Hello everyone, please I need your advice regarding fault code in address 13.
Any idea, what does that mean? What is the reason of fault? I noticed my Front Assist doesn´t work properly. Can be connection between this fault and FA? Thanks.Karel
Monday,22,February,2016,17:31:04:15380
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: TMBAH7NP9G704**** License Plate:
Mileage: 1346km-836mi Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55 5F
6C 6D A5
Address 01: Engine (J623-CRLB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 ES HW: 04L 907 309 R
Component: R4 2,0L EDC H22 1342
Revision: B5H22---
Coding: 01190012034401087000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_ECM20TDI01104L906026ES 002001
ROD: EV_ECM20TDI01104L906026AS.rod
VCID: 7F0969FAE6C168C608-802A
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 63455000000618
Coding: 1D076A9C34240B740780060141CA49B8562CD0E0608292F51463F0F8C0A2
Shop #: WSC 33361 790 00063
ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
VCID: 79FD87E2F8E546F636-802C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0389509664
Coding: 030C0C0603
ROD: EV_KessyHellaMQBAB_SK48.rod
VCID: 3A7F58EEBD638DEE7F-806E
Subsystem 2 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65048841
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 3V0 907 044 AT HW: 3V0 907 044 AT
Component: AC Automat H32 3701
Revision: 20K05000 Serial number: 00000B00048943
Coding: 11010104002400011005004100101002
ASAM Dataset: EV_ACClimaPrehVW37X 002012
ROD: EV_ACClimaPrehVW37X_SK48.rod
VCID: 0607FC1EB91B390E4B-8052
Slave 1:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061534502310
Coding: 0C010E76C2C722FB17A44086B11C172C0800000000000000000000000000
ROD: EV_BCMBOSCH_SK48.rod
VCID: 091DF722A805567626-805C
Slave 1:
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 151124 032 0121
Serial number: 00000001511200303326
Coding: 165DDD
Slave 2:
Component: RLHS 037 0059
Serial number: S3Y15M12D28H06M41S12
Coding: 0088DF
Serial number: 000000000ZY1530809V9
Serial number: 00000000000064482418
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391534606812
Coding: 0071157841
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 44832616CFA7CB1E15-8010
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Coding: 2A0060C251FFC428949C804D
Shop #: WSC 49103 001 1048576
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346376D69F077B9EA5-8060
0836 - Databus
Fault Frequency: 14
Reset counter: 68
Mileage: 1160 km
Date: 2016.02.18
Time: 15:18:44
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 15121541350049
ROD: EV_DRCONTITEMIC.rod
VCID: 377941DA8E71908680-8062
Part No SW: 5Q0 959 655 AK HW: 5Q0 959 655 AK
Component: AirbagVW21 005 0130
Serial number: 003Q5R1BRWFI
Coding: 98CCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X_SK48.rod
Subsystem 1 - Part No SW: ----------- HW: 480 000 212 15
Serial number: 35700000000DFB10F61Y
Subsystem 2 - Part No SW: ----------- HW: 480 000 112 15
Serial number: 358000000008B479E71Y
Subsystem 3 - Part No SW: ----------- HW: 480 400 412 15
Serial number: 3510002B71D73C63220Z
Subsystem 4 - Part No SW: ----------- HW: 480 400 412 15
Serial number: 3520002B31D73C61C11/
Subsystem 5 - Part No SW: ----------- HW: 480 402 711 15
Serial number: 3550002C51E34434B2C4
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 BD HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151220401156
Coding: 6400
ROD: EV_SMLSVALEOMQB.rod
VCID: 73E1B5CADA893CA67C-8026
Part No SW: 3V0 920 751 HW: 3V0 920 751
Component: KOMBI 313 6422
Coding: 07A501127F84000801886A0B5000000000000000
Shop #: WSC 73430 031 00063
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 71EDBFC2A0950EB68E-8024
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 18121510520366
Coding: 0B0100045F087300FB00025A880F00010001070000000000000000000000
ROD: EV_GatewConti.rod
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000D1869021215
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 8420258803
Inverter power receptacle:
Subsystem 4 - Part No SW: 5Q0 907 155 B HW: 5Q0 907 155 B
Component: WECHSELRICHTE H53 0033
Serial number: 0181440
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 15000160685009
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 A HW: 5Q0 959 760 A
Component: Sitzmemory H06 0009
Serial number: Y0006OL213563
Coding: 001000000000010001A080808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015
ROD: EV_SeatMemorDriveSide_SK37.rod
VCID: 3B715DEAB259B4E664-806E
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0388775773
Coding: 02011103
ROD: EV_HREntryHella_SK37.rod
VCID: 3C735EF6B757B3DE6D-8068
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 201015BJH17592
Coding: 001D0820DE00040000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 4381250ACAA9CC262C-8016
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000008345463
Coding: 110200
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000539204
Coding: 01000011005001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_SK48.rod
VCID: 3D7553F2AC4DBAD65A-8068
Component: TSG BFS 020 0041
Serial number: 171015BJG10518
Coding: 001D0220DE00040000001100
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 428F200ED5B3C52E27-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000008372801
Coding: 090200
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 06D202007F010000
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 408B2A06DBBFD73E31-8014
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0013
Coding: B30000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0013
Coding: B30000
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 A HW: 5Q0 035 874 A
Component: MU-S-ND-ER H24 0245
Serial number: SKZAZ2R8158065
Coding: 03840101000000001111120200880A002F0200E40120010086
ROD: EV_MUStd4CTSAT_SE25.rod
VCID: 326F70CE651375AEB7-8066
Media Player Position 1:
Subsystem 1 - Part No SW: 3V0 919 605 A HW: 3V0 919 605 A
Component: ABT_Std-2_Nav H44 1028
Serial number: SKZ8Z9RE600CRQ
Engine Control Module 2:
Subsystem 2 - Part No SW: 5L0 051 236 H HW: -----------
Component: ECE 2016 --- 0521
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 0484010182002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
VCID: 77F981DACEF1508640-8022
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30413378100000
Coding: 1008
ASAM Dataset: EV_DeckLidCONTIAU736 001012
ROD: EV_DeckLidCONTIAU736_SK48.rod
VCID: 3F8929FAA641A8C648-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 3Q0 980 654 D HW: 3Q0 980 654
Component: MQB_B_MFK H04 0024
Serial number: 06121511P21793
Coding: 0205080100000401002613468040A00090000E100040
ROD: EV_MFKBoschMQBB_SK48.rod
VCID: 387B42E6836F9FFE89-806C
End-------------------------(Elapsed Time: 05:26)--------------------------
