VC-Scope v1.9g failing
abishoff
C?ID=248712
When I open VC-scope I immediately get errors.
1. Impossible to run the graphs "Couldn't open MIB-PIPE.TXT"
2. Error "Sorry, the scaling values couldn't be saved to disk"
That will happen if you manually run VC-Scope while VCDS is running. If you wish to manually run VC-Scope, close VCDS first.
abishoff
C?ID=248712
thanjs. got it running but im having trouble getting this log to work
Mon,Feb,29,2016,16:11:59 ,VCDS Mobile: 0.4304,,,,,,,,,,,,,,,,,,,,
04L-906-016-AF,ADVMB,R4 2,0L EDC   H20 8417,
,,G3632,F-1,G43677,F-1,G4586,F-1,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Group 3632 - Field -1,TIME,Group 43677 - Field -1,TIME,Group 4586 - Field -1,,,,,,,,,,,,,,,,,,,,,,,,,,,
,STAMP,Charge air pressure specified value,STAMP,Charge pressure before throttle valve; calculated actual value,STAMP,Engine speed,,,,,,,,,,,,,,,,,,,,,,,,,,,
,,hPa,,hPa,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
,0.94,2300,1.13,2048.0,0.71,3306/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,1.56,2199,1.75,1988.5,1.52,3656/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,2.16,2499,2.36,2473.0,1.94,2344/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,2.77,2488,2.98,2472.3,2.56,2546/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,3.40,2462,3.59,2364.5,3.17,2753/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,4.00,2414,4.21,2354.0,3.79,2960/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,4.63,2354,4.82,2306.3,4.40,3160/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,5.23,2307,5.44,2291.5,5.02,3358/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,5.86,2251,6.05,2256.0,5.63,3547/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,6.46,2221,6.67,2220.3,6.25,3717/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,7.09,2182,7.28,2169.3,6.86,3872/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,7.69,1146,7.90,1311.0,7.48,3835/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,8.32,1163,8.51,1165.8,8.09,3844/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,8.92,2205,9.13,1965.0,8.71,3866/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,9.55,2191,9.74,2081.5,9.32,3930/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,10.15,2123,10.36,2097.5,9.94,4057/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,10.78,2086,10.97,2083.8,10.55,4182/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,11.38,2044,11.59,2057.8,11.78,4416/min,,,,,,,,,,,,,,,,,,,,,,,,,,
,12.01,2016,12.20,2081.8,11.78,4416/min,,,,,,,,,,,,,,,,,,,,,,,,,,
Can you ZIP up and e-mail us the original file please? In playback mode, VC-Scope can be a bit fussy about files that have been edited in any way.
abishoff
C?ID=248712
What is the best email?
abishoff
C?ID=248712
also, chrome wouldnt let me download this from vcds mobile, it just opened it in the browser, so i copied it out into a .txt and renamed to .csv
Oh, heck, I missed the fact that it was generated by VCDS-Mobile. I do not think we've worked on being able to play back logs from VCDS-Mobile in VC-Scope.
