VCDS no longer communication with my Fabia, previously fine
Marksman
C?ID=522337
Hi,
As the title, went to scan the fabia and get this message ? therefore I can't obtain a full vehicle scan.
Tried on my Golf and it's fine ?
I get the same message when I manually enter the vehicle details
Any assistance welcomed
Ralf@MFT
C?ID=56967
Your Batterie Voltage is bit low... So now surprice it wont work.
Marksman
C?ID=522337
Vehicle battery 13.97v, OBD port voltage 13.5v
Or is there a battery in the hex-v2 unit ?
On the scan , in post #1, VIgn. Voltage is only 4.9V , check your DLC connection. The pin(s) are not contacting properly to the VCDS plug.
Marksman
C?ID=522337
@stefdds
thanks, any idea of the pins the require testing ?
Marksman
C?ID=522337
Pin #16 should be 12V constant power
Pin 16 has constant 12v as measured (vehicle running) and as can be seen the Ground/neg is ok
But I still get this message
Marksman
C?ID=522337
I'm beginning to think it's a fault with the HEX-V2 or the lead (no visible issue with the pins)
Test it on another car?
Oh wait, you already did that:
Try a third car. If it works on yet another car, then I really don't think it's the HEX-V2 that's the problem here.
A volt meter puts no load on the circuit at all. What happens with a test lamp that draws a few watts?
