Australian Golf R Mk7 with MIB
kamold
Australia
C?ID=241363
Here is a scan of a Golf R that I upgraded the MIB infotainment system in last week.
Scan prior to removing anything
VCDS Version 15.7.4.1
Data version: 20160216
VIN: WVWZZZAUZE   License Plate:
Mileage: 15626km-9709mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
          A9
VIN: WVWZZZAUZEW   Mileage: 15626km-9709miles
05-Acc/Start Auth. -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0001
2B-Steer. Col. Lock -- Status: Not registered 0001
42-Door Elect, Driver -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: Not registered 0001
A9-Struct. Borne Sound -- Status: Not registered 0001
Address 01: Engine (J623-CJXB)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 B    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00322466050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
   ROD: EV_ECM20TFS0205G0906259B_VW37.rod
   VCID: 2D5AFB177C186256E5-8079
15416 - Cam Adjustment Actuator B; Cylinder 2
          P11A8 00 [104] - Implausible Signal
                    Fault Frequency: 30
                    Mileage: 12170 km
                    Date: 2015.06.08
                    Time: 09:41:20
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4311
   Revision: 03252204    Serial number: TFK01311250692
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 244C1E332FD2A31E3A-8071
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 63323000000125
   Coding: 01FA93A154232974037C070941C46980C92A94C0E08296F7F84250B8C208
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 7CFC0653F7E23BDE22-8029
Address 05: Acc/Start Auth.
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120004200100001005000012101800
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 66C8443B996E910EE4-8033
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011334601401
   Coding: 03011A46C24122F30BA44080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7BFE054FF2EC3CE62B-802F
   Slave 1:
   Component: WWS    131207  042 0551
   Serial number:         131210003007
   Slave 2:
   Component: RLFS  024 0042
   Serial number: Y13M12D11H17M57S37S8
   Coding: 00A8DD
   Serial number: 000000000ZY133100LTY
   Serial number: 00000000000028262586
12554 - Bulb for Left Back-up Light
          B12CB 15 [008] - Open or Short to Plus
                    Reset counter: 20
                    Mileage: 15585 km
                    Date: 2016.01.16
                    Time: 13:11:38
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 241
                    Mileage: 15626 km
                    Date: 2016.02.13
                    Time: 19:51:26
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331334600506
   Coding: 0071151011
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 3E78CC5BA17EE9CE4C-806B
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 01121377031211
   Coding: 001C1300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 3668D47B894E218E94-8063
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
                    Fault Frequency: 68
                    Reset counter: 20
                    Mileage: 12170 km
                    Date: 2015.06.08
                    Time: 09:41:21
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 20111341350085
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76E8147BC9CE618E54-8023
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR028KP%
   Coding: 98CCC000000000005C00000000C800000065
   VCID: 7F06F15FE6F420C607-802B
   Seat belt tensioner; left:
   Serial number: 34169677B10121350199
   Coding: 333135
   Seat belt tensioner; right:
   Serial number: 34169676B10121340169
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 712 13
   Serial number: 357670000009B5695E01
   Subsystem 4 - Part No SW: -----------    HW: 480 000 712 13
   Serial number: 358670000007A5156E0Y
   Subsystem 5 - Part No SW: -----------    HW: 480 400 612 13
   Serial number: 3516502A11220561F14R
   Subsystem 6 - Part No SW: -----------    HW: 480 400 612 13
   Serial number: 35265029F122056340E+
   Subsystem 7 - Part No SW: -----------    HW: 480 403 011 13
   Serial number: 3556502B91220561B25
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 09121304220254
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_SE37.rod
   Part No SW: 5G6 920 870 B    HW: 5G6 920 870 B
   Component: KOMBI         314 2210
   Coding: 27AD0818BF80000800886A01040000
   Shop #: WSC 00000 000 00200
   VCID: 2E58FC1B711E194EDC-807B
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001327330
   Coding: 030100042B085900EF00027E9C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear.rod
   VCID: 3F86B15FA674E0C647-806B
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H06 0038
   Serial number: 27130001974530103474
   Coding: 2DFFFF
   Component: J367-BDMHe  H03 8043
   Serial number: 0812122003
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00002.10.13
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4688A4BBF9AEB10E04-8013
   Revision: 00000000    Serial number: 13000265756001
   Coding: DD00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 346CEE739F32339EAA-8061
   Serial number: 09111304080830
   Coding: 003E12208001048000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 4084B2A3DB8A9F3E3E-8015
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001342364
   Coding: 1D0000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 356AD37794482A969D-8061
   Serial number: 29111302090104
   Coding: 003E12208E01048000800000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001337788
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 02A602000B000200
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 3D7ACB57AC78F2D655-8069
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     040 0430
   Serial number: V1F00712131320
   Coding: 02730008FF00000011510001000900001F0207960100010245
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 2756093F5EE448061F-8073
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9NJ9024LG
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 131113202175
End-------------------------(Elapsed Time: 05:31)--------------------------
