2016 Skoda Superb III 2.0 110kW - fault code in address 13
KarelM
CZ
C?ID=94707
Hello everyone, please I need your advice regarding fault code in address 13.
Any idea, what does that mean? What is the reason of fault? I noticed my Front Assist doesn´t work properly. Can be connection between this fault and FA? Thanks.Karel
Monday,22,February,2016,17:31:04:15380
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: TMBAH7NP9G704****   License Plate:
Mileage: 1346km-836mi   Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55 5F
          6C 6D A5
Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H22 1342
   Revision: B5H22---
   Coding: 01190012034401087000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002001
   ROD: EV_ECM20TDI01104L906026AS.rod
   VCID: 7F0969FAE6C168C608-802A
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63455000000618
   Coding: 1D076A9C34240B740780060141CA49B8562CD0E0608292F51463F0F8C0A2
   Shop #: WSC 33361 790 00063
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 79FD87E2F8E546F636-802C
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0389509664
   Coding: 030C0C0603
   ROD: EV_KessyHellaMQBAB_SK48.rod
   VCID: 3A7F58EEBD638DEE7F-806E
   Subsystem 2 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65048841
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 3V0 907 044 AT    HW: 3V0 907 044 AT
   Component: AC Automat    H32 3701
   Revision: 20K05000    Serial number: 00000B00048943
   Coding: 11010104002400011005004100101002
   ASAM Dataset: EV_ACClimaPrehVW37X 002012
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 0607FC1EB91B390E4B-8052
   Slave 1:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061534502310
   Coding: 0C010E76C2C722FB17A44086B11C172C0800000000000000000000000000
   ROD: EV_BCMBOSCH_SK48.rod
   VCID: 091DF722A805567626-805C
   Slave 1:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 151124  032 0121
   Serial number: 00000001511200303326
   Coding: 165DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S3Y15M12D28H06M41S12
   Coding: 0088DF
   Serial number: 000000000ZY1530809V9
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064482418
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391534606812
   Coding: 0071157841
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 44832616CFA7CB1E15-8010
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 2A0060C251FFC428949C804D
   Shop #: WSC 49103 001 1048576
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346376D69F077B9EA5-8060
0836 - Databus
                    Fault Frequency: 14
                    Reset counter: 68
                    Mileage: 1160 km
                    Date: 2016.02.18
                    Time: 15:18:44
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 15121541350049
   ROD: EV_DRCONTITEMIC.rod
   VCID: 377941DA8E71908680-8062
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R1BRWFI
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   Subsystem 1 - Part No SW: -----------    HW: 480 000 212 15
   Serial number: 35700000000DFB10F61Y
   Subsystem 2 - Part No SW: -----------    HW: 480 000 112 15
   Serial number: 358000000008B479E71Y
   Subsystem 3 - Part No SW: -----------    HW: 480 400 412 15
   Serial number: 3510002B71D73C63220Z
   Subsystem 4 - Part No SW: -----------    HW: 480 400 412 15
   Serial number: 3520002B31D73C61C11/
   Subsystem 5 - Part No SW: -----------    HW: 480 402 711 15
   Serial number: 3550002C51E34434B2C4
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 BD    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151220401156
   Coding: 6400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73E1B5CADA893CA67C-8026
   Part No SW: 3V0 920 751     HW: 3V0 920 751
   Component: KOMBI         313 6422
   Coding: 07A501127F84000801886A0B5000000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 71EDBFC2A0950EB68E-8024
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 18121510520366
   Coding: 0B0100045F087300FB00025A880F00010001070000000000000000000000
   ROD: EV_GatewConti.rod
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D1869021215
   Serial number: 8420258803
   Inverter power receptacle:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: WECHSELRICHTE  H53 0033
   Serial number: 0181440
   Serial number: 15000160685009
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OL213563
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B715DEAB259B4E664-806E
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0388775773
   Coding: 02011103
   ROD: EV_HREntryHella_SK37.rod
   VCID: 3C735EF6B757B3DE6D-8068
   Lane Change Assistant 2:
   Serial number: 201015BJH17592
   Coding: 001D0820DE00040000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 4381250ACAA9CC262C-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000008345463
   Coding: 110200
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000539204
   Coding: 01000011005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_SK48.rod
   VCID: 3D7553F2AC4DBAD65A-8068
   Serial number: 171015BJG10518
   Coding: 001D0220DE00040000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 428F200ED5B3C52E27-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000008372801
   Coding: 090200
   Coding: 06D202007F010000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 408B2A06DBBFD73E31-8014
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0013
   Coding: B30000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0013
   Coding: B30000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 A    HW: 5Q0 035 874 A
   Component: MU-S-ND-ER    H24 0245
   Serial number: SKZAZ2R8158065
   Coding: 03840101000000001111120200880A002F0200E40120010086
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: 326F70CE651375AEB7-8066
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3V0 919 605 A    HW: 3V0 919 605 A
   Component: ABT_Std-2_Nav  H44 1028
   Serial number: SKZ8Z9RE600CRQ
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5L0 051 236 H    HW: -----------
   Component: ECE 2016  --- 0521
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0484010182002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   VCID: 77F981DACEF1508640-8022
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30413378100000
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_SK48.rod
   VCID: 3F8929FAA641A8C648-806A
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 06121511P21793
   Coding: 0205080100000401002613468040A00090000E100040
   ROD: EV_MFKBoschMQBB_SK48.rod
   VCID: 387B42E6836F9FFE89-806C
End-------------------------(Elapsed Time: 05:26)--------------------------
Welder75
Canada
C?ID=261654
It kind of suck... but new car... take it to dealer and tell them the what is going on with the Front Assist. Let them figure it out.
Or you can clear the code since it's intermittent and see if it comes back.
With my little knowledge...Address 13: Auto Dist. Reg. Is the radar in the front of car that works with your ACC.(Adaptive Cruise control)
KarelM
CZ
C?ID=94707
Thanks, the radar works with Front Assist as well, it can be reason of problems with FA.
I cleared fault code in address 13, but in a few days appears again.
Welder75
Canada
C?ID=261654
you can check the connections, but could be a software gliche. Get dealer to look at it. explain problem, what car is doing. but leave out the part that u scanned it yourself. Don't want to mess around with assist options.
Gone But Not Forgotten
Run overlay as test to gateway for distance controller.further using new twisted pair that is adequately with shield.
