RNS-510 Retrofit to Jetta Hybrid and Energy Flow display
StuartQF
C?ID=131089
Hi there,
I was wondering if anyone has ever attempted this before.
I have succesfully installed my RNS-510 in my 2013 Jetta Hybrid Trendline, which did not come with the Energy Flow display. I've seen mention of the early Touareg Hybrid displaying energy flow on an RNS-510, so in theory it's possible.
If anyone has any suggestions it would be most welcome :)
Here's an autoscan.
Monday,17,February,2014,14:17:17:09090
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: 3VW637AJ1DM280254   License Plate: HYBRID
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 51 52 56 61 62 72
          77 8C
Address 01: Engine (J623-CNLA)       Labels: None
   Part No SW: 04E 906 023     HW: 04E 907 309 B
   Component: 1.4l TFSI hy  H01 5631
   Revision: V8H01---    Serial number: 00000000000000
   Coding: 00250012442401000000
   Shop #: WSC 95243 999 19308
   ASAM Dataset: EV_ECM14TFS01104E906023 002018
   ROD: EV_ECM14TFS01104E906023.rod
   VCID: DDBBDF0ECC128CF65F5-8088
20575 - Inverter Cooling System
          P0A93 00 [096] - Inadequate Performance
                    Mileage: 3635 km
                    Date: 2010.14.14
                    Time: 18:46:58
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [032] - Open or Short to Plus
                    Mileage: 3635 km
                    Date: 2010.14.14
                    Time: 18:46:58
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [036] - -
                    Mileage: 4038 km
                    Date: 2010.14.21
                    Time: 08:05:34
10593 - Cylinder 3
          P0303 00 [036] - Misfire Detected
                    Mileage: 4038 km
                    Date: 2010.14.21
                    Time: 08:05:39
Address 02: Auto Trans        Labels: 0CW-927-769.clb
   Part No SW: 0CG 300 045 A    HW: 0AM 927 769 H
   Component: GSG DSG AG7     431 4002
   Revision: 00043014    Serial number: CU501212165946
   Shop #: WSC 00066 000 00000
   VCID: 27573DE696CE9626F59-8072
005913 - Functionality limited due to Engine Control Module
               P1719 - 000 -  - Intermittent
                    Reset counter: 9
                    Mileage: 4038 km
                    Date: 2010.14.21
                    Time: 08:05:02
   Part No SW: 1K0 907 379 AR    HW: 1K0 907 379 AR
   Component: ESP MK60EC1   H31 0135
   Revision: 00H31001
   Coding: A14B400C492A20FA850D02E9921D0440211800
   VCID: 8201CC721D2C130E027-80D7
   Part No SW: -----------    HW: -----------
   Component: Climatronic   0202
   Revision: --------
   Coding: 0010404002
   Shop #: WSC 00066 000 00118
   ASAM Dataset: EV_ACClimaBHBVW361Hybri 001001
   ROD: EV_ACClimaBHBVW361Hybri.rod
   VCID: EFE795C636BE0E66FD9-80BA
   Air Conditioning Compressor:
   Subsystem 1 - Part No SW: 5C0 820 803 F    HW: 5C0 820 803 F
   Component: J842 eKK  H03 0001
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 118
9480753 - A/C Compressor
          U103B 00 [008] - No Communication
                    Reset counter: 189
                    Mileage: 4038 km
                    Date: 2010.14.18
                    Time: 18:46:16
9477872 - AC Compressor First Run-In
          B109E F0 [009] - Not Performed
                    Reset counter: 118
13646848 - A/C Compressor
          U103C 00 [008] - Implausible Signal
                    Reset counter: 182
                    Mileage: 3574 km
                    Date: 2010.14.14
                    Time: 15:44:27
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 1068
   Revision: BG021001
   Coding: 2D200A3A812F3EC400880881040000440100008640808D605C8026000043
   VCID: 3973EB9EB07A10D693D-806C
                    Fault Status: 00101010
                    Reset counter: 190
                    Mileage: 4038 km
                    Date: 2010.14.21
                    Time: 08:05:00
                    Voltage: 13.90 V
   Part No SW: 5C0 959 655 J    HW: 5C0 959 655 J
   Component: AirbagVW10    101 0911
   Serial number: 003KLD00571R
   Coding: 00004838
   Shop #: WSC 00066 790 00185
   ASAM Dataset: EV_AirbaVW10SMEVW360 001024
   ROD: EV_AirbaVW10SMEVW360_VW01.rod
   VCID: 3973EB9EB87A10D693D-806C
   Serial number: 6940000Y130000RHPU0R
   Coding: 303036
   Serial number: 3572MSME2C077375ZZZ-
   Serial number: 3582MSME5E087375ZZZ0
   Serial number: 3516KSME5E310A22ZZZQ
   Serial number: 3526KSME7A307F21ZZZZ
   Serial number: 3556LSME290E3821ZZZX
   Crash sensor for front airbag; passenger side:
   Serial number: 3566LSME5F493721ZZZ+
   Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MAH000X0
   Coding: 088A140000
   ROD: EV_SMLSNGKUDS.rod
   VCID: 42818C72D5AC530EC27-8017
   Serial number: 0002361 FLE 20130105
   Coding: 820000
   Part No SW: 5C6 920 870 D    HW: 5C6 920 870 D
   Component: KOMBI         H08 0710
   Coding: 381E00
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 2C5DC2CA4728B57E18B-8079
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 27021303281599
   Coding: 351002
   VCID: 75EB27AEDCE2B4B6B75-8020
   Component: IMMO          H08 0710
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EAD184D20D5CEB4EAA7-80BF
   Part No SW: 3C0 035 684 K    HW: 3C0 035 684 F
   Component: RNS-MID       H61 4366
   Revision: AB001001    Serial number: VWZ6Z7L7294108
   Coding: 00010400000000900006
   VCID: 2B5FC1D64A26B246111-807E
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V6  7963
02633 - Antenna for Satellite Tuner
                    Fault Frequency: 19
                    Reset counter: 151
                    Mileage: 4032 km
                    Reset counter: 151
                    Mileage: 4032 km
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0006355144
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: DBBFD116D20682C6211-808E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000007588598
   Coding: 000490
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3777EDA6466E06A6659-8062
   Part No SW: 5C0 907 080 E    HW: 5C0 907 080 C
   Component: VW361H0108000 H02 0535
   Revision: 00H02000    Serial number: 00000000000000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM04510115C0907080E 001021
   ROD: EV_DMCM04510115C0907080D.rod
   VCID: 254B37EE24C28436C75-8070
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0006352806
   Coding: 0004B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: DCBDD20AD70885FE28B-8089
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1508
   Serial number: 00000007607232
   Coding: 000490
                    Fault Frequency: 19
                    Reset counter: 151
                    Mileage: 4032 km
                    Reset counter: 151
                    Mileage: 4032 km
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 16660164
   VCID: F1E393BE288A1896EBD-80A4
   Subsystem 1 - Part No SW: 1S0 915 181 A    HW: 1S0 915 181 A
   Component: J367-BDM  H08 0181
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007665015491
   Coding: 0A00000000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A71F492BD7C1BCE9A7-806F
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
                    Reset counter: 150
                    Mileage: 4038 km
                    Date: 2010.14.18
                    Time: 18:54:24
   Part No SW: 5C6 915 182 B    HW: 5C6 915 182 B
   Component: BECM          H09 0601
   Serial number: 288 SYEQA02B31
   ASAM Dataset: EV_BECM06020115C6915182 005021
   ROD: EV_BECM06020115C6915182.rod
   VCID: 2A51C4D24DDCAB4EEA7-807F
United States
The newer 7P VW Touareg uses the RNS-850 and that infotainment system is similar to the fiber optic (4G) A6/A7 Audi models.
I don't know if this menu is possible but are you sure the Hybrid comparison vehicle had one of the older 7L6 Touareg specific RNS-510 units installed? If you happen to have a scan from the example vehicle please post it or a link to it.
