Hi. Wondering if anyone is able to help. Currently have a vehicle with amber drl/ indicators on full time. I’m trying to find the correct byte code and or adaption to rectify this. Indicators work as normal when requested but when off they are illuminated constantly as drl’s. I will attach a photo of said illumination fault and a full vehicle scan of the vehicle. any help is much appreciated.
Wednesday,06,May,2026,14:10:54:29298
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.4
VIN: WAUZZZ8V3EA088350 License Plate: YJ63 XCF
Mileage: 239283km-148683mi Repair Order: AUTO SCAN
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 52 55 5F A9
BB BC
VIN: WAUZZZ8V3EA088350 Mileage: 239283km-148683miles
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09--- CVN: 533670BC
Coding: 0A1D00322466010B3000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS021_AU37.rod
VCID: 7DA6F8F28D7649C2A45-8028
VINID: 9D196AAAA2260D54402080C500CAF4CA99
17789 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [00100000] - -
Mileage: 239281 km
Date: 2026.05.05
Time: 14:08:12
Engine speed: 758.75 /min
Normed load value: 9.4 %
Coolant temperature: 74 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.492 V
Engine: operating status: IS
Engine temp. management actuator: raw value: 2117
Engine temperature management actuator: stop open: 150
Engine temperature management actuator: after-run stop: 4000
RVC_SP: 67.00 °
RVC_AV: 130.30 °
RVCPWM: 0.000 %
16986 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [01100000] - -
Mileage: 239281 km
Date: 2026.05.05
Time: 14:08:10
Engine speed: 767.75 /min
Voltage terminal 30: 14.550 V
RVC_SP: 133.75 °
RVC_AV: 130.30 °
RVCPWM: -26.184 %
16987 - Insufficient Engine Cooling / Coolant Flow
Mileage: 239281 km
Date: 2026.05.06
Time: 10:43:20
Engine speed: 1839.00 /min
Normed load value: 20.0 %
Vehicle speed: 25 km/h
Coolant temperature: 34 °C
Intake air temperature: 13 °C
Engine: operating status: PL
Engine temp. management actuator: raw value: 2241
RVC_SP: 142.00 °
RVC_AV: 138.50 °
RVCPWM: -25.818 %
Readiness: 0010 0001
Part No SW: 0D9 300 011 N HW: 02E 927 770 AN
Component: DQ250-6A MQB H52 4033
Revision: 05652104 Serial number: TFK01309270327 CVN: 00009925
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 2018E1865A44C42AEF3-8074
P1734 00 [00000010] - -
Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000 Serial number: 62853000000374
Coding: 32F193A254282A74037A070541C3694CC92A54C0E08296F7F84150080508
Shop #: WSC 64465 001 1048576
VCID: 7CA0F5F6966C40CA93B-8028
Revision: 00021000 Serial number: 0194601669 Dataset Number: 8V0909577C 0009
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_AU37.rod
VCID: 3A2C33EEDCD8BEFAC17-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0040
Revision: 20025000 Serial number: 00000000174748
Coding: 03100004000000011000000000001100
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008017
VCID: 33321ECAFBB24FB2021-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: B51840D6000000000001
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011329103266 Dataset Number: 8V0909514C 0063
Coding: 07011C46C2C106FD03844004B31407A8080C000000000000000000000000
ROD: EV_BCMBOSCH_011_VW37.rod
VCID: 77AAEADAAF4A6392FE9-8022
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130923 041 0580
Serial number: 130928095020
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 21851957
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Serial number: 04 07 2013 00001215
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132542BVV
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000028067248
6666 - Bulb for Low Beam Headlamp Left
B1217 15 [00001001] - Open or Short to Plus
Reset counter: 238
Mileage: 239283 km
Date: 2026.05.06
Time: 11:47:05
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beams: Not operated
Voltage: 11.9 V
Outside temperature: 12.0 °C
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [00001001] - Voltage Supply Open or Short to Plus
Reset counter: 238
Mileage: 239283 km
Date: 2026.05.06
Time: 10:55:12
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
Outside temperature: 11.5 °C
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [00001001] - Voltage Supply Open or Short to Plus
Reset counter: 238
Mileage: 239283 km
Date: 2026.05.06
Time: 10:55:12
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231329001069 Dataset Number: 8V0909526C 0034
Coding: 0070050051
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 3B2236EAD3E287F2DA1-806E
13637120 - Databus
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Reset counter: 22
Mileage: 239281 km
Date: 2026.05.06
Time: 10:21:23
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 J HW: 5Q0 907 567 J
Component: ACC3 H10 0396
Serial number: 25101903030055 Dataset Number: 8V0909863B 0012
Coding: 003E1301FE0309
Shop #: WSC 60103 210 00000
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 42DC4B0EB408F63A997-8016
1060 - Databus
U1123 00 [00101000] - Received Error Message
[FAULT_CIS_EPB_FAIL]
Reset counter: 22
Mileage: 239281 km
Date: 2026.05.06
Time: 10:13:42
Control Module temperature: 6 °C
Voltage terminal 15: 12.0 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1061 - Databus
[FAULT_CIS_EPB_ACTUATOR_FAIL]
Reset counter: 22
Mileage: 239281 km
Date: 2026.05.06
Time: 10:13:42
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R03K786 Dataset Number: 8V0909602C 0008
Coding: 98CCC0000C0000005C5400CA00C800000065
VCID: 4BC2662A834237726A1-801E
Subsystem 1 - Part No SW: ----------- HW: 480 000 210 13
Serial number: 3576700000037A09DD0/
Subsystem 2 - Part No SW: ----------- HW: 480 000 210 13
Serial number: 358670000005EA09DD07
Subsystem 3 - Part No SW: ----------- HW: 480 401 710 13
Serial number: 3516502A911FBEA0A24N
Subsystem 4 - Part No SW: ----------- HW: 480 401 710 13
Serial number: 3526502AB11FBEA0815O
Subsystem 5 - Part No SW: ----------- HW: 480 400 909 13
Serial number: 3556502C51118713F2EA
Subsystem 6 - Part No SW: ----------- HW: 480 400 110 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B51142C8492EC
Subsystem 7 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_P --- ----
Serial number: -------------------$
Subsystem 8 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_C --- ----
B1006 1B [10001001] - Resistance Too High
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:47
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [10001001] - Resistance Too High
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:47
9451547 - Igniter 1 for pedestrian protection
B1038 1B [10001001] - Resistance Too High
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:47
9451803 - Igniter 2 for pedestrian protection
B1039 1B [10001001] - Resistance Too High
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:47
9450261 - Pedestrian Protection Crash Sensor (passenger's side)
B1033 15 [10001001] - Open or Short to Plus
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
9496853 - Front Crash Sensor for Pedestrian Protection
B10E9 15 [10001001] - Open or Short to Plus
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
Part No SW: 8V0 953 521 R HW: 5Q0 953 549
Revision: -------- Serial number: 18101308490196 Dataset Number: ----------
Coding: E418
ROD: EV_SMLSKLOMQB_009.rod
VCID: 49CE5C22893E256258D-801C
Part No SW: 8V0 920 970 R HW: 8V0 920 970 R
Component: KOMBI H03 2212
Coding: 278D081A2E8046000181FA00000000
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0001055564 Dataset Number: 8V0909515C 0045
Coding: 030100042B085A005B0002781C0B00000001000000000000000000000000
GVL: 01D43C1000000600400C90000000C80000000000000000000000000000000000
ROD: EV_GatewLear_009_AU37.rod
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 21 09 2013 C0346720
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051233190
Address 22: AWD (J492) Labels: None
Component: Haldex4Motion
Dataset Number: v1260x015G0 0000
Coding: 0001
VCID: 55F6805255867182CC5-8000
No ASAM data for: "Unknown" (AU37)
16646 - ROD - Unknown Error Code
- 00 [00001000]
Fault Frequency: 0
Reset counter: 0
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000230961005
Coding: 0900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73B2DECABB320FB2C21-8026
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 07101301101243 Dataset Number: 8V0909872D 0027
Coding: 001D9E205C01040000001003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 3FDA42FAC7FA9BD2F69-806A
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Dataset Number: 8V1909852A 0004
Coding: 8101
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 29091303110093 Dataset Number: 8V0909873D 0026
Coding: 001D96205E01040000001003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3E243FFEC0F092DAFDF-806A
65654 - Motor for mirror fold-in
B11F6 13 [00001001] - Open Circuit
Reset counter: 236
Mileage: 239270 km
Date: 2026.05.01
Time: 12:09:03
Part No SW: 7P6 907 357 B HW: 7P6 907 357 B
Component: AFS-ECU H01 0040
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865F 0032
Coding: 01AE00002B230200
ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
ROD: EV_HeadlRegulLEDAFSMQB.rod
Subsystem 1 - Part No SW: 7PP 941 472 E HW: 7PP 941 472 E Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H06 7510
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7000
Coding: E00100
U1014 00 [10001001] - -
[Steuergeraet falsch codiert]
Reset counter: 235
9574144 - Bulb for Low Beam Headlamp Left
B1217 00 [00001001] - -
Reset counter: 239
Mileage: 239270 km
Date: 2026.05.01
Time: 12:37:19
5275648 - Left/Right Driving Switch-Over Active
C1080 00 [00001001] - -
Reset counter: 238
Mileage: 239283 km
Date: 2026.05.06
Time: 10:53:01
5545009 - LED Headlamp Power Output Stage; Left
B149C 31 [10001001] - No Signal
Fault Frequency: 21
Reset counter: 239
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:46
5545201 - Output Stage for LED Headlamp; Left
B149C F1 [10001001] - Incorrectly Coded
Reset counter: 235
Part No SW: 8V0 035 036 H HW: 8V0 035 036
Component: MU-H-LND-EU H41 0186
Serial number: A300J0DB001284 Dataset Number: 8V2909545C 0027
Coding: 01730301FF0A000021111101000A00102F00020701000100DE
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 372A2ADAEFCAA3923E9-8062
Subsystem 1 - Part No SW: V03 959 800 PP HW: -----------
Component: ECE 2013/2014 --- 0062
Multimedia display unit 1:
Subsystem 2 - Part No SW: 8V0 919 604 B HW: 8V0 919 604 B
Component: DU High H49 0013
Serial number: AUZ8Z9DM6006EF
Subsystem 3 - Part No SW: 8V0 919 614 J HW: 8V0 919 614 E
Component: ControlUnit_H H64 0764
Serial number: C1000003091300020408
Compact disc data bank:
Component: Gracenote --- 1008
13 Faults Found:
1584 - invalid data record
B2005 00 [00001001] - -
[Control module (data record download) - invalid data record for DTCP]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
Voltage terminal 30: 12.3 V
1585 - invalid data record
[Control module (data record download) - invalid data record for ASAM/ODX MUX]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1586 - invalid data record
[Control module (data record download) - invalid data record for speed shutoff thresholds]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1587 - invalid data record
[Control module (data record download) - invalid data record for language]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1588 - invalid data record
[Control module (data record download) - invalid data record for visible MMI system languages]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1589 - invalid data record
[Control module (data record download) - invalid data record for power management timer]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1590 - invalid data record
[Control module (data record download) - invalid data record for sound audio parameters]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1593 - invalid data record
[Control module (data record download) - invalid data record for enhanced audio sound parameters]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1592 - invalid data record
[Control module (data record download) - invalid data record for DAB frequency tables]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1595 - invalid data record
[Control module (data record download) - invalid data record for audio management HMI constants]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1591 - invalid data record
[Control module (data record download) - invalid data record for telephone audio parameters]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
1605 - invalid data record
[Control module (data record download) - invalid data record for voice recognition audio parameters]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:50
3073 - Cellular Antenna
B1053 13 [00001001] - Open Circuit
[GSM/UMTS aerial - open circuit]
Reset counter: 234
Mileage: 239269 km
Date: 2026.05.01
Time: 07:40:49
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0008
Serial number: 130924200814
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V1.clb
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 11101303110075 Dataset Number: 8V0909897B 0013
Coding: 000C96204001040000001002
ROD: EV_DCURearDriveMAXCONT_VW37.rod
VCID: 41DE4402B10EED2280D-8014
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V1.clb
Component: TSG HBFS 010 0006
Serial number: 11101304080075 Dataset Number: 8V0909896B 0013
ROD: EV_DCURearPasseMAXCONT_VW37.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 12.4V/12.1V)-----------
------------------------------36 Faults Found------------------------------
