DSG TO MANUAL trans+ Good pratice before modiying codes and adaptations ( rollback)+ HOW TO, Audi a3 2015
BenChamp
Canada
C?ID=629579
Hi, im new with this tool and i have have couple of questions.
1-i would like to know what are the good pratice to work safely and be able to rollback if anything goes wrong.
2- My objective is to coded and adapted different module to convert my audi a3 2015 2.0t from DSG to manual.
3- does anyone can confirm which modules need to be coded for this conversion?( i think ecu, abs bcm and gateway)+ dsg need to be removed from gateway
4- i need to disabled lane assist and hill hold,cause im facing malfunction indicator on the instrument cluster. any info here would be great
5-Im facing an GENERAL ELECTRONIC MALFUNCTION too on the instrument cluster. any info here would be great too
6-Any other tips will be really appreciated
thanks alot
Dr Sheldon
Windsor UK
C?ID=334979
First post an Autoscan - So we some clue how your car is built.
@DrPeter might want to chime in here because he's doing project like that on a similar vintage A3 (a TDI).
DrPeter
16.4905° S, 151.7375° W
This 'project' is a little different than what I am doing... your vehicle is a 2015 Audi A3 TDI and I have a 2012 A3 TDI. So I will not be able to provide you with step-by-step instructions, but I am sure you will be facing similar challenges... as I like to call them!
In life there are only challenges or opportunities. And project/conversion vehicles present both! ;)
1) - "what are the good pratice to work safely and be able to rollback if anything goes wrong"
Perform and save your Auto-Scan before you do any work! Get the Official Factory Repair Information!​
2) - Code and Adapt a "different module"?
You may or may not be able to change the "Coding" of the Engine controller for the manual transmission conversion. Not all controllers support different transmission configurations. With VCDS, you can try to re-code the Engine controller, if there is a Coding Helper? So as Dr Sheldon suggested, please post an Auto-Scan, maybe we can help.​
However, if you are intending on replacing the Engine controller, this will require an online connection to the manufacture via ODIS. So many conversions utilize the existing Engine controller and the talents of a tuner who can flash the Engine controller with manual transmission software. This is the most likely route I will be taking.​
3) "does anyone can confirm which modules need to be coded for this conversion?"
The Gateway controller, the ABS controller will need changes to reflect the manual transmission conversion. There maybe other controllers that need 'adjustments' which had a relationship with the Auto tans. This may or may not be as easy as it sounds and coding alone may or may not work. (please post an Auto-Scan)​
4) "disabled lane assist and hill hold"
I do not have Lane Assist, but I do have "[UG4] - Hill start assist + comfort driving assist", and I am also installing larger brakes, front and rear as the TDI brake discs are smaller and lighter, so I will be 'adjusting' my ABS coding accordingly.​
5) and 6) - scan and post, please.....
Hope this helps,
drpeter
We received the Auto-Scan via email and I asked the OP to post it here. At that point I think we should move this to Retrofits if he doesn't create a new thread.
The summary is; This is a Mk7 based NAR market 2015 A3 however the 01-Engine controller is from a 2008 MY 8P chassis A3 (022 906 032 KA like this example scan) and that 01-Engine controller is DSG specific.
In addition, there are a lot of communication issues in general because the older platform CAN protocol control module is not talking to the rest of the installed units in the car.
BenChamp
Canada
C?ID=629579
thanks alot
thanks alot
VIN: WAUJFRFF6F1026007   License Plate: 26-04-2026
Mileage: 133624km-83030mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WAUJFRFF6F1026007   Mileage: 133624km-83030miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
Address 01: Engine        Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 KA    HW: 022 906 032 GP
    Component: A3-3.2-DQ-LEV2  G   1099
    Revision: 1QH02---    Serial number: AUX7Z0G8FN50AR
    Coding: 0000178
    Shop #: WSC 06314 000 00000
    VCID: 54FA0D3492E3158A3BB-5184
    VINID: 9D195A5A25961960400860001CFA70F8BC
11 Faults Found:
005253 - Secondary Air Injection Valve 2 (N320)
                P1485 - 004 - Open Circuit - Intermittent
                     Fault Status: 00110100
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Absolute Pres.: 1020.0 mbar
                     Voltage: 13.462 V
009216 - EVAP Leak Detection Pump Control Circuit
                P2400 - 004 - Malfunction - Intermittent
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
005170 - Secondary Air Injection Solenoid Valve (N112)
                P1432 - 004 - Open Circuit - Intermittent
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
049409 - No Communication with Transmission Control Module
                U0101 - 008 -
                     Fault Status: 01101000
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Absolute Pres.: 1010.0 mbar
                     Voltage: 12.446 V
009267 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
                P2433 - 001 - Short to Plus
                     Fault Status: 01100001
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
049441 - No Communication with ABS Brake Control Module
                U0121 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
049412 - No Communication with Cruise Control Module
                U0104 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                U0155 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
049478 - Diagnostic Gateway
                U0146 - 008 - No Communications
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 10.0 C
                     Temperature: 15.0 C
                     Voltage: 12.446 V
Readiness: 0110 1101
Address 02: Auto Trans
    Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
    Component: ESC           H31 0471
    Revision: 00000000    Serial number: 61364000002113
    Coding: 13FF6A9234220A720177030081CA29C8562C5080C08194B4024100080608
    Shop #: WSC 06385 790 00016
    VCID: 45DC20706529BC02BC5-8010
8 Faults Found:
0128 - Function Restricted due to Insufficient Voltage
           U1400 00 [00001000] - -
           [undervoltage]
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2026.01.18
                     Time: 12:39:38
0129 - Function Restricted due to Excessive Voltage
           U1401 00 [00001000] - -
           [Overvoltage]
                     Reset counter: 6
0297 - Steering angle sensor
           B1168 16 [10001001] - Voltage Too Low
                     Reset counter: 222
                     Date: 2025.12.11
                     Time: 10:54:10
8264 - Databus
           [FCAN: Tsk_06 message is not received]
                     Reset counter: 222
                     Date: 2025.12.11
                     Time: 10:54:10
8314 - Check Coding of ECUs on Powertrain Data Bus
           P1647 00 [00001001] - -
           [FCAN: Coding of ESP and TSK does not fit together]
                     Fault Frequency: 89
                     Reset counter: 222
                     Date: 2025.12.11
                     Time: 10:54:10
8351 - Databus
           [FCAN: Motor_17_alt veraltet bit is set]
                     Reset counter: 222
                     Date: 2025.12.11
                     Time: 10:54:10
32995 - Clutch Position Sensor
           C10BF 01 [10001001] - Electrical Failure
           [IPB-Sensor: clutch sensor: electrical failure]
                     Reset counter: 222
                     Date: 2025.12.11
                     Time: 10:54:10
32997 - Clutch Position Sensor
           C10BF 15 [10001001] - Open or Short to Plus
           [IPB-Sensor: clutch sensor: short to KL30]
                     Reset counter: 222
                     Date: 2025.12.11
                     Time: 10:54:10
    Component: AC Automat    H13 0052
    Revision: 20026000    Serial number: 00000000333729
    Coding: 03000014010000000000000000001400
    VCID: 33386EA83BBD32B2021-8066
    Humidity sensor: exterior:
    Serial number: B5094D27000000000001
131076 - Function Restricted due to Insufficient Voltage
                     Reset counter: 7
                     Mileage: 133624 km
                     Date: 2026.01.18
                     Time: 12:39:33
                     Voltage terminal 30: 8.3 V
                     Outside temperature: -2.5  C
                     Engine speed: 0.00 /min
                     System run time-Terminal 15 on: 1 s
262914 - Refrigerant Pressure
           B10AB F0 [00001001] - Too Low
                     Fault Frequency: 20
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:54:19
                     Outside temperature: 15  C
                     Temperature downstream of evaporator: 16.8  C
                     Refrigerant pressure: 1.0 bar
    Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
    Component: BCM MQBAB MNA H18 0134
    Serial number: 01011413300540 Dataset Number: 8V0909514G  0079
    Coding: 04141A46C04122FD41C04004511007000000000000000000000000000000
    ROD: EV_BCMBOSCH_013_VW37.rod
    VCID: 79A49C80595108E288D-802C
    Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
Labels: 5QX-955-119-V1.CLB
    Component: WWS371 140509  042 0585
    Serial number:         140513155301
    Coding: 0A47F7
    Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
Labels: 8U0-955-559.CLB
    Serial number: 22641366
    Coding: 00006C
    Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
    Serial number: 18 02 2014  00000533
    Serial number: 00000000000059572339
    Sunroof control module:
    Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
    Component: J245 PS73.014  H02 0007
    Serial number:     WOO2943396A
    Coding: 101F00
           [Funktionseinschr nkung durch Unterspannung - unterer
Grenzwert unterschritten >]
                     Reset counter: 7
                     Terminal 15 status: On
                     Terminal 50 status: OFF
                     CAN-Bus_aktiv: On
                     OFF: operated
                     Position lamps: Not operated
                     Low beams: Not operated
                     Voltage: 6.6 V
204546 - Remote key 2
           B147A 18 [00001000] - Current Too Low
                     Reset counter: 7
                     Mileage: 133624 km
                     Date: 2026.01.02
                     Time: 14:26:16
                     Terminal 15 status: OFF
                     CAN-Bus_aktiv: On
                     Status Bremslichtschalter (CAN): On
                     OFF: operated
                     Voltage: 12.2 V
                     Outside temperature: 1.5  C
542485 - Databus
           [Motor_18 Datenbus fehlende Botschaft]
                     Fault Frequency: 8
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:54:34
                     CAN-Bus_aktiv: On
                     OFF: operated
                     Voltage: 11.2 V
                     Outside temperature: 15.0  C
15360768 - Component Protection
           U1101 00 [00001000] - Active
                     Reset counter: 7
                     CAN-Bus_aktiv: On
                     OFF: Not operated
                     Voltage: 13.7 V
    Serial number: 003GCR00D3B% Dataset Number: 8V0909602F  0002
    Coding: 9DCCFCC00000000050000000C04800000065
    VCID: 47C02A785F25AE124E9-8012
    Left seat belt tensioner:
    Serial number: 34178311A26051470675
    Coding: 333135
    Right seat belt tensioner:
    Serial number: 34178312A20051441256
    Coding: 333135
    Subsystem 3 - Part No SW: -----------    HW: 480 001 905 14
    Serial number: 35700000000AB5449F0U
    Subsystem 4 - Part No SW: -----------    HW: 480 001 905 14
    Serial number: 358000000001E5449F0P
    Subsystem 5 - Part No SW: -----------    HW: 480 402 105 14
    Serial number: 3510002A514D3E7223B0
    Subsystem 6 - Part No SW: -----------    HW: 480 401 305 14
    Serial number: 3520002A3157E9E1F27E
    Subsystem 7 - Part No SW: -----------    HW: 480 400 804 14
    Serial number: 3550002AF1524DC1B28D
    Subsystem 8 - Part No SW: -----------    HW: 480 400 804 14
    Serial number: 3560002C31524DC5C223
           [ATP Inconsistency]
                     Mileage: 133624 km
                     Date: 2026.01.18
                     Time: 12:54:23
13643776 - Local Databus
           U1030 00 [00001000] - Electrical Malfunction
           [PreCrash LIN electrical error]
                     Reset counter: 7
                     Mileage: 133624 km
                     Date: 2026.01.18
                     Time: 12:44:18
9634838 - Control Module for Front Left Belt Tensioner
           B1304 16 [00001000] - Voltage Too Low
                     Reset counter: 7
                     Mileage: 133624 km
                     Date: 2026.01.18
                     Time: 12:39:49
9635094 - Control Module for Front Right Belt Tensioner
           B1305 16 [00001000] - Voltage Too Low
                     Reset counter: 7
                     Mileage: 133624 km
                     Date: 2026.01.18
                     Time: 12:39:49
1050117 - Databus
           [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:54:43
    Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
    Revision: --------    Serial number: 23051408491115
    Coding: A018
    ROD: EV_SMLSKLOMQB_017.rod
    VCID: 7CAA859456633DCA93B-8028
617752 - Selector Lever Park Position Lock Switch
           B1162 29 [00001001] - Signal Implausible
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2026.01.25
                     Time: 18:55:34
                     Operating time: 254662 min
                     Terminal 30 power supply: 14.4 V
                     Vehicle speed: 11 km/h
                     Voltage at switch: 4.98 V
                     Terminal 15 status: active
                     System status: 30
    Part No SW: 8V0 920 871     HW: 8V0 920 871
    Component: KOMBI         H02 4291
    Coding: 0BB518092A8080080200E8001800000000000000
    Shop #: WSC 12345 123 61029
                     Reset counter: 7
16776983 - Databus
           [WBA_03 keine Kommunikation]
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:53:32
9456681 - Key
           B104C 29 [00001000] - Implausible Signal
12858149 - Databus
           U1122 00 [00001000] - Implausible Message
           [SMLS_01 unplausibles Signal]
                     Reset counter: 7
    Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
    Component: GW MQB High   212 2186
    Revision: --------    Serial number: 19051410801161 Dataset Number:
8V0909515E  0055
    Coding: 0101000820085A005B00020C180B00000001010000000000000000000000
    GVL: 01D03C0000000000400C10000000C80000000000000000000000000000000000
    ASAM Dataset: EV_GatewConti 011017
    ROD: EV_GatewConti_011_AU37.rod
    VCID: 42D63B6C74078B3A997-8016
    Generator:
    Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
    Serial number: 19 05 2014  C0493561
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
           U0100 00 [00001001] - -
           [Timeout Knoten 0x76 / 01 - Motorsteuerger t]
                     Fault Frequency: 66
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:53:40
                     Terminal 30 power supply: 11.2 V
                     Terminal 15: On
131703 - No Communication with Transmission Control Module
           U0101 00 [00001001] - -
           [Timeout Knoten 0x77 / 02 - Steuerger t f r Getriebe]
                     Fault Frequency: 66
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:53:40
                     Terminal 15: On
65793 - Powertrain Databus (VAG Single-Wire Mode) (SAE  L Shorted H)
           U0009 00 [00001000] - -
           [Eindrahtfehler CAN-Antrieb]
                     Fault Frequency: 30
                     Reset counter: 7
                     Mileage: 133624 km
                     Date: 2026.01.10
                     Time: 18:06:41
                     Terminal 30 power supply: 14.0 V
                     Terminal 15: On
66567 - Local Databus
           U1030 00 [00001001] - Electrical Malfunction
           [LIN#1 (LIN-Energie) elektrischer Fehler]
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:53:40
                     Terminal 15: On
    Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
    Component: Haldex4Motion H52 7076
    Serial number: HA1-00015.04.14 Dataset Number: v1260x015G0 0000
    Coding: 0001
    ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
    VCID: 46DE277C582FB71AB5F-8012
16652 - Databus
           [Getriebe - TO -- Get_11]
                     Fault Frequency: 108
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:54:54
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
    Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
    Serial number: 18051402091265 Dataset Number: 8V0909872E  0030
    Coding: 001C0F204000048000000002
    ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
    VCID: 3E2E4F9C00FFEFDAFDF-806A
    Component: EPS_MQB_ZFLS  123 1043
    Dataset Number: 8V0909852G  0018
    Coding: 0102
    ROD: EV_SteerAssisMQB_010.rod
    VCID: 41D434607101902280D-8014
12288 - Supply voltage
           U1011 00 [00001000] - Voltage too Low
           [Abschaltung wegen zu niedriger Versorgungsspannung
Abschaltung aufgrund von Unterspannung]
                     Motor status: 00
                     Supply voltage: 5.75 V
                     Temperature: -1.0  C
                     KFC: 30
                     KFA: 00 01
                     Freeze frame conditions: 20
                     uioUdNotFilt_xdu16: 5.31 V
                     uAdSensI_SwitchedKl30_xdu16: 5.31 V
                     ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
16135 - Steering Angle Sensor
           B1168 F2 [00001000] - Not Initialized
                     Motor status: 00
                     Supply voltage: 12.50 V
                     Temperature: 14.0  C
                     KFC: 3F
                     KFA: 00 07
                     Freeze frame conditions: 21
                     uioUdNotFilt_xdu16: 12.44 V
                     uAdSensI_SwitchedKl30_xdu16: 12.44 V
    Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
    Serial number: 07051401100585 Dataset Number: 8V0909873E  0029
    Coding: 001C07204000048000000002
    ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
    VCID: 3D2C48900DF9F4C2E45-8068
65604 - Door Warning Lamp
           B1326 01 [00001001] - Electrical Failure
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2026.01.04
                     Time: 16:49:59
    Revision: --------    Serial number: -------------- Dataset Number:
8V0909865J  0037
    Coding: 012A000101000000
    ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
    VCID: 75BC90B075496C82EC5-8020
    Part No SW: 8V0 035 047 E    HW: 8V0 035 047
    Component: MU-H-NS-US    H42 0289
    Serial number: A052E0E7507671 Dataset Number: 8V2909545E  0040
    Coding: 01730102FF0A000021220001041A00002F000104010001047E
    ROD: EV_MUHig6C3HBAS_AU37.rod
    VCID: 363E57BC28CF279A25F-8062
    Subsystem 1 - Part No SW: V03 959 800 SE    HW: -----------
    Component: NAR 2014  --- 0024
    Multimedia display unit 1:
    Component: DU High  H49 0013
    Serial number: AUZ8Z9EY2010UH
    Subsystem 3 - Part No SW: 8V0 919 614 R    HW: 8V0 919 614 D
    Component: ControlUnit_H  H64 0766
    Serial number: C1000018021400040023
    Compact disc data bank:
    Component: Gracenote  --- 3005
                     Reset counter: 222
                     Mileage: 133624 km
                     Date: 2025.12.11
                     Time: 10:55:20
                     Voltage terminal 30: 11.3 V
                     Satellite radio tuner status-Satellite radio
antenna status: electrically OK
                     Satellite radio tuner status-Channel selection for
satellite radio: 0
                     Satellite radio tuner status-Audio Signal: Not
available
                     Satellite radio tuner status-Reception quality:
No_signal
                     Satellite radio tuner status-SDARS Flash Regional
code: US_Audio_Traffic_Travellink
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V1.clb
    Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
    Component: TSG HFS       020 0025
    Serial number: 15051404081247 Dataset Number: 8V0909897C  0017
    Coding: 000C07204000048000000002
    ROD: EV_DCURearDriveMAXCONT_VW37.rod
    VCID: 40D231647A0B992A8F3-8014
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V1.clb
    Component: TSG HBFS      020 0025
    Serial number: 15051404081245 Dataset Number: 8V0909896C  0017
    ROD: EV_DCURearPasseMAXCONT_VW37.rod
End----(Elapsed Time: 01:38, VBatt start/end: 12.2V/12.0V. VIgn 11.9V)-----
------------------------------44 Faults Found------------------------------
Control Module Part Number: 022 906 032 KA    HW: 022 906 032 GP
   Component and/or Version: A3-3.2-DQ-LEV2  G   1099
            Software Coding: 0000178
             Work Shop Code: WSC 06314 000 00000
11 Faults Found:
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
                U0101 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                U0121 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                U0104 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                U0155 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 10.0 C
                     Temperature: 15.0 C
                     Voltage: 12.446 V
11 Faults Found:
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
                     RPM: 1754 /min
                     Load: 15.7 %
                     Temperature: 96.0 C
                     Temperature: 75.0 C
                     Voltage: 13.462 V
                U0101 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                U0121 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                U0104 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                U0155 - 008 -
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 9.0 C
                     Temperature: 14.0 C
                     Voltage: 12.446 V
                     Temperature: 10.0 C
                     Temperature: 15.0 C
                     Voltage: 12.446 V
