- Feb 26, 2016
- 152
- 35
- Czech Republic
- C?ID=91614
First I would like to say, that I am already aprox 6 years lucky user of legal VCDS cable and Czech version of this VCDS software.
Because I am really interesting in improving things, I made some retrofits on my Audi A6 Avant 4G 3.0 TDI quattro S-tronic 2012, after final working solutions i provide my knowleges and how to, but now i need help from you :-)
Night vision - working now
I have to buy:
- new light switch - specified for every model - is different
- night vision camera + holdings
- holder under grill
- connect to washing system
- cables
- new instrument cluster - not needed but for ACC and Lane assist yes.
- remove CP + calibrate in audi dealer
- working now correctly!!
ACC + LANE ASSIST
I have to buy
- 2 radars + covers to bumper + cables (connectors)
- front camera + connector
- ABS + ESP module (very expensive and hard to get working - there is coding moduled by VIN) - I use Vag Can Pro
- new windshiled + cover to camera
- image processing unit + cables + holder
- new instrument cluster switch + ring (acc + lane)
- new tacho (instrument cluster)
- cables
- new door switch + cable
- remove CP
- calibrating camera
- coding VCDS + MMI on Green menu
- not working now :-/
I dont have side assist!
First i want to get working Lane assist.
But when i touch button in instrument cluster, it make message lane assist is not available
Also ACC does not work - ACC + brakong guard not available.
Audi dealer told me, that parrameters of ACC radars are ok.
Not sure about coding drivers doors, camera and image processor unit.
Any help ?
My VCDS file:
I have to buy:
- cables
ACC + LANE ASSIST
I have to buy
- cables
- remove CP
Any help ?
My VCDS file:
Friday,26,February,2016,10:33:21:34170
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ4G6CN170201 License Plate:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 34 3B 42 44 46 52
53 55 56 5F 62 6D 72 84 85 8B 8E 8F 90
Address 01: Engine (J623-CLAA) Labels: None
Part No SW: 4G0 ABT 311 E HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 A001
Revision: 53H37---
Coding: 0A254012056601020000
Shop #: WSC 28358 001 1048576
ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
ROD: EV_ECM30TDI0114G0907311E.rod
VCID: 5CB3F24157AEFDDE42-8008
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G1 927 156 C HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0004
Revision: --H10--- Serial number: 0000000137
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 2D556F857C944456E5-8078
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 07A6D701E065EB80CB00
Shop #: WSC 02391 785 00200
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 3B7151DDB2E0DAE66B-806E
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Coding: 01A93006000000000000
VCID: 76E780E9C142478E54-8022
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0076
Serial number: 30011300040731
Coding: 3602007E20
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS.rod
VCID: 62CFCCB975CACB2E08-8036
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001476545
Coding: 0907201109749FE08981008300001800CF9CC7082E080101000108542F01
Shop #: WSC 45343 001 104857
VCID: 77F98DEDC6483E864F-8022
Component: WWS57X 120319 H35 0080
Coding: 0045F7
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 T HW: 4G0 941 531 T
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 Q HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0060
Revision: 11001001 Serial number: 55901210101427
Coding: 082B07
ASAM Dataset: EV_EPHVA18AU57X0000 004005
ROD: EV_EPHVA18AU57X0000.rod
VCID: 408B2631DB06B93E3E-8014
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 3C04010202
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 285B9E915376617E16-807C
154624 - Door Contact Switch
C1076 29 [009] - Signal Implausible
Reset counter: 15
Mileage: 173763 km
Date: 2016.02.26
Time: 10:25:46
150016 - invalid data record
B2005 00 [009] - -
Reset counter: 15
Mileage: 173763 km
Date: 2016.02.26
Time: 10:25:46
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00887BT
Coding: 30323436313330303435554A304C34473053
VCID: 366740E989C2078E94-8062
Serial number: 3575HRB405718NQO30NR
Serial number: 3585HRB40691BBH298D
Serial number: 3515JRB404P18AICCHMW
Serial number: 3525JRB405D18E5ELGUV
Serial number: 3554VRB40024UFMUFHMW
Serial number: 3564VRB40024UFMUG8EH
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Revision: -------- Serial number: 90372LK700048
Coding: 0000FD
Shop #: WSC 02799 780 00200
VCID: 37794DED86C8FE868F-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 933 C HW: 4G8 920 933 C
Component: TDieRdwAccNv H58 0621
Revision: 29460233 Serial number: 658281013596008
Coding: 038E11004F010008080000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 306B76F16BA629BECE-8064
U1014 00 [009] - -
Reset counter: 15
Mileage: 173763 km
Date: 2016.02.26
Time: 10:25:46
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000492566
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001013
ROD: EV_GatewPkoUDS.rod
VCID: 70EBB6F1AB2669BE8E-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790874087
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018264747464545425363E
VCID: 336179FD92B012A6B3-8066
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 23041200040704
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 2F69758D76983646D7-807A
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008002
ROD: EV_AirSuspe_AU57.rod
VCID: 2E57688971923F4EDC-807A
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA4204NP6F0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA.rod
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011F16205000628002080002
VCID: 428F2C39DD0AAB2E28-8016
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0014765468
Coding: 101001010001
Shop #: WSC 37242 001 104857
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326F7CF965AA1BAEB8-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0175229198
Coding: 013A062020B9348083200904080104000000000000000000000000000000
Shop #: WSC 45343 001 1048576
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 418D2335D80CB03631-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000327681
ROD: EV_ParkiBrake_AU48.rod
VCID: 2A5F64994D7A536E00-807E
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 120424-0004-042
Coding: 11226F601002A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2C536281478E4D5EF2-8078
Part No SW: 4G0 035 056 J HW: 4G0 035 056
Component: Radio U STD H60 0133
Revision: AB001007 Serial number: 230DN0C2515562
Coding: 010003020100000001
VCID: 285B9E915B76617E16-807C
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 M HW: 4G0 035 670 H
Component: H-BNT-EU H49 0814
Revision: -------- Serial number: 190DU0C7501672
Coding: 050100010003F9FD2D348F3E00000003000001000100000002
VCID: 2D556F8574944456E5-8078
Subsystem 1 - Part No: 8R0 060 884 BT
Component: EUR 2014 1903
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204000628002080002
Shop #: WSC 22594 124 06010
VCID: 44832A21C71EA51E1A-8010
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 A HW: 4G9 959 107 A
Component: HDSG-Modul H03 0139
Revision: 14003001 Serial number: 106200229
Coding: 097205C010
ASAM Dataset: EV_HDSGAu572 001001
ROD: EV_HDSGAu571.rod
VCID: 34637AE19FBE159EAA-8060
Component: TSG HR H04 0212
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40004552
Coding: 1301
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 316D73F560AC20B6C1-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H07 0006
Serial number: 00000000001009814618
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: EA160000
Shop #: WSC 26483 001 104857
ROD: EV_OnBoardCamerDPC.rod
VCID: 264790A95962770E24-8072
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 3C04010202
ROD: EV_AdaptCruisContr2AU57X.rod
Reset counter: 15
Mileage: 173763 km
Date: 2016.02.26
Time: 10:25:46
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Serial number: 005000121102137
Coding: 04C0AB1A1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0148 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 15
Mileage: 173763 km
Date: 2016.02.26
Time: 10:25:47
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 05:54)--------------------------
