Kodiaq headlights retrofit problem
vagcars69
C?ID=413796
I've got a 2022 kodiaq that came with basic led headlights 8IT version. Upgraded to higher spec 8IU version. Installed headlights with modules, level sensor and a multifunction module, plugs and wirings. Problem I have is with can bus with module connected.
When module is connected car won't do auto scan, vcds just crashes or comes with a fault -function not supported by gateway. When module is disconnected then I can do auto scan. I can go into module directly and communicate but not via autoscan.
Tuesday,12,May,2026,18:38:19:45700
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
VIN: TMBMJ7NS7N8512fiversixzero   License Plate:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 42 44 4B 52 5F 75 BB
          BC D6 D7 D8 D9
VIN: TMBMJ7NS7N8512fiversixzero   Mileage: 50496km-31376miles
08-Auto HVAC -- Status: Cannot be reached 0100
4B-Multifunc. Module -- Status: Cannot be reached 0100
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100
D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-DTSB)       Labels: None
   Part No SW: 05L 906 022 KB    HW: 05L 907 309 T
   Component: R4 2.0l TDI   H80 2005
   Revision: EBH80---    Dataset Number: V03935325ML 0001 CVN: 244293E7914A6D2022E7CED8914A6D2043FB2DAA
   Coding: 0125003203261D0830000000000000000000000000000000
   ASAM Dataset: EV_ECM20TDI01105L906022KB 007001
   ROD: EV_ECM20TDI01105L906022KB_SK37.rod
   VCID: 71BFD185212232C230D-8024
   VINID: 91D49D6877A31DE20504214600DE6080F5
4527 - Coolant Fan Control Circuit 1
          P0480 00 [10100111] - Electrical Malfunction
28388 - Coolant Pump 3
          P26F4 00 [00100111] - Electrical Malfunction / Open Circuit
38317 - Mass Airflow Sensor 1
          U060F 00 [10100111] - No Communication
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100111] - -
Readiness: 0 0 0 1 1
   Part No SW: 0GC 300 013 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2803
   Revision: 00H06V13    CVN: 43118CEA
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F2D9D86C257A95F-8072
   No subsystems:
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 60762000001368 Dataset Number: V03935347XP 0001
   Coding: 6007929F50210B6E477C070662C34806490AD0E2E046127530615578D2094A0B00002F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76B5E299484C15FAE5F-8022
0297 - Steering Angle Sensor
          B1168 F2 [10001001] - Not Initialized
8356 - Databus
          [FCAN: Klima_11_alt veraltet bit is set]
32833 - Switch for Electric Parking Brake
          C100C 01 [10001001] - Electrical Failure
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0596052918 Dataset Number: V03935351DS 0001
   Coding: 0F20000723
   Shop #: WSC 00033 790 00164
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_004_SK37.rod
   VCID: 48C95C617238D30A473-801C
Address 08: Auto HVAC
   Part No SW: 5Q0 937 084 EA    HW: 5Q0 937 084 EA
   Component: BCM MQBAB MxL H44 0511
   Serial number: 01102212302352 Dataset Number: V03935354BN 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_SK37.rod
   VCID: 7BA3F3AD736E48929A1-802E
   Subsystem 1 - Part No SW: 567 955 119 B    HW: 567 955 119 B
   Component: J400FRWISCH  067 0070
   Serial number: 907353F0302209303489
   Coding: 104D0D
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M05D03H15M37S04
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL2209405VA
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000002419415
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KH    HW: 5Q1 953 569 J
   Component: Lenks.Modul  H14 0190
   Serial number: 0100260420220C200818
539157 - Databus
          [Klima_12 Datenbus fehlende Botschaft]
   Part No SW: 3Q0 919 283 D    HW: 3Q0 919 283
   Component: PDC 4 Kanal   H08 0055
   Serial number: 001801219448040 Dataset Number: V03935350P  0001
   Coding: 0001050011
   ASAM Dataset: EV_EPHBO14VW3260000 007018
   ROD: EV_EPHBO14VW3260000_SK37.rod
   VCID: 38292CA102D8A38A373-806C
13637426 - Databus
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935351GN 0001
   Coding: 3204600110FF8728749C812400408700000000000000000004
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B3DB8D5B3E00D2C21-8026
2082 - Databus
          [FAULT_EPB_SWITCH_FAIL]
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
          U1101 00 [00001001] - Active
          [FAULT_THP_EC_INVALID_IKA]
2101248 - Data Set Implausible
          B2012 00 [00001001] - -
          [FAULT_DATASET_MISMATCH]
201219 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FAULT_CODING2SWAP_GRP_AWV_TYPE]
   Part No SW: 5QF 959 655 AT    HW: 5QF 959 655 AT
   Component: Airbag VW22   015 0755
   Revision: --------    Serial number: 00301AFP2177WH Dataset Number: V03935361FG 0001
   Coding: 98CCC0C0000000005C5450CF008840000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
   ROD: EV_AirbaVW22TS6VW48X_SK37.rod
   VCID: 2809FCE1D278330AA73-807C
   Subsystem 1 - Part No SW: -----------    HW: 454 002 403 22
   Serial number: 35700000000E375D5E5
   Subsystem 2 - Part No SW: -----------    HW: 454 002 303 22
   Serial number: 35800000000387556A5M
   Subsystem 3 - Part No SW: -----------    HW: 454 801 804 22
   Serial number: 35100AC129B1F000000R
   Subsystem 4 - Part No SW: -----------    HW: 454 801 904 22
   Serial number: 35200DCD59C1F0000004
   Subsystem 5 - Part No SW: -----------    HW: 454 800 403 22
   Serial number: 3550066A88C1F000000-
14 Faults Found:
          B1000 1B [10001001] - Resistance Too High
          B1006 1B [10001001] - Resistance Too High
9445395 - Key switch for deactivation of passenger-side airbag
          B1020 13 [10001001] - Open Circuit
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
9437723 - Igniter for Passenger's Airbag
          B1002 1B [10001001] - Resistance Too High
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10001001] - Resistance Too High
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [10001001] - Resistance Too High
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [10001001] - Resistance Too High
9440283 - Driver side knee airbag igniter
          B100C 1B [10001001] - Resistance Too High
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001001] - Open or Short to Ground
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [10001001] - Open or Short to Ground
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [10001001] - Resistance Too High
9446675 - Redundant signal path for airbag shut-off; passenger side
          B1025 13 [10001001] - Open Circuit
9438491 - Igniter for Driver head airbag
          B1005 1B [10001001] - Resistance Too High
   Part No SW: 565 920 951 D    HW: 565 920 951 D
   Component: KOMBI         304 8400
   Dataset Number: V03935346BG 0001
   Coding: 27A4001CA380A60001886A011001000800600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   VCID: 1E65DA39803CFDBADDF-804A
1048578 - No Basic Setting
          B2010 00 [00001001] - -
          [Steuergerät keine oder falsche Grundeinstellung]
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 06052210520164 Dataset Number: V03935359PU 0001
   Coding: 030100045F28730023100240100F00010001070000000000000000000000
   GVL: 01C43C0000000600400C80008000C8000000C003000200000000000000000000
   ROD: EV_GatewNF_SK37.rod
   VCID: 79AFE9A579527A8288D-802C
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886104002205020190
8 Faults Found:
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001001] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
131734 - No Communications with Undefined Control Module
          U1126 00 [00001001] - -
          [Timeout Knoten 0x96]
131735 - No Communications with Undefined Control Module
          [Timeout Knoten 0x97]
131736 - No Communications with Undefined Control Module
          [Timeout Knoten 0x98]
131737 - No Communications with Undefined Control Module
          [Timeout Knoten 0x99]
131753 - Multifunction Module
          U1326 00 [00001001] - No Communication
          [Time_out_node_0xA9_multifunction_module_on_second_bus]
197169 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
          [MFL (LIN#2) Timeout]
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00022.03.22 Dataset Number: v1260x015G0 0000
   Coding: 0101
   VCID: 4CC1607166403F2A63B-8018
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000089455009 Dataset Number: V03935342UT 0001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 323D1E89E4A449DA097-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 393 P    HW: 5Q4 959 393 P
   Component: TSG FS        009 0911
   Serial number: 0000458826246  Dataset Number: V03935351XF 0001
   Coding: 001000208001020000001100
   ROD: EV_DCU2DriveSideMAXHCONT_SK37.rod
   VCID: 50F974018A681BCA1F3-8004
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000059747520
   Coding: 1D0200
          B1487 54 [00001001] - Missing Calibration / Basic Setting
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Dataset Number: V03935310ZH 0001
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D8915E3007EADBB-8020
16275 - Steering Angle Sensor
          B1168 F2 [00001001] - Not Initialized
Address 4B: Multifunc. Module
   Part No SW: 5Q4 959 392 P    HW: 5Q4 959 392 P
   Component: TSG BFS       009 0911
   Serial number: 0000458744659  Dataset Number: V03935351WV 0001
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 4FFB777D97560432069-801A
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000059792280
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3V0 035 820 H    HW: 3V0 035 820 H
   Component: MU-O-ND-EU    H22 0306
   Serial number: SKZAZ2A0337598  Dataset Number: V03935351FR 0001
   Coding: 33261008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_SK37.rod
   VCID: 33331B8D1BBE40D2021-8066
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [00001001] - Open Circuit
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [00001001] - Open Circuit
7169 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [A/C system (0x01) - function restriction due to communication error - BapErr_retry not successful]
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000201VIHJ9 Dataset Number: V03935359XV 0001
   Coding: 032610101969A8809025460161052607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4ACD66696C34211A517-801E
9457427 - Speaker for Emergency Calling
          B14A6 13 [00001001] - Open Circuit
12866049 - Databus
          [Airbag: Error value received]
7234 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Climate Master (0x42) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
0048 - Databus
          [Clima: No communication]
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
Address D8: LED HeadL. Pwr Left
Address D9: LED HeadL. Pwr Right
End----------(Elapsed Time: 01:34, VBatt start/end: 13.5V/13.5V)-----------
------------------------------48 Faults Found------------------------------
and faults in module itself:
Tuesday,12,May,2026,18:39:37:45700
VCDS Version: Release 26.3.0 (x64) Running on Windows 10 x64
Address 4B: Multifunc. Module Labels: 3Q0-907-338-V2.clb
Control Module Part Number: 3Q0 907 338 E HW: 3Q0 907 338 E
Component and/or Version: FCM MQB Low 003 0367
Software Coding: 000000070900036E00003D01190000000000000000000000000000000000
Work Shop Code: WSC 00033 790 00176
ASAM Dataset: EV_MultiModulContiVW48X 003003 (SK37)
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372B2F9D0FC6ACF23E9-8062
Fault Codes have been Erased
131080 - Databus Front Lights
U1504 00 [10001001] - No Communications
[Databus AFS no communication]
Reset counter: 2
Mileage: 50496 km
Date: 2025.08.13
Time: 04:05:54
Cant get my head around it....
downtime
Finland
C?ID=280813
What CAN and where did you connect?
vagcars69
C?ID=413796
Followed erwin diagram and connected orange brown/orange read near gateway plug. module also uses cans on orange gree/orange grey also connected to wire near gateway plug.
downtime
Finland
C?ID=280813
did you clear all dtcs before taking the autoscan? Because now you have a lot of errors due to missing communications to CAN which could be because of the plug being out
vagcars69
C?ID=413796
Yes that was cleared.
Car is fairly stripped - dashboard out etc thats why there is a few faults.
vagcars69
C?ID=413796
Turns out wiring to the gateway module was incorrect and simply one for obd port thats what was causing it.
vagcars69
C?ID=413796
Still no communication with headlights. Not sure why.
Wednesday,13,May,2026,18:12:45:45700
VCDS Version: 26.5.0.2 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260506 DS376.0
VIN: TMBMJ7NS7N8512   License Plate: KODI
Mileage: 50496km-31376mi   Repair Order:
Scan: 01 02 03 05 09 10 13 15 17 19 22 2B 42 44 4B 52 5F 75 BB BC
          D6 D7
VIN: TMBMJ7NS7N8512   Mileage: 50496km-31376miles
   ROD: EV_ECM20TDI01105L906022KB.rod
   VCID: 71BFD185212232C228F-8024
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [00100110] - -
   VCID: 2615F2D9D86C257A8DD-8072
   No subsystems:
   VCID: 76B5E299484C15FAFDD-8022
4410 - Indicator Lamp in Auto-Hold Switch
          C1156 14 [00001001] - Open or Short to Ground
8356 - Databus
32837 - Lamp in Switch for Electronic Parking Brake
          C1145 13 [10001001] - Open Circuit
   Coding: 0F20000723
   VCID: 48C95C617238D30A5F1-801C
   Serial number: 01102212302352 Dataset Number: V03935432RP 0001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7BA3F3AD736E4892823-802E
   Coding: 104D0D
   Coding: 00885D
10 Faults Found:
65800 - Rear Vehicle Height/Level Sensor
          C114E 29 [00001000] - Signal Implausible
          [Geber für Fahrzeugniveau hinten unplausibles Signal]
65802 - Rear Vehicle Height/Level Sensor
          C114E 15 [00001000] - Open or Short to Plus
          [Geber für Fahrzeugniveau hinten Unterbrechung/Kurzschluss nach Plus]
65806 - Rear Vehicle Height/Level Sensor
          C114E 04 [00001000] - Internal System Fault
          [Geber für Fahrzeugniveau hinten defekt]
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [00001000] - Open Circuit
133131 - Voltage Supply Terminal 30
          B1423 13 [00001000] - Open Circuit
137217 - Outside temperature sensor
          B103F 1B [00001000] - Resistance Too High
395273 - Control Circuit for Signal Horn
          B1344 14 [00001000] - Open or Short to Ground
460041 - Heated Rear Window
          B1265 14 [00001000] - Open or Short to Ground
539157 - Databus
787211 - Windshield Washer Pump
          B1261 13 [00001000] - Open Circuit
   Coding: 0001050011
   VCID: 38292CA102D8A38A2F1-806C
13637426 - Databus
   Dataset Number: V03935383SB 0001
   VCID: 73B3DB8D5B3E00D2DA3-8026
2082 - Databus
2101 - Databus
2055 - Databus
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 2809FCE1D278330ABF1-807C
14 Faults Found:
1050117 - Databus
   VCID: 1E65DA39803CFDBAC5D-804A
   GVL: 01C63C0000000600000C80008000C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 79AFE9A579527A8290F-802C
   Generator:
   Coding: 0101
   VCID: 4CC1607166403F2A7B9-8018
   VCID: 323D1E89E4A449DA115-8066
   VCID: 50F974018A681BCA071-8004
   Coding: 1D0200
   Coding: 01170000
   VCID: 74B1D8915E3007EAC39-8020
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17052111603215 Dataset Number: V03935295XH 0001
   Coding: 000000070900037600003D01190000000000000000000000000000000000
   Shop #: WSC 00033 790 00176
   VCID: 372B2F9D0FC6ACF226B-8062
0032 - Headlight
          C107E 54 [10001001] - Missing Calibration / Basic Setting
   VCID: 4FFB777D975604321EB-801A
   Coding: 050200
   VCID: 33331B8D1BBE40D21A3-8066
   VCID: 4ACD66696C34211A495-801E
12866049 - Databus
0048 - Databus
End----------(Elapsed Time: 01:25, VBatt start/end: 13.5V/13.5V)-----------
------------------------------51 Faults Found------------------------------
downtime
Finland
C?ID=280813
Where did you connect the light CAN wires? They go to 4B, not CAN gateway. You did take that into account?
vagcars69
C?ID=413796
Yes
its been corrected. Headlight bus wires now go to 4b.
I played with some coding and got modules visible but not sure these are correct codings. I am struggling to find correct adaptations. Current scan:
Wednesday,13,May,2026,19:17:55:45700
          D6 D7
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
   No subsystems:
8356 - Databus
   Coding: 0F20000723
   Coding: 104D0D
   Coding: 00885D
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [00001001] - Open or Short to Plus
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [00001001] - Open or Short to Plus
21772 - LED Headlamp Power Output Stage; Left
          B149C 01 [00001001] - Electrical Failure
22028 - LED Headlamp Power Output Stage; Right
          B149B 01 [00001001] - Electrical Failure
539157 - Databus
   Coding: 0001050011
13637426 - Databus
2082 - Databus
2101 - Databus
2055 - Databus
14 Faults Found:
1050117 - Databus
   Generator:
   Coding: 0101
   Coding: 1D0200
   Coding: 01170000
66881 - Databus
          [LED_L_falsch_codiert received error value]
66882 - Databus
          [LED_R_falsch_codiert received error value]
66889 - Databus
          U1123 00 [10001001] - Received Error Message
          [LED_L_Allg_Elektr_Def received error value]
66896 - Databus
          [LED_R_Allg_Elektr_Def received error value]
0032 - Headlight
   Coding: 050200
12866049 - Databus
0048 - Databus
   Part No SW: 992 941 572 CE    HW: 992 941 572 C
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6889BCE112F8F30A7F1-803C
131081 - Headlamp Type
          C119F 00 [10101111] - Implausible
131097 - Terminal 30
          U1407 00 [10101111] - Implausible Signal
   Component: LED1R         H08 9202
End----------(Elapsed Time: 01:27, VBatt start/end: 13.5V/13.5V)-----------
downtime
Finland
C?ID=280813
You need correct datasets for the light modules and 4B. Usually it needs them to be re flashed when you put them to a different car than where they originally were
downtime
Finland
C?ID=280813
Also power supply is probably in wrong terminal. Looks like you’ve taken the power feed from terminal 15 and not term 30. Terminal 15 is behind ignition and terminal 30 is direct battery power
vagcars69
C?ID=413796
Power supply is directly from battery.
Both light modules and 4b are from kodiaq, same as donor headlights. I tried to run coding in odis but it would allow as previously bcm coding was incorrect and wasn't seeing the light modules as installed. Just wondering if I need to do any more modifications before attempting to code with odis again?
In attached pic these are options available to select in bcm. Its headlights only retrofit without a camera.
downtime
Finland
C?ID=280813
Online coding won't work as your car didn't have these from factory.
From that list Fernlicht uber AFS is correct for your current setup.
Also I think you need to enabled LCM in BCM adaptations. And do the leuchte channels correctly because your new lights are not controlled via BCM but they have their own LCM control modules.
Have you checked reference scans if there's adamps from Kodiaq? I should have from Kodiaq RS that had those lights from factory. You should be able to get the coding and adaptations from those. Let me know if you need them
vagcars69
C?ID=413796
I was wondering about odis - will it read factory data? Or will it get current setup from gateway if implemented correctly.
YES I could do with a hand with correct settings and adaptations for bcm and other modules as I am unable to find it anywhere. I was hoping I can simply change from 8IU 8IU but its not as simple as that.
Currently I have some functionality with these lights but obviously indicators etc don't work.
Your help is much appreciated.
TTT
C?ID=547002
ODIS will read own server for factory setup. If changes are done to the vehicle after it left the production, it will not give 2 cents about it.
downtime
Finland
C?ID=280813
here's codings and adamaps for 4B and 09 from Kodiaq with factory 8IU lights.
Was the 4B and the light modules from the same car? 4B from Kodiaq does not really tell much. 8IT and 8IU have different datasets in 4B module and it is very important that all match together. Otherwise you will have problems.
;SW:3Q0-907-338-C   HW:3Q0-907-338-C ---  Multifunc. Module
;Component:FCM MQB Low   002 0345, Coding:000000070900037206002D01190000000000000000000000000000000000
;EV_MultiModulContiVW48X,002006,EV_MultiModulContiVW48X_002_VW41.rod
;Friday,29,March,2019,08:12:11:02525
;VCDS Version: Beta 19.1.2 (x64)  Data version: 20190131 DS301.0
;VCID: 3536D10E35C1EB7F4B5-8060
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,No ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,No ,1
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Yes ,1
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,No ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE01996-SFT33031-Installation list: specified installations-Antenna Control Module,No ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE08418-Matrix light: total dimming,0.0 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46,OFF ,12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47,OFF ,12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48,OFF ,12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49,OFF ,12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50,OFF ,12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51,OFF ,12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52,OFF ,12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53,OFF ,12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54,OFF ,12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55,OFF ,12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56,OFF ,12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57,OFF ,12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58,OFF ,12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59,OFF ,12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60,OFF ,12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61,OFF ,12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62,OFF ,12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63,OFF ,12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64,OFF ,12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65,OFF ,12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66,OFF ,12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67,OFF ,12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68,OFF ,12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69,OFF ,12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70,OFF ,12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71,OFF ,12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72,OFF ,12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73,OFF ,12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74,OFF ,12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75,OFF ,12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76,OFF ,12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77,OFF ,12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78,OFF ,12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79,OFF ,12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80,OFF ,12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81,OFF ,12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82,OFF ,12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83,OFF ,12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84,OFF ,12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85,OFF ,12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86,OFF ,12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87,OFF ,12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88,OFF ,12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89,OFF ,12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90,OFF ,12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46,OFF ,12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47,OFF ,12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48,OFF ,12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49,OFF ,12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50,OFF ,12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51,OFF ,12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52,OFF ,12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53,OFF ,12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54,OFF ,12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55,OFF ,12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56,OFF ,12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57,OFF ,12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58,OFF ,12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59,OFF ,12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60,OFF ,12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61,OFF ,12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62,OFF ,12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63,OFF ,12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64,OFF ,12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65,OFF ,12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66,OFF ,12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67,OFF ,12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68,OFF ,12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69,OFF ,12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70,OFF ,12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71,OFF ,12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72,OFF ,12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73,OFF ,12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74,OFF ,12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75,OFF ,12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76,OFF ,12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77,OFF ,12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78,OFF ,12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79,OFF ,12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80,OFF ,12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81,OFF ,12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82,OFF ,12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83,OFF ,12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84,OFF ,12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85,OFF ,12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86,OFF ,12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87,OFF ,12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88,OFF ,12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89,OFF ,12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90,OFF ,12
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1,OFF ,3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2,OFF ,3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3,OFF ,3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4,OFF ,3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5,OFF ,3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6,OFF ,3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7,OFF ,3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8,OFF ,3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9,OFF ,3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10,OFF ,3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11,OFF ,3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12,OFF ,3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13,OFF ,3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14,OFF ,3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15,OFF ,3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16,OFF ,3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17,OFF ,3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18,OFF ,3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19,OFF ,3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20,OFF ,3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1,OFF ,3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2,OFF ,3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3,OFF ,3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4,OFF ,3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5,OFF ,3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6,OFF ,3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7,OFF ,3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8,OFF ,3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9,OFF ,3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10,OFF ,3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11,OFF ,3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12,OFF ,3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13,OFF ,3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14,OFF ,3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15,OFF ,3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16,OFF ,3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17,OFF ,3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18,OFF ,3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19,OFF ,3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20,OFF ,3
IDE13611-Cornering lamp in operation,not active ,1
IDE13612-Matrix head lamps: steering angle,9600.00 °,2
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:09
;SW:5Q0-937-086-BR   HW:5Q0-937-086-BR ---  Cent. Elect.
;Component:BCM PQ37BOSCH 036 0265, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,019001,EV_BCMBOSCH_019.rod
;Friday,29,March,2019,08:07:30:02525
;VCID: 0B4257F603C5CD8FCD1-805E
IDE01550-Service position,157.999843 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,26.5 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,1.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,127.5 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,55 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,127.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,17 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04928-MAS01577-Anti-theft device-Parking heater,installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 42 00 25 13 17 64 1E 00 64 00 00 00 00 00 00 04 38 00 24 12 16 64 1E 00 64 00 00 00 00 00 00 01 42 00 23 13 17 7F 1E 00 7F 00 00 00 00 00 00 01 38 00 22 12 16 7F 1E 00 7F 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 0A 08 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 09 08 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C6 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 65 63 57 9B 25 44 3F 3A 69 58 95 1F 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 53 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 53 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 52 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 65 53 57 9B 25 24 0C FA 0A 34 95 1F 09 A3 21 03 00 02 02 02 02 02 02 B1 40 E1 28 FE ,172
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,37.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,37.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,43.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,42.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,43.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,42.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13129-Button in center console-Function of button 2,Offroad ,8
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,not_active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,not_active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,not_active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,not active ,8
IDE07356-Position during interval mode,19.296684 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,coupled ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.40 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,1 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,4 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,4 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,20 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,4 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,50 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,50 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,70 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,70 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,0.000000 °,2
IDE10299-Alternating park position 2,18.296685 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.37 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000011  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00110000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00001100  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00011001  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,0 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,40 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,10 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,37 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,127 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,0 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,125 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,125 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,127 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,125 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,127 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,125 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,0 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,40 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,10 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,37 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,40 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,10 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,37 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,40 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,10 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,37 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,1.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,235 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,57 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,5 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,55 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,40 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,240 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,222 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,255 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,255 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,221 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,172 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,108 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,116 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,76 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,102 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,192 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,204 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,217 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,182 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,255 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,253 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,242 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,252 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,132 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,1 ,30
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber,not active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,71 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,6 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,2 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,106 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,182 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,254 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,153 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,4 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,231 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,132 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,200 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,73 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,9 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,134 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,140 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,110 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,245 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,120 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,57 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,255 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,173 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,255 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,255 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,106 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,29 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,58 ,30
MAS05055-lower turn position,20.692287 °,2
MAS05056-upper turn position,159.999841 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,7 ,60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,8 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,5 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,8 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,9 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,12 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,13 ,60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,16 ,60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,17 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,installed ,60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,7 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,8 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,4 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,4 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,3 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,9 ,23
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,50 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,50 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,0 ms,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,83.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,67.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,50.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,33.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,17.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-0.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-0.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-0.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,0.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,0.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,0.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,0.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,0.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,0.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,0.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,0.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,0.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,36 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,27 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,3F ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,26 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,35 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,32 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten ,16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,100 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,25 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,42 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Nebellicht rechts ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Abbiegelicht rechts ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,100 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,24 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,38 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Nebellicht links ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Abbiegelicht links ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,23 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,42 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Nebellicht rechts ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Abbiegelicht rechts ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,22 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,38 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Nebellicht links ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Abbiegelicht links ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Parking light right ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 24 00 20 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1A 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2700 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,5.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,5.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,5.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.03 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.03 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,0.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,1000.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,0.0 %,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,20 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00 ,20
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Skoda ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,72.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,48.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,33.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,18.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,12.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,8.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,6.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,4.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,2.0 %,22
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,0 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,20.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,installed ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,installed ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys,not active ,8
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
Elapsed Time: 01:44
vagcars69
C?ID=413796
Thanks for that.
there was no 4b module installed, I had them installed but most likely both lights and module from 3 different cars.
Any way to filter out the settings related to headlights only?
downtime
Finland
C?ID=280813
Copy it to notepad++, easier to read
vagcars69
C?ID=413796
This is my configuration:
;SW:5Q0-937-084-EA   HW:5Q0-937-084-EA ---  09: Cent. Elect.
;Component:BCM MQBAB MxL H44 0511     Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB    22001    EV_BCMBOSCH_022_SK37.rod
;Thursday    14    May    2026    18:54:05:45700
;VCDS Version: 26.3.0.0 (x64)  Data version: 20260320 DS375.1
;VCID: 7BA3F3AD736E48929A1-802E
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE01550-Service position    158.010832 °    2
IDE02152-Characteristics in production mode    2000 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active     10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    not active     10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active     10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    not active     10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    normal     10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    not active     10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active     10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    not active     10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    not active     10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    200 ms    10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit    200 ms    10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit    200 ms    10
IDE02332-Deactivate production mode    0    3
IDE02488-Anti-theft system interior monitoring    100%    1
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    active     8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active     8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s    8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s    8
IDE02711-ENG112304-Rear wiper-Heckwischer    logikgesteuert     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer    Keine_Spannungsanforderung     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    not active     8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck    0 ms    8
IDE03638-IDE04231-Static cornering light-Steering wheel angle: offset    -0.3 °    16
IDE03638-ENG116677-Static cornering light-Abdimmgeschwindigkeit    26.5 %/s    16
IDE03638-ENG116673-Static cornering light-bei Rueckwaertsfahrt    OFF     16
IDE03638-ENG116675-Static cornering light-Lower speed threshold    0.0 km/h    16
IDE03638-ENG116682-Static cornering light-Maximaltemperatur    1.0 °C    16
IDE03638-ENG116679-Static cornering light-obere Grenztemperatur    127.5 °C    16
IDE03638-ENG116681-Static cornering light-Oberer Lenkradwinkel    55 °    16
IDE03638-ENG116680-Static cornering light-untere Grenztemperatur    127.0 °C    16
IDE03638-ENG116678-Static cornering light-Unterer Lenkradwinkel    30 °    16
IDE03638-ENG116676-Static cornering light-Upper speed threshold    40.0 km/h    16
IDE03638-ENG116674-Static cornering light-Vorschrift    OFF     16
IDE03638-ENG115830-Static cornering light-Zeitwert Einschaltzeit Abbiegelicht    15 min    16
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE04927-IDE01446-Window heater-Running time of heated front window    600 s    11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 °C    11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 °C    11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer    0 s    11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt    not installed     11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed     11
IDE04927-ENG126845-Window heater-FSH Automatik    active     11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s    11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe    installed     11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe    not installed     11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage    not installed     11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    not active     11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    not active     11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv    -2.0 °C    11
IDE04927-ENG141962-Window heater-Waschduesenheizung    not installed     11
IDE04927-ENG154810-Window heater-window heating front activation time pause    240 s    11
IDE04928-MAS01577-Anti-theft protection-Auxiliary heating    not installed     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system    active     8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick    activ     8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI    activ     8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    driver door contact thatcham     8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder    Sounder_verbaut     8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor    not installed     8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    No     8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm    activ     8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm    activ     8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    No     8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung    Yes     8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    10 Alarme     8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor    Yes     8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active     8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    2 sekunden verzoegerung     8
IDE05143-MAS02985-Writing parameter-Value    130    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-Light configuration    21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 48 00 4A 08 09 1B 14 00 64 06 00 80 00 00 00 04 4C 00 4C 08 0A 1B 14 00 64 07 00 80 00 00 00 01 48 00 49 14 00 7F 08 09 7F 06 00 80 00 00 00 01 4C 00 4B 14 00 7F 08 0A 7F 07 00 80 00 00 00 05 36 00 1A 0B 00 7F 0D 0F 7F 00 00 00 00 00 00 05 40 00 1B 0C 00 7F 0E 0F 7F 00 00 00 00 00 00 06 37 00 1C 0D 0F 7F 00 00 00 00 00 00 00 00 00 06 41 00 1D 0E 0F 7F 00 00 00 00 00 00 00 00 00 02 52 00 55 0B 0D 7F 0F 00 7F 00 00 00 00 00 00 02 53 00 56 0C 0E 7F 0F 00 7F 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00     224
IDE05822-Anti-theft alarm system vehicle inclination sensor    100%    1
IDE05823-DWA Interior monitoring parameter set    01 0A 08 00 43 53 0A C6 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 65 63 57 9B 25 44 3F 3A 69 58 95 1F 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 53 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 53 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 52 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 65 53 57 9B 25 24 0C FA 0A 34 95 1F 09 A3 21 03 00 02 02 02 02 02 02 B1 40 E1 28 FE     172
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler    0    30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN    not_installed     30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s    30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C    30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    33.00 °C    30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    32.00 °C    30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    33.00 °C    30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    32.00 °C    30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    38.00 °C    30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    37.00 °C    30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    38.00 °C    30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    37.00 °C    30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    41.00 °C    30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    40.00 °C    30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    41.00 °C    30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    40.00 °C    30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI    Keine_Spannungsanforderung     30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO    Keine_Spannungsanforderung     30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed     30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75    15.0 V    30
IDE06425-Dynamometer mode: functional    not active     1
IDE06507-MAS13125-Button in center console-Function of button 1    Start-stop     8
IDE06507-MAS13129-Button in center console-Function of button 2    not coded / not installed     8
IDE06507-MAS13132-Button in center console-Function of button 3    not coded / not installed     8
IDE06507-MAS13135-Button in center console-Function of button 4    not coded / not installed     8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED installed     8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich    not_active     8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt    not active     8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige    not_active     8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik    not_active     8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    not active     8
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbaut    not installed     8
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed     8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut    not installed     8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    not active     8
IDE07356-Position during interval mode    19.307673 °    2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit     6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    active     6
IDE08577-Garage door opener: use of GPS data    No Response From Subnet Component    6
IDE08578-Garage door opener: bi-directional communic.    No Response From Subnet Component    6
IDE08579-Garage door opener: drift adapt.    No Response From Subnet Component    6
IDE08580-Garage door opener: increasing transm. power    No Response From Subnet Component    6
IDE08583-Garage door opener: no. of channels    No Response From Subnet Component    6
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A    No Response From Subnet Component    6
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B    No Response From Subnet Component    6
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C    No Response From Subnet Component    6
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D    No Response From Subnet Component    6
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E    No Response From Subnet Component    6
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F    No Response From Subnet Component    6
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G    No Response From Subnet Component    6
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H    No Response From Subnet Component    6
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I    No Response From Subnet Component    6
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J    No Response From Subnet Component    6
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K    No Response From Subnet Component    6
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I    No Response From Subnet Component    6
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II    No Response From Subnet Component    6
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III    No Response From Subnet Component    6
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV    No Response From Subnet Component    6
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB    No Response From Subnet Component    6
IDE08585-Garage door opener: activation via remote key    No Response From Subnet Component    6
IDE08778-Garage door opener: surround. target area    No Response From Subnet Component    6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     9
IDE08786-ENG141956-Assistance light functions-Humidity sensor    installed     9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal     9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    not active     9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion    not active     9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR     9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor    not installed     9
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time    No Response From Subnet Component    9
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function    No Response From Subnet Component    9
IDE09377-IDE03007-Multi-contour seat driver's side-Component location    No Response From Subnet Component    9
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment    No Response From Subnet Component    9
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory    No Response From Subnet Component    9
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time    No Response From Subnet Component    9
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function    No Response From Subnet Component    9
IDE09378-IDE03007-Multi-contour seat passenger side-Component location    No Response From Subnet Component    9
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment    No Response From Subnet Component    9
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory    No Response From Subnet Component    9
IDE09546-Multicontour seat on driver's side: reset compressor counter    No Response From Subnet Component    9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter    No Response From Subnet Component    9
IDE09548-Multicontour seat on driver's side: reset adaptation    No Response From Subnet Component    9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation    No Response From Subnet Component    9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual    0    19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual    11    19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation    not active     19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung    not active     19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default    not active     19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.25 s    19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    2    19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    1    19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    4    19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    20%    19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    30%    19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    0%    19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    active     19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    active     19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active     19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting    Keine_Spannungsanforderung     19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    not active     19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    not installed     19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    not installed     19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    not installed     19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active     19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default    1    5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI    not active     5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed     5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    not installed     5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    not active     5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    not active     5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    not installed     5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    not installed     5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    not active     5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed     5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    30%    17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    30%    17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    50%    17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    50%    17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    50%    17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    50%    17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    50%    17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    50%    17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    70%    17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    70%    17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics    not installed     17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung    not installed     17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar    installed     17
IDE10298-Alternating park position 1    0.010989 °    2
IDE10299-Alternating park position 2    18.307674 °    2
IDE10308-Garage door opener: support door name    No Response From Subnet Component    2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode    No Response From Subnet Component    2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1    No Response From Subnet Component    2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2    No Response From Subnet Component    2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3    No Response From Subnet Component    2
IDE10350-Garage door opener: programming antenna    No Response From Subnet Component    2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    0    256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    0    256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    0    256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    0    256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    0    256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    0    256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    1    256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    0    256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    0    256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    0    256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0    256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0    256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    0    256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    0    256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    0    256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0    256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1    256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1    256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    0    256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0    256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    0%    256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    0%    256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    0%    256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    0%    256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    0%    256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%    256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    0%    256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    0%    256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    0%    256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    100%    256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    0%    256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    0%    256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    0%    256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    0%    256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%    256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    0%    256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    0%    256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    0%    256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    100%    256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    0%    256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    0%    256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    0%    256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    0%    256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    0%    256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    0%    256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    0%    256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    0%    256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    0%    256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    0%    256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    0%    256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    0%    256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    0%    256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    100%    256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    0%    256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    0%    256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    0%    256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    0%    256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%    256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    0%    256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    0%    256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    126%    256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    0%    256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    0%    256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    0%    256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    0%    256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    0%    256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%    256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    0%    256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    0%    256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    0%    256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    100%    256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    0%    256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    0%    256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    0%    256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    0%    256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    0%    256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    0%    256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    100%    256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    0%    256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    0%    256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    0%    256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    0%    256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    0%    256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    0%    256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    0%    256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    0%    256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    200 ms    256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s    256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s    256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s    256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s    256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s    256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s    256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s    256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s    256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    0.0 s    256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s    256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s    256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.0 s    256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s    256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s    256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s    256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s    256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s    256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s    256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s    256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s    256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s    256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s    256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s    256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s    256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s    256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s    256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s    256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s    256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s    256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s    256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s    256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s    256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s    256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s    256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s    256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s    256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s    256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s    256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s    256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s    256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s    256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s    256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0    256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1    235    30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10    0    30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2    0    30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3    0    30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4    0    30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5    0    30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6    0    30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7    0    30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8    0    30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9    0    30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1    221    30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10    0    30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2    0    30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3    0    30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4    0    30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5    0    30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6    0    30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7    0    30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8    0    30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9    0    30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1    217    30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10    0    30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2    0    30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3    0    30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4    0    30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5    0    30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6    0    30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7    0    30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8    0    30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9    0    30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung    installed     3
IDE11944-ENG141948-Keyless access and start authorization-Kessy    installed     3
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber    active     3
IDE11944-ENG281099-Keyless access and start authorization-Kessy Einzeltuerentriegelung NAR    not active     3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen    not active     3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen    active     3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung    not active     3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit    active     3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit    not active     3
IDE11944-ENG281087-Keyless access and start authorization-Kessy Toggle Taster (NAR)    not installed     3
IDE11944-ENG281074-Keyless access and start authorization-Komfort_oeffnen_ueber_Toggle_Taster    not active     3
IDE11944-ENG281094-Keyless access and start authorization-Komfort_schliessen_ueber_Toggle_Taster    not active     3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung    active     3
IDE11944-ENG281083-Keyless access and start authorization-Verriegeln über Toggle nur bei geschlossener Außenhaut    not active     3
IDE12119-Garage door opener: frequency range of bi-directional communication    No Response From Subnet Component    3
IDE12120-Garage door opener: piloted parking    No Response From Subnet Component    3
IDE12121-Garage door opener: vehicle variant    No Response From Subnet Component    3
IDE12122-Garage door opener: continuous transmission mode for level measurement    No Response From Subnet Component    3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module    Not available     6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor    Not available     6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch    Not available     6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module    Not available     6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head    Not available     6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor    Not available     6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn    Not available     6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module    Not available     6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module    Not available     6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module    Not available     6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior    Not available     6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater    Not available     6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater    Not available     6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest    Not available     6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion    Not available     6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest    Not available     6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion    Not available     6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control    Not available     6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch    Not available     6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin    0    30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin    0    30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin    0    30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin    0    30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin    0    30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin    0    30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin    0    30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin    0    30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin    0    30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin    0    30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin    0    30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin    0    30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin    0    30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin    0    30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin    0    30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin    0    30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin    0    30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin    0    30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin    0    30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin    0    30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin    0    30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin    0    30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin    0    30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin    0    30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin    0    30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin    0    30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin    0    30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin    0    30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin    0    30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin    0    30
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer    No Response From Subnet Component    30
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster    No Response From Subnet Component    30
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung    No Response From Subnet Component    30
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle    No Response From Subnet Component    30
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle    No Response From Subnet Component    30
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf    No Response From Subnet Component    30
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m    No Response From Subnet Component    30
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o    No Response From Subnet Component    30
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u    No Response From Subnet Component    30
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen    No Response From Subnet Component    30
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz    No Response From Subnet Component    30
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck    No Response From Subnet Component    30
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m    No Response From Subnet Component    30
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o    No Response From Subnet Component    30
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u    No Response From Subnet Component    30
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage    No Response From Subnet Component    30
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen    No Response From Subnet Component    30
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash    No Response From Subnet Component    30
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung    No Response From Subnet Component    30
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung    No Response From Subnet Component    30
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung    No Response From Subnet Component    30
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung    No Response From Subnet Component    30
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster    No Response From Subnet Component    30
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung    No Response From Subnet Component    30
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle    No Response From Subnet Component    30
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle    No Response From Subnet Component    30
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf    No Response From Subnet Component    30
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m    No Response From Subnet Component    30
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o    No Response From Subnet Component    30
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u    No Response From Subnet Component    30
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen    No Response From Subnet Component    30
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz    No Response From Subnet Component    30
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck    No Response From Subnet Component    30
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m    No Response From Subnet Component    30
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o    No Response From Subnet Component    30
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u    No Response From Subnet Component    30
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage    No Response From Subnet Component    30
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen    No Response From Subnet Component    30
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash    No Response From Subnet Component    30
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung    No Response From Subnet Component    30
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung    No Response From Subnet Component    30
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung    No Response From Subnet Component    30
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD    No Response From Subnet Component    30
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen    No Response From Subnet Component    30
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD    No Response From Subnet Component    30
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen    No Response From Subnet Component    30
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf    No Response From Subnet Component    30
IDE80016-Analysis 16    No Response From Subnet Component    30
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM    No Response From Subnet Component    30
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO    No Response From Subnet Component    30
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU    No Response From Subnet Component    30
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH    No Response From Subnet Component    30
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM    No Response From Subnet Component    30
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO    No Response From Subnet Component    30
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU    No Response From Subnet Component    30
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH    No Response From Subnet Component    30
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM    No Response From Subnet Component    30
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO    No Response From Subnet Component    30
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU    No Response From Subnet Component    30
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH    No Response From Subnet Component    30
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO    No Response From Subnet Component    30
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU    No Response From Subnet Component    30
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH    No Response From Subnet Component    30
IDE80017-ENG133480-Analysis 17-OffsetPP1    No Response From Subnet Component    30
IDE80017-ENG133481-Analysis 17-OffsetPP2    No Response From Subnet Component    30
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy    No Response From Subnet Component    30
IDE80017-ENG133478-Analysis 17-OffsetT1    No Response From Subnet Component    30
IDE80017-ENG133479-Analysis 17-OffsetT2    No Response From Subnet Component    30
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout    No Response From Subnet Component    30
IDE80017-ENG133491-Analysis 17-p_longpush_time    No Response From Subnet Component    30
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins    No Response From Subnet Component    30
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei    No Response From Subnet Component    30
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins    No Response From Subnet Component    30
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf    No Response From Subnet Component    30
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier    No Response From Subnet Component    30
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen    No Response From Subnet Component    30
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung    No Response From Subnet Component    30
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften    No Response From Subnet Component    30
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt    No Response From Subnet Component    30
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen    No Response From Subnet Component    30
IDE80017-ENG133465-Analysis 17-s_MaxIntervall    No Response From Subnet Component    30
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung    No Response From Subnet Component    30
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung    No Response From Subnet Component    30
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung    No Response From Subnet Component    30
IDE80017-ENG133468-Analysis 17-s_Sitzvariante    No Response From Subnet Component    30
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich    No Response From Subnet Component    30
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich    No Response From Subnet Component    30
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u    No Response From Subnet Component    30
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o    No Response From Subnet Component    30
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM    No Response From Subnet Component    30
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU    No Response From Subnet Component    30
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH    No Response From Subnet Component    30
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM    No Response From Subnet Component    30
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO    No Response From Subnet Component    30
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU    No Response From Subnet Component    30
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH    No Response From Subnet Component    30
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM    No Response From Subnet Component    30
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO    No Response From Subnet Component    30
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU    No Response From Subnet Component    30
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH    No Response From Subnet Component    30
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO    No Response From Subnet Component    30
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU    No Response From Subnet Component    30
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH    No Response From Subnet Component    30
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO    No Response From Subnet Component    30
IDE80018-ENG133480-Analysis 18-OffsetPP1    No Response From Subnet Component    30
IDE80018-ENG133481-Analysis 18-OffsetPP2    No Response From Subnet Component    30
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy    No Response From Subnet Component    30
IDE80018-ENG133478-Analysis 18-OffsetT1    No Response From Subnet Component    30
IDE80018-ENG133479-Analysis 18-OffsetT2    No Response From Subnet Component    30
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout    No Response From Subnet Component    30
IDE80018-ENG133491-Analysis 18-p_longpush_time    No Response From Subnet Component    30
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins    No Response From Subnet Component    30
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei    No Response From Subnet Component    30
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins    No Response From Subnet Component    30
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf    No Response From Subnet Component    30
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier    No Response From Subnet Component    30
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen    No Response From Subnet Component    30
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung    No Response From Subnet Component    30
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften    No Response From Subnet Component    30
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt    No Response From Subnet Component    30
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen    No Response From Subnet Component    30
IDE80018-ENG133465-Analysis 18-s_MaxIntervall    No Response From Subnet Component    30
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung    No Response From Subnet Component    30
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung    No Response From Subnet Component    30
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung    No Response From Subnet Component    30
IDE80018-ENG133468-Analysis 18-s_Sitzvariante    No Response From Subnet Component    30
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich    No Response From Subnet Component    30
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich    No Response From Subnet Component    30
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u    No Response From Subnet Component    30
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u    No Response From Subnet Component    30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung    active     5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active     5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug    not installed     5
MAS01490-ENG141950-Energy management-Hybrid vehicle    No     5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement    not active     5
MAS01490-ENG141978-Energy management-Recuperation    active     5
MAS01490-ENG142037-Energy management-Zweitbatterie    not installed     5
MAS05055-lower turn position    20.703276 °    2
MAS05056-upper turn position    160.208632 °    2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx    24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx    24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    1000 lx    24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx    24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx    24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx    24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 50     24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    4000 lx    24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    not active     24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain    not active     24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    frueh     24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    not active     24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active     24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    4500 mV    24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    6000 lx    24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    2000 mV    24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    2    24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status    not active     9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC    00 00 00     9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC    First_dtc     9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    active     4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    active     4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler    not installed     4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11    0    60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12    0    60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13    0    60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14    0    60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15    0    60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16    0    60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17    0    60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18    0    60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19    0    60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20    0    60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21    0    60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22    0    60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23    0    60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24    0    60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25    0    60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26    0    60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27    0    60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28    0    60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29    0    60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30    0    60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11    0    60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12    0    60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13    0    60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14    0    60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15    0    60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16    0    60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17    0    60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18    0    60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19    0    60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20    0    60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21    0    60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22    0    60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23    0    60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24    0    60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25    0    60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26    0    60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27    0    60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28    0    60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29    0    60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30    0    60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11    0    60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12    0    60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13    0    60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14    0    60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15    0    60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16    0    60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17    0    60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18    0    60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19    0    60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20    0    60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21    0    60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22    0    60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23    0    60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24    0    60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25    0    60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26    0    60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27    0    60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28    0    60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29    0    60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30    0    60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin    0    60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin    0    60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin    0    60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin    0    60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin    0    60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin    0    60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin    0    60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin    0    60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin    0    60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin    0    60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin    0    60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin    0    60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin    0    60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin    0    60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin    0    60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin    0    60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin    0    60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin    0    60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin    0    60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin    0    60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin    0    60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin    0    60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin    0    60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin    0    60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin    0    60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin    0    60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin    0    60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin    0    60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin    0    60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin    0    60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin    0    60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin    0    60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin    0    60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin    0    60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin    0    60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin    0    60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin    0    60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin    0    60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin    0    60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin    0    60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin    0    60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin    0    60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin    0    60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin    0    60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin    0    60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin    0    60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin    0    60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin    0    60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin    0    60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin    0    60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin    0    60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin    0    60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin    0    60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin    0    60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin    0    60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin    0    60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin    0    60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin    0    60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin    0    60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin    0    60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    not installed     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    0    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    0    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    0    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    0    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    0    60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    not installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    not installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    not installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    not installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung    No Response From Subnet Component    60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht    No Response From Subnet Component    60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1    No Response From Subnet Component    60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1    No Response From Subnet Component    60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2    No Response From Subnet Component    60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2    No Response From Subnet Component    60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung    No Response From Subnet Component    60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten    No Response From Subnet Component    60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3    No Response From Subnet Component    60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne    No Response From Subnet Component    60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung    No Response From Subnet Component    60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0    No Response From Subnet Component    60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1    No Response From Subnet Component    60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10    No Response From Subnet Component    60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2    No Response From Subnet Component    60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3    No Response From Subnet Component    60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4    No Response From Subnet Component    60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5    No Response From Subnet Component    60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6    No Response From Subnet Component    60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7    No Response From Subnet Component    60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8    No Response From Subnet Component    60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9    No Response From Subnet Component    60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0    No Response From Subnet Component    60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1    No Response From Subnet Component    60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10    No Response From Subnet Component    60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2    No Response From Subnet Component    60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3    No Response From Subnet Component    60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4    No Response From Subnet Component    60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5    No Response From Subnet Component    60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6    No Response From Subnet Component    60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7    No Response From Subnet Component    60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8    No Response From Subnet Component    60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9    No Response From Subnet Component    60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente    Sollspannungsanforderung 13.5     23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0    1    23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1    1    23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10    1    23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11    1    23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12    1    23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13    1    23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14    1    23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15    1    23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2    1    23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3    1    23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4    1    23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5    1    23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6    1    23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7    1    23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8    1    23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9    1    23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken    not active     10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken    active     10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    separte     10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing    not active     10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken    active     10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung    active     10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay    50 ms    10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken    not active     10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen    Warnblinke_zulaessig     10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken    active     10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen    3    10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken    not active     10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    active     10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing    not active     10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS    PreCrash_aktiv     10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links    active     10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts    active     10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken    active     10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken    not active     10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing    active     10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    active     10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken    not active     10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken    not active     10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    not active     10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max    120 min    10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS    active     10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN    active     10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf    active     10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu    active     10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp    H7     9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren    not active     9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze    350 km/h    9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze    350 km/h    9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag    Daytime running lights     9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL    5 km/h    9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich    not active     9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active     9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut    not installed     9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    not active     9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active     9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    not active     9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte    not active     9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    not active     9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    in Betrieb lassen     9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No     5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    0 km/h    5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    active     5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    not active     5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed     5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6    No     18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light    not installed     18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung     18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf    3000 ms    18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten    Low beams     18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus    automatic     18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door     18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    active     18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL     18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer    Faktor fuer x5 Minuten     18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH    Keine_Spannungsanforderung     18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp    Keine_Spannungsanforderung     18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    696 lx    18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    800 lx    18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No     18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker    false     18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL    Yes     18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    Yes     18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht    Yes     18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes     18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled     18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6    not active     18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)    discrete     18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig     18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module    not installed     18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beams    Keine_Spannungsanforderung     18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome    10 seconds     18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    10 seconds     18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active     18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active     18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert    One-sided     18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus    active     18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    active     18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit    24 s    18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6    No     18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp    Keine_Spannungsanforderung     18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    not active     18
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold    No Response From Subnet Component    18
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin    No Response From Subnet Component    18
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold    No Response From Subnet Component    18
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold    No Response From Subnet Component    18
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin    No Response From Subnet Component    18
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold    No Response From Subnet Component    18
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold    No Response From Subnet Component    18
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin    No Response From Subnet Component    18
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold    No Response From Subnet Component    18
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold    No Response From Subnet Component    18
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin    No Response From Subnet Component    18
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold    No Response From Subnet Component    18
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG246955-ENG246967-digital_key-central_locking_digital_key_general    not installed     3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle    not active     3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle    not active     3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246991-digital_key-pa_Two_Keys    active     3
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%    6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%    6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%    6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%    6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%    6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%    6
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD    No Response From Subnet Component    6
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen    No Response From Subnet Component    6
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD    No Response From Subnet Component    6
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen    No Response From Subnet Component    6
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf    No Response From Subnet Component    6
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN    No Response From Subnet Component    6
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM    No Response From Subnet Component    6
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION    No Response From Subnet Component    6
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK    No Response From Subnet Component    6
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK    No Response From Subnet Component    6
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK    No Response From Subnet Component    6
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK    No Response From Subnet Component    6
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN    No Response From Subnet Component    6
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND    No Response From Subnet Component    6
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB    No Response From Subnet Component    6
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM    No Response From Subnet Component    6
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM    No Response From Subnet Component    6
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK    No Response From Subnet Component    6
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE    No Response From Subnet Component    6
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1    No Response From Subnet Component    6
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2    No Response From Subnet Component    6
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3    No Response From Subnet Component    6
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4    No Response From Subnet Component    6
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1    No Response From Subnet Component    6
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2    No Response From Subnet Component    6
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3    No Response From Subnet Component    6
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4    No Response From Subnet Component    6
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1    No Response From Subnet Component    6
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2    No Response From Subnet Component    6
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3    No Response From Subnet Component    6
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4    No Response From Subnet Component    6
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH    No Response From Subnet Component    6
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW    No Response From Subnet Component    6
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT    No Response From Subnet Component    6
ENG122925-DWA_Interior_Monitoring_Data_Set_Development    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     150
ENG122934-erase_error_table    00 00 00     3
ENG122933-error_mask    0 bit    2
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present     6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: Fernlicht ueber AFS     6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    active     6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    Not available     6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    Not available     6
ENG141685-Front_wash_function    10    2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active     6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms    6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active     6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    active     6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig    Keine_Spannungsanforderung     6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    not active     6
ENG141682-ENG141966-Front_wiper-Frontwischertyp    LIN     6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active     6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer    0 ms    6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    Deactivating     6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    0 ms    6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active     6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    not active     6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung    active     6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active     6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    active     6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    not active     6
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed     8
ENG141645-MAS00212-HW_Verbau-Washer fluid low    installed     8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed     8
ENG141645-MAS00214-HW_Verbau-Brake pad wear    installed     8
ENG141645-ENG142026-HW_Verbau-Druckklappe    not installed     8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active     8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung    not installed     8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed     8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed     8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed     8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer    installed     8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active     8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung    not active     8
ENG126651-ENG115658-Kennlinie Abdimmen-x0    No Response From Subnet Component    8
ENG126651-ENG101574-Kennlinie Abdimmen-X1    No Response From Subnet Component    8
ENG126651-ENG115664-Kennlinie Abdimmen-x10    No Response From Subnet Component    8
ENG126651-ENG99557-Kennlinie Abdimmen-X2    No Response From Subnet Component    8
ENG126651-ENG102140-Kennlinie Abdimmen-X3    No Response From Subnet Component    8
ENG126651-ENG102936-Kennlinie Abdimmen-X4    No Response From Subnet Component    8
ENG126651-ENG103548-Kennlinie Abdimmen-X5    No Response From Subnet Component    8
ENG126651-ENG113992-Kennlinie Abdimmen-X6    No Response From Subnet Component    8
ENG126651-ENG115661-Kennlinie Abdimmen-x7    No Response From Subnet Component    8
ENG126651-ENG115662-Kennlinie Abdimmen-x8    No Response From Subnet Component    8
ENG126651-ENG115663-Kennlinie Abdimmen-x9    No Response From Subnet Component    8
ENG126651-ENG115659-Kennlinie Abdimmen-y0    No Response From Subnet Component    8
ENG126651-ENG99777-Kennlinie Abdimmen-Y1    No Response From Subnet Component    8
ENG126651-ENG115668-Kennlinie Abdimmen-y10    No Response From Subnet Component    8
ENG126651-ENG100480-Kennlinie Abdimmen-Y2    No Response From Subnet Component    8
ENG126651-ENG100773-Kennlinie Abdimmen-Y3    No Response From Subnet Component    8
ENG126651-ENG100631-Kennlinie Abdimmen-Y4    No Response From Subnet Component    8
ENG126651-ENG102174-Kennlinie Abdimmen-Y5    No Response From Subnet Component    8
ENG126651-ENG113993-Kennlinie Abdimmen-Y6    No Response From Subnet Component    8
ENG126651-ENG115665-Kennlinie Abdimmen-y7    No Response From Subnet Component    8
ENG126651-ENG115666-Kennlinie Abdimmen-y8    No Response From Subnet Component    8
ENG126651-ENG115667-Kennlinie Abdimmen-y9    No Response From Subnet Component    8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0    100.00%    30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1    83.00%    30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2    67.00%    30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3    50.00%    30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4    33.00%    30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5    17.00%    30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6    0.00%    30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7    0    30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8    0.00%    30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9    0.00%    30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0    51.00%    30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1    47.00%    30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2    43.00%    30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3    33.00%    30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4    29.00%    30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5    24.00%    30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6    20.00%    30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7    20.00%    30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8    20.00%    30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9    20.00%    30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    127    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    14    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    34    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    33 - LED-Modul Blinkleuchten     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    Blinken links Hellphase     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize     16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize     16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize     16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100    16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0    16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0    16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0    16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    0    16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    0    16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    36 - LED Kleinleistung     16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always     16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15    Warnblinktaster_Suchbeleuchtung     16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active     16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active     16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active     16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active     16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active     16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active     16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    127    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    127    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    55    16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    52    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    2 - Shutter: Diagnosesensierung für 'LED low'     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    Abblendlicht links     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    Main beam left     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    Lichthupe generell     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    127    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    127    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    56    16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    53    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    2 - Shutter: Diagnosesensierung für 'LED low'     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    Abblendlicht rechts     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    Main beam right     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    Lichthupe generell     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    100    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    22    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    38    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    10 - allgemeine Scheinwerfer     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Nebellicht links     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    not active     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    100    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    23    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    42    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    10 - allgemeine Scheinwerfer     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Nebellicht rechts     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    not active     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    minimize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    127    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    61    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    36 - LED Kleinleistung     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    only_if_closed     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    127    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    62    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    36 - LED Kleinleistung     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    Coming Home oder Leaving Home aktiv     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    127    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    16    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    38 - LED Blinkleuchten     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Blinken links Hellphase     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    127    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    18    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    38 - LED Blinkleuchten     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Blinken rechts Hellphase     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    127    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E     16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    33 - LED-Modul Blinkleuchten     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    127    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    0    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    2B     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    9    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    34 - LED Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    127    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    0    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    2D     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    19    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    34 - LED Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    34 - LED Bremsleuchten     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    0    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    43 - allgemeine LED     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    not active     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    0    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    43 - allgemeine LED     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Parking light right     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    not active     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    127    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    2F     16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    1C     16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    43 - allgemeine LED     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    only_if_closed     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    0    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    0    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0    16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    not active     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    not active     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    127    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    43 - allgemeine LED     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    127    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    43 - allgemeine LED     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    minimize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    27    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    100    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    4A     16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    48    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    4 - LED Tagfahrlichtmodul Signal     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    Daytime running lights     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    Blinken links aktiv (beide Phasen)     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    0    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    0    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    not active     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    not active     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    3    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    Ambientelicht 1     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    4    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    Ambientelicht 2     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    5    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    Ambientelicht 3     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    6    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    Ambientelicht 4     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    minimize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    27    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    100    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    4C     16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    4C     16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    4 - LED Tagfahrlichtmodul Signal     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    Parking light right     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    Daytime running lights     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    Blinken rechts aktiv (beide Phasen)     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    maximize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    minimize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    127    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    127    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    0    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    49    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    48    16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    1 - LED Tagfahrlichtmodul Versorgung     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lights     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    Blinken links aktiv (beide Phasen)     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    maximize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    minimize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    127    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    127    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    0    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    4B     16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    4C     16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    1 - LED Tagfahrlichtmodul Versorgung     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lights     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    Parking light right     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    Blinken rechts aktiv (beide Phasen)     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    127    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    5 - LED Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    not active     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    Main beam left     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    Lichthupe generell     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    127    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    5 - LED Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    not active     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    Main beam right     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    Lichthupe generell     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    127    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    1C     16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    37    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    6 - LED Lichtmodul     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Main beam left     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    Lichthupe generell     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    127    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    1D     16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    41    16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    6 - LED Lichtmodul     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Main beam right     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    Lichthupe generell     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck    26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1A 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00     192
ENG141662-Leuchtenkonfiguration_Sonstiges    24 00 00 61 3F 00 FF 00 00 80 00 00 00 00 00 00 24 00 00 62 1E 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00     128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR    1-Sensor_LWR     62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    2700 mm    62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    not active     62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze    100.00%    62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze    0.00%    62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung    -114.3 ms    62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz    15%    62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s    62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    5.00 mm/%    62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    5.00 mm/%    62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3    5.00 mm/%    62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    3.00 mm/%    62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    3.00 mm/%    62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3    3.00 mm/%    62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante    Variante_1     62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR    51.00%    62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf    0.03 Hz    62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung    normal     62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal    Negative     62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1    0 mm    62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2    0 mm    62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3    0 mm    62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4    0 mm    62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    550 mm    62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    680 mm    62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%    62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    5.00%    62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr    255 km/h    62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz    62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung    0.03 Hz    62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte    BCM     62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed    Rear     62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    active     62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese    0.00%    62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart    not active     62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad    1000.0 %/s    62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht    0.00%    62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut    HIM     62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s    62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1    2.0 s    7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang    10 s    7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion    active     7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik    active     7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS    Nicht_verbaut     7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark    not active     7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze    100 m    7
ENG246957-ENG246981-Lichttaster-Lichttastermodul    lds     7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config    1    7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle    20 km/h    7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig    active     7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig    active     7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig    not active     7
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active     1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active     1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active     1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active     1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active     1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active     1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active     1
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen    40 ms    27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen    40 ms    27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit    100 ms    27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt    10 ms    27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen    40 ms    27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen    40 ms    27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v    1 km/h    27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen    40 ms    27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen    500 ms    27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i    0.4    27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset    5 °C    27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p    18.00%    27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh    110 W    27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen    40 ms    27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh    25 Hz    27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg    0    27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0    34 °C    27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1    39 °C    27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2    44 °C    27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen    40 ms    27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus    50 °C    27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen    0 ms    27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung    0 ms    27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen    40 ms    27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen    40 ms    27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung    60 s    27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh    30 s    27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display    not installed     2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation    Always     2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper    installed     2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid    not installed     2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control    not installed     2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button    not installed     2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch    not installed     2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch    installed     2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn    not active     2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked    not active     2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation    not active     2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st    not installed     2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button    not installed     2
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0    -3.71%    20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1    -2.96%    20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2    -2.04%    20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3    -1.48%    20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4    -0.37%    20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0    -0.2    20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1    -0.1    20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2    -0.05    20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3    -0.01    20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4    0    20
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband    No Response From Subnet Component    20
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck    No Response From Subnet Component    20
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte    No Response From Subnet Component    20
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben    No Response From Subnet Component    20
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten    No Response From Subnet Component    20
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen    No Response From Subnet Component    20
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1    No Response From Subnet Component    20
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2    No Response From Subnet Component    20
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3    No Response From Subnet Component    20
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation    No Response From Subnet Component    20
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband    No Response From Subnet Component    20
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck    No Response From Subnet Component    20
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte    No Response From Subnet Component    20
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben    No Response From Subnet Component    20
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten    No Response From Subnet Component    20
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen    No Response From Subnet Component    20
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1    No Response From Subnet Component    20
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2    No Response From Subnet Component    20
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3    No Response From Subnet Component    20
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation    No Response From Subnet Component    20
ENG99457-ENG117394-Neck heating-blower_speed    1    2
ENG99457-ENG98971-Neck heating-Temperature    -2    2
ENG122979-ENG141954-Networking-A/C electronics    installed     8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    not installed     8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed     8
ENG122979-ENG141953-Networking-Getriebesteuergeraet    installed     8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed     8
ENG122979-ENG99457-Networking-Neck heating    not installed     8
ENG124714-ENG142044-OCU-DWA_push    active     8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    active     8
ENG124714-ENG246970-OCU-IAA -Nutzer_management    installed     8
ENG124714-OCU-    installed     8
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h    8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3 Hz    8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s    8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    2000 ms    8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    Via BAP / Fazit     8
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I    No Response From Subnet Component    8
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I    No Response From Subnet Component    8
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN    No Response From Subnet Component    8
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM    No Response From Subnet Component    8
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION    No Response From Subnet Component    8
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK    No Response From Subnet Component    8
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK    No Response From Subnet Component    8
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK    No Response From Subnet Component    8
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK    No Response From Subnet Component    8
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN    No Response From Subnet Component    8
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND    No Response From Subnet Component    8
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB    No Response From Subnet Component    8
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM    No Response From Subnet Component    8
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM    No Response From Subnet Component    8
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK    No Response From Subnet Component    8
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE    No Response From Subnet Component    8
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1    No Response From Subnet Component    8
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2    No Response From Subnet Component    8
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3    No Response From Subnet Component    8
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4    No Response From Subnet Component    8
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1    No Response From Subnet Component    8
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2    No Response From Subnet Component    8
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3    No Response From Subnet Component    8
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4    No Response From Subnet Component    8
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1    No Response From Subnet Component    8
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2    No Response From Subnet Component    8
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3    No Response From Subnet Component    8
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4    No Response From Subnet Component    8
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH    No Response From Subnet Component    8
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW    No Response From Subnet Component    8
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT    No Response From Subnet Component    8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    active     16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten    7    16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    active     16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion    profiles_active     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG142030-Personalization-Profil_Variante    Konto (v. 2.x)     16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1    active     16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2    not active     16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3    not active     16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4    not active     16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut    No     4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut    No     4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln    No     4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut    No     4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln    No     4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut    No     4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt    No     4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut    No     4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut    No     4
ENG141646-MAS01065-Querschnitts_funktionen-Brand    Skoda     5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active     5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    active     5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung    not active     5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    active     5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin A31     5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe    Keine_Spannungsanforderung     5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active     5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme    installed     5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active     5
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment    Right     5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side    Left     5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis    5 km/h    8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max    50 km/h    8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM    1.5 s    8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI    not active     8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash    not installed     8
ENG125614-Reset_Blower_1_Backrest_Left    No Response From Subnet Component    8
ENG125615-Reset_Blower_1_Backrest_Right    No Response From Subnet Component    8
ENG125613-Reset_Blower_1_Cushion_Left    No Response From Subnet Component    8
ENG125616-Reset_Blower_1_Cushion_Right    No Response From Subnet Component    8
ENG122927-RLS_close_glazing    2.0 s    1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off    120 s    3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on    10 s    3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off    65 km/h    3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on    140 km/h    3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle    6000 lx    2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high    12    2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low    6    2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht    30 s    2
ENG122929-RLS_LIN_Communication    4 s    1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn    200 lx    1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day    500 lx    1
ENG122930-RLS_tunel_gateway_recognize    5 s    1
ENG122935-RLS_Washer_Front    15 s    1
ENG122926-RLS_wiper_position_parking    15 s    1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    10    10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system    installed     10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    not active     10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    1500 ms    10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    700 ms    10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    0 ms    10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    0 ms    10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    700 ms    10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen    Keine_Spannungsanforderung     10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss    200 ms    48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung    1000 ms    48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus    5000 ms    48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein    300 s    48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus    5000 ms    48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein    300 s    48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus    5000 ms    48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein    300 s    48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel    200 ms    48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus    0 ms    48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein    0 ms    48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel    0 ms    48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung    90000 ms    48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung    90000 ms    48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error    200 ms    48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss    200 ms    48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung    1000 ms    48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus    5000 ms    48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein    300 s    48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel    200 ms    48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis    2000 ms    48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus    5000 ms    48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein    60 s    48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen    20 ms    48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen    0 ms    48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen    0 s    48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt    0    48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle    16.5 V    48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr    15.5 V    48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle    8.5 V    48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr    8.5 V    48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss    0 ms    48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus    0 ms    48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein    0 ms    48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus    0 ms    48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein    0 s    48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss    200 ms    48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung    1000 ms    48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus    0.0 s    48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein    0 s    48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus    5000 ms    48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein    300 s    48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel    200 ms    48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus    5000 ms    48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein    300 s    48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus    5000 ms    48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein    300 s    48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG    not installed     4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    SMLS     4
ENG116588-Sonderfunktionen-    not enabled     4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1    not installed     4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    not active     5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by look command via remote control key     5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    not active     5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    not active     5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    active     5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    not active     5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active     5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    not active     5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    active     5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    active     5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt    250    10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel    10 km/h    10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter    LIN     10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel    1000 ms    10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen    40 ms    10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx    10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx    10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx    10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx    10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx    10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6    10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6    10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20    10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50    10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100    10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx    10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx    10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx    10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx    10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx    10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6    10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6    10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20    10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50    10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100    10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms    22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1    200 ms    22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10    2000 ms    22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2    400 ms    22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3    600 ms    22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4    800 ms    22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5    1000 ms    22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6    1200 ms    22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7    1400 ms    22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8    1600 ms    22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9    1800 ms    22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%    22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1    72.00%    22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%    22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2    48.00%    22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3    33.00%    22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4    18.00%    22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5    12.00%    22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6    8.00%    22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7    6.00%    22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8    4.00%    22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9    2.00%    22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s    21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM    0.00 s    21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM    0.00 s    21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    HMI     21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    0.0 s    21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    0.0 s    21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    not active     21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    not_active     21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active     21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    0    21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM    0.00 s    21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    100%    21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi     21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    Always active     21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.1    21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    20.00%    21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0    0    22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1    50    22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10    0    22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2    100    22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3    200    22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4    253    22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5    0    22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6    0    22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7    0    22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8    0    22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9    0    22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx    22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1    50 lx    22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx    22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2    100 lx    22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3    200    22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500    22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0    22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx    22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx    22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx    22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx    22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms    22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1    200 ms    22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10    2000 ms    22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2    400 ms    22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3    600 ms    22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4    800 ms    22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5    1000 ms    22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6    1200 ms    22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7    1400 ms    22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8    1600 ms    22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9    1800 ms    22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%    22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    1.00%    22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%    22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    3.00%    22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    5.00%    22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    11.00%    22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    22.00%    22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    40.00%    22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7    80.00%    22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8    95.00%    22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9    100.00%    22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx    8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx    8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx    8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx    8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100    8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100    8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100    8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100    8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx    8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx    8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx    8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3    510 lx    8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6    8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6    8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100    8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100    8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%    12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%    12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%    12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%    12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%    12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%    12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10    12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10    12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100    12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150    12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220    12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253    12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx    10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx    10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx    10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx    10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx    10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16    10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16    10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100    10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100    10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100    10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx    10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx    10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx    10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx    10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx    10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6    10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6    10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100    10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100    10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100    10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0    12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10    12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    50    12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    100    12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220    12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253    12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    2.00%    12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    2.00%    12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    6.00%    12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    10.00%    12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    80.00%    12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%    12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx    8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx    8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx    8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx    8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6    8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6    8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100    8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100    8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx    8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx    8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx    8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx    8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100    8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100    8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100    8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100    8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%    6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%    6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%    6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%    6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%    6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%    6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx    12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    200 lx    12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    400 lx    12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    600 lx    12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx    12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx    12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0    12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    84    12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    166    12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    250    12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    370    12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500    12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms    10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms    10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms    10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms    10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5    10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15    10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40    10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100    10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen    not active     4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen    not active     4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    tilting     4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1    not installed     4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3    not installed     4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo    not installed     4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule    LIN     4
ENG141969-ENG249827-UGDO-Anlernblinken    not active     3
ENG141969-ENG249832-UGDO-Bedienfeld    not installed     3
ENG141969-ENG172987-UGDO-ugdo_transmitter    not installed     3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable    not active     3
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck    not_installed     9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    active     9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active     9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    not active     9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close    not installed     9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active     9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active     9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen    active     9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    not active     9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    active     9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    Always     9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    Always     9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit    not installed     9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active     9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    active     9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    active     9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active     9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung    active     9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy    active     9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder    active     9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active     9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar    not active     9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed     9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version    Version_1_2     9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation    5    8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold    30 s    8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation    180 s    8
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw    0 bit    4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute    40    3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute    60    3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute    30    3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active     7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active     7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    not active     7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active     7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt    installed     7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster    installed     7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion    not active     7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active     7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion    not active     7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung    not active     7
ENG141651-ENG141957-ZV allgemein-Radio freq.    434.42MHz     7
ENG141651-ENG141958-ZV allgemein-Tankschloss    Bidirectional     7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch     7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung    Einzeltuerentriegelung     7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion    not installed     7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active     3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln    active     3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    active     3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR    not active     3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    adjustable     3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    not active     4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    not active     4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    active     7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    not installed     7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    not active     7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    not active     7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste    No     7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung    Pulse control     7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.0 s    7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang    No     7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active     7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active     7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator     7
ENG141681-IDE02021-ZV Komfort-Comfort closing    active     8
ENG141681-IDE02022-ZV Komfort-Comfort opening    active     8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten    Yes     8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    active     8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    active     8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s    8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active     8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen    active     8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen    active     8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global    active     8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active     8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    not active     8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art    once     8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus    not active     8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    active     8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    active     8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss    2-Motorenschloesser     5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert     5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed     5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed     5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links    No     5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts    No     5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter    not installed     5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side     5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR    No     5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer    Yes     5
Elapsed Time: 02:37
Ai suggests changing these
IDE03638-ENG116673-Static cornering light-bei Rueckwaertsfahrt Set to: both sides
IDE03638-ENG116674-Static cornering light-Vorschrift Current: OFF Set to: ECE R119
IDE03638-ENG115830-Static cornering light-Zeitwert Einschaltzeit Abbiegelicht Current: 15 min Set to: 17 min
not sure on IDE05145-Light configuration its a long string.
I see file you provided is from pre lci kodiaq and different bcm part no. Was this kodiaq equipped with front camera? I'm setting this up without a front camera.
downtime
Finland
C?ID=280813
Yes it was. And no AI is not correct here. You need to update the leichte configurations to match your new lights
