Audi SQ5 Exhaust Temperature Sensor 2 issues
aka4ajax
Havant, Hampshire, UK
C?ID=570531
Hi,
I have a constant 220 degrees C and O Volts signal on Exhaust Temperature Sensor 2
Can anyone help me here, where is the sensor, is it most likely an open circuit or do these often break?
The full Scan from today:
Monday,20,April,2026,13:20:24:27500
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VIN:    License Plate: AF15OKE
Mileage: 1200176   Repair Order:
                Address 01: Engine  (8K5 907 589 D)
13:20:04
  IDE02229   Exhaust gas temperature sensor 1 115.9 °C
  IDE02233   Exhaust gas temperature sensor 2 222.0 °C
  IDE02234   Exhaust gas temperature sensor 3 67.8 °C
  IDE02236   Exhaust gas temperature sensor 4 40.2 °C
  IDE03270   Exh.gas temp.sen 1: unconditioned voltage 1114.6 mV
  IDE03271   Exh.gas temp.sen 2: unconditioned voltage 0.0 mV
  IDE03273   Exh.gas temp.sen 3: unconditioned voltage 1004.6 mV
  IDE05387   Exhaust gas model temperature 1 86.6 °C
  IDE05388   Exhaust gas model temperature 2 93.3 °C
  IDE05389   Exhaust gas model temperature 3 -20.0 °C
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 1B 36 42 44 46 47 52 53 56 5F
          62 69 6C 6D 72 A9 C0
VIN: WAUZZZ8R5FA094218   Mileage: 193400km-120173miles
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589 D    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0003
   Revision: 57H25---    CVN: B4A0953E
   Coding: 2A2A4032252603020000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589D 001004
   ROD: EV_ECM30BTD0118K5907589D.rod
   VCID: 42DD5ABA040967DAD8F-8016
   VINID: 9D196AAAA222156440244081200D86E47E
   Part No SW: 8R0 997 749     HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1001
   Revision: --H19---    CVN: 96AB74E0
   VCID: 074B8BAE6FAB82F2CF1-8052
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
   Component: ESP8 quattro  H09 0020
   Coding: 24EDCC01
   VCID: 0E45BE8A0051D3BA0C7-805A
02214 - Tire Pressure Warning
                    Reset counter: 111
                    Mileage: 193314 km
                    Date: 2026.04.13
                    Time: 10:37:28
                    Hex Value: 0x4100
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x19B6
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05B54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 005990B24A05B5CA8EB-8054
   Serial number: 3214000140274009
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 68
                    Mileage: 193302 km
                    Date: 2026.04.06
                    Time: 10:17:07
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01200120150398
   Coding: 3625028080
   VCID: 78A9F85212D5FD0AB6B-802C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000983699102
   Coding: 260000108034AFF0118140C300001D0D0F9DE70827090201000008004400030100000034000000
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 141210  H12 0050
   Serial number: 90243015141126234422
   Coding: 01DD13
   Serial number: 20066971
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001401151080
   Serial number: B4C80B87000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 108
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 17:47:23
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 108
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 17:47:23
                    Fault Status: 00101010
                    Reset counter: 108
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 17:49:08
                    Reset counter: 108
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 17:49:08
02069 - Front Parking Aid Sensors
                    Fault Status: 00101011
                    Reset counter: 108
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 17:56:06
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003JPDC2A1CB   Dataset Number: 8R0909602H  0001
   Coding: 30473531313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C9489222354D8A06B-801C
   Serial number: 6334MSME4C5C4021D
   Serial number: 6344MSME4C391057F
   Serial number: 6352QSME1B4C575E-
   Serial number: 6362QSME504E2868P
   Serial number: 63732SME3E4C0F4EM
   Serial number: 63832SME3E4C0B405
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372OAC000HA
   Coding: 000037
   VCID: 44D15CA21E9D69EAEA3-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 T    HW: 8R0 920 950 T
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 03F42CC1G
   Coding: 33A7220023012600010102
   Shop #: WSC 06335 123 12345
   VCID: 47CB4BAE2FAB42F20F1-8012
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y15108079B
   Coding: 80CD07FF00
   VCID: 4ACD729A3CB9BF9A10F-801E
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 7309705503
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 15009005034021200410
                    Reset counter: 107
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 17:47:22
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 6
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 0C0100
   VCID: 392F3D56695F2402895-806C
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000131286552
   Coding: 01781B00000000000000
   VCID: 42DD5ABA048967DAD8F-8016
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000131823576
   Coding: 011D12215E01440004
   VCID: 4FFB638EC7DB9AB2471-801A
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0019002300 Dataset Number: 8R0909852H  0021
   Coding: 010000010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3FDB534E77FB0A32B71-806A
2306 - Function Restriction due to Start Voltage Interruption
          U1410 00 [00001000] - -
          [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei hoher Geschwindigkeit]
                    Reset counter: 112
                    Mileage: 193327 km
                    Date: 2026.04.17
                    Time: 11:55:16
                    2048.00 /min
   Revision: 00002001    Serial number: 0357558359
   Coding: 013B0E22A0B9308187200536A0040047
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 72
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 18:02:18
02615 - Fuel Tank Cap; Lock
                    Reset counter: 72
                    Mileage: 193308 km
                    Date: 2026.04.06
                    Time: 13:26:11
   Revision: 00005001    Serial number: 94813039194606
   VCID: 2D071906AD1788A215D-8078
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Fault Frequency: 24
                    Reset counter: 114
                    Voltage: 12.50 V
                    Temperature: 5.0°C
                    Temperature: 7.0°C
                    Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Fault Frequency: 24
                    Reset counter: 114
                    Voltage: 12.50 V
                    Temperature: 5.0°C
                    Temperature: 7.0°C
                    Bin. Bits: 00000100
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000132452362
   VCID: 4EC57E8AC0D193BA4C7-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000483361
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D225A6CD92F1A80F-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109AN0F8001291
   Coding: 010103010000000001
   VCID: 2B03171E930386920B9-807E
   Part No SW: 8R2 035 666 H    HW: 8R2 035 666 H
   Component: H-BN-EU       H48 0897
   Revision: --------    Serial number: 515AU0F7507350
   Coding: 1A0101060205A1EF45808B5E00000403E40000020000000000
   VCID: 3E252E4A7071033ABC7-806A
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130AH0F3232443
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002102078
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000132687334
   Coding: 010C12204001240004
   VCID: 46D546AA28A15BFAF47-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: ConWys Trailer H09 0100
   Revision: 1G001001    Serial number: 00000173782896
   Coding: 0100000000000000
   Shop #: WSC 00375 223 87350
   VCID: 353731664547C0626DD-8060
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J4XA5IP
   Coding: 1021010
   VCID: 34310C62423DD96A5A3-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D2729467D771822A5D-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000132697519
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 141125201695
   VCID: 79AFFD56295FE402C95-802C
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 141122200794
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS_VW37.rod
   VCID: 71BFC576712FAC42715-8024
0006 - Actuator 1 for Engine Noise Simulation
          C113C 13 [00001001] - Open Circuit
                    Fault Frequency: 118
                    Reset counter: 74
                    Mileage: 193302 km
                    Date: 2026.04.05
                    Time: 17:49:04
End----------(Elapsed Time: 02:05, VBatt start/end: 14.5V/14.7V)-----------
------------------------------14 Faults Found------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
The fact that there is no DTC for that sensor (with those implausible values) possibly indicates that it is not fitted to your engine and you are looking at substituted values !
  • Agree
aka4ajax
C?ID=570531
No that makes sense, as its not throwing any codes related to the EGR or Particle filter.
Dr Sheldon
Windsor UK
C?ID=334979
Unlikely an EGT would, in the first instance, throw an EGR or DPF DTC. These cars are very good at looking at the EGT's and throwing accurate DTC's
Looking at the data from your car:
IDE03271 Exh.gas temp.sen 2: unconditioned voltage 0.0 mV - This would be flagged up !!
IDE05389 Exhaust gas model temperature 3 -20.0 °C - This looks wrong ? !! However No DTC so take it as a red herring for now.
Vdub
C?ID=57533
its common that a VW/Audi had EGT-sensor mentioned number 4, but only 3 times fitted in the car, then for example, only 1,3 and 4 are fitted, sometimes reading -40deg for (missing)sensor 2
You car has 3 according to Partslink,
1 in the turbocharger
1 before DPF (brown connector)
1 after DPF (black connector)
For a month or 2 ago i had an SQ5 in, there was the last EGT sensor after DPF broken, probably something underneath the car hitted the end of the sensor/begin cable
aka4ajax
C?ID=570531
Thanks.
I had a look and yes my car has never had that sensor.
Dr Sheldon
Windsor UK
C?ID=334979
Thanks.
Yep !! We have been there many times.
Happy to help !
