Registered vin numbers
Cam249
New Zealand
C?ID=578673 (NRRT)
Hey Team
Bit of a strange question but does vcds store the vin numbers of the activated vins somewhere user accessible?
I only ask as I need to get a gearbox code from a car I’ve activated but don’t have access to currently.
Cheers guys
Check your Auto-Scans. Check your PC for the VCDS scans / logs folder(s).
It keeps a log of VINs you've charged against the license. It will be in the Debug sub-folder and is called VINRegLog.CSV. However, this is only going to be complete if you are always using the same PC.
VINs charged against the license are also encrypted and stored in the interface. So if you've used charged VINs using different PCs, there may be more VINs in the interface than are found in that log file.
