Cannot reset SRI - no label file
MKLTD
West Sussex, UK
C?ID=449206
Hi,
I cannot reset my SRI as an error appears:
Autoscan below...How do I fix the error please?
Sunday,26,April,2026,19:33:25:38498
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
VIN: WVWZZZ3DZC8000601   License Plate: XAN
Mileage: 50830km-31584mi   Repair Order:
Chassis Type: 3D-VW61 (6N0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 28 2E 34 36 37 38 42 46
          47 52 55 56 62 68 6C 71 72 76
VIN: WVWZZZ3DZC8000601   Mileage: 50830km-31584miles
38-Roof Electronics -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (CMV)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 HF    HW: 03H 907 309 B
   Component: D1-3.6-FSI-EU5  G   6905
   Revision: 5KH06---    Serial number: VWX3Z0K3938117
   Coding: 0000175
   Shop #: WSC 01065 000 00000
   VCID: 6D87C07321889842145-5160
   VINID: 9E69EAAAA0D4A9320000018004E79778B1
001072 - Catalyst System; Bank 2
               P0430 - 002 - Efficiency Below Threshold - Intermittent
                    Mileage: 50539 km
                    Date: 2026.04.25
                    Time: 09:08:52
                    RPM: 2056 /min
                    Load: 39.6 %
                    Speed: 102.0 km/h
                    Temperature: 86.0 C
                    Temperature: 7.0 C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
Address 02: Auto Trans        Labels: 09L-927-760.clb
   Part No SW: 09L 927 760 S    HW: GS1 911 4
   Component: AG6 09L 3,6 FSI RdW 3603
   Revision: --H05---    Serial number:        4619539
   Coding: 0000001
   VCID: 47CB52DB63B492124E9-5160
006231 - Load Signal
               P1857 - 001 - Error Message from ECU - Intermittent
                    Fault Status: 00100001
                    Mileage: 49888 km
                    Date: 2026.01.29
                    Time: 17:01:02
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H35 0047
   Coding: 0008366
   VCID: 6B83CE6B1F9C96720A1-51F2
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component:    Kessy            6850
   Revision: 00H24072    Serial number: VWX3Z0K3938117
   Coding: 0147688
   Shop #: WSC 13117 002 1048576
   VCID: 2A0D0B6FD0B64F7AB17-807E
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
                    Fault Frequency: 0
                    Reset counter: 72
                    Date: 2025.12.14
                    Time: 15:16:06
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
                    Fault Frequency: 0
                    Reset counter: 131
                    Date: 2026.04.02
                    Time: 15:52:22
00165 - Switch for Transmission Position P/N
                    Fault Status: 00101010
                    Fault Frequency: 14
                    Reset counter: 238
                    Date: 2026.04.04
                    Time: 11:37:32
00192 - Rear Left Door Handle Touch Sensor (G417)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 14
                    Reset counter: 199
                    Date: 2026.04.19
                    Time: 13:57:00
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1722
   Coding: 0000003
   VCID: 77ABE21B53842292FE9-8022
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0035
   Revision: ABH40001    Serial number: VWZ6Z7L0152029
   VCID: 6393A64BF71CDE32B21-8036
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 M
   Component: Climatronic D1      2039
   Coding: 0000001
   Shop #: WSC 00999 444 64523
   VCID: 2809F167CEBA7D6AA73-807C
00716 - Air recirculation Flap Positioning Motor (V113)
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 P    HW: 3D0 937 049 P
   Component: J519                7600
   Revision: -4006---    Serial number: --------------
   Coding: 618C0000EB2915825502770000000000
   VCID: 372B221B1304E2923E9-8062
   Part No: 3D0 909 601 F
   Component: 0S Airbag 8.4E+ H13 1155
   Coding: 0012371
   VCID: 2615FF5FC4FE6B1A95F-5160
Address 16: Steering wheel
Address 17: Instruments        Labels: Redir Fail!
   Part No SW: 3D0 920 886 B    HW: 3D0 920 886 B
   Component: J285 KOMBI-INST.    1521
   Revision: KPH06V05
   Coding: 0039101
   Shop #: WSC 30002 067 57207
   VCID: 2A0D0B6FD0F64F7AB17-807E
Address 19: CAN Gateway        Labels:. 6N0-909-901-3D.clb
   Part No SW: 6N0 909 901     HW: 3D0 920 886 B
   Component: J533  GW-K-CAN TP20 1521
   Coding: 7FF2F7BEE3011003
   VCID: 70B9D90736AA75AA3F3-8024
Address 28: HVAC, Rear        Labels: 3D0-919-158.lbl
   Part No: 3D0 919 158 M
   Component: Klima-Bedienteil D1 0124
   VCID: 35372813090810822C5-8060
   Revision: A1001003    Serial number: 7660057352
   Coding: 020000
   VCID: 290FF463D9F04462B8D-807C
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   VCID: 270BF25BC3A47212AE9-8072
01583 - Leak in System Detected
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 CA
   Component: Sitzmemory D1 F     1722
   Coding: 0000004
   VCID: 6FBBDA7B2BD46A52269-803A
01172 - Temperature Sensor; Driver's Heated Seat (G59)
01888 - Control Circuit for Blower for Seat Cushion
            009 - Open or Short to Ground
Address 37: Navigation (J0506)       Labels:. 3D0-035-680.clb
   Part No SW: 3D0 035 680 B    HW: 3D0 035 680 B
   Component: RNS-MID       H40 1224
   Revision: AB001001    Serial number: VWZ6Z7L0152029
   Coding: 060500020000002000
   VCID: 1F1BEABB97B4BAD2D69-804A
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 F
   Component: Dachmodul           0903
   Coding: 0012335
   VCID: 2615FF5FC4AE6B1A95F-8072
00218 - Humidity Sensor (G355)
Address 46: Central Conv.        Labels: 3D0-959-933.clb
   Part No: 3D0 959 933 P
   Component: 75 HSG              8135
   Coding: 0000040
   Shop #: WSC 30001 810 102864
   VCID: 3D2730333168C8C2E45-4B00
   Subsystem 1 - Part No: 3D2 959 701 L
   Component: Tuersteuergeraet FS 6003
   Subsystem 2 - Part No: 3D2 959 702 L
   Component: Tuersteuergeraet BF 6003
   Subsystem 3 - Part No: 3D0 959 703 K
   Component: Tuersteuergeraet HL 6003
   Subsystem 4 - Part No: 3D0 959 704 K
   Component: Tuersteuergeraet HR 6003
   Subsystem 5 - Part No: 3D0 909 610 F
   Component: 3P HDSG             2630
   Subsystem 6 - Part No: 7L0 907 719 A
8 Faults Found:
01816 - Exterior Door Handle Switch in Drivers Door (F272)
00124 - Communication Wire Door Control Module-closing Aid Driver Side
01817 - Exterior Door Handle Switch in Pass. Door (F273)
00487 - Rear Left Outside Door Handle Central Locking Button (E371)
00488 - Rear Right Outside Door Handle Central Locking Button (E372)
00896 - Trunk Lock Unit (F256)
   Part No SW: 3D0 035 466 B    HW: 3D0 035 466 B
   Component: R12___DSP 12 Kanal  0230
   Revision: DBH04001    Serial number: BP218719876299
   VCID: 211FEC43ADC08C22E0D-8074
Address 52: Door Elect, Pass.
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0100
   Revision: --------    Serial number: -------------- Dataset Number: 3D0036v____ 0003
   Coding: 012E00000B000200
   Shop #: WSC 01065 000 00024
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_VW61.rod
   VCID: 36352F1F18CE1B9A25F-8062
   Subsystem 1 - Part No: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 3D0 941 329 A  Labels: 3D0-941-329.CLB
Address 56: Radio (J0506)       Labels:. 3D0-035-680.clb
Address 62: Door, Rear Left
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
   Part No: 3D2 955 120 B
   Component: Front Wiper         3501
   Coding: 0015733
   Shop #: WSC 01065 000 376832
   VCID: 211FEC43AD808C22E0D-8074
   Part No SW: 3D0 907 441     HW: 3D0 907 441
   Component: J772__Rearview      0020
   Coding: 8388607
   VCID: 6099A947E64AC52AAF3-8034
00001 - Brake Control Unit
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 E
   Component: Batteriemanagement  2800
   VCID: 2517F853B9A860029C5-8070
Address 72: Door, Rear Right
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 E
   Component: 18 Einparkhilfe     1107
   VCID: 2C010D77DA42514A43B-8078
00435 - Front Right Inner Parking Aid Sensor (G333)
            006 - Short to Plus - Intermittent
00436 - Rear Left Inner Parking Aid Sensor (G334)
End----(Elapsed Time: 03:25, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
------------------------------24 Faults Found------------------------------
Well if the window instruction is accurate, here is the link to send a controller channel map of Instruments Address [17] :
note: you don't have to run channel maps of all the modules ; you can enter the number ,17 in this case, and run only that controller. Note "single controller address" at time 1:39 in link video.
Also note the channel map (bold blue font in the first sentence of this post above) as that is a link to the instruction manual.
Hmm.. A 2012 Phaeton; that's a rare bird.
An Adaptation Channel Map would almost certainly get us to the point where we could give you manual instructions.
As for SRI Automation @Sebastian -- It looks like there should be a 3D0-920-INS-V2 file...?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Correct, I found a severe discrepancy a while back and we have been waiting for user feedback on the matter.
So yes, maps are needed here - both MVB and ADP. That should be enough to have proper coverage (and semi-automated SRI) for this again.
golfi_vend
Tartu, Estonia
C?ID=195131
Rare, but not that rare I'd say, Atleast this side of pond. :)
MKLTD
West Sussex, UK
C?ID=449206
Thanks for the replies. I'll give the alligator a try and see how I get on and post results over the next few days.
You don't need the Alligator for this. It's hand for posting a whole slew of maps, like if you're mapping the entire car. But all that's really needed here is are the maps from your Instrument Cluster.
MKLTD
West Sussex, UK
C?ID=449206
I have just sent a channel 17 map to the support email address. Thanks.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
What we received was just the meas. value blocks. Please include the adaptation channel map as well. Thanks.
