VCDS B8.5 S4 Control Module 44 Security Key rejected
dreamsforgotten
Louisiana, USA
C?ID=648189
My 1st post guys, hope I'm following protocol. I have a B8.5 S4 (2014) with a replaced steering rack and transmission. Audi flashed the transmission no problem but I'm having difficulty with the rack. My most pressing issue is VCDS rejects the security code in the pop up bubble.
Scan with bad rack (Possibly not even the rack that came on the car originally Audi states different revision than the vin shows)
Friday,13,March,2026,11:14:04:60224
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Wine 11.0)
VCDS Version 25.3.3.0  HEX-V2 CB: 0.4671.5
Data version: 20260227 DS365.0
VIN: WAUBGAFL0EA061536   License Plate: 000000
Mileage: 220000km-136701mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 72 A9
VIN: WAUBGAFL0EA061536   Mileage: 220000km-136701miles
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07---    CVN: 14D7E3E6
Coding: 0A250034052608060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
ROD: EV_ECM30TFS021_AU48.rod
VCID: 3A2AD0C65CD12DDA80F-806F
VINID: 9D19525D159C015440181143180040A7F4
15428 - No Communications with Power Steering Control Module
U0131 00 [00100100] - -
Mileage: 220003 km
Date: 2026.03.13
Time: 10:13:43
Engine speed: 0.00 /min
Coolant temperature: 11 °C
Intake air temperature: 12 °C
Voltage terminal 30: 11.577 V
Engine speed: actual: 0 /min
T_AST_ENVD: 0.00 s
Gear: 0
Engine: operating status: ES
Battery voltage: 11.679688 V
Vehicle speed: actual: 0 km/h
6506 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [01101101] - -
Mileage: 220003 km
Date: 2026.02.27
Time: 15:20:17
Engine speed: 723.00 /min
Normed load value: 43.5 %
Coolant temperature: 50 °C
Intake air temperature: 43 °C
Voltage terminal 30: 12.695 V
Engine speed: actual: 1248 /min
MAF_ENVD: 277.79999 mg/stroke
Coolant temperature (unfiltered): 24.75 °C
Engine: operating status: IS
Engine load: 18.750000 %
Readiness: 1110 0101
Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
Component: 0B5 30TFSINAR H02 0002
Revision: --H02---    CVN: 00001231
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
18443 - Clutch 1
P17D6 00 [11101000] - Pressure too High
Mileage: 220003 km
Date: 2026.02.27
Time: 15:19:14
Engine speed: 907 /min
Transmission input speed: 907 /min
Engine torque: 96 Nm
ATF temperature: 32 °C
Accelerator pedal position: 0.0 %
Clutch status: Kupplung 1 kann Moment übertragen
Clutch pressure: clutch 1-Data: 4.41 bar
Clutch status-Data: Creeping
Nominal_pressure_clutch_1-Data: 2.86 bar
Nominal_pressure_shaft_1-Data: 2.860 bar
18445 - Clutch 2
P17D7 00 [11101000] - Pressure too High
Mileage: 220003 km
Date: 2026.02.27
Time: 15:20:20
Engine speed: 697 /min
Transmission input speed: 697 /min
Engine torque: 88 Nm
ATF temperature: 33 °C
Clutch status: Kupplung 2 kann Moment übertragen
Clutch pressure: clutch 2-Data: 4.40 bar
Nominal_pressure_clutch_2-Data: 2.53 bar
Nominal_pressure_shaft_2-Data: 2.530 bar
18447 - Clutch 1 Pressure Engagement too High
P286B 00 [11101101] - -
Mileage: 220003 km
Date: 2026.03.10
Time: 14:10:44
Engine speed: 620 /min
Transmission input speed: 620 /min
Engine torque: 148 Nm
ATF temperature: 29 °C
Clutch status: Beide Kupplungen offen
Clutch pressure: clutch 1-Data: 4.19 bar
Nominal_pressure_clutch_1-Data: 2.84 bar
Nominal_pressure_shaft_1-Data: 2.840 bar
18448 - Clutch 2 Pressure Engagement too High
P2873 00 [11101101] - -
Mileage: 220003 km
Date: 2026.02.27
Time: 15:19:16
Engine speed: 983 /min
Transmission input speed: 983 /min
Engine torque: 56 Nm
Clutch pressure: clutch 2-Data: 4.45 bar
Nominal_pressure_clutch_2-Data: 2.44 bar
Nominal_pressure_shaft_2-Data: 2.440 bar
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
Component: ESP8 quattro  H09 0020
Coding: 291D1801
VCID: 09487F0A4937F642D95-805D
Fault Status: 00101101
Fault Frequency: 9
Reset counter: 179
Mileage: 220003 km
Date: 2026.02.27
Time: 15:19:15
Hex Value: 0x00C0
Hex Value: 0x4082
Hex Value: 0x000D
Hex Value: 0x2390
Hex Value: 0x0000
Reset counter: 179
Mileage: 220003 km
Date: 2026.03.13
Time: 10:13:43
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0015
Hex Value: 0x1091
Hex Value: 0x0000
Reset counter: 179
Mileage: 220003 km
Date: 2026.03.13
Time: 10:13:43
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x000C
Hex Value: 0xE391
Hex Value: 0x0000
Part No SW: 8K0 907 064 HM    HW: 8K0 907 064 GM
Component: BCM2 2.0      H13 0641
Coding: 0D814040000000000000
VCID: 025A68267401A51A98F-8057
Serial number: 0213000317879005
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
Revision: C1000000    Serial number: 01021020132068
Coding: 6600228000
VCID: 3928CFCA595726C2895-806D
Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
Revision: 08016001    Serial number: 00000052344501
Coding: 26084011873CAFE0010148C300003D0D4F9CD308A2090221000008004000030100000030000000
Shop #: WSC 12345 123 61029
VCID: 78AE0ACE22DDFFCAB6B-802D
Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
Component: MITSUBA070913  H18 0461
Serial number: 1309040711265
Coding: 004577
Serial number: 21799406
Coding: 02005D
Component: E1 - LDS  H03 0031
Serial number: 00000000002709130448
Component: USHL4.2  H30 0030
Serial number: 0000002274555R7W5S03
Serial number: 0BF88EC6000000000001
Reset counter: 179
Mileage: 220003 km
Date: 2026.03.13
Time: 10:16:01
Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
Component: AirbagVW-AU10 H47 0610
Serial number: 003KJDB0JEFS   Dataset Number: 8K0909602VA 0001
Coding: 303844354730303030304A55304C384B3053
Shop #: WSC 26753 001 1048576
VCID: 4ACA80060C31BD5A10F-801F
Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
Serial number: 5810000R130000F6AN
Serial number: 6334MSME7F3223038
Serial number: 6344MSME7F344D1F-
Serial number: 6352QSME13391F40D
Serial number: 6362QSME3B4110402
Serial number: 63732SME4C374B467
Serial number: 63832SME0D443466/
Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
Component: Lenks.Modul   H03 0003
Revision: C0062331    Serial number: 90862MJ50000E
Coding: 000036
VCID: 48CEBA0E12BD4F4A06B-801D
Part No SW: 8K0 920 983     HW: 8K0 920 983
Component: KOMBIINSTR.   H35 0564
Revision: 00000000    Serial number: ZAI65R2AE
Coding: 83B709000301D705020000
VCID: 72BA38E644A1959A88F-8027
Reset counter: 179
Mileage: 220003 km
Date: 2026.03.13
Time: 10:13:44
Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028    Serial number: 2841Z139160319
Coding: 80C303FF00
VCID: 4CC6861E06C5A36A223-8019
Serial number: 4005991303
Reset counter: 179
Mileage: 220003 km
Date: 2026.03.11
Time: 08:26:14
Bin. Bits:    10111
Voltage: 11.10 V
Count: 6
Reset counter: 179
Mileage: 220003 km
Date: 2026.03.13
Time: 10:12:15
Bin. Bits:    00000
Voltage: 11.90 V
Count: 7
Bin. Bits:    00000
Time: 0.40 s
Component: MEM-FS        H06 0076
Revision: AA000000    Serial number: 00000075890773
Coding: 00581B00000000000000
VCID: 3B24D5C2536B14D29B9-806F
Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
Serial number: 0316206921 Dataset Number: 8K0909535H  0028
Coding: 010211
Shop #: WSC 06324 000 00000
ROD: EV_LaneChangAssis_AU48.rod
VCID: 3FDCA1D247F308F2B71-806B
Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
Component: SWA Slave  H05 0071
Serial number: 0316387617
Coding: 010211
Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
Component: TSG FA        H09 0305
Coding: 011C13204E00410001
VCID: 56F26476C809E9BA847-8003
Component: RCEPS         H37 0507
Revision: 00001000    Serial number: 0009128094 Dataset Number: 8F0909852H  0018
Coding: 100000010001
ROD: EV_RCEPSAU48X_008.rod
VCID: 3436FEFE7EB5DBAA5A3-8061
1052420 - Internal Control Module Memory Check Sum Error
B2000 49 [10001001] - Internal Electronic Failure
[Unplausibler Signalverlauf Motortemperatursensor (zu hoher Temperaturgradient)]
Mileage: 218423 km
Date: 2025.11.08
Time: 13:07:22
03 00
Revision: 00002001    Serial number: 0316867123
Coding: 0106063A00FA400580B0013200000000
Component: GTO BF  H01 0080
Serial number: 00000000000000733780
Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
Component: J245 PS050  H08 0043
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 139
Mileage: 220003 km
Date: 2026.03.10
Time: 18:12:27
02615 - Fuel Tank Cap; Lock
Reset counter: 139
Mileage: 220003 km
Date: 2026.03.10
Time: 18:32:35
Revision: 00005001    Serial number: 94813020542203
VCID: 2D00EB9A9D1F8A6215D-8079
Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
Component: TSG BF        H09 0305
VCID: 55F0637AD50FE2A28DD-8001
Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
Component: EPB-4         H01 0004
Revision: --------    Serial number: 00000001370884
ROD: EV_ParkiBrake_AU48.rod
VCID: 3928CFCA59D726C2895-806D
Revision: AB001007    Serial number: 156JE0D7913989
Coding: 020007010000000001
VCID: 24160EBECED54B2ACA3-8071
02984 - Connection between Impedance Converter 2 and Window Antenna
Reset counter: 138
Mileage: 220003 km
Date: 2026.02.27
Time: 13:32:54
Voltage: 12.10 V
Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
Component: H-BNT-NA      H42 0901
Revision: --------    Serial number: 523JA0F7545786
Coding: 110200000206A1EF55028B4E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015  1102
Component: DU7 High  H42 0104
Serial number: A130IX0D2834905
Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
Serial number: 00000001630688
Component: CD-Database  5950
Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
Component: TSG HL        H07 0305
Coding: 010C13204000210001
VCID: 59E86F4AB917C6C2A95-800D
Revision: --H08---    Serial number: 525PA8-J3794LY
Coding: 1000006
VCID: 382ECACE6E5D3FCA76B-806D
02203 - Audio / Video Input 1
Reset counter: 139
Mileage: 220003 km
Date: 2026.03.10
Time: 18:01:53
Reverse OFF
Count: 3
Component: TSG HR        H07 0305
Part No SW: 8K0 907 159     HW: 4H0 907 159 A
Component: SAS-GEN 2     H06 0005
Serial number: 130910201623
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002_AU48.rod
VCID: 72BA38E64421959A88F-8027
End----(Elapsed Time: 02:00, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
------------------------------18 Faults Found------------------------------
New scan with new DSG and rack
Wednesday,29,April,2026,11:27:39:60224
VCDS Version 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: WAUBGAFL0EA061536   License Plate: 578JKV
Mileage: 220050km-136732mi   Repair Order:
          62 6C 72 A9
VIN: WAUBGAFL0EA061536   Mileage: 220050km-136732miles
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
3C-Lane Change -- Status: Cannot be reached 1100
A9-Struct. Borne Sound -- Status: Cannot be reached 1100
Address 01: Engine
   Coding: 291D1801
   VCID: 09487F0A4937F64298D-805D
   VCID: 025A68267401A51AD97-8057
   Coding: 6600228000
   VCID: 3928CFCA595726C2C8D-806D
   Coding: 26000091863CAFE0010048C300003D0D0F9CD308A2090221000008004000030100000030000000
   Shop #: WSC 99999 999 2097151
   VCID: 78AE0ACE22DDFFCAF73-802D
   Coding: 004577
   Coding: 02005D
Address 15: Airbags
   Coding: 000036
   VCID: 48CEBA0E12BD4F4A473-801D
   Coding: 8BB709000301D705020000
   VCID: 72BA38E644A1959AC97-8027
   Coding: 80C303FF00
   VCID: 4CC6861E06C5A36A63B-8019
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 183
                    Mileage: 220007 km
                    Date: 2026.04.27
                    Time: 08:57:03
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 11
                    Bin. Bits:    00000
   VCID: 3B24D5C2536B14D2DA1-806F
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0012576106 Dataset Number: 8K0909852H  0023
   VCID: 3436FEFE7EB5DBAA1BB-8061
5258753 - Steering End Stops Not Learned
          C10AC F0 [10001001] -
          [Lenkungsendanschläge nicht angelernt]
                    Fault Frequency: 107
                    Reset counter: 145
                    Mileage: 220004 km
                    Date: 2026.04.22
                    Time: 11:32:40
                    16 00 00 00
   Shop #: WSC 99999 999 12345
                    Reset counter: 141
                    Mileage: 220002 km
                    Date: 2026.04.21
                    Time: 16:05:28
                    Reset counter: 141
                    Mileage: 220002 km
                    Date: 2026.04.21
                    Time: 16:17:21
   VCID: 2D00EB9A9D1F8A62545-8079
   VCID: 3928CFCA59D726C2C8D-806D
   VCID: 24160EBECED54B2A8BB-8071
                    Reset counter: 141
                    Mileage: 220002 km
                    Date: 2026.04.21
                    Time: 16:04:47
                    Voltage: 13.80 V
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 182
                    Mileage: 220007 km
                    Date: 2026.04.27
                    Time: 08:34:07
                    Voltage: 12.20 V
End----(Elapsed Time: 01:24, VBatt start/end: 12.8V/12.7V. VIgn 0.0V)------
------------------------------6 Faults Found-------------------------------
Thank you for your time.
That's not VCDS rejecting it. That's the module rejecting it. VCDS is just relaying that fact to you.
dreamsforgotten
Louisiana, USA
C?ID=648189
Understood, but I'm not sure where to go from here. I've tried the one listed on many write ups as well, 40168 to no avail, I'm just not sure where I go about finding the code the control module will accept.
Let's see if we can get @RTSupport to chime in here.
dreamsforgotten
Louisiana, USA
C?ID=648189
I just got rejected attempting I believe 20113 to the central electronics module as well which is what the pop up box suggested so I'm not sure if it's my vcds setup on my computer or these codes aren't correct. Just adding this for context.
At a glance I think the old/faulty rack was from a B8.5 A5 Cabrio donor vehicle based on the 8F0909852H dataset that was flashed into it. It was faulty either way but I agree with the Audi dealer's suspicion that it was not original.
Next, the current condition scan is lacking communication with most of the control modules and it ended with VIgn 0.0V (meaning ignition/terminal 15 off). Most diagnostic functions are not available with the ignition off so please scan it again, perhaps with the engine at idle, and post that copy so we can see if that was a fluke versus an actual problem on the car side that we need to shift focus to.
If the terminal 15 issue is ongoing that may directly explain the Unknown Error 00 with SA 43702 in address 44 however that is rarely needed because it applies to Basic Setting Enabling. For that reason, when the engine is at idle please try the full lock right and left steps at the very bottom of this page:
dreamsforgotten
Louisiana, USA
C?ID=648189
The left/right full lock steps I've tried but the angle is out more than 20 degrees as of this moment. I'm about to pull all lower control arms and do the bushings so that I can get an alignment I was hoping was going to fix these end stops.
Here's the idle scan
Friday,01,May,2026,11:22:11:60224
Mileage: 220350km-136919mi Repair Order:
62 6C 72 A9
VIN: WAUBGAFL0EA061536 Mileage: 220350km-136919miles
VCID: 3A2AD0C65CD12DDAC17-806F
6532 - Throttle Actuator (J338)
P1568 00 [01100000] - Mechanical Failure
Fault Frequency: 36
Mileage: 220007 km
Vehicle speed: 255 km/h
Coolant temperature: 52 °C
Intake air temperature: -40 °C
Voltage terminal 30: 12.390 V
Unlearning counter according OBD: 33
V_TPS_1_ENVD: 4.72656 V
V_TPS_2_ENVD: 0.00000 V
Coolant temperature (unfiltered): 30.75 °C
TIA_AM_SCHA: 35.25 °C
Battery voltage: 13.101563 V
6422 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 00 [00100000] - Electrical Malfunction
Fault Frequency: 23
Mileage: 220007 km
Date: 2026.04.22
Time: 18:32:49
Coolant temperature: 27 °C
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 29.25 °C
V_PORT_1_ENVD: 4.49219 V
6424 - Intake Manifold Flap Position Sensor (Bank 2)
P2019 00 [00100000] - Electrical Malfunction
Fault Frequency: 21
Mileage: 220007 km
Date: 2026.04.23
Time: 08:45:59
Coolant temperature: 21 °C
Coolant temperature (unfiltered): 28.50 °C
V_PORT_2_ENVD: 0.00000 V
7804 - Position Sensor for Intake Air Regulating Flap
P10A6 00 [00100000] - Signal too Low
Fault Frequency: 36
Mileage: 220007 km
Coolant temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
PDT_ENVD: 95.51953 hPa
V_PVS_1_ENVD: 0.74219 V
RFP_SP_ENVD: 69.4488
VP_RFP_1_ENVD: 0.00000 V
RFPPWM_ENVD: 0.00000 %
20136 - PCV Valve Malfunction
P052E 00 [01101101] - -
Mileage: 220004 km
Date: 2026.04.22
Time: 11:41:40
Engine speed: 705.00 /min
Normed load value: 13.7 %
Coolant temperature: 85 °C
Intake air temperature: 37 °C
Voltage terminal 30: 13.710 V
Engine speed: actual: 704 /min
MAF_ENVD: 108.94117 mg/stroke
Coolant temperature (unfiltered): 94.50 °C
Engine load: 10.156250 %
13813 - Sensor for Cylinder Head Temperature
P017D 00 [00100000] - Short to Plus
Mileage: 220007 km
Date: 2026.04.23
Time: 08:45:58
Coolant temperature (unfiltered): 21.75 °C
Battery voltage: 12.390625 V
Part No SW: 8K5 927 156 D HW: 0B5 927 156 J
Shop #: WSC 02391 785 00200
Coding: 291D1801
Coding: 6600228000
Coding: 004577
Coding: 02005D
VCID: 4ACA80060C31BD5A517-801F
Seat occupant detection:
Coding: 000036
Coding: 80C303FF00
Reset counter: 183
Mileage: 220007 km
Date: 2026.04.27
Time: 08:57:03
Bin. Bits: 10000
Voltage: 12.20 V
Count: 11
Bin. Bits: 00000
Coding: 010211
VCID: 3FDCA1D247F308F2F69-806B
Coding: 010211
VCID: 56F26476C809E9BAC5F-8003
Fault Frequency: 232
Reset counter: 149
Mileage: 220004 km
Date: 2026.04.22
Time: 11:32:40
16 00 00 00
Reset counter: 141
Mileage: 220002 km
Date: 2026.04.21
Time: 16:05:28
Reset counter: 141
Mileage: 220002 km
Date: 2026.04.21
Time: 16:17:21
VCID: 55F0637AD50FE2A2CC5-8001
Reset counter: 141
Mileage: 220002 km
Date: 2026.04.21
Time: 16:04:47
Voltage: 13.80 V
Coding: 110200000206E1EF55028B4E00000403140000000000000000
Reset counter: 182
Mileage: 220007 km
Date: 2026.04.27
Time: 08:34:07
Voltage: 12.20 V
VCID: 59E86F4AB917C6C2E8D-800D
Coding: 1000006
VCID: 382ECACE6E5D3FCA373-806D
Reset counter: 185
Mileage: 220007 km
Date: 2026.04.28
Time: 15:56:09
Reverse OFF
Count: 3
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 72BA38E64421959AC97-8027
End----------(Elapsed Time: 01:56, VBatt start/end: 13.7V/14.1V)-----------
------------------------------13 Faults Found------------------------------
Excellent. Everything is communicating correctly and this scan looks a lot better.
For science, you can reconnect to address 44 at idle and see if Security Access 43702 = Basic Setting Enabling is accepted but I don't think that is the answer if you see a full 20° discrepancy. That is the specification I located when I added the Resetting of learned values for steering assistance notes at the bottom of this page but I don't like it at all:
When you are working with a smaller range (such as +/- 8°) you are less likely to encounter difficulty but I don't think you are going to make it worse if you try that once more prior to the remaining repairs and before the next alignment.
dreamsforgotten
Louisiana, USA
C?ID=648189
Every time I attemtped to access 44 I had the car running, it was only off when I ran the auto scan. The two sides are currently out beyound 20 degrees, the left side reads 515.70 and the right is 465. I installed the rack, even swapped the tie rod ends and I had no idea what I was doing. As soon as I change the bushings out, I will let the professionals do it the right way :D. What I did was set the rack to the incorrect rack which I pulled from the car, I believe I was working off bad intel!
OK, when you get to the point where the new bushing are installed and you are about to wrap up the work make sure to pop into address 16 (that's the clockspring/slipring and where G85 lives) with the ignition on and check MVB 033.3 Steering Angle (Internal)
Make sure that's as close as possible to 0.0° with the steering wheel straight. This is easier said than done without a drive-on rack and the full professional kit but as long as you have the wheels on and suspension loaded with G85 centered you might be able to correct that toe getting it closer to center using a tape measure. That will not substitute the need for a real alignment but the tires will thank you on the test drive after repairs and the trip to the shop. If you get it close enough the drive to the alignment shop might be with fully functional power steering assist.
dreamsforgotten
Louisiana, USA
C?ID=648189
Make sure that's as close as possible to 0.0° with the steering wheel straight. This is easier said than done without a drive-on rack and the full professional kit but as long as you have the wheels on and suspension loaded with G85 centered you might be able to correct that tow getting it closer to center using a tape measure. That will not substitute the need for a real alignment but the tires will thank you on the test drive after repairs and the trip to the shop. If you get it close enough the drive to the alignment shop might be with fully functional power steering assist.
will do, thanks!
dreamsforgotten
Louisiana, USA
C?ID=648189
I went outside and put the length of both tie rod ends in relation to the threads on the tie rods equal, did the left right full lock and the error is gone, however it made my alignment horrible, the wheels fighting each other, so i returned it to the "lopsided" setting it was previously. The steering error is gone and now I have full steering assist. I will have it parked until the bushings arrive and then drive it only to the alignment after, I think I'm in good shape. I still need to figure out the security codes for the modules as i'm trying to unlock, but I'm getting there.
