Kodiaq headlights retrofit problem
   #22
downtime
Finland
C?ID=280813
Why not use the adaptation map I pasted earlier? Just change your leuchte settings for the front lights to match
   #23
vagcars69
C?ID=413796
Ok I will give it a go. Only issue is no camera in this setup so high beam assistant won't function.
   #24
downtime
Finland
C?ID=280813
That’s not going to be a problem and is easy to code out. The incorrect light configuration is your biggest issue
   #25
vagcars69
C?ID=413796
Tried these.
Still have fault headlamp type implausible. From past I remember that modules might need coding?
Saturday,16,May,2026,12:12:00:45700
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
VIN: TMBMJ7NS7N8512   License Plate:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 09 10 13 15 17 19 22 2B 42 44 4B 52 5F 75 BB BC
          D6 D7
VIN: TMBMJ7NS7N8512   Mileage: 50496km-31376miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-DTSB)       Labels: None
   Part No SW: 05L 906 022 KB    HW: 05L 907 309 T
   Component: R4 2.0l TDI   H80 2005
   Revision: EBH80---    Dataset Number: V03935325ML 0001 CVN: 244293E7914A6D2022E7CED8914A6D2043FB2DAA
   Coding: 0125003203261D0830000000000000000000000000000000
   ASAM Dataset: EV_ECM20TDI01105L906022KB 007001
   ROD: EV_ECM20TDI01105L906022KB_SK37.rod
   VCID: 71BFD185212232C230D-8024
   VINID: 91D49D6877A31DE20504214600DE6080F5
4527 - Coolant Fan Control Circuit 1
          P0480 00 [10100111] - Electrical Malfunction
28388 - Coolant Pump 3
          P26F4 00 [00100111] - Electrical Malfunction / Open Circuit
38317 - Mass Airflow Sensor 1
          U060F 00 [10100111] - No Communication
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100111] - -
Readiness: 0 0 0 1 1
   Part No SW: 0GC 300 013 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2803
   Revision: 00H06V13    CVN: 43118CEA
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F2D9D86C257A95F-8072
   No subsystems:
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 60762000001368 Dataset Number: V03935347XP 0001
   Coding: 6007929F50210B6E477C070662C34806490AD0E2E046127530615578D2094A0B00002F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76B5E299484C15FAE5F-8022
0297 - Steering Angle Sensor
          B1168 F2 [10001001] - Not Initialized
4410 - Indicator Lamp in Auto-Hold Switch
          C1156 14 [00001001] - Open or Short to Ground
8356 - Databus
          [FCAN: Klima_11_alt veraltet bit is set]
32833 - Switch for Electric Parking Brake
          C100C 01 [10001001] - Electrical Failure
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0596052918 Dataset Number: V03935351DS 0001
   Coding: 0F20000723
   Shop #: WSC 00033 790 00164
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_004_SK37.rod
   VCID: 48C95C617238D30A473-801C
   Part No SW: 5Q0 937 084 EA    HW: 5Q0 937 084 EA
   Component: BCM MQBAB MxL H44 0511
   Serial number: 01102212302352 Dataset Number: V03935432RP 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_SK37.rod
   VCID: 7BA3F3AD736E48929A1-802E
   Subsystem 1 - Part No SW: 567 955 119 B    HW: 567 955 119 B
   Component: J400FRWISCH  067 0070
   Serial number: 907353F0302209303489
   Coding: 104D0D
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M05D03H15M37S04
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL2209405VA
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000002419415
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KH    HW: 5Q1 953 569 J
   Component: Lenks.Modul  H14 0190
   Serial number: 0100260420220C200818
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [00001001] - Open or Short to Plus
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [00001001] - Open or Short to Plus
18954 - Left LED Module for DRL and Parking Lights
          B12EC F5 [00001001] - Control Circuit Open or Short to Plus
539157 - Databus
          [Klima_12 Datenbus fehlende Botschaft]
   Part No SW: 3Q0 919 283 D    HW: 3Q0 919 283
   Component: PDC 4 Kanal   H08 0055
   Serial number: 001801219448040 Dataset Number: V03935350P  0001
   Coding: 0001050011
   ASAM Dataset: EV_EPHBO14VW3260000 007018
   ROD: EV_EPHBO14VW3260000_SK37.rod
   VCID: 38292CA102D8A38A373-806C
13637426 - Databus
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935383SB 0001
   Coding: 3204600110FF8728749C812400408700000000000000000004
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B3DB8D5B3E00D2C21-8026
2082 - Databus
          [FAULT_EPB_SWITCH_FAIL]
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
   Part No SW: 5QF 959 655 AT    HW: 5QF 959 655 AT
   Component: Airbag VW22   015 0755
   Revision: --------    Serial number: 00301AFP2177WH Dataset Number: V03935361FG 0001
   Coding: 98CCC0C0000000005C5450CF008840000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
   ROD: EV_AirbaVW22TS6VW48X_SK37.rod
   VCID: 2809FCE1D278330AA73-807C
   Subsystem 1 - Part No SW: -----------    HW: 454 002 403 22
   Serial number: 35700000000E375D5E5
   Subsystem 2 - Part No SW: -----------    HW: 454 002 303 22
   Serial number: 35800000000387556A5M
   Subsystem 3 - Part No SW: -----------    HW: 454 801 804 22
   Serial number: 35100AC129B1F000000R
   Subsystem 4 - Part No SW: -----------    HW: 454 801 904 22
   Serial number: 35200DCD59C1F0000004
   Subsystem 5 - Part No SW: -----------    HW: 454 800 403 22
   Serial number: 3550066A88C1F000000-
12 Faults Found:
          B1000 1B [10001001] - Resistance Too High
          B1006 1B [10001001] - Resistance Too High
9445395 - Key switch for deactivation of passenger-side airbag
          B1020 13 [10001001] - Open Circuit
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
9437723 - Igniter for Passenger's Airbag
          B1002 1B [10001001] - Resistance Too High
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10001001] - Resistance Too High
9440283 - Driver side knee airbag igniter
          B100C 1B [10001001] - Resistance Too High
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001001] - Open or Short to Ground
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [10001001] - Open or Short to Ground
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [10001001] - Resistance Too High
9446675 - Redundant signal path for airbag shut-off; passenger side
          B1025 13 [10001001] - Open Circuit
9438491 - Igniter for Driver head airbag
          B1005 1B [10001001] - Resistance Too High
   Part No SW: 565 920 951 D    HW: 565 920 951 D
   Component: KOMBI         304 8400
   Dataset Number: V03935346BG 0001
   Coding: 27A4001CA380A60001886A011001000800600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   VCID: 1E65DA39803CFDBADDF-804A
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 06052210520164 Dataset Number: V03935359PU 0001
   Coding: 030100045F28730023100240100F00010001070000000000000000000000
   GVL: 01C63C0000000600000C80008000C8000000C000000200000000000000000000
   ROD: EV_GatewNF_SK37.rod
   VCID: 79AFE9A579527A8288D-802C
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886104002205020190
131734 - No Communications with Undefined Control Module
          U1126 00 [00001001] - -
          [Timeout Knoten 0x96]
131735 - No Communications with Undefined Control Module
          [Timeout Knoten 0x97]
197169 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
          [MFL (LIN#2) Timeout]
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00022.03.22 Dataset Number: v1260x015G0 0000
   Coding: 0101
   VCID: 4CC1607166403F2A63B-8018
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000089455009 Dataset Number: V03935342UT 0001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 323D1E89E4A449DA097-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 393 P    HW: 5Q4 959 393 P
   Component: TSG FS        009 0911
   Serial number: 0000458826246  Dataset Number: V03935351XF 0001
   Coding: 001000208001020000001100
   ROD: EV_DCU2DriveSideMAXHCONT_SK37.rod
   VCID: 50F974018A681BCA1F3-8004
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000059747520
   Coding: 1D0200
          B1487 54 [00001001] - Missing Calibration / Basic Setting
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Dataset Number: V03935310ZH 0001
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D8915E3007EADBB-8020
16275 - Steering Angle Sensor
          B1168 F2 [00001001] - Not Initialized
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17052111603215 Dataset Number: V03935295XH 0001
   Coding: 000000070900037600003D01190000000000000000000000000000000000
   Shop #: WSC 00033 790 00176
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B2F9D0FC6ACF23E9-8062
13706046 - Databus
          U1123 00 [10001001] - Received Error Message
          [LV_Abblendlicht_li_def received error value]
66889 - Databus
          [LED_L_Allg_Elektr_Def received error value]
66896 - Databus
          [LED_R_Allg_Elektr_Def received error value]
   Part No SW: 5Q4 959 392 P    HW: 5Q4 959 392 P
   Component: TSG BFS       009 0911
   Serial number: 0000458744659  Dataset Number: V03935351WV 0001
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 4FFB777D97560432069-801A
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000059792280
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3V0 035 820 H    HW: 3V0 035 820 H
   Component: MU-O-ND-EU    H22 0306
   Serial number: SKZAZ2A0337598  Dataset Number: V03935351FR 0001
   Coding: 33261008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_SK37.rod
   VCID: 33331B8D1BBE40D2021-8066
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [00001001] - Open Circuit
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [00001001] - Open Circuit
7169 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [A/C system (0x01) - function restriction due to communication error - BapErr_retry not successful]
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000201VIHJ9 Dataset Number: V03935359XV 0001
   Coding: 032610101969A8809025460161052607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4ACD66696C34211A517-801E
7234 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Climate Master (0x42) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
9457427 - Speaker for Emergency Calling
          B14A6 13 [00001001] - Open Circuit
12866049 - Databus
          [Airbag: Error value received]
0048 - Databus
          [Clima: No communication]
   Part No SW: 992 941 572 CE    HW: 992 941 572 C
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6889BCE112F8F30A673-803C
131081 - Headlamp Type
          C119F 00 [10101111] - Implausible
131097 - Terminal 30
          U1407 00 [10101111] - Implausible Signal
   Component: LED1R         H08 9202
End----------(Elapsed Time: 01:29, VBatt start/end: 13.5V/13.5V)-----------
------------------------------48 Faults Found------------------------------
   #26
downtime
Finland
C?ID=280813
Nope, they need probably dataset to be flashed again to them. Those led lights are tricky
vagcars69
C?ID=413796
Tried to code with odis but it won't code. Guess thats because it didn't come with them from factory.
I found a way to perform svm retrofit but its asking for a 5 digit code. Where could I find one?
   #28
vagcars69
C?ID=413796
Still think I need correct adaptations for bcm for correct module no / 8IU variant.
   #29
downtime
Finland
C?ID=280813
can you post adamap from your 09 module?
   #30
vagcars69
C?ID=413796
;SW:5Q0-937-084-EA   HW:5Q0-937-084-EA ---  09: Cent. Elect.
;Component:BCM MQBAB MxL H44 0511, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,022001,EV_BCMBOSCH_022_SK37.rod
;Monday,18,May,2026,19:23:43:45700
;VCDS Version: 26.3.0.0 (x64)  Data version: 20260320 DS375.1
;VCID: 7BA3F3AD736E48929A1-802E
IDE01550-Service position,158.010832 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen,active ,8
IDE02711-ENG112304-Rear wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Static cornering light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-Static cornering light-Abdimmgeschwindigkeit,26.5 %/s,16
IDE03638-ENG116673-Static cornering light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-Static cornering light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Static cornering light-Maximaltemperatur,1.0 °C,16
IDE03638-ENG116679-Static cornering light-obere Grenztemperatur,127.5 °C,16
IDE03638-ENG116681-Static cornering light-Oberer Lenkradwinkel,55 °,16
IDE03638-ENG116680-Static cornering light-untere Grenztemperatur,127.0 °C,16
IDE03638-ENG116678-Static cornering light-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-Static cornering light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-Static cornering light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Static cornering light-Zeitwert Einschaltzeit Abbiegelicht,17 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
IDE04928-MAS01577-Anti-theft protection-Auxiliary heating,not installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 42 00 25 13 17 64 1E 00 64 00 00 00 00 00 00 04 38 00 24 12 16 64 1E 00 64 00 00 00 00 00 00 01 42 00 23 13 17 7F 1E 00 7F 00 00 00 00 00 00 01 38 00 22 12 16 7F 1E 00 7F 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 06 37 00 1C 0D 0F 7F 00 00 00 00 00 00 00 00 00 06 41 00 1D 0E 0F 7F 00 00 00 00 00 00 00 00 00 02 52 00 55 0B 0D 7F 0F 00 7F 00 00 00 00 00 00 02 53 00 56 0C 0E 7F 0F 00 7F 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C6 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 65 63 57 9B 25 44 3F 3A 69 58 95 1F 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 53 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 53 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 52 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 65 53 57 9B 25 24 0C FA 0A 34 95 1F 09 A3 21 03 00 02 02 02 02 02 02 B1 40 E1 28 FE ,172
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not_installed ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,37.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,37.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13129-Button in center console-Function of button 2,not coded / not installed ,8
IDE06507-MAS13132-Button in center console-Function of button 3,not coded / not installed ,8
IDE06507-MAS13135-Button in center console-Function of button 4,not coded / not installed ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,not_active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,not_active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,not_active ,8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active ,8
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung,not active ,8
IDE07356-Position during interval mode,19.307673 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,6
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,6
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,6
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,6
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,6
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,6
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,6
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,6
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,6
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,6
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,6
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,6
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,6
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,6
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,6
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,6
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,6
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,6
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,6
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,6
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,6
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,6
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,9
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,9
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,9
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,9
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,9
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,9
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,0 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,4 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,20 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,not installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,50 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,50 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,70 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,70 %,17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,0.010989 °,2
IDE10299-Alternating park position 2,18.307674 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,0.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,0.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,0 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,0 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,0 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,0 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,0 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,0 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,0 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,0 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,0 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,0 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,0 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,0 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,0 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,0 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,0 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,0 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,0 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,0 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,0 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,0 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,0 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,0 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,0 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,0 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,0 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,235 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,221 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,217 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,3
IDE11944-ENG281099-Keyless access and start authorization-Kessy Einzeltuerentriegelung NAR,not active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG281087-Keyless access and start authorization-Kessy Toggle Taster (NAR),not installed ,3
IDE11944-ENG281074-Keyless access and start authorization-Komfort_oeffnen_ueber_Toggle_Taster,not active ,3
IDE11944-ENG281094-Keyless access and start authorization-Komfort_schliessen_ueber_Toggle_Taster,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE11944-ENG281083-Keyless access and start authorization-Verriegeln über Toggle nur bei geschlossener Außenhaut,not active ,3
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,3
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,3
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,3
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,30
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,30
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,30
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,30
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,30
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,30
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,30
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,30
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,30
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,30
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,30
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,30
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,30
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,30
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,30
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,30
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,30
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,30
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,30
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,30
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,30
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,30
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,30
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,30
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,30
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,30
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,30
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,30
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,30
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,30
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,30
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,30
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,30
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,30
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,30
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,30
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,30
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,30
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,30
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,30
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,30
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,30
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,30
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,30
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,30
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,30
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,30
IDE80016-Analysis 16,No Response From Subnet Component,30
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,30
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,30
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,30
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,30
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,30
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,30
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,30
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,30
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,30
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,30
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,30
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,30
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,30
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,30
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,30
IDE80017-ENG133480-Analysis 17-OffsetPP1,No Response From Subnet Component,30
IDE80017-ENG133481-Analysis 17-OffsetPP2,No Response From Subnet Component,30
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,30
IDE80017-ENG133478-Analysis 17-OffsetT1,No Response From Subnet Component,30
IDE80017-ENG133479-Analysis 17-OffsetT2,No Response From Subnet Component,30
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,30
IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,30
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,30
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,30
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,30
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,30
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,30
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,30
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,30
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,30
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,30
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,30
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,30
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,30
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,30
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,30
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,30
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,30
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,30
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,30
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,30
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,30
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,30
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,30
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,30
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,30
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,30
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,30
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,30
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,30
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,30
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,30
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,30
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,30
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,30
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,30
IDE80018-ENG133480-Analysis 18-OffsetPP1,No Response From Subnet Component,30
IDE80018-ENG133481-Analysis 18-OffsetPP2,No Response From Subnet Component,30
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,30
IDE80018-ENG133478-Analysis 18-OffsetT1,No Response From Subnet Component,30
IDE80018-ENG133479-Analysis 18-OffsetT2,No Response From Subnet Component,30
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,30
IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,30
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,30
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,30
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,30
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,30
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,30
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,30
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,30
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,30
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,30
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,30
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,30
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,30
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,30
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,30
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,30
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,30
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,30
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,30
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,30
MAS05055-lower turn position,20.703276 °,2
MAS05056-upper turn position,160.208632 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,No Response From Subnet Component,60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,No Response From Subnet Component,60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,No Response From Subnet Component,60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,No Response From Subnet Component,60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,No Response From Subnet Component,60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,No Response From Subnet Component,60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,No Response From Subnet Component,60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,No Response From Subnet Component,60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,No Response From Subnet Component,60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,No Response From Subnet Component,60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,No Response From Subnet Component,60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,No Response From Subnet Component,60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,No Response From Subnet Component,60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,No Response From Subnet Component,60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,No Response From Subnet Component,60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,No Response From Subnet Component,60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,No Response From Subnet Component,60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,No Response From Subnet Component,60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,No Response From Subnet Component,60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,No Response From Subnet Component,60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,No Response From Subnet Component,60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,No Response From Subnet Component,60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,No Response From Subnet Component,60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,No Response From Subnet Component,60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,No Response From Subnet Component,60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,No Response From Subnet Component,60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,No Response From Subnet Component,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_aktiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,not installed ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,3000 ms,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beams ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,696 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,800 lx,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beams,Keine_Spannungsanforderung ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,18
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,18
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin,No Response From Subnet Component,18
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,18
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,18
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin,No Response From Subnet Component,18
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,18
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,18
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin,No Response From Subnet Component,18
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,18
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,18
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin,No Response From Subnet Component,18
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,active ,3
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,6
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,6
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,6
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,6
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,6
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,6
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,6
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,6
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,6
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,6
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,6
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,6
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,6
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,6
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,6
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,6
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,6
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,6
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,6
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,6
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,6
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,6
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,6
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,6
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,6
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,6
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,6
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,6
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,6
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,6
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,6
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,6
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,6
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,6
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG122934-erase_error_table,00 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not available ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,Not available ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,0 ms,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,6
ENG141645-MAS00212-HW_Verbau-Washer fluid low,installed ,8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer,installed ,8
ENG126651-ENG115658-Kennlinie Abdimmen-x0,No Response From Subnet Component,8
ENG126651-ENG101574-Kennlinie Abdimmen-X1,No Response From Subnet Component,8
ENG126651-ENG115664-Kennlinie Abdimmen-x10,No Response From Subnet Component,8
ENG126651-ENG99557-Kennlinie Abdimmen-X2,No Response From Subnet Component,8
ENG126651-ENG102140-Kennlinie Abdimmen-X3,No Response From Subnet Component,8
ENG126651-ENG102936-Kennlinie Abdimmen-X4,No Response From Subnet Component,8
ENG126651-ENG103548-Kennlinie Abdimmen-X5,No Response From Subnet Component,8
ENG126651-ENG113992-Kennlinie Abdimmen-X6,No Response From Subnet Component,8
ENG126651-ENG115661-Kennlinie Abdimmen-x7,No Response From Subnet Component,8
ENG126651-ENG115662-Kennlinie Abdimmen-x8,No Response From Subnet Component,8
ENG126651-ENG115663-Kennlinie Abdimmen-x9,No Response From Subnet Component,8
ENG126651-ENG115659-Kennlinie Abdimmen-y0,No Response From Subnet Component,8
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,No Response From Subnet Component,8
ENG126651-ENG115668-Kennlinie Abdimmen-y10,No Response From Subnet Component,8
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,No Response From Subnet Component,8
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,No Response From Subnet Component,8
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,No Response From Subnet Component,8
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,No Response From Subnet Component,8
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,No Response From Subnet Component,8
ENG126651-ENG115665-Kennlinie Abdimmen-y7,No Response From Subnet Component,8
ENG126651-ENG115666-Kennlinie Abdimmen-y8,No Response From Subnet Component,8
ENG126651-ENG115667-Kennlinie Abdimmen-y9,No Response From Subnet Component,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,83.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,67.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,50.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,33.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,17.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-0.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-0.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-0.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,51.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,47.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,43.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,33.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,29.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,24.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,20.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,20.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,20.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,36 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,127 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,55 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,52 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Abblendlicht links ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Main beam left ,16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,Lichthupe generell ,16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,127 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,56 ,16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,53 ,16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Abblendlicht rechts ,16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Main beam right ,16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,Lichthupe generell ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,minimize ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,61 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,36 - LED Kleinleistung ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,62 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,36 - LED Kleinleistung ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Coming Home oder Leaving Home aktiv ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2F ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,1C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,100 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,25 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,42 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Nebellicht rechts ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Abbiegelicht rechts ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,100 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,24 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,38 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Nebellicht links ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Abbiegelicht links ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,23 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,42 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Nebellicht rechts ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Abbiegelicht rechts ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,22 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,38 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Nebellicht links ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Abbiegelicht links ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Main beam left ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Main beam right ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1A 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,24 00 00 61 3F 00 FF 00 00 80 00 00 00 00 00 00 24 00 00 62 1E 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2700 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,5.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,5.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,5.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,51.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.03 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.03 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,0.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,1000.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,0.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,HIM ,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,20 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00 ,20
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,20
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,20
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,20
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,20
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,20
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,20
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,20
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,20
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,20
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,20
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,20
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,20
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,20
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,20
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,20
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,20
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,20
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,20
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,20
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,20
ENG99457-ENG117394-Neck heating-blower_speed,1 ,2
ENG99457-ENG98971-Neck heating-Temperature,-2 ,2
ENG122979-ENG99457-Networking-Neck heating,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,installed ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,8
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,8
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,8
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,8
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,8
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,8
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,8
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,8
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,8
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,8
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,8
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,8
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,8
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,8
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,8
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,8
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,8
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,8
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,8
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,8
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,8
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,8
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,8
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,8
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,8
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,8
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,8
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,8
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,8
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,8
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,7 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 2.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Skoda ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Right ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Left ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,8
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,8
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,8
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,8
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1500 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,700 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,700 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,72.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,48.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,33.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,18.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,12.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,8.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,6.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,4.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,2.0 %,22
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,0 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,20.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,0 bit,4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,not active ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,No ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
Elapsed Time: 02:28
attached
   #31
downtime
Finland
C?ID=280813
I see you haven’t changed your leuchte channels at all.
You HAVE to change them, the lights will not work correctly.
You need to change the leuchte channels for front lights the same as in the adamap I pasted earlier
Install notepad++ and compare plugin to that. Copy the adamap i posted to a file. Open that file in notepad++ and then open your current adamap. Choose first as compare target and second as comparison file.
It’s very easy to find what is different.
Concentrate on the leuchte adaptation channels first
   #32
vagcars69
C?ID=413796
I changed leuchte channels 2,3,4,5,6,7 i thought these are for the front lights setup?
   #33
downtime
Finland
C?ID=280813
Also at least 8,9, 10, 11. Shutter is front lights, it’s main beam setting
   #34
vagcars69
C?ID=413796
Ok will do these also. Which one are indicators controlled via led module? that's biggest issue
   #35
vagcars69
C?ID=413796
Just did these, still faults.
Tuesday,19,May,2026,09:47:21:45700
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
VIN: TMBMJ7NS7N85125   License Plate:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 42 44 4B 52 5F 75 BB
          BC D6 D7
VIN: TMBMJ7NS7N85125   Mileage: 50496km-31376miles
08-Auto HVAC -- Status: Cannot be reached 0100
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DTSB)       Labels: None
   Part No SW: 05L 906 022 KB    HW: 05L 907 309 T
   Component: R4 2.0l TDI   H80 2005
   Revision: EBH80---    Dataset Number: V03935325ML 0001 CVN: 244293E7914A6D2022E7CED8914A6D2043FB2DAA
   Coding: 0125003203261D0830000000000000000000000000000000
   ASAM Dataset: EV_ECM20TDI01105L906022KB 007001
   ROD: EV_ECM20TDI01105L906022KB_SK37.rod
   VCID: 71BFD185212232C230D-8024
   VINID: 91D49D6877A31DE20504214600DE6080F5
4527 - Coolant Fan Control Circuit 1
          P0480 00 [10100111] - Electrical Malfunction
28388 - Coolant Pump 3
          P26F4 00 [00100111] - Electrical Malfunction / Open Circuit
38317 - Mass Airflow Sensor 1
          U060F 00 [10100111] - No Communication
29987 - Coolant Pump for Intercooler
          P2B83 00 [00100111] - Over-Speed or Air in System
          [Charge Air Cooler Coolant Pump "A" Overspeed/Air In System]
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100111] - -
Readiness: 0 0 0 1 1
   Part No SW: 0GC 300 013 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2803
   Revision: 00H06V13    CVN: 43118CEA
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F2D9D86C257A95F-8072
   No subsystems:
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 60762000001368 Dataset Number: V03935347XP 0001
   Coding: 6007929F50210B6E477C070662C34806490AD0E2E046127530615578D2094A0B00002F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76B5E299484C15FAE5F-8022
0297 - Steering Angle Sensor
          B1168 F2 [10001001] - Not Initialized
4410 - Indicator Lamp in Auto-Hold Switch
          C1156 14 [00001001] - Open or Short to Ground
8356 - Databus
          [FCAN: Klima_11_alt veraltet bit is set]
32833 - Switch for Electric Parking Brake
          C100C 01 [10001001] - Electrical Failure
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0596052918 Dataset Number: V03935351DS 0001
   Coding: 0F20000723
   Shop #: WSC 00033 790 00164
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_004_SK37.rod
   VCID: 48C95C617238D30A473-801C
Address 08: Auto HVAC
   Part No SW: 5Q0 937 084 EA    HW: 5Q0 937 084 EA
   Component: BCM MQBAB MxL H44 0511
   Serial number: 01102212302352 Dataset Number: V03935432RP 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_SK37.rod
   VCID: 7BA3F3AD736E48929A1-802E
   Subsystem 1 - Part No SW: 567 955 119 B    HW: 567 955 119 B
   Component: J400FRWISCH  067 0070
   Serial number: 907353F0302209303489
   Coding: 104D0D
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M05D03H15M37S04
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL2209405VA
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000002419415
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KH    HW: 5Q1 953 569 J
   Component: Lenks.Modul  H14 0190
   Serial number: 0100260420220C200818
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [00001001] - Open or Short to Plus
8714 - Bulb for Left Fog Lamp
          B121F 15 [00001001] - Open or Short to Plus
8970 - Bulb for Right Fog Lamp
          B1220 15 [00001001] - Open or Short to Plus
539157 - Databus
          [Klima_12 Datenbus fehlende Botschaft]
   Part No SW: 3Q0 919 283 D    HW: 3Q0 919 283
   Component: PDC 4 Kanal   H08 0055
   Serial number: 001801219448040 Dataset Number: V03935350P  0001
   Coding: 0001050011
   ASAM Dataset: EV_EPHBO14VW3260000 007018
   ROD: EV_EPHBO14VW3260000_SK37.rod
   VCID: 38292CA102D8A38A373-806C
13637426 - Databus
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935383SB 0001
   Coding: 3204600110FF8728749C812400408700000000000000000004
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B3DB8D5B3E00D2C21-8026
2082 - Databus
          [FAULT_EPB_SWITCH_FAIL]
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
   Part No SW: 5QF 959 655 AT    HW: 5QF 959 655 AT
   Component: Airbag VW22   015 0755
   Revision: --------    Serial number: 00301AFP2177WH Dataset Number: V03935361FG 0001
   Coding: 98CCC0C0000000005C5450CF008840000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
   ROD: EV_AirbaVW22TS6VW48X_SK37.rod
   VCID: 2809FCE1D278330AA73-807C
   Subsystem 1 - Part No SW: -----------    HW: 454 002 403 22
   Serial number: 35700000000E375D5E5
   Subsystem 2 - Part No SW: -----------    HW: 454 002 303 22
   Serial number: 35800000000387556A5M
   Subsystem 3 - Part No SW: -----------    HW: 454 801 804 22
   Serial number: 35100AC129B1F000000R
   Subsystem 4 - Part No SW: -----------    HW: 454 801 904 22
   Serial number: 35200DCD59C1F0000004
   Subsystem 5 - Part No SW: -----------    HW: 454 800 403 22
   Serial number: 3550066A88C1F000000-
10 Faults Found:
          B1000 1B [10001001] - Resistance Too High
9445395 - Key switch for deactivation of passenger-side airbag
          B1020 13 [10001001] - Open Circuit
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
9437723 - Igniter for Passenger's Airbag
          B1002 1B [10001001] - Resistance Too High
9440283 - Driver side knee airbag igniter
          B100C 1B [10001001] - Resistance Too High
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001001] - Open or Short to Ground
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [10001001] - Open or Short to Ground
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [10001001] - Resistance Too High
9446675 - Redundant signal path for airbag shut-off; passenger side
          B1025 13 [10001001] - Open Circuit
9438491 - Igniter for Driver head airbag
          B1005 1B [10001001] - Resistance Too High
   Part No SW: 565 920 951 D    HW: 565 920 951 D
   Component: KOMBI         304 8400
   Dataset Number: V03935346BG 0001
   Coding: 27A4001CA380A60001886A011001000800600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   VCID: 1E65DA39803CFDBADDF-804A
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 06052210520164 Dataset Number: V03935359PU 0001
   Coding: 030100045F28730023100240100F00010001070000000000000000000000
   GVL: 01C43C0000000600400C80008000C80000000000000200000000000000000000
   ROD: EV_GatewNF_SK37.rod
   VCID: 79AFE9A579527A8288D-802C
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886104002205020190
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001001] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
66304 - Databus
          U1124 00 [00001001] - Additional Installations Detected
          [Mehrverbau CAN]
197169 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
          [MFL (LIN#2) Timeout]
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00022.03.22 Dataset Number: v1260x015G0 0000
   Coding: 0101
   VCID: 4CC1607166403F2A63B-8018
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000089455009 Dataset Number: V03935342UT 0001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 323D1E89E4A449DA097-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 393 P    HW: 5Q4 959 393 P
   Component: TSG FS        009 0911
   Serial number: 0000458826246  Dataset Number: V03935351XF 0001
   Coding: 001000208001020000001100
   ROD: EV_DCU2DriveSideMAXHCONT_SK37.rod
   VCID: 50F974018A681BCA1F3-8004
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000059747520
   Coding: 1D0200
          B1487 54 [00001001] - Missing Calibration / Basic Setting
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Dataset Number: V03935310ZH 0001
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D8915E3007EADBB-8020
16275 - Steering Angle Sensor
          B1168 F2 [00001001] - Not Initialized
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17052111603215 Dataset Number: V03935295XH 0001
   Coding: 000000070900037600003D01190000000000000000000000000000000000
   Shop #: WSC 00033 790 00176
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B2F9D0FC6ACF23E9-8062
66881 - Databus
          [LED_L_falsch_codiert received error value]
66882 - Databus
          [LED_R_falsch_codiert received error value]
66889 - Databus
          U1123 00 [10001001] - Received Error Message
          [LED_L_Allg_Elektr_Def received error value]
66896 - Databus
          [LED_R_Allg_Elektr_Def received error value]
   Part No SW: 5Q4 959 392 P    HW: 5Q4 959 392 P
   Component: TSG BFS       009 0911
   Serial number: 0000458744659  Dataset Number: V03935351WV 0001
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 4FFB777D97560432069-801A
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000059792280
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3V0 035 820 H    HW: 3V0 035 820 H
   Component: MU-O-ND-EU    H22 0306
   Serial number: SKZAZ2A0337598  Dataset Number: V03935351FR 0001
   Coding: 33261008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_SK37.rod
   VCID: 33331B8D1BBE40D2021-8066
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [00001001] - Open Circuit
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [00001001] - Open Circuit
7169 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [A/C system (0x01) - function restriction due to communication error - BapErr_retry not successful]
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000201VIHJ9 Dataset Number: V03935359XV 0001
   Coding: 032610101969A8809025460161052607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4ACD66696C34211A517-801E
9457427 - Speaker for Emergency Calling
          B14A6 13 [00001001] - Open Circuit
12866049 - Databus
          [Airbag: Error value received]
7234 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Climate Master (0x42) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
0048 - Databus
          [Clima: No communication]
   Part No SW: 992 941 572 CE    HW: 992 941 572 C
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6889BCE112F8F30A673-803C
131081 - Headlamp Type
          C119F 00 [10101111] - Implausible
131097 - Terminal 30
          U1407 00 [10101111] - Implausible Signal
   Component: LED1R         H08 9202
End----------(Elapsed Time: 01:31, VBatt start/end: 13.6V/13.6V)-----------
------------------------------48 Faults Found------------------------------
   #36
vagcars69
C?ID=413796
Anyone with correct kodiaq model who can provide adaptations map?
   #37
downtime
Finland
C?ID=280813
Copy this to your 4B coding as is : 000000070900037206002D01190000000000000000000000000000000000
This is from the other Kodiaq. If that works and puts the lights to correct coding, then fix the other parts of the coding correctly.
When you have 4B coded correctly with correct headlamp type, the blinker error should go away from module 9
To me it still looks like the 4B and the LCM modules on the lights don't have matching datasets.
vagcars69
C?ID=413796
Will try and report. 4B and lights/modules were sourced from correct vehicle so should be ok. Tried flashing with odis but it would not do it, would need a 5 digit code to change pr number on system, where could I get that?
   #39
vagcars69
C?ID=413796
Coding was already same, only difference lhd/rhd
   #40
downtime
Finland
C?ID=280813
You need to get a proper flash files with other means and us odis-e.
Not an easy retrofit you’ve chosen. Especially with these new led headlights, even more complicated
