N276 fuel pressure regulator valve problem
   #21
ahidley
Pennsylvania, USA
C?ID=549110
Thaanks to ziddywerks as well as uwe and others that assisted.
Now my origonal problem stated p2294 fuel pressure regulator valve (n276) . Thats stated from a VCDS scan posted at the top of this thread. So i'm looking for n276 and i cannot find it, but vcds says its causing a problem.
Thats when i went to chatgpt and chatgpt says i have one too. I ask where? chatgpt says its built into the fuel pump. I tell chatgpt that there are zero wires on my hpfp. Chatgpt says that it got confused with a 2.0 and that i was correct that I dont have one. But how could that be when vcds detects a fault with n276?
ziddywerks chimes in and says I don't have one. I should be looking at g247.
surely the god dam sensor g247 is located under the intake manifold. So off comes the intake manifold and I switched the g247 with a new one, cleared the codes and it ran great for 5 mins then back to limp mode. That was my fault I missed reconnecting a connector on the front lower left corner of the manifold. Now a new vcds scan says all kinds of codes but ironically it says n276 and g247. see scan file
Uwe, How is it possible for vcds to generate mil codes for sensors that are not on my engine? Seems as though there is a bug in the ointment.
reconnect the missed connector, clear codes again and the car runs better than it ever has since I purchased it several years ago.
VCDS saved the day eventhough it detected a non existant sensor.
p.s. Now i have a bently manual and after i removed the intake manifold my plan was to verify that the wires for the g247 were intact. As per the bently manual it says use the 14pin oval connector located inside the fuse box in the engine bay. buy using this connector I can run the engine and test g247 power, ground, and signal. There are no 14 pin connectors in that box. Does anyone know where that 14 pin oval connector is?
Thanks Ahidley
Sunday,28,June,2026,17:18:20:15949
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
VIN: WAUDH78EX7A103186   License Plate:
Mileage: 308050km-191413mi   Repair Order:
          67 69 75 76 77
VIN: WAUDH78EX7A103186   Mileage: 308050km-191413miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 8E1 910 559 F    HW: 8E0 907 559 J
   Component: 3.2l V6 FSI         0080
   Revision: --H19---    Serial number:
   Coding: 01040109180F0120
   Shop #: WSC 40636 444 999999
   VCID: 313F07F99D2ABE5270D-8064
   VINID: 9D1954607215A074410030481879395D91
10 Faults Found:
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 009 - Open Circuit - MIL ON
                    Fault Status: 10100100
                    Mileage: 308029 km
                    RPM: 768 /min
                    Mass Air / Rev.: 152.6 mg/str
                    Temperature: 42.0 C
                    Pressure: 2.8 bar
                    Voltage: 14.18 V
                    Temperature: 24.0 C
012425 - Signal Line for Fuel Pump Electronics
               P3089 - 007 - Electrical Malfunction - Intermittent
                    Fault Status: 00000010
                    Mileage: 308054 km
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 19.5 C
                        Engine Off
                    Pressure: 0.7 bar
004438 - Manifold Pressure Sensor (G71)
               P1156 - 007 - Open/Short to Ground - Intermittent
                    Mileage: 308054 km
                    Temperature: 19.5 C
                        Engine Off
                    Voltage: 12.14 V
008217 - Intake Manifold Flap Position Sensor (Bank 2)
               P2019 - 007 - Electrical Malfunction - Intermittent
                    Mileage: 308054 km
                    Temperature: 19.5 C
                        Engine Off
                    Voltage: 0.000 V
005430 - Camshaft Timing Adj. Bank2 (N208)
               P1536 - 009 - Open Circuit - Intermittent
                    Fault Status: 00000100
                    Mileage: 308054 km
                    Temperature: 19.5 C
                        Engine Off
000291 - Throttle Position Sensor (G69)
               P0123 - 006 - Signal too High - Intermittent
                    Mileage: 308054 km
                    Temperature: 19.5 C
                        Engine Off
                    Load: 100.0 %
                    Bin. Bits: 00000000
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 007 - Signal Too Low - Intermittent
                    Mileage: 308054 km
                    Temperature: 19.5 C
                        Engine Off
                    Load: 100.0 %
                    Bin. Bits: 00000000
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 006 - Signal too High - Intermittent
                    Mileage: 308054 km
                    Temperature: 19.5 C
                        Engine Off
000400 - Fuel Pressure Sensor (G247)
               P0190 - 006 - Circuit Malfunction - Intermittent
                    Mileage: 308054 km
                    Temperature: 19.5 C
                        Engine Off
                    Pressure: 144.2 bar
009218 - EVAP Leak Detection Pump Control Circuit
               P2402 - 006 - Short to Plus
                    Fault Status: 00010001
                    Mileage: 308054 km
                    RPM: 1312 /min
                    Mass Air / Rev.: 185.3 mg/str
                    Temperature: 21.0 C
                        Idle
                    Voltage: 14.18 V
Readiness: 0110 0101
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004379
   Shop #: WSC 06335 000 00000
   VCID: 2E051C858C14A1AA6DF-807A
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6D87DB8944821AB2145-50D0
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 01023
   Shop #: WSC 65536
   VCID: 3D272BC954624A32E45-4AA4
   Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
   Component: SDAR SIRIUS         0120
   Serial number: AUZ4Z7F1040029
   VCID: 2C01168DBA28D3BA43B-5160
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0CZZ1
   Coding: 0032607
   Shop #: WSC 06325 000 00000
   VCID: 3C2126CD4A68433AD3B-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3B9PA
   Subsystem 3 - Serial number: 0001.01.000000200000000000  63
   Subsystem 4 - Serial number: 000000  6332DRB403D98AAC5  63
   Subsystem 5 - Serial number: 98AAC5  6342DRB403DBD2A6%  63
   Subsystem 6 - Serial number: BD2A6%  6352ARB401B2E46FZ  63
   Subsystem 7 - Serial number: 2E46FZ  6362ARB401B15180A  63
   Subsystem 8 - Serial number: 15180A  63729RB401AD4AB4-  63
   Subsystem 9 - Serial number: D4AB4-  63829RB401AD4AB7/
   Subsystem 10 - Serial number: D4AB7/
   Part No: 8E0 953 549 Q
   Component: Lenks ulenmodul     0701
   Coding: 04041
   Shop #: WSC 06325
   VCID: 41DF5739289A2ED280D-4AA4
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
   Component: KOMBI+WFS 4     H14 0120
   Revision: 0120        Serial number: 00000000000000
   Coding: 0023261
   Shop #: WSC 06436 444 84396
   VCID: 2E051C858C04A1AA6DF-5118
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
   Coding: 0023261
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71BFC7F9588AFE5230D-4B3C
   Part No: 8E0 959 433 CG
   Component: Komfortger t T7B    4035
   Coding: 11788
   Shop #: WSC 06335
   VCID: 78A9FADD3BC0AF1AF73-4AA4
   Subsystem 1 - Part No: 8E1959801G
   Component: T rsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: T rsteuer.BF BRM 0706
   Component: T rsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: T rsteuer.HR BRM 0606
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: 290FEF99B5FAC692B8D-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0010
   Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
   Component: R Symphony2+    H03 0070
   Revision: 00H03000    Serial number: AUZ1Z4F2837782
   Coding: 0650102
   VCID: 6889AA9D6E503F9A673-5160
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005010357
   Coding: 0001677
   VCID: 3D272BC951624A32E45-50D0
End----(Elapsed Time: 04:49, VBatt start/end: 12.1V/11.9V. VIgn 11.8V)-----
------------------------------13 Faults Found------------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 0F: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 25: DTCs cleared
Address 36: DTCs cleared
Address 46: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 77: DTCs clearedSunday,28,June,2026,18:45:21:15949
          67 69 75 76 77
Readiness: 0010 0101
   Coding: 0004379
   Coding: 00000
   Coding: 01023
   Shop #: WSC 65536
   Coding: 0032607
   Coding: 04041
   Shop #: WSC 06325
   Coding: 0023261
   Coding: 0023261
   Coding: 00002
   Coding: 11788
   Shop #: WSC 06335
   Coding: 0000019
   Coding: 0650102
   Coding: 0001677
End----------(Elapsed Time: 04:44, VBatt start/end: 12.4V/12.3V)-----------
-------------------------------1 Fault Found-------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
P2294. Open circuit is your issue open circuit for g247.
Vdub
C?ID=57533
the N276 is this one i think, on the fuelpump, the other one is a LP-sensor
   #24
ahidley
Pennsylvania, USA
C?ID=549110
Vdyb,
Yes , you are correct but not for my engine a 2007 3.2 fsi.
The hpfp has no wires
   #25
Vdub
C?ID=57533
this is from Partslink with your vin..
   #26
Ziddywerks
Northern NJ USA
C?ID=208579
Attached pdf above tells you everything you need to do to test G247 and wiring for it. What is odd is that repair manual shows a fuel metering valve N290 on the HPFP with a 2 pin connector. So perhaps the engine was swapped out of a different vehicle or are you not seeing it? Note fu
Ziddywerks
Northern NJ USA
C?ID=208579
Note fuel metering valve is located on the bottom of the HPFP and has a 2 pin connector. However factory repair manual states if you have a p2294 to check g247. However maybe in this case you have a different HPFP installed? Or the HPFP fuel pump is bad? Factory repair manual shows a N290 fuel metering valve.
   #29
ahidley
Pennsylvania, USA
C?ID=549110
Above are 2 pics of my hpfp and I tried my best to get pics of the bottom . It's pretty zoomed on as in one pic you can see the "4" for the fuel injector wire. But I cannot see any wires on the bottom and there is absolutely no wires on the top.
   #30
Ziddywerks
Northern NJ USA
C?ID=208579
and what is that?
   #31
ahidley
Pennsylvania, USA
C?ID=549110
Hpfp pics upside down
For some reason pic 2 won't upload
   #32
ahidley
Pennsylvania, USA
C?ID=549110
Bottom of the hpfp showing NO connector.
   #33
ahidley
Pennsylvania, USA
C?ID=549110
Ziddywerks. The n290 fuel metering valve has no wires. All it is is a pressure relief valve. If the high pressure side becomes over pressurized this valve opens and let's pressure bleed back to the low pressure side. This all happens within the stainless lines connected to the hpfp. It just has a ball bearing with a spring . It works just like a air compressor blow off valve .
UT if there I no 2 pin connector on my hpfp where did my origonal mil come from?
You said maybe the pump or engine was switched. That's a possibility because I bought it used with 167,000 miles. But I know the previous owner and family and they said it's origonal.
Now I'm laying in bed staring at the ceiling wondering 🤔
Anyway. I replaced the sensor that ziggywerks recommended and the car runs better than it has since i bought it. Thanks everyone
   #34
Ziddywerks
Northern NJ USA
C?ID=208579
Question still remains. According to factory repair manual P2294 check of G247 is the first step. So now the question becomes do you actually have a problem? With fueling on the low side? High side? Or does the ecm have a internal problem?
   #35
ahidley
Pennsylvania, USA
C?ID=549110
Ziddywerks. I believe its fixed. I put 100 miles on it since replacing the g247 and no codes have come up, totally free of codes. Even the headlight range control has "fixed itself" . Please note that chatgpt said that a module could send codes that conflict with other modules through the canbus and create "ghost codes" . That appears to be what happened, consider that with a grain of salt, nevertheless for the AI haters. Now I did try 2 differant headlight range control modules and both were not detected by the car until the g247 was replaced. The only differance between the range control modules was the revision. The origonal was rev f and the second replacement was rev c. I have put the original rev f back in place. Clearing codes after each attempt.
Hopefully all electrical gremlins have been evicted.. Mobile rolling computers like these cars are very susceptible to resistance changes. Perhaps because I unplugged things several times , that cleaned off the contacts just enough. I saw ZERO CORROSION anywhere but that doesn't mean there wasn't any after 191,000 miles.
  • Disagree
Reactions: TTT
   #36
davisev5225
C?ID=263265
ChatGPT is full of shit with that statement, so the "AI haters" as you call them are still batting 1000.
That is possible. I had a "ghost" misfire code on a 2001 Allroad 2.7T that didn't make sense because I couldn't feel or hear the misfire, but the car would still go into limp mode. I ended up finding it by going into the ECU drybox and unplugging the wire harness at the ECU - everything looked brand new like it rolled off the factory floor yesterday, including the contacts; but tiny bits of corrosion "film" can still build up on electrical contacts over a long period of time, so unplugging and re-plugging "wipes" that film off so they can make better contact again. Turns out the piezoelectric microphones they use as misfire sensors in that engine are extremely sensitive to changes in resistance.
Ziddywerks
Northern NJ USA
C?ID=208579
Let's see what happens. I will stop you there and simply say NO ONE should be using Ai to fix vehicles, because it has zero intelligence. Just artificial nonsense that pulls data from all over the internet whether it be true or not and spews it out as fact. Bottom line you want to save yourself time money and aggravation.... do your own research, ask someone with experience, or take it to a technician who has lots of experience with the brand. I've been in this racket for over 22+ years and have yet to see ai be even close to resolving a problem or providing factual information on a consistent basis.
   #38
ahidley
Pennsylvania, USA
C?ID=549110
Im back!! The problem has returned . This time its telling me its n276. Thats the sensor
i just replaced. I verified two of its wires, aka power and ground. The signal wire Im not sure how to test for continuity. Everwhere I look it tells me to go to the 14 pin connector round. I dont have a clue where that is. So its possible a broken sensor wire or the n276 sensor that I bought is bad. I cannot find a way to test that sensor by itself. Any advice?
Friday,18,April,2025,21:28:14:15949
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
                Address 03: ABS Brakes  (8E0 910 517 J)
21:28:11 Group 001: Steering Angel Sensor (G85) Alignment
  Adj. Steering  Steering Angel Sensor (G85)
  Angle Sensor  Alignment
  OK  Alignment Status
  N/A
Thursday,21,August,2025,23:09:15:15949
VCDS Version: 25.3.1.2 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
VCDS Release 25.3.1:  SRI Reset
Control Module Part Number: 8E0 920 951 G       Labels:  8E0-920-9xx-8EC.clb
Component:KOMBI+WFS 4     H14 0120, Coding:0023261
Channel      Description                                           Unit          Current val.      New val.
02           Service Reminder Status                                             0                 ---
40           Mileage since Service                                 miles x100    11                ---
41           Time since Service                                    Days          77                ---
42           Min Mileage to Service                                miles x100    50                ---
43           Max Mileage to Service                                ---           ---               ---
44           Max Time to Service                                   ---           ---               ---
45           Oil Quality                                                         1                 ---
46           Total Consumption                                     ---           ---               ---
47           Soot Quantity                                         km x100       0                 ---
48           Thermal Load                                          km x100       36                ---
49           Min Time to Service                                   Days          365               ---
Thursday,19,March,2026,18:16:04:15949
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VCDS Release 25.3.3:  SRI Reset
02           Service Reminder Status                                             1                 ---
40           Mileage since Service                                 miles x100    47                ---
41           Time since Service                                    Days          287               ---
48           Thermal Load                                          km x100       202               ---
Saturday,04,April,2026,14:59:49:15949
Operation: Service Reset
40           Mileage since Service                                 miles x100    0                 ---
41           Time since Service                                    Days          0                 ---
48           Thermal Load                                          km x100       0                 ---
Saturday,06,June,2026,21:12:57:15949
                Address 01: Engine  (8E1 910 559 F)
21:12:10
  727 /min   Engine Speed (G28)
  93.6 C   Coolant Temperature (G62)
  15.6 %   Engine Load
  734 /min   Engine Speed (G28)
  0.0 %   Intake Camshaft Duty Cycle
  0.0 KW   Adjustment (specified)
  0.0 KW   Adjustment (actual)
  732 /min   Engine Speed (G28)
Wednesday,17,June,2026,15:49:58:15949
15:49:17
  4.98 bar   Low side Fuel Pressure
  1.0 %   Fuel Pressure Regulator
  25.0 %   Adaptation Value elect. Fuel Pump
  ADP. Run   Fuel Pump Adapt. Status
  733 /min   Engine Speed (G28)
  15.2 %   Engine Load
  84.7 C   Coolant Temperature (G62)
  4.97 bar   Low side Fuel Pressure
  81.6 %   Electric Fuel Pump 1/2 Load
  2.00 s   Fuel Pump Shut-Off Time
15:50:07
  4.95 bar   Low side Fuel Pressure
  728 /min   Engine Speed (G28)
  16.0 %   Engine Load
  4.96 bar   Low side Fuel Pressure
Thursday,09,July,2026,15:21:49:15949
                Address 01: Engine       Labels: 06E-910-559-BKH.clb
Control Module Part Number: 8E1 910 559 F    HW: 8E0 907 559 J
  Component and/or Version: 3.2l V6 FSI         0080
           Software Coding: 01040109180F0120
            Work Shop Code: WSC 40636 444 999999
7 Faults Found:
               P2402 - 006 - Short to Plus - MIL ON
                    Fault Status: 10100001
                    Mileage: 308392 km
                    RPM: 1152 /min
                    Mass Air / Rev.: 446.9 mg/str
                    Temperature: 30.0 C
                        Idle
                    Voltage: 14.18 V
000772 - Cylinder 4
               P0304 - 007 - Misfire Detected
                    Fault Status: 01000010
                    Mileage: 308477 km
                    RPM: 832 /min
                    Mass Air / Rev.: 207.1 mg/str
                    Temperature: 36.0 C
                        Idle
                    Time: 51.2 s
000771 - Cylinder 3
               P0303 - 007 - Misfire Detected
                    Mileage: 308477 km
                    RPM: 832 /min
                    Temperature: 36.0 C
                        Idle
                    Time: 51.2 s
000774 - Cylinder 6
               P0306 - 007 - Misfire Detected
                    Mileage: 308477 km
                    RPM: 832 /min
                    Temperature: 36.0 C
                        Idle
                    Time: 51.2 s
000770 - Cylinder 2
               P0302 - 007 - Misfire Detected
                    Mileage: 308477 km
                    RPM: 832 /min
                    Temperature: 36.0 C
                        Idle
                    Time: 51.2 s
000773 - Cylinder 5
               P0305 - 007 - Misfire Detected
                    Mileage: 308477 km
                    RPM: 832 /min
                    Temperature: 36.0 C
                        Idle
                    Time: 51.2 s
               P0300 - 006 -
                    Fault Status: 01000001
                    Mileage: 308477 km
                    RPM: 832 /min
                    Temperature: 36.0 C
                        Idle
                    Time: 51.2 s
Readiness: 0000 0100
Sunday,12,July,2026,20:29:37:15949
                    Fault Status: 00010100
                    Mileage: 308477 km
                    RPM: 1664 /min
                    Mass Air / Rev.: 109.0 mg/str
                    Temperature: 45.0 C
                    Pressure: 0.7 bar
                    Voltage: 12.75 V
                    Temperature: 28.5 C
000774 - Cylinder 6
                    Fault Status: 01010010
                    Mileage: 308477 km
                    RPM: 928 /min
                    Mass Air / Rev.: 119.9 mg/str
                    Temperature: 49.5 C
                        Idle
                    Time: 51.2 s
000773 - Cylinder 5
                    Mileage: 308477 km
                    RPM: 928 /min
                    Temperature: 49.5 C
                        Idle
                    Time: 51.2 s
               P0300 - 006 -
                    Fault Status: 01010001
                    Mileage: 308477 km
                    RPM: 928 /min
                    Temperature: 49.5 C
                        Idle
                    Time: 51.2 s
          67 69 75 76 77
VIN: WAUDH78EX7A103186   Mileage: 308470km-191674miles
                    Mileage: 308477 km
                    RPM: 1664 /min
                    Temperature: 45.0 C
                    Pressure: 0.7 bar
                    Voltage: 12.75 V
                    Temperature: 28.5 C
000774 - Cylinder 6
                    Mileage: 308477 km
                    RPM: 928 /min
                    Temperature: 49.5 C
                        Idle
                    Time: 51.2 s
000773 - Cylinder 5
                    Mileage: 308477 km
                    RPM: 928 /min
                    Temperature: 49.5 C
                        Idle
                    Time: 51.2 s
               P0300 - 006 -
                    Mileage: 308477 km
                    RPM: 928 /min
                    Temperature: 49.5 C
                        Idle
                    Time: 51.2 s
   Coding: 0004379
   Coding: 00000
   VCID: 6D87DB8944821AB2145-50AE
   Coding: 01023
   Shop #: WSC 65536
   Coding: 0032607
   Coding: 04041
   Shop #: WSC 06325
   Coding: 0023261
   Coding: 0023261
   Coding: 00002
   Coding: 11788
   Shop #: WSC 06335
   Coding: 0000019
   Coding: 0650102
   Coding: 0001677
End----(Elapsed Time: 04:50, VBatt start/end: 12.1V/12.1V. VIgn 11.9V)-----
------------------------------5 Faults Found-------------------------------
Vdub
C?ID=57533
Ofcourse its back.. G247 isnt N276
