Resolved Perplexed - Will clearing all DTC/faults cause some systems to stop working?
Resolved
RKTaylor
Arizona, USA
C?ID=521624
Backstory: 2011 JSW. DPF light was on along with other associated engine faults. Fixed problems then drove highway while monitoring progress. DPF light went off, we (I) cleared all faults. At that second, the RNS-315 clock was gone (black screen) Will not power on holding power button and eject. Now the sunroof, sunshade and interior courtesy lights do not work properly but I believe they had been. The roof/shade will respond to recalibrating but and indicates as learned, but do not operate by controls.
We have driven 200 miles with no engine code faults. Everything else on the car seems to work. GPS, Instrumentation, Lights
Here is what we have tried:
Compared earliest and latest scans for the coding for each module. (No differences)
Re wrote original coding for some modules. 09,19,2E,37,4F
Tested every fuse in both engine and passenger fuse blocks.
Checked fuse and power for RNS-315
Looked at BCM and the attached relay connections for signs of corrosion.
The Memory checksum has been present for some time, long before this problem so I didn't consider it a cause.
The ABS TPS comes and goes.
Considered a ground problem but the infotainment blacked out during the fault reset.
But VCDS showed the memory size in the SD card. The card is now removed.
What am I missing? Pretty Please...
Thursday,04,June,2026,07:03:24:10610
VCDS Version: 26.3.0.0  HEX-NET2 CB: 0.4713.5
VIN: 3VWPL7AJ9CM645816   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
          62 72
VIN: 3VWPL7AJ9CM645816   Mileage: 174890km-108671miles
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 84352 802 592294
   VCID: 30327917C621C4AA7F3-8064
   VINID: 0E69E070745A25374610520118E5915384
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351113    Serial number: 00001108261963
   Shop #: WSC 00066 000 00000
   VCID: 1760A28B438F33921E9-8042
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V2.clb
   Revision: 00H31001
   Coding: 114B600C492600FF881306E5921F0042B70000
   VCID: 7BA89E3B53E7F7F29A1-802E
                    Reset counter: 166
                    Mileage: 174889 km
                    Date: 2026.05.23.
                    Time: 23:55:52
                    Count: 3
                    Count: 12
                    Count: 20480
                    Count: 16390
                    Count: 46336
                    Count: 509
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0153287923 Dataset Number: 5K0116v____ 1K06
   Coding: 030C0C
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP_VW32.rod
   VCID: 3338761B3BB7FFB2021-8066
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001016
   Coding: 0000001002
   Shop #: WSC 00066 000 00119
   VCID: 0052E9D73A81942ACF3-8054
   Part No SW: 5K0 937 084 G    HW: 5K0 937 084 G
   Component: BCM PQ35 B    011 2048
   Revision: BG011001
   Coding: 6F380E1F802F3EC4008800817000004441000086575D05F064802020A040
   Shop #: WSC 49118 001 1048576
   VCID: 363E4F0F2845EA9A25F-8062
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 31101  26  0512
   Coding: 009795
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA0MSW/   Dataset Number: 1KM003v__B_ 0035
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FD02A2B07FF2BD2F69-806A
   Seat occupant detection:
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00002CJ700
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME054A4361ZZZQ
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME5F741461ZZZ.
   Serial number: 3511HSME4F212F28ZZZU
   Serial number: 3521HSME72062C28ZZZL
   Serial number: 35527SME31634028ZZZ3
   Serial number: 35627SME621B4028ZZZB
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20151031100125
   Coding: 100A140000
   Shop #: WSC 22539 444 85674
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 0256E3DF348D863AD97-8056
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0639149
   Coding: 820000
   Part No SW: 5K0 920 972 C    HW: 5K0 920 972 C
   Component: KOMBI         H32 0310
   Revision: X0032006    Serial number:
   Coding: 270F01
   ASAM Dataset: EV_KombiUDSMM9RM10 A04305
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 30327917CAA1C4AA7F3-8064
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 20101101290194
   Coding: 352002
   VCID: 3822413722511CEA373-806C
   Part No SW: 5K0 953 234     HW: 5K0 920 972 C
   Component: IMMO          H32 0310
   Coding: 000007
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
   VCID: 6A86AB7F2CFD7E7A717-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000177921005
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 2E0E676FD095D25A6DF-807A
   Revision: A1001003    Serial number: 7660813185
   Coding: 020000
   Shop #: WSC 00066 123 12345
   VCID: 29049473E9FBB562B8D-807C
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H33 0265
   Serial number: VWZAZ2L8474343
   Coding: 04000401040007000000100A
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2318865B8B576F32F21-8076
   Component: NAR_V2  0002
                    Reset counter: 166
                    Mileage: 174892 km
                    Date: 2026.06.02.
                    Time: 00:07:49
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [00001001] - General Memory Failure
          [ECU defect data memory failure]
                    Mileage: 128285 km
                    Date: 2032.06.29.
                    Time: 03:06:47
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0003549217
   Coding: 0004B5
   VCID: 5BE8FEBBF3A717F2FA1-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  007 1509
   Serial number: 00000006142114
   Coding: 000490
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 343A75073239F88A1BB-8060
   Component: EZE_2         H40 1620
   Coding: 050B0500
   VCID: 6FB0BA6B179F9B52269-803A
   Component: J245EE20SKB13  H02 0220
01512 - Control Module for Sliding Roof
                    Fault Status: 00100101
                    Reset counter: 206
                    Mileage: 174892 km
                    Date: 2026.06.02.
                    Time: 00:16:08
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0003543938
   Coding: 0004B4
   VCID: 5CEAFDA7F6A910CAF3B-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1509
   Serial number: 00000005975654
   Coding: 000490
End----------(Elapsed Time: 01:30, VBatt start/end: 12.4V/12.6V)-----------
------------------------------4 Faults Found-------------------------------
I cannot imagine how or why. I mean, you're buy no means the only person with a car like that who has cleared DTCs, but you're the only one I'm aware of with this issue, so my money is on: This is a coincidence, and I've seen some strange ones, but the cause is something else, I'm just not sure what it might be.
Dr Sheldon
Windsor UK
C?ID=334979
Something odd here
But then nothing for 56 - Radio in the scan ? Scan stops at Module 52 ??
Address 37
Mileage: 174892 km
Mileage: 128285 km
Does this have a Satellite Radio ?? What is Satellite Radio ?? - Sorry I have never needed to know !
I note that Tuner for Sat Radio is deactivated - Deactivated where ? In Gateway ? In Coding ? Can you check ?
That there seem to pointing at a dud unit yet you maintain Sat Nav is functioning ?
Mileage: 174892 km
How the F can "No or Incorrect Basic Setting / Adaptation" be intermittent ?? Not logical !
Also look at mileage in the Freeze Frame for the faults !
The Sliding Roof and Satellite tuner faults set together.
Go disconnect the battery for an hour. Reconnect and Rescan please.
Once again:
Dr Sheldon
Windsor UK
C?ID=334979
These cars do weird things.
For example a 2024 Vauxhall / Opel Corsa which is a rebadged Peugeot. I have experienced this more than once !! It is scary !!
If you disconnect / reconnect the battery it will then not start. Often Lock unlock will sort it but not always. Clearing DTC's will bring it back to life.
Agreed - Clearing codes with VCDS is not likely to cause this. This is a 2011 - 15 year old car. Any issue of this nature would have manifested a decade ago !!
It's a NAR market thing. Sirius/XM satellite radio. That fault code is just advisory, indicating no active subscription to the service.
Eric
HC800000
How did you clear codes? Direct in 01, or [Clear all DTCs] in the Autoscan screen?
Dr Sheldon
Windsor UK
C?ID=334979
RKTaylor
Arizona, USA
C?ID=521624
Great News I cant believe it. We put the car in transport mode for couple of days. As soon as we took out of transport more EVERYTHING started to work.
We had to enter the radio code and relearn the sunroof and sunshade. But everything seems to be normal. Thank you.
RKTaylor
Arizona, USA
C?ID=521624
Soory I did not see the two previous posts before my last. Me bad.
