SFD Public Beta!
welshkaiboy
C?ID=654838
Hopefully UK 2026 Tiguan tfsi ehybrid delivery will be confirmed tomorrow by the dealer. Can't wait to get inside a SFD car and get some scans fro you all.
Just posted in other thread, car being collected on Friday, excited YES :D
   #262
Eric
HC800000
Login before unlocking takes 10-20 seconds. I am not sure if it can be improved, if not this is it, 10-20 second extra is not a problem.
My understanding is this is a limitation of the interface, which needs to do several rounds of crypto computations, and sadly is not a supercomputer ;) . On the plus side, like you said, 20 seconds give you a 30 minute session, so in that context, I think it's reasonable.
   #263
Aerofan
C?ID=647191
All good, it was just a suggestion, since we are living in a world of speed. For me it is not a problem.
   #264
RTS
C?ID=492458
Volkswagen Crafter 2026? (75 plate registration UK) sfd unlocked and crash data reset no issues at all, will open a separate thread with autoscan and sfd log etc.
Bretterson
Cleveland, Ohio
C?ID=654007
I have been using the beta for the past couple of weeks and no issues to report other than entering my password wrong on a couple of occasions as I have too many to remember.
I'm really pleased a native unlock has finally been added as its easier and faster to use than logging into ODIS. Would be great if the "session" could be extended from 30 minutes to 60 / 1 hour.
Might I recommend a password manager? I use 1Password, but if you want a free option I'd probably suggest Bitwarden.
   #266
Bretterson
Cleveland, Ohio
C?ID=654007
Not a complaint, just a curiosity... how come the sessions are 30 minutes when a module's unlock lasts 90 minutes?
   #267
zoyichka
Australia
C?ID=638642
I’m of no authority to state the exact reason why - but it makes logical sense that a finite time span for data input requests presents finite opportunities for digital safety risks, exploitation, expensive mistakes and “poke around until something happens” level workmanship.
In my case, I’m currently awaiting my VCDS SFD service account activation confirmation to come through. I have a small but critical laundry list of values to address and have the guides hot and ready to go which 30 minutes really should be ample.
SFD is often referred to as a firewall, and I’m certain I would not want my home network firewall disabled for more than a few minutes since it is against best practice and carries unnecessary risk.
   #268
It's intentionally a bit on the short side for Beta testing purposes. I actually agree that it could be lengthened and might well be when we go to full Release. That said, 30 minutes is enough time to go and manually unlock every module that has SFD in a in a high-spec 2026 car -- I've done personally done this with time to spare. And for normal service operations, it should not be necessary to unlock more than two or three modules.
I tried a SFD2 protected car with the lates VCDS version and there were no prefixes like in this attachment.
What car? What module? Was the Gateway unlocked and the filter de-activated?
Bretterson
Cleveland, Ohio
C?ID=654007
I get what you're saying but I would argue just having an open SFD session isn't really like disabling a firewall, I think it's more akin to logging in to an admin account. Basically, you have the key to disable the firewall but haven't necessarily done so.
Also, I wasn't suggesting sessions should be indefinite, just wondered why the periods were different lengths.
Copy that, thanks.
   #272
Bretterson
Cleveland, Ohio
C?ID=654007
This is quite minor and not SFD-specific, but I noticed the "About" panel shows zeros for both the number of codings changed and adaptations saved. Just figured I'd mention since because beta.
   #273
Eric
HC800000
Because they're not directly related. You need a SFD session to unlock a module, but the SFD session doesn't need to continue for the module to stay unlocked. What do you feel would be gained by making the SFD session 90 minutes?
I see you did change some of both . Does that stay permanently at zero or was it a glitch that disappears if you test the interface again? I just checked with my SFD2 gateway here and the adaptation number increases when I turn off the filter.
   #274
Bretterson
Cleveland, Ohio
C?ID=654007
I'm not asking for it to be increased, I'm ok with either length; I just figured there was probably a reason they weren't the same so I was curious.
I'll try to check over the weekend.
   #275
Bretterson
Cleveland, Ohio
C?ID=654007
I just opened my computer and connected the cable to my car; VCDS was still open. I checked the "About" panel and now it shows three codings changed and seven adaptations saved. I tested the interface then checked "About" again and neither value changed. I quit VCDS, reopened it, and the values were the same.
Eric
HC800000
OK. Let us know if you find a way to reproduce the issue where it shows zeroes.
   #277
ruztok
Poland
C?ID=327224
Hi everyone,
I'm seeking some advice regarding a 2025 Skoda Scala. I performed an oil service on this vehicle, but I've hit a wall when it comes to resetting the service interval.
Even after successfully unlocking SFD for the Dashboard (module 17), the service reset procedure fails. Furthermore, I am unable to manually change any adaptation values in the dashboard. It seems that the controller is rejecting any modifications despite the SFD being unlocked.
I have tried the procedure with the hood open, but it made no difference. I have attached the full Auto-Scan and the SFD log from the session.
Has anyone encountered similar behavior with these newer models? Is there a specific procedure for this, or is this a hard limitation requiring online access via ODIS/GeKo?
Any guidance or insight would be greatly appreciated.
Best regards
Friday,03,July,2026,10:05:38:61563
VCDS Version: 26.5.2.1 (x64)  HEX-NET CB: 0.4713.4
Data version: 20260506 DS377.0
VIN: TMBEK6NW3R3054288   License Plate:
Mileage: 61432km-38172mi   Repair Order: skoda scala
Chassis Type: NW-SK27 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 5F 75 A5
VIN: TMBEK6NW3R3054288   Mileage: 61432km-38172miles
Address 01: Engine (J623-DXDB)       Labels: Redir Fail!
   Part No SW: 05E 906 019 BR    HW: 05E 907 309 CB
   Component: R4 1.5l TFS   H80 3608
   Revision: KMH80000    Dataset Number: V03935377HY 0001 CVN: 3DE9A874
   Coding: 0119003223241D0810000000000000000000000000000000
   Shop #: WSC 31000 074 00113
   ASAM Dataset: EV_ECM15TFS01105E906019BR 002003
   ROD: EV_ECM15TFS01105E906019BR_002_VW27.rod
   VCID: 77BE0424CE3D3F2663-8022 SFD+SFD2 [x]
   VINID: 91D4956C67A70E20C0144088206A22B2A0
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 CP    HW: 2Q0 614 517 CB
   Component: ESC_Base_vFGS H20 0120
   Serial number: BPA085150424015 Dataset Number: V03935424GV 0001
   Coding: 0D1B0152B1FE9B
   ASAM Dataset: EV_BrakeBoschMQBA0UNECE 012016
   ROD: EV_BrakeBoschMQBA0UNECE_012_SK27.rod
   VCID: 7EB01100E1070E6E20-802A SFD+SFD2 [x]
0621 - Display for Tire Pressure Monitoring
          C1146 02 [00100100] - Signal Failure
          [RKA library detected Signal Integrity Error]
                    Date: 2020.01.01
                    Time: 00:05:52
0631 - TPMS Warning
          C102D F5 [00100100] - Tire Pressure too Low
          [RKA library detected Pressure Warning Error]
                    Mileage: 18645 km
                    Date: 2025.03.10
                    Time: 18:57:05
0633 - Engine Control Unit Incorrectly Coded
          P0610 00 [00100100] - -
          [Gearbox type from NET and EEPROM are different during variant checking]
                    Date: 2020.01.01
                    Time: 00:05:43
   Part No SW: 3Q1 959 435 B    HW: 3Q1 959 435 B
   Component: VWKESSYMQB    027 1501
   Revision: 00027000    Serial number: 0642648123 Dataset Number: V03935404YM 0001
   Coding: 000F0F0623
   Shop #: WSC 31000 074 00017
   ASAM Dataset: EV_KessyHellaMQBAB 004056
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 3A38DD10BDAFE24E5C-806E
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 6VA 907 044 D    HW: 6VA 907 044 D
   Component: Climatronic   H05 0813
   Dataset Number: V03935402NZ 0001
   Coding: 111000000800010001100800524401051050000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004028
   ROD: EV_ACClimaBHBMQBA0.rod
   VCID: 49DAB2DCE84979D6C5-801C
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V2.clb
   Part No SW: 2Q0 937 090 F    HW: 2Q0 937 090 F
   Component: BCM A0 Std+   H15 0982
   Serial number: 02102410405538 Dataset Number: V03935434X  0001
   ASAM Dataset: EV_BCMA0 209001
   ROD: EV_BCMA0_209_VW27.rod
   VCID: 3522CE2C94B10D36B1-8060 SFD+SFD2 [x]
   Driver door control module:
   Front passenger door control module:
   Humidity sensor: interior:
   Serial number: 00000000000080607982
204290 - Remote key 1
          B1479 18 [00001000] - Current Too Low
                    Reset counter: 147
                    Mileage: 60318 km
                    Date: 2026.06.24
                    Time: 09:08:21
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beams: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.6 V
   Part No SW: 5QA 919 283 G    HW: 5QA 919 283
   Component: PDC 4 Kanal   H12 0083
   Serial number: 000150059324103 Dataset Number: V03935412J  0001
   Coding: 0601050001
   ASAM Dataset: EV_EPHVA14AU3700000 010055
   ROD: EV_EPHVA14AU3700000_009_VW27.rod
   VCID: 4ED081C011275EEE90-801A
   Part No SW: 2Q0 907 567 B    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H03 0534
   Dataset Number: V03935428GB 0001
   Coding: 2A05600148FF8748949C810D00508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_VW27.rod
   VCID: 373EC4248EBDFF26A3-8062 SFD+SFD2 [x]
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 BL    HW: 2Q0 959 655 BL
   Component: VW23Airbag    040 0719
   Revision: --------    Dataset Number: V03935440CZ 0001
   Coding: 88CCC0C0000000005C5400CF000840000065
   Shop #: WSC 48746 006 1048576
   ASAM Dataset: EV_AirbaVW23BPAVW27X 001012
   ROD: EV_AirbaVW23BPAVW27X.rod
   VCID: 085C77D8B3C340DE1A-805C SFD+SFD2 [x]
   Subsystem 1 - Part No SW: -----------    HW: 442 061 803 24
   Serial number: 3577Y51A91445DE0B1DI
   Subsystem 2 - Part No SW: -----------    HW: 442 061 803 24
   Serial number: 3587Y51A91445DE1B1EL
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 103 24
   Serial number: 35177829B124F7A0F1AW
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 103 24
   Serial number: 35277829D124F7A1138M
   Subsystem 5 - Part No SW: -----------    HW: 442 131 703 24
   Component: FrontSensor_D  290 118A
   Serial number: 355AG23BAAEC28D1C55I
   Part No SW: 654 920 310     HW: 654 920 310
   Component: KOMBI         075 5882
   Dataset Number: V03935432LY 0001
   Coding: 0524001061840008018B62431001000800000220
   ASAM Dataset: EV_DashBoardJCIMQBAB 012005
   ROD: EV_DashBoardJCIMQBAB_012_VW27.rod
   VCID: 4ED081C011275EEE90-801A SFD+SFD2 [x]
1310720 - Release / Enable Active
          B184C 00 [00001000] - -
          [Freischaltung aktiv]
                    Fault Frequency: 32
                    Reset counter: 15
                    Mileage: 60308 km
                    Date: 2026.06.24
                    Time: 08:42:01
   Part No SW: 3Q0 907 530 BB    HW: 3Q0 907 530 BA
   Component: GW 2023 CLA   542 5555
   Revision: --------    Serial number: CU5SIB120424109 Dataset Number: V03935418MV 0001
   Coding: 0000808D0F00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
   GVL: 3D00000006004080800000004800000000000000000000000000000000000044
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW27.rod
   VCID: 70AC3F38AB53681EA2-8024 SFD+SFD2 [x]
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 104A72FE
   Subsystem 3 - Part No SW: 5E3 919 719 R    HW: 5E3 919 719 R
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440061094242721
8712962 - Attention and Drowsiness Assist
          U1832 00 [00101000] - Function Restriction
          [FAULT_ADA_FUNCTION_ERROR]
                    Fault Frequency: 34
                    Reset counter: 38
                    Mileage: 60328 km
                    Date: 2026.06.28
                    Time: 11:23:10
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000097079014 Dataset Number: V03935361XC 0001
   Coding: 0008000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 AM    HW: 2Q1 909 144 AD
   Component: TRW_G4L_MQBA0 613 6064
   Serial number: 01O4F034CB4R114 Dataset Number: V03935423FP 0001
   Coding: 010000000100000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LClass 016018
   ROD: EV_SteerAssisTRWG4LClass.rod
   VCID: 7DB2160CEC01157639-8028 SFD+SFD2 [x]
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 657 035 869     HW: 657 035 869
   Component: MU-E-D-EU     061 0480
   Serial number: SKZAZ2C0562368  Dataset Number: V03935422HK 0001
   Coding: 33730000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIGPMQB 001001
   ROD: EV_MUEIGPMQB_VW27.rod
   VCID: 618A4A7C70B9D1963D-8034 SFD+SFD2 [x]
   Part No SW: 2GA 035 284 B    HW: 2GA 035 284
   Component: OCUClas2023_H H07 0523
   Serial number: 0000000404VISM6 Dataset Number: V03935434ZX 0001
   Coding: 03010500000100210000000012000607111112111012100000
   ASAM Dataset: EV_OCUClass2023 001059
   ROD: EV_OCUClass2023.rod
   VCID: 3228F53065DF1A0E94-8066 SFD+SFD2 [x]
   Part No SW: 2Q0 980 653 G    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1505
   Serial number: ED3659911241100 Dataset Number: V03935426ZL 0001
   Coding: 0002088801404020409E08001020000001018048600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007057
   VCID: 393AC21CB8A9E95655-806C
End----------(Elapsed Time: 01:00, VBatt start/end: 12.4V/12.3V)-----------
------------------------------6 Faults Found-------------------------------
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Wednesday,24,June,2026,08:41:47,HN1-010939,SFD challenge retrieval success, 583 bytes
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Wednesday,24,June,2026,08:41:49,HN1-010939,SFD unlock token retrieval success, 532 bytes
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Wednesday,24,June,2026,08:41:49,HN1-010939,SFD unlock token transmitted to controller
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Wednesday,24,June,2026,08:41:50,HN1-010939,Unlock_successful
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Friday,03,July,2026,10:14:56,HN1-010939,SFD challenge retrieval success, 583 bytes
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Friday,03,July,2026,10:14:58,HN1-010939,SFD unlock token retrieval success, 532 bytes
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Friday,03,July,2026,10:14:58,HN1-010939,SFD unlock token transmitted to controller
TMBEK6NW3R3054288,Address 0x17,654 920 310 ,Online SFD,Friday,03,July,2026,10:14:58,HN1-010939,Unlock_successful
   #278
Eric
HC800000
*Make a new thread, post autoscan
*Unlock 19, turn off filter
*Unlock 17
*Post ADP channel map of 17
FishBB
Poland
C?ID=631493
Did you disable the diagnostic filters in adaptations in CAN gateway?
   #280
greka
Poland
C?ID=382958
Hello, I have a problem with my order.
[Screen Shot Redacted]
