AC blowing hot air
kwamequainoo92
New Britain, CT, USA
C?ID=530179
I have tried calibrating the blend motor but it’s not working still blowing cold air.
Dr Sheldon
Windsor UK
C?ID=334979
WOW - What a great first post - Full of information we need to help you !!
First post a complete Autoscan.
kwamequainoo92
C?ID=530179
It’s a 2017 a6 2.0T
kwamequainoo92
C?ID=530179
Oh sorry I said cold air. The AC is blowing hot/warm air. The control won’t go to max when it’s turned to the AC side but it would to go max when the heat it turned.
What does 08 report?
BJMProce
Fryslan, Netherlands
C?ID=646597
As suggested by Sheldon, please post auto scan.
Like this it will be just guessing.
Ziddywerks
Northern NJ USA
C?ID=208579
Refrigerant is okay.
Okay is not a spec. Was the system empty when you checked it? What was pulled out in terms of weight and what was put in? Was a leak check done? Was dye put in? How bout a auto scan with codes? How bout checking ac compressor shut off condition? These are all things that should have been done. I mean If you want the help to guess we can help you load the parts cannon.
Not trying to be a dick but it comes with the territory especially when your thread consists of 1 sentence and no auto scan or any relevant information other than " Refrigerant is Okay."
Vdub
C?ID=57533
Post an autoscan of your car between the </> tags.
Very often this model has a bad AC Pressure sensor behind the front-grill near the left headlight, probably seen in the autoscan.
