2022 VW ID.4 Auto-Scan
paul.kim
C?ID=520080
Did not have latest VCDS version when this vehicle was scanned. My VCDS is now at 26.5.2. Will ask customer to return if I can get SFD access.
Tuesday,16,June,2026,11:05:27:59379
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4701.5
VIN: WVGGNPE2XNP069016   License Plate:
Mileage: 78619km-48851mi   Repair Order:
Chassis Type: E2-VWE3 (1EA)
Scan: 01 03 05 06 08 09 10 13 15 16 19 23 2B 36 3C 42 44 51 52 5F
          69 6C 6D 75 7E 8C A5 BB BC C0 C6 CA CE D6 D7 8105 8116 811E 811F 8120
          8121 8123 8124 8125 8128 C002 C003
VIN: WVGGNPE2XNP069016   Mileage: 78619km-48851miles
7E-Ctrl Head Dash -- Status: OK 0000
8C-HV Battery -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CE-Drive Motor 2 -- Status: OK 0000
8105-DC/DC Converter 12V -- Status: Malfunction 0010
8116-Snd enhanct 2 -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623-EBRA)       Labels: 0EA-907-425-V1.clb
   Part No SW: 0EA 906 012 DK    HW: 0EA 907 425 C
   Component: E-Vehicle     H01 2603
   CVN: FF4230F2
   Coding: 4102000003660000700000000000004030000E0000000000
   ASAM Dataset: EV_VCU00XXX0200EA906012DK 001001
   ROD: EV_VCU00XXX0200EA906012DG_VWE3.rod
   VCID: 77A084802F433B82FE9-8022 SFD
   VINID: 9E65D77A0542A1E800189001187E7FBA32
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501 A    HW: 1EA 965 501 A
   Component: V711           022 0007
   Serial number: 20220731060604072105
31949 - Front Camera for Driver Assist Systems
          U1229 00 [00100000] - Implausible Message
          [Front camera for driver assistance systems implausible]
Address 03: ABS Brakes (J104)       Labels: 1EA-614-517-V1.clb
   Part No SW: 1EA 614 517 BC    HW: 1EA 614 517
   Component: ESC-ZF_EBC470 H15 0526
   Serial number: B00EMWQ         Dataset Number: V03935390CC 0001
   Coding: 229564856941443F263C96DF22DF32A6484B91369031614928444C6512D2896C098C869214ED4BBCFD64B7D23DBF26
   ASAM Dataset: EV_Brake1ZFESCEPBMEB 013164
   ROD: EV_Brake1ZFESCEPBMEB.rod
   VCID: 74BAB38C3E35509ADBB-8020 SFD
16401 - Tire Pressure Warning
          C102D 00 [00101111] - -
          [RKA_DEM_MON_P_WARN]
                    Fault Frequency: 65
                    Mileage: 61919 km
                    Date: 2033.00.22
                    Time: 10:12:03
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 J    HW: 5WA 959 436 J
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935348VR 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 5BE8F830B3ABFFE2FA1-800E
   Part No SW: 1EB 959 760 H    HW: 1EB 959 760 H
   Component: MEM-BFS       010 0562
   Serial number: 2221501KA01114 Dataset Number: V03935351QL 0001
   Coding: 0118BA4000012A008803010101010000000000000000000000000000211000
   Shop #: WSC 55837 006 1048576
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 44DA234C2E15A01AABB-8010
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EA 907 727 AG    HW: 1EA 907 727 Q
   Component: Climatronic   H01 0460
   Coding: 602022247010120000100010110001102000102110101101000000000000
   ASAM Dataset: EV_ACClimaBHBMEB31X 002015
   ROD: EV_ACClimaBHBMEB31X_002_VWE3.rod
   VCID: 7F506CA0077303C2B69-802A
   Subsystem 1 - Part No SW: 1EA 820 021 A    HW: 1EA 820 021 A
   Component: J126 J126      002 0004
   Serial number: 00000000000000000138
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000001196703
   A/C compressor sub:
   Subsystem 3 - Part No SW: 1EA 816 797 G    HW: 1EA 816 797 G
   Component: J842 eKK       H09 0005
   Serial number: 1EA816797G01072210YO
   Auxiliary Heater Control Module/PTC 2:
   Subsystem 4 - Part No SW: 1EA 963 581 F    HW: 1EA 963 581 F
   Component: 0123456789012  010 0161
   Serial number: TA61671BA22243001768
   Interior temperature sensor:
   Subsystem 5 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002210622094601501
   Expansion valve 1 for refrigerant:
   Subsystem 6 - Part No SW: 1EA 816 590 B    HW: 1EA 816 590 B
   Component: N636 EV1_KaMi  H05 0002
   Serial number: 0642706
   Subsystem 7 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G395 pT-Sens1  H11 0010
15928685 - A/C Compressor Motor
          P0D6D 00 [00100000] - Voltage too Low
          [A/C Compressor HV Voltage Sens A Sens circuit out of range low]
15929001 - AC Compressor Voltage Sensor 2
          P0EA9 00 [00100000] - Implausible Signal
          [A/C Compressor HV Voltage Sens B Sens circuit out of range low]
1000761 - A/C Compressor; High Voltage Power Suppy
          B1453 F0 [00100000] - Malfunction
          [A/C Compressor HV Operating Voltage too low]
7341005 - A/C Compressor
          U103C 00 [00100000] - Implausible Signal
          [A/C Compressor Status signal Init plausibility]
Address 09: Cent. Elect. (J519)       Labels: 1EA-937-BCM-V1.clb
   Part No SW: 1EA 937 089 AA    HW: 1EA 937 089 H
   Component: SAM_H         H34 0311
   Serial number: 02102219503024- Dataset Number: V03935359VT 0001
   ASAM Dataset: EV_SAMVW31x 004001
   ROD: EV_SAMVW31x_004_VWE3.rod
   VCID: 7DAC96A80D7F11D2A45-8028 SFD
   Subsystem 1 - Part No SW: 11B 955 119 A    HW: 11B 955 119 A
   Component: FWISCHER_MYJT  003 0032
   Serial number: 907353F0402220806481
   Subsystem 2 - Part No SW: 5Q0 955 555 B    HW: 5Q0 955 555 B
   Component: RLHSS          054 0208
   Serial number: S6Y22M07D26H17M06S03
   Subsystem 3 - Part No SW: 10A 941 193 M    HW: 10A 941 193 M
   Component: LiSi           H04 0515
   Serial number: TW571416082200020605
   Subsystem 4 - Part No SW: 10A 925 200 D    HW: 10A 925 200 D
   Component: DiEta          H07 0513
   Serial number: TW571423082200010144
   Subsystem 5 - Part No SW: 10A 959 569     HW: 10A 959 569
   Component: DACHKONSOLE    007 0013
   Serial number: 000000092413VGL00882
1074806 - Databus
          U1123 00 [00100100] - Received Error Message
          [ICAS1_Gateway Datenbus empfangener Fehlerwert]
15401472 - Secure Onboard Communication
          U14FF 00 [01101100] - Signature Generation Failed
          [Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen]
                    Reset counter: 35
                    Mileage: 72016 km
                    Date: 2026.02.21
                    Time: 22:32:11
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 12.2 V
                    Outside temperature: 18.5  C
                    0: not active
                    Position lamps: not active
                    automatic: not active
                    Low beams: not active
                    Malfunction: not active
Address 10: Park/Steer Assist (-----)       Labels:| 1EA-919-294.clb
   Part No SW: 1EA 919 294 D    HW: 1EA 919 294
   Component: PDC08K        H02 0421
   Serial number: 000014082294560 Dataset Number: V03935363YG 0001
   Coding: 0040014141
   ASAM Dataset: EV_EPHBO18VW3100000 002016
   ROD: EV_EPHBO18VW3100000_VWE3.rod
   VCID: 3D2C56A84DFFD1D2E45-8068
1080304 - Parking Sensor(s); Rear
          B107B F0 [00100000] - Function Limitation due to External Factors
1113328 - Parking Sensor(s); Front
          B10FC F0 [00100100] - Function Limitation due to External Factors
          [Geber f r Einparkhilfe vorne - Funktionseinschr nkung durch Umwelteinfl sse]
13959168 - Parking Sensor(s); Rear
          B107B F1 [00100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe - Schmutz bzw. Eisbildung hinten]
Address 13: Auto Dist. Reg (J428)       Labels:| 1EA-907-572.clb
   Part No SW: 1EA 907 572 H    HW: 1EA 907 572
   Component: ARS510VW19 H03 0234
   Dataset Number: V03935384QE 0001
   Coding: 05A30080407180451247400000004005AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 003010
   ROD: EV_FRONTRADARCONTIVW310_003.rod
8 Faults Found:
0723 - Databus
          U1123 00 [00100000] - Received Error Message
          [FAULT_BV_RELEVANT_ERROR]
209054 - Databus
          [FAULT_BV_BLINDNESS_ERROR]
1561 - Databus
          [FAULT_BV_AVAILABILITY_ERROR]
0859 - Databus
          U1122 00 [00100000] - Implausible Message
          [FAULT_KAMERA_HIGH_SYSTEMZUSTAND_INIT]
0726 - Databus
          U1122 00 [10000000] - Implausible Message
          [FAULT_BRAKINGLIGHT_IMPLAUSIBLE]
          MIL ON - Intermittent - Not Confirmed - Tested Since Memory Clear
209154 - Databus
          U1123 00 [10000000] - Received Error Message
          [FAULT_VMM_BRAKINGLIGHT_DEFECTIVE]
2068 - Databus
          U1123 00 [11010000] - Received Error Message
          [FAULT_TSK_IRREV_ERROR]
          MIL ON - Intermittent - Not Confirmed - Not Tested Since Memory Clear
2425 - Databus
          [FAULT_SENSORFUSION_INPUT_CAMERA_NOT_ AVAILABLE]
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 EA    HW: 1EA 959 655 EA
   Component: VW40Airbag    010 0376
   Serial number: W207ZeE14C3     Dataset Number: V03935362XF 0001
   Coding: 8CCC000000FCC00000000020000000005100000081000000800036F8002B0065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_VWE3.rod
   VCID: 045AE34C6E95601AEBB-8050 SFD
   Component: J    IEEBOSE3  H16 0022
   Serial number: IBH00000000000IN26MV
   Subsystem 2 - Part No SW: -----------    HW: 440 002 604 22
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ0000001AC451F5D
   Subsystem 3 - Part No SW: -----------    HW: 440 002 904 22
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000CE371606A
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 4 - Part No SW: -----------    HW: 440 000 607 22
   Component: Side_Sens_B_D  00A 0149
   Serial number: I0PCJA9089CD4377800Z
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 5 - Part No SW: -----------    HW: 440 000 607 22
   Component: Side_Sens_B_P  00A 0149
   Serial number: I0QCJC508BEC14E4800$
   Subsystem 6 - Part No SW: -----------    HW: 440 000 607 22
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJA9089CD4427C001
   Subsystem 7 - Part No SW: -----------    HW: 440 000 707 22
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJA508BEC1393400Z
   Subsystem 8 - Part No SW: -----------    HW: 440 000 508 22
   Component: FrontSensor_P  00A 010A
   Serial number: 356ckBC9EC8C4532E00N
   Subsystem 9 - Part No SW: -----------    HW: 440 002 208 22
   Component: FrontSensor_D  00A 010A
   Serial number: 355CJBC9EC8C4904E00O
Address 16: Steering wheel (J527)       Labels:* 1EA-953-507.clb
   Part No SW: 1EA 953 507 N    HW: 1EA 953 507 N
   Component: GSMMEB        007 0072
   Serial number: 000000230822260
   Coding: 0000
   ASAM Dataset: EV_SMLSKLOMEB 010001
   ROD: EV_SMLSKLOMEB_010_VW49.rod
   VCID: 42D625543401AE2A997-8016
Address 19: CAN Gateway (J533)       Labels: 1EA-937-012.clb
   Part No SW: 1EA 937 012 AD    HW: 1EA 937 012 A
   Component: ICAS1 Host-SG 072 0329
   Serial number: SMERBG030822006 Dataset Number: V03935459JW 0001
   GVL: 2D00080006C8D0FC8062904248181050C400400000030000000000000000DE57
   ASAM Dataset: EV_GatewICAS1MEB 005001
   ROD: EV_GatewICAS1MEB_VWE3.rod
   VCID: 72B6B59444215EAAC97-8026 SFD
   Subsystem 1 - Part No SW: 1EA 915 181 B    HW: 1EA 915 181 B
   Component: J367-BDMConti  H04 1074
   Serial number: 77386103002207010527
   Subsystem 2 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230300931081
   Power rear lid opening control module:
   Subsystem 3 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 25893592
   Subsystem 4 - Part No SW: 1EA 959 442 H    HW: 1EA 959 442 H
   Component: MFL            H09 0032
   Serial number: 17029815152002201000
28 Faults Found:
8397569 - Quiescent Current
          U1406 00 [00100100] - Too High
                    Reset counter: 6
                    Date: 2026.05.25
                    Time: 13:12:05
8471814 - Databus
          U1123 00 [00101110] - Received Error Message
          [error_value_ESC_50_EPB_Fehlerstatus_02]
                    Date: 2025.03.04
                    Time: 01:09:02
8540417 - EgoMaster
          U15FA 00 [00100100] - Input Data Error
7467521 - Data Set Implausible
          B2012 00 [00101111] - -
          [Data_set_implausible_CMS]
                    Mileage: 45148 km
                    Date: 2025.03.03
                    Time: 23:34:31
7467522 - Data Set Implausible
          [Data_set_implausible_HLC]
                    Mileage: 45148 km
                    Date: 2025.03.03
                    Time: 23:34:31
8491266 - Secure Onboard Communication
          U14FE 00 [00101100] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Mileage: 45161 km
                    Date: 2025.03.11
                    Time: 16:38:45
8511745 - Occupant Detection
          U173E 00 [00100100] - Function Restriction due to Implausible Message
          [Occupant_Presence_Service_Restriction]
9371914 - Predictive Route Data
          B1630 02 [01101101] - Signal Failure
                    Mileage: 45149 km
                    Date: 2025.03.03
                    Time: 23:45:15
0336 - Software error detected
          C113E 00 [00100100] - -
          [SPI detected a checksum error (SPI_MCPU2WD)]
8515600 - Battery Charger Coupler
          P0E5F 00 [01100100] - Temperature too High
          [HVLM_ac_temperature_derating]
                    Reset counter: 8
                    Mileage: 77695 km
                    Date: 2026.05.30
                    Time: 02:19:06
8515633 - Charging Connector Lock
          B17E0 F0 [01101100] - Plug not Locked
          [HVLM_limp_home_plug_locking]
                    Reset counter: 24
                    Mileage: 78020 km
                    Date: 2026.06.05
                    Time: 19:56:21
8515841 - Heater Coolant Shut-Off Valve
          P1BF1 00 [01100100] - Input Voltage Fault
          [HVLM_timeout_grid_voltage]
8515849 - High Voltage Coordinator
          B1AF9 F0 [01100100] - No Charging Approval
          [HVLM_high_voltage_coordinator_no_approval]
8515864 - AC Charging Connector Recognition
          P30C1 00 [01100100] - Implausible Signal
          [HVLM_no_plug_detected_AC]
8515865 - HV Charge Monitoring
          P1CAF 00 [01100100] - Charging Current at Zero for too Long
          [HVLM_zero_current_time_exceeded_AC]
8516355 - Powerline Communication
          U1633 00 [01100100] - Connection Error
          [HVLM_vehicle_to_grid_setup_timeout]
8516362 - Powerline Communication
          [HVLM_plc_link_lost]
8516381 - HV Charge Monitoring
          [HVLM_zero_current_time_exceeded_2]
          B184C 00 [00100100] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
2244723 - Control unit for information electronics 1
          U1054 00 [00100000] - No Communication
          [Information_electronics_control_module_1_no_communication]
                    Reset counter: 20
                    Mileage: 77930 km
                    Date: 2026.06.03
                    Time: 20:16:52
2498824 - Ethernet Application Server 3 for System 1 Infotainment
          U1663 00 [00100000] - No Communication
          [Application_server_3_system_1_infotainment_no_communication_vlan]
8516881 - Charging Socket 1
          P1DD3 00 [01100100] - Connector Locking Status Faulty
          [HVLM_error_plug_lock_status_a]
8516883 - Charging Socket 1
          P1DD5 00 [01101100] - Connector Locking Activation Fault
          [HVLM_control_plug_lock_locking_a]
                    Reset counter: 24
                    Mileage: 77295 km
                    Date: 2026.05.11
                    Time: 02:02:56
8516873 - Charging Socket Flap A
          B1CA2 F1 [01100100] - Locking Activation Error
          [HVLM_control_flap_lock_locking_a]
8516896 - Charging Socket 1
          P1DDE 00 [01100100] - Connector Latch Activated
          [Hvlm_error_latch_activation_a]
8516869 - External Charging Infrastructure
          P1DCB 00 [01100100] - Not Ready for Charging Socket 1
          [HVLM_unknown_cp_communication_a]
8516866 - Charger for DC Charging Socket
          P1DCA 00 [01100100] - Temperature too High
          [HVLM_dc_temperature_derating]
                    Reset counter: 8
                    Mileage: 77695 km
                    Date: 2026.05.30
                    Time: 02:19:06
8398626 - Control Module 2 for Electric Drive Power
          U0292 00 [01101100] - No Communications
          [EM2_01_no_communication]
                    Reset counter: 26
                    Mileage: 77107 km
                    Date: 2026.05.04
                    Time: 17:55:26
Address 23: Brake Booster (J539)       Labels: 1EA-909-059-V1.clb
   Part No SW: 1EA 909 059 AN    HW: 1EA 909 059 AM
   Component: EBB-ZF-Gen1   H28 0626
   Serial number: AF23018
   Coding: 209532850041043F4C3C00DF20DF2020202020202021212121600404040404040404848484840608001000
   ASAM Dataset: EV_BrakeBoostZFMEB 012153
   ROD: EV_BrakeBoostZFMEB_012_VWE3.rod
   VCID: 065EF94458A9520AF5F-8052 SFD
   Part No SW: 1EA 905 861     HW: 2Q0 905 861 B
   Component: ELV-MEB       H10 0040
   Serial number: 22000208999001
   Coding: 8800000000000000
   Shop #: WSC 00028 000 00000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   Component: MEM-FS        010 0562
   Serial number: 2240201KA02304 Dataset Number: V03935359UA 0001
   Coding: 0118BA4000012A008803010101010000000000000000000000000000215000
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 K    HW: 2Q0 907 686 G
   Component: HRE_Master    H25 0289
   Serial number: 14520017697027  Dataset Number: V03935361VG 0001
   Coding: 66954750
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 K    HW: 2Q0 907 685 G
   Component: HRE_Slave      H25 0289
   Serial number: 14520017496415
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 1EA 959 593 E    HW: 1EA 959 593
   Component: TSG FS        004 0551
   Serial number: 0000475799704  Dataset Number: V03935407RX 0001
   Coding: 0035DB20D2000480E6008000
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
   ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 10A 959 862 AG    HW: 10A 959 862 AG
   Component: EX36 TBF_FS    H22 0110
   Serial number: 0710-16.08.22-------
   Part No SW: 1EA 907 144 AQ    HW: 1EA 907 144 H
   Component: BASGEN1MQB37  246 5033
   Serial number: 01388424 Dataset Number: V03935360GA 0001
   Coding: 00000000000002010000020101000100000001000101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 009050
   ROD: EV_SteerAssisBASGEN1MQB37_009.rod
   VCID: 0256E55474816E2AD97-8056
Address 51: Electric Drive (J841)       Labels: 1EA-907-121.clb
   Part No SW: 1EA 907 121 BC    HW: 1EA 907 230
   Component: MEB INV4.0    H09 6045
   Serial number: VES_P8001570544 CVN: 5645535F5038303031353730
   ASAM Dataset: EV_DMCM15000F11EA907121BC 001012
   ROD: EV_DMCM15000F11EA907121AC.rod
   VCID: 70B2BF9C4A2D6CBA3F3-8024 SFD
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 1EA 959 592 E    HW: 1EA 959 592
   Component: TSG BFS       004 0551
   Serial number: 0000476017143  Dataset Number: V03935407SF 0001
   Coding: 00355320DE000480E2808000
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
   ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
   VCID: 43D820502B1BA722921-8016
Address 5F: Information Electr. (J794)       Labels:| 10A-035-IC3-V1.clb
   Part No SW: 10A 035 842 N    HW: 10A 035 842 A
   Component: IC3-SF--US    H30 1751
   Dataset Number: V03935386PH 0001
   Coding: 23166030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 001001
   ROD: EV_MUICASSAFEPart_001_VWE3.rod
   VCID: 261E99C4B869720A95F-8072 SFD
   Subsystem 1 - Part No SW: 10B 919 606 B    HW: 10B 919 606 B
   Component: ABT_E_12       H40 6085
   Serial number: APUFJ919082200030180
4112 - Release / Enable Active
          B184C 00 [00100000] - -
7223 - Function Restricted due to Interrupted Communications
          U1110 00 [00101100] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 25
                    Mileage: 78039 km
                    Date: 2026.06.06
                    Time: 05:34:12
                    BAP: FF
                    Voltage terminal 30: 14.3 V
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383 B    HW: 5H0 907 383
   Component: Anhaenger     H10 0057
   Serial number: 000000000006034 Dataset Number: V03935341XL 0001
   Coding: 0200000200001400
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW38.rod
   VCID: 2D0C66E89D9F4152545-8078
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 1EA 980 556 J    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0397
   Serial number: FCLK20050822000 Dataset Number: V03935340QR 0001
   Coding: 02036300E43000
   ASAM Dataset: EV_CamSysRVCCompaFicosMEB 004014
   ROD: EV_CamSysRVCCompaFicosMEB_004_VWE3.rod
   Part No SW: 1EA 959 107 A    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0173
   Revision: --------    Serial number: A2-C776-3300-0 Dataset Number: V03935347BF 0001
   Coding: 5088
   ASAM Dataset: EV_DeckLidCONTIAU736 001018
   VCID: 372044806FC3FB823E9-8062
   Part No SW: 11A 035 285 D    HW: 11A 035 285
   Component: OCUGen4       H19 0686
   Serial number: 0000000207VIUQ1 Dataset Number: V03935397WJ 0001
   Coding: 02316020106880009005460070000000
   ASAM Dataset: EV_OCUGen4 001036
   ROD: EV_OCUGen4_VWE3.rod
   VCID: 1E6EB124E039AACADDF-804A SFD
1375744 - Secure Onboard Communication
          U14FE 00 [00101000] - Signature Verification Failed
                    Reset counter: 38
                    Date: 2025.03.04
                    Time: 01:08:28
Address 7E: Ctrl Head Dash (J1254)       Labels:| 10A-920-320.clb
   Part No SW: 10A 920 320 C    HW: 10A 920 320 A
   Component: FAHRERDISPLAY 021 0531
   Serial number: 2F1X6092-315443
   Coding: 6E72
   ASAM Dataset: EV_DashBoardLGMEB 001027
   ROD: EV_DashBoardLGMEB_001_VWE3.rod
   VCID: 157CAE08150FE9920C5-8040 SFD
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 J    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 010 1041
   Serial number: 000000260722030 Dataset Number: V03935382CA 0001 CVN: 9534C8BD00000000000000000000000000000000
   ASAM Dataset: EV_BMCeVWBSMEB 002015
   ROD: EV_BMCeVWBSMEB_002_VWE3.rod
   VCID: 41D42A583107B53280D-8014
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 F    HW: 0Z1 915 140 D
   Component: SX6  X74  CMC  005 1000
   Serial number: 00000027072205040392
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 F    HW: 0Z1 915 140 D
   Serial number: 00000027072205030391
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 F    HW: 0Z1 915 140 D
   Serial number: 00000027072205060390
   Coolant heating:
   Subsystem 4 - Part No SW: 1EE 963 231     HW: 1EE 963 231
   Component: J848 HV-PTC    H04 0020
   Serial number: 1EE96323122195000307
42532 - HV Battery System
          U163F 00 [00101110] - No Communication with Application Server
          [Diag_C_EVCAN_ORU_01_TO]
                    Mileage: 45155 km
                    Date: 2025.03.07
                    Time: 20:02:55
                    Mode HV battery actual value: Driving mode
                    Voltage terminal 30: 13.720 V
                    H-V battery voltage: 347.000 V
                    Current of H-V / hybrid battery: -40  C
                    Current of H-V / hybrid battery: -1.970 A
                    Current 2 of H-V / hybrid battery: -1.770 A
                    maximum voltage for battery cells-Index 1: 0
                    maximum voltage for battery cells-Value: 3.613 V
                    minimum voltage for battery cells-Index 1: 0
                    minimum voltage for battery cells-Value: 3.608 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* 1EA-980-65X-V1.clb
   Part No SW: 1EA 980 654 L    HW: 1EA 980 654
   Component: MEB MFK 4.1   H05 5332
   Dataset Number: V03935366TL 0001
   Coding: 000A306E1FC500F8172420000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001057
   ROD: EV_MFK41ValeoMEB_VWE3.rod
1124490 - Databus
          [PSD_04_PSD_Vorgaenger_Segment_ID_ERROR]
1124198 - Development code 1
          B2F01 00 [00100000] - -
          [VZF_Init]
1126400 - Internal Fault
          B200F F4 [00100000] - -
          [Failure_fusion_internal_error]
1124489 - Databus
          [PSD_04_PSD_Segment_ID_ERROR]
1124714 - Internal Fault
          B200F F0 [00100000] - -
          [SPI_communication_to_EyeQ_timout]
Address BB: Door Rear Drv (J388)       Labels:* Redir Fail!
   Part No SW: 1EA 959 597 E    HW: 1EA 959 597
   Component: TSG HFS       004 0551
   Serial number: 0000472621456  Dataset Number: V03935407SM 0001
   Coding: 0001D12001000480E2008000
   ASAM Dataset: EV_DCU3RearDriveMAXHCONT 001002
   ROD: EV_DCU3RearDriveMAXHCONT_VWE3.rod
   VCID: 48C2377C123D847A473-801C
Address BC: Door Rear Pass (J389)       Labels:* Redir Fail!
   Part No SW: 1EA 959 596 E    HW: 1EA 959 596
   Component: TSG HBFS      004 0551
   Serial number: 0000472637916  Dataset Number: V03935407SJ 0001
   ASAM Dataset: EV_DCU3RearPasseMAXHCONT 001002
   ROD: EV_DCU3RearPasseMAXHCONT_VWE3.rod
   VCID: 47C034401F238B024E9-8012
Address C0: Act. for Ext. Noise (J943)       Labels: 1EA-035-335.clb
   Part No SW: 11A 035 335 J    HW: 1EA 035 335
   Component: E_SOUND_SG    H05 0010
   Serial number: JTK072230722319
   ASAM Dataset: EV_ESoundMEBHarma 004011
   ROD: EV_ESoundMEBHarma_004_VWE3.rod
   VCID: 20128FDCDA4D9C3AEF3-8074
Address C6: Batt. Chrg. (J1050)       Labels:| 1EA-915-684.clb
   Part No SW: 1EA 915 684 GF    HW: 1EA 915 684 DH
   Component: HV_CHARGER    H61 2022
   Serial number: 93286VG3000D2
   Coding: 3080
   ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002019
   ROD: EV_OCCXPhase1KLOMEB01B.rod
   VCID: 055CFE4865AF5912FC5-8050
3280908 - Charging Station
          B1AD0 F0 [01100000] - Identification Failed
          [ETHTRCV_30_AR7000_SLAC_STEP_9_MATCH_REQ_Timeout]
3276854 - Intelligent Charging Function
          U15BF 00 [01101101] - Communications Error
          [SCC_TCP_ERROR]
                    Fault Frequency: 11
                    Mileage: 70597 km
                    Date: 2026.02.01
                    Time: 18:54:36
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Frequency: 0 Hz
                    Control voltage: 8926.0 mV
                    Pulse duty factor: 100.0 %
                    Activation charge cover lock charge socket A: not requested
                    Lock for high-voltage charging connector: locked
                    Status connect. recognition: detected
                    Charging socket temperature sensor AC: 30.0  C
                    Temperature sensor 1: resistance value: 1020 Ohm
                    DID 15E2: 31.0  C
                    DID 081C: 0 W
                    DID 081D: 0 W
                    DID 081E: 0 W
                    DID 0286: 12.7 V
                    DID 497C: not active
                    DID 537A: 14.2 V
                    DID 1525: 1522 mV
                    DID 4219: high-voltage de-energization not detected
                    DID 5372: 34.0  C
                    No. of lockings: 4138
                    No. of connections: 1349
                    Number of successful charging connector locks: 1443
                    Wake-up counter: contact (proximity): 0
                    Wake-up counter: Control Pilot: 0
                    Charging standard abort: status: not active
                    Loading plan: status: Not available
                    Price/performance table: status: Not available
                    Transport Layer Security (TLS) status communication: not active
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: not active
                    number_slac_attemps: 0
                    DID 1033: no_active_link
                    DID 1038: no_description
                    DID 1039: supported
                    Target HV charge current: 0.0 A
                    Powerline communication: charging process status: Standby
3280899 - Charging Station
          B1AD0 F0 [01101101] - Identification Failed
          [ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
                    Fault Frequency: 57
                    Mileage: 45158 km
                    Date: 2025.03.07
                    Time: 23:32:16
                    DID 1DA0: AC main charge
                    DID 1DAC: Charging
                    Frequency: 1001 Hz
                    Control voltage: 5960.0 mV
                    Pulse duty factor: 79.5 %
                    Temperature sensor 1: resistance value: 1021 Ohm
                    DID 15E2: 20.0  C
                    DID 081C: 3188 W
                    DID 081D: 3201 W
                    DID 081E: 3202 W
                    DID 0286: 13.3 V
                    DID 537A: 14.3 V
                    DID 1525: 1522 mV
                    DID 5372: 19.0  C
                    No. of lockings: 2798
                    No. of connections: 851
                    Number of successful charging connector locks: 909
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: active
                    number_slac_attemps: 1
                    DID 1033: SLAC_active
                    DID 1039: supported
                    Target HV charge current: 26.3 A
14750981 - Charging Socket 1
          P1CF6 00 [01100000] - Unlock Prohibited
          [Plug_unlocking_error]
   Part No SW: 89A 907 594 BD    HW: 89A 907 594
   Component: SAD_STG_1     006 0031
   Dataset Number: V03935322SM 0001
   Coding: 01002073166F
   ASAM Dataset: EV_SunRoofCONTIAU736 009012
   VCID: 7AA69DB41C5126EA817-802E
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 1ED 907 121 AS    HW: 1ED 907 121 AB
   Component: MEB INV4.4    H12 8353
   ASAM Dataset: EV_DMC208000C11ED907121AS 001001
   ROD: EV_DMC208000C11ED907121AB.rod
   VCID: 0256E55474816E2AD97-8056 SFD
42117 - Terminal 15
          U1405 00 [00100000] - Implausible signal
          [Funktion: Klemme 15 Plausibilisierung]
42328 - Control Module for Electric Drive Power Output
          P0A1B 00 [00100000] - -
          [Hardwareschutz: SBC-Fehler mit Softwarereset]
   Part No SW: 992 941 572 AE    HW: 992 941 572 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 669ED9C478E9B20A55F-8032
   Component: LED1R         H08 9202
Address 8105: DC/DC Converter 12V (A19)       Labels: 1EA-907-190-V1.clb
   Part No SW: 1EA 907 190 G    HW: 1EA 907 190 G
   Component: DCDC Gen4H13 1142
   Revision: 00H13000
   ASAM Dataset: EV_DCDC10030111EA907190G 001022
   ROD: EV_DCDC10030111EA907190G.rod
   VCID: 382247BC62DDF4FA373-806C
0110 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00101000] - -
          [Lost Communication with ECM/PCM]
                    Reset counter: 1
                    Mileage: 77695 km
                    Date: 2026.05.30
                    Time: 02:19:12
                    DC/DC Converter traction power supply: 0.97 V
                    DC/DC Converter controlled output current terminal 30: 12.969 V
                    DC/DC converter: voltage 1 active rectifier: 9.141 V
                    DC/DC converter: voltage 2 active rectifier: 9.121 V
                    DC/DC converter: transformer current 1: 0.000 A
                    DC/DC converter: transformer current 2: 0.000 A
                    DCDC temperature sensor 1: 28.38  C
                    DCDC temperature sensor 2: 28.06  C
                    DC/DC converter: operating mode output path 1: rbe_CmnGlb_DcdcMod_Stb_e
                    DC/DC converter: operating mode output path 1-Test_Program_Rbe Asw Dcdc Sym Enum rbe Cmn Glb St Dcdc Mod UBYTE: 1
Address 8116: Snd enhanct 2 (J943)       Labels: 1EA-035-335.clb
   Part No SW: 11A 035 335 K    HW: 1EA 035 335
   Serial number: JTK072280622812
   ASAM Dataset: EV_ESound2MEBHarma 003007
   ROD: EV_ESound2MEBHarma.rod
   VCID: 21148AD8D1479532E0D-8074
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 D    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 49C4327809377D7258D-801C
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-XXX-SWC4.clb
   Part No: V04 007 006 RS
   Component: ICAS1 Sys_Ada 0329
   Dataset Number: V03935366VU 0001
   ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
   ROD: EV_AppServe1Syste1ICAS1.rod
   VCID: 0C4ACB6C46C5285AA3B-8058 SFD
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-XXX-SWC5.clb
   Part No: V04 007 006 RT
   Component: ICAS1 Sys_Jav 0329
   ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
   ROD: EV_AppServe1Syste2ICAS1.rod
   VCID: 0D4CC6683DDF2152B45-8058 SFD
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 008 CD
   Component: IC3-IVI-S-US  1751
   Dataset Number: V03935386PD 0001
   ASAM Dataset: EV_MUICASIVIPart 002007
   ROD: EV_MUICASIVIPart_002_VWE3.rod
7178 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 22
                    Mileage: 77978 km
                    Date: 2026.06.04
                    Time: 20:29:02
                    BAP: 00
                    Voltage terminal 30: 14.1 V
0021 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Function restriction via shutoff stage Q2]
                    Fault Priority: 9
                    Reset counter: 6
                    Mileage: 77651 km
                    Date: 2026.05.25
                    Time: 02:54:17
                    Voltage terminal 30: 11.6 V
5688 - Control Head for Mulimedia System
          B13C9 F2 [00001000] - On/Off Switch
                    Reset counter: 6
                    Mileage: 76878 km
                    Date: 2026.04.21
                    Time: 20:32:15
Address 8128: Light line display (J145)       Labels: 10B-919-451.clb
   Part No SW: 11B 919 451 C    HW: 11B 919 451 C
   Component: Lichtlinie1   004 0107
   ASAM Dataset: EV_SmartLight1MEB 002001
   ROD: EV_SmartLight1MEB_002_VWE3.rod
   VCID: 241A83CCCE55801A8BB-8070
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-XXX-SWC2.clb
   Part No: V04 007 006 SA
   Component: ICAS1 SWCL_Em 0329
   Dataset Number: V03935368BZ 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1 005001
   ROD: EV_SWCLEmbed1ICAS1.rod
   VCID: 7BA898B0136B1FE29A1-802E SFD
13706049 - Databus
          [WLA_Blindheit received error value]
8491267 - Secure Onboard Communication
          U14FF 00 [01101101] - Signature Generation Failed
          [SOK_signature_creation_failed]
                    Date: 2025.08.30
                    Time: 17:23:38
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-XXX-SWC3.clb
   Part No: V04 007 006 SB
   Component: ICAS1 SWCL_HK 0329
   ASAM Dataset: EV_SWCLHouse1ICAS1 005001
   ROD: EV_SWCLHouse1ICAS1.rod
   VCID: 7CAA9BAC166518DA93B-8028 SFD
End----------(Elapsed Time: 02:37, VBatt start/end: 14.2V/14.3V)-----------
------------------------------68 Faults Found------------------------------
Thanks for the Release scan. At near 50K miles on a 2022 my guess is they need the Inspection reset done soon.
Once you have SFD access this is special in an ID.x based car. Our semi-automated SRI Reset function uses conventional address 17-Instruments and this car doesn't use that. For this reason you would need to:
1) Open the hood to disable the firewall (diagnostic filter).
2) Connect to address 5F-Information Electr. Use the [SFD] function to [Start SFD Session]. Once that is complete you can click [Online Unlock].
3) Go to the Adaptation function and search: since. Your drop-down menu results will be filtered to channels like this:
ENG253130-IDE12980-service_intervall-Inspection: distance driven since the last inspection​
ENG253130-IDE12981-service_intervall-Inspection: time since the last inspection​
Note, those may already have 0's stored in each channel (which can be confusing)​
Save 0 as the new value to each of them. If you have the service screen pulled up in the car at the same time the MIB should reset live time. If it doesn't, exit the controller and try a key cycle.
Additional things we would appreciate on that visit include the Beta version Auto-Scan, SFDLog.CSV and the AdpLog.CSV.
If you get into more operations or had an ICE model in for conventional SRI reset / rear brakes the full list is here:
paul.kim
C?ID=520080
Thank you! Yes, if I'm granted SFD access, I'll be getting an auto-scan and logs on the vehicle with the latest beta version. I've resubmitted my VCDS registration just to restart the process from step 1.
paul.kim
C?ID=520080
What exactly do you intend to do with this car?
Perform the service reset. Also have permission from the customer to fiddle around with VCDS and get any useful data.
OK, you may now order (free Beta) SFD Service.
paul.kim
C?ID=520080
Thank you, much appreciated! I am still getting the "SFD Service is currently not available for this Interface" message when I try to submit the order though.
Oh, I didn't notice that you have two HEX-NETs. I made the exception for the one with the serial number ending in 475. You're probably using the one that ends in 759?
paul.kim
C?ID=520080
Correct, I'm using -759.
paul.kim
C?ID=520080
OK, try again please.
SFD password set and ready to use. Will post auto-scan and logs once I have the vehicle!
paul.kim
C?ID=520080
Service interval successfully reset! The beta works with no problems. Any other data or functional tests you'd like other than the autoscan and logs?
Eric
HC800000
This is explained here:
paul.kim
C?ID=520080
Autoscan:
Wednesday,01,July,2026,11:48:06:59379
VCDS Version: 26.5.2.1 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260506 DS377.0
Dealer/Shop Name: KIMS AUTO SERVICE
VIN: WVGGNPE2XNP069016   Mileage: 79093km-49146miles
   CVN: FF4230F2
   ROD: EV_VCU00XXX0200EA906012DN.rod
   VCID: 77A084802F433B82E78-8022 SFD [x]
   Radiator shutter:
   VCID: 74BAB38C3E35509AC2A-8020 SFD [x]
          C102D 00 [01101100] - -
                    Fault Frequency: 68
                    Mileage: 61919 km
                    Date: 2033.00.22
                    Time: 10:12:03
   VCID: 5BE8F830B3ABFFE2E30-800E
   VCID: 44DA234C2E15A01AB2A-8010
Address 08: Auto HVAC (J979-----)       Labels:* None
   ROD: EV_ACClimaBHBMEB31X.rod
   VCID: 7F506CA0077303C2AF8-802A
   Air quality sensor:
   A/C compressor sub:
   ROD: EV_SAMVW31x_004.rod
   VCID: 7DAC96A80D7F11D2BD4-8028 SFD [x]
1074806 - Databus
                    Reset counter: 15
                    Mileage: 72016 km
                    Date: 2026.02.21
                    Time: 22:32:11
                    Voltage: 12.2 V
                    0: not active
   Coding: 0040014141
   VCID: 3D2C56A84DFFD1D2FD4-8068
8 Faults Found:
0723 - Databus
209054 - Databus
1561 - Databus
0859 - Databus
0726 - Databus
209154 - Databus
2068 - Databus
2425 - Databus
   ROD: EV_AirbaVW40ALVVW38X_VW41.rod
   VCID: 045AE34C6E95601AF2A-8050 SFD [x]
   Coding: 0000
   ROD: EV_SMLSKLOMEB.rod
   VCID: 42D625543401AE2A806-8016
Address 19: CAN Gateway (J533-----)       Labels: 1EA-937-012.clb
   ROD: EV_GatewICAS1MEB.rod
   VCID: 72B6B59444215EAAD06-8026 SFD [x]
30 Faults Found:
8471814 - Databus
                    Date: 2025.03.04
                    Time: 01:09:02
8540417 - EgoMaster
                    Mileage: 45148 km
                    Date: 2025.03.03
                    Time: 23:34:31
                    Mileage: 45148 km
                    Date: 2025.03.03
                    Time: 23:34:31
                    Mileage: 45161 km
                    Date: 2025.03.11
                    Time: 16:38:45
                    Mileage: 45149 km
                    Date: 2025.03.03
                    Time: 23:45:15
                    Reset counter: 7
                    Mileage: 78020 km
                    Date: 2026.06.05
                    Time: 19:56:21
2240615 - No Communications with Emergency Call Module
          U10E1 00 [00100000] - -
                    Reset counter: 39
                    Mileage: 79058 km
                    Date: 2026.06.27
                    Time: 21:35:44
          U1054 00 [00101000] - No Communication
                    Reset counter: 39
                    Mileage: 77930 km
                    Date: 2026.06.03
                    Time: 20:16:52
8515673 - HV Charging Management
          B16C5 F1 [01101100] - Online Remote Update Function Limitation
          [HVLM_online_remote_update_ongoing]
                    Reset counter: 39
                    Mileage: 78991 km
                    Date: 2026.06.25
                    Time: 21:21:52
                    Reset counter: 7
                    Mileage: 77295 km
                    Date: 2026.05.11
                    Time: 02:02:56
                    Reset counter: 35
                    Mileage: 77107 km
                    Date: 2026.05.04
                    Time: 17:55:26
   VCID: 065EF94458A9520AECE-8052 SFD [x]
   Coding: 66954750
   ROD: EV_DCU3DriveSideMAXHCONT.rod
   VCID: 0256E55474816E2AC06-8056
   VCID: 70B2BF9C4A2D6CBA262-8024 SFD [x]
   ROD: EV_DCU3PasseSideMAXHCONT.rod
   VCID: 43D820502B1BA7228B0-8016
   Part No SW: 10A 035 842 P    HW: 10A 035 842 A
   Component: IC3-SF--US    H30 1771
   VCID: 280297FCB27D647ABE2-807C SFD [x]
   Component: ABT_E_12       H40 6091
          B184C 00 [00101100] - -
                    Fault Frequency: 14
                    Mileage: 79093 km
                    Date: 2026.07.01
                    Time: 16:57:25
          U1110 00 [00101110] - -
                    Mileage: 79093 km
                    Date: 2026.07.01
                    Time: 17:44:06
                    BAP: FF
                    Voltage terminal 30: 14.2 V
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 2D0C66E89D9F41524D4-8078
13705529 - Databus
          U1121 00 [00101110] - Missing Message
          [message ORU_01 not received]
                    Reset counter: 39
                    Mileage: 79093 km
                    Date: 2026.07.01
                    Time: 17:44:06
   Coding: 5088
   VCID: 372044806FC3FB82278-8062
   Part No SW: 11A 035 285 E    HW: 11A 035 285
   Component: OCUGen4       H19 0716
   ASAM Dataset: EV_OCUGen4 001054
   VCID: 1F108C20E733A3C2CF8-804A SFD [x]
1281792 - Clock Syncronization Failure
          U138F 00 [00101000] - -
                    Mileage: 79091 km
                    Date: 2026.07.01
                    Time: 14:26:34
                    Voltage terminal 30: 13.4 V
1644276 - Backup Battery
          B1916 F4 [00101111] - Service Life Critical
          [Backup battery Service life critical]
                    Mileage: 79058 km
                    Date: 2026.06.27
                    Time: 22:05:45
          U14FE 00 [00101110] - Signature Verification Failed
                    Fault Frequency: 13
                    Mileage: 79058 km
                    Date: 2026.06.27
                    Time: 22:04:33
   Coding: 6E72
   VCID: 157CAE08150FE992154-8040 SFD [x]
   VCID: 41D42A583107B53299C-8014
   Coolant heating:
                    Mileage: 45155 km
                    Date: 2025.03.07
                    Time: 20:02:55
   ROD: EV_MFK41ValeoMEB.rod
1124490 - Databus
          [VZF_Init]
1124489 - Databus
   ROD: EV_DCU3RearDriveMAXHKLO.rod
   VCID: 48C2377C123D847A5E2-801C
   ROD: EV_DCU3RearPasseMAXHCONT.rod
   VCID: 47C034401F238B02578-8012
   VCID: 20128FDCDA4D9C3AF62-8074
   Coding: 3080
   VCID: 055CFE4865AF5912E54-8050
          [SCC_TCP_ERROR]
                    Fault Frequency: 12
                    Mileage: 70597 km
                    Date: 2026.02.01
                    Time: 18:54:36
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Frequency: 0 Hz
                    DID 15E2: 31.0  C
                    DID 081C: 0 W
                    DID 081D: 0 W
                    DID 081E: 0 W
                    DID 0286: 12.7 V
                    DID 537A: 14.2 V
                    DID 1525: 1522 mV
                    DID 5372: 34.0  C
                    DID 103A: supported
                    number_evse_slac: 0
                    DID 1039: supported
                    Fault Frequency: 58
                    Mileage: 45158 km
                    Date: 2025.03.07
                    Time: 23:32:16
                    DID 1DAC: Charging
                    Frequency: 1001 Hz
                    DID 15E2: 20.0  C
                    DID 081C: 3188 W
                    DID 081D: 3201 W
                    DID 081E: 3202 W
                    DID 0286: 13.3 V
                    DID 537A: 14.3 V
                    DID 1525: 1522 mV
                    DID 5372: 19.0  C
                    DID 103A: supported
                    number_evse_slac: 0
                    DID 1039: supported
   VCID: 7AA69DB41C5126EA986-802E
Address CE: Drive Motor 2 (J944-----)       Labels: None
   VCID: 0256E55474816E2AC06-8056 SFD [x]
42117 - Terminal 15
   VCID: 669ED9C478E9B20A4CE-8032
   Revision: 00H13000
   VCID: 382247BC62DDF4FA2E2-806C
                    Reset counter: 31
                    Mileage: 78902 km
                    Date: 2026.06.21
                    Time: 00:40:11
                    DC/DC Converter traction power supply: 1.13 V
                    DC/DC Converter controlled output current terminal 30: 12.768 V
                    DC/DC converter: voltage 1 active rectifier: 9.152 V
                    DC/DC converter: voltage 2 active rectifier: 9.131 V
                    DCDC temperature sensor 1: 30.39  C
                    DCDC temperature sensor 2: 29.77  C
   VCID: 21148AD8D1479532F9C-8074
   VCID: 49C4327809377D7241C-801C
   VCID: 0C4ACB6C46C5285ABAA-8058 SFD [x]
   VCID: 0D4CC6683DDF2152AD4-8058 SFD [x]
8478976 - OTA Update
          B199A F0 [01101100] - Software Version Inconsistent
                    Mileage: 79058 km
                    Date: 2026.06.27
                    Time: 21:32:45
   Part No: V04 007 000 AG
   Component: IC3-IVI-S-US  1771
   VCID: 6984D2F869F79D7261C-803C SFD [x]
                    Reset counter: 39
                    Mileage: 77978 km
                    Date: 2026.06.04
                    Time: 20:29:02
                    BAP: 00
   VCID: 241A83CCCE55801A92A-8070
   VCID: 7BA898B0136B1FE2830-802E SFD [x]
13706049 - Databus
                    Date: 2025.08.30
                    Time: 17:23:38
   VCID: 7CAA9BAC166518DA8AA-8028 SFD [x]
End----------(Elapsed Time: 24:54, VBatt start/end: 14.0V/13.4V)-----------
------------------------------70 Faults Found------------------------------
SFDLog:
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Monday,29,June,2026,07:48:57,HN2-016759,SFD challenge retrieval success, 583 bytes
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Monday,29,June,2026,07:49:01,HN2-016759,SFD unlock token retrieval success, 852 bytes
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Monday,29,June,2026,07:49:01,HN2-016759,SFD unlock token transmitted to controller
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Monday,29,June,2026,07:49:02,HN2-016759,Unlock_successful
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Wednesday,01,July,2026,09:57:23,HN2-016759,SFD challenge retrieval success, 583 bytes
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Wednesday,01,July,2026,09:57:25,HN2-016759,SFD unlock token retrieval success, 852 bytes
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Wednesday,01,July,2026,09:57:25,HN2-016759,SFD unlock token transmitted to controller
WVGGNPE2XNP069016,Address 0x5F,10A 035 842 P,Online SFD,Wednesday,01,July,2026,09:57:26,HN2-016759,Unlock_successful
WVGGNPE2XNP069016,Address 0x19,1EA937012AD,SFD re-lock,Wednesday,01,July,2026,10:35:47,HN2-016759,SFD re-lock (CAN)...Done. Acks received: 16
AdpLog:
Address 5F,10A 035 842 P,channel IDE12978-Inspection: distance until next inspection,adapted from,16093 km,to,87889 km,Monday,29,June,2026,07:52:01:59379,WVGGNPE2XNP069016
Address 5F,10A 035 842 P,channel IDE12978-Inspection: distance until next inspection,adapted from,16093 km,to,79091 km,Wednesday,01,July,2026,10:00:24:59379,WVGGNPE2XNP069016
Address 5F,10A 035 842 P,channel IDE12981-Inspection: time since the last inspection,adapted from,0 d,to,1 d,Wednesday,01,July,2026,10:04:29:59379
Address 5F,10A 035 842 P,channel IDE12980-Inspection: distance driven since the last inspection,adapted from,0 km,to,1 km,Wednesday,01,July,2026,10:04:53:59379
GESLog:
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00553-Automatic test procedure,Friday,19,June,2026,11:10:50:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00553-Automatic test procedure,Friday,19,June,2026,11:11:19:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00553-Automatic test procedure,Friday,19,June,2026,11:11:53:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00553-Automatic test procedure,Friday,19,June,2026,11:12:21:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00553-Automatic test procedure,Friday,19,June,2026,11:12:34:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00745-Fuel tank integrity test,Friday,19,June,2026,11:17:57:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00745-Fuel tank integrity test,Friday,19,June,2026,11:18:11:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00744-EVAP valve test,Friday,19,June,2026,11:19:09:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00745-Fuel tank integrity test,Friday,19,June,2026,11:19:18:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00744-EVAP valve test,Friday,19,June,2026,11:42:08:59379,3VWC57BU6KM089710
Address 0x01,04E 906 024 L,UDS Basic Settings,IDE00744-EVAP valve test,Friday,19,June,2026,11:43:34:59379,3VWC57BU6KM089710
Also got full control module maps:
Should I run these through the auto labeler, or would it be easier to just send you the files?
Nice. If you have the gator installed, and have the spare time, those maps can be posted here. If you are short on time you can send those via e-mail to our Support account with a link to this thread instead.
