Request SFD activation 2024 VW Atlas
EuropeanAutoVT
Coventry, VT, USA
C?ID=281711
I would like to request SFD unlock activation for a vehicle that will be in our shop for a rear brake replacement. Vehicle owner has a 2024 VW Atlas. I will be posting an auto scan shortly.
EuropeanAutoVT
Coventry, VT, USA
C?ID=281711
Here's the auto scan
Thursday,18,June,2026,09:37:55:53309
VCDS Version: 26.5.2.1 (x64)  HEX-NET CB: 0.4713.4
Data version: 20260506 DS377.0
VIN: 1V2LR2CA2RC510847   License Plate:
Chassis Type: CA-VW41 (5WB)
Scan: 01 02 03 05 08 09 13 15 17 19 22 3C 42 44 4B 52 5F 65 6C 75
          A5 A9 BB BC D6 D7 C002 C003
VIN: 1V2LR2CA2RC510847   Mileage: 93919km-58358miles
Address 01: Engine (J623-DRKB)       Labels: Redir Fail!
   Part No SW: 3CN 906 259 H    HW: 06K 907 425 N
   Component: R4 2.0l TFS   H08 0002
   CVN: 341AC81F03D6BB30
   Coding: 092A00122466012E70010000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0203CN906259H 001007
   ROD: EV_ECM20TFS0203CN906259H.rod
   VCID: 4BD6AF0FE2152DC6F7-801E
   VINID: 06609C8824D10A24C50402041C437D2FE9
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1       H13 0110
   Serial number: 20230309060604084450
23079 - Control unit for information electronics 1
          U1054 00 [00100000] - No Communication
40263 - Radiator Shutter 1
          P1A84 00 [01100000] - Iced Over
15318 - Engine Coolant Temp. Sensor (G62)
          P0116 00 [01100000] - Implausible Signal
15377 - Valve for Fuel Metering (N290)
          P0091 00 [01100000] - Short to Ground
          [Fuel Pressure Regulator "A" Control Circuit Low]
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09S 927 158 DB    HW: 09S 927 309 C
   Component: AISIN AQ8     216 4065
   CVN: 37C05442
   Coding: 0100000100000000010000000000000000000000
   ASAM Dataset: EV_TCMAQ450032 001002
   ROD: EV_TCMAQ450032.rod
   VCID: 0248422B95DF2C8E44-8056
   Subsystem 1 - Part No SW: 3CN 713 059 D    HW: 3CN 713 059 D
H03 0014
   Subsystem 2 - Part No SW: 3QF 713 033 G    HW: H27
   Component: ZSB_SB_AUTO    H27 2036
   Serial number: 20230330000086873198
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 3QG 614 517 J    HW: 3QG 614 517 A
   Component: ESC           H01 0230
   Serial number: 31723000002660  Dataset Number: V03935408ZZ 0001 CVN: B0AF2829
   Coding: 26FC648D8621616CBA7F680416CA618642425B55DA88030820A0A42D26000000000C30
   ASAM Dataset: EV_Brake1ESCEPBMQB41B 004017
   ROD: EV_Brake1ESCEPBMQB41B.rod
   VCID: 4DD2A1171C0123F6E9-8018 SFD [x]
8472 - Implausible Data Received from Airbag Control Module
          U0452 00 [00100000] - -
          [CCan_AB_Gurtschloss_FA_ext_inv]
33015 - Switch for Electric Parking Brake
          C100C 29 [00100000] - Signal Implausible
          [Switch_disturbance_failure]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 Q    HW: 5WA 959 436 Q
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935388CK 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 628862AB759F8C8E24-8036
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 3CN 907 727     HW: 3CN 907 727
   Component: Climatronic   H02 0540
   Coding: 612000010011120011100110101001110000132001200100000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005071
   ROD: EV_ACClimaBHBVW38X_VW38.rod
   VCID: 044444338FCB22BE76-8050
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000001933540
   Subsystem 2 - Part No SW: 3CN 907 049 D    HW: 3CN 907 049 D
   Component: E265KlimaHeck  H01 0201
   Serial number: 00003064441023250912
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002040523225741520
393636 - High Pressure Sensor
          B10AE 31 [00100000] - No Signal
          [High_pressure_sensor_no_signal_2]
393634 - High Pressure Sensor
          B10AE 22 [00100000] - Signal Amplitude Too High
1048848 - Interior HVAC
          U1935 00 [00100000] - Function Restriction
          [Functional_limitation_climatisation]
1048849 - Interior HVAC
459025 - Databus
          U1121 00 [00100000] - Missing Message
          [Databus missing message radio]
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [01100000] - -
                    Fault Frequency: 13
                    Reset counter: 18
                    Mileage: 90806 km
                    Date: 2026.05.18
                    Time: 15:37:28
                    Voltage terminal 30: 12.10 V
                    Compressor shut-off condition: Shut-off from Engine Control Module (ECM) via CAN
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BQ    HW: 5WA 937 086 BB
   Component: BCM37w_H132 0192
   Serial number: BXJ53F060523940 Dataset Number: V03935411GL 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VW41.rod
   VCID: 210A2DA73019D7967D-8074 SFD [x]
   Subsystem 1 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS          054 0207
   Serial number: S6Y23M07D10H11M16S33
   Subsystem 2 - Part No SW: 10A 941 193 N    HW: 10A 941 193 N
   Component: LiSi           H04 0515
   Serial number: YSJ61920072300030187
   Subsystem 3 - Part No SW: 5H0 925 200 S    HW: 5H0 925 200 S
   Component: DiETa          H07 0008
   Serial number: 93547WGK00145
   Subsystem 4 - Part No SW: 7T0 959 561 P    HW: 7T0 959 561 P
   Component: -VW----LINDA-  504 0831
   Serial number: K5JLND05072300001547
   Subsystem 5 - Part No SW: 3GB 963 345     HW: 3GB 963 345
   Component: SysNameFanLin  005 0012
   Serial number: FGKF996392
   Subsystem 6 - Part No SW: 3GB 963 345     HW: 3GB 963 345
   Serial number: FGKF622598
   Subsystem 7 - Part No SW: 3GB 963 345     HW: 3GB 963 345
   Serial number: FGKF1000235
   Subsystem 8 - Part No SW: 3GB 963 345     HW: 3GB 963 345
   Serial number: FGKF625531
   Steering Column Switch:
   Subsystem 9 - Part No SW: 5Q1 953 521 KS    HW: 5Q1 953 569 K
   Component: Lenks.Modul    H24 0190
   Serial number: 0300300720230C202191
1074837 - Databus
          U1121 00 [01101101] - Missing Message
          [TA_01 Datenbus fehlende Botschaft]
                    Mileage: 63383 km
                    Date: 2025.09.18
                    Time: 08:49:37
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Engine run: OFF
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 11.7 V
                    Outside temperature: 17.0 °C
                    Light switch position: 0
219136 - Remote key 1
          B1479 18 [01101101] - Current Too Low
          [Funkschlüssel 1 --> Batterie leer]
                    Mileage: 69782 km
                    Date: 2025.11.15
                    Time: 10:08:21
                    Terminal 15 status: On
                    Terminal 50 status: On
                    Engine run: OFF
                    Status of brake lamp switch: discrete: On
                    Voltage: 11.8 V
                    Outside temperature: -1.0 °C
                    Light switch position: automatic
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H40 0461
   Dataset Number: V03935406FG 0001
   Coding: 0C2308E44077804512474000008000C4A84020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4ED0A61B110718EE90-801A
8 Faults Found:
1230 - Databus
          [FAULT_TIMEOUT_MAINUNIT_01]
1396 - Sensor for Automatic Distance Control
          C110B F0 [00100000] - Limited Visibility
          [FAULT_SENSOR_NO_FREE_SIGHT]
1538 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLINDNESS]
1592 - Sensor for Automatic Distance Control
          C110B F0 [01100000] - Limited Visibility
          [FAULT_SENSOR_NO_FREE_SIGHT_TIMESTAMP]
2068 - Databus
          U1123 00 [00100000] - Received Error Message
          [FAULT_TSK_IRREV_ERROR]
209054 - Databus
          U1123 00 [00101000] - Received Error Message
          [FAULT_BV_BLINDNESS_ERROR]
                    Reset counter: 16
                    Mileage: 92204 km
                    Date: 2026.06.03
                    Time: 06:30:34
2425 - Databus
          U1122 00 [00101000] - Implausible Message
          [FAULT_SENSORFUSION_INPUT_CAMERA_NOT_AVAILABLE]
                    Reset counter: 16
                    Mileage: 92204 km
                    Date: 2026.06.03
                    Time: 06:30:34
0800 - Databus
          [FAULT_SWA_RELEVANT_ERROR]
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 AF    HW: 5WA 959 655 S
   Component: AirbagVW40    011 0660
   Serial number: 000000003C0MWRA Dataset Number: V03935410MJ 0001
   Coding: 8CCC000000FC000000000000000000005154500000000000000036F800130065
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001034
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 1B761F4F1275FD46A7-804E SFD [x]
   Component: -------------  H17 0022
   Serial number: IBH00000000000KSWYB%
   Subsystem 2 - Part No SW: -----------    HW: 480 051 001 23
   Component: SideSensor_Dr  000 0149
   Serial number: 35100006F25DE74804BC
   Subsystem 3 - Part No SW: -----------    HW: 480 052 704 23
   Component: SideSensor_Pr  000 0149
   Serial number: 352000070C257606E86/
   Subsystem 4 - Part No SW: -----------    HW: 480 041 904 23
   Serial number: 3570000812475889EA8D
   Subsystem 5 - Part No SW: -----------    HW: 480 040 305 23
   Serial number: 35800008524F504F0FFI
   Subsystem 6 - Part No SW: -----------    HW: 480 051 204 23
   Component: FrontSensor_D  000 014A
   Serial number: 35500007925DDFD2429L
   Subsystem 7 - Part No SW: -----------    HW: 480 051 204 23
   Component: FrontSensor_P  000 014A
   Serial number: 35600008125DDFC9E6B.
Address 17: Instruments (J285)       Labels:. 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 C    HW: 5H0 920 340 C
   Component: KOMBI         310 7370
   Coding: 10F42CCC6A8CCF050280620F0000000820302000
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW41.rod
   VCID: 220822AB351FCC8E64-8076 SFD [x]
16777018 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 116
                    Mileage: 91952 km
                    Date: 2026.05.30
                    Time: 17:48:38
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 116
                    Mileage: 93006 km
                    Date: 2026.06.08
                    Time: 21:31:21
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 116
                    Mileage: 93194 km
                    Date: 2026.06.10
                    Time: 19:37:33
16711695 - Low Coolant Level
          B1B07 00 [00001000] - -
          [warning_insufficient_coolant]
                    Fault Frequency: 9
                    Mileage: 65598 km
                    Date: 2025.10.10
                    Time: 07:43:05
   Part No SW: 5WB 907 530 F    HW: 5WB 907 530 F
   Component: GW2020 High   H06 0075
   Serial number: BXJ53F130523958 Dataset Number: V03935403XN 0001
   Coding: 0000838D0F00000000000000000003322102000902000301030100000001010000000000000000000000000000000000
   GVL: 3D000000000040CC80008002C8000040040040020040000000000000000000C8
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 4CD4AC13E71B2AFEFE-8018 SFD [x]
   Generator:
   Subsystem 2 - Part No SW: 3QF 915 181     HW: 3QF 915 181
   Component: J367-BDMHella  H01 2360
   Serial number: 3052780001
3145728 - Databus
          U1124 00 [00100000] - Additional Installations Detected
          [Multiple_plug_CAN_and_Ethernet]
2232425 - Rear View Camera System Control Module
          U104C 00 [00100000] - No communication
2175091 - Control unit for information electronics 1
          [Information_electronics_control_module_1_no_communication]
1049254 - Ethernet Databus Branch 6
          U1231 00 [00100000] - No Communication
          [Ethernet_databus_no_communication_branch_6_/_port_7]
2502759 - Ethernet Module for Emergency Call
          U1642 00 [00100000] - No Communication
          [Emergency-call_module_no_communication_vlan]
8397571 - LV Energy Management
          B1802 F1 [00100000] - Warning Triggered
Address 22: AWD (-----)       Labels:| 0CQ-907-554-V1.clb
   Part No SW: 5WA 907 554 M    HW: 5WA 525 130
   Component: 4Motion       H65 0659
   Serial number: HA1-00006.05.23
   Coding: 0201
   ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
   ROD: EV_AllWheelContrHA1VW37X_005.rod
   VCID: 58FC404323C3565E4A-800C
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 G    HW: 2Q0 907 686 G
   Component: HRE_Master    H25 0287
   Serial number: 11230061846849  Dataset Number: V03935393LD 0001
   Coding: 5A94C5D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   VCID: 3E30F6DBA1A7886E60-806A
   Subsystem 1 - Part No SW: 2Q0 907 685 G    HW: 2Q0 907 685 G
   Component: HRE_Slave      H25 0287
   Serial number: 11230061921974
2240560 - Databus
          [databus error value received - ESP_10 - ESP_HR_Fahrtrichtung]
2232357 - Databus
          [databus message missing - MainUnit_01]
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YC008WFM019S9 Dataset Number: V03935397TR 0001
   Coding: 003813200000040000040000
   ROD: EV_DCU2DriveSideMAXHKLO_VW41.rod
   VCID: 4AD8AA0BED6F34CECC-801E
196711 - Motor for Window Regulator
          B1487 29 [00001000] - Signal Implausible
                    Reset counter: 122
                    Mileage: 90854 km
                    Date: 2026.05.18
                    Time: 19:29:35
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 122
                    Mileage: 90854 km
                    Date: 2026.05.18
                    Time: 19:29:35
   Part No SW: 3QG 907 145 C    HW: 3QG 907 145
   Component: BASGEN1MQB37  176 1061
   Serial number: 01952841 Dataset Number: V03935416CC 0001
   Coding: 00000000000000010001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
   ROD: EV_SteerAssisBASGEN1MQB37_010.rod
   VCID: 48DC9003F363C6DEDA-801C
1312 - Databus
          U1121 00 [00101000] - Missing Message
          [DTC_BEM_05_TIMEOUT]
                    Fault Frequency: 91
                    Reset counter: 0
                    Mileage: 77144 km
                    Date: 2026.01.19
                    Time: 09:38:45
                    MonitorId: 02 01
                    HybridDriveReady: 00000000
                    IgnitionEnabled: 00000001
                    Communication control: 00000000
                    Diagnostic session: 00000000
                    ComM_ModeType: 00000000
                    NM_Signal_Fahrbereit: 00000000
                    NM Signal V gr 7: 00000001
                    System status: 3
                    ECU Status: 0
                    HWLib Status: 1
                    Support power reduction: 100.0 %
                    Voltage terminal 30: 15.125 V
                    Vehicle speed: 88 km/h
                    Temperature circuit board: 17 °C
                    Output stage temperature: 3 °C
                    Rackposition: 0.10 mm
                    Rackspeed: 0.54 mm/s
                    pinion angle dependent amplitude factor: 0.7 °
                    Steering wheel angle: 5.375 °/s
                    SupplierFreezeFrameData: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
   Part No SW: 5WA 907 338 B    HW: 5WA 907 338
   Component: FCM2020 Low   H14 1447
   Serial number: 200151223173098 Dataset Number: V03935404LW 0001
   Coding: 0000000009004452020122000B0003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 004012
   ROD: EV_MultiModulContiVW38X.rod
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YB008WFF017FB Dataset Number: V03935397TS 0001
   Coding: 003813208000040000040000
   ROD: EV_DCU2PasseSideMAXHKLO_VW41.rod
   VCID: 49DA9507E8693FD6C5-801C
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 842 C    HW: 5H0 035 842
   Component: MU-O-NS-US    H61 1969
   Serial number: WG8LGM170623000 Dataset Number: V03935408GQ 0001
   Coding: 24160000000010000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VW41.rod
   VCID: 26003EBB593730AE08-8072 SFD [x]
   Subsystem 1 - Part No SW: 5H0 919 606 E    HW: 5H0 919 606 E
   Component: ABT_W_12       H41 6098
   Serial number: APUFM313052300010649
   Subsystem 2 - Part No SW: V03 959 820 GP    HW: -----------
   Component: NAR 2023/24    --- 9085
6725 - Rearview Camera Module
          U1745 00 [00001000] - Ethernet Data Bus Implausible Signal
          [rear_view_cam_ethernet_corrupt_signal]
                    Reset counter: 24
                    Mileage: 93378 km
                    Date: 2026.06.12
                    Time: 12:39:36
                    Voltage terminal 30: 13.6 V
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H06 0011
   Serial number: 30000000709967 Dataset Number: V03935358JV 0001
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 383CE0C38383B65EAA-806C
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20190723000 Dataset Number: V03935391BP 0001
   Coding: 02022000E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   VCID: 52E8B26B053F7C0EB4-8006
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 285 D    HW: 5WA 035 285 A
   Component: OCU3HMQB37W   H12 0021
   Serial number: 0000000305VIVR4 Dataset Number: V03935403PM 0001
   Coding: 024160209068A8209005460070102607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW41.rod
   VCID: 48DC9003F363C6DEDA-801C SFD [x]
1644017 - Online Services
          B1915 F1 [00001000] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Fault Frequency: 71
                    Reset counter: 38
                    Mileage: 90270 km
                    Date: 2026.05.17
                    Time: 09:21:46
                    Voltage terminal 30: 12.5 V
                    Remaining long term energy budget: 3596 mAh
                    Remaining short term energy budget: 3 mAh
                    Wake up cycles counter: 11187
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3403
   Serial number: EA8808903231170 Dataset Number: V03935411FX 0001
   Coding: 00000A88116C4040109F40001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VW41.rod
   VCID: 50ECB8630B330E1E82-8004
   Part No SW: 3QF 907 159     HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 230419291683
   ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
   VCID: 095A5507A8E97FD605-805C
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007WEN08303 Dataset Number: V03935405WF 0001
   Coding: 000811208000020000000000
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS005 0350
   Serial number: YE007WE20447C Dataset Number: V03935407HH 0001
   Coding: 000811200000020000000000
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
   Part No SW: 992 941 572 AF    HW: 992 941 572 A
   Component: LED1L         H14 9103
   ROD: EV_LLPGen3LKEBODPO68X_001_VW41.rod
   VCID: 679E73BF9EBDE9A6F3-8032
135744 - Position Sensor; Motor for Dynamic Cornering Lamps
          C133E F0 [00100000] - Implausible Signal
   Component: LED1R         H14 9103
131106 - Terminal 30
          U1407 00 [00100000] - Implausible Signal
          [CAN data bus - NM implausible]
End----(Elapsed Time: 01:51, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------41 Faults Found------------------------------
EuropeanAutoVT
Coventry, VT, USA
C?ID=281711
I have placed the free SFD order and received an email with confirmation of the order. Now we are in the start SFD session under application and it says Service status for SFD pro is active, but there is a message in red letters that email confirmation is required and I cannot type in my SFD password or start an SFD session (these options are greyed out). Instructions are not very clear. What email needs to be confirmed in order to use my SFD password and begin my session.
Andy
Sector 7G
HC424490
Did you do steps 4 and 5 here?
Guess I though that was for future password change, not confirmation of the new password reset
The pedants among us would say: You did change your password: From nothing to something. ;)
