21 VW Atlas Getting No Response from Controller
Hankpuppy
Spotsylvania, VA, USA
C?ID=388015
Hi
I just registered my 21 VW Atlas prepping to do brake job this weekend and want to use VCDS to release the rear calipers; I upgraded to latest version as well as updated to latest firmware but when I open the menus I get "No Response from Controller".
I was able to do an auto scan and below is the output as well as screen captures.
Also what am I supposed to do with all those fault codes?
I appreciate the help.
Thursday,04,June,2026,20:51:14:09364
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
VIN: 1V2FR2CA4MC5xxxxx   License Plate:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 36 3C 42 44 47 4B 52 5F
          69 6C 6D 75 A5 CA D6 D7
VIN: 1V2FR2CA4MC5xxxxx   Mileage: 103457km-64285miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CDVC)       Labels:. 03H-907-309-V2.clb
   Part No SW: 03H 906 026 AJ    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 1017
   Revision: 52H21000    CVN: B2A48C75
   Coding: 012A003244740108F0000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM36FSI01103H906026AJ 001007
   ROD: EV_ECM36FSI01103H906026AG.rod
   VCID: 6D87CE212D13B722145-8038
   VINID: 0660968824D111D4C51C21471C00ED1E7E
Address 02: Auto Trans (J217)       Labels: 09P-927-749-V1.clb
   Part No SW: 09G 927 158 DR    HW: 09G 927 158
   Component: AISIN AQ8     206 3742
   CVN: ACC08B57
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 0655918D28A5647AF5F-8052
   Part No SW: 5Q0 614 517 GB    HW: 5Q0 614 517 BP
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 50551000000370
   Coding: 44FC6B8D80271A6EC57C0307A2CA6922D60158A3C045967638415058D2AA4A0B004023641C12141A1D8DDB45506CC8CF
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 77ABEC495F4F0DF2FE9-8022
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 24
                    Mileage: 102386 km
                    Date: 2026.05.15
                    Time: 19:22:40
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0566320789 Dataset Number: V03935312PG 0001
   Coding: 1F20000723
   Shop #: WSC 28555 006 1048576
   ROD: EV_KessyHellaMQBAB_VW41.rod
   VCID: 45D756815523AF62BC5-8010
   Power rear lid opening control module:
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 25155690
221445 - Sensor for Rear Lid/Hatch Opening
          B1303 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 240
                    Mileage: 60666 km
                    Date: 2024.10.17
                    Time: 14:59:08
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 12.909 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 738.5 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Driver´s door: Open
                    Passenger´s door: closed
                    Rear left door: closed
                    Rear right door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 3CN 907 044 AB    HW: 3CN 907 044 AB
   Component: Climatronic   H05 2401
   Revision: 00001K03
   Coding: 1602002620001C001104210C5210D534
   ASAM Dataset: EV_ACClimaBHBVW416 002015
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 7F5B0469777F35B2B69-802A
   Fresh air blower control module (rear):
   Part No SW: 5Q0 937 085 CG    HW: 5Q0 937 085 CG
   Component: BCM MQBAB HNA H42 0411
   Serial number: 1048063201ÿÿÿÿ Dataset Number: V03935331FE 0001
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021_VW26.rod
   VCID: 005987950A814A4ACF3-8054
   Subsystem 1 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S7Y20M12D22H13M37S31
   Coding: 00382D
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 KS    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 0300170220210C200782
   Subsystem 3 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0565043
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1596313
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0521039
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1596114
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000460609421043 Dataset Number: V03935323DK 0001
   Coding: 8271667951
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_VW41.rod
   VCID: 58E98FF5B291228AD73-800C
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H04 0383
   Dataset Number: V03935344SB 0001
   Coding: 320007DB5CFF8728949C810530409700000000000000000034
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_VW41.rod
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 33
                    Mileage: 97024 km
                    Date: 2026.02.19
                    Time: 18:17:45
                    Voltage terminal 15: 14.3 V
                    Control Module temperature: 43 °C
                    Vehicle speed: 8.89 m/s
                    Longitudinal acceleration: -1.81 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 33
                    Mileage: 97024 km
                    Date: 2026.02.19
                    Time: 18:17:45
                    Vehicle speed: 8.84 m/s
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 33
                    Mileage: 97024 km
                    Date: 2026.02.19
                    Time: 18:17:45
                    Vehicle speed: 8.94 m/s
                    Longitudinal acceleration: -1.84 m/s²
0858 - Databus
          [FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
                    Reset counter: 31
                    Mileage: 103134 km
                    Date: 2026.05.31
                    Time: 10:02:42
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 21 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.53 m/s²
   Part No SW: 3Q0 959 655 DM    HW: 3Q0 959 655 DM
   Component: Airbag VW21   007 0732
   Revision: --------    Serial number: 003013VM35U4 Dataset Number: V03935330AZ 0001
   Coding: 8CCCFC00000000005000001AC20840000065
   ROD: EV_AirbaVW21TS6VW48X_VW41.rod
   VCID: 0C41A3A536C91E2AA3B-8058
   Component: Occ.Detection  H16 0022
   Serial number: IBH0000D21000FJCPM0Q
   Coding: 303636
   Subsystem 2 - Part No SW: -----------    HW: 454 001 711 20
   Serial number: 35700000000B34E83E4X
   Subsystem 3 - Part No SW: -----------    HW: 454 001 811 20
   Serial number: 35800000000F7310DE4U
   Subsystem 4 - Part No SW: -----------    HW: 454 802 202 21
   Serial number: 35100790B601D000000D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 502 21
   Serial number: 352002F01601D0000005
   Subsystem 6 - Part No SW: -----------    HW: 454 802 202 21
   Serial number: 35500F9CF381D0000003
   Subsystem 7 - Part No SW: -----------    HW: 454 802 202 21
   Component: FrontSensor_P  304 0149
   Serial number: 356009FD2381D000000Z
   Part No SW: 3G0 920 420 B    HW: 3G0 920 420 B
   Component: KOMBI         502 5178
   Coding: 08A428086F8CCF050288624B10010000A0201009
   ASAM Dataset: EV_DashBoardVDDMQBA0 001044
   ROD: EV_DashBoardVDDMQBA0_001_VW41.rod
   VCID: 1D67DEE19D3387A2C45-8048
7 Faults Found:
16777012 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_VZA_0x21 keine Kommunikation]
                    Reset counter: 4
                    Mileage: 102153 km
                    Date: 2026.05.13
                    Time: 09:40:20
16777018 - Function Restricted due to Interrupted Communications
          [BAP_Audio_0x31 keine Kommunikation]
                    Fault Frequency: 189
                    Mileage: 60711 km
                    Date: 2024.10.17
                    Time: 19:45:18
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 33
                    Mileage: 103150 km
                    Date: 2026.05.31
                    Time: 10:21:27
16777022 - Function Restricted due to Interrupted Communications
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Fault Frequency: 25
                    Reset counter: 33
                    Mileage: 95909 km
                    Date: 2026.02.03
                    Time: 18:18:07
16777056 - Function Restricted due to Interrupted Communications
          [BAP_SDS_0x46 keine Kommunikation]
                    Fault Frequency: 193
                    Mileage: 60711 km
                    Date: 2024.10.17
                    Time: 19:45:18
16777030 - Function Restricted due to Interrupted Communications
          [BAP_TEL2_0x29 keine Kommunikation]
                    Fault Frequency: 192
                    Mileage: 60711 km
                    Date: 2024.10.17
                    Time: 19:45:18
16711685 - Databus
          [Datenbus fehlende Botschaft]
                    Fault Frequency: 148
                    Reset counter: 43
                    Mileage: 73292 km
                    Date: 2025.03.23
                    Time: 11:00:40
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 04022100842002 Dataset Number: V03935329FB 0001
   Coding: 0B0D00347F087300FB07225A1E0F00010001070000000000000000000000
   GVL: 01C63C0008000400C0DC80008082C80010000000000200000000000000000000
   ROD: EV_GatewNF_VW41.rod
   VCID: 74B1DB454E3966EADBB-8020
   Generator:
   Component: 5-01-15-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 S    HW: 3G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-YLG  H07 0110
   Serial number: YLG-0700084041210128
   Coding: 2E0B00
   Serial number: 7370477900
   Inverter for socket:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0890
   Serial number: B160303
131699 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Fault Frequency: 13
                    Reset counter: 33
                    Mileage: 97024 km
                    Date: 2026.02.19
                    Time: 18:17:46
                    Terminal 30 power supply: 14.2 V
                    Terminal 15: On
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00022.09.20 Dataset Number: v1260x015G0 0000
   Coding: 0301
   ROD: EV_AllWheelContrHA1VW37X_004_VW41.rod
   VCID: 4CC163A576495E2A63B-8018
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
   Component: Sitzmemory    H10 0026
   Serial number: Y0007TKE29622
   Coding: 0010000000000500018280808080000000008100000000F440
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide_VW41.rod
   VCID: 40D947954A018A4A8F3-8014
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 11230026981020  Dataset Number: V03935332MH 0001
   Coding: 62954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW41.rod
   VCID: 392F2A7129DBDB82C8D-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 11230029220038
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS003 0330
   Serial number: YA008UBA004SC Dataset Number: V03935346DY 0001
   Coding: 003F1B205200020000040000
   ROD: EV_DCU2DriveSideMAXHKLO_VW41.rod
   VCID: 49CF5AB1793B4B0258D-801C
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000007799891
   Coding: 011000
196676 - Door Warning / Entry Lighting
          B1775 01 [00001000] - Electrical Failure
                    Reset counter: 39
                    Mileage: 60666 km
                    Date: 2024.10.17
                    Time: 14:59:08
   Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
   Component: EPS_MQB_ZFLS  570 1582
   Dataset Number: V03935328UN 0001
   Coding: 9B1F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 47CB5C896F2FBD724E9-8012
   Part No SW: 5H0 035 456     HW: 5H0 035 456
   Component: AMPeth12C     H04 3327
   Serial number: A1129A00073465  Dataset Number: V03935333GS 0001
   Coding: 24000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW41.rod
   VCID: 6491AB05FED9F66A4BB-8030
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 19022100840727 Dataset Number: V03935326VF 0001
   Coding: 000000070900135202112300030000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372B2C491FCFCDF23E9-8062
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS003 0330
   Serial number: YA008UB9001QA Dataset Number: V03935346DZ 0001
   Coding: 003F13205E00020000040000
   ROD: EV_DCU2PasseSideMAXHKLO_VW41.rod
   VCID: 48C95FB56231B20A473-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000007802166
   Coding: 091000
                    Reset counter: 43
                    Mileage: 60814 km
                    Date: 2024.10.20
                    Time: 11:00:50
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 842 B    HW: 3G5 035 842
   Component: MU-O-NS-US    H56 0813
   Serial number: WG8LGM271120000 Dataset Number: V03935343FG 0001
   Coding: 24160000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_VW41.rod
   VCID: 270BFC09CF6F5D72AE9-8072
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  261 8214
   Serial number: VWZ6ZMY0536396
   Subsystem 2 - Part No SW: V03 959 809 CR    HW: -----------
   Component: NAR 2021       --- 5041
7201 - Function Restricted due to Interrupted Communications
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 1
                    Mileage: 102153 km
                    Date: 2026.05.13
                    Time: 09:40:23
                    BAP: 00
                    Voltage terminal 30: 14.2 V
6945 - Function Restricted due to Interrupted Communications
          [Road sign display (0x21) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 1
                    Mileage: 102153 km
                    Date: 2026.05.13
                    Time: 09:40:20
                    Voltage terminal 30: 14.1 V
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005698 Dataset Number: V03935297PW 0001
   Coding: 0200000200001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW41.rod
   VCID: 6B83C0391307B9120A1-803E
   Part No SW: 5Q0 907 556 D    HW: 5Q0 907 556
   Component: Areaview 2    H21 0609
   Serial number: C854711JJ000092 Dataset Number: V03935330QR 0001
   Coding: 01140604A30F200030204014
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW48.rod
   VCID: 3A2D357D2CDDD09AC17-806E
9591827 - Video Signal Line
          B125C 13 [00001000] - Open Circuit
                    Reset counter: 33
                    Mileage: 103150 km
                    Date: 2026.05.31
                    Time: 10:21:34
   Part No SW: 5WC 959 107     HW: 5WC 959 107
   Component: HDSG-Modul    H04 0430
   Revision: --------    Serial number: A2-C774-8980-3 Dataset Number: V03935348NS
   Coding: 0988
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_001_VW41.rod
   VCID: 0E45A9AD40D52C3A4DF-805A
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 285 B    HW: 5WA 035 285
   Component: OCUGen3High   H12 0318
   Serial number: 0000000103VIXF0 Dataset Number: V03935342UF 0001
   Coding: 024160201968AC209005460160502E07
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW41.rod
   VCID: 46D5518D6825A47AB5F-8012
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Reset counter: 30
                    Mileage: 97024 km
                    Date: 2026.02.19
                    Time: 18:17:46
                    Voltage terminal 30: 14.4 V
   Part No SW: 2Q0 980 653 B    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H13 1202
   Serial number: E57829512203470 Dataset Number: V03935347VY 0001
   Coding: 00000A08117EC020089F10001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW41.rod
   VCID: 34311B450EB926EA1BB-8060
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 30
                    Mileage: 103180 km
                    Date: 2026.05.31
                    Time: 16:19:33
15361024 - Component Protection
          U1101 00 [00001000] - Active
                    Reset counter: 1
                    Mileage: 102155 km
                    Date: 2026.05.13
                    Time: 09:45:07
                    Theft_protection_error_counter: 37
   Dataset Number: V03935322HK 0001
   Coding: 00804074160C
   ROD: EV_SunRoofCONTIAU736_009_VW41.rod
   VCID: 75B7E64145437FE2EC5-8020
   Part No SW: 992 941 572 AA    HW: 992 941 572 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_VW41.rod
   VCID: 629DAD1DE4CDF85AB97-8036
135744 - Position Sensor; Motor for Dynamic Cornering Lamps
          C133E F0 [00100000] - Implausible Signal
   Component: LED1R         H08 9002
End----------(Elapsed Time: 02:07, VBatt start/end: 12.3V/12.3V)-----------
------------------------------23 Faults Found------------------------------
Santos is correct. ABS is MK100IPB, and "IPB" stands for Integrated Parking Brake.
Instructions are HERE.
"Kill them all. Let God sort them out."
Er, clear them. Then see what comes back. :D
Hankpuppy
C?ID=388015
Ok just went outside and tried to get into that ABD menu and even though I didn't complete it (not ready to do it yet) it didn't give me that "No response from controller" error; One thing to note is that i guess when I'm done the instructions say to choose "Select End lining change mode" but on mine it says "End brake pad change mode", see picture below....
  • Agree
