Amazing Forum (beginner with 12 VCDS fault codes)
Larkmanvue
Harrow, UK
Hi All,
How amazing that there are people out there willing to share their knowledge and expeience.
I brought the VCDS tester for my VW Golf Plus 1.6 fsi which i have had for 5 years full service and MOT.
Just wondering with this 12 faults if it's worth me spending what i guess will be the 1000 pounds to keep this lovely machine going?
I guess the main ones are the ABS module which I;ve read could just be a brake sensor as opposed to the actual ABS module and the crank shaft sensor.
All thoughts and opinions welcome!
Mileage: 127196 Repair Order:
Chassis Type: 1K (1K0)
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response - Intermittent
000802 - Engine Speed Sensor (G28)
P0322 - 004 - No Signal - Intermittent
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
00003 - Control Module
014 - Defective
00950 - Central Locking Motor - tailgate (V53); UNLOCK
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00099 - Rear Right Central Locking (Safe) Motor (V164)
Dr Sheldon
Windsor UK
C?ID=334979
Start by posting an Autoscan - It is essential !!
Larkmanvue
Harrow, UK
thanks Dr Sheldon
Saturday,18,April,2026,10:19:36:47253
VCDS domain=26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: WVWZZZ1KZ8W521678   License Plate: YE57ZFR
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 EP    HW: 03C 906 056 T
   Component: MED9.5.10       G00 1187
   Revision: 66H09---    Serial number: VWX7Z0G63NB7VN
   Coding: 0000075
   Shop #: WSC 01392 785 00200
   VCID: 75B0026A39CABFF2EC5-8020
   VINID: 9E69EAAAA05BA889C50811872087A328BE
                    Mileage: 203244 km
                    Time: 08:20:52
                    RPM: 1200 /min
                    Load: 18.4 %
                    Speed: 26.0 km/h
                    Temperature: 82.0 C
                    Mileage: 203445 km
                    Time: 08:26:27
                    Speed: 16.0 km/h
                    Temperature: 84.0 C
   Part No: 09G 927 750 BE
   Component: AQ 250 6F           0851
   Coding: 0000008
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0021234
   VCID: 688E5B1E7E78521A673-803C
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 7BA414521FEEE9829A1-802E
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007296639
   Coding: E48D0F2700041800470A00000F000000000859035C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 6FBC30025B968522269-803A
   Subsystem 1 - Part No: 5M0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 050707 021  0501
   Coding: 00038805
   Subsystem 2 - Part No: 1K0 955 559 AD  Labels: 1K0-955-559-AF.CLB
   Component: RLS     060607 014  1201
   Coding: 06500389
                    Fault Status: 00101100
                    Reset counter: 157
                    Mileage: 204676 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
   Component: 1K AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1CBK6D
   Coding: 0012619
   Shop #: WSC 01373 785 00200
   VCID: 3D20DA4A417A27B2E45-8068
   Subsystem 1 - Serial number: 6332MSME145D4858J
   Subsystem 2 - Serial number: 6342MSME1B584531A
   Subsystem 3 - Serial number: 6351HSME0F223106$
   Subsystem 4 - Serial number: 6361HSME0F25424AA
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.clb
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenks ulenmodul 036 0070
   Coding: 0010042
   VCID: 005E63BE76088A5ACF3-8054
Address 17: Instruments
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 110707F2001470
   Coding: 3F3F034007009003
   VCID: 2F3CF0029B16C522669-807A
   Part No SW: 1K0 920 964 A    HW: 1K0 920 964 A
   Component: IMMO            VDD 1212
   Revision: V0002000    Serial number: VWX7Z0G63NB7VN
   VCID: 2B04E412AF0EB9024A1-807E
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 34410 km
                    Time: 16:15:14
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1214
   Coding: 0000694
   Shop #: WSC 00144 210 71444
   VCID: 3928CE5A55521B92C8D-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3632C566644CF4EA25F-8062
   Coding: 819002005103087F2D04840570085FC690FCA0
   VCID: 03546CB2671E9142D21-8056
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
                    Fault Status: 00100111
                    Fault Frequency: 46
                    Reset counter: 123
                    Mileage: 196382 km
                    Time: 11:41:21
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000694
   VCID: 3A2AD1565054108AC17-806E
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No: 5M0 035 186 C
   Component: Radio GR0       033 0033
   Revision: 0003303S    Serial number: VWZ2Z2G1177449
   Coding: 0040400
   VCID: 2C06E70EAA00BE3A43B-8078
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1203
   Coding: 0000144
   VCID: 382ECB5E6E58029A373-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End----(Elapsed Time: 01:23, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------12 Faults Found------------------------------
Control Module Part Number: 03C 906 056 EP    HW: 03C 906 056 T
  Component and/or Version: MED9.5.10       G00 1187
           Software Coding: 0000075
            Work Shop Code: WSC 01392 785 00200
                    Mileage: 203244 km
                    Time: 08:20:52
                    RPM: 1200 /min
                    Load: 18.4 %
                    Speed: 26.0 km/h
                    Temperature: 82.0 C
                    Mileage: 203445 km
                    Time: 08:26:27
                    Speed: 16.0 km/h
                    Temperature: 84.0 C
                    Mileage: 203244 km
                    Time: 08:20:52
                    RPM: 1200 /min
                    Load: 18.4 %
                    Speed: 26.0 km/h
                    Temperature: 82.0 C
                    Mileage: 203445 km
                    Time: 08:26:27
                    Speed: 16.0 km/h
                    Temperature: 84.0 C
The engine needs a chain rebuild, professionally that is £1500 on its own. The ABS needs a new rear left wheel bearing and ABS pump repair kit (£670.80 for the part), a new ignition switch and a couple of door modules plus possibly a new AC compressor.
Dr Sheldon
Windsor UK
C?ID=334979
A lot of those faults are marked intermittent.
Go clear all the faults, run the car for a day and then Re Scan and Post.
Larkmanvue
Harrow, UK
Thanks for your thoughts Crasher. I have read that this could be could be as simple as old oil or a solenoid
The engine codes are highly indicative of timing chain wear with the crank and cams going out of synchronisation.
P0322 -- Engine Speed Sensor -- No Signal - Intermittent is indicative of chain wear?
With 120,000 miles on it, it's certainly possible that it needs a timing chain job, but I'd like to understand how that P0322 fault points there?
Dr Sheldon
Windsor UK
C?ID=334979
Speed: 16.0 km/h
Odd that DTC at that Rpm and Wheel Speed ?? At first I thought he had been push starting it but its an Auto !!
Maybe not. RPM comes from that sensor. So if the sensor is producing "no signal", the ECU will see RPM as 0.
Dr Sheldon
Windsor UK
C?ID=334979
Yes - I was referring to the 16 kmh road speed with Engine Rpm at 0 rpm
Road speed comes from a different source, either a dedicated vehicle speed sensor at the transmission (old school) or from the wheel speed sensors via CAN messages from the ABS. So it's entire possible to have the ECU see non-zero road speed at the same time as zero engine speed.
Dr Sheldon
Windsor UK
C?ID=334979
It is possible - It is there in the freeze frame. I just dont often see cars at 0 rpm moving at 10mph. Probably not relevant to OP and his woes. Just something I saw in the FF that made me wonder.
Larkmanvue
Harrow, UK
HI Guys thanks for this, I've decided it's worth spending a few hundred on sorting out the major issues to see if it clears the fault to get a couple of more years out of it as it's a good runner and it's always been reliable.
I've ordered a replacement ABS rear wheel sensor for fault ABS Wheel Speed Sensor Rear Left (G46) and a new Camshaft speed sensor/Solenoid for Camshaft Positioner Bank 1 Intake (P000A).
I've also ordered crankshaft position/impulse sensor for 000802 - Engine Speed Sensor (G28).
These should be arriving soon which i'll get fitted then taking DR Sheldon's advice I'll reset the fault codes and see what comes back and post next week.
In the meantime I'll hopefully find someone to rebuild the ABS controller - Brake Pressure Sensor 1 (G201).
Thanks for all your advice all your knowledge is humbling!
I take the inlet manifold off to do the BLF G28.
Larkmanvue
Harrow, UK
Hi All. Again thanks for your input.
I replaced the front parking light Camshaft Adjustment Valve 1 (N205) and cleared faults as advised by Dr Sheldon.
Planning on doing the rear ABS and Crankshaft sensor hopefully this weekend.
New vcds which has no longer shows some of the faults and I have uploaded below for any guidance
Are any of these deal breakers so you think or easy fixes?
Saturday,02,May,2026,18:43:58:47253
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
Mileage: 127303   Repair Order:
   Coding: 0000075
001384 - Cruise Control Switch (E45)
               P0568 - 008 - Implausible Signal - Intermittent
                    Temperature: 74.0°C
   Coding: 0000008
   Revision: 00H14001
   Coding: 0021234
   Coding: 00038805
   Coding: 06500389
   Coding: 0012619
   Component: Lenksäulenmodul 036 0070
   Coding: 0010042
            014 - Defective
                    Mileage: 34410 km
                    Time: 16:15:14
   Coding: 0000694
   Coding: 0000694
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:17, VBatt start/end: 12.4V/12.4V)-----------
------------------------------8 Faults Found-------------------------------
The ABS, ignition switch and instrument/immobiliser errors/no comms directly attract my attention. New ABS pump and ignition switch first.
