Caddy 2016 1.6TDI maps
golfi_vend
Tartu, Estonia
C?ID=195131
Well car is little bit broken, but electrically it should be ok.
Thursday,03,March,2016,18:28:40:36026
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ2KZGX0xxxxx   License Plate: CADDY 5F
Mileage: 16360km-10165mi   Repair Order:
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F
VIN: WV1ZZZ2KZGX0xxxxx   Mileage: 16360km-10165miles
Address 01: Engine (J623-CAYD)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 8013
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114014030400080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PC 003009
   ROD: EV_ECM16TDI02103L906023DB.rod
   VCID: F6A0AD94494B078ED4-80A2
9835 - Injector: Cylinder 3 (N32)
          P0203 00 [101] - Circuit Malfunction
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:33:59
Readiness: 0110 1000
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 41865000000107
   Coding: 1079409B9363A0860875027DC98605E3280000
   ROD: EV_Brake1ESCCONTIVN75XGP2.rod
   VCID: BFCE08B026F186C6C7-80EA
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 1K8 907 426 AB    HW: 1K8 907 426 AB
   Component: AC Manuell    H20 0808
   Revision: 00001002
   Coding: 0010004002
   ROD: EV_ACManueBHBVW36X_SE36.rod
   VCID: F3A694805A3912A6F3-80A6
          B10AB F0 [009] - Too Low
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:14:14
   Part No SW: 5K0 937 085 AD    HW: 5K0 937 085 AD
   Component: BCM PQ35 B+   122 0183
   Revision: BB122001
   Coding: 611A0A3A8025082D088800829000006403810008524F8120648000000040
   Shop #: WSC 35110 377 00146
   VCID: F5A2AA985C4D0C96DD-80A0
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 22051  27  0512
   Coding: 009795
11 Faults Found:
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:15
                        Term 15 Off
                    Voltage: 11.85 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:15
                        Term 15 Off
                    Voltage: 11.85 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:15
                        Term 15 Off
                    Voltage: 11.70 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:15
                        Term 15 Off
                    Voltage: 11.70 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:15
                        Term 15 Off
                    Voltage: 11.70 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:15
                        Term 15 Off
                    Voltage: 11.70 V
01835 - Bulb for Side-Blinkers; Right (M19)
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:15
                        Term 15 Off
                    Voltage: 11.65 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:13
                    Voltage: 11.60 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:15:13
                    Voltage: 11.60 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:14:19
                    Voltage: 12.00 V
                    Reset counter: 206
                    Mileage: 16360 km
                    Date: 2016.03.03
                    Time: 16:14:19
                    Voltage: 12.00 V
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 1K8 919 465     HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0479
   Revision: --------    Serial number: 39231519204642
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001006
   ROD: EV_EPHVA14VW364GP00.rod
Address 15: Airbags (J234)       Labels: None
   Part No SW: 2K5 959 655     HW: 2K5 959 655
   Component: VW10Airbag00H 008 0016
   Revision: --------    Serial number: 003QV0008E84
   Coding: 000000000000000000000000000000003048
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: F9BAA6A8785568F6B9-80AC
   Serial number: 3497ARB405F3C6BKP8PX
   Serial number: 3507ARB405D3C6BKN0UI
   Part No SW: 5K0 953 521 FT    HW: 5K0 953 569 BE
   Revision: FF010042    Serial number: 20150707100155
   Coding: 5080060000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 8346C4400A992226E3-80D6
Address 17: Instruments (J285)       Labels: None
   Part No SW: 2K5 920 876 A    HW: 2K5 920 876 A
   Component: KOMBI         H04 1009
   Coding: 180A000400
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: B32654801AB952A633-80E6
   Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1663
   Revision:   H57       Serial number: 060715F1002088
   Coding: 357430
   VCID: 8248C1441D832B2EE8-80D6
   Component: IMMO          H04 1009
   VCID: EA9889E40DF3D36E40-80BE
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 04 0173
   Coding: 0000000
   VCID: F6A0AD94814B078ED4-80A2
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: B93A66A8F0D5A8F6F9-80EC
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: F5A2AA989C4D0C96DD-80A0
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0241
   Serial number: VWZAZ2R8731579
   Coding: 063307013C00000011110001000808001F01008400200100CE
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: A00CABCCBB4FD93EDE-80F4
   Engine Control Module 2:
   Subsystem 1 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
End-------------------------(Elapsed Time: 01:09)--------------------------
17 MAP
;SW:2K5-920-876-A   HW:2K5-920-876-A ---  Instruments
;Component:KOMBI         H04 1009, Coding:180A000400
;EV_Kombi_UDS_VDD_RM09,A05730,EV_Kombi_UDS_VDD_RM09_SE36.rod
;Thursday,03,March,2016,18:42:00:36026
;VCDS Version: Release 15.7.4 (x64)  Data version: 20160216
;VCID: B32654801AB952A633-80E6
Activating and deactivating all development messages,not active
(1)-Additional coding-Speed source,via CAN
(2)-Additional coding-Coolant temperature source,via CAN
(3)-Additional coding-Tank characteristic curve,1
(4)-Additional coding-Number of fuel level sensors,1
(5)-Additional coding-Locking bit,locked
Automatic door locking,Yes
(1)-Component protection mode-Radio,not requested
(2)-Component protection mode-Navigation,requested
(3)-Component protection mode-Stopping distance reduction,not requested
(4)-Component protection mode-Vorhalt,not requested
Component protection showroom mode,not activated
Display correction of consumptions and operating range,100 %
Display correction of fuel gauge,0.0
Display depiction,Not available
Distance,16360 km
(1)-Emergency telephone number-Telephone number,
(2)-Emergency telephone number-Status,not active
(3)-Emergency telephone number-Preselection,
(1)-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SID on
(2)-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI)
(3)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation
(4)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure
(5)-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver
(6)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality
(7)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster
ESI: distance driven from inspection,16300 km
ESI: maximum value km-driving distance/inspection,30000 km
ESI: maximum value of time between inspections,744 d
ESI: minimum value km-driving distance/inspection,15000 km
ESI: minimum value of time between inspections,744 d
ESI: oil quality,good oil quality
ESI: Resetting ESI,Reset
ESI: soot entry,11300 km
ESI: thermal load,11500 km
ESI: time from inspection,171 d
FIX: Distance covered since last mileage-dependent inspection,16300 km
FIX: Max. distance until next mileage-related inspection,30000 km
FIX: Maximum time until next time-dependent inspection,730 d
FIX: Reset value for next mileage-dependent inspection,30000 km
FIX: Reset value for next mileage-dependent inspections,730 d
FIX: Time since last time-dependent inspection,184 d
Hour,17 H
Ignition active message; actuator,Driver door
Indicator light for start-stop operation,active
Language version,Dutch
Minute,42 min
Pause recommendation,Yes
Seat belt warning,Version 4
Service notification,30 d
Service notification in days,30 d
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,On
(6)-Service-key settings-p_main_switch_basis,On
Speed threshold of dynamic oil pressure warning,kein Offset
(1)-Units adjusted-Temperature,°C
(2)-Units adjusted-Distance,Kilometers
(3)-Units adjusted-Speed,Kilometers per hour
(4)-Units adjusted-Pressure,bar
(5)-Units adjusted-Volume,Liter
(6)-Units adjusted-Time,24h
(7)-Units adjusted-Date,dd_mm_yy
(8)-Units adjusted-Consumption,Liters per 100 km
Volume to be replenished,No
(1)-additional_adaption-Logic address,0
(2)-additional_adaption-Function status,No
indicator_celebration,not active
Service_Key_Clear_All_Counters,Yes
Twindrive,not active
(1)-velocity_detection-Speed source,Distance impulses
(2)-velocity_detection-Distance impulses,4
5F MAP
;SW:5C0-035-680-B   HW:5C0-035-680-B ---  Information Electr.
;Component:MU-S-N-ER     H20 0241, Coding:063307013C00000011110001000808001F01008400200100CE
;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_SE25.rod
;Thursday,03,March,2016,18:30:58:36026
;VCID: A00CABCCBB4FD93EDE-80F4
(1)-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
(2)-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
(1)-Audio Management Input Gain Generation 2-TV Tuner,-128
(2)-Audio Management Input Gain Generation 2-Radio (FM),4
(3)-Audio Management Input Gain Generation 2-Radio (AM),7
(4)-Audio Management Input Gain Generation 2-Digital radio (DAB),4
(5)-Audio Management Input Gain Generation 2-Satellite radio,5
(6)-Audio Management Input Gain Generation 2-Tuner_TI,-128
(7)-Audio Management Input Gain Generation 2-Media_AUXIN,-128
(8)-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
(9)-Audio Management Input Gain Generation 2-Media_CDA,0
(10)-Audio Management Input Gain Generation 2-Media_DVD,-128
(11)-Audio Management Input Gain Generation 2-Media_MFP,0
(12)-Audio Management Input Gain Generation 2-Media_BTDevice,-128
(13)-Audio Management Input Gain Generation 2-TA_Tuner_FM,7
(14)-Audio Management Input Gain Generation 2-Media_Bluray,-128
(15)-Audio Management Input Gain Generation 2-Media_HDMI,-128
(16)-Audio Management Input Gain Generation 2-Tuner_Online,-128
(17)-Audio Management Input Gain Generation 2-Media_Airplay,-128
(18)-Audio Management Input Gain Generation 2-Media_UPNP,-128
(19)-Audio Management Input Gain Generation 2-Media_Cloud,-128
(20)-Audio Management Input Gain Generation 2-Tuner_Personal,-128
(21)-Audio Management Input Gain Generation 2-Tone_Beep,-128
(22)-Audio Management Input Gain Generation 2-Tone_Warning,-128
(23)-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
(24)-Audio Management Input Gain Generation 2-Tone_Messaging,-128
(25)-Audio Management Input Gain Generation 2-Exbox_DMB,-128
(26)-Audio Management Input Gain Generation 2-Mirrorlink,-128
(27)-Audio Management Input Gain Generation 2-TTS_Nav,-128
(28)-Audio Management Input Gain Generation 2-TTS_SDS,-128
(29)-Audio Management Input Gain Generation 2-Phone_Voice,-128
(30)-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
(31)-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
(32)-Audio Management Input Gain Generation 2-HFP,-128
(33)-Audio Management Input Gain Generation 2-TV_AV_IN,-128
Audio Parameter,1
Base volume of speech output,50 %
Base volume of telephone,50 %
Bluetooth,On
Bluetooth: Sniff mode,OFF
CD eject button,Enabled
(1)-Check tone frequency-High note frequency range,4000 Hz
(2)-Check tone frequency-Medium note frequency range,1000 Hz
(3)-Check tone frequency-Low note frequency range,100 Hz
Confirmation of installation change,FF FF
Country identification; country of sale HMI,BE
Deactivate production mode,0
Developer mode,not activated
(1)-Electrical test of loudspeakers-Mode,automatic
(2)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
(3)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36
(4)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
(5)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36
(6)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
(7)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36
(8)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
(9)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36
(10)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
(11)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36
(12)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
(13)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36
(14)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
(15)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36
(16)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
(17)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36
(18)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
(19)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36
(20)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
(21)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36
(22)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
(23)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36
(24)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
(25)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36
(26)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
(27)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36
(28)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
(29)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36
(30)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
(31)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36
(32)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
(33)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36
Fee-based traffic information (TMC),32768
Infotainment Recorder,activated
(1)-Interface for external media; activation-Connection 1,activated
(2)-Interface for external media; activation-Connection 2,not activated
(3)-Interface for external media; activation-Connection 3,not activated
(4)-Interface for external media; activation-Connection 4,not activated
(1)-Locked menu contents-FB_TUNER_0,non_blocked
(2)-Locked menu contents-FB_TUNER_1,non_blocked
(3)-Locked menu contents-FB_TUNER_2,non_blocked
(4)-Locked menu contents-FB_TUNER_3,non_blocked
(5)-Locked menu contents-FB_TUNER_4,non_blocked
(6)-Locked menu contents-FB_TUNER_5,non_blocked
(7)-Locked menu contents-FB_TUNER_6,non_blocked
(8)-Locked menu contents-FB_TUNER_7,non_blocked
(9)-Locked menu contents-FB_TUNER_8,non_blocked
(10)-Locked menu contents-FB_TUNER_9,non_blocked
(11)-Locked menu contents-FB_TUNER_10,non_blocked
(12)-Locked menu contents-FB_TUNER_11,non_blocked
(13)-Locked menu contents-FB_TUNER_12,non_blocked
(14)-Locked menu contents-FB_TUNER_13,non_blocked
(15)-Locked menu contents-FB_TUNER_14,non_blocked
(16)-Locked menu contents-FB_TUNER_15,non_blocked
(17)-Locked menu contents-FB_MEDIA_0,non_blocked
(18)-Locked menu contents-FB_MEDIA_1,non_blocked
(19)-Locked menu contents-FB_MEDIA_2,non_blocked
(20)-Locked menu contents-FB_MEDIA_3,non_blocked
(21)-Locked menu contents-FB_MEDIA_4,non_blocked
(22)-Locked menu contents-FB_MEDIA_5,non_blocked
(23)-Locked menu contents-FB_MEDIA_6,non_blocked
(24)-Locked menu contents-FB_MEDIA_7,non_blocked
(25)-Locked menu contents-FB_MEDIA_8,non_blocked
(26)-Locked menu contents-FB_MEDIA_9,non_blocked
(27)-Locked menu contents-FB_MEDIA_10,non_blocked
(28)-Locked menu contents-FB_MEDIA_11,non_blocked
(29)-Locked menu contents-FB_MEDIA_12,non_blocked
(30)-Locked menu contents-FB_MEDIA_13,non_blocked
(31)-Locked menu contents-FB_MEDIA_14,non_blocked
(32)-Locked menu contents-FB_MEDIA_15,non_blocked
(33)-Locked menu contents-FB_MEDIA_16,non_blocked
(34)-Locked menu contents-FB_MEDIA_17,non_blocked
(35)-Locked menu contents-FB_MEDIA_18,non_blocked
(36)-Locked menu contents-FB_MEDIA_19,non_blocked
(37)-Locked menu contents-FB_MEDIA_20,non_blocked
(38)-Locked menu contents-FB_MEDIA_21,non_blocked
(39)-Locked menu contents-FB_MEDIA_22,non_blocked
(40)-Locked menu contents-FB_MEDIA_23,non_blocked
(41)-Locked menu contents-FB_PHONE_0,non_blocked
(42)-Locked menu contents-FB_PHONE_1,non_blocked
(43)-Locked menu contents-FB_PHONE_2,non_blocked
(44)-Locked menu contents-FB_PHONE_3,non_blocked
(45)-Locked menu contents-FB_PHONE_4,non_blocked
(46)-Locked menu contents-FB_PHONE_5,non_blocked
(47)-Locked menu contents-FB_PHONE_6,non_blocked
(48)-Locked menu contents-FB_PHONE_7,non_blocked
(49)-Locked menu contents-FB_PHONE_8,non_blocked
(50)-Locked menu contents-FB_PHONE_9,non_blocked
(51)-Locked menu contents-FB_PHONE_10,non_blocked
(52)-Locked menu contents-FB_PHONE_11,non_blocked
(53)-Locked menu contents-FB_PHONE_12,non_blocked
(54)-Locked menu contents-FB_PHONE_13,non_blocked
(55)-Locked menu contents-FB_PHONE_14,non_blocked
(56)-Locked menu contents-FB_PHONE_15,non_blocked
(57)-Locked menu contents-FB_NAV_0,non_blocked
(58)-Locked menu contents-FB_NAV_1,non_blocked
(59)-Locked menu contents-FB_NAV_2,non_blocked
(60)-Locked menu contents-FB_NAV_3,non_blocked
(61)-Locked menu contents-FB_NAV_4,non_blocked
(62)-Locked menu contents-FB_NAV_5,non_blocked
(63)-Locked menu contents-FB_NAV_6,non_blocked
(64)-Locked menu contents-FB_NAV_7,non_blocked
(65)-Locked menu contents-FB_NAV_8,non_blocked
(66)-Locked menu contents-FB_NAV_9,non_blocked
(67)-Locked menu contents-FB_NAV_10,non_blocked
(68)-Locked menu contents-FB_NAV_11,non_blocked
(69)-Locked menu contents-FB_NAV_12,non_blocked
(70)-Locked menu contents-FB_NAV_13,non_blocked
(71)-Locked menu contents-FB_NAV_14,non_blocked
(72)-Locked menu contents-FB_NAV_15,non_blocked
(73)-Locked menu contents-FB_NAV_16,non_blocked
(74)-Locked menu contents-FB_NAV_17,non_blocked
(75)-Locked menu contents-FB_NAV_18,non_blocked
(76)-Locked menu contents-FB_NAV_19,non_blocked
(77)-Locked menu contents-FB_NAV_20,non_blocked
(78)-Locked menu contents-FB_NAV_21,non_blocked
(79)-Locked menu contents-FB_NAV_22,non_blocked
(80)-Locked menu contents-FB_NAV_23,non_blocked
(81)-Locked menu contents-FB_NAV_24,non_blocked
(82)-Locked menu contents-FB_NAV_25,non_blocked
(83)-Locked menu contents-FB_NAV_26,non_blocked
(84)-Locked menu contents-FB_NAV_27,non_blocked
(85)-Locked menu contents-FB_NAV_28,non_blocked
(86)-Locked menu contents-FB_NAV_29,non_blocked
(87)-Locked menu contents-FB_NAV_30,non_blocked
(88)-Locked menu contents-FB_NAV_31,non_blocked
(89)-Locked menu contents-FB_NAV_32,non_blocked
(90)-Locked menu contents-FB_NAV_33,non_blocked
(91)-Locked menu contents-FB_NAV_34,non_blocked
(92)-Locked menu contents-FB_NAV_35,non_blocked
(93)-Locked menu contents-FB_NAV_36,non_blocked
(94)-Locked menu contents-FB_NAV_37,non_blocked
(95)-Locked menu contents-FB_NAV_38,non_blocked
(96)-Locked menu contents-FB_NAV_39,non_blocked
(97)-Locked menu contents-FB_CAR_0,non_blocked
(98)-Locked menu contents-FB_CAR_1,non_blocked
(99)-Locked menu contents-FB_CAR_2,non_blocked
(100)-Locked menu contents-FB_CAR_3,non_blocked
(101)-Locked menu contents-FB_CAR_4,non_blocked
(102)-Locked menu contents-FB_CAR_5,non_blocked
(103)-Locked menu contents-FB_CAR_6,non_blocked
(104)-Locked menu contents-FB_CAR_7,non_blocked
(105)-Locked menu contents-FB_CAR_8,non_blocked
(106)-Locked menu contents-FB_CAR_9,non_blocked
(107)-Locked menu contents-FB_CAR_10,non_blocked
(108)-Locked menu contents-FB_CAR_11,non_blocked
(109)-Locked menu contents-FB_CAR_12,non_blocked
(110)-Locked menu contents-FB_CAR_13,non_blocked
(111)-Locked menu contents-FB_CAR_14,non_blocked
(112)-Locked menu contents-FB_CAR_15,non_blocked
(113)-Locked menu contents-FB_CAR_16,non_blocked
(114)-Locked menu contents-FB_CAR_17,non_blocked
(115)-Locked menu contents-FB_CAR_18,non_blocked
(116)-Locked menu contents-FB_CAR_19,non_blocked
(117)-Locked menu contents-FB_CAR_20,non_blocked
(118)-Locked menu contents-FB_CAR_21,non_blocked
(119)-Locked menu contents-FB_CAR_22,non_blocked
(120)-Locked menu contents-FB_CAR_23,non_blocked
(121)-Locked menu contents-FB_MISC_0,non_blocked
(122)-Locked menu contents-FB_MISC_1,non_blocked
(123)-Locked menu contents-FB_MISC_2,non_blocked
(124)-Locked menu contents-FB_MISC_3,non_blocked
(125)-Locked menu contents-FB_MISC_4,non_blocked
(126)-Locked menu contents-FB_MISC_5,non_blocked
(127)-Locked menu contents-FB_MISC_6,non_blocked
(128)-Locked menu contents-FB_MISC_7,non_blocked
(129)-Locked menu contents-FB_MISC_8,non_blocked
(130)-Locked menu contents-FB_MISC_9,non_blocked
(131)-Locked menu contents-FB_MISC_10,non_blocked
(132)-Locked menu contents-FB_MISC_11,non_blocked
(133)-Locked menu contents-FB_MISC_12,non_blocked
(134)-Locked menu contents-FB_MISC_13,non_blocked
(135)-Locked menu contents-FB_MISC_14,non_blocked
(136)-Locked menu contents-FB_MISC_15,non_blocked
(137)-Locked menu contents-FB_MISC_16,non_blocked
(138)-Locked menu contents-FB_MISC_17,non_blocked
(139)-Locked menu contents-FB_MISC_18,non_blocked
(140)-Locked menu contents-FB_MISC_19,non_blocked
(141)-Locked menu contents-FB_MISC_20,non_blocked
(142)-Locked menu contents-FB_MISC_21,non_blocked
(143)-Locked menu contents-FB_MISC_22,non_blocked
(144)-Locked menu contents-FB_MISC_23,non_blocked
(145)-Locked menu contents-FB_MISC_24,non_blocked
(146)-Locked menu contents-FB_MISC_25,non_blocked
(147)-Locked menu contents-FB_MISC_26,non_blocked
(148)-Locked menu contents-FB_MISC_27,non_blocked
(149)-Locked menu contents-FB_MISC_28,non_blocked
(150)-Locked menu contents-FB_MISC_29,non_blocked
(151)-Locked menu contents-FB_MISC_30,non_blocked
(152)-Locked menu contents-FB_MISC_31,non_blocked
(153)-Locked menu contents-FB_MISC_32,non_blocked
(154)-Locked menu contents-FB_MISC_33,non_blocked
(155)-Locked menu contents-FB_MISC_34,non_blocked
(156)-Locked menu contents-FB_MISC_35,non_blocked
(157)-Locked menu contents-FB_MISC_36,non_blocked
(158)-Locked menu contents-FB_MISC_37,non_blocked
(159)-Locked menu contents-FB_MISC_38,non_blocked
(160)-Locked menu contents-FB_MISC_39,non_blocked
(161)-Locked menu contents-FB_MISC_40,non_blocked
(162)-Locked menu contents-FB_MISC_41,non_blocked
(163)-Locked menu contents-FB_MISC_42,non_blocked
(164)-Locked menu contents-FB_MISC_43,non_blocked
(165)-Locked menu contents-FB_MISC_44,non_blocked
(166)-Locked menu contents-FB_MISC_45,non_blocked
(167)-Locked menu contents-FB_MISC_46,non_blocked
(168)-Locked menu contents-FB_MISC_47,non_blocked
Menu entries for mobile online services,activated
Microphone sensitivity,0 dB
(1)-Navigation receiver GNSS configuration-Default,On
(2)-Navigation receiver GNSS configuration-GPS,OFF
(3)-Navigation receiver GNSS configuration-Galileo,OFF
(4)-Navigation receiver GNSS configuration-Glonass,OFF
(5)-Navigation receiver GNSS configuration-Compass,OFF
Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Production mode,00 00 00
Selection of release codes for a SWaP function,FF FF FF FF
Summertime-automatic,none
Wheel circ.,0 mm
Wheel pulse,0
WLAN,On
BAP_Debug_Mode_Release,not_released
Bluetooth_Phonebook_Access_Profile,PBAP
(1)-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
(2)-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
(3)-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated
(4)-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
(5)-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
(6)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated
(7)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
(8)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated
(9)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
(10)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
(11)-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
(12)-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
(13)-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
(14)-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
(15)-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
(16)-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
(17)-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
(18)-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated
(19)-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
(20)-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
(22)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated
(24)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
(25)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
(26)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
(27)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
(28)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated
(29)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
(30)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
(31)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated
(32)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
(33)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated
(34)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
(35)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
(36)-Car_Function_Adaptations_Gen2-menu_display_windows,not activated
(37)-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
(38)-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated
(39)-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
(40)-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
(41)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated
(42)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
(43)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated
(44)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
(45)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
(46)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
(47)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
(48)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated
(49)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
(50)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
(51)-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated
(52)-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
(53)-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated
(54)-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
(55)-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
(56)-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated
(57)-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
(58)-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated
(59)-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
(60)-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
(61)-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated
(62)-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
(63)-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated
(64)-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
(65)-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
(66)-Car_Function_Adaptations_Gen2-menu_display_sia,not activated
(67)-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
(68)-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated
(69)-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
(70)-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
(71)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
(72)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
(73)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated
(74)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
(75)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
(76)-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated
(77)-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
(78)-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated
(79)-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
(80)-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
(81)-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
(82)-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
(83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated
(84)-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
(85)-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
(86)-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated
(87)-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
(88)-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated
(89)-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
(90)-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
(91)-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
(92)-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
(93)-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated
(94)-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
(95)-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
(96)-Car_Function_Adaptations_Gen2-menu_display_vin,not activated
(97)-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
(98)-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated
(99)-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
(100)-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
(101)-Car_Function_Adaptations_Gen2-menu_display_clock,not activated
(102)-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
(103)-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated
(104)-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
(105)-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
(106)-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
(107)-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
(108)-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
(109)-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
(110)-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
(111)-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
(112)-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
(113)-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated
(114)-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
(115)-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
(116)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated
(117)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
(118)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated
(119)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
(120)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
(121)-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
(122)-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
(123)-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated
(124)-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
(125)-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
(126)-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
(127)-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
(128)-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
(129)-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
(130)-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
(131)-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
(132)-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
(133)-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
(134)-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
(135)-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
(136)-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
(137)-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
(138)-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
(139)-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
(140)-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
(141)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
(142)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
(143)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated
(144)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
(145)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
(146)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
(147)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
(148)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
(149)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
(150)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
(151)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
(152)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
(153)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated
(154)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
(155)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
(156)-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
(157)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
(158)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated
(159)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
(160)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
(161)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
(162)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
(163)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated
(164)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
(165)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
(166)-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated
(167)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
(168)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated
(169)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
(170)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
(171)-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
(172)-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
(173)-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated
(174)-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
(175)-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
(176)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated
(177)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
(178)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated
(179)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
(180)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
(181)-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated
(182)-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
(183)-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated
(184)-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
(185)-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
(186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated
(187)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
(188)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated
(189)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
(190)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
(191)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated
(192)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
(193)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated
(194)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
(195)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
(196)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated
(197)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
(198)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated
(199)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
(200)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
(201)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
(202)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
(203)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated
(204)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
(205)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
(206)-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
(207)-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
(208)-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated
(209)-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
(210)-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
(211)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
(212)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
(213)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated
(214)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
(215)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
(216)-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
(217)-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
(218)-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated
(219)-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
(220)-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
(221)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
(222)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
(223)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated
(224)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
(225)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
(226)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
(227)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
(228)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
(229)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
(230)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
(231)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
(232)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
(233)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated
(234)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
(235)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
(236)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
(237)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
(238)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated
(239)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
(240)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
(241)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
(242)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
(243)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated
(244)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
(245)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
(246)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
(247)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
(248)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
(249)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
(250)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
(251)-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
(252)-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
(253)-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
(254)-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
(255)-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
(256)-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
(257)-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
(258)-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
(259)-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
(260)-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
(261)-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
(262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
(263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
(264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
(265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
(266)-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
(267)-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
(268)-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
(269)-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
(270)-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
(271)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue,not activated
(272)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_clamp_15_off,not activated
(273)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_over_threshold_high,not activated
(274)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_standstill,not activated
(275)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_after_disclaimer,not activated
(276)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
(277)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
(278)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
(279)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
(280)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
(1)-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated
(2)-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated
(3)-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
(4)-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated
(5)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
(6)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated
(7)-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
(8)-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated
(9)-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
(10)-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated
(11)-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
(12)-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated
(13)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated
(14)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,not activated
(15)-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated
(16)-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated
(17)-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated
(18)-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated
(19)-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
(20)-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
(21)-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
(22)-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,not activated
(23)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated
(24)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated
(25)-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated
(26)-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated
(27)-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated
(28)-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated
(29)-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated
(30)-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated
(31)-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
(32)-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated
(33)-Car_Function_List_BAP_Gen2-clock_0x11,not activated
(34)-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated
(35)-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated
(36)-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated
(37)-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated
(38)-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated
(39)-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
(40)-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated
(41)-Car_Function_List_BAP_Gen2-compass_0x15,not activated
(42)-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated
(43)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
(44)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated
(45)-Car_Function_List_BAP_Gen2-charisma_0x17,not activated
(46)-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated
(47)-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
(48)-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated
(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
(50)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated
(51)-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
(52)-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated
(53)-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
(54)-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated
(55)-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
(56)-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated
(57)-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
(58)-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated
(59)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
(60)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated
(61)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20,not activated
(62)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20_msg_bus,not activated
(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
(64)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated
(65)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated
(66)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated
(67)-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
(68)-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated
(69)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
(70)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated
(71)-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
(72)-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated
(73)-Car_Function_List_BAP_Gen2-Brake_0x26,not activated
(74)-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated
(75)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated
(76)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated
(77)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
(78)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated
(79)-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
(80)-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated
(81)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
(82)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated
(83)-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
(84)-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated
(85)-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
(86)-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated
(87)-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
(88)-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated
(89)-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
(90)-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated
(91)-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
(92)-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated
(93)-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
(94)-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated
(95)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
(96)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated
(97)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
(98)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated
(99)-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
(100)-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated
(1)-Car_Function_List_CAN_Gen2-MFL,Not available
(2)-Car_Function_List_CAN_Gen2-MFL_msg_bus,Not available
(3)-Car_Function_List_CAN_Gen2-Oil_level,Not available
(4)-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available
(5)-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
(6)-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15
(7)-Car_Function_List_CAN_Gen2-VIN,Not available
(8)-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available
(9)-Car_Function_List_CAN_Gen2-Driving_school,Not available
(10)-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available
(11)-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
(12)-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available
(1)-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
(2)-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
(3)-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20
(4)-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20
(5)-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50
(6)-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50
(1)-Dimming_Illumination_for_Display_Unit-X1,3
(2)-Dimming_Illumination_for_Display_Unit-Y1,2 %
(3)-Dimming_Illumination_for_Display_Unit-X2,10
(4)-Dimming_Illumination_for_Display_Unit-Y2,10 %
(5)-Dimming_Illumination_for_Display_Unit-X3,15
(6)-Dimming_Illumination_for_Display_Unit-Y3,15 %
(7)-Dimming_Illumination_for_Display_Unit-X4,60
(8)-Dimming_Illumination_for_Display_Unit-Y4,90 %
(9)-Dimming_Illumination_for_Display_Unit-X5,0
(10)-Dimming_Illumination_for_Display_Unit-Y5,0 %
(11)-Dimming_Illumination_for_Display_Unit-X6,0
(12)-Dimming_Illumination_for_Display_Unit-Y6,0 %
Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 DC C8 96 82 96 82 DC C8 07 64 1E 04 10 03 0A 00 00 00 02 28
(1)-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
(2)-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
Startup_Screen_Sticker_HMI,00 00
(1)-Vehicle_configuration-VZAPro,OFF
(2)-Vehicle_configuration-online_POI,OFF
(3)-Vehicle_configuration-online_POI_voice,OFF
(4)-Vehicle_configuration-online_portal_browser_services,OFF
(5)-Vehicle_configuration-online_navigation,OFF
(6)-Vehicle_configuration-online_street_view,OFF
(7)-Vehicle_configuration-WIFI_Hotspot,On
(8)-Vehicle_configuration-my_audi,OFF
(9)-Vehicle_configuration-picture_navi,On
(10)-Vehicle_configuration-online_dictation,OFF
(11)-Vehicle_configuration-remote_HMI,OFF
(12)-Vehicle_configuration-advanced_range_display,OFF
(13)-Vehicle_configuration-gracenote_online_coverarts,OFF
(14)-Vehicle_configuration-gracenote_online_other,OFF
(15)-Vehicle_configuration-gracenote_local_coverarts,OFF
(16)-Vehicle_configuration-gracenote_local_other,OFF
(17)-Vehicle_configuration-UPnP,OFF
(18)-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF
(19)-Vehicle_configuration-Joker_button_1,Not Present
(20)-Vehicle_configuration-Joker_button_2,Not Present
(21)-Vehicle_configuration-LTE_modul,activated
(22)-Vehicle_configuration-Support_second_phone,On
(23)-Vehicle_configuration-Support_of_threeway_calling,OFF
(24)-Vehicle_configuration-Dtmf_without_active_call,On
(25)-Vehicle_configuration-Support_for_response_and_hold,OFF
(26)-Vehicle_configuration-Sim_card_mode_switch,Not Present
(27)-Vehicle_configuration-Phone_module_operation_mode,Data & language service active
(28)-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5
(29)-Vehicle_configuration-RVC_video_input,FBAS
(30)-Vehicle_configuration-Station_Logo_DB_Mode,1
(31)-Vehicle_configuration-TPEG_availability,OFF
(32)-Vehicle_configuration-VZO,OFF
(33)-Vehicle_configuration-LGI,OFF
(34)-Vehicle_configuration-ProbeCar_vzo,OFF
(35)-Vehicle_configuration-online_media,OFF
(36)-Vehicle_configuration-ProbeCar_lgi,OFF
(37)-Vehicle_configuration-NMH_stopwatch,OFF
(38)-Vehicle_configuration-Google_GAL,On
(39)-Vehicle_configuration-Apple_DIO,On
(40)-Vehicle_configuration-UOTA,OFF
(41)-Vehicle_configuration-WiFi_Client_HMI,OFF
