Seat Arona Year 2019 ABS Long Code all zeros after ABS Replacment
Miri
C?ID=49131
Hi, we had a Seat Arona Year 2019 with ABS Long Code all zeros after ABS Replacement,tried to code the replacement (Used) ABS module but it wont accept the code,it comes up with an error message "Coding rejected".
Part No SW: 2Q0 614 517 AG (Original)
Part No SW: 2Q0 614 517 AA (Replacement)
Does anyone know if its even possible to recode the USED ABS Module with VCDS
Saturday,09,May,2026,15:11:32:23195
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
VIN: VSSZZZKJZKR108465   License Plate: YM19LB Z
Mileage: 39478km-24530mi   Repair Order: 1
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 55 5F D6 D7
VIN: VSSZZZKJZKR108465   Mileage: 39478km-24530miles
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 K    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6203
   Revision: D7H20000    CVN: 79703594
   Coding: 0125003223241D080000
   Shop #: WSC 00049 770 00144
   ASAM Dataset: EV_ECM10TFS01104C906025K 002002
   ROD: EV_ECM10TFS01104C906025M_002_AU27.rod
   VCID: 28080EB61276B2FAA73-807C
   VINID: 9A38EAAAA6DAA9B8810081061473C6723E
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:21:11
                    Engine speed: 0.00 /min
                    Coolant temperature: 60 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.180 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 1
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0
-7: 0
-7: 128
-7: 128
-7: 0
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [00100111] - -
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:58
                    Engine speed: 966.50 /min
                    Normed load value: 11.4 %
                    Voltage terminal 30: 14.580 V
                    Outside temperature: 15 °C
                    Absolute intake pressure: 37 kPa abs
                    Engine torque: 18.4 Nm
                    Fuel: tank fill level: 21.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [00100111] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:59
                    Engine speed: 950.50 /min
                    Normed load value: 13.3 %
                    Absolute intake pressure: 42 kPa abs
                    Engine torque: 20.5 Nm
4675 - Please Check Fault Codes in Control Module for ABS Brakes
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:58
20201 - Implausible Data Received from ESP Control Module
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:59
                    Engine speed: 941.00 /min
                    Normed load value: 12.9 %
                    Voltage terminal 30: 14.500 V
                    Engine torque: 20.8 Nm
Readiness: 1110 0001
   Part No SW: 0CW 300 043     HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1604
   Revision: 00005008    Serial number: CU501901277667 CVN: DDC485A4
   ROD: EV_TCMDQ200021.rod
   VCID: 74B02AC69E3E861ADBB-8020
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H22 0222
   Serial number: 08503919170816
   Coding:
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000
   Shop #: WSC 00049 770 00021
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_004_VW27.rod
   VCID: 6D863FA2FD1457D2145-8038
0943 - ABS/ESP Control Module
          U10C5 00 [10001001] - No or Incorrect Basic Setting
          [IISOEMCalibrationError]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:02:30
0887 - Control Module
          C104A F0 [00001000] - Incorrect VIN
                    Reset counter: 113
                    Mileage: 39479 km
                    Date: 2026.05.02
                    Time: 12:23:42
0883 - Control module not coded
          U1013 00 [10001001] - -
          [VehicleConfigUncoded]
                    Reset counter: 73
                    Mileage: 39479 km
0797 - Rear Left Wheel Speed Sensor
          C101C 4A [10001001] - Incorrect Component(s) Installed
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:48
0798 - Rear Right Wheel Speed Sensor
          C101D 4A [10001001] - Incorrect Component(s) Installed
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:49
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6F0 907 044 B    HW: 6F0 907 044 B
   Component: Climatronic   H03 0502
   Coding: 8101000008000100110008000240010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0_SK27.rod
   VCID: 2614008E1862A48A95F-8072
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V1.clb
   Part No SW: 2Q0 937 090 B    HW: 2Q0 937 090
   Component: BCM A0 Std+   H98 0936
   Serial number: 00001903301730 Dataset Number: V03935293NN 0002
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205_VW27.rod
   VCID: 313EE3D221ACF33270D-8064
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S3Y19M01D31H16M36S49
   Coding: 00194D
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q2 959 881 D    HW: 2Q2 959 881 D
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000026003280
   Coding: 1F000F
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q2 959 882 D    HW: 2Q2 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000027236987
   Coding: 05000F
   Subsystem 4 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY183332XYV
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000325606
   Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000026977633
   Coding: 1D0000
   Subsystem 7 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000027011933
   Coding: 050000
   Part No SW: 5QA 919 283 C    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0050
   Serial number: 000308419619044 Dataset Number: V03935281SS 0001
   Coding: 0601050011
   Shop #: WSC 00049 770 00109
   ASAM Dataset: EV_EPHVA14AU3700000 009037
   ROD: EV_EPHVA14AU3700000_010_AU37.rod
   VCID: 4ACC943EAC3AA0EA517-801E
7 Faults Found:
13637408 - Databus
          [Bremsensteuergerät - ESP_02.ESP_Gierrate - Fehlerspeicher auslesen]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
13637409 - Databus
          [Bremsensteuergerät - ESP_10.ESP_WegimpulsHL - Fehlerspeicher auslesen]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
13637410 - Databus
          [Bremsensteuergerät - ESP_10.ESP_WegimpulsHR - Fehlerspeicher auslesen]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
13637419 - Databus
          [Bremsensteuergerät - ESP_02.ESP_Laengsbeschl - Fehlerspeicher auslesen]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
13637422 - Databus
          [ESP - ESP_19.ESP_HL_Radgeschw_02 - Fehlerspeicher auslesen]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
13637423 - Databus
          [ESP - ESP_19.ESP_HR_Radgeschw_02 - Fehlerspeicher auslesen]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
13637426 - Databus
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Dataset Number: V03935279FN 0004
   Coding: 3200608140FF8728749C814500408700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 42DCBC1E940A78AA997-8016
8 Faults Found:
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:01
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 43 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
0815 - Databus
          [FAULT_ESP_WEGIMPULS_HL_ERROR]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:01
                    Voltage terminal 15: 14.5 V
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:06
                    Voltage terminal 15: 14.6 V
0828 - Databus
          [FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:06
0855 - Databus
          [FAULT_EGO_FZG_GIERRATE]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:01
0854 - Databus
          [FAULT_EGO_FZG_LAENGSBESCHLEUNIGUNG]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:01
0863 - Databus
          [FAULT_ESP_QBIT_WEGIMPULS]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:01
196808 - Databus
          [VDY_VEH_YWR_NOT_AVAIL]
                    Reset counter: 115
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:46
                    Voltage terminal 15: 14.7 V
   Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
   Component: Airbag VW22   006 0520
   Revision: --------    Serial number: 003XNP2AMM3E   Dataset Number: V03935264KF 0003
   Coding: 88CCC0C000000000585400CF008C00000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
   ROD: EV_AirbaVW22TS6VW48X_VW27.rod
   VCID: 5F9A556A07B83542969-800A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 401 19
   Serial number: 357000000003A609183C
   Subsystem 2 - Part No SW: -----------    HW: 454 002 301 19
   Serial number: 35800000000B05E8183N
   Subsystem 3 - Part No SW: -----------    HW: 454 801 001 19
   Serial number: 351000A9970170000009
   Subsystem 4 - Part No SW: -----------    HW: 454 801 501 19
   Serial number: 3520079B66D17000000R
   Subsystem 5 - Part No SW: -----------    HW: 454 801 701 19
   Component: FrontSensor_D  307 0189
   Serial number: 35500572271170000002
          B13BC F2 [10001001] - No function
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:53
1060614 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:53
1060615 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_v_rel]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:53
1060617 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:53
   Part No SW: 6F0 920 940 A    HW: 6F0 920 940 A
   Component: KOMBI         212 2670
   Coding: 24A4090A29800600018862011000000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001040
   ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
   VCID: 251607826564AF929C5-8070
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:54
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009088811 Dataset Number: V03935285J  0001
   Coding: 030100046F085700E90002481C0F00010001070000000000000000000000
   GVL: 01443C0000000000400090000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_SK25.rod
   VCID: 6E8438AEF012ACCA2DF-803A
   Generator:
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000G0720310119
   Coding: 012000
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 100D7441
Address 44: Steering Assist (J792)       Labels:| 2Qx-909-144-V1.clb
   Part No SW: 2Q2 909 144 M    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 621 6041
   Serial number: 1015143CB4K0422 Dataset Number: V03935280VJ 0004
   Coding: 010000010000000101010201010001010000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3D26CFE2EDF40752E45-8068
8 Faults Found:
10494976 - Databus
          [DEM_WHEEL_SPD_INVALID_FAULT]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:57
                    Engine speed: 968 /min
                    System status: Driving mode
                    Terminal 15 status: On
                    Voltage terminal 30: 14.66 V
                    Power steering current consumption: 0.5 A
                    max.value: 33.8 A
                    End stage temperature: 28 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 84 °
                    Speed of electric drive motor: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
10535168 - Databus
          [DEM_CAN_YAW_RATE_INVALID_FAULT]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:57
                    max.value: 33.8 A
                    Engine angle: 84 °
10535424 - Databus
          [DEM_CAN_LONG_ACCEL_INVALID_FAULT]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:57
                    max.value: 33.8 A
                    Engine angle: 84 °
10535680 - Databus
          [DEM_CAN_LAT_ACCEL_INVALID_FAULT]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:57
                    max.value: 33.8 A
                    Engine angle: 84 °
10625024 - Databus
          [DEM_CAN_WHEEL_PULSE_RL_INVALID_FAULT]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:57
                    max.value: 33.8 A
                    Engine angle: 84 °
10622976 - Databus
          [DEM_CAN_WHEEL_PULSE_RR_INVALID_FAULT]
                    Reset counter: 75
10624256 - Databus
          [DEM_VEH_MOT_RL_INVALID_FAULT]
                    Reset counter: 75
10624512 - Databus
          [DEM_VEH_MOT_RR_INVALID_FAULT]
                    Reset counter: 75
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Revision: --------    Serial number: -------------- Dataset Number: V03935271FD 0001
   Coding: 078E000009200003
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DEB312910C63B280D-8014
13705985 - Databus
          U1123 00 [10001001] - Received Error Message
          [Fehlerwert im Signal ESP_HL_Radgeschw]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:17:01
13705987 - Databus
          [Fehlerwert im Signal ESP_HR_Radgeschw]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:17:01
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD1.clb
   Part No SW: 5F0 035 858 C    HW: 5F0 035 858 C
   Component: MU-S-ND-ER    H50 0516
   Serial number: SEZAZ2W0245046 Dataset Number: V03935284FS 0001
   Coding: 04120601960A000011110101008808212F0101C601200500C6
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE27.rod
   VCID: 2B02F1BA038099E24A1-807E
   Subsystem 1 - Part No SW: 6F0 919 605 A    HW: 6F0 919 605 A
   Component: ABT_Std-2_Nav  H53 8130
   Serial number: SEZ6ZHW0442140
   Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
   Component: ECE1 2018/19  --- 1030
          U1111 00 [00001001] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication
error - BapErr_retry not successful]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
                    Voltage terminal 30: 14.5 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          [Brake (0x26) - function restriction due to communication error - BapErr_retry
not successful]
                    Reset counter: 75
                    Mileage: 39478 km
                    Date: 2026.05.05
                    Time: 00:16:17
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 7EA408EEA072DC4ABDF-802A
End----(Elapsed Time: 01:20, VBatt start/end: 11.9V/12.1V. VIgn 12.0V)-----
------------------------------42 Faults Found------------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Do you have an old Auto Scan, where you can see what coding was used?
Miri
C?ID=49131
Unfortunately Not,this vehicle was in another garage before it came to me and i don't have any previous scans
chr
Romania
C?ID=79671
2Q0 614 517 AA seems to be from VW Polo 2018-2023 and isn't compatible with Seat Arona.
Spacewalker
Poland
C?ID=159607
so what coding you use if you NOT have org coding from old autoscan, but you said - coding is rejected ?
Miri
C?ID=49131
Is anyone able to help with this ABS issue please?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
You installed a module which is older than the original, with a lower software level. This is generally considered a bad idea w/o even checking if the coding can be generated here. In cases where we are providing codings etc. the prerequisite is that the replacement module is a suitable/compatible part. Rule of thumb, it starts with "never install an older module" (i.e. lower hardware/software level).
Miri
C?ID=49131
Thank you for your reply Sebastian, just to clarify, We didn’t install the ABS module!
The vehicle came to our garage with it already installed by another garage and apparently they could not complete the coding because they didn’t have the “right equipment”.
The difference in part number was the first thing I noticed when it first came to our garage. So the ABS Module will have to be replaced with another newer version then ?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Since we have no means to determine the exact difference in these hardware/software/firmware levels of the module (that would be VW development internal data) and therefor no means to verify compatibility, I would not feel comfortable to leave this in the car. If it was mine, I would replace it with a proper/matching module. Based on a quick search, 2Q0-614-517-AA was never installed in any MY 2019 - only in early MY 2018's. That said, 2Q0-614-517-AG seems to be a proper replacement for 2Q0-614-517-AA but then this does not guarantee upwards compatibility.
Vdub
C?ID=57533
according to PL24 2Q0 907 379 AK was fitted in the car.
Did you ask WHY the abs was changed?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The parts catalog never shows what was actually installed but what the suitable replacement at this point would be, that said I am not sure what you're looking at but mine sure does not show AK for this VIN.
Vdub
C?ID=57533
Sorry, didnt look well, its AG indeed.
Miri
C?ID=49131
Hi, this vehicle has now been fitted with the Correct ABS Module Part No SW: 2Q0 614 517 AG (Original) and we would appreciate if anyone can assist us with a long code for this vehicle since no previous scans were performed before the ABS module died, anyone who happened to have any scans from a vehicle that shares the same exact ABS Part number.
Westbury, UK
Are you sure the ABS coding is not VIN dependent?
Miri
C?ID=49131
I don’t know to be honest with you but I we can get a long code compatible with the part number then maybe we can tweak the long code to suit the vehicles specifications
I would give long odds, on the order of 10:1 that it is, but I don't know anything about this particular ABS.
The path of least resistance here might just be to take it to someone with ODIS and a GRP account, and code it using SVM.
AINils
Germany (AIB)
C?ID=56975
It is VIN dependent as nearly all ABS since MK60EC1
With UNECE Cars this was stopped, as controller are secured by SFD2
