoryState_sport,0 ,70
IDE12800-ENG155257-Personalization of user account 5-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12800-ENG155258-Personalization of user account 5-LastMode_HMI_MFA_store,0 ,70
IDE12800-ENG155259-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12800-ENG155260-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12800-ENG155261-Personalization of user account 5-LastMode_v_Kunde_aktiv,not active ,70
IDE12800-ENG155262-Personalization of user account 5-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12800-ENG155263-Personalization of user account 5-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12800-ENG262859-Personalization of user account 5-speed_value,0 ,70
IDE12800-ENG263509-Personalization of user account 5-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12802-IDE00301-Personalization of user account 6-Distance,Kilometres ,70
IDE12802-MAS01230-Personalization of user account 6-Date,dd_mm_yy ,70
IDE12802-MAS01456-Personalization of user account 6-Speed,Kilometers per hour ,70
IDE12802-MAS02201-Personalization of user account 6-Temperature,°C ,70
IDE12802-MAS02957-Personalization of user account 6-Time,24h ,70
IDE12802-MAS03032-Personalization of user account 6-Volume,litre ,70
IDE12802-MAS03034-Personalization of user account 6-Pressure,bar ,70
IDE12802-MAS05637-Personalization of user account 6-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12802-MAS05638-Personalization of user account 6-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12802-MAS05875-Personalization of user account 6-Average consumption: electric drive,kWh per 100 km ,70
IDE12802-Personalization of user account 6-,not active ,70
IDE12802-ENG154881-Personalization of user account 6-Active_design,0 ,70
IDE12802-ENG154882-Personalization of user account 6-Active_view,0 ,70
IDE12802-ENG155000-Personalization of user account 6-DC_aktiverSpeicherplatz,0 ,70
IDE12802-ENG155001-Personalization of user account 6-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12802-ENG155002-Personalization of user account 6-DC_linkeTubeninformation,00 ,70
IDE12802-ENG155003-Personalization of user account 6-DC_rechteTubeninformation,00 ,70
IDE12802-ENG155004-Personalization of user account 6-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155005-Personalization of user account 6-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155006-Personalization of user account 6-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155007-Personalization of user account 6-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155008-Personalization of user account 6-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155009-Personalization of user account 6-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155051-Personalization of user account 6-Display_Average_Consumption,active ,70
IDE12802-ENG155052-Personalization of user account 6-Display_Average_Speed,active ,70
IDE12802-ENG155053-Personalization of user account 6-Display_ComfortPowerConsumption,not active ,70
IDE12802-ENG155054-Personalization of user account 6-Display_ConsumerList,not active ,70
IDE12802-ENG155055-Personalization of user account 6-Display_CoolantTemperature,not active ,70
IDE12802-ENG155056-Personalization of user account 6-Display_CurrentConsumption,active ,70
IDE12802-ENG155057-Personalization of user account 6-Display_DigitalSpeedometer,active ,70
IDE12802-ENG155058-Personalization of user account 6-Display_Distance,active ,70
IDE12802-ENG155059-Personalization of user account 6-Display_DrivingTime,active ,70
IDE12802-ENG155060-Personalization of user account 6-Display_DualSpeedometer,not active ,70
IDE12802-ENG155061-Personalization of user account 6-Display_Laptimer,not active ,70
IDE12802-ENG155062-Personalization of user account 6-Display_LiveTips,not active ,70
IDE12802-ENG155063-Personalization of user account 6-Display_Nachtankmenge,not active ,70
IDE12802-ENG155064-Personalization of user account 6-Display_OilTemperature,active ,70
IDE12802-ENG155065-Personalization of user account 6-Display_Range,active ,70
IDE12802-ENG155066-Personalization of user account 6-Display_ResetTime,not active ,70
IDE12802-ENG155067-Personalization of user account 6-Display_SpeedWarning,not active ,70
IDE12802-ENG155068-Personalization of user account 6-Display_VZA,active ,70
IDE12802-ENG155069-Personalization of user account 6-Display_ZeroEmission_Distance,not active ,70
IDE12802-ENG155070-Personalization of user account 6-Display_ZeroEmission_Time,not active ,70
IDE12802-ENG155246-Personalization of user account 6-LastMode_HMI_global_active_layout,0 ,70
IDE12802-ENG155247-Personalization of user account 6-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12802-ENG155248-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12802-ENG155249-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12802-ENG155250-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12802-ENG155251-Personalization of user account 6-LastMode_HMI_HistoryState_main,0 ,70
IDE12802-ENG155252-Personalization of user account 6-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12802-ENG155253-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12802-ENG155254-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12802-ENG155255-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12802-ENG155256-Personalization of user account 6-LastMode_HMI_HistoryState_sport,0 ,70
IDE12802-ENG155257-Personalization of user account 6-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12802-ENG155258-Personalization of user account 6-LastMode_HMI_MFA_store,0 ,70
IDE12802-ENG155259-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12802-ENG155260-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12802-ENG155261-Personalization of user account 6-LastMode_v_Kunde_aktiv,not active ,70
IDE12802-ENG155262-Personalization of user account 6-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12802-ENG155263-Personalization of user account 6-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12802-ENG262859-Personalization of user account 6-speed_value,0 ,70
IDE12802-ENG263509-Personalization of user account 6-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12804-IDE00301-Personalization of user account 7-Distance,Kilometres ,70
IDE12804-MAS01230-Personalization of user account 7-Date,dd_mm_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Kilometers per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature,°C ,70
IDE12804-MAS02957-Personalization of user account 7-Time,24h ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,litre ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,bar ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,kWh per 100 km ,70
IDE12804-Personalization of user account 7-,not active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,0 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG262859-Personalization of user account 7-speed_value,0 ,70
IDE12804-ENG263509-Personalization of user account 7-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,4600 km,2
IDE12963-Oil: thermal loading,21100 km,2
IDE12964-Oil: driven distance since last oil service,4000 km,3
IDE12965-Oil: time since last oil service,254 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),30000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,30000 km,3
IDE12979-Inspection: time until next inspection,730 d,2
IDE12980-Inspection: distance driven since the last inspection,4000 km,3
IDE12981-Inspection: time since the last inspection,254 d,2
IDE12982-Inspection: distance reset value,30000 km,2
IDE12983-Inspection: time reset value,365 d,2
IDE13031-MAS03935-Long-term store-Driving time,0 min,44
IDE13031-MAS15517-Long-term store-Travel distance,0 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,0 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,0 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,0 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,0 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.000 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.000 kWh,44
IDE13094-Tachometer end value,Variant 4 ,1
IDE13275-IDE00301-Personalization default value-Distance,Kilometres ,70
IDE13275-MAS01230-Personalization default value-Date,dd_mm_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Kilometers per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature,°C ,70
IDE13275-MAS02957-Personalization default value-Time,24h ,70
IDE13275-MAS03032-Personalization default value-Volume,litre ,70
IDE13275-MAS03034-Personalization default value-Pressure,bar ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,kWh per 100 km ,70
IDE13275-Personalization default value-,not active ,70
IDE13275-ENG154881-Personalization default value-Active_design,0 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,not active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,not active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,0 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,5 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG262859-Personalization default value-speed_value,0 ,70
IDE13275-ENG263509-Personalization default value-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE13441-Secondary speed in case of unit replacement,Display ,1
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14112-Gas system test - warning reset,No ,1
IDE14116-Gas system test - warning time,1443 d,2
IDE14123-MAS01129-Design variant activation-Variant 1,not active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,Yes ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,0 s,1
IDE14222-Test number length: authentic time,16 B,1
IDE14875-MAS19483-Activation of views-View 1,active ,2
IDE14875-MAS19484-Activation of views-View 2,not active ,2
IDE14875-MAS19485-Activation of views-View 3,active ,2
IDE14875-MAS19486-Activation of views-View 4,active ,2
IDE14875-MAS19487-Activation of views-View 5,not active ,2
IDE14875-MAS19488-Activation of views-View 6,active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,active ,2
IDE14875-MAS19491-Activation of views-View 9,not active ,2
IDE14875-MAS19492-Activation of views-View 10,not active ,2
IDE14875-MAS19493-Activation of views-View 12,not active ,2
IDE14875-MAS19494-Activation of views-View 11,not active ,2
IDE14875-MAS19495-Activation of views-View 13,active ,2
IDE14875-MAS19496-Activation of views-View 14,not active ,2
IDE14875-MAS19497-Activation of views-View 15,not active ,2
IDE14875-MAS19498-Activation of views-View 16,not active ,2
IDE15080-Logo,logo_2 ,1
IDE15909-Removable seats,Layout normal ,1
IDE17327-MAS01877-Tachometer color setting-Red,0 ,3
IDE17327-MAS01878-Tachometer color setting-Green,0 ,3
IDE17327-MAS01879-Tachometer color setting-Blue,0 ,3
IDE18473-WLTP concept,Default WLTP ,1
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,No ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
MAS01083-IDE18009-Country Variant-Canada variant,No ,2
ENG309777-Aktivierung IPA,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG262830-Correction_factor_consumption_and_operating_range_electric,100 %,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,96 ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,9 ‰,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,9 ‰,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,16 ‰,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,56 ‰,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,400 ‰,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,1000 ‰,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.0 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.0 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.0 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.0 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.0 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.0 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.0 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.0 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.0 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.0 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.0 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.0 %,24
ENG316729-ESI_Maximum_mileage_to_next_service_ZDC,30000 km,2
ENG316730-ESI_Maximum_time_to_next_service_ZDC,730 d,2
ENG316731-ESI_Minimum_mileage_to_next_service_ZDC,15000 km,2
ENG316732-ESI_Minimum_time_to_next_service_ZDC,365 d,2
ENG316733-ESI_Oil_quality_ZDC,poor oil quality ,1
ENG316701-FIX_Maximum_distance_to_next_mileage_based_service_event_zdc,30000 km,3
ENG316702-FIX_Maximum_time_to_next_time_based_service_event_zdc,1095 d,2
ENG316734-FIX_resetvalue_distance_to_next_mileage_based_service_events_ZDC,30000 km,2
ENG316735-FIX_resetvalue_time_to_next_mileage_based_service_events_ZDC,365 d,2
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4.0 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6.0 °C,16
ENG135292-phev_stat_intervall-,1.0 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.0 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.0 s,7
ENG135292-phev_stat_intervall-,00000000 00010000 ,7
ENG316738-SID_Maximum_mileage_to_next_oil_service_ZDC,15000 km,2
ENG316739-SID_Maximum_time_to_next_oil_service_ZDC,365 d,2
ENG262832-Switching_Networking,Ethernet ,1
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.50 ,18
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:46
adpmap - 18
SW:3J0-963-272-A HW:3J0-963-272-A --- 18: Aux. Heat
Component:STH-VW37x 006 0002, Coding:2D1B155A5C25162CE46D19
EV_AuxilHeateWOSVW38X,003004,EV_AuxilHeateWOSVW38X.rod
Sunday,26,July,2026,16:34:32:15875
VCDS Version: 26.7.0.1 (x64) Data version: 20260708 DS378.0
VCID: 2B0205B7D386D0625A0-807E-R
IDE00470-Initial fuel filling,Yes ,1
IDE06640-MAS01167-Transfer fuel pump-Actuation time,20 s,3
IDE06640-MAS05080-Transfer fuel pump-Maximum standing time,0.0 H,3
IDE06640-MAS05689-Transfer fuel pump-Activation delay,10 s,3
IDE06642-IDE15463-Coolant change-over valve-Activation delay: medium-voltage holding voltage,10 s,3
IDE06642-MAS05071-Coolant change-over valve-Temperature difference: engine/parking heater,0 °C,3
IDE06642-MAS05073-Coolant change-over valve-Residual heat: threshold,-40 °C,3
IDE06686-Low voltage threshold,11.3 V,1
IDE06687-CO2 setting,175 ,1
IDE06689-Low voltage detection: time limit,20.0 s,1
IDE06690-MAS05059-Auxil. heat control parameters-Lower temperature threshold: ambient temperature,5.0 °C,2
IDE06690-MAS05060-Auxil. heat control parameters-Upper temperature threshold: ambient temperature,12.0 °C,2
IDE06692-Note request for aux. heater from A/C system,Do not ignore ,1
IDE06693-Evaluate air pressure via CAN,Yes ,1
IDE06694-MAS05076-Minimum burn time-Time,160 s,2
IDE06694-MAS05077-Minimum burn time-Temperature threshold offset,1 °C,2
IDE07160-MAS04357-Control module switch-off: switch-off time-Time 1,140 min,2
IDE07160-MAS04358-Control module switch-off: switch-off time-Time 2,20 min,2
IDE11710-MAS03980-Heating time limitation-Maximum heating time,180 min,2
IDE11710-MAS13122-Heating time limitation-Activation function heating time exceedance,active ,2
MAS01488-MAS05072-recirc. pump-Maximum engine rpm,12750 /min,4
MAS01488-MAS06093-recirc. pump-Lowest temperature for request of exterior water pump,-20 °C,4
MAS01488-MAS06094-recirc. pump-Lowest activation temperat. for request of exterior water pump,150 s,4
MAS01488-MAS06095-recirc. pump-Maximum temperature for request of exterior water pump,180 s,4
MAS05075-Evaluate ethanol content,Yes ,1
MAS09096-Recirc. pump locking mechan.,1 ,1
ENG119729-activacion_of_simulated_flamme_run_for_emv_measuring,No ,1
ENG119721-development_data_on_CAN,not active ,1
Elapsed Time: 00:05
adpmap - 19
SW:5QS-907-530-B HW:5QS-907-530 --- 19: CAN Gateway
Component:GW MQB 23 005 3093, Coding:000000000000000000000000000000000000000000000300030000000000000000000000000000000000000000000000
EV_GatewMQBwBL,001018,EV_GatewMQBwBL_VW41.rod
Sunday,26,July,2026,16:18:46:15875
VCID: 53F27D57AB76A8A2320-8006 SFD+SFD2 [x]
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
IDE00003-Coding,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,48
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG447862-Activating and deactivating all development messages-ELF_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG447864-Activating and deactivating all development messages-HVLM_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG447863-Activating and deactivating all development messages-HVL-SF_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,Security access required You should unlock SFD before attempting advanced functions.,48
IDE01996-ENG151565-Installation list: specified installations-ECU coded Bit 0,Yes ,32
IDE01996-ENG176508-Installation list: specified installations-ECU coded Bit 1,No ,32
IDE01996-ENG176493-Installation list: specified installations-ECU coded Bit 2,Yes ,32
IDE01996-ENG176430-Installation list: specified installations-ECU coded Bit 3,Yes ,32
IDE01996-ENG176439-Installation list: specified installations-ECU coded Bit 4,Yes ,32
IDE01996-ENG176505-Installation list: specified installations-ECU coded Bit 5,Yes ,32
IDE01996-ENG176473-Installation list: specified installations-ECU coded Bit 6,No ,32
IDE01996-ENG176498-Installation list: specified installations-ECU coded Bit 7,No ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,VAO ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,640525P2H7 ,15
IDE03903-Production process data 1,01 BF ,2
IDE06425-Dynamometer mode: functional-,Security access required You should unlock SFD before attempting advanced functions.,4
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,Security access required You should unlock SFD before attempting advanced functions.,4
IDE06530-Distance left for deactivation of static current measuring mode,4 km,1
IDE06541-Distance left for deactivation of transport mode,50 km,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE07160-Control module switch-off: switch-off time,20 min,2
IDE08220-Vehicle production mode,not active ,1
IDE08623-MAS02672-OBD configuration-Start-stop,StartStopp ,2
IDE08623-MAS08039-OBD configuration-HV charging,NoHVLaden ,2
IDE08623-MAS14468-OBD configuration-OBD type,EOBD ,2
IDE08623-MAS26199-OBD configuration-MHEV,NoMHEV ,2
IDE08623-MAS26725-OBD configuration-Internal combustion engine information,ICE ,2
IDE08623-MAS26826-OBD configuration-HEV,NoHEV ,2
IDE08623-MAS27147-OBD configuration-OBD on event data recorder (EDR),No ,2
IDE08623-MAS28789-OBD configuration-Starter battery: type,Lead ,2
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.1 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,4 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,0 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,0 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,0 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,151 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,10.1 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,15.1 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,15.1 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,15.1 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,15.1 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,20.1 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),15.1 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,5.1 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,15.1 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,10.1 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,10.1 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,5.1 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,5.1 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,5.1 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,5.1 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,5.1 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.1 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,5.1 l/100km,48
IDE10351-MAS10460-Message mirroring-Target bus,Security access required You should unlock SFD before attempting advanced functions.,48
IDE10351-MAS21167-Message mirroring-Source bus,Security access required You should unlock SFD before attempting advanced functions.,48
IDE11689-48V-System: locking,regular operation ,1
IDE13748-IDE17293-Coding low voltage energy management-Autonomous inverter for socket,Not coded ,6
IDE13748-IDE17294-Coding low voltage energy management-Battery architecture,0 ,6
IDE13748-MAS23870-Coding low voltage energy management-Battery installation point,8 ,6
IDE13748-MAS23871-Coding low voltage energy management-Additional memory control,Not coded ,6
IDE13748-SFT271977-Coding low voltage energy management-Inverter for socket,coded ,6
IDE13844-Distance left for deactivation of production mode,100 km,1
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,12.0 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,12.0 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,12.0 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,12.0 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,12.0 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,12.0 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,12.0 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,12.0 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,12.0 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,12.0 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,12.0 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,12.0 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,12.0 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,12.0 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,12.0 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,12.0 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,12.0 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,12.0 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,12.0 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,12.0 kWh/100 km,40
IDE14423-IDE01058-High-voltage charging management coding-Country coding,Europe ,5
IDE14423-MAS01065-High-voltage charging management coding-Brand,Volkswagen AG ,5
IDE14423-MAS08226-High-voltage charging management coding-Max charging current,6A ,5
IDE14423-ENG172426-High-voltage charging management coding-AC_charging_socket_A,not installed ,5
IDE14423-ENG172427-High-voltage charging management coding-AC_charging_socket_B,not installed ,5
IDE14423-ENG174048-High-voltage charging management coding-Automatic_wireless_charging,not installed ,5
IDE14423-ENG259912-High-voltage charging management coding-charge_flap_lock_detection,not installed ,5
IDE14423-ENG260779-High-voltage charging management coding-Charge_flap_locking,not installed ,5
IDE14423-ENG172423-High-voltage charging management coding-DC_charging_Chademo,not installed ,5
IDE14423-ENG258832-High-voltage charging management coding-DC_charging_china,not installed ,5
IDE14423-ENG174370-High-voltage charging management coding-kind_of_plug_interlock_detection,limit_switch ,5
IDE14423-ENG172503-High-voltage charging management coding-PLC_charging_socket_A,not installed ,5
IDE14423-ENG172504-High-voltage charging management coding-PLC_charging_socket_B,not installed ,5
IDE14423-ENG251485-High-voltage charging management coding-plug_and_charge,not installed ,5
IDE14423-ENG251486-High-voltage charging management coding-plug_interlock,not installed ,5
IDE14423-ENG174643-High-voltage charging management coding-stimulation_wire,not installed ,5
IDE15100-IDE02321-Parking coordinator coding-Activation of park assist,automatic ,8
IDE15100-IDE17041-Parking coordinator coding-Reversing mode bumper protection,not installed ,8
IDE15100-IDE17042-Parking coordinator coding-Reversing mode parking space,installed ,8
IDE15100-IDE17043-Parking coordinator coding-Reversing mode parallel to road,not installed ,8
IDE15100-IDE17044-Parking coordinator coding-Reversing mode crossing traffic,installed ,8
IDE15100-IDE17045-Parking coordinator coding-Reversing mode trailer hitch,installed ,8
IDE15100-IDE17046-Parking coordinator coding-Rear Assist,not installed ,8
IDE15100-IDE17047-Parking coordinator coding-Automatic rear pedestrian brake,not installed ,8
IDE15100-IDE17048-Parking coordinator coding-Video Parking System,Peripheral camera system (eEntry) ,8
IDE15100-IDE21181-Parking coordinator coding-Cross traffic alert (RCTA): mode,last mode active ,8
IDE15100-IDE21185-Parking coordinator coding-TopView camera (design variant),eMid not installed ,8
IDE15100-IDE21225-Parking coordinator coding-Main switch parking message manager,not active ,8
IDE15100-MAS01083-Parking coordinator coding-Country Variant,Europe ,8
IDE15100-MAS01090-Parking coordinator coding-Gearbox,automatic ,8
IDE15100-MAS09095-Parking coordinator coding-Optical parking system,installed ,8
IDE15100-MAS12061-Parking coordinator coding-Sensor with rotation direction detection,installed ,8
IDE15100-MAS12321-Parking coordinator coding-Trailer maneuvering system,Car_trailer_assistant_Gen_1 ,8
IDE15100-MAS15696-Parking coordinator coding-Rear cross traffic assistant,installed ,8
IDE15100-MAS23011-Parking coordinator coding-trailer hitch,Trailer hitch (manually removable) ,8
IDE15100-MAS23012-Parking coordinator coding-Intersection assistant,installed ,8
IDE15100-MAS23014-Parking coordinator coding-Acoustic parking system,PDC front and rear or front: rear and side ,8
IDE15100-MAS23015-Parking coordinator coding-Collision assistant,Maneuvering brake function ,8
IDE15100-MAS23016-Parking coordinator coding-Remote controlled functions,not installed ,8
IDE15100-MAS23019-Parking coordinator coding-Electric parking brake,installed ,8
IDE15100-MAS23063-Parking coordinator coding-PDC front and rear or front: rear and side,intelligent parking assistant ,8
IDE15100-MAS25259-Parking coordinator coding-Trained parking,installed ,8
IDE15100-SFT33108-Parking coordinator coding-Rush Hour Pilot,not installed ,8
IDE15100-ENG364596-Parking coordinator coding-HMI Concept,User interface (HMI) 1.X ,8
IDE15100-ENG257808-Parking coordinator coding-PaCo_Car_HardKeyFAS,not installed ,8
IDE15100-ENG258080-Parking coordinator coding-PaCo_Drive_type,Combustion engine ,8
IDE15100-ENG257781-Parking coordinator coding-PaCo_Parking_Hardkey,not installed ,8
IDE15100-ENG257858-Parking coordinator coding-PaCo_Personalisation,active ,8
IDE15100-ENG258079-Parking coordinator coding-PaCo_Traffic_side,Right hand driv. ,8
IDE15316-FoD Partner,Available ,1
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
IDE15413-IDE18871-Anomaly detection configuration-Report system for deviations: activation status,On ,1
IDE15413-MAS26275-Anomaly detection configuration-GBT China compliant,OFF ,1
IDE15756-Ethernet port 3 VLAN configuration,VLAN_Comfort and VLAN_Infotainment ,1
IDE16058-FoD Set assignment of work clearance ID,02 00 0A 00 5F 00 00 01 0F FF FF 00 09 10 02 00 10 02 FF 00 A5 10 0E 00 10 0E FF 00 19 10 00 01 10 00 01 00 13 10 01 00 10 01 FF 00 01 10 07 00 10 07 FF 00 08 10 05 00 10 05 FF 00 19 10 13 00 10 13 FF 00 17 10 04 00 10 04 FF 81 5A 10 09 00 10 09 FF ,83
IDE16455-Configuration of unlockable functions,02 08 00 00 01 00 76 01 00 09 00 0E 02 00 13 00 57 03 00 17 00 14 06 00 A5 00 4F 07 00 5F 00 73 0B 00 08 00 46 10 81 5A 00 39 ,42
IDE16462-Unlockable functions: communication configuration,02 08 00 00 01 04 03 02 01 00 09 04 03 02 02 00 13 04 03 00 03 00 17 04 03 00 06 00 A5 04 03 02 07 00 5F 04 03 02 0B 00 08 04 03 02 10 81 5A 04 03 02 ,50
IDE16611-Diagnosis filter: temporary deactivation,active ,1
IDE17298-MAS00128-Trustworthy time synchronization in the master performance-Adaptive Cruise Control,Activate ,3
IDE17298-MAS13018-Trustworthy time synchronization in the master performance-Front sensor for driver assistance systems,Activate ,3
IDE17298-MAS23893-Trustworthy time synchronization in the master performance-Round counter for redeterminations,3 ,3
IDE17298-MAS23894-Trustworthy time synchronization in the master performance-Round counter for memory attempts,3 ,3
IDE17298-SFT33033-Trustworthy time synchronization in the master performance-Short-range radar 1,Activate ,3
IDE17298-SFT33034-Trustworthy time synchronization in the master performance-Short-range radar 2,Activate ,3
IDE17298-SFT33035-Trustworthy time synchronization in the master performance-Short-range radar 3,Deactivating ,3
IDE17298-SFT33036-Trustworthy time synchronization in the master performance-Short-range radar 4,Deactivating ,3
IDE18363-Electronic architecture,00 00 00 ,3
IDE19530-Ethernet port 4 VLAN configuration,VLAN infotainment system and VLAN Internet ,1
MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,active ,5
MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,active ,5
MAS08072-ENG172201-Driving profile selection-FPA_Funktion,active ,5
MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,active ,5
MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,active ,5
MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,not active ,5
MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,active ,5
MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,active ,5
MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,active ,5
MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,active ,5
MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,active ,5
MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,not active ,5
MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,not active ,5
MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,active ,5
MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,active ,5
MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,active ,5
MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,active ,5
MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,active ,5
MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,not active ,5
MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,active ,5
MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,active ,5
MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,not active ,5
MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,not active ,5
MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,not active ,5
MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,not active ,5
MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,not active ,5
MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,active ,5
MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Rising slope ,5
MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Yes ,4
MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Yes ,4
MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Yes ,4
MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,Yes ,4
MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,No ,4
MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,No ,4
MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,Yes ,4
MAS16743-Alternator gear ratio,6A ,1
MAS23693-MAS18081-Drowsiness and attention detection-Test Mode,00 ,22
MAS23693-MAS20954-Drowsiness and attention detection-Function coding,01 ,22
MAS23693-ENG101808-Drowsiness and attention detection-Bytes 1-16,6C 4D C0 00 00 0A 9C 6B 2C 24 00 00 00 00 3F 6B ,22
MAS26807-Engine start with belt-driven starter-alternator,not active ,1
MAS28749-MAS28939-DoIP ECU configuration-Node address: DoIP-only control module 1,No ecu ,16
MAS28749-MAS28939-DoIP ECU configuration-Node address: DoIP-only control module 1,MFK ,16
MAS28749-MAS28940-DoIP ECU configuration-Node address: DoIP-only control module 2,No ecu ,16
MAS28749-MAS28940-DoIP ECU configuration-Node address: DoIP-only control module 2,Umfeld-Kamera ,16
MAS28749-MAS28941-DoIP ECU configuration-Node address: DoIP-only control module 3,No ecu ,16
MAS28749-MAS28942-DoIP ECU configuration-Node address: DoIP-only control module 4,No ecu ,16
MAS28749-MAS28943-DoIP ECU configuration-Node address: DoIP-only control module 5,No ecu ,16
MAS28749-MAS28944-DoIP ECU configuration-Node address: DoIP-only control module 6,No ecu ,16
MAS28749-MAS28945-DoIP ECU configuration-Node address: DoIP-only control module 7,No ecu ,16
MAS28749-MAS28946-DoIP ECU configuration-Node address: DoIP-only control module 8,No ecu ,16
SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,installed ,3
SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,active with terminal 58 ,3
SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multi-function steering wheel control module-Variant,ACC ,3
SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,installed ,3
SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,not active ,3
SFT271921-MAS13892-Multi-function steering wheel control module-Platform,MQB2020 ,3
SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,not active ,3
SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),activated ,3
SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),automatic ,3
SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,invalid ,3
ENG253073-Diagnostic_filter_permanent_deactivation,activated ,1
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,not active ,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,0 ms,12
ENG331085-ENG280094-Egress_filter-packet_based_/_port_shaper_burst_size_configuration,Security access required You should unlock SFD before attempting advanced functions.,12
ENG331085-ENG280095-Egress_filter-packet_based_/_port_shaper_shaping_rate_configuration,Security access required You should unlock SFD before attempting advanced functions.,12
ENG331085-ENG280098-Egress_filter-port_shaper_bucket_count_select,Security access required You should unlock SFD before attempting advanced functions.,12
ENG331085-ENG280099-Egress_filter-port_shaper_enabling,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253271-ENG259280-GW_Content_list-Bus_ID,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253271-ENG253458-GW_Content_list-Node_address,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376439-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ACC_18_can-id_0x14D,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258827-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_01_can-id_0x040,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG259901-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_02_can-id_0x520,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG259106-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_03_can-id_0x041,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376486-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Airbag_04_can-id_0x545,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376503-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-AWV_03_can-id_0x0DB,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376508-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Blinkmodi_02_can-id_0x366,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258357-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-BMS_07_can-id_0x5CA,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376567-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_02_can-id_0x3F4,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376569-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DCDC_04_can-id_0x0F7,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376581-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-DiETa_01_can-id_0x353,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258444-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_01_can-id_0x1A4,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG259736-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EA_02_can-id_0x1F0,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376591-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EBKV_03_can-id_0x176,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376634-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ELV_01_can-id_0x656,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376635-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM1_01_can-id_0x0C0,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376636-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EM2_01_can-id_0x0C1,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258228-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-EPB_03_can-id_0x1F7,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376650-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_50_can-id_0x102,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376651-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_51_Auth_can-id_0x0FC,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376652-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESC_52_can-id_0x12DD5497,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258443-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_10_can-id_0x116,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258752-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_21_can-id_0x0FD,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258803-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_24_can-id_0x31B,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376653-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-ESP_30_can-id_0x1A555521,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376705-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_11_can-id_0x0AD,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376706-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Getriebe_16_can-id_0x144,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376748-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-HVK_01_can-id_0x503,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376756-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-IPA_02_can-id_0x16A9545F,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG259431-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Status_01_can-id_0x3C0,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258280-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Klemmen_Steuerung_01_can-id_0x58C,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG260883-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_01_can-id_0x32A,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG261199-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_02_can-id_0x11D,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG259434-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_03_can-id_0x09F,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376764-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LH_EPS_05_can-id_0x06E,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258969-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Licht_Anf_01_can-id_0x3D5,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG259107-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-LWI_01_can-id_0x086,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376780-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_BT_01_can-id_0x49C,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376781-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Mem_Taster_FT_01_can-id_0x492,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG260730-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_14_can-id_0x3BE,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376786-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_51_Auth_can-id_0x10B,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376787-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_54_can-id_0x14C,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376788-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_55_Auth_can-id_0x0F6,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376789-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_56_can-id_0x0BE,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376790-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_57_can-id_0x12DD54AA,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG258115-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Motor_Code_01_can-id_0x641,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376814-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PAO_Status_01_can-id_0x16A954FD,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376817-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Parken_01_can-id_0x206,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376824-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-PLA_04_can-id_0x407,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376834-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-QFK_01_Auth_can-id_0x13D,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG260760-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-RCTA_01_can-id_0x2B7,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376908-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TA_01_can-id_0x26B,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG259993-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_FT_02_can-id_0x3E5,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376959-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-TSG_HFS_02_can-id_0x341,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376988-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-VMM_02_can-id_0x139,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376354-ENG376990-IDS_critical_PDUs_list_MQBw_Baseline_UNECE-Waehlhebel_04_can-id_0x0B5,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253192-MAS01898-IDS_white_list_features-Drive train,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253192-MAS03178-IDS_white_list_features-Suspension data bus,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253192-MAS12183-IDS_white_list_features-Comfort CAN bus 2,Security access required You should unlock SFD before attempting advanced functions.,12
ENG253192-MAS16574-IDS_white_list_features-Infotainment,Security access required You should unlock SFD before attempting advanced functions.,12
ENG376363-Max_number_of_TCP-Sockets,Security access required You should unlock SFD before attempting advanced functions.,12
ENG309781-NVEM_function_variant,0 ,1
ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253268-MAS03174-TCR_bus_can-Comfort data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253268-MAS03175-TCR_bus_can-Extended data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253268-MAS03178-TCR_bus_can-Suspension data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253268-MAS16910-TCR_bus_can-Migration data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253184-MAS03180-TCR_bus_lin-Local data bus,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,Security access required You should unlock SFD before attempting advanced functions.,1
ENG253199-MAS18934-TCR_bus_vlan-VLAN Connect,Security access required You should unlock SFD before attempting advanced functions.,1
ENG376385-Traffic_Limit_on_ext_ETH-Ports,Security access required You should unlock SFD before attempting advanced functions.,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,10
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,10
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,10
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,10
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,10
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,10
ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,1800 s,10
Elapsed Time: 00:33
adpmap - 23
SW:3WA-909-059-R HW:3WA-909-059-B --- 23: Brake Booster
Component:EBB-ZF-Gen1 H06 0486, Coding:201010200040E8
EV_BrakeBoostZFMQB48W,001072,EV_BrakeBoostZFMQB48W_001.rod
Sunday,26,July,2026,16:34:49:15875
VCDS Version: 26.7.0.1 (x64) Data version: 20260708 DS378.0
VCID: 5DE69B6FDDB26ED2944-8008-R SFD+SFD2 [x]
IDE00820-ENG376444-Activating and deactivating all development messages-Activation of Development Message BKV_00,not activated ,3
IDE00820-ENG376445-Activating and deactivating all development messages-Activation of Development Message BKV_01,not activated ,3
IDE00820-ENG376446-Activating and deactivating all development messages-Activation of Development Message BKV_02,not activated ,3
IDE00820-ENG376447-Activating and deactivating all development messages-Activation of Development Message BKV_03,not activated ,3
IDE00820-ENG376448-Activating and deactivating all development messages-Activation of Development Message BKV_04,not activated ,3
IDE00820-ENG376449-Activating and deactivating all development messages-Activation of Development Message BKV_05,not activated ,3
IDE00820-ENG376450-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_1,not activated ,3
IDE00820-ENG376451-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_2,not activated ,3
IDE00820-ENG376452-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_3,not activated ,3
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE11985-Expected OBD requirements,EOBD ,1
IDE14698-Parameters of leak test-,14.00 mm,20
IDE14698-Parameters of leak test-,30.00 ,20
IDE14698-Parameters of leak test-,4 ,20
IDE14698-Parameters of leak test-,1.00 s,20
IDE14698-Parameters of leak test-,3.00 ,20
IDE14698-Parameters of leak test-,12.00 s,20
IDE14698-Parameters of leak test-,10.00 s,20
IDE14698-Parameters of leak test-,60 bar,20
IDE14698-Parameters of leak test-,6.00 mm,20
IDE14698-Parameters of leak test-,12.00 mm,20
IDE14699-Parameters of heaviness test-,12.00 mm,13
IDE14699-Parameters of heaviness test-,30.00 ,13
IDE14699-Parameters of heaviness test-,0 ,13
IDE14699-Parameters of heaviness test-,0.50 s,13
IDE14699-Parameters of heaviness test-,0.00 s,13
IDE14699-Parameters of heaviness test-,1.30 Nm,13
IDE14699-Parameters of heaviness test-,50.00 ,13
IDE14700-Parameters of ventilation routine-,511.99 mm,18
IDE14700-Parameters of ventilation routine-,511.99 ,18
IDE14700-Parameters of ventilation routine-,255 ,18
IDE14700-Parameters of ventilation routine-,25.50 s,18
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,12
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,5 ,12
IDE80125-Analysis 125-,Security access required You should unlock SFD before attempting advanced functions.,12
MAS02080-XCP calibration protocol,Security access required You should unlock SFD before attempting advanced functions.,12
MAS14035-Precondition,Security access required You should unlock SFD before attempting advanced functions.,12
ENG264022-Developer_Function_01,00 00 ,2
ENG264025-Developer_Function_04,5 ,1
ENG264029-Dynamic_Developer_Function_01,General reject,1
ENG264027-Dynamic_Developer_Function_02,General reject,1
ENG264028-Dynamic_Developer_Function_03,General reject,1
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
Elapsed Time: 00:07
adpmap - 42
SW:3WA-959-593-A HW:3WA-959-593 --- 42: Door Elect, Driver
Component:TSG FS 001 0222, Coding:003D9A20DC00008102003030
EV_DCU4DriveSideMAXHKLO,001016,EV_DCU4DriveSideMAXHBRO_VW42.rod
Sunday,26,July,2026,16:35:35:15875
VCID: 54F07E4BAE78AF9A2BA-8000-R SFD+SFD2 [x]
IDE00001-IDE17904-Production mode-Check of emergency door release,Deactivating ,3
IDE00001-IDE21198-Production mode-Suppression of door emergency release,Deactivating ,3
IDE00820-Activating and deactivating all development messages,00 00 00 00 00 00 00 00 ,8
IDE07159-MAS01155-Control module switch-off: counter-Control module,2 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,2
IDE09067-Side window shade: service mode,Deactivating ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,20
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,9 ,20
IDE16389-Front ambient Lighting configuration - light output 1,Unknown (255),1
IDE16390-Front ambient Lighting configuration - light output 2,Driver side exterior door handle lamp ,1
IDE16391-Front ambient Lighting configuration - light output 3,Mirror welcome light on driver side ,1
IDE16392-Front ambient Lighting configuration - light output 4,Exit warning lamp/side member lighting on driver side ,1
IDE17073-Operating status stand-alone mode 1,BD DB 6B 3A ,4
IDE17074-Operating status stand-alone mode 2,42 24 94 C5 ,4
MAS19336-Active participant function activated,activated ,1
ENG307653-ENG331874-Deactivation_of_component_protection-Central_locking_thermal_protection_deactivation,not active ,1
ENG307653-ENG331909-Deactivation_of_component_protection-Mirror_folding_thermal_protection_deactivation,not active ,1
ENG307653-ENG332344-Deactivation_of_component_protection-Power_latching_system_thermal_protection_deactivation,not active ,1
ENG307653-ENG332366-Deactivation_of_component_protection-Side_window_blind_thermal_protection_deactivation,not active ,1
ENG307653-ENG332407-Deactivation_of_component_protection-Window_regulator_release_clamb_15_dependence_deactivation,not active ,1
ENG307653-ENG332408-Deactivation_of_component_protection-Window_regulator_thermal_protection_deactivation,not active ,1
ENG316728-Door_handle_outside_actuation_calibration,General reject,1
ENG153885-MAS00478-Knockout_test_mode-Reserved,0 ,1
ENG344855-Masking_out_dtc,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,40
Elapsed Time: 00:08
adpmap - 44
SW:3WA-907-145-E HW:3WA-907-145 --- 44: Steering Assist
Component:BASGEN1MQB37 504 1122, Coding:00000000000000010001020101000100000001010101
EV_SteerAssisBASGEN1MQB37,017078,EV_SteerAssisBASGEN1MQB37_017.rod
Sunday,26,July,2026,16:35:58:15875
VCID: 4ACC60337C3CE96A416-801E-R SFD+SFD2 [x]
IDE03724-Straight line running,Active: with learned value ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE06678-Pull compensation,Active: without learned value ,1
IDE09571-RPM monitoring,active ,1
IDE14345-Lateral assistant coordinator: parking assist,active ,1
IDE14346-Lateral assistant coordinator: reduced stopping distance,active ,1
IDE14347-Lateral assistance coordinator: lane assist,active ,1
IDE14348-Lateral assistant coordination: counter-steering assist,active ,1
IDE15619-Maneuvering assistant lateral control coordinator,not active ,1
MAS06373-Vehicle variant,MQB_W_Baseline ,1
MAS09008-Plausibility check,active ,1
Elapsed Time: 00:06
adpmap - 52
SW:3WA-959-592-A HW:3WA-959-592 --- 52: Door Elect, Pass.
Component:TSG BFS 001 0222, Coding:003D1820DC00008102003030
EV_DCU4PasseSideMAXHKLO,001016,EV_DCU4PasseSideMAXHKLO_VW41.rod
Sunday,26,July,2026,16:36:47:15875
VCID: 53F27D57AB76A8A2320-8006-R SFD+SFD2 [x]
IDE07159-MAS01155-Control module switch-off: counter-Control module,1 ,2
Elapsed Time: 00:08
adpmap - 69
SW:5H2-907-383-D HW:5H2-907-383 --- 69: Trailer
Component:Anhaenger H12 0204, Coding:0100000202001200
EV_TrailFunctG3MPFMHella,001009,EV_TrailFunctG3MPFMHella_VW49.rod
Sunday,26,July,2026,16:39:11:15875
VCID: 313E17DFF1AABAB260C-8064-R SFD+SFD2 [x]
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 min,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,92 min,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE15064-Trailer LED forced activation,not active ,1
Elapsed Time: 00:02
adpmap - 75
SW:571-035-284-B HW:571-035-284 --- 75: Telematics
Component:OCUMQBW2023_H H07 0626, Coding:02010601000000211000010113002607101112111012111110
EV_OCUMWB2023,001066,EV_OCUMWB2023_VW42.rod
Sunday,26,July,2026,16:42:16:15875
VCID: 1576C34F650276921C4-8040-R SFD+SFD2 [x]
IDE00608-MAS00713-Fuel type-Petrol,not installed ,1
IDE00608-MAS00716-Fuel type-Diesel,installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,not installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,3000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE01718-Crash signal,10 ms ,1
IDE02330-Call number 2 for info call,+420800050252 ,15
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG252092-Vehicle function list CAN-Dash_Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,not activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,not activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,not activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior lighting,not activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multi-function display,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Air Conditioning,not activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,not activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane departure warning,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,not activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up-Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Road sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Auxiliary heating,activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,not activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,not activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,11
IDE04307-MAS07249-Vehicle function list BAP-Main beam,not activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,not activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,not activated ,11
IDE04307-MAS19459-Vehicle function list BAP-Plug and Charge Status,not activated ,11
IDE04307-MAS19762-Vehicle function list BAP-Car2X,not activated ,11
IDE04307-MAS20539-Vehicle function list BAP-BAP distance PaCo_0x55,not activated ,11
IDE04307-MAS20545-Vehicle function list BAP-BAP distance doors2_0x63,not activated ,11
IDE04307-MAS20550-Vehicle function list BAP-BAP distance infotainment_settings_0x50,not activated ,11
IDE04307-MAS20553-Vehicle function list BAP-BAP distance mirror_0x0E,not activated ,11
IDE04307-MAS20556-Vehicle function list BAP-BAP distance unit_master_0x13,not activated ,11
IDE04307-MAS22226-Vehicle function list BAP-BAP distance REM_0x5B,activated ,11
IDE04307-MAS22227-Vehicle function list BAP-BAP distance REM2_0x67,activated ,11
IDE04307-MAS22228-Vehicle function list BAP-BAP distance remote_services_0x4E,not activated ,11
IDE04307-MAS22229-Vehicle function list BAP-BAP distance info_settings_0x50_Buszuordnung,Ethernet ,11
IDE04307-MAS23125-Vehicle function list BAP-BAP distance RemonteStartOnline_0x70,not activated ,11
IDE04307-MAS26521-Vehicle function list BAP-Display configuration,not activated ,11
IDE04307-MAS26522-Vehicle function list BAP-Seat pneumatics,not activated ,11
IDE04307-MAS27766-Vehicle function list BAP-Report system for deviations,activated ,11
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,1 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,3 ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,48 ,2
IDE07699-Mobile network operator,info.m2mcubic.com ,21
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE09244-Fuel tank volume,70 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,not activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,5 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,5 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14170-Timeout for service key query,10 ,1
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Maximum private sphere in shape 2 ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic settings not detected guest: services,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with balancing of interests,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with consent,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Maximum private sphere in shape 2 ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,not activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE15407-IDE01762-BAP route control-Doors,automatic ,25
IDE15407-IDE03031-BAP route control-Seat adjustment,automatic ,25
IDE15407-IDE03111-BAP route control-Interior lighting,automatic ,25
IDE15407-MAS00688-BAP route control-Multi-function display,automatic ,25
IDE15407-MAS01118-BAP route control-Air Conditioning,automatic ,25
IDE15407-MAS01282-BAP route control-Wiper,automatic ,25
IDE15407-MAS01891-BAP route control-Lane departure warning,OFF ,25
IDE15407-MAS02444-BAP route control-Central locking,OFF ,25
IDE15407-MAS03385-BAP route control-Lane change assistance,automatic ,25
IDE15407-MAS03420-BAP route control-Head-Up-Display,automatic ,25
IDE15407-MAS03853-BAP route control-Road sign detection,OFF ,25
IDE15407-MAS05087-BAP route control-ACC,automatic ,25
IDE15407-MAS05506-BAP route control-Stopping distance reduction,OFF ,25
IDE15407-MAS07249-BAP route control-Main beam,automatic ,25
IDE15407-MAS08072-BAP route control-Driving profile selection,automatic ,25
IDE15407-MAS08785-BAP route control-Parking aid,automatic ,25
IDE15407-MAS20537-BAP route control-BAP distance Car2X_0x61,automatic ,25
IDE15407-MAS20539-BAP route control-BAP distance PaCo_0x55,automatic ,25
IDE15407-MAS20545-BAP route control-BAP distance doors2_0x63,automatic ,25
IDE15407-MAS20550-BAP route control-BAP distance infotainment_settings_0x50,automatic ,25
IDE15407-MAS20553-BAP route control-BAP distance mirror_0x0E,automatic ,25
IDE15407-MAS20556-BAP route control-BAP distance unit_master_0x13,automatic ,25
IDE15407-MAS26521-BAP route control-Display configuration,OFF ,25
IDE15407-MAS26522-BAP route control-Seat pneumatics,automatic ,25
IDE15407-ENG98891-BAP route control-Reserved,OFF ,25
IDE15695-Front radar-based localization-,activated ,1
IDE15695-ENG263520-Front radar-based localization-Front_radar_rem_data_output,activated ,1
IDE16311-MAS22303-Voice amplification for call services-Radio voice amplification: voice services,20 00 ,8
IDE16311-MAS22305-Voice amplification for call services-Emergency call speaker voice amplification: normal state,20 00 ,8
IDE16311-MAS22306-Voice amplification for call services-Emergency call speaker voice amplification: emergency battery,20 00 ,8
IDE16311-MAS22307-Voice amplification for call services-Emergency call speaker voice amplification: low temperature,20 00 ,8
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,140
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,69 ,140
IDE18871-Report system for deviations: activation status,On ,1
MAS00194----,0 min,1
MAS01078-Vehicle model,Passenger car (category M1) ,1
MAS07110-Muting of audio sources,Muting not active ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://mod3vkmsmbbreg-0.prd.eu.dp.vwg-connect.com/mbb/vehicles/v2/deviceRegistered ,89
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,89
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,MBB ,89
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Normal/Hybrid ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,2 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-Transmission interval below threshold,5 %,3
MAS13840-GNSS: data transmission rate,10 Hz ,2
MAS13841-GNSS: minimum height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Rear left door,installed ,1
MAS17427-MAS00221-Door configuration-Rear right door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17554-Digital key: backend notification,activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,OFF ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Accident,OFF ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,OFF ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,OFF ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,OFF ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,OFF ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,700 ms,1
MAS19213-Operation during severe BAP errors while storing data,Continue operation ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,installed ,1
MAS19239-Time window for key recognition,5 min,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
MAS26501-MAS26530-Background for synchronization timer-Time until background synchronization of inactive users,2 min,2
MAS26501-MAS26531-Background for synchronization timer-Time until background synchronization of the active user,21 min,2
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG113413-a2b_data_streams-reserved_01,0 ,10
ENG253242-ENG261390-a2b_data_streams-reserved_02,0 ,10
ENG253242-ENG261450-a2b_data_streams-reserved_03,0 ,10
ENG253242-ENG261451-a2b_data_streams-reserved_04,0 ,10
ENG253242-ENG261386-a2b_data_streams-Reserved_05,0 ,10
ENG253242-ENG261387-a2b_data_streams-Reserved_06,0 ,10
ENG253242-ENG261388-a2b_data_streams-Reserved_07,0 ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG376637-function_configuration_a2b_topology-Emergency_Mic_uses_I2S,false ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,Not_present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 °,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 °,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 °,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 °,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not activated ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not activated ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not activated ,1
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Direction of travel,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,activated ,1
ENG298058-Vehicle_Transport_Tracking,inactive ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:38
adpmap - 82
SW:3J1-919-608-A HW:3J1-919-608 --- 82: Head Up Display
Component:HeadupDisplay H09 2417, Coding:5700E000
EV_HUDMQBwBL,002013,EV_HUDMQBwBL_002.rod
Sunday,26,July,2026,16:43:08:15875
VCID: 303812DBFAA0B3BA6F2-8064-R SFD+SFD2 [x]
IDE03503-MAS03692-Image rotation-Key 1,6 ,9
IDE03503-MAS03693-Image rotation-Key 2,6 ,9
IDE03503-MAS03694-Image rotation-Key 3,0 ,9
IDE03503-MAS03695-Image rotation-Key 4,6 ,9
IDE03503-MAS03696-Image rotation-Key 5,-3 ,9
IDE03503-MAS03697-Image rotation-Key 6,0 ,9
IDE03503-MAS03698-Image rotation-Key 7,0 ,9
IDE03503-MAS03699-Image rotation-Key 8,0 ,9
IDE03503-MAS03700-Image rotation-Key 9,0 ,9
IDE04355-Production reference point,159 ,2
IDE09031-MAS01390-Manual warping-Block 1,00 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01391-Manual warping-Block 2,00 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01392-Manual warping-Block 3,00 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01393-Manual warping-Block 4,00 00 00 00 ,102
IDE09031-MAS01394-Manual warping-Block 5,00 00 32 00 00 32 00 00 32 00 ,102
IDE09031-MAS01395-Manual warping-Block 6,32 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01396-Manual warping-Block 7,00 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01397-Manual warping-Block 8,00 00 00 00 ,102
IDE09031-MAS01398-Manual warping-Block 9,00 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01399-Manual warping-Block 10,00 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01400-Manual warping-Block 11,00 00 00 00 00 00 00 00 00 00 ,102
IDE09031-MAS01401-Manual warping-Block 12,00 00 00 00 ,102
IDE09033-MAS01390-Correction matrix: end of line: center-Block 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01391-Correction matrix: end of line: center-Block 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01392-Correction matrix: end of line: center-Block 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01393-Correction matrix: end of line: center-Block 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01394-Correction matrix: end of line: center-Block 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01395-Correction matrix: end of line: center-Block 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01396-Correction matrix: end of line: center-Block 7,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01397-Correction matrix: end of line: center-Block 8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01398-Correction matrix: end of line: center-Block 9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01399-Correction matrix: end of line: center-Block 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01400-Correction matrix: end of line: center-Block 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01401-Correction matrix: end of line: center-Block 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01402-Correction matrix: end of line: center-Block 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01403-Correction matrix: end of line: center-Block 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01404-Correction matrix: end of line: center-Block 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01405-Correction matrix: end of line: center-Block 16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01406-Correction matrix: end of line: center-Block 17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01407-Correction matrix: end of line: center-Block 18,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09033-MAS01408-Correction matrix: end of line: center-Block 19,FF FF 00 AB CD ,761
IDE09036-MAS01390-Correction matrix: customer service: center-Block 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01391-Correction matrix: customer service: center-Block 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01392-Correction matrix: customer service: center-Block 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01393-Correction matrix: customer service: center-Block 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01394-Correction matrix: customer service: center-Block 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01395-Correction matrix: customer service: center-Block 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01396-Correction matrix: customer service: center-Block 7,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01397-Correction matrix: customer service: center-Block 8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01398-Correction matrix: customer service: center-Block 9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01399-Correction matrix: customer service: center-Block 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01400-Correction matrix: customer service: center-Block 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01401-Correction matrix: customer service: center-Block 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01402-Correction matrix: customer service: center-Block 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01403-Correction matrix: customer service: center-Block 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01404-Correction matrix: customer service: center-Block 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01405-Correction matrix: customer service: center-Block 16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01406-Correction matrix: customer service: center-Block 17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01407-Correction matrix: customer service: center-Block 18,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,761
IDE09036-MAS01408-Correction matrix: customer service: center-Block 19,FF FF 00 AB CD ,761
IDE09038-MAS04894-Active correction matrix index-Operating mode,centre ,5
IDE09038-MAS08155-Active correction matrix index-Matrix bottom,1 ,5
IDE09038-MAS08156-Active correction matrix index-Matrix center,2 ,5
IDE09038-MAS08157-Active correction matrix index-Matrix top,3 ,5
IDE09038-MAS08160-Active correction matrix index-Matrix selection: bottom,OFF ,5
IDE09038-MAS08161-Active correction matrix index-Matrix selection: center,OFF ,5
IDE09038-MAS08162-Active correction matrix index-Matrix selection: top,OFF ,5
IDE09038-MAS08163-Active correction matrix index-Memory mode,EEPROM ,5
IDE09432-MAS08882-Image shift-Horizontal shift,-128 ,2
IDE09432-MAS08883-Image shift-Vertical shift,-128 ,2
IDE16014-MAS25561-visual range adjustment-Lower view area limit,1 ,4
IDE16014-MAS25562-visual range adjustment-View area movement: motor steps,2 ,4
IDE16014-MAS25563-visual range adjustment-Upper view area limit,1 ,4
IDE16014-MAS25564-visual range adjustment-View area movement: display ratio,50 ,4
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,6
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,2 ,6
ENG344798-Configuration_of_development_CAN_messages,OFF ,1
ENG111832-ENG111804-Dimming_characteristic-Characteristic_curve_max_X1,0 ,56
ENG111832-ENG111806-Dimming_characteristic-Characteristic_curve_max_X2,132 ,56
ENG111832-ENG111808-Dimming_characteristic-Characteristic_curve_max_X3,1740 ,56
ENG111832-ENG111810-Dimming_characteristic-Characteristic_curve_max_X4,4008 ,56
ENG111832-ENG111812-Dimming_characteristic-Characteristic_curve_max_X5,12252 ,56
ENG111832-ENG136224-Dimming_characteristic-Characteristic_curve_max_X6,25008 ,56
ENG111832-ENG136226-Dimming_characteristic-Characteristic_curve_max_X7,48826 ,56
ENG111832-ENG111805-Dimming_characteristic-Characteristic_curve_max_Y1,400 ,56
ENG111832-ENG111807-Dimming_characteristic-Characteristic_curve_max_Y2,5000 ,56
ENG111832-ENG111809-Dimming_characteristic-Characteristic_curve_max_Y3,20000 ,56
ENG111832-ENG111811-Dimming_characteristic-Characteristic_curve_max_Y4,33000 ,56
ENG111832-ENG111813-Dimming_characteristic-Characteristic_curve_max_Y5,50000 ,56
ENG111832-ENG136225-Dimming_characteristic-Characteristic_curve_max_Y6,65535 ,56
ENG111832-ENG136227-Dimming_characteristic-Characteristic_curve_max_Y7,65535 ,56
ENG111832-ENG111794-Dimming_characteristic-Characteristic_curve_min_X1,0 ,56
ENG111832-ENG111796-Dimming_characteristic-Characteristic_curve_min_X2,132 ,56
ENG111832-ENG111798-Dimming_characteristic-Characteristic_curve_min_X3,1740 ,56
ENG111832-ENG111800-Dimming_characteristic-Characteristic_curve_min_X4,4008 ,56
ENG111832-ENG111802-Dimming_characteristic-Characteristic_curve_min_X5,12252 ,56
ENG111832-ENG136220-Dimming_characteristic-Characteristic_curve_min_X6,25008 ,56
ENG111832-ENG136222-Dimming_characteristic-Characteristic_curve_min_X7,48826 ,56
ENG111832-ENG111795-Dimming_characteristic-Characteristic_curve_min_Y1,40 ,56
ENG111832-ENG111797-Dimming_characteristic-Characteristic_curve_min_Y2,100 ,56
ENG111832-ENG111799-Dimming_characteristic-Characteristic_curve_min_Y3,1500 ,56
ENG111832-ENG111801-Dimming_characteristic-Characteristic_curve_min_Y4,2000 ,56
ENG111832-ENG111803-Dimming_characteristic-Characteristic_curve_min_Y5,6000 ,56
ENG111832-ENG136221-Dimming_characteristic-Characteristic_curve_min_Y6,24000 ,56
ENG111832-ENG136223-Dimming_characteristic-Characteristic_curve_min_Y7,65535 ,56
ENG111833-ENG139516-Dimming_parameters-Input_medium_customer,1 ,35
ENG111833-ENG139515-Dimming_parameters-Input_medium_customer_hud,2 ,35
ENG111833-ENG111814-Dimming_parameters-Loading_k,0 %,35
ENG111833-ENG139513-Dimming_parameters-Mapping_fotosensor,250 ,35
ENG111833-ENG139511-Dimming_parameters-Mapping_RLS,10 ,35
ENG111833-ENG139512-Dimming_parameters-Mapping_RLS_boost,2 ,35
ENG111833-ENG136244-Dimming_parameters-Max_implausible_Output_PWM,65535 ,35
ENG111833-ENG136247-Dimming_parameters-Plausibility_threshold,253 ,35
ENG111833-ENG136235-Dimming_parameters-PT1_down_Boost,100 ,35
ENG111833-ENG139510-Dimming_parameters-PT1_down_customer_wish,0 ,35
ENG111833-ENG136237-Dimming_parameters-PT1_down_Fotosensor,100 ,35
ENG111833-ENG139508-Dimming_parameters-PT1_down_HUD_HMI_brightness,0 ,35
ENG111833-ENG136231-Dimming_parameters-PT1_down_Output_PWM,2 ,35
ENG111833-ENG136229-Dimming_parameters-PT1_down_RLS,100 ,35
ENG111833-ENG136233-Dimming_parameters-PT1_switch_off,0 ,35
ENG111833-ENG136232-Dimming_parameters-PT1_switch_on,0 ,35
ENG111833-ENG136234-Dimming_parameters-PT1_up_Boost,255 ,35
ENG111833-ENG139509-Dimming_parameters-PT1_up_customer_wish,0 ,35
ENG111833-ENG136236-Dimming_parameters-PT1_up_Fotosensor,255 ,35
ENG111833-ENG139507-Dimming_parameters-PT1_up_HUD_HMI_brightness,0 ,35
ENG111833-ENG136230-Dimming_parameters-PT1_up_Output_PWM,2 ,35
ENG111833-ENG136228-Dimming_parameters-PT1_up_RLS,255 ,35
ENG111833-ENG136248-Dimming_parameters-Substitute_value_customer_brighness,23 %,35
ENG111833-ENG136243-Dimming_parameters-Substitute_value_Output_PWM,3000 ,35
ENG111833-ENG111820-Dimming_parameters-Substitute_value_s_BAP_HUD_illumination,50 %,35
ENG111833-ENG111819-Dimming_parameters-Substitute_value_s_BCM1_actuating_variable_Kl_58_s,50 %,35
ENG111833-ENG136245-Dimming_parameters-Substitute_value_s_Boost_Illumination,6126 ,35
ENG111833-ENG136242-Dimming_parameters-Substitute_value_s_RLS_illumination_FW,20 ,35
ENG111833-ENG136246-Dimming_parameters-Threshold_level,12252 ,35
ENG111833-ENG139514-Dimming_parameters-White_balance,0 ,35
ENG394999-ENG395101-DTC Configuration-ESP_24.ESP_HDC_Regelgeschw empfangener Fehlerwert,Disable ,1
ENG394999-ENG395102-DTC Configuration-Ethernet Databus missing message - TA_02,enable ,1
ENG394999-ENG395139-DTC Configuration-LoGeWa_03 keine Kommunikation,enable ,1
ENG394999-ENG395195-DTC Configuration-PSD_06 keine Kommunikation,enable ,1
ENG394999-ENG395225-DTC Configuration-Steuergerät fehlende RTP Botschaft,Disable ,1
ENG394999-ENG395226-DTC Configuration-Steuergerät keine RTP Kommunikation,Disable ,1
Elapsed Time: 00:09
adpmap - 810A
SW:3WA-907-541-J HW:95C-907-541 --- 810A: Close Rge Radar 2
Component:Nanoradar 2 H08 0138, Coding:59955A1529C405000000
EV_NR2HELLAVW38X,001112,EV_NR2HELLAVW38X_001_VW38.rod
Sunday,26,July,2026,16:47:49:15875
VCDS Version: 26.7.0.1 (x64) Data version: 20260708 DS378.0
VCID: 4FFA7127875ECC42168-801A-R SFD+SFD2 [x]
IDE00001-MAS16327-Production mode-Production mode 1,not active ,3
IDE00001-MAS16328-Production mode-Production mode 2,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,4
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,4
IDE00820-ENG376709-Activating and deactivating all development messages-Group_2_1,not activated ,4
IDE00820-ENG376710-Activating and deactivating all development messages-Group_2_2,not activated ,4
IDE02385-Object distance towards direction X,6.0 m,1
IDE03199-Dynamic calibration,not active ,1
IDE04350-Correction matrix (supplier),00 ,1
IDE05982-lane change assist. control module calibration values,10.24 °,2
IDE06218-MAS04607-Test bench data for calibration: production-Body height left front wheel house edge,703.50 mm,19
IDE06218-MAS04608-Test bench data for calibration: production-Body height right front wheel house edge,703.00 mm,19
IDE06218-MAS04609-Test bench data for calibration: production-Body height left rear wheel house edge,710.00 mm,19
IDE06218-MAS04610-Test bench data for calibration: production-Body height right rear wheel house edge,709.25 mm,19
IDE06218-MAS04611-Test bench data for calibration: production-Angle of driven axle,0 °,19
IDE06218-MAS04612-Test bench data for calibration: production-Transverse position: vehicle: front axle,0 mm,19
IDE06218-MAS04613-Test bench data for calibration: production-Transverse position: vehicle: rear axle,-2 mm,19
IDE06218-MAS04614-Test bench data for calibration: production-X-coordinate: Doppler simulator: left,1009 mm,19
IDE06218-MAS04615-Test bench data for calibration: production-Y-coordinate: Doppler simulator: left,-2235 mm,19
IDE06218-MAS04616-Test bench data for calibration: production-Z-coordinate: Doppler simulator: left,659.00 mm,19
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: active coupling ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,2
IDE13063-Short distance calibration,not active ,1
IDE13109-Short distance calibration: status,not activated ,1
IDE14104-XCP communication,not activated ,1
IDE16156-Dynamic calibration: individual progresses,15 min,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,10
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,4 ,10
IDE16782-Maximum route length of short-track calibration,70 m,1
IDE17405-MAS10959-Trustworthy time synchronization in slave performance-Identification number 1,6 ,5
IDE17405-MAS24094-Trustworthy time synchronization in slave performance-Lap time,500 ms,5
IDE17405-MAS24095-Trustworthy time synchronization in slave performance-Response time,100 ms,5
IDE18639-Calibration values,5.12 °,2
IDE80015-Analysis 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,64
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
ENG376364-PCS_ego_bounding_box_adaptation-,0 cm,8
Elapsed Time: 00:08
adpmap - 810B
SW:3WA-907-541-J HW:95C-907-541 --- 810B: Close Rge Radar 3
Component:Nanoradar 3 H08 0138, Coding:59565A1529C405000000
EV_NR3HELLAVW38X,001112,EV_NR3HELLAVW38X_001_VW38.rod
Sunday,26,July,2026,16:48:26:15875
IDE06218-MAS04614-Test bench data for calibration: production-X-coordinate: Doppler simulator: left,-5124 mm,19
IDE06218-MAS04615-Test bench data for calibration: production-Y-coordinate: Doppler simulator: left,2100 mm,19
IDE06218-MAS04616-Test bench data for calibration: production-Z-coordinate: Doppler simulator: left,701.00 mm,19
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
ENG153885-MAS00478-Knockout_test_mode-Reserved,0 ,1
Elapsed Time: 00:07
adpmap - 810C
SW:3WA-907-541-J HW:95C-907-541 --- 810C: Close Rge Radar 4
Component:Nanoradar 4 H08 0138, Coding:99696A1631C40F000000
EV_NR4HELLAVW38X,001112,EV_NR4HELLAVW38X_001_VW38.rod
Sunday,26,July,2026,16:49:06:15875
IDE06218-MAS04614-Test bench data for calibration: production-X-coordinate: Doppler simulator: left,-5128 mm,19
IDE06218-MAS04615-Test bench data for calibration: production-Y-coordinate: Doppler simulator: left,-2100 mm,19
IDE16614-Additional debug information,not activated ,1
Elapsed Time: 00:08
adpmap - 811E
SW:5WA-962-133-G HW:5WA-962-133-E --- 811E: Burglary Protection FL
Component:Kessy RSAD 122 0770, Coding:
EV_RSADVL37w,004018,EV_RSADHR37w_004_VW38.rod
Sunday,26,July,2026,16:49:42:15875
VCID: 4CC0662B7648F75A73A-8018-R
ENG253318-Par_Fahrzeugkonfiguration,255 dBµA/m,5
Elapsed Time: 00:01
adpmap - 811F
SW:5WA-962-133-G HW:5WA-962-133-E --- 811F: Burglary Protection FR
EV_RSADVR37w,004018,EV_RSADHR37w_004_VW38.rod
Sunday,26,July,2026,16:49:51:15875
Elapsed Time: 00:01
adpmap - 8107
SW:5QS-035-741-A HW:5QS-035-741 --- 8107: Antenna
Component:TrxModulHigh H04 0610, Coding:02492000010101010000010000010100000001
EV_TrxMLGEMQBWBL,001026,EV_TrxMLGEMQBWBL_VW49.rod
Sunday,26,July,2026,16:46:35:15875
VCID: 4EC46C238054C54A1DE-801A-R SFD+SFD2 [x]
IDE02122-Developer mode-,Security access required You should unlock SFD before attempting advanced functions.,3
IDE02122-ENG259763-Developer mode-dTLS_state,Security access required You should unlock SFD before attempting advanced functions.,3
IDE02122-ENG260134-Developer mode-SOK_state,Security access required You should unlock SFD before attempting advanced functions.,3
IDE07159-MAS01155-Control module switch-off: counter-Control module,4 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,1 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE09602-ENG369599-Locale hazard warning-LGW_information_stage,active ,6
IDE09602-ENG309779-Locale hazard warning-Local_hazard_warning,active ,6
IDE13966-Bluetooth: signal strength,BT Tx Power 4dBm ,1
IDE14831-IDE14832-Car2X noise level reduction-Drop during warning,not activated ,1
IDE14831-IDE14833-Car2X noise level reduction-Setback in information,not activated ,1
IDE14834-Car2X units,meter ,1
IDE14836-MAS19394-Car2X vehicle parameters-Accelerator pedal position,30 %,15
IDE14836-MAS19395-Car2X vehicle parameters-Maximum acceleration,50 m/s˛,15
IDE14836-MAS19396-Car2X vehicle parameters-Maximum brake pressure,40.0 bar,15
IDE14836-MAS19397-Car2X vehicle parameters-Maximum delay,100 m/s˛,15
IDE14836-MAS19399-Car2X vehicle parameters-Vehicle length,492 cm,15
IDE14836-MAS19400-Car2X vehicle parameters-Vehicle width,185 cm,15
IDE14836-MAS19446-Car2X vehicle parameters-Reference distance,380 cm,15
IDE14836-ENG260979-Car2X vehicle parameters-Vehicle_LongitudinalAxis_ReferencePoint,0 cm,15
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,32
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,15 ,32
IDE17073-Operating status stand-alone mode 1,00 00 00 01 ,4
IDE17074-Operating status stand-alone mode 2,00 00 00 01 ,4
MAS18420-MAS18439-Performance compensation: WLAN 5 GHz main antenna-Transmitting power,21 dBm,4
MAS18420-MAS23865-Performance compensation: WLAN 5 GHz main antenna-Cable attenuation,0 dBm,4
MAS18423-MAS18439-Performance compensation: WLAN 5 GHz auxiliary antenna-Transmitting power,19 dBm,4
MAS18423-MAS23865-Performance compensation: WLAN 5 GHz auxiliary antenna-Cable attenuation,10 dBm,4
MAS19391-MAS19419-Car2X detection functions-EASS Detection,activated ,2
MAS19391-MAS19420-Car2X detection functions-Bad weather detection,not activated ,2
MAS19391-MAS19421-Car2X detection functions-Traction loss detection,not activated ,2
MAS19391-MAS19422-Car2X detection functions-Stopper detection,activated ,2
MAS19391-MAS19423-Car2X detection functions-Breakdown detection,activated ,2
MAS19391-MAS19424-Car2X detection functions-Crash detection,activated ,2
MAS19391-MAS19425-Car2X detection functions-Traffic jam detection,activated ,2
MAS19391-MAS19426-Car2X detection functions-End of tailback detection,activated ,2
MAS19391-MAS19427-Car2X detection functions-SEF detection emergency drive,not activated ,2
MAS19391-MAS19428-Car2X detection functions-Detection SEF protection hazardous area,not activated ,2
MAS19392-MAS19429-Car2X Interpretation-EASS interpretation,activated ,2
MAS19392-MAS19430-Car2X Interpretation-Breakdown interpretation,activated ,2
MAS19392-MAS19431-Car2X Interpretation-Standing vehicle interpretation,activated ,2
MAS19392-MAS19432-Car2X Interpretation-Stationary SEF interpretation,activated ,2
MAS19392-MAS19433-Car2X Interpretation-Construction site interpretation,activated ,2
MAS19392-MAS19434-Car2X Interpretation-Crash interpretation,activated ,2
MAS19392-MAS19435-Car2X Interpretation-End of tailback interpretation,activated ,2
MAS19392-MAS19436-Car2X Interpretation-Obstructed view interpretation,not activated ,2
MAS19392-MAS19437-Car2X Interpretation-Interpretation,not activated ,2
MAS19392-MAS19438-Car2X Interpretation-Interpretation of generic point event,not activated ,2
MAS19392-MAS19439-Car2X Interpretation-Interpretation of generic SEF,not activated ,2
MAS19392-MAS19440-Car2X Interpretation-Dynamic SEF interpretation,activated ,2
MAS19392-MAS19441-Car2X Interpretation-Basic service,activated ,2
MAS19393-IDE14830-Car2X display-Function display,activated ,14
MAS19393-ENG395065-Car2X display-Breakdown_Activation_state,activated ,14
MAS19393-ENG395066-Car2X display-Breakdown_Information_hazard_level,activated ,14
MAS19393-ENG395067-Car2X display-Breakdown_Information_tone,activated ,14
MAS19393-ENG395068-Car2X display-Breakdown_Warning_hazard_level,not activated ,14
MAS19393-ENG395069-Car2X display-Breakdown_Warning_tone,not activated ,14
MAS19393-ENG395073-Car2X display-Crash_Activation_state,activated ,14
MAS19393-ENG395074-Car2X display-Crash_Information_hazard_level,activated ,14
MAS19393-ENG395075-Car2X display-Crash_Information_tone,activated ,14
MAS19393-ENG395076-Car2X display-Crash_Warning_hazard_level,activated ,14
MAS19393-ENG395077-Car2X display-Crash_Warning_tone,activated ,14
MAS19393-ENG395079-Car2X display-Dangerous_End_Of_Queue_Activation_State,activated ,14
MAS19393-ENG395080-Car2X display-Dangerous_End_Of_Queue_Information_Hazard_Level,activated ,14
MAS19393-ENG395081-Car2X display-Dangerous_End_Of_Queue_Information_Tone,activated ,14
MAS19393-ENG395082-Car2X display-Dangerous_End_Of_Queue_Warning_Hazard_Level,activated ,14
MAS19393-ENG395083-Car2X display-Dangerous_End_Of_Queue_Warning_Tone,activated ,14
MAS19393-ENG395086-Car2X display-Dynamic_Emergency_Vehicle_Activation_state,activated ,14
MAS19393-ENG395087-Car2X display-Dynamic_Emergency_Vehicle_Information_hazard_level,activated ,14
MAS19393-ENG395088-Car2X display-Dynamic_Emergency_Vehicle_Information_tone,activated ,14
MAS19393-ENG395089-Car2X display-Dynamic_Emergency_Vehicle_Warning_hazard_level,activated ,14
MAS19393-ENG395090-Car2X display-Dynamic_Emergency_Vehicle_Warning_tone,activated ,14
MAS19393-ENG395091-Car2X display-EASS_Activation_state,activated ,14
MAS19393-ENG395092-Car2X display-EASS_Information_hazard_level,not activated ,14
MAS19393-ENG395093-Car2X display-EASS_Information_tone,activated ,14
MAS19393-ENG395094-Car2X display-EASS_Warning_hazard_level,activated ,14
MAS19393-ENG395095-Car2X display-EASS_Warning_tone,activated ,14
MAS19393-ENG395112-Car2X display-Generic_emergency_vehicle_Activation_state,activated ,14
MAS19393-ENG395113-Car2X display-Generic_emergency_vehicle_Information_hazard_level,activated ,14
MAS19393-ENG395114-Car2X display-Generic_emergency_vehicle_Information_tone,activated ,14
MAS19393-ENG395115-Car2X display-Generic_emergency_vehicle_Warning_hazard_level,activated ,14
MAS19393-ENG395116-Car2X display-Generic_emergency_vehicle_Warning_tone,activated ,14
MAS19393-ENG395117-Car2X display-Generic_Punctual_Event_Activation_state,not activated ,14
MAS19393-ENG395118-Car2X display-Generic_Punctual_Event_Information_hazard_level,not activated ,14
MAS19393-ENG395119-Car2X display-Generic_Punctual_Event_Information_tone,not activated ,14
MAS19393-ENG395120-Car2X display-Generic_Punctual_Event_Warning_hazard_level,not activated ,14
MAS19393-ENG395121-Car2X display-Generic_Punctual_Event_Warning_tone,not activated ,14
MAS19393-ENG395140-Car2X display-Loss_of_Traction_Activation_state,activated ,14
MAS19393-ENG395141-Car2X display-Loss_of_Traction_Information_hazard_level,activated ,14
MAS19393-ENG395142-Car2X display-Loss_of_Traction_Information_tone,activated ,14
MAS19393-ENG395143-Car2X display-Loss_of_Traction_Warning_hazard_level,not activated ,14
MAS19393-ENG395144-Car2X display-Loss_of_Traction_Warning_tone,not activated ,14
MAS19393-ENG395188-Car2X display-Poor_Visibility_Activation_state,activated ,14
MAS19393-ENG395189-Car2X display-Poor_Visibility_Information_hazard_level,activated ,14
MAS19393-ENG395190-Car2X display-Poor_Visibility_Information_tone,activated ,14
MAS19393-ENG395191-Car2X display-Poor_Visibility_Warning_hazard_level,not activated ,14
MAS19393-ENG395192-Car2X display-Poor_Visibility_Warning_tone,not activated ,14
MAS19393-ENG395198-Car2X display-Roadworks_Activation_state,activated ,14
MAS19393-ENG395199-Car2X display-Roadworks_Information_hazard_level,activated ,14
MAS19393-ENG395200-Car2X display-Roadworks_Information_tone,activated ,14
MAS19393-ENG395201-Car2X display-Roadworks_Warning_hazard_level,not activated ,14
MAS19393-ENG395202-Car2X display-Roadworks_Warning_tone,not activated ,14
MAS19393-ENG395215-Car2X display-Stationary_Emergency_Vehicle_Activation_state,activated ,14
MAS19393-ENG395216-Car2X display-Stationary_Emergency_Vehicle_Information_hazard_level,activated ,14
MAS19393-ENG395217-Car2X display-Stationary_Emergency_Vehicle_Information_tone,activated ,14
MAS19393-ENG395218-Car2X display-Stationary_Emergency_Vehicle_Warning_hazard_level,activated ,14
MAS19393-ENG395219-Car2X display-Stationary_Emergency_Vehicle_Warning_tone,activated ,14
MAS19393-ENG395220-Car2X display-Stationary_Vehicle_Activation_state,activated ,14
MAS19393-ENG395221-Car2X display-Stationary_Vehicle_Information_hazard_level,activated ,14
MAS19393-ENG395222-Car2X display-Stationary_Vehicle_Information_tone,activated ,14
MAS19393-ENG395223-Car2X display-Stationary_Vehicle_Warning_hazard_level,not activated ,14
MAS19393-ENG395224-Car2X display-Stationary_Vehicle_Warning_tone,not activated ,14
ENG369151-Logging_mode-,Security access required You should unlock SFD before attempting advanced functions.,1
ENG369151-ENG155276-Logging_mode-Logging GwSm Error,Security access required You should unlock SFD before attempting advanced functions.,1
ENG369151-ENG155277-Logging_mode-Logging GwSm Status,Security access required You should unlock SFD before attempting advanced functions.,1
Elapsed Time: 00:09
adpmap - 8109
SW:3WA-907-541-J HW:95C-907-541 --- 8109: Close Rge Radar 1
Component:Nanoradar 1 H08 0138, Coding:59955A1529C405000000
EV_NR1HELLAVW38X,001112,EV_NR1HELLAVW38X_001_VW38.rod
Sunday,26,July,2026,16:47:13:15875
IDE06218-MAS04614-Test bench data for calibration: production-X-coordinate: Doppler simulator: left,1000 mm,19
IDE06218-MAS04615-Test bench data for calibration: production-Y-coordinate: Doppler simulator: left,2218 mm,19
IDE06218-MAS04616-Test bench data for calibration: production-Z-coordinate: Doppler simulator: left,639.00 mm,19
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE17405-MAS10959-Trustworthy time synchronization in slave performance-Identification number 1,5 ,5
Elapsed Time: 00:08
adpmap - 8117
SW:5R3-980-568-F HW:1EA-980-568-B --- 8117: Rear surroundings cam
Component:RV eSmart H20 0445, Coding:0203800027152080
EV_AVCamerRearFicosBL,004029,EV_AVCamerRearFicosBL_004_VW49.rod
Sunday,26,July,2026,16:49:30:15875
VCID: 44D04E0B5E183F1ABBA-8010-R SFD+SFD2 [x]
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,71 00 ,8
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,3 ,8
ENG153885-Knockout_test_mode,0 ,1
Uplynulý čas: 00:04
adpmap - 8120
SW:5WA-962-133-G HW:5WA-962-133-E --- 8120: Burglary Protection RL
EV_RSADHL37w,004018,EV_RSADHL37w_004_VW38.rod
Sunday,26,July,2026,16:49:59:15875
Elapsed Time: 00:01
adpmap - 8121
SW:5WA-962-133-G HW:5WA-962-133-E --- 8121: Burglary Protection RR
EV_RSADHR37w,004018,EV_RSADHR37w_004_VW38.rod
Sunday,26,July,2026,16:50:08:15875
Elapsed Time: 00:01
adpmap - A5
SW:3WA-907-217-C HW:3WA-907-217 --- A5: Frt Sens. Drv. Assist
Component:MFK120 H18 1423, Coding:0005000000000000000000BAF940C00400000000806580000000FC00000038FE43F040004000000000800000000000000000000000000000000000000000000000000000
EV_MFK120MAGNAMQBWB,001024,EV_MFK120MAGNAMQBWB_001.rod
Sunday,26,July,2026,16:43:56:15875
VCID: 48C85A3B62301B7A572-801C-R SFD+SFD2 [x]
IDE02514-MAS21664-Camera heater-Activation time for camera heater due to image processing,5730 s,4
IDE02514-MAS21665-Camera heater-Total activation time for camera heater,202020 s,4
IDE04733-Road sign detection fusion mode-,00 ,2
IDE04733-Road sign detection fusion mode-,Road sign fusion ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE13160-MAS08824-Front camera: target position (static calibration)-Target 1: calibration mark 1: x-coordinate,0.00 mm,24
IDE13160-MAS08825-Front camera: target position (static calibration)-Target 1: calibration mark 1: y-coordinate,0.00 mm,24
IDE13160-MAS08826-Front camera: target position (static calibration)-Target 1: calibration mark 1: z-coordinate,0.00 mm,24
IDE13160-MAS08827-Front camera: target position (static calibration)-Target 1: calibration mark 2: x-coordinate,0.00 mm,24
IDE13160-MAS08828-Front camera: target position (static calibration)-Target 1: calibration mark 2: y-coordinate,0.00 mm,24
IDE13160-MAS08829-Front camera: target position (static calibration)-Target 1: calibration mark 2: z-coordinate,0.00 mm,24
IDE13160-MAS08830-Front camera: target position (static calibration)-Target 1: calibration mark 3: x-coordinate,0.00 mm,24
IDE13160-MAS08831-Front camera: target position (static calibration)-Target 1: calibration mark 3: y-coordinate,0.00 mm,24
IDE13160-MAS08832-Front camera: target position (static calibration)-Target 1: calibration mark 3: z-coordinate,0.00 mm,24
IDE13160-MAS08833-Front camera: target position (static calibration)-Target 1: calibration mark 4: x-coordinate,0.00 mm,24
IDE13160-MAS08834-Front camera: target position (static calibration)-Target 1: calibration mark 4: y-coordinate,0.00 mm,24
IDE13160-MAS08835-Front camera: target position (static calibration)-Target 1: calibration mark 4: z-coordinate,0.00 mm,24
IDE13162-MAS06929-Front camera: vehicle position (static calibration)-Axle offset front,0.00 mm,4
IDE13162-MAS06930-Front camera: vehicle position (static calibration)-Axle offset rear,0.00 mm,4
IDE13163-MAS15924-Front camera: bodywork height (static calibration)-Wheel house edge front left,0.00 mm,8
IDE13163-MAS15925-Front camera: bodywork height (static calibration)-Wheel house edge front right,0.00 mm,8
IDE13163-MAS15926-Front camera: bodywork height (static calibration)-Wheel house edge rear left,0.00 mm,8
IDE13163-MAS15927-Front camera: bodywork height (static calibration)-Wheel house edge rear right,0.00 mm,8
IDE13872-MAS21335-Manual calibration-Manual calibration: pitch angle,-0.980 °,6
IDE13872-MAS21336-Manual calibration-Manual calibration: yaw angle,-0.000 °,6
IDE13872-MAS21337-Manual calibration-Manual calibration: roll angle,-0.35 °,6
IDE13872-MAS21338-Manual calibration-Manual calibration: camera height,1321 mm,6
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,24
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,11 ,24
IDE16782-Maximum route length of short-track calibration,0 m,1
IDE18352-MAS00478-Control module shut-off: test configuration-Reserved,0 ,1
IDE18352-MAS21993-Control module shut-off: test configuration-Return value idle bus,not active ,1
IDE18352-MAS21994-Control module shut-off: test configuration-Veto,not active ,1
IDE18352-MAS21995-Control module shut-off: test configuration-Suppress veto,not active ,1
MAS22521-Maximum net duration of the service calibration,0 min,1
ENG376268-ENG130919-Activation of Development Messages VZE-Activation_of_development_messages_EHR,not active ,1
ENG376268-ENG185761-Activation of Development Messages VZE-Activation_of_development_messages_TSF,not_active ,1
ENG376268-ENG185762-Activation of Development Messages VZE-Activation_of_development_messages_VZF_TSR1,not_active ,1
ENG344762-Activation_of_development_messages_HCA,HCA_development_message_deactivated ,1
ENG278486-Activation_of_development_messages_TPA,not active ,1
ENG344781-ENG345960-Adaption_status_signals-STS System Components Fault Counter,0 ,6
ENG344781-ENG345973-Adaption_status_signals-STS_Fault_Counter_Aurix,0 ,6
ENG344781-ENG345974-Adaption_status_signals-STS_Fault_Counter_IP,0 ,6
ENG344784-AHC_persistent_data-0x100C,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B9 00 00 00 4F 04 00 00 62 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B9 00 00 00 F1 03 00 00 62 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3202
ENG344792-ENG345730-Cam_Init_Layout - 0x1006-INIT_Cam_CODX,96 76 F1 E0 14 29 8E 40 ,190
ENG344792-ENG345731-Cam_Init_Layout - 0x1006-INIT_Cam_CODY,8E D7 E3 AA F5 81 76 40 ,190
ENG344792-ENG345732-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_0,CC 66 91 BF 9C 4C 46 BF ,190
ENG344792-ENG345733-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_1,19 09 A9 F3 B6 67 43 BF ,190
ENG344792-ENG345734-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_10,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345735-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_11,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345736-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_12,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345737-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_13,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345738-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_14,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345739-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_15,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345740-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_2,C5 3B A3 AE 28 FF 48 3F ,190
ENG344792-ENG345741-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_3,86 75 17 B7 FD F7 4D BF ,190
ENG344792-ENG345742-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_4,D8 07 05 45 48 5B 4E 3F ,190
ENG344792-ENG345743-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_5,60 38 67 88 88 A6 4C BF ,190
ENG344792-ENG345744-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_6,00 00 00 00 00 00 F0 3F ,190
ENG344792-ENG345745-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_7,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345746-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_8,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345747-Cam_Init_Layout - 0x1006-INIT_Cam_distor_Params_9,00 00 00 00 00 00 00 00 ,190
ENG344792-ENG345748-Cam_Init_Layout - 0x1006-INIT_Cam_distortion_Model_Type,3 ,190
ENG344792-ENG345749-Cam_Init_Layout - 0x1006-INIT_Cam_Focal_Length_X,E5 3A 9C B0 77 00 93 40 ,190
ENG344792-ENG345750-Cam_Init_Layout - 0x1006-INIT_Cam_Focal_Length_Y,E5 3A 9C B0 77 00 93 40 ,190
ENG344792-ENG345751-Cam_Init_Layout - 0x1006-INIT_Cam_Principal_Point_X,96 76 F1 E0 14 29 8E 40 ,190
ENG344792-ENG345752-Cam_Init_Layout - 0x1006-INIT_Cam_Principal_Point_Y,8E D7 E3 AA F5 81 76 40 ,190
ENG344792-ENG345753-Cam_Init_Layout - 0x1006-INIT_Cam_Skew,00 00 00 00 00 00 00 00 ,190
ENG98484-Coding,00 05 00 00 00 00 00 00 00 00 00 BA F9 40 C0 04 00 00 00 00 80 65 80 00 00 00 FC 00 00 00 38 FE 43 F0 40 00 40 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,68
ENG344799-Country_Code_Setting,0 ,2
ENG344804-ENG345680-Dlt_loglevel-global_loglevel,OFF ,32
ENG344804-ENG345763-Dlt_loglevel-loglevel_Active_Headlamp_Calibration,OFF ,32
ENG344804-ENG345764-Dlt_loglevel-loglevel_cal,ERROR ,32
ENG344804-ENG387613-Dlt_loglevel-loglevel_Combined_Local_Time,OFF ,32
ENG344804-ENG387614-Dlt_loglevel-loglevel_Customer_Function_Bridge,OFF ,32
ENG344804-ENG345767-Dlt_loglevel-loglevel_Degradation,ERROR ,32
ENG344804-ENG387616-Dlt_loglevel-loglevel_EyeQ_Fault_Manager,OFF ,32
ENG344804-ENG345769-Dlt_loglevel-loglevel_fan,ERROR ,32
ENG344804-ENG345770-Dlt_loglevel-loglevel_heater,ERROR ,32
ENG344804-ENG345771-Dlt_loglevel-loglevel_MCU_Error_Manager,ERROR ,32
ENG344804-ENG410013-Dlt_loglevel-loglevel_reserved_15,OFF ,32
ENG344804-ENG345772-Dlt_loglevel-loglevel_reserved_16,OFF ,32
ENG344804-ENG345773-Dlt_loglevel-loglevel_reserved_17,OFF ,32
ENG344804-ENG345774-Dlt_loglevel-loglevel_reserved_18,OFF ,32
ENG344804-ENG345775-Dlt_loglevel-loglevel_reserved_19,OFF ,32
ENG344804-ENG345776-Dlt_loglevel-loglevel_reserved_20,OFF ,32
ENG344804-ENG345777-Dlt_loglevel-loglevel_reserved_21,OFF ,32
ENG344804-ENG345778-Dlt_loglevel-loglevel_reserved_22,OFF ,32
ENG344804-ENG345779-Dlt_loglevel-loglevel_reserved_23,OFF ,32
ENG344804-ENG345780-Dlt_loglevel-loglevel_reserved_24,OFF ,32
ENG344804-ENG345781-Dlt_loglevel-loglevel_reserved_25,OFF ,32
ENG344804-ENG345782-Dlt_loglevel-loglevel_reserved_26,OFF ,32
ENG344804-ENG345783-Dlt_loglevel-loglevel_reserved_27,OFF ,32
ENG344804-ENG345784-Dlt_loglevel-loglevel_reserved_28,OFF ,32
ENG344804-ENG345785-Dlt_loglevel-loglevel_reserved_29,OFF ,32
ENG344804-ENG345786-Dlt_loglevel-loglevel_reserved_30,OFF ,32
ENG344804-ENG345787-Dlt_loglevel-loglevel_reserved_31,OFF ,32
ENG344804-ENG345788-Dlt_loglevel-loglevel_reserved_32,OFF ,32
ENG344804-ENG345789-Dlt_loglevel-loglevel_reserved_33,OFF ,32
ENG344804-ENG345790-Dlt_loglevel-loglevel_reserved_34,OFF ,32
ENG344804-ENG345791-Dlt_loglevel-loglevel_reserved_35,OFF ,32
ENG344804-ENG345792-Dlt_loglevel-loglevel_reserved_36,OFF ,32
ENG344804-ENG345793-Dlt_loglevel-loglevel_reserved_37,OFF ,32
ENG344804-ENG345794-Dlt_loglevel-loglevel_reserved_38,OFF ,32
ENG344804-ENG345795-Dlt_loglevel-loglevel_reserved_39,OFF ,32
ENG344804-ENG345796-Dlt_loglevel-loglevel_reserved_40,OFF ,32
ENG344804-ENG345797-Dlt_loglevel-loglevel_reserved_41,OFF ,32
ENG344804-ENG345798-Dlt_loglevel-loglevel_reserved_42,OFF ,32
ENG344804-ENG345799-Dlt_loglevel-loglevel_reserved_43,OFF ,32
ENG344804-ENG345800-Dlt_loglevel-loglevel_reserved_44,OFF ,32
ENG344804-ENG345801-Dlt_loglevel-loglevel_reserved_45,OFF ,32
ENG344804-ENG345802-Dlt_loglevel-loglevel_reserved_46,OFF ,32
ENG344804-ENG345803-Dlt_loglevel-loglevel_reserved_47,OFF ,32
ENG344804-ENG345804-Dlt_loglevel-loglevel_reserved_48,OFF ,32
ENG344804-ENG345805-Dlt_loglevel-loglevel_reserved_49,OFF ,32
ENG344804-ENG345806-Dlt_loglevel-loglevel_reserved_50,OFF ,32
ENG344804-ENG345807-Dlt_loglevel-loglevel_reserved_51,OFF ,32
ENG344804-ENG345808-Dlt_loglevel-loglevel_reserved_52,OFF ,32
ENG344804-ENG345809-Dlt_loglevel-loglevel_reserved_53,OFF ,32
ENG344804-ENG345810-Dlt_loglevel-loglevel_reserved_54,OFF ,32
ENG344804-ENG345811-Dlt_loglevel-loglevel_reserved_55,OFF ,32
ENG344804-ENG345812-Dlt_loglevel-loglevel_reserved_56,OFF ,32
ENG344804-ENG345813-Dlt_loglevel-loglevel_reserved_57,OFF ,32
ENG344804-ENG345814-Dlt_loglevel-loglevel_reserved_58,OFF ,32
ENG344804-ENG345815-Dlt_loglevel-loglevel_reserved_59,OFF ,32
ENG344804-ENG345816-Dlt_loglevel-loglevel_reserved_60,OFF ,32
ENG344804-ENG345817-Dlt_loglevel-loglevel_reserved_61,OFF ,32
ENG344804-ENG345818-Dlt_loglevel-loglevel_reserved_62,OFF ,32
ENG344804-ENG345819-Dlt_loglevel-loglevel_reserved_63,OFF ,32
ENG344804-ENG345820-Dlt_loglevel-loglevel_Safe_State_Manager,ERROR ,32
ENG344804-ENG345822-Dlt_loglevel-loglevel_ssm,ERROR ,32
ENG344804-ENG345823-Dlt_loglevel-loglevel_Time_Sychronization,OFF ,32
ENG344804-ENG345824-Dlt_loglevel-loglevel_Trustworthy_Local_Time,OFF ,32
ENG344804-ENG345825-Dlt_loglevel-loglevel_Watchdog,ERROR ,32
ENG344814-DMC_of_the_imager_0x101C,2402000209571 ,13
ENG344816-Dtc_deactivation_bitmask,General reject,13
ENG344824-ENG345696-Envir_Init_Layout - 0x1007-IEnvironment_Bottom_Crop,00 05 ,28
ENG344824-ENG345697-Envir_Init_Layout - 0x1007-IEnvironment_Cam_To_Front_Axle,01 86 ,28
ENG344824-ENG345698-Envir_Init_Layout - 0x1007-IEnvironment_Cam_To_Rear_Axle,00 72 ,28
ENG344824-ENG345699-Envir_Init_Layout - 0x1007-IEnvironment_LeftWheel,00 5D ,28
ENG344824-ENG345700-Envir_Init_Layout - 0x1007-IEnvironment_MaxHorizon,01 2C ,28
ENG344824-ENG345701-Envir_Init_Layout - 0x1007-IEnvironment_MaxRoll,01 65 ,28
ENG344824-ENG345702-Envir_Init_Layout - 0x1007-IEnvironment_MaxYaw,00 3F ,28
ENG344824-ENG345703-Envir_Init_Layout - 0x1007-IEnvironment_MinHorizon,00 50 ,28
ENG344824-ENG345704-Envir_Init_Layout - 0x1007-IEnvironment_MinYaw,00 25 ,28
ENG344824-ENG345705-Envir_Init_Layout - 0x1007-IEnvironment_RefPX_Front_Bumper,00 C8 ,28
ENG344824-ENG345706-Envir_Init_Layout - 0x1007-IEnvironment_RightWheel,00 5D ,28
ENG344824-ENG345707-Envir_Init_Layout - 0x1007-IEnvironment_Top_Crop,00 87 ,28
ENG344824-ENG345708-Envir_Init_Layout - 0x1007-IEnvironment_Wheel_Radius,23 ,28
ENG344824-ENG345709-Envir_Init_Layout - 0x1007-IEnvironment_Wheel_Width,26 ,28
ENG344827-EyeQSPIDataTestSimulation - 0x1004,0x1 - Activate EyeQ ,1
ENG376350-ENG345883-Fan min CarSpeed-p_FAN_min_CarSpeed,34 km/h,2
ENG376350-ENG345884-Fan min CarSpeed-p_FAN_min_CarSpeed_L1_state,activated ,2
ENG376350-ENG345885-Fan min CarSpeed-p_FAN_min_CarSpeed_L2_state,activated ,2
ENG344828-ENG345859-Fan speed level 1-p_FAN_fan_speed_L1,3900 ,3
ENG344828-ENG345860-Fan speed level 1-p_FAN_fan_speed_L1_state,activated ,3
ENG344828-ENG345871-Fan speed level 1-p_FAN_L1_temp1,53 ,3
ENG344828-ENG345872-Fan speed level 1-p_FAN_L1_temp2,70 ,3
ENG344829-ENG345861-Fan speed level 2-p_FAN_fan_speed_L2,4200 ,3
ENG344829-ENG345862-Fan speed level 2-p_FAN_fan_speed_L2_state,activated ,3
ENG344829-ENG345873-Fan speed level 2-p_FAN_L2_temp1,63 ,3
ENG344829-ENG345874-Fan speed level 2-p_FAN_L2_temp2,80 ,3
ENG344830-ENG345863-Fan speed level 3-p_FAN_fan_speed_L3,4500 ,11
ENG344830-ENG345864-Fan speed level 3-p_FAN_fan_speed_L3_AC,5000 ,11
ENG344830-ENG345865-Fan speed level 3-p_FAN_fan_speed_L3_Car_Speed_1,5000 ,11
ENG344830-ENG345866-Fan speed level 3-p_FAN_fan_speed_L3_Car_Speed_2,5500 ,11
ENG344830-ENG345867-Fan speed level 3-p_FAN_fan_speed_L3_Window_Car_Speed_1,5500 ,11
ENG344830-ENG345868-Fan speed level 3-p_FAN_fan_speed_L3_Window_Car_Speed_2,6000 ,11
ENG344830-ENG345875-Fan speed level 3-p_FAN_L3_AC,6 ,11
ENG344830-ENG345876-Fan speed level 3-p_FAN_L3_Car_Speed_1,5 km/h,11
ENG344830-ENG345877-Fan speed level 3-p_FAN_L3_Car_Speed_2,50 ,11
ENG344830-ENG345878-Fan speed level 3-p_FAN_L3_temp1,73 ,11
ENG344830-ENG345879-Fan speed level 3-p_FAN_L3_temp2,90 ,11
ENG344830-ENG345880-Fan speed level 3-p_FAN_L3_Window,10 %,11
ENG344831-ENG345869-Fan speed level 4-p_FAN_fan_speed_L4,7000 ,3
ENG344831-ENG345881-Fan speed level 4-p_FAN_L4_temp1,120 ,3
ENG344831-ENG345882-Fan speed level 4-p_FAN_L4_temp2,120 ,3
ENG344832-ENG345870-Fan speed level limitation - Phone-p_FAN_fan_speed_limit_phone,3900 ,1
ENG344832-ENG345886-Fan speed level limitation - Phone-p_FAN_phone_limit_state,activated ,1
ENG344841-ENG345619-General Layout - 0x1008-Data Collection Mode,00000000 ,12
ENG344841-ENG345710-General Layout - 0x1008-IGeneral_Cam_Height_Full,00 82 ,12
ENG344841-ENG345711-General Layout - 0x1008-IGeneral_CLB_DYN_AF_Pitch_V,00000000 ,12
ENG344841-ENG345712-General Layout - 0x1008-IGeneral_CLB_DYN_AF_Roll_V,00000000 ,12
ENG344841-ENG345713-General Layout - 0x1008-IGeneral_CLB_DYN_AF_Yaw_V,00000000 ,12
ENG344841-ENG345714-General Layout - 0x1008-IGeneral_Driving_Side,Unknown ,12
ENG344841-ENG345715-General Layout - 0x1008-IGeneral_HIL_Mode,SET_OFF ,12
ENG344841-ENG345716-General Layout - 0x1008-IGeneral_Roll_Angle_Base_V,00000001 ,12
ENG185780-HCA_Development_1,00 00 00 00 ,4
ENG185781-HCA_Development_2,00 00 00 00 ,4
ENG344842-HCA_persistent_data-0x100A,00 14 35 35 00 00 00 00 00 0D 00 00 00 02 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,256
ENG408619-HCA_PSD_support_mode,General reject,256
ENG159831-MAS01155-Knockout_counter-Control module,0 ,2
ENG159831-MAS05583-Knockout_counter-Data bus,0 ,2
ENG387332-ENG387617-Magna Production Mode - 0x103C-Magna Production mode,Disable ,6
ENG387332-ENG395163-Magna Production Mode - 0x103C-p_JTAG,locked ,6
ENG387332-ENG395164-Magna Production Mode - 0x103C-p_OTP_Status,protected ,6
ENG387332-ENG395165-Magna Production Mode - 0x103C-p_Pflash,locked ,6
ENG387332-ENG395166-Magna Production Mode - 0x103C-p_SKM,cleared ,6
ENG344866-ENG345289-Reset Increment Counter - 0x1027-Aurix_Reset_Counter (MCU_Resets),1 ,14
ENG344866-ENG345623-Reset Increment Counter - 0x1027-Diagnostic_Reset_Counter (Diagnostics_ECU_reset),5 ,14
ENG344866-ENG345670-Reset Increment Counter - 0x1027-EyeQ_Reset_Counter_(Diagnostic_EQ_Healing_Reset),3 ,14
ENG344866-ENG345911-Reset Increment Counter - 0x1027-POR_Counter (Clamp_Cycle),5896 ,14
ENG344866-ENG345924-Reset Increment Counter - 0x1027-Reserved0,0 ,14
ENG344866-ENG345933-Reset Increment Counter - 0x1027-SBC_Error_Counter (other_SBC_Resets),0 ,14
ENG344866-ENG346099-Reset Increment Counter - 0x1027-Watchdog_Reset_Counter (SBC_Watchdog),0 ,14
ENG344868-ENG345925-Road Model INIT - 0x1011-Road_Model_Distance_Range,5.00 ,4
ENG344868-ENG345926-Road Model INIT - 0x1011-Road_Model_Number_Of_Points,10 ,4
ENG344868-ENG345927-Road Model INIT - 0x1011-Road_Model_Path_type,Lane Center ,4
ENG344868-ENG345928-Road Model INIT - 0x1011-Road_Model_Time_Range,2.30 ,4
ENG344879-ENG345673-STS_Adaption_status_signals-FRC_simulation,Disabled ,2
ENG344879-ENG345961-STS_Adaption_status_signals-STS_Degradation_BHE,Enabled ,2
ENG344879-ENG345962-STS_Adaption_status_signals-STS_Degradation_CAL,Enabled ,2
ENG344879-ENG345963-STS_Adaption_status_signals-STS_Degradation_ECR,Enabled ,2
ENG344879-ENG345965-STS_Adaption_status_signals-STS_Degradation_LDA,Enabled ,2
ENG344879-ENG345966-STS_Adaption_status_signals-STS_Degradation_MOD,Enabled ,2
ENG344879-ENG345968-STS_Adaption_status_signals-STS_Degradation_PED,Enabled ,2
ENG344879-ENG345969-STS_Adaption_status_signals-STS_Degradation_REM,Enabled ,2
ENG344879-ENG345971-STS_Adaption_status_signals-STS_Degradation_TSR,Enabled ,2
ENG344879-ENG345972-STS_Adaption_status_signals-STS_Degradation_WLA,Enabled ,2
ENG344879-ENG345975-STS_Adaption_status_signals-STS_Healing_EyeQ,Enabled ,2
ENG376373-ENG376904-STS_Adaption_status_signals_extended-STS_Degradation_HCA,Enabled ,1
ENG376373-ENG376905-STS_Adaption_status_signals_extended-STS_Degradation_TPA,Enabled ,1
ENG376373-ENG376906-STS_Adaption_status_signals_extended-STS_Degradation_VZE,Enabled ,1
ENG344890-ENG346055-TSR_Settings-TSR_Measurement_Block_Source,General reject,1
ENG344890-ENG346056-TSR_Settings-TSR_Object_Slot,General reject,1
ENG344896-Watch_Dog_Enable_0x101A,Reset_enabled ,1
ENG344897-ENG346104-WLA_Configuration-WLA_Activation,WLA_active ,12
ENG344897-ENG346105-WLA_Configuration-WLA_Activation_brightness,8.00 ,12
ENG344897-ENG346106-WLA_Configuration-WLA_Activation_during_standstill,WLA_deactive_at_standing ,12
ENG344897-ENG346107-WLA_Configuration-WLA_Brightness_Theshold_Reflectors,0.6 ,12
ENG344897-ENG346108-WLA_Configuration-WLA_Deactivation_brightness,6.00 ,12
ENG344897-ENG346109-WLA_Configuration-WLA_Object_Distance_MXB_Test_Bench,0 ,12
ENG344897-ENG346110-WLA_Configuration-WLA_Prediction_Time_Vehicle_Position,0 ms,12
ENG344897-ENG346111-WLA_Configuration-WLA_Sensitivity,0.00 ,12
ENG344897-ENG346112-WLA_Configuration-WLA_Size_Threshold_Reflectors,20 ,12
ENG130779-Xcp_interface,not active ,1
Elapsed Time: 00:22
adpmap - BB
SW:3WA-959-595-A HW:3WA-959-595 --- BB: Door Rear Drv
Component:TSG HFS 001 0222, Coding:000C90200100008100003020
EV_DCU4RearDriveMAXHKLO,001016,EV_DCU4RearDriveMAXHBRO_VW42.rod
Sunday,26,July,2026,16:44:37:15875
VCID: 56F48443B884BD8AD5E-8002-R SFD+SFD2 [x]
IDE00001-IDE17904-Production mode-Check of emergency door release,Deactivating ,3
IDE00001-IDE21198-Production mode-Suppression of door emergency release,Deactivating ,3
IDE00820-Activating and deactivating all development messages,00 00 00 00 00 00 00 00 ,8
IDE09067-Side window shade: service mode,Deactivating ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,20
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,9 ,20
IDE16393-Rear ambient Lighting configuration - light output 1,Unknown (255),1
IDE16394-Rear ambient Lighting configuration - light output 2,Unknown (93),1
IDE16395-Rear ambient Lighting configuration - light output 3,Unknown (255),1
IDE16396-Rear ambient Lighting configuration - light output 4,Unknown (87),1
IDE17073-Operating status stand-alone mode 1,BD DB 6B 3A ,4
IDE17074-Operating status stand-alone mode 2,42 24 94 C5 ,4
MAS19336-Active participant function activated,activated ,1
ENG307653-ENG331874-Deactivation_of_component_protection-Central_locking_thermal_protection_deactivation,not active ,1
ENG307653-ENG331909-Deactivation_of_component_protection-Mirror_folding_thermal_protection_deactivation,not active ,1
ENG307653-ENG332344-Deactivation_of_component_protection-Power_latching_system_thermal_protection_deactivation,not active ,1
ENG307653-ENG332366-Deactivation_of_component_protection-Side_window_blind_thermal_protection_deactivation,not active ,1
ENG307653-ENG332407-Deactivation_of_component_protection-Window_regulator_release_clamb_15_dependence_deactivation,not active ,1
ENG307653-ENG332408-Deactivation_of_component_protection-Window_regulator_thermal_protection_deactivation,not active ,1
ENG316728-Door_handle_outside_actuation_calibration,General reject,1
ENG344855-Masking_out_dtc,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,40
Elapsed Time: 00:07
adpmap - BC
SW:3WA-959-594-A HW:3WA-959-594 --- BC: Door Rear Pass
Component:TSG HBFS 001 0222, Coding:000C90200100008100003020
EV_DCU4RearPasseMAXHKLO,001016,EV_DCU4RearPasseMAXHBRO_VW42.rod
Sunday,26,July,2026,16:45:02:15875
VCID: 55F6834FA582B692DC4-8000-R SFD+SFD2 [x]
Elapsed Time: 00:07
adpmap - CA
SW:8Y1-907-594-AC HW:4K1-907-594 --- CA: Sunroof
Component:SAD_STG_1 010 0010, Coding:608040749202
EV_SunRoofCONTIAU736,009015,EV_SunRoofCONTIAU736_009_VW27.rod
Sunday,26,July,2026,16:45:20:15875
VCID: 08489A3B22B0DB7A972-805C-R
ENG146366-Applikationmode deactivate,Deactivating ,1
Elapsed Time: 00:03
adpmap - D6
SW:992-941-572-AH HW:992-941-572-A --- D6: Light Ctrl Left 2
Component:LED1L H25 9204, Coding:
EV_LLPGen3LKEBODPO68X,002003,EV_LLPGen3LKEBODPO68X_002_VW27.rod
Sunday,26,July,2026,16:45:40:15875
VCID: 698EBFBF19FA027268C-803C-R
IDE00820-Activating and deactivating all development messages,No ,1
Elapsed Time: 00:00
adpmap - D7
SW:992-941-572-AH HW:992-941-572-A --- D7: Light Ctrl Right 2
Component:LED1R H25 9204, Coding:
EV_LLPGen3RKEBODPO68X,002003,EV_LLPGen3RKEBODPO68X_002_VW27.rod
Sunday,26,July,2026,16:45:57:15875
Elapsed Time: 00:00
adpmap - DE
SW:3P0-035-502-B HW:3P0-035-502 --- DE: Charger 1 for mobile dev
Component:COUPLING BOX 004 0170, Coding:800000
EV_DualCouplBoxSK336,001006,EV_DualCouplBoxSK336.rod
Sunday,26,July,2026,16:46:05:15875
VCID: 2410EE8BBE581F1A9BA-8070-R SFD+SFD2 [x]
IDE00001-MAS16893-Production mode-Contactless charging,not active ,3
IDE00001-ENG376492-Production mode-Antenna_coupling,not active ,3
IDE12489-ENG387563-Antenna 2 for short-range communication-EcpTci_1,1 ,51
IDE12489-ENG387564-Antenna 2 for short-range communication-EcpTci_2,1 ,51
IDE12489-ENG387565-Antenna 2 for short-range communication-EcpTci_3,3 ,51
IDE12489-ENG321400-Antenna 2 for short-range communication-number_retry_authentication_request,3 ,51
IDE12489-ENG321402-Antenna 2 for short-range communication-number_retry_nfc_detection,1 ,51
IDE12489-ENG321433-Antenna 2 for short-range communication-routing_timer,6000 ,51
IDE12489-ENG321445-Antenna 2 for short-range communication-time_retry_authentication_request,100 ,51
IDE12489-ENG321446-Antenna 2 for short-range communication-time_waiting_communication_error,250 ,51
IDE12489-ENG405757-Antenna 2 for short-range communication-Time_Waiting_Owner_Pairing,30 s,51
IDE12489-ENG376991-Antenna 2 for short-range communication-WaitingApduSelectResponse,500 ,51
IDE15288-Mobile device charger: transferable power,15.00 W,1
IDE15296-Fan power adjustment,100 %,1
IDE15297-Fan characteristic curves,Characteristic curve 1 ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,02 50 ,14
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,6 ,14
MAS19184-Production mode for test activated,Productionmode_for_development_use_not_active ,1
Elapsed Time: 00:02
SFDLog
WVWZZZCJXRD029582,,,Start SFD Session,Sunday,26,July,2026,16:54:14,H12-063104,SFD session start successful
WVWZZZCJXRD029582,Address 0x19,5QS 907 530 B,Online SFD,Sunday,26,July,2026,16:55:00,H12-063104,SFD challenge retrieval success, 583 bytes
WVWZZZCJXRD029582,Address 0x19,5QS 907 530 B,Online SFD,Sunday,26,July,2026,16:55:03,H12-063104,SFD unlock token retrieval success, 852 bytes
WVWZZZCJXRD029582,Address 0x19,5QS 907 530 B,Online SFD,Sunday,26,July,2026,16:55:03,H12-063104,SFD unlock token transmitted to controller
WVWZZZCJXRD029582,Address 0x19,5QS 907 530 B,Online SFD,Sunday,26,July,2026,16:55:04,H12-063104,Unlock_successful
WVWZZZCJXRD029582,Address 0x03,3WA 614 517 AM,Online SFD,Sunday,26,July,2026,16:55:56,H12-063104,SFD challenge retrieval success, 583 bytes
WVWZZZCJXRD029582,Address 0x03,3WA 614 517 AM,Online SFD,Sunday,26,July,2026,16:55:59,H12-063104,SFD unlock token retrieval success, 852 bytes
WVWZZZCJXRD029582,Address 0x03,3WA 614 517 AM,Online SFD,Sunday,26,July,2026,16:55:59,H12-063104,SFD unlock token transmitted to controller
WVWZZZCJXRD029582,Address 0x03,3WA 614 517 AM,Online SFD,Sunday,26,July,2026,16:56:00,H12-063104,Unlock_successful
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:58:24,H12-063104,SFD challenge retrieval success, 583 bytes
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:58:27,H12-063104,SFD unlock token retrieval success, 852 bytes
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:58:27,H12-063104,SFD unlock token transmitted to controller
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:58:28,H12-063104,Unlock_successful
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:59:03,H12-063104,SFD challenge retrieval success, 583 bytes
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:59:06,H12-063104,SFD unlock token retrieval success, 852 bytes
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:59:06,H12-063104,SFD unlock token transmitted to controller
WVWZZZCJXRD029582,Address 0x09,5WA 937 084 AG,Online SFD,Sunday,26,July,2026,16:59:07,H12-063104,Unlock_successful
WVWZZZCJXRD029582,Address 0x19,5QS907530B,SFD re-lock,Sunday,26,July,2026,17:03:20,H12-063104,SFD re-lock (CAN)...Done. Acks received: 30
Paskal
Czech Republic
C?ID=508876
So I'm still waiting for the software update for Park Assist Plus. VW support hasn't been able to fix the bug in the A5 yet :banghead:
As I searched for the bug, most new cars on the forum have it, as I've seen. So I don't know if anyone has fixed it or if they don't even know about it.
1) https://www.ross-tech.com/Search-Results.php?q=3146032+-+Databus
2) https://www.ross-tech.com/Search-Results.php?q=3146032+-+Databus
   Part No SW: 3WA 907 217 C    HW: 3WA 907 217
   Component: MFK120        H18 1423
   Dataset Number: V03935484GV 0001
   Coding: 0005000000000000000000BAF940C00400000000806580000000FC00000038FE43F040004000000000800000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK120MAGNAMQBWB 001024
   ROD: EV_MFK120MAGNAMQBWB_001.rod
   VCID: 48C85A3B62301B7A5E2-801C SFD+SFD2 [x]
3146032 - Databus
          U1123 00 [00100111] - Received Error Message
          [NR_RL_Blindness_ERROR]
                    Mileage: 22586 km
                    Date: 2026.06.19
                    Time: 13:25:46
3146033 - Databus
          [NR_RS_Blindness_ERROR]
                    Mileage: 22586 km
                    Date: 2026.06.19
                    Time: 13:25:46
Hey, you've got a 2024 car with only a single-digit count of fault codes. Consider yourself lucky!
Paskal
Czech Republic
C?ID=508876
I am happy. :)
But VW company is weak!!! Because the Park Assist Plus function is not free (they charge a lot for it) and they can't figure it out. :D
Therefore, the Memory function does not work either - A big novelty for the Passat B9 is the memory function. The car can remember the last 50 meters of driving. For example, if you park in a difficult place at home in the garage or in a company parking lot every day, you can save this maneuver in the system (capacity is up to 5 different maneuvers). The next time you arrive at the given place, the Passat will automatically offer to park completely by itself.
  • Informative
