Model: Audi e-tron 50 quattro
VIN: WAUZZZGE5LB039739
Built: 18-08-2020
Headlights code: 8IY
Hi,
My apologies for the long post, but I don't want to omit information.
I've got a lighting problem on an Audi e-tron and I'm not 100% certain to condemn the onboard supply control module J519. Customer drove the car and suddenly there was a lighting warning and other cars started flashing at him. He had no front lights. Also the wipers didn't work around that time, but now there's no problem with the wipers.
After some research I found that the J519 module had some water ingress (plenum drains were clogged, but surrounding of J519 seems dry), so this increases the chances of hardware failure of the module, but the following makes me doubt it:
When no lights are switched on or only parking lights, the power supply to the LED headlights (code 8IY) is missing from the J519 module on terminal T73a pins 64 & 65 for the left headlight. (And probably also right headlight on connector T73b) Due to the missing power, there's no high beam when requested, no turn signal lights in the front headlights and no communication with both front headlights. BUT if low beam is on (manually or auto-switched on due to low light conditions) there is power to and communication with both front headlights! Power supply to T73a pin 66 (KL30) and ground (pin 63) are present.
According to the wiring diagrams for the 8IY code LED headlights, the power is supplied only via these two pins on T73a (left) and T73b (right) which are combined in a splice B317/B318 to a single power supply to the module, see wiring diagram. CAN communication seems normal in both cases, no signal disruption/distortion.
On the connectors of the J519 module only corrosion was found at pin 19 on T73a (middle connector), which seems to be a circuit 15 supply signal ("SIG15"). Also some signs at the bottom of this connector, but no green stuff.
My problem to condemn the module hardware is that if the hardware is at fault, I would expect no power at any time to the headlight module(s). And the problem is present for both left and right front headlights although the circuits seem to be separated within the module and connector (T73a / T73b). It feels more like a software and/or coding problem (maybe caused by voltage fluctuations due to the water ingress?), like the FRM modules in BMWs. Does anyone have any experience with both headlights failing unless low beam is on?
Any tips for further testing?
Remote (re-)programming/coding is an option, but also costs a few hundred. But it’s also a waste to throw away a good module if recoding would fix it.
I don't see any codes for short circuit protection. One of my thoughts is that there's another item in the front headlights J519 internal power circuit, which is not activated with low beam on. But when it is on, it causes a failure detection to shutdown the power supply to prevent overloading? It feels like an emergency mode, although I would expect the turn signal to work too. If low beam is switch off, there's no power from the BCM J519 to the headlights, so they're unreachable with corresponding DTCs in the gateway.
Maybe I will open up the module again and do a thorough clean again.
Thanks in advance!
Kind regards,
Geert
(The Netherlands)
Built: 18-08-2020
Hi,
Thanks in advance!
Kind regards,
Geert
(The Netherlands)
Tuesday,14,April,2026,09:05:12:50819
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4701.5
VIN: WAUZZZGE5LB039739 License Plate: X-251-BJ
Mileage: 60164km-37384mi Repair Order: 20260414
*** scan with dim light (low beam?) on => power to headlights ! ***
*** now headlights are reachable! ***
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 3C 42 44 46 51 52 5F 6D 74 75 81
82 84 8C A5 BB BC C5 C6 CE CF D6 D7 DB DC DE 8104
VIN: WAUZZZGE5LB039739 Mileage: 60164km-37384miles
84-Night Vision -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CE-Drive Motor 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623- ) Labels: Redir Fail!
Part No SW: 4KE 907 558 A HW: 4KE 907 558
Component: I99 99.9l XXX H02 0001
CVN: F1EB3FE6
Coding: 2A0A0012006E040034280000000000000000000000000000
ASAM Dataset: EV_VCU00XXX0204KE907558A 001004
ROD: EV_VCU00XXX0204KE907558A.rod
VCID: C7C0B075FF211C02CE9-8092
VINID: 9D196AAAA5D515C4800C91C3241BF3E076
Parking lock:
Subsystem 1 - Part No SW: 0MA 341 601 D HW: 0MA 341 601 B
Component: V682 ParkLock H23 0637
Serial number: 2020.02.26.000000064
Address 03: ABS Brakes (J104) Labels: 4KE-909-059-V1.clb
Part No SW: 4KE 909 059 AF HW: 4KE 909 059 N
Component: ESC H11 0242
Revision: 00000000 Serial number: 61840000003379 Dataset Number: 4KE909504AH 0003 CVN: 8163DE29
Coding: 008800BA3D970BA293570C741880D2E425BEA90000BCD0C930184B27A47D95
Shop #: WSC 08847 004 1048576
ASAM Dataset: EV_BRSContiMKC1AU516 011001
ROD: EV_BRSContiMKC1AU516_011.rod
VCID: 8B484C45A3C9B8622A1-80DE
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 KG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0691
Dataset Number: 4KE909514E 0027
Coding: 07000143C13900DD074087089CEF8068130B33100C06009709010800192316810A45090240102000000001000049181A0800800044010000000000000000000000
Shop #: WSC 00046 412 00046
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016.rod
VCID: FDAC129DED7D86D2245-80A8
Subsystem 1 - Part No SW: 4KL 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0840
Serial number: 00000002001300402492
Coding: 7DC727
Serial number: 24818486X81A955555A0
Coding: 02005E
Subsystem 3 - Part No SW: 4K1 941 501 A HW: 4K1 941 501 A
Component: E1 - LTM H09 0086
Serial number: 14S02.07.2000692831
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE125022024110561
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AE HW: 4K0 947 135 AE
Component: Dachmodul H42 0416
Serial number: B01696230
Coding: 0D0104
67686 - Databus
[MxB left high beam: faulty]
Fault Frequency: 27
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:14
average_Voltage_terminals: 14.80 V
Outside air temperature sensor-Outside air temperature on CAN: 14.50 °C
interior_temperature: 16.50 °C
Vehicle speed: 11.16 km/h
67687 - Databus
[MxB right high beam: faulty]
Fault Frequency: 27
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:14
67735 - Databus
[MxB not available]
Fault Frequency: 28
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:14
66672 - Control Module for Light Activation/Adjustment; Left
U116E 00 [00001000] - No Communications
[Left LCM: no signal/communication]
Fault Frequency: 118
Reset counter: 36
Mileage: 59583 km
Date: 2026.03.31
Time: 17:22:09
average_Voltage_terminals: 13.20 V
Outside air temperature sensor-Outside air temperature on CAN: 12.50 °C
interior_temperature: 19.50 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: OFF
Terminal activation-Terminal 15 status signal: OFF
Terminal activation-Terminal 15 via CAN: OFF
66673 - Control Module for Light Activation/Adjustment; Right
U116F 00 [00001000] - No Communications
[Right LCM: no signal/communication]
Reset counter: 36
Mileage: 59583 km
Date: 2026.03.31
Time: 17:22:09
131080 - Databus Front Lights
U1504 00 [00001000] - No Communications
[Front light CAN: no signal/communication]
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:11
average_Voltage_terminals: 15.20 V
Vehicle speed: 7.71 km/h
System run time-Engine running time: 65535 s
System run time-Terminal 15 on: 0 s
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4KE 907 561 C HW: 4K0 907 561
Component: LRR4R H04 0354
Dataset Number: 4KE909863G 0002
Coding: 7E65FF5458082C00010380200000003E4A1246494401009E01
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_VW53.rod
VCID: C3D8A465CB193022121-8096
Address 15: Airbags (J234) Labels:| 80A-959-655-V1.clb
Part No SW: 4KE 959 655 D HW: 4KE 959 655 D
Component: AirbagVW32 H42 3221
Serial number: 0031NM01EYBN Dataset Number: 4KE909602AA 0008
Coding: AACCF0C0003000009A5400FFF81D49A800C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
VCID: CFF098551751C442869-809A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2020169616400000
Coding: 03F002
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2020161063400000
Coding: 03F002
Subsystem 3 - Part No SW: ----------- HW: 480 002 006 20
Serial number: 357000000006D971084K
Subsystem 4 - Part No SW: ----------- HW: 480 002 006 20
Serial number: 358000000005BA71084J
Subsystem 5 - Part No SW: ----------- HW: 480 031 906 20
Component: SideSensor_Dr 002 0149
Serial number: 351002C08D9326711995
Subsystem 6 - Part No SW: ----------- HW: 480 031 906 20
Component: SideSensor_Pr 002 0149
Serial number: 352002C08D83A4F02F9P
Subsystem 7 - Part No SW: ----------- HW: 480 022 906 20
Component: FrontSensor_D 002 0149
Serial number: 3550001C6F487596562D
Subsystem 8 - Part No SW: ----------- HW: 480 022 906 20
Component: FrontSensor_P 002 0149
Serial number: 3560001C6F4875965309
Crash sensor high-voltage system 1:
Subsystem 9 - Part No SW: ----------- HW: 480 022 906 20
Component: HVSensor_gSat 002 0149
Serial number: I0T0001C4F48759841B7
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 10 - Part No SW: ----------- HW: 480 022 906 20
Component: SideSens_B_Df 002 0149
Serial number: I0P0001166370DB4550J
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 11 - Part No SW: ----------- HW: 480 022 906 20
Component: SideSens_B_Pf 002 0149
Serial number: I0Q0001C4F487596D537
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: F9A4068DF955BAF208D-80AC
Address 17: Instruments (J285) Labels:| 4KE-920-KOM-V1.clb-SRI2
Part No SW: 4KE 920 795 A HW: 4KE 920 795 A
Component: FHybRDWACC--- H13 0105
Coding: 850400C87C88000800A6E170B284480008000000
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: C5DCBA7DC52D0E123C5-8090
16777089 - Databus
[ACC_12 communication error can_error_timeout]
Fault Frequency: 8
Reset counter: 33
Mileage: 59607 km
Date: 2026.03.31
Time: 20:56:11
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 4K1 907 468 J HW: 4K1 907 468 C
Component: Gateway H05 0456
Serial number: 1EF02154917001 Dataset Number: 4KE909515D 0028
Coding: 02030005000100C000810000005B01329C8A0047180000000900009F00000000
GVL: F1513C088800020014CC880080004818010C0060000080010000000000000700
ASAM Dataset: EV_Gatew31xAU65x 003190
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: BC2ADF99B6E74FDA53B-80E8
Subsystem 1 - Part No SW: 4N0 951 523 G HW: 4N0 951 523 G
Component: E221__MFL H06 0010
Subsystem 2 - Part No SW: 80D 915 181 HW: 80D 915 181
Component: J367-BDMConti H03 1051
Serial number: 775552000020062301FA
Subsystem 3 - Part No SW: 4N0 419 508 A HW: 4N0 419 508
Component: J1158 KLR H46 0041
Serial number: 20161022114S00414601
131826 - Ethernet Module for Information Electronics 1
U1645 00 [00001000] - No Communication
[Timeout_Node_0xF2_zr2_DiagAdress_005F]
Reset counter: 33
Mileage: 59592 km
Date: 2026.03.31
Time: 17:49:08
8531970 - Quiescent Current
U1406 00 [00001000] - Too High
[Electric_current_Upper_Limit_Value_Exceeded]
Reset counter: 30
Mileage: 59906 km
Date: 2026.04.08
Time: 20:56:52
EM_vehicle_state: 01 40
Total static current-current total quiescent current: 62 mA
Total static current-Total time quiescent current exceeded: 1.0 H
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 20000110653013
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW53.rod
VCID: B43AF7B99EB7879A9BB-80E0
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 G HW: 4N0 907 566 A
Component: MRR_HR H14 0479
Dataset Number: 4KE909535B 0005
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001020
ROD: EV_RearRadarS1DelphAU651_AU58.rod
VCID: BA26D981BCD371EA417-80EE
Part No SW: 4M0 959 793 M HW: 4M0 959 793 J
Component: TSG FS 010 0387
Serial number: 0000413120760 Dataset Number: 4KE909872D 0023
Coding: 0017CB0050000480A001B030
ROD: EV_DCU2DriveSideMAXHCONT_AU58.rod
VCID: C8C2B349F23F137AC73-809C
Address 44: Steering Assist (J500) Labels:* 4N0-909-144-V1.clb
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Dataset Number: 4KE909852E 0005
Coding: B4000101010000
ROD: EV_EPSVWBSAU426_010.rod
VCID: B236F1A164A389AA897-80E6
Part No SW: 8W1 907 064 AH HW: 8W1 907 064 H
Component: BCM2 MLBevo 044 0542
Dataset Number: 4KE909501F 0028
Coding: 01740000002000E16309A0040C00880200004000804F06582F0400000504823F001F0100010F13
ASAM Dataset: EV_BCM2HellaAU736 017017
ROD: EV_BCM2HellaAU736_017_AU58.rod
VCID: 835864658B99F022521-80D6
Left taillight 1:
Subsystem 1 - Part No SW: 4KE 945 423 HW: 4KE 945 423
Component: T1 LH ECE HD H11 0403
Serial number: A1W70001FUK
Power rear lid opening control module:
Subsystem 2 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 38073323
Left taillight 2:
Subsystem 3 - Part No SW: 4KE 945 429 B HW: 4KE 945 429 B
Component: T2 LH ECE HD H12 0403
Serial number: A1WK0001YFH
Right taillight 1:
Subsystem 4 - Part No SW: 4KE 945 424 HW: 4KE 945 424
Component: T1 RH ECE HD H11 0403
Serial number: A1WD0001G7X
Right taillight 2:
Subsystem 5 - Part No SW: 4KE 945 430 B HW: 4KE 945 430 B
Component: T2 RH ECE HD H12 0403
Serial number: A1WL0001YFJ
65781 - Feedback; Blink Status Implausible
B1827 00 [00001000] - -
Reset counter: 34
Mileage: 59718 km
Date: 2026.04.04
Time: 14:55:45
Supply voltages-Terminal 30 power supply: 15.612 V
Supply voltages-Supply voltage Terminal 30 - 2: 15.612 V
Supply voltages-Supply voltage Terminal 30 - 3: 15.626 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 AA 94 01 E0
general_additional_freeze_frame-Vehicle speed: 4.36 km/h
Address 51: Electric Drive (J841) Labels: 0EF-907-XXX-V1.clb
Part No SW: 0EF 907 080 E HW: 0EF 907 080 E
Component: CUFZD68540AD0 H06 1002
Revision: -------- Serial number: -00119.01.20000
Coding: 01000000000000000000
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_DMCMHITACAU516 003009
ROD: EV_DMCM2HITACAU516_003.rod
VCID: B822C38982DF63FAB73-80EC
Part No SW: 4M0 959 792 M HW: 4M0 959 792 J
Component: TSG BFS 010 0387
Serial number: 0000392678586 Dataset Number: 4KE909873D 0023
Coding: 0017CB005C000480A001B030
ROD: EV_DCU2PasseSideMAXHCONT_AU58.rod
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 063 D HW: 4K0 035 063 A
Component: MU-H-LND-EU 056 2711
Dataset Number: 4KE909545C 0017
Coding: 01157601FF0A000043111101C00802302F0001E4037008008E
VCID: A41A07F92E57171A0BB-80F0
Subsystem 1 - Part No: V03 959 807 SE
Component: MIB2P_EU_Q420 0490
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4KE 919 605 L HW: 4KE 919 605 F
Component: DU AU516 Top H31 0053
Serial number: INX00120032000180513
Compact disc data bank:
Component: Gracenote2 1010
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004419000060899013
Multimedia display unit 5:
Subsystem 5 - Part No SW: 4KE 919 603 L HW: 4KE 919 603 F
Component: DU AU516 Bot H31 0053
Serial number: INX00122121900190126
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 052000242792012
3072 - Cellular Antenna
B1053 11 [00001000] - Short to Ground
[GSM/UMTS aerial - short circuit to ground]
Reset counter: 30
Mileage: 59905 km
Date: 2026.04.08
Time: 17:16:25
Voltage terminal 30: 14.6 V
3083 - GSM antenna 2
B1533 11 [00001000] - Short to Ground
Reset counter: 30
Mileage: 59905 km
Date: 2026.04.08
Time: 17:16:25
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C744-8781-2 Dataset Number: 4KE909541B 0007
Coding: 3330
VCID: CAC68941EC33E16AD17-809E
Address 74: Chassis Control (J775) Labels:* 4N0-907-777.clb
Part No SW: 4KE 907 777 AH HW: 4KE 907 777 A
Component: Fahrwerk-SG H52 2320
Serial number: 2306201516 Dataset Number: 4KE909576T 0008
Coding: 10D8586BDA4030
ASAM Dataset: EV_ChassContrContiAU651 003018
ROD: EV_ChassContrContiAU651_003.rod
VCID: 92765121C4E369AAE97-80C6
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130938411
Coding: 303030
Address 75: Telematics (J949) Labels:* Redir Fail!
Part No SW: 4K1 035 282 D HW: 4K1 035 282 B
Component: ConBox H09 0232
Serial number: 005CCA11F121154 Dataset Number: 4KE909612B 0015
Coding: 01C0E0FFC040800000
ROD: EV_ConBoxAU651_002.rod
VCID: A80213C9527FF37A273-80FC
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4KL 713 041 A HW: 4KL 713 041
Component: GSM-LL H04 0045
Serial number: 92145TG900094
ASAM Dataset: EV_GSMKLOAU516 001011
ROD: EV_GSMKLOAU516.rod
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 4KL 919 617 HW: 4KL 919 617
Component: HeadupDisplay H05 4910
Coding: 5700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001011
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 8C4A4F59A6C7BF5A23B-80D8
Address 84: Night Vision (J853) Labels:| 4KE-907-547.clb
Part No SW: 4KE 907 547 B HW: 4M0 907 547
Component: NV-ECU-Gen3 H13 0260
Serial number: 648027100202022
Coding: 100112
ASAM Dataset: EV_NightVisioG3AUTOLAU516 001002
ROD: EV_NightVisioG3AUTOLAU516.rod
VCID: C6DEBD71F82B050A35F-8092
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 A HW: 4G0 980 552
Component: NV-CAM-Gen3 H07 0007
Serial number: 639589400B2005200144
8705 - Databus
[BCM1: headlamp defective]
Fault Frequency: 52
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:16
Address 8C: HV Battery (J840) Labels: None
Part No SW: 4KE 915 233 R HW: 4KE 915 233 B
Component: BMC_MLBCBEV H15 0467
CVN: A6278093708B356FACDF4197ACDF4197ACDF4197ACDF4197ACDF4197ACDF4197
ASAM Dataset: EV_BECM0842071 001004
ROD: EV_BECM0842071_AU58.rod
VCID: CDCC825D1D5DF652F45-8098
High-Voltage Battery Switch Box:
Subsystem 1 - Part No SW: 4KE 915 253 E HW: 4KE 915 253 C
Component: BJB_MLBBEV H07 0445
Cell module control module 1:
Subsystem 2 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 2:
Subsystem 3 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 3:
Subsystem 4 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 4:
Subsystem 5 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 5:
Subsystem 6 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 6:
Subsystem 7 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 7:
Subsystem 8 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 8:
Subsystem 9 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Cell module control module 9:
Subsystem 10 - Part No SW: 4KE 915 022 B HW: 4KE 915 022
H06 0112
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* Redir Fail!
Part No SW: 4K4 907 117 HW: 4K4 907 117
Component: zFAS Var C H09 0352
Dataset Number: 4KE909466J 0022
Coding: 042184000000000000FBD60000F4640E5B9E5600000000800000000000969401009BA8000000000000000080000000000000000000000000F98040000000000000007CD80000009000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 003008
ROD: EV_ZFASAU516_003.rod
VCID: EC8A2FD986071F5A83B-80B8
9 Faults Found:
2114853 - Databus
[LWR_Soll_Fkt_SOL_FehlPos_L]
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:11
2114854 - Databus
[LWR_Soll_Fkt_SOL_FehlPos_R]
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:11
2114597 - Databus
[TIMEOUT_LED_Feh_LM_L_03]
Fault Frequency: 28
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:13
Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
Supply voltages-Terminal 30: 14.90 V
Supply voltages-Terminal 30 local: 14.80 V
2114598 - Databus
[TIMEOUT_LED_Feh_LM_R_03]
Fault Frequency: 28
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:13
2114605 - Databus
[TIMEOUT_LWR_Sta_LM_L]
Fault Frequency: 28
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:11
Supply voltages-Terminal 30 local: 15.00 V
2114606 - Databus
[TIMEOUT_LWR_Sta_LM_R]
Fault Frequency: 28
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:11
2117692 - Control unit for information electronics 1
U1054 00 [00001000] - No Communication
[Databus_Ethernet_missing_PDU]
Reset counter: 26
Mileage: 59754 km
Date: 2026.04.06
Time: 12:05:50
Ethernet signal quality: good: link available
233479 - Parking Sensor(s); Rear
B107B F0 [00001000] - Function Limitation due to External Factors
Reset counter: 30
Mileage: 59919 km
Date: 2026.04.10
Time: 16:59:46
65544 - Night Vision Assist
C12DE F0 [00001000] - Status Feedback for HMI Implausible
Fault Frequency: 56
Reset counter: 36
Mileage: 59577 km
Date: 2026.03.31
Time: 17:09:22
Profile master status night vision assistant-Nominal status: OFF
Profile master status night vision assistant-Actual status:: Malfunction
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 4M0 959 795 M HW: 4M0 959 795 J
Component: TSG HFS 010 0387
Serial number: 0000410338551 Dataset Number: 4KE909897D 0018
Coding: 0007C90000000480A000B020
ROD: EV_DCU2RearDriveMAXHCONT_AU58.rod
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS 010 0387
Serial number: 0000410336823 Dataset Number: 4KE909896D 0018
ROD: EV_DCU2RearPasseMAXHCONT_AU58.rod
Address C5: Therm. mgt. (J1024) Labels:* 5GE-907-458.clb
Part No SW: 4KE 965 429 C HW: 4KE 965 429
Component: TME-Max H08 0312
Serial number: 0222288 Dataset Number: 4KE909476C 0012
Coding: 00
ASAM Dataset: EV_ThermContrVISAU49X 002036
ROD: EV_ThermContrVISAU49X_002_AU58.rod
Subsystem 1 - Part No SW: 4M0 959 603 E HW: 4M0 959 603 E
Component: G395 pT-Sens1 H11 0010
Subsystem 2 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00102.4X.3A20370312
A/C compressor sub:
Subsystem 3 - Part No SW: 4G0 816 797 D HW: 4G0 816 797 D
Component: J842 EKK es33 H04 0016
Serial number: 00000000020030401056
A/C pressure/coolant temperature sensor 2:
Subsystem 4 - Part No SW: 4M0 959 603 E HW: 4M0 959 603 E
Component: G826 pT-Sens2 H11 0010
Expansion valve 2 for refrigerant:
Subsystem 5 - Part No SW: 4M0 816 682 E HW: 4M0 816 682 E
Component: N637 EV2_KaMi H12 0102
Serial number: 00000000000151361312
Refrigerant Shut-Off Valve 3:
Subsystem 6 - Part No SW: 4M0 816 099 HW: 4M0 816 099
Component: N641 AV3_KaMi H12 0102
Serial number: 36000000000000038890
Refrigerant Shut-Off Valve 5:
Subsystem 7 - Part No SW: 4M0 816 099 HW: 4M0 816 099
Component: N643 AV5_KaMi H12 0102
Serial number: 33000000000000038890
Radiator shutter:
Subsystem 8 - Part No SW: 95B 965 501 AA HW: 95B 965 501 AA
Component: V544KJS1 H13 0110
Serial number: 20200619060404050055
Radiator louver 2:
Subsystem 9 - Part No SW: 95B 965 501 AA HW: 95B 965 501 AA
Component: V550KJS2 H13 0110
Serial number: 20200615060404053980
Coolant valve 1:
Subsystem 10 - Part No SW: 4KE 963 375 K HW: 4KE 963 375 K
Component: N632 V1_KUEMI 010 0103
Serial number: 00000000000000777245
Coolant valve 2:
Subsystem 11 - Part No SW: 4KE 963 375 J HW: 4KE 963 375 J
Component: N633 V2_KUEMI 010 0103
Serial number: 00000000000000709903
Coolant valve 3:
Subsystem 12 - Part No SW: 4KE 963 375 H HW: 4KE 963 375 H
Component: N634 V3_KUEMI 010 0103
Serial number: 00000000000000802523
Coolant valve 4:
Subsystem 13 - Part No SW: 4KE 963 375 N HW: 4KE 963 375 N
Component: N635 V4_KUEMI 010 0103
Serial number: 00000000000000657908
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 684 J HW: 5QE 915 684 J
Component: OBC KOSTAL H24 0023
Serial number: --------------- Dataset Number: 4KE909811F 0002
Coding: 2B48844542080E000000
ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
ROD: EV_OBC2PhaseKLOMLBev14P.rod
VCID: D6FE6D31288BB58A45F-8082
Flap 1 for charging socket:
Subsystem 1 - Part No SW: 4KE 862 277 A HW: 4KE 862 277 A
Component: F496LKL1 004 0004
Serial number: 20210616030206081007
Address CE: Drive Motor 2 (J944) Labels: None
Part No SW: 0EF 907 180 F HW: 0EF 907 180 F
Component: CUBZE68540AD0 H06 1002
Revision: -------- Serial number: -00110.01.20000
ASAM Dataset: EV_DMCM2HITACAU516 003009
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H14 0479
Dataset Number: 4KE909468B 0005
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001020
ROD: EV_RearRadarS2DelphAU651_AU58.rod
Part No SW: 4K0 941 591 BC HW: 4K0 941 591 B
Component: LMS_MLBevo H11 0031
Dataset Number: 4KE909471F 0012
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: F1B43EADA125F2B2B0D-80A4
Dataset Number: 4KE909472F 0012
Address DB: Frt Corner Rdar 1 (J1089) Labels:| 4N0-907-669.clb
Part No SW: 4N0 907 669 G HW: 4N0 907 669 A
Component: MRR_VR H14 0478
Dataset Number: 4KE909482B 0006
Coding: 001000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001020
ROD: EV_FrontCorneRadarS1AU651.rod
VCID: BE2ED591A0FB5DCA7DF-80EA
Address DC: Frt Corner Rdar 2 (J1088) Labels:| 4N0-907-669.clb
Component: MRR_VL H14 0478
Dataset Number: 4KE909483B 0006
Coding: 001000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001020
ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 800000
VCID: A31804E52B591022721-80F6
Address 8104: DC/DC Converter HV (A19) Labels: None
Part No SW: 4KE 907 171 B HW: 4KE 907 171 B
Component: DCDC Wandler H10 0400
ASAM Dataset: EV_DCDCHVTDKAU516 001004
ROD: EV_DCDCHVTDKAU516.rod
VCID: BFD0A895A7F154C2769-80EA
End----------(Elapsed Time: 02:53, VBatt start/end: 14.8V/14.7V)-----------
------------------------------22 Faults Found------------------------------
Corrosion at J519 T73a pin19 - pin 19 connector clean.png909.1 KB · Views: 3 -
J519 supplies and grounds - likely used for headlights.png35.1 KB · Views: 3 -
