Does anyone know to calibrate steering angle sensor on MQB Golf/Leon etc.?
The procedure from this post http://forums.ross-tech.com/showthr...ensor-(G85)-Calibration-in-44-Steering-Assist doesn't work.
Sorry for the translated scan, I just have enough time to do it only with Polish version since the car is away for couple of days
Monday, 29 February, 2016.22: 55: 05: 49923
VCDS - Emulator VAG / VAS working in the Windows environment are working on Windows 7 x64
VCDS Version: AKP 15.7.3.1
Data version: 20160206
www.vcds.pl
VIN: VSSZZZ5FZER005746 Registration number:
Mileage: 26399km number of repair:
Floor type: 5F (5Q0)
Scanning: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZER005746 Mileage: 26399km
01-Engine - Status: Malfunction 0010
03-ABS / Brakes - Status: Malfunction 0010
08-conditioning - State: OK 0000
09-Centr.zesp.elektr. - Status: Malfunction 0010
10-Asyst.park./kierow. - Status: Malfunction 0010
15-Airbag - Status: Malfunction 0010
16-wheel steering - Status: OK 0000
17-Zest.wskaźników - Status: OK 0000
19-CAN Gateway - Status: Malfunction 0010
42-Elektr.drzwi hearts. - Status: OK 0000
44-Wsp.kierownicy - Status: Malfunction 0010
52-Elektr.drzwi belt. - Status: OK 0000
55-Light range - Status: Malfunction 0010
5F-Elektr.informacji - Status: OK 0000
Address 01: Engine (J623-CLHA) File Label: None
Marking element SW: 04L 906 021 F HW: 04L 907 309 B
Component: 1.6L R4 EDC X22 5517
Revision: 84X22 ---
Encoding: 01110012032401090000
Service Code: WSC 92521 052 00000
ASAM data set: 002009 EV_ECM16TDI01104L906021M
ROD: EV_ECM16TDI01104L906021M_SE37.rod
VCID: 2F677AC076DE4F46D9-807A
3 - the number of errors found. Here they are:
5608 - No communication with the steering wheel angle sensor (G85)
U0126 00 [036] - -
Sporadic - Unconfirmed - Tested on reset error codes
Frame frozen:
State error: 00000001
Priority Error: 6
Frequency of error: 1
Mileage: 26399 km
Date: 2016.02.29
Time: 10:45:40 p.m.
7150 - received incorrect data from the driver steering angle sensor (G85)
U0428 00 [047] - -
Confirmed - Tested on reset error codes
Frame frozen:
Priority Error: 6
Mileage: 26386 km
Date: 2016.02.29
Time: 9:20:48 p.m.
17158 - Data Bus
U1123 00 [047] - received the value of the fault
Frame frozen:
Priority Error: 6
Frequency of error: 2
Mileage: 26386 km
Date: 2016.02.29
Time: 9:20:47 p.m.
Codes readiness: 0 0 0 0 0
Address 03: ABS / brakes (J104) File Label: None
Marking element SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial Number: 612830000002A7
Encoding: 18EE629224200971007E060441C9241846249000608224F200410060C002
Service Code: WSC 00049 770 00106
ASAM data set: 033001 EV_Brake1UDSContiMK100ESP
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 4B9F0E50E2061366D5-801E
4 - the number of errors found. Here they are:
0166 - Sensor angle
B1168 31 [008] - No Signal
Sporadic - Confirmed - Tested on reset error codes
Frame frozen:
Priority Error: 2
Wew.licznik errors: 156
Mileage: 26399 km
Date: 2016.02.29
Time: 10:45:40 p.m.
0295 - Sensor angle
B1168 54 [137] - No calibration
MIL lit - Confirmed - Tested on reset error codes
Frame frozen:
Priority Error: 2
Wew.licznik errors: 116
Date: 2016.02.29
Time: 10:42:55 p.m.
8277 - Data bus
U1122 00 [009] - unbelievable information
Frame frozen:
Priority Error: 6
Date: 2016.02.29
Time: 10:42:55 p.m.
16390 - Unknown error code
C1146 02 [137] - Signal Fault
Frame frozen:
Priority Error: 6
Mileage: 26399 km
Date: 2016.02.29
Time: 10:43:04 p.m.
Address 08: Air conditioning (J255) File Label: 5G0-907-044.clb
Marking element SW: 5F0 907 044 E HW: 5F0 907 044 E
Component: Climatronic H03 0705
Revision: 00001K07
Encoding: 04000104202100011005000000101000
ASAM data set: 003017 EV_ACClimaBHBVW37X
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 285591DC5330187E18-807C
No errors were found.
Address 09: Centr.zesp.elektr. (J519) File Label: None
Marking element SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial Number: 00011312200189
Encoding: 08000A46420102FB4B644000401C07081000000000000000000000000000
Service Code: WSC 00049 770 00126
ASAM data set: 011001 EV_BCMCONTI
ROD: EV_BCMBOSCH_SE37.rod
VCID: 77F782A0CE0E478641-8022
Slave 1:
Subsystem 1 - Marking element SW: 5F1 955 119 HW: 5F1 955 119 File Label: 5QX-955-119-V1.CLB
Component: WWS370 130 516 041 0574
Serial number: 130518200220
Encoding: 0BC5FD
Slave 2:
Subsystem 2 - Marking element SW: 5Q0 955 547 HW: 5Q0 955 547 File Label: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M05D25H16M43S21S4
Encoding: 00885D
2 - the number of errors found. Here they are:
555285 - Data bus
U1121 00 [008] - a lack of information
Frame frozen:
Priority Error: 6
Mileage: 26399 km
Date: 2016.02.29
Time: 10:45:40 p.m.
787462 - Relay headlight cleaning system
B1262 15 [009] - Open circuit or short circuit to positive
Frame frozen:
Priority Error: 4
Wew.licznik errors: 115
Mileage: 26386 km
Date: 2016.02.29
Time: 9:20:47 p.m.
Address 10: Asyst.park./kierow. (J791) File Label: 5Q0-919-294.clb
Marking element SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Review: -------- Serial Number: 94231313903196
Encoding: 0011051001
ASAM data set: 002016 EV_EPHVA18AU3700000
ROD: EV_EPHVA18AU3700000_AU37.rod
VCID: 3A715B94BD9C9AEE7E-806E
13637426 - Data bus
U1123 00 [009] - received the value of the fault
Frame frozen:
Priority Error: 6
Mileage: 26386 km
Date: 2016.02.29
Time: 9:20:47 p.m.
13638914 - Data bus
Frame frozen:
Priority Error: 6
Mileage: 26399 km
Date: 2016.02.29
Time: 10:45:40 p.m.
Address 15: Airbag (J234) File Label: 5Q0-959-655.clb
Marking element SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Review: -------- Serial Number: 003P4P9RJZP0
Encoding: 98CCC000000000005C0000CC000800000065
ASAM data set: 001116 EV_AirbaVW20TS6VW48X
ROD: EV_AirbaVW20TS6VW48X_SE37.rod
VCID: 7F076A80E63E7FC609-802A
Impact sensor side airbag bezp.po driver's side:
Subsystem 1 - Marking element SW: HW ----------- 454 002 504 13
Serial number: 3576U000000262CCAC0L
Encoding: 2D2D2D
Impact sensor side airbag on the passenger side bezp.po:
Subsystem 2 - Marking element SW: HW ----------- 454 002 405 13
Serial number: 3586U0000003D638EC0P
Encoding: 2D2D2D
Impact sensor side airbag bezp.z back of the str.kierowcy:
Subsystem 3 - Marking element SW: HW ----------- 454 801 505 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R72235E01000000X
Encoding: 2D2D2D
The sensor pads zderz.bocznej bezp.z back of the str.przedn.pasaż .:
Subsystem 4 - Marking element SW: HW ----------- 454 801 505 13
Component: SideSensor_Pr 111 0148
Serial number: 3526RBCE65701000000D
Encoding: 2D2D2D
Impact sensor front airbags bezp.po driver's side:
Subsystem 5 - Marking element SW: HW ----------- 454 801 612 14
Component: FrontSensor_D 114 0149
Serial number: 3556V50254905000000.
Encoding: 2D2D2D
9438747 - Fuse belt pretensioner on the driver's side
B1006 1B [137] - Resistance too high
Frame frozen:
Priority Error: 2
Mileage: 26386 km
Date: 2016.02.29
Time: 9:20:47 p.m.
1050112 - Data bus
Frame frozen:
Priority Error: 6
Mileage: 26399 km
Date: 2016.02.29
Time: 10:45:41 p.m.
Address 16: Steering wheel (J527) File Label: 5Q0-953-549.clb
Marking element SW: 5Q0 953 507 AC HW: 5Q0 953 549
Review: -------- Serial Number: 23051304400424
Encoding: 9400
ASAM data set: 009001 EV_SMLSKLOMQB
ROD: EV_SMLSKLOMQB_SE37.rod
Address 17: Zest.wskaźników (J285) File Label: 5G0-920-XXX-17.clb
Marking element SW: 5F0 920 861 A HW: 5F0 920 861 A
Component: ESTATE 203 2210
Encoding: 07A40A002980000800082A00000000
ASAM data set: 008031 EV_DashBoardVDDMQBAB
ROD: EV_DashBoardVDDMQBAB_SE37.rod
VCID: 26499FE459240E0E2A-8072
Address 19: CAN Gateway (J533) File Label: 5Q0-907-530-V1.clb
Marking element SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW High MQB 125 1144
Review: -------- Serial number: 0000635832
Encoding: 030100F40B087600EF000248080F00010001000000000000000000000000
ASAM data set: 009013 EV_GatewLear
ROD: EV_GatewLear.rod
VCID: 3B7F5E90B2A6A3E665-806E
alternator:
Multifunction controller unit:
Subsystem 2 - Marking element SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL FP6-H03 0100
Serial number: 000000000A0164220413
Encoding: 002000
Found 1 error:
197175 - controller control system battery
U1050 00 [009] - lack of communication
Frame frozen:
Priority Error: 2
Mileage: 26386 km
Date: 2016.02.29
Time: 9:20:47 p.m.
Address 42: Elektr.drzwi hearts. (J386) File Label: 5QX-959-X93-42.clb
Marking element SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000062820635
Encoding: 00100320C000020100001000
ASAM data set: 006001 EV_DCUDriveSideEWMAXCONT
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 0201E37495CC122E66-8056
Address 44: Wsp.kierownicy (J500) File Label: 5Q0-909-144.clb
Marking element SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Encoding: 0002
Service Code: WSC 00011 888 182020
ASAM data set: 012140 EV_SteerAssisMQB
ROD: EV_SteerAssisMQB.rod
VCID: 438F2670CA56DB262D-8016
Found 1 error:
15873 - steering angle sensor
B1168 54 [009] - No calibration
Frame frozen:
Priority Error: 1
Mileage: 26399 km
Date: 2016.02.29
Time: 10:46:47 p.m.
Address 52: Elektr.drzwi belt. (J387) File Label: 5QX-959-X92-52.clb
Marking element SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000062578308
ASAM data set: 006001 EV_DCUPasseSideEWMAXCONT
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 0103EC7890CA09367F-8054
Address 55: Light range (J431) File Label: 5Q0-907-357.clb
Marking element SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Review: -------- Serial Number: --------------
Encoding: 048A000009000000
ASAM data set: 001110 EV_HeadlRegulVWLWRMQB
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75EB88A8D402359653-8020
13705474 - Data bus
Frame frozen:
Priority Error: 2
Mileage: 26399 km
Date: 2016.02.29
Time: 10:45:40 p.m.
13705992 - Data bus
U1123 00 [137] - received the value of the fault
Frame frozen:
Priority Error: 6
Frequency of error: 25
Mileage: 26386 km
Date: 2016.02.29
Time: 9:20:47 p.m.
Address 5F: Elektr.informacji (J794) File Label: None
Marking element SW: 5F0 035 869 B HW: 5F0 035 869 B
Component: MU-E - ER 170 0147
Review: -------- Serial number: 000086821602000
Encoding: 04731000BE00000011110001000000002F0004840000010000
ASAM data set: 004052 EV_MUEnt4CCONT
ROD: EV_MUEnt4CCONT_SE37.rod
VCID: 2C5D6DCC47C8345EFC-8078
End -------------------- (Scan lasted: 2:59) --------------------- -
