Tuesday,16,June,2026,17:19:12:50799
VCDS Version: 24.7.0.0 (x64)
VIN: WVGAV7AX0GW616438 License Plate:
Mileage: 213930km-132929mi Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 36 42 44 46 47 4C 4F 52
53 55 5F 62 69 6C 72 75
VIN: WVGAV7AX0GW616438 Mileage: 213930km-132929miles
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0403131876 Dataset Number: 5N0116v____ 0002
Coding: 030C0C
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 377CA1C18E8BEB2E32-8062
Part No SW: 1K8 907 044 BS HW: 1K8 907 044 BS
Component: Climatronic H07 0405
Revision: 00001K04
Coding: 0010019002
VCID: 01080F1990CF659ECC-8054
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
Reset counter: 227
Mileage: 213931 km
Date: 2026.06.13.
Time: 00:00:17
B10AB F0 [00001001] - Too Low
Reset counter: 187
Mileage: 213931 km
Date: 2026.06.13.
Time: 00:00:16
9480469 - Control Circuit for A/C Compressor
B10A9 15 [00001001] - Open or Short to Plus
Reset counter: 187
Mileage: 213931 km
Date: 2026.06.13.
Time: 00:00:17
Part No SW: 5K0 937 086 AB HW: 5K0 937 086 AB
Component: BCM PQ35 M 122 0183
Revision: BJ122001
Coding: EF1A0A1B88232EC4018800C114000D4448D50006566D8DB0E4840000A040
VCID: 74E656CDD77D4036D7-8020
Subsystem 1 - Part No SW: 5N1 955 119 B HW: 5N1 955 119 B Labels: 1KX-955-119.CLB
Component: WWS316 110416 24 0664
Coding: 009795
Component: RLS 090516 05 54 0403
Coding: 02304D
Address 15: Airbags
Part No SW: 5K0 953 501 DM HW: 5K0 953 569 AP
Component: LENKS.MODUL 016 0180
Revision: FF010042 Serial number: 20160512200427
Coding: 110A140000
VCID: 78FE62FDC3152456FB-802C
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0996053
Coding: 820000
Part No SW: 5N0 920 973 L HW: 5N0 920 973 L
Component: KOMBI H04 1008
Coding: 211F010000
VCID: 3D70B3E9ACB7C17EE8-8068
13639424 - Please Check Fault Codes in Engine Control Module
U101F 00 [00001001] - -
Reset counter: 187
Mileage: 213931 km
Date: 2026.06.13.
Time: 00:00:12
Part No SW: 7N0 907 530 BF HW: 7N0 907 530 AM
Component: J533 Gateway H55 1673
Revision: H55 Serial number: 110516F1001460
Coding: 356032
VCID: 75E06BC9DC07593EE0-8020
Component: IMMO H04 1008
Coding: 000007
VCID: 6ADA48B58DB986C67D-803E
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000077531001
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 31689FD960EF351E7C-8064
1048844 - Ignition Starter Switch
B11D7 29 [00001001] - Signal Implausible
Reset counter: 187
Mileage: 213931 km
Date: 2026.06.14.
Time: 18:10:42
ELV State: 0A
Information Clamps: 00 00
CoCo State: F0 01
WFS State: 00 1A
Vehicle speed: 655.35 km/h
Voltage: 6A
Part No SW: 561 959 760 C HW: 561 959 760 C
Component: MEM-FS H04 0183
Revision: AA000000 Serial number: 00000146135344
Coding: 00581B0000000000000001010101202020202121202020
VCID: 234465912213978EFE-8076
Part No SW: 5N0 959 701 J HW: 3C0 959 793 J
Component: TUER-SG FT 002 0601
Revision: 12100010 Serial number: 0010549945
Coding: 0015B6
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
VCID: 3C76BEEDB7ADC876DF-8068
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 010 1505
Serial number: 00000009741767
Coding: 000490
B11EC 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 187
Address 44: Steering Assist
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H09 6831
Revision: -------- Serial number: EAA098C0092892 Dataset Number: 5N0050v____ 0008
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 285E72BD533574D6AB-807C
9463315 - Rear Left Treble Speaker
B1066 13 [00001001] - Open Circuit
Reset counter: 187
Mileage: 213931 km
Date: 2026.06.16.
Time: 03:09:58
Address 4C: Tire Pressure II
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1673
Coding: 050B0500
VCID: 6FEC59A1BE5B63EE2A-803A
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Part No SW: 5N0 959 702 J HW: 3C0 959 792 J
Component: TUER-SG BT 002 0601
Revision: 14100010 Serial number: 0010547903
Coding: 0015B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 010 1505
Serial number: 00000009738924
Coding: 000490
67330 - Switch for Central Locking
B122D 29 [00001000] - Signal Implausible
Fault Frequency: 24
Reset counter: 227
Mileage: 211836 km
Date: 2026.05.12.
Time: 14:13:47
Address 53: Parking Brake
Address 55: Headlight Range
Part No SW: 5C0 035 684 HW: 5C0 035 684
Component: MU-S-NS-US H22 0247
Serial number: VWZAZ2S0232965 Dataset Number: V03935240VJ 0001
Coding: 02130602AA00000051220003001808001F0100C400200105C6
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 62CA20957589DE86B5-8036
Subsystem 1 - Part No SW: ----------- HW: -----------
Component: NAR 2016 --- 0321
U1400 00 [00001000] - -
Reset counter: 121
Mileage: 193948 km
Date: 2025.08.03.
Time: 13:07:56
Voltage terminal 30: 8.5 V
Address 69: Trailer
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Dataset Number: 5N0525v____ 0028
Coding: 011306012101000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428_VW36.rod
VCID: 306E9ADD6BE53C1673-8064
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0158
Serial number: 000003554140551 Dataset Number: 561098V____ 0017
Coding: 02130602C24232107F1606000000
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
VCID: 1426364DFFBDE03677-8040
End-------------------------(Elapsed Time: 04:40)--------------------------
