I'm confident this is a VW issue. I'm not sure I'd call it a bug. For some reason, the Antenna module has decided those faults are not worthy of reporting a Malfunction status to the Gateway yet. Whether this is intentional, by design, or whether it's an oversight/bug is a question I can't answer.And yet, if you scroll down, you can see there are several DTCs. Is this a VCDS bug, or a VW bug?
Installation lists are no longer clean and all contained in the Gateway. Other modules may have additional installation lists that we don't find until we're well into the scan. My guess is that these are virtual modules, possibly more like sub-systems that can be queried for fault codes. Note the lack of a HW Part Number on them.At the bottom, there are two control modules named "Address C002: SW Cluster Embedded (SWC2)" and "Address C003: SW Cluster Housekeeping (SWC3)". And yet, they do not show in the control unit list at the top. They are also not present when selecting a control unit individually. Is this a bug, or is there an explanation for this?
Have you tried accessing them individually by typing their addresses into the Direct Entry box on the Select Control Module screen?
