I could use some help from any 6R/PQ25 platform experts with an aftermarket LED lighting conversion that was carried out without coding changes (not by me). I gather this should be handled by BYTE 18 of the BCM coding byte but there is a special note in VCDS software indicating that no guidance is provided on the value of these bits. I have tried to disable the lamp diagnosis for the lamps in the other documented bytes but the error for the brake lamps persists - presumably as the BCM does not know they are LED.
Recent Auto-Scan provided for context. Everything is OE, except the powertrain and brakes. Aftermarket LEDs front & rear were added and there is a full MFSW as well.
Current BCM coding = 25B029B808A1060001280EC02DAB0ED8B08041FF60060000200000000000
Byte 18 = 0x41
Byte 19 = 0xFF
I dug out a very old scan from the car when it had the factory fitted regular lights and Byte 18 was also 0x41 so I think that is the problem as the BCM is expecting non LED lamps. Other bytes were of course different as we since added an OE MFSW and made some other changes along the way, but for the record the 'factory fresh' BCM coding with the legacy lights etc is below:
Original BCM Coding = 24B029BF08A10000012808002D2B0ED00000410F60060000200000000000
Byte 18 = 0x41
Byte 19 = 0x0F
I was unable to find any trustworthy guides online for Byte 18 coding on the specific PQ25 BCM (6R0 937 087 K) which I gather should be capable of the necessary changes, but I am definitely not a 6R platform expert so I could use some pointers as I gather that bad coding changes can be permanent - or maybe that is just some internet FUD which is significant enough to make me want to check.
Tuesday,05,May,2026,20:31:37:30756
VCDS Version: 26.3.0.0 (x64) HEX-NET CB: 0.4701.4
VIN: TRUZZZ8N841028314 License Plate: 6R32
Chassis Type: 8N-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: TRUZZZ8N841028314 Mileage: 204640km-127157miles
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 FA HW: 021 203
Component: MOTRONIC ME7.1.1G 5903
Coding: 0000032
Shop #: WSC 87119 806 641192
VCID: 4FEE7790DFA508E70A-5184
VINID: 92296AAAA21E2040400880C110E20D3EB3
Readiness: 0010 0100
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 230248E3436D00B9C42912E2C2D400821300
Shop #: WSC 00788 648 00255
VCID: 02488EA49977358FD5-8056
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H06 0060
Serial number: 090465LJ5000ZR
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EB0FA54E18F516FB1-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 393A2948B021B657C4-806C
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 249
Mileage: 204641 km
Date: 2020.09.25.
Time: 20:27:18
Temperature: 9.0°C
Hex Value: 0xFFFF
Hex Value: 0xFFFF
Voltage: 14.30 V
Absolute Pres.: 0.0 bar
Time: 0.00 s
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 266121636
Coding: 25B029B808A1060001280EC02DAB0ED8B08041FF60060000200000000000
Shop #: WSC 12469 483 00190
VCID: 45C255B8CCD9C2B7B0-8010
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 210912 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU020091200018422
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU017091200010077
Coding: 18BC30
Subsystem 4 - Part No SW: 6C0 959 442 C HW: 6C0 959 442 C
Component: E221__MFL-DC1 H04 0103
Serial number: 29160000565620056125
Coding: B0FFFF
01758 - Bulbs for Brake Lamps
Reset counter: 249
Mileage: 204641 km
Date: 2020.09.25.
Time: 20:27:50
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01X H10 0020
Revision: -------- Serial number: 003GX01EFA8E Dataset Number: v00307236R0 0001
Coding: 003158
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4AD86684EDC72DCF5D-801E
Serial number: 3575HRB40511KADSGHBT
Serial number: 3585HRB404T1KADSF0UF
Serial number: 3515RRB405H1GLOM6HSP
Serial number: 3525RRB401C4UHC45H7L
Part No SW: 6R0 920 960 D HW: 6R0 920 960 D
Component: KOMBI H03 0207
Coding: 440E00
Shop #: WSC 31414 790 50316
ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
VCID: 36202274893F592F29-8062
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002100
VCID: 70ACD46CA3DB371F33-8024
Address 25: Immobilizer
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11230
Shop #: WSC 00788
VCID: 302C146CF75B771F73-8064
End----------(Elapsed Time: 01:21, VBatt start/end: 14.3V/14.2V)-----------
------------------------------2 Faults Found-------------------------------
Byte 18 = 0x41
Byte 19 = 0xFF
Byte 18 = 0x41
Byte 19 = 0x0F
