- May 3, 2026
- 7
- 0
- Lancaster, PA, USA
- C?ID=652547
Howdy. I'm plagued with a DPF code, P226D. I cleaned the DPF, no change, replaced with know good DPF and cleaned it.
My AllData does not have a diagnostic procedure for this code.
I'm looking for a diagnostic prodedure or suggestions on how to fix this.
Here is the data:
Here is the data:
Sunday,03,May,2026,09:55:20:46115
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4701.5
VIN: WVGEP9BP4GD003482 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 52 53 55 56
5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BP4GD003482 Mileage: 254533km-158159miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF82755A21130E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 06462 444 00000
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 30327FBF4AA811BA7F3-8064
VINID: 9E65D58094A011750000310808554EF873
22838 - Particulate Filter (Bank 1)
P226D 00 [01101000] - Damaged or Substrate Missing
Mileage: 252758 km
Date: 2026.04.20
Time: 07:19:14
Engine speed: 1303.00 /min
Normed load value: 79.6 %
Vehicle speed: 79 km/h
Coolant temperature: 95 °C
Intake air temperature: 9 °C
Voltage terminal 30: 14.860 V
Unlearning counter according OBD: 35
Engine status: COENG_RUNNING
29012 - Particulate Filter (Bank 1)
P226D 00 [11101000] - Damaged or Substrate Missing
Mileage: 252762 km
Date: 2026.04.20
Time: 07:21:58
Engine speed: 1441.00 /min
Normed load value: 87.1 %
Vehicle speed: 72 km/h
Coolant temperature: 96 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.880 V
Particle filter: soot mass measured: 24.64 g
Particle filter: soot mass calculated: 12.82 g
Particle sensor: exhust speed: 29.70 m/s
Particle sensor: soot volume in exhaust: 0.30 mg/m³
Particle sensor: exhaust temperature: 236.3 °C
Particle sensor: cleaning deviation reaction time: 0.336
8863 - Particulate Filter
P2459 00 [01100000] - Regeneration Frequency
Mileage: 253591 km
Date: 2026.04.26
Time: 14:37:43
Engine speed: 1897.00 /min
Normed load value: 81.6 %
Vehicle speed: 115 km/h
Coolant temperature: 93 °C
Intake air temperature: 18 °C
Voltage terminal 30: 14.900 V
Unlearning counter according OBD: 34
Particle filter: difference pressure: 99 hPa
Particle filter: soot mass measured: 33.76 g
Particle filter: soot mass calculated: 33.76 g
Exhaust gas temperature sensor 3: 391.1 °C
Exhaust gas temperature sensor 4: 213.2 °C
Readiness: 1 2 0 0 0
