2015 Caddy 1.6TDI 55KW problem with neutral sensor/press clutch
Vdub
C?ID=57533
Flashed ECU stock with latest softwareversion
Tried with ODIS restore coding of ECU (failed)
ODIS restore coding of 09 succes
Cluster still displays clutch
Car doesnt have button for stop/start, afaics no neutral position switch on gearbox.
Car starts/drives fine.
Friday,17,April,2026,16:38:34:16149
VCDS Version: 26.4.0.5 (x64)  HEX-NET CB: 0.4713.4
Data version: 20260410 DS376.0
Dealer/Shop Name: VAG Performance Center
Workshop Code: 221 99230 000001
VIN: WV1ZZZ2KZGX028142   License Plate: CADDY
Mileage: 138640km-86146mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZGX028142   Mileage: 138640km-86146miles
Address 01: Engine (J623-CAYE)       Labels:. 03L-907-425-V1.clb
   Part No SW: 03L 906 023 TD    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9980
   Revision: --H43---    Serial number: 00000000000000 CVN: 9A7ACB95
   Coding: 00114014030401080000
   Shop #: WSC 03410 010 04400
   ASAM Dataset: EV_ECM16TDI02103L906023TD 003004
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 7BB600B6F2DA754653-802E
   VINID: 9E606AAAA09BA97A0008804408B8F5C0E3
10453 - Output for Starter Relay
          P0615 00 [00100111] - Open Circuit
                    Mileage: 138649 km
                    Date: 2026.04.17.
                    Time: 00:28:59
                    Engine speed: 782.75 /min
                    Normed load value: 31.4 %
                    Coolant temperature: 51 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.005 V
                    Engine speed: 783 /min
                    Battery voltage: 14.0 V
                    Starter activation: status-FRF_ST_RL: 1
                    Sensor for engine block temperature: raw value-Coolant temperature: 51 °C
                    Number of resets of main unit-CTR_RST_MC: 0
10457 - Control Circuit for Starter Relay 2
          P3049 00 [00100111] - Open Circuit
                    Mileage: 138649 km
                    Date: 2026.04.17.
                    Time: 00:28:59
10446 - Neutral Gear Sensor
          P15A0 00 [00100111] - Electrical Malfunction
                    Mileage: 138649 km
                    Date: 2026.04.17.
                    Time: 00:28:59
                    Engine speed: 783.50 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 18.221 °
                    Neutral position sensor: adapted transmission angle-ANG_NEUT_GEAR_AD_NEUT: -0.516 °
                    Engaged gear: calculated-DRI_MT_BAS: 0
                    Clutch Position Sensor-Starter control: clutch switch: 00000000
                    Starter control: clutch switch-Starter control: interlock switch: 00000000
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 42145000000017
   Coding: 1079409B9364A0860876027AC98405E3280000
   Shop #: WSC 35110 790 50316
   VCID: 3FCEB4A6A642A9663F-806A
8319 - Databus
          U1122 00 [10001001] - Implausible Message
          [ACAN: mMotor_10 Start_Stop coding missmatch]
                    Reset counter: 69
                    Mileage: 138649 km
                    Date: 2026.04.17.
                    Time: 00:30:08
   Part No SW: 1K8 907 426 AB    HW: 1K8 907 426 AB
   Component: AC Manuell    H20 0808
   Revision: 00001002
   Coding: 0010004002
   VCID: 73A62896DA8A3D060B-8026
   Part No SW: 5K0 937 085 AD    HW: 5K0 937 085 AD
   Component: BCM PQ35 B+   122 0183
   Revision: BB122001
   Coding: 611A583A8025086D088000829000006403010008524F8160648000000040
   Shop #: WSC 35110 377 08192
   VCID: 75A2168EDCFE233625-8020
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 21071  27  0512
   Coding: 009795
   Part No SW: 2K5 959 655     HW: 2K5 959 655
   Component: VW10Airbag00H 008 0016
   Revision: --------    Serial number: 003QV000E17$ Dataset Number: 2KC003V__A_ 0595
   Coding: 000000000000000000000000000000003048
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 79BA1ABEF8E6475641-802C
   Serial number: 3497ARB405L3EENCIHC%
   Serial number: 3507ARB405T3EENCS19X
   Part No SW: 5K0 953 521 FT    HW: 5K0 953 569 BE
   Revision: FF010042    Serial number: 20150717100979
   Coding: 5080060000
   ROD: EV_SMLSNGVOLWSR8C_VW32.rod
   VCID: 034678568A2A0D861B-8056
   Part No SW: 2K5 920 866 A    HW: 2K5 920 866 A
   Component: KOMBI         H04 1009
   Coding: 180A000400
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 3228ED926510740EC0-8066
   Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1663
   Revision:   H57       Serial number: 040815F1001177
   Coding: 357400
   VCID: 02487D529D30048E10-8056
   Component: IMMO          H04 1009
   VCID: 6A9835F28D40FCCEB8-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2143
   Coding: 0001072
   VCID: 71AA229E68960F16F9-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 309    3501
   Revision: 00H22000
   VCID: 393ADABE7066875601-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0001072
   VCID: 72A82D926D90340E00-8026
   Part No SW: 7F0 035 153     HW: 7F0 035 153
   Component: Radio         012 0046
   Revision: --------    Serial number: VWZGZ1R3008093
   Coding: 00000220000000
   VCID: 5EF069224908806E54-800A
End----------(Elapsed Time: 00:47, VBatt start/end: 14.2V/14.2V)-----------
------------------------------4 Faults Found-------------------------------
Does it have start/stop? I'm thinking it doesn't because I see no BMS anywhere in that scan. So you might try clearing Coding Byte 6, Bit 0.
Vdub
C?ID=57533
No it doesnt have st/st, Byte6 bit 0 in in which module?
Vdub
C?ID=57533
Unfortunatly it says coding rejected.
BUT i fixed the problem, 09 > Coding Byte 20, bit 4 unchecked.
It now only says error start-stop a few times but the Clutch is gone from the display.
Vdub
C?ID=57533
Is there a security-code or so to get the byte6 - bit0 to work/save?
NEtech
Denmark
C?ID=56995
I doubt it very much.
I have just tested 5 different SA, all accepted, not possible to change that Bit.
Need correct part number I guess.
All with PR-7L6 (for 2K):
03L 906 023 FL,EV_ECM16TDI02103L906023FL 003002,00114010032401080000
03L 906 023 FJ,EV_ECM16TDI02103L906023FJ 003012,00114010032401080000
03L 906 023 FJ,EV_ECM16TDI02103L906023FJ 003004,00114014032401080000
03L 906 023 FL,EV_ECM16TDI02103L906023FL 003004,00114034032501080000
03L 906 023 PB,EV_ECM16TDI02103L906023PB 003003,00114010032401080000
03L 906 023 PD,EV_ECM16TDI02103L906023PD 003010,00114010032501080000
03L 906 023 TD,EV_ECM16TDI02103L906023TD 003003,00114014032401080000
03L 906 023 TD,EV_ECM16TDI02103L906023TD 003003,00114010032501080000
03L 906 023 PB,EV_ECM16TDI02103L906023PB 003003,00114010032501080000
03L 906 023 PK,EV_ECM16TDI02103L906023PK 003008,00254014032401080000
03L 906 023 TH,EV_ECM16TDI02103L906023TH 003003,00114034032401080000
03L 906 023 PB,EV_ECM16TDI02103L906023PB 003006,00114014032401080000
03L 906 023 PD,EV_ECM16TDI02103L906023PD 003006,00114034032401080000
03L 906 023 TD,EV_ECM16TDI02103L906023TD 003003,00114010032401080000
03L 906 023 TH,EV_ECM16TDI02103L906023TH 003002,00114010032401080000
03L 906 023 PB,EV_ECM16TDI02103L906023PB 003007,00114010032401080000
03L 906 023 TL,EV_ECM16TDI02103L906023TL 003001,00254014032401080000
03L 906 023 RE,EV_ECM16TDI02103L906023RE 003002,00114034032501080000
03L 906 023 TL,EV_ECM16TDI02103L906023TL 003001,00254014032501080000
03L 906 023 TD,EV_ECM16TDI02103L906023TD 003003,00114034032401080000
03L 906 023 PD,EV_ECM16TDI02103L906023PD 003009,00114034032401080000
03L 906 023 PD,EV_ECM16TDI02103L906023PD 003009,00114034032501080000
03L 906 023 DQ,EV_ECM16TDI02103L906023DQ 003009,00114016032401080000
03L 906 023 PD,EV_ECM16TDI02103L906023PD 003010,00114034032401080000
03L 906 023 SH,EV_ECM16TDI02103L906023SH 003001,00114014032401080000
03L 906 023 FL,EV_ECM16TDI02103L906023FL 003008,00114034032401080000
03L 906 023 FJ,EV_ECM16TDI02103L906023FJ 003009,00114014032401080000
03L 906 023 PD,EV_ECM16TDI02103L906023PD 003008,00114036032401080000
03L 906 023 PB,EV_ECM16TDI02103L906023PB 003009,00114014032401080000
03L 906 023 TH,EV_ECM16TDI02103L906023TH 003002,00114036032401080000
All with PR-7L0 (for 2K):
03L 906 023 FK,EV_ECM16TDI02103L906023FK 003012,00254014030400080000
03L 906 023 FK,EV_ECM16TDI02103L906023FK 003003,00254014030500080000
03L 906 023 DB,EV_ECM16TDI02103L906023DB 003011,00114014032500080000
03L 906 023 DB,EV_ECM16TDI02103L906023DB 003002,00114014030500080000
03L 906 023 DB,EV_ECM16TDI02103L906023DB 003008,00114010030500080000
03L 906 023 DB,EV_ECM16TDI02103L906023DB 003004,00114014032500080000
03L 906 023 CT,EV_ECM16TDI02103L906023CT 003004,00114014032400080000
03L 906 023 FK,EV_ECM16TDI02103L906023FK 003005,00254014032500080000
03L 906 023 DB,EV_ECM16TDI02103L906023DB 003004,00114010030500080000
03L 906 023 PE,EV_ECM16TDI02103L906023PE 003002,00254014030400080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003002,00114010030500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003002,00114014030500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003004,00114014030500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003009,00114010030500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003002,00114010032500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003002,00114014030400080000
03L 906 023 PA,EV_ECM16TDI02103L906023PA 003005,00114010030400080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003002,00114014032500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003002,00114014032500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003003,00114010032500080000
03L 906 023 PE,EV_ECM16TDI02103L906023PE 003002,00254014032400080000
03L 906 023 PA,EV_ECM16TDI02103L906023PA 003002,00114010030400080000
03L 906 023 TB,EV_ECM16TDI02103L906023TB 003003,00114014030500080000
03L 906 023 PA,EV_ECM16TDI02103L906023PA 003002,00114010030500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003003,00114014030500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003002,00114014032400080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003006,00114010030500080000
03L 906 023 PE,EV_ECM16TDI02103L906023PE 003008,00254010030500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003007,00114014032500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003002,00114010032400080000
03L 906 023 TK,EV_ECM16TDI02103L906023TK 003002,00254014030500080000
03L 906 023 TB,EV_ECM16TDI02103L906023TB 003003,00114010032500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003008,00114014032500080000
03L 906 023 PA,EV_ECM16TDI02103L906023PA 003008,00114016032500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003002,00114010030500080000
03L 906 023 TK,EV_ECM16TDI02103L906023TK 003001,00254014032500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003003,00114014032500080000
03L 906 023 TB,EV_ECM16TDI02103L906023TB 003003,00114010030500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003004,00114014032500080000
03L 906 023 SE,EV_ECM16TDI02103L906023SE 003001,00114010030500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003009,00114014030400080000
03L 906 023 PA,EV_ECM16TDI02103L906023PA 003009,00114014030400080000
03L 906 023 TB,EV_ECM16TDI02103L906023TB 003003,00114014032400080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003009,00114014032500080000
03L 906 023 SE,EV_ECM16TDI02103L906023SE 003001,00114014032400080000
03L 906 023 DB,EV_ECM16TDI02103L906023DB 003002,00114014030400080000
03L 906 023 FK,EV_ECM16TDI02103L906023FK 003013,00254016032400080000
03L 906 023 FK,EV_ECM16TDI02103L906023FK 003005,00254014032400080000
03L 906 023 DB,EV_ECM16TDI02103L906023DB 003008,00114014032500080000
03L 906 023 CT,EV_ECM16TDI02103L906023CT 003004,00114014030400080000
03L 906 023 FK,EV_ECM16TDI02103L906023FK 003012,00254014030500080000
03L 906 023 TK,EV_ECM16TDI02103L906023TK 003001,00254014030400080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003002,00114014030400080000
03L 906 023 PE,EV_ECM16TDI02103L906023PE 003002,00254016030400080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003002,00114016032400080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003002,00114016032400080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003005,00114014030400080000
03L 906 023 TB,EV_ECM16TDI02103L906023TB 003003,00114014030400080000
03L 906 023 PE,EV_ECM16TDI02103L906023PE 003009,00254014032400080000
03L 906 023 TK,EV_ECM16TDI02103L906023TK 003001,00254014030500080000
03L 906 023 TF,EV_ECM16TDI02103L906023TF 003002,00114014030500080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003006,00114014030500080000
03L 906 023 TK,EV_ECM16TDI02103L906023TK 003001,00254016032400080000
03L 906 023 PC,EV_ECM16TDI02103L906023PC 003009,00114016032400080000
03L 906 023 PE,EV_ECM16TDI02103L906023PE 003010,00254014030500080000
