Resolved Audi A3 8Y Facelift fault U042900
Resolved
crazyrs6
C?ID=521878
Hi all,
Today I got an Audi A3 8Y facelift. The owner had a custom steering wheel installed, but it did not work. So he had it removed and put back on the original steering wheel again.
The custom wheel had a start/stop button and drive select button. The person who tried installing it ran wires to the original start and drive select button.
Right now the issue is, everything works fine, except when turning on the low beams, a transmission fault appears on the dash. So driving the car during the day, everything is good. When it gets darker and the lights go on, the transmission fault appears.
I scanned the car and it refers to the steering column electronics. For this car I think it is integrated in the gateway(?). However the gateway is fault free.
I am trying to understand what the connection is between the low beam, transmission and steering column electronics. I hope someone has more understanding of this.
Full scan of the car:
Thursday,07,May,2026,17:27:44:40745
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4701.5
VIN: WAUZZZGY3SA   License Plate:
Chassis Type: GY-AU38P PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 4B 52 5F 61
          6C 6D 75 82 A5 BB BC C4 CA CC D6 D7 DE 811E 811F 8120 8121 C002 C003
VIN: WAUZZZGY3SA   Mileage: 38639km-24009miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DXDB)       Labels: Redir Fail!
   Part No SW: 05E 906 019 CM    HW: 05E 907 309 CA
   Component: R4 1.5l TFS   H80 3952
   Revision: KNH80000    Dataset Number: V03935404LB 0001 CVN: 59F197D2
   Coding: 0225003223641D0870086000000000000000000000000000
   Shop #: WSC 46332 006 1048576
   ASAM Dataset: EV_ECM15TFS01105E906019CM 001004
   ROD: EV_ECM15TFS01105E906019CM_AU38P.rod
   VCID: 73B8B06A3B3CDA02C21-8026-R SFD+SFD2
   VINID: 9D196AAAA5E90E34400040C2144650D5C9
   Radiator shutter:
   Subsystem 1 - Part No SW: 95C 965 501 G    HW: 95C 965 501 G
   Component:  V544_SAB_S_1  H03 0003
   Serial number: 20231130060604083193
   Active oil separating system:
Readiness: 1111 0001
   Part No SW: 0CW 906 556 DC    HW: 0CW 300 028 Q
   Component: DQ200G3 CFD   H07 0362
   Serial number: VTH02404010572  CVN: 669B93EF
   ASAM Dataset: EV_TCMDQ200024 001003
   ROD: EV_TCMDQ200024_AU38P.rod
   VCID: 1072DFE62AEA811A5F3-8044-R SFD
   Parking lock:
   Subsystem 1 - Part No SW: 5QS 907 483 A    HW: 5QS 907 483
   Component: SB_Auto        H02 0053
   Serial number: 9120441000047007
   Selector lever:
   Subsystem 2 - Part No SW: 8Y0 713 059 H    HW: 8Y0 713 059 F
   Component: AUDI_SBW_SAAM  H06 0370
   Serial number: 01571XC700598-------
41826 - Implausible Data Received from Steering Column Control Module
          U0429 00 [00101100] - -
          [Invalid Data Received From Steering Column Control Module]
                    Mileage: 38639 km
                    Date: 2026.05.07
                    Time: 17:24:24
                    Engine speed: 1400.00 /min
                    Engine torque: -4 Nm
                    Control Module temperature: 60  C
                    CURRENT pressure: 43.5 bar
                    Clutch: primary stat: Kriechen - Gangwechsel
                    selected gear: GANG_1
                    Position: d
                    Accelerator pedal position: 14.5 %
                    DTC memory status: 200
                    SCB at a phase W: not active
                    SCG at a phase W: not active
                    OG at a phase W: not active
                    OL at a phase W: not active
                    SCB at a phase U: not active
                    SCG at a phase U: not active
                    OG at a phase U: not active
                    OL at a phase U: not active
                    SCB at a phase V: not active
                    SCG at a phase V: not active
                    OG at a phase V: not active
                    OL at a phase V: not active
                    Error during active shut off: not active
                    Overtemperature from Bldc1 driver: not active
                    Overcurrent at the shunts: not active
                    Overvoltage at supply: not active
                    Undervoltage at supply: not active
                    Overvoltage at sensor supply: not active
                    Undervoltage at sensor supply: not active
                    OV or UV at charge pump: not active
                    Communication error SPI: not active
                    Sensor interner Fehler: not active
                    Sensor Kurzschluss nach Masse: not active
                    Sensor Kurzschluss nach Plus: not active
                    Sensor offen: not active
                    Sensorversorgung_elektrischer Fehler: not active
                    Sensor untere Toleranz unterschritten: not active
                    Sensor obere Toleranz  berschritten: not active
                    Gradientenfehler: not active
                    Kalibrationsfehler: not active
Address 03: ABS Brakes (J104)       Labels:. 5WA-614-517-V2.clb
   Part No SW: 5WA 614 517 DG    HW: 5WA 614 517 BT
   Component: ESC           H32 0379
   Serial number: 60854000009696  Dataset Number: 8Y0909504MR 0001 CVN: 1523AE3E
   Coding: 2C185428C44D399C410355AC9EA702CD3A8F97349C2800
   ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006022
   ROD: EV_Brake1ESCMQB37WUNECE_AU38P.rod
   VCID: 1072DFE62AEA811A5F3-8044-R SFD+SFD2
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 N    HW: 5WA 959 436 N
   Component: Kessy IOBOX   122 0757
   Serial number: --------------- Dataset Number: 8Y0909577C  0017
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 5F90CCDAA7B46E62969-800A-R
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 3WA 907 007 B    HW: 3WA 907 007
   Component: Climatronic   H01 5044
   Serial number: 212022419061160 Dataset Number: 83H909862A  0031
   Coding: 006000110011120120200000111011010000032100200000000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002043
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
   VCID: 44DA23B62E122DBAABB-8010-R SFD+SFD2
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002050324224528505
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000003114065
   Front A/C control console:
   Subsystem 3 - Part No SW: 89A 820 043 F    HW: 89A 820 043 F
   Component: MEB SH         H04 0151
   Serial number: 11 S07.03.2400451064
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BL    HW: 5WA 937 086 BE
   Component: BCM37w_H238 0434
   Serial number: BXJ53F200324940 Dataset Number: 8Y1909514B  0031
   ASAM Dataset: EV_BCMwBL 004001
   ROD: EV_BCMwBL_004_AU38P.rod
   VCID: 1C6ABBD6F622357A33B-8048-R SFD+SFD2
   Subsystem 1 - Part No SW: 8Y1 955 119 B    HW: 8Y1 955 119
   Component: J400FRWISCH    067 0100
   Serial number: 907453F0302407200954
   Component: G397_RLFSS     H06 0004
   Serial number: 23204998X81A955555B0
   Subsystem 3 - Part No SW: 4K1 941 501 AA    HW: 4K1 941 501 AA
   Component: E1 - LTM       H05 0011
   Serial number: 92160WL5000PV    11S
   Steering Column Switch:
   Subsystem 4 - Part No SW: 82A 953 521 LT    HW: 5Q1 953 549 D
   Serial number: 00000020032420240806
   Power rear lid opening control module:
   Subsystem 5 - Part No SW: 80A 962 243     HW: 80A 962 243
   Component: GEB.F.Heckoef  H17 0911
   Serial number: 40409696
   Left taillight 1:
   Subsystem 6 - Part No SW: 8Y0 945 423 B    HW: 8Y0 945 423 B
H08 0003
   Serial number: 0023106806L016241354
   Left taillight 2:
   Subsystem 7 - Part No SW: 8Y0 945 429 A    HW: 8Y0 945 429 A
H08 0003
   Serial number: 0023139406L020240414
   Right taillight 1:
   Subsystem 8 - Part No SW: 8Y0 945 424 B    HW: 8Y0 945 424 B
H08 0003
   Serial number: 0023106906R016241910
   Right taillight 2:
   Subsystem 9 - Part No SW: 8Y0 945 430 A    HW: 8Y0 945 430 A
H08 0003
   Serial number: 0023139506R020241183
   Part No SW: 5QS 919 298     HW: 5QS 919 298
   Component: PLA 12ch mid  H01 0997
   Serial number: 000018032494560 Dataset Number: V03935380EB 0028
   Coding: 8206026013
   ASAM Dataset: EV_EPHBO2CVW3360000 001013
   ROD: EV_EPHBO2CVW3360000_AU38P.rod
   VCID: 1F108CDAE7342E62D69-804A-R
   Part No SW: 5WA 907 567     HW: 5WA 907 819
   Component: ACC Bosch MQB H50 0576
   Dataset Number: 8Y0909863R  0010
   Coding: 2E0B086F4077404522474000008440C9B64020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 005024
   ROD: EV_FRONTRADARBOSCHVW380_001.rod
   VCID: 0F70DC9A37D49EE2469-805A-R SFD+SFD2
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 A    HW: 5QS 959 655 A
   Component: AirbagVW50    004 0077
   Serial number: 000000003C0MZRB Dataset Number: 8Y0909602AE 0006
   Coding: 88CC008000CCC000000000400000000091540000A1540000C000F670802B4000
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001010
   ROD: EV_AirbaVW50SMEVW49X_VW41.rod
   VCID: 6194CA2291C05892A0D-8034-R SFD+SFD2
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 85E 980 945 E    HW: 85E 980 945 E
   Component: BeltPretRevFL  007 0640
   Serial number: 03042400160402000000
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 85E 980 946 E    HW: 85E 980 946 E
   Component: BeltPretRevFR  007 0640
   Serial number: 05042400160049000000
   Subsystem 3 - Part No SW: -----------    HW: 480 000 401 18
   Serial number: 35700006B38561B74B13
   Subsystem 4 - Part No SW: -----------    HW: 480 000 401 18
   Serial number: 35800003D48D3A717065
   Subsystem 5 - Part No SW: -----------    HW: 480 051 703 18
   Component: SideSensor_Dr  000 0149
   Serial number: 35100009CCEFAE8EE89J
   Subsystem 6 - Part No SW: -----------    HW: 480 051 703 18
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000A0CEFAE9384D-
   Subsystem 7 - Part No SW: -----------    HW: 480 051 603 18
   Component: FrontSensor_D  000 014A
   Serial number: 3550000B4CE3D55386BM
   Subsystem 8 - Part No SW: -----------    HW: 480 051 603 18
   Component: FrontSensor_P  000 014A
   Serial number: 3560000B4CE3D553C93M
   Part No SW: 8Y0 920 790 E    HW: 8Y0 920 790 E
   Component: FBenRDW------ H31 0434
   Dataset Number: 8Y1909525G  0028
   Coding: 8C0415406F9C00080080E340200000080800040800
   ASAM Dataset: EV_DashBoardFPK2pAU38X 004063
   ROD: EV_DashBoardFPK2pAU38X_004.rod
   VCID: 41D42AA23100389280D-8014-R SFD
   Part No SW: 5QS 907 530 D    HW: 5QS 907 530
   Component: GW MQB 23     005 2086
   Serial number: SMERBG040324007 Dataset Number: 8Y1909515B  0037
   Coding: 000000000000000000000000000000000000000000000300000000000000000000000000000000000000000000000000
   GVL: 3D08080002C842CC80008002C800304004104002004000000200000000000044
   ASAM Dataset: EV_GatewMQBwBL 001018
   ROD: EV_GatewMQBwBL_AU38P.rod
   VCID: 55FCEEF2D588A432CC5-8000 SFD+SFD2
   Subsystem 1 - Part No SW: 5QS 915 181     HW: 5QS 915 181
   Component: J367-BDMHella  H01 2362
   Serial number: 9067593906
   Subsystem 2 - Part No SW: 83A 951 523 J    HW: 83A 951 523 J
   Component: J453 MFL       H07 0004
   Serial number: 20240117013438 30164
   Subsystem 3 - Part No SW: 8Y0 419 508     HW: 8Y0 419 508
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230101429378
   Part No SW: 5WA 909 059 AC    HW: 3Q0 909 059 C
   Component: EBKV          H10 0553
   Serial number: BPA085140324013 Dataset Number: 8YF909524AF 0001
   Coding: 1302C5047900000080F7DE7B000049922449922400
   ASAM Dataset: EV_BrakeBoostVW37WUNECE 012002
   ROD: EV_BrakeBoostVW37WUNECE_012_AU38P.rod
   VCID: 1174DAE221E0881250D-8044-R SFD+SFD2
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000081057015 Dataset Number: 8Y0909564B  0005
   Coding: 8820000000000000
   Shop #: WSC 38168 004 1048576
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0842F78652BAC9DA873-805C-R SFD+SFD2
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 14520042144353  Dataset Number: 8Y0909535C  0060
   Coding: 5AA54750
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW41.rod
   VCID: 3FD02C5A47F44E62F69-806A-R
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 14520042047015
   Part No SW: 3WA 959 593     HW: 3WA 959 593
   Component: TSG FS        001 0163
   Serial number: YG007XBH05275   Dataset Number: 8Y1909872C  0025
   Coding: 003C8B005000008102001020
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001015
   ROD: EV_DCU4DriveSideMAXHBRO_AUE4.rod
   VCID: 1378D0EA1BFC7A02621-8046-R SFD+SFD2
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 3WA 907 145 E    HW: 3WA 907 145
   Component: BASGEN1MQB37  504 1122
   Serial number: 03698773 Dataset Number: 8Y0909852AF 0002
   Coding: 00000000000001010001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 4AC60D8E0C36FBCA517-801E-R SFD+SFD2
   Part No SW: 5QS 907 338 B    HW: 5QS 907 338 B
   Component: FCM Baseline  019 3091
   Serial number: 230205814104084 Dataset Number: 8Y1909583A  0007
   Coding: 00000000090025EA02202913020003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiWBL 001008
   ROD: EV_MultiModulContiWBL_AU38P.rod
   VCID: 59E4E2C2B9908052E8D-800C-R SFD
   Part No SW: 3WA 959 592     HW: 3WA 959 592
   Component: TSG BFS       001 0163
   Serial number: YG007XC615055   Dataset Number: 8Y1909873C  0025
   Coding: 003C89005C00008102001020
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001015
   ROD: EV_DCU4PasseSideMAXHKLO_AUE4.rod
   VCID: 1276D5EE24E6730A697-8046-R SFD+SFD2
   Part No SW: 8Y0 035 042 C    HW: 8Y0 035 043 B
   Component: MU-TH-ND-EU   055 4143
   Serial number: GRO-63307.03.24 Dataset Number: 8Y1909545A  0011
   Coding: 13801010004020000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU38P.rod
   VCID: 3236756E84A6930A097-8066-R SFD+SFD2
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 8Y0 919 620 A    HW: 8Y0 919 620 A
   Component: CenterDisplay  H40 0132
   Serial number: AUZ8ZHR23028BS
   Subsystem 2 - Part No: V03 959 828 GT
   Component: MIB3_EU_       1550
   Compact disc data bank:
   Component: Gracenote2     1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 8Y0 919 616 E    HW: 8Y0 919 616 B
   Component: Sensoric LSR   H33 0210
   Serial number: 17S14.03.24007400581
   Android control module:
   Subsystem 5 - Part No SW: 8W0 919 806 A    HW: 8W0 919 806
   Component: AED2-EU        H54 0555
   Serial number: YD700219032403192143
   Media socket:
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 8Y0 035 465 A    HW: 8Y0 035 465 A
   Component: B_A_3_P_0_AU   H11 0100
   Serial number: HHA-07306.03.2434860
Address 61: Battery Regul. (A6)       Labels: 5QA-915-107.clb
   Part No SW: 3WA 915 107 A    HW: 5QA 915 107
   Component: BMS 48V       H07 0522
   Serial number: 000000000000000
   ASAM Dataset: EV_BMSmHevGen2CATL 002020
   ROD: EV_BMSmHevGen2CATL_SE27.rod
   VCID: 43D820AA2B1C2A82921-8016-R SFD+SFD2
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 E    HW: 5WA 980 556 C
   Component: RV eCompact   H52 0484
   Serial number: FCLK20180324010 Dataset Number: 8Y0909460H  0001
   Coding: 01014E0021040000
   ASAM Dataset: EV_CamSysRVCeCFicosBL 003009
   ROD: EV_CamSysRVCeCFicosBL.rod
   VCID: 53F810EADB7CBA02221-8006-R
   Part No SW: 5WB 959 107 C    HW: 5WB 959 107 B
   Component: HDSG-Modul    H08 0444
   Revision: --------    Serial number: A2-C767-1202-1 Dataset Number: 8Y0909541H  0018
   Coding: 4028
   ASAM Dataset: EV_DeckLidCONTIAU536 001009
   ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
   VCID: 50F21FE6EA6AC11A1F3-8004-R
   Part No SW: 571 035 284 A    HW: 571 035 284
   Component: OCUMQBW2023_H H07 0567
   Serial number: 0000000401VIHJA Dataset Number: 8Y0909612J  0038
   Coding: 01010601001111211000010003012607111112111012111110
   ASAM Dataset: EV_OCUMWB2023 001061
   ROD: EV_OCUMWB2023_VW42.rod
   VCID: 147AD3F61EF27D3A7BB-8040-R SFD+SFD2
Address 82: Head Up Display (J898)       Labels:| 5H1-919-608.clb
   Part No SW: 8Y1 919 617 A    HW: 8Y1 919 617 A
   Component: HeadupDisplay H09 2311
   Dataset Number: 8Y0909463B  0009
   Coding: 4700F0
   ASAM Dataset: EV_HUDMQBwBL 001010
   ROD: EV_HUDMQBwBL_001_VW41.rod
16776969 - Databus
          U1121 00 [00101111] - Missing Message
          [LoGeWa_03_communication_error_can_error_timeout]
                    Mileage: 38639 km
                    Date: 2026.05.07
                    Time: 17:23:40
   Part No SW: 5WA 980 653 E    HW: 5WA 980 653 A
   Component: MQB MFK 3.0   H12 3504
   Serial number: ED3371602240820 Dataset Number: 8Y1909466A  0015
   Coding: 00040888216CC044109E4C001020008000A30048600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005068
   ROD: EV_MFK3ValeoMQB_AU38P.rod
   VCID: 51F41AE2E160C81210D-8004-R
Address BB: Door Rear Drv (J388)       Labels:* Redir Fail!
   Part No SW: 3WA 959 595     HW: 3WA 959 595
   Component: TSG HFS       001 0163
   Serial number: YG007XCE0935A   Dataset Number: 8Y1909897C  0025
   Coding: 002C81000000008100001020
   ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001015
   ROD: EV_DCU4RearDriveMAXHBRO_AUE4.rod
   VCID: 157CAEF2150864320C5-8040-R SFD+SFD2
Address BC: Door Rear Pass (J389)       Labels:* Redir Fail!
   Part No SW: 3WA 959 594     HW: 3WA 959 594
   Component: TSG HBFS      001 0163
   Serial number: YG007XCE11347   Dataset Number: 8Y1909896C  0025
   ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001015
   ROD: EV_DCU4RearPasseMAXHBRO_AUE4.rod
Address C4: DC/DC Converter (A7)       Labels: 5QS-959-663.clb
   Part No SW: 5QS 959 663 B    HW: 5QS 959 663 B
   Component: DCDC48VGen2.5 H19 0113
   Serial number: 202404300000000 Dataset Number: 8Y1909475A  0007
   ASAM Dataset: EV_DCDC48VHellaAU336 001005
   ROD: EV_DCDC48VHellaAU336_001_AU38P.rod
   Part No SW: 8Y1 907 594 AB    HW: 4K1 907 594
   Component: SAD_STG_1     010 0010
   Dataset Number: 8Y0909469C  0013
   Coding: 628008038011
   VCID: 0740F4BA5FA4C6A28E9-8052-R
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 019 H    HW: 05E 903 019 F
   Component: 48BSG_2P0_H   H12 0024
   Serial number: 917320403120019 Dataset Number: X147A000
   ASAM Dataset: EV_SGCM624323105E903019H 005001
   ROD: EV_SGCM624323105E903019H.rod
   VCID: 28029706B27AE9DAA73-807C-R SFD
   Part No SW: 4K0 941 592 BL    HW: 4K0 941 592 B
   Component: LMS_MQB       H20 0152
   Dataset Number: 8Y0909471G  0019
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 7BA8984A136C92429A1-802E-R
   Dataset Number: 8Y0909472G  0020
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4N0 035 502 D    HW: 4N0 035 502 D
   Component: WLC Front     H14 0061
   Dataset Number: 4N0909485A  0007
   Coding: 800080
   Shop #: WSC 00021 790 03076
   VCID: 251C9E32C568F4B29C5-8070-R
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 E    HW: 5WA 962 133 E
   Component: Kessy RSAD    122 0756
   ASAM Dataset: EV_RSADVL37w 004018
   ROD: EV_RSADHR37w_004_VW38.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 004018
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 004018
   ROD: EV_RSADHL37w_004_VW38.rod
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 004018
End----(Elapsed Time: 02:22, VBatt start/end: 12.2V/11.9V. VIgn 11.9V)-----
------------------------------2 Faults Found-------------------------------
Suki
Banja Luka
C?ID=370038
The steering column electronics are connected via LIN-bus to the gateway. It is also connected to the central electrics (j519) with another LIN-bus network (it can be seen that it is registered). You should pay attention to whether the cables are connected correctly.
crazyrs6
C?ID=521878
Issue has been solved. After doing some more investigation, it turned out that somebody had removed the steering wheel shift paddles en damaged them.
After replacing the shift paddles, error went away!
