1999 VW B5 Passat 2.8L
darksim905
New Jersey, USA
C?ID=259537
Beware, this is an ugly scan. :(
Thursday,25,February,2016,19:06:06:34948
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
   Mileage: 350500km-217790miles
Address 01: Engine        Labels: 078-907-551-AHA.lbl
   Part No: 4D0 907 551 AH
   Component: 2.8L V6/5V  MOTR AT D04
   Coding: 06151
   Shop #: WSC 05311
   VCID: 6CD79BAD1C03735E91-4B00
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
16839 - EVAP System
            P0455 - 35-10 - Large Leak Detected - Intermittent
16521 - Oxygen (Lambda) Sensor B1 S2
            P0137 - 35-10 - Signal too Low - Intermittent
Readiness: 0000 0101
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8D0 927 156 BR
   Component: AG5 01V 2.8l5V  USA 8511
   Coding: 00000
   VCID: 7EF3A1E57A7FF1CE2F-4B00
            27-00 - Implausible Signal
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 8E0 614 111 C
   Component: ABS/ASR 5.3 FRONT   D10
   Coding: 00003
   Shop #: WSC 05314
   VCID: 1E3381659A3F51CE4F-515E
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 607 B
   Component: AIRBAG VW3 S        V04
   Coding: 00066
   Shop #: WSC 05311
   VCID: 2C575BADDC83B35ED1-4B32
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            25-10 - Unknown Switch Condition - Intermittent
Address 17: Instruments        Labels: 3B0-919-xxx-17.lbl
   Part No: 3B1 919 930 G
   Component: B5-KOMBIINSTR. VDO V01
   Coding: 06262
   VCID: 2C575BADDC83B35ED1-515E
   Part No: 1J0 959 799 AJ
   Component: 63 Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 05311
   VCID: 0603C90522AFA90E67-4B00
   Subsystem 1 - Part No: 1J1959801D
   Component: 63 Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802E
   Component: 63 Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811D
   Component: 63 Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812D
   Component: 63 Tõrsteuerger. HR0002r
13 Faults Found:
00953 - Interior Light Time limit
01329 - Convenience System Data Bus in Emergency Mode
            35-10 -  -  - Intermittent
            35-00 -  -
            35-00 -  -
   Part No: 1J0 035 180 D
   Component:  RADIO 3CP         0001
   Coding: 00403
   Shop #: WSC 08207
   VCID: 204FBF9DA04B673E7D-4B00
00856 - Radio Antenna
            36-00 - Open Circuit
00855 - Connection to CD changer
            49-00 - No Communications
End-------------------------(Elapsed Time: 04:59)--------------------------
I'll post a 'cleaner' scan tomorrow as I think some of these faults may have disappeared while driving around. To my knowledge, these are the original coding values, I can't imagine anyone has messed with this vehicle other than the CCM wiring harness being damaged, or water logged. I'm unsure if this is useful information as I'm sure Ross-Tech, UWE & the like are probably focusing on the latest & greatest, but I'm posting it here in the hopes it helps in some capacity.
darksim905
New Jersey, USA
C?ID=259537
I just realized this forum was for clean scans only. Apologies. I can't seem to find the delete or edit link :-\
No worries. The scans don't have to be "clean".
