2018 toledo with no abs communication.
Already tested fuses/power supply, checked ground, checked bus voltage.
Tuesday,02,June,2026,14:30:10:45700
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.4
VIN: VSSZZZNHZJ15028twoeight License Plate:
Chassis Type: NH-SK25 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
03-ABS Brakes -- Status: Cannot be reached 0100
Address 01: Engine (J623-CXMA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FN HW: 04L 907 309 E
Component: R4 1.6l TDI H22 2065
Revision: 86H22--- CVN: 39BE2470
Coding: 01110032030501090000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM16TDI01104L906021FN 004005
ROD: EV_ECM16TDI01104L906021FN_004.rod
VCID: 76B5E299484C15FAE5F-8022
VINID: 9A38EAAAA798A9A0450022022003C87F91
8 Faults Found:
28386 - Coolant Pump 3
P26F5 00 [00100111] - Short to GND
10065 - Mass Air Flow Sensor (G70)
P0104 00 [10100111] - Intermittent
25195 - Intake Air Temp. Sensor (G42)
P0113 00 [00100111] - Signal too High
4984 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [00100111] - Electrical Fault
4985 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [00100111] - Electrical Fault
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [00100111] - Electrical Fault
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [00100111] - Electrical Fault
4713 - No Communication with ABS Brake Control Module
U0121 00 [10100111] - -
[Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
Readiness: 0 0 0 0 X
Address 03: ABS Brakes
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6P0 820 045 H HW: 6P0 820 045 H
Component: AC Manuell H01 0204
Serial number: 1707191B-0485
Coding: 001000001100000200
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 313F1185E1A272C270D-8064
262914 - Refrigerant Pressure
B10AB F0 [00001101] - Too Low
459012 - Databus
U1121 00 [00001101] - Missing Message
B10CD 00 [00001100] - -
[Funktionseinschränkung durch Energiemangement]
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-BCM-V1.clb
Part No SW: 6C0 937 089 E HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0101
Serial number: 006728033379
Coding: 0B0008404215005303A04080B107030800005000570A3514030000000000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_BCMA0 006004
ROD: EV_BCMA0_006_VW26.rod
VCID: 323D1E89E4A449DA097-8066
Driver door control module:
Subsystem 1 - Part No SW: 6V2 959 802 B HW: 6V2 959 802 B
Component: FHSG DRV 007 0001
Serial number: 00000000000005366428
Coding: 0D1200
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY17228003L
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000070373146
U1400 00 [00001001] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
134667 - Voltage Supply for Terminal 30 of Exterior Mirror Heating
B1900 13 [00001001] - Open Circuit
134923 - Voltage Supply for Terminal 30 of Rear Window Heating
B1901 13 [00001001] - Open Circuit
528917 - Databus
[ESP_21 Datenbus fehlende Botschaft]
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 3K H10 0054
Revision: -------- Serial number: 39231726801032 Dataset Number: V03935245CP 0001
Coding: 0001050001
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3C2130B136E08FAAD3B-8068
12656913 - Databus
[Bremsensteuergerät - ESP_10 - kein Signal/keine Kommunikation]
12656920 - Databus
[Bremsensteuergerät - ESP_21 - kein Signal/keine Kommunikation]
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 L HW: 6C0 959 655 L
Component: VW20Airbag85E 002 0380
Revision: -------- Serial number: 003TK001BLUT Dataset Number: 605003T____ 0354
Coding: 88CCC00000800000540000C8008800000000
ROD: EV_AirbaVW20BPAVW26X_VW26.rod
Subsystem 1 - Part No SW: ----------- HW: 442 151 008 17
Component: SideSensor_Df 1CA 0148
Serial number: 3497A00BB2772293316B
Subsystem 2 - Part No SW: ----------- HW: 442 151 008 17
Component: SideSensor_Pf 1CA 0148
Serial number: 3507A00B52777833C0BF
Subsystem 3 - Part No SW: ----------- HW: 442 151 008 17
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00BB2772291A27B
Subsystem 4 - Part No SW: ----------- HW: 442 151 008 17
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00B527778364247
B13BC F2 [10001001] - No function
1052672 - Databus
[NWD: 0x392 ESP_07 Timeout]
1052928 - Databus
[NWD: 0x0FD ESP_21 Timeout]
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI3
Part No SW: 6JA 920 941 J HW: 6JA 920 941 J
Component: KOMBI 204 2317
Coding: 272404002180A60001082A001000000000000000
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 44D148514E10F76AABB-8010
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001001] - -
[BAP_Audio_0x31 keine Kommunikation]
[BAP_TEL_0x28 keine Kommunikation]
16776968 - Databus
[ESP_24 keine Kommunikation]
16776973 - Databus
[RKA_01 keine Kommunikation]
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0101
Revision: -------- Serial number: 006728033379
Coding: 030100040F005A0000000000000000010001050000000000000000000000
GVL: 01443C0000000000400000000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_SK25.rod
VCID: 2615F2D9D86C257A95F-8072
Subsystem 1 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000I1548250717
Coding: 002000
Subsystem 2 - Part No SW: 6C0 915 181 E HW: 6C0 915 181 E
Serial number: 8143354904
131603 - No Communication with ABS Brake Control Module
U0121 00 [00001001] - -
[Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [00001000] - -
[Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
131699 - Control unit for information electronics 1
U1054 00 [00001001] - No Communication
[Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AK HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3250
Serial number: CH9C0468 Dataset Number: V03935252FD 0001
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 72BDDE89242409DAC97-8026
8 Faults Found:
1055232 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[DEM_LOW_BATT_FAULT]
1058048 - Databus
[DEM_WHEEL_SPD_ABSENT_FAULT]
1054720 - Databus
[DEM_VEH_SPD_ABSENT_FAULT]
1095680 - Databus
[DEM_ACCEL_MSG_ABSENT_FAULT]
1096704 - Databus
[DEM_BRAKE_PRESS_MSG_ABSENT_FAULT]
1106944 - Databus
[DEM_WHEEL_PULSE_MSG_ABSENT_FAULT]
1088512 - Databus
[DEM_WHEEL_SIZE_MSG_ABSENT_FAULT]
1089536 - Databus
[DEM_ESP_STATUS_MSG_ABSENT_FAULT]
End-----(Elapsed Time: 00:46, VBatt start/end: 9.5V/9.6V. VIgn 9.5V)-------
------------------------------35 Faults Found------------------------------
