2016 VW GTI - No rod data for 55-Xenon range
csalvarr
Uruguay
C?ID=243709
Hi everybody. I'm having trouble working with a friend's GTI, I'm getting an error for AFS function (everything is working ok, car does the statup procedure up down and to the sides) but then it shows a message about AFS not working.
When entering module 55 I'm getting a dialog stating there's no ROD data or something like that, and then the error is about a missing calibration. I can't enter 04-basic settings to adjust the xenons, which could solve the issue.
Any help would be appreciated.
Full autoscan:
Sunday,28,February,2016,22:05:58:34553
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: 3VW476AU6FM101287   License Plate: JAVIER
Mileage: 2795km-1736mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: 3VW476AU6FM101287   Mileage: 2795km-1736miles
Address 01: Engine (J623-CXDA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0009
   Revision: --H13---
   Coding: 091D1032242404280000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM20TFS0215G0906259 001013
   ROD: EV_ECM20TFS0215G0906259_VW37.rod
   VCID: 6B960E8C82030966BB-803E
Readiness: 0010 0000
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01504081836
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 291A3484487FDB7609-807C
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 51335000000021
   Coding: 01FA6BA13420096D00790608C1CA2980D62C9000608394B600430030C009
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 47DE923CFE2B0D06FF-8012
16389 - TPMS Display
          C1146 F1 [008] - Currently Not Available
                    Reset counter: 245
                    Mileage: 2490 km
                    Date: 2016.02.12
                    Time: 22:14:05
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100010005000000101400
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 42C88328D509282E28-8016
   Part No SW: 5Q0 937 086 AE    HW: 5Q0 937 086 AE
   Revision: --------    Serial number: 86581104150110
   Coding: 00101A46C04122FB4BE44080B10C07001000000000000000000000000000
   Shop #: WSC 00066 790 00165
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7DB230D4EC7797D615-8028
   Slave 1:
   Component: WWS    150407  043 0581
   Serial number:         150605103125
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S5Y15M04D23H13M49S40
   Coding: 90A8DD
   Serial number: 000000000ZY1504824DS
   Serial number: 00000000000062013676
   Subsystem 5 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694812360202150253
   Coding: 181803
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331511300681
   Coding: 0031051011
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 3D32F0D4ACF757D655-8068
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6M00TJ5D
   VCID: 41CA8C24D00F333631-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 304 15
   Serial number: 3576700000074D88B31/
   Subsystem 2 - Part No SW: -----------    HW: 480 001 304 15
   Serial number: 35867000000AA83D041Z
   Subsystem 3 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3516502991A878635259
   Subsystem 4 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3526502C119EFF54D3B/
   Subsystem 5 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3556502C119EFF5472D
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150409500043
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FCE8ADCA6FB45C647-806A
   Part No SW: 5G1 920 756     HW: 5G1 920 756
   Component: KOMBI         342 4270
   Coding: 07AD09082980000800082A001000000000000000
   VCID: 6A980B888DF9106EC0-803E
1048578 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 147
                    Mileage: 1662 km
                    Date: 2015.12.22
                    Time: 21:01:55
   Revision: --------    Serial number: 27041510001328
   Coding: 0101000820085900EF00022A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_GatewConti.rod
   VCID: 72A813E8A529D8AE78-8026
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150000831280075174
   Coding: 29FFFF
   Serial number: 18051506050F05
   Coding: 003F0320D000040000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 40CC8920DB053A3E3E-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000001280001
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   VCID: 373EE2FC8ECB7D868F-8062
   Serial number: 220515060500Y5
   Coding: 003F0320DE00040000001000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000001235872
   Coding: 090000
   Coding: 021A01000B000200
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 2795 km
                    Date: 2016.02.28
                    Time: 22:01:13
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      041 0421
   Serial number: V1C01604151574
   Coding: 02730000FF00000021220001001800001F0203040100010001
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 271E32BC5E6BED061F-8072
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9RS2093KE
   Component: SAS-GEN 2     H06 0014
   Serial number: 150408202261
End-------------------------(Elapsed Time: 02:02)--------------------------
Interesting. It's picking up ROD data in the Auto-Scan. Can you post a screen-shot of the error message please?
csalvarr
Uruguay
C?ID=243709
I'm meeting with my friend again today and will test everything again. It's strange, I didn't see the error when working with the module (no ROD data message and no error data), but then I did one last auto-scan to post here and the error was there. I didn't realize I had the error until today when I opened the file, as I saved it without looking.
csalvarr
Uruguay
C?ID=243709
Here you can see the error I get via VCDS desktop. Also when I enter the module, fault codes, I get the unknown error / no rod data error (this was done about an hour ago):
But when doing a full autoscan I'm getting results, as you saw earlier.
Then I tried to use VCDS Mobile, with similar results:
Then the autoscan with VCDS Mobile also does not show the error:
Mon,Feb,29,2016,23:45:38
VCDS Mobile 0.4305.0.4
55-Xenon Range -- Status: Malfunction 0010
Address 01: Engine  (CXDA2 J623)	Labels: 06K-907-425-V1.clb
	Revision: --H13---
	ROD: N/A
	VCID: EB99D4AF9D66F83214311D1723-80BE
	No ASAM data for: "EV_ECM20TFS0215G0906259"
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Revision: 05853104
	ROD: N/A
	VCID: 29156EA7D71AAA22269DC7FFC9-807C
	No ASAM data for: "EV_TCMDQ250021"
Address 03: ABS Brakes  (J104)	Labels: None
	Revision: 00000000
	ROD: N/A
	VCID: 47D1C81F614E7C52D0C911474F-8012
	No ASAM data for: "EV_Brake1UDSContiMK100ESP"
	Revision: 00001K01
	ROD: N/A
	VCID: 42C7D90B4A6C597A0797D80B8C-8017
	No ASAM data for: "EV_ACClimaBHBVW37X"
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: None
	Revision: --------
	ROD: N/A
	VCID: 7DBD6AF77312E6823AE563CF8D-8028
	No ASAM data for: "EV_BodyContrModul1UDSBosc"
	Subsystem 1 - 	Part No SW: 5GM-955-119	Labels: 5Qx-955-119-V1.clb
	Component: MÝ
	Subsystem 2 - 	Component: ¨Ý
	Subsystem 3 -
	Subsystem 4 -
	Subsystem 5 - 	Component:
	Subsystem 6 -
	Revision: --------
	Coding: 0031051011
	ROD: N/A
	VCID: 3D3DAAF7339226827A65A3CFCD-8068
	No ASAM data for: "EV_EPHVA18AU3700000"
	ROD: N/A
	VCID: 41C5D6074F6A42621E8DCF1F81-8014
	No ASAM data for: "EV_AirbaVW20SMEVW37X"
	Subsystem 1 - 	Part No SW: --------------
	Component: ---
	Subsystem 2 - 	Component: ---
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
Address 16: Steering wheel  (J524)	Labels: 5Q-16.lbl
	Revision: FF032032
	Coding: 0410
	ROD: N/A
	VCID: 3FC1D0FF399E34926879B9E7E7-806A
	No ASAM data for: "EV_SMLSVALEOMQB"
	ROD: N/A
	VCID: EA97D1AB929CE13A6F2710EB34-80BF
	No ASAM data for: "EV_DashBoardVDDMQBAB"
1048578 - ROD - Unknown faultcode
	Revision: --------
	ROD: N/A
	VCID: 72A749CB3A4CA9FA5777E84B1C-8027
	No ASAM data for: "EV_GatewConti"
	Subsystem 1 -
	Subsystem 2 - 	Component: )ÿÿ
Address 42: Door Elect, Driver  (J386)	Labels: None
	ROD: N/A
	VCID: 40C3D30344604B6A1183C21392-8015
	No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
	Coding: 0102
	ROD: N/A
	VCID: 3731B8DF11AE0CD2A02961871F-8062
	No ASAM data for: "EV_SteerAssisMQB"
Address 52: Door Elect, Pass.  (J387)	Labels: None
	ROD: N/A
	No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Revision: --------
	ROD: N/A
	No ASAM data for: "EV_HeadlRegulVWAFSMQB"
	Subsystem 1 - 	Part No SW: 5N0-941-329	Labels: 3D0-941-329.clb
	Component: .
5275220 - ROD - Unknown faultcode
Address 5F: Information Electr.  (J794)	Labels: None
	ROD: N/A
	VCID: 2711689FC10E9C523089B1C72F-8072
	No ASAM data for: "EV_MUStd4CPASE"
	Subsystem 1 - 	Part No SW: 5G0-919-605
Address A9: Struct. Borne Sound  (J869)	Labels: 5G-a9.lbl
	Shop #: WSC 00000 000
	ROD: N/A
	No ASAM data for: "EV_SoundActuaGen2AU64X"
I'm seeing an update right now via HEXNET config utility, do you think it might fix this issue? Thanks for your support.
The DS 39 update should address some of this for VCDS-Mobile.
As to the problem with VCDS, it looks like there's some confusion over the chassis type depending on whether VCDS has seen the VIN of the car or not. In other words, if you start VCDS and go directly to 55-Headlight Range, it looks for a different suffix file than if it knows or has seen the VIN (i.e. during an Auto-Scan). We have access to a very similar car that has the same Xenon setup and will see if we can reproduce this.
csalvarr
Uruguay
C?ID=243709
Thanks again. My main problem still is I can't do basic settings, via VCDS desktop or VCDS mobile, I see no options on the dropdown where there should be at least one option to reset or calibrate the system, to solve the missing calibration error, am I right about this?
csalvarr
Uruguay
C?ID=243709
Also my HEX NET is already on DS 10xxxx39, BL 0.27, CFB 0.10, FW 0.238 and CB 0.4305.
When I check for updates via VCDS mobile, it says up to date, but when using the HEX NET UTILITY I see "Updated rod data needed", and when I download updates is just hangs. I tried several PCs (WinXP, Win7, Win10):
Andy
Sector 7G
HC424490
I just checked on my 2015 GTI and going straight into 55-Xenons with a HEX-NET connected via USB using VCDS Release 15.7.4, it went right in and loaded the ROD data.
csalvarr
Uruguay
C?ID=243709
Thanks for checking!
So is there a way the ROD data on my HEXNET got corrupted? Or when using VCDS on the desktop it doesn't matter? Maybe asociated with the problem I'm having with the message "Updated rod data needed" I get from the hexnet utility and can't seem to complete.
Any suggestions on what I could try?
Eric
HC800000
I'll let others comment on the VCDS-Mobile side, but VCDS only needs the VIN from the HEX-NET. Whatever ROD data is in the hexnet is not relevant to VCDS on the PC. I would try again after giving the hexnet time to boot up and retrieve the VIN (maybe 30 seconds after you've connected to the DLC?), only then go directly to 55. Or try an autoscan first. Please let us know if the problem persists either way, because if that is the case I'd like to take a look at debug files to see why this is happening.
csalvarr
Uruguay
C?ID=243709
Thanks. I'll check again and let you know.
csalvarr
Uruguay
C?ID=243709
As you predicted the problem seems to be with the VIN. I tried three screnarios:
1) Start VCDS, go straight to 55 -> ROD ERROR and no basic settings.
2) Start VCDS, perform autoscan, then go straigth to 55 -> No ERROR and basic settings work OK.
3) Start VCDS, go to 1-Engine, Advanced ID (gets the VIN), then go to 55 -> No ERROR and basic settings work OK.
So whenever the VIN was read, the problem was not present.
Thanks everybody for your help, I was able to perform the basic settings and get rid of the error in the GTI.
