Steering Angle Sensor (G85) Basic setings
senna1
C?ID=231631
Hi All
I have steering wheel logo ON in the dash display, The vehicle has had a electric power steering assembly fitted, and now this fault,
Here is Some information, below, i have looked at this link http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
which i think is correct for our vw caddy van. to do basic setting,, I dont have the PR codes, as this is a Van there is no spare wheel well as no boot,, and have never seen a Pr label
on any of the vw cadddy vans,, Would i be able to get the information from my vw dealer with vin number. The mk70 has soft coding, but nothing in the steering Assist.
Friday,26,February,2016,13:42:34:46146
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WV1ZZZ2KZ5X053067
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
Address 01: Engine        Labels: 03G-906-016-BDJ.clb
   Part No SW: 03G 906 016 GP    HW: 028 101 216 8
   Component: R4 2,0L EDC 0000SG  7001
   Revision: 12345678    Serial number: VWZ7Z0D1006870
   Coding: 0053031
   Shop #: WSC 35110 377 00162
   VCID: 77FDC7E60679068640-8022
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -
                    Torque: 120.0 Nm
                    Voltage: 12.16 V
                    Temperature: 12.6°C
                    Temperature: 10.8°C
                    Temperature: 11.7°C
   Part No: 2K0 907 379 A
   Coding: 0017106
   Shop #: WSC 35110 377 08192
   VCID: 316939FEA89D18B6CE-8064
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00H30000    Serial number: 00000001183502
   Coding: 00884F0200041000000000000000000000
   Shop #: WSC 00162 210 120669
   VCID: 3F8D6FC66EC9FEC648-806A
   Subsystem 1 - Part No: 1T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 260210 021  0512
   Coding: 00038805
   Shop #: WSC 00162
9 Faults Found:
01834 - Bulb for Side-Blinkers; Left (M18)
01495 - Bulb for High-Beams; Left (M30)
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 2Q AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR06WUV-
   Coding: 0012881
   Shop #: WSC 35110 377 00155
   VCID: 7DF1D5CE24452CD61A-8028
   Part No SW: 1K0 953 549 E    HW: 1K0 953 549 E
   Component: Lenksäulenmodul 021 0050
   Coding: 0000002
   VCID: 346730EA578F2D9EA5-8060
   Part No: 2K0 920 941 C
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0016403
   Shop #: WSC 00252 067 57207
   VCID: 2959D19E804D607606-807C
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104B2101AD
   Coding: 3D0F0140079001
   Shop #: WSC 35110 377 00158
                    Fault Frequency: 117
                    Reset counter: 14
                    Mileage: 339707 km
                    Time: 17:49:16
01304 - Radio
                    Reset counter: 14
                    Mileage: 339707 km
                    Time: 17:49:20
   Component: IMMO            VDD 0716
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   VCID: 76E3CAE201737F8E5B-8022
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.11      1502
02546 - Steering Limit Stop
                    Mileage: 9680 km
                    Temperature: 15.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 808A04087F2D84040858010010
   VCID: 7BF5DBD63A5122E624-802E
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75E1CDEE1C75749652-8020
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0040400
   Shop #: WSC 05311 000 00000
   VCID: 336533F652812AA6BC-8066
7 Faults Found:
00877 - Treble Speaker Rear Right (R16)
End-------------------------(Elapsed Time: 01:20)--------------------------
So have you done the G85 Basic Setting and Steering Limit Stop Adaptation shown on the page you linked to? Why do you think you need PR codes for this?
senna1
C?ID=231631
Got it criss crossed with another function ross tech youtube video,, will follow procedure for Basic settings g85 and steering limit stop, on monday see if it works.
and i assume the link for golf with mk70 is same procedure for Vw caddy Van. Thanks Uwe.
Yes, the Caddy van is essentially a Golf with an over-sized body.
You may want to check the values from the steering angle sensor for plausibility first, i.e. make sure they change as you turn the steering wheel and that they're within +/- 1.5° of zero with the wheel centered.
Jef
HQ
Since I had a phone call this week with a guy having issues doing a G85 relearn.... he was doing the first part wrong...
When you do the prerequisite test drive... do not scan the ABS module.... car in gear, let it roll forward... while rolling crank the steering wheel as fast as you can all the way to the left, then crank the steering wheel all the way to the right... straighten out the steering wheel so you are now rolling in a straight line... .come to a gentle stop and part car, leave engine running. Now you are ready to connect with VCDS and do your G85 relearn
It isn't a question of how fast you drive or how far you drive... just be rolling, lock to lock turn of the steering wheel, straight line stop.
The Caddy... my wife WANTS one of those after seeing them in NZ.
senna1
C?ID=231631
Ok Jeff, will try it,,
Gone But Not Forgotten
I actually have found that doing this in both directions forward and backward; with going lock to lock, further with ending in straight ahead position.
vu2gte
India
C?ID=262838
When I replaced the steering on an Octavia 2,I too got the yellow steering light on even though the steering assist worked fine. Followed the wiki procedure and the light vanished.
senna1
C?ID=231631
Hi All
I did the procedure today,including steering limit stop, drove the van low speed approx 5 mph, then steering lock to lock, then straight and stopped, connected Vcds and followed jeff's
initial instructions, The basic settings acivated on-off-next, showed correct field 1 "OK" But under mvb 007 no value carried on to steering limit stop instructions inc small drive cycle still no joy, left key cycle for 30 seconds, no joy, so just repeated it again including another drive cycle, while doing the drive cycles the warning light went off, and you could feel the difference in steering, NEW SCAN
Friday,04,March,2016,13:08:50:46146
Mileage: 339700km-211079mi   Repair Order:
VIN: WV1ZZZ2KZ5X053067   Mileage: 339700km-211079miles
   Coding: 0053031
            P1654 - 000 -
                    Torque: 122.0 Nm
                    Voltage: 11.55 V
                    Temperature: 8.1°C
                    Temperature: 6.3°C
                    Temperature: 6.3°C
   Coding: 0017106
   Coding: 00038805
   Shop #: WSC 00162
9 Faults Found:
   Coding: 0012881
   Coding: 0000002
   Coding: 0016403
                    Reset counter: 14
                    Mileage: 339707 km
                    Time: 17:49:16
01304 - Radio
                    Reset counter: 14
                    Mileage: 339707 km
                    Time: 17:49:20
   Coding: 0000000
   Coding: 0000000
   Coding: 0040400
7 Faults Found:
End-------------------------(Elapsed Time: 01:21)--------------------------
senna1
C?ID=231631
I would clear codes and fix that Open/Short to + code........
Hi Jeff, the van is still being built up need to connect the OAT sensor, one thing i see a lot on vw is 18062 - Please check DTC Memory of Instrument Cluster
yet the vehicle's runs fine and no lights on the dash or problems,
senna1
C?ID=231631
also could be oil level / temp sensor, answered my own question.:thumbs:
