I am trying to cycle the fuel pump on a 2014 3L v6 TDI but measuring blocks (I think that is where I access the fuel pump) is not highlighted so I can't access it. The update to VCDS was done when I started the task.
This has nothing to do with the version of VCDS, but rather the protocol your ECU uses. See:I am trying to cycle the fuel pump on a 2014 3L v6 TDI but measuring blocks (I think that is where I access the fuel pump) is not highlighted so I can't access it.
Thanks for that information. The output test screen doesn't "activate". It says select an output and start but the start tab isn't highlighted.Note the Manual Index (links) half way down the Interactive Manual page.
Also Output tests:
Try Advanced measuring values:
Did you select one? One like: "Fuel pump electronics" ?The output test screen doesn't "activate". It says select an output and start but the start tab isn't highlighted
Post a screen-shot so we can see what you're trying to tell us.When I go to output test the page doesn't fully lode
Codes is probably not the correct word.What imaginary codes are you asking about?
We understand\appreciate that you're in over your head... but taking the "poor me" approach won't solve anything.At 76 with failing mechanical (lack of patience and getting overwhelmed) I never should have started this project but paying someone to finish it is not an option.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
