Originally posted this thread in the "retrofits" forum but got zero replies.
I've installed a ATOTO S8 aftermarket stereo. I currently don't have audio when using android auto. Stereo install instructions say to select AUX audio input in MMI sources. I don't have that option. From the green screen I disabled the AMI and AMI BT inputs and enabled the AUX. Still no AUX option from sources. I do have "AUX Video Input" in the MMI sources. I have selected this and it doesn't solve the audio problem.
I've gone through control module 5F Coding - Long Coding and don't see an option to turn on AUX input and turn off AMI input. There's several posts online showing VCDS screen grabs that show options that I don't see in my control module.
Can someone point me on the right direction?
Thank you - Christopher
2015 Audi Q5
2015 Audi Q5
Wednesday,08,April,2026,19:11:01:09471
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.4
VIN: WA1LFAFP8FA009189 License Plate: 2015 AUDI Q5
Mileage: 186690km-116003mi Repair Order: 8APR2026
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72
VIN: WA1LFAFP8FA009189 Mileage: 186690km-116003miles
Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-V2.clb
Part No SW: 8R1 907 115 L HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09--- CVN: E5EDE92F
Coding: 6A2A0013242600062000
Shop #: WSC 55278 001 1048576
ASAM Dataset: EV_ECM20TFS0118R1907115L 001006
ROD: EV_ECM20TFS0118R1907115L.rod
VCID: 3E2529EA70F5FA0AFDF-806A
VINID: 9D105C5915A021644000904824952A48D6
Readiness: 0010 0001
Part No SW: 8R0 927 158 AS HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H18 1001
Revision: --H18--- CVN: 980F6D01
VCID: 0E45B92A00D52A8A4DF-805A
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 151D1803
Shop #: WSC 06335 000 00000
VCID: 117FA256116B357250D-8044
Part No SW: 8K0 907 064 JP HW: 8K0 907 064 JP
Component: BCM2 2.0 H14 0650
Coding: 0D854040000000000000
VCID: 074B8C0E6F2F7BC28E9-8052
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000101037013
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 69
Mileage: 186684 km
Date: 2026.04.07
Time: 20:13:52
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01300520142332
Coding: 6481208000
VCID: 77ABFCCE1FCF0B42FE9-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000828253002
Coding: 26000091863CAFE00100488300003D0D0F9CC608A2090221000008004000030100000034000000
VCID: 78A9FFF212D1043AF73-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140522 H12 0050
Serial number: 90243014140516101620
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 22708145
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000002405140097
Component: USHL4.2 H30 0030
Serial number: 0000002274555R9HEY03
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: E2488F27000000000001
00910 - Indicator Lamp for Emergency Flashers (K6)
Fault Status: 00101100
Reset counter: 111
Mileage: 186684 km
Date: 2026.04.07
Time: 19:51:35
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED1230EU Dataset Number: 8R0909602F 0002
Coding: 303634313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC173223649589A63B-8018
Seat occupant detection:
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000L20J
Serial number: 6334MSME455E3414D
Serial number: 6344MSME453D583ET
Serial number: 6352QSME2C4214529
Serial number: 6362QSME013F3F4AT
Serial number: 63732SME4645067C0
Serial number: 63832SME46451264W
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NF6001AB
Coding: 000037
VCID: 48C94F3222B1B4BA473-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 N HW: 8R0 920 981 N
Component: KOMBIINSTR. H35 0564
Revision: 00200000 Serial number: ZD322G86F
Coding: 8BB622000301D705020000
VCID: 45D7460615A3A9D2BC5-8010
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z1452409E4
Coding: 80C303FF00
VCID: 4CC1732236C9589A63B-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 9991783403
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000103229619
Coding: 00581B00000000000000
VCID: 42DD5D1A048D9EEA997-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0335982255 Dataset Number: 8R0909535F 0021
Coding: 010211
Shop #: WSC 06334 000 00000
ROD: EV_LaneChangAssis_AU48.rod
VCID: 3FDB54EE77FFF302F69-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0336185698
Coding: 010211
730117 - Control Module 2 for Lane-Change Assist
C1115 F0 [00001001] - Automatic Calibration Not Possible
Reset counter: 69
Mileage: 186684 km
Date: 2026.04.07
Time: 18:37:18
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000104318116
Coding: 011D13205E00440004
VCID: 4FFB642EC7DF6382069-801A
Part No SW: 8R0 909 144 G HW: 8R0 909 144 B
Component: RCEPS H40 0508
Revision: 00001000 Serial number: 0013584583 Dataset Number: 8R0909852H 0021
Coding: 100000010000
ASAM Dataset: EV_RCEPSAU48X 008015
ROD: EV_RCEPSAU48X_008.rod
VCID: 3C2123E266E9E81AD3B-8068
Revision: 00002001 Serial number: 0337362971
Coding: 0126023A20FA709584B0053200040000
Component: GTO BF H01 0080
Serial number: 00000000000000844923
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813030410904
VCID: 2D071EA6AD137192545-8078
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Fault Status: 00101011
Reset counter: 111
Voltage: 12.20 V
Temperature: 28.0C
Temperature: 28.0C
Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Reset counter: 111
Voltage: 12.20 V
Temperature: 28.0C
Temperature: 28.0C
Bin. Bits: 00000100
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000104431905
VCID: 4EC5792AC0D56A8A0DF-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000220711
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D25FA6CDDD62AC17-806E
Revision: AB001007 Serial number: 156FT0E8016510
Coding: 020007010000000001
VCID: 2411FB82FED9B0DA8BB-8070
Part No SW: 8R1 035 746 F HW: 8R1 035 746 D
Component: H-BNT-NA H41 0812
Revision: -------- Serial number: 204FU0EB006407
Coding: 160200060005A1EF55028B5E00000403140000000000000000
VCID: 3A2D25FA6C5DD62AC17-806E
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Subsystem 2 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001878550
Subsystem 3 - Part No: 8R0 060 961 G
Component: CD-Database 5950
00658 - Control Head
Reset counter: 111
Mileage: 186684 km
Date: 2026.04.07
Time: 18:39:17
Voltage: 12.00 V
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 69
Mileage: 186684 km
Date: 2026.04.07
Time: 18:37:21
Voltage: 11.80 V
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000103618958
Coding: 010C13204000240004
VCID: 46D5410A28A5A2CAB5F-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J44A1KA
Coding: 1020010
VCID: 34310BC24239205A1BB-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H53 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D272EE67D73E112E45-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H53 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000104597973
End----(Elapsed Time: 02:04, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
------------------------------7 Faults Found-------------------------------
